串口debug信息打印是不是可以开使能
串口信息打印不完全,是不是有什么配置选项可以选择开启 debug 模式打印输出?
烧录了4.4的编译出啦的内核之后,串口信息变少了,很多关键的通讯都看不到,求解
我做LCM 驱动 debug 包含显示和touch 功能调试
串口输出为:(能不能打更完整的信息,kernal启动之后就完全没有信息输出了)
DDR Version 1.00 20141007
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-02 (Nov 26 2014 - 09:28:44)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-7 pin-5
pmic:ricoh619
#Boot ver: 2014-11-26#2.17
empty serial no.
checkKey
vbus = 1
rockusb key pressed.
SRX
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:ricoh619
empty serial no.
checkKey
vbus = 1
ricoh619_charger_setting iset1:0x18 chgiset:0xd3 current 2
RICOH619_FG capacity = 7, voltage_uV = 3780,state_of_chrg=2
failed to load fdt from boot!
kernel @ 0x02000000 (0x00653bf0)
ramdisk @ 0x04bf0000 (0x00124de7)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 04809000, end 0482705c … OK
我想要打的信息是类如下:
<6>[ 0.000000] Booting Linux on physical CPU 0x500
<6>[ 0.000000] Initializing cgroup subsys cpu
<6>[ 0.000000] Initializing cgroup subsys cpuacct
<5>[ 0.000000] Linux version 3.10.0 (root@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #26 SMP PREEMPT Fri Mar 24 16:04:11 CST 2017
<4>[ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
<4>[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
<6>[ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288
<4>[ 0.000000] hdmi init vic is -1
<4>[ 0.000000] rockchip_ion_reserve
<6>[ 0.000000] ion heap(cma): base(40000000) size(28000000) align(0)
<6>[ 0.000000] ion heap(vmalloc): base(0) size(0) align(0)
<6>[ 0.000000] cma: CMA: reserved 640 MiB at 40000000
<6>[ 0.000000] ion_reserve: cma reserved base 40000000 size 671088640
<6>[ 0.000000] cma: CMA: reserved 16 MiB at 2e800000
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
<7>[ 0.000000] On node 0 totalpages: 524288
<7>[ 0.000000] free_area_init_node: node 0, pgdat c0c79e40, node_mem_map c0da0000
<7>[ 0.000000] Normal zone: 1520 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 194560 pages, LIFO batch:31
<7>[ 0.000000] HighMem zone: 2576 pages used for memmap
<7>[ 0.000000] HighMem zone: 329728 pages, LIFO batch:31
<6>[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1dde000 s14016 r8192 d14656 u36864
<7>[ 0.000000] pcpu-alloc: s14016 r8192 d14656 u36864 alloc=9*4096
<7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768
<5>[ 0.000000] Kernel command line: console=ttyFIQ0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 board.ap_has_alsa=0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00020000@0x00414000(radical_update),-@0x00434000(user) storagemedia=emmc loader.timestamp=2014-11-26_09:28:44 hdmi.vic=-1
<6>[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ 0.000000] allocated 4194304 bytes of page_cgroup
<6>[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
<6>[ 0.000000] Memory: 2048MB = 2048MB total
<5>[ 0.000000] Memory: 1388464k/1388464k available, 708688k reserved, 663552K highmem
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .text : 0xc0008000 - 0xc0ae39a4 (11119 kB)
<5>[ 0.000000] .init : 0xc0ae4000 - 0xc0b786c0 ( 594 kB)
<5>[ 0.000000] .data : 0xc0b7a000 - 0xc0c81678 (1054 kB)
<5>[ 0.000000] .bss : 0xc0c81678 - 0xc0d9f804 (1145 kB)
<6>[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
<6>[ 0.000000] Preemptible hierarchical RCU implementation.
<6>[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
<6>[ 0.000000] NR_IRQS:16 nr_irqs:16 16
<4>[ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000
<4>[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0
<4>[ 0.000000] rkclk_init_clks: cnt_parent = 7
<4>[ 0.000000] rkclk_init_clks: cnt_rate = 31
<4>[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
<6>[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
<6>[ 0.000000] Switching to timer-based delay loop
<6>[ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns
<6>[ 0.000000] process version: 3
<6>[ 0.000000] channel:0, lkg:13
<6>[ 0.000000] target-temp:80
<6>[ 0.000000] channel:2, lkg:0
<6>[ 0.000000] channel:1, lkg:13
<6>[ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
<6>[ 0.306678] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
<6>[ 0.306693] pid_max: default: 32768 minimum: 301
<6>[ 0.306799] Security Framework initialized
<6>[ 0.306815] SELinux: Initializing.
<7>[ 0.306839] SELinux: Starting in permissive mode
<6>[ 0.306886] Mount-cache hash table entries: 512
<6>[ 0.307533] Initializing cgroup subsys debug
<6>[ 0.307548] Initializing cgroup subsys memory
<6>[ 0.307575] Initializing cgroup subsys freezer
<6>[ 0.307604] CPU: Testing write buffer coherency: ok
<3>[ 0.307912] /cpus/cpu@0 missing clock-frequency property
<3>[ 0.307925] /cpus/cpu@1 missing clock-frequency property
<3>[ 0.307934] /cpus/cpu@2 missing clock-frequency property
<3>[ 0.307943] /cpus/cpu@3 missing clock-frequency property
<6>[ 0.308005] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
<6>[ 0.308055] Setting up static identity map for 0xc07e36d0 - 0xc07e3728
<6>[ 0.311158] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x16b4 (version 3.0)
<4>[ 0.384737] CPU1: Booted secondary processor
<6>[ 0.384770] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
<4>[ 0.404418] CPU2: Booted secondary processor
<6>[ 0.404442] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
<4>[ 0.424131] CPU3: Booted secondary processor
<6>[ 0.424154] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
<6>[ 0.424253] Brought up 4 CPUs
<6>[ 0.424282] SMP: Total of 4 processors activated (192.00 BogoMIPS).
<6>[ 0.424290] CPU: All CPU(s) started in SVC mode.
<6>[ 0.425016] devtmpfs: initialized
<6>[ 0.429932] pinctrl core: initialized pinctrl subsystem
<6>[ 0.430183] regulator-dummy: no parameters
<6>[ 0.441605] NET: Registered protocol family 16
<6>[ 0.443392] DMA: preallocated 256 KiB pool for atomic coherent allocations
<6>[ 0.443742] ion_snapshot: 0x2e248000 map to 0xf0107000 and copy to 0xc0d7adc4 (version 0.1)
<6>[ 0.444058] Registered FIQ tty driver
<3>[ 0.444476] fiq-debugger is disabled in device tree
<4>[ 0.445053] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
<4>[ 0.445082] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
<4>[ 0.445100] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
<4>[ 0.445116] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
<4>[ 0.445206] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
<4>[ 0.445271] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
<4>[ 0.445330] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
<4>[ 0.445389] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
<4>[ 0.445449] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
<4>[ 0.445508] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
<4>[ 0.445568] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
<4>[ 0.445630] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
<4>[ 0.445697] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
<4>[ 0.445759] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
<4>[ 0.445773] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
<4>[ 0.445784] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
<4>[ 0.445796] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
<7>[ 0.445864] gpiochip_add: registered GPIOs 0 to 31 on device: gpio0
<7>[ 0.445909] gpiochip_add: registered GPIOs 32 to 63 on device: gpio1
<7>[ 0.445953] gpiochip_add: registered GPIOs 64 to 95 on device: gpio2
<7>[ 0.446002] gpiochip_add: registered GPIOs 96 to 127 on device: gpio3
<7>[ 0.446046] gpiochip_add: registered GPIOs 128 to 159 on device: gpio4
<7>[ 0.446091] gpiochip_add: registered GPIOs 160 to 191 on device: gpio5
<7>[ 0.446135] gpiochip_add: registered GPIOs 192 to 223 on device: gpio6
<7>[ 0.446185] gpiochip_add: registered GPIOs 224 to 255 on device: gpio7
<7>[ 0.446229] gpiochip_add: registered GPIOs 256 to 287 on device: gpio8
<7>[ 0.446273] gpiochip_add: registered GPIOs 288 to 319 on device: gpio15
<4>[ 0.446305] rockchip_interrupts_register:bank_num=7
<4>[ 0.448220] rockchip_pinctrl_probe:init ok
<6>[ 0.454229] rk_iommu ff900800.iep_mmu: (iep) Enter
<6>[ 0.454323] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.454337] rk_iommu ff900800.iep_mmu: (iep) Initialized
<6>[ 0.454504] rk_iommu ff950800.vip_mmu: (vip) Enter
<6>[ 0.454573] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.454585] rk_iommu ff950800.vip_mmu: (vip) Initialized
<6>[ 0.454744] rk_iommu ff930300.vopb_mmu: (vopb) Enter
<6>[ 0.454813] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.454826] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
<6>[ 0.454990] rk_iommu ff940300.vopl_mmu: (vopl) Enter
<6>[ 0.455058] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.455070] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
<6>[ 0.455229] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
<6>[ 0.455302] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.455313] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
<6>[ 0.455476] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
<6>[ 0.455545] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.455557] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
<6>[ 0.455719] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
<6>[ 0.455789] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.455800] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
<6>[ 0.457724] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
<6>[ 0.457737] hw-breakpoint: maximum watchpoint size is 4 bytes.
