这是我的“CameraSource.cpp”源代码,大家看我该改哪里?另外,我的摄像头帧率是30。
#include <inttypes.h>
//#define LOG_NDEBUG 0
#define LOG_TAG “CameraSource”
#include <utils/Log.h>
#include <OMX_Component.h>
#include <binder/IPCThreadState.h>
#include <media/stagefright/foundation/ADebug.h>
#include <media/stagefright/CameraSource.h>
#include <media/stagefright/MediaDefs.h>
#include <media/stagefright/MediaErrors.h>
#include <media/stagefright/MetaData.h>
#include <camera/Camera.h>
#include <camera/CameraParameters.h>
#include <gui/Surface.h>
#include <utils/String8.h>
#include <cutils/properties.h>
#if LOG_NDEBUG
#define UNUSED_UNLESS_VERBOSE(x) (void)(x)
#else
#endif
namespace android {
static const int64_t CAMERA_SOURCE_TIMEOUT_NS = 3000000000LL;
struct CameraSourceListener : public CameraListener {
CameraSourceListener(const sp &source);
virtual void notify(int32_t msgType, int32_t ext1, int32_t ext2);
virtual void postData(int32_t msgType, const sp<IMemory> &dataPtr,
camera_frame_metadata_t *metadata);
virtual void postDataTimestamp(
nsecs_t timestamp, int32_t msgType, const sp<IMemory>& dataPtr);
protected:
virtual ~CameraSourceListener();
private:
wp mSource;
CameraSourceListener(const CameraSourceListener &);
CameraSourceListener &operator=(const CameraSourceListener &);
CameraSourceListener::CameraSourceListener(const sp &source)
: mSource(source) {
CameraSourceListener::~CameraSourceListener() {
void CameraSourceListener::notify(int32_t msgType, int32_t ext1, int32_t ext2) {
UNUSED_UNLESS_VERBOSE(msgType);
UNUSED_UNLESS_VERBOSE(ext1);
UNUSED_UNLESS_VERBOSE(ext2);
ALOGV(“notify(%d, %d, %d)”, msgType, ext1, ext2);
void CameraSourceListener::postData(int32_t msgType, const sp &dataPtr,
camera_frame_metadata_t * /* metadata */) {
ALOGV(“postData(%d, ptr:%p, size:%zu)”,
msgType, dataPtr->pointer(), dataPtr->size());
sp<CameraSource> source = mSource.promote();
if (source.get() != NULL) {
source->dataCallback(msgType, dataPtr);
void CameraSourceListener::postDataTimestamp(
nsecs_t timestamp, int32_t msgType, const sp& dataPtr) {
source->dataCallbackTimestamp(timestamp/1000, msgType, dataPtr);
static int32_t getColorFormat(const char* colorFormat) {
if (!strcmp(colorFormat, CameraParameters::PIXEL_FORMAT_YUV420P)) {
return OMX_COLOR_FormatYUV420Planar;
if (!strcmp(colorFormat, CameraParameters::PIXEL_FORMAT_YUV422SP)) {
return OMX_COLOR_FormatYUV422SemiPlanar;
if (!strcmp(colorFormat, CameraParameters::PIXEL_FORMAT_YUV420SP)) {
return OMX_COLOR_FormatYUV420SemiPlanar;
if (!strcmp(colorFormat, CameraParameters::PIXEL_FORMAT_YUV422I)) {
return OMX_COLOR_FormatYCbYCr;
if (!strcmp(colorFormat, CameraParameters::PIXEL_FORMAT_RGB565)) {
return OMX_COLOR_Format16bitRGB565;
if (!strcmp(colorFormat, "OMX_TI_COLOR_FormatYUV420PackedSemiPlanar")) {
return OMX_TI_COLOR_FormatYUV420PackedSemiPlanar;
if (!strcmp(colorFormat, CameraParameters::PIXEL_FORMAT_ANDROID_OPAQUE)) {
return OMX_COLOR_FormatAndroidOpaque;
ALOGE("Uknown color format (%s), please add it to "
"CameraSource::getColorFormat", colorFormat);
CHECK(!"Unknown color format");
return -1;
CameraSource *CameraSource::Create(const String16 &clientName) {
Size size;
size.width = -1;
size.height = -1;
sp<ICamera> camera;
return new CameraSource(camera, NULL, 0, clientName, -1,
size, -1, NULL, false);
// static
CameraSource *CameraSource::CreateFromCamera(
const sp& camera,
const sp& proxy,
int32_t cameraId,
const String16& clientName,
uid_t clientUid,
Size videoSize,
int32_t frameRate,
const sp& surface,
bool storeMetaDataInVideoBuffers) {
CameraSource *source = new CameraSource(camera, proxy, cameraId,
