自己编译的镜像FirePrimeS+上可以运行,FirePrime运行不来。只能用官方的img。
自己编译的系统在FirePrimeS+上可以正常运行。在FirePrime运行不起来。总是进入recovery。刷写官方的img后替换自己的kernel.img和resource.img都是可以运行的。
为什么?有没有人知道?
DDR Version 2.04 20150121
1A1A2A2B 0
1A1A2828 3
LPDDR2
27282828 F
Bus Width=32 Col=10 Bank=8 Row=14 CS=2 Die Bus-Width=32 Size=1024MB
mach:14
Boot1 Release Time: 2015-05-25, version: 2.25
ChipType = a 1374
No.1 FLASH ID:ad de 14 a7 42 4a
ECC:60
*V玨%攻氧0 20
StorageInit ok = 624099
theLC?ㄕ浇褋2014.10-RK3128-10 (Nov 28 2016 - 14:17:21)
CPU: rk3128
CPU’s clock information:
arm pll = 300000000HZ
periph pll = 594000000HZ
ddr pll = 600000000HZ
codec pll = 400000000HZ
Uboot as second level loader
DRAM: Found dram banks:1
128 MiB
rk dma黶torage init OK!
GetParam
check parameter success
power key: bank-3 pin-23
can’t find dts node for act8846
can’t find dts node for rk808
cpu_det GPIO pull up
pmic:rk818
can’t find dts node for ADC
#Boot ver: 2016-11-28#2.25
empty serial no.
checkKey
vbus = 1
use dc chg rk818_charger_setting iset1:0x79 chgiset:0x75 current 1
read logo_on switch from dts [1]
failed to find part:logo
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x62000000 (0x00697020)
ramdisk @ 0x65bf0000 (0x002d017c)
bootrk: do_bootm_linux…
Loading Device Tree to 65600000, end 6561677b … OK
Add bank:0000000060000000, 0000000040000000
[ 0.000000] Booting Linux on physical CPU 0xf00 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (lc@Dvper-Ubuntu-X64) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Mon Nov 28 09:46:07 CST 2016 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3128, model: rockchip,rk3128 [ 0.000000] rockchip_uboot_logo_setup: mem: 2000000@9dc00000, offset:0 [ 0.000000] rockchip_uboot_mem_reserve: reserve 2000000@9dc00000 for uboot logo [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(cma): base(0) size(800000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 8 MiB at 9d400000 [ 0.000000] ion_reserve: cma reserved base 9d400000 size 8388608 [ 0.000000] cma: CMA: reserved 16 MiB at 7f000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203) [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1654000 s14016 r8192 d14656 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 261120 [ 0.000000] Kernel command line: vmalloc=496M rockchip_jtag console=ttyFIQ0,115200 earlyprintk androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00006000@0x0000E000(kernel),0x00006000@0x00014000(boot),0x00010000@0x0001A000(recovery),0x00020000@0x0002A000(backup),0x00040000@0x0004A000(cache),0x001FE000@0x0008A000(userdata),0x00008000@0x00288000(metadata),0x00002000@0x00290000(kpanic),0x00200000@0x00292000(system),0x00020000@0x00492000(radical_update),-@0x004B2000(user) storagemedia=nand uboot_logo=0x02000000@0x9dc00000 loader.timestamp=2016-11-28_14:17:21 [ 0.000000] rockchip jtag enabled [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] allocated 2097152 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 1024MB = 1024MB total [ 0.000000] Memory: 962768k/962768k available, 85808k reserved, 483328K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0b95f80 (11832 kB) [ 0.000000] .init : 0xc0b96000 - 0xc0bee6c0 ( 354 kB) [ 0.000000] .data : 0xc0bf0000 - 0xc0d095f8 (1126 kB) [ 0.000000] .bss : 0xc0d095f8 - 0xc0e2a9fc (1158 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000 [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1 [ 0.000000] rkclk_init_clks: cnt_parent = 25 [ 0.000000] rkclk_init_clks: cnt_rate = 17 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 0 [ 0.000000] channel:0, lkg:23 [ 0.000000] target-temp:85 [ 0.000000] FirePrime hardware version: V00 [ 0.000000] channel:0, lkg:23 [ 0.000000] target-temp:85 [ 0.000000] channel:0, lkg:23 [ 0.000000] target-temp:85 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 0.553705] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.553732] pid_max: default: 32768 minimum: 301 [ 0.553937] Security Framework initialized [ 0.553967] SELinux: Initializing. [ 0.554104] Mount-cache hash table entries: 512 [ 0.555337] Initializing cgroup subsys debug [ 0.555366] Initializing cgroup subsys memory [ 0.555418] Initializing cgroup subsys freezer [ 0.555481] CPU: Testing write buffer coherency: ok [ 0.556039] /cpus/cpu@0 missing clock-frequency property [ 0.556067] /cpus/cpu@1 missing clock-frequency property [ 0.556087] /cpus/cpu@2 missing clock-frequency property [ 0.556105] /cpus/cpu@3 missing clock-frequency property [ 0.556181] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00 [ 0.556256] Setting up static identity map for 0xc0844fa8 - 0xc0845000 [ 0.558410] last_log: 0x7e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x17c1 (version 3.0) [ 0.631607] CPU1: Booted secondary processor [ 0.631665] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01 [ 0.651311] CPU2: Booted secondary processor [ 0.651357] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02 [ 0.671059] CPU3: Booted secondary processor [ 0.671102] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03 [ 0.671287] Brought up 4 CPUs [ 0.671339] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.671354] CPU: All CPU(s) started in SVC mode. [ 0.672799] devtmpfs: initialized [ 0.683068] pinctrl core: initialized pinctrl subsystem [ 0.683581] regulator-dummy: no parameters [ 0.685123] NET: Registered protocol family 16 [ 0.688612] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.689187] ion_snapshot: 0x7ea18000 map to 0xe0907000 and copy to 0xc0e05f04 (version 0.1) [ 0.689425] Registered FIQ tty driver [ 0.691848] console [ttyFIQ0] enabled [ 0.692264] Registered fiq debugger ttyFIQ0 [ 0.694031] rockchip_get_bank_data:name=/pinctrl@20008000/gpio0@2007c000 start=0x2007c000,end=0x2007c0ff [ 0.694171] rockchip_get_bank_data:name=/pinctrl@20008000/gpio1@20080000 start=0x20080000,end=0x200800ff [ 0.694253] rockchip_get_bank_data:name=/pinctrl@20008000/gpio2@20084000 start=0x20084000,end=0x200840ff [ 0.694329] rockchip_get_bank_data:name=/pinctrl@20008000/gpio3@20088000 