Android5.1.1启动问题
新买回的firefly-rk3288开发板,烧入最新的Android5.1.1编译的固件,一直卡在Android字符界面,进不了桌面,各位版主帮忙分析一下启动log信息。
[ 2.338220] ======== PULL WL_REG_ON LOW! ========
[ 2.338228] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2.346816] arm_release_ver of this mali_ko is ‘r6p0-02rel0’, rk_ko_ver is ‘13’, built at ‘09:15:10’, on ‘Oct 22 2015’.
[ 2.346900] mali ffa30000.gpu: Continuing without Mali clock control
[ 2.346942] mali pd enabled
[ 2.346955] clk enabled
[ 2.346968] MALI_DVFS_STEP = 4, div_dvfs = 10
[ 2.346978] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
[ 2.346988] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
[ 2.346998] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
[ 2.347008] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
[ 2.347111] turn on mali power
[ 2.347125] kbase_platform_rk_init,register_reboot_notifier
[ 2.347168] hrtimer: interrupt took 11959 ns
[ 2.347273] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 2.348078] mali ffa30000.gpu: Probed as mali0
[ 2.349118] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.349732] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.350356] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.351142] zram0: detected capacity change from 0 to 533413888
[ 2.398062] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 2.422039] EXT4-fs (mmcblk0p12): Unrecognized mount option “background_gc=on” or missing value
[ 2.428887] bat_cap: oldcap path is /sys/devices/ff100000.adc
[ 2.428939] bat_cap: oldcap_path no exist
[ 2.429094] binder: 156:156 transaction failed 29189, size 0-0
[ 2.429630] init: Warning! Service displayd needs a SELinux domain defined; please fix!
[ 2.433472] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 2.433504] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 2.433730] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 2.434271] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.434290] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.434306] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.434316] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.434339] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.434349] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.434364] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.434374] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.438710] [WLAN_RFKILL]: wifi shut off power.
[ 2.438727] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 2.438734] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 2.438795] 0,baud is:9600
[ 2.438802] dhd_module_init: Exit err=0
[ 2.438922] 1, baud is:115200
[ 2.439069] 1, baud is:115200
[ 2.439159] 0,baud is:9600
[ 2.443338] 2, baud is:115200
[ 2.443897] android_usb: already disabled
[ 2.446128] read descriptors
[ 2.446141] read strings
[ 2.446171] pcd_pullup, is_on 1
[ 2.497678] logd.auditd: start
[ 2.516211] firefly_vga_get_enable 180, 1
[ 2.516334] firefly_vga_get_status 186
[ 2.516922] firefly_vga_set_mode 203
[ 2.517499] firefly_vga_set_enable 159 enable:1
[ 2.792931] EHCI: rk_ehci_hcd_enable, disable host controller
[ 2.792939] dwc_otg_hcd_enable, enable host controller
[ 2.823286] rk3288-lcdc lcdc0: blank mode:0
[ 2.896677] Using Buffer DMA mode
[ 2.896689] Periodic Transfer Interrupt Enhancement - disabled
[ 2.896694] Multiprocessor Interrupt Enhancement - disabled
[ 2.896700] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.896705] ^^^^^^^^^^^^^^^^^^Host Mode
[ 2.940616] Init: Power Port (0)
[ 3.255433] Indeed it is in host mode hprt0 = 00021501
