有谁调过显示屏转换IC??
我现在在rk3288上边调试一款mipi转edp的转换ic,有谁调试过显示屏转换IC的,能否传授下经验~~~~
方便把你代码贴上来吗?
loading 发表于 2017-3-23 18:49
方便把你代码贴上来吗?
// I2C_Adr = 0x52;// bit0 是读写标志位;如果是Linux系统,IIC address 的 bit7作为读写标志位,则I2C_Adr 应该是 0x29;
// IIC速率不要超过100KHz
// 刷寄存器之前,先Reset LT8911/B ,用GPIO 先拉低LT8911/B的复位脚 150ms左右,再拉高,保持150ms
LT8911/LT8911B mipi输入格式、要求:
1,non-burst mode(continue mode)
2,Video mode
3,sync event
4,MIPI DSI
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/fb.h>
#include <linux/fs.h>
#include <linux/rk_fb.h>
#include <linux/seq_file.h>
#include <linux/time.h>
#include <linux/delay.h>
#include <linux/slab.h>
#include <linux/device.h>
#include <linux/i2c.h>
#include <linux/gpio.h>
#include <linux/debugfs.h>
#include <linux/of_gpio.h>
#include <linux/rk_screen.h>
#include “mipi_dsi.h”
#include “anx6345.h”
#include “lt8911.h”
#include “dpcd_edid.h”
#if defined(CONFIG_HAS_EARLYSUSPEND)
#include <linux/earlysuspend.h>
#endif
//#define Test_Pattern
#define MODULE_NAME “LT8911”
#define MODULE_I2C_ADDR (0x52>>1)//(0xE0>>1)
static struct i2c_client *lt8911_client = NULL;
static struct lt8911 *lt8911;
//#define 1080P_eDP_Panel
#define 1366x768_eDP_Panel
//#define 1280x800_eDP_Panel
#define MIPI_Lane 4 // MIPI Lane 1,2,4
//#ifdef 1080P_eDP_Panel
// 根据前端MIPI信号的Timing,修改以下参数:
//static int MIPI_Timing =
//H_act V_act H_total V_total H_BP H_sync V_sync V_BP
// {1920, 1080, 2200, 1125, 148, 44, 5, 36};// 1080P Vesa Timing
// {1920, 1080, 2080, 1111, 80, 32, 5, 16};
//#define 2_Lane
// #define 8_Bit_ColorDepth // eDP panel Color Depth,16.7M color
//#define 6_Bit_ColorDepth // eDP panel Color Depth,262K color
//#endif
//#ifdef 1280x800_eDP_Panel
// {1280, 800, 1440, 823, 80, 32, 6, 14};// _1280x800 Vesa Timing
//#define 1_Lane
//#endif
#ifdef 1366x768_eDP_Panel
{1368, 768, 1592, 800, 104, 48, 6, 23};// 1366x768 VESA Timing
#define 1_Lane
#endif
enum
H_act = 0,
V_act,
H_tol,
V_tol,
H_bp,
H_sync,
V_sync,
V_bp
u8 swing_req=0x00;
#define Swing_Level_Close 0x00
#define Swing_Level_0_H 0x00
#define Swing_Level_0_L 0xa0
#define Swing_Level_1_H 0x00
#define Swing_Level_1_L 0xf0
#define Swing_Level_2_H 0x01
#define Swing_Level_2_L 0x40
#define Swing_Level_3_H 0x02
#define Swing_Level_3_L 0xb4
static u8 DPCD0000H;
static u8 DPCD0001H;
static u8 DPCD0002H;
static u8 DPCD0003H;
static u8 DPCD0004H;
static u8 DPCD0005H;
static u8 DPCD0006H;
static u8 DPCD0007H;
static u8 DPCD0008H;
static u8 DPCD0009H;
static u8 DPCD000aH;
static u8 DPCD000bH;
static u8 DPCD0200H;
static u8 DPCD0201H;
u8 DPCD0202H;
static u8 DPCD0203H;
static u8 DPCD0204H;
static u8 DPCD0205H;
u8 DPCD0206H;
static int i2c_master_reg8_send(const struct i2c_client *client,
const char reg, const char *buf, int count, int scl_rate)
struct i2c_adapter *adap=client->adapter;
struct i2c_msg msg;
int ret;
char *tx_buf = (char *)kmalloc(count + 1, GFP_KERNEL);
if(!tx_buf)
return -ENOMEM;
tx_buf[0] = reg;
memcpy(tx_buf+1, buf, count);
    msg.addr = client->addr;
    msg.flags = client->flags;
    msg.len = count + 1;
    msg.buf = (char *)tx_buf;
    msg.scl_rate = scl_rate;
    ret = i2c_transfer(adap, &msg, 1);
    kfree(tx_buf);
    return (ret == 1) ? count : ret;
static int i2c_master_reg8_recv(const struct i2c_client *client,
const char reg, char *buf, int count, int scl_rate)
struct i2c_msg msgs[2];
int ret;
char reg_buf = reg;
    msgs[0].addr = client->addr;
    msgs[0].flags = client->flags;
    msgs[0].len = 1;
    msgs[0].buf = &reg_buf;
    msgs[0].scl_rate = scl_rate;
    msgs[1].addr = client->addr;
    msgs[1].flags = client->flags | I2C_M_RD;
    msgs[1].len = count;
    msgs[1].buf = (char *)buf;
    msgs[1].scl_rate = scl_rate;
    ret = i2c_transfer(adap, msgs, 2);
    return (ret == 2)? count : ret;
static u8 HDMI_ReadI2C_Byte(unsigned char reg_addr)
u8 dummy;
unsigned char addr;
unsigned char val;
addr = reg_addr;
//dummy = i2c_smbus_read_byte_data(lt8911_client, addr);
//printk(“HDMI_ReadI2C_Byte dummy=%d\n”,dummy);