start=0x20088000,end=0x200880ff [ 0.694417] rockchip_get_bank_data:name=/pinctrl@20008000/gpio15@2008A000 start=0x20086000,end=0x200860ff [ 0.694489] rockchip_pinctrl_probe:name=rk312x-GPIO,type=5 [ 0.694533] rockchip_pinctrl_probe:name=base start=0x20008000,end=0x200080a7 [ 0.694564] rockchip_pinctrl_probe:name=mux start=0x200080a8,end=0x200080f3 [ 0.694593] rockchip_pinctrl_probe:name=pull start=0x20008118,end=0x20008137 [ 0.694621] rockchip_pinctrl_probe:name=drv start=0x20008100,end=0x20008103 [ 0.697350] rockchip_pinctrl_probe:init ok [ 0.705218] rk_iommu 1010e300.vop_mmu: (vop) Enter [ 0.705275] rk_iommu 1010e300.vop_mmu: skip request vop mmu irq [ 0.705371] rk_iommu 1010e300.vop_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.705400] rk_iommu 1010e300.vop_mmu: (vop) Initialized [ 0.705671] rk_iommu 10104440.hevc_mmu: (hevc) Enter [ 0.705827] rk_iommu 10104440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.705858] rk_iommu 10104440.hevc_mmu: (hevc) Initialized [ 0.706124] rk_iommu 10106800.vpu_mmu: (vpu) Enter [ 0.706254] rk_iommu 10106800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.706284] rk_iommu 10106800.vpu_mmu: (vpu) Initialized [ 0.706549] rk_iommu 10108800.iep_mmu: (iep) Enter [ 0.706684] rk_iommu 10108800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.706715] rk_iommu 10108800.iep_mmu: (iep) Initialized [ 0.708550] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.708580] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.708873] DDR DEBUG: version 1.02 20140828 [ 0.708898] DDR DEBUG: DRAM Type:LPDDR2 [ 0.708924] DDR DEBUG: 2 CS, ROW=14, Bank=8, COL=10, Total Capability=1024MB [ 0.708972] DDR DEBUG: init success!!! freq=300MHz [ 0.762604] bio: create slab at 0 [ 0.763683] Rockchip hdmi driver version 2.0 . [ 0.765550] SCSI subsystem initialized [ 0.765931] usbcore: registered new interface driver usbfs [ 0.766036] usbcore: registered new interface driver hub [ 0.766250] usbcore: registered new device driver usb [ 0.768483] rockchip_i2c 20072000.i2c: i2c-0: Rockchip I2C adapter [ 0.770788] media: Linux media interface: v0.10 [ 0.770880] Linux video capture interface: v2.00 [ 0.771098] pps_core: LinuxPPS API ver. 1 registered [ 0.771122] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.771171] PTP clock support registered [ 0.771268] i2c-core: driver [bq24296] using legacy suspend method [ 0.771291] i2c-core: driver [bq24296] using legacy resume method [ 0.772690] Rockchip ion module is successfully loaded (v1.1) [ 0.772957] Advanced Linux Sound Architecture Driver Initialized. [ 0.773731] Bluetooth: Core ver 2.16 [ 0.773811] NET: Registered protocol family 31 [ 0.773834] Bluetooth: HCI device and connection manager initialized [ 0.773868] Bluetooth: HCI socket layer initialized [ 0.773897] Bluetooth: L2CAP socket layer initialized [ 0.773951] Bluetooth: SCO socket layer initialized [ 0.774383] cfg80211: Calling CRDA to update world regulatory domain [ 0.776075] act8931_i2c_probe,line=715 [ 0.776882] The device is not act8931 [ 0.777559] rk818_i2c_probe,line=1286 [ 0.777868] rk818_pre_init,line=1201 [ 0.78?睉}澚ソ乽p [ 0.785625] rk818_i2c_probe: rk818_pmic_sleep=0 [ 0.789562] vdd_arm: 712 <--> 1500 mV at 1100 mV [ 0.793914] vdd_logic: 712 <--> 1500 mV at 1100 mV [ 0.797752] rk818_dcdc3: 1200 mV [ 0.802062] vccio: 1800 <--> 3300 mV at 3000 mV [ 0.805950] rk818_ldo1: 3300 mV [ 0.809798] rk818_ldo2: 3000 mV [ 0.813647] rk818_ldo3: 1100 mV [ 0.817439] rk818_ldo4: 2800 mV [ 0.821344] rk818_ldo5: 3000 mV [ 0.825167] rk818_ldo6: 1200 mV [ 0.829049] rk818_ldo7: 1800 mV [ 0.832902] rk818_ldo8: 1800 mV [ 0.835771] vcc_sd: 1800 <--> 3000 mV at 3000 mV [ 0.837253] rk818_ldo10: at 3000 mV [ 0.839055] rk818_irq_init: rk818_pmic_irq=1 [ 0.839723] fireprime_rk818_hdmi_5v_en enable:1 [ 0.840559] i2c-core: driver [rk818] using legacy suspend method [ 0.840586] i2c-core: driver [rk818] using legacy resume method [ 0.842798] Switching to clocksource arch_sys_counter [ 0.865398] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 0.879922] fb disp policy is box [ 0.880041] rk-fb rockchip-fb: rk fb ion client create success! [ 0.880069] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 0.880561] rk-screen rk_screen.9: rockchip screen probe success [ 0.881149] rk31xx-lvds 20038000.lvds: screen is not lvds/rgb! [ 0.881194] rk31xx-lvds: probe of 20038000.lvds failed with error -22 [ 0.882384] rk312x-lcdc lcdc0: can't find power_ctr node for lcdc0 [ 0.882414] rk_fb_trsm_ops_get:un supported transmitter:6! [ 0.882980] graphics fb0: rockchip framebuffer registerd:fb0 [ 0.883754] graphics fb1: rockchip framebuffer registerd:fb1 [ 0.884164] graphics fb2: rockchip framebuffer registerd:fb2 [ 0.884800] rk312x-lcdc lcdc0: set lcdc0 dclk failed [ 0.884835] rk312x-lcdc lcdc0: lcdc0: dclk:74250000>>fps:60 [ 0.884862] rk312x-lcdc lcdc0: wakeup from standby! [ 0.903155] alloc_buffer:ion_phy_addr=0x10000000 [ 0.908479] fb0:phy:10000000>>vir:e0930000>>len:0xb00000 [ 0.921560] rk312x-lcdc lcdc0: lcdc0 probe ok, iommu enabled [ 0.924909] NET: Registered protocol family 2 [ 0.925821] TCP established hash table entries: 4096 (order: 3, 32768 bytes) [ 0.925957] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 0.926071] TCP: Hash tables configured (established 4096 bind 4096) [ 0.926178] TCP: reno registered [ 0.926207] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.926256] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.926638] NET: Registered protocol family 1 [ 0.928761] rk818-battery rk818-battery: invalid fcc(0x0), use design capacity [ 0.929624] rk818-battery rk818-battery: update fcc : 2100 [ 0.929914] rk818-battery rk818-battery: not battery, enter test power mode [ 0.951338] rk818-battery rk818-battery: v=4200, ov=4200, rv=0, c=0, pwroff_min=0 [ 0.957471] rk818-battery rk818-battery: c=0, v=4200, relax=0, ocv=4200, est=4200, calib=-1 [ 0.958229] rk818-battery rk818-battery: reg soc=0, init soc = 0, init cap=0 [ 