DVP接口配置问题咨询
目前我们调试了3288在Linux下的cif摄像头。但遇到数据管脚设置不对应的问题,特此求教:
设备树中,
cif: cif@ff950000 {
compatible = “rockchip,cif”;
reg = <0xff950000 0x10000>;
interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&pd_isp>,<&clk_gates15 14>,<&clk_gates15 15>,<&clkin_cif>,<&clk_gates16 0>,<&clk_cif_out>;
clock-names = “pd_cif0”, “aclk_cif0”,“hclk_cif0”,“cif0_in”,“g_pclkin_cif”,“cif0_out”;
pinctrl-names = “cif_pin_jpe”;
pinctrl-0 = <&isp_dvp_d0d7>;
status = “okay”;
isp_dvp_d0d7:isp_d0d7 {
rockchip,pins = <CIF_DATA0>,<CIF_DATA1>,
<CIF_DATA2>,<CIF_DATA3>,
<CIF_DATA4>,<CIF_DATA5>,
<CIF_DATA6>,<CIF_DATA7>,
<CIF_VSYNC>,<CIF_HREF>,
<CIF_CLKIN>,<CIF_CLKOUT>;
rockchip,pull = <VALUE_PULL_DISABLE>;
rockchip,drive = <VALUE_DRV_DEFAULT>;
//rockchip,tristate = <VALUE_TRI_DEFAULT>;
这样描述了硬件资源。但采集相机数据的时候发现,采集到的数永远是CIF_DATA[9:2],其管脚2-9中在设备树中定义状态的都能正常采集,没有定义的永远是管脚默认值0或1。请问大神们这个设置采集数据管脚是在什么地方设置?
还有DVP中的这些寄存器都是什么意思?
[ 128.383655] rk_cam_cif(2744):CIF_CIF_CTRL = 0xf001
[ 128.388360] rk_cam_cif(2745):CIF_CIF_INTEN = 0x201
[ 128.393065] rk_cam_cif(2746):CIF_CIF_INTSTAT = 0x103
[ 128.397953] rk_cam_cif(2747):CIF_CIF_FOR = 0x0
[ 128.402319] rk_cam_cif(2748):CIF_CIF_CROP = 0x0
[ 128.412080] rk_cam_cif(2750):CIF_CIF_SCL_CTRL = 0x10
[ 128.416963] rk_cam_cif(2751):CRU_PCLK_REG30 = 0X0
[ 128.437422] rk_cam_cif(2756):CIF_CIF_LINE_NUM_ADDR = 0X0
[ 128.464385] rk_cam_cif(2761):CIF_CIF_CUR_DST = 0X1f2ea5e0
请问,你这个cif配置信息是从哪里参考来的?能有效采到图吗?
楼主,问题出在哪里了,。我也在弄这个
我要开始灌水了
._Xbc5c 发表于 2021-8-16 18:24
我要开始灌水了
同上