dummy = i2c_master_reg8_recv(lt8911_client, addr, &val, 1, LT8911_SCL_RATE);
//dummy = i2c_master_recv(addr, &val, 1);
if (dummy < 0)
return -1;
return dummy & 0x000000ff;
HDMI_WriteI2C_Byte
lt8911_smbus_write_byte(unsigned char reg_addr, unsigned char data)
static int HDMI_WriteI2C_Byte(unsigned char reg_addr, unsigned char data)
s32 dummy;
unsigned char addr;
//unsigned char *tmp;
addr = reg_addr;
//tmp = &data;
//dummy = i2c_smbus_write_byte_data(lt8911_client, addr, *tmp);
//printk(“HDMI_WriteI2C_Byte dummy=%d addr=0x%x tmp=0x%x\n”,dummy,addr,tmp);
dummy = i2c_master_reg8_send(lt8911_client, addr, &data, 1, LT8911_SCL_RATE);
//dummy = i2c_master_send(addr, &data, 1);
if (dummy < 0)
return -1;
return 0;
void DpcdWrite(u32 Address, u8 Data)
u8 AddressH = 0x0f & (Address>>16);
u8 AddressM = 0xff & (Address>>8);
u8 AddressL = 0xff & Address ;
HDMI_WriteI2C_Byte(0xff,0x80);
HDMI_WriteI2C_Byte(0x36,0x00);
HDMI_WriteI2C_Byte(0x30,0x0e);// 0x11
HDMI_WriteI2C_Byte(0x33,AddressL);
HDMI_WriteI2C_Byte(0x34,AddressM);
HDMI_WriteI2C_Byte(0x35,AddressH);
HDMI_WriteI2C_Byte(0x37,Data);
HDMI_WriteI2C_Byte(0x36,0x20);
u8 DpcdRead(u32 Address)
u8 read_cnt=0x03;
u8 DpcdValue = 0x00;
HDMI_WriteI2C_Byte(0x30,0x8e);// 0x91
mdelay(2); //必要的
if(HDMI_ReadI2C_Byte(0x39)==0x01)
	DpcdValue = HDMI_ReadI2C_Byte(0x38);
else
	while((HDMI_ReadI2C_Byte(0x39)!=0x01)&&(read_cnt>0))
		read_cnt--;
		mdelay(2);
return DpcdValue;
void adj_swing(void)
swing_req=DPCD0206H&0x0f; //lane 0
HDMI_WriteI2C_Byte(0xff,0x81);
switch(swing_req)
case 0x00:
HDMI_WriteI2C_Byte(0x18,Swing_Level_0_H);
HDMI_WriteI2C_Byte(0x19,Swing_Level_0_L);
DpcdWrite(0x0103,0x00);
break;
	case 0x01:
		HDMI_WriteI2C_Byte(0x18,Swing_Level_1_H);
		HDMI_WriteI2C_Byte(0x19,Swing_Level_1_L);
		DpcdWrite(0x0103,0x01);
		break;
	case 0x02:
		HDMI_WriteI2C_Byte(0x18,Swing_Level_2_H);
		HDMI_WriteI2C_Byte(0x19,Swing_Level_2_L);
		DpcdWrite(0x0103,0x02);
		break;
	case 0x03:
		HDMI_WriteI2C_Byte(0x18,Swing_Level_3_H);
		HDMI_WriteI2C_Byte(0x19,Swing_Level_3_L);
		DpcdWrite(0x0103,0x07);
		break;
	case 0x04:
		DpcdWrite(0x0103,0x08);
		break;
	case 0x05:
		DpcdWrite(0x0103,0x09);
		break;
	case 0x06:
		DpcdWrite(0x0103,0x0a);
		break;
	case 0x07:
		DpcdWrite(0x0103,0x0f);
		break;
	case 0x08:
		DpcdWrite(0x0103,0x10);
		break;
	case 0x09:
		DpcdWrite(0x0103,0x11);
		break;
	case 0x0a:
		DpcdWrite(0x0103,0x12);
		break;
	case 0x0b:
		DpcdWrite(0x0103,0x17);
		break;
	case 0x0c:
		DpcdWrite(0x0103,0x38);
		break;
	case 0x0d:
		DpcdWrite(0x0103,0x39);
		break;
	case 0x0e:
		DpcdWrite(0x0103,0x3a);
		break;
	case 0x0f:
		DpcdWrite(0x0103,0x3f);
		break;
	default:   break;
#ifdef _2_Lane_
	swing_req=DPCD0206H&0xf0;      //lane 1
	switch(swing_req)
	case 0x00:
		HDMI_WriteI2C_Byte(0x1a,Swing_Level_0_H);
		HDMI_WriteI2C_Byte(0x1b,Swing_Level_0_L);
		DpcdWrite(0x0104,0x00);
		break;
	case 0x10:
		HDMI_WriteI2C_Byte(0x1a,Swing_Level_1_H);
		HDMI_WriteI2C_Byte(0x1b,Swing_Level_1_L);
		DpcdWrite(0x0104,0x01);
		break;
	case 0x20:
		HDMI_WriteI2C_Byte(0x1a,Swing_Level_2_H);
		HDMI_WriteI2C_Byte(0x1b,Swing_Level_2_L);
		DpcdWrite(0x0104,0x02);
		break;
	case 0x30:
		HDMI_WriteI2C_Byte(0x1a,Swing_Level_3_H);
		HDMI_WriteI2C_Byte(0x1b,Swing_Level_3_L);
		DpcdWrite(0x0104,0x07);
		break;
	case 0x40:
		DpcdWrite(0x0104,0x08);
		break;
	case 0x50:
		DpcdWrite(0x0104,0x09);
		break;
	case 0x60:
		DpcdWrite(0x0104,0x0a);
		break;
	case 0x70:
		DpcdWrite(0x0104,0x0f);
		break;
	case 0x80:
		DpcdWrite(0x0104,0x10);
		break;
	case 0x90:
		DpcdWrite(0x0104,0x11);
		break;
	case 0xa0:
		DpcdWrite(0x0104,0x12);
		break;
	case 0xb0:
		DpcdWrite(0x0104,0x17);
		break;
	case 0xc0:
		DpcdWrite(0x0104,0x38);
		break;
	case 0xd0:
		DpcdWrite(0x0104,0x39);
		break;
	case 0xe0:
		DpcdWrite(0x0104,0x3a);
		break;
	case 0xf0:
		DpcdWrite(0x0104,0x3f);  break;
	default:   break;
#endif
void LT8911_AUX_Training(void)
u8 swing_adj_cnt=0x00;