0.986687] rk818-battery rk818-battery: battery driver version 4.0.0 [ 0.987457] Unpacking initramfs... [ 1.234643] Freeing initrd memory: 2880K (c5bf0000 - c5ec0000) [ 1.236249] hw perfevents: enabled with ARMv7_Cortex_A7 PMU driver, 5 counters available [ 1.237049] vcodec_service: probe device vpu_combo.10 [ 1.237086] vcodec_service: No reset resource define [ 1.237105] vcodec_service: No reset resource define [ 1.237123] vcodec_service: No reset resource define [ 1.237251] vcodec vpu_combo.10: failed on clk_get clk_cabac [ 1.237362] vcodec_service: vpu_combo.10: power on [ 1.237519] vcodec_service: probe device 10106000.vpu_service [ 1.237581] vcodec_service: checking hw id 4831 [ 1.238951] vcodec_service: probe device 10104000.hevc_service [ 1.239015] vcodec_service: checking hw id 6867 [ 1.239967] vcodec_service: vpu_combo.10: power off... [ 1.240039] vcodec_service: done [ 1.240059] vcodec_service: init success [ 1.240224] rknandbase v1.0 2014-03-31 [ 1.240498] rknand_probe clk rate = 148500000 [ 1.240688] rknand_driver:ret = 0 [ 1.241373] rk_dts_sensor_probe:Get s5k4ec rockchip,power failed! [ 1.241415] s5k4ec_io==1 [ 1.241467] the gpiorst1 is 107 [ 1.241498] the gpiorst2 is 107 [ 1.241556] rk_dts_sensor_probe:Get ov2659 rockchip,power failed! [ 1.241587] s5k4ec_io==2 [ 1.241624] rk_dts_sensor_probe:Get gc0329 rockchip,power failed! [ 1.241653] s5k4ec_io==2 [ 1.241688] rk_dts_sensor_probe:Get gc2035 rockchip,powerdown failed! [ 1.241718] s5k4ec_io==2 [ 1.241760] s5k4ec_io==2 [ 1.243294] audit: initializing netlink socket (disabled) [ 1.243381] type=2000 audit(0.690:1): initialized [ 1.244753] bounce pool size: 64 pages [ 1.255288] fuse init (API version 7.22) [ 1.256228] msgmni has been set to 974 [ 1.259942] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 1.259978] io scheduler noop registered [ 1.259999] io scheduler deadline registered [ 1.260217] io scheduler cfq registered (default) [ 1.265758] rga 1010c000.rga: rga ion client create success! [ 1.266124] rga: Driver loaded succesfully [ 1.266254] rga: Module initialized. [ 1.374540] rk-hdmi 20034000.hdmi: rockchip_hdmiv1_set_pwr_mode change pwr_mode 0 --> 1 [ 1.374578] rk-hdmi 20034000.hdmi: rockchip_hdmiv1_set_pwr_mode change pwr_mode LOWER_PWR [ 1.374669] rk-hdmi 20034000.hdmi: rockchip_hdmiv1_set_pwr_mode change pwr_mode 1 --> 0 [ 1.374702] rk-hdmi 20034000.hdmi: rockchip_hdmiv1_set_pwr_mode change pwr_mode NORMAL [ 1.374744] rk-hdmi 20034000.hdmi: EDID DATA (Segment = 0 Block = 0 Offset = 0): [ 1.386899] rk-hdmi 20034000.hdmi: [rockchip_hdmiv1_read_edid] edid read sucess [ 1.386982] rk-hdmi 20034000.hdmi: EDID DATA (Segment = 0 Block = 1 Offset = 128): [ 1.399153] rk-hdmi 20034000.hdmi: [rockchip_hdmiv1_read_edid] edid read sucess [ 1.399230] ******** Show Sink Info ******** [ 1.399251] Max tmds clk is 225000000 [ 1.399268] Support video mode: [ 1.399285] 1920x1080p@60Hz [ 1.399300] 1920x1080p@50Hz [ 1.399317] 1920x1080p@30Hz [ 1.399332] 1920x1080p@24Hz [ 1.399348] 1920x1080i@60Hz [ 1.399363] 1920x1080i@50Hz [ 1.399379] 1280x720p@60Hz [ 1.399394] 1280x720p@50Hz [ 1.399410] 720x576p@50Hz [ 1.399425] 720x576i@50Hz [ 1.399441] 720x480p@60Hz [ 1.399456] 720x480i@60Hz [ 1.399471] Support video color mode: [ 1.399487] RGB [ 1.399501] YCbCr422 [ 1.399516] YCbCr444 [ 1.399531] Support video color depth: [ 1.399546] 24bit [ 1.399561] 30bit [ 1.399575] 36bit [ 1.399589] Support audio type: [ 1.399605] LPCM [ 1.399621] Support max audio channel is 2 [ 1.399638] Support audio sample rate: [ 1.399654] 32000 [ 1.399668] 44100 [ 1.399682] 48000 [ 1.399697] Support audio word lenght: [ 1.399713] 16bit [ 1.399727] 20bit [ 1.399741] 24bit [ 1.399755] [ 1.399769] AC3 [ 1.399784] Support max audio channel is 2 [ 1.399800] Support audio sample rate: [ 1.399816] 32000 [ 1.399830] 44100 [ 1.399844] 48000 [ 1.399858] 96000 [ 1.399872] Support audio word lenght: [ 1.399889] 16bit [ 1.399902] 20bit [zd t1.whe944]n l***i*g foo lScnltInfo *******s : 1on9r9lling tty: opet corlor mode is ch device or addressd __bionic_open_tzdata: couldn't find any tzdata whe0.hdmi: [rockchip! /sbin/sh: warning: won't have fullut_color=3 1. _0081] rk-hdmi 2d034000.hdmi: [rond any tzdata when looking for posioutput HDMIta [ 1.400558 (pid 110)2on Sa00.hdmi: hdmi pro 2 su read cmdline 6[ 1.4ip_jtag conson client create success! [ k 1.402110] IEPsPower OFF [ 1.402147] IEP Drimissive androidbofully [ 1.402oard androidboot.conzed. [ 1.4nit=/init mtdparts=rk29xxnand:0x0ckchip,rk312x-tve (parameter),0x00 ok [ 1.405541] dma-pl330 [email]20070@00.pdma[/email]:0Loaded),0x00008000@0x00 DMAC-2364208 [ 0x00006000@0x0000El030 20078000.pdma: DBUFF-64x8bytes Num_Chans-8 Num_Per1i-16 Num_Every),0x00020000@0x6471] rk_serial., v1.8 2014-03-044A0 1.406804] 10060000.serial: ttyS0 at MMIO 0x20060000 (irq = 52etadata),0x00002000@0x00290000(kpa1ic)erial 20060000.serial: membase,e3452000 [ 1921302ra ioal: pdoaule l@axed [ (1.413859] i2c-cora=ndriver [mpu60o=0102u0i000legacy0 suspend method [ 1.413884] _1c:1o:e: driverootmude 0 un nswng egacy resuvermethod u 0 /mnt/interna14263] ak8963_modock/rknand_user 0 1 /mnt/external_sd vfat /dev/bldia Changer drive v0.25 [ 1 416214] tun: Universal TUN T 3 /cache ext4 /, 1.6 [ 1.41_cache 0n (C) 1999-2004 Mt4 /dasnyansky <[email]maxk@qualcomm.com[/email] [ 1.416547] vmacoinit. [ serdata 0] 6 /cust ext4 /dig_dt: Can not rcust 0op 7 /custom ext4tor. [ 1.417708] stmmac_p be_config_dt: Cte ext4 /dev/blocrty: pmu_enable_level. [ 9 /misc mtd miac 0r 10 /uboot mtd oboot 0u or output? (induthar 1.417756] stmmactd resource 0 e 0 13 /parameter mtd parameter 0 ] stmmac_probe_config 15 /recovery m). [ 1.417 78] stmmac_probe config_d 17 /tmp ramdis12x-gmac [ 1./17898] stmmc_plble/recovery/recovery.cp1; [Line]_p: 1r_init: ERROR:SetSdcardRootPath; InternalSD_ROO18013] stmmc_pltfsdinI/ [File] : bootable[ 1.418038overy.cpp; [Line] : 1.418038] rx delay=0x10 [ 1 E18273] stmmacT: /mnt/external_sdynopsysfailed to create .418h95] Normalile exists!
