1、fireprime开发板用官网FirePrime_Android5.1_201512011705.7z固件可以正常跑起来,用kernel编译好kerenl.img,resource.ing,只要更新resource.ing,系统就跑不起来,
1.059207] This platfrom have not i2s_mclk,no need to set i2s_mclk.
[ 1.059914] rockchip-spdif 10204000.spdif: spdif ready.
[ 1.063016] audio-rk312x audio-rk312x.14: rk312x-hifi ↔ rockchip-i2s.1 mapping ok
[ 1.064154] audio-rk312x audio-rk312x.14: rk312x-voice ↔ rockchip-i2s.1 mapping ok
[ 1.064390] audio-rk312x audio-rk312x.14: ASoC: no sink widget found for Mic Bias
[ 1.064424] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Mic Jack → direct → Mic Bias
[ 1.064454] audio-rk312x audio-rk312x.14: ASoC: no source widget found for Mic Bias
[ 1.064482] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Mic Bias → direct → MICP
[ 1.064511] audio-rk312x audio-rk312x.14: ASoC: no source widget found for Mic Bias
[ 1.064539] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Mic Bias → direct → MICN
[ 1.064568] audio-rk312x audio-rk312x.14: ASoC: no sink widget found for Mic Bias
[ 1.064596] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Headset Jack → direct → Mic Bias
[ 1.064625] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTR
[ 1.064653] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTR → direct → Ext Spk
[ 1.064682] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTL
[ 1.064710] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTL → direct → Ext Spk
[ 1.064738] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTR
[ 1.064766] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTR → direct → Headphone Jack
[ 1.064795] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTL
[ 1.064823] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTL → direct → Headphone Jack
[ 1.068452] rockchip-hdmi-spdif rockchip-hdmi-spdif.13: rk-hdmi-spdif-hifi ↔ 10204000.spdif mapping ok
[ 1.069876] u32 classifier
[ 1.069902] Actions configured
[ 1.069927] Netfilter messages via NETLINK v0.30.
[ 1.070045] nf_conntrack version 0.5.0 (7360 buckets, 29440 max)
[ 1.070859] ctnetlink v0.93: registering with nfnetlink.
[ 1.070976] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.071000] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.071819] xt_time: kernel timezone is -0000
[ 1.072363] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.072730] arp_tables: (C) 2002 David S. Miller
[ 1.072835] TCP: cubic registered
[ 1.072855] Initializing XFRM netlink socket
[ 1.073504] NET: Registered protocol family 10
[ 1.074970] mip6: Mobile IPv6
[ 1.075048] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.075375] sit: IPv6 over IPv4 tunneling driver
[ 1.076283] NET: Registered protocol family 17
[ 1.076350] NET: Registered protocol family 15
[ 1.076498] Bridge firewalling registered
[ 1.076532] Ebtables v2.0 registered
[ 1.076868] Bluetooth: RFCOMM TTY layer initialized
[ 1.076938] Bluetooth: RFCOMM socket layer initialized
[ 1.076961] Bluetooth: RFCOMM ver 1.11
[ 1.076983] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.077004] Bluetooth: BNEP filters: protocol multicast
[ 1.077037] Bluetooth: BNEP socket layer initialized
[ 1.077060] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.077090] Bluetooth: HIDP socket layer initialized
[ 1.077162] l2tp_core: L2TP core driver, V2.0
[ 1.077200] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.077220] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.077502] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.077533] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 1.077556] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.077579] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 1.077603] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.077680] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 43, flags = 0.
[ 1.077748] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 2, flags = 0.
[ 1.077773] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.077826] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.077920] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.078231] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 17.
[ 1.078300] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 35.
[ 1.078346] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 42.
[ 1.078391] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 41.
[ 1.078512] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.078692] [BT_RFKILL]: ** disable irq
[ 1.078907] [BT_RFKILL]: ap6212 device registered.
[ 1.079344] rk_cam_cif(3083):rk312x-camera version: v0.1.14 Zoom by ipp
[ 1.079516] rk_cif 1010a000.cif: rk_camera_cif_iomux:could not get cif_pin_all pinstate
[ 1.080187] soc-camera-pdrv s5k4ec_back_3: Probing s5k4ec_back_3
[ 1.081378] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 1.081428] rk312x_init_suspend
[ 1.081447] rk312x_suspend_init
[ 1.081826] Registering SWP/SWPB emulation handler
[ 1.081856] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 2000000@7dc00000
[ 1.092029] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can’t get regulator(vdd_logic)!