DPCD0202H=0x00;
DPCD0000H=DpcdRead(0x0000);
DPCD0200H=DpcdRead(0x0200);
DPCD0201H=DpcdRead(0x0201);
DPCD0202H=DpcdRead(0x0202);
DPCD0203H=DpcdRead(0x0203);
DPCD0204H=DpcdRead(0x0204);
DPCD0205H=DpcdRead(0x0205);
DPCD0001H=DpcdRead(0x0001);
DPCD0002H=DpcdRead(0x0002);
DPCD0003H=DpcdRead(0x0003);
DPCD0004H=DpcdRead(0x0004);
DPCD0005H=DpcdRead(0x0005);
DPCD0006H=DpcdRead(0x0006);
DPCD0007H=DpcdRead(0x0007);
DPCD0008H=DpcdRead(0x0008);
DPCD0009H=DpcdRead(0x0009);
DPCD000aH=DpcdRead(0x000a);
DPCD000bH=DpcdRead(0x000b);
HDMI_WriteI2C_Byte(0xff,0x80);//register bank
HDMI_WriteI2C_Byte(0x62,0x3f); //Reset dp video
#ifdef 2_Lane
HDMI_WriteI2C_Byte(0x03,0x42); //41-1lane,42-2lane,44-4lane
#endif
#ifdef 1_Lane
HDMI_WriteI2C_Byte(0x03,0x41); //41-1lane,42-2lane,44-4lane
#endif
HDMI_WriteI2C_Byte(0x04,0x14);
HDMI_WriteI2C_Byte(0xff,0x84);  //register bank
HDMI_WriteI2C_Byte(0x14,0x01);
HDMI_WriteI2C_Byte(0x14,0x81);
HDMI_WriteI2C_Byte(0x14,0x82);
DpcdWrite(0x0600,0x01);
if(DpcdRead(0x0600)!=0x01)
DpcdWrite(0x0100,0x0a);
#ifdef 2_Lane
DpcdWrite(0x0101,0x82); // 2 lane
#endif
#ifdef 1_Lane
DpcdWrite(0x0101,0x81); // 1 lane
#endif
DpcdWrite(0x010a,0x00);
DpcdWrite(0x0107,0x00);
DpcdWrite(0x0108,0x01);
if(DpcdRead(0x0100)!=0x0a)
#ifdef 2_Lane
if(DpcdRead(0x0101)!=0x82) // 2 Lane
#endif
#ifdef 1_Lane
if(DpcdRead(0x0101)!=0x81) // 1 Lane
#endif
if(DpcdRead(0x010a)!=0x00)
DpcdWrite(0x0102,0x00);
DpcdWrite(0x0102,0x01); // sent TPS1
#ifdef 2_Lane
#endif
if(DpcdRead(0x0102)!=0x01)
mdelay(16);
swing_adj_cnt=0x05;
#ifdef 2_Lane
DPCD0202H=DPCD0202H&0x11;// 2 Lane 0x11 ; 1 Lane 0x01
while(((DPCD0202H&0x11)!=0x11)&&(swing_adj_cnt>0))// 1080P 0x11 ; 1366 0x01
#endif
#ifdef 1_Lane
DPCD0202H=DPCD0202H&0x01;// 2 Lane 0x11 ; 1 Lane 0x01
while(((DPCD0202H&0x01)!=0x01)&&(swing_adj_cnt>0))// 1080P 0x11 ; 1366 0x01
#endif
DPCD0206H=DpcdRead(0x0206);
adj_swing();
swing_adj_cnt–;
mdelay(1);
#ifdef 2_Lane
#endif
#ifdef 1_Lane
#endif
// HDMI_WriteI2C_Byte(0xff,0x82); //for debug
// HDMI_WriteI2C_Byte(0x1b,DPCD0202H);
#ifdef 2_Lane
if(DPCD0202H==0x11)// 2 Lane 0x11 ; 1 Lane 0x01
#endif
#ifdef 1_Lane
if(DPCD0202H==0x01)// 2 Lane 0x11 ; 1 Lane 0x01
#endif
HDMI_WriteI2C_Byte(0x04,0x18);
	HDMI_WriteI2C_Byte(0xff,0x84);//register bank
	HDMI_WriteI2C_Byte(0x14,0x04);
	HDMI_WriteI2C_Byte(0x14,0x84);
	HDMI_WriteI2C_Byte(0x14,0x88); //0x88
	DpcdWrite(0x0102,0x02);      // sent TPS2
	if(DpcdRead(0x0102)!=0x02)
	mdelay(16);
	swing_adj_cnt=0x05;
#ifdef 2_Lane
while(((DPCD0202H&0x77)!=0x77)&&(swing_adj_cnt>0))// 2 Lane 0x77 ; 1 Lane 0x07
#endif
#ifdef 1_Lane
while(((DPCD0202H&0x07)!=0x07)&&(swing_adj_cnt>0))// 2 Lane 0x77 ; 1 Lane 0x07
#endif
HDMI_WriteI2C_Byte(0x14,0x08);
adj_swing();
swing_adj_cnt–;
mdelay(1);
// HDMI_WriteI2C_Byte(0xff,0x82);//register bank
// HDMI_WriteI2C_Byte(0x1c,DPCD0202H);
HDMI_WriteI2C_Byte(0xff,0x80); //register bank
HDMI_WriteI2C_Byte(0x04,0x10);
HDMI_WriteI2C_Byte(0x14,0x80);
HDMI_WriteI2C_Byte(0x14,0xc0);
HDMI_WriteI2C_Byte(0x62,0xbf);
HDMI_WriteI2C_Byte(0xff,0x88);//register bank
if(HDMI_ReadI2C_Byte(0x24)!=0xc0)
DpcdWrite(0x0102,0x00); // sent data
if(DpcdRead(0x0102)!=0x00)
	DpcdWrite(0x0600,0x01); //
	DpcdWrite(0x010a,0x00); //
/*void reset_lt8911(void)
GPIO_WriteLow(GPIOA,GPIO_PIN_1);
delay1ms(150);
GPIO_WriteHigh(GPIOA,GPIO_PIN_1);
delay1ms(150);
void lt8911_hw_enable(void){
printk("lt8911_hw_enable****\n");
if (!lt8911->pdata->pwron) {
	gpio_set_value(lt8911->pdata->dvdd33_en_pin,lt8911->pdata->dvdd33_en_val);
	msleep(5);
	gpio_set_value(lt8911->pdata->dvdd18_en_pin,lt8911->pdata->dvdd18_en_val);
	gpio_set_value(lt8911->pdata->edp_en_pin,1);
	msleep(20);
	gpio_set_value(lt8911->pdata->edp_rst_pin,1);
	msleep(50);
	gpio_set_value(lt8911->pdata->edp_rst_pin,0);
	msleep(50);
	lt8911->pdata->pwron = true;
lt8911->edp_anx_init(lt8911->client);
void lt8911_hw_disable(void){
printk("LT8911_hw_disable****\n");
gpio_set_value(lt8911->pdata->dvdd33_en_pin,!lt8911->pdata->dvdd33_en_val);