<4>[ 0.457932] DDR DEBUG: version 1.00 20140603
<4>[ 0.457959] DDR DEBUG: Channel a:
<4>[ 0.457967] DDR DEBUG: DDR3 Device
<4>[ 0.457980] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.457989] DDR DEBUG: Channel b:
<4>[ 0.457996] DDR DEBUG: DDR3 Device
<4>[ 0.458008] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.458017] DDR DEBUG: addr=0xc89000
<4>[ 0.458027] DDR DEBUG: stride=9, size=256, halfcap=40000000
<4>[ 0.458035] DDR DEBUG: socAddr[0]=0xc89000, socAddr[1]=0xc89100
<4>[ 0.458044] DDR DEBUG: chAddr[0]=0xc89000, chAddr[1]=0xc89000
<4>[ 0.458056] DDR DEBUG: dtar[0]=0x10191000, dtar[1]=0x10191000
<4>[ 0.458295] DDR DEBUG: init success!!! freq=300MHz
<4>[ 0.458303] DDR DEBUG: Channel a:
<4>[ 0.458315] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.458327] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=3,0, DGSL=1,1 extra clock, DGPS=360,360
<4>[ 0.458340] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.458351] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.458363] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.458372] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.458380] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<4>[ 0.458387] DDR DEBUG: Channel b:
<4>[ 0.458398] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.458410] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.458422] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.458434] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.458444] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.458453] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.458461] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<6>[ 0.480110] bio: create slab at 0
<5>[ 0.480957] SCSI subsystem initialized
<6>[ 0.481105] usbcore: registered new interface driver usbfs
<6>[ 0.481149] usbcore: registered new interface driver hub
<6>[ 0.481231] usbcore: registered new device driver usb
<7>[ 0.481480] of_get_named_gpio_flags exited with status 14
<7>[ 0.481510] of_get_named_gpio_flags exited with status 12
<7>[ 0.482440] of_get_named_gpio_flags exited with status 15
<7>[ 0.482458] of_get_named_gpio_flags exited with status 16
<6>[ 0.482601] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
<7>[ 0.484518] of_get_named_gpio_flags exited with status 260
<7>[ 0.484538] of_get_named_gpio_flags exited with status 261
<6>[ 0.484690] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
<7>[ 0.485972] of_get_named_gpio_flags exited with status 201
<7>[ 0.485992] of_get_named_gpio_flags exited with status 202
<6>[ 0.486133] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
<7>[ 0.486887] of_get_named_gpio_flags exited with status 241
<7>[ 0.486905] of_get_named_gpio_flags exited with status 242
<6>[ 0.487038] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
<3>[ 0.487848] i2c i2c-4: 1 i2c clients have been registered at 0x68
<6>[ 0.488025] media: Linux media interface: v0.10
<6>[ 0.488064] Linux video capture interface: v2.00
<6>[ 0.488106] pps_core: LinuxPPS API ver. 1 registered
<6>[ 0.488116] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
<6>[ 0.488134] PTP clock support registered
<6>[ 0.488607] Rockchip ion module is successfully loaded (v1.0)
<6>[ 0.488762] Advanced Linux Sound Architecture Driver Initialized.
<6>[ 0.489142] Bluetooth: Core ver 2.16
<6>[ 0.489177] NET: Registered protocol family 31
<6>[ 0.489186] Bluetooth: HCI device and connection manager initialized
<6>[ 0.489201] Bluetooth: HCI socket layer initialized
<6>[ 0.489213] Bluetooth: L2CAP socket layer initialized
<6>[ 0.489238] Bluetooth: SCO socket layer initialized
<6>[ 0.489445] cfg80211: Calling CRDA to update world regulatory domain
<7>[ 0.490375] of_get_named_gpio_flags exited with status 13
<7>[ 0.490398] of_get_named_gpio_flags exited with status 227
<4>[ 0.490611] act8846_i2c_probe,line=898
<4>[ 0.492076] act8846 set 0xf4 error!
<4>[ 0.492159] act8846: probe of 0-005a failed with error -11
<6>[ 0.496699] vdd_arm: 712 ↔ 1500 mV at 1000 mV
<6>[ 0.501394] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
<6>[ 0.502166] Switching to clocksource arch_sys_counter
<7>[ 0.522258] uboot-logo-on:0
<6>[ 0.522297] rk-fb rockchip-fb: rk fb ion client create success!
<6>[ 0.522309] rk-fb rockchip-fb: rockchip framebuffer driver probe
<6>[ 0.522701] rk-screen rk_screen.8: rockchip screen probe success
<3>[ 0.522861] rk32-lvds ff96c000.lvds: screen is not lvds/rgb!
<4>[ 0.522881] rk32-lvds: probe of ff96c000.lvds failed with error -22
<3>[ 0.523198] rk32-edp ff970000.edp: screen is not edp!
<4>[ 0.523213] rk32-edp: probe of ff970000.edp failed with error -22
<6>[ 0.523362] rk32-dsi
<4>[ 0.523501] dsi->host.irq =51
<4>[ 0.523519] load mipi dsi chip:rk_mipi_dsi.0 id:3133302a
<4>[ 0.523527] mipi_dsi v1.3 2014-04-17
<6>[ 0.523550] rk32-mipi ff960000.mipi: rk mipi_dsi probe success!
<6>[ 0.523562] rk32-mipi ff960000.mipi: rockchip mipi_dsi v1.1 2014-06-17
<7>[ 0.524057] of_get_named_gpio_flags exited with status 13
<7>[ 0.524071] _gpio_request: gpio-13 (lcd_rst) status -16
<3>[ 0.524084] rk3288-lcdc lcdc0: request lcd_rst gpio fail:-16
<6>[ 0.524333] graphics fb0: rockchip framebuffer registerd:fb0
<6>[ 0.524682] graphics fb1: rockchip framebuffer registerd:fb1
<6>[ 0.524829] graphics fb2: rockchip framebuffer registerd:fb2
<6>[ 0.524974] graphics fb3: rockchip framebuffer registerd:fb3
<6>[ 0.535472] rk3288-lcdc lcdc0: lcdc0: dclk:130000000>>fps:50
<4>[ 0.535486] dsi->phy.sys_clk =24000000
<4>[ 0.583264] rk_battery_charger_detect_cb , battery_charger_detect 1
<6>[ 0.945026] rk3288-lcdc lcdc0: wakeup from standby!
<6>[ 0.970085] alloc_buffer:ion_phy_addr=0x40000000
<6>[ 0.982606] fb0:phy:40000000>>vir:f0171000>>len:0x1900000
<6>[ 0.986142] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled
<3>[ 0.986306] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
<4>[ 0.986317] rk_fb_trsm_ops_get:un supported transmitter:0!