[E:failed to mount /cache /dev/blo
[ 1.418329] No such file or d register
u/ported
:[ 1ble/recovery/roocksum Offload Eng138; [Func] : enspe 2)
[ 1.418 failed to mount /cache /dev/blockted
[ c 1.41838 such file or dirn suppo
delay 1sec
18490] Enable RX Mitigation via HW Watchdog Timer
[ 1.419356] PPP generic driver version 2.4.2
[ 1.419734] PPP BSD Compression module registered
[ 1.419762] PPP Deflate Compression module registered
[ 1.419799] PPP MPPE Compression module registered
[ 1.419822] NET: Registered protocol family 24
[ 1.419880] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.419905] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.419927] Rockchip WiFi SYS interface (V1.00) …
[ 1.419999] esp_mem_init enter date Nov 28 2016 09:45:38
[ 1.420020] esp_mem_init VERSION [V2.5]
[ 1.420103] esp_mem_init complete
[ 1.420231] usbcore: registered new interface driver catc
[ 1.420315] usbcore: registered new interface driver kaweth
[ 1.420339] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.420420] usbcore: registered new interface driver pegasus
[ 1.420499] usbcore: registered new interface driver rtl8150
[ 1.420606] usbcore: registered new interface driver r8152
[ 1.420629] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.420771] usbcore: registered new interface driver hso
[ 1.420867] usbcore: registered new interface driver asix
[ 1.420949] usbcore: registered new interface driver ax88179_178a
[ 1.421030] usbcore: registered new interface driver cdc_ether
[ 1.421110] usbcore: registered new interface driver cdc_eem
[ 1.421200] usbcore: registered new interface driver dm9601
[ 1.421281] usbcore: registered new interface driver dm9620
[ 1.421380] usbcore: registered new interface driver smsc75xx
[ 1.421486] usbcore: registered new interface driver smsc95xx
[ 1.421569] usbcore: registered new interface driver gl620a
[ 1.421649] usbcore: registered new interface driver net1080
[ 1.421739] usbcore: registered new interface driver plusb
[ 1.421822] usbcore: registered new interface driver rndis_host
[ 1.421902] usbcore: registered new interface driver cdc_subset
[ 1.421981] usbcore: registered new interface driver zaurus
[ 1.422065] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.422193] usbcore: registered new interface driver int51x1
[ 1.422275] usbcore: registered new interface driver kalmia
[ 1.422357] usbcore: registered new interface driver ipheth
[ 1.422457] usbcore: registered new interface driver sierra_net
[ 1.422541] usbcore: registered new interface driver cx82310_eth
[ 1.422642] usbcore: registered new interface driver cdc_ncm
[ 1.422724] usbcore: registered new interface driver qmi_wwan
[ 1.422805] usbcore: registered new interface driver cdc_mbim
[ 1.422829] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.424796] EHCI: ehci_rk_probe e3480000 e3480010
[ 1.424832] rockchip_ehci_host 101c0000.usb: EHCI Host Controller
[ 1.424891] rockchip_ehci_host 101c0000.usb: new USB bus registered, assigned bus number 1
[ 1.425578] rockchip_ehci_host 101c0000.usb: irq 43, io mem 0x101c0000
[ 1.443179] rockchip_ehci_host 101c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.443328] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.443359] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.443386] usb usb1: Product: EHCI Host Controller
[ 1.443411] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 1.443435] usb usb1: SerialNumber: 101c0000.usb
[ 1.444357] hub 1-0:1.0: USB hub found
[ 1.444405] hub 1-0:1.0: 1 port detected
[ 1.444793] EHCI: ehci_rk_probe ok
[ 1.444976] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.445216] ohci-rockchip 101e0000.usb: RK OHCI Host Controller
[ 1.445272] ohci-rockchip 101e0000.usb: new USB bus registered, assigned bus number 2
[ 1.445356] ohci-rockchip 101e0000.usb: irq 64, io mem 0x101e0000
[ 1.506235] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.506270] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.506298] usb usb2: Product: RK OHCI Host Controller
[ 1.506323] usb usb2: Manufacturer: Linux 3.10.0 ohci_hcd
[ 1.506347] usb usb2: SerialNumber: 101e0000.usb
[ 1.507184] hub 2-0:1.0: USB hub found
[ 1.507243] hub 2-0:1.0: 1 port detected
[ 1.507882] usbcore: registered new interface driver cdc_acm
[ 1.507908] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.508028] usbcore: registered new interface driver usblp
[ 1.508135] usbcore: registered new interface driver cdc_wdm
[ 1.508287] usbcore: registered new interface driver usb-storage
[ 1.508371] usbcore: registered new interface driver ums-alauda
[ 1.508454] usbcore: registered new interface driver ums-cypress
[ 1.508536] usbcore: registered new interface driver ums-datafab
[ 1.508616] usbcore: registered new interface driver ums_eneub6250
[ 1.508695] usbcore: registered new interface driver ums-freecom
[ 1.508775] usbcore: registered new interface driver ums-isd200
[ 1.508867] usbcore: registered new interface driver ums-jumpshot
[ 1.508949] usbcore: registered new interface driver ums-karma
[ 1.509030] usbcore: registered new interface driver ums-onetouch
[ 1.509119] usbcore: registered new interface driver ums-sddr09
[ 1.509203] usbcore: registered new interface driver ums-sddr55
[ 1.509284] usbcore: registered new interface driver ums-usbat
[ 1.509472] usbcore: registered new interface driver usbserial
[ 1.509558] usbcore: registered new interface driver usbserial_generic
[ 1.509638] usbserial: USB Serial support registered for generic
[ 1.509727] usbcore: registered new interface driver option
[ 1.509795] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.510018] usbcore: registered new interface driver trancevibrator
[ 1.510042] usb20_otg: version 3.10a 21-DEC-2012
[ 1.510669] e3500040
[ 1.510698] Core Release: 2.91a
[ 1.510720] Setting default values for core params
[ 1.510983] Using Buffer DMA mode
[ 1.511007] Periodic Transfer Interrupt Enhancement - disabled
[ 1.511028] Multiprocessor Interrupt Enhancement - disabled
[ 1.511049] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.511068] ^^^^^^^^^^^^^^^^^Device Mode
[ 1.511094] Dedicated Tx FIFOs mode
[ 1.511130] pcd_init otg_dev = c5a25780
[ 1.511494] usb20_otg 10180000.usb: DWC OTG Controller
[ 1.511552] usb20_otg 10180000.usb: new USB bus registered, assigned bus number 3
[ 1.511612] usb20_otg 10180000.usb: irq 42, io mem 0x00000000
[ 1.511737] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.511769] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.511796] usb usb3: Product: DWC OTG Controller
[ 1.511821] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.511846] usb usb3: SerialNumber: 10180000.usb
[ 1.512811] hub 3-0:1.0: USB hub found
[ 1.512861] hub 3-0:1.0: 1 port detected
[ 1.513508] usb20_host: version 3.10a 21-DEC-2012
[ 1.514455] usbcore: registered new interface driver xpad
[ 1.514578] usbcore: registered new interface driver usb_acecad
[ 1.514679] usbcore: registered new interface driver aiptek
[ 1.514777] usbcore: registered new interface driver gtco
[ 1.514874] usbcore: registered new interface driver hanwang
[ 1.514969] usbcore: registered new interface driver kbtab
[ 1.515100] usbcore: registered new interface driver wacom
[ 1.515984] sensor_register_slave:mma8452,id=17
[ 1.516013] sensor_register_slave:gs_mc3230,id=23
[ 1.516031] gsensor_init
[ 1.516050] sensor_register_slave:mpu6880_acc,id=24
[ 1.516070] sensor_register_slave:cm3217,id=47
[ 1.516090] sensor_register_slave:cm3218,id=48
[ 1.516474] .. rk pwm remotectl v1.1 init
[ 1.516892] input: 20050030.pwm as /devices/20050030.pwm/input/input0
[ 1.523176] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 1.523260] i2c /dev entries driver
[ 1.523869] IR NEC protocol handler initialized
[ 1.523895] IR RC5(x) protocol handler initialized
[ 1.523914] IR RC6 protocol handler initialized
[ 1.523933] IR JVC protocol handler initialized
[ 1.523951] IR Sony protocol handler initialized
[ 1.523969] IR RC5 (streamzap) protocol handler initialized
[ 1.523988] IR SANYO protocol handler initialized
[ 1.524006] IR MCE Keyboard/mouse protocol handler initialized
[ 1.524477] usbcore: registered new interface driver uvcvideo
[ 1.524502] USB Video Class driver (1.1.1)
[ 1.524525] CamSys driver version: v0.27.1, CamSys head file version: v0.10.0
[ 1.524551] E:camsys_soc_init(87): camsys isn’t support soc: 0x31260001!