gpio_set_value(lt8911->pdata->dvdd18_en_pin,!lt8911->pdata->dvdd18_en_val);
gpio_set_value(lt8911->pdata->edp_en_pin,0);
lt8911->pdata->pwron = false;
/*static int edp_reg_show(struct seq_file *s, void *v)
int i = 0;
char val;
struct lt8911 *lt8911 = s->private;
if(!lt8911)
printk(KERN_ERR “no edp device!\n”);
return 0;
seq_printf(s,"0x70:\n");
for(i=0;i< MAX_REG;i++)
	HDMI_ReadI2C_Byte(&val);
	seq_printf(s,"0x%02x>>0x%02x\n",i,val);
seq_printf(s,"\n0x72:\n");
return 0;
/*static int lt8911_power_ctl(struct lt8911_platform_data *pdata)
int ret;
ret = gpio_request(pdata->dvdd33_en_pin, “dvdd33_en_pin”);
if (ret != 0) {
gpio_free(pdata->dvdd33_en_pin);
printk(KERN_ERR “request dvdd33 en pin fail!\n”);
return -1;
} else {
gpio_direction_output(pdata->dvdd33_en_pin, pdata->dvdd33_en_val);
mdelay(5);
   ret = gpio_request(pdata->dvdd18_en_pin, "dvdd18_en_pin");
   if (ret != 0) {
       gpio_free(pdata->dvdd18_en_pin);
       printk(KERN_ERR "request dvdd18 en pin fail!\n");
       return -1;
   } else {
       gpio_direction_output(pdata->dvdd18_en_pin, pdata->dvdd18_en_pin);
   ret = gpio_request(pdata->edp_en_pin, "edp_en_pin");
   if (ret != 0) {
       gpio_free(pdata->edp_en_pin);
       printk(KERN_ERR "request en pin fail!\n");
       return -1;
   } else {
       gpio_direction_output(pdata->edp_en_pin, 1);
       msleep(20);
   ret = gpio_request(pdata->edp_rst_pin, "edp_rst_pin");
   if (ret != 0) {
       gpio_free(pdata->edp_rst_pin);
       printk(KERN_ERR "request rst pin fail!\n");
       return -1;
   } else {
	   gpio_direction_output(pdata->edp_rst_pin, 1);
	   msleep(50);
       gpio_direction_output(pdata->edp_rst_pin, 0);
       msleep(50);
   return 0;
static void lt8911_parse_dt(struct lt8911 *lt8911)
struct device_node *np = lt8911->client->dev.of_node;
struct lt8911_platform_data *pdata;
enum of_gpio_flags dvdd33_flags,dvdd18_flags,rst_flags,vcc_flags;
pdata = devm_kzalloc(&lt8911->client->dev,
sizeof(struct lt8911_platform_data ), GFP_KERNEL);
if (!pdata) {
dev_err(&lt8911->client->dev,
“failed to allocate platform data\n”);
return ;
pdata->dvdd33_en_pin = of_get_named_gpio_flags(np, “dvdd33-gpio”, 0, &dvdd33_flags);
pdata->dvdd18_en_pin = of_get_named_gpio_flags(np, “dvdd18-gpio”, 0, &dvdd18_flags);
pdata->edp_rst_pin = of_get_named_gpio_flags(np, “reset-gpio”, 0, &rst_flags);
pdata->edp_en_pin = of_get_named_gpio_flags(np, “vcc-gpio”, 0, &vcc_flags);
pdata->dvdd33_en_val = (dvdd33_flags & OF_GPIO_ACTIVE_LOW) ? 0 : 1;
pdata->dvdd18_en_val = (dvdd18_flags & OF_GPIO_ACTIVE_LOW) ? 0 : 1;
pdata->power_ctl = lt8911_power_ctl;
lt8911->pdata = pdata;
// MIPI输入点1920x01080 eDP屏的 LT8911/B 寄存器设置:
void lt8911_open(void)
printk(“lt8911_open\n”);
lt8911_hw_enable();// 刷寄存器之前,先Reset LT8911/B ,用GPIO 先拉低LT8911/B的复位脚 150ms左右,再拉高,保持150ms
HDMI_WriteI2C_Byte(0xff,0x81);//register bank
HDMI_WriteI2C_Byte(0x00,0x04);
HDMI_WriteI2C_Byte(0x7a,0x07);
HDMI_WriteI2C_Byte(0x71,0x36);
HDMI_WriteI2C_Byte(0x72,0x00);
HDMI_WriteI2C_Byte(0x73,0x00);
HDMI_WriteI2C_Byte(0x63,0x7f);
HDMI_WriteI2C_Byte(0x63,0xff);
///////////txpll_analog///////
HDMI_WriteI2C_Byte(0x0e,0x37);
HDMI_WriteI2C_Byte(0x01,0x18);
HDMI_WriteI2C_Byte(0x02,0x42);
HDMI_WriteI2C_Byte(0x04,0x00);
HDMI_WriteI2C_Byte(0x04,0x01);
HDMI_WriteI2C_Byte(0x61,0x7f);
HDMI_WriteI2C_Byte(0x61,0xff);
HDMI_WriteI2C_Byte(0x05,0x13);
//////////txpll_digtal////////
HDMI_WriteI2C_Byte(0x74,0x41);
HDMI_WriteI2C_Byte(0x75,0x03);
HDMI_WriteI2C_Byte(0x76,0x0a);
HDMI_WriteI2C_Byte(0x78,0x0a);
#ifdef 1_Lane
// 1 Lane eDP Output
HDMI_WriteI2C_Byte(0x22,0x10);// 关闭 LANE1 / LANE2 / LANE3 SWING 的电流开关
HDMI_WriteI2C_Byte(0x23,0x3e);// 关闭 LANE1 / LANE2 / LANE3 pre-emphase 的电流开关
HDMI_WriteI2C_Byte(0x25,0x08);
#else
// 2 Lane eDP Output
HDMI_WriteI2C_Byte(0x22,0x30);// 关闭 LANE2 / LANE3 SWING的电流开关
HDMI_WriteI2C_Byte(0x23,0x3c);// 关闭 LANE2 / LANE3 pre-emphase的电流开关
#endif
// 前面可以先打开DDS.
