firefly 4.4桌面一直崩溃问题
本人使用的rk3288的开发板,android 4.4系统。总管有10块开发板,在测试的过程中,发现android 4.4的桌面程序Launcher3在四块板子上出了"Launcher3 已经停止运行“ 点击确定后 依然弹出此窗口。往复循环,无法关闭此此窗口。
无奈只有刷机解决。但是这个问题就是一块定时炸弹,现在贴出日志及问题图片。望各位广大同志帮忙找出问题原因。
问题图片
日志:
I/installd( 1261): installd firing up
E/installd( 1261): Could not create directories; exiting.
I/installd( 1263): installd firing up
E/installd( 1263): Could not create directories; exiting.
I/installd( 1267): installd firing up
E/installd( 1267): Could not create directories; exiting.
I/installd( 1270): installd firing up
E/installd( 1270): Could not create directories; exiting.
I/installd( 1271): installd firing up
E/installd( 1271): Could not create directories; exiting.
I/installd( 1272): installd firing up
E/installd( 1272): Could not create directories; exiting.
I/installd( 1273): installd firing up
E/installd( 1273): Could not create directories; exiting.
I/installd( 1274): installd firing up
E/installd( 1274): Could not create directories; exiting.
I/installd( 1276): installd firing up
E/installd( 1276): Could not create directories; exiting.
I/installd( 1277): installd firing up
E/installd( 1277): Could not create directories; exiting.
I/installd( 1278): installd firing up
E/installd( 1278): Could not create directories; exiting.
I/installd( 1282): installd firing up
E/installd( 1282): Could not create directories; exiting.
I/installd( 1283): installd firing up
E/installd( 1283): Could not create directories; exiting.
I/installd( 1284): installd firing up
E/installd( 1284): Could not create directories; exiting.
I/installd( 1285): installd firing up
E/installd( 1285): Could not create directories; exiting.
I/installd( 1286): installd firing up
E/installd( 1286): Could not create directories; exiting.
I/installd( 1287): installd firing up
E/installd( 1287): Could not create directories; exiting.
I/installd( 1288): installd firing up
E/installd( 1288): Could not create directories; exiting.
I/installd( 1289): installd firing up
E/installd( 1289): Could not create directories; exiting.
I/installd( 1291): installd firing up
E/installd( 1291): Could not create directories; exiting.
I/installd( 1295): installd firing up
E/installd( 1295): Could not create directories; exiting.
I/installd( 1296): installd firing up
E/installd( 1296): Could not create directories; exiting.
I/installd( 1297): installd firing up
E/installd( 1297): Could not create directories; exiting.
I/installd( 1298): installd firing up
E/installd( 1298): Could not create directories; exiting.
I/installd( 1299): installd firing up
E/installd( 1299): Could not create directories; exiting.
I/installd( 1300): installd firing up
E/installd( 1300): Could not create directories; exiting.
I/installd( 1301): installd firing up
E/installd( 1301): Could not create directories; exiting.
I/installd( 1302): installd firing up
E/installd( 1302): Could not create directories; exiting.
I/installd( 1303): installd firing up
E/installd( 1303): Could not create directories; exiting.
I/installd( 1304): installd firing up
E/installd( 1304): Could not create directories; exiting.
I/installd( 1305): installd firing up
E/installd( 1305): Could not create directories; exiting.
I/installd( 1306): installd firing up
E/installd( 1306): Could not create directories; exiting.
I/installd( 1307): installd firing up
E/installd( 1307): Could not create directories; exiting.
I/installd( 1308): installd firing up
E/installd( 1308): Could not create directories; exiting.
I/installd( 1309): installd firing up
E/installd( 1309): Could not create directories; exiting.
I/installd( 1310): installd firing up
E/installd( 1310): Could not create directories; exiting.
I/installd( 1311): installd firing up
E/installd( 1311): Could not create directories; exiting.
I/installd( 1312): installd firing up
E/installd( 1312): Could not create directories; exiting.
I/Process ( 1213): Sending signal. PID: 1213 SIG: 9
I/ActivityManager( 477): Process com.android.launcher3 (pid 1213) has died.