clientName, clientUid, videoSize, frameRate, surface,
storeMetaDataInVideoBuffers);
return source;
CameraSource::CameraSource(
const sp& camera,
const sp& proxy,
int32_t cameraId,
uid_t clientUid,
Size videoSize,
int32_t frameRate,
const sp& surface,
: mCameraFlags(0),
mNumInputBuffers(0),
mVideoFrameRate(-1),
mCamera(0),
mSurface(surface),
mNumFramesReceived(0),
mLastFrameTimestampUs(0),
mStarted(false),
mNumFramesEncoded(0),
mTimeBetweenFrameCaptureUs(0),
mFirstFrameTimeUs(0),
mNumFramesDropped(0),
mNumGlitches(0),
mGlitchDurationThresholdUs(200000),
mCollectStats(false) {
mVideoSize.width = -1;
mVideoSize.height = -1;
mInitCheck = init(camera, proxy, cameraId,
if (mInitCheck != OK) releaseCamera();
status_t CameraSource::initCheck() const {
return mInitCheck;
status_t CameraSource::isCameraAvailable(
const sp& camera, const sp& proxy,
int32_t cameraId, const String16& clientName, uid_t clientUid) {
if (camera == 0) {
mCamera = Camera::connect(cameraId, clientName, clientUid);
if (mCamera == 0) return -EBUSY;
mCameraFlags &= ~FLAGS_HOT_CAMERA;
} else {
// We get the proxy from Camera, not ICamera. We need to get the proxy
// to the remote Camera owned by the application. Here mCamera is a
// local Camera object created by us. We cannot use the proxy from
// mCamera here.
mCamera = Camera::create(camera);
mCameraRecordingProxy = proxy;
mCameraFlags |= FLAGS_HOT_CAMERA;
mDeathNotifier = new DeathNotifier();
// isBinderAlive needs linkToDeath to work.
mCameraRecordingProxy->asBinder()->linkToDeath(mDeathNotifier);
mCamera->lock();
return OK;
Check to see whether the requested video width and height is one
of the supported sizes.
@param width the video frame width in pixels
@param height the video frame height in pixels
@param suppportedSizes the vector of sizes that we check against
@return true if the dimension (width and height) is supported.
static bool isVideoSizeSupported(
int32_t width, int32_t height,
const Vector& supportedSizes) {
ALOGV(“isVideoSizeSupported”);
for (size_t i = 0; i < supportedSizes.size(); ++i) {
if (width == supportedSizes[i].width &&
height == supportedSizes[i].height) {
return true;
return false;
- If the preview and video output is separate, we only set the
- the video size, and applications should set the preview size
- to some proper value, and the recording framework will not
- change the preview size; otherwise, if the video and preview
- output is the same, we need to set the preview to be the same
- as the requested video size.
static void getSupportedVideoSizes(
const CameraParameters& params,
bool *isSetVideoSizeSupported,
Vector& sizes) {
*isSetVideoSizeSupported = true;
params.getSupportedVideoSizes(sizes);
if (sizes.size() == 0) {
ALOGD("Camera does not support setVideoSize()");
params.getSupportedPreviewSizes(sizes);
*isSetVideoSizeSupported = false;
- Check whether the camera has the supported color format
- @param params CameraParameters to retrieve the information
- @return OK if no error.
status_t CameraSource::isCameraColorFormatSupported(
const CameraParameters& params) {
mColorFormat = getColorFormat(params.get(
CameraParameters::KEY_VIDEO_FRAME_FORMAT));
if (mColorFormat == -1) {
return BAD_VALUE;
return OK;
Configure the camera to use the requested video size
(width and height) and/or frame rate. If both width and
height are -1, configuration on the video size is skipped.
if frameRate is -1, configuration on the frame rate
is skipped. Skipping the configuration allows one to
use the current camera setting without the need to
actually know the specific values (see Create() method).