[ 1.526619] i2c-core: driver [bq27320] using legacy suspend method
[ 1.526649] i2c-core: driver [bq27320] using legacy resume method
[ 1.527424] device-mapper: uevent: version 1.0.3
[ 1.527954] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.528675] Bluetooth: HCI UART driver ver 2.2
[ 1.528704] Bluetooth: HCI H4 protocol initialized
[ 1.528723] Bluetooth: HCILL protocol initialized
[ 1.528743] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.19
[ 1.528764] rtk_btusb: Register usb char device interface for BT driver
[ 1.529163] usbcore: registered new interface driver rtk_btusb
[ 1.534799] cpufreq version 1.0, suspend freq 1008 MHz
[ 1.535169] cpuidle: using governor ladder
[ 1.535194] cpuidle: using governor menu
[ 1.535266] Synopsys Designware Multimedia Card Interface Driver
[ 1.535289] MHSC version = Ver 2.00 2015-06-10
[ 1.535726] dw cru_regsbase addr 0x124.
[ 1.535752] dw cru_reset_offset val 3.
[ 1.535781] dwmmc_rockchip 1021c000.rksdmmc: Version ID is 270a
[ 1.535843] dwmmc_rockchip 1021c000.rksdmmc: failed to get hpclk_mmc
[ 1.536320] dwmmc_rockchip 1021c000.rksdmmc: Using external DMA controller.
[ 1.536721] dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc0]
[ 1.537007] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.551431] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.571269] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.571307] dwmmc_rockchip 1021c000.rksdmmc: DW MMC controller at irq 48, 32 bit host data width, 256 deep fifo
[ 1.571341] dwmmc_rockchip 1021c000.rksdmmc: 1 slots initialized
[ 1.572088] dw cru_regsbase addr 0x124.
[ 1.572196] dw cru_reset_offset val 1.
[ 1.572228] dwmmc_rockchip 10214000.rksdmmc: Version ID is 270a
[ 1.572288] dwmmc_rockchip 10214000.rksdmmc: failed to get hpclk_mmc
[ 1.574908] dwmmc_rockchip 10214000.rksdmmc: Using external DMA controller.
[ 1.575239] dw_mci_init_slot: fmin=400000, fmax=37500000 [mmc1]
[ 1.575915] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.590779] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.610532] dwc_otg_hcd_suspend, usb device mode
[ 1.610564] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.610596] dwmmc_rockchip 10214000.rksdmmc: DW MMC controller at irq 46, 32 bit host data width, 256 deep fifo
[ 1.610621] dwmmc_rockchip 10214000.rksdmmc: 1 slots initialized
[ 1.611036] dw cru_regsbase addr 0x124.
[ 1.611057] dw cru_reset_offset val 2.
[ 1.611077] dwmmc_rockchip 10218000.rksdmmc: Version ID fa 27d t
[ rea1.61cac6] dirmc_r=Filhipxis218
0Erksdlec: f mled ocaet h/dlk_mlock[ an.611ch1] do mc_r fkchior10ire000ry)
mmc:Fising: xterabl DMecconty/llers.
ch ev6122ck] 13an..dwchci_so ios f no orrd. ectc2])cuninit elotrefminh_0000te fmaai3750to00 [ntc2]
d y 130c130] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.649822] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.649850] dwmmc_rockchip 10218000.rksdmmc: DW MMC controller at irq 47, 32 bit host data width, 256 deep fifo
[ 1.649867] dwmmc_rockchip 10218000.rksdmmc: 1 slots initialized
[ 1.650176] leds-gpio leds.18: pins are not configured from the driver
[ 1.650570] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.653006] usbcore: registered new interface driver usbhid
[ 1.653023] usbhid: USB HID core driver
[ 1.653587] zram: Created 1 device(s) …
[ 1.654160] ashmem: initialized
[ 1.654357] logger: created 256K log ‘log_main’
[ 1.654554] logger: created 256K log ‘log_events’
[ 1.654730] logger: created 256K log ‘log_radio’
[ 1.654893] logger: created 256K log ‘log_system’
[ 1.656438] input: rk29-keypad as /devices/2006c000.adc/key.23/input/input1
[ 1.657861] ------------[ cut here ]------------
[ 1.657884] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4()
[ 1.657896] autorequest GPIO-27
[ 1.657905] Modules linked in:
[ 1.657921] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 3.10.0 #1
[ 1.657951] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 1.657973] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
[ 1.657994] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
[ 1.658015] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4)
[ 1.658036] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_input+0x58/0x1f0)
[ 1.658060] [] (gpiod_direction_input+0x58/0x1f0) from [] (rk312x_platform_probe+0x46c/0x5a4)
[ 1.658085] [] (rk312x_platform_probe+0x46c/0x5a4) from [] (platform_drv_probe+0x14/0x18)
[ 1.658106] [] (platform_drv_probe+0x14/0x18) from [] (really_probe+0xa8/0x20c)
[ 1.658126] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48)
[ 1.658145] [] (driver_probe_device+0x30/0x48) from [] (driver_attach+0x60/0x84)
[ 1.658164] [] (driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90)
[ 1.658183] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c)
[ 1.658203] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138)
[ 1.658223] [] (driver_register+0x9c/0x138) from [] (do_one_initcall+0x34/0xc8)
[ 1.658245] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0)
[ 1.658267] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130)
[ 1.658289] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4)
[ 1.658311] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c)
[ 1.658356] —[ end trace 588714abaf94bce4 ]—
[ 1.658627] This platfrom have not i2s_mclk,no need to set i2s_mclk.
[ 1.659107] rockchip-spdif 10204000.spdif: spdif ready.
