rk3288在Android5.1上用OV13850 进入相机是黑屏
按照firefly-rk3288教程在ubuntu14.04上编译Android5.1固件以及MIPI CSI使用,
最后结果是进入相机是黑屏的,中间有个相机图像。
下面试启动android并进入相机的log信息,请大神分析一下可能存在的问题。
--------- beginning of system
E/DrmService(    0): ----------------running drmservice---------------
E/DrmService(    0): ------------ set_iface ----------------
I/Vold    (  155): Vold 2.1 (the revenge) firing up
E/Vold    (  155): Volume::Volume mDiskVolumeLabel = USB_DISK0
E/Vold    (  155): Volume::Volume mLabel = internal_sd
D/Vold    (  155): Volume internal_sd state changing -1 (Initializing) -> 0 (No-Media)
E/Vold    (  155): label internal_sd addPath /devices/ff0f0000.rksdmmc/mmc_host/mmc
E/Vold    (  155): Volume::Volume mLabel = external_sd
I/Vold    (  155): Error(call No.1) opening /sys/sd-sdio/rescan in the file of Volume.cpp
D/Vold    (  155): Volume external_sd state changing -1 (Initializing) -> 0 (No-Media)
E/Vold    (  155): label external_sd addPath /devices/ff0c0000.rksdmmc/mmc_host/mmc
E/Vold    (  155): Volume::Volume mLabel = usb_storage
D/Vold    (  155): Volume usb_storage state changing -1 (Initializing) -> 0 (No-Media)
E/Vold    (  155): label usb_storage addPath /devices/ff580000.usb
E/Vold    (  155): Volume::Volume mDiskVolumeLabel = USB_DISK1
E/Vold    (  155): label usb_storage addPath /devices/ff500000.usb
E/Vold    (  155): Volume::Volume mDiskVolumeLabel = USB_DISK2
E/Vold    (  155): label usb_storage addPath /devices/ff540000.usb
E/Vold    (  155): Volume::Volume mDiskVolumeLabel = USB_DISK3
E/Vold    (  155): Volume::Volume mDiskVolumeLabel = USB_DISK4
E/Vold    (  155): Volume::Volume mDiskVolumeLabel = USB_DISK5
E/Vold    (  155): Start Misc devices Manager...
D/Vold    (  155): Vendor path: /sys/bus/usb/devices/1-1/idVendor
D/Vold    (  155): === config_file is: 0000_0000
D/DirectVolume(  155): DEVPATH = /devices/virtual/block/loop0.
D/DirectVolume(  155): DEVPATH = /devices/virtual/block/loop1.
D/DirectVolume(  155): DEVPATH = /devices/virtual/block/loop2.
D/DirectVolume(  155): DEVPATH = /devices/virtual/block/loop3.
D/DirectVolume(  155): DEVPATH = /devices/virtual/block/loop4.
D/DirectVolume(  155): DEVPATH = /devices/virtual/block/loop5.
D/DirectVolume(  155): DEVPATH = /devices/virtual/block/loop6.
D/DirectVolume(  155): DEVPATH = /devices/virtual/block/loop7.
D/DirectVolume(  155): DEVPATH = /devices/virtual/block/zram0.
D/DirectVolume(  155): DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0.
W/DirectVolume(  155): Deprecated implied prefix pattern detected, please use '/devices/ff0f0000.rksdmmc/mmc_host/mmc*' instead
D/DirectVolume(  155): DEVTYPE = disk.
D/DirectVolume(  155): getLabel = internal_sd,devtype = disk,getDevPath = (null).
D/DirectVolume(  155): ----handleDiskAdded,mDiskNumParts =15,mDiskMajor=179,mDiskMinor=0
D/DirectVolume(  155): Dv::diskIns - waiting for 15 pending partitions
D/Vold    (  155): Volume internal_sd state changing 0 (No-Media) -> 2 (Pending)
D/DirectVolume(  155): DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p1.
D/DirectVolume(  155): DEVTYPE = partition.
D/DirectVolume(  155): getLabel = internal_sd,devtype = partition,getDevPath = (null).
D/DirectVolume(  155): ---handlePartitionAdded,part_num=1,major=179,minor=1,mDiskMajor=179
D/DirectVolume(  155): Dv:partAdd: part_num = 1, minor = 1
D/DirectVolume(  155): Dv:partAdd: pending 14 disk
D/DirectVolume(  155): DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p2.
D/DirectVolume(  155): ---handlePartitionAdded,part_num=2,major=179,minor=2,mDiskMajor=179
D/DirectVolume(  155): Dv:partAdd: part_num = 2, minor = 2
D/DirectVolume(  155): Dv:partAdd: pending 13 disk
D/DirectVolume(  155): DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p3.
D/DirectVolume(  155): ---handlePartitionAdded,part_num=3,major=179,minor=3,mDiskMajor=179
D/DirectVolume(  155): Dv:partAdd: part_num = 3, minor = 3
D/DirectVolume(  155): Dv:partAdd: pending 12 disk
D/DirectVolume(  155): DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p4.
D/DirectVolume(  155): ---handlePartitionAdded,part_num=4,major=179,minor=4,mDiskMajor=179
D/DirectVolume(  155): Dv:partAdd: part_num = 4, minor = 4
D/DirectVolume(  155): Dv:partAdd: pending 11 disk
D/DirectVolume(  155): DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p5.
D/DirectVolume(  155): ---handlePartitionAdded,part_num=5,major=179,minor=5,mDiskMajor=179
D/DirectVolume(  155): Dv:partAdd: part_num = 5, minor = 5
D/DirectVolume(  155): Dv:partAdd: pending 10 disk
D/DirectVolume(  155): DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p6.
D/DirectVolume(  155): ---handlePartitionAdded,part_num=6,major=179,minor=6,mDiskMajor=179
D/DirectVolume(  155): Dv:partAdd: part_num = 6, minor = 6
D/DirectVolume(  155): Dv:partAdd: pending 9 disk
D/DirectVolume(  155): DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p7.
D/DirectVolume(  155): ---handlePartitionAdded,part_num=7,major=179,minor=7,mDiskMajor=179
D/DirectVolume(  155): Dv:partAdd: part_num = 7, minor = 7
D/DirectVolume(  155): Dv:partAdd: pending 8 disk
D/DirectVolume(  155): DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p8.
D/DirectVolume(  155): ---handlePartitionAdded,part_num=8,major=179,minor=8,mDiskMajor=179
D/DirectVolume(  155): Dv:partAdd: part_num = 8, minor = 8
D/DirectVolume(  155): Dv:partAdd: pending 7 disk
D/DirectVolume(  155): DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p9.
D/DirectVolume(  155): ---handlePartitionAdded,part_num=9,major=179,minor=9,mDiskMajor=179
D/DirectVolume(  155): Dv:partAdd: part_num = 9, minor = 9
D/DirectVolume(  155): Dv:partAdd: pending 6 disk
D/DirectVolume(  155): DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p10.
D/DirectVolume(  155): ---handlePartitionAdded,part_num=10,major=179,minor=10,mDiskMajor=179
D/DirectVolume(  155): Dv:partAdd: part_num = 10, minor = 10
D/DirectVolume(  155): Dv:partAdd: pending 5 disk
D/DirectVolume(  155): DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p11.
D/DirectVolume(  155): ---handlePartitionAdded,part_num=11,major=179,minor=11,mDiskMajor=179
D/DirectVolume(  155): Dv:partAdd: part_num = 11, minor = 11
D/DirectVolume(  155): Dv:partAdd: pending 4 disk
D/DirectVolume(  155): DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p12.
D/DirectVolume(  155): ---handlePartitionAdded,part_num=12,major=179,minor=12,mDiskMajor=179
D/DirectVolume(  155): Dv:partAdd: part_num = 12, minor = 12
D/DirectVolume(  155): Dv:partAdd: pending 3 disk
D/DirectVolume(  155): DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p13.
D/DirectVolume(  155): ---handlePartitionAdded,part_num=13,major=179,minor=13,mDiskMajor=179
D/DirectVolume(  155): Dv:partAdd: part_num = 13, minor = 13
D/DirectVolume(  155): Dv:partAdd: pending 2 disk
D/DirectVolume(  155): DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p14.
D/DirectVolume(  155): ---handlePartitionAdded,part_num=14,major=179,minor=14,mDiskMajor=179
D/DirectVolume(  155): Dv:partAdd: part_num = 14, minor = 14
D/DirectVolume(  155): Dv:partAdd: pending 1 disk
D/DirectVolume(  155): DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p15.
D/DirectVolume(  155): ---handlePartitionAdded,part_num=15,major=179,minor=15,mDiskMajor=179
D/DirectVolume(  155): Dv:partAdd: part_num = 15, minor = 15
D/DirectVolume(  155): Dv:partAdd: Got all partitions - ready to rock!
D/Vold    (  155): Volume internal_sd state changing 2 (Pending) -> 1 (Idle-Unmounted)
E/DrmService(  165): [wlan0] interface is up
W/Vold    (  155): subsystem found in netlink event
D/Vold    (  155): usb, 1
D/Vold    (  155): == current usb device: 1A40/0101 ===
E/DrmService(  165): [wlan0] interface is down
D/Vold    (  155): == current usb device: 093A/2510 ===
E/DrmService(  165): -------------generate_device_serialno,len =10,result=2IMFESC8YF
E/DrmService(  165): auto generate serialno,serialno = 2IMFESC8YF
E/DrmService(  165): rknand_sys_storage open fail
E/DrmService(  165): detect keybox disabled
--------- beginning of main
W/Resources(  166): Preloaded drawable resource #0x10805d2 (android:drawable/scrollbar_handle_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10805d3 (android:drawable/scrollbar_handle_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080634 (android:drawable/spinner_disabled_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080642 (android:drawable/spinner_pressed_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108063a (android:drawable/spinner_focused_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108062f (android:drawable/spinner_default_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080628 (android:drawable/spinner_background_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080636 (android:drawable/spinner_disabled_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080644 (android:drawable/spinner_pressed_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108063c (android:drawable/spinner_focused_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080631 (android:drawable/spinner_default_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080629 (android:drawable/spinner_background_holo_light) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 534(55KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1601KB/2MB, paused 104us total 5.114ms
W/Resources(  166): Preloaded drawable resource #0x1080614 (android:drawable/spinner_ab_default_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080616 (android:drawable/spinner_ab_default_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080618 (android:drawable/spinner_ab_disabled_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108061a (android:drawable/spinner_ab_disabled_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108061c (android:drawable/spinner_ab_focused_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108061e (android:drawable/spinner_ab_focused_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080622 (android:drawable/spinner_ab_pressed_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080624 (android:drawable/spinner_ab_pressed_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080620 (android:drawable/spinner_ab_holo_dark) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 634(57KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1609KB/2MB, paused 103us total 5.182ms
W/Resources(  166): Preloaded drawable resource #0x1080621 (android:drawable/spinner_ab_holo_light) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 501(59KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1602KB/2MB, paused 105us total 5.112ms
W/Resources(  166): Preloaded drawable resource #0x108026f (android:drawable/cab_background_bottom_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080274 (android:drawable/cab_background_top_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080270 (android:drawable/cab_background_bottom_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080330 (android:drawable/ic_cab_done_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080273 (android:drawable/cab_background_top_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080331 (android:drawable/ic_cab_done_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800d5 (android:drawable/btn_cab_done_default_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800d8 (android:drawable/btn_cab_done_focused_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800d6 (android:drawable/btn_cab_done_default_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800dd (android:drawable/btn_cab_done_pressed_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800d7 (android:drawable/btn_cab_done_focused_holo_dark) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 483(54KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1598KB/2MB, paused 104us total 5.091ms
W/Resources(  166): Preloaded drawable resource #0x10800de (android:drawable/btn_cab_done_pressed_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10804a3 (android:drawable/list_pressed_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800da (android:drawable/btn_cab_done_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10804a2 (android:drawable/list_pressed_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800d9 (android:drawable/btn_cab_done_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080038 (android:drawable/ic_menu_close_clear_cancel) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10803d6 (android:drawable/ic_menu_copy_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10803d7 (android:drawable/ic_menu_copy_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10803da (android:drawable/ic_menu_cut_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10803db (android:drawable/ic_menu_cut_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080045 (android:drawable/ic_menu_more) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 470(51KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1600KB/2MB, paused 103us total 5.067ms
W/Resources(  166): Preloaded drawable resource #0x10803f2 (android:drawable/ic_menu_moreoverflow_normal_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10803ef (android:drawable/ic_menu_moreoverflow_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10803f3 (android:drawable/ic_menu_moreoverflow_normal_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10803f0 (android:drawable/ic_menu_moreoverflow_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10803f6 (android:drawable/ic_menu_paste_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10803f7 (android:drawable/ic_menu_paste_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080400 (android:drawable/ic_menu_selectall_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10803ff (android:drawable/ic_menu_selectall_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080335 (android:drawable/ic_clear_disabled) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108033a (android:drawable/ic_clear_normal) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080334 (android:drawable/ic_clear) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 377(49KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1608KB/2MB, paused 102us total 5.038ms
W/Resources(  166): Preloaded drawable resource #0x1080433 (android:drawable/ic_search_api_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080434 (android:drawable/ic_search_api_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080363 (android:drawable/ic_go) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080442 (android:drawable/ic_voice_search_api_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080443 (android:drawable/ic_voice_search_api_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080290 (android:drawable/dialog_bottom_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080291 (android:drawable/dialog_bottom_holo_light) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 276(48KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1614KB/2MB, paused 128us total 6.136ms
W/Resources(  166): Preloaded drawable resource #0x1080295 (android:drawable/dialog_full_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080296 (android:drawable/dialog_full_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108029e (android:drawable/dialog_middle_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108029f (android:drawable/dialog_middle_holo_light) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 158(46KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1617KB/2MB, paused 128us total 5.998ms
W/Resources(  166): Preloaded drawable resource #0x10802a0 (android:drawable/dialog_top_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10802a1 (android:drawable/dialog_top_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080351 (android:drawable/ic_dialog_alert_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080352 (android:drawable/ic_dialog_alert_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080496 (android:drawable/list_divider_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080497 (android:drawable/list_divider_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800c1 (android:drawable/ab_transparent_dark_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800bf (android:drawable/ab_stacked_transparent_dark_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800a1 (android:drawable/ab_bottom_transparent_dark_holo) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 247(57KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1611KB/2MB, paused 129us total 6.020ms
W/Resources(  166): Preloaded drawable resource #0x10800b7 (android:drawable/ab_solid_dark_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800bc (android:drawable/ab_stacked_solid_dark_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108009e (android:drawable/ab_bottom_solid_dark_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800c2 (android:drawable/ab_transparent_light_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800c0 (android:drawable/ab_stacked_transparent_light_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800a2 (android:drawable/ab_bottom_transparent_light_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800b8 (android:drawable/ab_solid_light_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800be (android:drawable/ab_stacked_solid_light_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800a0 (android:drawable/ab_bottom_solid_light_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800b9 (android:drawable/ab_solid_shadow_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10804c3 (android:drawable/list_selector_disabled_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10804a0 (android:drawable/list_longpressed_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10804c0 (android:drawable/list_selector_background_transition_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108049b (android:drawable/list_focused_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080454 (android:drawable/item_background_holo_dark) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 525(63KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1612KB/2MB, paused 127us total 6.346ms
W/Resources(  166): Preloaded drawable resource #0x10804c4 (android:drawable/list_selector_disabled_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10804a1 (android:drawable/list_longpressed_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10804c1 (android:drawable/list_selector_background_transition_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080455 (android:drawable/item_background_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10802f3 (android:drawable/fastscroll_thumb_pressed_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10802f0 (android:drawable/fastscroll_thumb_default_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10802f1 (android:drawable/fastscroll_thumb_holo) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 539(56KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1607KB/2MB, paused 127us total 6.123ms
W/Resources(  166): Preloaded drawable resource #0x10802f9 (android:drawable/fastscroll_track_pressed_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10802f4 (android:drawable/fastscroll_track_default_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10802f6 (android:drawable/fastscroll_track_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10802ea (android:drawable/fastscroll_label_left_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10802ed (android:drawable/fastscroll_label_right_holo_dark) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 307(41KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1630KB/2MB, paused 128us total 6.067ms
W/Resources(  166): Preloaded drawable resource #0x10802fa (android:drawable/fastscroll_track_pressed_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10802f5 (android:drawable/fastscroll_track_default_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10802f7 (android:drawable/fastscroll_track_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10802eb (android:drawable/fastscroll_label_left_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10802ee (android:drawable/fastscroll_label_right_holo_light) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 235(62KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1625KB/2MB, paused 130us total 6.020ms
W/Resources(  166): Preloaded drawable resource #0x10802cb (android:drawable/editbox_dropdown_background_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080740 (android:drawable/textfield_search_selected_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080732 (android:drawable/textfield_search_default_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080742 (android:drawable/textfield_searchview_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108073d (android:drawable/textfield_search_right_selected_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108073b (android:drawable/textfield_search_right_default_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080744 (android:drawable/textfield_searchview_right_holo_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080741 (android:drawable/textfield_search_selected_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080733 (android:drawable/textfield_search_default_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080743 (android:drawable/textfield_searchview_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108073e (android:drawable/textfield_search_right_selected_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108073c (android:drawable/textfield_search_right_default_holo_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080745 (android:drawable/textfield_searchview_right_holo_light) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 509(76KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1598KB/2MB, paused 128us total 6.141ms
W/Resources(  166): Preloaded drawable resource #0x10806fc (android:drawable/tab_unselected_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10806f7 (android:drawable/tab_selected_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10806fb (android:drawable/tab_unselected_focused_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10806f6 (android:drawable/tab_selected_focused_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10806fd (android:drawable/tab_unselected_pressed_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10806f8 (android:drawable/tab_selected_pressed_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10806e9 (android:drawable/tab_indicator_holo) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108059c (android:drawable/quickcontact_badge_overlay_pressed_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080593 (android:drawable/quickcontact_badge_overlay_focused_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080598 (android:drawable/quickcontact_badge_overlay_normal_dark) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080592 (android:drawable/quickcontact_badge_overlay_dark) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 676(45KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1604KB/2MB, paused 128us total 6.173ms
W/Resources(  166): Preloaded drawable resource #0x108059e (android:drawable/quickcontact_badge_overlay_pressed_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080595 (android:drawable/quickcontact_badge_overlay_focused_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108059a (android:drawable/quickcontact_badge_overlay_normal_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080597 (android:drawable/quickcontact_badge_overlay_light) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800b5 (android:drawable/ab_share_pack_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800ba (android:drawable/ab_solid_shadow_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800db (android:drawable/btn_cab_done_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10800e5 (android:drawable/btn_check_material_anim) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 980(61KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1775KB/2MB, paused 133us total 6.477ms
W/Resources(  166): Preloaded drawable resource #0x10801a1 (android:drawable/btn_radio_material_anim) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 955(205KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1756KB/2MB, paused 111us total 5.590ms
W/Resources(  166): Preloaded drawable resource #0x1080215 (android:drawable/btn_star_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080248 (android:drawable/btn_toggle_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080271 (android:drawable/cab_background_bottom_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080275 (android:drawable/cab_background_top_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108028f (android:drawable/dialog_background_shadow_material) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 527(170KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1679KB/2MB, paused 108us total 5.409ms
W/Resources(  166): Preloaded drawable resource #0x10802c8 (android:drawable/edit_text_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10802e4 (android:drawable/expander_group_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080344 (android:drawable/ic_commit_search_api_material) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 679(97KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1634KB/2MB, paused 109us total 5.396ms
W/Resources(  166): Preloaded drawable resource #0x108035c (android:drawable/ic_find_next_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080360 (android:drawable/ic_find_previous_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10803b0 (android:drawable/ic_media_route_connecting_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10803b6 (android:drawable/ic_media_route_material) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 565(40KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1673KB/2MB, paused 104us total 5.333ms
W/Resources(  166): Preloaded drawable resource #0x10803e2 (android:drawable/ic_menu_find_material) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 1244(97KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1627KB/2MB, paused 103us total 5.186ms
W/Resources(  166): Preloaded drawable resource #0x10803fd (android:drawable/ic_menu_search_material) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 1518(55KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1639KB/2MB, paused 105us total 5.214ms
I/art     (  166): Explicit concurrent mark sweep GC freed 1386(51KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1643KB/2MB, paused 103us total 5.202ms
W/Resources(  166): Preloaded drawable resource #0x1080499 (android:drawable/list_divider_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10804a6 (android:drawable/list_section_divider_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108056a (android:drawable/progress_horizontal_material) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 1523(61KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1682KB/2MB, paused 107us total 6.492ms
W/Resources(  166): Preloaded drawable resource #0x10805c0 (android:drawable/ratingbar_full_empty_material) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 684(32KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1718KB/2MB, paused 106us total 5.434ms
W/Resources(  166): Preloaded drawable resource #0x10805c4 (android:drawable/ratingbar_full_filled_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10805c7 (android:drawable/ratingbar_full_material) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 411(40KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1766KB/2MB, paused 106us total 5.331ms
W/Resources(  166): Preloaded drawable resource #0x10805df (android:drawable/scrubber_control_material_anim) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10805e7 (android:drawable/scrubber_control_selector_material) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 367(96KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1725KB/2MB, paused 106us total 5.364ms
W/Resources(  166): Preloaded drawable resource #0x10805f2 (android:drawable/scrubber_progress_horizontal_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108062a (android:drawable/spinner_background_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080647 (android:drawable/spinner_textfield_background_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10806bb (android:drawable/switch_thumb_material_anim) that varies with configuration!!
I/art     (  166): Explicit concurrent mark sweep GC freed 880(60KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1817KB/2MB, paused 105us total 5.579ms
W/Resources(  166): Preloaded drawable resource #0x10806c0 (android:drawable/switch_track_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x10806ea (android:drawable/tab_indicator_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080701 (android:drawable/text_cursor_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080739 (android:drawable/textfield_search_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x1080707 (android:drawable/text_select_handle_left_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108070a (android:drawable/text_select_handle_middle_material) that varies with configuration!!
W/Resources(  166): Preloaded drawable resource #0x108070d (android:drawable/text_select_handle_right_material) that varies with configuration!!
I/Zygote  (  166): ...preloaded 343 resources in 628ms.
I/art     (  166): Explicit concurrent mark sweep GC freed 1207(157KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1719KB/2MB, paused 107us total 5.523ms
I/Zygote  (  166): ...preloaded 41 resources in 10ms.
I/art     (  166): Counter: 0
D/libEGL  (  166): loaded /vendor/lib/egl/libGLES_mali.so
I/Zygote  (  166): Preloading shared libraries...
D/Zygote  (  166): end preload
I/art     (  166): Explicit concurrent mark sweep GC freed 581(39KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1718KB/2MB, paused 104us total 5.504ms
I/art     (  166): Explicit concurrent mark sweep GC freed 389(16KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1702KB/2MB, paused 104us total 5.243ms
I/art     (  166): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 40% free, 1702KB/2MB, paused 107us total 5.480ms
I/Zygote  (  166): System server process 620 has been created
I/Zygote  (  166): Accepting command socket connections
I/InstallerConnection(  620): connecting...
I/installd(  163): new connection
I/dex2oat (  636): Error opening the directory: /system/lib/plugins
I/dex2oat (  636): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/services.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@services.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  636): Decided to run without swap.
E/sdcard  (  167): missing packages.list; retrying
I/dex2oat (  636): dex2oat took 3.014s (threads: 4) arena alloc=3MB java alloc=4MB native alloc=16MB free=1216KB
I/dex2oat (  641): Error opening the directory: /system/lib/plugins
I/dex2oat (  641): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/ethernet-service.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@ethernet-service.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  641): Decided to run without swap.
I/dex2oat (  641): dex2oat took 42.085ms (threads: 4) arena alloc=236KB java alloc=70KB native alloc=1190KB free=25KB
I/dex2oat (  646): Error opening the directory: /system/lib/plugins
I/dex2oat (  646): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/wifi-service.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@wifi-service.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  646): Decided to run without swap.
I/dex2oat (  646): dex2oat took 483.463ms (threads: 4) arena alloc=2001KB java alloc=889KB native alloc=4MB free=169KB
I/dex2oat (  651): Error opening the directory: /system/lib/plugins
I/dex2oat (  651): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/pppoe-service.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@pppoe-service.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  651): Decided to run without swap.
I/dex2oat (  651): dex2oat took 63.051ms (threads: 4) arena alloc=138KB java alloc=57KB native alloc=1175KB free=24KB
I/InstallerConnection(  620): disconnecting...
E/installd(  163): eof
E/installd(  163): failed to read size
I/installd(  163): closing connection
I/SystemServer(  620): Entered the Android system server!
V/Fingerprint-JNI(  620): FingerprintManager JNI ready.
D/SensorService(  620): nuSensorService starting...
V/Sensors (  620): int open_sensors(const hw_module_t*, const char*, hw_device_t**)
V/Sensors (  620): sensors_poll_context_t::sensors_poll_context_t()
E/Sensors (  620): could not open the mpu irq device node
E/Sensors (  620): could not open the accel irq device node
D/Sensors (  620): MPLSensor falling back to timerirq for accel data
I/MPL-mlsl(  620): inv_serial_open: /dev/mpu
I/Sensors (  620): InvenSense MPL v4.1.2 Engineering Dec 12 2016 16:50:33
E/        (  620): hardware/rockchip/sensor/mpu/mlsdk/./mllite/mldl_cfg_mpu.c|mldl_cfg_pull|457 returning 9
E/        (  620): hardware/rockchip/sensor/mpu/mlsdk/./mllite/mldl_cfg_mpu.c|inv_mpu_open|547 returning 9
E/        (  620): hardware/rockchip/sensor/mpu/mlsdk/./mllite/mldl.c|inv_dl_open|188 returning 9
E/        (  620): hardware/rockchip/sensor/mpu/mlsdk/./mllite/mldmp.c|inv_dmp_open|93 returning 9
E/Sensors (  620): Fatal Error : could not open DMP correctly.
E/MPL-mldl(  620): inv_set_mpu_memory : p_get_dmp_address is NULL
E/        (  620): hardware/rockchip/sensor/mpu/mlsdk/./mllite/mlFIFO.c|inv_send_accel|1077 returning 19
E/Sensors (  620): Fatal error: inv_send_accel returned 19
E/        (  620): hardware/rockchip/sensor/mpu/mlsdk/./mllite/mlFIFO.c|inv_send_quaternion|1363 returning 19
E/Sensors (  620): Fatal error: inv_send_quaternion returned 19
E/        (  620): hardware/rockchip/sensor/mpu/mlsdk/./mllite/mlFIFO.c|inv_send_gravity|1203 returning 19
E/        (  620): hardware/rockchip/sensor/mpu/mlsdk/./mllite/mlFIFO.c|inv_send_linear_accel|1286 returning 19
E/Sensors (  620): Fatal error: inv_send_linear_accel returned 19
E/        (  620): hardware/rockchip/sensor/mpu/mlsdk/./mllite/mlFIFO.c|inv_send_linear_accel_in_world|1317 returning 19
E/Sensors (  620): Fatal error: inv_send_linear_accel_in_world returned 19
E/Sensors (  620): Fatal error: inv_send_gravity returned 19
E/        (  620): hardware/rockchip/sensor/mpu/mlsdk/./mllite/mlFIFO.c|inv_send_gyro|1242 returning 19
E/Sensors (  620): Fatal error: inv_send_gyro returned 19
D/Sensors (  620): transform_for_pre_rotation 0x00000000 (ROT_0 , IDENTITY )
D/Sensors (  620): 1.0000  0.0000  0.0000
D/Sensors (  620): 0.0000  1.0000  0.0000
D/Sensors (  620): 0.0000  0.0000  1.0000
V/Sensors (  620): MPLSensor::getFd returning -1
V/Sensors (  620): MPLSensor::getAccelFd returning -1
V/Sensors (  620): MPLSensor::getTimerFd returning 21
E/Sensors (  620): couldn't find 'lightsensor-level' input device
V/Sensors (  620): MPLSensor::getPowerFd returning -1
V/Sensors (  620): int poll__activate(sensors_poll_device_t*, int, int)
V/Sensors (  620): int sensors_poll_context_t::activate(int, int)
V/Sensors (  620): enable - sensor RotationVector (handle 0) dis -> dis
V/Sensors (  620): enable - sensor LinearAccel (handle 1) dis -> dis
V/Sensors (  620): enable - sensor Gravity (handle 2) dis -> dis
V/Sensors (  620): enable - sensor Gyro (handle 3) dis -> dis
V/Sensors (  620): enable - sensor Accelerometer (handle 4) dis -> dis
V/Sensors (  620): enable - sensor MagneticField (handle 5) dis -> dis
V/Sensors (  620): enable - sensor Orientation (handle 6) dis -> dis
D/SensorService(  620): new thread SensorEventAckReceiver
D/SensorService(  620): nuSensorService thread starting...
I/SystemServiceManager(  620): Starting com.android.server.pm.Installer
I/Installer(  620): Waiting for installd to be ready.
I/SystemServiceManager(  620): Starting com.android.server.am.ActivityManagerService$Lifecycle
I/ActivityManager(  620): Memory class: 192
I/ServiceThread(  620): Enabled StrictMode logging for ActivityManager looper.
I/AppOps  (  620): No existing app ops /data/system/appops.xml; starting empty
I/IntentFirewall(  620): Read new rules (A:0 B:0 S:0)
I/ServiceThread(  620): Enabled StrictMode logging for android.ui looper.
I/ServiceThread(  620): Enabled StrictMode logging for android.display looper.
I/PowerProfile(  620): Reading power values from XML resource
D/AppOps  (  620): AppOpsService published
I/SystemServiceManager(  620): Starting com.android.server.power.PowerManagerService
I/ServiceThread(  620): Enabled StrictMode logging for PowerManagerService looper.