<6>[ 0.986531] graphics fb4: rockchip framebuffer registerd:fb4
<6>[ 0.986828] graphics fb5: rockchip framebuffer registerd:fb5
<6>[ 0.986980] graphics fb6: rockchip framebuffer registerd:fb6
<6>[ 0.987130] graphics fb7: rockchip framebuffer registerd:fb7
<6>[ 1.034517] alloc_buffer:ion_phy_addr=0x41900000
<6>[ 1.034534] fb0:phy:41900000>>vir: (null)>>len:0x3000000
<6>[ 1.034549] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled
<4>[ 1.035213] rockchip_set_mux:warning ignore bank num 15
<4>[ 1.035327] rockchip_set_mux:warning ignore bank num 15
<4>[ 1.035427] rockchip_set_mux:warning ignore bank num 15
<4>[ 1.035536] rockchip_set_mux:warning ignore bank num 15
<4>[ 1.035634] rockchip_set_mux:warning ignore bank num 15
<4>[ 1.035736] rockchip_set_mux:warning ignore bank num 15
<4>[ 1.035836] rockchip_set_mux:warning ignore bank num 15
<4>[ 1.035943] rockchip_set_mux:warning ignore bank num 15
<4>[ 1.036058] rockchip_set_mux:warning ignore bank num 15
<4>[ 1.036175] rockchip_set_mux:warning ignore bank num 15
<6>[ 1.037515] NET: Registered protocol family 2
<6>[ 1.037955] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
<6>[ 1.038085] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
<6>[ 1.038219] TCP: Hash tables configured (established 8192 bind 8192)
<6>[ 1.038265] TCP: reno registered
<6>[ 1.038279] UDP hash table entries: 512 (order: 2, 16384 bytes)
<6>[ 1.038312] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
<6>[ 1.038506] NET: Registered protocol family 1
<6>[ 1.038682] Unpacking initramfs…
<6>[ 1.101190] Freeing initrd memory: 1168K (c4bf0000 - c4d14000)
<6>[ 1.101758] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
<6>[ 1.102243] probe device ff9a0000.vpu_service
<4>[ 1.102432] vpu_service: power on
<6>[ 1.103546] checking hw id 4831
<6>[ 1.103885] vpu_service set to auto frequency mode
<6>[ 1.103917] vpu_service: power off…
<6>[ 1.103953] done
<6>[ 1.103960] init success
<6>[ 1.104008] probe device ff9c0000.hevc_service
<4>[ 1.104199] hevc_service: power on
<6>[ 1.105232] checking hw id 6867
<6>[ 1.105450] hevc_service: power off…
<6>[ 1.105487] done
<6>[ 1.105494] init success
<4>[ 1.105605] rknandbase v1.0 2014-03-31
<3>[ 1.105701] rknand ff400000.nandc0: no irq resource?
<4>[ 1.105826] rknand_driver:ret = 0
<6>[ 1.106479] audit: initializing netlink socket (disabled)
<5>[ 1.106520] type=2000 audit(0.800:1): initialized
<4>[ 1.107292] bounce pool size: 64 pages
<6>[ 1.111778] fuse init (API version 7.22)
<6>[ 1.112110] msgmni has been set to 1450
<7>[ 1.112156] SELinux: Registering netfilter hooks
<6>[ 1.113877] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
<6>[ 1.113892] io scheduler noop registered
<6>[ 1.113900] io scheduler deadline registered
<6>[ 1.113983] io scheduler cfq registered (default)
<7>[ 1.114528] of_get_named_gpio_flags exited with status 262
<6>[ 1.117444] rga2 ff920000.rga: rga ion client create success!
<6>[ 1.117578] rga: Driver loaded succesfully
<4>[ 1.118183] IEP Driver loaded succesfully
<4>[ 1.118274] Module initialized.
<6>[ 1.119135] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 1.119151] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
<6>[ 1.120395] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 1.120411] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
<3>[ 1.120678] pwm-voltage-regulator pwm_regulator.28: unable to request PWM, trying legacy API
<3>[ 1.120692] pwm-voltage-regulator pwm_regulator.28: unable to request legacy PWM
<4>[ 1.120700] pwm_regulator_probe:error
<6>[ 1.120721] platform pwm_regulator.28: Driver pwm-voltage-regulator requests probe deferral
<4>[ 1.121051] rk_serial.c v1.8 2014-03-04
<6>[ 1.121247] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
<6>[ 1.121428] serial ff180000.serial: membase f1a72000
<6>[ 1.121552] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
<6>[ 1.121718] serial ff690000.serial: membase fed60000
<6>[ 1.124455] loop: module loaded
<6>[ 1.125013] SCSI Media Changer driver v0.25
<6>[ 1.125328] tun: Universal TUN/TAP device driver, 1.6
<6>[ 1.125338] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
<4>[ 1.125453] vmac_init.
<3>[ 1.125956] stmmac_probe_config_dt: Can not read property: pmu_regulator.
<3>[ 1.125968] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
<6>[ 1.125979] stmmac_probe_config_dt: clock input or output? (input).
<6>[ 1.125988] stmmac_probe_config_dt: TX delay(0x30).
<6>[ 1.125998] stmmac_probe_config_dt: RX delay(0x20).
<7>[ 1.126008] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 1.126021] of_get_named_gpio_flags exited with status 136
<7>[ 1.126032] of_get_named_gpio_flags exited with status 6
<4>[ 1.126043] stmmac_probe_config_dt: is rockchip,rk3288-gmac
<6>[ 1.126052] stmmc_pltfr_init:
<6>[ 1.126069] stmmc_pltfr_init: init for RGMII
<6>[ 1.126080] tx delay=0x30
<6>[ 1.126080] rx delay=0x20
<6>[ 1.126512] stmmac - user ID: 0x10, Synopsys ID: 0x35
<6>[ 1.126521] Normal descriptors
<6>[ 1.126528] Ring mode enabled
<6>[ 1.126537] DMA HW capability register supported
<6>[ 1.126545] RX Checksum Offload Engine supported (type 2)
<6>[ 1.126553] TX Checksum insertion supported
<6>[ 1.126560] Wake-Up On Lan supported
<6>[ 1.126593] Enable RX Mitigation via HW Watchdog Timer
<6>[ 1.126994] PPP generic driver version 2.4.2
<6>[ 1.127139] PPP BSD Compression module registered
<6>[ 1.127149] PPP Deflate Compression module registered
<6>[ 1.127167] PPP MPPE Compression module registered
<6>[ 1.127177] NET: Registered protocol family 24
<6>[ 1.127207] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
<6>[ 1.127217] CSLIP: code copyright 1989 Regents of the University of California.
