3288-reload ubuntu14.04 编译内核启动错误
使用官方的Ubuntu14.04固件,然后按照wiki步骤编译内核并打包成boot.img烧入启动信息如下:
DDR Version 1.00 20160530
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (Oct 13 2016 - 10:04:48)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from boot image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2016-10-13#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
Secure Boot state: 0
kernel @ 0x02000000 (0x0069cc80)
ramdisk @ 0x05bf0000 (0x00275e30)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561b5c2 … OK
[ 0.000000] Linux version 3.10.0 (impact@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #3 SMP PREEMPT Mon Feb 27 19:16:05 PST 2017
[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[ 0.000000] cma: CMA: reserved 16 MiB at 7f000000
[ 0.000000] ion_reserve: cma reserved base 7f000000 size 16777216
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f08000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
[ 0.000000] Kernel command line: vmalloc=496M console=tty0 console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00008000@0x00002000(resource),0x00008000@0x0000A000(boot),0x00002000@0x00012000(misc),0x0001a000@0x00014000(backup),-@0x0002e000(linuxroot) storagemedia=emmc loader.timestamp=2016-10-13_10:04:48
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 2025304k/2025304k available, 71848k reserved, 1556480K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0b9cba8 (11859 kB)
[ 0.000000] .init : 0xc0b9d000 - 0xc0bf6440 ( 358 kB)
[ 0.000000] .data : 0xc0bf8000 - 0xc0d8d240 (1621 kB)
[ 0.000000] .bss : 0xc0d8d240 - 0xc0eaf2bc (1161 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rkclk_init_clks: cnt_rate = 28
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:13
[ 0.000000] target-temp:95
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:11
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty0] enabled
[ 0.499820] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.499851] pid_max: default: 32768 minimum: 301
[ 0.499972] Security Framework initialized
[ 0.499995] SELinux: Initializing.
[ 0.500074] Mount-cache hash table entries: 512
[ 0.500717] Initializing cgroup subsys debug
[ 0.500742] Initializing cgroup subsys memory
[ 0.500776] Initializing cgroup subsys freezer
[ 0.500812] CPU: Testing write buffer coherency: ok
[ 0.501143] /cpus/cpu@0 missing clock-frequency property
[ 0.501168] /cpus/cpu@1 missing clock-frequency property
[ 0.501186] /cpus/cpu@2 missing clock-frequency property
[ 0.501203] /cpus/cpu@3 missing clock-frequency property
[ 0.501266] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.501327] Setting up static identity map for 0xc085b690 - 0xc085b6e8
[ 0.503715] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x1678 (version 3.1)
[ 0.577297] CPU1: Booted secondary processor
[ 0.577332] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.596973] CPU2: Booted secondary processor
[ 0.596998] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.616686] CPU3: Booted secondary processor
[ 0.616709] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.616811] Brought up 4 CPUs
[ 0.616895] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.616913] CPU: All CPU(s) started in SVC mode.
[ 0.617647] devtmpfs: initialized
[ 0.622060] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.623174] pinctrl core: initialized pinctrl subsystem
[ 0.623430] regulator-dummy: no parameters
[ 0.636800] NET: Registered protocol family 16
[ 0.638652] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.639114] ion_snapshot: 0x1ea98000 map to 0xe0907000 and copy to 0xc0e8a5cc (version 0.1)
[ 0.639367] Registered FIQ tty driver
[ 0.639760] fiq-debugger is disabled in device tree
[ 0.640478] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.640512] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.640543] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.640571] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.640671] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.640752] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.640830] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.640908] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.640984] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.641062] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.641139] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.641216] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.641307] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.641390] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.641413] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.641434] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.641455] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.642070] rockchip_interrupts_register:bank_num=7
[ 0.643992] of_get_gpio_init_config:gpio[0] = 233, value = 0
[ 0.644024] of_get_gpio_init_config:gpio[1] = 136, value = 0
[ 0.644084] rockchip_pinctrl_probe:init ok
[ 0.650491] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.650592] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.650618] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.650795] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.650879] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.650907] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.651082] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.651166] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.651192] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.651370] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.651457] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.651485] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.651674] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.651755] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.651781] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.651953] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.652042] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.652068] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.652242] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.652324] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.652351] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.654041] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.654069] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.654645] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.654680] DDR DEBUG: version 1.00 20150126
[ 0.654715] DDR DEBUG: Channel a:
[ 0.654731] DDR DEBUG: DDR3 Device
[ 0.654750] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.654771] DDR DEBUG: Channel b:
[ 0.654784] DDR DEBUG: DDR3 Device
[ 0.654801] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.654823] DDR DEBUG: addr=0xd97000
[ 0.654839] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.654855] DDR DEBUG: socAddr[0]=0xd97000, socAddr[1]=0xd97100
[ 0.654873] DDR DEBUG: chAddr[0]=0xd97000, chAddr[1]=0xd97000
[ 0.654892] DDR DEBUG: dtar[0]=0x701b2000, dtar[1]=0x701b2000
[ 0.654953] DDR DEBUG: init success!!! freq=200MHz
[ 0.654969] DDR DEBUG: Channel a:
[ 0.654988] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.655014] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.655041] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.655068] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.655093] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.655112] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.655128] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.655143] DDR DEBUG: Channel b:
[ 0.655161] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.655187] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.655213] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.655238] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.655263] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.655281] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.655297] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.680129] bio: create slab at 0
[ 0.680660] Rockchip hdmi driver version 2.0
[ 0.680660] .