D/RKPowerHAL(  620): version 3.0
W/libsuspend(  620): Error writing 'on' to /sys/power/state: Invalid argument
I/libsuspend(  620): Selected wakeup count
E/RKPowerHAL(  620): Error opening /sys/devices/system/cpu/cpufreq/interactive/input_boost: No such file or directory
E/RKPowerHAL(  620): Error opening /sys/devices/system/cpu/cpu7/online: No such file or directory
E/RKPowerHAL(  620): Error opening /sys/devices/system/cpu/cpu6/online: No such file or directory
E/RKPowerHAL(  620): Error opening /sys/devices/system/cpu/cpu5/online: No such file or directory
E/RKPowerHAL(  620): Error opening /sys/devices/system/cpu/cpu4/online: No such file or directory
E/RKPowerHAL(  620): Error opening /sys/devices/system/cpu/cpu3/online: Permission denied
E/RKPowerHAL(  620): Error opening /sys/devices/system/cpu/cpu2/online: Permission denied
I/SystemServiceManager(  620): Starting com.android.server.display.DisplayManagerService
I/SystemServiceManager(  620): Starting phase 100
I/DisplayManagerService(  620): Display device added: DisplayDeviceInfo{"Built-in Screen": uniqueId="local:0", 1280 x 720, 60.000004 fps, supportedRefreshRates [60.000004], density 160, 160.15764 x 160.42105 dpi, appVsyncOff 0, presDeadline 17666666, touch INTERNAL, rotation 0, type BUILT_IN, state UNKNOWN, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/SystemServer(  620): Package Manager
I/DisplayManagerService(  620): Display device added: DisplayDeviceInfo{"HDMI Screen": uniqueId="local:1", 1280 x 720, 60002.4 fps, supportedRefreshRates [60002.4], density 213, 213.0 x 213.0 dpi, appVsyncOff 0, presDeadline 1016666, touch EXTERNAL, rotation 0, type HDMI, state UNKNOWN, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS, FLAG_PRESENTATION}
W/SELinuxMMAC(  620): Error opening /data/system/seapp_hash. Assuming first boot.
W/FileUtils(  620): Failed to chmod(/data/system/packages.list): android.system.ErrnoException: chmod failed: ENOENT (No such file or directory)
W/SystemConfig(  620): No directory /system/etc/sysconfig, skipping
D/StrictMode(  620): No activity manager; failed to Dropbox violation.
D/SELinuxMMAC(  620): Using policy file /system/etc/security/mac_permissions.xml
I/PackageManager(  620): No settings file; creating initial state
I/dex2oat (  673): Error opening the directory: /system/lib/plugins
I/dex2oat (  673): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/com.android.location.provider.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@com.android.location.provider.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  673): Decided to run without swap.
I/dex2oat (  673): dex2oat took 36.449ms (threads: 4) arena alloc=79KB java alloc=75KB native alloc=1187KB free=24KB
I/dex2oat (  678): Error opening the directory: /system/lib/plugins
I/dex2oat (  678): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/com.android.future.usb.accessory.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@com.android.future.usb.accessory.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  678): Decided to run without swap.
I/dex2oat (  678): dex2oat took 20.784ms (threads: 4) arena alloc=57KB java alloc=11KB native alloc=620KB free=23KB
I/dex2oat (  683): Error opening the directory: /system/lib/plugins
I/dex2oat (  683): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/javax.obex.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@javax.obex.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  683): Decided to run without swap.
I/dex2oat (  683): dex2oat took 69.701ms (threads: 4) arena alloc=465KB java alloc=39KB native alloc=1516KB free=31KB
I/dex2oat (  688): Error opening the directory: /system/lib/plugins
I/dex2oat (  688): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/android.test.runner.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@android.test.runner.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  688): Decided to run without swap.
I/dex2oat (  688): dex2oat took 214.329ms (threads: 4) arena alloc=101KB java alloc=235KB native alloc=1822KB free=74KB
I/dex2oat (  693): Error opening the directory: /system/lib/plugins
I/dex2oat (  693): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/com.android.media.remotedisplay.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@com.android.media.remotedisplay.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  693): Decided to run without swap.
I/dex2oat (  693): dex2oat took 21.281ms (threads: 4) arena alloc=84KB java alloc=15KB native alloc=1158KB free=25KB
I/dex2oat (  698): Error opening the directory: /system/lib/plugins
I/dex2oat (  698): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/com.android.mediadrm.signer.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@com.android.mediadrm.signer.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  698): Decided to run without swap.
I/dex2oat (  698): dex2oat took 28.586ms (threads: 4) arena alloc=81KB java alloc=5KB native alloc=878KB free=21KB
I/dex2oat (  703): Error opening the directory: /system/lib/plugins
I/dex2oat (  703): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/am.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@am.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  703): Decided to run without swap.
I/dex2oat (  703): dex2oat took 67.755ms (threads: 4) arena alloc=557KB java alloc=35KB native alloc=1232KB free=31KB
I/dex2oat (  708): Error opening the directory: /system/lib/plugins
I/dex2oat (  708): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/appops.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@appops.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  708): Decided to run without swap.
I/dex2oat (  708): dex2oat took 24.550ms (threads: 4) arena alloc=27KB java alloc=9KB native alloc=357KB free=18KB
I/dex2oat (  713): Error opening the directory: /system/lib/plugins
I/dex2oat (  713): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/appwidget.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@appwidget.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  713): Decided to run without swap.
I/dex2oat (  713): dex2oat took 18.383ms (threads: 4) arena alloc=162KB java alloc=5KB native alloc=1147KB free=24KB
I/dex2oat (  718): Error opening the directory: /system/lib/plugins
I/dex2oat (  718): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/bmgr.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@bmgr.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  718): Decided to run without swap.
I/dex2oat (  718): dex2oat took 31.883ms (threads: 4) arena alloc=113KB java alloc=15KB native alloc=638KB free=25KB
I/dex2oat (  723): Error opening the directory: /system/lib/plugins
I/dex2oat (  723): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/bu.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@bu.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  723): Decided to run without swap.
I/dex2oat (  723): dex2oat took 20.275ms (threads: 4) arena alloc=53KB java alloc=8KB native alloc=352KB free=23KB
I/dex2oat (  728): Error opening the directory: /system/lib/plugins
I/dex2oat (  728): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/content.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@content.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  728): Decided to run without swap.
I/dex2oat (  728): dex2oat took 67.814ms (threads: 4) arena alloc=97KB java alloc=14KB native alloc=1167KB free=20KB
I/dex2oat (  733): Error opening the directory: /system/lib/plugins
I/dex2oat (  733): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/dpm.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@dpm.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  733): Decided to run without swap.
I/dex2oat (  733): dex2oat took 22.063ms (threads: 4) arena alloc=27KB java alloc=4KB native alloc=355KB free=16KB
I/dex2oat (  738): Error opening the directory: /system/lib/plugins
I/dex2oat (  738): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/ime.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@ime.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  738): Decided to run without swap.
I/dex2oat (  738): dex2oat took 22.869ms (threads: 4) arena alloc=65KB java alloc=6KB native alloc=357KB free=22KB
I/dex2oat (  743): Error opening the directory: /system/lib/plugins
I/dex2oat (  743): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/input.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@input.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  743): Decided to run without swap.
I/dex2oat (  743): dex2oat took 24.828ms (threads: 4) arena alloc=114KB java alloc=5KB native alloc=624KB free=23KB
I/dex2oat (  748): Error opening the directory: /system/lib/plugins
I/dex2oat (  748): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/media_cmd.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@media_cmd.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  748): Decided to run without swap.
I/dex2oat (  748): dex2oat took 25.101ms (threads: 4) arena alloc=194KB java alloc=31KB native alloc=893KB free=26KB
I/dex2oat (  753): Error opening the directory: /system/lib/plugins
I/dex2oat (  753): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/monkey.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@monkey.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  753): Decided to run without swap.
I/dex2oat (  753): dex2oat took 109.044ms (threads: 4) arena alloc=942KB java alloc=119KB native alloc=1638KB free=49KB
I/dex2oat (  758): Error opening the directory: /system/lib/plugins
I/dex2oat (  758): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/pm.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@pm.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  758): Decided to run without swap.
I/dex2oat (  758): dex2oat took 107.207ms (threads: 4) arena alloc=122KB java alloc=38KB native alloc=1224KB free=31KB
I/dex2oat (  763): Error opening the directory: /system/lib/plugins
I/dex2oat (  763): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/requestsync.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@requestsync.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  763): Decided to run without swap.
I/dex2oat (  763): dex2oat took 24.428ms (threads: 4) arena alloc=28KB java alloc=3KB native alloc=359KB free=24KB
I/dex2oat (  768): Error opening the directory: /system/lib/plugins
I/dex2oat (  768): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/settings.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@settings.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  768): Decided to run without swap.
I/dex2oat (  768): dex2oat took 25.815ms (threads: 4) arena alloc=253KB java alloc=5KB native alloc=623KB free=28KB
I/dex2oat (  773): Error opening the directory: /system/lib/plugins
I/dex2oat (  773): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/svc.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@svc.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  773): Decided to run without swap.
I/dex2oat (  773): dex2oat took 103.986ms (threads: 4) arena alloc=93KB java alloc=13KB native alloc=1155KB free=28KB
I/dex2oat (  778): Error opening the directory: /system/lib/plugins
I/dex2oat (  778): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/uiautomator.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@uiautomator.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  778): Decided to run without swap.
I/dex2oat (  778): dex2oat took 189.448ms (threads: 4) arena alloc=266KB java alloc=134KB native alloc=1398KB free=37KB
I/dex2oat (  783): Error opening the directory: /system/lib/plugins
I/dex2oat (  783): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/wm.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@wm.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  783): Decided to run without swap.
I/dex2oat (  783): dex2oat took 23.395ms (threads: 4) arena alloc=27KB java alloc=3KB native alloc=355KB free=16KB
D/PackageManager(  620): No files in app dir /vendor/overlay
I/PackageManager(  620): /system/framework/framework-res.apk changed; collecting certs
I/PackageManager(  620): /system/priv-app/BackupRestoreConfirmation changed; collecting certs
I/PackageManager(  620): /system/priv-app/CalendarProvider changed; collecting certs
I/PackageManager(  620): New shared user android.uid.calendar: id=10001
W/PackageParser(  620): No actions in intent filter at /system/priv-app/Contacts/Contacts.apk Binary XML file line #356
I/PackageManager(  620): /system/priv-app/Contacts changed; collecting certs
I/PackageManager(  620): New shared user android.uid.shared: id=10002
I/PackageManager(  620): /system/priv-app/ContactsProvider changed; collecting certs
I/PackageManager(  620): /system/priv-app/DefaultContainerService changed; collecting certs
I/PackageManager(  620): /system/priv-app/DownloadProvider changed; collecting certs
I/PackageManager(  620): New shared user android.media: id=10004
I/PackageManager(  620): /system/priv-app/ExternalStorageProvider changed; collecting certs
I/PackageManager(  620): /system/priv-app/FusedLocation changed; collecting certs
I/PackageManager(  620): /system/priv-app/InputDevices changed; collecting certs
I/PackageManager(  620): /system/priv-app/ManagedProvisioning changed; collecting certs
I/PackageManager(  620): /system/priv-app/MediaProvider changed; collecting certs
I/PackageManager(  620): /system/priv-app/MmsService changed; collecting certs
I/PackageManager(  620): /system/priv-app/MusicFX changed; collecting certs
I/PackageManager(  620): /system/priv-app/OneTimeInitializer changed; collecting certs
I/PackageManager(  620): /system/priv-app/ProxyHandler changed; collecting certs
I/PackageManager(  620): /system/priv-app/Settings changed; collecting certs
I/PackageManager(  620): /system/priv-app/SettingsProvider changed; collecting certs
I/PackageManager(  620): /system/priv-app/SharedStorageBackup changed; collecting certs
I/PackageManager(  620): /system/priv-app/Shell changed; collecting certs
W/PackageParser(  620): No actions in intent filter at /system/priv-app/StressTest/StressTest.apk Binary XML file line #42
I/PackageManager(  620): /system/priv-app/StressTest changed; collecting certs
I/PackageManager(  620): /system/priv-app/SystemUI changed; collecting certs
I/PackageManager(  620): New shared user android.uid.systemui: id=10011
W/ResourceType(  620): Failure getting entry for 0x7f08026f (t=7 e=623) (error -75)
I/PackageManager(  620): /system/priv-app/TeleService changed; collecting certs
W/PackageParser(  620): Unknown element under <intent-filter>: android at /system/priv-app/Telecom/Telecom.apk Binary XML file line #232
I/PackageManager(  620): /system/priv-app/Telecom changed; collecting certs
I/PackageManager(  620): /system/priv-app/TelephonyProvider changed; collecting certs
I/PackageManager(  620): /system/priv-app/VpnDialogs changed; collecting certs
I/PackageManager(  620): /system/priv-app/WallpaperCropper changed; collecting certs
I/PackageManager(  620): /system/app/BasicDreams changed; collecting certs
W/PackageParser(  620): No actions in intent filter at /system/app/Bluetooth/Bluetooth.apk Binary XML file line #209
I/PackageManager(  620): /system/app/Bluetooth changed; collecting certs
I/PackageManager(  620): /system/app/Browser changed; collecting certs
I/PackageManager(  620): /system/app/Calculator changed; collecting certs
I/PackageManager(  620): /system/app/Calendar changed; collecting certs
I/PackageManager(  620): /system/app/Camera2 changed; collecting certs
I/PackageManager(  620): /system/app/CaptivePortalLogin changed; collecting certs
I/PackageManager(  620): /system/app/CertInstaller changed; collecting certs
I/PackageManager(  620): /system/app/DeskClock changed; collecting certs
I/PackageManager(  620): /system/app/DeviceTest changed; collecting certs
I/PackageManager(  620): /system/app/DocumentsUI changed; collecting certs
I/PackageManager(  620): /system/app/DownloadProviderUi changed; collecting certs
I/PackageManager(  620): /system/app/Exchange2 changed; collecting certs
I/PackageManager(  620): /system/app/Galaxy4 changed; collecting certs
W/PackageParser(  620): Unknown element under <application>: permission at /system/app/Gallery2/Gallery2.apk Binary XML file line #243
W/PackageParser(  620): Unknown element under <application>: permission at /system/app/Gallery2/Gallery2.apk Binary XML file line #246
I/PackageManager(  620): /system/app/Gallery2 changed; collecting certs
I/PackageManager(  620): /system/app/GoogleEmail changed; collecting certs
I/PackageManager(  620): /system/app/HTMLViewer changed; collecting certs
I/PackageManager(  620): /system/app/HoloSpiralWallpaper changed; collecting certs
I/PackageManager(  620): /system/app/KeyChain changed; collecting certs
I/PackageManager(  620): /system/app/LatinIME changed; collecting certs
I/PackageManager(  620): /system/app/Launcher3 changed; collecting certs
I/PackageManager(  620): /system/app/LiveWallpapers changed; collecting certs
I/PackageManager(  620): /system/app/LiveWallpapersPicker changed; collecting certs
I/PackageManager(  620): /system/app/MediaFloat changed; collecting certs
I/PackageManager(  620): /system/app/NoiseField changed; collecting certs
I/PackageManager(  620): /system/app/OpenWnn changed; collecting certs
I/PackageManager(  620): /system/app/PacProcessor changed; collecting certs
I/PackageManager(  620): /system/app/PackageInstaller changed; collecting certs
I/PackageManager(  620): /system/app/PhaseBeam changed; collecting certs
I/PackageManager(  620): /system/app/PhotoTable changed; collecting certs
I/PackageManager(  620): /system/app/PicoTts changed; collecting certs
I/PackageManager(  620): /system/app/PrintSpooler changed; collecting certs
I/PackageManager(  620): /system/app/Provision changed; collecting certs
I/PackageManager(  620): /system/app/QuickSearchBox changed; collecting certs
I/PackageManager(  620): /system/app/RKGameControlSettingV1.0.1 changed; collecting certs
I/PackageManager(  620): /system/app/RKUpdateService changed; collecting certs
I/PackageManager(  620): /system/app/RkApkinstaller changed; collecting certs
I/PackageManager(  620): /system/app/RkBoxVideoPlayer changed; collecting certs
W/ResourceType(  620): Failure getting entry for 0x7f02001c (t=1 e=28) (error -75)
I/PackageManager(  620): /system/app/RkExplorer changed; collecting certs
I/PackageManager(  620): /system/app/RkMusic changed; collecting certs
I/PackageManager(  620): /system/app/SoundRecorder changed; collecting certs
I/PackageManager(  620): /system/app/UserDictionaryProvider changed; collecting certs
I/PackageManager(  620): /system/app/VisualizationWallpapers changed; collecting certs
I/PackageManager(  620): /system/app/WAPPushManager changed; collecting certs
I/PackageManager(  620): /system/app/eHomeMediaCenter_box changed; collecting certs
I/PackageManager(  620): /system/app/webview changed; collecting certs
D/PackageManager(  620): No files in app dir /system/vendor/app
D/PackageManager(  620): No files in app dir /oem/app
D/PackageManager(  620): No files in app dir /data/app
D/PackageManager(  620): No files in app dir /data/app-private
W/PackageManager(  620): Package com.android.gallery3d desires unavailable shared library com.google.android.media.effects; ignoring!
I/PackageManager(  620): Adjusting ABI for : com.android.keychain to armeabi-v7a
I/PackageManager(  620): Running dexopt on: /system/app/KeyChain/KeyChain.apk pkg=com.android.keychain isa=arm vmSafeMode=false
I/dex2oat (  788): Error opening the directory: /system/lib/plugins
I/dex2oat (  788): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/KeyChain/KeyChain.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@KeyChain@KeyChain.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  788): Decided to run without swap.
I/dex2oat (  788): dex2oat took 41.620ms (threads: 4) arena alloc=56KB java alloc=79KB native alloc=1201KB free=26KB
I/PackageManager(  620): Adjusting ABI for : com.android.server.telecom to armeabi-v7a
I/PackageManager(  620): Running dexopt on: /system/priv-app/Telecom/Telecom.apk pkg=com.android.server.telecom isa=arm vmSafeMode=false
I/dex2oat (  793): Error opening the directory: /system/lib/plugins
I/dex2oat (  793): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/Telecom/Telecom.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@Telecom@Telecom.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  793): Decided to run without swap.
I/dex2oat (  793): dex2oat took 189.585ms (threads: 4) arena alloc=94KB java alloc=377KB native alloc=2MB free=89KB
I/PackageManager(  620): Adjusting ABI for : com.android.settings to armeabi-v7a
I/PackageManager(  620): Running dexopt on: /system/priv-app/Settings/Settings.apk pkg=com.android.settings isa=arm vmSafeMode=false
I/dex2oat (  798): Error opening the directory: /system/lib/plugins
I/dex2oat (  798): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/Settings/Settings.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@Settings@Settings.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  798): Decided to run without swap.
I/dex2oat (  798): dex2oat took 1.738s (threads: 4) arena alloc=238KB java alloc=4MB native alloc=7MB free=766KB
I/PackageManager(  620): Adjusting ABI for : com.android.location.fused to armeabi-v7a
I/PackageManager(  620): Running dexopt on: /system/priv-app/FusedLocation/FusedLocation.apk pkg=com.android.location.fused isa=arm vmSafeMode=false
I/dex2oat (  803): Error opening the directory: /system/lib/plugins
I/dex2oat (  803): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/FusedLocation/FusedLocation.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@FusedLocation@FusedLocation.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  803): Decided to run without swap.
I/dex2oat (  803): dex2oat took 26.387ms (threads: 4) arena alloc=93KB java alloc=44KB native alloc=1162KB free=25KB
I/PackageManager(  620): Adjusting ABI for : com.android.inputdevices to armeabi-v7a
I/PackageManager(  620): Running dexopt on: /system/priv-app/InputDevices/InputDevices.apk pkg=com.android.inputdevices isa=arm vmSafeMode=false
I/dex2oat (  808): Error opening the directory: /system/lib/plugins
I/dex2oat (  808): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/InputDevices/InputDevices.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@InputDevices@InputDevices.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  808): Decided to run without swap.
I/dex2oat (  808): dex2oat took 20.920ms (threads: 4) arena alloc=24KB java alloc=1984B native alloc=341KB free=30KB
I/PackageManager(  620): Adjusting ABI for : com.android.providers.settings to armeabi-v7a
I/PackageManager(  620): Running dexopt on: /system/priv-app/SettingsProvider/SettingsProvider.apk pkg=com.android.providers.settings isa=arm vmSafeMode=false
I/dex2oat (  813): Error opening the directory: /system/lib/plugins
I/dex2oat (  813): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/SettingsProvider/SettingsProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@SettingsProvider@SettingsProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  813): Decided to run without swap.
I/dex2oat (  813): dex2oat took 110.669ms (threads: 4) arena alloc=2MB java alloc=106KB native alloc=3MB free=107KB
I/PackageManager(  620): Adjusting ABI for : com.android.rockchip to armeabi-v7a
I/PackageManager(  620): Running dexopt on: /system/app/RkExplorer/RkExplorer.apk pkg=com.android.rockchip isa=arm vmSafeMode=false
I/dex2oat (  818): Error opening the directory: /system/lib/plugins
I/dex2oat (  818): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/RkExplorer/RkExplorer.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@RkExplorer@RkExplorer.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  818): Decided to run without swap.
I/dex2oat (  818): dex2oat took 562.198ms (threads: 4) arena alloc=113KB java alloc=713KB native alloc=2MB free=176KB
I/PackageManager(  620): Adjusting ABI for : com.rockchip.devicetest to armeabi-v7a
I/PackageManager(  620): Running dexopt on: /system/app/DeviceTest/DeviceTest.apk pkg=com.rockchip.devicetest isa=arm vmSafeMode=false
I/dex2oat (  823): Error opening the directory: /system/lib/plugins
I/dex2oat (  823): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/DeviceTest/DeviceTest.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@DeviceTest@DeviceTest.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  823): Decided to run without swap.
I/dex2oat (  823): dex2oat took 1.599s (threads: 4) arena alloc=165KB java alloc=2MB native alloc=5MB free=698KB
I/PackageManager(  620): Adjusting ABI for : com.cghs.stresstest to armeabi-v7a
I/PackageManager(  620): Running dexopt on: /system/priv-app/StressTest/StressTest.apk pkg=com.cghs.stresstest isa=arm vmSafeMode=false
I/dex2oat (  828): Error opening the directory: /system/lib/plugins
I/dex2oat (  828): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/StressTest/StressTest.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@StressTest@StressTest.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  828): Decided to run without swap.
I/dex2oat (  828): dex2oat took 212.968ms (threads: 4) arena alloc=198KB java alloc=412KB native alloc=1883KB free=60KB
I/PackageManager(  620): Time to scan packages: 9.974 seconds
W/PackageManager(  620): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
W/PackageManager(  620): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
W/PackageManager(  620): Not granting permission android.permission.GLOBAL_SEARCH to package com.android.quicksearchbox (protectionLevel=18 flags=0x8be45)
W/PackageManager(  620): Not granting permission android.permission.ACCESS_DOWNLOAD_MANAGER to package com.android.browser (protectionLevel=18 flags=0x9be45)
W/PackageManager(  620): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
W/PackageManager(  620): Not granting permission android.permission.BIND_WALLPAPER to package com.android.camera2 (protectionLevel=18 flags=0x58bc45)
W/PackageManager(  620): Not granting permission android.permission.BIND_APPWIDGET to package com.android.launcher3 (protectionLevel=18 flags=0x583e45)
W/PackageManager(  620): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.launcher3
W/PackageManager(  620): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.launcher3
W/PackageManager(  620): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
W/PackageManager(  620): Not granting permission android.permission.INSTALL_PACKAGES to package com.android.apkinstaller (protectionLevel=18 flags=0x8be45)
W/PackageManager(  620): Not granting permission android.permission.DELETE_PACKAGES to package com.android.apkinstaller (protectionLevel=18 flags=0x8be45)
W/PackageManager(  620): Unknown permission android.Manifest.permission.INJECT_EVENTS in package com.rockchip.devicetest
W/PackageManager(  620): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.onetimeinitializer
W/PackageManager(  620): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.onetimeinitializer
W/PackageManager(  620): Unknown permission android.permission.READ_MEDIA_STORAGE in package com.android.packageinstaller
W/PackageManager(  620): Not granting permission android.permission.DELETE_PACKAGES to package com.svox.pico (protectionLevel=18 flags=0x8be45)
W/PackageManager(  620): Unknown permission com.google.android.gallery3d.permission.PICASA_STORE in package com.android.dreams.phototable
W/PackageManager(  620): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
W/PackageManager(  620): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.settings
W/PackageManager(  620): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.settings
W/PackageManager(  620): Not granting permission android.permission.MOUNT_UNMOUNT_FILESYSTEMS to package com.rockchip.mediacenter (protectionLevel=18 flags=0x8be45)
W/PackageManager(  620): Not granting permission android.permission.DEVICE_POWER to package com.rockchip.mediacenter (protectionLevel=2 flags=0x8be45)
W/PackageManager(  620): Unknown permission com.android.email.permission.READ_ATTACHMENT in package com.rockchip.mediacenter
W/PackageManager(  620): Not granting permission android.permission.WRITE_MEDIA_STORAGE to package com.android.music (protectionLevel=18 flags=0x8be65)
W/PackageManager(  620): Not granting permission android.permission.DEVICE_POWER to package com.android.music (protectionLevel=2 flags=0x8be65)
W/PackageManager(  620): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x48be45)
W/PackageManager(  620): Unknown permission com.android.email.permission.READ_ATTACHMENT in package com.android.exchange
W/PackageManager(  620): Unknown permission com.android.email.permission.ACCESS_PROVIDER in package com.android.exchange
W/PackageManager(  620): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
W/PackageManager(  620): Unknown permission android.permission.MMS_SEND_OUTBOX_MSG in package com.android.bluetooth
W/PackageManager(  620): Unknown permission rockchip.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
W/PackageManager(  620): Unknown permission android.permission.RAISED_THREAD_PRIORITY in package android.rk.RockVideoPlayer
W/PackageManager(  620): Unknown permission android.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
W/PackageManager(  620): Unknown permission archos.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
I/art     (  620): Explicit concurrent mark sweep GC freed 5757(434KB) AllocSpace objects, 6(103KB) LOS objects, 33% free, 2MB/3MB, paused 314us total 17.055ms
I/SystemServer(  620): User Service
I/lowmemorykiller(  152): ActivityManager connected
I/SystemServiceManager(  620): Starting com.android.server.lights.LightsService
I/Lights  (  620): >>> Enter light_device_open:backlight
I/Lights  (  620): >>> Enter light_device_open:keyboard
I/Lights  (  620): >>> Enter light_device_open:buttons
I/Lights  (  620): >>> Enter light_device_open:battery
I/Lights  (  620): >>> Enter light_device_open:notifications
I/Lights  (  620): >>> Enter light_device_open:attention
I/Lights  (  620): >>> Enter light_device_open:bluetooth
I/Lights  (  620): >>> undefine light id
I/Lights  (  620): >>> Enter light_device_open:wifi
I/SystemServiceManager(  620): Starting com.android.server.BatteryService
I/BatteryStatsImpl(  620): Resetting battery stats: level=100 status=4 dischargeLevel=100 lowAmount=0 highAmount=0
I/SystemServiceManager(  620): Starting com.android.server.usage.UsageStatsService
I/UsageStatsDatabase(  620): Upgrading from version 0 to 2
I/UsageStatsDatabase(  620): Deleting all usage stats files
I/UsageStatsService(  620): User[0] Rollover scheduled @ 2016-12-15 00:00:00(1481760000000)
I/SystemServiceManager(  620): Starting com.android.server.webkit.WebViewUpdateService
I/SystemServer(  620): Reading configuration...
I/SystemServer(  620): Scheduling Policy
I/SystemServiceManager(  620): Starting com.android.server.telecom.TelecomLoaderService
I/SystemServer(  620): Telephony Registry
I/SystemServer(  620): Entropy Mixer
W/EntropyMixer(  620): No existing entropy file -- first boot?
I/EntropyMixer(  620): Writing entropy...
I/SystemServer(  620): Account Manager
I/SystemServer(  620): Start SimStateChange Service
W/ActivityManager(  620): Unable to start service Intent { cmp=com.android.contacts/.SimStateChangedService } U=0: not found
I/SystemServer(  620): Content Manager
I/SystemServer(  620): System Content Providers
I/SyncManager(  620): No initial accounts
I/SyncManager(  620): No initial status
I/SyncManager(  620): No initial statistics
D/SettingsProvider(  620): Generated and saved new ANDROID_ID [fa41e7aa9fcfd3ff] for user 0
I/SystemServer(  620): Vibrator Service
I/SystemServer(  620): Consumer IR Service
E/ConsumerIrService(  620): Can't open consumer IR HW Module, error: -2
I/SystemServiceManager(  620): Starting com.android.server.AlarmManagerService
D/AlarmManager(  620):  Failed while trying resolve alarm filter file, not exists
I/SystemServer(  620): Init Watchdog
I/SystemServer(  620): Input Manager
I/InputManager(  620): Initializing input manager, mUseDevInputEventForAudioJack=false
I/SystemServer(  620): Window Manager
I/WindowManager(  620): No existing display settings /data/system/display_settings.xml; starting empty
D/PermissionCache(  156): checking android.permission.ACCESS_SURFACE_FLINGER for uid=1000 => granted (350 us)
I/InputManager(  620): Starting input manager
I/SystemServer(  620): Bluetooth Manager Service
D/EventHub(  620): No input device configuration file found for device 'PixArt USB Optical Mouse'.
I/EventHub(  620): New device: id=1, fd=82, path='/dev/input/event2', name='PixArt USB Optical Mouse', classes=0x80000008, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
D/EventHub(  620): No input device configuration file found for device 'rk29-keypad'.
D/BluetoothManagerService(  620): Loading stored name and address
D/BluetoothManagerService(  620): Stored bluetooth Name=null,Address=null
I/SystemServer(  620): Input Method Service
W/EventHub(  620): Unable to disable kernel key repeat for /dev/input/event1: Function not implemented
I/EventHub(  620): New device: id=2, fd=83, path='/dev/input/event1', name='rk29-keypad', classes=0x401, configuration='', keyLayout='/system/usr/keylayout/rk29-keypad.kl', keyCharacterMap='/system/usr/keychars/Generic.kcm', builtinKeyboard=true, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
D/EventHub(  620): No input device configuration file found for device 'ff680000.pwm'.