[ 1.093042] ddrfreq: verion 1.2 20140526
[ 1.093080] ddrfreq: normal 492MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 198MHz reboot 492MHz
[ 1.093106] ddrfreq: auto-freq=0
[ 1.093125] ddrfreq: auto-freq-table[0] 240MHz
[ 1.093144] ddrfreq: auto-freq-table[1] 324MHz
[ 1.093162] ddrfreq: auto-freq-table[2] 396MHz
[ 1.093182] ddrfreq: auto-freq-table[3] 528MHz
[ 1.094484] regulator-dummy: disabling
[ 1.094756] =======================================================
[ 1.094783] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 1.094803] =======================================================
[ 1.094824] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 1.094967] dhd_module_init: in
[ 1.094995] ======== bcm_wlan_set_plat_data ========
[ 1.095016] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.095089] host_oob_irq: 163
[ 1.095108] host_oob_irq_flags=4
[ 1.095125] dhd_wifi_platform_load: Enter
[ 1.095179] pcd_pullup, is_on 0
[ 1.095196] Power-up adapter ‘DHD generic adapter’
[ 1.095270] wifi_platform_set_power = 1
[ 1.095291] ======== PULL WL_REG_ON HIGH! ========
[ 1.095311] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.095326] file system registered
[ 1.095347] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 1.095367] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 1.097432] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.097465] android_usb gadget: Number of LUNs=2
[ 1.097490] lun0: LUN: removable file: (no medium)
[ 1.097511] lun1: LUN: removable file: (no medium)
[ 1.098009] android_usb gadget: android_usb ready
[ 1.098198] sensor_init: Probe name sensors
[ 1.098244] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 1.099871] rtc_hym8563 0-0051: hctosys: invalid date/time
[ 1.110795] usbcore: registered new interface driver snd-usb-audio
[ 1.110829] ALSA device list:
[ 1.110848] #0: RK_RK312X
[ 1.110865] #1: RK-HDMI-SPDIF
[ 1.111754] Freeing unused kernel memory: 352K (c0b95000 - c0bed000)
[ 1.182341] Cam_Powerdowm
[ 1.182398] Unable to handle kernel paging request at virtual address fffffe2b
[ 3.758982] [WLAN_RFKILL]: wifi turn on power. 43
[ 3.759014] EHCI: rk_ehci_hcd_enable, disable host controller
[ 3.759041] pgd = c0004000
[ 3.759061] [fffffe2b] *pgd=7fff2821, *pte=00000000, *ppte=00000000
[ 3.759079] Internal error: Oops: 17 [#1] PREEMPT SMP ARM
[ 3.759093] Modules linked in:
[ 3.759111] CPU: 1 PID: 95 Comm: rk_camera_init Tainted: G W 3.10.0 #1
[ 3.759126] task: c583de80 ti: dab8e000 task.ti: dab8e000
[ 3.759146] PC is at regulator_set_voltage+0x8/0xe0
[ 3.759163] LR is at sensor_power_default_cb+0x90/0x270
[ 3.759181] pc : [] lr : [] psr: 200f0013
[ 3.759181] sp : dab8fd10 ip : 00000000 fp : 002ab980
[ 3.759199] r10: fffffdfb r9 : 001b7740 r8 : c5611318
[ 3.759212] r7 : 00000001 r6 : ffffffff r5 : c5611340 r4 : fffffdfb
[ 3.759226] r3 : 00000000 r2 : 001b7740 r1 : 001b7740 r0 : fffffdfb
[ 3.759240] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 3.759254] Control: 10c5387d Table: 7f44006a DAC: 00000015
[ 3.759264]
[ 3.759264] PC: 0xc02e0c00:
[ 3.759300] 0c00 e3530000 1a000002 e5962018 e3520000 0a000013 e58d3000 e1a00004 e5963018
[ 3.759332] 0c20 e1a0100d e28d2004 e58d3004 ebfffa43 e2506000 ba00000b e1a00004 e1a0100d
[ 3.759363] 0c40 e28d2004 ebffffb9 e2506000 ba000005 e1a00004 e89d0006 ebfffc14 e1a06000
[ 3.759394] 0c60 ea000000 e3e06015 e1a00005 eb15863b e1a00006 e8bd807c e92d45f7 e1a04000
[ 3.759425] 0c80 e5905030 e58d2000 e2856038 e58d1004 e1a00006 eb1586c8 e5942014 e59d3004
[ 3.759456] 0ca0 e1520003 1a000004 e5942018 e59d3000 e1520003 03a0a000 0a000022 e5953000