[ 0.681789] SCSI subsystem initialized
[ 0.681957] usbcore: registered new interface driver usbfs
[ 0.682012] usbcore: registered new interface driver hub
[ 0.682106] usbcore: registered new device driver usb
[ 0.684686] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.685343] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.685801] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.686064] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.686514] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.686636] media: Linux media interface: v0.10
[ 0.686683] Linux video capture interface: v2.00
[ 0.686747] pps_core: LinuxPPS API ver. 1 registered
[ 0.686765] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.686798] PTP clock support registered
[ 0.686861] i2c-core: driver [bq24296] using legacy suspend method
[ 0.686879] i2c-core: driver [bq24296] using legacy resume method
[ 0.687548] ion_drm_heap_create: 0@0
[ 0.687704] Rockchip ion module is successfully loaded (v1.1)
[ 0.687876] Advanced Linux Sound Architecture Driver Initialized.
[ 0.688301] Bluetooth: Core ver 2.16
[ 0.688348] NET: Registered protocol family 31
[ 0.688366] Bluetooth: HCI device and connection manager initialized
[ 0.688390] Bluetooth: HCI socket layer initialized
[ 0.688411] Bluetooth: L2CAP socket layer initialized
[ 0.688444] Bluetooth: SCO socket layer initialized
[ 0.688682] cfg80211: Calling CRDA to update world regulatory domain
[ 0.689397] act8846_i2c_probe,line=898
[ 0.690411] act8846_parse_dt,line=746
[ 0.690883] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.690912] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.690936] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.690959] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.693046] act_dcdc1: 1200 mV
[ 0.696031] vccio: 3300 mV
[ 0.697904] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 0.700870] act_dcdc4: 2000 mV
[ 0.702125] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.704435] act_ldo2: 1050 mV
[ 0.706819] act_ldo3: 2800 mV
[ 0.709132] act_ldo4: 3300 mV
[ 0.711439] act_ldo5: 3300 mV
[ 0.713785] act_ldo6: 1100 mV
[ 0.716098] vcc_18: 1800 mV
[ 0.718407] act_ldo8: 1850 mV
[ 0.723153] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 0.727862] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 0.728607] rk808_i2c_probe,line=1355
[ 0.729944] The device is not rk808 -11
[ 0.730033] rk808: probe of 0-001b failed with error -11
[ 0.730113] i2c-core: driver [rk818] using legacy suspend method
[ 0.730132] i2c-core: driver [rk818] using legacy resume method
[ 0.731913] Switching to clocksource arch_sys_counter
[ 0.755650] rga: Module initialized.
[ 0.756393] rga2 ff920000.rga: rga ion client create success!
[ 0.756569] rga: Driver loaded succesfully
[ 0.756770] fb disp policy is box
[ 0.756821] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.756842] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.757179] rk-screen rk_screen.8: rockchip screen probe success
[ 0.757428] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.757776] rk32-edp ff970000.edp: screen is not edp!
[ 0.757806] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.758281] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 0.758506] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.758832] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.759010] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.759183] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.760388] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 0.760426] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.783831] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 0.790936] alloc_buffer:ion_phy_addr=0x10000000
[ 0.803561] fb0:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.803598] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eab0000
[ 0.803630] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 0.803854] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 0.803876] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 0.804156] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.804506] graphics fb5: rockchip framebuffer registerd:fb5
[ 0.804689] graphics fb6: rockchip framebuffer registerd:fb6
[ 0.804867] graphics fb7: rockchip framebuffer registerd:fb7
[ 0.805679] rk3288-lcdc lcdc1: lcdc1: dclk:148500000>>fps:60
[ 0.805705] rk3288-lcdc lcdc1: wakeup from standby!
[ 0.809439] fb4:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.809464] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
[ 0.810334] rockchip_set_mux:warning ignore bank num 15
[ 0.810481] rockchip_set_mux:warning ignore bank num 15
[ 0.810604] rockchip_set_mux:warning ignore bank num 15
[ 0.810769] rockchip_set_mux:warning ignore bank num 15
[ 0.810901] rockchip_set_mux:warning ignore bank num 15
[ 0.811028] rockchip_set_mux:warning ignore bank num 15
[ 0.811611] rockchip_set_mux:warning ignore bank num 15
[ 0.811781] rockchip_set_mux:warning ignore bank num 15
[ 0.812331] rockchip_set_mux:warning ignore bank num 15
[ 0.812484] rockchip_set_mux:warning ignore bank num 15
[ 0.813027] rockchip_set_mux:warning ignore bank num 15
[ 0.813180] rockchip_set_mux:warning ignore bank num 15
[ 0.813724] rockchip_set_mux:warning ignore bank num 15
[ 0.813887] rockchip_set_mux:warning ignore bank num 15_hdmiin_probe OK!