I/ActivityManager( 477): Start proc com.android.launcher3 for activity com.android.launcher3/.Launcher: pid=1313 uid=10030 gids={50030, 1028}
W/ContextImpl( 1313): Unable to create cache directory /data/user/0/com.android.launcher3/cache
E/ActivityThread( 1313): Unable to setupGraphicsSupport due to missing cache directory
E/SQLiteLog( 1313): (14) cannot open file at line 30191 of [00bb9c9ce4]
E/SQLiteLog( 1313): (14) os_unix.c:30191: (5) open(/data/user/0/com.android.launcher3/databases/launcher.db) -
E/SQLiteDatabase( 1313): Failed to open database ‘/data/user/0/com.android.launcher3/databases/launcher.db’.
E/SQLiteDatabase( 1313): android.database.sqlite.SQLiteCantOpenDatabaseException: unknown error (code 14): Could not open database
E/SQLiteDatabase( 1313): at android.database.sqlite.SQLiteConnection.nativeOpen(Native Method)
E/SQLiteDatabase( 1313): at android.database.sqlite.SQLiteConnection.open(SQLiteConnection.java:209)
E/SQLiteDatabase( 1313): at android.database.sqlite.SQLiteConnection.open(SQLiteConnection.java:193)
E/SQLiteDatabase( 1313): at android.database.sqlite.SQLiteConnectionPool.openConnectionLocked(SQLiteConnectionPool.java:463)
E/SQLiteDatabase( 1313): at android.database.sqlite.SQLiteConnectionPool.open(SQLiteConnectionPool.java:185)
E/SQLiteDatabase( 1313): at android.database.sqlite.SQLiteConnectionPool.open(SQLiteConnectionPool.java:177)
E/SQLiteDatabase( 1313): at android.database.sqlite.SQLiteDatabase.openInner(SQLiteDatabase.java:804)
E/SQLiteDatabase( 1313): at android.database.sqlite.SQLiteDatabase.open(SQLiteDatabase.java:789)
E/SQLiteDatabase( 1313): at android.database.sqlite.SQLiteDatabase.openDatabase(SQLiteDatabase.java:694)
E/SQLiteDatabase( 1313): at android.app.ContextImpl.openOrCreateDatabase(ContextImpl.java:959)
E/SQLiteDatabase( 1313): at android.content.ContextWrapper.openOrCreateDatabase(ContextWrapper.java:256)
E/SQLiteDatabase( 1313): at android.database.sqlite.SQLiteOpenHelper.getDatabaseLocked(SQLiteOpenHelper.java:224)
E/SQLiteDatabase( 1313): at android.database.sqlite.SQLiteOpenHelper.getWritableDatabase(SQLiteOpenHelper.java:164)
E/SQLiteDatabase( 1313): at com.android.launcher3.LauncherProvider$DatabaseHelper.(LauncherProvider.java:314)
E/SQLiteDatabase( 1313): at com.android.launcher3.LauncherProvider.onCreate(LauncherProvider.java:101)
E/SQLiteDatabase( 1313): at android.content.ContentProvider.attachInfo(ContentProvider.java:1591)
E/SQLiteDatabase( 1313): at android.content.ContentProvider.attachInfo(ContentProvider.java:1562)
E/SQLiteDatabase( 1313): at android.app.ActivityThread.installProvider(ActivityThread.java:4790)
E/SQLiteDatabase( 1313): at android.app.ActivityThread.installContentProviders(ActivityThread.java:4385)
E/SQLiteDatabase( 1313): at android.app.ActivityThread.handleBindApplication(ActivityThread.java:4325)
E/SQLiteDatabase( 1313): at android.app.ActivityThread.access$1500(ActivityThread.java:135)
E/SQLiteDatabase( 1313): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1256)
E/SQLiteDatabase( 1313): at android.os.Handler.dispatchMessage(Handler.java:102)
E/SQLiteDatabase( 1313): at android.os.Looper.loop(Looper.java:136)
E/SQLiteDatabase( 1313): at android.app.ActivityThread.main(ActivityThread.java:5017)
E/SQLiteDatabase( 1313): at java.lang.reflect.Method.invokeNative(Native Method)
E/SQLiteDatabase( 1313): at java.lang.reflect.Method.invoke(Method.java:515)
E/SQLiteDatabase( 1313): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:794)
E/SQLiteDatabase( 1313): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:610)
E/SQLiteDatabase( 1313): at dalvik.system.NativeStart.main(Native Method)
D/AndroidRuntime( 1313): Shutting down VM
W/dalvikvm( 1313): threadid=1: thread exiting with uncaught exception (group=0x415c9300)
E/AndroidRuntime( 1313): FATAL EXCEPTION: main
E/AndroidRuntime( 1313): Process: com.android.launcher3, PID: 1313
