<6>[ 0.000000] Booting Linux on physical CPU 0x500
<6>[ 0.000000] Initializing cgroup subsys cpu
<6>[ 0.000000] Initializing cgroup subsys cpuacct
<5>[ 0.000000] Linux version 3.10.0 (root@mingri-All-Series) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #34 SMP PREEMPT Thu Mar 23 16:12:09 CST 2017
<4>[ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
<4>[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
<6>[ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288
<6>[ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x00000000
<6>[ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo
<4>[ 0.000000] rockchip_ion_reserve
<6>[ 0.000000] ion heap(drm): base(0) size(0) align(0)
<6>[ 0.000000] ion heap(cma): base(0) size(28000000) align(0)
<6>[ 0.000000] ion heap(vmalloc): base(0) size(0) align(0)
<6>[ 0.000000] cma: CMA: reserved 640 MiB at 55c00000
<6>[ 0.000000] ion_reserve: cma reserved base 55c00000 size 671088640
<6>[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
<7>[ 0.000000] On node 0 totalpages: 524288
<7>[ 0.000000] free_area_init_node: node 0, pgdat c0d5a180, node_mem_map c0e83000
<7>[ 0.000000] Normal zone: 1024 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
<7>[ 0.000000] HighMem zone: 3072 pages used for memmap
<7>[ 0.000000] HighMem zone: 393216 pages, LIFO batch:31
<6>[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1ede000 s13376 r8192 d15296 u36864
<7>[ 0.000000] pcpu-alloc: s13376 r8192 d15296 u36864 alloc=9*4096
<7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
<5>[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),0x00200000@0x0039C000(userdata),0x00020000@0x0059C000(radical_update),-@0x005BC000(user) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2016-10-08_15:45:52
<6>[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[ 0.000000] allocated 4194304 bytes of page_cgroup
<6>[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
<6>[ 0.000000] Memory: 2048MB = 2048MB total
<5>[ 0.000000] Memory: 1354936k/1354936k available, 742216k reserved, 884736K highmem
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .text : 0xc0008000 - 0xc0b78b8c (11715 kB)
<5>[ 0.000000] .init : 0xc0b79000 - 0xc0bd1440 ( 354 kB)
<5>[ 0.000000] .data : 0xc0bd2000 - 0xc0d617c0 (1598 kB)
<5>[ 0.000000] .bss : 0xc0d617c0 - 0xc0e8263c (1156 kB)
<6>[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
<6>[ 0.000000] Preemptible hierarchical RCU implementation.
<6>[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
<6>[ 0.000000] NR_IRQS:16 nr_irqs:16 16
<4>[ 0.000000] rk_clk_tree_init start!
<3>[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
<3>[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
<4>[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
<4>[ 0.000000] rkclk_init_clks: cnt_parent = 7
<4>[ 0.000000] rkclk_init_clks: cnt_rate = 29
<4>[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
<6>[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
<6>[ 0.000000] Switching to timer-based delay loop
<6>[ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns
<6>[ 0.000000] process version: 2
<6>[ 0.000000] channel:0, lkg:45
<6>[ 0.000000] target-temp:80
<6>[ 0.000000] channel:2, lkg:0
<6>[ 0.000000] channel:1, lkg:46
<6>[ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
<6>[ 0.344550] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
<6>[ 0.344566] pid_max: default: 32768 minimum: 301
<6>[ 0.344683] Security Framework initialized
<6>[ 0.344699] SELinux: Initializing.
<7>[ 0.344735] SELinux: Starting in permissive mode
<6>[ 0.344773] Mount-cache hash table entries: 512
<6>[ 0.345415] Initializing cgroup subsys debug
<6>[ 0.345428] Initializing cgroup subsys memory
<6>[ 0.345456] Initializing cgroup subsys freezer
<6>[ 0.345484] CPU: Testing write buffer coherency: ok
<3>[ 0.345792] /cpus/cpu@0 missing clock-frequency property
<3>[ 0.345806] /cpus/cpu@1 missing clock-frequency property
<3>[ 0.345816] /cpus/cpu@2 missing clock-frequency property
<3>[ 0.345825] /cpus/cpu@3 missing clock-frequency property
<6>[ 0.345876] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
<6>[ 0.345926] Setting up static identity map for 0xc083edc8 - 0xc083ee20
<6>[ 0.349190] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x17eb (version 3.1)
<4>[ 0.422701] CPU1: Booted secondary processor
<6>[ 0.422733] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
<4>[ 0.442363] CPU2: Booted secondary processor
<6>[ 0.442386] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
<4>[ 0.462077] CPU3: Booted secondary processor
<6>[ 0.462100] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
<6>[ 0.462202] Brought up 4 CPUs
<6>[ 0.462230] SMP: Total of 4 processors activated (192.00 BogoMIPS).
<6>[ 0.462239] CPU: All CPU(s) started in SVC mode.
<6>[ 0.462984] devtmpfs: initialized
<6>[ 0.467269] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
<6>[ 0.468344] pinctrl core: initialized pinctrl subsystem
<6>[ 0.468593] regulator-dummy: no parameters
<6>[ 0.493394] NET: Registered protocol family 16
<6>[ 0.495211] DMA: preallocated 256 KiB pool for atomic coherent allocations
<6>[ 0.495594] ion_snapshot: 0x1eaa0000 map to 0xe0907000 and copy to 0xc0e5d90c (version 0.1)
<6>[ 0.495825] Registered FIQ tty driver
<3>[ 0.496242] fiq-debugger is disabled in device tree
<4>[ 0.496886] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
<4>[ 0.496908] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
<4>[ 0.496925] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
<4>[ 0.496941] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
<4>[ 0.497030] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
<4>[ 0.497095] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
<4>[ 0.497157] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
<4>[ 0.497220] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
<4>[ 0.497281] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
<4>[ 0.497342] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
<4>[ 0.497403] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
<4>[ 0.497466] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
<4>[ 0.497534] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
<4>[ 0.497598] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
<4>[ 0.497611] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
<4>[ 0.497623] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
<4>[ 0.497634] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
<7>[ 0.497712] gpiochip_add: registered GPIOs 0 to 31 on device: gpio0
<7>[ 0.497769] gpiochip_add: registered GPIOs 32 to 63 on device: gpio1
<7>[ 0.497823] gpiochip_add: registered GPIOs 64 to 95 on device: gpio2
<7>[ 0.497885] gpiochip_add: registered GPIOs 96 to 127 on device: gpio3
<7>[ 0.497940] gpiochip_add: registered GPIOs 128 to 159 on device: gpio4
<7>[ 0.497994] gpiochip_add: registered GPIOs 160 to 191 on device: gpio5
<7>[ 0.498046] gpiochip_add: registered GPIOs 192 to 223 on device: gpio6
<7>[ 0.498106] gpiochip_add: registered GPIOs 224 to 255 on device: gpio7
<7>[ 0.498160] gpiochip_add: registered GPIOs 256 to 287 on device: gpio8
<7>[ 0.498214] gpiochip_add: registered GPIOs 288 to 319 on device: gpio15
<4>[ 0.498246] rockchip_interrupts_register:bank_num=7
<7>[ 0.500143] of_get_named_gpio_flags exited with status 256
<4>[ 0.500155] of_get_gpio_init_config:gpio[0] = 256, value = 0
<7>[ 0.500166] of_get_named_gpio_flags exited with status 136
<4>[ 0.500175] of_get_gpio_init_config:gpio[1] = 136, value = 0
<4>[ 0.500228] rockchip_pinctrl_probe:init ok
<6>[ 0.507230] rk_iommu ff900800.iep_mmu: (iep) Enter
<6>[ 0.507315] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.507328] rk_iommu ff900800.iep_mmu: (iep) Initialized
<6>[ 0.507498] rk_iommu ff950800.vip_mmu: (vip) Enter
<6>[ 0.507571] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.507583] rk_iommu ff950800.vip_mmu: (vip) Initialized
<6>[ 0.507750] rk_iommu ff930300.vopb_mmu: (vopb) Enter
<6>[ 0.507819] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.507831] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
<6>[ 0.507994] rk_iommu ff940300.vopl_mmu: (vopl) Enter
<6>[ 0.508065] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.508077] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
<6>[ 0.508256] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
<6>[ 0.508331] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.508344] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
<6>[ 0.508508] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
<6>[ 0.508577] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.508590] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
<6>[ 0.508764] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
<6>[ 0.508844] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.508856] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
<6>[ 0.510642] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
<6>[ 0.510655] hw-breakpoint: maximum watchpoint size is 4 bytes.