[ 0.965366] NET: Registered protocol family 2
[ 0.966061] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.966151] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.966234] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.966303] TCP: reno registered
[ 0.966325] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.966357] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.966552] NET: Registered protocol family 1
[ 0.967204] Unpacking initramfs…
[ 1.109157] Freeing initrd memory: 2516K (c5bf0000 - c5e65000)
[ 1.109994] hw perfevents: Loading, please wait…
Begin: Loading essential drivers … FAenabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 1.110562] vcodec_service: probe device ff9a0000.vpu_service
[ 1.110770] vcodec_service: No reset resource define
[ 1.110945] vcodec_service: ff9a0000.vpu_service: power on
[ 1.111041] vcodec_service: probe device ff9a0000.vpu_service
[ 1.111066] vcodec_service: checking hw id 4831
[ 1.112120] vcodec_service: ff9a0000.vpu_service: power off…
[ 1.112176] vcodec_service: done
[ 1.112197] vcodec_service: init success
[ 1.112274] vcodec_service: probe device ff9c0000.hevc_service
[ 1.112622] vcodec_service: ff9c0000.hevc_service: power on
[ 1.112695] vcodec_service: probe device ff9c0000.hevc_service
[ 1.112719] vcodec_service: checking hw id 6867
[ 1.113294] vcodec_service: ff9c0000.hevc_service: power off…
[ 1.113345] vcodec_service: done
[ 1.113363] vcodec_service: init success
[ 1.113507] rknandbase v1.0 2014-03-31
[ 1.113655] rknand: probe of ff400000.nandc failed with error -1
[ 1.113771] rknand_driver:ret = 0
[ 1.114867] audit: initializing netlink socket (disabled)
[ 1.114943] type=2000 audit(0.610:1): initialized
[ 1.115810] bounce pool size: 64 pages
[ 1.120417] fuse init (API version 7.22)
[ 1.120799] msgmni has been set to 952
[ 1.122603] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.122636] io scheduler noop registered
[ 1.122652] io scheduler deadline registered
[ 1.122752] io scheduler cfq registered (default)
[ 1.123920] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 1.124619] IEP Power ON
[ 1.124667] iep ion client create success!
[ 1.125111] rk_iommu ff900800.iep_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaaa000
[ 1.125140] IEP Power OFF
[ 1.125162] IEP Driver loaded succesfully
[ 1.125263] Module initialized.
[ 1.126137] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.126168] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.127556] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.127586] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.127887] pwm-voltage-regulator pwm_regulator.22: unable to request PWM, trying legacy API
[ 1.127915] pwm-voltage-regulator pwm_regulator.22: unable to request legacy PWM
[ 1.127937] pwm_regulator_probe:error
[ 1.127962] platform pwm_regulator.22: Driver pwm-voltage-regulator requests probe deferral
[ 1.128184] rk_serial.c v1.8 2014-03-04
[ 1.128432] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 1.128636] serial ff180000.serial: membase e097e000
[ 1.128799] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 1.130445] console [ttyS2] enabled
[ 1.130638] serial ff690000.serial: membase fed60000
[ 1.133443] loop: module loaded
[ 1.133826] zram: Created 1 device(s) …
[ 1.133918] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 1.133940] i2c-core: driver [mpu6050B1] using legacy resume method
[ 1.133967] mpu_init: Probe name mpu6050B1
[ 1.134130] ak8963_mod_init: Probe name ak8963_mod
[ 1.134820] SCSI Media Changer driver v0.25
[ 1.135137] tun: Universal TUN/TAP device driver, 1.6
[ 1.135159] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.135791] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 1.135821] stmmac_probe_config_dt: clock input/output? (input).
[ 1.135843] stmmac_probe_config_dt: TX delay(0x30).
[ 1.135863] stmmac_probe_config_dt: RX delay(0x20).
