编译5.1生成的kernel.img和boot.img烧入firefly-rk3288开发板中,kernel出错
你好,我按照官方开源代码和文档编译android5.1
firefly-rk3288_android5.1_git_20150910.tar 解压大小和检验值都是对的
我的开发板是firefly-rk3288
编译步骤:
Rk3288安卓5.1开发板代码编译好了。
具体编译步骤:
  1. /rk3288$ source build/envsetup.sh
  2. lunch 8 或者( lunch rk3288-userdebug)
3.进入kernel目录(/Y3/rk3288/kernel$ )
4 make firefly-rk3288_defconfig
  1. make -j8 firefly-rk3288.img
我代码没有任何改动
编译5.1的内核生成的kernel.img和boot.img烧入firefly-rk3288开发板中,
串口打印出来的是跟时钟clk和irq相关panic。
请问一下这个是什么问题?
谢谢
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-01-ge884d10 (Nov 25 2014 - 15:36:51)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
Board: Rockchipplatform Board
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 2014-11-25#2.19
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
got recovery cmd from misc.
failed to load fdt from recovery!
kernel @ 0x02000000 (0x00692268)
ramdisk @ 0x04bf0000 (0x002ab9c0)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 0480d000, end 0482ab6f … OK
[ 0.000000] Linux version 3.10.0 (jiangyuelong@yfub56.ccdomain.com)(gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #5 SMP PREEMPT Sat Nov26 11:46:59 CST 2016
[ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision1 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache,VIPT aliasing instruction cache
[ 0.000000] Machine: Rockchip RK3288 (FlattenedDevice Tree), model: rockchip,rk3288
[ 0.000000] rockchip_ion_populate_heap: Unable topopulate heap, error: -22
[ 0.000000] ion heap((null)): base(40000000)size(28000000) align(0)
[ 0.000000] ion heap((null)): base(0) size(0)align(0)
[ 0.000000] ion_reserve: (null) reserved base40000000 size 671088640
[ 0.000000] cma: CMA: reserved 16 MiB at 2e800000
[ 0.000000] Memory policy: ECC disabled, Data cachewritealloc
[ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER(0xc3524203)
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1efe000s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order,mobility grouping on. Total pages: 522768
[ 0.000000] Kernel command line: console=ttyFIQ0androidboot.hardware=rk30board androidboot.console=ttyFIQ0 board.ap_has_alsa=0init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00100000@0x00092000(system),0x00002000@0x00192000(metadata),0x00200000@0x00194000(userdata),0x00020000@0x00394000(radical_update),-@0x003B4000(user)storagemedia=emmc loader.timestamp=2014-11-25_15:36:51
[ 0.000000] PID hash table entries: 4096 (order: 2,16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072(order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536(order: 6, 262144 bytes)
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory’option if you don’t want memory cgroups
[ 0.000000] Memory: 1385752k/1385752k available,711400k reserved, 663552K highmem
[ 0.000000] vector :0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap :0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc :0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem :0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] modules :0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0b8d364 (11797 kB)
[ 0.000000] .init: 0xc0b8e000 - 0xc0be6440 ( 354 kB)
[ 0.000000] .data : 0xc0be8000 - 0xc0d79100 (1605 kB)
[ 0.000000] .bss : 0xc0d79100 -0xc0e9a6fc (1158 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3,MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCUimplementation.
[ 0.000000] RCUdyntick-idle grace-period acceleration is enabled.
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on= 0
[ 0.000000] rkclk_init_clks: cnt_rate = 31
[ 0.000000] Architected cp15 timer(s) running at24.00MHz (phys).
[ 0.000000] sched_clock: ARM arch timer >56 bitsat 24000kHz, resolution 41ns
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:15
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:11
[ 0.000000] sched_clock: 32 bits at 100 Hz,resolution 10000000ns, wraps every 4294967286ms
[ 0.306331] Calibrating delay loop (skipped), valuecalculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.306347] pid_max: default: 32768 minimum: 301
[ 0.306454] Security Framework initialized
[ 0.306471] SELinux: Initializing.