<3>[ 0.511261] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
<4>[ 0.511286] DDR DEBUG: version 1.00 20150126
<4>[ 0.511313] DDR DEBUG: Channel a:
<4>[ 0.511321] DDR DEBUG: DDR3 Device
<4>[ 0.511359] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.511368] DDR DEBUG: Channel b:
<4>[ 0.511375] DDR DEBUG: DDR3 Device
<4>[ 0.511388] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.511397] DDR DEBUG: addr=0xd6b000
<4>[ 0.511406] DDR DEBUG: stride=9, size=256, halfcap=40000000
<4>[ 0.511415] DDR DEBUG: socAddr[0]=0xd6b000, socAddr[1]=0xd6b100
<4>[ 0.511424] DDR DEBUG: chAddr[0]=0xd6b000, chAddr[1]=0xd6b000
<4>[ 0.511435] DDR DEBUG: dtar[0]=0x301ad000, dtar[1]=0x301ad000
<4>[ 0.511490] DDR DEBUG: init success!!! freq=200MHz
<4>[ 0.511498] DDR DEBUG: Channel a:
<4>[ 0.511510] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
<4>[ 0.511523] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
<4>[ 0.511537] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
<4>[ 0.511549] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
<4>[ 0.511561] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.511570] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.511578] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<4>[ 0.511586] DDR DEBUG: Channel b:
<4>[ 0.511597] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
<4>[ 0.511609] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
<4>[ 0.511622] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
<4>[ 0.511634] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
<4>[ 0.511644] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.511653] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.511662] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<6>[ 0.536216] bio: create slab at 0
<6>[ 0.536743] Rockchip hdmi driver version 2.0
<6>[ 0.536743] .
<5>[ 0.537919] SCSI subsystem initialized
<6>[ 0.538076] usbcore: registered new interface driver usbfs
<6>[ 0.538121] usbcore: registered new interface driver hub
<6>[ 0.538205] usbcore: registered new device driver usb
<7>[ 0.538463] of_get_named_gpio_flags exited with status 14
<7>[ 0.538503] of_get_named_gpio_flags exited with status 12
<7>[ 0.539568] of_get_named_gpio_flags exited with status 15
<7>[ 0.539588] of_get_named_gpio_flags exited with status 16
<6>[ 0.540918] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
<7>[ 0.541033] of_get_named_gpio_flags exited with status 260
<7>[ 0.541054] of_get_named_gpio_flags exited with status 261
<6>[ 0.541402] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
<7>[ 0.541509] of_get_named_gpio_flags exited with status 201
<7>[ 0.541527] of_get_named_gpio_flags exited with status 202
<6>[ 0.541853] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
<7>[ 0.541954] of_get_named_gpio_flags exited with status 81
<7>[ 0.541972] of_get_named_gpio_flags exited with status 80
<6>[ 0.542101] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
<7>[ 0.542203] of_get_named_gpio_flags exited with status 241
<7>[ 0.542221] of_get_named_gpio_flags exited with status 242
<6>[ 0.543068] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
<6>[ 0.543188] media: Linux media interface: v0.10
<6>[ 0.543228] Linux video capture interface: v2.00
<6>[ 0.543292] pps_core: LinuxPPS API ver. 1 registered
<6>[ 0.543302] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
<6>[ 0.543322] PTP clock support registered
<4>[ 0.543383] i2c-core: driver [bq24296] using legacy suspend method
<4>[ 0.543393] i2c-core: driver [bq24296] using legacy resume method
<4>[ 0.544084] ion_drm_heap_create: 0@0
<6>[ 0.544222] Rockchip ion module is successfully loaded (v1.1)
<6>[ 0.544383] Advanced Linux Sound Architecture Driver Initialized.
<6>[ 0.544813] Bluetooth: Core ver 2.16
<6>[ 0.544852] NET: Registered protocol family 31
<6>[ 0.544862] Bluetooth: HCI device and connection manager initialized
<6>[ 0.544877] Bluetooth: HCI socket layer initialized
<6>[ 0.544890] Bluetooth: L2CAP socket layer initialized
<6>[ 0.544915] Bluetooth: SCO socket layer initialized
<6>[ 0.545144] cfg80211: Calling CRDA to update world regulatory domain
<4>[ 0.545850] act8846_i2c_probe,line=898
<4>[ 0.546852] act8846_parse_dt,line=746
<7>[ 0.547275] of_get_named_gpio_flags exited with status 238
<7>[ 0.547289] of_get_named_gpio_flags exited with status 1
<7>[ 0.547301] of_get_named_gpio_flags exited with status 234
<7>[ 0.547313] of_get_named_gpio_flags exited with status 259
<4>[ 0.547336] act8846_i2c_probe: act8846_pmic_hold=1
<4>[ 0.547357] act8846_i2c_probe: act8846_pmic_sleep=1
<4>[ 0.547373] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
<4>[ 0.547387] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
<6>[ 0.549480] act_dcdc1: 1200 mV
<6>[ 0.552462] vccio: 3300 mV
<6>[ 0.554320] vdd_logic: 700 ↔ 1500 mV at 1100 mV
<6>[ 0.557260] act_dcdc4: 2000 mV
<6>[ 0.558494] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
<6>[ 0.560831] act_ldo2: 1050 mV
<6>[ 0.563137] act_ldo3: 2800 mV
<6>[ 0.565439] act_ldo4: 3300 mV
<6>[ 0.567727] act_ldo5: 3300 mV
<6>[ 0.570042] act_ldo6: 1100 mV
<6>[ 0.572335] vcc_18: 1800 mV
<6>[ 0.574636] act_ldo8: 1850 mV
<6>[ 0.579377] vdd_arm: 712 ↔ 1500 mV at 1000 mV
<6>[ 0.584065] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
<4>[ 0.584828] rk808_i2c_probe,line=1355
<4>[ 0.586156] The device is not rk808 -11
<4>[ 0.586239] rk808: probe of 0-001b failed with error -11
<4>[ 0.586318] i2c-core: driver [rk818] using legacy suspend method
<4>[ 0.586328] i2c-core: driver [rk818] using legacy resume method
<6>[ 0.588030] Switching to clocksource arch_sys_counter
<6>[ 0.611886] rga: Module initialized.
<6>[ 0.612617] rga2 ff920000.rga: rga ion client create success!
<6>[ 0.612790] rga: Driver loaded succesfully
<6>[ 0.612989] fb disp policy is box
<7>[ 0.613001] uboot-logo-on:1
<6>[ 0.613032] rk-fb rockchip-fb: rk fb ion client create success!
<6>[ 0.613044] rk-fb rockchip-fb: rockchip framebuffer driver probe
<6>[ 0.613345] rk-screen rk_screen.8: rockchip screen probe success
<6>[ 0.613501] ===================================================ssssssssssssssssssssssssssss=====================
<6>[ 0.613740] rk32-edp rk32-edp: rk32 edp driver probe success
<3>[ 0.614117] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
<6>[ 0.614339] graphics fb0: rockchip framebuffer registerd:fb0
<6>[ 0.614651] graphics fb1: rockchip framebuffer registerd:fb1
<6>[ 0.614829] graphics fb2: rockchip framebuffer registerd:fb2
<6>[ 0.614991] graphics fb3: rockchip framebuffer registerd:fb3
<6>[ 0.615708] rk3288-lcdc lcdc0: lcdc0: dclk:265000000>>fps:121
<6>[ 0.615733] rk3288-lcdc lcdc0: lcdc0: dclk:265000000>>fps:121
<6>[ 0.615743] rk3288_load_screen[1413] ====================
<6>[ 0.615945] rk32-edp rk32-edp: edp pll locked
<6>[ 0.616976] rk32-edp rk32-edp: max link rate:2.70Gps max number of lanes:4
<6>[ 0.617984] =========== val = 1
<6>[ 0.617996] rk32-edp rk32-edp: link training success.
<4>[ 0.639627] rk_battery_charger_detect_cb , battery_charger_detect 1
<6>[ 0.647611] rk3288-lcdc lcdc0: wakeup from standby!
<6>[ 0.678379] alloc_buffer:ion_phy_addr=0x10000000
<6>[ 0.691328] fb0:phy:10000000>>vir:e0991000>>len:0x1800000
<6>[ 0.701920] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eabd000
<6>[ 0.701938] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
<3>[ 0.702163] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
<4>[ 0.702175] rk_fb_trsm_ops_get:un supported transmitter:0!
<6>[ 0.702439] graphics fb4: rockchip framebuffer registerd:fb4
<6>[ 0.702780] graphics fb5: rockchip framebuffer registerd:fb5
<6>[ 0.702953] graphics fb6: rockchip framebuffer registerd:fb6
<6>[ 0.703124] graphics fb7: rockchip framebuffer registerd:fb7
<6>[ 0.703925] rk3288-lcdc lcdc1: wakeup from standby!
