rk3288 为什么没有设置自动调整背光的地方
true
<integer-array name="config_autoBrightnessLevels">
<item>10</item>
<item>85</item>
<item>145</item>
<item>320</item>
<item>640</item>
<item>1280</item>
<item>2600</item>
<item>10240</item>
</integer-array>
<!-- Array of output values for LCD backlight corresponding to the LUX values
in the config_autoBrightnessLevels array. This array should have size one greater
than the size of the config_autoBrightnessLevels array.
The brightness values must be between 0 and 255 and be non-decreasing.
This must be overridden in platform specific overlays -->
<integer-array name="config_autoBrightnessLcdBacklightValues">
<item>10</item>
<item>45</item>
<item>80</item>
<item>105</item>
<item>150</item>
<item>185</item>
<item>220</item>
<item>255</item>
</integer-array>
这是哪个文件