[ 1.661161] audio-rk312x audio-rk312x.14: rk312x-hifi ↔ rockchip-i2s.1 mapping ok
[ 1.661882] audio-rk312x audio-rk312x.14: rk312x-voice ↔ rockchip-i2s.1 mapping ok
[ 1.661923] audio-rk312x audio-rk312x.14: ASoC: no sink widget found for Mic Bias
[ 1.661940] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Mic Jack → direct → Mic Bias
[ 1.661955] audio-rk312x audio-rk312x.14: ASoC: no source widget found for Mic Bias
[ 1.661969] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Mic Bias → direct → MICP
[ 1.661984] audio-rk312x audio-rk312x.14: ASoC: no source widget found for Mic Bias
[ 1.661998] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Mic Bias → direct → MICN
[ 1.662013] audio-rk312x audio-rk312x.14: ASoC: no sink widget found for Mic Bias
[ 1.662027] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Headset Jack → direct → Mic Bias
[ 1.662041] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTR
[ 1.662055] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTR → direct → Ext Spk
[ 1.662069] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTL
[ 1.662083] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTL → direct → Ext Spk
[ 1.662097] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTR
[ 1.662111] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTR → direct → Headphone Jack
[ 1.662126] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTL
[ 1.662140] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTL → direct → Headphone Jack
[ 1.663582] u32 classifier
[ 1.663601] Actions configured
[ 1.663616] Netfilter messages via NETLINK v0.30.
[ 1.663700] nf_conntrack version 0.5.0 (15472 buckets, 61888 max)
[ 1.664201] ctnetlink v0.93: registering with nfnetlink.
[ 1.664295] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.664308] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.664806] xt_time: kernel timezone is -0000
[ 1.665108] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.665320] arp_tables: (C) 2002 David S. Miller
[ 1.665387] TCP: cubic registered
[ 1.665399] Initializing XFRM netlink socket
[ 1.665787] NET: Registered protocol family 10
[ 1.666632] mip6: Mobile IPv6
[ 1.666682] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.666873] sit: IPv6 over IPv4 tunneling driver
[ 1.667432] NET: Registered protocol family 17
[ 1.667477] NET: Registered protocol family 15
[ 1.667572] Bridge firewalling registered
[ 1.667593] Ebtables v2.0 registered
[ 1.667896] Bluetooth: RFCOMM TTY layer initialized
[ 1.667944] Bluetooth: RFCOMM socket layer initialized
[ 1.667956] Bluetooth: RFCOMM ver 1.11
[ 1.667968] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.667979] Bluetooth: BNEP filters: protocol multicast
[ 1.667996] Bluetooth: BNEP socket layer initialized
[ 1.668009] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.668025] Bluetooth: HIDP socket layer initialized
[ 1.668074] l2tp_core: L2TP core driver, V2.0
[ 1.668095] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.668106] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.668322] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.668341] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 1.668353] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.668365] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 1.668377] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.668434] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 43, flags = 0.
[ 1.668469] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 2, flags = 0.
[ 1.668482] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.668518] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.668586] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.668787] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 17.
[ 1.668824] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 35.
[ 1.668848] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 42.
[ 1.668871] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 41.
[ 1.668932] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.669056] [BT_RFKILL]: ** disable irq
[ 1.669207] [BT_RFKILL]: ap6212 device registered.
[ 1.669568] rk_cam_cif(3083):rk312x-camera version: v0.1.14 Zoom by ipp
[ 1.669700] rk_cif 1010a000.cif: rk_camera_cif_iomux:could not get cif_pin_all pinstate
[ 1.670170] soc-camera-pdrv s5k4ec_back_3: Probing s5k4ec_back_3
[ 1.670714] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 1.670744] rk312x_init_suspend
[ 1.670754] rk312x_suspend_init
[ 1.671008] Registering SWP/SWPB emulation handler
[ 1.671027] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 2000000@9dc00000
[ 1.676325] ddrfreq: verion 1.2 20140526
[ 1.676352] ddrfreq: normal 396MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 198MHz reboot 396MHz
[ 1.676367] ddrfreq: auto-freq=0
[ 1.676377] ddrfreq: auto-freq-table[0] 240MHz
[ 1.676386] ddrfreq: auto-freq-table[1] 324MHz
[ 1.676396] ddrfreq: auto-freq-table[2] 396MHz
[ 1.676405] ddrfreq: auto-freq-table[3] 528MHz
[ 1.694330] rk818_ldo8: disabling
[ 1.695250] rk818_ldo4: disabling
[ 1.695926] regulator-dummy: disabling
[ 1.696105] =======================================================
[ 1.696122] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 1.696135] =======================================================
[ 1.696147] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 1.696239] dhd_module_init: in
[ 1.696255] ======== bcm_wlan_set_plat_data ========
[ 1.696269] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.696315] host_oob_irq: 169
[ 1.696326] host_oob_irq_flags=4
[ 1.696337] dhd_wifi_platform_load: Enter
[ 1.696367] Power-up adapter ‘DHD generic adapter’
[ 1.696380] pcd_pullup, is_on 0
[ 1.696430] wifi_platform_set_power = 1
[ 1.696441] ======== PULL WL_REG_ON HIGH! ========
[ 1.696454] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.696467] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 1.696475] file system registered
[ 1.696488] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 1.697833] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.697855] android_usb gadget: Number of LUNs=2
[ 1.697869] lun0: LUN: removable file: (no medium)
[ 1.697882] lun1: LUN: removable file: (no medium)
[ 1.698223] android_usb gadget: android_usb ready
[ 1.698346] sensor_init: Probe name sensors
[ 1.698375] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 1.699011] rtc_hym8563 0-0051: setting system clock to 2011-01-01 20:03:29 UTC (1293912209)
[ 1.706393] rockchip-spdif-card rockchip-spdif-card.21: rk-hdmi-spdif-hifi ↔ 10204000.spdif mapping ok
[ 1.707755] usbcore: registered new interface driver snd-usb-audio
[ 1.707776] ALSA device list:
[ 1.707787] #0: RK_RK312X
[ 1.707798] #1: RK-SPDIF-CARD
[ 1.708332] Freeing unused kernel memory: 352K (c0b96000 - c0bee000)
[ 1.758073] usb 1-1: new high-speed USB device number 2 using rockchip_ehci_host
[ 1.777701] Cam_Powerdowm
[ 1.777835] rk818_ldo8: operation not allowed
[ 1.797411] [WLAN_RFKILL]: wifi turn on power. 43
[ 1.846701] rk818_ldo4: operation not allowed
[ 1.885962] ret: 0
[ 1.906225] min_w = 800,min_h = 600 ,max_real_w = 2592,max_real_h = 1944,max_w = 2592,max_h =1944
[ 1.906344] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[ 1.906366] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.906382] usb 1-1: Product: USB 2.0 Hub [MTT]
ov cp9074Li] hu: 1-1:; 0: 4c]ortsaieteco d
[ a 1.be7823ges5k4gs
) ck
1 camumensos)169)
/iten/rg(0verfc,
vE::0x’t00) d iled
E/y tilwrit bagainle
[ ov1.90bo53]oa5k4ecpbackLi(rk
: m_sensun:169 : w_btetlog(0r_mec,agel:0d; 00)'t iled mtry
o/ ritee]gainoo
[ e/1.91ve54] eck4ecy.ack
[rk_c] sen4;r:16n9] write rergs; cfc, val’bxd000) fa co, try t
r1.9108y : :
stback_3(
cafasensoro cre: w /cae array,err=eile e 1.9
0E:6] s5k4to mockt /ca_cam_sev/block/rk soft rche (foiled
file 1.910r96]
) E/ .92679 : b5k4ac_e/rec3(rk_caoose.cpp;169): w : 138; (0x2c, : ensure00) faiountetryfto writo moain!