[ 0.306551] Mount-cache hash table entries: 512
[ 0.307193] Initializing cgroup subsys debug
[ 0.307207] Initializing cgroup subsys memory
[ 0.307234] Initializing cgroup subsys freezer
[ 0.307263] CPU: Testing write buffer coherency: ok
[ 0.307576] /cpus/cpu@0 missing clock-frequencyproperty
[ 0.307590] /cpus/cpu@1 missing clock-frequencyproperty
[ 0.307600] /cpus/cpu@2 missing clock-frequencyproperty
[ 0.307609] /cpus/cpu@3 missing clock-frequencyproperty
[ 0.307672] CPU0: thread -1, cpu 0, socket 5, mpidr80000500
[ 0.307722] Setting up static identity map for0xc084e4f0 - 0xc084e548
[ 0.310693] last_log: 0x2e100000 map to 0xf0004000and copy to 0xf0086000, size 0x80000 early 0x16c1 (version 3.1)
[ 0.384357] CPU1: Booted secondary processor
[ 0.384390] CPU1: thread -1, cpu 1, socket 5, mpidr80000501
[ 0.404040] CPU2: Booted secondary processor
[ 0.404063] CPU2: thread -1, cpu 2, socket 5, mpidr80000502
[ 0.423751] CPU3: Booted secondary processor
[ 0.423775] CPU3: thread -1, cpu 3, socket 5, mpidr80000503
[ 0.423876] Brought up 4 CPUs
[ 0.423904] SMP: Total of 4 processors activated(192.00 BogoMIPS).
[ 0.423913] CPU: All CPU(s) started in SVC mode.
[ 0.424640] devtmpfs: initialized
[ 0.428772] VFP support v0.3: implementor 41architecture 3 part 30 variant d rev 0
[ 0.429880] pinctrl core: initialized pinctrlsubsystem
[ 0.430132] regulator-dummy: no parameters
[ 0.444833] NET: Registered protocol family 16
[ 0.446519] DMA: preallocated 256 KiB pool foratomic coherent allocations
[ 0.446845] ion_snapshot: 0x2e290000 map to0xf0107000 and copy to 0xc0e75a0c (version 0.1)
[ 0.447076] Registered FIQ tty driver
[ 0.448321] console [ttyFIQ0] enabled
[ 0.448559] Registered fiq debugger ttyFIQ0
[ 0.449103] rockchip_get_bank_data:name=basestart=0xff750000,end=0xff7500ff
[ 0.449127] rockchip_get_bank_data:name=mux_bank0start=0xff730084,end=0xff73008f
[ 0.449147] rockchip_get_bank_data:name=pull_bank0start=0xff730064,end=0xff73006f
[ 0.449165] rockchip_get_bank_data:name=drv_bank0start=0xff730070,end=0xff73007b
[ 0.449259]rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000start=0xff780000,end=0xff7800ff
[ 0.449327]rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000start=0xff790000,end=0xff7900ff
[ 0.449397] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000start=0xff7a0000,end=0xff7a00ff
[ 0.449464]rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000start=0xff7b0000,end=0xff7b00ff
[ 0.449528]rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.449592]rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000start=0xff7d0000,end=0xff7d00ff
[ 0.449656]rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000start=0xff7e0000,end=0xff7e00ff
[ 0.449721] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000start=0xff7f0000,end=0xff7f00ff
[ 0.449793]rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000start=0xff7f2000,end=0xff7f20ff