[ 1.135921] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 1.135939] stmmc_pltfr_init:
[ 1.135954] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 1.135985] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 1.136006] stmmc_pltfr_init: init for RGMII
[ 1.136023] tx delay=0x30
[ 1.136023] rx delay=0x20
[ 1.136049] tx delay=0x30
[ 1.136049] rx delay=0x20
[ 1.136530] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.136551] Normal descriptors
[ 1.136566] Ring mode enabled
[ 1.136582] DMA HW capability register supported
[ 1.136600] RX Checksum Offload Engine supported (type 2)
[ 1.136621] TX Checksum insertion supported
[ 1.136637] Wake-Up On Lan supported
[ 1.136680] Enable RX Mitigation via HW Watchdog Timer
[ 1.137139] PPP generic driver version 2.4.2
[ 1.137304] PPP BSD Compression module registered
[ 1.137326] PPP Deflate Compression module registered
[ 1.137356] PPP MPPE Compression module registered
[ 1.137377] NET: Registered protocol family 24
[ 1.137421] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.137449] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.137475] Rockchip WiFi SYS interface (V1.00) …
[ 1.137519] esp_mem_init enter date Feb 27 2017 18:29:55
[ 1.137539] esp_mem_init VERSION [V2.5]
[ 1.137585] esp_mem_init complete
[ 1.137684] usbcore: registered new interface driver catc
[ 1.137737] usbcore: registered new interface driver kaweth
[ 1.137759] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.137813] usbcore: registered new interface driver pegasus
[ 1.137865] usbcore: registered new interface driver rtl8150
[ 1.137915] usbcore: registered new interface driver r8152
[ 1.137936] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.138011] usbcore: registered new interface driver hso
[ 1.138073] usbcore: registered new interface driver asix
[ 1.138126] usbcore: registered new interface driver ax88179_178a
[ 1.138176] usbcore: registered new interface driver cdc_ether
[ 1.138227] usbcore: registered new interface driver cdc_eem
[ 1.138275] usbcore: registered new interface driver dm9601
[ 1.138323] usbcore: registered new interface driver dm9620
[ 1.138386] usbcore: registered new interface driver smsc75xx
[ 1.138451] usbcore: registered new interface driver smsc95xx
[ 1.138503] usbcore: regisTAL: Could not load /lib/modules/3.10.0/modules.dep: No such filtered new interface driver gl620a
[ 1.138553] usbcore: registered new interface driver net1080
[ 1.138602] usbcore: registered new interface driver plusb
[ e or directory
FATAL: Could not load /lib/modules/3.10.0/module 1.138654] usbcore: registered new interface driver rndis_host
[ 1.138704] usbcore: registered new interface driver cdc_subset
[ 1.138754] usbcore: registered new interface driver zaurus
[ 1.138812] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.138893] usbcore: registered new interface driver int51x1
[ 1.138945] usbcore: registered new interface driver kalmia
[ 1.138995] usbcore: registered new interface driver ipheth
[ 1.139048] usbcore: registered new interface driver sierra_net
[ 1.139100] usbcore: registered new interface driver cx82310_eth
[ 1.139166] usbcore: registered new interface driver cdc_ncm
[ 1.139219] usbcore: registered new interface driver qmi_wwan
[ 1.139272] usbcore: registered new interface driver cdc_mbim
[ 1.139294] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.141745] EHCI: ehci_rk_probe e2240000 e2240010
[ 1.141771] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 1.141813] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 1.142176] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 1.155125] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 1.155229] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.155258] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.155285] usb usb1: Product: EHCI Host Controller
[ 1.155305] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 1.155326] usb usb1: SerialNumber: ff500000.usb
[ 1.155793] hub 1-0:1.0: USB hub found
[ 1.155827] hub 1-0:1.0: 1 port detected
[ 1.156030] EHCI: ehci_rk_probe ok
[ 1.156148] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.156371] usbcore: registered new interface driver cdc_acm
[ 1.156393] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.156459] usbcore: registered new interface driver usblp
[ 1.156511] usbcore: registered new interface driver cdc_wdm
[ 1.156589] usbcore: registered new interface driver usb-storage
[ 1.156641] usbcore: registered new interface driver ums-alauda
[ 1.156689] usbcore: registered new interface driver ums-cypress
[ 1.156738] usbcore: registered new interface driver ums-datafab
[ 1.156786] usbcore: registered new interface driver ums_eneub6250
[ 1.156835] usbcore: registered new interface driver ums-freecom
[ 1.156884] usbcore: registered new interface driver ums-isd200
[ 1.156932] usbcore: registered new interface driver ums-jumpshot
[ 1.156980] usbcore: registered new interface driver ums-karma
[ 1.157028] usbcore: registered new interface driver ums-onetouch
[ 1.157084] usbcore: registered new interface driver ums-sddr09
[ 1.157134] usbcore: registered new interface driver ums-sddr55
[ 1.157183] usbcore: registered new interface driver ums-usbat
[ 1.157282] usbcore: registered new interface driver usbserial
[ 1.157334] usbcore: registered new interface driver usbserial_generic
[ 1.157376] usbserial: USB Serial support registered for generic
[ 1.157432] usbcore: registered new interface driver option
[ 1.157473] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.157565] usbcore: registered new interface driver trancevibrator
[ 1.157589] usb20_otg: version 3.10a 21-DEC-2012
[ 1.158022] e2280040
[ 1.158046] Core Release: 3.10a
[ 1.158064] Setting default values for core params
[ 1.158198] Using Buffer DMA mode
[ 1.158218] Periodic Transfer Interrupt Enhancement - disabled
[ 1.158237] Multiprocessor Interrupt Enhancement - disabled
[ 1.158257] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.158274] ^^^^^^^^^^^^^^^^^Device Mode
[ 1.158296] Dedicated Tx FIFOs mode
[ 1.158322] pcd_init otg_dev = deb773c0
[ 1.173810] rockchip-hdmiv2 ff980000.hdmi: warning: no CEA video mode parsed from EDID !!!