@param params the CameraParameters to be configured
@param width the target video frame width in pixels
@param height the target video frame height in pixels
@param frameRate the target frame rate in frames per second.
status_t CameraSource::configureCamera(
CameraParameters params,
int32_t frameRate) {
ALOGV(“configureCamera”);
Vector sizes;
bool isSetVideoSizeSupportedByCamera = true;
getSupportedVideoSizes(*params, &isSetVideoSizeSupportedByCamera, sizes);
bool isCameraParamChanged = false;
if (width != -1 && height != -1) {
if (!isVideoSizeSupported(width, height, sizes)) {
ALOGE(“Video dimension (%dx%d) is unsupported”, width, height);
return BAD_VALUE;
if (isSetVideoSizeSupportedByCamera) {
params->setVideoSize(width, height);
} else {
params->setPreviewSize(width, height);
isCameraParamChanged = true;
} else if ((width == -1 && height != -1) ||
(width != -1 && height == -1)) {
// If one and only one of the width and height is -1
// we reject such a request.
ALOGE(“Requested video size (%dx%d) is not supported”, width, height);
return BAD_VALUE;
} else { // width == -1 && height == -1
// Do not configure the camera.
// Use the current width and height value setting from the camera.
if (frameRate != -1) {
CHECK(frameRate > 0 && frameRate <= 120);
const char* supportedFrameRates =
params->get(CameraParameters::KEY_SUPPORTED_PREVIEW_FRAME_RATES);
CHECK(supportedFrameRates != NULL);
ALOGV(“Supported frame rates: %s”, supportedFrameRates);
char buf[4];
snprintf(buf, 4, “%d”, frameRate);
if (strstr(supportedFrameRates, buf) == NULL) {
ALOGE(“Requested frame rate (%d) is not supported: %s”,
frameRate, supportedFrameRates);
return BAD_VALUE;
// The frame rate is supported, set the camera to the requested value.
params->setPreviewFrameRate(frameRate);
} else { // frameRate == -1
// Use the current frame rate value setting from the camera
if (isCameraParamChanged) {
// Either frame rate or frame size needs to be changed.
String8 s = params->flatten();
if (OK != mCamera->setParameters(s)) {
ALOGE(“Could not change settings.”
" Someone else is using camera %p?", mCamera.get());
return -EBUSY;
return OK;
Check whether the requested video frame size
has been successfully configured or not. If both width and height
are -1, check on the current width and height value setting
is performed.
@param the target video frame width in pixels to check against
@param the target video frame height in pixels to check against
status_t CameraSource::checkVideoSize(
int32_t width, int32_t height) {
ALOGV(“checkVideoSize”);
// The actual video size is the same as the preview size
// if the camera hal does not support separate video and
// preview output. In this case, we retrieve the video
// size from preview.
int32_t frameWidthActual = -1;
int32_t frameHeightActual = -1;
Vector sizes;
// video size is the same as preview size
params.getPreviewSize(&frameWidthActual, &frameHeightActual);
} else {
// video size may not be the same as preview
params.getVideoSize(&frameWidthActual, &frameHeightActual);
if (frameWidthActual < 0 || frameHeightActual < 0) {
ALOGE(“Failed to retrieve video frame size (%dx%d)”,
frameWidthActual, frameHeightActual);
return UNKNOWN_ERROR;
// Check the actual video frame size against the target/requested
// video frame size.
if (frameWidthActual != width || frameHeightActual != height) {
ALOGE("Failed to set video frame size to %dx%d. "
"The actual video size is %dx%d ", width, height,
// Good now.
mVideoSize.width = frameWidthActual;
mVideoSize.height = frameHeightActual;
return OK;
Check the requested frame rate has been successfully configured or not.
If the target frameRate is -1, check on the current frame rate value
setting is performed.
@param the target video frame rate to check against
status_t CameraSource::checkFrameRate(
ALOGV(“checkFrameRate”);
int32_t frameRateActual = params.getPreviewFrameRate();
if (frameRateActual < 0) {
ALOGE(“Failed to retrieve preview frame rate (%d)”, frameRateActual);
// Check the actual video frame rate against the target/requested
// video frame rate.
if (frameRate != -1 && (frameRateActual - frameRate) != 0) {
ALOGE("Failed to set preview frame rate to %d fps. The actual "
“frame rate is %d”, frameRate, frameRateActual);
// Good now.
mVideoFrameRate = frameRateActual;
return OK;
Initialize the CameraSource to so that it becomes
ready for providing the video input streams as requested.