E/AndroidRuntime( 1313): java.lang.RuntimeException: Unable to get provider com.android.launcher3.LauncherProvider: android.database.sqlite.SQLiteCantOpenDatabaseException: unknown error (code 14): Could not open database
E/AndroidRuntime( 1313): at android.app.ActivityThread.installProvider(ActivityThread.java:4793)
E/AndroidRuntime( 1313): at android.app.ActivityThread.installContentProviders(ActivityThread.java:4385)
E/AndroidRuntime( 1313): at android.app.ActivityThread.handleBindApplication(ActivityThread.java:4325)
E/AndroidRuntime( 1313): at android.app.ActivityThread.access$1500(ActivityThread.java:135)
E/AndroidRuntime( 1313): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1256)
E/AndroidRuntime( 1313): at android.os.Handler.dispatchMessage(Handler.java:102)
E/AndroidRuntime( 1313): at android.os.Looper.loop(Looper.java:136)
E/AndroidRuntime( 1313): at android.app.ActivityThread.main(ActivityThread.java:5017)
E/AndroidRuntime( 1313): at java.lang.reflect.Method.invokeNative(Native Method)
E/AndroidRuntime( 1313): at java.lang.reflect.Method.invoke(Method.java:515)
E/AndroidRuntime( 1313): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:794)
E/AndroidRuntime( 1313): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:610)
E/AndroidRuntime( 1313): at dalvik.system.NativeStart.main(Native Method)
E/AndroidRuntime( 1313): Caused by: android.database.sqlite.SQLiteCantOpenDatabaseException: unknown error (code 14): Could not open database
E/AndroidRuntime( 1313): at android.database.sqlite.SQLiteConnection.nativeOpen(Native Method)
E/AndroidRuntime( 1313): at android.database.sqlite.SQLiteConnection.open(SQLiteConnection.java:209)
E/AndroidRuntime( 1313): at android.database.sqlite.SQLiteConnection.open(SQLiteConnection.java:193)
E/AndroidRuntime( 1313): at android.database.sqlite.SQLiteConnectionPool.openConnectionLocked(SQLiteConnectionPool.java:463)
E/AndroidRuntime( 1313): at android.database.sqlite.SQLiteConnectionPool.open(SQLiteConnectionPool.java:185)
E/AndroidRuntime( 1313): at android.database.sqlite.SQLiteConnectionPool.open(SQLiteConnectionPool.java:177)
E/AndroidRuntime( 1313): at android.database.sqlite.SQLiteDatabase.openInner(SQLiteDatabase.java:804)
E/AndroidRuntime( 1313): at android.database.sqlite.SQLiteDatabase.open(SQLiteDatabase.java:789)
E/AndroidRuntime( 1313): at android.database.sqlite.SQLiteDatabase.openDatabase(SQLiteDatabase.java:694)
E/AndroidRuntime( 1313): at android.app.ContextImpl.openOrCreateDatabase(ContextImpl.java:959)
E/AndroidRuntime( 1313): at android.content.ContextWrapper.openOrCreateDatabase(ContextWrapper.java:256)
E/AndroidRuntime( 1313): at android.database.sqlite.SQLiteOpenHelper.getDatabaseLocked(SQLiteOpenHelper.java:224)
E/AndroidRuntime( 1313): at android.database.sqlite.SQLiteOpenHelper.getWritableDatabase(SQLiteOpenHelper.java:164)
E/AndroidRuntime( 1313): at com.android.launcher3.LauncherProvider$DatabaseHelper.(LauncherProvider.java:314)
E/AndroidRuntime( 1313): at com.android.launcher3.LauncherProvider.onCreate(LauncherProvider.java:101)
E/AndroidRuntime( 1313): at android.content.ContentProvider.attachInfo(ContentProvider.java:1591)
E/AndroidRuntime( 1313): at android.content.ContentProvider.attachInfo(ContentProvider.java:1562)
E/AndroidRuntime( 1313): at android.app.ActivityThread.installProvider(ActivityThread.java:4790)
E/AndroidRuntime( 1313): … 12 more
W/ActivityManager( 477): Force finishing activity com.android.launcher3/.Launcher
W/gralloc ( 141): Debugmem The fd=73, in vmalloc !!! Ishwc=0
W/ActivityManager( 477): Activity pause timeout for ActivityRecord{419e5148 u0 com.android.launcher3/.Launcher t7 f}
I/ActivityManager( 477): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.launcher3/.Launcher} from pid 0
W/gralloc ( 141): Debugmem The fd=49, in vmalloc !!! Ishwc=0
W/gralloc ( 141): Debugmem The fd=60, in vmalloc !!! Ishwc=0
I/installd( 1327): installd firing up
E/installd( 1327): Could not create directories; exiting.