[ 1.173864] hdmi output corlor mode is 1
[ 1.173888] hdmi connect to lcdc1
[ 1.173906] switch:en=1,lcdc_id=1,screen type=6,cur type=1
[ 1.256901] Using Buffer DMA mode
[ 1.256923] Periodic Transfer Interrupt Enhancement - disabled
[ 1.256943] Multiprocessor Interrupt Enhancement - disabled
[ 1.256963] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.256979] ^^^^^^^^^^^^^^^^^Device Mode
[ 1.257016] usb20_otg ff580000.usb: DWC OTG Controller
[ 1.257053] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 1.257100] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 1.257173] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.257200] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.257227] usb usb2: Product: DWC OTG Controller
[ 1.257247] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.257268] usb usb2: SerialNumber: ff580000.usb
[ 1.257708] hub 2-0:1.0: USB hub found
[ 1.257739] hub 2-0:1.0: 1 port detected
[ 1.258044] usb20_host: version 3.10a 21-DEC-2012
[ 1.260578] e2300040
[ 1.260597] Core Release: 3.10a
[ 1.260614] Setting default values for core params
[ 1.260735] Using Buffer DMA mode
[ 1.260753] Periodic Transfer Interrupt Enhancement - disabled
[ 1.260772] Multiprocessor Interrupt Enhancement - disabled
[ 1.260792] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.260809] ^^^^^^^^^^^^^^^^^^Host Mode
[ 1.260842] usb20_host ff540000.usb: DWC OTG Controller
[ 1.260876] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 1.260917] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 1.261020] Init: Power Port (0)
[ 1.261088] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.261114] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.261140] usb usb3: Product: DWC OTG Controller
[ 1.261160] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.261182] usb usb3: SerialNumber: ff540000.usb
[ 1.261566] hub 3-0:1.0: USB hub found
[ 1.261596] hub 3-0:1.0: 1 port detected
[ 1.262292] usbcore: registered new interface driver xpad
[ 1.262391] usbcore: registered new interface driver usb_acecad
[ 1.262454] usbcore: registered new interface driver aiptek
[ 1.262511] usbcore: registered new interface driver gtco
[ 1.262568] usbcore: registered new interface driver hanwang
[ 1.262628] usbcore: registered new interface driver kbtab
[ 1.262692] usbcore: registered new interface driver wacom
[ 1.262962] sensor_register_slave:mma8452,id=17
[ 1.262986] sensor_register_slave:gs_mc3230,id=23
[ 1.263004] gsensor_init
[ 1.263020] sensor_register_slave:mpu6880_acc,id=24
[ 1.263038] sensor_register_slave:mpu6500_acc,id=25
[ 1.263057] sensor_register_slave:cm3217,id=48
[ 1.263074] sensor_register_slave:cm3218,id=49
[ 1.263299] .. rk pwm remotectl v1.1 init
[ 1.263574] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 1.268616] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 1.268685] i2c /dev entries driver
[ 1.269387] IR NEC protocol handler initialized
[ 1.269409] IR RC5(x) protocol handler initialized
[ 1.269427] IR RC6 protocol handler initialized
[ 1.269444] IR JVC protocol handler initialized
[ 1.269461] IR Sony protocol handler initialized
[ 1.269478] IR RC5 (streamzap) protocol handler initialized
[ 1.269497] IR SANYO protocol handler initialized
[ 1.269514] IR MCE Keyboard/mouse protocol handler initialized
[ 1.269686] usbcore: registered new interface driver uvcvideo
[ 1.269709] USB Video Class driver (1.1.1)
[ 1.269730] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[ 1.271207] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[ 1.271243] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[ 1.271274] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
[ 1.271304] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
[ 1.271352] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 1.271352]
[ 1.271441] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.271607] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe21f8000 size: 0x4000)
[ 1.272262] D1:camsys_platform_probe(1447): ff910000.isp memory:
[ 1.272291] D1:camsys_platform_probe(1457): Register memory (phy: 0xff910000 vir: 0xe2220000 size: 0x10000)
[ 1.272323] D1:camsys_platform_probe(1452): I2c memory (phy: 0x1dfde000 vir: 0xddfde000 size: 0x1000)
[ 1.272353] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.272374] D1:camsys_platform_probe(1472): Probe ff910000.isp device success
[ 1.273542] i2c-core: driver [bq27320] using legacy suspend method
[ 1.273569] i2c-core: driver [bq27320] using legacy resume method
[ 1.273919] rockchip_temp_probe,line=362
[ 1.332230] tsadc ff280000.tsadc: initialized
[ 1.332644] device-mapper: uevent: version 1.0.3
[ 1.332898] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.333204] Bluetooth: HCI UART driver ver 2.2
[ 1.333228] Bluetooth: HCI H4 protocol initialized
[ 1.333247] Bluetooth: HCILL protocol initialized
[ 1.333266] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 1.333288] rtk_btusb: Register usb char device interface for BT driver
[ 1.333473] usbcore: registered new interface driver rtk_btusb
[ 1.338203] cpufreq version 1.0, suspend freq 1200 MHz
[ 1.338418] cpuidle: using governor ladder
[ 1.338439] cpuidle: using governor menu
[ 1.338481] Synopsys Designware Multimedia Card Interface Driver
[ 1.338502] MHSC version = Ver 2.00 2015-06-10
[ 1.338793] dw cru_regsbase addr 0x1d8.
[ 1.338814] dw cru_reset_offset val 3.
[ 1.338836] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 1.338887] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[ 1.339192] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 1.339371] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 1.339526] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.351935] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.351996] dwc_otg_hcd_suspend, usb device mode
[ 1.371681] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 1.371717] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 1.371746] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.372030] dw cru_regsbase addr 0x1d8.
[ 1.372053] dw cru_reset_offset val 0.