<6>[ 0.707761] fb4:phy:10000000>>vir:e0991000>>len:0x1800000
<6>[ 0.707786] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
<4>[ 0.708167] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.708309] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.708424] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.708549] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.708667] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.708780] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.709376] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.709537] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.710090] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.710245] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.710787] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.710940] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.711475] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.711628] rockchip_set_mux:warning ignore bank num 15
<6>[ 0.713163] NET: Registered protocol family 2
<6>[ 0.713849] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 0.713925] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 0.713997] TCP: Hash tables configured (established 4096 bind 4096)
<6>[ 0.714052] TCP: reno registered
<6>[ 0.714067] UDP hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.714091] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.714279] NET: Registered protocol family 1
<6>[ 0.714914] Unpacking initramfs…
<6>[ 0.786035] Freeing initrd memory: 1304K (c5bf0000 - c5d36000)
<6>[ 0.786771] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
<6>[ 0.787330] vcodec_service: probe device ff9a0000.vpu_service
<4>[ 0.787529] vcodec_service: No reset resource define
<6>[ 0.787731] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 0.787817] vcodec_service: probe device ff9a0000.vpu_service
<6>[ 0.787833] vcodec_service: checking hw id 4831
<6>[ 0.788830] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 0.788874] vcodec_service: done
<6>[ 0.788883] vcodec_service: init success
<6>[ 0.788954] vcodec_service: probe device ff9c0000.hevc_service
<6>[ 0.789287] vcodec_service: ff9c0000.hevc_service: power on
<6>[ 0.789346] vcodec_service: probe device ff9c0000.hevc_service
<6>[ 0.789361] vcodec_service: checking hw id 6867
<6>[ 0.789942] vcodec_service: ff9c0000.hevc_service: power off…
<6>[ 0.789984] vcodec_service: done
<6>[ 0.789993] vcodec_service: init success
<4>[ 0.790131] rknandbase v1.0 2014-03-31
<4>[ 0.790264] rknand: probe of ff400000.nandc failed with error -1
<4>[ 0.790373] rknand_driver:ret = 0
<6>[ 0.792189] audit: initializing netlink socket (disabled)
<5>[ 0.792233] type=2000 audit(0.440:1): initialized
<4>[ 0.793063] bounce pool size: 64 pages
<6>[ 0.797651] fuse init (API version 7.22)
<6>[ 0.798029] msgmni has been set to 952
<7>[ 0.798080] SELinux: Registering netfilter hooks
<6>[ 0.799822] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
<6>[ 0.799838] io scheduler noop registered
<6>[ 0.799847] io scheduler deadline registered
<6>[ 0.799936] io scheduler cfq registered (default)
<6>[ 0.801079] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
<4>[ 0.801644] IEP Driver loaded succesfully
<4>[ 0.801731] Module initialized.
<6>[ 0.802548] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 0.802566] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
<6>[ 0.803925] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 0.803943] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
<3>[ 0.804234] pwm-voltage-regulator pwm_regulator.22: unable to request PWM, trying legacy API
<3>[ 0.804248] pwm-voltage-regulator pwm_regulator.22: unable to request legacy PWM
<4>[ 0.804257] pwm_regulator_probe:error
<6>[ 0.804277] platform pwm_regulator.22: Driver pwm-voltage-regulator requests probe deferral
<4>[ 0.804468] rk_serial.c v1.8 2014-03-04
<6>[ 0.804742] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
<6>[ 0.804935] serial ff180000.serial: membase e097e000
<6>[ 0.805103] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
<6>[ 0.805276] serial ff190000.serial: membase e419c000
<6>[ 0.805416] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
<4>[ 0.805502] 2, baud is:115200
<6>[ 0.807057] console [ttyS2] enabled
<6>[ 0.807231] serial ff690000.serial: membase fed60000
<6>[ 0.807415] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
<6>[ 0.807587] serial ff1b0000.serial: membase e419e000
<6>[ 0.810380] loop: module loaded
<6>[ 0.810780] zram: Created 1 device(s) …
<4>[ 0.810866] i2c-core: driver [mpu6050B1] using legacy suspend method
<4>[ 0.810878] i2c-core: driver [mpu6050B1] using legacy resume method
<6>[ 0.810897] mpu_init: Probe name mpu6050B1
<6>[ 0.811058] ak8963_mod_init: Probe name ak8963_mod
<6>[ 0.811763] SCSI Media Changer driver v0.25
<6>[ 0.812017] dws->regs: e41be000
<4>[ 0.813225] rockchip_spi_probe:num_cs=2,bus_num=0,irq=76,freq=45692308 ok
<6>[ 0.813504] tun: Universal TUN/TAP device driver, 1.6
<6>[ 0.813517] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
<4>[ 0.813649] vmac_init.
<3>[ 0.814243] stmmac_probe_config_dt: Can not read property: pmu_regulator.
<6>[ 0.814259] stmmac_probe_config_dt: clock input/output? (input).
<6>[ 0.814273] stmmac_probe_config_dt: TX delay(0x30).
<6>[ 0.814284] stmmac_probe_config_dt: RX delay(0x20).
<7>[ 0.814298] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 0.814314] of_get_named_gpio_flags exited with status 136
<7>[ 0.814324] of_get_named_gpio_flags: can’t parse gpios property
<6>[ 0.814335] stmmac_probe_config_dt: is rockchip,rk3288-gmac
<6>[ 0.814346] stmmc_pltfr_init:
<3>[ 0.814355] stmmc_pltfr_init: ERROR: Get power-gpio failed.
<7>[ 0.814369] _gpio_request: gpio-136 (gmac_phy_reset) status -16
<3>[ 0.814378] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
<6>[ 0.814390] stmmc_pltfr_init: init for RGMII
<6>[ 0.814423] tx delay=0x30
<6>[ 0.814423] rx delay=0x20
<6>[ 0.814440] tx delay=0x30
<6>[ 0.814440] rx delay=0x20
<6>[ 0.814887] stmmac - user ID: 0x10, Synopsys ID: 0x35
<6>[ 0.814900] Normal descriptors
<6>[ 0.814927] Ring mode enabled
<6>[ 0.814939] DMA HW capability register supported
<6>[ 0.814951] RX Checksum Offload Engine supported (type 2)
<6>[ 0.814962] TX Checksum insertion supported
<6>[ 0.814971] Wake-Up On Lan supported
<6>[ 0.815008] Enable RX Mitigation via HW Watchdog Timer
<6>[ 0.815446] PPP generic driver version 2.4.2
<6>[ 0.815628] PPP BSD Compression module registered
<6>[ 0.815643] PPP Deflate Compression module registered
<6>[ 0.815669] PPP MPPE Compression module registered
<6>[ 0.815681] NET: Registered protocol family 24
<6>[ 0.815721] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
<6>[ 0.815735] CSLIP: code copyright 1989 Regents of the University of California.
<4>[ 0.815749] Rockchip WiFi SYS interface (V1.00) …
<4>[ 0.815784] esp_mem_init enter date Mar 22 2017 11:47:26
<4>[ 0.815795] esp_mem_init VERSION [V2.5]
<4>[ 0.815836] esp_mem_init complete
<6>[ 0.815923] usbcore: registered new interface driver catc
<6>[ 0.815962] usbcore: registered new interface driver kaweth
<6>[ 0.815976] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
<6>[ 0.816015] usbcore: registered new interface driver pegasus
<6>[ 0.816059] usbcore: registered new interface driver rtl8150
<6>[ 0.816099] usbcore: registered new interface driver r8152
<6>[ 0.816111] hso: drivers/net/usb/hso.c: Option Wireless
<6>[ 0.816187] usbcore: registered new interface driver hso
<6>[ 0.816233] usbcore: registered new interface driver asix
<6>[ 0.816274] usbcore: registered new interface driver ax88179_178a
<6>[ 0.816314] usbcore: registered new interface driver cdc_ether
<6>[ 0.816352] usbcore: registered new interface driver cdc_eem
<6>[ 0.816389] usbcore: registered new interface driver dm9601
<6>[ 0.816427] usbcore: registered new interface driver dm9620
<6>[ 0.816479] usbcore: registered new interface driver smsc75xx
<6>[ 0.816526] usbcore: registered new interface driver smsc95xx
<6>[ 0.816565] usbcore: registered new interface driver gl620a
<6>[ 0.816604] usbcore: registered new interface driver net1080
<6>[ 0.816643] usbcore: registered new interface driver plusb
<6>[ 0.816684] usbcore: registered new interface driver rndis_host
<6>[ 0.816727] usbcore: registered new interface driver cdc_subset
<6>[ 0.816767] usbcore: registered new interface driver zaurus
<6>[ 0.816808] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
<6>[ 0.816872] usbcore: registered new interface driver int51x1
<6>[ 0.816912] usbcore: registered new interface driver kalmia
<6>[ 0.816951] usbcore: registered new interface driver ipheth
<6>[ 0.816993] usbcore: registered new interface driver sierra_net
<6>[ 0.817038] usbcore: registered new interface driver cx82310_eth
<6>[ 0.817086] usbcore: registered new interface driver cdc_ncm
<6>[ 0.817127] usbcore: registered new interface driver qmi_wwan
<6>[ 0.817166] usbcore: registered new interface driver cdc_mbim
<6>[ 0.817179] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
<6>[ 0.819638] EHCI: ehci_rk_probe e4240000 e4240010
<6>[ 0.819655] rockchip_ehci_host ff500000.usb: EHCI Host Controller
<6>[ 0.819689] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
<6>[ 0.820032] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
<6>[ 0.834112] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
<6>[ 0.834195] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 0.834212] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 0.834228] usb usb1: Product: EHCI Host Controller
