运行一个ffmpeg播放视频的app,一二十秒后闪退,上传log,大家帮忙看下
同样的app,其它平台和手机上是可以正常播放,以个是log,大家帮忙看看
--------- beginning of /dev/log/main
V/SDL (23649): SDL audio: opening device
I/AudioTrack(23649): set() streamType 3 frameCount 3072 flags 0000 channelMask 3 sampleRate 44100 format 1
I/AudioHardwareALSA( 143): Audio exiting sandby will open audio device
D/dalvikvm(23649): GC_CONCURRENT freed 1518K, 22% free 5567K/7120K, paused 1ms+4ms, total 21ms
W/gralloc ( 140): Debugmem The fd=44, in vmalloc !!! Ishwc=0
V/ALSAModule( 143): SAMPLERATE:44100
D/ALSAModule( 143): open called for devices 00000400 in mode 0…
D/ALSAModule( 143): DevName: AndroidPlayback_Aux_normal
E/ALSAModule( 143): buffersize: 3072, periodsize:1024
V/ALSAModule( 143): Set PLAYBACK PCM format to S16_LE (Signed 16 bit Little Endian)
V/ALSAModule( 143): Using 2 channels for PLAYBACK.
V/ALSAModule( 143): Set PLAYBACK sample rate to 44100 HZ
E/ALSAModule( 143): audio type flag: 0
V/ALSAModule( 143): Buffer size: 3072(frames) period Size: 1024(frames) periods: 3 (buffersize=periodSizeperiods)
V/ALSAModule( 143): Latency: 69659 periodTime: 23219
W/gralloc ( 140): Debugmem The fd=47, in vmalloc !!! Ishwc=0
D/ALSAModule( 143):
D/ALSAModule( 143): DumpHandleInfo:
D/ALSAModule( 143): devices: 0xbfff
D/ALSAModule( 143): format: 0x2
D/ALSAModule( 143): channels: 2
D/ALSAModule( 143): sampleRate: 44100
D/ALSAModule( 143): latency: 69659
D/ALSAModule( 143): periodSize:1024
D/ALSAModule( 143): bufferSize:3072
D/ALSAModule( 143): open called for devices 00000800 in mode 0…
D/ALSAModule( 143): DevName: AndroidPlayback_Spdif_normal
periods)
D/ALSAModule( 143):
W/gralloc ( 140): Debugmem The fd=60, in vmalloc !!! Ishwc=0
E/dalvikvm(23649): JNI ERROR (app bug): local reference table overflow (max=512)
W/dalvikvm(23649): JNI local reference table (0x7fb986a8) dump:
W/dalvikvm(23649): Last 10 entries (of 512):
W/dalvikvm(23649): 511: 0x41c76220 android.graphics.SurfaceTexture
W/dalvikvm(23649): 510: 0x417c98a8 java.lang.Object
W/dalvikvm(23649): 509: 0x417c98a8 java.lang.Object
W/dalvikvm(23649): 508: 0x417c98a8 java.lang.Object
W/dalvikvm(23649): 507: 0x417c98a8 java.lang.Object
W/dalvikvm(23649): 506: 0x417c98a8 java.lang.Object
W/dalvikvm(23649): 505: 0x417c98a8 java.lang.Object
W/dalvikvm(23649): 504: 0x417c98a8 java.lang.Object
W/dalvikvm(23649): 503: 0x417c98a8 java.lang.Object
W/dalvikvm(23649): 502: 0x417c98a8 java.lang.Object
W/dalvikvm(23649): Summary:
W/dalvikvm(23649): 1 of java.lang.Class
W/dalvikvm(23649): 510 of java.lang.Object (1 unique instances)
W/dalvikvm(23649): 1 of android.graphics.SurfaceTexture
E/dalvikvm(23649): Failed adding to JNI local ref table (has 512 entries)
I/dalvikvm(23649): “Thread-258” prio=5 tid=11 RUNNABLE
I/dalvikvm(23649): | group=“main” sCount=0 dsCount=0 obj=0x41858558 self=0x763cf4d0
