我是用分区镜像来烧的,因为按统一固件方式烧不起来,recovery.img有35MB,但paremeter.txt里只分20MB(0x00010000)大小,所以就按分区镜像方式了,然后我paremeter.txt里面也没改动,以下就是paremeter.txt里的信息
FIRMWARE_VER: 6.0.1
MACHINE_MODEL: RK3399
MACHINE_ID: 007
MANUFACTURER: RK3399
MAGIC: 0x5041524B
ATAG: 0x00200800
MACHINE: 3399
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
#KERNEL_IMG: 0x00280000
#FDT_NAME: rk-kernel.dtb
#RECOVER_KEY: 1,1,0,20,0
#in section; per section 512(0x200) bytes
CMDLINE: androidboot.baseband=N/A androidboot.selinux=disabled androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x00008000@0x00010000(kernel),0x00010000@0x00018000(boot),0x00010000@0x00028000(recovery),0x00038000@0x00038000(backup),0x00040000@0x00070000(cache),0x00200000@0x000B0000(system),0x00008000@0x002B0000(metadata),0x00002000@0x002B8000(baseparamer),-@0x002BA000(userdata)
我改了paremeter.txt里的分区大小,然后使用分区镜像烧录还是不行,还是“下载完成”“没有发现设备”
我改了recovery大小,后面的分区也改了,系统还是起不来,还是5秒死循环,然后只有下面串口信息,adb进不去没有logcat信息,求大神分析一下。
#recovery大小改动
DDR Version 1.07 20161103
soft reset
SRX
Channel 0: LPDDR3, 666MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x3
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
CS = 1
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x3
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=2048MB
Channel 1: LPDDR3, 666MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x3
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
CS = 1
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x3
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
256B stride
pmugrf_os_reg[2] = 0x3AA0DAA0, stride = 0xD
Boot1: 2016-07-29, version: 1.05
CPUId = 0x0
ChipType = 10 1913
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7456MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 63270
LoadTrustBL
No find bl30.bin
No find bl32.bin
theLoader 200000 78806
LoaderFlag2: 0xc3524203
WARNING: plat_rockchip_comm_sram_init:code:ff8d9000, 67000, ef0
NOTICE: BL31: v1.2(debug):b995f80
NOTICE: BL31: Built : 16:53:56, Nov 7 2016
WARNING: check_cpu_wfie: 1, 0, 69632, error!
INFO: boot cpu mask: 0
INFO: Vesion: 2016.0.01
INFO: plat_rockchip_pmu_init(1211): pd status 2e
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-10-02120-g8f1e39c (Dec 27 2016 - 20:01:46)
CPU: rk3399
CPU's clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
aclk_periph_h = 148500000HZ, hclk_periph_h = 74250000HZ, pclk_periph_h = 37125000HZ
aclk_periph_l0 = 99000000HZ, hclk_periph_l0 = 99000000HZ, pclk_periph_l0 = 49500000HZ
hclk_periph_l1 = 99000000HZ, pclk_periph_l1 = 49500000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can't find dts node for pwm1
#Boot ver: 2016-12-27#1.05
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
rk lcdc - 0 dclk set: dclk = 205000000HZ, pll select = 1, div = 4
edp pll locked
Aux Transaction fail!
link training success.
unable to config video
no fuel gauge found
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x010121e8)
ramdisk @ 0x05bf0000 (0x012bcc50)
bootrk: do_bootm_linux...
Loading Device Tree to 0000000005600000, end 0000000005614d47 ... OK
Add bank:0000000000200000, 00000000f7e00000
Starting kernel ...
[ 0.000000] Linux version 4.4.30 (root@Ubuntu-Z) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP PREEMPT Tue Dec 27 19:58:48 CST 2016
[ 0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000edc00000, size 128 MiB
[ 0.000000] Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7efa000 s45248 r8192 d32576 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 999432
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00012000@0x0002C000(recovery),0x00038000@0x0003E000(backup),0x00040000@0x00076000(cache),0x00600000@0x000B6000(system),0x00008000@0x006B6000(metadata),0x00002000@0x006BE000(baseparamer),0x00000400@0x006C0000(frp),-@0x006C0400(userdata) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000:0x01000000 loader.timestamp=2016-12-27_20:01:46
[ 0.000000] software IO TLB [mem 0xf7eb2000-0xf7ef2000] (0MB) mapped at [ffffffc0f7eb2000-ffffffc0f7ef1fff]
[ 0.000000] Memory: 3787496K/4061184K available (9982K kernel code, 1160K rwdata, 4468K rodata, 768K init, 1043K bss, 142616K reserved, 131072K cma-reserved)
[ 0.000000] .init : 0xffffff8008eb0000 - 0xffffff8008f70000 ( 768 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008a40000 ( 9984 KB)
[ 0.000000] .rodata : 0xffffff8008a40000 - 0xffffff8008eb0000 ( 4544 KB)
[ 0.000000] .data : 0xffffff8008f70000 - 0xffffff80090920a8 ( 1161 KB)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.000000] ITS: allocated 65536 Devices @e9000000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x00000000e9080000
[ 0.000000] CPU0: using LPI pending table @0x00000000e9090000
[ 0.001700] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.002731] pid_max: default: 32768 minimum: 301
[ 0.003232] Security Framework initialized
[ 0.003628] SELinux: Initializing.