[ 0.449859]rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.449875] rockchip_pinctrl_probe:name=basestart=0xff770000,end=0xff77013f
[ 0.449889] rockchip_pinctrl_probe:name=pullstart=0xff770140,end=0xff7701bf
[ 0.449903] rockchip_pinctrl_probe:name=drvstart=0xff7701c0,end=0xff77023f
[ 0.450545] rockchip_interrupts_register:bank_num=7
[ 0.452467] rockchip_pinctrl_probe:init ok
[ 0.453699] ------------[ cut here ]------------
[ 0.453729] WARNING: at drivers/clk/clk.c:839clk_disable+0x18/0x24()
[ 0.453741] Modules linked in:
[ 0.453758] CPU: 0 PID: 1 Comm: swapper/0 Nottainted 3.10.0 #5
[ 0.453795] from [] (show_stack+0x10/0x14)
[ 0.453820] from [] (warn_slowpath_common+0x4c/0x68)
[ 0.453843] from
[ 0.453864] from [] (clk_disable+0x18/0x24)
[ 0.453893] from [] (amba_device_add+0xfc/0x1cc)
[ 0.453920] from
[ 0.453943] from
[ 0.453964] from
[ 0.453986] from [] (of_platform_populate+0x5c/0x88)
[ 0.454011] from
[ 0.454034] from
[ 0.454055] from [] (do_initcalls+0x70/0xa0)
[ 0.454074] from
[ 0.454098] from
[ 0.454123] from [] (ret_from_fork+0x14/0x3c)
[ 0.454161] —[ end trace 1b75b31a2719ed1c ]—
[ 0.454182] Unable to handle kernel NULL pointerdereference at virtual address 00000032
[ 1.303731] pgd = c0004000
[ 1.306392] [00000032] *pgd=00000000
[ 1.309921] Internal error: Oops: 5 [#1] PREEMPT SMPARM
[ 1.315141] Modules linked in:
[ 1.318155] CPU: 0 PID: 1 Comm: swapper/0 Tainted:G W 3.10.0 #5
[ 1.324912] task: ee090000 ti: ee072000 task.ti:ee072000
[ 1.330221] PC is at __clk_unprepare+0x10/0x78
[ 1.334588] LR is at clk_unprepare+0x14/0x1c
[ 1.338787] pc :[] lr : [] psr: a0000113
[ 1.338787] sp : ee073e28 ip : 00000000 fp : 00000000
[ 1.350058] r10: 00241330 r9 : ee2c6410 r8 : f0118000
[ 1.355193] r7 : ee2c6778 r6 : b105f00d r5 : fffffffe r4 : fffffffe
[ 1.361607] r3 : 00000000 r2 : c0e8dd58 r1 : ee073e20 r0 : fffffffe
[ 1.368023] Flags: NzCv IRQs on FIQson Mode SVC_32 ISA ARM Segment kernel
[ 1.375206] Control: 10c5387d Table:0000406a DAC: 00000015
[ 1.380852]
[ 1.380852] PC: 0xc06033e0:
[ 1.385050] 33e0 e5934030 e3540000 1a000006e59f0050 e3a01c06 e59f204c e59f304c ebe8cd7d
[ 1.393176] 3400 e1a00004 e8bd8038 e5950008e12fff34 e5953014 e3530000 e1a04000 1a000004
[ 1.401301] 3420 e5d50018 e30810d0 e1a00100ebebf2d4 e5850014 e1a00005 e1a01004 e8bd4038
[ 1.409424] 3440 eaffffba c0acf4fa c0acf630c08c1a64 e92d4010 e1a04000 e3540000 08bd8010
[ 1.417549] 3460 e5943034 e3530000 1a000003e59f0050 e30012ef e8bd4010 eae8cd49 e2433001
[ 1.425673] 3480 e5843034 e3530000 18bd8010e5943030 e3530000 0a000002 e59f0024 e30012f5
[ 1.433797] 34a0 ebe8cd3f e5943004 e5933004e3530000 0a000001 e5940008 e12fff33 e594400c
[ 1.441920] 34c0 eaffffe4 c0acf4fa e92d4010e1a04000 ebfffa36 e1a00004 ebffffdc e8bd4010
[ 1.450044]
[ 1.450044] LR: 0xc060345c:
[ 1.454243] 345c 08bd8010 e5943034 e35300001a000003 e59f0050 e30012ef e8bd4010 eae8cd49
[ 1.462366] 347c e2433001 e5843034 e353000018bd8010 e5943030 e3530000 0a000002 e59f0024