[ 3.413597] healthd: No charger supplies found
[ 3.413610] healthd: No battery devices found
[ 3.432545] usb 3-1: new high-speed USB device number 2 using usb20_host
[ 3.432611] Indeed it is in host mode hprt0 = 00001101
[ 3.629539] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 3.629550] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.629557] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 3.630136] hub 3-1:1.0: USB hub found
[ 3.630191] hub 3-1:1.0: 4 ports detected
[ 3.904948] usb 3-1.1: new low-speed USB device number 3 using usb20_host
[ 4.007217] usb 3-1.1: New USB device found, idVendor=093a, idProduct=2510
[ 4.007228] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.007235] usb 3-1.1: Product: USB Optical Mouse
[ 4.007241] usb 3-1.1: Manufacturer: PixArt
[ 4.010535] input: PixArt USB Optical Mouse as /devices/ff540000.usb/usb3/3-1/3-1.1/3-1.1:1.0/input/input3
[ 4.011296] hid-generic 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-ff540000.usb-1.1/input0
shell@firefly:/ $ [ 8.696950] [otg id chg] last id -1 current id 1
[ 8.696973] PortPower off
[ 8.696980] rk_battery_charger_detect_cb , battery_charger_detect 6
[ 8.796403] Using Buffer DMA mode
[ 8.796419] Periodic Transfer Interrupt Enhancement - disabled
[ 8.796425] Multiprocessor Interrupt Enhancement - disabled
[ 8.796432] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 8.796438] ^^^^^^^^^^^^^^^^^Device Mode
[ 8.894272] es8323_mic_state_ctrl read: 0
[ 8.894289] mic_state_switch 0
[ 8.894297] hp_det = 0,insert hp
[ 8.894301] hp mic use intern
[ 9.287339] vbus detect**
[ 9.289528] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 9.466583] Using Buffer DMA mode
[ 9.466600] Periodic Transfer Interrupt Enhancement - disabled
[ 9.466607] Multiprocessor Interrupt Enhancement - disabled
[ 9.466614] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 9.466620] ^^^^^^^^^^^^^^^^^Device Mode
[ 9.466660] soft connect!!!
[ 9.584171] USB RESET
[ 9.621746] android_work: sent uevent USB_STATE=CONNECTED
[ 9.625342] USB RESET
[ 9.698655] android_usb gadget: high-speed config #1: android
[ 9.698760] android_work: sent uevent USB_STATE=CONFIGURED
请试一下升级官方固件试试
http://developer.t-firefly.com/thread-11202-1-1.html
日志没有发全把
成功了没?我也遇到这样的问题,代码拉下来,按照教程一步一步来的,进不鸟桌面,烧的img有问题
可能是parameter参数有问题,你参考官方的文件
你说的官方文件在哪里?是从官方固件里解压出来吗?
嗯,官方固件解压的parameter
你好,parameter参数不能修改吗?如果想增加内存的话只有修改parameter参数吧
xujin071 发表于 2017-1-17 17:39
嗯,官方固件解压的parameter
兄弟,烧写官方的固件是OK。直接用解压出来的parameter文件,打包自己源码编译出来的镜像,烧写的时候总是出现图上面的情况?
这个怎么解,忘大神赐教或者你这边有打包统一固件的工具么?多谢!
最近买的板子吧,更新最新的代码试试:
danielfirefly 发表于 2017-1-18 16:33
兄弟,烧写官方的固件是OK。直接用解压出来的parameter文件,打包自己源码编译出来的镜像,烧写的时候总 …
我这边用最新的Android5.1的代码没问题。
那你把官方的固件解压,逐个替换解压文件,看看问题出在哪
你直接用最新代码里的RKTool里的工具?都没用官方固件解压出来的文件替换吗?
没用RKTool里面的,就parameter参照官方固件里的
兄弟,你能把你的parameter文件给我看下么,多谢
FIRMWARE_VER:5.0.0
MACHINE_MODEL:rk3288
MACHINE_ID:007
MANUFACTURER:RK3288
MAGIC: 0x5041524B
ATAG: 0x60000800
MACHINE: 3288
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
#KERNEL_IMG: 0x62008000
#FDT_NAME: rk-kernel.dtb
#RECOVER_KEY: 1,1,0,20,0
CMDLINE:console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),0x00200000@0x0039C000(userdata),0x00020000@0x0059C000(radical_update),-@0x005BC000(user)
我这里也出现了
好像没结论?
fireprime 的代码
commit 55e39966ed00355420368deb3ab3a7a78303a14b
Author: lkd <service@t-firefly.com>
Date: Fri Sep 30 11:35:59 2016 +0800
kernel->codec: adjust output volume perfect
commit 54fc822ab7d3c40a1421d01682fe70875574f070
fengmushu 发表于 2017-4-1 12:46
我这里也出现了
好像没结论?
你用RKTOOLS下面的工具试试,出现过用旧版本工具升级失败的