<6>[ 0.834241] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
<6>[ 0.834254] usb usb1: SerialNumber: ff500000.usb
<6>[ 0.834698] hub 1-0:1.0: USB hub found
<6>[ 0.834728] hub 1-0:1.0: 1 port detected
<6>[ 0.834899] EHCI: ehci_rk_probe ok
<6>[ 0.835008] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
<6>[ 0.835302] usbcore: registered new interface driver cdc_acm
<6>[ 0.835316] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
<6>[ 0.835377] usbcore: registered new interface driver usblp
<6>[ 0.835422] usbcore: registered new interface driver cdc_wdm
<6>[ 0.835482] usbcore: registered new interface driver usb-storage
<6>[ 0.835522] usbcore: registered new interface driver ums-alauda
<6>[ 0.835560] usbcore: registered new interface driver ums-cypress
<6>[ 0.835599] usbcore: registered new interface driver ums-datafab
<6>[ 0.835636] usbcore: registered new interface driver ums_eneub6250
<6>[ 0.835674] usbcore: registered new interface driver ums-freecom
<6>[ 0.835715] usbcore: registered new interface driver ums-isd200
<6>[ 0.835760] usbcore: registered new interface driver ums-jumpshot
<6>[ 0.835798] usbcore: registered new interface driver ums-karma
<6>[ 0.835837] usbcore: registered new interface driver ums-onetouch
<6>[ 0.835876] usbcore: registered new interface driver ums-sddr09
<6>[ 0.835918] usbcore: registered new interface driver ums-sddr55
<6>[ 0.835959] usbcore: registered new interface driver ums-usbat
<6>[ 0.836044] usbcore: registered new interface driver usbserial
<6>[ 0.836088] usbcore: registered new interface driver usbserial_generic
<6>[ 0.836126] usbserial: USB Serial support registered for generic
<6>[ 0.836169] usbcore: registered new interface driver option
<6>[ 0.836201] usbserial: USB Serial support registered for GSM modem (1-port)
<6>[ 0.836278] usbcore: registered new interface driver trancevibrator
<6>[ 0.836291] usb20_otg: version 3.10a 21-DEC-2012
<4>[ 0.836732] e4280040
<4>[ 0.836746] Core Release: 3.10a
<4>[ 0.836758] Setting default values for core params
<4>[ 0.836894] Using Buffer DMA mode
<4>[ 0.836907] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 0.836918] Multiprocessor Interrupt Enhancement - disabled
<4>[ 0.836930] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 0.836941] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 0.836955] Dedicated Tx FIFOs mode
<4>[ 0.836975] pcd_init otg_dev = ddf3f840
<6>[ 0.837130] usb20_otg ff580000.usb: DWC OTG Controller
<6>[ 0.837160] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
<6>[ 0.837190] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
<6>[ 0.837249] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 0.837266] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 0.837281] usb usb2: Product: DWC OTG Controller
<6>[ 0.837294] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 0.837307] usb usb2: SerialNumber: ff580000.usb
<6>[ 0.837715] hub 2-0:1.0: USB hub found
<6>[ 0.837738] hub 2-0:1.0: 1 port detected
<6>[ 0.838051] usb20_host: version 3.10a 21-DEC-2012
<4>[ 0.840557] e4300040
<4>[ 0.840569] Core Release: 3.10a
<4>[ 0.840581] Setting default values for core params
<4>[ 0.840687] Using Buffer DMA mode
<4>[ 0.840697] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 0.840708] Multiprocessor Interrupt Enhancement - disabled
<4>[ 0.840720] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 0.840730] ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 0.840753] usb20_host ff540000.usb: DWC OTG Controller
<6>[ 0.840780] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
<6>[ 0.840811] usb20_host ff540000.usb: irq 57, io mem 0x00000000
<4>[ 0.840905] Init: Power Port (0)
<6>[ 0.840976] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 0.840994] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 0.841009] usb usb3: Product: DWC OTG Controller
<6>[ 0.841021] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 0.841034] usb usb3: SerialNumber: ff540000.usb
<6>[ 0.841435] hub 3-0:1.0: USB hub found
<6>[ 0.841457] hub 3-0:1.0: 1 port detected
<6>[ 0.842151] usbcore: registered new interface driver xpad
<6>[ 0.842209] usbcore: registered new interface driver usb_acecad
<6>[ 0.842264] usbcore: registered new interface driver aiptek
<6>[ 0.842311] usbcore: registered new interface driver gtco
<6>[ 0.842357] usbcore: registered new interface driver hanwang
<6>[ 0.842403] usbcore: registered new interface driver kbtab
<6>[ 0.842457] usbcore: registered new interface driver wacom
<4>[ 0.842741] sensor_register_slave:mma8452,id=17
<4>[ 0.842756] sensor_register_slave:gs_mc3230,id=23
<4>[ 0.842766] gsensor_init
<4>[ 0.842777] sensor_register_slave:mpu6880_acc,id=24
<4>[ 0.842788] sensor_register_slave:mpu6500_acc,id=25
<4>[ 0.842800] sensor_register_slave:cm3217,id=48
<4>[ 0.842811] sensor_register_slave:cm3218,id=49
<3>[ 0.843027] .. rk pwm remotectl v1.1 init
<6>[ 0.843256] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
<7>[ 0.846273] of_get_named_gpio_flags exited with status 228
<6>[ 0.848237] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
<6>[ 0.848296] i2c /dev entries driver
<6>[ 0.848989] IR NEC protocol handler initialized
<6>[ 0.849002] IR RC5(x) protocol handler initialized
<6>[ 0.849013] IR RC6 protocol handler initialized
<6>[ 0.849023] IR JVC protocol handler initialized
<6>[ 0.849033] IR Sony protocol handler initialized
<6>[ 0.849043] IR RC5 (streamzap) protocol handler initialized
<6>[ 0.849053] IR SANYO protocol handler initialized
<6>[ 0.849063] IR MCE Keyboard/mouse protocol handler initialized
<6>[ 0.849218] usbcore: registered new interface driver uvcvideo
<6>[ 0.849230] USB Video Class driver (1.1.1)
<4>[ 0.849243] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
<7>[ 0.850705] of_get_named_gpio_flags exited with status 236
<4>[ 0.850718] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
<7>[ 0.850733] of_get_named_gpio_flags exited with status 236
<4>[ 0.850743] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
<4>[ 0.850764] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
<4>[ 0.850785] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
<4>[ 0.850824] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
<4>[ 0.850824]
<4>[ 0.850896] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
<4>[ 0.851064] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe41f8000 size: 0x4000)
<4>[ 0.851680] D1:camsys_platform_probe(1447): ff910000.isp memory:
<4>[ 0.851699] D1:camsys_platform_probe(1457): Register memory (phy: 0xff910000 vir: 0xe4220000 size: 0x10000)
<4>[ 0.851716] D1:camsys_platform_probe(1452): I2c memory (phy: 0x1dfd0000 vir: 0xddfd0000 size: 0x1000)
<4>[ 0.851731] D1:camsys_init_ext_fsh_module(20): init external flash module
<4>[ 0.851744] D1:camsys_platform_probe(1472): Probe ff910000.isp device success
<6>[ 0.852192] not find test_power_init dev node
<4>[ 0.852251] i2c-core: driver [bq27320] using legacy suspend method
<4>[ 0.852263] i2c-core: driver [bq27320] using legacy resume method
<4>[ 0.852596] rockchip_temp_probe,line=364
<6>[ 0.902986] tsadc ff280000.tsadc: initialized
<6>[ 0.903368] device-mapper: uevent: version 1.0.3
<6>[ 0.903615] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
<6>[ 0.903910] Bluetooth: HCI UART driver ver 2.2
<6>[ 0.903927] Bluetooth: HCI H4 protocol initialized
<6>[ 0.903938] Bluetooth: HCILL protocol initialized
<6>[ 0.903950] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
<6>[ 0.903962] rtk_btusb: Register usb char device interface for BT driver
<6>[ 0.904141] usbcore: registered new interface driver rtk_btusb
<4>[ 0.907531] cpufreq version 1.0, suspend freq 1200 MHz
<6>[ 0.907731] cpuidle: using governor ladder
<6>[ 0.907745] cpuidle: using governor menu
<6>[ 0.907783] Synopsys Designware Multimedia Card Interface Driver
<6>[ 0.907794] MHSC version = Ver 2.00 2015-06-10
<4>[ 0.908126] dw cru_regsbase addr 0x1d8.
<4>[ 0.908139] dw cru_reset_offset val 3.
<6>[ 0.908155] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
<3>[ 0.908197] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
<6>[ 0.908502] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
<4>[ 0.908691] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
<7>[ 0.908723] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 0.908834] 1358..dw_mci_set_ios: no card. [mmc0]
<4>[ 0.922667] 1358..dw_mci_set_ios: no card. [mmc0]
<4>[ 0.942372] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
<6>[ 0.942392] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
<6>[ 0.942408] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
<4>[ 0.942737] dw cru_regsbase addr 0x1d8.
<4>[ 0.942750] dw cru_reset_offset val 0.
<6>[ 0.942764] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
<3>[ 0.942804] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
<6>[ 0.943555] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
<4>[ 0.943735] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
<7>[ 0.943762] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 0.944262] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
<4>[ 0.944329] 1358..dw_mci_set_ios: no card. [mmc1]
<4>[ 0.962020] 1358..dw_mci_set_ios: no card. [mmc1]
<6>[ 0.974485] mmc0: BKOPS_EN bit is not set
<4>[ 0.976354] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
<6>[ 0.978635] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
<4>[ 0.978659] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
<6>[ 0.978680] [mmc0] tuning regsbase addr 0x218.