[ 1.372074] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 1.372122] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[ 1.372908] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 1.373070] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 1.373575] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 1.373660] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.391280] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.403744] mmc0: unrecognised EXT_CSD revision 8
[ 1.403764] mmc0: error -22 whilst initialising MMC card
[ 1.410964] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.410980] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 1.410987] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 1.411252] dw cru_regsbase addr 0x1d8.
[ 1.411267] dw cru_reset_offset val 1.
[ 1.411281] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.411313] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 1.411486] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 1.411627] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 1.411874] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.420786] rk_fb_switch_screen: wait update_regs_wait timeout
[ 1.420840] rk3288-lcdc lcdc1: lcdc1: dclk:74250000>>fps:60
[ 1.420882] pixel clk is 74250000 tmds clk is 74250000
[ 1.420915] rockchip-hdmiv2 ff980000.hdmi: [hdmi_dev_config_video] sucess output DVI.
[ 1.430627] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.450325] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.450339] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.450346] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.450589] leds-gpio leds.27: pins are not configured from the driver
[ 1.450868] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.452325] usbcore: registered new interface driver usbhid
[ 1.452344] usbhid: USB HID core driver
[ 1.452466] ashmem: initialized
[ 1.452596] logger: created 256K log ‘log_main’
[ 1.452695] logger: created 256K log ‘log_events’
[ 1.452809] logger: created 256K log ‘log_radio’
[ 1.452909] logger: created 256K log ‘log_system’
[ 1.454038] input: rk29-keypad as /devices/ff100000.adc/key.30/input/input1
[ 1.454888] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 1.454918] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 1.454937] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 1.454957] ES8323 2-0010: Error applying setting, reverse things back
[ 1.455254] es8323 probe i2c recv ok
[ 1.456170] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 1.456725] es8323_probe
[ 1.456827] es8323_probe:register ISR (irq=194)
[ 1.745503] vbus detect**
[ 2.090268] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 2.090285] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 2.090301] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 2.090314] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 2.090328] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 2.090342] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 2.090356] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 2.090369] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 2.090383] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 2.090396] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 2.090410] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 2.090423] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 2.090437] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 2.090449] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 2.090462] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 2.090475] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 2.090489] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 2.090503] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 2.090517] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 2.090530] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 2.090543] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 2.090556] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 2.090569] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 2.090582] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 2.090596] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 2.090609] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 2.090624] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 2.090637] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 2.090651] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 2.090664] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 2.090678] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 2.090691] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 2.090715] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 2.090727] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 2.090741] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 2.090754] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 2.090768] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 2.090781] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 2.090796] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 2.090808] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 2.090822] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 2.090835] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 2.090849] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 2.090862] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 2.091003] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 2.091019] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 2.091034] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 2.091047] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 2.091069] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 2.097154] rockchip-es8323 rockchip-es8323.26: ES8323 HiFi ↔ ff890000.rockchip-i2s mapping ok
[ 2.097784] u32 classifier
[ 2.097795] Actions configured
[ 2.097807] Netfilter messages via NETLINK v0.30.
[ 2.097859] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.098113] ctnetlink v0.93: registering with nfnetlink.
[ 2.098177] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 2.098188] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 2.098401] xt_time: kernel timezone is -0000
[ 2.098560] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.098672] arp_tables: (C) 2002 David S. Miller
[ 2.098708] TCP: cubic registered
[ 2.098717] Initializing XFRM netlink socket
[ 2.098876] NET: Registered protocol family 10
[ 2.099302] mip6: Mobile IPv6
[ 2.099328] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.099428] sit: IPv6 over IPv4 tunneling driver
[ 2.099693] NET: Registered protocol family 17
[ 2.099717] NET: Registered protocol family 15
[ 2.099812] Bridge firewalling registered
[ 2.099827] Ebtables v2.0 registered
[ 2.099978] Bluetooth: RFCOMM TTY layer initialized
[ 2.100006] Bluetooth: RFCOMM socket layer initialized
[ 2.100016] Bluetooth: RFCOMM ver 1.11
[ 2.100024] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.100033] Bluetooth: BNEP filters: protocol multicast
[ 2.100045] Bluetooth: BNEP socket layer initialized
[ 2.100054] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.100067] Bluetooth: HIDP socket layer initialized
[ 2.100094] l2tp_core: L2TP core driver, V2.0
[ 2.100110] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 2.100120] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.100314] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.100326] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 2.100337] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 2.100348] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.100360] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 2.100373] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.100396] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 2.100419] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 2.100432] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.100459] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 2.100472] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.100511] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.100635] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 2.100657] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 270.
[ 2.100674] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 2.100691] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 2.100708] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 2.100753] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.100842] [BT_RFKILL]: ** disable irq
[ 2.100912] [BT_RFKILL]: ap6335 device registered.