[ /dev8300] s5k4ac_backhe (N
auch fsor:169dirertory)
E:Cac, val:nt /cachfailed,ery/cto write a [Fil
[ ot9ble/r] s5k4e/recov_3(rk_cam_sine]r: 298; write : f0x2n_patl:0x700t ount d, try recovete agaiand
n’t f307] s5k4ec
[Fil3(rk_caotablsor:cover writtloag(0x2e,; [Li0e] 4) fail[Funcry: setrite agader_mes 1.93d; Ca s5k4ecd mis
D/ cam_se : bo16ab: /recov reg(0xoe,ry.cp0x1a4) e]iled282; to wri: ain; !
r arg e reg(0x2overyl(k_3(rk_cam_rgumer:169):
x1afa failto crry to/write dir,n!
[ exist14
d t 1.93 171che / 1.9ck/62nand_e=1403 No such 9391220 direct): polE:y loadeount d=4c94967coveres=429_96729ets.cpk_cam_se] : 1318): erc] : misuatchedh_moud = 0xffff
[/ 1.996: booinit:/recod not icpvery.ile ‘/iine] : 29ery.rk3c] : fopc’ from; Canit.mc’
[/cach.001069] b/lastp: oldcaplocal is /synull)]c
dreaso 2.00null)] stage6c000.
it: invalid gid ‘trace’
[can’2.00117/dev/t_cap:Noldcah filh oo eirst
[ 2.fb0110] wis (poatform_inaccnumerate devi.bipresentpix
l = 12
132] reoffse
[ 2.0 .l] ===== =
d detecen.ofto d tect .lcard! ======
vi 2.0ffset mmc2:mm .lent r = n start!.line 2.131 = 25Cam_Powerdowm
[ 2.141966] soc-camera-pdrv ov2659_front_4: Probing ov2659_front_4
[ 2.181381] usb 1-1.3: new low-speframeb device0 (1280 3 usin doubkehip_eer 1h
st
[ d png7303] instal/dev/hwidth o80not fou 2975 n.199734] fotn: /ramesw_random not found
[ 2.202220] android_usb: already disabled
[ 2.202665] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 2.202699] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 2.202937] init: Unable to open persistent property directory /data/property errno: 2
[ 2.204584] android_usb: already disabled
[ 2.205004] init: using deprecated syntax for specifying property ‘ro.product.manufacturer’, use ${name} instead
[ 2.205136] init: using deprecated syntax for specifying property ‘ro.product.model’, use ${name} instead
[ 2.205268] init: using deprecated syntax for specifying property ‘ro.serialno’, use ${name} instead
[ 2.205308] init: property 'ro.load png icon_ert exist while expanding ‘$ro.serial 3’
[ 2.205337] init: cannot expand ‘$ro.serialno’ while writing to '/sys/class/androipng progress_empty, width 25 2.208098] initlsWa
ing! Service consols_fill, width 252 height 7 channelplease fiload 2.210761] ret: 0
[ 2.215151] read des1
ptorl
[ 2.215184] read strings
pullup, is_on 1pcd
[ 2.220552] rk_sdmmc: BOOT dw_mci_I/ [File] : bootaclk_mmc workaround out 800000Hz f r init[mmc2]
[ main.293541] mmcy: queuing unknown CIS tuple 0x80 n bytes)
297887] usb 1-1.3: New USB device found, idVendor=093a, idProduct=2510
[ 2.2failed to create:/New USB device drings: Mfr=1, Product=2, SerialNumber=0able/recover7/rootusb 1-1.3: Product: USB Optical Mure_path_mounted;44] usb 1-1.3: Manufacturer: PixAr t
.300901]W/ [File]e: bootnkable/CIS tupy/roo8s cpp; tes) [
[: 161;308112] : en:ure_uing ununted CtS tuplmount0 (3 bytesk/mmc 2.30 45fs
usb1/1-1/1-1.3/1-1.3:1.File]ut/input2le/re 2.3093oo] .hid; [Liric 0016:093A:2c] : 001urenput,hiounte: UfB HID to m1 Mouse [Pexter USB Op(icasuch se] on
b-lay 2000.usb-1.3/input0
[ 2.316141] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.358266] Cam_Powerdowm
[ 2.358998] min_w = 800,min_h = 600 ,max_real_w = 1600,max_real_h = 1200,max_w = 1600,max_h =1200
[ 2.363372] ov2659_front_4(rk_cam_sensor:169): write reg(0x103, val:0x1) failed, try to write again!
[ 2.369261] ov2659_front_4(rk_cam_sensor:169): write reg(0x103, val:0x1) failed, try to write again!
[ 2.373092] ov2659_front_4(rk_cam_sensor:169): write reg(0x103, val:0x1) failed, try to write again!
[ 2.373122] ov2659_front_4(rk_cam_sensor:387): write array failed!
[ 2.373138] ov2659_front_4(rk_cam_sensor:671): soft reset failed
[ 2.373138]
[ 2.392110] ov2659_front_4(rk_cam_sensor:335): read reg(0x300a val:0x0) failed, try to read again!
[ 2.392142] ov2659_front_4(rk_cam_sensor:699): read chip id failed
[ 2.483749] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 37500000Hz, actual 37500000HZ div = 0)
[ 2.483787] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[ 2.483902] rk_sdmmc: BOOT Bus speed=37500000Hz,Bus width=4bits.[mmc2]
[ 2.486316] mmc2: new high speed SDIO card at address 0001
[ 2.496042] Cam_Powerdowm
[ 2.502929] bcmsdh_register: register client driver
[ 2.503073] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.503190] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.503206] bus num (host idx)=2, slot num (rca)=1
[ 2.503219] found adapter info ‘DHD generic adapter’
[ 2.503731] F1 signature read @0x18000000=0x1540a9a6
[ 2.506709] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x0 pkg:0x4
[ 2.507700] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 2.507853] wifi_platform_get_mac_addr
[ 2.507868] ======== bcm_wlan_get_mac_address ========
[ 2.507881] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 2.507900] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[bf:4f:36:b3:f0:e7]
[ 2.507913] [WLAN_RFKILL]: This mac address is not valid, ignored…
[ 2.507932] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=0
[ 2.508007] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[ 2.509053] wl_create_event_handler(): thread:wl_event_handler:77 started
[ 2.509067] tsk Enter, tsk = 0xddda149c
[ 2.509636] dhd_attach(): thread:dhd_watchdog_thread:78 started
[ 2.509738] dhd_attach(): thread:dhd_dpc:79 started
[ 2.509790] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 2.509829] dhd_attach(): thread:dhd_rxf:7a started
[ 2.509850] dhd_deferred_work_init: work queue initialized
[ 2.510095] dhdsdio_probe_init: set use_rxchain 0 from config.txt
[ 2.521382] Dongle Host Driver, version 1.201.59.5 (r506368)
[ 2.521382] Compiled in drivers/net/wireless/bcmdhd on Nov 28 2016 at 09:45:42
[ 2.522193] Register interface [wlan0] MAC: 94:a1:a2:a5:bd:08
[ 2.522193]
[ 2.522224] dhd_prot_ioctl : bus is down. we have nothing to do
[ 2.522305] bcmsdh_oob_intr_unregister: Enter
[ 2.522319] bcmsdh_oob_intr_unregister: irq is not registered
[ 2.522338] dhd_txglom_enable: enable 0
[ 2.522350] dhd_bus_devreset: WLAN OFF DONE
[ 2.522432] wifi_platform_set_power = 0
[ 2.522447] ======== PULL WL_REG_ON LOW! ========
[ 2.522460] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2.564928] ret: 0
[ 2.594455] soc-camera-pdrv gc0329_front_5: Probing gc0329_front_5
[ 2.623947] [WLAN_RFKILL]: wifi shut off power.