I/dalvikvm(23649): | sysTid=23662 nice=0 sched=0/0 cgrp=apps handle=1979711032
I/dalvikvm(23649): | state=R schedstat=( 11103732832 345690885 26533 ) utm=925 stm=185 core=2
I/dalvikvm(23649): at android.graphics.SurfaceTexture.nativeGetTransformMatrix(Native Method)
I/dalvikvm(23649): at android.graphics.SurfaceTexture.getTransformMatrix(SurfaceTexture.java:240)
I/dalvikvm(23649): at dalvik.system.NativeStart.run(Native Method)
I/dalvikvm(23649):
E/dalvikvm(23649): VM aborting
F/libc (23649): Fatal signal 6 (SIGABRT) at 0x00005c61 (code=-6), thread 23662 (adero.C3DPlayer)
I/DEBUG ( 138): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
I/DEBUG ( 138): Build fingerprint: ‘rockchip/rk3288/rk3288:4.4.2/KOT49H/eng.hyj.20161128.142741:eng/test-keys’
I/DEBUG ( 138): Revision: ‘0’
I/DEBUG ( 138): pid: 23649, tid: 23662, name: adero.C3DPlayer >>> com.embarcadero.C3DPlayer <<<
I/DEBUG ( 138): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
I/DEBUG ( 138): r0 00000000 r1 00005c6e r2 00000006 r3 00000000
I/DEBUG ( 138): r4 00000006 r5 0000000b r6 00005c6e r7 0000010c
I/DEBUG ( 138): r8 763cf578 r9 41c76220 sl 763cf4e0 fp 6f11077f
I/DEBUG ( 138): ip 00000000 sp 77e4bbf8 lr 4005009d pc 4005f048 cpsr 000f0010
I/DEBUG ( 138): d0 74726f6261204d56 d1 0a29646f6874654d
I/DEBUG ( 138): d2 656361667275532e d3 2e65727574786554
I/DEBUG ( 138): d4 0000000101028340 d5 0000000000000048
I/DEBUG ( 138): d6 0000000000000008 d7 0000000101028338
I/DEBUG ( 138): d8 0000000000000000 d9 0000000000000000
I/DEBUG ( 138): d10 0000000000000000 d11 0000000000000000
I/DEBUG ( 138): d12 0000000000000000 d13 0000000000000000
I/DEBUG ( 138): d14 0000000000000000 d15 0000000000000000
I/DEBUG ( 138): d16 4d637e6c81dd0f8e d17 86e6aa1c69eb42be
I/DEBUG ( 138): d18 0000000101028000 d19 0000000000000008
I/DEBUG ( 138): d20 0000000101028340 d21 0000000000000008
I/DEBUG ( 138): d22 0000000000000048 d23 0000000000000040
I/DEBUG ( 138): d24 0000000000000008 d25 0000000000000040
I/DEBUG ( 138): d26 0000000000000038 d27 3f12c03a04dd13f8
I/DEBUG ( 138): d28 3f1478aedf2fa172 d29 bef375cbdb605373
I/DEBUG ( 138): d30 780000007a10d0c1 d31 7800000000000001
I/DEBUG ( 138): scr 80000010
I/DEBUG ( 138):
I/DEBUG ( 138): backtrace:
I/DEBUG ( 138): #00 pc 00022048 /system/lib/libc.so (tgkill+12)
I/DEBUG ( 138): #01 pc 00013099 /system/lib/libc.so (pthread_kill+48)
I/DEBUG ( 138): #02 pc 000132ad /system/lib/libc.so (raise+10)
I/DEBUG ( 138): #03 pc 00011fe3 /system/lib/libc.so
I/DEBUG ( 138): #04 pc 000218fc /system/lib/libc.so (abort+4)
I/DEBUG ( 138): #05 pc 00045cc7 /system/lib/libdvm.so (dvmAbort+78)
I/DEBUG ( 138): #06 pc 0004914f /system/lib/libdvm.so
I/DEBUG ( 138): #07 pc 0004e021 /system/lib/libdvm.so (dvmCallJNIMethod(unsigned int const*, JValue*, Method const*, Thread*)+124)
I/DEBUG ( 138): #08 pc 00026fe0 /system/lib/libdvm.so