<3>[ 0.979554] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-282 (26 len)
<3>[ 0.979566] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-282 (26 len)
<3>[ 0.979577] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 147
<6>[ 0.979618] mmc0: new HS200 MMC card at address 0001
<6>[ 0.979896] mmcblk0: mmc0:0001 8WPD3R 7.28 GiB
<6>[ 0.980205] uboot: 0x000400000 – 0x000800000 (4 MB)
<6>[ 0.980217] misc: 0x000800000 – 0x000c00000 (4 MB)
<6>[ 0.980227] resource: 0x000c00000 – 0x001c00000 (16 MB)
<6>[ 0.980236] kernel: 0x001c00000 – 0x002c00000 (16 MB)
<6>[ 0.980245] boot: 0x002c00000 – 0x004c00000 (32 MB)
<6>[ 0.980253] recovery: 0x004c00000 – 0x006c00000 (32 MB)
<6>[ 0.980262] backup: 0x006c00000 – 0x00a000000 (52 MB)
<6>[ 0.980270] cache: 0x00a000000 – 0x012000000 (128 MB)
<6>[ 0.980279] kpanic: 0x012000000 – 0x012400000 (4 MB)
<6>[ 0.980287] system: 0x012400000 – 0x072400000 (1536 MB)
<6>[ 0.980296] metadata: 0x072400000 – 0x073400000 (16 MB)
<6>[ 0.980304] baseparamer: 0x073400000 – 0x073800000 (4 MB)
<6>[ 0.980313] userdata: 0x073800000 – 0x0b3800000 (1024 MB)
<6>[ 0.980321] radical_update: 0x0b3800000 – 0x0b7800000 (64 MB)
<6>[ 0.980330] user: 0x0b7800000 – 0x1d1c00000 (4516 MB)
<6>[ 0.981750] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
<6>[ 0.981764] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
<6>[ 0.980359] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p151358..dw_mci_set_ios: no card. [mmc1]
<4>[ 0.982087] dw cru_regsbase addr 0x1d8.
<4>[ 0.982096] dw cru_reset_offset val 1.
<6>[ 0.982106] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
<3>[ 0.982145] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
<6>[ 0.982366] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
<4>[ 0.982493] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
<7>[ 0.982514] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 0.982756] 1358..dw_mci_set_ios: no card. [mmc2]
<4>[ 1.001371] 1358..dw_mci_set_ios: no card. [mmc2]
<4>[ 1.021079] 1358..dw_mci_set_ios: no card. [mmc2]
<6>[ 1.021092] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
<6>[ 1.021105] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
<4>[ 1.021408] leds-gpio leds.29: pins are not configured from the driver
<7>[ 1.021427] of_get_named_gpio_flags exited with status 257
<7>[ 1.021435] of_get_named_gpio_flags exited with status 258
<7>[ 1.021444] of_get_named_gpio_flags exited with status 257
<7>[ 1.021522] of_get_named_gpio_flags exited with status 258
<6>[ 1.021627] hidraw: raw HID events driver (C) Jiri Kosina
<6>[ 1.023036] usbcore: registered new interface driver usbhid
<6>[ 1.023046] usbhid: USB HID core driver
<6>[ 1.023158] ashmem: initialized
<6>[ 1.023274] logger: created 256K log ‘log_main’
<6>[ 1.023363] logger: created 256K log ‘log_events’
<6>[ 1.023463] logger: created 256K log ‘log_radio’
<6>[ 1.023551] logger: created 256K log ‘log_system’
<7>[ 1.024396] of_get_named_gpio_flags exited with status 5
<7>[ 1.024406] of_get_named_gpio_flags exited with status 5
<6>[ 1.024648] input: rk29-keypad as /devices/ff100000.adc/key.32/input/input1
<3>[ 1.025523] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
<3>[ 1.025540] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
<3>[ 1.025553] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
<3>[ 1.025564] ES8323 2-0010: Error applying setting, reverse things back
<7>[ 1.025589] of_get_named_gpio_flags exited with status 10
<7>[ 1.025600] of_get_named_gpio_flags exited with status 239
<4>[ 1.026282] es8323 probe error
<4>[ 1.026298] ES8323: probe of 2-0010 failed with error -11
<6>[ 1.027061] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
<3>[ 1.027579] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
<4>[ 1.027609] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 1.027626] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
<6>[ 1.027797] u32 classifier
<6>[ 1.027805] Actions configured
<6>[ 1.027817] Netfilter messages via NETLINK v0.30.
<6>[ 1.027877] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
<6>[ 1.028240] ctnetlink v0.93: registering with nfnetlink.
<6>[ 1.028316] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[ 1.028325] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[ 1.028634] xt_time: kernel timezone is -0000
<6>[ 1.028846] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 1.028981] arp_tables: (C) 2002 David S. Miller
<6>[ 1.029021] TCP: cubic registered
<6>[ 1.029029] Initializing XFRM netlink socket
<6>[ 1.029282] NET: Registered protocol family 10
<6>[ 1.029845] mip6: Mobile IPv6
<6>[ 1.029874] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 1.029998] sit: IPv6 over IPv4 tunneling driver
<6>[ 1.030373] NET: Registered protocol family 17
<6>[ 1.030400] NET: Registered protocol family 15
<5>[ 1.030460] Bridge firewalling registered
<6>[ 1.030473] Ebtables v2.0 registered
<6>[ 1.030639] Bluetooth: RFCOMM TTY layer initialized
<6>[ 1.030668] Bluetooth: RFCOMM socket layer initialized
<6>[ 1.030677] Bluetooth: RFCOMM ver 1.11
<6>[ 1.030685] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[ 1.030692] Bluetooth: BNEP filters: protocol multicast
<6>[ 1.030704] Bluetooth: BNEP socket layer initialized
<6>[ 1.030713] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[ 1.030725] Bluetooth: HIDP socket layer initialized
<6>[ 1.030755] l2tp_core: L2TP core driver, V2.0
<6>[ 1.030769] l2tp_ppp: PPPoL2TP kernel driver, V2.0
<6>[ 1.030777] [WLAN_RFKILL]: Enter rfkill_wlan_init
<6>[ 1.031017] [WLAN_RFKILL]: Enter rfkill_wlan_probe
<6>[ 1.031030] [WLAN_RFKILL]: can’t find rockchip,grf property
<6>[ 1.031039] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
<6>[ 1.031048] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
<6>[ 1.031057] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
<6>[ 1.031067] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
<7>[ 1.031082] of_get_named_gpio_flags exited with status 156
<6>[ 1.031089] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
<7>[ 1.031098] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 1.031106] of_get_named_gpio_flags exited with status 158
<6>[ 1.031113] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
<6>[ 1.031123] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
<6>[ 1.031152] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
<6>[ 1.031161] [WLAN_RFKILL]: Exit rfkill_wlan_probe
<6>[ 1.031209] [BT_RFKILL]: Enter rfkill_rk_init
<7>[ 1.031354] of_get_named_gpio_flags exited with status 147
<6>[ 1.031362] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
<7>[ 1.031373] of_get_named_gpio_flags exited with status 155
<6>[ 1.031380] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
<7>[ 1.031404] of_get_named_gpio_flags exited with status 157
<6>[ 1.031412] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
<7>[ 1.031421] of_get_named_gpio_flags exited with status 154
<6>[ 1.031427] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
<7>[ 1.031438] of_get_named_gpio_flags exited with status 159
<6>[ 1.031444] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
<6>[ 1.031490] [BT_RFKILL]: Request irq for bt wakeup host
<6>[ 1.031585] [BT_RFKILL]: ** disable irq
<6>[ 1.031674] [BT_RFKILL]: ap6335 device registered.
