15.6寸edp屏只亮背光,无图像
使用15.6寸 NT156FHM无法点亮,只亮背光,屏幕呈现灰色。附件是15.6寸显示屏规格书和打印信息。15.6寸edp屏规格书
                    native-mode = <&timing0>;
                    timing0: timing0 {
			screen-type = <SCREEN_EDP>;
			out-face    = <OUT_P666>;
			clock-frequency = <153600000>;
			hactive = <1920>;
			vactive = <1080>;
			hback-porch = <100>;
			hfront-porch = <100>;
			vback-porch = <30>;
			vfront-porch = <30>;
			hsync-len = <87>;
			vsync-len = <20>;
			hsync-active = <0>;
			vsync-active = <0>;
			de-active = <0>;
			pixelclk-active = <0>;
			swap-rb = <0>;
			swap-rg = <0>;
			swap-gb = <0>;
麻烦各位高手帮忙看看是什么问题。。。。
把内核log 贴出来看看
loading 发表于 2017-3-15 18:32
把内核log 贴出来看看
U-Boot 2014.10-RK3288-10-gc28aaca (Feb 18 2017 - 04:10:44)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 20
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2017-02-18#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
pll_src = 0, dclk_hz = 153600000, dclk_div = 2
edp pll locked
link training success.
unable to config video
no fuel gauge found
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x00692e20)
ramdisk @ 0x05bf0000 (0x00138ef4)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561b486 … OK
[ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (xxl@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #14 SMP PREEMPT Fri Mar 10 02:49:17 EST 2017 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288 [ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x01000000 [ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(drm): base(0) size(0) align(0) [ 0.000000] ion heap(cma): base(0) size(28000000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 640 MiB at 55c00000 [ 0.000000] ion_reserve: cma reserved base 55c00000 size 671088640 [ 0.000000] cma: CMA: reserved 16 MiB at 1f000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] Boot mode: REBOOT (6) flag: NORMAL (0xc3524200) [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1ee5000 s13376 r8192 d15296 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264 [ 0.000000] Kernel command line: vmalloc=496M console=ttyFIQ0 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),0x00200000@0x0039C000(userdata),0x00020000@0x0059C000(radical_update),-@0x005BC000(user) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000:0x01000000 loader.timestamp=2017-02-18_04:10:44 [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] allocated 4194304 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 1354968k/1354968k available, 742184k reserved, 884736K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0b81504 (11750 kB) [ 0.000000] .init : 0xc0b82000 - 0xc0bdb440 ( 358 kB) [ 0.000000] .data : 0xc0bdc000 - 0xc0d6b8c0 (1599 kB) [ 0.000000] .bss : 0xc0d6b8c0 - 0xc0e8c97c (1157 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! [ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div [ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1 [ 0.000000] rkclk_init_clks: cnt_parent = 7 [ 0.000000] rkclk_init_clks: cnt_rate = 28 [ 0.000000] rk3288 set GPLL BW 20 for HDMI! [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 3 [ 0.000000] channel:0, lkg:16 [ 0.000000] target-temp:80 [ 0.000000] channel:2, lkg:0 [ 0.000000] channel:0, lkg:16 [ 0.000000] channel:1, lkg:13 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 0.345337] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.345353] pid_max: default: 32768 minimum: 301 [ 0.345466] Security Framework initialized [ 0.345482] SELinux: Initializing. [ 0.345555] Mount-cache hash table entries: 512 [ 0.346197] Initializing cgroup subsys debug [ 0.346213] Initializing cgroup subsys memory [ 0.346239] Initializing cgroup subsys freezer [ 0.346268] CPU: Testing write buffer coherency: ok [ 0.346578] /cpus/cpu@0 missing clock-frequency property [ 0.346591] /cpus/cpu@1 missing clock-frequency property [ 0.346601] /cpus/cpu@2 missing clock-frequency property [ 0.346610] /cpus/cpu@3 missing clock-frequency property [ 0.346661] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500 [ 0.346712] Setting up static identity map for 0xc0852eb8 - 0xc0852f10 [ 0.348966] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x1830 (version 3.1) [ 0.423516] CPU1: Booted secondary processor [ 0.423548] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501 [ 0.443186] CPU2: Booted secondary processor [ 0.443210] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502 [ 0.462896] CPU3: Booted secondary processor [ 0.462919] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503 [ 0.463022] Brought up 4 CPUs [ 0.463051] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.463060] CPU: All CPU(s) started in SVC mode. [ 0.463801] devtmpfs: initialized [ 0.467992] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0 [ 0.469065] pinctrl core: initialized pinctrl subsystem [ 0.469315] regulator-dummy: no parameters [ 0.493486] NET: Registered protocol family 16 [ 0.495291] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.495618] ion_snapshot: 0x1ea90000 map to 0xe0907000 and copy to 0xc0e67e8c (version 0.1) [ 0.495872] Registered FIQ tty driver [ 0.497171] console [ttyFIQ0] enabled [ 0.497416] Registered fiq debugger ttyFIQ0 [ 0.498029] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff [ 0.498053] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f [ 0.498073] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f [ 0.498092] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b [ 0.498186] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff [ 0.498253] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff [ 0.498317] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff [ 0.498387] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff [ 0.498455] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff [ 0.498521] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff [ 0.498585] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff [ 0.498650] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff [ 0.498723] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff [ 0.498790] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3 [ 0.498806] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f [ 0.498821] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf [ 0.498835] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f [ 0.499450] rockchip_interrupts_register:bank_num=7 [ 0.501430] of_get_gpio_init_config:gpio[0] = 6, value = 0 [ 0.501490] rockchip_pinctrl_probe:init ok [ 0.508001] rk_iommu ff900800.iep_mmu: (iep) Enter [ 0.508090] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.508107] rk_iommu ff900800.iep_mmu: (iep) Initialized [ 0.508281] rk_iommu ff950800.vip_mmu: (vip) Enter [ 0.508354] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.508370] rk_iommu ff950800.vip_mmu: (vip) Initialized [ 0.508543] rk_iommu ff930300.vopb_mmu: (vopb) Enter [ 0.508614] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.508631] rk_iommu ff930300.vopb_mmu: (vopb) Initialized [ 0.508799] rk_iommu ff940300.vopl_mmu: (vopl) Enter [ 0.508874] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.508890] rk_iommu ff940300.vopl_mmu: (vopl) Initialized [ 0.509085] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter [ 0.509162] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.509178] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized [ 0.509343] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter [ 0.509414] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.509430] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized [ 0.509605] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter [ 0.509684] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.509700] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized [ 0.511358] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.511374] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.511996] rk3368_init_rockchip_pmu_ops: could not find pmu dt node [ 0.512023] DDR DEBUG: version 1.00 20150126 [ 0.512055] DDR DEBUG: Channel a: [ 0.512065] DDR DEBUG: DDR3 Device [ 0.512080] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.512092] DDR DEBUG: Channel b: [ 0.512101] DDR DEBUG: DDR3 Device [ 0.512115] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.512127] DDR DEBUG: addr=0xd75000 [ 0.512138] DDR DEBUG: stride=9, size=256, halfcap=40000000 [ 0.512149] DDR DEBUG: socAddr[0]=0xd75000, socAddr[1]=0xd75100 [ 0.512160] DDR DEBUG: chAddr[0]=0xd75000, chAddr[1]=0xd75000 [ 0.512173] DDR DEBUG: dtar[0]=0x501ae000, dtar[1]=0x501ae000 [ 0.512229] DDR DEBUG: init success!!! freq=200MHz [ 0.512239] DDR DEBUG: Channel a: [ 0.512254] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.512269] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.512285] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.512301] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.512316] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.512328] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.512339] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.512348] DDR DEBUG: Channel b: [ 0.512361] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.512377] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.512392] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.512408] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.512422] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.512433] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.512444] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.536606] bio: create slab at 0 [ 0.537146] Rockchip hdmi driver version 2.0 . [ 0.538291] SCSI subsystem initialized [ 0.538450] usbcore: registered new interface driver usbfs [ 0.538497] usbcore: registered new interface driver hub [ 0.538595] usbcore: registered new device driver usb [ 0.541289] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter [ 0.541815] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter [ 0.542280] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter [ 0.542733] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter [ 0.542857] media: Linux media interface: v0.10 [ 0.542898] Linux video capture interface: v2.00 [ 0.543013] pps_core: LinuxPPS API ver. 1 registered [ 0.543026] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.543056] PTP clock support registered [ 0.543113] i2c-core: driver [bq24296] using legacy suspend method [ 0.543126] i2c-core: driver [bq24296] using legacy resume method [ 0.543785] ion_drm_heap_create: 0@0 [ 0.543921] Rockchip ion module is successfully loaded (v1.1) [ 0.544083] Advanced Linux Sound Architecture Driver Initialized. [ 0.544490] Bluetooth: Core ver 2.16 [ 0.544529] NET: Registered protocol family 31 [ 0.544541] Bluetooth: HCI device and connection manager initialized [ 0.544560] Bluetooth: HCI socket layer initialized [ 0.544576] Bluetooth: L2CAP socket layer initialized [ 0.544606] Bluetooth: SCO socket layer initialized [ 0.544852] cfg80211: Calling CRDA to update world regulatory domain [ 0.545499] act8846_i2c_probe,line=880 [ 0.546512] act8846_parse_dt,line=744 [ 0.546954] act8846_i2c_probe: act8846_pmic_hold=1 [ 0.549023] act_dcdc1: 1200 mV [ 0.552000] vccio: 3300 mV [ 0.553876] vdd_logic: 700 <--> 1500 mV at 1125 mV [ 0.556839] act_dcdc4: 2000 mV [ 0.558096] vccio_sd: 1800 <--> 3300 mV at 3300 mV [ 0.560413] act_ldo2: 1000 mV [ 