[ 3.759488] 0cc0 e5933014 e5932004 e3520000 1a000003 e593300c e3530000 03e0a015 0a000019
[ 3.759519] 0ce0 e1a00005 e28d1004 e1a0200d ebfffa13 e250a000 ba000013 e59d3004 e1a00005
[ 3.759529]
[ 3.759529] LR: 0xc0032870:
[ 3.759565] 2870 e1a07001 e5906004 e590b054 e58d3008 e5903018 e5909058 e5908048 e58d300c
[ 3.759596] 2890 e59f3210 e590504c e5933000 e3530002 da000007 e59f3200 e30021aa e59f01fc
[ 3.759627] 28b0 e59f11fc e58d3004 e59f31f8 e58d2000 eb1fdca5 e3550000 0a000018 e3a00000
[ 3.759658] 28d0 e1a01005 eb0ab728 e3570000 e1a0a000 0a00000b e1a01009 e1a02009 eb0ab8e1
[ 3.759689] 28f0 e1a0000a eb0ab9dc e1a05000 e1a0000a eb0aafb9 e3a0000a eb0047af ea000007
[ 3.759720] 2910 eb0ab9bf e1a0000a eb0abb1d e3500000 e1a0000a cafffff9 eb0aafaf e3a05000
[ 3.759751] 2930 e3a0a033 e59f9180 ea000002 e5993004 e59f0178 e12fff33 e25aa001 1afffffa
[ 3.759782] 2950 e3580000 0a000017 e1a01008 e1a0000a eb0ab705 e3570000 e1a08000 0a00000b
[ 3.759793]
[ 3.759793] SP: 0xdab8fc90:
[ 3.759827] fc90 c0d27fc8 c0037acc 0000001d c0d36048 00000000 0000001d c0d36048 c0037f38
[ 3.759857] fcb0 00000400 c02e0c80 200f0013 ffffffff dab8fcfc c000d598 fffffdfb 001b7740
[ 3.759887] fcd0 001b7740 00000000 fffffdfb c5611340 ffffffff 00000001 c5611318 001b7740
[ 3.759917] fcf0 fffffdfb 002ab980 00000000 dab8fd10 c00328f0 c02e0c80 200f0013 ffffffff
[ 3.759948] fd10 fffffdfb 001b7740 001b7740 dc297228 c5611340 ffffffff 00000001 c5611318
[ 3.759976] fd30 fffffdfb c00328f0 c0d27ac0 c00327e8 00000008 00000004 00000000 00000001
[ 3.760006] fd50 c0032860 dc297228 dc297000 00000000 00000467 00000000 016e3600 c00314d4
[ 3.760034] fd70 00000005 c02992dc db87c228 00000000 0000007f 00000001 00000008 dc297080
[ 3.760045]
[ 3.760045] R0: 0xfffffd7b:
[ 3.760079] fd78 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.760107] fd98 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.760133] fdb8 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.760161] fdd8 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.760188] fdf8 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.760216] fe18 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.760243] fe38 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.760270] fe58 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.760297] fe78 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.760308]
[ 3.760308] R4: 0xfffffd7b:
[ 3.760339] fd78 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.760366] fd98 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.760394] fdb8 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.760421] fdd8 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.760448] fdf8 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.760475] fe18 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.760502] fe38 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.760530] fe58 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.760557] fe78 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.760567]
[ 3.760567] R5: 0xc56112c0:
[ 3.760601] 12c0 04000000 d40f0000 00000000 03000000 04000000 f20f0000 00000000 01000000
[ 3.760631] 12e0 346b3573 00006365 03000000 05000000 f0020000 79616b6f 00000000 03000000
[ 3.760661] 1300 04000000 0d100000 00000000 03000000 0b000000 16100000 31386b72 646c5f38
[ 3.760692] 1320 0000346f 03000000 04000000 2f100000 80b92a00 03000000 0b000000 4b100000
[ 3.760722] 1340 31386b72 646c5f38 0000386f 03000000 04000000 64100000 40771b00 03000000
[ 3.760753] 1360 0c000000 80100000 76000000 1f000000 00000000 03000000 04000000 93100000