[ 2.623964] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 2.623977] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 2.624100] dhd_module_init: Exit err=0
[ 2.663316] ret: 0
[ 2.810902] Cam_Powerdowm
[ 2.811509] min_w = 640,min_h = 480 ,max_real_w = 640,max_real_h = 480,max_w = 640,max_h =480
[ 2.831568] gc0329_front_5(rk_cam_sensor:169): write reg(0xfc, val:0x16) failed, try to write again!
[ 2.832539] gc0329_front_5(rk_cam_sensor:169): write reg(0xfc, val:0x16) failed, try to write again!
[ 2.833496] gc0329_front_5(rk_cam_sensor:169): write reg(0xfc, val:0x16) failed, try to write again!
[ 2.861340] gc0329_front_5(rk_cam_sensor:335): read reg(0x0 val:0x0) failed, try to read again!
[ 2.861366] gc0329(917): gc0329 read chip id high byte failed
[ 2.861366]
[ 2.861382] gc0329(924): error: gc0329 mismatched pid = 0x0
[ 2.861382]
[ 2.861399] gc0329_front_5(rk_cam_sensor:718): error: mismatched pid = 0x0
[ 2.861399]
[ 2.968360] Cam_Powerdowm
[ 3.037228] ret: 0
[ 3.066900] soc-camera-pdrv gc2035_back_6: Probing gc2035_back_6
[ 3.155291] ret: 0
[ 3.302899] Cam_Powerdowm
[ 3.302915] rk_cam_io(1128):SENSOR_PWRSEQ_PWRDN failed
[ 3.302981] soc-camera-pdrv gc2035_back_6: Cannot get I2C adapter #2. No driver?
[ 3.412429] Cam_Powerdowm
[ 3.412448] rk_cam_io(1128):SENSOR_PWRSEQ_PWRDN failed
[ 3.412461] rk_cam_io(1117):SENSOR_PWRSEQ_HWRST failed
[ 3.480039] ret: 0
[ 3.509590] soc-camera-pdrv gc0308_front_7: Probing gc0308_front_7
[ 3.598105] ret: 0
[ 3.745693] Cam_Powerdowm
[ 3.745769] soc-camera-pdrv gc0308_front_7: Cannot get I2C adapter #2. No driver?
[ 3.853957] Cam_Powerdowm
[ 3.922816] ret: 0
[ 4.595769] rk312x-lcdc lcdc0: blank mode:0
[ 4.621555] rk312x_delay_workq
[ 4.739592] [off]
[ 5.919211] rk818-battery rk818-battery: changed: dsoc=0, rsoc=0
failed to create /mnt/external_sd dir,err=File exists!
W/ [File] : bootable/recovery/roots.cpp; [Line] : 145; [Func] : ensure_path_mounted; trying mount /dev/block/mmcblk0p1 to ntfs
W/ [File] : bootable/recovery/roots.cpp; [Line] : 161; [Func] : ensure_path_mounted; trying mount /dev/block/mmcblk0 to ntfs
E:failed to mount /mnt/external_sd (No such device)
E/ [File] : bootable/recovery/roots.cpp; [Line] : 167; [Func] : ensure_path_mounted; failed to mount /mnt/external_sd (No such device)
delay 2sec
[ 6.903193] rk818-battery rk818-battery: changed: dsoc=0, rsoc=0
[ 6.903981] rk818-battery rk818-battery: set charge to digital termination mode
read cmdline
Not enter sdboot!
failed to create /cache dir,err=File exists!
E:failed to mount /cache /dev/block/rknand_cache (No such file or directory)
E/ [File] : bootable/recovery/roots.cpp; [Line] : 138; [Func] : ensure_path_mounted; failed to mount /cache /dev/block/rknand_cache (No such file or directory)
mount cache fail,so formate…
[ 8.815d 4] t oe=14le ysdit(1293or2216vo30:3::mavc: xtenieil { wn te }/bor /rd=11d_cach=“rithvery” sume=filockr dir=“torfs” ino=7901 scontextEu:r:ieco : y:st blentecovu:o/roct_.cploc[Lievi : s0 ; [assc] r pormassiolu1
fo 8t_v595me:typke 4004 fdited 939/de16.loc:4)knand: dheied h add same fifor r id=1ct comm=“refaverd namre"rkn/ca_ca di” srr=text e:r:rs!
er:fs0 td ntexouut bjecher:bev/k_dck/ce:andtclche=dilocermeviiverequire 8.816026] type=1400 E/ it(le]391boo6.7le/5):ovec: rooniecpp{ cLinte : 13r [Fu=11 : ommu"r_pavermounamd; rknled_ca me" s ocacxt=/de:relocery:na tcoacext=Blocjecevi:blreq_deeice:s0 fclaed filcreermi/meve=ata[ r,e.8=Fi02]exipe=1400 auE:t(12939to mo.730:6)tadat: denibd ck/rkite opeta}atar pid=ch fiom or ecoveryry)ath=“/dev/block/rknand/cache” devbootafs" recov928 scotsext=u [Lincovery:s0 [Funtext=u:sure_p_r:blountedv ce:s0d to ss=fil/metadissive=v/bloc 8.816_metatype=1400 uch f(12939122recto0:7
ice:s0 tclass=file pe/ [Fiive=1v/block/rolume_cache ext4="tmpfs i /dev28 sconrkxt=d_metecoveryith tconteuch fobject_r:bectorde
ootable/recovery/roots.cpp; [Line] : 316; [Func] : format_volume; format_volume: make ext4 failed on /dev/block/rknand_metadata with 1(No such file or directory)
failed to create /metadata dir,err=File exists!
E:failed to mount /metadata /dev/block/rknand_metadata (Block device required)
E/ [File] : bootable/recovery/roots.cpp; [Line] : 138; [Func] : ensure_path_mounted; failed to mount /metadata /dev/block/rknand_metadata (Block device required)
bootmode = unknown
Command: “/sbin/recovery”
ro.rk.cpu=rk312x
ro.rk.soc=rk3128
ro.rk.bt_enable=true
ro.rk.systembar.tabletUI=false
ro.rk.systembar.voiceicon=true
ro.rk.MassStorage=false
ro.rk.hdmi_enable=false
ro.rk.cpu_min_freq=216000
ro.rk.display_array=100,128,160
ro.rk.homepage_base=http://en.t-firefly.com/en/firenow/fireprime/
ro.rk.def_brightness=200
ro.rk.screenoff_time=2147483647
ro.rk.screenshot_enable=true
ro.rk.LowBatteryBrightness=true
ro.rk.install_non_market_apps=true
ro.sf.hwrotation=0
ro.sf.lcd_density=160
ro.sf.fakerotation=false
ro.sf.lcdc_composer=0
ro.adb.secure=0
ro.com.android.dateformat=MM-dd-yyyy
ro.ril.ecclist=112,911
ro.boot.console=ttyFIQ0
ro.boot.selinux=permissive
ro.boot.baseband=N/A
ro.boot.hardware=rk30board
ro.wifi.channels=
ro.allow.mock.location=1
ro.audio.monitorOrientation=true
ro.board.platform=rk312x
ro.build.id=LMY48Y
ro.build.date=2016骞11鏈28鏃鏄熸湡涓
确保代码更新到最新,还有烧写固件时烧写自己编译的全部img
我 自己编译的镜像在FirePrimeS+上也不能正常启动,烧写固件时烧写了自己编绎的全部IMG