<4>[ 1.127226] Rockchip WiFi SYS interface (V1.00) …
<4>[ 1.127255] esp_mem_init enter date Feb 28 2017 14:04:07
<4>[ 1.127298] esp_mem_init complete
<6>[ 1.127364] usbcore: registered new interface driver catc
<6>[ 1.127400] usbcore: registered new interface driver kaweth
<6>[ 1.127410] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
<6>[ 1.127444] usbcore: registered new interface driver pegasus
<6>[ 1.127479] usbcore: registered new interface driver rtl8150
<6>[ 1.127518] usbcore: registered new interface driver r8152
<6>[ 1.127527] hso: drivers/net/usb/hso.c: Option Wireless
<6>[ 1.127586] usbcore: registered new interface driver hso
<6>[ 1.127626] usbcore: registered new interface driver asix
<6>[ 1.127660] usbcore: registered new interface driver ax88179_178a
<6>[ 1.127694] usbcore: registered new interface driver cdc_ether
<6>[ 1.127728] usbcore: registered new interface driver cdc_eem
<6>[ 1.127766] usbcore: registered new interface driver dm9601
<6>[ 1.127800] usbcore: registered new interface driver dm9620
<6>[ 1.127841] usbcore: registered new interface driver smsc75xx
<6>[ 1.127883] usbcore: registered new interface driver smsc95xx
<6>[ 1.127917] usbcore: registered new interface driver gl620a
<6>[ 1.127951] usbcore: registered new interface driver net1080
<6>[ 1.127990] usbcore: registered new interface driver plusb
<6>[ 1.128026] usbcore: registered new interface driver rndis_host
<6>[ 1.128064] usbcore: registered new interface driver cdc_subset
<6>[ 1.128098] usbcore: registered new interface driver zaurus
<6>[ 1.128134] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
<6>[ 1.128186] usbcore: registered new interface driver int51x1
<6>[ 1.128222] usbcore: registered new interface driver kalmia
<6>[ 1.128256] usbcore: registered new interface driver ipheth
<6>[ 1.128301] usbcore: registered new interface driver sierra_net
<6>[ 1.128337] usbcore: registered new interface driver cx82310_eth
<6>[ 1.128380] usbcore: registered new interface driver cdc_ncm
<6>[ 1.128416] usbcore: registered new interface driver qmi_wwan
<6>[ 1.128450] usbcore: registered new interface driver cdc_mbim
<6>[ 1.128460] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
<4>[ 1.130829] ehci_rk_probe f1b00000 f1b00010
<6>[ 1.130845] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller
<6>[ 1.130871] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
<6>[ 1.131172] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
<6>[ 1.141835] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00
<6>[ 1.141906] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 1.141920] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 1.141932] usb usb1: Product: Rockchip On-Chip EHCI Host Controller
<6>[ 1.141943] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
<6>[ 1.141953] usb usb1: SerialNumber: ff500000.usb
<6>[ 1.142359] hub 1-0:1.0: USB hub found
<6>[ 1.142381] hub 1-0:1.0: 1 port detected
<4>[ 1.171346] ehci_rk_probe ok
<6>[ 1.171497] usbcore: registered new interface driver cdc_acm
<6>[ 1.171507] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
<6>[ 1.171560] usbcore: registered new interface driver usblp
<6>[ 1.171600] usbcore: registered new interface driver cdc_wdm
<6>[ 1.171656] usbcore: registered new interface driver usb-storage
<6>[ 1.171692] usbcore: registered new interface driver ums-alauda
<6>[ 1.171727] usbcore: registered new interface driver ums-cypress
<6>[ 1.171761] usbcore: registered new interface driver ums-datafab
<6>[ 1.171795] usbcore: registered new interface driver ums_eneub6250
<6>[ 1.171834] usbcore: registered new interface driver ums-freecom
<6>[ 1.171870] usbcore: registered new interface driver ums-isd200
<6>[ 1.171905] usbcore: registered new interface driver ums-jumpshot
<6>[ 1.171940] usbcore: registered new interface driver ums-karma
<6>[ 1.171976] usbcore: registered new interface driver ums-onetouch
<6>[ 1.172011] usbcore: registered new interface driver ums-sddr09
<6>[ 1.172046] usbcore: registered new interface driver ums-sddr55
<6>[ 1.172081] usbcore: registered new interface driver ums-usbat
<6>[ 1.172165] usbcore: registered new interface driver usbserial
<6>[ 1.172204] usbcore: registered new interface driver usbserial_generic
<6>[ 1.172234] usbserial: USB Serial support registered for generic
<6>[ 1.172271] usbcore: registered new interface driver option
<6>[ 1.172299] usbserial: USB Serial support registered for GSM modem (1-port)
<6>[ 1.172365] usbcore: registered new interface driver trancevibrator
<6>[ 1.172374] usb20_otg: version 3.10a 21-DEC-2012
<4>[ 1.172814] f1b80040
<4>[ 1.172826] Core Release: 3.10a
<4>[ 1.172835] Setting default values for core params
<4>[ 1.172955] Using Buffer DMA mode
<4>[ 1.172965] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 1.172973] Multiprocessor Interrupt Enhancement - disabled
<4>[ 1.172982] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 1.172991] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 1.173002] Dedicated Tx FIFOs mode
<4>[ 1.173016] pcd_init otg_dev = ed697ac0
<6>[ 1.173165] usb20_otg ff580000.usb: DWC OTG Controller
<6>[ 1.173192] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
<6>[ 1.173219] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
<6>[ 1.173271] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 1.173284] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 1.173295] usb usb2: Product: DWC OTG Controller
<6>[ 1.173305] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 1.173316] usb usb2: SerialNumber: ff580000.usb
<6>[ 1.173698] hub 2-0:1.0: USB hub found
<6>[ 1.173718] hub 2-0:1.0: 1 port detected
<6>[ 1.174038] usb20_host: version 3.10a 21-DEC-2012
<4>[ 1.176491] f1c00040
<4>[ 1.176502] Core Release: 3.10a
<4>[ 1.176511] Setting default values for core params
<4>[ 1.176599] Using Buffer DMA mode
<4>[ 1.176608] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 1.176616] Multiprocessor Interrupt Enhancement - disabled
<4>[ 1.176625] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 1.176634] ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 1.176662] usb20_host ff540000.usb: DWC OTG Controller
<6>[ 1.176685] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
<6>[ 1.176711] usb20_host ff540000.usb: irq 57, io mem 0x00000000
<4>[ 1.176798] Init: Power Port (0)
<6>[ 1.176852] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 1.176865] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 1.176877] usb usb3: Product: DWC OTG Controller
<6>[ 1.176887] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 1.176898] usb usb3: SerialNumber: ff540000.usb
<6>[ 1.177241] hub 3-0:1.0: USB hub found
<6>[ 1.177261] hub 3-0:1.0: 1 port detected
<4>[ 1.177785] .. rk pwm remotectl v1.0 init
<4>[ 1.177869] remotectl probe j=0x0
<6>[ 1.178003] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
<4>[ 1.178175] pwm enable val=0x646205
<6>[ 1.178437] usbcore: registered new interface driver xpad
<6>[ 1.178488] usbcore: registered new interface driver usb_acecad
<6>[ 1.178529] usbcore: registered new interface driver aiptek
<6>[ 1.178569] usbcore: registered new interface driver gtco
<6>[ 1.178615] usbcore: registered new interface driver hanwang
<6>[ 1.178656] usbcore: registered new interface driver kbtab
<6>[ 1.178703] usbcore: registered new interface driver wacom
<4>[ 1.178898] ft5x0x_ts_probe-362
<7>[ 1.178915] of_get_named_gpio_flags exited with status 230
<7>[ 1.178926] of_get_named_gpio_flags exited with status 228
<6>[ 1.388232] input: ft5x0x_ts as /devices/virtual/input/input1
<4>[ 1.545998] ft5x0x_ts_probe ok !!!466
<6>[ 1.546048] Successfully added driver ft5x0x_ts
<6>[ 1.549372] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed
<7>[ 1.553516] of_get_named_gpio_flags exited with status 228
<6>[ 1.559874] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
<6>[ 1.559930] i2c /dev entries driver
<6>[ 1.560530] IR NEC protocol handler initialized
<6>[ 1.560542] IR RC5(x) protocol handler initialized
<6>[ 1.560550] IR RC6 protocol handler initialized
<6>[ 1.560558] IR JVC protocol handler initialized
<6>[ 1.560566] IR Sony protocol handler initialized
<6>[ 1.560574] IR RC5 (streamzap) protocol handler initialized
<6>[ 1.560581] IR SANYO protocol handler initialized
<6>[ 1.560589] IR MCE Keyboard/mouse protocol handler initialized
<6>[ 1.560727] usbcore: registered new interface driver uvcvideo
<6>[ 1.560737] USB Video Class driver (1.1.1)
<4>[ 1.560748] CamSys driver version: v0.23.0, CamSys head file version: v0.9.0
<7>[ 1.562112] of_get_named_gpio_flags exited with status 236
<4>[ 1.562123] D1:camsys_platform_probe(1067): 1-gpios-cifpower: gpio=236
<7>[ 1.562135] of_get_named_gpio_flags exited with status 236
<4>[ 1.562145] D1:camsys_platform_probe(1070): gpios-cifpower: gpio_request
<4>[ 1.562160] D1:camsys_platform_probe(1072): 1-gpios-cifpower: gpio_request=0
<4>[ 1.562176] D1:camsys_platform_probe(1079): gpios-cifpower: 236 high
<4>[ 1.562252] D1:camsys_mipiphy_probe_cb(163): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
<4>[ 1.562387] D1:camsys_mipiphy_probe_cb(160): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xf1ab0000 size: 0x4000)
<4>[ 1.563009] D1:camsys_platform_probe(1183): ff910000.isp memory:
<4>[ 1.563023] D1:camsys_platform_probe(1193): Register memory (phy: 0xff910000 vir: 0xf1ae0000 size: 0x10000)
<4>[ 1.563036] D1:camsys_platform_probe(1188): I2c memory (phy: 0x2d9b0000 vir: 0xed9b0000 size: 0x1000)
<4>[ 1.563047] D1:camsys_platform_probe(1208): Probe ff910000.isp device success
<4>[ 1.564256] rockchip_temp_probe,line=362
<6>[ 1.614147] tsadc ff280000.tsadc: initialized
<6>[ 1.614504] device-mapper: uevent: version 1.0.3
<6>[ 1.614726] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
<6>[ 1.614990] Bluetooth: HCI UART driver ver 2.2
<6>[ 1.615003] Bluetooth: HCI H4 protocol initialized
<6>[ 1.615011] Bluetooth: HCILL protocol initialized
<3>[ 1.615060] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can’t get regulator(vdd_logic)!