[ 1.470492] 349c e30012f5 ebe8cd3f e5943004e5933004 e3530000 0a000001 e5940008 e12fff33
[ 1.478617] 34bc e594400c eaffffe4 c0acf4fae92d4010 e1a04000 ebfffa36 e1a00004 ebffffdc
[ 1.486742] 34dc e8bd4010 eafffb37 e92d4038e2504000 01a05004 0a000015 e5943034 e3530000
[ 1.494867] 34fc 1a00000e e594000c ebfffff6e2505000 1a00000e e5943004 e5933000 e3530000
[ 1.502992] 351c 0a000006 e5940008 e12fff33e2505000 0a000002 e594000c ebffffc5 ea000003
[ 1.511118] 353c e5943034 e3a05000 e2833001e5843034 e1a00005 e8bd8038 e92d41f0 e1a04000
[ 1.519244]
[ 1.519244] SP: 0xee073da8:
[ 1.523441] 3da8 00000000 00000000 ee073fb000000000 c06021b8 00000347 c0acf4fa 00000009
[ 1.531567] 3dc8 ee2c6410 c0603460 a0000113ffffffff ee073e14 c000d598 fffffffe ee073e20
[ 1.539692] 3de8 c0e8dd58 00000000 fffffffefffffffe b105f00d ee2c6778 f0118000 ee2c6410
[ 1.547816] 3e08 00241330 00000000 00000000ee073e28 c06034dc c0603460 a0000113 ffffffff
[ 1.555941] 3e28 fffffffe c06034dc ee2c6600c02e0d3c 00000000 c1ed9958 ee2c6600 00000000
[ 1.564065] 3e48 c1ed99a8 ee2c6410 00000000c05f4054 ee2c6410 c1ed9958 00000001 00000000
[ 1.572189] 3e68 00000001 c08c08ac 00000000c05f435c c08c09b0 c08c09b0 c481c8c4 c05f1ab8
[ 1.580312] 3e88 c1ed97b8 0000000d c08c097000000001 c1ed97b8 c05f1b80 c0e75868 c1ed97b8
[ 1.588437]
[ 1.588437] R1: 0xee073da0:
[ 1.592636] 3da0 c082c860 00003db4 0000000000000000 ee073fb0 00000000 c06021b8 00000347
[ 1.600760] 3dc0 c0acf4fa 00000009 ee2c6410c0603460 a0000113 ffffffff ee073e14 c000d598
[ 1.608885] 3de0 fffffffe ee073e20 c0e8dd5800000000 fffffffe fffffffe b105f00d ee2c6778
[ 1.617010] 3e00 f0118000 ee2c6410 0024133000000000 00000000 ee073e28 c06034dc c0603460
[ 1.625135] 3e20 a0000113 ffffffff fffffffec06034dc ee2c6600 c02e0d3c 00000000 c1ed9958
[ 1.633258] 3e40 ee2c6600 00000000 c1ed99a8ee2c6410 00000000 c05f4054 ee2c6410 c1ed9958
[ 1.641382] 3e60 00000001 00000000 00000001c08c08ac 00000000 c05f435c c08c09b0 c08c09b0
[ 1.649507] 3e80 c481c8c4 c05f1ab8 c1ed97b80000000d c08c0970 00000001 c1ed97b8 c05f1b80
[ 1.657632]
[ 1.657632] R2: 0xc0e8dcd8:
[ 1.661830] dcd8 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 1.669953] dcf8 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 1.678074] dd18 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 1.686196] dd38 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 1.694318] dd58 00000000 ee025d3c ee09000000000001 005e005e 00000000 00000000 00000000
[ 1.702441] dd78 00000000 ee02573c 0000000000410041 fed00000 fed10000 00000000 c1ebb0e4
[ 1.710563] dd98 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 1.718686] ddb8 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 1.726809]
[ 1.726809] R7: 0xee2c66f8:
[ 1.731007] 66f8 00000000 00000000 ffff8adf00000000 00000000 00000000 00000000 ee2c6798
[ 1.739131] 6718 ffffffff ffffffff 00000000ee2c6724 ee2c6724 00000000 00000000 00000000
