我的机子升级固件后就出现了如下的情况,请教大神,谢谢
DDR Version V1.16 20151110
600MHz
DDR3
Bus Width=32 Col=10 Bank=8 Row=15 CS=2 Die Bus-Width=16 Size=2048MB
mach:14
Boot1 Release Time: 2015-12-24, version: 2.50
ChipType = b 2393
CPUId = 0x0
SDC_BusRequest: CMD=8 SDC_RESP_TIMEOUT 1884
SDC_BusRequest: CMD=5 SDC_RESP_TIMEOUT 1884
SDC_BusRequest: CMD=55 SDC_RESP_TIMEOUT 1884
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=1d1f000
FwPartOffset=2000 , 2000
DATA_BUSY:cmd=0x8
DATA_BUSY:cmd=0x8
DATA_BUSY:cmd=0x8
SdmmcInit=0 400
StorageInit ok = 61800
LoadTrustBL
Trust version:100
Open bl32.bin fail!
LoadBL33
theLoader 200000 109073
INFO: Bl31 Release Time: 2015-10-29, version: 1.7
NOTICE: BL3-1: v1.1(debug):d209b14
NOTICE: BL3-1: Built : 09:26:20, Oct 29 2015
get_chip_info: chip_code is 3368!
pmu_init:pd st (1ee) (1ef)
INFO: BL3-1: Initializing runtime services
INFO: BL3-1: Preparing for EL3 exit to normal world
INFO: BL3-1: Next image address = 0x200000
INFO: BL3-1: Next image spsr = 0x3c5
U-Boot 2014.10-RK3368-10-01995-gcce8953 (Jan 21 2016 - 14:31:47)
CPU: rk3368
CPU’s clock information:
arm pll big = 816000000HZ
arm pll little = 600000000HZ
periph pll = 576000000HZ
ddr pll = 1200000000HZ
codec pll = 400000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
128 MiB
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
power key: bank-0 pin-2
can’t find dts node for rk808
pmic rk818 i2c probe failed
No pmic detect.
set pwm voltage ok,pwm_id =1 vol=1000000,pwm_value=84
fg:cw201x
#Boot ver: 2016-01-21#2.50
empty serial no.
checkKey
vbus = 0
CW201X_FG capacity = 0, voltage_uV = 0,state_of_chrg=2
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x0073e9a8)
ramdisk @ 0x05bf0000 (0x003316b4)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000005600000, end 000000000563cbbe … OK
Add bank:0000000000200000, 000000007fe00000
“Synchronous Abort” handler, esr 0x00280000
ELR: fffffff700000001
LR: ffffffffffffff7f
x0 : 0000000000000000 x1 : 0000000080000000
x2 : ffffffffffffffff x3 : ffffffffffdfffff
x4 : efffffffffffefff x5 : ffffffffffffffff
x6 : fffffffffffeffff x7 : fffffff7ffffffff
x8 : ffffffffefffffff x9 : ffffffffffffbff7
x10: ffffffffffffffff x11: ffffffffffffffff
x12: fdeffffffeffffff x13: ffffffffffffffff
x14: ffffffffffffffff x15: ffffffffffffffff
x16: ffffffffffffffff x17: ffffffffffffffff
x18: ffffffffffffffff x19: ffffffffffffffff
x20: ffef7ffffffffffe x21: ffffcfffffffffff
x22: ffffffff77ffffff x23: ffffffffffffffbf
x24: ffeffffffffffff7 x25: ffffffffffffffff
x26: ffffffffffffffff x27: ffffffffffffffff
x28: fffffffffffffffe x29: fefff7ffffffffff
Resetting CPU …
resetting …
600MHz
DDR3
mach:14
ChipType = b 2392
CPUId = 0x0
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=1d1f000
DATA_BUSY:cmd=0x8
DATA_BUSY:cmd=0x8
DATA_BUSY:cmd=0x8
SdmmcInit=0 400
StorageInit ok = 61795
LoadTrustBL
Trust version:100
Open bl32.bin fail!
LoadBL33
theLoader 200000 109065
CPU: rk3368
128 MiB
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
No pmic detect.
fg:cw201x
empty serial no.
checkKey
vbus = 0
CW201X_FG capacity = 58, voltage_uV = 3796,state_of_chrg=2