0.562741] act_ldo3: 3300 mV [ 0.565063] act_ldo4: 3300 mV [ 0.567373] act_ldo5: 3300 mV [ 0.569697] act_ldo6: 1000 mV [ 0.572036] vcc_18: 1800 mV [ 0.574365] act_ldo8: 1800 mV [ 0.579216] vdd_arm: 712 <--> 1500 mV at 1100 mV [ 0.583950] vdd_gpu: 712 <--> 1500 mV at 900 mV [ 0.584680] rk808_i2c_probe,line=1355 [ 0.586016] The device is not rk808 -11 [ 0.586104] rk808: probe of 0-001b failed with error -11 [ 0.586174] i2c-core: driver [rk816] using legacy suspend method [ 0.586187] i2c-core: driver [rk816] using legacy resume method [ 0.586229] i2c-core: driver [rk818] using legacy suspend method [ 0.586241] i2c-core: driver [rk818] using legacy resume method [ 0.587957] Switching to clocksource arch_sys_counter [ 0.611790] rga: Module initialized. [ 0.612513] rga2 ff920000.rga: rga ion client create success! [ 0.612711] rga: Driver loaded succesfully [ 0.612946] rk-fb rockchip-fb: rk fb ion client create success! [ 0.612962] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 0.613256] rk-screen rk_screen.9: rockchip screen probe success [ 0.613410] rk32-lvds ff96c000.lvds: screen is not lvds/rgb! [ 0.613433] rk32-lvds: probe of ff96c000.lvds failed with error -22 [ 0.613916] rk32-edp rk32-edp: failed to get reset [ 0.613934] rk32-edp rk32-edp: failed to get reset [ 0.614030] rk32-edp rk32-edp: rk32 edp driver probe success [ 0.614780] graphics fb0: rockchip framebuffer registerd:fb0 [ 0.615104] graphics fb1: rockchip framebuffer registerd:fb1 [ 0.615271] graphics fb2: rockchip framebuffer registerd:fb2 [ 0.615439] graphics fb3: rockchip framebuffer registerd:fb3 [ 0.615670] rk3288-lcdc lcdc0: lcdc0: dclk:153600000>>fps:60 [ 0.615688] rk3288-lcdc lcdc0: wakeup from standby! [ 0.639641] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 0.648492] alloc_buffer:ion_phy_addr=0x55c00000 [ 0.661068] fb0:phy:55c00000>>vir:e0991000>>len:0x1800000 [ 0.667187] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled [ 0.667375] rk3288-lcdc lcdc1: can't find power_ctr node for lcdc1 [ 0.667392] rk_fb_trsm_ops_get:un supported transmitter:0! [ 0.667640] graphics fb4: rockchip framebuffer registerd:fb4 [ 0.667970] graphics fb5: rockchip framebuffer registerd:fb5 [ 0.668140] graphics fb6: rockchip framebuffer registerd:fb6 [ 0.668309] graphics fb7: rockchip framebuffer registerd:fb7 [ 0.668554] unknow screen type: 0 [ 0.668620] rk3288-lcdc lcdc1: lcdc1: dclk:153600000>>fps:791 [ 0.668634] rk3288-lcdc lcdc1: wakeup from standby! [ 0.668650] fb4:phy:55c00000>>vir:e0991000>>len:0x1800000 [ 0.668663] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled [ 0.669528] rockchip_set_mux:warning ignore bank num 15 [ 0.669668] rockchip_set_mux:warning ignore bank num 15 [ 0.669790] rockchip_set_mux:warning ignore bank num 15 [ 0.669908] rockchip_set_mux:warning ignore bank num 15 [ 0.670023] rockchip_set_mux:warning ignore bank num 15 [ 0.670148] rockchip_set_mux:warning ignore bank num 15 [ 0.670726] rockchip_set_mux:warning ignore bank num 15 [ 0.670906] rockchip_set_mux:warning ignore bank num 15 [ 0.671465] rockchip_set_mux:warning ignore bank num 15 [ 0.671612] rockchip_set_mux:warning ignore bank num 15 [ 0.672164] rockchip_set_mux:warning ignore bank num 15 [ 0.672328] rockchip_set_mux:warning ignore bank num 15 [ 0.672895] rockchip_set_mux:warning ignore bank num 15 [ 0.673049] rockchip_set_mux:warning ignore bank num 15 [ 0.674514] NET: Registered protocol family 2 [ 0.675205] TCP established hash table entries: 4096 (order: 3, 32768 bytes) [ 0.675288] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 0.675364] TCP: Hash tables configured (established 4096 bind 4096) [ 0.675427] TCP: reno registered [ 0.675443] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.675469] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.675670] NET: Registered protocol family 1 [ 0.676394] Unpacking initramfs... [ 0.743488] Freeing initrd memory: 1248K (c5bf0000 - c5d28000) [ 0.744206] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available [ 0.744746] vcodec_service: probe device ff9a0000.vpu_service [ 0.744943] vcodec_service: No reset resource define [ 0.745147] vcodec_service: ff9a0000.vpu_service: power on [ 0.745235] vcodec_service: probe device ff9a0000.vpu_service [ 0.745254] vcodec_service: checking hw id 4831 [ 0.745729] vcodec_service: ff9a0000.vpu_service: power off... [ 0.745776] vcodec_service: done [ 0.745787] vcodec_service: init success [ 0.745850] vcodec_service: probe device ff9c0000.hevc_service [ 0.746190] vcodec_service: ff9c0000.hevc_service: power on [ 0.746251] vcodec_service: probe device ff9c0000.hevc_service [ 0.746268] vcodec_service: checking hw id 6867 [ 0.746525] vcodec_service: ff9c0000.hevc_service: power off... [ 0.746567] vcodec_service: done [ 0.746578] vcodec_service: init success [ 0.746714] rknandbase v1.0 2014-03-31 [ 0.746850] rknand: probe of ff400000.nandc failed with error -1 [ 0.746968] rknand_driver:ret = 0 [ 0.748169] audit: initializing netlink socket (disabled) [ 0.748218] type=2000 audit(0.400:1): initialized [ 0.749054] bounce pool size: 64 pages [ 0.753625] fuse init (API version 7.22) [ 0.754019] msgmni has been set to 952 [ 0.755925] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 0.755944] io scheduler noop registered [ 0.755956] io scheduler deadline registered [ 0.756075] io scheduler cfq registered (default) [ 0.757789] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess. [ 0.758490] IEP Driver loaded succesfully [ 0.758582] Module initialized. [ 0.759537] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208 [ 0.759559] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10 [ 0.760926] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208 [ 0.760946] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 0.761220] pwm-voltage-regulator pwm_regulator.24: unable to request PWM, trying legacy API [ 0.761240] pwm-voltage-regulator pwm_regulator.24: unable to request legacy PWM [ 0.761253] pwm_regulator_probe:error [ 0.761274] pwm-voltage-regulator: probe of pwm_regulator.24 failed with error -16 [ 0.761473] rk_serial.c v1.8 2014-03-04 [ 0.761701] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0 [ 0.761902] serial ff180000.serial: membase e319c000 [ 0.762055] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1 [ 0.762221] serial ff190000.serial: membase e319e000 [ 0.762384] ff1c0000.serial: ttyS4 at MMIO 0xff1c0000 (irq = 91) is a rk29_serial.4 [ 0.762550] serial ff1c0000.serial: membase e31be000 [ 0.765337] loop: module loaded [ 0.765706] zram: Created 1 device(s) ... [ 0.765781] i2c-core: driver [mpu6050B1] using legacy suspend method [ 0.765794] i2c-core: driver [mpu6050B1] using legacy resume method [ 0.765811] mpu_init: Probe name mpu6050B1 [ 0.765962] ak8963_mod_init: Probe name ak8963_mod [ 0.766659] SCSI Media Changer driver v0.25 [ 0.766976] tun: Universal TUN/TAP device driver, 1.6 [ 0.766990] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 0.767115] vmac_init. [ 0.767693] stmmac_probe_config_dt: Can not read property: pmu_regulator. [ 0.767711] stmmac_probe_config_dt: clock input/output? (input). [ 0.767725] stmmac_probe_config_dt: TX delay(0x30). [ 0.767737] stmmac_probe_config_dt: RX delay(0x20). [ 0.767791] stmmac_probe_config_dt: is rockchip,rk3288-gmac [ 0.767802] stmmc_pltfr_init: [ 0.767812] stmmc_pltfr_init: ERROR: Get power-gpio failed. [ 0.767871] stmmc_pltfr_init: init for RGMII [ 0.767884] tx delay=0x30 [ 0.767884] rx delay=0x20 [ 0.767900] tx delay=0x30 [ 0.767900] rx delay=0x20 [ 0.768354] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 0.768366] Normal descriptors [ 0.768375] Ring mode enabled [ 0.768386] DMA HW capability register supported [ 0.768399] RX Checksum Offload Engine supported (type 2) [ 0.768410] TX Checksum insertion supported [ 0.768420] Wake-Up On Lan supported [ 0.768459] Enable RX Mitigation via HW Watchdog Timer [ 0.768929] PPP generic driver version 2.4.2 [ 0.769085] PPP BSD Compression module registered [ 0.769100] PPP Deflate Compression module registered [ 0.769124] PPP MPPE Compression module registered [ 0.769138] NET: Registered protocol family 24 [ 0.769175] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 0.769190] CSLIP: code copyright 1989 Regents of the University of California. [ 0.769203] Rockchip WiFi SYS interface (V1.00) ... [ 0.769240] esp_mem_init enter date Mar 6 2017 05:05:09 [ 0.769252] esp_mem_init VERSION [V2.5] [ 0.769293] esp_mem_init complete [ 0.769380] usbcore: registered new interface driver catc [ 0.769434] usbcore: registered new interface driver kaweth [ 0.769448] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 0.769493] usbcore: registered new interface driver pegasus [ 0.769534] usbcore: registered new interface driver rtl8150 [ 0.769576] usbcore: registered new interface driver r8152 [ 0.769588] hso: drivers/net/usb/hso.c: Option Wireless [ 0.769659] usbcore: registered new interface driver hso [ 0.769707] usbcore: registered new interface driver asix [ 0.769753] usbcore: registered new interface driver ax88179_178a [ 0.769796] usbcore: registered new interface driver cdc_ether [ 0.769838] usbcore: registered new interface driver cdc_eem [ 0.769878] usbcore: registered new interface driver dm9601 [ 0.769932] usbcore: registered new interface driver dm9620 [ 0.769986] usbcore: registered new interface driver smsc75xx [ 0.770037] usbcore: registered new interface driver smsc95xx [ 0.770078] usbcore: registered new interface driver gl620a [ 0.770118] usbcore: registered new interface driver net1080 [ 0.770156] usbcore: registered new interface driver plusb [ 0.770195] usbcore: registered new interface driver rndis_host [ 0.770233] usbcore: registered new interface driver cdc_subset [ 0.770269] usbcore: registered new interface driver zaurus [ 0.770309] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 0.770376] usbcore: registered new interface driver int51x1 [ 0.770417] usbcore: registered new interface driver kalmia [ 0.770456] usbcore: registered new interface driver ipheth [ 0.770498] usbcore: registered new interface driver sierra_net [ 0.770537] usbcore: registered new interface driver cx82310_eth [ 0.770584] usbcore: registered new interface driver cdc_ncm [ 0.770628] usbcore: registered new interface driver qmi_wwan [ 0.770669] usbcore: registered new interface driver cdc_mbim [ 0.770682] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.773126] EHCI: ehci_rk_probe e3240000 e3240010 [ 0.773144] rockchip_ehci_host ff500000.usb: EHCI Host Controller [ 0.773179] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1 [ 0.773510] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000 [ 0.784845] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00 [ 0.784931] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.784949] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.784964] usb usb1: Product: EHCI Host Controller [ 0.784978] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd [ 0.784991] usb usb1: SerialNumber: ff500000.usb [ 0.785432] hub 1-0:1.0: USB hub found [ 0.785458] hub 1-0:1.0: 1 port detected [ 0.785626] EHCI: ehci_rk_probe ok [ 0.785729] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.785931] usbcore: registered new interface driver cdc_acm [ 0.785944] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 0.785998] usbcore: registered new interface