<3>[ 1.616755] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can’t get regulator(vdd_logic)!
<4>[ 1.617334] cpufreq version 1.0, suspend freq 1200 MHz
<6>[ 1.617524] cpuidle: using governor ladder
<6>[ 1.617535] cpuidle: using governor menu
<6>[ 1.617567] Synopsys Designware Multimedia Card Interface Driver
<6>[ 1.617804] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
<6>[ 1.618071] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
<4>[ 1.618209] 3379..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
<4>[ 1.618220] mmc0 : Rockchip specific MHSC: Ver 1.13 2014-09-05
<7>[ 1.618242] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.618330] 1390..dw_mci_set_ios: no card. [mmc0]
<4>[ 1.633847] 1390..dw_mci_set_ios: no card. [mmc0]
<4>[ 1.653542] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
<6>[ 1.653576] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
<6>[ 1.653591] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
<6>[ 1.653853] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
<6>[ 1.654676] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
<4>[ 1.654806] 3379..dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc1]
<4>[ 1.654817] mmc1 : Rockchip specific MHSC: Ver 1.13 2014-09-05
<7>[ 1.654838] of_get_named_gpio_flags: can’t parse gpios property
<6>[ 1.654885] mmc1: no vmmc regulator found
<4>[ 1.655031] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
<4>[ 1.655129] 1390..dw_mci_set_ios: no card. [mmc1]
<4>[ 1.673216] 1390..dw_mci_set_ios: no card. [mmc1]
<6>[ 1.685714] mmc0: BKOPS_EN bit is not set
<6>[ 1.687625] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
<4>[ 1.687650] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
<4>[ 1.687717] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=8bits.[mmc0]
<6>[ 1.687819] mmc0: new high speed MMC card at address 0001
<6>[ 1.688153] mmcblk0: mmc0:0001 AGND3R 14.5 GiB
<6>[ 1.689007] uboot: 0x000400000 – 0x000800000 (4 MB)
<6>[ 1.689042] misc: 0x000800000 – 0x000c00000 (4 MB)
<6>[ 1.689070] resource: 0x000c00000 – 0x001c00000 (16 MB)
<6>[ 1.689096] kernel: 0x001c00000 – 0x002c00000 (16 MB)
<6>[ 1.689121] boot: 0x002c00000 – 0x004c00000 (32 MB)
<6>[ 1.689168] recovery: 0x004c00000 – 0x006c00000 (32 MB)
<6>[ 1.689194] backup: 0x006c00000 – 0x00a000000 (52 MB)
<6>[ 1.689226] cache: 0x00a000000 – 0x012000000 (128 MB)
<6>[ 1.689252] kpanic: 0x012000000 – 0x012400000 (4 MB)
<6>[ 1.689278] system: 0x012400000 – 0x042400000 (768 MB)
<6>[ 1.689305] metadata: 0x042400000 – 0x042800000 (4 MB)
<6>[ 1.689331] userdata: 0x042800000 – 0x082800000 (1024 MB)
<6>[ 1.689357] radical_update: 0x082800000 – 0x086800000 (64 MB)
<6>[ 1.689385] user: 0x086800000 – 0x3a3a00000 (12754 MB)
<6>[ 1.693064] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
<6>[ 1.693102] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
<6>[ 1.689505] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141390..dw_mci_set_ios: no card. [mmc1]
<6>[ 1.693938] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
<6>[ 1.694513] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
<4>[ 1.694881] 3379..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
<4>[ 1.694906] mmc2 : Rockchip specific MHSC: Ver 1.13 2014-09-05
<7>[ 1.694957] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.695607] 1390..dw_mci_set_ios: no card. [mmc2]
<4>[ 1.712640] 1390..dw_mci_set_ios: no card. [mmc2]
<4>[ 1.732560] 1390..dw_mci_set_ios: no card. [mmc2]
<6>[ 1.732752] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
<6>[ 1.732835] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
<4>[ 1.734352] leds-gpio leds.37: pins are not configured from the driver
<7>[ 1.734450] of_get_named_gpio_flags exited with status 257
<7>[ 1.734519] of_get_named_gpio_flags exited with status 258
<7>[ 1.734591] of_get_named_gpio_flags exited with status 257
<7>[ 1.735111] of_get_named_gpio_flags exited with status 258
<6>[ 1.735968] hidraw: raw HID events driver (C) Jiri Kosina
<6>[ 1.747985] usbcore: registered new interface driver usbhid
<6>[ 1.748049] usbhid: USB HID core driver
<6>[ 1.750214] zram: Created 1 device(s) …
<6>[ 1.752390] ashmem: initialized
<6>[ 1.752982] logger: created 256K log ‘log_main’
<6>[ 1.753502] logger: created 256K log ‘log_events’
<6>[ 1.753982] logger: created 256K log ‘log_radio’
<6>[ 1.754472] logger: created 256K log ‘log_system’
<7>[ 1.757849] of_get_named_gpio_flags exited with status 229
<7>[ 1.757898] of_get_named_gpio_flags exited with status 229
<6>[ 1.758773] input: rk29-keypad as /devices/ff100000.adc/key.39/input/input2
<7>[ 1.761063] of_get_named_gpio_flags exited with status 10
<7>[ 1.761115] of_get_named_gpio_flags exited with status 239
<3>[ 2.145744] rockchip_i2c ff660000.i2c: Addr[0x0010] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x0
<4>[ 2.149777] rockchip_i2c ff660000.i2c: I2C_CON: start bit is set
<4>[ 2.150822] es8323 probe error
<4>[ 2.150924] ES8323: probe of 2-0010 failed with error -110
<4>[ 2.151114] i2c-core: driver [ES8323] using legacy suspend method
<4>[ 2.151172] i2c-core: driver [ES8323] using legacy resume method
<3>[ 2.157869] rockchip-hdmi-spdif rockchip-hdmi-spdif.32: ASoC: CPU DAI (null) not registered
<4>[ 2.158043] rockchip_hdmi_spdif_audio_probe() register card failed:-517
<6>[ 2.158162] platform rockchip-hdmi-spdif.32: Driver rockchip-hdmi-spdif requests probe deferral
<3>[ 2.159626] rockchip-es8323 rockchip-es8323.34: ASoC: CODEC (null) not registered
<4>[ 2.159776] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 2.159884] platform rockchip-es8323.34: Driver rockchip-es8323 requests probe deferral
<6>[ 2.164225] rockchip-hdmi-i2s rockchip-hdmi-i2s.31: rk-hdmi-i2s-hifi ↔ rockchip-i2s.0 mapping ok
<6>[ 2.167434] u32 classifier
<6>[ 2.167472] Actions configured
<6>[ 2.167514] Netfilter messages via NETLINK v0.30.