@param camera the camera object used for the video source
@param cameraId if camera == 0, use camera with this id
as the video source
@param videoSize the target video frame size. If both
width and height in videoSize is -1, use the current
width and heigth settings by the camera
if it is -1, use the current camera frame rate setting.
@param storeMetaDataInVideoBuffers request to store meta
data or real YUV data in video buffers. Request to
store meta data in video buffers may not be honored
if the source does not support this feature.
status_t CameraSource::init(
const sp& camera,
const sp& proxy,
int32_t cameraId,
uid_t clientUid,
Size videoSize,
int32_t frameRate,
ALOGV(“init”);
status_t err = OK;
int64_t token = IPCThreadState::self()->clearCallingIdentity();
err = initWithCameraAccess(camera, proxy, cameraId, clientName, clientUid,
IPCThreadState::self()->restoreCallingIdentity(token);
return err;
status_t CameraSource::initWithCameraAccess(
const sp& camera,
const sp& proxy,
int32_t cameraId,
uid_t clientUid,
Size videoSize,
int32_t frameRate,
ALOGV(“initWithCameraAccess”);
status_t err = OK;
if ((err = isCameraAvailable(camera, proxy, cameraId,
clientName, clientUid)) != OK) {
ALOGE("Camera connection could not be established.");
return err;
CameraParameters params(mCamera->getParameters());
if ((err = isCameraColorFormatSupported(params)) != OK) {
return err;
// Set the camera to use the requested video frame size
// and/or frame rate.
if ((err = configureCamera(¶ms,
videoSize.width, videoSize.height,
frameRate))) {
return err;
// Check on video frame size and frame rate.
CameraParameters newCameraParams(mCamera->getParameters());
if ((err = checkVideoSize(newCameraParams,
videoSize.width, videoSize.height)) != OK) {
return err;
if ((err = checkFrameRate(newCameraParams, frameRate)) != OK) {
return err;
// Set the preview display. Skip this if mSurface is null because
// applications may already set a surface to the camera.
if (mSurface != NULL) {
// This CHECK is good, since we just passed the lock/unlock
// check earlier by calling mCamera->setParameters().
CHECK_EQ((status_t)OK, mCamera->setPreviewTarget(mSurface));
// By default, do not store metadata in video buffers
mIsMetaDataStoredInVideoBuffers = false;
mCamera->storeMetaDataInBuffers(false);
if (storeMetaDataInVideoBuffers) {
if (OK == mCamera->storeMetaDataInBuffers(true)) {
mIsMetaDataStoredInVideoBuffers = true;
int64_t glitchDurationUs = (1000000LL / mVideoFrameRate);
if (glitchDurationUs > mGlitchDurationThresholdUs) {
mGlitchDurationThresholdUs = glitchDurationUs;
// XXX: query camera for the stride and slice height
// when the capability becomes available.
mMeta = new MetaData;
mMeta->setCString(kKeyMIMEType, MEDIA_MIMETYPE_VIDEO_RAW);
mMeta->setInt32(kKeyColorFormat, mColorFormat);
mMeta->setInt32(kKeyWidth, mVideoSize.width);
mMeta->setInt32(kKeyHeight, mVideoSize.height);
mMeta->setInt32(kKeyStride, mVideoSize.width);
mMeta->setInt32(kKeySliceHeight, mVideoSize.height);
mMeta->setInt32(kKeyFrameRate, mVideoFrameRate);
return OK;
CameraSource::~CameraSource() {
if (mStarted) {
reset();
} else if (mInitCheck == OK) {
// Camera is initialized but because start() is never called,
// the lock on Camera is never released(). This makes sure
// Camera’s lock is released in this case.
releaseCamera();
status_t CameraSource::startCameraRecording() {
ALOGV(“startCameraRecording”);
// Reset the identity to the current thread because media server owns the
// camera and recording is started by the applications. The applications
// will connect to the camera in ICameraRecordingProxy::startRecording.