driver usblp [ 0.786041] usbcore: registered new interface driver cdc_wdm [ 0.786102] usbcore: registered new interface driver usb-storage [ 0.786150] usbcore: registered new interface driver ums-alauda [ 0.786190] usbcore: registered new interface driver ums-cypress [ 0.786228] usbcore: registered new interface driver ums-datafab [ 0.786267] usbcore: registered new interface driver ums_eneub6250 [ 0.786305] usbcore: registered new interface driver ums-freecom [ 0.786345] usbcore: registered new interface driver ums-isd200 [ 0.786384] usbcore: registered new interface driver ums-jumpshot [ 0.786426] usbcore: registered new interface driver ums-karma [ 0.786465] usbcore: registered new interface driver ums-onetouch [ 0.786508] usbcore: registered new interface driver ums-sddr09 [ 0.786552] usbcore: registered new interface driver ums-sddr55 [ 0.786592] usbcore: registered new interface driver ums-usbat [ 0.786686] usbcore: registered new interface driver usbserial [ 0.786727] usbcore: registered new interface driver usbserial_generic [ 0.786760] usbserial: USB Serial support registered for generic [ 0.786801] usbcore: registered new interface driver option [ 0.786832] usbserial: USB Serial support registered for GSM modem (1-port) [ 0.786906] usbcore: registered new interface driver trancevibrator [ 0.786919] usb20_otg: version 3.10a 21-DEC-2012 [ 0.787364] e3280040 [ 0.787377] Core Release: 3.10a [ 0.787388] Setting default values for core params [ 0.787514] Using Buffer DMA mode [ 0.787526] Periodic Transfer Interrupt Enhancement - disabled [ 0.787537] Multiprocessor Interrupt Enhancement - disabled [ 0.787549] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 0.787560] ^^^^^^^^^^^^^^^^^Device Mode [ 0.787574] Dedicated Tx FIFOs mode [ 0.787593] pcd_init otg_dev = ddefd180 [ 0.787745] usb20_otg ff580000.usb: DWC OTG Controller [ 0.787777] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2 [ 0.787807] usb20_otg ff580000.usb: irq 55, io mem 0x00000000 [ 0.787866] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.787883] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.787898] usb usb2: Product: DWC OTG Controller [ 0.787911] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 0.787924] usb usb2: SerialNumber: ff580000.usb [ 0.788332] hub 2-0:1.0: USB hub found [ 0.788356] hub 2-0:1.0: 1 port detected [ 0.788667] usb20_host: version 3.10a 21-DEC-2012 [ 0.791153] e3300040 [ 0.791166] Core Release: 3.10a [ 0.791177] Setting default values for core params [ 0.791283] Using Buffer DMA mode [ 0.791296] Periodic Transfer Interrupt Enhancement - disabled [ 0.791306] Multiprocessor Interrupt Enhancement - disabled [ 0.791319] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 0.791329] ^^^^^^^^^^^^^^^^^^Host Mode [ 0.791354] usb20_host ff540000.usb: DWC OTG Controller [ 0.791383] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3 [ 0.791413] usb20_host ff540000.usb: irq 57, io mem 0x00000000 [ 0.791505] Init: Power Port (0) [ 0.791561] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.791578] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.791592] usb usb3: Product: DWC OTG Controller [ 0.791606] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 0.791619] usb usb3: SerialNumber: ff540000.usb [ 0.792001] hub 3-0:1.0: USB hub found [ 0.792028] hub 3-0:1.0: 1 port detected [ 0.792702] usbcore: registered new interface driver xpad [ 0.792762] usbcore: registered new interface driver usb_acecad [ 0.792809] usbcore: registered new interface driver aiptek [ 0.792855] usbcore: registered new interface driver gtco [ 0.792902] usbcore: registered new interface driver hanwang [ 0.792953] usbcore: registered new interface driver kbtab [ 0.793016] usbcore: registered new interface driver wacom [ 0.793029] ILITEK line = 3281: Enter [ 0.793144] ILITEK line = 2937: Enter ilitek_i2c_probe +++++++++ client->addr = 0x41++++++ [ 0.793193] ILITEK line = 2639: 2639,ilitek_request_io_port,ilitek_request_io_port gpio_free(i2c.reset_gpio); reset_gpio = 229 i2c.irq_gpio = 230 [ 0.793210] ------------[ cut here ]------------ [ 0.793236] WARNING: at drivers/gpio/gpiolib.c:1519 gpiod_free+0xe0/0xfc() [ 0.793247] Modules linked in: [ 0.793265] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 3.10.0 #14 [ 0.793304] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14) [ 0.793329] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68) [ 0.793351] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_null+0x18/0x1c) [ 0.793372] [] (warn_slowpath_null+0x18/0x1c) from [] (gpiod_free+0xe0/0xfc) [ 0.793400] [] (gpiod_free+0xe0/0xfc) from [] (ilitek_request_io_port+0xe4/0x1e8) [ 0.793423] [] (ilitek_request_io_port+0xe4/0x1e8) from [] (ilitek_i2c_probe+0xe4/0x3d4) [ 0.793450] [] (ilitek_i2c_probe+0xe4/0x3d4) from [] (i2c_device_probe+0xa8/0xd4) [ 0.793478] [] (i2c_device_probe+0xa8/0xd4) from [] (really_probe+0xa8/0x20c) [ 0.793501] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48) [ 0.793524] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84) [ 0.793546] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90) [ 0.793567] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c) [ 0.793589] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138) [ 0.793611] [] (driver_register+0x9c/0x138) from [] (i2c_register_driver+0x40/0xac) [ 0.793631] [] (i2c_register_driver+0x40/0xac) from [] (ilitek_init+0x34/0x78) [ 0.793653] [] (ilitek_init+0x34/0x78) from [] (do_one_initcall+0x34/0xc8) [ 0.793677] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0) [ 0.793697] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130) [ 0.793722] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4) [ 0.793749] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c) [ 0.793780] ---[ end trace c2a8e57315c42696 ]--- [ 0.793844] ILITEK line = 2983: ilitek i2c.irq_gpio = 230, i2c.client->irq = 193 [ 0.793858] ILITEK line = 223: Enter 10 ilitek_reset [ 0.883323] dwc_otg_hcd_suspend, usb device mode [ 1.020662] ILITEK line = 350: ilitek_i2c_transfer err [ 1.070579] ILITEK line = 350: ilitek_i2c_transfer err [ 1.099714] usb 1-1: new high-speed USB device number 2 using rockchip_ehci_host [ 1.129622] ILITEK line = 350: ilitek_i2c_transfer err [ 1.188656] ILITEK line = 350: ilitek_i2c_transfer err [ 1.247300] ILITEK line = 453: ilitek_i2c_write_and_read, i2c write error, ret = -11 [ 1.247968] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101 [ 1.247986] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 1.248001] usb 1-1: Product: USB 2.0 Hub [ 1.248576] hub 1-1:1.0: USB hub found [ 1.248703] hub 1-1:1.0: 4 ports detected [ 1.267935] ILITEK line = 350: ilitek_i2c_transfer err [ 1.326956] ILITEK line = 350: ilitek_i2c_transfer err [ 1.386007] ILITEK line = 350: ilitek_i2c_transfer err [ 1.445045] ILITEK line = 350: ilitek_i2c_transfer err [ 1.503144] ILITEK line = 462: ilitek_i2c_write_and_read, i2c read error, ret = -11 [ 1.503163] ILITEK line = 2444: ilitek_i2c_read_tp_info, MCU KERNEL version:255.255.255.255.255 [ 1.503578] ILITEK line = 350: ilitek_i2c_transfer err [ 1.562588] ILITEK line = 350: ilitek_i2c_transfer err [ 1.621620] ILITEK line = 350: ilitek_i2c_transfer err [ 1.680668] ILITEK line = 350: ilitek_i2c_transfer err [ 1.739303] ILITEK line = 453: ilitek_i2c_write_and_read, i2c write error, ret = -11 [ 1.759785] ILITEK line = 350: ilitek_i2c_transfer err [ 1.818829] ILITEK line = 350: ilitek_i2c_transfer err [ 1.877868] ILITEK line = 350: ilitek_i2c_transfer err [ 1.936910] ILITEK line = 350: ilitek_i2c_transfer err [ 1.995151] ILITEK line = 462: ilitek_i2c_write_and_read, i2c read error, ret = -11 [ 1.995167] ILITEK line = 3035: ilitek read tp info fail free gpio [ 1.995195] ilitek_i2c: probe of 4-0041 failed with error -1 [ 1.995604] sensor_register_slave:mma8452,id=17 [ 1.995618] sensor_register_slave:gs_mc3230,id=23 [ 1.995628] gsensor_init [ 1.995639] sensor_register_slave:mpu6880_acc,id=24 [ 1.995650] sensor_register_slave:mpu6500_acc,id=25 [ 1.995661] sensor_register_slave:cm3217,id=48 [ 1.995672] sensor_register_slave:cm3218,id=49 [ 2.000633] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0 [ 2.000684] i2c /dev entries driver [ 2.001299] IR NEC protocol handler initialized [ 2.001313] IR RC5(x) protocol handler initialized [ 2.001323] IR RC6 protocol handler initialized [ 2.001333] IR JVC prhtolorkh2ndle $initialized [ 2.001344] IR Sony protocol handler initialized [ 2.001353] IR RC5 (streamzap) protocol handler initialized [ 2.001363] IR SANYO protocol handler initialized [ 2.001373] IR MCE Keyboard/mouse protocol handler initialized [ 2.001546] usbcore: registered new interface driver uvcvideo [ 2.001559] USB Video Class driver (1.1.1) [ 2.001573] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0 [ 2.002607] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288 [ 2.002607] [ 2.002687] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0) [ 2.002860] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe31f8000 size: 0x4000) [ 2.003504] D1:camsys_platform_probe(1394): ff910000.isp memory: [ 2.003524] D1:camsys_platform_probe(1404): Register memory (phy: 0xff910000 vir: 0xe3220000 size: 0x10000) [ 2.003540] D1:camsys_platform_probe(1399): I2c memory (phy: 0x1df9c000 vir: 0xddf9c000 size: 0x1000) [ 2.003555] D1:camsys_init_ext_fsh_module(20): init external flash module [ 2.003567] D1:camsys_platform_probe(1419): Probe ff910000.isp device success [ 2.003915] not find test_power_init dev node [ 2.003976] i2c-core: driver [bq27320] using legacy suspend method [ 2.003989] i2c-core: driver [bq27320] using legacy resume method [ 2.004317] rockchip_temp_probe,line=362 [ 2.054190] tsadc ff280000.tsadc: initialized [ 2.054570] device-mapper: uevent: version 1.0.3 [ 2.054826] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email]dm-devel@redhat.com[/email] [ 2.055141] Bluetooth: HCI UART driver ver 2.2 [ 2.055157] Bluetooth: HCI H4 protocol initialized [ 2.055169] Bluetooth: HCILL protocol initialized [ 2.055180] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21 [ 2.055192] rtk_btusb: Register usb char device interface for BT driver [ 2.055374] usbcore: registered new interface driver rtk_btusb [ 2.060100] cpufreq version 1.0, suspend freq 1200 MHz [ 2.060299] cpuidle: using governor ladder [ 2.060312] cpuidle: using governor menu [ 2.060348] Synopsys Designware Multimedia Card Interface Driver [ 2.060360] MHSC version = Ver 2.00 2015-06-10 [ 2.060648] dw cru_regsbase addr 0x1d8. [ 2.060661] dw cru_reset_offset val 3. [ 2.060677] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a [ 2.060722] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc [ 2.061028] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller. [ 2.061200] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0] [ 2.061327] 1358..dw_mci_set_ios: no card. [mmc0] [ 2.073887] 1358..dw_mci_set_ios: no card. [mmc0] [ 2.093588] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0] [ 2.093606] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo [ 2.093616] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized [ 2.093919] dw cru_regsbase addr 0x1d8. [ 2.093933] dw cru_reset_offset val 0. [ 2.093948] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a [ 2.093986] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc [ 2.094758] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller. [ 