RK3288芯片资料整理
rk3288-chapter-12-generic-interrupt-controller(gic).pdf (245 KB)
rk3288-chapter-31-image-signal-processing-(isp).pdf (590 KB)
rk3288-chapter-16-i2s-pcm-controller-(8-channel).pdf (611 KB)
rk3288-chapter-17-spdif-transmitter.pdf (491 KB)
rk3288-chapter-53-universal-asynchronous-receiver-transmitter-(uart).pdf (864 KB)
rk3288-chapter-26-hevc.pdf (116 KB)
rk3288-chapter-25-video-encoder-decoder-unit-(vcodec).pdf (878 KB)
rk3288-chapter-29-image-enhancement-processor-(iep).pdf (783 KB)
rk3288-chapter-07-general-register-files-(grf).pdf (1.88 MB)
rk3288-chapter-04-power-management-unit-(pmu).pdf (1 MB)
rk3288-chapter-03-clock-reset-unit-(cru).pdf (1.77 MB)
rk3288-chapter-02-system-overview.pdf (467 KB)
rk3288-chapter-01-introduction.pdf (486 KB)
rk3288-chapter-10-dma-controller-for-bus-system-(dmac-bus).pdf (670 KB)
rk3288-chapter-27-visual-output-processor-(vop).pdf (2.3 MB)
rk3288-chapter-28-rga2.pdf (957 KB)
rk3288-chapter-52-i2c-interface.pdf (592 KB)
rk3288-chapter-32-hdmi-tx.pdf (600 KB)
rk3288-chapter-37-mipi-controller.pdf (1.27 MB)
rk3288-chapter-36-mipi-csi-2-host-controller.pdf (684 KB)
rk3288-chapter-35-mipi-csi-phy.pdf (906 KB)
rk3288-chapter-34-edp-tx-controller.pdf (477 KB)
rk3288-chapter-33-lvds.pdf (723 KB)
rk3288-chapter-49-general-purpose-input-output-ports-(gpio).pdf (368 KB)
rk3288-chapter-47-timer.pdf (344 KB)
rk3288-chapter-51-pulse-width-modulation-(pwm).pdf (584 KB)
rk3288-chapter-41-gmac-ethernet-interface.pdf (1.52 MB)
rk3288-chapter-45-sar-adc.pdf (346 KB)
rk3288-chapter-42-serial-peripheral-interface-(spi).pdf (516 KB)
rk3288-chapter-46-temperature-sensor-adc(ts-adc).pdf (634 KB)
rk3288-chapter-50-watchdog.pdf (413 KB)
不错,顶给有需要的朋友
期待所有模块的资料!!!
买了firefly3288,急需timer和PWM的资料,谢谢楼主
timer和PWM的资料已添加
gpu的也该给吧!gpu的驱动迟迟不出,open库也没法用,感觉自己手上的gpu是块费gg:lol,楼主给点建议,小白我怎么把gpu用起来,跑跑代码?
版主,可否发下MIPI ,RGB,LVDS接口的资料啊,刚买了一块板,想在上面高度双lcd显示,,MIPI +RGB
GPU的可以看看这个帖子:http://community.arm.com/message/24367#24367
参考mcgeagh 2015-1-28 下午1:54 (回复 aamr)最后回复的帖子。
ARM有计划在接下来支持Firefly Mail驱动> We plan to release binary userspace drivers for the Firefly board within the next month for both fbdev and X11.
这种芯片资料一般去哪下载呀
谢谢头版主支持,还有lcdc的资料可否发一下? 这部分应该是lcdc到各个接口(mipi,lvds等)切换及连接的相关寄存器。再次感谢!
楼主,有没有HDMI部分的???目前不支持420啊!!!
HDMI文档已经上传到附件
wico 发表于 2015-2-12 10:48
HDMI文档已经上传到附件
谢谢版主!
非常好用
tjCFeng 发表于 2015-3-4 16:40
版主有IOMUX的部分吗?开发驱动时功能复用是不是需要设置这个?
IOMUX驱动中已经包含了
一级棒的资源,慢慢消化@!~
快点升级就可以下载了 急需啊..
版主, Parallel RGB LCD Interface 的TRM 章节能帮忙共享一下吗?
楼主有audio codec和i2s相关的资料么?
参考 rk3288-chapter-16-i2s-pcm-controller-(8-channel).pdf