W/EventHub(  620): Unable to disable kernel key repeat for /dev/input/event0: Function not implemented
I/EventHub(  620): New device: id=3, fd=84, path='/dev/input/event0', name='ff680000.pwm', classes=0x421, configuration='', keyLayout='/system/usr/keylayout/ff680000_pwm.kl', keyCharacterMap='/system/usr/keychars/Generic.kcm', builtinKeyboard=false, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
I/InputReader(  620): Device added: id=-1, name='Virtual', sources=0x00000301
I/InputReader(  620): Device added: id=3, name='ff680000.pwm', sources=0x00002303
I/InputReader(  620): Device added: id=0, name='rk29-keypad', sources=0x00002103
I/InputReader(  620): Device added: id=1, name='PixArt USB Optical Mouse', sources=0x00002002
W/InputMethodManagerService(  620): No IME selected. Choose the most applicable IME.
I/InputMethodManagerService(  620): Default found, using com.android.inputmethod.latin/.LatinIME
I/SystemServer(  620): Accessibility Manager
I/ActivityManager(  620): Config changes=1df8 {1.15 ?mcc?mnc en_US ?layoutDir sw720dp w1280dp h720dp 160dpi xlrg long land ?uimode ?night -touch -keyb/h/h dpad/v s.2}
I/InputReader(  620): Reconfiguring input devices.  changes=0x00000004
I/ActivityManager(  620): Config changes=500 {1.15 ?mcc?mnc en_US ?layoutDir sw720dp w1280dp h647dp 160dpi lrg long land ?uimode ?night -touch -keyb/h/h dpad/v s.3}
I/SystemServer(  620): Mount Service
D/MountService(  620): got storage path: /storage/sdcard0 description: SD card primary: true removable: true emulated: true mtpReserve: 100 allowMassStorage: false maxFileSize: 0
D/MountService(  620): ---getMaxSupportedUsers,we has UMS,ignore emulated storage---
D/MountService(  620): got storage path: /mnt/internal_sd description: NAND FLASH primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService(  620): ---getMaxSupportedUsers,we has UMS,force NAND FLASH to primary storage---
D/MountService(  620): addVolumeLocked() StorageVolume:
D/MountService(  620):     mStorageId=0 mPath=/mnt/internal_sd mDescriptionId=17041209 mPrimary=true
D/MountService(  620):     mRemovable=true mEmulated=false mMtpReserveSpace=100
D/MountService(  620):     mAllowMassStorage=true mMaxFileSize=0 mOwner=null mUuid=null
D/MountService(  620):     mUserLabel=null mState=null
D/MountService(  620): got storage path: /mnt/external_sd description: SD card primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService(  620):     mStorageId=0 mPath=/mnt/external_sd mDescriptionId=17040806 mPrimary=false
D/MountService(  620): got storage path: /mnt/usb_storage/USB_DISK0 description: USB storage 0 primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService(  620):     mStorageId=0 mPath=/mnt/usb_storage/USB_DISK0 mDescriptionId=17041123
D/MountService(  620):     mPrimary=false mRemovable=true mEmulated=false mMtpReserveSpace=100
D/MountService(  620): got storage path: /mnt/usb_storage/USB_DISK1 description: USB storage 1 primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService(  620):     mStorageId=0 mPath=/mnt/usb_storage/USB_DISK1 mDescriptionId=17041124
D/MountService(  620): got storage path: /mnt/usb_storage/USB_DISK2 description: USB storage 2 primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService(  620):     mStorageId=0 mPath=/mnt/usb_storage/USB_DISK2 mDescriptionId=17041125
D/MountService(  620): got storage path: /mnt/usb_storage/USB_DISK3 description: USB storage 3 primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService(  620):     mStorageId=0 mPath=/mnt/usb_storage/USB_DISK3 mDescriptionId=17041126
D/MountService(  620): got storage path: /mnt/usb_storage/USB_DISK4 description: USB storage 4 primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService(  620):     mStorageId=0 mPath=/mnt/usb_storage/USB_DISK4 mDescriptionId=17041127
D/MountService(  620): got storage path: /mnt/usb_storage/USB_DISK5 description: USB storage 5 primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService(  620):     mStorageId=0 mPath=/mnt/usb_storage/USB_DISK5 mDescriptionId=17041128
W/PackageManager(  620): No disk maintenance in 1481693840645; running immediately
D/VoldCmdListener(  155): volume list broadcast
D/Vold    (  155): listVolumes :internal_sd /mnt/internal_sd 1
D/Vold    (  155): listVolumes :external_sd /mnt/external_sd 0
D/Vold    (  155): listVolumes :usb_storage /mnt/usb_storage/USB_DISK0 0
D/Vold    (  155): listVolumes :usb_storage /mnt/usb_storage/USB_DISK1 0
D/Vold    (  155): listVolumes :usb_storage /mnt/usb_storage/USB_DISK2 0
D/Vold    (  155): listVolumes :usb_storage /mnt/usb_storage/USB_DISK3 0
D/Vold    (  155): listVolumes :usb_storage /mnt/usb_storage/USB_DISK4 0
D/Vold    (  155): listVolumes :usb_storage /mnt/usb_storage/USB_DISK5 0
I/MountService(  620): /mnt/internal_sdUpdating valid state unmounted   st 1
D/MountService(  620): volume state changed for /mnt/internal_sd (mounted -> unmounted)
I/PackageManager(  620): Updating external media status from unmounted to unmounted
I/MountService(  620): /mnt/external_sdUpdating valid state removed   st 0
D/MountService(  620): volume state changed for /mnt/external_sd (unmounted -> removed)
I/MountService(  620): /mnt/usb_storage/USB_DISK0Updating valid state removed   st 0
D/MountService(  620): volume state changed for /mnt/usb_storage/USB_DISK0 (unmounted -> removed)
I/MountService(  620): /mnt/usb_storage/USB_DISK1Updating valid state removed   st 0
D/MountService(  620): volume state changed for /mnt/usb_storage/USB_DISK1 (unmounted -> removed)
I/MountService(  620): /mnt/usb_storage/USB_DISK2Updating valid state removed   st 0
D/MountService(  620): volume state changed for /mnt/usb_storage/USB_DISK2 (unmounted -> removed)
I/MountService(  620): /mnt/usb_storage/USB_DISK3Updating valid state removed   st 0
D/MountService(  620): volume state changed for /mnt/usb_storage/USB_DISK3 (unmounted -> removed)
I/MountService(  620): /mnt/usb_storage/USB_DISK4Updating valid state removed   st 0
D/MountService(  620): volume state changed for /mnt/usb_storage/USB_DISK4 (unmounted -> removed)
I/MountService(  620): /mnt/usb_storage/USB_DISK5Updating valid state removed   st 0
D/MountService(  620): volume state changed for /mnt/usb_storage/USB_DISK5 (unmounted -> removed)
I/MountService(  620): Running fstrim idle maintenance
I/PackageManager(  620): Running dexopt on: /system/priv-app/MmsService/MmsService.apk pkg=com.android.mms.service isa=arm vmSafeMode=false
D/VoldCmdListener(  155): cryptfs getfield SystemLocale
D/VoldCmdListener(  155): fstrim dotrim
I/fstrim  (  155): Starting fstrim work...
W/MountService(  620): getSecureContainerList() called when storage not mounted
I/fstrim  (  155): Invoking FITRIM ioctl on /cache
D/VoldCmdListener(  155): asec list
I/fstrim  (  155): Trimmed 127590400 bytes on /cache
I/fstrim  (  155): Invoking FITRIM ioctl on /metadata
I/PackageManager(  620): No secure containers found
I/dex2oat (  854): Error opening the directory: /system/lib/plugins
I/dex2oat (  854): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/MmsService/MmsService.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@MmsService@MmsService.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/fstrim  (  155): Trimmed 12263424 bytes on /metadata
I/fstrim  (  155): Invoking FITRIM ioctl on /data
I/dex2oat (  854): Decided to run without swap.
I/fstrim  (  155): Trimmed 940552192 bytes on /data
I/fstrim  (  155): Trimmed 0 bytes on /data
E/fstrim  (  155): Cannot stat mount point none
I/fstrim  (  155): Finished fstrim work.
I/dex2oat (  854): dex2oat took 100.850ms (threads: 4) arena alloc=96KB java alloc=121KB native alloc=1564KB free=23KB
I/PackageManager(  620): Running dexopt on: /system/priv-app/DefaultContainerService/DefaultContainerService.apk pkg=com.android.defcontainer isa=arm vmSafeMode=false
I/dex2oat (  860): Error opening the directory: /system/lib/plugins
I/dex2oat (  860): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/DefaultContainerService/DefaultContainerService.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@DefaultContainerService@DefaultContainerService.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  860): Decided to run without swap.
I/dex2oat (  860): dex2oat took 32.336ms (threads: 4) arena alloc=72KB java alloc=28KB native alloc=895KB free=24KB
I/PackageManager(  620): Running dexopt on: /system/app/LatinIME/LatinIME.apk pkg=com.android.inputmethod.latin isa=arm vmSafeMode=false
I/dex2oat (  865): Error opening the directory: /system/lib/plugins
I/dex2oat (  865): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/LatinIME/LatinIME.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@LatinIME@LatinIME.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  865): Decided to run without swap.
I/dex2oat (  865): dex2oat took 937.672ms (threads: 4) arena alloc=181KB java alloc=1617KB native alloc=4MB free=410KB
I/PackageManager(  620): Running dexopt on: /system/priv-app/TeleService/TeleService.apk pkg=com.android.phone isa=arm vmSafeMode=false
I/dex2oat (  870): Error opening the directory: /system/lib/plugins
I/dex2oat (  870): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/TeleService/TeleService.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@TeleService@TeleService.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  870): Decided to run without swap.
I/dex2oat (  870): dex2oat took 618.646ms (threads: 4) arena alloc=351KB java alloc=1447KB native alloc=3MB free=250KB
I/PackageManager(  620): Running dexopt on: /system/priv-app/SystemUI/SystemUI.apk pkg=com.android.systemui isa=arm vmSafeMode=false
I/dex2oat (  875): Error opening the directory: /system/lib/plugins
I/dex2oat (  875): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/SystemUI/SystemUI.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@SystemUI@SystemUI.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  875): Decided to run without swap.
I/dex2oat (  875): dex2oat took 1.513s (threads: 4) arena alloc=102KB java alloc=3MB native alloc=5MB free=669KB
I/PackageManager(  620): Running dexopt on: /system/priv-app/TelephonyProvider/TelephonyProvider.apk pkg=com.android.providers.telephony isa=arm vmSafeMode=false
I/dex2oat (  880): Error opening the directory: /system/lib/plugins
I/dex2oat (  880): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/TelephonyProvider/TelephonyProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@TelephonyProvider@TelephonyProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  880): Decided to run without swap.
I/dex2oat (  880): dex2oat took 133.827ms (threads: 4) arena alloc=495KB java alloc=112KB native alloc=1705KB free=50KB
I/PackageManager(  620): Running dexopt on: /system/priv-app/ProxyHandler/ProxyHandler.apk pkg=com.android.proxyhandler isa=arm vmSafeMode=false
I/dex2oat (  885): Error opening the directory: /system/lib/plugins
I/dex2oat (  885): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/ProxyHandler/ProxyHandler.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@ProxyHandler@ProxyHandler.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  885): Decided to run without swap.
I/dex2oat (  885): dex2oat took 22.750ms (threads: 4) arena alloc=281KB java alloc=17KB native alloc=1154KB free=29KB
I/PackageManager(  620): Running dexopt on: /system/priv-app/Shell/Shell.apk pkg=com.android.shell isa=arm vmSafeMode=false
I/dex2oat (  890): Error opening the directory: /system/lib/plugins
I/dex2oat (  890): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/Shell/Shell.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@Shell@Shell.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  890): Decided to run without swap.
I/dex2oat (  890): dex2oat took 329.829ms (threads: 4) arena alloc=186KB java alloc=359KB native alloc=2MB free=98KB
I/PackageManager(  620): Running dexopt on: /system/priv-app/ManagedProvisioning/ManagedProvisioning.apk pkg=com.android.managedprovisioning isa=arm vmSafeMode=false
I/dex2oat (  895): Error opening the directory: /system/lib/plugins
I/dex2oat (  895): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/ManagedProvisioning/ManagedProvisioning.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@ManagedProvisioning@ManagedProvisioning.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  895): Decided to run without swap.
I/dex2oat (  895): dex2oat took 413.353ms (threads: 4) arena alloc=136KB java alloc=561KB native alloc=2MB free=128KB
I/PackageManager(  620): Running dexopt on: /system/priv-app/ContactsProvider/ContactsProvider.apk pkg=com.android.providers.contacts isa=arm vmSafeMode=false
I/dex2oat (  900): Error opening the directory: /system/lib/plugins
I/dex2oat (  900): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/ContactsProvider/ContactsProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@ContactsProvider@ContactsProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  900): Decided to run without swap.
I/dex2oat (  900): dex2oat took 755.744ms (threads: 4) arena alloc=1259KB java alloc=739KB native alloc=4MB free=245KB
I/PackageManager(  620): Running dexopt on: /system/priv-app/MediaProvider/MediaProvider.apk pkg=com.android.providers.media isa=arm vmSafeMode=false
I/dex2oat (  905): Error opening the directory: /system/lib/plugins
I/dex2oat (  905): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/MediaProvider/MediaProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@MediaProvider@MediaProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  905): Decided to run without swap.
I/dex2oat (  905): dex2oat took 181.834ms (threads: 4) arena alloc=960KB java alloc=153KB native alloc=1767KB free=48KB
I/PackageManager(  620): Running dexopt on: /system/priv-app/CalendarProvider/CalendarProvider.apk pkg=com.android.providers.calendar isa=arm vmSafeMode=false
I/dex2oat (  910): Error opening the directory: /system/lib/plugins
I/dex2oat (  910): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/CalendarProvider/CalendarProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@CalendarProvider@CalendarProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  910): Decided to run without swap.
I/dex2oat (  910): dex2oat took 442.406ms (threads: 4) arena alloc=339KB java alloc=438KB native alloc=2MB free=126KB
I/PackageManager(  620): Running dexopt on: /system/app/SoundRecorder/SoundRecorder.apk pkg=com.android.soundrecorder isa=arm vmSafeMode=false
I/dex2oat (  915): Error opening the directory: /system/lib/plugins
I/dex2oat (  915): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/SoundRecorder/SoundRecorder.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@SoundRecorder@SoundRecorder.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  915): Decided to run without swap.
I/dex2oat (  915): dex2oat took 57.807ms (threads: 4) arena alloc=95KB java alloc=86KB native alloc=1250KB free=21KB
I/PackageManager(  620): Running dexopt on: /system/app/OpenWnn/OpenWnn.apk pkg=jp.co.omronsoft.openwnn isa=arm vmSafeMode=false
I/dex2oat (  920): Error opening the directory: /system/lib/plugins
I/dex2oat (  920): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/OpenWnn/OpenWnn.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@OpenWnn@OpenWnn.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  920): Decided to run without swap.
I/dex2oat (  920): dex2oat took 259.195ms (threads: 4) arena alloc=582KB java alloc=356KB native alloc=2MB free=71KB
I/PackageManager(  620): Running dexopt on: /system/app/Calculator/Calculator.apk pkg=com.android.calculator2 isa=arm vmSafeMode=false
I/dex2oat (  925): Error opening the directory: /system/lib/plugins
I/dex2oat (  925): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Calculator/Calculator.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Calculator@Calculator.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  925): Decided to run without swap.
I/dex2oat (  925): dex2oat took 459.707ms (threads: 4) arena alloc=136KB java alloc=745KB native alloc=2MB free=225KB
I/PackageManager(  620): Running dexopt on: /system/app/RkBoxVideoPlayer/RkBoxVideoPlayer.apk pkg=android.rk.RockVideoPlayer isa=arm vmSafeMode=false
I/dex2oat (  930): Error opening the directory: /system/lib/plugins
I/dex2oat (  930): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/RkBoxVideoPlayer/RkBoxVideoPlayer.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@RkBoxVideoPlayer@RkBoxVideoPlayer.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  930): Decided to run without swap.
I/dex2oat (  930): dex2oat took 750.621ms (threads: 4) arena alloc=91KB java alloc=986KB native alloc=2MB free=257KB
I/PackageManager(  620): Running dexopt on: /system/app/DownloadProviderUi/DownloadProviderUi.apk pkg=com.android.providers.downloads.ui isa=arm vmSafeMode=false
I/dex2oat (  935): Error opening the directory: /system/lib/plugins
I/dex2oat (  935): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/DownloadProviderUi/DownloadProviderUi.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@DownloadProviderUi@DownloadProviderUi.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  935): Decided to run without swap.
I/dex2oat (  935): dex2oat took 28.624ms (threads: 4) arena alloc=94KB java alloc=54KB native alloc=1158KB free=17KB
I/PackageManager(  620): Running dexopt on: /system/app/CaptivePortalLogin/CaptivePortalLogin.apk pkg=com.android.captiveportallogin isa=arm vmSafeMode=false
I/dex2oat (  940): Error opening the directory: /system/lib/plugins
I/dex2oat (  940): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/CaptivePortalLogin/CaptivePortalLogin.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@CaptivePortalLogin@CaptivePortalLogin.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  940): Decided to run without swap.
I/dex2oat (  940): dex2oat took 67.103ms (threads: 4) arena alloc=108KB java alloc=79KB native alloc=1156KB free=23KB
I/PackageManager(  620): Running dexopt on: /system/priv-app/MusicFX/MusicFX.apk pkg=com.android.musicfx isa=arm vmSafeMode=false
I/dex2oat (  945): Error opening the directory: /system/lib/plugins
I/dex2oat (  945): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/MusicFX/MusicFX.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@MusicFX@MusicFX.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  945): Decided to run without swap.
I/dex2oat (  945): dex2oat took 157.364ms (threads: 4) arena alloc=1233KB java alloc=151KB native alloc=1974KB free=49KB
I/PackageManager(  620): Running dexopt on: /system/app/LiveWallpapers/LiveWallpapers.apk pkg=com.android.wallpaper isa=arm vmSafeMode=false
I/dex2oat (  950): Error opening the directory: /system/lib/plugins
I/dex2oat (  950): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/LiveWallpapers/LiveWallpapers.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@LiveWallpapers@LiveWallpapers.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  950): Decided to run without swap.
I/dex2oat (  950): dex2oat took 57.196ms (threads: 4) arena alloc=105KB java alloc=78KB native alloc=1183KB free=24KB
I/PackageManager(  620): Running dexopt on: /system/app/QuickSearchBox/QuickSearchBox.apk pkg=com.android.quicksearchbox isa=arm vmSafeMode=false
I/dex2oat (  955): Error opening the directory: /system/lib/plugins
I/dex2oat (  955): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/QuickSearchBox/QuickSearchBox.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@QuickSearchBox@QuickSearchBox.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  955): Decided to run without swap.
I/dex2oat (  955): dex2oat took 540.946ms (threads: 4) arena alloc=62KB java alloc=597KB native alloc=2MB free=161KB
I/PackageManager(  620): Running dexopt on: /system/app/PhaseBeam/PhaseBeam.apk pkg=com.android.phasebeam isa=arm vmSafeMode=false
I/dex2oat (  960): Error opening the directory: /system/lib/plugins
I/dex2oat (  960): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/PhaseBeam/PhaseBeam.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@PhaseBeam@PhaseBeam.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  960): Decided to run without swap.
I/dex2oat (  960): dex2oat took 28.629ms (threads: 4) arena alloc=123KB java alloc=129KB native alloc=1176KB free=23KB
I/PackageManager(  620): Running dexopt on: /system/app/RKUpdateService/RKUpdateService.apk pkg=android.rockchip.update.service isa=arm vmSafeMode=false
I/dex2oat (  965): Error opening the directory: /system/lib/plugins
I/dex2oat (  965): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/RKUpdateService/RKUpdateService.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@RKUpdateService@RKUpdateService.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  965): Decided to run without swap.
I/dex2oat (  965): dex2oat took 152.030ms (threads: 4) arena alloc=508KB java alloc=170KB native alloc=1582KB free=37KB
I/PackageManager(  620): Running dexopt on: /system/app/HTMLViewer/HTMLViewer.apk pkg=com.android.htmlviewer isa=arm vmSafeMode=false
I/dex2oat (  970): Error opening the directory: /system/lib/plugins
I/dex2oat (  970): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/HTMLViewer/HTMLViewer.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@HTMLViewer@HTMLViewer.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  970): Decided to run without swap.
I/dex2oat (  970): dex2oat took 61.039ms (threads: 4) arena alloc=103KB java alloc=75KB native alloc=882KB free=25KB
I/PackageManager(  620): Running dexopt on: /system/app/MediaFloat/MediaFloat.apk pkg=com.android.rk.mediafloat isa=arm vmSafeMode=false
I/dex2oat (  975): Error opening the directory: /system/lib/plugins
I/dex2oat (  975): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/MediaFloat/MediaFloat.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@MediaFloat@MediaFloat.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  975): Decided to run without swap.
I/dex2oat (  975): dex2oat took 56.806ms (threads: 4) arena alloc=78KB java alloc=115KB native alloc=1281KB free=26KB
I/PackageManager(  620): Running dexopt on: /system/app/Camera2/Camera2.apk pkg=com.android.camera2 isa=arm vmSafeMode=false
I/dex2oat (  980): Error opening the directory: /system/lib/plugins
I/dex2oat (  980): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Camera2/Camera2.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Camera2@Camera2.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  980): Decided to run without swap.
I/dex2oat (  980): dex2oat took 1.233s (threads: 4) arena alloc=268KB java alloc=2MB native alloc=5MB free=587KB
I/PackageManager(  620): Running dexopt on: /system/app/PacProcessor/PacProcessor.apk pkg=com.android.pacprocessor isa=arm vmSafeMode=false
I/dex2oat (  985): Error opening the directory: /system/lib/plugins
I/dex2oat (  985): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/PacProcessor/PacProcessor.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@PacProcessor@PacProcessor.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  985): Decided to run without swap.
I/dex2oat (  985): dex2oat took 18.271ms (threads: 4) arena alloc=83KB java alloc=8KB native alloc=883KB free=24KB
I/PackageManager(  620): Running dexopt on: /system/app/Bluetooth/Bluetooth.apk pkg=com.android.bluetooth isa=arm vmSafeMode=false
I/dex2oat (  990): Error opening the directory: /system/lib/plugins
I/dex2oat (  990): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Bluetooth/Bluetooth.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Bluetooth@Bluetooth.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  990): Decided to run without swap.
I/dex2oat (  990): dex2oat took 815.261ms (threads: 4) arena alloc=482KB java alloc=1390KB native alloc=4MB free=308KB
I/PackageManager(  620): Running dexopt on: /system/app/CertInstaller/CertInstaller.apk pkg=com.android.certinstaller isa=arm vmSafeMode=false
I/dex2oat (  995): Error opening the directory: /system/lib/plugins
I/dex2oat (  995): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/CertInstaller/CertInstaller.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@CertInstaller@CertInstaller.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat (  995): Decided to run without swap.
I/dex2oat (  995): dex2oat took 36.274ms (threads: 4) arena alloc=187KB java alloc=82KB native alloc=1206KB free=25KB
I/PackageManager(  620): Running dexopt on: /system/app/Gallery2/Gallery2.apk pkg=com.android.gallery3d isa=arm vmSafeMode=false
I/dex2oat ( 1000): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1000): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Gallery2/Gallery2.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Gallery2@Gallery2.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1000): Decided to run without swap.
I/dex2oat ( 1000): dex2oat took 2.209s (threads: 4) arena alloc=186KB java alloc=3MB native alloc=7MB free=983KB
I/PackageManager(  620): Running dexopt on: /system/priv-app/OneTimeInitializer/OneTimeInitializer.apk pkg=com.android.onetimeinitializer isa=arm vmSafeMode=false
I/dex2oat ( 1005): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1005): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/OneTimeInitializer/OneTimeInitializer.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@OneTimeInitializer@OneTimeInitializer.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1005): Decided to run without swap.
I/dex2oat ( 1005): dex2oat took 83.027ms (threads: 4) arena alloc=189KB java alloc=61KB native alloc=1207KB free=28KB
I/PackageManager(  620): Running dexopt on: /system/app/Galaxy4/Galaxy4.apk pkg=com.android.galaxy4 isa=arm vmSafeMode=false
I/dex2oat ( 1010): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1010): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Galaxy4/Galaxy4.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Galaxy4@Galaxy4.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1010): Decided to run without swap.
I/dex2oat ( 1010): dex2oat took 28.679ms (threads: 4) arena alloc=75KB java alloc=129KB native alloc=1172KB free=23KB
I/PackageManager(  620): Running dexopt on: /system/app/Exchange2/Exchange2.apk pkg=com.android.exchange isa=arm vmSafeMode=false
I/dex2oat ( 1015): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1015): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Exchange2/Exchange2.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Exchange2@Exchange2.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1015): Decided to run without swap.
I/dex2oat ( 1015): dex2oat took 2.758s (threads: 4) arena alloc=365KB java alloc=3MB native alloc=6MB free=1089KB
I/PackageManager(  620): Running dexopt on: /system/app/LiveWallpapersPicker/LiveWallpapersPicker.apk pkg=com.android.wallpaper.livepicker isa=arm vmSafeMode=false
I/dex2oat ( 1020): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1020): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/LiveWallpapersPicker/LiveWallpapersPicker.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@LiveWallpapersPicker@LiveWallpapersPicker.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1020): Decided to run without swap.
I/dex2oat ( 1020): dex2oat took 28.031ms (threads: 4) arena alloc=77KB java alloc=57KB native alloc=1177KB free=22KB
I/PackageManager(  620): Running dexopt on: /system/priv-app/BackupRestoreConfirmation/BackupRestoreConfirmation.apk pkg=com.android.backupconfirm isa=arm vmSafeMode=false
I/dex2oat ( 1025): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1025): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/BackupRestoreConfirmation/BackupRestoreConfirmation.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@BackupRestoreConfirmation@BackupRestoreConfirmation.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1025): Decided to run without swap.
I/dex2oat ( 1025): dex2oat took 24.406ms (threads: 4) arena alloc=101KB java alloc=25KB native alloc=1153KB free=18KB
I/PackageManager(  620): Running dexopt on: /system/app/UserDictionaryProvider/UserDictionaryProvider.apk pkg=com.android.providers.userdictionary isa=arm vmSafeMode=false
I/dex2oat ( 1030): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1030): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/UserDictionaryProvider/UserDictionaryProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@UserDictionaryProvider@UserDictionaryProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1030): Decided to run without swap.
I/dex2oat ( 1030): dex2oat took 27.449ms (threads: 4) arena alloc=65KB java alloc=20KB native alloc=899KB free=24KB
I/PackageManager(  620): Running dexopt on: /system/app/PhotoTable/PhotoTable.apk pkg=com.android.dreams.phototable isa=arm vmSafeMode=false
I/dex2oat ( 1035): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1035): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/PhotoTable/PhotoTable.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@PhotoTable@PhotoTable.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1035): Decided to run without swap.
I/dex2oat ( 1035): dex2oat took 102.875ms (threads: 4) arena alloc=435KB java alloc=156KB native alloc=1618KB free=29KB
I/PackageManager(  620): Running dexopt on: /system/priv-app/VpnDialogs/VpnDialogs.apk pkg=com.android.vpndialogs isa=arm vmSafeMode=false
I/dex2oat ( 1040): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1040): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/VpnDialogs/VpnDialogs.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@VpnDialogs@VpnDialogs.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1040): Decided to run without swap.
I/dex2oat ( 1040): dex2oat took 68.378ms (threads: 4) arena alloc=139KB java alloc=33KB native alloc=623KB free=28KB
I/PackageManager(  620): Running dexopt on: /system/app/NoiseField/NoiseField.apk pkg=com.android.noisefield isa=arm vmSafeMode=false
I/dex2oat ( 1045): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1045): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/NoiseField/NoiseField.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@NoiseField@NoiseField.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1045): Decided to run without swap.
I/dex2oat ( 1045): dex2oat took 29.362ms (threads: 4) arena alloc=78KB java alloc=128KB native alloc=1178KB free=21KB
I/PackageManager(  620): Running dexopt on: /system/priv-app/SharedStorageBackup/SharedStorageBackup.apk pkg=com.android.sharedstoragebackup isa=arm vmSafeMode=false
I/dex2oat ( 1050): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1050): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/SharedStorageBackup/SharedStorageBackup.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@SharedStorageBackup@SharedStorageBackup.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1050): Decided to run without swap.
I/dex2oat ( 1050): dex2oat took 20.845ms (threads: 4) arena alloc=110KB java alloc=22KB native alloc=886KB free=29KB
I/PackageManager(  620): Running dexopt on: /system/priv-app/ExternalStorageProvider/ExternalStorageProvider.apk pkg=com.android.externalstorage isa=arm vmSafeMode=false
I/dex2oat ( 1055): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1055): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/ExternalStorageProvider/ExternalStorageProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@ExternalStorageProvider@ExternalStorageProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1055): Decided to run without swap.
I/dex2oat ( 1055): dex2oat took 36.024ms (threads: 4) arena alloc=99KB java alloc=36KB native alloc=1059KB free=25KB
I/PackageManager(  620): Running dexopt on: /system/priv-app/Contacts/Contacts.apk pkg=com.android.contacts isa=arm vmSafeMode=false
I/dex2oat ( 1060): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1060): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/Contacts/Contacts.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@Contacts@Contacts.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1060): Decided to run without swap.
I/dex2oat ( 1060): dex2oat took 1.786s (threads: 4) arena alloc=70KB java alloc=2MB native alloc=5MB free=644KB
I/PackageManager(  620): Running dexopt on: /system/app/PicoTts/PicoTts.apk pkg=com.svox.pico isa=arm vmSafeMode=false
I/dex2oat ( 1065): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1065): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/PicoTts/PicoTts.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@PicoTts@PicoTts.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1065): Decided to run without swap.