I/DEBUG ( 138): #09 pc 0002dfa0 /system/lib/libdvm.so (dvmMterpStd(Thread*)+76)
I/DEBUG ( 138): #10 pc 0002b638 /system/lib/libdvm.so (dvmInterpret(Thread*, Method const*, JValue*)+184)
I/DEBUG ( 138): #11 pc 00060427 /system/lib/libdvm.so (dvmCallMethodA(Thread*, Method const*, Object*, bool, JValue*, jvalue const*)+354)
I/DEBUG ( 138): #12 pc 0004c6cd /system/lib/libdvm.so
I/DEBUG ( 138): #13 pc 007ba6cf /data/app-lib/com.embarcadero.C3DPlayer-1/libC3DPlayer.so
I/DEBUG ( 138):
I/DEBUG ( 138): stack:
I/DEBUG ( 138): 77e4bbb8 763cf4d0 [anon:libc_malloc]
I/DEBUG ( 138): 77e4bbbc 4157ec74 /system/lib/libdvm.so
I/DEBUG ( 138): 77e4bbc0 00000000
I/DEBUG ( 138): 77e4bbc4 763cf578 [anon:libc_malloc]
I/DEBUG ( 138): 77e4bbc8 41c76220 /dev/ashmem/dalvik-heap (deleted)
I/DEBUG ( 138): 77e4bbcc 763cf4e0 [anon:libc_malloc]
I/DEBUG ( 138): 77e4bbd0 6f11077f /data/dalvik-cache/system@framework@framework.jar@classes.dex
I/DEBUG ( 138): 77e4bbd4 40063501 /system/lib/libc.so (snprintf+80)
I/DEBUG ( 138): 77e4bbd8 34373031
I/DEBUG ( 138): 77e4bbdc 36333231
I/DEBUG ( 138): 77e4bbe0 77e4bc54 [stack:23662]
I/DEBUG ( 138): 77e4bbe4 00000000
I/DEBUG ( 138): 77e4bbe8 00000000
I/DEBUG ( 138): 77e4bbec 34313833
I/DEBUG ( 138): 77e4bbf0 00004000
I/DEBUG ( 138): 77e4bbf4 77e4bc62 [stack:23662]
I/DEBUG ( 138): #00 77e4bbf8 00000006
I/DEBUG ( 138): 77e4bbfc 0000000b
I/DEBUG ( 138): 77e4bc00 00005c6e
I/DEBUG ( 138): 77e4bc04 00000000
I/DEBUG ( 138): 77e4bc08 00000000
I/DEBUG ( 138): 77e4bc0c 4005009d /system/lib/libc.so (pthread_kill+52)
I/DEBUG ( 138): #01 77e4bc10 00000006
I/DEBUG ( 138): 77e4bc14 00000000
I/DEBUG ( 138): 77e4bc18 4157ec74 /system/lib/libdvm.so
I/DEBUG ( 138): 77e4bc1c 400502b1 /system/lib/libc.so (raise+14)
I/DEBUG ( 138): #02 77e4bc20 77e4bc2c [stack:23662]
I/DEBUG ( 138): 77e4bc24 4004efe7 /system/lib/libc.so
I/DEBUG ( 138):
I/DEBUG ( 138): memory near r1:
I/DEBUG ( 138): 00005c4c ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 138): 00005c5c ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 138): 00005c6c ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 138): 00005c7c ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 138): 00005c8c ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 138): 00005c9c ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 138): 00005cac ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 138): 00005cbc ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 138): 00005ccc ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 138): 00005cdc ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 138): 00005cec ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 138): 00005cfc ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 138): 00005d0c ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 138): 00005d1c ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 138): 00005d2c ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 138): 00005d3c ffffffff ffffffff ffffffff ffffffff