[ 0.004060] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004701] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006217] Initializing cgroup subsys freezer
[ 0.006682] Initializing cgroup subsys debug
[ 0.007593] sched-energy: Sched-energy-costs installed from DT
[ 0.008152] CPU0: update cpu_capacity 401
[ 0.008590] ASID allocator initialised with 65536 entries
[ 0.026903] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.028190] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.042930] Detected VIPT I-cache on CPU1
[ 0.042963] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.043000] CPU1: using LPI pending table @0x00000000e9200000
[ 0.043045] CPU1: update cpu_capacity 401
[ 0.043048] CPU1: Booted secondary processor [410fd034]
[ 0.054931] Detected VIPT I-cache on CPU2
[ 0.054950] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.054982] CPU2: using LPI pending table @0x00000000e9230000
[ 0.055010] CPU2: update cpu_capacity 401
[ 0.055013] CPU2: Booted secondary processor [410fd034]
[ 0.066968] Detected VIPT I-cache on CPU3
[ 0.066986] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.067019] CPU3: using LPI pending table @0x00000000e9270000
[ 0.067046] CPU3: update cpu_capacity 401
[ 0.067049] CPU3: Booted secondary processor [410fd034]
[ 1.080061] CPU4: failed to come online
[ 1.096507] Detected PIPT I-cache on CPU5
[ 1.096537] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 1.096574] CPU5: using LPI pending table @0x00000000e92e0000
[ 1.096615] CPU5: update cpu_capacity 1024
[ 1.096619] CPU5: Booted secondary processor [410fd082]
[ 1.096714] Brought up 5 CPUs
[ 1.099413] SMP: Total of 5 processors activated.
[ 1.099864] CPU features: detected feature: GIC system register CPU interface
[ 1.100560] CPU: All CPU(s) started at EL2
[ 1.100983] alternatives: patching kernel code
[ 1.102602] devtmpfs: initialized
[ 1.121377] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 1.127373] pinctrl core: initialized pinctrl subsystem
[ 1.130870] NET: Registered protocol family 16
[ 1.131828] schedtune: init normalization constants...
[ 1.132324] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 1.132947] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 1.133569] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 1.134190] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 1.134833] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 1.135455] schedtune: CLUSTER[5] min_pwr: 65 max_pwr: 1108
[ 1.136076] schedtune: CPU[5] min_pwr: 65 max_pwr: 1108
[ 1.136704] Unable to handle kernel NULL pointer dereference at virtual address 00000010
[ 1.137471] pgd = ffffff800919b000
[ 1.137796] [00000010] *pgd=00000000f7ffe003, *pud=00000000f7ffe003, *pmd=0000000000000000
[ 1.138592] Internal error: Oops: 96000005 [#1] PREEMPT SMP
[ 1.139124] Modules linked in:
[ 1.139424] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.30 #1
[ 1.139986] Hardware name: rockchip,rk3399-excavator-edp (DT)
[ 1.140534] task: ffffffc0e9160000 ti: ffffffc0e9168000 task.ti: ffffffc0e9168000
[ 1.141247] PC is at schedtune_init+0x21c/0x3ac
[ 1.141680] LR is at schedtune_init+0x20c/0x3ac
[ 1.142112] pc : [<ffffff80080de924>] lr : [<ffffff80080de914>] pstate: 60000045
[ 1.142813] sp : ffffffc0e916bcd0
[ 1.143130] x29: ffffffc0e916bcd0 x28: ffffff8008f77bf0
[ 1.143639] x27: ffffffc0e92957e0 x26: ffffff8008f77000
[ 1.144149] x25: ffffff8008d436a8 x24: ffffff8008d43669
[ 1.144658] x23: ffffffc0e9269400 x22: ffffff8009098000
[ 1.145166] x21: ffffff8008f4de40 x20: ffffff8008d43000
[ 1.145675] x19: ffffffc0e92957c0 x18: 0000000000000078
[ 1.146184] x17: 000000000000000e x16: 0000000000000007
[ 1.146694] x15: ffffff8008a99000 x14: 0fffffffffffffff
[ 1.147202] x13: 0000000000000030 x12: 0101010101010101
[ 1.147712] x11: 7f7f7f7f7f7f7f7f x10: 59ff5c345a544f42
[ 1.148220] x9 : ffffffffffffffff x8 : ffffffc0e9269c00
[ 1.148727] x7 : 0000000000000005 x6 : ffffff8009099981
[ 1.149236] x5 : 0000000000000002 x4 : 0000000000000000
[ 1.149745] x3 : 0000000000000000 x2 : cb88537fdc8ba61e
[ 1.150254] x1 : 0000000000000020 x0 : 0000000000000000
[ 1.150764]
[ 1.150764] PC: 0xffffff80080de8a4:
[ 1.151238] e8a4 f9400402 51000421 f861784a aa1903e2 b9401001 f9400c00 51000421 f9003baa
[ 1.152039] e8c4 8b011001 f940d2c0 8b0a0000 f900d2c0 f9400429 910682c1 f9003fa9 f9400420