2.094910] dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc1] [ 2.095361] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found! [ 2.095429] 1358..dw_mci_set_ios: no card. [mmc1] [ 2.113233] 1358..dw_mci_set_ios: no card. [mmc1] [ 2.125690] mmc0: BKOPS_EN bit is not set [ 2.127560] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0] [ 2.129841] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0) [ 2.129865] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0] [ 2.129885] [mmc0] tuning regsbase addr 0x218. [ 2.130478] [mmc0] Data transmission error !!!! MINTSTS: [0x00000088] [ 2.130488] [mmc0] host was already tuning, Don't need to retry tune again ignore 0. [ 2.130517] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84 [ 2.130543] [mmc0] Data transmission error !!!! MINTSTS: [0x00002000] [ 2.130553] [mmc0] host was already tuning, Don't need to retry tune again ignore 0. [ 2.130580] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115 [ 2.130824] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-180 (17 len) [ 2.130836] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 214-282 (7 len) [ 2.130847] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-180 (17 len) [ 2.130857] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 90 [ 2.130903] mmc0: new HS200 MMC card at address 0001 [ 2.131188] mmcblk0: mmc0:0001 AWPD3R 14.5 GiB [ 2.131500] uboot: 0x000400000 -- 0x000800000 (4 MB) [ 2.131513] misc: 0x000800000 -- 0x000c00000 (4 MB) [ 2.131523] resource: 0x000c00000 -- 0x001c00000 (16 MB) [ 2.131532] kernel: 0x001c00000 -- 0x002c00000 (16 MB) [ 2.131541] boot: 0x002c00000 -- 0x004c00000 (32 MB) [ 2.131549] recovery: 0x004c00000 -- 0x006c00000 (32 MB) [ 2.131558] backup: 0x006c00000 -- 0x00a000000 (52 MB) [ 2.131567] cache: 0x00a000000 -- 0x012000000 (128 MB) [ 2.131576] kpanic: 0x012000000 -- 0x012400000 (4 MB) [ 2.131584] system: 0x012400000 -- 0x072400000 (1536 MB) [ 2.131593] metadata: 0x072400000 -- 0x073400000 (16 MB) [ 2.131601] baseparamer: 0x073400000 -- 0x073800000 (4 MB) [ 2.131610] userdata: 0x073800000 -- 0x0b3800000 (1024 MB) [ 2.131618] radical_update: 0x0b3800000 -- 0x0b7800000 (64 MB) [ 2.131627] user: 0x0b7800000 -- 0x3a3a00000 (11970 MB) [ 2.131657] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15[ 2.132980] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo [ 2.132994] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized 1358..dw_mci_set_ios: no card. [mmc1] [ 2.133310] dw cru_regsbase addr 0x1d8. [ 2.133319] dw cru_reset_offset val 1. [ 2.133329] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a [ 2.133363] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc [ 2.133581] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller. [ 2.133707] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2] [ 2.133970] 1358..dw_mci_set_ios: no card. [mmc2] [ 2.152600] 1358..dw_mci_set_ios: no card. [mmc2] [ 2.172282] 1358..dw_mci_set_ios: no card. [mmc2] [ 2.172302] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo [ 2.172315] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized [ 2.172587] hidraw: raw HID events driver (C) Jiri Kosina [ 2.174078] usbcore: registered new interface driver usbhid [ 2.174088] usbhid: USB HID core driver [ 2.174205] ashmem: initialized [ 2.174311] logger: created 256K log 'log_main' [ 2.174399] logger: created 256K log 'log_events' [ 2.174496] logger: created 256K log 'log_radio' [ 2.174588] logger: created 256K log 'log_system' [ 2.175806] input: rk29-keypad as /devices/ff100000.adc/key.32/input/input0 [ 2.176674] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010 [ 2.176693] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22 [ 2.176705] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl [ 2.176717] ES8323 2-0010: Error applying setting, reverse things back [ 2.177176] es8323_i2c_probe:register ISR (irq=196) [ 2.177828] rockchip-spdif ff8b0000.rockchip-spdif: spdif ready. [ 2.178146] es8323_probe [ 2.767582] EHCI: rk_ehci_hcd_enable, enable host controller [ 2.925536] rockchip-es8323 rockchip-es8323.29: ES8323 HiFi <-> ff890000.rockchip-i2s mapping ok [ 2.927774] rockchip-hdmi-i2s rockchip-hdmi-i2s.27: rk-hdmi-i2s-hifi <-> ff890000.rockchip-i2s mapping ok [ 2.928098] u32 classifier [ 2.928105] Actions configured [ 2.928116] Netfilter messages via NETLINK v0.30. [ 2.928164] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 2.928416] ctnetlink v0.93: registering with nfnetlink. [ 2.928473] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 2.928480] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 2.928689] xt_time: kernel timezone is -0000 [ 2.928846] ip_tables: (C) 2000-2006 Netfilter Core Team [ 2.928951] arp_tables: (C) 2002 David S. Miller [ 2.928983] TCP: cubic registered [ 2.928989] Initializing XFRM netlink socket [ 2.929156] NET: Registered protocol family 10 [ 2.929565] mip6: Mobile IPv6 [ 2.929586] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 2.929688] sit: IPv6 over IPv4 tunneling driver [ 2.929988] NET: Registered protocol family 17 [ 2.930009] NET: Registered protocol family 15 [ 2.930052] Bridge firewalling registered [ 2.930062] Ebtables v2.0 registered [ 2.930197] Bluetooth: RFCOMM TTY layer initialized [ 2.930216] Bluetooth: RFCOMM socket layer initialized [ 2.930223] Bluetooth: RFCOMM ver 1.11 [ 2.930230] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 2.930235] Bluetooth: BNEP filters: protocol multicast [ 2.930245] Bluetooth: BNEP socket layer initialized [ 2.930251] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 2.930261] Bluetooth: HIDP socket layer initialized [ 2.930282] l2tp_core: L2TP core driver, V2.0 [ 2.930293] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 2.930299] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 2.930480] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 2.930489] [WLAN_RFKILL]: can't find rockchip,grf property [ 2.930497] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6212 [ 2.930504] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 2.930511] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control. [ 2.930519] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 2.930537] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0. [ 2.930554] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0. [ 2.930561] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 2.930586] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 3.3V [ 2.930594] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 2.930629] [BT_RFKILL]: Enter rfkill_rk_init [ 2.930750] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147. [ 2.930768] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157. [ 2.930779] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154. [ 2.930790] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159. [ 2.930829] [BT_RFKILL]: Request irq for bt wakeup host [ 2.930916] [BT_RFKILL]: ** disable irq [ 2.930978] [BT_RFKILL]: ap6335 device registered. [ 2.931569] rk3288_init_suspend [ 2.931581] rk3288_suspend_init enter [ 2.931761] rk3288_suspend_init: pm_ctrbits =200007 [ 2.931787] gpio_get_dts_info suspend:4 [ 2.931793] gpio_get_dts_info resume:4 [ 2.931798] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 2.931820] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 2.931938] clks_gating_suspend_init:clkgt info ok [ 2.932019] Registering SWP/SWPB emulation handler [ 2.932029] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000 [ 2.934413] ddrfreq: verion 1.2 20140526 [ 2.934426] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz [ 2.934434] ddrfreq: auto-freq=0 [ 2.934439] ddrfreq: auto-freq-table[0] 240MHz [ 2.934444] ddrfreq: auto-freq-table[1] 324MHz [ 2.934448] ddrfreq: auto-freq-table[2] 456MHz [ 2.934453] ddrfreq: auto-freq-table[3] 528MHz [ 2.950585] regulator-dummy: disabling [ 2.950655] ======================================================= [ 2.950662] ==== Launching Wi-Fi driver! (Powered by Rockchip) ==== [ 2.950667] ======================================================= [ 2.950672] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init. [ 2.950714] dhd_module_init: in [ 2.950720] ======== bcm_wlan_set_plat_data ======== [ 2.950725] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter [ 2.950742] host_oob_irq: 198 [ 2.950747] host_oob_irq_flags=4 [ 2.950751] dhd_wifi_platform_load: Enter [ 2.950765] pcd_pullup, is_on 0 [ 2.950768] Power-up adapter 'DHD generic adapter' [ 2.950782] wifi_platform_set_power = 1 [ 2.950787] ======== PULL WL_REG_ON HIGH! ======== [ 2.950792] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ 2.950798] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1 [ 2.950802] file system registered [ 2.950807] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled. [ 2.951268] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 2.951276] android_usb gadget: Number of LUNs=2 [ 2.951283] lun0: LUN: removable file: (no medium) [ 2.951288] lun1: LUN: removable file: (no medium) [ 2.951405] android_usb gadget: android_usb ready [ 2.951464] sensor_init: Probe name sensors [ 2.951478] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01 [ 2.952003] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:29:19 UTC (1293884959) [ 2.956253] rockchip_headset_probe() Can not read property headset_gpio [ 2.956266] rockchip_headset: probe of rockchip_headset.31 failed with error -2 [ 2.956675] usbcore: registered new interface driver snd-usb-audio [ 2.956683] ALSA device list: [ 2.956688] #0: RK_ES8323 [ 2.956692] #1: RK-HDMI-I2S [ 2.956925] Freeing unused kernel memory: 356K (c0b82000 - c0bdb000) [ 3.057860] [WLAN_RFKILL]: wifi turn on power. 