[ 3.760783] 1380 00000000 03000000 0c000000 9f100000 76000000 0b000000 01000000 03000000
[ 3.760813] 13a0 00000000 a9100000 03000000 00000000 b9100000 03000000 04000000 c5100000
[ 3.760823]
[ 3.760823] R8: 0xc5611298:
[ 3.760857] 1298 01000000 03000000 04000000 940f0000 00000000 03000000 04000000 b20f0000
[ 3.760887] 12b8 00000000 03000000 04000000 d40f0000 00000000 03000000 04000000 f20f0000
[ 3.760917] 12d8 00000000 01000000 346b3573 00006365 03000000 05000000 f0020000 79616b6f
[ 3.760946] 12f8 00000000 03000000 04000000 0d100000 00000000 03000000 0b000000 16100000
[ 3.760976] 1318 31386b72 646c5f38 0000346f 03000000 04000000 2f100000 80b92a00 03000000
[ 3.761007] 1338 0b000000 4b100000 31386b72 646c5f38 0000386f 03000000 04000000 64100000
[ 3.761037] 1358 40771b00 03000000 0c000000 80100000 76000000 1f000000 00000000 03000000
[ 3.761067] 1378 04000000 93100000 00000000 03000000 0c000000 9f100000 76000000 0b000000
[ 3.761077]
[ 3.761077] R10: 0xfffffd7b:
[ 3.761108] fd78 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.761136] fd98 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.761163] fdb8 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.761190] fdd8 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.761217] fdf8 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.761244] fe18 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.761272] fe38 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.761299] fe58 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.761326] fe78 ******** ******** ******** ******** ******** ******** ******** ********
[ 3.761339] Process rk_camera_init (pid: 95, stack limit = 0xdab8e238)
[ 3.761352] Stack: (0xdab8fd10 to 0xdab90000)
[ 3.761370] fd00: fffffdfb 001b7740 001b7740 dc297228
[ 3.761393] fd20: c5611340 ffffffff 00000001 c5611318 fffffdfb c00328f0 c0d27ac0 c00327e8
[ 3.761413] fd40: 00000008 00000004 00000000 00000001 c0032860 dc297228 dc297000 00000000
[ 3.761434] fd60: 00000467 00000000 016e3600 c00314d4 00000005 c02992dc db87c228 00000000
[ 3.761455] fd80: 0000007f 00000001 00000008 dc297080 c0d27ac0 c00317e4 dc297080 00000467
[ 3.761476] fda0: 00000001 00000467 dc297080 016e3600 c0d27ac0 dc297000 00000001 00000001
[ 3.761497] fdc0: 000004a5 c0031b74 dc297080 00000001 00000000 dc297028 dc297080 00000000
[ 3.761519] fde0: 00000000 c0de2de4 db87f000 00000000 da9c8264 c05329f8 da9c8210 dc297028
[ 3.761542] fe00: da9c8210 c0532a9c c0bf72a8 0066f000 ff0a0004 ffffffff 00000001 db87f000
[ 3.761563] fe20: c0c11db8 00000000 00000000 c0de2de4 c0c11db8 c0a4438b 00000000 c027fa94
[ 3.761585] fe40: db87f014 dab8fe54 c0a6c784 db87f000 c0c905a0 da9c8210 00000000 c0de2de4
[ 3.761607] fe60: c0c11db8 c0a4438b 00000000 c0533004 00000000 db87f000 c0c11da8 c0d27ae0
[ 3.761628] fe80: 00000000 c0547224 00000000 db87f000 0000000e c0abfafb 00000000 c0c11db8
[ 3.761649] fea0: 00000000 c0c923f4 00000000 00000000 00000000 c02ff314 c02ff300 c02fe0dc
[ 3.761670] fec0: c0c11db8 c0c923f4 c0c923f4 00000000 00000000 c02fe338 00000000 c0c11db8
[ 3.761693] fee0: c0c11dec c02fe3b0 c0c923f4 dab8fef8 c02fe350 c02fcb8c dc1c965c dc27f734
[ 3.761716] ff00: c0c923f4 c0c923f4 da9afb00 c0c308d0 00000000 c02fd93c c0a4438b c0a4438d
[ 3.761736] ff20: c0c923f4 00000000 00000000 c054457c 00000000 c02fe88c 00000000 dc05ff00
[ 3.761757] ff40: 00000000 00000000 c054457c 00000000 00000000 c05445b8 00000000 dab8ff6c
[ 3.761777] ff60: dab8ff50 c0055984 7759ebce 00000000 c8f75f76 00000000 00000000 00000000
[ 3.761800] ff80: dab8ff80 dab8ff80 00000000 00000000 dab8ff90 dab8ff90 dab8ffac dc05ff00