[ 1.152838] e8e4 8b090000 f9000420 d2800401 910263a0 940a3fac f9403baa 910263a1 f9403fa9
[ 1.153636] e904 9119e280 aa0a03e2 aa0903e3 9401fee0 f94037a8 f9401261 f94033a7 f9400100
[ 1.154432] e924 f9400800 f9401000 ca000020 92401c00 b4fff8e0 d4210000 f9400273 f9400ae0
[ 1.155230] e944 eb00027f 54fff3c1 910682d5 94005024 f940d2c2 b0006661 9124e421 9119e280
[ 1.156026] e964 f94006a3 b0006337 911c92f7 9401fec8 f94006b4 f940d2c0 cb000294 2a1403e0
[ 1.156824] e984 940a67b0 2a0003e1 f9000aa0 d3609c02 d368bc03 b0006320 911ac000 52800015
[ 1.157623]
[ 1.157623] LR: 0xffffff80080de894:
[ 1.158096] e894 f90033a7 f90037a8 f9400c00 b9400001 f9400402 51000421 f861784a aa1903e2
[ 1.158894] e8b4 b9401001 f9400c00 51000421 f9003baa 8b011001 f940d2c0 8b0a0000 f900d2c0
[ 1.159691] e8d4 f9400429 910682c1 f9003fa9 f9400420 8b090000 f9000420 d2800401 910263a0
[ 1.160488] e8f4 940a3fac f9403baa 910263a1 f9403fa9 9119e280 aa0a03e2 aa0903e3 9401fee0
[ 1.161286] e914 f94037a8 f9401261 f94033a7 f9400100 f9400800 f9401000 ca000020 92401c00
[ 1.162083] e934 b4fff8e0 d4210000 f9400273 f9400ae0 eb00027f 54fff3c1 910682d5 94005024
[ 1.162880] e954 f940d2c2 b0006661 9124e421 9119e280 f94006a3 b0006337 911c92f7 9401fec8
[ 1.163677] e974 f94006b4 f940d2c0 cb000294 2a1403e0 940a67b0 2a0003e1 f9000aa0 d3609c02
[ 1.164474]
[ 1.164474] SP: 0xffffffc0e916bc50:
[ 1.164948] bc50 09098000 ffffff80 e9269400 ffffffc0 08d43669 ffffff80 08d436a8 ffffff80
[ 1.165745] bc70 08f77000 ffffff80 e92957e0 ffffffc0 08f77bf0 ffffff80 e916bcd0 ffffffc0
[ 1.166542] bc90 080de914 ffffff80 e916bcd0 ffffffc0 080de924 ffffff80 60000045 00000000
[ 1.167339] bcb0 00000001 00000000 00000001 00000000 ffffffff ffffffff 00000000 00000000
[ 1.168134] bcd0 e916bd90 ffffffc0 08082ba4 ffffff80 080de708 ffffff80 08f84b20 ffffff80
[ 1.168932] bcf0 e93f1cc0 ffffffc0 08f76000 ffffff80 08f84b20 ffffff80 00000000 00000000
[ 1.169729] bd10 08eb04a4 ffffff80 08f12310 ffffff80 09096000 ffffff80 08f12320 ffffff80
[ 1.170526] bd30 00000005 00000000 e9269c00 ffffffc0 00000041 00000000 00000454 00000000
[ 1.171328]
[ 1.171328] X6: 0xffffff8009099901:
[ 1.171801] 9900 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.172599] 9920 00000000 00000000 00000000 00000000 00000000 00000000 30303020 32303330
[ 1.173395] 9940 39333337 39205d35 20303439 312e3120 32333137 58205d38 30203a36 66666678
[ 1.174192] 9960 38666666 30393030 30393939 300a3a31 64303830 34313965 70205d3e 74617473
[ 1.174989] 9980 36203a65 30303030 0a353430 3030300a 0a303130 30353436 38373134 30303135
[ 1.175787] 99a0 20303030 390a736e 32303235 20323935 740a736e 726f7720 20200a6b 302e3020
[ 1.176582] 99c0 30303030 20205d30 76202020 6c6c616d 3a20636f 66783020 66666666 30303866
[ 1.177379] 99e0 30303038 20303030 7830202d 66666666 64626666 66666662 30303030 28202020
[ 1.178176] 9a00 32202020 47203634 5b0a2942 20202020 30302e30 30303030 2020205d 20202020
[ 1.178976]
[ 1.178976] X8: 0xffffffc0e9269b80:
[ 1.179450] 9b80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.180248] 9ba0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.181043] 9bc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.181840] 9be0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.182636] 9c00 00000000 00000000 00000000 00000000 e92957c0 ffffffc0 00000005 00000000
[ 1.183433] 9c20 0000000a 00000000 00000020 0000007d 00000001 00000002 00000001 00000000
[ 1.184230] 9c40 00000000 00000000 00000000 00000000 0000102f 00000001 fffedc23 00000000
[ 1.185027] 9c60 00000005 00000000 00002352 00000000 fffedd16 00000000 00000004 00000000
[ 1.185827]
[ 1.185827] X15: 0xffffff8008a98f80:
[ 1.186309] 8f80 74707572 00000000 08433cb0 ffffff80 08433bf4 ffffff80 30353238 696b732e
[ 1.187107] 8fa0 78745f70 745f6e65 00747365 00000000 30353238 5f726e2e 74726175 00000073
[ 1.187904] 8fc0 30353238 6168732e 695f6572 00737172 180c0600 00001218 00001e1e 00000000
[ 1.188701] 8fe0 00000b0b 00000000 2d2a2800 00000000 08d8f4b0 ffffff80 00010001 00000000
[ 1.189497] 9000 00000000 00000000 08d7e66d ffffff80 00010001 00000000 00000000 00000000
[ 1.190293] 9020 08d7e6f4 ffffff80 00010001 00000000 00000000 00000000 08d7e6fa ffffff80
[ 1.191089] 9040 00010001 00000000 00000000 00000000 08d7e74b ffffff80 00100010 08040181
[ 1.191883] 9060 0000000e 00000100 08d7e700 ffffff80 00010001 00000000 00000000 00000000
[ 1.192684]
[ 1.192684] X19: 0xffffffc0e9295740:
[ 1.193165] 5740 616d6f64 00306e69 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.193962] 5760 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.194759] 5780 30757063 ffffff00 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.195554] 57a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.196351] 57c0 e92955c0 ffffffc0 00000001 00000001 e9295800 ffffffc0 e90edc00 ffffffc0
[ 1.197146] 57e0 00000020 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.197943] 5800 00000001 00000000 00000400 00000000 00000400 00000000 fffedc25 00000000
[ 1.198740] 5820 00000000 00000001 000000ff 00000000 00000000 00000000 00000000 00000000
[ 1.199538]
[ 1.199538] X20: 0xffffff8008d42f80:
[ 1.200020] 2f80 75725f63 6d69746e 65730065 74733e2d 73697461 73636974 6961772e 74735f74
[ 1.200817] 2fa0 00747261 3e2d6573 74617473 69747369 732e7363 7065656c 6174735f 73007472
[ 1.201615] 2fc0 733e2d65 69746174 63697473 6c622e73 5f6b636f 72617473 65730074 74733e2d
[ 1.202413] 2fe0 73697461 73636974 656c732e 6d5f7065 73007861 733e2d65 69746174 63697473
[ 1.203211] 3000 6c622e73 5f6b636f 0078616d 3e2d6573 74617473 69747369 652e7363 5f636578
[ 1.204008] 3020 0078616d 3e2d6573 74617473 69747369 732e7363 6563696c 78616d5f 2d657300
[ 1.204806] 3040 6174733e 74736974 2e736369 74696177 78616d5f 2d657300 6174733e 74736974
[ 1.205603] 3060 2e736369 74696177 6d75735f 2e202000 30332d25 25203a73 0a646c6c 2d657300
[ 1.206403]
[ 1.206403] X21: 0xffffff8008f4ddc0:
[ 1.206884] ddc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.207681] dde0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.208479] de00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.209275] de20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.210070] de40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.210867] de60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.211662] de80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.212457] dea0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.213256]
[ 1.213256] X22: 0xffffff8009097f80:
[ 1.213737] 7f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.214533] 7fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.215330] 7fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.216128] 7fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.216924] 8000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.217719] 8020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.218516] 8040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.219313] 8060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.220111]
[ 1.220111] X23: 0xffffffc0e9269380:
[ 1.220593] 9380 e9269200 ffffffc0 e92693a9 ffffffc0 00000000 00000000 00000000 00000000
[ 1.221391] 93a0 e9269200 ffffffc0 e9269268 ffffffc0 e9269288 ffffffc0 e9269388 ffffffc0
[ 1.222188] 93c0 e9269200 ffffffc0 e9269288 ffffffc0 00000000 00000000 00000000 00000000
[ 1.222985] 93e0 e9269200 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.223782] 9400 00000000 00000000 e9268a00 ffffffc0 e92955c0 ffffffc0 00000005 00000000
[ 1.224577] 9420 0000000a 00000000 00000020 0000007d 00000001 00000002 00000001 00000000
[ 1.225374] 9440 00000000 00000000 00000000 00000000 0000102f 00000001 fffedc1b 00000000
[ 1.226171] 9460 0000000a 00000000 00000b64 00000000 fffedd16 00000000 00000000 00000000
[ 1.226968]
[ 1.226968] X24: 0xffffff8008d435e9:
[ 1.227449] 35e8 65726320 20657461 65726f6d 61687420 6425206e 68635320 75546465 6220656e
[ 1.228247] 3608 74736f6f 20676e69 756f7267 000a7370 63733601 74646568 3a656e75 696e6920
[ 1.229044] 3628 6f6e2074 6c616d72 74617a69 206e6f69 736e6f63 746e6174 2e2e2e73 3601000a
[ 1.229842] 3648 65686373 6e757464 6e203a65 6e65206f 79677265 646f6d20 64206c65 0a617461
[ 1.230639] 3668 554c4300 52455453 702a255b 005d6c62 63733601 74646568 3a656e75 312d2520
[ 1.231437] 3688 6d207337 705f6e69 203a7277 756c3525 78616d20 7277705f 3525203a 000a756c
[ 1.232232] 36a8 5b555043 005d6425 63733601 74646568 3a656e75 69737520 6e20676e 616d726f
[ 1.233031] 36c8 617a696c 6e6f6974 6e6f6320 6e617473 6d207374 203a6c75 73207525 203a3168
[ 1.233828] 36e8 73207525 203a3268 000a7525 63733601 74646568 3a656e75 72657620 20796669
[ 1.234627]
[ 1.234627] X25: 0xffffff8008d43628:
[ 1.235109] 3628 6f6e2074 6c616d72 74617a69 206e6f69 736e6f63 746e6174 2e2e2e73 3601000a
[ 1.235906] 3648 65686373 6e757464 6e203a65 6e65206f 79677265 646f6d20 64206c65 0a617461