<6>[ 2.167676] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
<6>[ 2.169082] ctnetlink v0.93: registering with nfnetlink.
<6>[ 2.169287] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[ 2.169319] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[ 2.170388] xt_time: kernel timezone is -0000
<6>[ 2.171333] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 2.171914] arp_tables: (C) 2002 David S. Miller
<6>[ 2.172074] TCP: cubic registered
<6>[ 2.172107] Initializing XFRM netlink socket
<6>[ 2.173182] NET: Registered protocol family 10
<6>[ 2.175695] mip6: Mobile IPv6
<6>[ 2.175812] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 2.176333] sit: IPv6 over IPv4 tunneling driver
<6>[ 2.177780] NET: Registered protocol family 17
<6>[ 2.177880] NET: Registered protocol family 15
<5>[ 2.178091] Bridge firewalling registered
<6>[ 2.178137] Ebtables v2.0 registered
<6>[ 2.178567] Bluetooth: RFCOMM TTY layer initialized
<6>[ 2.178659] Bluetooth: RFCOMM socket layer initialized
<6>[ 2.178694] Bluetooth: RFCOMM ver 1.11
<6>[ 2.178728] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[ 2.178759] Bluetooth: BNEP filters: protocol multicast
<6>[ 2.178807] Bluetooth: BNEP socket layer initialized
<6>[ 2.178839] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[ 2.178886] Bluetooth: HIDP socket layer initialized
<6>[ 2.178985] l2tp_core: L2TP core driver, V2.0
<6>[ 2.179043] l2tp_ppp: PPPoL2TP kernel driver, V2.0
<6>[ 2.179073] [WLAN_RFKILL]: Enter rfkill_wlan_init
<6>[ 2.179585] [WLAN_RFKILL]: Enter rfkill_wlan_probe
<6>[ 2.179627] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
<6>[ 2.179663] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
<6>[ 2.179697] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
<6>[ 2.179731] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
<7>[ 2.179779] of_get_named_gpio_flags exited with status 156
<6>[ 2.179814] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
<7>[ 2.179846] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 2.179883] of_get_named_gpio_flags exited with status 158
<6>[ 2.179918] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
<6>[ 2.179949] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
<6>[ 2.180024] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
<6>[ 2.180189] [WLAN_RFKILL]: Exit rfkill_wlan_probe
<6>[ 2.180362] [BT_RFKILL]: Enter rfkill_rk_init
<7>[ 2.180909] of_get_named_gpio_flags exited with status 147
<6>[ 2.180948] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
<7>[ 2.180996] of_get_named_gpio_flags exited with status 155
<6>[ 2.181028] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
<7>[ 2.181065] of_get_named_gpio_flags exited with status 157
<6>[ 2.181097] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
<7>[ 2.181134] of_get_named_gpio_flags exited with status 154
<6>[ 2.181166] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
<7>[ 2.181203] of_get_named_gpio_flags exited with status 159
<6>[ 2.181235] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
<6>[ 2.181414] [BT_RFKILL]: Request irq for bt wakeup host
<6>[ 2.181687] [BT_RFKILL]: ** disable irq
<6>[ 2.182006] [BT_RFKILL]: ap6335 device registered.
<6>[ 2.184148] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess.
<6>[ 2.187846] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
<4>[ 2.187898] rk3288_init_suspend
<4>[ 2.187921] rk3288_suspend_init enter
<4>[ 2.188190] rk3288_suspend_init: pm_ctrbits =200007
<4>[ 2.188278] gpio_get_dts_info suspend:4
<4>[ 2.188302] gpio_get_dts_info resume:4
<4>[ 2.188321] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 2.188419] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 2.188919] clks_gating_suspend_init:clkgt info ok
<5>[ 2.189207] Registering SWP/SWPB emulation handler
<3>[ 2.189265] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can’t get regulator(vdd_logic)!
<6>[ 2.190231] ddrfreq: verion 1.2 20140526
<6>[ 2.190271] ddrfreq: normal 396MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 200MHz reboot 396MHz
<6>[ 2.190294] ddrfreq: auto-freq=0
<6>[ 2.190316] ddrfreq: auto-freq-table[0] 240MHz
<6>[ 2.190337] ddrfreq: auto-freq-table[1] 324MHz
<6>[ 2.190356] ddrfreq: auto-freq-table[2] 396MHz
<6>[ 2.190377] ddrfreq: auto-freq-table[3] 528MHz
<7>[ 2.190513] ddrfreq: change freq to 300 MHz when normal
<6>[ 2.191892] regulator-dummy: disabling
<3>[ 2.193097] rockchip-hdmi-spdif rockchip-hdmi-spdif.32: ASoC: CPU DAI (null) not registered
<4>[ 2.193178] rockchip_hdmi_spdif_audio_probe() register card failed:-517
<6>[ 2.193232] platform rockchip-hdmi-spdif.32: Driver rockchip-hdmi-spdif requests probe deferral
<3>[ 2.193801] rockchip-es8323 rockchip-es8323.34: ASoC: CODEC (null) not registered
<4>[ 2.193866] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 2.193911] platform rockchip-es8323.34: Driver rockchip-es8323 requests probe deferral
<4>[ 2.194250] pcd_pullup, is_on 0
<6>[ 2.194405] file system registered
<6>[ 2.196873] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[ 2.196905] android_usb gadget: Number of LUNs=2
<6>[ 2.196933] lun0: LUN: removable file: (no medium)
<6>[ 2.196957] lun1: LUN: removable file: (no medium)
<6>[ 2.197537] android_usb gadget: android_usb ready
<3>[ 2.199317] rtc_hym8563 0-0051: hctosys: invalid date/time
<6>[ 2.219517] rk_spdif:rk_spdif_init
<6>[ 2.219884] rk_spdif:Entered spdif_probe
<6>[ 2.220201] rk_spdif:spdif:spdif probe ok!
<6>[ 2.221202] usbcore: registered new interface driver snd-usb-audio
<6>[ 2.221259] ALSA device list:
<6>[ 2.221272] #0: RK-HDMI-I2S
<3>[ 2.221412] Warning: unable to open an initial console.
<6>[ 2.221685] rockchip-hdmi-spdif rockchip-hdmi-spdif.32: rk-hdmi-spdif-hifi ↔ rockchip-spdif mapping ok
<6>[ 2.222011] Freeing unused kernel memory: 592K (c0ae4000 - c0b78000)
<3>[ 2.223090] rockchip-es8323 rockchip-es8323.34: ASoC: CODEC (null) not registered
<4>[ 2.223137] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 2.223166] platform rockchip-es8323.34: Driver rockchip-es8323 requests probe deferral
<7>[ 2.229251] SELinux: 512 avtab hash slots, 1338 rules.
<7>[ 2.229778] SELinux: 512 avtab hash slots, 1338 rules.
<7>[ 2.229794] SELinux: 1 users, 2 roles, 288 types, 1 bools, 1 sens, 1024 cats
<7>[ 2.229803] SELinux: 84 classes, 1338 rules
<6>[ 2.230581] SELinux: Permission attach_queue in class tun_socket not defined in policy.
<6>[ 2.230594] SELinux: the above unknown classes and permissions will be denied
<7>[ 2.230614] SELinux: Completing initialization.
<7>[ 2.230620] SELinux: Setting up existing superblocks.