<4>[ 1.032482] rk3288_init_suspend
<4>[ 1.032507] rk3288_suspend_init enter
<4>[ 1.032715] rk3288_suspend_init: pm_ctrbits =200007
<4>[ 1.032754] gpio_get_dts_info suspend:4
<4>[ 1.032762] gpio_get_dts_info resume:4
<4>[ 1.032770] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 1.032802] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 1.032960] clks_gating_suspend_init:clkgt info ok
<5>[ 1.033058] Registering SWP/SWPB emulation handler
<6>[ 1.033071] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000
<6>[ 1.036448] ddrfreq: verion 1.2 20140526
<6>[ 1.036465] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
<6>[ 1.036475] ddrfreq: auto-freq=0
<6>[ 1.036482] ddrfreq: auto-freq-table[0] 240MHz
<6>[ 1.036489] ddrfreq: auto-freq-table[1] 324MHz
<6>[ 1.036496] ddrfreq: auto-freq-table[2] 456MHz
<6>[ 1.036503] ddrfreq: auto-freq-table[3] 528MHz
<6>[ 1.043533] regulator-dummy: disabling
<3>[ 1.043936] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
<4>[ 1.043961] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 1.043976] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
<4>[ 1.044004] =======================================================
<4>[ 1.044013] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
<4>[ 1.044018] =======================================================
<4>[ 1.044024] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
<4>[ 1.044082] dhd_module_init: in
<4>[ 1.044090] ======== bcm_wlan_set_plat_data ========
<6>[ 1.044096] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
<4>[ 1.044118] host_oob_irq: 195
<4>[ 1.044123] host_oob_irq_flags=4
<4>[ 1.044128] dhd_wifi_platform_load: Enter
<4>[ 1.044136] pcd_pullup, is_on 0
<4>[ 1.044143] Power-up adapter ‘DHD generic adapter’
<4>[ 1.044164] wifi_platform_set_power = 1
<4>[ 1.044169] ======== PULL WL_REG_ON HIGH! ========
<6>[ 1.044172] file system registered
<6>[ 1.044180] [WLAN_RFKILL]: rockchip_wifi_power: 1
<6>[ 1.044186] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
<6>[ 1.044192] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<6>[ 1.044715] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[ 1.044724] android_usb gadget: Number of LUNs=2
<6>[ 1.044730] lun0: LUN: removable file: (no medium)
<6>[ 1.044737] lun1: LUN: removable file: (no medium)
<6>[ 1.044878] android_usb gadget: android_usb ready
<6>[ 1.044963] sensor_init: Probe name sensors
<4>[ 1.044979] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
<6>[ 1.045510] rtc_hym8563 0-0051: setting system clock to 2000-01-01 08:27:39 UTC (946715259)
<6>[ 1.052059] rockchip-spdif-card rockchip-spdif-card.25: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
<3>[ 1.052701] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
<4>[ 1.052728] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 1.052741] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
<6>[ 1.052829] usbcore: registered new interface driver snd-usb-audio
<6>[ 1.052837] ALSA device list:
<6>[ 1.052843] #0: RK-SPDIF-CARD
<4>[ 1.053032] 2, baud is:115200
<6>[ 1.053201] Freeing unused kernel memory: 352K (c0b79000 - c0bd1000)
<6>[ 1.148972] [WLAN_RFKILL]: wifi turn on power. 156
<6>[ 1.148978] usb 1-1: new high-speed USB device number 2 using rockchip_ehci_host
<7>[ 1.168885] SELinux: 2048 avtab hash slots, 5368 rules.
<7>[ 1.170408] SELinux: 2048 avtab hash slots, 5368 rules.
<7>[ 1.170426] SELinux: 1 users, 2 roles, 442 types, 0 bools, 1 sens, 1024 cats
<7>[ 1.170433] SELinux: 86 classes, 5368 rules
<7>[ 1.171251] SELinux: Completing initialization.
<7>[ 1.171256] SELinux: Setting up existing superblocks.
<7>[ 1.171271] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<7>[ 1.171286] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
<7>[ 1.171340] SELinux: initialized (dev bdev, type bdev), not configured for labeling
<7>[ 1.171349] SELinux: initialized (dev proc, type proc), uses genfs_contexts
<7>[ 1.171362] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.171375] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
<7>[ 1.171519] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
<7>[ 1.181121] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
<7>[ 1.181136] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
<7>[ 1.181145] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
<7>[ 1.181154] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
<7>[ 1.181171] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
<7>[ 1.181213] SELinux: initialized (dev configfs, type configfs), not configured for labeling
<7>[ 1.181221] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.181240] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<5>[ 1.270414] type=1403 audit(946715259.720:2): policy loaded auid=4294967295 ses=4294967295
<6>[ 1.296950] usb 1-1: New USB device found, idVendor=0409, idProduct=005a
<6>[ 1.296970] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
<6>[ 1.297537] hub 1-1:1.0: USB hub found
<11>[ 1.297664] init: invalid gid ‘trace’
<6>[ 1.297680] hub 1-1:1.0: 3 ports detected
<3>[ 1.298630] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
<4>[ 1.298664] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 1.298684] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
<4>[ 1.355625] wifi_platform_bus_enumerate device present 1
<4>[ 1.355643] ======== Card detection to detect SDIO card! ========
<6>[ 1.355651] mmc2:mmc host rescan start!
<11>[ 1.396251] init: /dev/hw_random not found
<6>[ 1.396327] keychord: using input dev ff680000.pwm for fevent
<6>[ 1.396342] keychord: using input dev rk29-keypad for fevent
<4>[ 1.396442] 2, baud is:115200
<7>[ 1.396827] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 1.397100] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.397380] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 1.398641] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.398799] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.400019] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<11>[ 1.401277] init: /dev/hw_random not found
<14>[ 1.402222] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
<14>[ 1.403041] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs:
<4>[ 1.405962] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
<6>[ 1.410990] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 1.411020] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<14>[ 1.411083] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0
<14>[ 1.412915] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
<14>[ 1.420625] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 1.420673] e2fsck: system: clean, 1882/84672 files, 115281/393216 blocks
<6>[ 1.424522] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
<7>[ 1.424547] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<14>[ 1.424596] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0
<6>[ 1.429787] EXT4-fs (mmcblk0p8): recovery complete
<6>[ 1.429807] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 1.429826] SELinux: initialized (dev mmcblk0p8, type ext4), uses xattr
<14>[ 1.429871] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
<4>[ 1.430191] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
<6>[ 1.434900] EXT4-fs (mmcblk0p11): recovery complete
<6>[ 1.434918] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 1.434937] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
<14>[ 1.434979] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0
<14>[ 1.436232] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata
<14>[ 1.441359] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 1.441395] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
<6>[ 1.446070] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 1.446095] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
<14>[ 1.446141] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
<14>[ 1.446186] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
<14>[ 1.447105] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
<14>[ 1.447146] fsck.f2fs: fsck.f2fs terminated by exit(255)
<14>[ 1.447387] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
<4>[ 1.447704] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
<6>[ 1.471407] EXT4-fs (mmcblk0p13): recovery complete
<6>[ 1.471829] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 1.471853] SELinux: initialized (dev mmcblk0p13, type ext4), uses xattr
<14>[ 1.471905] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
<14>[ 1.472792] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
<14>[ 1.477758] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 1.477795] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 487/65536 files, 30845/262144 blocks
<6>[ 1.481948] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
<7>[ 1.481973] SELinux: initialized (dev mmcblk0p13, type ext4), uses xattr
<14>[ 1.482011] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
<11>[ 1.482032] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs
<7>[ 1.482695] SELinux: initialized (dev functionfs, type functionfs), uses genfs_contexts
<6>[ 1.496586] arm_release_ver of this mali_ko is ‘r6p0-02rel0’, rk_ko_ver is ‘13’, built at ‘09:15:10’, on ‘Oct 22 2015’.
<6>[ 1.496671] mali ffa30000.gpu: Continuing without Mali clock control
<4>[ 1.496717] mali pd enabled
<4>[ 1.496730] clk enabled
<4>[ 1.496743] MALI_DVFS_STEP = 4, div_dvfs = 10
<6>[ 1.496754] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
<6>[ 1.496763] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
<6>[ 1.496773] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
<6>[ 1.496782] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
<3>[ 1.496880] turn on mali power
<6>[ 1.496894] kbase_platform_rk_init,register_reboot_notifier
<4>[ 1.496936] hrtimer: interrupt took 13125 ns
<6>[ 1.497038] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
<6>[ 1.497814] mali ffa30000.gpu: Probed as mali0
<3>[ 1.498193] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
<4>[ 1.498229] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 1.498249] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
<3>[ 1.498916] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<3>[ 1.499555] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<3>[ 1.500149] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<6>[ 1.500907] zram0: detected capacity change from 0 to 533413888
<6>[ 1.548524] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
<4>[ 1.572117] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
<6>[ 1.572223] usb 1-1.2: new low-speed USB device number 3 using rockchip_ehci_host
<3>[ 1.577947] EXT4-fs (mmcblk0p13): Unrecognized mount option “background_gc=on” or missing value
<14>[ 1.587031] bat_cap: oldcap path is /sys/devices/ff100000.adc
<11>[ 1.587090] bat_cap: oldcap_path no exist
<6>[ 1.587283] binder: 154:154 transaction failed 29189, size 0-0
<11>[ 1.587764] init: Warning! Service displayd needs a SELinux domain defined; please fix!
