声卡问题???
RK3288烧的Firefly-rk3288_Ubuntu_1604_2016_10181203_Beta.7z.
alsamixer显示This sound device does not have any controls.
用aplay播放自己在别的地方捕获的原始音频数据有声音但声音极小,用其它播放器或网上播放音视频都完全没声音,调节音量都没用;后面装了pulseaudio后连用aplay播放都完全没声音了。
什么问题呀?求解答,先谢。
firefly@localhost:~$ dmesg
[ 0.000000] Linux version 4.4.16 (zouxf@mid-server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #102 SMP Mon Oct 17 11:19:36 CST 2016
[ 0.000000] Machine model: Firefly-RK3288
[ 0.000000] On node 0 totalpages: 524288
[ 0.000000] free_area_init_node: node 0, pgdat c0f8c6c0, node_mem_map eeffa000
[ 0.000000] Normal zone: 1536 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 196608 pages, LIFO batch:31
[ 0.000000] HighMem zone: 327680 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 13 pages/cpu @eef90000 s24064 r8192 d20992 u53248
[ 0.000000] pcpu-alloc: s24064 r8192 d20992 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522752
[ 0.000000] Kernel command line: earlyprintk=ttyS2,115200 console=tty0 console=ttyS2,115200 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00010000@0x00002000(boot),0x00002000@0x00012000(backup),-@0x00014000(linuxroot) storagemedia=emmc loader.timestamp=2015-01-21_16:36:44
[ 0.000000] Memory: 2061352K/2097152K available (9964K kernel code, 592K rwdata, 3328K rodata, 1024K init, 525K bss, 35800K reserved, 0K cma-reserved, 1310720K highmem)
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0dfb174 (14285 kB)
.init : 0xc0e00000 - 0xc0f00000 (1024 kB)
.data : 0xc0f00000 - 0xc0f943c0 ( 593 kB)
.bss : 0xc0f96000 - 0xc1019624 ( 526 kB)
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] L2C: failed to init: -19
[ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000025] Switching to timer-based delay loop, resolution 41ns
[ 0.002222] Console: colour dummy device 80x30
[ 0.003393] console [tty0] enabled
[ 0.003448] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.003523] pid_max: default: 32768 minimum: 301
[ 0.003663] Security Framework initialized
[ 0.003703] Yama: becoming mindful.
[ 0.003800] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.003848] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.004804] Initializing cgroup subsys devices
[ 0.004857] Initializing cgroup subsys freezer
[ 0.004917] CPU: Testing write buffer coherency: ok
[ 0.004988] ftrace: allocating 32784 entries in 97 pages
[ 0.083763] CPU0: update cpu_capacity 430
[ 0.083809] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.084165] Setting up static identity map for 0x100000 - 0x100058
[ 0.087457] CPU1: update cpu_capacity 430
[ 0.087464] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.089407] CPU2: update cpu_capacity 430
[ 0.089415] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.091331] CPU3: update cpu_capacity 430
[ 0.091338] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.091429] Brought up 4 CPUs
[ 0.091578] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.091604] CPU: All CPU(s) started in SVC mode.
[ 0.093176] devtmpfs: initialized
[ 0.107350] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.107791] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.108254] pinctrl core: initialized pinctrl subsystem
[ 0.109427] NET: Registered protocol family 16
[ 0.110313] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.133485] cpuidle: using governor ladder
[ 0.163512] cpuidle: using governor menu
[ 0.178736] gpiochip_add: registered GPIOs 0 to 23 on device: gpio0
[ 0.178869] gpiochip_add: registered GPIOs 24 to 55 on device: gpio1
[ 0.178995] gpiochip_add: registered GPIOs 56 to 87 on device: gpio2
[ 0.179113] gpiochip_add: registered GPIOs 88 to 119 on device: gpio3
[ 0.179238] gpiochip_add: registered GPIOs 120 to 151 on device: gpio4
[ 0.179356] gpiochip_add: registered GPIOs 152 to 183 on device: gpio5
[ 0.179474] gpiochip_add: registered GPIOs 184 to 215 on device: gpio6
[ 0.179602] gpiochip_add: registered GPIOs 216 to 247 on device: gpio7
[ 0.179722] gpiochip_add: registered GPIOs 248 to 263 on device: gpio8
[ 0.189371] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.189422] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.224973] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/dovdd-1v8-regulator[0]’
[ 0.225296] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vsys-regulator[0]’
[ 0.225715] of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/sdmmc-regulator[0]’ - status (0)
[ 0.226069] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/flash-regulator[0]’
[ 0.226340] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/usb-regulator[0]’
[ 0.226730] of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/usb-host-regulator[0]’ - status (0)
[ 0.227119] of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/usb-otg-regulator[0]’ - status (0)
[ 0.227520] of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/vcc28-dvp-regulator[0]’ - status (0)
[ 0.227966] of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/vga-regulator[0]’ - status (0)
[ 0.228654] iommu: Adding device ff930000.vop to group 0
[ 0.228771] iommu: Adding device ff940000.vop to group 1
[ 0.228887] iommu: Adding device ff9a0000.video-codec to group 2
[ 0.230148] SCSI subsystem initialized
[ 0.230466] usbcore: registered new interface driver usbfs
[ 0.230562] usbcore: registered new interface driver hub
[ 0.230649] usbcore: registered new device driver usb
[ 0.230833] Linux video capture interface: v2.00
[ 0.230902] pps_core: LinuxPPS API ver. 1 registered
[ 0.230929] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.230990] PTP clock support registered
[ 0.231571] Advanced Linux Sound Architecture Driver Initialized.