[ 1.747255] 6738 00000000 c1ed9958 0000000000000000 00000000 ee2c674c ee2c674c 00000000
[ 1.755379] 6758 00000000 00000000 0000000000000000 00000000 c02e0b14 00000000 00000000
[ 1.763502] 6778 ffb20000 ffb23fff c1ed99b000000200 c0c0c4e8 00000000 00000000 fffffffe
[ 1.771626] 6798 ffffffff ffffffff 0000000000000020 00000021 00000000 00000000 00000000
[ 1.779749] 67b8 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 1.787871] 67d8 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 1.795995]
[ 1.795995] R8: 0xf0117f80:
[ 1.800193] 7f80 ******** ******** **************** ******** ******** ******** ********
[ 1.808320] 7fa0 ******** ******** **************** ******** ******** ******** ********
[ 1.816446] 7fc0 ******** ******** **************** ******** ******** ******** ********
[ 1.824569] 7fe0 ******** ******** **************** ******** ******** ******** ********
[ 1.832696] 8000 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 1.840819] 8020 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 1.848943] 8040 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 1.857066] 8060 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 1.865191]
[ 1.865191] R9: 0xee2c6390:
[ 1.869390] 6390 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 1.877512] 63b0 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 1.885634] 63d0 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 1.893757] 63f0 00000000 00000000 0000000000000000 ee1b6440 ffffffff 00000000 00000000
[ 1.901880] 6410 00000000 ee1ddd00 ee1b6440ee070880 ee2c621c ee07088c ee070880 c0caa818
[ 1.910004] 6430 ee1b64c0 00000002 0000000700000000 00000000 00000001 00000000 ee2c644c
[ 1.918128] 6450 ee2c644c 00000000 00000000c0caa978 00000000 00000000 00000000 00000020
[ 1.926250] 6470 00010001 c0caaf40 ee2c62747fffffff 00010001 ee2c6484 ee2c6484 00000000
[ 1.934377] Process swapper/0 (pid: 1, stack limit =0xee072238)
[ 1.940279] Stack: (0xee073e28 to 0xee074000)
[ 1.944565]3e20: fffffffe c06034dc ee2c6600 c02e0d3c 00000000 c1ed9958
[ 1.952604] 3e40: ee2c6600 00000000 c1ed99a8ee2c6410 00000000 c05f4054 ee2c6410 c1ed9958
[ 1.960642] 3e60: 00000001 00000000 00000001c08c08ac 00000000 c05f435c c08c09b0 c08c09b0
[ 1.968681] 3e80: c481c8c4 c05f1ab8 c1ed97b80000000d c08c0970 00000001 c1ed97b8 c05f1b80
[ 1.976720] 3ea0: c0e75868 c1ed97b8 c1ed995800000000 00000001 c08c08ac c08c0970 ee2c6410
[ 1.984758] 3ec0: 00000000 c05f43b8 00000001ee005800 00000002 c0304bdc ee005810 ee005800
[ 1.992795] 3ee0: 00000002 00000038 00000002c0309748 00000000 c1ed97b8 c1ea415c 00000000
[ 2.000834] 3f00: 00000000 c08c08ac c0be20dc 0000000100000000 c05f4460 00000001 c08c08ac
[ 2.008872] 3f20: 00000000 00000003 c0b90a24ee072000 00000000 c0d7a000 c0b8e5f0 c0b90a54
[ 2.016910] 3f40: 00000000 c00086a4 c0b90a2400000000 00000003 c0bdbaec c0bdbacc c0d7a000
[ 2.024949] 3f60: 000001fc c0b8eb28 0000000300000003 c0b8e5f0 00000000 c0be1ffc c0be1ffc