// #ifdef Test_Pattern
#ifdef _1080P_eDP_Panel_
HDMI_WriteI2C_Byte(0xff,0x90);//register bank
HDMI_WriteI2C_Byte(0x4a,0x33); // 148.5MHz
HDMI_WriteI2C_Byte(0x4b,0x33);
HDMI_WriteI2C_Byte(0x4c,0x33);
HDMI_WriteI2C_Byte(0x4d,0x10);
#endif
#ifdef _1366x768_eDP_Panel_
//HDMI_WriteI2C_Byte(0x4a,0x66); // 72MHz
//HDMI_WriteI2C_Byte(0x4b,0x66);
//HDMI_WriteI2C_Byte(0x4c,0x66);
HDMI_WriteI2C_Byte(0x4a,0xab); // 76.42MHz
HDMI_WriteI2C_Byte(0x4b,0xaf);
HDMI_WriteI2C_Byte(0x4c,0x6c);
#endif
// #else
// HDMI_WriteI2C_Byte(0xff,0x90);//register bank
// HDMI_WriteI2C_Byte(0x4d,0x00)
// #endif
HDMI_WriteI2C_Byte(0x09,0x01);
HDMI_WriteI2C_Byte(0x0b,0x0b);
HDMI_WriteI2C_Byte(0x08,0x13);
//-----------------1080P_60Hz---------------------//
HDMI_WriteI2C_Byte(0x00,0x6a);
HDMI_WriteI2C_Byte(0x04,0xff);
HDMI_WriteI2C_Byte(0x05,(u8)(MIPI_Timing[H_tol]/256));//RG_HTOTAL[15:0]
HDMI_WriteI2C_Byte(0x06,(u8)(MIPI_Timing[H_tol]%256));//RG_HTOTAL[7:0]
HDMI_WriteI2C_Byte(0x07,(u8)((MIPI_Timing[H_bp]+MIPI_Timing[H_sync])/256));//RG_HSTART [15:8]
HDMI_WriteI2C_Byte(0x08,(u8)((MIPI_Timing[H_bp]+MIPI_Timing[H_sync])%256));//RG_HSTART[7:0]=110
HDMI_WriteI2C_Byte(0x09,(u8)(MIPI_Timing[H_sync]/256));//[7]RG_HSPOL;[6:0]RG_HSYNC_WIDTH[14:8]	0x80-->0x00
HDMI_WriteI2C_Byte(0x0a,(u8)(MIPI_Timing[H_sync]%256));//RG_HSYNC_WIDTH[7:0]=60
HDMI_WriteI2C_Byte(0x0b,(u8)(MIPI_Timing[H_act]/256));//RG_HWIDTH[15:8]
HDMI_WriteI2C_Byte(0x0c,(u8)(MIPI_Timing[H_act]%256));//RG_HWIDTH[7:0]
HDMI_WriteI2C_Byte(0x0d,(u8)(MIPI_Timing[V_tol]/256));//RG_VTOTAL [15:8]
HDMI_WriteI2C_Byte(0x0e,(u8)(MIPI_Timing[V_tol]%256));//RG_VTOTAL[7:0]
HDMI_WriteI2C_Byte(0x0f,0x00);//RG_TOP_VTOTAL[15:8] //fiexd
HDMI_WriteI2C_Byte(0x10,0x00);//RG_TOP_VTOTAL[7:0]	//fixed
HDMI_WriteI2C_Byte(0x11,(u8)((MIPI_Timing[V_bp]+MIPI_Timing[V_sync])/256));//RG_VSTART[15:8]
HDMI_WriteI2C_Byte(0x12,(u8)((MIPI_Timing[V_bp]+MIPI_Timing[V_sync])%256));//RG_VSTART[7:0]
HDMI_WriteI2C_Byte(0x13,(u8)(MIPI_Timing[V_sync]/256));//RG_VSPOL;RG_VSYNC_WIDTH[14:8]  0x80-->0x00
HDMI_WriteI2C_Byte(0x14,(u8)(MIPI_Timing[V_sync]%256));//RG_VSYNC_WIDTH[7:0]
HDMI_WriteI2C_Byte(0x15,(u8)(MIPI_Timing[V_act]/256));//RG_VHEIGTH[15:8]
HDMI_WriteI2C_Byte(0x16,(u8)(MIPI_Timing[V_act]%256));//RG_VHEIGTH[7:0]
#ifdef 6_Bit_ColorDepth
HDMI_WriteI2C_Byte(0x17,0x00);// LVDS Color Depth: 6 bit: 0x00 ; 8 bit: 0x08
HDMI_WriteI2C_Byte(0x18,0x00);// LVDS Color Depth: 6 bit: 0x00 ; 8 bit: 0x20
#endif
#ifdef 8_Bit_ColorDepth
HDMI_WriteI2C_Byte(0x17,0x08);// LVDS Color Depth: 6 bit: 0x00 ; 8 bit: 0x08
HDMI_WriteI2C_Byte(0x18,0x20);// LVDS Color Depth: 6 bit: 0x00 ; 8 bit: 0x20
#endif
HDMI_WriteI2C_Byte(0x19,0x00);
HDMI_WriteI2C_Byte(0x1a,0x80);
HDMI_WriteI2C_Byte(0x1e,0x30);
HDMI_WriteI2C_Byte(0x21,0x00);
HDMI_WriteI2C_Byte(0x2c,0xdf);
HDMI_WriteI2C_Byte(0x2d,0x00);
HDMI_WriteI2C_Byte(0x4b,0xfe);
HDMI_WriteI2C_Byte(0x2e,(u8)((MIPI_Timing[V_bp]+MIPI_Timing[V_sync])%256));//RG_GCM_DE_TOP[6:0]
HDMI_WriteI2C_Byte(0x2f,(u8)((MIPI_Timing[H_bp]+MIPI_Timing[H_sync])/256));//RG_GCM_DE_DLY[11:8]
HDMI_WriteI2C_Byte(0x30,(u8)((MIPI_Timing[H_bp]+MIPI_Timing[H_sync])%256));//RG_GCM_DE_DLY[7:0]