156 [ 3.080633] type=1403 audit(1293884959.620:2): policy loaded auid=4294967295 ses=4294967295 [ 3.100791] init: could not import file 'init.box.samba.rc' from '/init.rk30board.rc' [ 3.102320] init: invalid gid 'trace' [ 3.181163] init: /dev/hw_random not found [ 3.181222] keychord: using input dev rk29-keypad for fevent [ 3.185529] init: /dev/hw_random not found [ 3.186361] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system [ 3.187127] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs: [ 3.189576] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option [ 3.194479] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro [ 3.194556] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0 [ 3.195296] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system [ 3.200404] e2fsck: e2fsck 1.42.9 (28-Dec-2013) [ 3.200441] e2fsck: system: clean, 1857/80256 files, 108990/393216 blocks [ 3.204114] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc [ 3.204172] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0 [ 3.208120] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard [ 3.208175] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0 [ 3.208459] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option [ 3.212086] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro [ 3.212131] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0 [ 3.212793] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata [ 3.217011] e2fsck: e2fsck 1.42.9 (28-Dec-2013) [ 3.217040] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks [ 3.220955] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard [ 3.221012] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0 [ 3.221048] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata [ 3.221838] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory [ 3.221869] fsck.f2fs: fsck.f2fs terminated by exit(255) [ 3.222074] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1 [ 3.222351] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option [ 3.226032] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro [ 3.226080] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0 [ 3.226756] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata [ 3.231492] e2fsck: e2fsck 1.42.9 (28-Dec-2013) [ 3.231519] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 604/65536 files, 30781/262144 blocks [ 3.235523] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic [ 3.235572] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0 [ 3.235586] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs [ 3.249152] arm_release_ver of this mali_ko is 'r6p0-02rel0', rk_ko_ver is '13', built at '09:15:10', on 'Oct 22 2015'. [ 3.249219] mali ffa30000.gpu: Continuing without Mali clock control [ 3.249251] mali pd enabled [ 3.249258] clk enabled [ 3.249268] MALI_DVFS_STEP = 4, div_dvfs = 10 [ 3.249273] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70 [ 3.249280] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80 [ 3.249286] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90 [ 3.249292] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100 [ 3.249379] turn on mali power [ 3.249387] kbase_platform_rk_init,register_reboot_notifier [ 3.249424] hrtimer: interrupt took 10500 ns [ 3.249507] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1 [ 3.250160] mali ffa30000.gpu: Probed as mali0 [ 3.251163] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ' should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ' [ 3.251783] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ' should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ' [ 3.252338] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ' should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ' [ 3.253215] zram0: detected capacity change from 0 to 533413888 [ 3.264521] wifi_platform_bus_enumerate device present 1 [ 3.264534] ======== Card detection to detect SDIO card! ======== [ 3.264542] mmc2:mmc host rescan start! [ 3.299210] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS [ 3.324308] EXT4-fs (mmcblk0p13): Unrecognized mount option "background_gc=on" or missing value [ 3.331817] bat_cap: oldcap path is /sys/devices/ff100000.adc [ 3.331858] bat_cap: oldcap_path no exist [ 3.331985] binder: 145:145 transaction failed 29189, size 0-0 [ 3.332311] init: Warning! Service displayd needs a SELinux domain defined; please fix! [ 3.335917] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}' [ 3.335934] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial' [ 3.336108] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead [ 3.336484] rtk_btusb: btchr_open: BT usb char device is opening [ 3.336492] rtk_btusb: btchr_open: Failed to get hci dev[NULL] [ 3.336503] rtk_btusb: btchr_open: BT usb char device is opening [ 3.336509] rtk_btusb: btchr_open: Failed to get hci dev[NULL] [ 3.336523] rtk_btusb: btchr_open: BT usb char device is opening [ 3.336528] rtk_btusb: btchr_open: Failed to get hci dev[NULL] [ 3.336538] rtk_btusb: btchr_open: BT usb char device is opening [ 3.336542] rtk_btusb: btchr_open: Failed to get hci dev[NULL] [ 3.417019] logd.auditd: start [ 3.419660] init: cannot find '/system/bin/debuggerd64', disabling 'debuggerd64' [ 3.420982] init: cannot find '/system/bin/install-recovery.sh', disabling 'flash_recovery' [ 3.421357] init: cannot find '/system/bin/bplus_helper', disabling 'bplus_helper' [ 3.421565] init: Warning! Service drmservice needs a SELinux domain defined; please fix! [ 3.421786] init: cannot find '/system/bin/akmd', disabling 'akmd' [ 3.422842] android_usb: already disabled [ 3.425329] read descriptors [ 3.425343] read strings [ 3.425370] pcd_pullup, is_on 1 [ 3.480996] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2] [ 3.515760] mmc2: queuing unknown CIS tuple 0x80 (2 bytes) [ 3.517278] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) [ 3.518785] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) [ 3.521528] mmc2: queuing unknown CIS tuple 0x80 (7 bytes) [ 3.524883] mmc2: queuing unknown CIS tuple 0x81 (9 bytes) [ 3.609115] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [ 3.609139] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2] [ 3.609192] mmc2: error -110 whilst initialising SDIO card [ 3.628607] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84) [ 3.628619] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 600000Hz for init[mmc2] [ 3.665869] mmc2: queuing unknown CIS tuple 0x80 (2 bytes) [ 3.667859] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) [ 3.669860] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) [ 3.674025] mmc2: queuing unknown CIS tuple 0x80 (7 bytes) [ 3.678489] mmc2: queuing unknown CIS tuple 0x81 (9 bytes) [ 3.796599] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [ 3.796631] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2] [ 3.796694] mmc2: error -110 whilst initialising SDIO card [ 3.815574] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125) [ 3.815589] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 400000Hz for init[mmc2] [ 3.876629] rk3288-lcdc lcdc0: blank mode:0 [ 4.044485] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [ 4.044520] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2] [ 4.044578] mmc2: error -110 whilst initialising SDIO card [ 4.316670] healthd: No charger supplies found [ 4.316685] healthd: No battery devices found [ 5.232512] failed to power up DHD generic adapter, 0 retry left [ 5.248343] wifi_platform_set_power = 0 [ 5.248354] ======== PULL WL_REG_ON LOW! ======== [ 5.248360] [WLAN_RFKILL]: rockchip_wifi_power: 0 [ 5.350585] [WLAN_RFKILL]: wifi shut off power. [ 5.350598] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0 [ 5.350604] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled. [ 5.350611] wifi_platform_bus_enumerate device present 0 [ 5.350616] ======== Card detection to remove SDIO card! ======== [ 5.350621] mmc2:mmc host rescan start! [ 5.350634] failed to power up DHD generic adapter, max retry reached** [ 5.350654] unregister wifi platform drivers [ 5.350660] wifi_platform_bus_enumerate device present 0 [ 5.350664] ======== Card detection to remove SDIO card! ======== [ 5.350669] mmc2:mmc host rescan start! [ 5.350676] dhd_module_init: Failed to load the driver, try cnt 0 [ 5.350692] dhd_module_init: Failed to load driver max retry reached** [ 5.350697] dhd_module_init: Exit err=-19 [ 5.831427] warning: `system_server' uses 32-bit capabilities (legacy support in use) [ 7.329301] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.329324] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.329334] D1:camsys_open(739): camsys_marvin(ddd5e710) is opened! [ 7.329428] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 7.329443] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 7.329472] rockchip_gpio_request:GPIO7-13 [ 7.329483] rockchip_gpio_set:GPIO7-13 level = 1 [ 7.329490] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 7.329499] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0 [ 7.329509] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xf024,result=0xf024 [ 7.329517] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 7.329539] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8825) register success [ 7.334585] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 7.334596] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 7.334701] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 7.334730] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 7.335794] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 7.336848] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.337905] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 7.339961] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.340034] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 7.340044] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.340056] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 7.341152] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 7.341180] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 7.343239] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 7.343255] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 7.343266] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.343273] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.343281] D1:camsys_release(763): camsys_marvin(ddd5e710) is closed [ 7.349341] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.349354] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.349363] D1:camsys_open(739): camsys_marvin(ddd5e710) is opened! [ 7.349453] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 7.349467] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 7.349503] rockchip_gpio_set:GPIO7-13 level = 1 [ 7.349510] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 7.349520] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0 [ 7.349529] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xf024,result=0xf024 [ 7.349539] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 7.349553] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8858) register success [ 7.354596] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 7.354607] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 7.354712] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 7.354741] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 7.355804] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 7.356859] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.357916] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 7.359968] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.359979] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.360036] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 7.360046] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.360058] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 7.361146] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 7.361174] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 7.363225] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 7.363241] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 7.363251] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.363259] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.363267] D1:camsys_release(763): camsys_marvin(ddd5e710) is closed [ 7.367667] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.367680] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.367689] D1:camsys_open(739): camsys_marvin(ddd5e710) is opened! [ 7.367800] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 7.367814] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 7.367848] rockchip_gpio_set:GPIO7-13 level = 1 [ 7.367855] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 7.367865] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0 [ 7.367875] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xf024,result=0xf024 [ 7.367884] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 7.367897] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success [ 7.372955] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 7.372971] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 7.373077] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 7.373107] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 7.374177] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 7.375233] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.376301] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 7.378352] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.378362] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.378431] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 7.378442] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.378454] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 7.379540] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 7.379571] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 7.381627] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 7.381642] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 7.381652] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.381660] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.381668] D1:camsys_release(763): camsys_marvin(ddd5e710) is closed [ 7.385579] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.385590] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.385600] D1:camsys_open(739): camsys_marvin(ddd5e710) is opened! [ 7.385690] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 7.385704] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 7.385742] rockchip_gpio_set:GPIO7-13 level = 1 [ 7.385749] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 7.385758] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0 [ 7.385769] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xf024,result=0xf024 [ 7.385777] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 7.385791] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV5648) register success [ 7.390838] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 7.390849] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 7.390955] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 7.390983] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 7.392054] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 7.393112] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.394179] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 7.396229] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.396240] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.396301] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 7.396310] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.396322] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 7.397410] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 7.397437] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 7.399492] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 7.399508] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 7.399518] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.399526] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.399534] D1:camsys_release(763): camsys_marvin(ddd5e710) is closed [ 7.404646] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.404659] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.404668] D1:camsys_open(739): camsys_marvin(ddd5e710) is opened! [ 7.404757] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 1) for dev_id 0x1000000 success! [ 7.404771] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x1000000 success! [ 7.404781] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit [ 7.404878] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV2659) register success [ 7.409925] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 7.409937] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 7.410043] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 7.410071] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 7.411138] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 7.412200] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.413265] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 0 [ 7.415312] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.415387] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 1 [ 7.415399] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.415414] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 7.416499] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 7.416528] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 7.418592] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success [ 7.418611] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 7.418622] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.418630] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.418638] D1:camsys_release(763): camsys_marvin(ddd5e710) is closed [ 7.422935] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.422947] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.422956] D1:camsys_open(739): camsys_marvin(ddd5e710) is opened! [ 7.423051] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 7.423066] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 7.423075] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default [ 7.423101] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: TC358749XBG) register success [ 7.428147] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 7.428158] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 7.428264] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 7.428292] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on [ 7.429367] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 7.430423] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.431493] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 7.433550] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.433562] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.433632] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 7.433643] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.433656] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 7.434752] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 7.434783] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 7.436841] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 7.436857] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 7.436868] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.436876] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.436884] D1:camsys_release(763): camsys_marvin(ddd5e710) is closed [ 8.610621] healthd: battery none chg= [ 8.676527] [otg id chg] last id -1 current id 1 [ 8.676551] PortPower off [ 8.676559] rk_battery_charger_detect_cb , battery_charger_detect 6 [ 8.776193] Using Buffer DMA mode [ 8.776208] Periodic Transfer Interrupt Enhancement - disabled [ 8.776213] Multiprocessor Interrupt Enhancement - disabled [ 8.776219] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 8.776224] ^^^^^^^^^^^^^^^^^Device Mode [ 8.798582] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj: [ 8.798598] lowmemorykiller: oom_adj 0 => oom_score_adj 0 [ 8.798603] lowmemorykiller: oom_adj 1 => oom_score_adj 58 [ 8.798608] lowmemorykiller: oom_adj 2 => oom_score_adj 117 [ 8.798613] lowmemorykiller: oom_adj 3 => oom_score_adj 176 [ 8.798618] lowmemorykiller: oom_adj 9 => oom_score_adj 529 [ 8.798623] lowmemorykiller: oom_adj 15 => oom_score_adj 1000 [ 9.141542] acc_open [ 9.141567] acc_release [ 9.266916] ***************vbus detect***************** [ 9.269107] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 9.446158] Using Buffer DMA mode [ 9.446174] Periodic Transfer Interrupt Enhancement - disabled [ 9.446182] Multiprocessor Interrupt Enhancement - disabled [ 9.446189] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 9.446196] ^^^^^^^^^^^^^^^^^Device Mode [ 9.446237] *******************soft connect!!!******************* [ 9.561278] USB RESET [ 9.652114] android_work: sent uevent USB_STATE=CONNECTED [ 9.655846] USB RESET [ 9.775953] android_usb gadget: high-speed config #1: android [ 9.776068] android_work: sent uevent USB_STATE=CONFIGURED [ 10.223482] phy_power_on: enable = 1 [ 10.346534] Read the Ethernet MAC address from IDB:00:00:00:00:00:00 [ 10.346574] eth0: device MAC address 56:0b:fe:5a:f7:c6 [ 10.350805] libphy: stmmac: probed [ 10.350817] eth0: PHY ID 001cc916 at 0 IRQ 192 (stmmac-0:00) active [ 10.350824] eth0: PHY ID 001cc916 at 1 IRQ 192 (stmmac-0:01) active [ 10.693166] dwc_otg_hcd_resume, usb device mode [ 10.792288] dwc_otg_hcd_suspend, usb device mode [ 10.861049] usb 1-1: USB disconnect, device number 2 [ 11.136535] usb 1-1: new high-speed USB device number 3 using rockchip_ehci_host [ 11.164291] FAT-fs (mmcblk0p15): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 11.190904] init: no such service 'fuse_internal_sd' [ 11.284747] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101 [ 11.284769] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 11.284778] usb 1-1: Product: USB 2.0 Hub [ 11.285775] hub 1-1:1.0: USB hub found [ 11.286012] hub 1-1:1.0: 4 ports detected [ 11.558381] pm policy 0 -> 1 [ 12.723915] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.723934] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.723942] D1:camsys_open(739): camsys_marvin(ddd5e710) is opened! [ 12.724013] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 12.724025] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 12.724058] rockchip_gpio_set:GPIO7-13 level = 1 [ 12.724063] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 12.724072] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0 [ 12.724080] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xf024,result=0xf024 [ 12.724088] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 12.724107] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8825) register success [ 12.729146] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 12.729158] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 12.729263] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 12.729286] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 12.730349] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 12.731404] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.732465] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 12.734502] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.734560] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 12.734568] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.734579] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 12.735651] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 12.735670] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 12.737715] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 12.737726] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 12.737735] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.737741] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.737747] D1:camsys_release(763): camsys_marvin(ddd5e710) is closed [ 12.738400] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.738409] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.738416] D1:camsys_open(739): camsys_marvin(ddd5e710) is opened! [ 12.738485] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 12.738496] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 12.738527] rockchip_gpio_set:GPIO7-13 level = 1 [ 