[ 2.032986] 3f80: 00000000 00000000 0000000000000000 00000000 c0b8ebe8 ee072000 00000000
[ 2.041024] 3fa0: c082c858 c082c860 00000000c000da98 00000000 00000000 00000000 00000000
[ 2.049061] 3fc0: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.057099] 3fe0: 00000000 00000000 0000000000000000 00000013 00000000 ffffffff ffffffff
[ 2.065142] from [] (clk_unprepare+0x14/0x1c)
[ 2.073781] from [] (amba_device_add+0x104/0x1cc)
[ 2.082592] from
[ 2.092253] from
[ 2.102427] from
[ 2.112685] [] (of_platform_bus_create+0x134/0x180)from [] (of_platform_populate+0x5c/0x88)
[ 2.122689] from
[ 2.132095] from
[ 2.141073] from [] (do_initcalls+0x70/0xa0)
[ 2.149626] from
[ 2.158690] from
[ 2.167585] from [] (ret_from_fork+0x14/0x3c)
[ 2.175795] Code: e92d4010 e1a04000 e354000008bd8010 (e5943034)
[ 2.181795] —[ end trace 1b75b31a2719ed1d ]—
[ 2.186364] Kernel panic - not syncing: Attempted tokill init! exitcode=0x0000000b
[ 2.186364]
[ 2.195345] CPU3: stopping
[ 2.198012] CPU: 3 PID: 0 Comm: swapper/3 Tainted:G D W 3.10.0 #5
[ 2.204780] from [] (show_stack+0x10/0x14)
[ 2.213163] from [] (handle_IPI+0x154/0x2c8)
[ 2.221289] from [] (gic_handle_irq+0x54/0x5c)
[ 2.229756] from [] (__irq_svc+0x40/0x70)
[ 2.237961] Exception stack(0xee0c1f80 to0xee0c1fc8)
[ 2.242930] 1f80: ffffffed 00000000 0133600000000000 ee0c0000 ee0c0000 10c0387d c0852ee0
[ 2.250969] 1fa0: 0000406a 410fc0d1 0000000000000000 c0bf046c ee0c1fc8 c000e774 c000e778
[ 2.259004] 1fc0: 60000113 ffffffff
[ 2.262440] [] (__irq_svc+0x40/0x70)from [] (arch_cpu_idle+0x30/0x38)
[ 2.270569] from [] (cpu_idle_loop+0x1b8/0x224)
[ 2.279209] from
[ 2.288183] CPU2: stopping
[ 2.290849] CPU: 2 PID: 0 Comm: swapper/2 Tainted:G D W 3.10.0 #5
[ 2.297616] from [] (show_stack+0x10/0x14)
[ 2.305999] from [] (handle_IPI+0x154/0x2c8)
[ 2.314125] from [] (gic_handle_irq+0x54/0x5c)
[ 2.322592] from [] (__irq_svc+0x40/0x70)
[ 2.330798] Exception stack(0xee0bff80 to0xee0bffc8)
[ 2.335767] ff80: ffffffed 00000000 0132d00000000000 ee0be000 ee0be000 10c0387d c0852ee0
[ 2.343806] ffa0: 0000406a 410fc0d1 0000000000000000 c0bf046c ee0bffc8 c000e774 c000e778
[ 2.351841] ffc0: 60000113 ffffffff
[ 2.355277] [] (__irq_svc+0x40/0x70)from [] (arch_cpu_idle+0x30/0x38)
[ 2.363404] from [] (cpu_idle_loop+0x1b8/0x224)
[ 2.372042] from
[ 2.381016] CPU1: stopping
[ 2.383683] CPU: 1 PID: 0 Comm: swapper/1 Tainted:G D W 3.10.0 #5
[ 2.390450] from [] (show_stack+0x10/0x14)
[ 2.398833] from [] (handle_IPI+0x154/0x2c8)
[ 2.406959] from [] (gic_handle_irq+0x54/0x5c)
[ 2.415425] from [] (__irq_svc+0x40/0x70)
[ 2.423630] Exception stack(0xee0bdf80 to0xee0bdfc8)
[ 2.428599] df80: ffffffed 00000000 0132400000000000 ee0bc000 ee0bc000 10c0387d c0852ee0
[ 2.436638] dfa0: 0000406a 410fc0d1 0000000000000000 c0bf046c ee0bdfc8 c000e774 c000e778
[ 2.444672] dfc0: 60000113 ffffffff
[ 2.448109] [] (__irq_svc+0x40/0x70)from [] (arch_cpu_idle+0x30/0x38)