HDMI_WriteI2C_Byte(0x31,(u8)(MIPI_Timing[H_act]/256));//RG_GCM_DE_CNT[11:8]
HDMI_WriteI2C_Byte(0x32,(u8)(MIPI_Timing[H_act]%256));//RG_GCM_DE_CNT[7:0]
HDMI_WriteI2C_Byte(0x33,(u8)(MIPI_Timing[V_act]/256));//RG_GCM_DE_LIN[10:8]
HDMI_WriteI2C_Byte(0x34,(u8)(MIPI_Timing[V_act]%256));//RG_GCM_DE_LIN[7:0]
HDMI_WriteI2C_Byte(0x35,(u8)(MIPI_Timing[H_tol]/256));//RG_GCM_HTOTAL[11:8]
HDMI_WriteI2C_Byte(0x36,(u8)(MIPI_Timing[H_tol]%256));//RG_GCM_HTOTAL[7:0]
#ifdef Test_Pattern
HDMI_WriteI2C_Byte(0x37,0x18+(u8)(MIPI_Timing[V_tol]/256));//1c:pre-pattern,0c:mipi pattern;RG_GCM_VTOTAL[10:8]
#else
HDMI_WriteI2C_Byte(0x37,0x08+(u8)(MIPI_Timing[V_tol]/256));//1c:pre-pattern,0c:mipi pattern;RG_GCM_VTOTAL[10:8]
#endif
HDMI_WriteI2C_Byte(0x38,(u8)(MIPI_Timing[V_tol]%256));//RG_GCM_VTOTAL[7:0]
HDMI_WriteI2C_Byte(0x39,0x00);//reseve
HDMI_WriteI2C_Byte(0x3a,((u8)(MIPI_Timing[V_sync]%256))*4 + (u8)(MIPI_Timing[H_sync]/256));//RG_GCM_VWIDTH[5:0];RG_GCM_HWIDTH[9:8]
HDMI_WriteI2C_Byte(0x3b,(u8)(MIPI_Timing[H_sync]%256));//RG_GCM_HWIDTH[7:0]
////////////////////Nvid//////////////
HDMI_WriteI2C_Byte(0xff,0x8c); //register bank
HDMI_WriteI2C_Byte(0x00,0x00);
HDMI_WriteI2C_Byte(0x01,0x80);
HDMI_WriteI2C_Byte(0x02,0x00);
//-----------------Training-----------------------------//
LT8911_AUX_Training();
#ifdef 2_Lane
if(DPCD0202H!=0x77)
#endif
#ifdef 1_Lane
if(DPCD0202H!=0x07)
#endif
// HDMI_WriteI2C_Byte(0xff,0x88);//register bank
// HDMI_WriteI2C_Byte(0x1e,0x30);
// HDMI_WriteI2C_Byte(0x4b,0xfe);
HDMI_WriteI2C_Byte(0x27,0x80);
HDMI_WriteI2C_Byte(0x28,0xa4);
HDMI_WriteI2C_Byte(0x29,0xd2);
HDMI_WriteI2C_Byte(0x2a,0x04);
HDMI_WriteI2C_Byte(0x2b,0x7e);
HDMI_WriteI2C_Byte(0x2c,0x02);
HDMI_WriteI2C_Byte(0x2d,0x02);
HDMI_WriteI2C_Byte(0x2e,0xaa);
HDMI_WriteI2C_Byte(0x2f,0x02);
HDMI_WriteI2C_Byte(0x30,0xaa);
HDMI_WriteI2C_Byte(0x31,0x4b);
HDMI_WriteI2C_Byte(0x32,0x43);
HDMI_WriteI2C_Byte(0x33,0x20);
HDMI_WriteI2C_Byte(0x34,0x00);
HDMI_WriteI2C_Byte(0x35,0x80);
HDMI_WriteI2C_Byte(0x36,0xa4);
HDMI_WriteI2C_Byte(0x37,0xd2);
HDMI_WriteI2C_Byte(0x38,0x00);
HDMI_WriteI2C_Byte(0x39,0x36);
HDMI_WriteI2C_Byte(0x3a,0x00);
HDMI_WriteI2C_Byte(0x01,0x04);
HDMI_WriteI2C_Byte(0x02,0x04);
HDMI_WriteI2C_Byte(0x03,0x04);
HDMI_WriteI2C_Byte(0x04,0xc8);
HDMI_WriteI2C_Byte(0x05,0x00);
HDMI_WriteI2C_Byte(0x06,0x0b);
HDMI_WriteI2C_Byte(0x0b,_MIPI_Lane_%4);// 00:4 Lane;01:1 Lane;02:2 Lane;03:3 Lane
HDMI_WriteI2C_Byte(0x0c,0x00);// 3210
HDMI_WriteI2C_Byte(0x10,0x03);
HDMI_WriteI2C_Byte(0x11,0x03);
HDMI_WriteI2C_Byte(0x12,(u8)(MIPI_Timing[H_sync]%256));
HDMI_WriteI2C_Byte(0x13,(u8)(MIPI_Timing[V_sync]%256));
HDMI_WriteI2C_Byte(0x14,(u8)(MIPI_Timing[H_act]%256));
HDMI_WriteI2C_Byte(0x15,(u8)(MIPI_Timing[H_act]/256));
HDMI_WriteI2C_Byte(0x16,(u8)(MIPI_Timing[H_act]%256));
HDMI_WriteI2C_Byte(0x17,(u8)(MIPI_Timing[H_act]/256));
HDMI_WriteI2C_Byte(0x19,0x01);
HDMI_WriteI2C_Byte(0x1a,0x17);
HDMI_WriteI2C_Byte(0x2b,0x0b);
HDMI_WriteI2C_Byte(0x2c,0x0c);
HDMI_WriteI2C_Byte(0x31,(u8)(MIPI_Timing[H_tol]%256));
HDMI_WriteI2C_Byte(0x32,(u8)(MIPI_Timing[H_tol]/256));
