编译好内核下载到板子启动不出来,求大神指导~~~在线等答案
按照http://wiki.t-firefly.com/index.php/Firefly-RK3288/Build_kerne做的,下载内核之前统一固件Firefly-RK3288_Ubuntu14.04_201611021526.img,自己编译的内核放进去出问题,串口打印:
DDR Version 1.00 20160530
SRX
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
U-Boot 2014.10-RK3288-10 (Oct 13 2016 - 10:04:48)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2016-10-13#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
boot or recovery image sha mismatch!
Unable to boot:boot
try to start recovery
http://blog.csdn.net/kris_fei/article/details/53410703
Unable to boot:boot
提示你boot.img有问题。
Unable to boot:boot
提示你boot.img有问题。
编译都是按照WIKI上做的,做的过程也没出现错误。不知道怎么弄了{:4_158:}
按照wiki上做应该没有问题,在重新做一次试试。论坛上之前也有很多帖子讨论的,搜搜看。
可以开机?问题描述的清楚点,不然弄不懂你的问题是什么。
同样问题 请问版主问题解决了吗(我用的内核firefly-3.14-kernel)按照http://developer.t-firefly.com/thread-10907-1-1.html做
开发板为RK3288 原先烧录固件为Firefly-RK3288_Ubuntu14.04_201611211031.img
想换个自己编译的内核
SRX
U-Boot 2014.10-RK3288-10 (Mar 13 2017 - 18:07:53)
CPU: rk3288
cpu version = 0
Adding bank:0000000000000000(0000000100000000)
128 MiB
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from boot image.
pmic:act8846
#Boot ver: 2017-03-13#2.30
empty serial no.
reboot to rockusb.
SRX
CPU: rk3288
cpu version = 0
128 MiB
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
no key node
pmic:act8846
can’t find dts node for pwm0
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
Unable to boot:boot
‘recovery’ does not seem to be a partition nor an address
Unable to boot:recovery
try to start backup
ERROR: [rk_load_image_from_storage]: bootrk: bad boot or kernel image
Unable to boot:backup
try to start rockusb
今天自己修改编译内核,遇到和楼上同样的问题,
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
misc partition not found!
Unable to boot:boot
try to start backup
求解答
用官方:Firefly-RK3288_Ubuntu16.04_HDMI_VGA_DiffDisplay_20170215
刷自编译:firefly-3.14-kernel
烧录boot 地址用的0x00002000
请问有谁知道原因么
妈的,真想骂娘,我也遇到了这个问题,官方就不能给个完整镜像对应的内核版本吗????!!垃圾!
文档也是一塌糊涂,按照文档操作根本就不行,这个公司咋这么垃圾?
大神,请教下,目前是 进不了 kernel,kernel是自编译的,不可以开机;log 只打出以下那么多
[16-43-43]U-Boot 2014.10-RK3288-10-gc28aaca-dirty (Jul 10 2017 - 16:11:05)
[16-43-43]
[16-43-43]CPU: rk3288
[16-43-43]cpu version = 0
[16-43-43]CPU’s clock information:
[16-43-43] arm pll = 600000000HZ
[16-43-43] periph pll = 297000000HZ
[16-43-43] ddr pll = 200000000HZ
[16-43-43] codec pll = 384000000HZ
[16-43-43]Board: Rockchip platform Board
[16-43-43]DRAM: Found dram banks: 1
[16-43-43]Adding bank:0000000000000000(0000000080000000)
[16-43-43]128 MiB
[16-43-43]GIC CPU mask = 0x00000001
[16-43-43]SdmmcInit = 0 400
[16-43-43]SdmmcInit = 2 0
[16-43-43]storage init OK!
[16-43-43]Using default environment
[16-43-43]
[16-43-43]GetParam
[16-43-43]Load FDT from boot image.
[16-43-43]no key node
[16-43-44]No pmic detect.
[16-43-44]can’t find dts node for pwm0
[16-43-44]Can’t find dts node for fuel guage cw201x
[16-43-44]SecureBootEn = 0, SecureBootLock = 0
[16-43-44]
[16-43-44]#Boot ver: 2017-07-10#2.30
[16-43-44]empty serial no.
[16-43-44]checkKey
[16-43-44]vbus = 1
[16-43-44]no fuel gauge found
[16-43-44]read logo on state from dts [0]
[16-43-44]I2C bus error, PLS set i2c bus first!
[16-43-44][jxw] lcd power ldo6,ldo8,swout2 on.
[16-43-44]misc partition not found!
[16-43-45]Hit any key to stop autoboot: 0
[16-43-45]boot or recovery image sha mismatch!
[16-43-45]Unable to boot:boot
[16-43-45]try to start recovery
求教下大神,要从哪几个方面入手解决
各种问题,根本没法编译。官方又不给个标准编译环境(ubuntu版本)