[ 1.236703] 3668 554c4300 52455453 702a255b 005d6c62 63733601 74646568 3a656e75 312d2520
[ 1.237500] 3688 6d207337 705f6e69 203a7277 756c3525 78616d20 7277705f 3525203a 000a756c
[ 1.238297] 36a8 5b555043 005d6425 63733601 74646568 3a656e75 69737520 6e20676e 616d726f
[ 1.239094] 36c8 617a696c 6e6f6974 6e6f6320 6e617473 6d207374 203a6c75 73207525 203a3168
[ 1.239889] 36e8 73207525 203a3268 000a7525 63733601 74646568 3a656e75 72657620 20796669
[ 1.240687] 3708 6d726f6e 7a696c61 6f697461 6f63206e 6174736e 2e73746e 000a2e2e 63733601
[ 1.241486]
[ 1.241486] X26: 0xffffff8008f76f80:
[ 1.241968] 6f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.242764] 6fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.243560] 6fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.244357] 6fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.245154] 7000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.245950] 7020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.246747] 7040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.247544] 7060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.248342]
[ 1.248342] X27: 0xffffffc0e9295760:
[ 1.248824] 5760 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.249621] 5780 30757063 ffffff00 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.250418] 57a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.251214] 57c0 e92955c0 ffffffc0 00000001 00000001 e9295800 ffffffc0 e90edc00 ffffffc0
[ 1.252011] 57e0 00000020 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.252808] 5800 00000001 00000000 00000400 00000000 00000400 00000000 fffedc25 00000000
[ 1.253605] 5820 00000000 00000001 000000ff 00000000 00000000 00000000 00000000 00000000
[ 1.254402] 5840 00000001 00000001 00000001 00000001 ffffffff 00000001 00000000 00000000
[ 1.255201]
[ 1.255201] X28: 0xffffff8008f77b70:
[ 1.255682] 7b70 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.256478] 7b90 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.257276] 7bb0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.258071] 7bd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.258868] 7bf0 00000006 00000000 00000013 00000000 00000000 00000000 00000000 00000000
[ 1.259665] 7c10 00000000 00000000 00000000 00000000 00000000 00000000 09089118 ffffff80
[ 1.260462] 7c30 00000000 00000000 00000000 00000000 00000000 00000000 0000000a 00000000
[ 1.261258] 7c50 00400000 0000000a 00000003 00000000 00000000 00000000 00000000 00000000
[ 1.262057]
[ 1.262057] X29: 0xffffffc0e916bc50:
[ 1.262539] bc50 09098000 ffffff80 e9269400 ffffffc0 08d43669 ffffff80 08d436a8 ffffff80
[ 1.263336] bc70 08f77000 ffffff80 e92957e0 ffffffc0 08f77bf0 ffffff80 e916bcd0 ffffffc0
[ 1.264134] bc90 080de914 ffffff80 e916bcd0 ffffffc0 080de924 ffffff80 60000045 00000000
[ 1.264932] bcb0 00000001 00000000 00000001 00000000 ffffffff ffffffff 00000000 00000000
[ 1.265728] bcd0 e916bd90 ffffffc0 08082ba4 ffffff80 080de708 ffffff80 08f84b20 ffffff80
[ 1.266525] bcf0 e93f1cc0 ffffffc0 08f76000 ffffff80 08f84b20 ffffff80 00000000 00000000
[ 1.267323] bd10 08eb04a4 ffffff80 08f12310 ffffff80 09096000 ffffff80 08f12320 ffffff80
[ 1.268120] bd30 00000005 00000000 e9269c00 ffffffc0 00000041 00000000 00000454 00000000
[ 1.268916]
[ 1.269062] Process swapper/0 (pid: 1, stack limit = 0xffffffc0e9168020)
[ 1.269700] Stack: (0xffffffc0e916bcd0 to 0xffffffc0e916c000)
[ 1.270249] bcc0: ffffffc0e916bd90 ffffff8008082ba4
[ 1.270994] bce0: ffffff80080de708 ffffff8008f84b20 ffffffc0e93f1cc0 ffffff8008f76000
[ 1.271740] bd00: ffffff8008f84b20 0000000000000000 ffffff8008eb04a4 ffffff8008f12310
[ 1.272485] bd20: ffffff8009096000 ffffff8008f12320 0000000000000005 ffffffc0e9269c00
[ 1.273231] bd40: 0000000000000041 0000000000000454 ffffff8008f76000 ffffff8008f78000
[ 1.273976] bd60: ffffffc0e93f1cc0 5b005d355b555043 ffffff005d005d35 0000000000000000
[ 1.274722] bd80: ffffff8008eb04a4 cb88537fdc8ba61e ffffffc0e916be20 ffffff8008eb0e00
[ 1.275467] bda0: 00000000000001bd ffffff8008e97aa0 ffffff8009096000 0000000000000002
[ 1.276212] bdc0: ffffff8008f76000 ffffff8008f123a0 ffffff8008eb04a4 ffffff8008f12300
[ 1.276958] bde0: ffffff8009096000 ffffff8008f12320 ffffff8008d41a2c ffffff8008d774f6
[ 1.277703] be00: ffffff8008a7b1b8 0000000000000000 0000000200000002 cb88537fdc8ba61e
[ 1.278448] be20: ffffffc0e916bea0 ffffff8008a26fb0 ffffff8008a26fa0 0000000000000000