status_t err;
if (mNumInputBuffers > 0) {
err = mCamera->sendCommand(
CAMERA_CMD_SET_VIDEO_BUFFER_COUNT, mNumInputBuffers, 0);
// This could happen for CameraHAL1 clients; thus the failure is
// not a fatal error
if (err != OK) {
ALOGW("Failed to set video buffer count to %d due to %d",
mNumInputBuffers, err);
err = OK;
if (mCameraFlags & FLAGS_HOT_CAMERA) {
mCamera->unlock();
mCamera.clear();
if ((err = mCameraRecordingProxy->startRecording(
new ProxyListener(this))) != OK) {
ALOGE("Failed to start recording, received error: %s (%d)",
strerror(-err), err);
} else {
mCamera->setListener(new CameraSourceListener(this));
mCamera->startRecording();
if (!mCamera->recordingEnabled()) {
err = -EINVAL;
ALOGE("Failed to start recording");
return err;
status_t CameraSource::start(MetaData *meta) {
ALOGV(“start”);
CHECK(!mStarted);
if (mInitCheck != OK) {
ALOGE(“CameraSource is not initialized yet”);
return mInitCheck;
char value[PROPERTY_VALUE_MAX];
if (property_get("media.stagefright.record-stats", value, NULL)
&& (!strcmp(value, "1") || !strcasecmp(value, "true"))) {
mCollectStats = true;
mStartTimeUs = 0;
mNumInputBuffers = 0;
if (meta) {
int64_t startTimeUs;
if (meta->findInt64(kKeyTime, &startTimeUs)) {
mStartTimeUs = startTimeUs;
int32_t nBuffers;
if (meta->findInt32(kKeyNumBuffers, &nBuffers)) {
CHECK_GT(nBuffers, 0);
mNumInputBuffers = nBuffers;
status_t err;
if ((err = startCameraRecording()) == OK) {
mStarted = true;
return err;
void CameraSource::stopCameraRecording() {
ALOGV(“stopCameraRecording”);
mCameraRecordingProxy->stopRecording();
} else {
mCamera->setListener(NULL);
mCamera->stopRecording();
void CameraSource::releaseCamera() {
ALOGV(“releaseCamera”);
sp camera;
bool coldCamera = false;
Mutex::Autolock autoLock(mLock);
// get a local ref and clear ref to mCamera now
camera = mCamera;
mCamera.clear();
coldCamera = (mCameraFlags & FLAGS_HOT_CAMERA) == 0;
if (camera != 0) {
if (coldCamera) {
ALOGV("Camera was cold when we started, stopping preview");
camera->stopPreview();
camera->disconnect();
camera->unlock();
if (mCameraRecordingProxy != 0) {
mCameraRecordingProxy->asBinder()->unlinkToDeath(mDeathNotifier);
mCameraRecordingProxy.clear();
mCameraFlags = 0;
status_t CameraSource::reset() {
ALOGD(“reset: E”);
mStarted = false;
mFrameAvailableCondition.signal();
int64_t token;
bool isTokenValid = false;
if (mCamera != 0) {
isTokenValid = true;
releaseQueuedFrames();
while (!mFramesBeingEncoded.empty()) {
if (NO_ERROR !=
mFrameCompleteCondition.waitRelative(mLock,
mTimeBetweenFrameCaptureUs * 1000LL + CAMERA_SOURCE_TIMEOUT_NS)) {
ALOGW("Timed out waiting for outstanding frames being encoded: %zu",
mFramesBeingEncoded.size());
stopCameraRecording();
if (isTokenValid) {
if (mCollectStats) {
ALOGI("Frames received/encoded/dropped: %d/%d/%d in %" PRId64 " us",
mNumFramesReceived, mNumFramesEncoded, mNumFramesDropped,
mLastFrameTimestampUs - mFirstFrameTimeUs);
if (mNumGlitches > 0) {
ALOGW("%d long delays between neighboring video frames", mNumGlitches);
CHECK_EQ(mNumFramesReceived, mNumFramesEncoded + mNumFramesDropped);
releaseCamera();
ALOGD("reset: X");
return OK;
void CameraSource::releaseRecordingFrame(const sp& frame) {
ALOGV(“releaseRecordingFrame”);
if (mCameraRecordingProxy != NULL) {
mCameraRecordingProxy->releaseRecordingFrame(frame);
} else if (mCamera != NULL) {
mCamera->releaseRecordingFrame(frame);
void CameraSource::releaseQueuedFrames() {
List<sp >::iterator it;
while (!mFramesReceived.empty()) {
it = mFramesReceived.begin();
releaseRecordingFrame(*it);
