push了一个GPS的动态库后,设备重启后,一直在开机动画,界面出不来
不知是什么问题,又遇到此情况的,快来帮帮我,谢谢啦
为什么没有动静,好郁闷{:4_177:}
不知道你在说什么,没log信息怎么看
I/DEBUG ( 138): #00 pc 000007c2 /system/lib/libhardware.so (hw_get_module_by_class+365)
库模库初始化有问题吧,要自己分析代码了
库 …
/system/lib/libhardware.so是这个库的问题吗?
我push进去的是/system/lib/hw/gps.default.so,开机就是这样的情况。
能看出来具体是哪里的问题吗?
我push进去的是/system/lib/hw/gps.default.so,开机就 …
要自己分析GPS的代码
zhansb 发表于 2016-11-16 10:56
要自己分析GPS的代码
谢谢喽!问题已经找到啦!
const struct hw_module_t HAL_MODULE_INFO_SYM = {
.tag = HARDWARE_MODULE_TAG,
.version_major = 1,
.version_minor = 0,
.id = GPS_HARDWARE_MODULE_ID,
.name = “HZZKW GNSS Module”,
.author = “Jarod Lee”,
.methods = &gps_module_methods,
我想问问这写编两的赋值在哪里?依据什么赋值?
要自己分析GPS的代码
- Copyright (C) 2008 The Android Open Source Project
- Licensed under the Apache License, Version 2.0 (the “License”);
- you may not use this file except in compliance with the License.
- You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0 - Unless required by applicable law or agreed to in writing, software
- distributed under the License is distributed on an “AS IS” BASIS,
- WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- See the License for the specific language governing permissions and
- limitations under the License.
#include <hardware/hardware.h>
#include <cutils/properties.h>
#include <dlfcn.h>
#include <string.h>
#include <pthread.h>
#include <errno.h>
#include <limits.h>
#define LOG_TAG “HAL”
#include <utils/Log.h>
/** Base path of the hal modules */
#define HAL_LIBRARY_PATH1 “/system/lib/hw”
#define HAL_LIBRARY_PATH2 “/vendor/lib/hw”
- There are a set of variant filename for modules. The form of the filename
- is “<MODULE_ID>.variant.so” so for the led module the Dream variants
- of base “ro.product.board”, “ro.board.platform” and “ro.arch” would be:
- led.trout.so
- led.msm7k.so
- led.ARMV6.so
- led.default.so
static const char variant_keys[] = {
“ro.hardware”, / This goes first so that it can pick up a different
file on the emulator. */
“ro.product.board”,
// “ro.product.device”,
“ro.board.platform”,
“ro.arch”
static const int HAL_VARIANT_KEYS_COUNT =
(sizeof(variant_keys)/sizeof(variant_keys[0]));
Load the file defined by the variant and if successful
return the dlopen handle and the hmi.
@return 0 = success, !0 = failure.
static int load(const char *id,
const char *path,
const struct hw_module_t **pHmi)
int status;
void *handle;
struct hw_module_t *hmi;/*
- load the symbols resolving undefined symbols before
- dlopen returns. Since RTLD_GLOBAL is not or’d in with
- RTLD_NOW the external symbols will not be global
handle = dlopen(path, RTLD_NOW);
if (handle == NULL) {
char const *err_str = dlerror();
ALOGE(“load: module=%s\n%s”, path, err_str?err_str:“unknown”);
status = -EINVAL;
goto done;
/* Get the address of the struct hal_module_info. */
const char *sym = HAL_MODULE_INFO_SYM_AS_STR;
hmi = (struct hw_module_t *)dlsym(handle, sym);
if (hmi == NULL) {
ALOGE(“load: couldn’t find symbol %s”, sym);
status = -EINVAL;
goto done;
}/* Check that the id matches */
if (strcmp(id, hmi->id) != 0) {
ALOGE(“load: id=%s != hmi->id=%s”, id, hmi->id);
status = -EINVAL;
goto done;
}hmi->dso = handle;
/* success */
status = 0;done:
if (status != 0) {
hmi = NULL;
if (handle != NULL) {
dlclose(handle);
handle = NULL;
} else {
ALOGV(“loaded HAL id=%s path=%s hmi=%p handle=%p”,
id, path, *pHmi, handle);
}*pHmi = hmi;
return status;
int hw_get_module_by_class(const char *class_id, const char *inst,
const struct hw_module_t **module)
int status;
int i;
const struct hw_module_t *hmi = NULL;
char prop[PATH_MAX];
char path[PATH_MAX];
char name[PATH_MAX];
if (inst)
snprintf(name, PATH_MAX, "%s.%s", class_id, inst);
else
strlcpy(name, class_id, PATH_MAX);
* Here we rely on the fact that calling dlopen multiple times on
* the same .so will simply increment a refcount (and not load
* a new copy of the library).
* We also assume that dlopen() is thread-safe.
/* Loop through the configuration variants looking for a module */
for (i=0 ; i<HAL_VARIANT_KEYS_COUNT+1 ; i++) {
if (i < HAL_VARIANT_KEYS_COUNT) {
if (property_get(variant_keys[i], prop, NULL) == 0) {
continue;
snprintf(path, sizeof(path), "%s/%s.%s.so",
HAL_LIBRARY_PATH2, name, prop);
if (access(path, R_OK) == 0) break;
HAL_LIBRARY_PATH1, name, prop);
} else {
snprintf(path, sizeof(path), "%s/%s.default.so",
HAL_LIBRARY_PATH2, name);
HAL_LIBRARY_PATH1, name);
status = -ENOENT;
if (i < HAL_VARIANT_KEYS_COUNT+1) {
/* load the module, if this fails, we're doomed, and we should not try
* to load a different variant. */
status = load(class_id, path, module);
return status;
int hw_get_module(const char *id, const struct hw_module_t **module)
return hw_get_module_by_class(id, NULL, module);
这个是我的hardware.c的文件,还是有问题,不知道哪里的问题