[ 1.279193] be40: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.279938] be60: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.280683] be80: 0000000000000000 ffffff8008f416b0 0000000000000000 cb88537fdc8ba61e
[ 1.281428] bea0: 0000000000000000 ffffff8008082690 ffffff8008a26fa0 0000000000000000
[ 1.282173] bec0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.282917] bee0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.283662] bf00: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.284406] bf20: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.285151] bf40: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.285896] bf60: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.286640] bf80: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.287385] bfa0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.288130] bfc0: 0000000000000000 0000000000000005 0000000000000000 0000000000000000
[ 1.288874] bfe0: 0000000000000000 0000000000000000 ffffffffffffffff ffffffffffffffff
[ 1.289616] Call trace:
[ 1.289854] Exception stack(0xffffffc0e916bae0 to 0xffffffc0e916bc10)
[ 1.290469] bae0: ffffffc0e92957c0 0000008000000000 ffffffc0e916bcd0 ffffff80080de924
[ 1.291214] bb00: 0000000060000045 000000000000003a ffffff8008f93688 000000000000221c
[ 1.291959] bb20: 0000000000000006 ffffff8008f93688 000000000000004a 00000000090997e8
[ 1.292704] bb40: ffffffc0e916bbe0 ffffff80080e8fb4 ffffff8008f76000 ffffff80080e8f80
[ 1.293450] bb60: ffffff8008f4de40 ffffff8009098000 ffffffc0e9269400 ffffff8008d43669
[ 1.294195] bb80: ffffff8008d436a8 ffffff8008f77000 ffffffc0e92957e0 cb88537fdc8ba61e
[ 1.294940] bba0: 0000000000000000 0000000000000020 cb88537fdc8ba61e 0000000000000000
[ 1.295685] bbc0: 0000000000000000 0000000000000002 ffffff8009099981 0000000000000005
[ 1.296431] bbe0: ffffffc0e9269c00 ffffffffffffffff 59ff5c345a544f42 7f7f7f7f7f7f7f7f
[ 1.297174] bc00: 0101010101010101 0000000000000030
[ 1.297642] [<ffffff80080de924>] schedtune_init+0x21c/0x3ac
[ 1.298175] [<ffffff8008082ba4>] do_one_initcall+0x17c/0x198
[ 1.298719] [<ffffff8008eb0e00>] kernel_init_freeable+0x1b8/0x270
[ 1.299303] [<ffffff8008a26fb0>] kernel_init+0x10/0xf8
[ 1.299794] [<ffffff8008082690>] ret_from_fork+0x10/0x40
[ 1.300304] Code: f94037a8 f9401261 f94033a7 f9400100 (f9400800)
[ 1.300903] ---[ end trace d5cb4d4f865c868c ]---
[ 1.301374] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 1.301374]
[ 1.302245] CPU2: stopping
[ 1.302513] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 4.4.30 #1
[ 1.303189] Hardware name: rockchip,rk3399-excavator-edp (DT)
[ 1.303735] Call trace:
[ 1.303977] [<ffffff80080884c4>] dump_backtrace+0x0/0x1c8
[ 1.304494] [<ffffff80080886a0>] show_stack+0x14/0x1c
[ 1.304980] [<ffffff8008362ae4>] dump_stack+0x8c/0xac
[ 1.305465] [<ffffff800808e334>] handle_IPI+0x140/0x284
[ 1.305965] [<ffffff8008080e80>] gic_handle_irq+0x10c/0x150
[ 1.306496] Exception stack(0xffffffc0f7f28000 to 0xffffffc0f7f28130)
[ 1.307112] 8000: ffffffc0e91c3e20 0000008000000000 ffffffc0e91c3f50 ffffff8008084944
[ 1.307857] 8020: 0000000060000045 0000000000000000 ffffffc0f7f24060 0000000000000000
[ 1.308602] 8040: ffffffc0e91c3f50 ffffffc0e91c3e20 0000000000000000 0000000000000000
[ 1.309347] 8060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.310092] 8080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.310837] 80a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.311581] 80c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.312326] 80e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.313071] 8100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.313814] 8120: 0000000000000000 0000000000000000
[ 1.314281] [<ffffff8008081fb4>] el1_irq+0xb4/0x128
[ 1.314750] [<ffffff8008084944>] arch_cpu_idle+0x84/0x160
[ 1.315269] [<ffffff80080daa50>] default_idle_call+0x20/0x28
[ 1.315810] [<ffffff80080dac84>] cpu_startup_entry+0x22c/0x380
[ 1.316368] [<ffffff800808dec8>] secondary_start_kernel+0x188/0x194
[ 1.316965] [<0000000000282978>] 0x282978
[ 1.317349] CPU3: stopping
[ 1.317615] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.4.30 #1
[ 1.318292] Hardware name: rockchip,rk3399-excavator-edp (DT)
[ 1.318837] Call trace:
[ 1.319078] [<ffffff80080884c4>] dump_backtrace+0x0/0x1c8
[ 1.319595] [<ffffff80080886a0>] show_stack+0x14/0x1c
[ 1.320078] [<ffffff8008362ae4>] dump_stack+0x8c/0xac