I/DEBUG ( 138):
I/DEBUG ( 138): memory near r6:
I/DEBUG ( 138):
I/DEBUG ( 138): memory near r8:
I/DEBUG ( 138): 763cf558 00000000 00000000 00000000 00000000
I/DEBUG ( 138): 763cf568 00001ff0 4158391c 415aa4d8 6d48e270
I/DEBUG ( 138): 763cf578 00000200 838ecc70 00000001 00000200
I/DEBUG ( 138): 763cf588 00000200 00000004 00000003 6ef3fa8c
I/DEBUG ( 138): 763cf598 6ef3fa96 00000001 6eea5c54 6d6667c0
I/DEBUG ( 138): 763cf5a8 00000000 00000000 00000000 00000000
I/DEBUG ( 138): 763cf5b8 00000000 16801ce5 168e1d16 00000000
I/DEBUG ( 138): 763cf5c8 0b16a44e 00000000 00000000 35a62812
I/DEBUG ( 138): 763cf5d8 8552948a 00000000 00000000 00000000
I/DEBUG ( 138): 763cf5e8 00000000 00000000 84aa91f6 00000000
I/DEBUG ( 138): 763cf5f8 00000000 00000000 00000000 00000000
I/DEBUG ( 138): 763cf608 84b89204 00000000 00000000 00000000
I/DEBUG ( 138): 763cf618 00000000 00000000 00000000 00000000
I/DEBUG ( 138): 763cf628 001c0002 00000001 6f0a546a 00000000
I/DEBUG ( 138): 763cf638 00000000 00000000 6d48e270 00000000
I/DEBUG ( 138): 763cf648 00210101 00000001 00000100 00000001
I/DEBUG ( 138):
I/DEBUG ( 138): memory near r9:
I/DEBUG ( 138): 41c76200 43206bc7 42700001 00000000 000003ef
I/DEBUG ( 138): 41c76210 00000438 00000001 00000070 00000023
I/DEBUG ( 138): 41c76220 415e8df0 00000000 417c9ea8 41c76310
I/DEBUG ( 138): 41c76230 7c96a6d8 7c969b48 7cb8cca0 0000002b
I/DEBUG ( 138): 41c76240 4158b010 00000000 00000000 4158b718
I/DEBUG ( 138): 41c76250 00000000 41c76220 41c76070 41c76578
I/DEBUG ( 138): 41c76260 00000000 000000ab 415861e8 00000000
I/DEBUG ( 138): 41c76270 00000000 00000000 00000000 00000000
I/DEBUG ( 138): 41c76280 6f093c09 00000000 00030000 50000e22
I/DEBUG ( 138): 41c76290 6f442000 00000007 00000000 0000000b
I/DEBUG ( 138): 41c762a0 00000020 00000000 00000000 00000000
I/DEBUG ( 138): 41c762b0 415c5480 00000000 00000000 00000000
I/DEBUG ( 138): 41c762c0 00000000 00000000 00000001 6d7887f8
I/DEBUG ( 138): 41c762d0 00000001 6d788838 0000002b 6d788878
I/DEBUG ( 138): 41c762e0 00000000 00000000 00000000 00000000
I/DEBUG ( 138): 41c762f0 00000001 00000001 6d7887e0 f4000000
I/DEBUG ( 138):
I/DEBUG ( 138): memory near sl:
I/DEBUG ( 138): 763cf4c0 006f0069 0000006e 00000000 0000045b
I/DEBUG ( 138): 763cf4d0 6ed7dfac 77e50f98 6d505570 6f442000
I/DEBUG ( 138): 763cf4e0 00000000 00000000 77e4bf98 00000000
I/DEBUG ( 138): 763cf4f0 77e4bfec 0000000b 00000000 414f1d40
I/DEBUG ( 138): 763cf500 00000000 00000000 6c805f70 77e4d300
I/DEBUG ( 138): 763cf510 00000000 00000000 00000001 00004000
I/DEBUG ( 138): 763cf520 00000000 75fffe38 414f1d40 414f6c00
I/DEBUG ( 138): 763cf530 00000000 414facfc 414fad70 414fac20