<7>[ 2.230639] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<7>[ 2.230653] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
<7>[ 2.230710] SELinux: initialized (dev bdev, type bdev), not configured for labeling
<7>[ 2.230721] SELinux: initialized (dev proc, type proc), uses genfs_contexts
<7>[ 2.230738] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 2.230756] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
<7>[ 2.230998] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
<7>[ 2.236114] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
<7>[ 2.236133] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
<7>[ 2.236145] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
<7>[ 2.236158] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
<7>[ 2.236178] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
<7>[ 2.236242] SELinux: initialized (dev configfs, type configfs), not configured for labeling
<7>[ 2.236253] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 2.236283] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<5>[ 2.513561] type=1403 audit(2.230:2): policy loaded auid=4294967295 ses=4294967295
<12>[ 2.513688] SELinux: Loaded policy from /sepolicy
<5>[ 2.515615] type=1404 audit(2.230:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
<11>[ 3.481804] init: could not import file ‘/init.usbstorage.rc’ from ‘/init.rc’
<4>[ 3.481871] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
<11>[ 3.542412] init: /dev/hw_random not found
<6>[ 3.542488] keychord: using input dev ff680000.pwm for fevent
<6>[ 3.542501] keychord: using input dev rk29-keypad for fevent
<7>[ 3.542999] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 3.543303] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 3.543635] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 3.544814] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 3.545176] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 3.545346] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 3.546401] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 3.548195] SELinux: initialized (dev functionfs, type functionfs), not configured for labeling
<11>[ 3.548929] fs_mgr: parse_link_device : path = NULL
<11>[ 3.548957] fs_mgr: parse_link_device : path = NULL
<11>[ 3.548993] fs_mgr: parse_link_device : path = NULL
<14>[ 3.549070] fs_mgr: ---------------resize_fs blk_dev /dev/block/platform/ff0f0000.rksdmmc/by-name/system, type ext4fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
<14>[ 3.550114] resize2fs: resize2fs 1.41.14 (22-Dec-2010)resize2fs: The filesystem is already 196608 blocks long. Nothing to do!resize2fs:
<6>[ 3.559422] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
<7>[ 3.559446] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<6>[ 3.569911] EXT4-fs (mmcblk0p8): recovery complete
<6>[ 3.570286] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 3.570311] SELinux: initialized (dev mmcblk0p8, type ext4), uses xattr
<4>[ 3.571641] EXT4-fs (mmcblk0p11): warning: mounting unchecked fs, running e2fsck is recommended
<6>[ 3.572093] EXT4-fs (mmcblk0p11): mounted filesystem without journal. Opts: noauto_da_alloc,discard
<7>[ 3.572110] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
<7>[ 3.720652] EXT4-fs (mmcblk0p12): ext4_orphan_cleanup: deleting unreferenced inode 878
<7>[ 3.720840] EXT4-fs (mmcblk0p12): ext4_orphan_cleanup: deleting unreferenced inode 872
<6>[ 3.720881] EXT4-fs (mmcblk0p12): 2 orphan inodes deleted
<6>[ 3.720888] EXT4-fs (mmcblk0p12): recovery complete
<6>[ 3.725138] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 3.725164] SELinux: initialized (dev mmcblk0p12, type ext4), uses xattr
<4>[ 3.741509] mali pd enabled
<4>[ 3.741524] clk enabled
<4>[ 3.742710] MALI_DVFS_STEP=5,div_dvfs=7
<6>[ 3.742721] mali_dvfs_infotbl[0].clock=99000,min_threshold=0,max_threshold=70
<6>[ 3.742729] mali_dvfs_infotbl[1].clock=179000,min_threshold=66,max_threshold=77
<6>[ 3.742736] mali_dvfs_infotbl[2].clock=297000,min_threshold=73,max_threshold=84
<6>[ 3.742743] mali_dvfs_infotbl[3].clock=417000,min_threshold=82,max_threshold=91
<6>[ 3.742751] mali_dvfs_infotbl[4].clock=480000,min_threshold=94,max_threshold=100
<6>[ 3.742874] gpufreq_input_connect
<3>[ 3.742883] turn on mali power
<6>[ 3.742891] kbase_platform_rk_init,register_reboot_notifier
<6>[ 3.742914] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
<6>[ 3.743399] mali ffa30000.gpu: Probed as mali0
<3>[ 3.745171] rockchip-es8323 rockchip-es8323.34: ASoC: CODEC (null) not registered
<4>[ 3.745198] rockchip_es8323_audio_probe() register card failed:-517
<6>[ 3.745215] platform rockchip-es8323.34: Driver rockchip-es8323 requests probe deferral
<3>[ 3.746230] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<11>[ 3.755361] init: /dev/hw_random not found
<6>[ 3.763083] binder: 165:165 transaction failed 29189, size 0-0
<11>[ 3.765354] init: cannot find ‘/system/vendor/bin/pvrsrvctl’, disabling ‘pvrsrvctl’
<11>[ 3.768040] init: cannot find ‘/system/bin/rild3’, disabling ‘ril-daemon3’
<11>[ 3.782450] init: cannot find ‘/system/etc/install-recovery.sh’, disabling ‘flash_recovery’
<11>[ 3.784065] init: cannot find ‘/system/bin/chrome.sh’, disabling ‘chrome’
<11>[ 3.785122] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
<11>[ 3.785140] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
<11>[ 3.785346] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
<7>[ 3.880084] SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
<11>[ 3.937201] init: property ‘sys.powerctl’ doesn’t exist while expanding ‘${sys.powerctl}’
<11>[ 3.937219] init: powerctl: cannot expand ‘${sys.powerctl}’
<11>[ 3.937233] init: property ‘sys.sysctl.extra_free_kbytes’ doesn’t exist while expanding ‘${sys.sysctl.extra_free_kbytes}’
<11>[ 3.937245] init: cannot expand ‘${sys.sysctl.extra_free_kbytes}’ while writing to ‘/proc/sys/vm/extra_free_kbytes’
<11>[ 3.937258] init: property ‘sys.sysctl.tcp_def_init_rwnd’ doesn’t exist while expanding ‘${sys.sysctl.tcp_def_init_rwnd}’
<11>[ 3.937268] init: cannot expand ‘${sys.sysctl.tcp_def_init_rwnd}’ while writing to ‘/proc/sys/net/ipv4/tcp_default_init_rwnd’
<11>[ 3.937406] init: service ‘console’ requires console
<3>[ 3.937803] android_usb: already disabled
<6>[ 3.940303] read descriptors
<6>[ 3.940320] read strings
<4>[ 3.940531] pcd_pullup, is_on 1
<11>[ 4.048707] fs_mgr: parse_link_device : path = NULL
<11>[ 4.048743] fs_mgr: parse_link_device : path = NULL
<11>[ 4.048771] fs_mgr: parse_link_device : path = NULL
<4>[ 4.902167] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 4.902181] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 4.902190] D1:camsys_open(717): camsys_marvin(ee377310) is opened!
<7>[ 4.902254] of_get_named_gpio_flags exited with status 237
<7>[ 4.902262] of_get_named_gpio_flags exited with status 237
<4>[ 4.902270] rockchip_gpio_request:GPIO7-13
<4>[ 4.902286] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 4.902293] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 4.902305] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
<4>[ 4.902314] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x3008,result=0x3008
<4>[ 4.902322] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 4.902347] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV8825) register success
<7>[ 4.907403] ddrfreq: change freq to 300 MHz when isp
<4>[ 4.907452] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 4.907463] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
<4>[ 4.907569] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
<4>[ 4.907601] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
<3>[ 4.908677] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
<3>[ 4.909748] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
<3>[ 4.910816] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
<3>[ 4.912869] E:camsys_i2c_write(35): Get 3 i2c adapter is failed!
<3>[ 4.912904] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
<3>[ 4.912912] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
<3>[ 4.912919] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
<7>[ 4.914028] ddrfreq: change freq to 300 MHz when normal
<4>[ 4.914057] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
<4>[ 4.914093] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
<4>[ 4.916166] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 4.916184] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
<4>[ 4.916197] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 4.916204] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 4.916212] D1:camsys_release(741): camsys_marvin(ee377310) is closed
<4>[ 4.924572] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 4.924584] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 4.924594] D1:camsys_open(717): camsys_marvin(ee377310) is opened!
<7>[ 4.924657] of_get_named_gpio_flags exited with status 237
<7>[ 4.924666] of_get_named_gpio_flags exited with status 237
<7>[ 4.924674] _gpio_request: gpio-237 (camsys_gpio) status -16
<4>[ 4.924684] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 4.924690] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 4.924702] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
<4>[ 4.924711] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x3008,result=0x3008
<4>[ 4.924719] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 4.924736] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV8858) register success
<7>[ 4.929787] ddrfreq: change freq to 300 MHz when isp
<4>[ 4.929841] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 4.929853] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
<4>[ 4.929961] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
<4>[ 4.929997] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
<3>[ 4.931063] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
<3>[ 4.932122] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
<3>[ 4.933190] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
<3>[ 4.935250] E:camsys_i2c_write(35): Get 3 i2c adapter is failed!