<11>[ 1.591644] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
<11>[ 1.591676] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
<11>[ 1.591930] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
<6>[ 1.592400] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 1.592416] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 1.592434] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 1.592444] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 1.592465] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 1.592476] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 1.592491] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 1.592501] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<4>[ 1.595521] 0,baud is:9600
<4>[ 1.595637] 1, baud is:115200
<4>[ 1.595771] 1, baud is:115200
<4>[ 1.595854] 0,baud is:9600
<4>[ 1.600282] 2, baud is:115200
<11>[ 1.601070] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
<11>[ 1.602647] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’
<11>[ 1.603092] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
<11>[ 1.603307] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
<11>[ 1.603550] init: cannot find ‘/system/bin/akmd’, disabling ‘akmd’
<7>[ 1.604640] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<3>[ 1.605205] android_usb: already disabled
<6>[ 1.607383] read descriptors
<6>[ 1.607398] read strings
<4>[ 1.607427] pcd_pullup, is_on 1
<4>[ 1.607942] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
<4>[ 1.609476] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 1.610999] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 1.613741] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
<6>[ 1.667777] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
<4>[ 1.667804] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
<4>[ 1.667866] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
<4>[ 1.669682] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
<6>[ 1.669705] mmc2: new high speed SDIO card at address 0001
<3>[ 1.670282] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
<4>[ 1.670309] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 1.670323] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
<6>[ 1.684511] usb 1-1.2: New USB device found, idVendor=093a, idProduct=2510
<6>[ 1.684524] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
<6>[ 1.684533] usb 1-1.2: Product: USB Optical Mouse
<6>[ 1.684540] usb 1-1.2: Manufacturer: PixArt
<4>[ 1.685885] bcmsdh_register: register client driver
<4>[ 1.685955] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
<4>[ 1.686012] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
<4>[ 1.686020] bus num (host idx)=2, slot num (rca)=1
<4>[ 1.686026] found adapter info ‘DHD generic adapter’
<3>[ 1.686238] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
<4>[ 1.686252] F1 signature read @0x18000000=0x15264345
<4>[ 1.686262] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 1.686276] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
<6>[ 1.687878] input: PixArt USB Optical Mouse as /devices/ff500000.usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input2
<6>[ 1.688161] hid-generic 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-ff500000.usb-1.2/input0
<4>[ 1.688363] F1 signature OK, socitype:0x1 chip:0x4345 rev:0x6 pkg:0x2
<4>[ 1.688711] DHD: dongle ram size is set to 819200(orig 819200) at 0x198000
<4>[ 1.688755] wifi_platform_get_mac_addr
<4>[ 1.688763] ======== bcm_wlan_get_mac_address ========
<6>[ 1.688770] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
<6>[ 1.688778] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
<6>[ 1.688785] [WLAN_RFKILL]: This mac address is not valid, ignored…
<4>[ 1.688796] dhd_conf_set_chiprev: chip=0x4345, chiprev=6
<4>[ 1.688837] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
<4>[ 1.689121] wl_create_event_handler(): thread:wl_event_handler:af started
<4>[ 1.689126] tsk Enter, tsk = 0xdd58149c
<4>[ 1.689257] dhd_attach(): thread:dhd_watchdog_thread:b0 started
<4>[ 1.689309] dhd_attach(): thread:dhd_dpc:b1 started
<4>[ 1.689321] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
<4>[ 1.689352] dhd_attach(): thread:dhd_rxf:b2 started
<4>[ 1.689363] dhd_deferred_work_init: work queue initialized
<4>[ 1.689476] dhdsdio_probe_init: set use_rxchain 1 from config.txt
<3>[ 1.689585] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
<4>[ 1.689609] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 1.689624] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
<4>[ 1.694977] Dongle Host Driver, version 1.201.59.5 (r506368)
<4>[ 1.694977] Compiled in drivers/net/wireless/bcmdhd on Mar 22 2017 at 11:47:36
<4>[ 1.695369] Register interface [wlan0] MAC: ac:83:f3:06:35:9c
<4>[ 1.695369]
<4>[ 1.695383] dhd_prot_ioctl : bus is down. we have nothing to do
<4>[ 1.695421] bcmsdh_oob_intr_unregister: Enter
<4>[ 1.695428] bcmsdh_oob_intr_unregister: irq is not registered
<4>[ 1.695437] dhd_txglom_enable: enable 0
<4>[ 1.695443] dhd_bus_devreset: WLAN OFF DONE
<4>[ 1.695475] wifi_platform_set_power = 0
<4>[ 1.695482] ======== PULL WL_REG_ON LOW! ========
<6>[ 1.695488] [WLAN_RFKILL]: rockchip_wifi_power: 0
<6>[ 1.798430] [WLAN_RFKILL]: wifi shut off power.
<6>[ 1.798443] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
<6>[ 1.798449] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<4>[ 1.798501] dhd_module_init: Exit err=0
<3>[ 1.798778] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
<4>[ 1.798800] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 1.798811] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
<38>[ 1.871601] logd.auditd: start
<11>[ 2.571944] healthd: No charger supplies found
<12>[ 2.571958] healthd: No battery devices found
<6>[ 2.836648] fb_release[1481] ====================== fb0
<6>[ 2.836859] fb_release[1481] ====================== fb0
<6>[ 2.842697] rk_fb_pan_display[1391]========================
<6>[ 3.044233] fb_release[1481] ====================== fb0
<6>[ 3.065664] rk3288-lcdc lcdc0: blank mode:0
<6>[ 3.088579] fb_release[1481] ====================== fb0
<6>[ 4.029301] warning: `system_server’ uses 32-bit capabilities (legacy support in use)
<4>[ 5.340753] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 5.340764] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 5.340771] D1:camsys_open(739): camsys_marvin(de027d10) is opened!
<4>[ 5.340864] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 5.340875] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 5.340885] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
<7>[ 5.340900] of_get_named_gpio_flags exited with status 237
<7>[ 5.340905] of_get_named_gpio_flags exited with status 237
<4>[ 5.340910] rockchip_gpio_request:GPIO7-13
<4>[ 5.340919] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 5.340924] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 5.340932] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x15
<4>[ 5.340940] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7400,result=0x7400
<4>[ 5.340946] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 5.340967] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
<4>[ 5.346006] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 5.346015] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 5.346119] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 5.346146] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 5.347214] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 5.348270] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 5.349329] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
<4>[ 5.352476] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 5.352489] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 5.352499] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 5.353573] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 5.353602] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 5.355650] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 5.355664] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 5.355673] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 5.355679] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 5.355685] D1:camsys_release(763): camsys_marvin(de027d10) is closed
<4>[ 5.363506] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 5.363517] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 5.363525] D1:camsys_open(739): camsys_marvin(de027d10) is opened!
<4>[ 5.363619] D1:camsys_extdev_register(243): Get RK30_PIN3_PB4(108) gpio(active: 1) for dev_id 0x4000000 success!
<4>[ 5.363631] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x4000000 success!
<4>[ 5.363641] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x4000000 success!
<4>[ 5.363648] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
<4>[ 5.363735] D1:camsys_extdev_register(268): Extdev(dev_id: 0x4000000 dev_name: OV5640) register success
<4>[ 5.368766] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 5.368775] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 5.368879] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 5.368903] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 5.369962] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 5.371019] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 5.372073] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(108) set 0
<3>[ 5.375310] E:camsys_i2c_write(78): i2c write dev(addr:0x78) failed!
<4>[ 5.375388] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(108) set 1
<4>[ 5.375399] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 5.375409] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 5.376485] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 5.376514] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 5.378590] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x4000000) is deregister success
<4>[ 5.378607] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 5.378620] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 5.378627] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 5.378635] D1:camsys_release(763): camsys_marvin(de027d10) is closed
<4>[ 5.383846] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 5.383856] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 5.383864] D1:camsys_open(739): camsys_marvin(de027d10) is opened!
<4>[ 5.383939] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
<4>[ 5.383964] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
<4>[ 5.388996] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 5.389005] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 5.389109] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 5.389133] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
<3>[ 5.390186] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<3>[ 5.391237] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 5.392298] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 5.395793] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
<3>[ 5.397259] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
<3>[ 5.397326] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 5.397334] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 5.397341] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<4>[ 5.398433] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 5.398463] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 5.400512] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
<4>[ 5.400526] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 5.400536] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 5.400543] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 5.400549] D1:camsys_release(763): camsys_marvin(de027d10) is closed
<38>[ 5.402235] type=1400 audit(946715263.920:3): avc: denied { execute } for pid=495 comm=“mediaserver” name=“sh” dev=“mmcblk0p10” ino=317 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 5.402418] type=1400 audit(946715263.920:4): avc: denied { read open } for pid=495 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=317 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 5.402544] type=1400 audit(946715263.920:5): avc: denied { execute_no_trans } for pid=495 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=317 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 5.404329] type=1400 audit(946715263.920:6): avc: denied { getattr } for pid=495 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=332 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 5.404455] type=1400 audit(946715263.920:7): avc: denied { execute } for pid=495 comm=“sh” name=“toolbox” dev=“mmcblk0p10” ino=332 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 5.404543] type=1400 audit(946715263.920:8): avc: denied { read open } for pid=495 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=332 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 5.404617] type=1400 audit(946715263.920:9): avc: denied { execute_no_trans } for pid=495 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=332 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<12>[ 6.701922] healthd: battery none chg=
<6>[ 6.878385] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
<6>[ 6.878399] lowmemorykiller: oom_adj 0 => oom_score_adj 0
<6>[ 6.878404] lowmemorykiller: oom_adj 1 => oom_score_adj 58
<6>[ 6.878409] lowmemorykiller: oom_adj 2 => oom_score_adj 117
<6>[ 6.878414] lowmemorykiller: oom_adj 3 => oom_score_adj 176
<6>[ 6.878419] lowmemorykiller: oom_adj 9 => oom_score_adj 529
<6>[ 6.878424] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
<6>[ 7.243291] acc_open
<6>[ 7.243326] acc_release
<4>[ 7.348474] phy_power_on: enable = 1
<4>[ 7.387875] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
<4>[ 7.387910] eth0: device MAC address 6e:a1:0c:99:87:95
<6>[ 7.391877] libphy: stmmac: probed
<6>[ 7.391887] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
<6>[ 7.391894] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
<3>[ 7.392273] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
<4>[ 7.392295] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 7.392308] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
<4>[ 8.064878] FAT-fs (mmcblk0p15): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
<7>[ 8.064946] SELinux: initialized (dev mmcblk0p15, type vfat), uses genfs_contexts
<11>[ 8.092694] init: no such service ‘fuse_internal_sd’
<6>[ 8.630321] pm policy 0 → 1
<6>[ 8.735749] [otg id chg] last id -1 current id 1
<4>[ 8.735782] PortPower off
<4>[ 8.735792] rk_battery_charger_detect_cb , battery_charger_detect 6
<4>[ 8.837857] Using Buffer DMA mode
<4>[ 8.837884] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 8.837893] Multiprocessor Interrupt Enhancement - disabled
<4>[ 8.837901] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 8.837909] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 9.326038] vbus detect**
<4>[ 9.328236] rk_battery_charger_detect_cb , battery_charger_detect 1
<4>[ 9.509009] Using Buffer DMA mode
<4>[ 9.509032] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 9.509041] Multiprocessor Interrupt Enhancement - disabled
<4>[ 9.509049] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 9.509056] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 9.509097] soft connect!!!