[ 3.761819] ffa0: c00558e4 00000000 00000000 c000da98 00000000 00000000 00000000 00000000
[ 3.761837] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 3.761857] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000 3f7ffee6 76ffde7f
[ 3.761891] [] (regulator_set_voltage+0x8/0xe0) from [] (sensor_power_default_cb+0x90/0x270)
[ 3.761917] [] (sensor_power_default_cb+0x90/0x270) from [] (rk_sensor_ioctrl+0xdc/0x2e4)
[ 3.761941] [] (rk_sensor_ioctrl+0xdc/0x2e4) from [] (rk_sensor_pwrseq+0xa0/0x230)
[ 3.761965] [] (rk_sensor_pwrseq+0xa0/0x230) from [] (rk_sensor_power+0x200/0x2dc)
[ 3.761992] [] (rk_sensor_power+0x200/0x2dc) from [] (soc_camera_power_on+0x48/0x78)
[ 3.762019] [] (soc_camera_power_on+0x48/0x78) from [] (soc_camera_probe+0x74/0x41c)
[ 3.762047] [] (soc_camera_probe+0x74/0x41c) from [] (soc_camera_host_register+0x1c0/0x220)
[ 3.762076] [] (soc_camera_host_register+0x1c0/0x220) from [] (rk_camera_probe+0x3e8/0x598)
[ 3.762104] [] (rk_camera_probe+0x3e8/0x598) from [] (platform_drv_probe+0x14/0x18)
[ 3.762131] [] (platform_drv_probe+0x14/0x18) from [] (really_probe+0xa8/0x20c)
[ 3.762156] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48)
[ 3.762180] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84)
[ 3.762204] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90)
[ 3.762227] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c)
[ 3.762252] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138)
[ 3.762279] [] (driver_register+0x9c/0x138) from [] (rk_camera_init_async+0x3c/0x5c)
[ 3.762308] [] (rk_camera_init_async+0x3c/0x5c) from [] (kthread+0xa0/0xac)
[ 3.762336] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x3c)
[ 3.762358] Code: e1a00006 e8bd807c e92d45f7 e1a04000 (e5905030)
[ 3.762436] —[ end trace f2936dcf8da18aa0 ]—
[ 4.801743] rk312x_delay_workq
[ 4.921593] rockchip_line_in enable
[ 4.925038] [on]
[ 5.010104] wifi_platform_bus_enumerate device present 1
[ 5.015336] ======== Card detection to detect SDIO card! ========
[ 5.021392] mmc2:mmc host rescan start!
[ 5.068661] type=1403 audit(5.040:2): policy loaded auid=4294967295 ses=4294967295
[ 5.160386] init: could not import file ‘/init.recovery.rk30board.rc’ from ‘/init.rc’
[ 5.175083] bat_cap: oldcap path is /sys/devices/2006c000.adc
[ 5.175599] init: invalid gid ‘trace’
[ 5.184655] bat_cap: oldcap_path no exist
[ 5.236452] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[ 5.285656] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 300000Hz, actual 297619HZ div = 63)
[ 5.295065] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 600000Hz for init[mmc2]
[ 5.344710] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 200000Hz, actual 199468HZ div = 94)
[ 5.354064] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 400000Hz for init[mmc2]
[ 5.444773] init: /dev/hw_random not found
[ 5.451963] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[ 5.459591] init: /dev/hw_random not found
[ 5.466580] SELinux: initialized (dev functionfs, type functionfs), uses genfs_contexts
[ 5.474961] android_usb: already disabled
[ 5.479482] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 5.487451] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 5.498291] rk30xxnand_ko: module license ‘’ taints kernel.
[ 5.506487] rknand_init:
[ 5.509186] FtlInit fffffffe
[ 5.512077] NandInit fail
[ 5.514748] init_nand_blk_dev:ret = ffffffff
[ 5.640967] init: Unable to open persistent property directory /data/property errno: 2
[ 5.651268] android_usb: already disabled