[ 1.320562] [<ffffff800808e334>] handle_IPI+0x140/0x284
[ 1.321062] [<ffffff8008080e80>] gic_handle_irq+0x10c/0x150
[ 1.321592] Exception stack(0xffffffc0f7f3d000 to 0xffffffc0f7f3d130)
[ 1.322208] d000: ffffffc0e91c7e20 0000008000000000 ffffffc0e91c7f50 ffffff8008084944
[ 1.322953] d020: 0000000060000045 0000000000000000 ffffffc0f7f39060 0000000000000000
[ 1.323698] d040: ffffffc0e91c7f50 ffffffc0e91c7e20 0000000000000000 0000000000000000
[ 1.324443] d060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.325188] d080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.325933] d0a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.326678] d0c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.327423] d0e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.328168] d100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.328910] d120: 0000000000000000 0000000000000000
[ 1.329376] [<ffffff8008081fb4>] el1_irq+0xb4/0x128
[ 1.329844] [<ffffff8008084944>] arch_cpu_idle+0x84/0x160
[ 1.330362] [<ffffff80080daa50>] default_idle_call+0x20/0x28
[ 1.330904] [<ffffff80080dac84>] cpu_startup_entry+0x22c/0x380
[ 1.331461] [<ffffff800808dec8>] secondary_start_kernel+0x188/0x194
[ 1.332057] [<0000000000282978>] 0x282978
[ 1.332441] CPU1: stopping
[ 1.332706] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G D 4.4.30 #1
[ 1.333383] Hardware name: rockchip,rk3399-excavator-edp (DT)
[ 1.333928] Call trace:
[ 1.334169] [<ffffff80080884c4>] dump_backtrace+0x0/0x1c8
[ 1.334687] [<ffffff80080886a0>] show_stack+0x14/0x1c
[ 1.335170] [<ffffff8008362ae4>] dump_stack+0x8c/0xac
[ 1.335653] [<ffffff800808e334>] handle_IPI+0x140/0x284
[ 1.336152] [<ffffff8008080e80>] gic_handle_irq+0x10c/0x150
[ 1.336683] Exception stack(0xffffffc0f7f13000 to 0xffffffc0f7f13130)
[ 1.337298] 3000: ffffffc0e91bbe20 0000008000000000 ffffffc0e91bbf50 ffffff8008084944
[ 1.338043] 3020: 0000000060000045 0000000000000000 ffffffc0f7f0f060 0000000000000000
[ 1.338789] 3040: ffffffc0e91bbf50 ffffffc0e91bbe20 0000000000000000 0000000000000000
[ 1.339533] 3060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.340278] 3080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.341023] 30a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.341768] 30c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.342512] 30e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.343257] 3100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.344000] 3120: 0000000000000000 0000000000000000
[ 1.344467] [<ffffff8008081fb4>] el1_irq+0xb4/0x128
[ 1.344934] [<ffffff8008084944>] arch_cpu_idle+0x84/0x160
[ 1.345452] [<ffffff80080daa50>] default_idle_call+0x20/0x28
[ 1.345994] [<ffffff80080dac84>] cpu_startup_entry+0x22c/0x380
[ 1.346551] [<ffffff800808dec8>] secondary_start_kernel+0x188/0x194
[ 1.347147] [<0000000000282978>] 0x282978
[ 1.347531] CPU5: stopping
[ 1.347806] CPU: 5 PID: 0 Comm: swapper/5 Tainted: G D 4.4.30 #1
[ 1.348498] Hardware name: rockchip,rk3399-excavator-edp (DT)
[ 1.349056] Call trace:
[ 1.349310] [<ffffff80080884c4>] dump_backtrace+0x0/0x1c8
[ 1.349837] [<ffffff80080886a0>] show_stack+0x14/0x1c
[ 1.350331] [<ffffff8008362ae4>] dump_stack+0x8c/0xac
[ 1.350824] [<ffffff800808e334>] handle_IPI+0x140/0x284
[ 1.351333] [<ffffff8008080e80>] gic_handle_irq+0x10c/0x150
[ 1.351875] Exception stack(0xffffffc0f7f67000 to 0xffffffc0f7f67130)
[ 1.352502] 7000: ffffffc0e91cfe20 0000008000000000 ffffffc0e91cff50 ffffff8008084944
[ 1.353262] 7020: 0000000060000045 0000000000000000 ffffffc0f7f63060 0000000000000000
[ 1.354022] 7040: ffffffc0e91cff50 ffffffc0e91cfe20 0000000000000000 0000000000000000
[ 1.354781] 7060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.355539] 7080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.356298] 70a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.357057] 70c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.357816] 70e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.358576] 7100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.359333] 7120: 0000000000000000 0000000000000000
[ 1.359808] [<ffffff8008081fb4>] el1_irq+0xb4/0x128
[ 1.360285] [<ffffff8008084944>] arch_cpu_idle+0x84/0x160
[ 1.360813] [<ffffff80080daa50>] default_idle_call+0x20/0x28
[ 1.361365] [<ffffff80080dac84>] cpu_startup_entry+0x22c/0x380
[ 1.361933] [<ffffff800808dec8>] secondary_start_kernel+0x188/0x194
[ 1.362541] [<0000000000282978>] 0x282978