mFramesReceived.erase(it);
++mNumFramesDropped;
sp CameraSource::getFormat() {
return mMeta;
void CameraSource::releaseOneRecordingFrame(const sp& frame) {
void CameraSource::signalBufferReturned(MediaBuffer *buffer) {
ALOGV(“signalBufferReturned: %p”, buffer->data());
for (List<sp >::iterator it = mFramesBeingEncoded.begin();
it != mFramesBeingEncoded.end(); ++it) {
if ((*it)->pointer() == buffer->data()) {
releaseOneRecordingFrame((*it));
mFramesBeingEncoded.erase(it);
++mNumFramesEncoded;
buffer->setObserver(0);
buffer->release();
mFrameCompleteCondition.signal();
return;
CHECK(!“signalBufferReturned: bogus buffer”);
status_t CameraSource::read(
MediaBuffer **buffer, const ReadOptions *options) {
ALOGV(“read”);
*buffer = NULL;
int64_t seekTimeUs;
ReadOptions::SeekMode mode;
if (options && options->getSeekTo(&seekTimeUs, &mode)) {
return ERROR_UNSUPPORTED;
sp<IMemory> frame;
int64_t frameTime;
while (mStarted && mFramesReceived.empty()) {
if (NO_ERROR !=
mFrameAvailableCondition.waitRelative(mLock,
if (mCameraRecordingProxy != 0 &&
!mCameraRecordingProxy->asBinder()->isBinderAlive()) {
ALOGW("camera recording proxy is gone");
return ERROR_END_OF_STREAM;
ALOGW("Timed out waiting for incoming camera video frames: %" PRId64 " us",
mLastFrameTimestampUs);
if (!mStarted) {
return OK;
frame = *mFramesReceived.begin();
mFramesReceived.erase(mFramesReceived.begin());
frameTime = *mFrameTimes.begin();
mFrameTimes.erase(mFrameTimes.begin());
uint32_t FramePhyaddress = *((int*)frame->pointer());
mFramesBeingEncoded.push_back(frame);
*buffer = new MediaBuffer(frame->pointer(), frame->size());
(*buffer)->setObserver(this);
(*buffer)->add_ref();
(*buffer)->meta_data()->setInt32(kKeyBusAdds, FramePhyaddress);
(*buffer)->meta_data()->setInt64(kKeyTime, frameTime);
return OK;
void CameraSource::dataCallbackTimestamp(int64_t timestampUs,
int32_t msgType, const sp &data) {
ALOGV(“dataCallbackTimestamp: timestamp %” PRId64 " us", timestampUs);
if (!mStarted || (mNumFramesReceived == 0 && timestampUs < mStartTimeUs)) {
ALOGV(“Drop frame at %” PRId64 “/%” PRId64 " us", timestampUs, mStartTimeUs);
releaseOneRecordingFrame(data);
return;
if (mNumFramesReceived > 0) {
CHECK(timestampUs > mLastFrameTimestampUs);
if (timestampUs - mLastFrameTimestampUs > mGlitchDurationThresholdUs) {
++mNumGlitches;
// May need to skip frame or modify timestamp. Currently implemented
// by the subclass CameraSourceTimeLapse.
if (skipCurrentFrame(timestampUs)) {
return;
mLastFrameTimestampUs = timestampUs;
if (mNumFramesReceived == 0) {
mFirstFrameTimeUs = timestampUs;
// Initial delay
if (mStartTimeUs > 0) {
if (timestampUs < mStartTimeUs) {
// Frame was captured before recording was started
// Drop it without updating the statistical data.
return;
mStartTimeUs = timestampUs - mStartTimeUs;
++mNumFramesReceived;
CHECK(data != NULL && data->size() > 0);
mFramesReceived.push_back(data);
int64_t timeUs = mStartTimeUs + (timestampUs - mFirstFrameTimeUs);
mFrameTimes.push_back(timeUs);
ALOGV("initial delay: %" PRId64 ", current time stamp: %" PRId64,
mStartTimeUs, timeUs);
bool CameraSource::isMetaDataStoredInVideoBuffers() const {
ALOGV(“isMetaDataStoredInVideoBuffers”);
return mIsMetaDataStoredInVideoBuffers;
CameraSource::ProxyListener::ProxyListener(const sp& source) {
mSource = source;
void CameraSource::ProxyListener::dataCallbackTimestamp(
mSource->dataCallbackTimestamp(timestamp / 1000, msgType, dataPtr);
void CameraSource::DeathNotifier::binderDied(const wp& who) {
ALOGI(“Camera recording proxy died”);
} // namespace android
