如何啟動pcba test
如題所述
想請教一下各路大神
我依照pcba test tools 的說明文件
產生了recovery.img 以及 pcba_whole_misc.img
兩個img檔案
並照著步驟 要燒寫兩個img進去時
卻不知道該把pcba_whole_misc.img的分區設為多少
且recovery.img已經燒進去了
跪求解答
另外 有看到有DeviceTest這個apk 已經被安裝在system中
卻不知道該如何啟動
目前唯一能啟動的 就是stressTest工具
跪求幫忙!!
开发板没有支持pcba test,要的话自己要去分析处理。
我这边参考PCBA 测试说明V3.0 执行:
make installclean
make
rm -rf out/target/product/rk3288/root/
make recoveryimage提示:
----- Making recovery image ------
Copying baseline ramdisk…
Modifying ramdisk contents…
cp: cannot stat ‘out/target/product/rk3288_box/root/init.recovery.*.rc’: No such file or directory
make: [out/target/product/rk3288_box/recovery.img] Error 1 (ignored)
device/rockchip/common/recovery_contents.sh rk3288_box out/target/product/rk3288_box rk3288 true arm
cp: cannot stat ‘vendor/rockchip/common/bin/arm/newfs_msdos’: No such file or directory
cp: cannot stat ‘out/target/product/rk3288_box/obj/EXECUTABLES/codec_test_intermediates/codec_test’: No such file or directory
rk-pcba-test/res.sh rk3288_box out/target/product/rk3288_box rk3288
MODULE modules_smp
----- Made recovery image: out/target/product/rk3288_box/recovery.img
但最后还是会有得到 recovery.img,没有pcba_whole_misc.img。
自己拷贝了rkst/Image/misc.img ,烧录后:
U-Boot 2014.10-RK3288-10 (Dec 16 2016 - 13:01:50)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
Adding bank:0000000000000000(0000000100000000)
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2016-12-16#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
got recovery cmd from misc.
boot or recovery image sha mismatch!
Unable to boot:recovery
try to start backup
bad image magic.
load boot image failed
ERROR: [rk_load_image_from_storage]: bootrk: bad boot or kernel image
Unable to boot:backup
try to start rockusb
1111111111111
