最近开始玩RK3288,需要用到USB转串口驱动,烧写的是单固件Firefly-RK3288_Ubuntu14.04_201611211031.img。
该固件不支持USB转串口。按照http://developer.t-firefly.com/thread-1085-1-1.html的方法试着编译内核。
开始的几步都很顺利,最后烧写完boot.img之后板子无法启动,一直黑屏。
我自己感觉有问题的地方在于parameter文件,看了教程试着改了改,可能是没有改对,总之是启动不了,希望各位大神帮忙解决一下
或者说有集成了USB转串口驱动的单Ubuntu固件也可以,我用那个新的,就不折腾内核了。我用的是PL2303
我用的Firefly-RK3288_Ubuntu14.04_201611211031.img的镜像,刷的是T-Firefly-firefly-rk3288-kernel-888979adc1a4.tar.gz的内核(版本是3.10的),按照git clone https://bitbucket.org/T-Firefly/firefly-rk3288-kernel.git上代码下的。 现在ubuntu系统在串口那里看是跑起来了,但是显示器上没有图形界面,用官方的内核就有图形界面。不知道是什么问题!
下面是打印信息
- Starting Mount network filesystems [ OK ]
- Starting Upstart job to start rpcbind on boot only [ OK ]
- Starting Failsafe Boot Delay [ OK ]
- Starting NFSv4 id ↔ name mapper [ OK ]
- Stopping Upstart job to start rpcbind on boot only [ OK ]
- Stopping Mount network filesystems [ OK ]
- Starting configure network device [ OK ]
- Stopping Failsafe Boot Delay [ OK ]
- Starting System V initialisation compatibility [ OK ]
- Starting configure network device security [ OK ]
- Starting RPC portmapper replacement [ OK ]
- Setting up X socket directories… * Starting NSM status monito[ OK ]
[ OK ] - Starting NFSv4 id ↔ name mapper [ OK ]
- Stopping System V initialisation compatibility [ OK ]
- Starting System V runlevel compatibility [ OK ]
- Starting save kernel messages [ OK ]
- Starting anac(h)ronistic cron [ OK ]
- Starting regular background program processing daemon [ OK ]
- Starting NSM status monitor [ OK ]
- Not starting NFS kernel daemon: no exports.
- Starting OpenSSH server [ OK ]
- Starting configure virtual network devices [ OK ]
- Stopping save kernel messages [ OK ]
[ 6.303645] turn on mali power
Ubuntu 14.04.1 LTS firefly ttyFIQ0
firefly login: root (automatic login)
Last login: Sat Jan 1 15:11:28 UTC 2011 on ttyFIQ0
Welcome to Ubuntu 14.04.1 LTS (GNU/Linux 3.10.0 armv7l)
- Documentation: https://help.ubuntu.com/
root@firefly:~# ls /dev/