[ 2.456235] from [] (cpu_idle_loop+0x1b8/0x224)
[ 2.464865] [] (cpu_idle_loop+0x1b8/0x224)from [] (freezing_slow_path+0x0/0x80)
[ 2.473840] CRU:
[ 2.475658] 00000000: 00000001 9fff0041 0fff002100000008 00000005 9fff0031 0fff0018 00000008
[ 2.484040] 00000020: 00000103 9fff007f 0fff004000000008 00000107 9fff00c5 0fff0063 00000008
[ 2.492422] 00000040: 00000b00 9fff0270 0fff013800000008 00005111 00000000 00000000 00000000
[ 2.500803] 00000060: 00004031 0000b100 0000002000000200 00008300 00008200 00008386 0bb8ea60
[ 2.509185] 00000080: 0bb8ea60 0bb8ea60 0000a1000000277d 00004380 00008a00 00000200 00000200
[ 2.517566] 000000a0: 00000200 0bb8ea60 0bb8ea600bb8ea60 0bb8ea60 00000900 00000900 001f05dc
[ 2.525947] 000000c0: 00001703 00000707 00000e4000000700 00000286 00000742 00004040 00000101
[ 2.534328] 000000e0: 00004040 00000202 000080c600008f8f 00000000 00000631 00001ee5 00008307
[ 2.542708] 00000100: 00001200 0bb8ea60 0000404000000000 00000000 00000000 00000000 00000000
[ 2.551089] 00000120: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.559470] 00000140: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.567850] 00000160: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.576229] 00000180: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.584609] 000001a0: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.592989] 000001c0: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.601370] 000001e0: 00000000 00000000 0000000000640064 00000004 00000000 00000000 00000000
[ 2.609750] 00000200: 00000002 00000000 0000000200000000 00000002 00000000 00000004 00000000
[ 2.618129] 00000220: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.626509] 00000240: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.634889] 00000260: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.643269] 00000280: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.651649] 000002a0: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.660029] 000002c0: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.668409] 000002e0: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.676789] 00000300: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.685169] 00000320: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.693549] 00000340: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.701929] 00000360: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.710309] 00000380: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.718689] 000003a0: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.727068] 000003c0: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.735448] 000003e0: 00000000 00000000 0000000000000000 00000000 00000000 00000000 00000000
[ 2.743829] 00000400: 00000001 9fff0041 0fff002100000008 00000005 9fff0031 0fff0018 00000008
[ 2.752205] Rebooting in 5 seconds..
请烧完整固件,同时升级工具请用SDK附带的
您好,烧入的是整个固件的,烧入从官网下载的Firefly-RK3288_Android5.1_201611021526固件包也不能启动,是不是5.1和4.4的硬件不一样啊?