12.738532] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 12.738539] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0 [ 12.738548] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xf024,result=0xf024 [ 12.738555] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 12.738568] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8858) register success [ 12.743608] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 12.743620] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 12.743724] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 12.743748] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 12.744812] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 12.745831] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.746890] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 12.748928] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.748937] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.748996] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 12.749003] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.749014] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 12.750094] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 12.750117] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 12.752159] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 12.752171] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 12.752180] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.752186] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.752192] D1:camsys_release(763): camsys_marvin(ddd5e710) is closed [ 12.752762] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.752772] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.752779] D1:camsys_open(739): camsys_marvin(ddd5e710) is opened! [ 12.752845] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 12.752857] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 12.752888] rockchip_gpio_set:GPIO7-13 level = 1 [ 12.752893] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 12.752902] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0 [ 12.752910] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xf024,result=0xf024 [ 12.752917] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 12.752929] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success [ 12.757951] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 12.757959] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 12.758063] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 12.758081] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 12.759148] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 12.760204] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.761259] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 12.763298] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.763306] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.763355] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 12.763363] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.763373] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 12.764449] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 12.764473] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 12.766518] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 12.766528] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 12.766537] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.766543] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.766549] D1:camsys_release(763): camsys_marvin(ddd5e710) is closed [ 12.767065] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.767074] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.767080] D1:camsys_open(739): camsys_marvin(ddd5e710) is opened! [ 12.767146] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 12.767158] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 12.767187] rockchip_gpio_set:GPIO7-13 level = 1 [ 12.767193] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 12.767201] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0 [ 12.767209] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xf024,result=0xf024 [ 12.767216] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 12.767228] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV5648) register success [ 12.772244] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 12.772252] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 12.772357] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 12.772373] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 12.773431] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 12.774483] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.775542] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 12.777579] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.777586] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.777628] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 12.777636] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.777646] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 12.778718] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 12.778737] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 12.780779] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 12.780789] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 12.780796] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.780802] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.780808] D1:camsys_release(763): camsys_marvin(ddd5e710) is closed [ 12.781221] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.781229] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.781237] D1:camsys_open(739): camsys_marvin(ddd5e710) is opened! [ 12.781295] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 1) for dev_id 0x1000000 success! [ 12.781306] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x1000000 success! [ 12.781314] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit [ 12.781396] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV2659) register success [ 12.786415] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 12.786424] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 12.786528] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 12.786546] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 12.787604] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 12.788655] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.789716] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 0 [ 12.791757] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.791807] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 1 [ 12.791815] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.791825] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 12.792895] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 12.792914] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 12.794956] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success [ 12.794966] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 12.794974] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.794980] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.794986] D1:camsys_release(763): camsys_marvin(ddd5e710) is closed [ 12.795633] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.795643] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.795650] D1:camsys_open(739): camsys_marvin(ddd5e710) is opened! [ 12.795709] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 12.795720] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 12.795727] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default [ 12.795744] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: TC358749XBG) register success [ 12.800766] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 12.800774] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 12.800878] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 12.800897] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on [ 12.801956] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 12.803008] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.804063] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 12.806099] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.806106] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.806149] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 12.806157] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.806167] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 12.807238] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 12.807255] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 12.809304] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 12.809316] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 12.809324] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.809331] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.809337] D1:camsys_release(763): camsys_marvin(ddd5e710) is closed [ 12.818291] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.818303] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.818310] D1:camsys_open(739): camsys_marvin(ddd5e710) is opened! [ 12.818383] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 12.818395] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 12.818428] rockchip_gpio_set:GPIO7-13 level = 1 [ 12.818434] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 12.818442] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0 [ 12.818450] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xf024,result=0xf024 [ 12.818458] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 12.818476] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8825) register success [ 12.823510] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 12.823519] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 12.823624] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 12.823648] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 12.824712] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 12.825766] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.826821] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 12.828862] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.828921] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 12.828930] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.828940] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 12.830020] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 12.830046] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 12.832092] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 12.832104] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 12.832112] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.832118] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.832124] D1:camsys_release(763): camsys_marvin(ddd5e710) is closed [ 12.832756] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.832765] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.832771] D1:camsys_open(739): camsys_marvin(ddd5e710) is opened! [ 12.832841] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 12.832852] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 12.832881] rockchip_gpio_set:GPIO7-13 level = 1 [ 12.832887] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 12.832894] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0 [ 12.832902] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xf024,result=0xf024 [ 12.832909] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 