<3>[ 4.935261] E:camsys_i2c_write(35): Get 3 i2c adapter is failed!
<3>[ 4.935294] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
<3>[ 4.935303] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
<3>[ 4.935311] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
<7>[ 4.936424] ddrfreq: change freq to 300 MHz when normal
<4>[ 4.936452] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
<4>[ 4.936489] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
<4>[ 4.938556] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 4.938574] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
<4>[ 4.938586] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 4.938593] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 4.938600] D1:camsys_release(741): camsys_marvin(ee377310) is closed
<4>[ 4.941407] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 4.941419] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 4.941428] D1:camsys_open(717): camsys_marvin(ee377310) is opened!
<4>[ 4.941487] D1:camsys_extdev_register(230): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 4.941500] D1:camsys_extdev_register(230): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 4.941512] D1:camsys_extdev_register(230): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
<7>[ 4.941531] of_get_named_gpio_flags exited with status 237
<7>[ 4.941538] of_get_named_gpio_flags exited with status 237
<7>[ 4.941545] _gpio_request: gpio-237 (camsys_gpio) status -16
<4>[ 4.941554] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 4.941561] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 4.941571] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
<4>[ 4.941580] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x3008,result=0x3008
<4>[ 4.941588] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 4.941604] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
<7>[ 4.946639] ddrfreq: change freq to 300 MHz when isp
<4>[ 4.946683] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 4.946693] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
<4>[ 4.946799] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
<4>[ 4.946832] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 4.947900] D1:camsys_sysctl_extdev(335): Sysctl 11 success, gpio(11) set 1
<4>[ 4.948962] D1:camsys_sysctl_extdev(339): Sysctl 8 success, gpio(79) set 1
<4>[ 4.950041] D1:camsys_sysctl_extdev(339): Sysctl 7 success, gpio(78) set 1
<3>[ 4.952094] E:camsys_i2c_write(35): Get 3 i2c adapter is failed!
<3>[ 4.952104] E:camsys_i2c_write(35): Get 3 i2c adapter is failed!
<4>[ 4.952135] D1:camsys_sysctl_extdev(335): Sysctl 7 success, gpio(78) set 0
<4>[ 4.952148] D1:camsys_sysctl_extdev(335): Sysctl 8 success, gpio(79) set 0
<4>[ 4.952160] D1:camsys_sysctl_extdev(339): Sysctl 11 success, gpio(11) set 0
<7>[ 4.953243] ddrfreq: change freq to 300 MHz when normal
<4>[ 4.953266] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
<4>[ 4.953293] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
<4>[ 4.955358] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 4.955375] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
<4>[ 4.955385] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 4.955392] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 4.955399] D1:camsys_release(741): camsys_marvin(ee377310) is closed
<4>[ 4.963121] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 4.963133] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 4.963142] D1:camsys_open(717): camsys_marvin(ee377310) is opened!
<4>[ 4.963187] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
<4>[ 4.963296] D1:camsys_extdev_register(255): Extdev(dev_id: 0x1000000 dev_name: OV2659) register success
<7>[ 4.968324] ddrfreq: change freq to 300 MHz when isp
<4>[ 4.968365] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 4.968374] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
<4>[ 4.968479] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
<4>[ 4.968510] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
<3>[ 4.969580] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
<3>[ 4.970638] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
<3>[ 4.971693] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
<3>[ 4.973741] E:camsys_i2c_write(35): Get 3 i2c adapter is failed!
<3>[ 4.973771] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
<3>[ 4.973781] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
<3>[ 4.973790] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
<7>[ 4.974877] ddrfreq: change freq to 300 MHz when normal
<4>[ 4.974900] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
<4>[ 4.974928] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
<4>[ 4.976976] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x1000000) is deregister success
<4>[ 4.976990] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
<4>[ 4.977000] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 4.977007] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 4.977014] D1:camsys_release(741): camsys_marvin(ee377310) is closed
<6>[ 5.325726] rk3288-lcdc lcdc0: blank mode:0
<4>[ 5.325746] I’am in gsl_ts_resume() start
<11>[ 5.415003] init: sys_prop: permission denied uid:1003 name:sys.gmali.version
<6>[ 6.565540] warning: `zygote’ uses 32-bit capabilities (legacy support in use)
<4>[ 9.053197] vbus detect**
<4>[ 9.232533] Using Buffer DMA mode
<4>[ 9.232547] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 9.232553] Multiprocessor Interrupt Enhancement - disabled
<4>[ 9.232560] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 9.232565] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 9.232609] soft connect!!!
<4>[ 9.359052] USB RESET
<6>[ 9.445161] android_work: sent uevent USB_STATE=CONNECTED
<4>[ 9.449719] USB RESET
<6>[ 9.567256] android_usb gadget: high-speed config #1: android
<6>[ 9.567415] android_work: sent uevent USB_STATE=CONFIGURED
<14>[ 13.300711] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
<6>[ 13.399023] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
<6>[ 13.399038] lowmemorykiller: oom_adj 0 => oom_score_adj 0
<6>[ 13.399044] lowmemorykiller: oom_adj 1 => oom_score_adj 58
<6>[ 13.399050] lowmemorykiller: oom_adj 2 => oom_score_adj 117
<6>[ 13.399056] lowmemorykiller: oom_adj 3 => oom_score_adj 176
<6>[ 13.399061] lowmemorykiller: oom_adj 9 => oom_score_adj 529
<6>[ 13.399067] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
<4>[ 13.640753] phy_power_on: enable = 1
<4>[ 13.680159] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
<4>[ 13.680193] eth0: device MAC address 26:06:60:86:30:19
<6>[ 13.683807] libphy: stmmac: probed
<4>[ 13.683816] eth0: No PHY found
<6>[ 13.818708] acc_open
<6>[ 13.818728] acc_release
<4>[ 13.821191] wifi_driver_write: wifi driver already rmmod
<4>[ 14.515740] FAT-fs (mmcblk0p14): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
<7>[ 14.515799] SELinux: initialized (dev mmcblk0p14, type vfat), uses genfs_contexts
<12>[ 14.544840] avc: denied { set } for property=sys.vold.hasAsec scontext=u:r:vold:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service
<11>[ 14.544863] init: sys_prop: permission denied uid:0 name:sys.vold.hasAsec
<11>[ 14.545175] init: no such service ‘fuse_internal_sd’
<11>[ 15.016892] init: sys_prop: permission denied uid:10012 name:sys.gmali.version
<11>[ 16.118540] init: sys_prop: permission denied uid:10037 name:sys.gmali.version
<11>[ 16.559888] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
<5>[ 16.584291] type=1400 audit(86410.150:4): avc: denied { execute } for pid=997 comm=“Thread-53” name=“libestool2.so” dev=“mmcblk0p12” ino=713 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:app_data_file:s0 tclass=file permissive=1
<5>[ 16.584384] type=1400 audit(86410.150:5): avc: denied { execute_no_trans } for pid=997 comm=“Thread-53” path=“/data/data/com.estrongs.android.pop/files/libestool2.so” dev=“mmcblk0p12” ino=713 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:app_data_file:s0 tclass=file permissive=1
<6>[ 16.685543] f28c5234,f28c5234,f28c5234
<4>[ 28.780954] I’am in gsl_ts_suspend() start
<6>[ 28.781095] rk3288-hdmi ff980000.hdmi: Removed.
<4>[ 29.004455] DVFS WARNING: clk_disable_dvfs:clk(aclk_vio1) is already closed!
<6>[ 29.004478] rk3288-lcdc lcdc0: blank mode:4
<7>[ 29.004526] ddrfreq: change auto self refresh to 1 when suspend
<7>[ 29.004547] ddrfreq: change freq to 300 MHz when suspend
<14>[ 62.805742] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