<4>[ 9.623541] USB RESET
<6>[ 9.714354] android_work: sent uevent USB_STATE=CONNECTED
<4>[ 9.717697] USB RESET
<6>[ 9.848508] android_usb gadget: high-speed config #1: android
<6>[ 9.848723] android_work: sent uevent USB_STATE=CONFIGURED
<4>[ 10.440386] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.440411] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.440420] D1:camsys_open(739): camsys_marvin(de027d10) is opened!
<4>[ 10.440501] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 10.440515] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 10.440527] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
<7>[ 10.440546] of_get_named_gpio_flags exited with status 237
<7>[ 10.440553] of_get_named_gpio_flags exited with status 237
<7>[ 10.440558] _gpio_request: gpio-237 (camsys_gpio) status -16
<4>[ 10.440566] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 10.440573] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 10.440583] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x15
<4>[ 10.440593] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7400,result=0x7400
<4>[ 10.440601] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 10.440624] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
<4>[ 10.445765] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 10.445780] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 10.445887] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 10.445917] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 10.446999] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 10.448077] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 10.449168] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
<4>[ 10.452643] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 10.452660] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 10.452674] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 10.453782] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 10.453820] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 10.456075] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 10.456093] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 10.456106] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 10.456114] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 10.456123] D1:camsys_release(763): camsys_marvin(de027d10) is closed
<4>[ 10.457359] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.457371] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.457381] D1:camsys_open(739): camsys_marvin(de027d10) is opened!
<4>[ 10.457476] D1:camsys_extdev_register(243): Get RK30_PIN3_PB4(108) gpio(active: 1) for dev_id 0x4000000 success!
<4>[ 10.457491] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x4000000 success!
<4>[ 10.457503] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x4000000 success!
<4>[ 10.457513] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
<4>[ 10.457638] D1:camsys_extdev_register(268): Extdev(dev_id: 0x4000000 dev_name: OV5640) register success
<4>[ 10.463037] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 10.463053] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 10.463159] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 10.463190] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 10.464274] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 10.465362] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 10.466445] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(108) set 0
<3>[ 10.469735] E:camsys_i2c_write(78): i2c write dev(addr:0x78) failed!
<4>[ 10.469835] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(108) set 1
<4>[ 10.469850] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 10.469865] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 10.470964] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 10.471003] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 10.473081] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x4000000) is deregister success
<4>[ 10.473103] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 10.473116] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 10.473124] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 10.473132] D1:camsys_release(763): camsys_marvin(de027d10) is closed
<4>[ 10.473838] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.473849] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.473857] D1:camsys_open(739): camsys_marvin(de027d10) is opened!
<4>[ 10.473942] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
<4>[ 10.473974] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
<38>[ 10.476489] type=1400 audit(946715269.070:10): avc: denied { write } for pid=1010 comm=“chip.devicetest” name=“force_usb_mode” dev=“sysfs” ino=12667 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
<4>[ 10.477241] force_usb_mode_store 0->0
<4>[ 10.479024] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 10.479037] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 10.479144] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 10.479173] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
<3>[ 10.480230] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<3>[ 10.481286] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 10.482354] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 10.485888] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
<3>[ 10.487387] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
<3>[ 10.487486] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 10.487497] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 10.487505] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<4>[ 10.488629] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 10.488670] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 10.490744] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
<4>[ 10.490764] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 10.490776] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 10.490784] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 10.490792] D1:camsys_release(763): camsys_marvin(de027d10) is closed
<4>[ 10.496856] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.496872] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.496880] D1:camsys_open(739): camsys_marvin(de027d10) is opened!
<4>[ 10.498877] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 10.498895] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 10.498908] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
<7>[ 10.498930] of_get_named_gpio_flags exited with status 237
<7>[ 10.498938] of_get_named_gpio_flags exited with status 237
<7>[ 10.498946] _gpio_request: gpio-237 (camsys_gpio) status -16
<4>[ 10.498954] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 10.498962] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 10.498973] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x15
<4>[ 10.498983] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7400,result=0x7400
<4>[ 10.498993] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 10.499015] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
<4>[ 10.504083] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 10.504098] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 10.504204] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 10.504235] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 10.505313] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 10.506388] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 10.507580] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
<4>[ 10.510754] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 10.510770] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 10.510782] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 10.511874] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 10.511908] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 10.513959] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 10.513974] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 10.513985] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 10.513992] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 10.514000] D1:camsys_release(763): camsys_marvin(de027d10) is closed
<4>[ 10.515218] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.515229] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.515237] D1:camsys_open(739): camsys_marvin(de027d10) is opened!
<4>[ 10.515327] D1:camsys_extdev_register(243): Get RK30_PIN3_PB4(108) gpio(active: 1) for dev_id 0x4000000 success!
<4>[ 10.515340] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x4000000 success!
<4>[ 10.515352] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x4000000 success!
<4>[ 10.515361] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
<4>[ 10.515458] D1:camsys_extdev_register(268): Extdev(dev_id: 0x4000000 dev_name: OV5640) register success
<4>[ 10.520497] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 10.520508] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 10.520614] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 10.520641] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 10.521706] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 10.522763] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 10.523820] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(108) set 0
<3>[ 10.527040] E:camsys_i2c_write(78): i2c write dev(addr:0x78) failed!
<4>[ 10.527106] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(108) set 1
<4>[ 10.527120] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 10.527132] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 10.528211] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 10.528232] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 10.530279] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x4000000) is deregister success
<4>[ 10.530293] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 10.530302] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 10.530309] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 10.530317] D1:camsys_release(763): camsys_marvin(de027d10) is closed
<4>[ 10.530881] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.530891] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 10.530899] D1:camsys_open(739): camsys_marvin(de027d10) is opened!
<4>[ 10.530970] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
<4>[ 10.530991] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
<4>[ 10.536023] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 10.536032] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 10.536138] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 10.536159] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
<3>[ 10.537223] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<3>[ 10.538280] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 10.539334] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 10.542807] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
<3>[ 10.544252] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
<3>[ 10.544308] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 10.544316] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 10.544323] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<4>[ 10.545398] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 10.545421] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 10.547500] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
<4>[ 10.547521] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 10.547534] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 10.547541] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 10.547548] D1:camsys_release(763): camsys_marvin(de027d10) is closed
<4>[ 14.701241] force_usb_mode_store 0->0
z-order:
layer3_sel_win[3]
layer2_sel_win[2]
layer1_sel_win[1]
layer0_sel_win[0]
win0:
state:1, fmt:ARGB888, y_vir:1920, uv_vir:0
xact:1920, yact:1080, dsp_x:1920, dsp_y:1080, x_st: 0, y_st: 0
y_h_fac: 4096, y_v_fac: 4096, uv_h_fac: 4096, uv_v_fac: 4096
y_addr: 0x10fd2000, uv_addr:0x00000000
win1:
state:0, fmt:ARGB888, y_vir:1920, uv_vir:0
y_addr: 0x1362c000, uv_addr:0x00000000
win2:
state:0
fmt:ARGB888
area0: state:0, y_vir:1920, dsp_x: 1, dsp_y: 1, x_st: 0, y_st: 0, addr:0x10000000
area1: state:0, y_vir:1920, dsp_x: 1, dsp_y: 1, x_st: 0, y_st: 0, addr:0x10000000
area2: state:0, y_vir: 320, dsp_x: 1, dsp_y: 1, x_st: 0, y_st: 0, addr:0x10000000
area3: state:0, y_vir: 320, dsp_x: 1, dsp_y: 1, x_st: 0, y_st: 0, addr:0x10000000
win3:
state:0
fmt:ARGB888
area0: state:0, y_vir: 320, dsp_x: 320, dsp_y: 240, x_st: 0, y_st: 0, addr:0x00000000
area1: state:0, y_vir: 320, dsp_x: 320, dsp_y: 240, x_st: 0, y_st: 0 addr:0x00000000
area2: state:0, y_vir: 320, dsp_x: 320, dsp_y: 240, x_st: 0, y_st: 0, addr:0x00000000
area3: state:0, y_vir: 320, dsp_x: 320, dsp_y: 240, x_st: 0, y_st: 0, addr:0x00000000
分辨率是多少??
刷新率这么高。。。rk3288-lcdc lcdc0: lcdc0: dclk:265000000>>fps:121
loading 发表于 2017-3-23 18:48
分辨率是多少??
是转hdmi输出,接的是电视屏
edp初始那些都成功,应该是有信号的才是