12.832921] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8858) register success [ 12.837947] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 12.837955] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 12.838060] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 12.838080] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 12.839139] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 12.840191] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.841257] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 12.843298] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.843306] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.843354] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 12.843362] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.843372] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 12.844448] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 12.844472] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 12.846516] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 12.846529] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 12.846537] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.846543] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.846549] D1:camsys_release(763): camsys_marvin(ddd5e710) is closed [ 12.847069] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.847078] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.847085] D1:camsys_open(739): camsys_marvin(ddd5e710) is opened! [ 12.847150] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 12.847161] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 12.847189] rockchip_gpio_set:GPIO7-13 level = 1 [ 12.847195] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 12.847202] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0 [ 12.847210] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xf024,result=0xf024 [ 12.847216] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 12.847227] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success [ 12.852243] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 12.852251] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 12.852355] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 12.852372] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 12.853430] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 12.854482] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.855536] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 12.857592] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.857602] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.857662] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 12.857671] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.857682] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 12.858764] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 12.858795] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 12.860851] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 12.860866] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 12.860877] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.860883] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.860889] D1:camsys_release(763): camsys_marvin(ddd5e710) is closed [ 12.861494] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.861504] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.861512] D1:camsys_open(739): camsys_marvin(ddd5e710) is opened! [ 12.861582] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 12.861594] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 12.861630] rockchip_gpio_set:GPIO7-13 level = 1 [ 12.861635] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 12.861645] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0 [ 12.861654] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xf024,result=0xf024 [ 12.861662] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 12.861676] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV5648) register success [ 12.866703] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 12.866712] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 12.866817] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 12.866841] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 12.867898] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 12.868956] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.870012] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 12.872047] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.872055] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.872101] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 12.872109] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.872119] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 12.873163] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 12.873216] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 12.875274] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 12.875323] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 12.875346] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.875353] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.875360] D1:camsys_release(763): camsys_marvin(ddd5e710) is closed [ 12.876026] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.876036] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.876042] D1:camsys_open(739): camsys_marvin(ddd5e710) is opened! [ 12.876115] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 1) for dev_id 0x1000000 success! [ 12.876126] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x1000000 success! [ 12.876135] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit [ 12.876225] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV2659) register success [ 12.881255] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 12.881267] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 12.881371] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 12.881396] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 12.882457] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 12.883507] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.884560] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 0 [ 12.886596] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.886645] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 1 [ 12.886653] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.886663] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 12.887725] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 12.887743] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 12.889817] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success [ 12.889831] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 12.889841] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.889847] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.889854] D1:camsys_release(763): camsys_marvin(ddd5e710) is closed [ 12.890718] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.890730] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 12.890737] D1:camsys_open(739): camsys_marvin(ddd5e710) is opened! [ 12.890813] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 12.890832] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 12.890841] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default [ 12.890876] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: TC358749XBG) register success [ 12.895918] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 12.895929] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 12.896033] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 12.896058] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on [ 12.897128] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 12.898180] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.899236] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 12.901271] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.901279] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 12.901328] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 12.901336] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 12.901346] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 12.902409] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 12.902428] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 12.904470] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 12.904483] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 12.904492] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.904498] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 12.904505] D1:camsys_release(763): camsys_marvin(ddd5e710) is closed [ 31.937864] pcd_pullup, is_on 0 [ 31.957026] read descriptors [ 31.957152] read strings [ 31.957291] pcd_pullup, is_on 1 [ 32.893082] **************soft reconnect************** [ 33.072995] Using Buffer DMA mode [ 33.073010] Periodic Transfer Interrupt Enhancement - disabled [ 33.073019] Multiprocessor Interrupt Enhancement - disabled [ 33.073027] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 33.073034] ^^^^^^^^^^^^^^^^^Device Mode [ 33.073075] *******************soft connect!!!******************* [ 33.187588] USB RESET [ 33.281782] USB RESET [ 33.398362] android_usb gadget: high-speed config #1: android [ 33.399309] android_work: sent uevent USB_STATE=CONFIGURED [ 42.461677] rk3288-lcdc lcdc0: blank mode:4 [ 42.480861] suspend_flag=1 [ 42.486871] CPU1: shutdown [ 45.019458] suspend_flag=1 [ 45.036656] CPU1: Booted secondary processor [ 45.069876] rk32-edp rk32-edp: edp pll locked [ 45.069889] rk32_edp_init_aux [ 45.069894] rk32_edp_reset_aux [ 45.070518] rk32_edp_init_training rate:10Gps lanes:2 [ 45.070529] rk32-edp rk32-edp: max link rate:2.70Gps max number of lanes:2 [ 45.074491] rk32-edp rk32-edp: link training success. [ 45.128755] rk3288-lcdc lcdc0: blank mode:0
loading 发表于 2017-3-15 18:32
把内核log 贴出来看看
另外还有个现象就是 休眠唤醒休眠唤醒之后的现象之后屏幕显示这样,
把内核log 贴出来看看
从log看,edp 驱动加载也正常
试试在dts 里面把logo 这个关掉
loading 发表于 2017-3-20 13:34
从log看,edp 驱动加载也正常
试试在dts 里面把logo 这个关掉
修改rockchip,uboot-logo-on = <0>,将logo关掉 现象也还是一样
我另外点过一个1366x768的edp屏 那个是可以正常点亮的,两个屏唯一的区别就是:1366x768的是1lane的 1920x1080的是2lane的
abcxyztt 发表于 2017-3-20 14:50
那就应该要改驱动了
改驱动?要怎么改?刚刚接触rk3288 不是很熟悉
从log看,edp 驱动加载也正常
试试在dts 里面把logo 这个关掉
我看你之前好像在rk3399上调试过一款N133HSG 1920x1080p edp的显示屏,也是2lane的吧? 请问下硬件上接线有什么注意的地方吗?
xi0325 发表于 2017-3-20 15:17
我看你之前好像在rk3399上调试过一款N133HSG 1920x1080p edp的显示屏,也是2lane的吧? 请问下硬件上接线 …
按定义来就可以,你是完整的屏线还是飞线?
可以修改这个地方试试
kernel/drivers/video/rockchip/transmitter/rk32_dp.c
  • edp->video_info.link_rate = LINK_RATE_1_62GBPS;
  • edp->video_info.lane_count = LANE_CNT4;
  • edp->video_info.link_rate = LINK_RATE_2_70GBPS;
  • edp->video_info.lane_count = LANE_CNT2;
谢谢分享 赞一个
可以修改这个地方试试
kernel/drivers/video/rockchip/transm …
是飞线的,
可以修改这个地方试试
按你说的修改之后 现象还是一样
但我这边发现个现象,反复休眠唤醒之后 偶尔能显示正常,我怀疑是上电时序的问题,请问下你知道edp的上电时序大概在哪吗?
xi0325 发表于 2017-3-20 19:20
按你说的修改之后 现象还是一样
但我这边发现个现象,反复休眠唤醒之后 偶尔能显示正常,我怀疑是上电 …
就这个文件里面。。。kernel/drivers/video/rockchip/transmitter/rk32_dp.c
偶然能显示,,会不会是飞线有干扰呢?
我自己飞的3399-edp,,,刚开始也是只有背光两,,然后碰一下线又亮了,,结果发现是飞线有干扰导致的,拿导电胶布包一下就好了
偶然能显示,,会不会是飞 …
应该不是飞线有干扰,我尝试将3.3v的电,休眠的时候也不关闭的话 反复休眠唤醒都能正常显示了
我猜想应该是数据信号出来早了,电供的太晚。
能否详细说明下在哪个函数里边吗?
我猜想应 …
—> 加打印看看,,我也不太清楚了,,
—> 加打印看看,,我也不太清楚了,,
我在rk3288_lcdc_clk_enable(lcdc_dev)之前添加延时,现在休眠唤醒正常,但是开机仍只亮背光,后边尝试将dts里边的uboot-logo-on改为0,开机过程能显示开机动画了,但是无法显示开机logo。
uboot-logo-on置0后,要怎样操作才能显示开机logo??
menuconfig 里面打开bootup logo 里面standard 224 xxx 那个