[ 2.101521] rk3288_init_suspend
[ 2.101537] rk3288_suspend_init enter
[ 2.101733] rk3288_suspend_init: pm_ctrbits =200007
[ 2.101764] gpio_get_dts_info suspend:4
[ 2.101773] gpio_get_dts_info resume:4
[ 2.101780] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 2.101813] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 2.101938] clks_gating_suspend_init:clkgt info ok
[ 2.102017] Registering SWP/SWPB emulation handler
[ 2.102317] ddrfreq: verion 1.2 20140526
[ 2.102334] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 492MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
[ 2.102348] ddrfreq: auto-freq=0
[ 2.102356] ddrfreq: auto-freq-table[0] 240MHz
[ 2.102364] ddrfreq: auto-freq-table[1] 324MHz
[ 2.102371] ddrfreq: auto-freq-table[2] 456MHz
[ 2.102379] ddrfreq: auto-freq-table[3] 528MHz
[ 2.119281] act_ldo3: operation not allowed
[ 2.119293] rgb2hdmi_probe: turn on ldo3 done.
[ 2.119553] act_ldo4: operation not allowed
[ 2.119562] rgb2hdmi_probe: turn on ldo done.
[ 2.119829] act_ldo2: operation not allowed
[ 2.119838] rgb2hdmi_probe: turn on ldo2 done.
[ 2.120083] act_ldo8: operation not allowed
[ 2.120092] rgb2hdmi_probe: turn on ldo done.
[ 2.120137] rgb2hdmi_probe: success. 10
[ 2.120190] firefly_rgb2hdmi_get_enable 184, 0
[ 2.120199] firefly_rgb2hdmi_get_status 190
[ 2.120207] firefly_rgb2hdmi_set_enable 166 enable:1
[ 2.120215] firefly_rgb2hdmi_enable 133 start
[ 2.120223] firefly_switch_to_rgb 58
[ 2.120232] switch:en=1,lcdc_id=0,screen type=1,cur type=1
[ 2.375263] rk_fb_switch_screen: wait update_regs_wait timeout
[ 2.375287] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 2.375319] HDMI ENABLE
[ 2.375329] HDMI Devie connected 10
[ 2.375336] firefly_rgb2hdmi_set_mode 209
[ 2.375344] firefly_rgb2hdmi_set_mode 225 1920 1080 60 148500000
[ 2.375353] firefly_rgb2hdmi_enable 133 start
[ 2.375360] firefly_switch_to_rgb 58
[ 2.375369] switch:en=1,lcdc_id=0,screen type=1,cur type=1
[ 2.631102] rk_fb_switch_screen: wait update_regs_wait timeout
[ 2.631120] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 2.631164] regulator-dummy: disabling
[ 2.631367] =======================================================
[ 2.631382] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.631391] =======================================================
[ 2.631401] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 2.631451] dhd_module_init: in
[ 2.631461] ======== bcm_wlan_set_plat_data ========
[ 2.631470] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.631491] host_oob_irq: 196
[ 2.631498] host_oob_irq_flags=4
[ 2.631503] pcd_pullup, is_on 0
[ 2.631510] dhd_wifi_platform_load: Enter
[ 2.631526] Power-up adapter ‘DHD generic adapter’
[ 2.631532] file system registered
[ 2.631553] wifi_platform_set_power = 1
[ 2.631561] ======== PULL WL_REG_ON HIGH! ========
[ 2.631569] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.631578] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 2.631586] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 2.632017] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 2.632030] android_usb gadget: Number of LUNs=2
[ 2.632040] lun0: LUN: removable file: (no medium)
[ 2.632048] lun1: LUN: removable file: (no medium)
[ 2.632174] android_usb gadget: android_usb ready
[ 2.632245] sensor_init: Probe name sensors
[ 2.632263] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 2.632794] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:17:41 UTC (1293884261)
[ 2.638449] rockchip-spdif-card rockchip-spdif-card.25: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
[ 2.639094] usbcore: registered new interface driver snd-usb-audio
[ 2.639106] ALSA device list:
[ 2.639113] #0: RK_ES8323
[ 2.639120] #1: RK-SPDIF-CARD
[ 2.639481] Freeing unused kernel memory: 356K (c0b9d000 - c0bf6000)
[ 2.658503] udevd[146]: starting version 175
[ 2.739355] [WLAN_RFKILL]: wifi turn on power. 156
[ 2.945986] wifi_platform_bus_enumerate device present 1
[ 2.946006] ======== Card detection to detect SDIO card! ========
[ 2.946016] mmc2:mmc host rescan start!