I/installd( 1328): installd firing up
E/installd( 1328): Could not create directories; exiting.
W/ActivityManager( 477): Launch timeout has expired, giving up wake lock!
I/installd( 1329): installd firing up
E/installd( 1329): Could not create directories; exiting.
I/installd( 1330): installd firing up
E/installd( 1330): Could not create directories; exiting.
W/ActivityManager( 477): Activity destroy timeout for ActivityRecord{419e5148 u0 com.android.launcher3/.Launcher t7 f}
I/installd( 1331): installd firing up
E/installd( 1331): Could not create directories; exiting.
I/installd( 1332): installd firing up
E/installd( 1332): Could not create directories; exiting.
I/installd( 1333): installd firing up
E/installd( 1333): Could not create directories; exiting.
I/installd( 1334): installd firing up
E/installd( 1334): Could not create directories; exiting.
I/installd( 1336): installd firing up
E/installd( 1336): Could not create directories; exiting.
I/installd( 1337): installd firing up
E/installd( 1337): Could not create directories; exiting.
I/installd( 1338): installd firing up
E/installd( 1338): Could not create directories; exiting.
I/installd( 1339): installd firing up
E/installd( 1339): Could not create directories; exiting.
I/installd( 1340): installd firing up
E/installd( 1340): Could not create directories; exiting.
I/installd( 1341): installd firing up
E/installd( 1341): Could not create directories; exiting.
I/installd( 1342): installd firing up
E/installd( 1342): Could not create directories; exiting.
I/installd( 1343): installd firing up
E/installd( 1343): Could not create directories; exiting.
I/installd( 1344): installd firing up
E/installd( 1344): Could not create directories; exiting.
I/installd( 1345): installd firing up
E/installd( 1345): Could not create directories; exiting.
I/installd( 1346): installd firing up
E/installd( 1346): Could not create directories; exiting.
I/installd( 1347): installd firing up
E/installd( 1347): Could not create directories; exiting.
I/installd( 1348): installd firing up
E/installd( 1348): Could not create directories; exiting.
I/installd( 1349): installd firing up
E/installd( 1349): Could not create directories; exiting.
I/installd( 1350): installd firing up
E/installd( 1350): Could not create directories; exiting.
I/installd( 1351): installd firing up
E/installd( 1351): Could not create directories; exiting.
I/installd( 1352): installd firing up
E/installd( 1352): Could not create directories; exiting.
I/installd( 1353): installd firing up
E/installd( 1353): Could not create directories; exiting.
I/installd( 1354): installd firing up
E/installd( 1354): Could not create directories; exiting.
I/installd( 1355): installd firing up
E/installd( 1355): Could not create directories; exiting.
I/installd( 1356): installd firing up
E/installd( 1356): Could not create directories; exiting.
I/installd( 1357): installd firing up
E/installd( 1357): Could not create directories; exiting.
通过adb shell 无法进入 /data/user/目录 错误原因 I/O errer
