In order to use this, you will also need to build the kernel-side driver and replace the kernel in your build. This can be achieved by following the Firefly wiki page I mentioned earlier and starting with this Linux repository (master branch):
T-Firefly / Firefly-RK3288-kernel / Commits — Bitbucket https://bitbucket.org/T-Firefly/firefly-rk3288-kernel.git
You’ll need to remove the main drivers files under drivers/gpu/arm/, but not drivers/gpu/arm/midgard/platform/rk which contains the RK3288 platform support files, and replace them with the files from the archive. Some relatively small changes may be needed in the RK3288 platform files to make it work with the new r5p0 driver; sorry we haven’t got a patch for that at the moment.