I/dex2oat ( 1065): dex2oat took 25.111ms (threads: 4) arena alloc=71KB java alloc=58KB native alloc=1174KB free=25KB
I/PackageManager(  620): Running dexopt on: /system/app/eHomeMediaCenter_box/eHomeMediaCenter_box.apk pkg=com.rockchip.mediacenter isa=arm vmSafeMode=false
I/dex2oat ( 1070): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1070): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/eHomeMediaCenter_box/eHomeMediaCenter_box.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@eHomeMediaCenter_box@eHomeMediaCenter_box.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1070): Decided to run without swap.
I/dex2oat ( 1070): dex2oat took 1.337s (threads: 4) arena alloc=257KB java alloc=1961KB native alloc=4MB free=564KB
I/PackageManager(  620): Running dexopt on: /system/priv-app/DownloadProvider/DownloadProvider.apk pkg=com.android.providers.downloads isa=arm vmSafeMode=false
I/dex2oat ( 1075): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1075): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/DownloadProvider/DownloadProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@DownloadProvider@DownloadProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1075): Decided to run without swap.
I/dex2oat ( 1075): dex2oat took 628.231ms (threads: 4) arena alloc=119KB java alloc=423KB native alloc=2MB free=121KB
I/PackageManager(  620): Running dexopt on: /system/app/PrintSpooler/PrintSpooler.apk pkg=com.android.printspooler isa=arm vmSafeMode=false
I/dex2oat ( 1080): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1080): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/PrintSpooler/PrintSpooler.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@PrintSpooler@PrintSpooler.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1080): Decided to run without swap.
I/dex2oat ( 1080): dex2oat took 685.491ms (threads: 4) arena alloc=538KB java alloc=973KB native alloc=3MB free=270KB
I/PackageManager(  620): Running dexopt on: /system/app/Browser/Browser.apk pkg=com.android.browser isa=arm vmSafeMode=false
I/dex2oat ( 1085): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1085): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Browser/Browser.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Browser@Browser.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1085): Decided to run without swap.
I/dex2oat ( 1085): dex2oat took 983.299ms (threads: 4) arena alloc=134KB java alloc=1999KB native alloc=3MB free=434KB
I/PackageManager(  620): Running dexopt on: /system/app/BasicDreams/BasicDreams.apk pkg=com.android.dreams.basic isa=arm vmSafeMode=false
I/dex2oat ( 1090): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1090): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/BasicDreams/BasicDreams.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@BasicDreams@BasicDreams.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1090): Decided to run without swap.
I/dex2oat ( 1090): dex2oat took 27.391ms (threads: 4) arena alloc=130KB java alloc=29KB native alloc=1165KB free=22KB
I/PackageManager(  620): Running dexopt on: /system/app/webview/webview.apk pkg=com.android.webview isa=arm vmSafeMode=false
I/dex2oat ( 1095): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1095): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/webview/webview.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@webview@webview.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1095): Decided to run without swap.
I/dex2oat ( 1095): dex2oat took 667.681ms (threads: 4) arena alloc=84KB java alloc=1374KB native alloc=3MB free=370KB
I/PackageManager(  620): Running dexopt on: /system/app/RkMusic/RkMusic.apk pkg=com.android.music isa=arm vmSafeMode=false
I/dex2oat ( 1100): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1100): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/RkMusic/RkMusic.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@RkMusic@RkMusic.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1100): Decided to run without swap.
I/dex2oat ( 1100): dex2oat took 706.975ms (threads: 4) arena alloc=123KB java alloc=1071KB native alloc=3MB free=245KB
I/PackageManager(  620): Running dexopt on: /system/app/Calendar/Calendar.apk pkg=com.android.calendar isa=arm vmSafeMode=false
I/dex2oat ( 1105): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1105): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Calendar/Calendar.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Calendar@Calendar.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1105): Decided to run without swap.
I/dex2oat ( 1105): dex2oat took 1.058s (threads: 4) arena alloc=124KB java alloc=1972KB native alloc=4MB free=389KB
I/PackageManager(  620): Running dexopt on: /system/app/WAPPushManager/WAPPushManager.apk pkg=com.android.smspush isa=arm vmSafeMode=false
I/dex2oat ( 1110): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1110): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/WAPPushManager/WAPPushManager.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@WAPPushManager@WAPPushManager.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1110): Decided to run without swap.
I/dex2oat ( 1110): dex2oat took 79.254ms (threads: 4) arena alloc=136KB java alloc=65KB native alloc=1216KB free=27KB
I/PackageManager(  620): Running dexopt on: /system/app/DocumentsUI/DocumentsUI.apk pkg=com.android.documentsui isa=arm vmSafeMode=false
I/dex2oat ( 1115): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1115): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/DocumentsUI/DocumentsUI.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@DocumentsUI@DocumentsUI.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1115): Decided to run without swap.
I/dex2oat ( 1115): dex2oat took 1.026s (threads: 4) arena alloc=147KB java alloc=965KB native alloc=3MB free=279KB
I/PackageManager(  620): Running dexopt on: /system/app/RkApkinstaller/RkApkinstaller.apk pkg=com.android.apkinstaller isa=arm vmSafeMode=false
I/dex2oat ( 1120): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1120): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/RkApkinstaller/RkApkinstaller.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@RkApkinstaller@RkApkinstaller.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1120): Decided to run without swap.
I/dex2oat ( 1120): dex2oat took 61.343ms (threads: 4) arena alloc=158KB java alloc=102KB native alloc=1287KB free=28KB
I/PackageManager(  620): Running dexopt on: /system/app/Provision/Provision.apk pkg=com.android.provision isa=arm vmSafeMode=false
I/dex2oat ( 1125): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1125): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Provision/Provision.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Provision@Provision.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1125): Decided to run without swap.
I/dex2oat ( 1125): dex2oat took 17.444ms (threads: 4) arena alloc=36KB java alloc=7KB native alloc=344KB free=27KB
I/PackageManager(  620): Running dexopt on: /system/priv-app/WallpaperCropper/WallpaperCropper.apk pkg=com.android.wallpapercropper isa=arm vmSafeMode=false
I/dex2oat ( 1130): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1130): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/WallpaperCropper/WallpaperCropper.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@WallpaperCropper@WallpaperCropper.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1130): Decided to run without swap.
I/dex2oat ( 1130): dex2oat took 428.730ms (threads: 4) arena alloc=95KB java alloc=478KB native alloc=2MB free=131KB
I/PackageManager(  620): Running dexopt on: /system/app/HoloSpiralWallpaper/HoloSpiralWallpaper.apk pkg=com.android.wallpaper.holospiral isa=arm vmSafeMode=false
I/dex2oat ( 1135): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1135): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/HoloSpiralWallpaper/HoloSpiralWallpaper.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@HoloSpiralWallpaper@HoloSpiralWallpaper.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1135): Decided to run without swap.
I/dex2oat ( 1135): dex2oat took 66.482ms (threads: 4) arena alloc=56KB java alloc=125KB native alloc=1180KB free=23KB
I/PackageManager(  620): Running dexopt on: /system/app/PackageInstaller/PackageInstaller.apk pkg=com.android.packageinstaller isa=arm vmSafeMode=false
I/dex2oat ( 1140): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1140): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/PackageInstaller/PackageInstaller.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@PackageInstaller@PackageInstaller.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1140): Decided to run without swap.
I/dex2oat ( 1140): dex2oat took 362.010ms (threads: 4) arena alloc=101KB java alloc=542KB native alloc=2MB free=136KB
I/PackageManager(  620): Running dexopt on: /system/app/RKGameControlSettingV1.0.1/RKGameControlSettingV1.0.1.apk pkg=com.rockchip.gamecontrolsetting isa=arm vmSafeMode=false
I/dex2oat ( 1145): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1145): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/RKGameControlSettingV1.0.1/RKGameControlSettingV1.0.1.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@RKGameControlSettingV1.0.1@RKGameControlSettingV1.0.1.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1145): Decided to run without swap.
I/dex2oat ( 1145): dex2oat took 450.018ms (threads: 4) arena alloc=126KB java alloc=668KB native alloc=2MB free=184KB
I/PackageManager(  620): Running dexopt on: /system/app/GoogleEmail/GoogleEmail.apk pkg=com.google.android.email isa=arm vmSafeMode=false
I/dex2oat ( 1150): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1150): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/GoogleEmail/GoogleEmail.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@GoogleEmail@GoogleEmail.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1150): Decided to run without swap.
I/dex2oat ( 1150): dex2oat took 3.110s (threads: 4) arena alloc=134KB java alloc=4MB native alloc=9MB free=1173KB
I/PackageManager(  620): Running dexopt on: /system/app/Launcher3/Launcher3.apk pkg=com.android.launcher3 isa=arm vmSafeMode=false
I/dex2oat ( 1155): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1155): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Launcher3/Launcher3.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Launcher3@Launcher3.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1155): Decided to run without swap.
I/dex2oat ( 1155): dex2oat took 1.005s (threads: 4) arena alloc=1433KB java alloc=1782KB native alloc=5MB free=418KB
I/PackageManager(  620): Running dexopt on: /system/app/DeskClock/DeskClock.apk pkg=com.android.deskclock isa=arm vmSafeMode=false
I/dex2oat ( 1160): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1160): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/DeskClock/DeskClock.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@DeskClock@DeskClock.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1160): Decided to run without swap.
I/dex2oat ( 1160): dex2oat took 575.019ms (threads: 4) arena alloc=89KB java alloc=1111KB native alloc=3MB free=253KB
I/PackageManager(  620): Running dexopt on: /system/app/VisualizationWallpapers/VisualizationWallpapers.apk pkg=com.android.musicvis isa=arm vmSafeMode=false
I/InputDispatcher(  620): Dropped event because input dispatch is disabled.
I/dex2oat ( 1165): Error opening the directory: /system/lib/plugins
I/dex2oat ( 1165): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/VisualizationWallpapers/VisualizationWallpapers.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@VisualizationWallpapers@VisualizationWallpapers.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=8
I/dex2oat ( 1165): Decided to run without swap.
I/dex2oat ( 1165): dex2oat took 89.778ms (threads: 4) arena alloc=60KB java alloc=133KB native alloc=1207KB free=24KB
I/SystemServer(  620): LockSettingsService
I/SystemServiceManager(  620): Starting com.android.server.devicepolicy.DevicePolicyManagerService$Lifecycle
I/SystemServer(  620): Status Bar
I/SystemServer(  620): Clipboard Service
I/SystemServer(  620): NetworkManagement Service
I/SystemServer(  620): Text Service Manager Service
I/SystemServer(  620): Network Score Service
I/SystemServer(  620): NetworkStats Service
I/SystemServer(  620): NetworkPolicy Service
I/SystemServiceManager(  620): Starting com.android.server.wifi.p2p.WifiP2pService
I/WifiP2pService(  620): Registering wifip2p
I/SystemServiceManager(  620): Starting com.android.server.wifi.WifiService
E/WifiConfigStore(  620): associatedPartialScanPeriodMilli set to 20000
D/WifiController(  620): isAirplaneModeOn = false, isWifiEnabled = false, isScanningAvailable = false
I/WifiService(  620): Registering wifi
I/SystemServiceManager(  620): Starting com.android.server.wifi.WifiScanningService
I/WifiScanningService(  620): Creating wifiscanner
I/WifiScanningService(  620): Starting wifiscanner
I/SystemServiceManager(  620): Starting com.android.server.wifi.RttService
I/RttService(  620): Creating rttmanager
I/RttService(  620): Starting rttmanager
I/SystemServiceManager(  620): Starting com.android.server.ethernet.EthernetService
I/EthernetServiceImpl(  620): Creating EthernetConfigStore
E/IpConfigStore(  620): Error parsing configuration: java.io.FileNotFoundException: /data/misc/ethernet/ipconfig.txt: open failed: ENOENT (No such file or directory)
W/EthernetConfigStore(  620): No Ethernet configuration found. Using default.
I/EthernetServiceImpl(  620): Read stored IP configuration: IP assignment: DHCP
I/EthernetServiceImpl(  620): Proxy settings: NONE
I/EthernetService(  620): Registering service ethernet
I/SystemServer(  620): PppoeService
I/SystemServiceManager(  620): Starting com.android.server.pppoe.PppoeService
I/PppoeServiceImpl(  620): Creating PppoeServiceImpl
I/PppoeService(  620): Registering service pppoe
I/SystemServer(  620): Connectivity Service
D/ConnectivityService(  620): ConnectivityService starting up
D/ConnectivityService(  620): wifiOnly=false
E/ConnectivityService(  620): Ignoring protectedNetwork 14
I/SystemServer(  620): Network Service Discovery Service
D/NsdService(  620): Network service discovery enabled true
I/SystemServer(  620): UpdateLock Service
I/SystemServiceManager(  620): Starting com.android.server.notification.NotificationManagerService
D/ZenLog  (  620): set_zen_mode: off,setting
I/SystemServiceManager(  620): Starting com.android.server.storage.DeviceStorageMonitorService
I/SystemServer(  620): Location Manager
I/SystemServer(  620): Country Detector
I/SystemServer(  620): Search Service
I/SystemServer(  620): DropBox Service
I/SystemServer(  620): Wallpaper Service
W/WallpaperManagerService(  620): no current wallpaper -- first boot?
I/SystemServer(  620): Audio Service
W/TelecomManager(  620): Telecom Service not found.
V/AudioService(  620): monitoring device orientation
I/SystemServiceManager(  620): Starting com.android.server.DockObserver
W/DockObserver(  620): This kernel does not have dock station support
I/SystemServer(  620): Wired Accessory Manager
W/WiredAccessoryManager(  620): This kernel does not have wired headset support
I/SystemServiceManager(  620): Starting com.android.server.usb.UsbService$Lifecycle
I/SystemServer(  620): Serial Service
I/SystemServiceManager(  620): Starting com.android.server.twilight.TwilightService
I/SystemServiceManager(  620): Starting com.android.server.UiModeManagerService
I/SystemServiceManager(  620): Starting com.android.server.job.JobSchedulerService
I/SystemServiceManager(  620): Starting com.android.server.backup.BackupManagerService$Lifecycle
I/SystemServiceManager(  620): Starting com.android.server.appwidget.AppWidgetService
I/SystemServiceManager(  620): Starting com.android.server.voiceinteraction.VoiceInteractionManagerService
W/SoundTriggerHelper(  620): listModules status=0, # of modules=0
I/SystemServer(  620): DiskStats Service
I/SystemServer(  620): SamplingProfiler Service
I/SystemServer(  620): NetworkTimeUpdateService
I/SystemServer(  620): CommonTimeManagementService
I/SystemServer(  620): CertBlacklister
I/SystemServiceManager(  620): Starting com.android.server.dreams.DreamManagerService
I/SystemServer(  620): Assets Atlas Service
I/SystemServiceManager(  620): Starting com.android.server.print.PrintManagerService
D/AssetAtlas(  620): Computing best atlas configuration...
D/AssetAtlas(  620): Running Atlas Worker #1
D/AssetAtlas(  620): Running Atlas Worker #2
D/AssetAtlas(  620): Running Atlas Worker #3
D/AssetAtlas(  620): Running Atlas Worker #4
I/SystemServiceManager(  620): Starting com.android.server.restrictions.RestrictionsManagerService
D/AssetAtlas(  620): Found best atlas configuration in 0.00s
I/SystemServiceManager(  620): Starting com.android.server.media.MediaSessionService
D/AssetAtlas(  620): Loaded configuration: SliceMinArea (768x768) flags=0x2 count=2
I/SystemServer(  620): Media Router Service
I/SystemServer(  620): DisplayDeviceManagementService Service
I/mali_so (  620): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 899;
I/mali_so (  620): [Func] : base_context_deal_with_version_affairs_rk_ext; arm_release_ver of this mali_so is 'r5p0-06rel0', rk_so_ver is '8@0', built at '18:11:21', on 'Jul  2 2015'.
I/mali_so (  620): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 926;
I/mali_so (  620): [Func] : base_context_deal_with_version_affairs_rk_ext; mali_ver_property has been set to 'r5p0-06rel0-12-8@0', to return.
D/DisplayDeviceManagementService(  620): DisplayDeviceManagementService start
I/SystemServiceManager(  620): Starting com.android.server.trust.TrustManagerService
I/SystemServiceManager(  620): Starting com.android.server.fingerprint.FingerprintService
V/Fingerprint-JNI(  620): nativeInit()
V/Fingerprint-JNI(  620): nativeOpenHal()
E/Fingerprint-JNI(  620): Can't open fingerprint HW Module, error: -2
I/SystemServer(  620): BackgroundDexOptService
I/SystemServiceManager(  620): Starting com.android.server.pm.LauncherAppsService
I/SystemServiceManager(  620): Starting com.android.server.media.projection.MediaProjectionManagerService
D/AssetAtlas(  620): Rendered atlas in 15.49ms (0.09+15.40ms)
I/WindowManager(  620): SAFE MODE not enabled
I/SystemServiceManager(  620): Starting com.android.server.MmsServiceBroker
E/SQLiteLog(  620): (1) no such table: locksettings
I/LockSettingsService(  620): Migrated lock settings to new location
I/LockSettingsService(  620): Migrated per-user lock settings to new location
E/LockSettingsStorage(  620): Cannot read file java.io.FileNotFoundException: /data/system/password.key: open failed: ENOENT (No such file or directory)
E/LockSettingsStorage(  620): Cannot read file java.io.FileNotFoundException: /data/system/gesture.key: open failed: ENOENT (No such file or directory)
I/SystemServiceManager(  620): Starting phase 480
I/SystemServiceManager(  620): Starting phase 500
I/WifiService(  620): WifiService starting up with Wi-Fi disabled
D/WifiService(  620): New client listening to asynchronous messages
D/RkWifiCtrl(  620): check_wifi_preload: Wifi driver is preload when bootup.
E/WifiStateMachine(  620): setWifiState: disabled
I/WifiScanningService(  620): Registering wifiscanner
D/WifiScanningService(  620): New client, channel: null messenger: null
I/RttService(  620): Registering rttmanager
D/WifiChangeStateMachine(  620): Entering IdleState
D/WifiScanningService(  620): DefaultState
I/EthernetServiceImpl(  620): Starting Ethernet service
D/Ethernet(  620): Registering NetworkFactory
D/ConnectivityService(  620): Got NetworkFactory Messenger for Ethernet
D/Ethernet(  620): got request NetworkRequest [ id=1, legacyType=-1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
D/EthernetNetworkFactory(  620): Started tracking interface eth0
D/CommandListener(  158): Setting iface cfg
D/CommandListener(  158): Trying to bring up eth0
D/EthernetNetworkFactory(  620): updateInterface: eth0 link up
I/PppoeServiceImpl(  620): Starting PPPOE service
I/EthernetNetworkFactory(  620): dhcpThread(+eth0): mNetworkInfo=[type: Ethernet[], state: UNKNOWN/IDLE, reason: (unspecified), extra: 36:29:8c:a5:2b:b3, roaming: false, failover: false, isAvailable: true, isConnectedToProvisioningNetwork: false]
D/PppoeManager(  620): PppoeManager() : start 'pppoe handle thread'.
D/PPPOE   (  620): Registering NetworkFactory
D/ConnectivityService(  620): Got NetworkFactory Messenger for PPPOE
D/PPPOE   (  620): got request NetworkRequest [ id=1, legacyType=-1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
I/ActivityManager(  620): Config changes=200 {1.15 ?mcc?mnc en_US ?layoutDir sw720dp w1280dp h647dp 160dpi lrg long land -touch -keyb/h/h dpad/v s.4}
I/dhcpcd  ( 1212): version 5.5.6 starting
E/dhcpcd  ( 1212): get_duid: Read-only file system
I/SELinux (  620): SELinux: Loaded file_contexts from /file_contexts
V/BackupManagerService(  620): No ancestral data
D/BackupManagerService(  620): Now staging backup of com.android.browser
D/BackupManagerService(  620): Now staging backup of android
D/BackupManagerService(  620): Now staging backup of com.android.calendar
D/BackupManagerService(  620): Now staging backup of com.android.providers.settings
D/BackupManagerService(  620): Now staging backup of com.android.sharedstoragebackup
D/BackupManagerService(  620): Now staging backup of com.android.providers.userdictionary
V/BackupManagerService(  620): Starting with transport android/com.android.internal.backup.LocalTransport
V/BackupManagerService(  620): Found transports: 1
I/BackupManagerService(  620): Binding to transport host ComponentInfo{android/com.android.internal.backup.LocalTransportService}
I/dhcpcd  ( 1212): eth0: broadcasting for a lease
I/ActivityManager(  620): Sending system update to ComponentInfo{com.android.providers.calendar/com.android.providers.calendar.CalendarUpgradeReceiver} for user 0
I/ActivityManager(  620): Sending system update to ComponentInfo{com.android.providers.contacts/com.android.providers.contacts.ContactsUpgradeReceiver} for user 0
I/ActivityManager(  620): Sending system update to ComponentInfo{com.android.managedprovisioning/com.android.managedprovisioning.PreBootListener} for user 0
I/ActivityManager(  620): Sending system update to ComponentInfo{com.android.providers.media/com.android.providers.media.MediaUpgradeReceiver} for user 0
E/Lights  (  620): write_int failed to open sys/class/leds/rk29_key_led/brightness
I/Lights  (  620): >>> Enter set_keyboard_light
D/DisplayPowerController(  620): button lights toggle
I/ActivityManager(  620): Sending system update to ComponentInfo{com.android.settings/com.android.settings.ManagedProfileSetup} for user 0
D/DisplayPowerController(  620): send timeout msg after 1500
I/SystemServer(  620): Enabled StrictMode for system server main thread.
D/SurfaceFlinger(  156): Set power mode=2, type=0 flinger=0xb8a50550
D/SurfaceFlinger(  156): Screen type=0 is already mode=2
D/SurfaceFlinger(  156): Set power mode=2, type=1 flinger=0xb8a50550
I/hwcomposer(  156): hwc_blank dpy[1],blank[0]
E/Lights  (  620): write_int failed to open /sys/class/backlight/rk28_bl/brightness
I/Zygote  (  620): Process: zygote socket opened, supported ABIS: armeabi-v7a,armeabi
I/ActivityManager(  620): Start proc 1228:com.android.providers.calendar/u0a1 for broadcast com.android.providers.calendar/.CalendarUpgradeReceiver
V/ActivityManager(  620): Display changed displayId=0
V/ActivityManager(  620): Display changed displayId=1
I/DisplayManagerService(  620): Display device changed: DisplayDeviceInfo{"Built-in Screen": uniqueId="local:0", 1280 x 720, 60.000004 fps, supportedRefreshRates [60.000004], density 160, 160.15764 x 160.42105 dpi, appVsyncOff 0, presDeadline 17666666, touch INTERNAL, rotation 0, type BUILT_IN, state ON, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/WifiScanningService(  620): SCAN_AVAILABLE : 1
D/RttService(  620): SCAN_AVAILABLE : 1
I/DisplayManagerService(  620): Display device changed: DisplayDeviceInfo{"HDMI Screen": uniqueId="local:1", 1280 x 720, 60002.4 fps, supportedRefreshRates [60002.4], density 213, 213.0 x 213.0 dpi, appVsyncOff 0, presDeadline 1016666, touch EXTERNAL, rotation 0, type HDMI, state ON, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS, FLAG_PRESENTATION}
D/WifiScanningService(  620): DefaultState got{ when=0 what=160007 target=com.android.internal.util.StateMachine$SmHandler }
D/RttService(  620): DefaultState got{ when=0 what=160513 target=com.android.internal.util.StateMachine$SmHandler }
I/ActivityManager(  620): Launching preboot mode app: ProcessRecord{2b18d8ba 1228:com.android.providers.calendar/u0a1}
V/BackupManagerService(  620): Connected to transport ComponentInfo{android/com.android.internal.backup.LocalTransportService}
V/BackupManagerService(  620): Registering transport android/com.android.internal.backup.LocalTransportService::android/com.android.internal.backup.LocalTransport = android.app.backup.BackupTransport$TransportImpl@579236b
W/ResourcesManager( 1228): Asset path '/system/framework/android.test.runner.jar' does not exist or contains no resources.
I/ActivityManager(  620): Start proc 1258:android.process.acore/u0a2 for broadcast com.android.providers.contacts/.ContactsUpgradeReceiver
I/ActivityManager(  620): Launching preboot mode app: ProcessRecord{d20dec8 1258:android.process.acore/u0a2}
I/ContactsUpgradeReceiver( 1258): Creating or opening contacts database
I/ContactsDatabaseHelper( 1258): Bootstrapping database version: 910
I/ContactsProviderV1( 1258): Bootstrapping database legacy support
I/ContactsProvider( 1258): Locale has changed from null to en-US
I/ContactsDatabaseHelper( 1258): Switching to locale en-US (ICU v53.1.0.1)
I/ContactsDatabaseHelper( 1258): Locale change completed in 83ms
I/ContactsDatabaseHelper( 1258): Locale change completed in 58ms
I/ActivityManager(  620): Start proc 1279:com.android.managedprovisioning/u0a6 for broadcast com.android.managedprovisioning/.PreBootListener
I/ActivityManager(  620): Launching preboot mode app: ProcessRecord{318ffb61 1279:com.android.managedprovisioning/u0a6}
I/ActivityManager(  620): Start proc 1297:android.process.media/u0a4 for broadcast com.android.providers.media/.MediaUpgradeReceiver
I/ActivityManager(  620): Launching preboot mode app: ProcessRecord{6ebc686 1297:android.process.media/u0a4}
I/ActivityManager(  620): Start proc 1316:com.android.settings/1000 for broadcast com.android.settings/.ManagedProfileSetup
I/ActivityManager(  620): Launching preboot mode app: ProcessRecord{1a848b47 1316:com.android.settings/1000}
D/ActivityManager(  620): OK, system ready!
I/ActivityManager(  620): Removing system update proc: ProcessRecord{2b18d8ba 1228:com.android.providers.calendar/u0a1}
I/ActivityManager(  620): Killing 1228:com.android.providers.calendar/u0a1 (adj 15): system update done
I/ActivityManager(  620): Removing system update proc: ProcessRecord{d20dec8 1258:android.process.acore/u0a2}
I/ActivityManager(  620): Killing 1258:android.process.acore/u0a2 (adj 15): system update done
I/ActivityManager(  620): Removing system update proc: ProcessRecord{318ffb61 1279:com.android.managedprovisioning/u0a6}
I/ActivityManager(  620): Killing 1279:com.android.managedprovisioning/u0a6 (adj 13): system update done
I/ActivityManager(  620): Removing system update proc: ProcessRecord{6ebc686 1297:android.process.media/u0a4}
I/ActivityManager(  620): Killing 1297:android.process.media/u0a4 (adj 11): system update done
I/ActivityManager(  620): Removing system update proc: ProcessRecord{1a848b47 1316:com.android.settings/1000}
I/ActivityManager(  620): Killing 1316:com.android.settings/1000 (adj 9): system update done
I/ActivityManager(  620): System now ready
W/ActivityManager(  620): Spurious death for ProcessRecord{2b18d8ba 1228:com.android.providers.calendar/u0a1}, curProc for 1228: null
W/ActivityManager(  620): Spurious death for ProcessRecord{d20dec8 1258:android.process.acore/u0a2}, curProc for 1258: null
W/ActivityManager(  620): Spurious death for ProcessRecord{318ffb61 1279:com.android.managedprovisioning/u0a6}, curProc for 1279: null
W/ActivityManager(  620): Spurious death for ProcessRecord{6ebc686 1297:android.process.media/u0a4}, curProc for 1297: null
W/ActivityManager(  620): Spurious death for ProcessRecord{1a848b47 1316:com.android.settings/1000}, curProc for 1316: null
I/SystemServer(  620): Making services ready
I/SystemServiceManager(  620): Starting phase 550
I/Telecom (  620): TelecomGlobals: TelecomGlobals initializing
I/SystemServer(  620): WebViewFactory preparation
D/UsbHostManager(  620): Added device UsbDevice[mName=/dev/bus/usb/003/003,mVendorId=2362,mProductId=9488,mClass=0,mSubclass=0,mProtocol=0,mManufacturerName=PixArt,mProductName=USB Optical Mouse,mSerialNumber=null,mConfigurations=[
D/UsbHostManager(  620): UsbConfiguration[mId=1,mName=null,mAttributes=160,mMaxPower=50,mInterfaces=[
D/UsbHostManager(  620): UsbInterface[mId=0,mAlternateSetting=0,mName=null,mClass=3,mSubclass=1,mProtocol=2,mEndpoints=[
D/UsbHostManager(  620): UsbEndpoint[mAddress=129,mAttributes=3,mMaxPacketSize=4,mInterval=10]]]]
W/ContextImpl(  620): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1339 com.android.server.usb.UsbSettingsManager.deviceAttached:741 com.android.server.usb.UsbHostManager.endUsbDeviceAdded:224 com.android.server.usb.UsbHostManager.monitorUsbHostBus:-2 com.android.server.usb.UsbHostManager.access$000:42
I/ActivityManager(  620): Start proc 1340:android.process.acore/u0a2 for content provider com.android.providers.contacts/.CallLogProvider
D/UsbDeviceManager(  620): Usb state is true true true
I/ActivityManager(  620): Start proc 1358:WebViewLoader-armeabi-v7a/1037 [android.webkit.WebViewFactory$RelroFileCreator] for
D/BluetoothManagerService(  620): Message: 20
D/BluetoothManagerService(  620): Added callback: android.bluetooth.BluetoothAdapter$1@162d89f8:true
D/BluetoothManagerService(  620): Trying to bind to profile: 1, while Bluetooth was disabled
D/BluetoothManagerService(  620): Message: 30
D/DisplayPowerController(  620): MSG_BUTTON_LIGHTS_TIME_OUT
V/WebViewFactory( 1358): RelroFileCreator (64bit = false),  32-bit lib: /system/app/webview/lib/arm/libwebviewchromium.so, 64-bit lib:
I/ActivityManager(  620): Start proc 1378:com.android.systemui/u0a11 for service com.android.systemui/.SystemUIService
I/MountService(  620): doMountVolume: Mouting /mnt/internal_sd
D/VoldCmdListener(  155): volume mount /mnt/internal_sd
D/DirectVolume(  155): getDeviceNodes mPartIdx = 15, mDiskNumParts = 15.