[ 3.132944] EHCI: rk_ehci_hcd_enable, disable host controller
[ 3.162469] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[ 3.197080] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.198584] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.200087] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.202781] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.231340] dwc_otg_hcd_enable, enable host controller
[ 3.255127] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 3.255153] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[ 3.255201] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
[ 3.257136] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.257160] mmc2: new high speed SDIO card at address 0001
[ 3.273244] bcmsdh_register: register client driver
[ 3.273350] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.273413] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.273424] bus num (host idx)=2, slot num (rca)=1
[ 3.273432] found adapter info ‘DHD generic adapter’
[ 3.273701] F1 signature read @0x18000000=0x16224335
[ 3.275455] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
[ 3.275710] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 3.275754] wifi_platform_get_mac_addr
[ 3.275763] ======== bcm_wlan_get_mac_address ========
[ 3.275772] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 3.275783] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 3.275792] [WLAN_RFKILL]: This mac address is not valid, ignored…
[ 3.275804] dhd_conf_set_chiprev: chip=0x4339, chiprev=1
[ 3.275841] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[ 3.276074] wl_create_event_handler(): thread:wl_event_handler:102 started
[ 3.276150] tsk Enter, tsk = 0xdd94149c
[ 3.276340] dhd_attach(): thread:dhd_watchdog_thread:103 started
[ 3.276376] dhd_attach(): thread:dhd_dpc:104 started
[ 3.276397] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 3.276416] dhd_attach(): thread:dhd_rxf:105 started
[ 3.276428] dhd_deferred_work_init: work queue initialized
[ 3.276532] dhdsdio_probe_init: set use_rxchain 1 from config.txt
[ 3.282096] Dongle Host Driver, version 1.201.59.5 (r506368)
[ 3.282096] Compiled in drivers/net/wireless/bcmdhd on Feb 27 2017 at 18:30:04
[ 3.282388] Register interface [wlan0] MAC: e0:76:d0:d0:87:f7
[ 3.282388]
[ 3.282405] dhd_prot_ioctl : bus is down. we have nothing to do
[ 3.282440] bcmsdh_oob_intr_unregister: Enter
[ 3.282449] bcmsdh_oob_intr_unregister: irq is not registered
[ 3.282461] dhd_txglom_enable: enable 0
[ 3.282469] dhd_bus_devreset: WLAN OFF DONE
[ 3.282499] wifi_platform_set_power = 0
[ 3.282508] ======== PULL WL_REG_ON LOW! ========
[ 3.282516] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 3.344512] Using Buffer DMA mode
[ 3.344524] Periodic Transfer Interrupt Enhancement - disabled
[ 3.344533] Multiprocessor Interrupt Enhancement - disabled
[ 3.344542] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.344550] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.388799] [WLAN_RFKILL]: wifi shut off power.
[ 3.388811] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 3.388823] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 3.388867] dhd_module_init: Exit err=0
[ 3.388872] Init: Power Port (0)
[ 3.388896] ff540000.usb resume, HPRT0:0x21401
[ 3.526591] Indeed it is in host mode hprt0 = 00021501
[ 3.703668] usb 3-1: new high-speed USB device number 2 using usb20_host
[ 3.703735] Indeed it is in host mode hprt0 = 00001101
[ 3.900666] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 3.900685] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.900696] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 3.901009] hub 3-1:1.0: USB hub found
[ 3.901072] hub 3-1:1.0: 4 ports detected
[ 4.018551] ff540000.usb suspend, HPRT0:0x1485
s.dep: No such file or directory
FATAL: Could not load /lib/modules/3.10.0/modules.dep: No such file or directory
done.
Begin: Running /scripts/init-premount … Waiting for eMMC storage…
Timeout!
done.
[ 9.047021] [otg id chg] last id -1 current id 1
[ 9.342335] es8323_create file error
Gave up waiting for root device. Common problems:
  • Boot args (cat /proc/cmdline)
    • Check rootdelay= (did the system wait long enough?)
    • Check root= (did the system wait for the right device?)
  • Missing modules (cat /proc/modules; ls /dev)
    ALERT! /dev/block/mtd/by-name/linuxroot does not exist. Dropping to a shell!
    /bin/sh: can’t access tty; job control turned off
    (initramfs)
parameter文件如下:
FIRMWARE_VER:5.0.0
MACHINE_MODEL:rk3288
MACHINE_ID:007
MANUFACTURER:RK3288
MAGIC: 0x5041524B
ATAG: 0x60000800
MACHINE: 3288
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
CMDLINE:vmalloc=496M console=tty0 console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00008000@0x00002000(resource),0x00008000@0x0000A000(boot),0x00002000@0x00012000(misc),0x0001a000@0x00014000(backup),-@0x0002e000(linuxroot) storagemedia=emmc loader.timestamp=2016-10-13_10:04:48 androidboot.mode=emmc
使用分解的官方Ubuntu14.04固件的boot.img可以正常启动,自己编译的出现以上错误。
请高人指点迷津。
对比正常开机的打印信息,Running /scripts/init-premount这里开始出现不一致。
正常:Begin: Running /scripts/init-premount … done.
自己内核异常情况:Begin: Running /scripts/init-premount … Waiting for eMMC storage…
Timeout!
done.
修改kernel/drivers/mmc/core/mmc.c
card->ext_csd.rev = ext_csd[EXT_CSD_REV];
  • if (card->ext_csd.rev > 7) {
  •   pr_err("%s: unrecognised EXT_CSD revision %d\n",
  •   	mmc_hostname(card->host), card->ext_csd.rev);
  •   err = -EINVAL;
  •   goto out;
    card->ext_csd.raw_sectors[0] = ext_csd[EXT_CSD_SEC_CNT + 0];
    card->ext_csd.raw_sectors[1] = ext_csd[EXT_CSD_SEC_CNT + 1];
修改parameter文件root=/dev/mmcblk0p5
终端打印正常 hdmi接口输出是白屏
搞个这玩意跟西天取经一样 步步该灾
今天上午都搞定了 内核没问题了 系统里加xorg.conf
你好 我和你遇到了一样的问题 系统白屏 请问可以帮助我解答吗 感激不尽
我按你的方法,卡在了Starting kernel …是怎么回事