HDMI_WriteI2C_Byte(0x33,(u8)(MIPI_Timing[V_tol]%256));
HDMI_WriteI2C_Byte(0x34,(u8)(MIPI_Timing[V_tol]/256));
HDMI_WriteI2C_Byte(0x35,(u8)(MIPI_Timing[V_bp]%256));
HDMI_WriteI2C_Byte(0x36,(u8)(MIPI_Timing[V_bp]/256));
HDMI_WriteI2C_Byte(0x37,(u8)((MIPI_Timing[V_tol]-MIPI_Timing[V_act]-MIPI_Timing[V_bp]-MIPI_Timing[V_sync])%256));
HDMI_WriteI2C_Byte(0x38,(u8)((MIPI_Timing[V_tol]-MIPI_Timing[V_act]-MIPI_Timing[V_bp]-MIPI_Timing[V_sync])/256));
HDMI_WriteI2C_Byte(0x39,(u8)(MIPI_Timing[H_bp]%256));
HDMI_WriteI2C_Byte(0x3a,(u8)(MIPI_Timing[H_bp]/256));
HDMI_WriteI2C_Byte(0x3b,(u8)((MIPI_Timing[H_tol]-MIPI_Timing[H_act]-MIPI_Timing[H_bp]-MIPI_Timing[H_sync])%256));
HDMI_WriteI2C_Byte(0x3c,(u8)((MIPI_Timing[H_tol]-MIPI_Timing[H_act]-MIPI_Timing[H_bp]-MIPI_Timing[H_sync])/256));
HDMI_WriteI2C_Byte(0x1b,0x90);
HDMI_WriteI2C_Byte(0x1c,0x01);
HDMI_WriteI2C_Byte(0x1d,0x68);
HDMI_WriteI2C_Byte(0x1e,0x01);
HDMI_WriteI2C_Byte(0x1f,0x5e);
HDMI_WriteI2C_Byte(0x20,0x01);
HDMI_WriteI2C_Byte(0x21,0x54);
HDMI_WriteI2C_Byte(0x22,0x01);
HDMI_WriteI2C_Byte(0x23,0x90);
HDMI_WriteI2C_Byte(0x24,0x01);
HDMI_WriteI2C_Byte(0x25,0x68);
HDMI_WriteI2C_Byte(0x26,0x01);
HDMI_WriteI2C_Byte(0x27,0x5e);
HDMI_WriteI2C_Byte(0x28,0x01);
HDMI_WriteI2C_Byte(0x29,0x54);
HDMI_WriteI2C_Byte(0x2a,0x01);
HDMI_WriteI2C_Byte(0x3d,0x64);
HDMI_WriteI2C_Byte(0x3f,0x00);
HDMI_WriteI2C_Byte(0x40,0x04);
HDMI_WriteI2C_Byte(0x41,0x00);
HDMI_WriteI2C_Byte(0x42,0x59);
HDMI_WriteI2C_Byte(0x43,0x00);
HDMI_WriteI2C_Byte(0x44,0xf2);
HDMI_WriteI2C_Byte(0x45,0x06);
HDMI_WriteI2C_Byte(0x46,0x00);
HDMI_WriteI2C_Byte(0x47,0x72);
HDMI_WriteI2C_Byte(0x48,0x45);
HDMI_WriteI2C_Byte(0x49,0x00);
HDMI_WriteI2C_Byte(0x60,0x08);
HDMI_WriteI2C_Byte(0x61,0x00);
HDMI_WriteI2C_Byte(0x62,0xb2);
HDMI_WriteI2C_Byte(0x63,0x00);
HDMI_WriteI2C_Byte(0x64,0xe4);
HDMI_WriteI2C_Byte(0x65,0x0d);
HDMI_WriteI2C_Byte(0x66,0x00);
HDMI_WriteI2C_Byte(0x67,0xe4);
HDMI_WriteI2C_Byte(0x68,0x8a);
HDMI_WriteI2C_Byte(0x69,0x00);
HDMI_WriteI2C_Byte(0x6a,0x0b);
HDMI_WriteI2C_Byte(0x1a,0x4f);
HDMI_WriteI2C_Byte(0x6b,0x04);
#ifdef Test_Pattern
// 前面已经设置过DDS了,这里不需设置了。
// HDMI_WriteI2C_Byte(0xff,0x90); //register bank
// HDMI_WriteI2C_Byte(0x4a,0x33);
// HDMI_WriteI2C_Byte(0x4b,0x33);
// HDMI_WriteI2C_Byte(0x4c,0xd3);
// HDMI_WriteI2C_Byte(0x4d,0x10);
#else
// HDMI_WriteI2C_Byte(0x4a,0x00);
// HDMI_WriteI2C_Byte(0x4b,0x00);
// HDMI_WriteI2C_Byte(0x4c,0x00);
HDMI_WriteI2C_Byte(0x4d,0x00);// 关闭DDS
#endif
HDMI_WriteI2C_Byte(0x60,0xde);
HDMI_WriteI2C_Byte(0x60,0xff);
// For test
HDMI_WriteI2C_Byte(0x07,0xc0);
HDMI_WriteI2C_Byte(0x94,0x00);
HDMI_WriteI2C_Byte(0x95,0x00);
HDMI_WriteI2C_Byte(0x3f,0x02);
HDMI_WriteI2C_Byte(0x3e,0xff);
HDMI_WriteI2C_Byte(0x3d,0x03);
HDMI_WriteI2C_Byte(0x2b,0x7f);
EXPORT_SYMBOL(lt8911_open);
void lt8911_close(void)
lt8911_hw_disable();
EXPORT_SYMBOL(lt8911_close);
/*static int edp_reg_open(struct inode *inode, struct file file)
//struct lt8911 lt8911 = inode->i_private;
lt8911_open();
return 0;
static const struct file_operations edp_reg_fops = {
.owner = THIS_MODULE,
.open = edp_reg_open,
.read = seq_read,