E/Vold    (  155): deviceNodes[0]= 0x0000b30f,[1]= 0x00000000,[2]= 0x00000000,[3]= 0x00000000
I/Vold    (  155): /dev/block/vold/179:15 being considered for volume internal_sd,1
I/Vold    (  155):
D/Vold    (  155): Volume internal_sd state changing 1 (Idle-Unmounted) -> 3 (Checking)
I/MountService(  620): onEvent:: raw= 605 Volume internal_sd /mnt/internal_sd state changed from 1 (Idle-Unmounted) to 3 (Checking) cooked =  605 Volume internal_sd /mnt/internal_sd state changed from 1 (Idle-Unmounted) to 3 (Checking)
I/MountService(  620): notifyVolumeStateChange::unmounted
I/MountService(  620): updating volume state checking
D/MountService(  620): volume state changed for /mnt/internal_sd (unmounted -> checking)
D/MountService(  620): sendStorageIntent Intent { act=android.intent.action.MEDIA_CHECKING dat=file:///mnt/internal_sd flg=0x4000000 (has extras) } to UserHandle{-1}
I/art     (  166): Explicit concurrent mark sweep GC freed 704(30KB) AllocSpace objects, 0(0B) LOS objects, 91% free, 92KB/1116KB, paused 128us total 8.608ms
I/Telecom (  620): TelecomGlobals: CallsManager initialized
W/ContextImpl(  620): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1704 android.content.ContextWrapper.startService:516 com.android.server.telecom.BluetoothPhoneService.start:440 com.android.server.telecom.TelecomGlobals.initialize:93 com.android.server.telecom.TelecomService.onCreate:164
I/ValidateNoPeople(  620): skipping global notification
I/art     (  166): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 91% free, 92KB/1116KB, paused 140us total 8.514ms
I/art     (  166): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 91% free, 92KB/1116KB, paused 135us total 8.216ms
I/fsck_msdos(  155): ** /dev/block/vold/179:15
I/fsck_msdos(  155): ** Phase 1 - Read FAT (compare skipped)
I/fsck_msdos(  155): Attempting to allocate 5984 KB for FAT
I/art     ( 1358): System.exit called, status: 0
I/AndroidRuntime( 1358): VM exiting with result code 0, cleanup skipped.
D/EthernetNetworkFactory(  620): updateInterface: eth0 link down
D/NetworkManagementService(  620): enabling bandwidth control
V/SystemUIService( 1378): Starting SystemUI services.
V/FingerprintService(  620): startListening(android.service.fingerprint.IFingerprintServiceReceiver$Stub$Proxy@296b9c15)
I/fsck_msdos(  155): ** Phase 2 - Check Cluster Chains
I/AwesomePlayer(  162): AwesomePlayer::AwesomePlayer()in
I/fsck_msdos(  155): ** Phase 3 - Checking Directories
I/libstagefrighthw(  162): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.avc
I/libstagefrighthw(  162): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.m4v
I/libstagefrighthw(  162): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.h263
I/libstagefrighthw(  162): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.flv1
I/libstagefrighthw(  162): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.m2v
I/libstagefrighthw(  162): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.rv
I/libstagefrighthw(  162): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vp8
I/libstagefrighthw(  162): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vc1
I/libstagefrighthw(  162): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.wmv3
I/libstagefrighthw(  162): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vp6
I/libstagefrighthw(  162): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.hevc
I/libstagefrighthw(  162): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.mjpeg
I/libstagefrighthw(  162): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.avc.secure
I/libstagefrighthw(  162): OMX IL core libOMX_Core.so: declares component OMX.rk.video_encoder.avc
I/libstagefrighthw(  162): OMX IL core libOMX_Core.so: declares component OMX.rk.video_encoder.vp8
I/libstagefrighthw(  162): OMX IL core libOMX_Core.so: contains 15 components
I/AwesomePlayer(  162): AwesomePlayer::AwesomePlayer()aftermClient.connect()
E/OMXNodeInstance(  162): getParameter(1:google.mp3.decoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(1:google.mp3.decoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(2:google.amrnb.decoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(2:google.amrnb.decoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(3:google.amrwb.decoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(3:google.amrwb.decoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(4:google.aac.decoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(4:google.aac.decoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(5:google.g711.alaw.decoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(5:google.g711.alaw.decoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(6:google.g711.mlaw.decoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(6:google.g711.mlaw.decoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(7:google.vorbis.decoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(7:google.vorbis.decoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(8:google.opus.decoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(8:google.opus.decoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(9:google.raw.decoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(9:google.raw.decoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(a:google.aac.encoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(a:google.aac.encoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(b:google.amrnb.encoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(b:google.amrnb.encoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(c:google.amrwb.encoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(c:google.amrwb.encoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(d:google.flac.encoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance(  162): getParameter(d:google.flac.encoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/ROCKCHIP_VIDEO_DECCONTROL(  162): OMX_IndexParamdescribeColorFormat get
W/OMXNodeInstance(  162): [e:rk._decoder.avc] component does not support metadata mode; using fallback
W/OMXNodeInstance(  162): [f:rk._decoder.m2v] component does not support metadata mode; using fallback
W/OMXNodeInstance(  162): [10:rk._decoder.vp8] component does not support metadata mode; using fallback
W/OMXNodeInstance(  162): [11:google.vp9.decoder] component does not support metadata mode; using fallback
D/VolumeUI( 1378): Registering volume controller
W/OMXNodeInstance(  162): [12:rk._decoder.h263] component does not support metadata mode; using fallback
W/OMXNodeInstance(  162): [13:rk._decoder.m4v] component does not support metadata mode; using fallback
W/OMXNodeInstance(  162): [14:rk._decoder.flv1] component does not support metadata mode; using fallback
W/OMXNodeInstance(  162): [15:rk._decoder.vc1] component does not support metadata mode; using fallback
W/OMXNodeInstance(  162): [16:rk._decoder.mjpeg] component does not support metadata mode; using fallback
W/OMXNodeInstance(  162): [17:rk._decoder.hevc] component does not support metadata mode; using fallback
I/fsck_msdos(  155): ** Phase 4 - Checking for Lost Files
W/ACodec  (  162): do not know color format 0x7f000789 = 2130708361
I/fsck_msdos(  155): Free space in FSInfo block (-1) not correct (1530661)
I/fsck_msdos(  155): FIXED
I/fsck_msdos(  155): Next free cluster in FSInfo block (2) not free
I/fsck_msdos(  155): 1 files, 3856680 free (1530661 clusters)
W/OMXNodeInstance(  162): [19:google.h264.decoder] component does not support metadata mode; using fallback
I/Vold    (  155): Filesystem check completed OK
W/OMXNodeInstance(  162): [1a:google.vp9.decoder] component does not support metadata mode; using fallback
I/StatusBarManagerService(  620): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@3bda0330
I/SoftMPEG4Encoder(  162): Construct SoftMPEG4Encoder
I/OMXCodec(  162): --->InstantiateSoftwareCodec create OMX.google.vorbis.decoder codec
I/OMXCodec(  162): Successfully allocated OMX node 'OMX.google.vorbis.decoder'
I/OMXCodec(  162): mOutputPortSettingsHaveChanged set true
I/OMXCodec(  162): found informat change ComponentName = OMX.google.vorbis.decoder
D/PermissionMonitor(  620): Monitoring
D/PermissionMonitor(  620): Users: 1, Apps: 57
I/SystemServiceManager(  620): Starting phase 600
D/ZenLog  (  620): downtime: Autotrigger skipped: not in downtime
E/Vold    (  155): ---------set mSkipAsec to enable app2sd because mount Vfat succeed for internal_sd, mountpoint =/mnt/internal_sd
I/BackupManagerService(  620): Backup enabled => false
W/AudioCache(  162): Battery track warning: refCount is already 0
I/BackupManagerService(  620): Opting out of backup
I/FrameQueueManage(  162): FrameQueueManage::~FrameQueueManage end!
E/InputMethodManagerService(  620): Ignoring setImeWindowStatus due to an invalid token. uid:1000 token:null
W/InputMethodManagerService(  620): Reset the default IME as "Resource" is ready here.
I/InputMethodManagerService(  620): Selected default: com.android.inputmethod.latin/.LatinIME
I/ActivityManager(  620): Config changes=20 {1.15 ?mcc?mnc en_US ?layoutDir sw720dp w1280dp h647dp 160dpi lrg long land -touch -keyb/v/h dpad/v s.5}
D/Vold    (  155): blkid identified as /dev/block/vold/179:15: LABEL="ROCKCHIP" UUID="F9B6-0D04" TYPE="vfat"
I/MountService(  620): onEvent:: raw= 613 internal_sd /mnt/internal_sd "F9B6-0D04" cooked =  613 internal_sd /mnt/internal_sd F9B6-0D04
I/MountService(  620): onEvent:: raw= 614 internal_sd /mnt/internal_sd "ROCKCHIP" cooked =  614 internal_sd /mnt/internal_sd ROCKCHIP
I/ActivityManager(  620): Start proc 1537:com.android.inputmethod.latin/u0a29 for service com.android.inputmethod.latin/.LatinIME
V/InputMethodManagerService(  620): Adding window token: android.os.Binder@30859302
W/InputMethodManagerService(  620): Illegal subtype state: old subtype = null, new subtype = android.view.inputmethod.InputMethodSubtype@c9194f98
I/ContactLocale( 1340): AddressBook Labels [en-US]: [, A, B, C, D, E, F, G, H, I, J, K, L, M, N, O, P, Q, R, S, T, U, V, W, X, Y, Z, Α, Β, Γ, Δ, Ε, Ζ, Η, Θ, Ι, Κ, Λ, Μ, Ν, Ξ, Ο, Π, Ρ, Σ, Τ, Υ, Φ, Χ, Ψ, Ω, , А, Б, В, Г, Д, Ђ, Е, Є, Ж, З, И, І, Ї, Й, Ј, К, Л, Љ, М, Н, Њ, О, П, Р, С, Т, Ћ, У, Ф, Х, Ц, Ч, Џ, Ш, Щ, Ю, Я, , א, ב, ג, ד, ה, ו, ז, ח, ט, י, כ, ל, מ, נ, ס, ע, פ, צ, ק, ר, ש, ת, , ا, ب, ت, ث, ج, ح, خ, د, ذ, ر, ز, س, ش, ص, ض, ط, ظ, ع, غ, ف, ق, ك, ل, م, ن, ه, و, ي, , ก, ข, ฃ, ค, ฅ, ฆ, ง, จ, ฉ, ช, ซ, ฌ, ญ, ฎ, ฏ, ฐ, ฑ, ฒ, ณ, ด, ต, ถ, ท, ธ, น, บ, ป, ผ, ฝ, พ, ฟ, ภ, ม, ย, ร, ฤ, ล, ฦ, ว, ศ, ษ, ส, ห, ฬ, อ, ฮ, , ㄱ, ㄴ, ㄷ, ㄹ, ㅁ, ㅂ, ㅅ, ㅇ, ㅈ, ㅊ, ㅋ, ㅌ, ㅍ, ㅎ, , あ, か, さ, た, な, は, ま, や, ら, わ, #, ]
D/GpsLocationProvider(  620): Reset GPS properties, previous size = 0
D/GpsLocationProvider(  620): GpsParamsResource: SUPL_HOST=supl.google.com
D/GpsLocationProvider(  620): GpsParamsResource: SUPL_PORT=7275
D/GpsLocationProvider(  620): GpsParamsResource: NTP_SERVER=north-america.pool.ntp.org
D/GpsLocationProvider(  620): GpsParamsResource: SUPL_VER=0x20000
D/GpsLocationProvider(  620): GpsParamsResource: SUPL_MODE=1
W/GpsLocationProvider(  620): Could not open GPS configuration file /etc/gps.conf
D/GpsLocationProvider(  620): GPS properties reloaded, size = 5
E/GpsLocationProvider(  620): no AGPS interface in set_agps_server
E/GpsLocationProvider(  620): no GPS configuration interface in configuraiton_update
D/GpsLocationProvider(  620): final config = #Wed Dec 14 05:37:55 GMT+00:00 2016
D/GpsLocationProvider(  620): SUPL_VER=0x20000
D/GpsLocationProvider(  620): SUPL_HOST=supl.google.com
D/GpsLocationProvider(  620): NTP_SERVER=north-america.pool.ntp.org
D/GpsLocationProvider(  620): SUPL_PORT=7275
D/GpsLocationProvider(  620): SUPL_MODE=1
D/Vold    (  155): Volume internal_sd state changing 3 (Checking) -> 4 (Mounted)
I/MountService(  620): onEvent:: raw= 605 Volume internal_sd /mnt/internal_sd state changed from 3 (Checking) to 4 (Mounted) cooked =  605 Volume internal_sd /mnt/internal_sd state changed from 3 (Checking) to 4 (Mounted)
I/MountService(  620): notifyVolumeStateChange::checking
I/MountService(  620): updating volume state mounted
D/MountService(  620): volume state changed for /mnt/internal_sd (checking -> mounted)
I/PackageManager(  620): Updating external media status from unmounted to mounted
D/MountService(  620): sendStorageIntent Intent { act=android.intent.action.MEDIA_MOUNTED dat=file:///mnt/internal_sd flg=0x4000000 (has extras) } to UserHandle{-1}
W/ServiceWatcher(  620): com.google.android.gms not found
W/LocationManagerService(  620): no network location provider found
E/LocationManagerService(  620): no geocoder provider found
E/FlpHardwareProvider(  620): Error hw_get_module 'flp': -2
E/LocationManagerService(  620): FLP HAL not supported
E/LocationManagerService(  620): Unable to bind FLP Geofence proxy.
E/ActivityRecognitionHardware(  620): Error hw_get_module: -2
E/LocationManagerService(  620): Hardware Activity-Recognition not supported.
W/ResourcesManager(  620): Asset path '/system/framework/com.android.location.provider.jar' does not exist or contains no resources.
I/CommonTimeManagementService(  620): No common time service detected on this platform.  Common time services will be unavailable.
I/InputReader(  620): Reconfiguring input devices.  changes=0x00000020
I/MmsServiceBroker(  620): Delay connecting to MmsService until an API is called
W/VoiceInteractionManagerService(  620): no available voice interaction services found for user 0
W/VoiceInteractionManagerService(  620): no available voice recognition services found for user 0
I/InputReader(  620): Reconfiguring input devices.  changes=0x00000010
D/VoldCmdListener(  155): asec list
I/ActivityManager(  620): Start proc 1563:com.android.inputmethod.latin/u0a29 for added application com.android.inputmethod.latin
I/ActivityManager(  620): Start proc 1586:com.cghs.stresstest/1000 for added application com.cghs.stresstest
I/ActivityManager(  620): Start proc 1608:com.android.phone/1001 for added application com.android.phone
I/ActivityManager(  620): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.settings/.CryptKeeper} from uid 0 on display 0
V/WindowManager(  620): addAppToken: AppWindowToken{6cb6f72 token=Token{2f6a447d ActivityRecord{32986ad4 u0 com.android.settings/.CryptKeeper t1}}} to stack=0 task=1 at 0
I/ActivityManager(  620): Start proc 1630:com.android.settings/1000 for activity com.android.settings/.CryptKeeper
W/ActivityManager(  620): No pending application record for pid 1537 (IApplicationThread android.app.ApplicationThreadProxy@edd10be); dropping process
I/ActivityManager(  620): Start proc 1658:com.android.printspooler/u0a41 for service com.android.printspooler/.model.PrintSpoolerService
I/ActivityManager(  620): Start proc 1676:android.process.media/u0a4 for broadcast com.android.providers.media/.MtpReceiver
D/MountService(  620): sharedvolumeNum: 0 ;avail: true
V/WiredAccessoryManager(  620): init()
V/WiredAccessoryManager(  620): newName=hdmi newState=16 headsetState=16 prev headsetState=0
D/Tethering(  620): UsbManager.ACTION_USB_STATE: true, false, false
D/GpsNetInitiatedHandler(  620): location enabled :false
W/AppWidgetServiceImpl(  620): Failed to read state: java.io.FileNotFoundException: /data/system/users/0/appwidgets.xml: open failed: ENOENT (No such file or directory)
V/AppWidgetServiceImpl(  620): Upgrading widget database from 0 to 1
D/BluetoothManagerService(  620): Message: 300
D/BluetoothManagerService(  620): MESSAGE_USER_SWITCHED
I/LatinIME( 1563): Hardware accelerated drawing: true
W/art     (  620): No such thread id for suspend: 72
I/PackageManager(  620): No secure containers found
W/PackageManager(  620): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
W/PackageManager(  620): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
W/PackageManager(  620): Not granting permission android.permission.GLOBAL_SEARCH to package com.android.quicksearchbox (protectionLevel=18 flags=0x88be45)
W/PackageManager(  620): Not granting permission android.permission.ACCESS_DOWNLOAD_MANAGER to package com.android.browser (protectionLevel=18 flags=0x89be45)
W/PackageManager(  620): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x89be45)
W/PackageManager(  620): Not granting permission android.permission.BIND_WALLPAPER to package com.android.camera2 (protectionLevel=18 flags=0xd8bc45)
W/PackageManager(  620): Not granting permission android.permission.BIND_APPWIDGET to package com.android.launcher3 (protectionLevel=18 flags=0xd83e45)
W/PackageManager(  620): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.launcher3
D/PermissionCache(  156): checking android.permission.HARDWARE_TEST for uid=1000 => granted (143 us)
W/PackageManager(  620): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.launcher3
W/PackageManager(  620): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
W/PackageManager(  620): Not granting permission android.permission.INSTALL_PACKAGES to package com.android.apkinstaller (protectionLevel=18 flags=0x88be45)
W/PackageManager(  620): Not granting permission android.permission.DELETE_PACKAGES to package com.android.apkinstaller (protectionLevel=18 flags=0x88be45)
W/PackageManager(  620): Unknown permission android.Manifest.permission.INJECT_EVENTS in package com.rockchip.devicetest
W/PackageManager(  620): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.onetimeinitializer
W/PackageManager(  620): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.onetimeinitializer
W/PackageManager(  620): Unknown permission android.permission.READ_MEDIA_STORAGE in package com.android.packageinstaller
W/PackageManager(  620): Not granting permission android.permission.DELETE_PACKAGES to package com.svox.pico (protectionLevel=18 flags=0x88be45)
I/PrintSpoolerService( 1658): No existing print spooler state.
W/PackageManager(  620): Unknown permission com.google.android.gallery3d.permission.PICASA_STORE in package com.android.dreams.phototable
W/PackageManager(  620): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
W/PackageManager(  620): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.settings
W/PackageManager(  620): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.settings
W/PackageManager(  620): Not granting permission android.permission.MOUNT_UNMOUNT_FILESYSTEMS to package com.rockchip.mediacenter (protectionLevel=18 flags=0x88be45)
W/PackageManager(  620): Not granting permission android.permission.DEVICE_POWER to package com.rockchip.mediacenter (protectionLevel=2 flags=0x88be45)
W/PackageManager(  620): Unknown permission com.android.email.permission.READ_ATTACHMENT in package com.rockchip.mediacenter
W/PackageManager(  620): Not granting permission android.permission.WRITE_MEDIA_STORAGE to package com.android.music (protectionLevel=18 flags=0x88be65)
W/PackageManager(  620): Not granting permission android.permission.DEVICE_POWER to package com.android.music (protectionLevel=2 flags=0x88be65)
W/PackageManager(  620): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0xc8be45)
W/PackageManager(  620): Unknown permission com.android.email.permission.READ_ATTACHMENT in package com.android.exchange
W/PackageManager(  620): Unknown permission com.android.email.permission.ACCESS_PROVIDER in package com.android.exchange
W/PackageManager(  620): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
W/PackageManager(  620): Unknown permission android.permission.MMS_SEND_OUTBOX_MSG in package com.android.bluetooth
W/PackageManager(  620): Unknown permission rockchip.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
W/PackageManager(  620): Unknown permission android.permission.RAISED_THREAD_PRIORITY in package android.rk.RockVideoPlayer
W/PackageManager(  620): Unknown permission android.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
W/PackageManager(  620): Unknown permission archos.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
I/ActivityManager(  620): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.provision/.DefaultActivity} from uid 0 on display 0
V/WindowManager(  620): addAppToken: AppWindowToken{3fd71393 token=Token{2a855082 ActivityRecord{2de9bfcd u0 com.android.provision/.DefaultActivity t2}}} to stack=0 task=2 at 0
I/ActivityManager(  620): Start proc 1713:com.android.provision/u0a42 for activity com.android.provision/.DefaultActivity
V/WiredAccessoryManager(  620): device hdmi connected
W/ContextImpl(  620): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1339 com.android.server.WiredAccessoryManager.setDeviceStateLocked:308 com.android.server.WiredAccessoryManager.setDevicesState:257 com.android.server.WiredAccessoryManager.access$000:56 com.android.server.WiredAccessoryManager$1.handleMessage:240
D/WiredAccessoryManager(  620): --- hdmi connect
D/PowerManagerService(  620): ----------------------HdmiReceiver  state= 1
W/AudioPolicyManager(  162): setDeviceConnectionState() device already connected: 400
W/InputAttributes( 1563): No editor info for this field. Bug?
I/ResourceUtils( 1563): Found default value: resource=keypress_vibration_durations build=[HARDWARE=rk30board MODEL=firefly-rk3288 BRAND=firefly MANUFACTURER=rockchip] default=-1
I/ResourceUtils( 1563): Found default value: resource=keypress_volumes build=[HARDWARE=rk30board MODEL=firefly-rk3288 BRAND=firefly MANUFACTURER=rockchip] default=-1.0f
D/BluetoothManagerService(  620): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@7a86dda:true
D/BluetoothAdapter( 1378): 1046016206: getState() :  mService = null. Returning STATE_OFF
I/LatinIME:LogUtils( 1563): Dictionary info: dictionary = UserHistoryDictionary.en_US.dic ; version = ? ; date = 1481693875
E/BluetoothA2dpSink( 1378): Could not bind to Bluetooth A2DP Service with Intent { act=android.bluetooth.IBluetoothA2dpSink }
E/BluetoothAvrcpController( 1378): Could not bind to Bluetooth AVRCP Controller Service with Intent { act=android.bluetooth.IBluetoothAvrcpController }
I/LatinIME:LogUtils( 1563): Dictionary info: dictionary = personalization.en_US.dict ; version = ? ; date = 1481693876
I/LatinIME:LogUtils( 1563): Dictionary info: dictionary = PersonalizationPredictionDictio ; version = ? ; date = 1481693876
I/art     ( 1563): Background sticky concurrent mark sweep GC freed 4908(350KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 678KB/1117KB, paused 5.668ms total 20.440ms
D/ContactDirectoryManager( 1340): Found com.android.exchange.directory.provider
E/BluetoothHeadsetClient( 1378): Could not bind to Bluetooth Headset Client Service with Intent { act=android.bluetooth.IBluetoothHeadsetClient }
I/FusedLocation(  620): engine started (com.android.location.fused)
D/BluetoothMap( 1378): Create BluetoothMap proxy object
E/BluetoothMap( 1378): Could not bind to Bluetooth MAP Service with Intent { act=android.bluetooth.IBluetoothMap }
D/ConnectivityService(  620): listenForNetwork for NetworkRequest [ id=2, legacyType=-1, [] ]
W/BackupManagerService(  620): dataChanged but no participant pkg='com.android.providers.settings' uid=10042
I/ActivityManager(  620): Start proc 1740:com.android.exchange/u0a23 for content provider com.android.exchange/.provider.ExchangeDirectoryProvider
I/LatinIME:LogUtils( 1563): Dictionary info: dictionary = userunigram.en_US.dict ; version = ? ; date = ?
I/MediaProvider( 1676): Upgrading media database from version 0 to 800, which will destroy all old data
E/blb     ( 1378): mmEthernetVisible: false
I/CameraManagerGlobal( 1378): getCameraService: Reconnecting to camera service
D/mmk     ( 1378): onStatusChangedLocked.+++++++
E/CameraManagerGlobal( 1378): Camera id 0 has status changed to 0x1
I/CameraService(  162): getCameraCharacteristics: Switching to HAL1 shim implementation...
D/CameraHal(  162): camera_get_camera_info(1307): camera_get_camera_info(1307): camera_0 facing(0), orientation(180)
I/AwesomePlayer(  162): setDataSource_l(<no-scheme URI suppressed>)
I/ActivityManager(  620): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.launcher3/.Launcher} from uid 0 on display 0
V/WindowManager(  620): addAppToken: AppWindowToken{88c8cd5 token=Token{2d1fbd8c ActivityRecord{f28f2bf u0 com.android.launcher3/.Launcher t3}}} to stack=0 task=3 at 0
I/Binder_3( 1778): type=1400 audit(0.0:10): avc: denied { write } for name="/" dev="mmcblk0p13" ino=2 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1
I/Binder_3( 1778): type=1400 audit(0.0:11): avc: denied { add_name } for name="vpumem_observer" scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1
I/Binder_3( 1778): type=1400 audit(0.0:12): avc: denied { create } for name="vpumem_observer" scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=sock_file permissive=1
W/AppOps  (  620): Bad call: specified package media under uid 1000 but it is really 1013
I/CameraClient(  162): Opening camera 0
I/CameraHal(  162): camera_device_open(496): camera_device open
E/CameraManagerGlobal( 1378): Camera id 0 has status changed to 0x80000000
D/CameraHal(  162): gCameraHalLogLevel: 0
D/CameraHal(  162): CameraHal(138): it is a isp  camera
D/CameraHal(  162): Calling process is: /system/bin/mediaserver
I/vpu_mem_pool(  162): pid 162, open_vpu_memory_pool:473: success
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (80000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 32
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (160000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 33
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (240000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 35
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (320000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 36
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (400000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 37
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (480000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 38
I/vpu_mem_pool(  162): pid 162, vpu_memory_status_observer:927: observer: /data/vpumem_observer
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (560000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 39
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (640000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 40
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (720000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 41
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (800000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 42
E/CameraHal(  162): disconnectCamera(1691): getFocusLimits failed!
I/ActivityManager(  620): Start proc 1783:com.android.launcher3/u0a30 for activity com.android.launcher3/.Launcher
E/ActivityThread( 1740): Failed to find provider info for com.android.email.provider
I/LatinIME:LogUtils( 1563): Dictionary info: dictionary = main:en ; version = 42 ; date = 1381226429
D/TelephonyProvider( 1608): dbh.onCreate:+ db=SQLiteDatabase: /data/data/com.android.providers.telephony/databases/telephony.db
D/TelephonyProvider( 1608): dbh.createSimInfoTable:+
D/TelephonyProvider( 1608): dbh.createSimInfoTable:-
D/TelephonyProvider( 1608): dbh.createCarriersTable:+
D/TelephonyProvider( 1608): dbh.createCarriersTable:-
D/TelephonyProvider( 1608): No APNs in OEM image = /oem/telephony/apns-conf.xml Load APNs from system image
D/TelephonyProvider( 1608): confFile = /system/etc/apns-conf.xml
I/ContactDirectoryManager( 1340): deleted 0 stale rows which don't have any relevant directory
D/CameraHal_Marvin(  162):
D/CameraHal_Marvin(  162): CameraHal Version Check:
D/CameraHal_Marvin(  162):     CamSys_Head.h version:
D/CameraHal_Marvin(  162):        kernel: (0x) v0.b.0
D/CameraHal_Marvin(  162):        libisp_siliconimage_isp.so: (0x) v0.b.0
D/CameraHal_Marvin(  162):     LibIsp version:
D/CameraHal_Marvin(  162):        local: (0x) v1.27.0
D/CameraHal_Marvin(  162):        camera.rk30board.so: (0x) v1.27.0
D/CameraHal_Marvin(  162):     Sensor ISI version:
D/CameraHal_Marvin(  162):         libisp_isi_drv_XXX: (0x) v0.a.0
D/CameraHal_Marvin(  162):         libisp_siliconimage_isp.so: (0x) v0.a.0
D/CameraHal_Marvin(  162):     Tunning XML version:
D/CameraHal_Marvin(  162):         libisp_isi_drv_XXX: (22-May-2014_OUYANG_OV13850_FX288_v1.0)
D/CameraHal_Marvin(  162):         Calibdb: (06-Aug-2014_ZYL-OYYF_OV13850_CMK-CT0116-FV1_v0.1.2)
D/CameraHal_Marvin(  162):     sensor name OV13850:
D/CameraHal_Marvin(  162):        sensor drv version: (0x) v0.9.0
D/CameraHal(  162): setupPreview(248): isp out put format is YUV420SP.
I/ContactDirectoryManager( 1340): Discovered 0 contact directories in 377ms
I/ValidateNoPeople(  620): mEvictionCount: 0
V/Launcher( 1783): LauncherAppState inited
I/ContactsProvider( 1340): Upgrading aggregation algorithm
D/Launcher.Model( 1783): Old launcher provider: content://com.android.launcher2.settings/favorites?notify=true
D/Launcher.Model( 1783): Old launcher provider does not exist.
I/ContactAggregator( 1340): Marked all visible contacts for aggregation: 0 raw contacts, 3 ms
W/Launcher( 1783): setApplicationContext called twice! old=com.android.launcher3.LauncherApplication@2c7f1e81 new=com.android.launcher3.LauncherApplication@2c7f1e81
I/ContactsProvider( 1340): Aggregation algorithm upgraded for 0 raw contacts in 66ms
W/ResourceType( 1783): Attempt to retrieve bag 0x7f0d0008 which is invalid or in a cycle.
E/CameraHal_Marvin(  162): HAL-MOCKUP: PHY ADDR (0x10000000),iommu addr (0x10000000)
I/ContactsFTS( 1340): Rebuild contact search index in 49ms, 0 contacts
E/CameraHal_Marvin(  162): HAL-MOCKUP: PHY ADDR (0x112f5000),iommu addr (0x112f5000)
E/CameraHal_Marvin(  162): HAL-MOCKUP: PHY ADDR (0x125ea000),iommu addr (0x125ea000)
D/Launcher.Model( 1783): 11683562 - loadWorkspace()
D/Launcher.LauncherProvider( 1783): loading default workspace
E/DefaultLayoutParser( 1783): Default layout parser initialized
E/CameraHal_Marvin(  162): HAL-MOCKUP: PHY ADDR (0x138df000),iommu addr (0x138df000)
D/OpenGLRenderer( 1783): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
D/Atlas   ( 1783): Validating map...