I/DEBUG ( 138): 763cf540 414fac40 414fac9c 00000000 00000000
I/DEBUG ( 138): 763cf550 782dedc8 00000028 00000000 00000000
I/DEBUG ( 138): 763cf560 00000000 00000000 00001ff0 4158391c
I/DEBUG ( 138): 763cf570 415aa4d8 6d48e270 00000200 838ecc70
I/DEBUG ( 138): 763cf580 00000001 00000200 00000200 00000004
I/DEBUG ( 138): 763cf590 00000003 6ef3fa8c 6ef3fa96 00000001
I/DEBUG ( 138): 763cf5a0 6eea5c54 6d6667c0 00000000 00000000
I/DEBUG ( 138): 763cf5b0 00000000 00000000 00000000 16801ce5
I/DEBUG ( 138):
I/DEBUG ( 138): memory near fp:
I/DEBUG ( 138): 6f11075c 4c4a5604 5605004c 4c4c4c4a 4a560600
I/DEBUG ( 138): 6f11076c 4c4c4c4c 4a560300 5604005a 005a5a4a
I/DEBUG ( 138): 6f11077c 004c5602 424c5603 4c560400 04004242
I/DEBUG ( 138): 6f11078c 4c424c56 4c560300 56030043 0400444c
I/DEBUG ( 138): 6f11079c 4c444c56 4c560300 56040046 0046464c
I/DEBUG ( 138): 6f1107ac 464c5605 06004646 46464c56 09004646
I/DEBUG ( 138): 6f1107bc 46464c56 46464646 560b0046 4646464c
I/DEBUG ( 138): 6f1107cc 46464646 05004646 46464c56 5605004c
I/DEBUG ( 138): 6f1107dc 5a46464c 4c560600 4c5a4646 4c560600
I/DEBUG ( 138): 6f1107ec 49494946 4c560500 004c4c46 464c5604
I/DEBUG ( 138): 6f1107fc 5603005a 0400494c 46494c56 4c560500
I/DEBUG ( 138): 6f11080c 00464649 494c5606 00464646 494c5607
I/DEBUG ( 138): 6f11081c 46464646 4c560900 46464649 00464646
I/DEBUG ( 138): 6f11082c 494c560c 46464646 46464646 56040046
I/DEBUG ( 138): 6f11083c 0049494c 494c5605 0a004649 49494c56
I/DEBUG ( 138): 6f11084c 49494646 07004c5a 49494c56 004c4646
I/DEBUG ( 138):
I/DEBUG ( 138): memory near sp:
I/DEBUG ( 138): 77e4bbd8 34373031 36333231 77e4bc54 00000000
I/DEBUG ( 138): 77e4bbe8 00000000 34313833 00004000 77e4bc62
I/DEBUG ( 138): 77e4bbf8 00000006 0000000b 00005c6e 00000000
I/DEBUG ( 138): 77e4bc08 00000000 4005009d 00000006 00000000
I/DEBUG ( 138): 77e4bc18 4157ec74 400502b1 77e4bc2c 4004efe7
I/DEBUG ( 138): 77e4bc28 00000000 ffffffdf 400872c4 4008722c
I/DEBUG ( 138): 77e4bc38 00000000 40051ba7 415831f0 415831f0
I/DEBUG ( 138): 77e4bc48 763cf4d0 4005e900 00000000 41519ccb
I/DEBUG ( 138): 77e4bc58 40095324 6c756e28 0000296c 00000000
I/DEBUG ( 138): 77e4bc68 00000000 00000000 00000000 00000000
I/DEBUG ( 138): 77e4bc78 00000000 00000000 00000000 00000000
I/DEBUG ( 138): 77e4bc88 00000000 00000000 00000000 00000000
I/DEBUG ( 138): 77e4bc98 00000000 00000000 00000000 00000000
I/DEBUG ( 138): 77e4bca8 00000000 00000000 00000000 00000000
I/DEBUG ( 138): 77e4bcb8 00000000 00000000 00000000 00000000
I/DEBUG ( 138): 77e4bcc8 00000000 00000000 00000000 00000000
I/DEBUG ( 138):
I/DEBUG ( 138): code around pc:
I/DEBUG ( 138): 4005f028 e8bd00f0 e3700a01 912fff1e e2600000
I/DEBUG ( 138): 4005f038 ea006e40 e92d50f0 e3a07f43 ef000000
I/DEBUG ( 138): 4005f048 e8bd50f0 e3700a01 912fff1e e2600000