[ 1.362935] CRU:
[ 1.363128] 00000000: 00000044 00001201 80000000 00000108 00000007 00007f00 00000000 00000000
[ 1.363945] 00000020: 00000044 00001201 80000000 00000108 00000007 00007f00 00000000 00000000
[ 1.364763] 00000040: 00000037 00001201 8000031f 00000108 00000007 00007f00 00000000 00000000
[ 1.365580] 00000060: 00000190 00001206 80000000 00000108 00000007 00007f00 00000000 00000000
[ 1.366397] 00000080: 00000063 00001401 80000000 00000108 00000007 00007f00 00000000 00000000
[ 1.367214] 000000a0: 000001f4 00001206 80000000 00000108 00000007 00007f00 00000000 00000000
[ 1.368031] 000000c0: 00000063 00001102 80000000 00000008 00000007 00007f00 00000000 00000000
[ 1.368848] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.369665] 00000100: 00000300 00000505 00000140 00006404 00000043 00008341 00000320 00000101
[ 1.370483] 00000120: 00000101 00004141 00000101 00000101 00004101 00008323 00003183 00000500
[ 1.371299] 00000140: 0000013d 00000300 00004a87 00000103 00009303 00008307 00001007 00001007
[ 1.372115] 00000160: 00008107 00000107 00003107 000002dc 00000300 00000300 00000300 00000000
[ 1.372932] 00000180: 00006300 00000200 00000200 00000200 00000200 00000200 00003f3f 00000041
[ 1.373749] 000001a0: 00000000 00000000 00000101 00000421 00000700 000002dc 00000004 00000141
[ 1.374566] 000001c0: 00000141 00000103 00000003 00000005 00000005 00000101 00000101 00008181
[ 1.375382] 000001e0: 0000033f 00000005 00000f1f 00000f0f 00000f0f 00000f0f 00000f0f 00000f0f
[ 1.376199] 00000200: 000000c5 000000c5 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.377016] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.377832] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.378649] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.379466] 00000280: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60
[ 1.380283] 000002a0: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 00000000 00000000 00000000 00000000
[ 1.381100] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.381916] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.382733] 00000300: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.383549] 00000320: 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.384366] 00000340: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.385182] 00000360: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.385999] 00000380: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.386815] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.387632] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.388448] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.389265] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.390082] 00000420: 000000bc 00007070 00000000 00000014 00000000 00000000 00000000 00000000
[ 1.390898] 00000440: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.391715] 00000460: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.392531] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.393347] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.394164] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.394980] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.395797] 00000500: 00000000 00000000 00640064 00000000 00000003 00000003 00000000 00000000
[ 1.396614] 00000520: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.397430] 00000540: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.398247] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.399060] 00000580: 00000004 00000000 00000004 00000000 00000004
[ 1.399646] PMU CRU:
[ 1.399866] 00000000: 000000a9 00001203 80000000 00000108 00000007 00007f00 00000000 00000000
[ 1.400684] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.401503] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.402321] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.403140] 00000080: 0000070d 00001986 00000d0d 0000000d 000002dc 00000200 0bb8ea60 0bb8ea60
[ 1.403958] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.404776] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.405594] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.406412] 00000100: 00000000 00000000 00000000 00000000 00000024 00000000 00000000 00000000
[ 1.407226] 00000120: 00000000 00000180 00000000 00000000 00000000
[ 1.407814] Rebooting in 5 seconds..
是否解决,我也碰到相同的问题。初步怀疑是电源问题…
系统崩了,关注第290行。。。。
我也遇到同样问题,是不是能解决