V/WindowManager(  620): Based on layer: Adding window Window{3d529008 u0 com.android.launcher3/com.android.launcher3.Launcher} at 0 of 1
D/Launcher.LauncherProvider( 1783): 11683562 - initializeMaxScreenId(): 0
I/mali_so ( 1783): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 899;
I/mali_so ( 1783): [Func] : base_context_deal_with_version_affairs_rk_ext; arm_release_ver of this mali_so is 'r5p0-06rel0', rk_so_ver is '8@0', built at '18:11:21', on 'Jul  2 2015'.
I/mali_so ( 1783): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 926;
I/mali_so ( 1783): [Func] : base_context_deal_with_version_affairs_rk_ext; mali_ver_property has been set to 'r5p0-06rel0-12-8@0', to return.
D/Launcher.Model( 1783): 11683562 -   loadedOldDb: false
I/OpenGLRenderer( 1783): Initialized EGL, version 1.4
D/CameraHal(  162): enableSensor(203): orientation = 0xb8f00ae0 (MPL accel)
V/Sensors (  620): int poll__activate(sensors_poll_device_t*, int, int)
V/Sensors (  620): int sensors_poll_context_t::activate(int, int)
V/Sensors (  620): enable - sensor Accelerometer (handle 4) dis -> en
E/Sensors (  620): MPU is not available
V/Sensors (  620): int poll__setDelay(sensors_poll_device_t*, int, int64_t)
V/Sensors (  620): int sensors_poll_context_t::setDelay(int, int64_t)
V/Sensors (  620): setDelay - sensor Accelerometer (handle 4), rate 20 ms (50.00 Hz)
V/Sensors (  620): setDelay - sensor Accelerometer (handle 4), rate 100 ms (10.00 Hz)
W/CameraService(  162): CameraService::connect X (id 0, this pid is 162, name media)
D/CameraHal(  162): commandThread(988): commandThread(988): receive CMD_PREVIEW_CAPTURE_CANCEL
D/CameraHal(  162): commandThread(996): commandThread(996): CMD_PREVIEW_CAPTURE_CANCEL out
D/CameraHal(  162): cancelPicture(566): cancel picture OK.
D/CameraHal(  162): commandThread(916): commandThread(916):receive CMD_PREVIEW_STOP
D/CameraHal(  162): commandThread(937): commandThread(937): CMD_PREVIEW_STOP out
D/CameraHal(  162): stopPreview(367): stop preview OK.
I/CameraClient(  162): Destroying camera 0
D/CameraHal(  162): camera_device_close(447): camera_device_close
D/CameraHal(  162): disableSensor(222): orientation = 0xb8f00ae0 (MPL accel)
V/Sensors (  620): enable - sensor Accelerometer (handle 4) en -> dis
D/CameraHal(  162): ~SensorListener(110): Kill looper thread
D/CameraHal(  162): ~SensorListener(122): Kill looper
D/CameraHal(  162): ~SensorListener(128): SensorListener destroyed
D/CameraHal(  162): displayThread(615): displayThread(615): receive CMD_DISPLAY_STOP
D/CameraHal(  162): cameraDisplayBufferDestory(392): cameraDisplayBufferDestory(392): mANativeWindow is NULL, destory is ignore
D/CameraHal(  162): encProcessThread(1522): encProcessThread(1522): receive CMD_ENCPROCESS_EXIT
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (720000)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (640000)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (560000)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (480000)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (400000)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (320000)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (240000)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (160000)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (80000)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (0)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:552:
D/OpenGLRenderer( 1783): Enabling debug mode 0
D/Launcher.Model( 1783): 11683562 - loadWorkspaceScreensDb()
D/Launcher.Model( 1783): 11683562 -   screens:
D/Launcher.Model( 1783): 11683562 -   sBgWorkspaceScreens:
E/SQLiteLog( 1676): (1) no such table: album_info
D/xzj     ( 1676): true---------------------------ooooooooooo,stop mtp service---------------false
I/ActivityManager(  620): Start proc 1847:android.rockchip.update.service/1000 for broadcast android.rockchip.update.service/.RKUpdateReceiver
I/art     (  166): Explicit concurrent mark sweep GC freed 704(30KB) AllocSpace objects, 0(0B) LOS objects, 91% free, 92KB/1116KB, paused 1.165ms total 8.442ms
E/CameraHal_Marvin(  162): OV13850:  STREAM OFF ++++++++++++++
I/art     (  166): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 91% free, 92KB/1116KB, paused 99us total 6.667ms
I/DownloadManager( 1676): Upgrading downloads database from version 0 to version 109, which will destroy all old data
D/CameraHal(  162): commandThread(1100): commandThread(1100): receive CMD_EXIT
D/CameraHal(  162): ~CameraHal(298): CameraHal destory success
W/CameraService(  162): removeClient: clear camera 0, package name media
I/art     (  166): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 91% free, 92KB/1116KB, paused 121us total 9.205ms
I/ActivityManager(  620): Displayed com.android.launcher3/.Launcher: +539ms (total +1s124ms)
D/mmk     ( 1378): updateCallbackLocked.+++++++
D/mmk     ( 1378): postSingleUpdate.+++++++++ status = 1
D/Launcher( 1783): 11683562 - bindAddScreens()
D/Launcher( 1783): 11683562 -   orderedScreenIds:
D/Launcher.Workspace( 1783): 11683562 - addExtraEmptyScreen()
D/Launcher.Workspace( 1783): 11683562 - insertNewWorkspaceScreen(): -201 at index: 0
D/RKUpdateReceiver( 1847): action = android.hardware.usb.action.USB_STATE
D/UserManager( 1378): ---getMaxSupportedUsers,we has UMS,force disabled M-user---
D/TelephonyProvider( 1608): dbh.onCreate:- db=SQLiteDatabase: /data/data/com.android.providers.telephony/databases/telephony.db
D/TelephonyProvider( 1608): dbh.onOpen: ok, queried table=siminfo
D/TelephonyProvider( 1608): dbh.onOpen: ok, queried table=carriers
V/KeyguardServiceDelegate(  620): *** Keyguard: can't bind to com.android.systemui.keyguard.KeyguardService
W/KeyguardServiceDelegate(  620): onScreenTurnedOn(): no keyguard service!
V/Sensors (  620): setDelay - sensor Accelerometer (handle 4), rate 66 ms (15.00 Hz)
D/OpenGLRenderer( 1378): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
D/Atlas   ( 1378): Validating map...
D/PhoneStatusBar( 1378): disable: < EXPAND* icons alerts system_info BACK* HOME* RECENT* clock SEARCH* >
I/ActivityManager(  620): Start proc 1874:com.android.smspush/u0a50 for service com.android.smspush/.WapPushManager
D/GpsLocationProvider(  620): received SIM realted action:
E/DcSwitchStateMachine-0( 1608): DctController is not ready
E/ConnectivityService(  620): Failed to find Messenger in unregisterNetworkFactory
D/ConnectivityService(  620): Got NetworkFactory Messenger for Telephony
D/GpsLocationProvider(  620): SIM MCC/MNC is still not available
D/PhoneStatusBar( 1378): heads up is enabled
D/BluetoothManagerService(  620): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@325fb3e5:true
D/StatusBar( 1378): user hasn't seen notification about hidden notifications
D/StatusBar( 1378): insecure lockscreen, skipping notification
W/BackupManagerService(  620): dataChanged but no participant pkg='com.android.providers.settings' uid=10011
I/Choreographer( 1378): Skipped 102 frames!  The application may be doing too much work on its main thread.
I/Telephony( 1608): TtyManager: updateUiTtyMode -1 -> 0
D/ViewRootImpl( 1378): changeCanvasOpacity: opaque=true
I/mali_so ( 1378): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 899;
I/mali_so ( 1378): [Func] : base_context_deal_with_version_affairs_rk_ext; arm_release_ver of this mali_so is 'r5p0-06rel0', rk_so_ver is '8@0', built at '18:11:21', on 'Jul  2 2015'.
I/mali_so ( 1378): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 926;
I/mali_so ( 1378): [Func] : base_context_deal_with_version_affairs_rk_ext; mali_ver_property has been set to 'r5p0-06rel0-12-8@0', to return.
I/OpenGLRenderer( 1378): Initialized EGL, version 1.4
D/OpenGLRenderer( 1378): Enabling debug mode 0
D/Launcher.Model( 1783): going to save icon bitmap for info=ShortcutInfo(title=Galleryintent=Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.gallery3d/.app.Gallery (has extras) }id=4 type=0 container=-101 screen=5 cellX=5 cellY=0 spanX=1 spanY=1 dropPos=null user=UserHandle{0})
W/BackupManagerService(  620): dataChanged but no participant pkg='com.android.launcher3' uid=10030
D/Launcher.Model( 1783): going to save icon bitmap for info=ShortcutInfo(title=Settingsintent=Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.settings/.Settings (has extras) }id=2 type=0 container=-101 screen=2 cellX=2 cellY=0 spanX=1 spanY=1 dropPos=null user=UserHandle{0})
D/Launcher.Model( 1783): going to save icon bitmap for info=ShortcutInfo(title=Videointent=Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=android.rk.RockVideoPlayer/.RockVideoPlayer (has extras) }id=1 type=0 container=-101 screen=1 cellX=1 cellY=0 spanX=1 spanY=1 dropPos=null user=UserHandle{0})
D/Launcher.Model( 1783): going to save icon bitmap for info=ShortcutInfo(title=Browserintent=Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 pkg=com.android.browser cmp=com.android.browser/.BrowserActivity (has extras) }id=3 type=0 container=-101 screen=4 cellX=4 cellY=0 spanX=1 spanY=1 dropPos=null user=UserHandle{0})
D/StorageNotification( 1378): ---------------MEDIA_MOUNTED---------------
E/NetworkController( 1378): onReceive ETHERNET_STATE_CHANGED_ACTION
D/TelephonyDebugService( 1608): TelephonyDebugService()
D/PhoneStatusBar( 1378): disable: < expand* icons alerts system_info back* home* recent* clock search* >
I/Telephony( 1608): PstnIncomingCallNotifier: Registering: Handler (com.android.internal.telephony.gsm.GSMPhone) {37461f27}
V/KeyguardUpdateMonitor( 1378): action android.intent.action.SIM_STATE_CHANGED state: NOT_READY slotId: 0 subid: 0
D/OpenGLRenderer( 1378): setting property extraRasterBucket to 0.95
D/OpenGLRenderer( 1378):     failed
D/OpenGLRenderer( 1378): setting property extraRasterBucket to 0.0
D/KeyguardUpdateMonitor( 1378): handleSimStateChange(subId=0, slotId=0, state=NOT_READY)
V/KeyguardUpdateMonitor( 1378): onSubscriptionInfoChanged()
V/KeyguardUpdateMonitor( 1378): onSubscriptionInfoChanged: list is null
W/WindowManager(  620): Keyguard drawn timeout. Setting mKeyguardDrawComplete
I/SurfaceFlinger(  156): Boot is finished (74590 ms)
E/installd(  163): Unable to unlink boot marker at /data/dalvik-cache/arm/.booting, error=No such file or directory
E/ActivityManager(  620): Unable to mark boot complete for abi: armeabi-v7a
I/SystemServiceManager(  620): Starting phase 1000
I/ActivityManager(  620): Start proc 1927:com.rockchip.devicetest/1000 for broadcast com.rockchip.devicetest/.BootReceiver
V/TestService( 1927): action:android.intent.action.MEDIA_MOUNTED
V/TestService( 1927): pathfile:///mnt/internal_sd,bootcomplete=true
V/TestService( 1927): path1:file:///mnt/internal_sd
W/ContextImpl( 1927): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1704 android.content.ContextWrapper.startService:516 android.content.ContextWrapper.startService:516 com.rockchip.devicetest.BootReceiver.onReceive:58 android.app.ActivityThread.handleReceiver:2609
I/chip.devicetest( 1927): type=1400 audit(0.0:13): avc: denied { write } for name="force_usb_mode" dev="sysfs" ino=12262 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
D/TestService( 1927): onCreate
I/ActivityManager(  620): Start proc 1950:com.android.externalstorage/u0a5 for broadcast com.android.externalstorage/.MountReceiver
D/TestService( 1927): onStartCommand,from:mount
D/StorageList( 1927): VolumnState:mounted
D/StorageList( 1927): Storage'paths:/mnt/internal_sd state:mounted
D/StorageList( 1927): VolumnState:removed
D/StorageList( 1927): Storage'paths:/mnt/external_sd state:removed
D/StorageList( 1927): Storage'paths:/mnt/usb_storage/USB_DISK0 state:removed
D/StorageList( 1927): Storage'paths:/mnt/usb_storage/USB_DISK1 state:removed
D/StorageList( 1927): Storage'paths:/mnt/usb_storage/USB_DISK2 state:removed
D/StorageList( 1927): Storage'paths:/mnt/usb_storage/USB_DISK3 state:removed
D/StorageList( 1927): Storage'paths:/mnt/usb_storage/USB_DISK4 state:removed
D/StorageList( 1927): Storage'paths:/mnt/usb_storage/USB_DISK5 state:removed
D/DeviceTest-FileUitls( 1927): find path:/mnt/internal_sd
D/DeviceTest-FileUitls( 1927): find path:/mnt/external_sd
D/DeviceTest-FileUitls( 1927): find path:/mnt/usb_storage/USB_DISK0
D/DeviceTest-FileUitls( 1927): find path:/mnt/usb_storage/USB_DISK1
D/DeviceTest-FileUitls( 1927): find path:/mnt/usb_storage/USB_DISK2
D/DeviceTest-FileUitls( 1927): find path:/mnt/usb_storage/USB_DISK3
D/DeviceTest-FileUitls( 1927): find path:/mnt/usb_storage/USB_DISK4
D/DeviceTest-FileUitls( 1927): find path:/mnt/usb_storage/USB_DISK5
D/ExternalStorage( 1950): After updating volumes, found 1 active roots
D/DeviceTest-FileUitls( 1927): find file:/mnt/internal_sd/LOST.DIR
D/DeviceTest-FileUitls( 1927): find file:/mnt/internal_sd/.android_secure
D/DeviceTest-FileUitls( 1927): find file:/mnt/internal_sd/Music
D/DeviceTest-FileUitls( 1927): find file:/mnt/internal_sd/Podcasts
D/DeviceTest-FileUitls( 1927): find file:/mnt/internal_sd/Ringtones
D/DeviceTest-FileUitls( 1927): find file:/mnt/internal_sd/Alarms
D/DeviceTest-FileUitls( 1927): find file:/mnt/internal_sd/Notifications
D/DeviceTest-FileUitls( 1927): find file:/mnt/internal_sd/Pictures
D/DeviceTest-FileUitls( 1927): find file:/mnt/internal_sd/Movies
D/DeviceTest-FileUitls( 1927): find file:/mnt/internal_sd/Download
D/DeviceTest-FileUitls( 1927): find file:/mnt/internal_sd/DCIM
D/TestService( 1927): no DeviceTest.apk
D/TestService( 1927): Rock Recv Mount action. 77694
D/MediaScannerReceiver( 1676): action: android.intent.action.MEDIA_MOUNTED path: /mnt/internal_sd
D/RKUpdateReceiver( 1847): action = android.intent.action.MEDIA_MOUNTED
I/ActivityManager(  620): Start proc 1972:com.android.music/u0a47 for broadcast com.android.music/.MediaButtonIntentReceiver
D/MediaScannerService( 1676): start scanning volume external: [/mnt/internal_sd]
D/DisplayOutputManager( 1630): main display iface num is 2
D/DisplayOutputManager( 1630): HDMI
D/DisplayOutputManager( 1630): VGA
D/LyricManager( 1972): lrc layout w = 1110, lrc layout h = 115, left = 85, top = 595
E/DisplayOutputManager( 1630): Error listing aux interfaces :java.lang.NullPointerException: Attempt to get length of null array
D/HdmiReceiver( 1630): hdmi receiver action=android.intent.action.HDMI_PLUG
D/BluetoothManagerService(  620): Retrieving Bluetooth Adapter name and address...
D/BluetoothManagerService(  620): getNameAndAddress(): mBluetooth = null mBinding = false
D/BluetoothManagerService(  620): Message: 200
D/BluetoothManagerService(  620): MESSAGE_GET_NAME_AND_ADDRESS
D/BluetoothManagerService(  620): Binding to service to get name and address
V/MediaScanner( 1676): pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@1f6ccb75
V/MediaScanner( 1676): /pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@1f6ccb75
I/ActivityManager(  620): Start proc 1993:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
I/art     (  620): Explicit concurrent mark sweep GC freed 17533(1687KB) AllocSpace objects, 16(802KB) LOS objects, 33% free, 6MB/9MB, paused 1.144ms total 61.846ms
I/ActivityManager(  620): Start proc 2012:com.android.keychain/1000 for service com.android.keychain/.KeyChainService
D/OpenGLRenderer( 1630): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
D/Atlas   ( 1630): Validating map...
I/RecoverySystem(  620): Deleted: /cache/recovery/log
I/BootReceiver(  620): Copying /proc/last_kmsg to DropBox (SYSTEM_LAST_KMSG)
W/ResourcesManager( 1993): Asset path '/system/framework/javax.obex.jar' does not exist or contains no resources.
D/HdmiReceiver( 1630): hdmi receiver action=android.intent.action.BOOT_COMPLETED
D/HdmiReceiver( 1630): BOOT_COMPLETED
D/MediaScannerService( 1676): done scanning volume external
E/SystemUIBootReceiver( 1378): BootReceiver:config.disable_systemui=true
V/TestService( 1927): action:android.intent.action.BOOT_COMPLETED
V/TestService( 1927): getSystemAbnormalRestartTime0:0
V/TestService( 1927): setSystemStart0:false
V/TestService( 1927): SystemUtils.isBootComplete()=true
I/BootReceiver(  620): Copying /cache/recovery/last_kmsg to DropBox (SYSTEM_RECOVERY_KMSG)
D/AdapterServiceConfig( 1993): Adding HeadsetService
D/AdapterServiceConfig( 1993): Adding A2dpService
D/AdapterServiceConfig( 1993): Adding HidService
D/AdapterServiceConfig( 1993): Adding HealthService
D/AdapterServiceConfig( 1993): Adding PanService
D/AdapterServiceConfig( 1993): Adding GattService
D/BluetoothServiceJni( 1993): int android::check_wifi_chip_type_string(char*): AP6210
D/BluetoothServiceJni( 1993): void android::classInitNative(JNIEnv*, jclass), load bluetooth.default.so
V/TestService( 1927): setSystemStart1:true
W/ContextImpl( 1927): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1704 android.content.ContextWrapper.startService:516 android.content.ContextWrapper.startService:516 com.rockchip.devicetest.BootReceiver.onReceive:77 android.app.ActivityThread.handleReceiver:2609
I/BootReceiver(  620): Copying audit failures to DropBox
I/BootReceiver(  620): Copied 0 worth of audits to DropBox
D/BluetoothManagerService(  620): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@26a11dce:true
D/BluetoothAdapterState( 1993): make
I/BootReceiver(  620): Checking for fsck errors
I/bluedroid( 1993): init
I/BluetoothAdapterState( 1993): Entering OffState
E/bt-btif ( 1993): btif_config_get(L190): assert failed: section && *section && key && *key && name && *name && bytes && type
I/bte_conf( 1993): bte_load_conf attempt to load stack conf from /etc/bluetooth/bt_stack.conf
V/TestService( 1927): getSystemAbnormalRestartTime1:0
I/bte_conf( 1993): bte_load_ble_conf attempt to load ble stack conf from /etc/bluetooth/ble_stack.conf
I/mali_so ( 1630): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 899;
I/mali_so ( 1630): [Func] : base_context_deal_with_version_affairs_rk_ext; arm_release_ver of this mali_so is 'r5p0-06rel0', rk_so_ver is '8@0', built at '18:11:21', on 'Jul  2 2015'.
I/mali_so ( 1630): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 926;
I/mali_so ( 1630): [Func] : base_context_deal_with_version_affairs_rk_ext; mali_ver_property has been set to 'r5p0-06rel0-12-8@0', to return.
E/bt_osi_config( 1993): config_new unable to open file '/etc/bluetooth/ble_stack.conf': No such file or directory
I/bte_conf( 1993): bte_load_ble_conf file >/etc/bluetooth/ble_stack.conf< not found
I/OpenGLRenderer( 1630): Initialized EGL, version 1.4
I/bluedroid( 1993): get_profile_interface socket
I/bluedroid( 1993): get_profile_interface map_client
I/GKI_LINUX( 1993): gki_task_entry task_id=1 [BTIF] starting
D/BluetoothAdapterProperties( 1993): Address is:22:22:74:19:03:E2
D/OpenGLRenderer( 1630): Enabling debug mode 0
I/ActivityManager(  620): Start proc 2052:com.rockchip.mediacenter/u0a51 for broadcast com.rockchip.mediacenter/.BootReceiver
D/BluetoothAdapterProperties( 1993): Name is: firefly
D/BluetoothManagerService(  620): Bluetooth Adapter name changed to firefly
D/BluetoothManagerService(  620): Stored Bluetooth name: firefly
D/BluetoothManagerService(  620): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
D/BluetoothManagerService(  620): Message: 40
D/BluetoothManagerService(  620): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
I/bluedroid( 1993): config_hci_snoop_log
D/BluetoothManagerService(  620): Message: 201
D/BluetoothManagerService(  620): MESSAGE_SAVE_NAME_AND_ADDRESS
I/art     (  620): Background sticky concurrent mark sweep GC freed 2389(380KB) AllocSpace objects, 21(2MB) LOS objects, 30% free, 6MB/9MB, paused 5.511ms total 20.153ms
D/BluetoothAdapterState( 1993): CURRENT_STATE=OFF, MESSAGE = USER_TURN_ON
D/BluetoothAdapterProperties( 1993): Setting state to 11
I/BluetoothAdapterState( 1993): Bluetooth adapter state changed: 10-> 11
D/BluetoothBondStateMachine( 1993): make
W/art     (  620): Long monitor contention event with owner method=void com.android.server.am.ActivityManagerService.removeContentProvider(android.os.IBinder, boolean) from ActivityManagerService.java:9570 waiters=2 for 161ms
W/art     (  620): Long monitor contention event with owner method=void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread) from ActivityManagerService.java:6119 waiters=1 for 162ms
I/BluetoothBondStateMachine( 1993): StableState(): Entering Off State
D/TestService( 1927): onStartCommand,from:boot
D/BluetoothAdapterService( 1993): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@6317b26
D/HeadsetService( 1993): Received start request. Starting profile...
I/BluetoothHeadsetServiceJni( 1993): classInitNative: succeeds
D/HeadsetStateMachine( 1993): make
D/HeadsetStateMachine( 1993): max_hf_connections = 1
I/bluedroid( 1993): get_profile_interface handsfree
I/BluetoothAdapterState( 1993): Entering PendingCommandState State: isTurningOn()=true, isTurningOff()=false
D/HeadsetStateMachine( 1993): Enter Disconnected: -2, size: 0
D/BluetoothA2dp(  620): Proxy object connected
D/BluetoothA2dp( 1378): Proxy object connected
D/BluetoothAdapter(  620): 729670395: getState() :  mService = null. Returning STATE_OFF
D/A2dpService( 1993): Received start request. Starting profile...
I/BluetoothAvrcpServiceJni( 1993): classInitNative: succeeds
I/bluedroid( 1993): get_profile_interface avrcp
D/TestService( 1927): Rock Recv boot action. 78366
D/TestService( 1927): Rock check storage inter_path=/mnt/internal_sd
D/TestService( 1927): Rock check storage, mounted.
E/RemoteController( 1993): Cannot set synchronization mode on an unregistered RemoteController
I/BluetoothA2dpServiceJni( 1993): classInitNative: succeeds
D/A2dpStateMachine( 1993): make
I/bluedroid( 1993): get_profile_interface a2dp
I/GKI_LINUX( 1993): gki_task_entry task_id=2 [A2DP-MEDIA] starting
D/A2dpStateMachine( 1993): Enter Disconnected: -2
I/BluetoothHidServiceJni( 1993): classInitNative: succeeds
D/BluetoothInputDevice( 1378): Proxy object connected
D/HidService( 1993): Received start request. Starting profile...
I/bluedroid( 1993): get_profile_interface hidhost
I/BluetoothHealthServiceJni( 1993): classInitNative: succeeds
D/HealthService( 1993): Received start request. Starting profile...
I/bluedroid( 1993): get_profile_interface health
I/BluetoothPanServiceJni( 1993): classInitNative(L105): succeeds
D/BluetoothPan( 1378): BluetoothPAN Proxy object connected
D/PanService( 1993): Received start request. Starting profile...
D/BluetoothPanServiceJni( 1993): initializeNative(L110): pan
I/bluedroid( 1993): get_profile_interface pan
I/BtGatt.JNI( 1993): classInitNative(L873): classInitNative: Success!
D/BtGatt.DebugUtils( 1993): handleDebugAction() action=null
D/BtGatt.GattService( 1993): Received start request. Starting profile...
D/BtGatt.GattService( 1993): start()
I/bluedroid( 1993): get_profile_interface gatt
D/BtGatt.AdvertiseManager( 1993): advertise manager created
I/ActivityManager(  620): Start proc 2083:com.rockchip.mediacenter:service/u0a51 for service com.rockchip.mediacenter/.SystemDeviceService
D/HeadsetStateMachine( 1993): Proxy object connected
D/HeadsetStateMachine( 1993): Disconnected process message: 10, size: 0
D/BluetoothAdapterState( 1993): CURRENT_STATE=PENDING, MESSAGE = STARTED, isTurningOn=true, isTurningOff=false
I/bluedroid( 1993): enable
I/bt_hci_bdroid( 1993): init
D/RkWifiCtrl( 1993): check_wifi_chip_type_string: AP6210
D/bt_vendor( 1993): vendor_open load libbt-vendor.so
D/HeadsetPhoneState( 1993): sendDeviceStateChanged. mService=0 mSignal=0 mRoam=0 mBatteryCharge=5
D/HeadsetStateMachine( 1993): Disconnected process message: 11, size: 0
I/GKI_LINUX( 1993): gki_task_entry task_id=0 [BTU] starting
I/bt-btu  ( 1993): btu_task pending for preload complete event
I/bt_vendor( 1993): init
I/bt_vnd_conf( 1993): Attempt to load conf from /etc/bluetooth/bt_vendor.conf
I/bt_vnd_conf( 1993): vnd_load_conf file >/etc/bluetooth/bt_vendor.conf< not found
D/bt_hci_bdroid( 1993): init, use hci h4
D/bt_userial( 1993): userial_init
D/WIFI    (  620): Registering NetworkFactory
D/WIFI_UT (  620): Registering NetworkFactory
D/ConnectivityService(  620): Got NetworkFactory Messenger for WIFI
D/ConnectivityService(  620): Got NetworkFactory Messenger for WIFI_UT
D/WIFI    (  620): got request NetworkRequest [ id=1, legacyType=-1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
D/WIFI_UT (  620): got request NetworkRequest [ id=1, legacyType=-1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
I/ActivityManager(  620): Start proc 2105:com.android.calendar/u0a17 for broadcast com.android.calendar/.UpgradeReceiver
D/bt_upio ( 1993): Delay 500ms for bluetooth power up
W/art     (  620): Long monitor contention event with owner method=void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread) from ActivityManagerService.java:6119 waiters=2 for 123ms
D/ExtensionsFactory( 2105): No custom extensions.
I/ActivityManager(  620): Start proc 2129:com.android.providers.calendar/u0a1 for broadcast com.android.providers.calendar/.CalendarReceiver
W/ResourcesManager( 2129): Asset path '/system/framework/android.test.runner.jar' does not exist or contains no resources.
I/CalendarDatabaseHelper( 2129): Bootstrapping database
I/CalendarProvider2( 2129): Created com.android.providers.calendar.CalendarAlarmManager@34d81a68(com.android.providers.calendar.CalendarProvider2@2c7f1e81)
I/ActivityManager(  620): Start proc 2150:com.android.managedprovisioning/u0a6 for broadcast com.android.managedprovisioning/.BootReminder
I/art     (  166): Explicit concurrent mark sweep GC freed 704(30KB) AllocSpace objects, 0(0B) LOS objects, 91% free, 92KB/1116KB, paused 291us total 19.713ms
I/art     (  166): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 91% free, 92KB/1116KB, paused 205us total 13.475ms
I/art     (  166): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 91% free, 92KB/1116KB, paused 209us total 12.982ms
D/PowerManagerService(  620): LockScreenOff10
D/MediaScannerService( 1676): start scanning volume internal: [/system/media, /oem/media]
I/ActivityManager(  620): Start proc 2171:com.android.onetimeinitializer/u0a8 for broadcast com.android.onetimeinitializer/.OneTimeInitializerReceiver
V/OneTimeInitializerRece( 2171): OneTimeInitializerReceiver.onReceive
I/OneTimeInitializerServ( 2171): Updating to version 1.
E/ActivityThread( 2171): Failed to find provider info for com.android.launcher2.settings
D/AlertReceiver( 2105): onReceive: a=android.intent.action.BOOT_COMPLETED Intent { act=android.intent.action.BOOT_COMPLETED flg=0x8000010 cmp=com.android.calendar/.alerts.AlertReceiver (has extras) }
D/AlertUtils( 2105): Flushing old alerts from shared prefs table
I/ActivityManager(  620): Start proc 2195:com.android.camera2/u0a18 for broadcast com.android.camera2/com.android.camera.DisableCameraReceiver
D/AlertService( 2105): 0 Action = android.intent.action.BOOT_COMPLETED
D/AlertService( 2105): Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null
I/bt_userial_vendor( 1993): userial vendor open: opening /dev/ttyS0
I/bt_userial_vendor( 1993): device fd = 55 open
D/bt_userial( 1993): Entering userial_read_thread()
I/bt_hwcfg( 1993): bt vendor lib: set UART baud 1500000
D/bt_hwcfg( 1993): Chipset BCM4335C0
D/bt_hwcfg( 1993): Target name = [BCM4335C0]
I/bt_hwcfg( 1993): BT module name is: AP6210, p_chip_id_str = BCM4335C0
I/bt_hwcfg( 1993): Target HCD file name is: bcm4339a0.hcd
E/SQLiteLog( 1676): (1) no such table: files
I/bt_hwcfg( 1993): Found patchfile: /vendor/firmware//bcm4339a0.hcd
D/AlarmScheduler( 2105): No events found starting within 1 week.