I/DEBUG ( 138): 4005f058 ea006e38 e92d50f0 e3a070ee ef000000
I/DEBUG ( 138): 4005f068 e8bd50f0 e3700a01 912fff1e e2600000
I/DEBUG ( 138): 4005f078 ea006e30 f200429a bf0080cf f000f891
I/DEBUG ( 138): 4005f088 4001e92d f040f891 d3532a10 0301ea80
I/DEBUG ( 138): 4005f098 0303f013 806ef000 d3262ae0 0300f1c0
I/DEBUG ( 138): 4005f0a8 030ff013 eba2d021 ea5f0203 bf447cc3
I/DEBUG ( 138): 4005f0b8 eb01f811 eb01f800 f811bf21 f811cb01
I/DEBUG ( 138): 4005f0c8 f800eb01 f800cb01 ea5feb01 da037c43
I/DEBUG ( 138): 4005f0d8 080df9a1 083df980 f921d303 f900070d
I/DEBUG ( 138): 4005f0e8 f891071d f891f000 3a40f040 f891d30f
I/DEBUG ( 138): 4005f0f8 f891f080 f921f0c0 f921020d f891420d
I/DEBUG ( 138): 4005f108 3a40f0c0 020df900 420df900 f102d2f3
I/DEBUG ( 138): 4005f118 3a200240 f921d305 3a20020d 020df900
I/DEBUG ( 138):
I/DEBUG ( 138): code around lr:
I/DEBUG ( 138): 4005007c 447b4b13 42b3e010 6a1ed10e 44784811
I/DEBUG ( 138): 4005008c ec84f7fb ea0ef00d 46224631 efd0f00e
I/DEBUG ( 138): 4005009c d00a3001 e00b2400 2b00681b 480ad1eb
I/DEBUG ( 138): 400500ac 44782403 ec72f7fb f001e002 6804fa23
I/DEBUG ( 138): 400500bc fa20f001 46206005 bf00bd70 0003b326
I/DEBUG ( 138): 400500cc 0003b31a 0003b312 0003b2ee bf7ef7ff
I/DEBUG ( 138): 400500dc 4a3e4b3d e92d447b b08b43f0 4606589c
I/DEBUG ( 138): 400500ec 6823460d 930946a1 fa04f001 8000f8d0
I/DEBUG ( 138): 400500fc d0482d00 f00f4628 280ffe91 d8444604
I/DEBUG ( 138): 4005010c ffe4f7ff d1064286 4629200f e8d8f00d
I/DEBUG ( 138): 4005011c d03c2800 482ee02e f7fb4478 482debb6
I/DEBUG ( 138): 4005012c e0154478 d11342b0 482b6a06 f7fb4478
I/DEBUG ( 138): 4005013c 4a2aec2e 46332120 a801447a f9b2f013
I/DEBUG ( 138): 4005014c a8012101 fcccf01a 46061c42 e011d104
I/DEBUG ( 138): 4005015c 28006800 e02cd1e6 46294630 f00d4622
I/DEBUG ( 138): 4005016c 1c43e914 d11e4607 f9c4f001 29046801
--------- beginning of /dev/log/system
I/BootReceiver( 470): Copying /data/tombstones/tombstone_01 to DropBox (SYSTEM_TOMBSTONE)
W/gralloc ( 140): Debugmem The fd=71, in vmalloc !!! Ishwc=0
W/ActivityManager( 470): Force finishing activity com.embarcadero.C3DPlayer/com.embarcadero.firemonkey.FMXNativeActivity
D/Zygote ( 141): Process 23649 terminated by signal (6)
I/ActivityManager( 470): Process com.embarcadero.C3DPlayer (pid 23649) has died.
I/WindowState( 470): WIN DEATH: Window{41d5d1e8 u0 com.embarcadero.C3DPlayer/com.embarcadero.firemonkey.FMXNativeActivity}
D/mali_winsys( 679): new_window_surface returns 0x3000
W/gralloc ( 140): Debugmem The fd=43, in vmalloc !!! Ishwc=0
W/gralloc ( 140): Debugmem The fd=54, in vmalloc !!! Ishwc=0
W/gralloc ( 140): Debugmem The fd=38, in vmalloc !!! Ishwc=0
W/gralloc ( 140): Debugmem The fd=39, in vmalloc !!! Ishwc=0
D/AudioHardwareALSA( 143): AudioStreamOutALSA::standby()…
补充一下,官方安卓4.4的最新系统,刚刚又试了一下5.1的,5.1的没有问题,好像这个4.4的是tv-box的版本? 是少了什么的原因吗?