.llseek = seq_lseek,
.release = single_release,
#ifdef CONFIG_HAS_EARLYSUSPEND
static void lt8911_early_suspend(struct early_suspend *h)
lt8911_close();
static void lt8911_late_resume(struct early_suspend h)
lt8911_open();
#endif
static int lt8911_probe(struct i2c_client *client,
const struct i2c_device_id *id)
//struct i2c_adapter *adapter = to_i2c_adapter(client->dev.parent);
//struct lt8911 *lt8911 = NULL;
pr_info("%s()\n", __FUNCTION__);
if (!i2c_check_functionality(client->adapter, I2C_FUNC_I2C)) {
    printk(KERN_INFO "i2c_check_functionality error\n");
    goto exit;
/*lt8911 = kzalloc(sizeof(struct lt8911), GFP_KERNEL);
if (lt8911 == NULL) {
	dev_err(&client->dev, "alloc for struct lt8911fail\n");
	return -ENOMEM;
	lt8911_client = client;
	/*lt8911->pdata = client->dev.platform_data;
if (!lt8911->pdata) {
	lt8911_parse_dt(lt8911);
i2c_set_clientdata(client,lt8911);
if(lt8911->pdata->power_ctl)
	lt8911->pdata->power_ctl(lt8911->pdata);
	debugfs_create_file("edp-reg", S_IRUSR,NULL,lt8911,&edp_reg_fops);
lt8911->early_suspend.suspend = lt8911_early_suspend;
lt8911->early_suspend.resume = lt8911_late_resume;
lt8911->early_suspend.level = EARLY_SUSPEND_LEVEL_STOP_DRAWING;
register_early_suspend(&lt8911->early_suspend);
#endif
edp = lt8911;*/
dev_info(&client->dev, "edp lt8911 probe ok \n");
return 0;
exit:
return -1;
/*static struct mipi_dsi_ops lt8911_ops = {
.id = MODULE_I2C_ADDR,
.name = MODULE_NAME,
.get_id = lt8911_get_id,
.power_up = lt8911_power_up,
.power_down = lt8911_power_down,
static const unsigned short lt8911_addresses = {
MODULE_I2C_ADDR,
I2C_CLIENT_END,
static const struct i2c_device_id lt8911_id = {
{ MODULE_NAME, 0 },
/static struct of_device_id lt8911_dt_ids[] = {
{ .compatible = “lt8911” },
static struct i2c_driver lt8911_driver = {
.driver = {
.id_table = lt8911_id,
.probe = lt8911_probe,
static struct i2c_board_info lt8911_board_info={
.type = MODULE_NAME,
.addr = MODULE_I2C_ADDR,
//static struct i2c_client *lt8911_client;
int __init lt8911_i2c_init(void)
struct i2c_adapter *i2c_adap;
unsigned int cfg_i2c_adap_id;
cfg_i2c_adap_id = 1;
i2c_adap = i2c_get_adapter(cfg_i2c_adap_id);
lt8911_client = i2c_new_device(i2c_adap, &lt8911_board_info);
i2c_put_adapter(i2c_adap);
return i2c_add_driver(&lt8911_driver);
fs_initcall(lt8911_i2c_init);
void __exit lt8911_i2c_exit(void)
//del_dsi_ops(lt8911_ops);
//lt8911_lcd_manager = NULL;
i2c_del_driver(&lt8911_driver);
//i2c_unregister_device(lt8911_client);
module_exit(lt8911_i2c_exit);
xi0325 发表于 2017-3-23 18:57
// I2C_Adr = 0x52;// bit0 是读写标志 …
自己参照dp_anx6345.c文件移植的,也不知道对不对
  1. dts 里面添加节点了吗?
  2. 具体问题是什么?
    驱动可以正常加载了吗? 或是只有屏不亮
loading 发表于 2017-3-23 22:37
  1. dts 里面添加节点了吗?
  2. 具体问题是什么?
    驱动可以正常加载了吗? 或是只有屏不亮
1,dts里边有添加节点
lt8911@52 {
compatible = “rockchip,lt8911”;
reg = <0x52>;
gpio-power = <&gpio8 GPIO_A1 GPIO_ACTIVE_HIGH>;
gpio-reset = <&gpio8 GPIO_A2 GPIO_ACTIVE_HIGH>;
status = “okay”;
2,现在是8911B都还没通
xi0325 发表于 2017-3-24 09:17
1,dts里边有添加节点
lt8911@52 {
  1. 确认驱动加载成功
  2. 确认i2c 可以正常读写
  3. 然后进行寄存器的读写
现在这个driver 有porting成功吗?能否借鉴一下 谢谢~~~~
lt8911_i2c_init 这个函数写的有问题