D/CAM_MemoryManagerImpl( 2195): Max native memory: 358 MB
I/ActivityManager(  620): Start proc 2218:com.android.deskclock/u0a21 for broadcast com.android.deskclock/.AlarmInitReceiver
I/CalendarProvider2( 2129): Sending notification intent: Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar }
W/ContentResolver( 2129): Failed to get type for: content://com.android.calendar (Unknown URL content://com.android.calendar)
V/AlarmClock( 2218): AlarmInitReceiver android.intent.action.BOOT_COMPLETED
D/DeviceTest-FileUitls( 1927): find file:/mnt/internal_sd/eHomeMediaCenter
D/DeviceTest-FileUitls( 1927): find file:/mnt/internal_sd/Android
D/TestService( 1927): factoryFilePath: agingFilePath: externalStorageFilePath:/mnt/internal_sd
I/chip.devicetest( 1927): type=1400 audit(0.0:14): avc: denied { write } for name="force_usb_mode" dev="sysfs" ino=12262 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
D/TestService( 1927): It is not in factory/aging test mode.
D/TestService( 1927): onDestroy
V/AlarmClock( 2218): AlarmInitReceiver - Reset timers and clear stopwatch data
V/AlarmClock( 2218): AlarmInitReceiver - resetting volume button default
I/AlarmClock( 2218): Alarms Table created
I/AlarmClock( 2218): Instance table created
I/AlarmClock( 2218): Cities table created
I/AlarmClock( 2218): Inserting default alarms
V/AlarmClock( 2218): AlarmInitReceiver finished
I/ActivityManager(  620): Start proc 2240:com.android.gallery3d/u0a25 for broadcast com.android.gallery3d/com.android.camera.DisableCameraReceiver
I/bt_hwcfg( 1993): bt vendor lib: set UART baud 115200
D/bt_hwcfg( 1993): Settlement delay -- 100 ms
I/bt_hwcfg( 1993): Setting fw settlement delay to 100
I/bt_hwcfg( 1993): Setting local bd addr to 22:22:74:19:03:E2
I/G:DisableCameraReceiver( 2240): back camera found: 0
I/LauncherIconVisibilityManager( 1563): Boot has been completed
I/bt_hwcfg( 1993): vendor lib fwcfg completed
I/bt-btu  ( 1993): btu_task received preload complete event
I/        ( 1993): BTE_InitTraceLevels -- TRC_HCI
I/        ( 1993): BTE_InitTraceLevels -- TRC_L2CAP
I/        ( 1993): BTE_InitTraceLevels -- TRC_RFCOMM
I/        ( 1993): BTE_InitTraceLevels -- TRC_AVDT
I/        ( 1993): BTE_InitTraceLevels -- TRC_AVRC
I/        ( 1993): BTE_InitTraceLevels -- TRC_A2D
I/        ( 1993): BTE_InitTraceLevels -- TRC_BNEP
I/        ( 1993): BTE_InitTraceLevels -- TRC_BTM
I/        ( 1993): BTE_InitTraceLevels -- TRC_GAP
I/        ( 1993): BTE_InitTraceLevels -- TRC_PAN
I/        ( 1993): BTE_InitTraceLevels -- TRC_SDP
I/        ( 1993): BTE_InitTraceLevels -- TRC_GATT
I/        ( 1993): BTE_InitTraceLevels -- TRC_SMP
I/        ( 1993): BTE_InitTraceLevels -- TRC_BTAPP
I/        ( 1993): BTE_InitTraceLevels -- TRC_BTIF
I/LauncherIconVisibilityManager( 1563): Disable activity: ComponentInfo{com.android.inputmethod.latin/com.android.inputmethod.latin.setup.SetupActivity}
D/RKUpdateReceiver( 1847): action = android.intent.action.BOOT_COMPLETED
D/RKUpdateReceiver( 1847): RKUpdateReceiver recv ACTION_BOOT_COMPLETED.
W/ContextImpl( 1847): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1704 android.content.ContextWrapper.startService:516 android.content.ContextWrapper.startService:516 android.rockchip.update.service.RKUpdateReceiver.onReceive:59 android.app.ActivityThread.handleReceiver:2609
W/ContextImpl( 1847): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1704 android.content.ContextWrapper.startService:516 android.content.ContextWrapper.startService:516 android.rockchip.update.service.RKUpdateReceiver.onReceive:65 android.app.ActivityThread.handleReceiver:2609
I/android_rockchip_update_UpdateService.cpp( 1847): JNI_OnLoad
D/RKUpdateService( 1847): starting RKUpdateService, version is 1.8.1
D/RKUpdateService( 1847): remote uri is http://www.rockchip.com:2300/OtaUpdater/android?product=firefly-rk3288&version=1.0.0&sn=2IMFESC8YF&country=US&language=en
D/RKUpdateService( 1847): remote uri backup is http://192.168.1.143:2300/OtaUpdater/android?product=firefly-rk3288&version=1.0.0&sn=2IMFESC8YF&country=US&language=en
D/AlertReceiver( 2105): onReceive: a=android.intent.action.PROVIDER_CHANGED Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar flg=0x10 cmp=com.android.calendar/.alerts.AlertReceiver }
D/RKUpdateService( 1847): first startup!!!
D/RKUpdateService( 1847): onStartCommand.......
D/RKUpdateService( 1847): command = 1 delaytime = 20000
D/RKUpdateService( 1847): command = 2 delaytime = 25000
D/AlertService( 2105): 0 Action = android.intent.action.PROVIDER_CHANGED
E/bt-btm  ( 1993): BTM_SecRegister:p_cb_info->p_le_callback == 0xaf6ac271
E/bt-btm  ( 1993): BTM_SecRegister: btm_cb.api.p_le_callback = 0xaf6ac271
E/bt-btif ( 1993): Calling BTA_HhEnable
E/bt-btif ( 1993): btif_storage_get_adapter_property service_mask:0x2140040
D/BluetoothAdapterProperties( 1993): Scan Mode:20
D/BluetoothAdapterProperties( 1993): Discoverable Timeout:120
D/bt_vendor( 1993): SCO config
D/bte_conf( 1993): Device ID record 1 : primary
D/bte_conf( 1993):   vendorId            = 000f
D/bte_conf( 1993):   vendorIdSource      = 0001
D/bte_conf( 1993):   product             = 1200
D/bte_conf( 1993):   version             = 1436
D/bte_conf( 1993):   clientExecutableURL =
D/bte_conf( 1993):   serviceDescription  =
D/bte_conf( 1993):   documentationURL    =
D/bte_conf( 1993): bte_load_did_conf no section named DID2.
D/BluetoothAdapterState( 1993): CURRENT_STATE=PENDING, MESSAGE = ENABLE_READY, isTurningOn=true, isTurningOff=false
D/BluetoothAdapterProperties( 1993): ScanMode =  20
D/BluetoothPanServiceJni( 1993): control_state_callback(L61): state:0, local_role:3, ifname:bt-pan
D/BluetoothAdapterProperties( 1993): State =  11
D/BluetoothAdapterProperties( 1993): Scan Mode:21
D/BluetoothAdapterProperties( 1993): Setting state to 12
I/BluetoothAdapterState( 1993): Bluetooth adapter state changed: 11-> 12
I/BluetoothAdapterState( 1993): Entering On State
W/bt-btm  ( 1993): Stopping oneshot timer
E/bt_h4   ( 1993): vendor lib postload completed
D/UsbDeviceManager(  620): Usb state is true false true
I/ValidateNoPeople(  620): skipping global notification
D/BluetoothManagerService(  620): Stored Bluetoothaddress: 22:22:74:19:03:E2
D/BluetoothAdapterState( 1993): CURRENT_STATE=ON, MESSAGE = USER_TURN_OFF
D/BluetoothAdapterProperties( 1993): Setting state to 13
I/BluetoothAdapterState( 1993): Bluetooth adapter state changed: 12-> 13
D/BluetoothAdapterProperties( 1993): onBluetoothDisable()
I/BluetoothAdapterState( 1993): Entering PendingCommandState State: isTurningOn()=false, isTurningOff()=true
D/BluetoothAdapterState( 1993): CURRENT_STATE=PENDING, MESSAGE = BEGIN_DISABLE, isTurningOn=false, isTurningOff=true
W/bt-btif ( 1993): bta_dm_disable BTA_DISABLE_DELAY set to 200 ms
D/btif_config_util( 1993): btif_config_save_file(L188): in file name:/data/misc/bluedroid/bt_config.new
W/bt-l2cap( 1993): L2CAP - PSM: 0x0019 not found for deregistration
W/bt-l2cap( 1993): L2CAP - PSM: 0x0017 not found for deregistration
W/bt-btif ( 1993): ag scb idx 1 not allocated
E/bt-btif ( 1993): BTA AG is already disabled, ignoring ...
D/bt_userial( 1993): RX termination
W/bt_userial( 1993): select_read return size <=0:-1, exiting userial_read_thread
D/bt_userial( 1993): Leaving userial_read_thread()
D/bt_userial( 1993): userial_close_reader Joined userial reader thread: 0
D/bt_hwcfg( 1993): hw_epilog_process
I/bt_userial_vendor( 1993): device fd = 55 close
I/GKI_LINUX( 1993): gki_task task_id=0 [BTU] terminating
I/GKI_LINUX( 1993): GKI_exit_task 0 done
I/GKI_LINUX( 1993): GKI_shutdown(): task [BTU] terminated
D/BluetoothAdapterState( 1993): CURRENT_STATE=PENDING, MESSAGE = DISABLED, isTurningOn=false, isTurningOff=true
D/HeadsetService( 1993): Received stop request...Stopping profile...
D/HeadsetStateMachine( 1993): Exit Disconnected: -1
D/A2dpService( 1993): Received stop request...Stopping profile...
D/A2dpStateMachine( 1993): Exit Disconnected: -1
D/BluetoothA2dp(  620): Proxy object disconnected
D/HidService( 1993): Received stop request...Stopping profile...
D/BluetoothAdapterState( 1993): Stopping profile services that were post enabled
D/HeadsetStateMachine( 1993): Unbinding service...
D/BluetoothA2dp( 1378): Proxy object disconnected
D/BluetoothInputDevice( 1378): Proxy object disconnected
W/BluetoothHeadsetServiceJni( 1993): Cleaning up Bluetooth Handsfree Interface...
W/BluetoothHeadsetServiceJni( 1993): Cleaning up Bluetooth Handsfree callback object
D/HealthService( 1993): Received stop request...Stopping profile...
I/GKI_LINUX( 1993): gki_task task_id=2 [A2DP-MEDIA] terminating
I/GKI_LINUX( 1993): GKI_exit_task 2 done
I/GKI_LINUX( 1993): GKI_shutdown(): task [A2DP-MEDIA] terminated
D/PanService( 1993): Received stop request...Stopping profile...
D/BluetoothPan( 1378): BluetoothPAN Proxy object disconnected
D/BtGatt.GattService( 1993): Received stop request...Stopping profile...
D/BtGatt.GattService( 1993): stop()
D/BtGatt.AdvertiseManager( 1993): advertise clients cleared
W/BluetoothHidServiceJni( 1993): Cleaning up Bluetooth HID Interface...
W/bt-btif ( 1993): cleanup: HH disabling or disabled already, status = 0
W/BluetoothHidServiceJni( 1993): Cleaning up Bluetooth GID callback object
W/BluetoothHealthServiceJni( 1993): Cleaning up Bluetooth Health Interface...
W/BluetoothHealthServiceJni( 1993): Cleaning up Bluetooth Health object
W/BluetoothPanServiceJni( 1993): Cleaning up Bluetooth PAN Interface...
W/BluetoothPanServiceJni( 1993): Cleaning up Bluetooth PAN callback object
D/BtGatt.GattService( 1993): cleanup()
D/BluetoothAdapterState( 1993): CURRENT_STATE=PENDING, MESSAGE = STOPPED, isTurningOn=false, isTurningOff=true
W/bt-btif ( 1993): GATTC Module not enabled/already disabled
W/bt-btif ( 1993): GATTS Module not enabled/already disabled
D/BluetoothAdapterProperties( 1993): Setting state to 10
I/BluetoothAdapterState( 1993): Bluetooth adapter state changed: 13-> 10
E/MetadataRetrieverClient(  162): failed to extract an album art
D/BluetoothManagerService(  620): unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@1dfabf19 mBinding = false
D/BluetoothManagerService(  620): Sending unbind request.
I/GKI_LINUX( 1993): gki_task task_id=1 [BTIF] terminating
I/GKI_LINUX( 1993): GKI_exit_task 1 done
I/GKI_LINUX( 1993): GKI_shutdown(): task [BTIF] terminated
I/BluetoothServiceJni( 1993): cleanupNative: return from cleanup
I/art     ( 1993): System.exit called, status: 0
I/AndroidRuntime( 1993): VM exiting with result code 0, cleanup skipped.
I/ActivityManager(  620): Process com.android.bluetooth (pid 1993) has died
W/BackupManagerService(  620): dataChanged but no participant pkg='com.android.providers.settings' uid=10004
W/AudioTrack(  620): AUDIO_OUTPUT_FLAG_FAST denied by client
D/AudioHardwareTiny(  162): start_output_stream
D/AudioHardwareTiny(  162): Audio HAL start_output_stream  out->device = 0x80400
E/SQLiteLog( 2129): (284) automatic index on view_events(_id)
D/BackupManagerService(  620): Received broadcast Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.android.camera2 flg=0x4000010 (has extras) }
D/BackupManagerService(  620): Received broadcast Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.android.provision flg=0x4000010 (has extras) }
D/BackupManagerService(  620): Received broadcast Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.android.calendar flg=0x4000010 (has extras) }
D/BackupManagerService(  620): Received broadcast Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.android.gallery3d flg=0x4000010 (has extras) }
D/BackupManagerService(  620): Received broadcast Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.android.inputmethod.latin flg=0x4000010 (has extras) }
D/BackupManagerService(  620): Received broadcast Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.android.settings flg=0x4000010 (has extras) }
W/MediaScanner( 1676): Error opening directory '/oem/media/', skipping: No such file or directory.
D/MediaScannerService( 1676): done scanning volume internal
D/MediaScannerService( 1676): start scanning volume external: [/mnt/external_sd]
W/MediaScanner( 1676): Error opening directory '/mnt/external_sd/', skipping: Permission denied.
V/MediaScanner( 1676): pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@330edd62
V/MediaScanner( 1676): /pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@330edd62
D/MediaScannerService( 1676): start scanning volume external: [/mnt/usb_storage]
V/MediaScanner( 1676): pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@20944ef3
V/MediaScanner( 1676): /pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@20944ef3
D/MediaScanner( 1676): Skipping: /mnt/internal_sd/Android/
V/MediaScanner( 1676): pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@1225d7b0
V/MediaScanner( 1676): /pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@1225d7b0
D/Launcher.Workspace( 1783): 11683562 - stripEmptyScreens()
I/ActivityManager(  620): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.settings/.Settings bnds=[478,589][592,666] (has extras)} from uid 10030 on display 0
V/WindowManager(  620): addAppToken: AppWindowToken{3225bc45 token=Token{1d0b44bc ActivityRecord{3dde58af u0 com.android.settings/.Settings t4}}} to stack=1 task=4 at 0
D/OpenGLRenderer(  620): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
D/Atlas   (  620): Validating map...
V/WindowManager(  620): Adding window Window{965f13e u0 Starting com.android.settings} at 2 of 7 (after Window{3d529008 u0 com.android.launcher3/com.android.launcher3.Launcher})
I/OpenGLRenderer(  620): Initialized EGL, version 1.4
D/OpenGLRenderer(  620): Enabling debug mode 0
I/InputDispatcher(  620): Dropping event because there is no touchable window at (526, 617).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (527, 616).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (529, 614).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (534, 613).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (540, 611).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (548, 610).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (558, 607).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (572, 603).
V/WindowManager(  620): Adding window Window{12c591a2 u0 com.android.settings/com.android.settings.Settings} at 2 of 8 (before Window{965f13e u0 Starting com.android.settings})
I/InputDispatcher(  620): Dropping event because there is no touchable window at (587, 596).
I/IndexDatabaseHelper( 1630): Bootstrapped database
I/InputDispatcher(  620): Dropping event because there is no touchable window at (605, 589).
E/NFC     ( 1630): could not retrieve NFC service
I/IndexDatabaseHelper( 1630): Using schema version: 115
D/UserManager( 1630): ---getMaxSupportedUsers,we has UMS,force disabled M-user---
I/IndexDatabaseHelper( 1630): Index is fine
I/InputDispatcher(  620): Dropping event because there is no touchable window at (623, 582).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (640, 578).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (663, 570).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (682, 568).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (705, 563).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (728, 559).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (748, 553).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (771, 551).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (793, 549).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (820, 544).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (841, 542).
D/DashboardSummary( 1630): rebuildUI took: 98 ms
I/InputDispatcher(  620): Dropping event because there is no touchable window at (861, 540).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (878, 540).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (893, 540).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (907, 540).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (919, 544).
I/GlobalDismissManager( 2105): no sender configured
D/AlertService( 2105): Beginning updateAlertNotification
D/AlertService( 2105): No fired or scheduled alerts
I/ActivityManager(  620): Displayed com.android.settings/.Settings: +427ms
D/WifiService(  620): New client listening to asynchronous messages
D/SensorManager( 1630): aidl getSensorManager:null
D/BluetoothManagerService(  620): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@2d1f90ab:true
D/BluetoothAdapter( 1630): 998267537: getState() :  mService = null. Returning STATE_OFF
D/BluetoothManagerService(  620): Message: 30
D/LocalBluetoothProfileManager( 1630): Adding local MAP profile
D/BluetoothMap( 1630): Create BluetoothMap proxy object
E/BluetoothMap( 1630): Could not bind to Bluetooth MAP Service with Intent { act=android.bluetooth.IBluetoothMap }
D/LocalBluetoothProfileManager( 1630): LocalBluetoothProfileManager construction complete
D/Index   ( 1630): Indexing locale 'en_US' took 587 millis
I/ActivityManager(  620): START u0 {act=android.intent.action.MAIN cmp=com.android.settings/.SubSettings (has extras)} from uid 1000 on display 0
V/WindowManager(  620): addAppToken: AppWindowToken{117d1e38 token=Token{2409fa9b ActivityRecord{1176ceaa u0 com.android.settings/.SubSettings t4}}} to stack=1 task=4 at 1
D/SubSettings( 1630): Launching fragment com.android.settings.SecuritySettings
W/Settings( 1630): Setting install_non_market_apps has moved from android.provider.Settings.Global to android.provider.Settings.Secure, returning read-only value.
V/WindowManager(  620): Adding window Window{322a7e49 u0 com.android.settings/com.android.settings.SubSettings} at 3 of 8 (after Window{12c591a2 u0 com.android.settings/com.android.settings.Settings})
D/Index   ( 1630): Deleting data for locale 'en_US' took 5 millis
D/Index   ( 1630): Indexing locale 'en_US' took 35 millis
I/ActivityManager(  620): Displayed com.android.settings/.SubSettings: +256ms
D/OpenGLRenderer( 1630): endAllStagingAnimators on 0xb89394c0 (RippleDrawable) with handle 0xb89f66e0
D/DashboardSummary( 1630): rebuildUI took: 74 ms
D/OpenGLRenderer( 1630): endAllStagingAnimators on 0xb8a39cf8 (RippleDrawable) with handle 0xb8c09d20
D/SurfaceFlinger(  156): shader cache generated - 24 shaders in 181.429794 ms
V/WindowManager(  620): addAppToken: AppWindowToken{10a41898 token=Token{5a0e27b ActivityRecord{29baea0a u0 com.android.settings/.SubSettings t4}}} to stack=1 task=4 at 1
D/SubSettings( 1630): Launching fragment com.android.settings.inputmethod.InputMethodAndLanguageSettings
V/WindowManager(  620): Adding window Window{1190d529 u0 com.android.settings/com.android.settings.SubSettings} at 3 of 8 (after Window{12c591a2 u0 com.android.settings/com.android.settings.Settings})
I/ActivityManager(  620): Displayed com.android.settings/.SubSettings: +240ms
D/OpenGLRenderer( 1630): endAllStagingAnimators on 0xb8b3cc98 (RippleDrawable) with handle 0xb8b8c3b0
D/UsbDeviceManager(  620): Usb state is true true true
D/Tethering(  620): UsbManager.ACTION_USB_STATE: true, false, false
D/MountService(  620): sharedvolumeNum: 0 ;avail: true
V/WindowManager(  620): addAppToken: AppWindowToken{25dd0061 token=Token{1ad7c8 ActivityRecord{aab606b u0 com.android.settings/.SubSettings t4}}} to stack=1 task=4 at 2
D/SubSettings( 1630): Launching fragment com.android.settings.LocalePicker
V/WindowManager(  620): Adding window Window{1c53615e u0 com.android.settings/com.android.settings.SubSettings} at 4 of 9 (after Window{1190d529 u0 com.android.settings/com.android.settings.SubSettings})
I/InputDispatcher(  620): Dropping event because there is no touchable window at (202, 154).
I/ActivityManager(  620): Displayed com.android.settings/.SubSettings: +208ms
D/OpenGLRenderer( 1630): endAllStagingAnimators on 0xb89fa388 (ListView) with handle 0xb889bae8
I/ActivityManager(  620): Waited long enough for: ServiceRecord{36473988 u0 com.android.music/.MediaPlaybackService}
D/AndroidRuntime( 2354): >>>>>> START com.android.internal.os.RuntimeInit uid 2000 <<<<<<
D/AndroidRuntime( 2354): CheckJNI is OFF
I/AndroidRuntime( 2354): JNI options: '-Xjniopts:warnonly'
E/memtrack( 2354): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug( 2354): failed to load memtrack module: -2
D/AndroidRuntime( 2354): Calling main entry com.android.commands.settings.SettingsCmd
D/AndroidRuntime( 2354): Shutting down VM
I/ActivityManager(  620): Waited long enough for: ServiceRecord{8682fad u0 com.rockchip.mediacenter/.SystemDeviceService}
D/AndroidRuntime( 2369): >>>>>> START com.android.internal.os.RuntimeInit uid 2000 <<<<<<
D/AndroidRuntime( 2369): CheckJNI is OFF
I/AndroidRuntime( 2369): JNI options: '-Xjniopts:warnonly'
E/memtrack( 2369): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug( 2369): failed to load memtrack module: -2
D/AndroidRuntime( 2369): Calling main entry com.android.commands.settings.SettingsCmd
D/AndroidRuntime( 2369): Shutting down VM
D/AndroidRuntime( 2384): >>>>>> START com.android.internal.os.RuntimeInit uid 2000 <<<<<<
D/AndroidRuntime( 2384): CheckJNI is OFF
I/AndroidRuntime( 2384): JNI options: '-Xjniopts:warnonly'
D/AudioHardwareTiny(  162): close device
E/memtrack( 2384): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug( 2384): failed to load memtrack module: -2
D/AndroidRuntime( 2384): Calling main entry com.android.commands.settings.SettingsCmd
D/AndroidRuntime( 2384): Shutting down VM
I/ActivityManager(  620): Waited long enough for: ServiceRecord{34fb66f4 u0 com.android.calendar/.alerts.InitAlarmsService}
D/AndroidRuntime( 2399): >>>>>> START com.android.internal.os.RuntimeInit uid 2000 <<<<<<
D/AndroidRuntime( 2399): CheckJNI is OFF
I/AndroidRuntime( 2399): JNI options: '-Xjniopts:warnonly'
I/ActivityManager(  620): Config changes=2004 {1.15 ?mcc?mnc zh_CN ldltr sw720dp w1280dp h647dp 160dpi lrg long land -touch -keyb/v/h dpad/v s.6}
D/ActivityManager(  620): Storing locale zh-CN for decryption UI
D/VoldCmdListener(  155): cryptfs setfield SystemLocale zh-CN
E/memtrack( 2399): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug( 2399): failed to load memtrack module: -2
D/AlertReceiver( 2105): onReceive: a=android.intent.action.LOCALE_CHANGED Intent { act=android.intent.action.LOCALE_CHANGED flg=0x10000010 cmp=com.android.calendar/.alerts.AlertReceiver }
I/InputDispatcher(  620): Dropping event because there is no touchable window at (230, 392).
I/Launcher( 1783): setLoadOnResume
I/InputDispatcher(  620): Dropping event because there is no touchable window at (240, 396).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (258, 403).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (280, 415).
I/InputMethodManagerService(  620): Default found, using com.android.inputmethod.latin/.LatinIME
D/AndroidRuntime( 2399): Calling main entry com.android.commands.settings.SettingsCmd
I/InputDispatcher(  620): Dropping event because there is no touchable window at (309, 431).
D/AlertService( 2105): 0 Action = android.intent.action.LOCALE_CHANGED
V/AlarmClock( 2218): AlarmInitReceiver android.intent.action.LOCALE_CHANGED
I/InputDispatcher(  620): Dropping event because there is no touchable window at (330, 439).
I/Telephony( 1608): PstnIncomingCallNotifier: Unregistering: Handler (com.android.internal.telephony.gsm.GSMPhone) {37461f27}
I/InputDispatcher(  620): Dropping event because there is no touchable window at (356, 451).
I/art     ( 1630): Explicit concurrent mark sweep GC freed 9807(631KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 2MB/4MB, paused 399us total 35.445ms
I/InputDispatcher(  620): Dropping event because there is no touchable window at (380, 470).
W/InputMethodManagerService(  620): Illegal subtype state: old subtype = null, new subtype = android.view.inputmethod.InputMethodSubtype@c9194f98
I/InputDispatcher(  620): Dropping event because there is no touchable window at (410, 490).
I/art     ( 1630): Explicit concurrent mark sweep GC freed 529(34KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 2MB/4MB, paused 323us total 17.397ms
I/InputDispatcher(  620): Dropping event because there is no touchable window at (435, 508).
D/AndroidRuntime( 2399): Shutting down VM
I/ContactLocale( 1340): AddressBook Labels [zh-CN]: [, A, B, C, D, E, F, G, H, I, J, K, L, M, N, O, P, Q, R, S, T, U, V, W, X, Y, Z, Α, Β, Γ, Δ, Ε, Ζ, Η, Θ, Ι, Κ, Λ, Μ, Ν, Ξ, Ο, Π, Ρ, Σ, Τ, Υ, Φ, Χ, Ψ, Ω, , А, Б, В, Г, Д, Ђ, Е, Є, Ж, З, И, І, Ї, Й, Ј, К, Л, Љ, М, Н, Њ, О, П, Р, С, Т, Ћ, У, Ф, Х, Ц, Ч, Џ, Ш, Щ, Ю, Я, , א, ב, ג, ד, ה, ו, ז, ח, ט, י, כ, ל, מ, נ, ס, ע, פ, צ, ק, ר, ש, ת, , ا, ب, ت, ث, ج, ح, خ, د, ذ, ر, ز, س, ش, ص, ض, ط, ظ, ع, غ, ف, ق, ك, ل, م, ن, ه, و, ي, , ก, ข, ฃ, ค, ฅ, ฆ, ง, จ, ฉ, ช, ซ, ฌ, ญ, ฎ, ฏ, ฐ, ฑ, ฒ, ณ, ด, ต, ถ, ท, ธ, น, บ, ป, ผ, ฝ, พ, ฟ, ภ, ม, ย, ร, ฤ, ล, ฦ, ว, ศ, ษ, ส, ห, ฬ, อ, ฮ, , ㄱ, ㄴ, ㄷ, ㄹ, ㅁ, ㅂ, ㅅ, ㅇ, ㅈ, ㅊ, ㅋ, ㅌ, ㅍ, ㅎ, , あ, か, さ, た, な, は, ま, や, ら, わ, #, ]
I/InputDispatcher(  620): Dropping event because there is no touchable window at (457, 523).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (475, 529).
I/art     ( 1630): Explicit concurrent mark sweep GC freed 3(96B) AllocSpace objects, 0(0B) LOS objects, 39% free, 2MB/4MB, paused 411us total 21.456ms
E/blb     ( 1378): mmEthernetVisible: false
I/InputDispatcher(  620): Dropping event because there is no touchable window at (495, 543).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (511, 552).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (530, 560).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (539, 567).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (549, 576).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (563, 584).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (576, 591).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (594, 599).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (607, 608).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (622, 616).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (637, 625).
W/AppOps  (  620): Bad call: specified package media under uid 1000 but it is really 1013
I/InputDispatcher(  620): Dropping event because there is no touchable window at (649, 631).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (663, 640).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (673, 646).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (681, 649).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (685, 652).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (693, 654).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (696, 655).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (702, 658).
W/InputMethodSettingValuesWrapper( 1630): ascii capable subtype enabled imi not found. Fall back to English Keyboard subtype.
I/InputDispatcher(  620): Dropping event because there is no touchable window at (707, 660).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (713, 664).
I/ContactsProvider( 1340): Locale has changed from en-US to zh-CN
V/WindowManager(  620): Adding window Window{7ba531f u0 com.android.settings/com.android.settings.SubSettings} at 3 of 9 (before Window{1c53615e u0 com.android.settings/com.android.settings.SubSettings})
I/ContactsDatabaseHelper( 1340): Switching to locale zh-CN (ICU v53.1.0.1)
I/InputDispatcher(  620): Dropping event because there is no touchable window at (720, 668).
I/InputDispatcher(  620): Dropping event because there is no touchable window at (727, 670).
I/ContactsDatabaseHelper( 1340): Locale change completed in 56ms
I/ContactsFTS( 1340): Rebuild contact search index in 11ms, 0 contacts
D/AndroidRuntime( 2429): >>>>>> START com.android.internal.os.RuntimeInit uid 2000 <<<<<<
D/AndroidRuntime( 2429): CheckJNI is OFF
I/AndroidRuntime( 2429): JNI options: '-Xjniopts:warnonly'
I/art     ( 1630): Explicit concurrent mark sweep GC freed 13624(725KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 3MB/5MB, paused 300us total 17.001ms
E/memtrack( 2429): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug( 2429): failed to load memtrack module: -2
I/art     ( 1630): Explicit concurrent mark sweep GC freed 5501(391KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 2MB/4MB, paused 364us total 17.334ms
I/art     ( 1630): Explicit concurrent mark sweep GC freed 3(96B) AllocSpace objects, 0(0B) LOS objects, 39% free, 2MB/4MB, paused 352us total 16.390ms
D/AndroidRuntime( 2429): Calling main entry com.android.commands.pm.Pm
I/art     ( 2429): System.exit called, status: 0
I/AndroidRuntime( 2429): VM exiting with result code 0.
I/ActivityManager(  620): Waited long enough for: ServiceRecord{1832263 u0 android.rockchip.update.service/.RKUpdateService}
I/InputDispatcher(  620): Dropping event because there is no touchable window at (39, 63).
V/WindowManager(  620): Adding window Window{d1080bb u0 com.android.settings/com.android.settings.Settings} at 2 of 8 (before Window{7ba531f u0 com.android.settings/com.android.settings.SubSettings})
D/DashboardSummary( 1630): rebuildUI took: 70 ms
D/OpenGLRenderer( 1630): endAllStagingAnimators on 0xb8d81d48 (RippleDrawable) with handle 0xb8f5bf48
I/art     ( 1630): Explicit concurrent mark sweep GC freed 12662(816KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 3MB/5MB, paused 396us total 20.848ms
I/art     ( 1630): Explicit concurrent mark sweep GC freed 14482(942KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 2MB/4MB, paused 416us total 17.434ms
D/Index   ( 1630): Indexing locale 'zh_CN' took 389 millis
I/art     ( 1630): Explicit concurrent mark sweep GC freed 1548(85KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 2MB/4MB, paused 300us total 16.260ms
D/AndroidRuntime( 2681): >>>>>> START com.android.internal.os.RuntimeInit uid 2000 <<<<<<
D/AndroidRuntime( 2681): CheckJNI is OFF
I/AndroidRuntime( 2681): JNI options: '-Xjniopts:warnonly'
E/memtrack( 2681): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug( 2681): failed to load memtrack module: -2
D/AndroidRuntime( 2681): Calling main entry com.android.commands.pm.Pm
I/art     ( 2681): System.exit called, status: 0
I/AndroidRuntime( 2681): VM exiting with result code 0.
I/ActivityManager(  620): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10200000 cmp=com.android.launcher3/.Launcher} from uid 1000 on display 0
D/PermissionCache(  156): checking android.permission.READ_FRAME_BUFFER for uid=1000 => granted (249 us)
W/Launcher( 1783): setApplicationContext called twice! old=com.android.launcher3.LauncherApplication@2c7f1e81 new=com.android.launcher3.LauncherApplication@2c7f1e81
W/ResourceType( 1783): Attempt to retrieve bag 0x7f0d0008 which is invalid or in a cycle.
D/Launcher.Model( 1783): 11683562 - loadWorkspace()
V/WindowManager(  620): Adding window Window{3d0b4acb u0 com.android.launcher3/com.android.launcher3.Launcher} at 2 of 7 (after Window{d1080bb u0 com.android.settings/com.android.settings.Settings})
W/ProcessCpuTracker(  620): Skipping unknown process pid 2812
W/ProcessCpuTracker(  620): Skipping unknown process pid 2814
W/ResourceType( 1378): No package identifier when getting value for resource number 0x00000000
W/PackageManager( 1378): Failure retrieving resources for com.android.settings: Resource ID #0x0
I/art     (  620): WaitForGcToComplete blocked for 7.106ms for cause HeapTrim
I/ActivityManager(  620): START u0 {act=com.android.systemui.recents.SHOW_RECENTS flg=0x10804000 cmp=com.android.systemui/.recents.RecentsActivity} from uid 10011 on display 0
V/WindowManager(  620): addAppToken: AppWindowToken{1757733e token=Token{249007f9 ActivityRecord{218d5ec0 u0 com.android.systemui/.recents.RecentsActivity t5}}} to stack=0 task=5 at 0
D/OpenGLRenderer( 1378): setting property ambientRatio to 1.5
D/OpenGLRenderer( 1378): ambientRatio = 1.50
V/WindowManager(  620): Adding window Window{b2bc833 u0 com.android.systemui/com.android.systemui.recents.RecentsActivity} at 3 of 8 (after Window{3d0b4acb u0 com.android.launcher3/com.android.launcher3.Launcher EXITING})
I/ActivityManager(  620): Displayed com.android.systemui/.recents.RecentsActivity: +102ms
D/AndroidRuntime( 2921): >>>>>> START com.android.internal.os.RuntimeInit uid 2000 <<<<<<
D/AndroidRuntime( 2921): CheckJNI is OFF
I/AndroidRuntime( 2921): JNI options: '-Xjniopts:warnonly'
E/memtrack( 2921): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug( 2921): failed to load memtrack module: -2
D/AndroidRuntime( 2921): Calling main entry com.android.commands.pm.Pm
I/art     ( 2921): System.exit called, status: 1
I/AndroidRuntime( 2921): VM exiting with result code 1.
D/RKUpdateService( 1847): WorkHandler::handleMessage() : To perform 'COMMAND_CHECK_LOCAL_UPDATING'.
D/RKUpdateService( 1847): getValidFirmwareImageFile() : Target image file path : /data/media/0/update.zip
D/RKUpdateService( 1847): getValidFirmwareImageFile() : Target image file path : /mnt/internal_sd/update.zip
D/RKUpdateService( 1847): getValidFirmwareImageFile() : Target image file path : /mnt/external_sd/update.zip
D/RKUpdateService( 1847): getValidFirmwareImageFile() : Target image file path : /mnt/usb_storage/update.zip
I/ActivityManager(  620): Killing 1630:com.android.settings/1000 (adj 9): remove task
D/WifiService(  620): Client connection lost with reason: 4
I/WindowState(  620): WIN DEATH: Window{d1080bb u0 com.android.settings/com.android.settings.Settings}
W/art     (  620): Long monitor contention event with owner method=boolean com.android.server.am.ActivityManagerService.removeTask(int) from ActivityManagerService.java:8531 waiters=2 for 117ms
D/TaskPersister(  620): removeObsoleteFile: deleting file=4_task.xml
D/TaskPersister(  620): removeObsoleteFile: deleting file=4_task_thumbnail.png
I/ActivityManager(  620): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10200000 cmp=com.android.launcher3/.Launcher} from uid 10011 on display 0
W/OpenGLRenderer( 1783): Incorrectly called buildLayer on View: ShortcutAndWidgetContainer, destroying layer...
I/ActivityManager(  620): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.camera2/com.android.camera.CameraLauncher (has extras)} from uid 10030 on display 0
V/WindowManager(  620): addAppToken: AppWindowToken{26e646c6 token=Token{315f54a1 ActivityRecord{101cd508 u0 com.android.camera2/com.android.camera.CameraLauncher t6}}} to stack=1 task=6 at 0
V/WindowManager(  620): Adding window Window{331cf6d9 u0 Starting com.android.camera2} at 3 of 8 (after Window{3d0b4acb u0 com.android.launcher3/com.android.launcher3.Launcher})
V/CAM_QuickActivity( 2195): START onCreate: Activity = com.android.camera.CameraActivity@3f9f1705
V/CAM_QuickActivity( 2195): Intent Action = android.intent.action.MAIN
I/CameraManagerGlobal( 2195): getCameraService: Reconnecting to camera service
D/mmk     ( 2195): onStatusChangedLocked.+++++++
I/CameraService(  162): getCameraCharacteristics: Switching to HAL1 shim implementation...
D/CameraHal(  162): camera_get_camera_info(1307): camera_get_camera_info(1307): camera_0 facing(0), orientation(180)
E/CameraManagerGlobal( 2195): Camera id 0 has status changed to 0x1
W/AudioFlinger(  162): acquireAudioSessionId() unknown client 2195 for session 24
I/AwesomePlayer(  162): AwesomePlayer::AwesomePlayer()in
I/AwesomePlayer(  162): AwesomePlayer::AwesomePlayer()aftermClient.connect()
I/AwesomePlayer(  162): setDataSource_l(<no-scheme URI suppressed>)
I/OMXCodec(  162): --->InstantiateSoftwareCodec create OMX.google.vorbis.decoder codec
I/OMXCodec(  162): Successfully allocated OMX node 'OMX.google.vorbis.decoder'
W/AudioFlinger(  162): acquireAudioSessionId() unknown client 2195 for session 25
I/CameraClient(  162): Opening camera 0
D/mmk     ( 1378): onStatusChangedLocked.+++++++
I/CameraHal(  162): camera_device_open(496): camera_device open
D/CameraHal(  162): gCameraHalLogLevel: 0
E/CameraManagerGlobal( 1378): Camera id 0 has status changed to 0x80000000
E/CameraManagerGlobal( 2195): Camera id 0 has status changed to 0x80000000
D/mmk     ( 1378): postSingleUpdate.+++++++++ status = -2147483648
D/CameraHal(  162): CameraHal(138): it is a isp  camera
D/CameraHal(  162): Calling process is: com.android.camera2
I/vpu_mem_pool(  162): pid 162, open_vpu_memory_pool:473: success
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (80000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 38
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (160000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 39
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (240000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 40
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (320000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 42
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (400000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 44
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (480000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 45
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (560000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 46
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (640000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 47
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (720000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 48
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:717: vpu memory pool size (800000)
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 49
E/CameraHal(  162): disconnectCamera(1691): getFocusLimits failed!
D/CameraHal_Marvin(  162):
D/CameraHal_Marvin(  162): CameraHal Version Check:
D/CameraHal_Marvin(  162):     CamSys_Head.h version:
D/CameraHal_Marvin(  162):        kernel: (0x) v0.b.0
D/CameraHal_Marvin(  162):        libisp_siliconimage_isp.so: (0x) v0.b.0
D/CameraHal_Marvin(  162):     LibIsp version:
D/CameraHal_Marvin(  162):        local: (0x) v1.27.0
D/CameraHal_Marvin(  162):        camera.rk30board.so: (0x) v1.27.0
D/CameraHal_Marvin(  162):     Sensor ISI version:
D/CameraHal_Marvin(  162):         libisp_isi_drv_XXX: (0x) v0.a.0
D/CameraHal_Marvin(  162):         libisp_siliconimage_isp.so: (0x) v0.a.0
D/CameraHal_Marvin(  162):     Tunning XML version:
D/CameraHal_Marvin(  162):         libisp_isi_drv_XXX: (22-May-2014_OUYANG_OV13850_FX288_v1.0)
D/CameraHal_Marvin(  162):         Calibdb: (06-Aug-2014_ZYL-OYYF_OV13850_CMK-CT0116-FV1_v0.1.2)
D/CameraHal_Marvin(  162):     sensor name OV13850:
D/CameraHal_Marvin(  162):        sensor drv version: (0x) v0.9.0
D/CameraHal(  162): setupPreview(248): isp out put format is YUV420SP.
E/CameraHal_Marvin(  162): HAL-MOCKUP: PHY ADDR (0x10000000),iommu addr (0x10000000)
E/CameraHal_Marvin(  162): HAL-MOCKUP: PHY ADDR (0x112f5000),iommu addr (0x112f5000)
E/CameraHal_Marvin(  162): HAL-MOCKUP: PHY ADDR (0x125ea000),iommu addr (0x125ea000)
E/CameraHal_Marvin(  162): HAL-MOCKUP: PHY ADDR (0x138df000),iommu addr (0x138df000)
D/CameraHal(  162): enableSensor(203): orientation = 0xb8f00ae0 (MPL accel)
V/Sensors (  620): int poll__setDelay(sensors_poll_device_t*, int, int64_t)
V/Sensors (  620): int sensors_poll_context_t::setDelay(int, int64_t)
V/Sensors (  620): setDelay - sensor Accelerometer (handle 4), rate 20 ms (50.00 Hz)
E/Sensors (  620): MPU is not available
V/Sensors (  620): setDelay - sensor Accelerometer (handle 4), rate 66 ms (15.00 Hz)
W/CameraService(  162): CameraService::connect X (id 0, this pid is 162, name com.android.camera2)
D/CameraHal(  162): commandThread(988): commandThread(988): receive CMD_PREVIEW_CAPTURE_CANCEL
D/CameraHal(  162): commandThread(996): commandThread(996): CMD_PREVIEW_CAPTURE_CANCEL out
D/CameraHal(  162): cancelPicture(566): cancel picture OK.
D/CameraHal(  162): commandThread(916): commandThread(916):receive CMD_PREVIEW_STOP
D/CameraHal(  162): commandThread(937): commandThread(937): CMD_PREVIEW_STOP out
D/CameraHal(  162): stopPreview(367): stop preview OK.
I/CameraClient(  162): Destroying camera 0
D/CameraHal(  162): camera_device_close(447): camera_device_close
D/CameraHal(  162): disableSensor(222): orientation = 0xb8f00ae0 (MPL accel)
D/CameraHal(  162): ~SensorListener(110): Kill looper thread
D/CameraHal(  162): ~SensorListener(122): Kill looper
D/CameraHal(  162): ~SensorListener(128): SensorListener destroyed
D/CameraHal(  162): displayThread(615): displayThread(615): receive CMD_DISPLAY_STOP
D/CameraHal(  162): cameraDisplayBufferDestory(392): cameraDisplayBufferDestory(392): mANativeWindow is NULL, destory is ignore
D/CameraHal(  162): encProcessThread(1522): encProcessThread(1522): receive CMD_ENCPROCESS_EXIT
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (720000)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (640000)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (560000)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (480000)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (400000)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (320000)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (240000)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (160000)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (80000)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:501: vpu memory pool size (0)
I/vpu_mem_pool(  162): pid 162, close_vpu_memory_pool:552:
E/CameraHal_Marvin(  162): OV13850:  STREAM OFF ++++++++++++++
D/CameraHal(  162): commandThread(1100): commandThread(1100): receive CMD_EXIT
D/CameraHal(  162): ~CameraHal(298): CameraHal destory success
W/CameraService(  162): removeClient: clear camera 0, package name com.android.camera2
E/CameraManagerGlobal( 1378): Camera id 0 has status changed to 0x1
D/mmk     ( 1378): postSingleUpdate.+++++++++ status = 1
I/FrameQueueManage(  162): FrameQueueManage::~FrameQueueManage end!
I/InputDispatcher(  620): Dropping event because there is no touchable window at (196, 344).
D/CAM_LocationManager( 2195): Using legacy location provider.
D/SensorManager( 2195): aidl getSensorManager:null
V/CAM_SettingsManager( 2195): listeners: [com.android.camera.app.CameraAppUI@2d2fc8c7]
V/CAM_SettingsManager( 2195): listeners: [com.android.camera.app.CameraAppUI@2d2fc8c7, com.android.camera.ButtonManager@34ac6660]
V/CAM_SettingsManager( 2195): listeners: [com.android.camera.app.CameraAppUI@2d2fc8c7, com.android.camera.ButtonManager@34ac6660, com.android.camera.widget.IndicatorIconController@2ce7d3de]
E/NFC     ( 2195): could not retrieve NFC service
V/CAM_QuickActivity( 2195): END onCreate: Activity = com.android.camera.CameraActivity@3f9f1705
V/CAM_QuickActivity( 2195): START onStart: Activity = com.android.camera.CameraActivity@3f9f1705
V/CAM_QuickActivity( 2195): END onStart: Activity = com.android.camera.CameraActivity@3f9f1705
V/CAM_QuickActivity( 2195): START onResume: Activity = com.android.camera.CameraActivity@3f9f1705
V/CAM_CameraActivity( 2195): Build info: rk3288_box-userdebug 5.1.1 LMY47V eng.root.20161212.160319 test-keys
V/CAM_PhotoModule( 2195): requestCameraOpen
V/CAM_CameraController( 2195): requestCamera
V/CAM_CameraController( 2195): checkAndOpenCamera
I/CAM2PORT_AndCamAgntImp( 2195): Opening camera 0 with camera1 API
W/AudioFlinger(  162): acquireAudioSessionId() unknown client 2195 for session 26
D/CAM_Storage( 2195): External storage state=mounted
V/Sensors (  620): int poll__activate(sensors_poll_device_t*, int, int)
V/Sensors (  620): int sensors_poll_context_t::activate(int, int)
V/Sensors (  620): enable - sensor MagneticField (handle 5) dis -> en
V/Sensors (  620): setDelay - sensor MagneticField (handle 5), rate 200 ms (5.00 Hz)
V/CAM_QuickActivity( 2195): END onResume: Activity = com.android.camera.CameraActivity@3f9f1705
D/OpenGLRenderer( 2195): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
D/NuPlayerDriver(  162): start(0xb8f58270)
I/GenericSource(  162): start
I/InputDispatcher(  620): Dropping event because there is no touchable window at (197, 344).
V/CAM_CameraDataAdapter( 2195): retrieved photo metadata, number of items: 0
V/CAM_CameraDataAdapter( 2195): retrieved video metadata, number of items: 0
V/CAM_CameraDataAdapter( 2195): sorting video/photo metadata
V/CAM_CameraDataAdapter( 2195): sorted video/photo metadata
W/ActivityThread( 1847): ClassLoader.loadClass: The class loader returned by Thread.getContextClassLoader() may fail for processes that host multiple applications. You should explicitly specify a context class loader. For example: Thread.setContextClassLoader(getClass().getClassLoader());
D/Atlas   ( 2195): Validating map...
V/WindowManager(  620): Adding window Window{15bbb44d u0 com.android.camera2/com.android.camera.CameraLauncher} at 3 of 9 (before Window{331cf6d9 u0 Starting com.android.camera2})
V/CAM_CameraActivity( 2195): ignoring storage callback after activity pause
W/AudioFlinger(  162): acquireAudioSessionId() unknown client 2195 for session 27
I/InputDispatcher(  620): Dropping event because there is no touchable window at (198, 344).
D/NuPlayerDriver(  162): reset(0xb8f58270)
D/NuPlayerDriver(  162): notifyResetComplete(0xb8f58270)
D/CAM_MemoryQuery( 2195): timestamp=106027, availMem=1626, totalMem=2012, totalPSS=10, lastTrimLevel=0, largeMemoryClass=512, nativePSS=1, dalvikPSS=2, otherPSS=5,threshold=144, lowMemory=false
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 41
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 43
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 50
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 51
I/vpu_mem_pool(  162): pid 162, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 52
D/NuPlayerDriver(  162): start(0xb8f66f40)
D/RKUpdateService( 1847): request remote server error...
I/mali_so ( 2195): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 899;
I/mali_so ( 2195): [Func] : base_context_deal_with_version_affairs_rk_ext; arm_release_ver of this mali_so is 'r5p0-06rel0', rk_so_ver is '8@0', built at '18:11:21', on 'Jul  2 2015'.
I/mali_so ( 2195): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 926;
I/mali_so ( 2195): [Func] : base_context_deal_with_version_affairs_rk_ext; mali_ver_property has been set to 'r5p0-06rel0-12-8@0', to return.
I/OpenGLRenderer( 2195): Initialized EGL, version 1.4
D/OpenGLRenderer( 2195): Enabling debug mode 0
D/NuPlayerDriver(  162): reset(0xb8f66f40)
D/NuPlayerDriver(  162): notifyResetComplete(0xb8f66f40)
V/CAM_TexViewHelper( 2195): onLayoutChange
V/CAM_TexViewHelper( 2195): updateTransform
V/CAM_CameraDataAdapter( 2195): new photos query return num items: 0
W/ResourceType( 2195): No package identifier when getting value for resource number 0x00000000
W/PackageManager( 2195): Failure retrieving resources for com.android.gallery3d: Resource ID #0x0
V/CAM_CameraAppUI( 2195): SurfaceTexture is available
I/CAM_PhotoModule( 2195): onPreviewUIReady
I/CAM_PhotoModule( 2195): attempted to start preview before camera device
W/PathParser( 2195): Points are too far apart 4.000000596046461
I/ActivityManager(  620): Displayed com.android.camera2/com.android.camera.CameraLauncher: +775ms
V/CAM_CameraController( 2195): onCameraOpened
V/CAM_CameraActivity( 2195): onCameraOpened
I/CAM_PhotoModule( 2195): onCameraAvailable
V/CAM_FocusOverlayMgr( 2195): stored focus setting for camera: continuous-picture
V/CAM_FocusOverlayMgr( 2195): focus mode resolved from setting: CONTINUOUS_PICTURE
V/CAM_SettingsManager( 2195): listeners: [com.android.camera.app.CameraAppUI@2d2fc8c7, com.android.camera.ButtonManager@34ac6660, com.android.camera.widget.IndicatorIconController@2ce7d3de, com.android.camera.PhotoModule@36fe5d24]
V/CAM_PhotoModule( 2195): setDisplayOrientation (screen:preview) 0:180
V/CAM_FocusOverlayMgr( 2195): returning override focus: CONTINUOUS_PICTURE
D/CAM_SettingsUtil( 2195): Selected 4224x3136 resolution: 4224x3136
D/CameraHal(  162): commandThread(1086): commandThread(1086): receive CMD_AF_CANCEL
V/CAM_PhotoModule( 2195): updating aspect ratio
V/CAM_TexViewHelper( 2195): updateAspectRatio
V/CAM_TexViewHelper( 2195): setAspectRatio: 1.3469387
V/CAM_TexViewHelper( 2195): aspect ratio changed from: 0.0
D/CAM_PhotoModule( 2195): Preview size is Size: (2112 x 1568)
I/CAM_PhotoModule( 2195): startPreview
V/CAM_CameraAppUI( 2195): onPreviewStarted
D/CameraHal(  162): commandThread(942): commandThread(942):receive CMD_SET_PREVIEW_WINDOW
D/CameraHal(  162): commandThread(958): commandThread(958): CMD_SET_PREVIEW_WINDOW out
D/CameraHal(  162): commandThread(837): commandThread(837):receive CMD_PREVIEW_START
V/WindowManager(  620): not Base app: Adding window Window{39bddf7c u0 com.android.camera2/com.android.camera.CameraLauncher} at 5 of 10
V/CAM_CameraActivity( 2195): invoking onChangeCamera
W/CAM_IndicatorIconCtrlr( 2195): Trying to sync a pano indicator that is not initialized.
D/CameraHal(  162): stop(1766): m_camDevice->stopPreview success!
D/CameraHal(  162): start(1721): m_camDevice->startPreview success
D/CameraHal(  162): displayThread(589): displayThread(589): receive CMD_DISPLAY_START
D/CameraHal(  162): commandThread(910): commandThread(910): CMD_PREVIEW_START out
D/CAM_LcyLocProvider( 2195): provider does not exist provider doesn't exist: network
D/CAM_LcyLocProvider( 2195): provider does not exist provider doesn't exist: gps
D/CAM_LcyLocProvider( 2195): startReceivingLocationUpdates
D/InitAlarmsService( 2105): Clearing and rescheduling alarms.
D/PowerManagerService(  620): screen time out
E/Lights  (  620): write_int failed to open /sys/class/backlight/rk28_bl/brightness
E/dhcpcd  ( 1212): timed out
D/NetUtils(  620): dhcp_do_request failed : eth0 (new)
E/EthernetNetworkFactory(  620): DHCP request error:Timed out waiting for DHCP to finish
E/NetworkController( 1378): onReceive ETHERNET_STATE_CHANGED_ACTION
D/LyricManager( 1972): hide lrc
D/LyricManager( 1972): not attached to window manager
I/MediaFocusControl(  620):  AudioFocus  abandonAudioFocus() from android.media.AudioManager@3fc1ce80com.android.music.MediaPlaybackService$4@29701cb9
I/ActivityManager(  620): Start proc 3052:com.android.musicfx/u0a7 for broadcast com.android.musicfx/.ControlPanelReceiver
V/MusicFXControlPanelReceiver( 3052): onReceive
V/MusicFXControlPanelReceiver( 3052): Action: android.media.action.CLOSE_AUDIO_EFFECT_CONTROL_SESSION
V/MusicFXControlPanelReceiver( 3052): Package name: com.android.music
V/MusicFXControlPanelReceiver( 3052): Audio session: 10
V/MusicFXControlPanelEffect( 3052): closeSession(android.app.ReceiverRestrictedContext@28fa527c, com.android.music, 10)
I/ActivityManager(  620): Killing 1740:com.android.exchange/u0a23 (adj 15): empty #17
补充下 以下是运行时内核的信息 有错误信息 话说内核是从SDK下载来的 难道安装包有问题?
<4>[  508.586852] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in
turn on
<4>[  508.586890] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in
turn on
<4>[  508.586903] D1:camsys_open(739): camsys_marvin(debdda10) is opened!
<4>[  508.594066] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 420000000
Hz) in turn on
<4>[  508.594087] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[  508.594196] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[  508.594216] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[  508.594314] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[  508.596383] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[  508.597130] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set
0
<4>[  508.597243] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[  508.597362] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<3>[  508.598481] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is
NULL!
<3>[  508.598501] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is
 NULL!
<4>[  508.598623] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set
0
<4>[  508.599024] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[  508.599233] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<3>[  508.600363] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is
NULL!
<3>[  508.600382] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is
 NULL!
<4>[  508.600442] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24
000000Hz) turn on
<4>[  508.600731] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set
<4>[  508.604890] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
<4>[  508.604999] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<3>[  508.606129] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is
NULL!
<3>[  508.606154] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is
 NULL!
<4>[  508.756579] D1:camsys_mrv_iommu_cb(276): map fd 10 ,client fd 45
<4>[  508.756579]
<6>[  508.756619] rk_iommu ff914000.isp_mmu: rockchip_iommu_attach_device: Attac
hed new IOMMU with pgtable 0x1eab3000
<4>[  508.758651] D1:camsys_mrv_iommu_cb(276): map fd 19 ,client fd 45
<4>[  508.758651]
<6>[  508.758666] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
<4>[  508.760625] D1:camsys_mrv_iommu_cb(276): map fd 20 ,client fd 45
<4>[  508.760625]
<6>[  508.760640] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
<4>[  508.762638] D1:camsys_mrv_iommu_cb(276): map fd 22 ,client fd 45
<4>[  508.762638]
<6>[  508.762653] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
<4>[  508.827244] D1:camsys_rk3288_mipihpy_cfg(109): mipi phy 1 standby!
<3>[  508.827271] W:camsys_phy_ops(478): mipiphy->phy_index(-1218202540) != extd
ev->phy.info.mipi.phy_index(1)!
<4>[  508.827489] D1:camsys_rk3288_mipihpy_cfg(219): mipi phy(1) turn on(lane: 0
x3  bit_rate: 600Mbps)
<4>[  508.915820] D1:camsys_irq_connect(542): Thread(pid: 4499) connect camsys_m
arvin irq success! mis: 0x5c4 icr: 0x5c8
<4>[  508.915899] D1:camsys_irq_connect(542): Thread(pid: 4500) connect camsys_m
arvin irq success! mis: 0x1500 icr: 0x1504
<4>[  515.990214] D1:camsys_irq_disconnect(651): Thread(pid: 4500) disconnect ca
msys_marvin irq success!
<3>[  515.995463] W:camsys_irq_wait(611): Thread(pid: 4500) has been disconnect!
<4>[  515.995792] D1:camsys_irq_disconnect(651): Thread(pid: 4499) disconnect ca
<3>[  516.005278] W:camsys_irq_wait(611): Thread(pid: 4499) has been disconnect!
<4>[  516.168557] D1:camsys_rk3288_mipihpy_cfg(109): mipi phy 1 standby!
<4>[  516.169488] D1:camsys_mrv_iommu_cb(276): map fd 22 ,client fd 45
<4>[  516.169488]
<6>[  516.170748] rk_iommu ff914000.isp_mmu: (isp_mmu) 3 times left to be disabl
ed
<3>[  516.170774] rk_iommu ff914000.isp_mmu: rockchip_iommu_detach_device: Detac
hing IOMMU with pgtable 1eab3000 delayed
<4>[  516.172570] D1:camsys_mrv_iommu_cb(276): map fd 20 ,client fd 45
<4>[  516.172570]
<6>[  516.173809] rk_iommu ff914000.isp_mmu: (isp_mmu) 2 times left to be disabl
ed
<3>[  516.173832] rk_iommu ff914000.isp_mmu: rockchip_iommu_detach_device: Detac
<4>[  516.175787] D1:camsys_mrv_iommu_cb(276): map fd 19 ,client fd 45
<4>[  516.175787]
<6>[  516.177031] rk_iommu ff914000.isp_mmu: (isp_mmu) 1 times left to be disabl
ed
<3>[  516.177054] rk_iommu ff914000.isp_mmu: rockchip_iommu_detach_device: Detac
<4>[  516.178319] D1:camsys_mrv_iommu_cb(276): map fd 10 ,client fd 45
<4>[  516.178319]
<4>[  516.181735] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[  516.181899] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set
0
<4>[  516.182018] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[  516.182136] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<3>[  516.183233] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is
NULL!
<3>[  516.183263] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is
 NULL!
<4>[  516.184653] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[  516.184808] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set
0
<4>[  516.184911] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[  516.185109] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<3>[  516.186220] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is
NULL!
<3>[  516.186253] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is
 NULL!
<4>[  516.186322] D1:camsys_irq_disconnect(664): All thread disconnect camsys_ma
rvin irq success!
<4>[  516.186344] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in
turn off
<4>[  516.186364] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in
turn off
<4>[  516.186378] D1:camsys_release(763): camsys_marvin(debdda10) is closed
是不是还要配置i2c?
firefly-3288 MIPI CSAI使用里
配置 Android:修改 hardware/rk29/camera/Config/cam_board.xml 来注册摄像头。
可在我的hardware下面没有rk29文件,但有rockchip文件
是因为我下android5.1源码有关吗?
请确认OV18350与固件版本, 参考如下:
http://developer.t-firefly.com/forum.php?mod=viewthread&tid=5434&highlight=OV13850