[ 0.232423] Bluetooth: Core ver 2.21
[ 0.232485] NET: Registered protocol family 31
[ 0.232511] Bluetooth: HCI device and connection manager initialized
[ 0.232546] Bluetooth: HCI socket layer initialized
[ 0.232579] Bluetooth: L2CAP socket layer initialized
[ 0.232638] Bluetooth: SCO socket layer initialized
[ 0.234111] clocksource: Switched to clocksource arch_sys_counter
[ 0.287956] NET: Registered protocol family 2
[ 0.288747] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.288873] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[ 0.289380] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.289490] UDP hash table entries: 512 (order: 2, 24576 bytes)
[ 0.289568] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[ 0.289912] NET: Registered protocol family 1
[ 0.290252] Trying to unpack rootfs image as initramfs…
[ 0.489607] Freeing initrd memory: 2660K (c4bf0000 - c4e89000)
[ 0.490586] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
[ 0.492507] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.493253] Initialise system trusted keyring
[ 0.504993] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.506701] fuse init (API version 7.23)
[ 0.512793] NET: Registered protocol family 38
[ 0.512849] Key type asymmetric registered
[ 0.512880] Asymmetric key parser ‘x509’ registered
[ 0.512993] bounce: pool size: 64 pages
[ 0.513267] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.513319] io scheduler noop registered
[ 0.513349] io scheduler deadline registered
[ 0.513557] io scheduler cfq registered (default)
[ 0.513996] rockchip-usb-phy phy: GPIO lookup for consumer vbus_drv
[ 0.514011] rockchip-usb-phy phy: using device tree for GPIO lookup
[ 0.514026] of_get_named_gpiod_flags: can’t parse ‘vbus_drv-gpios’ property of node ‘/phy[0]’
[ 0.514039] of_get_named_gpiod_flags: can’t parse ‘vbus_drv-gpio’ property of node ‘/phy[0]’
[ 0.514051] rockchip-usb-phy phy: using lookup tables for GPIO lookup
[ 0.514064] rockchip-usb-phy phy: lookup for GPIO vbus_drv failed
[ 0.514076] rockchip-usb-phy phy: vbus_drv is not assigned!
[ 0.518781] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.518834] dma-pl330 ff250000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.519823] dma-pl330 ffb20000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.519873] dma-pl330 ffb20000.dma-controller: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.520597] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.522701] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[ 0.523625] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 38, base_baud = 1500000) is a 16550A
[ 0.524584] console [ttyS2] disabled
[ 0.524658] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 39, base_baud = 1500000) is a 16550A
[ 1.256098] console [ttyS2] enabled
[ 1.260504] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 40, base_baud = 1500000) is a 16550A
[ 1.271006] [drm] Initialized drm 1.1.0 20060810
[ 1.277109] rockchip-lvds ff96c000.lvds: Failed to get supply ‘avdd1v0’: -517
[ 1.284372] platform ff96c000.lvds: Driver rockchip-lvds requests probe deferral
[ 1.293105] usbcore: registered new interface driver udl
[ 1.300333] vga-encoder vga-encoder: GPIO lookup for consumer psave
[ 1.300349] vga-encoder vga-encoder: using device tree for GPIO lookup
[ 1.300382] of_get_named_gpiod_flags: parsed ‘psave-gpios’ property of node ‘/vga-encoder[0]’ - status (0)
[ 1.300501] platform vga-encoder: Driver vga-encoder requests probe deferral
[ 1.308169] platform vga-connector: Driver vga-connector requests probe deferral
[ 1.315967] platform ffa30000.gpu: Driver mali requests probe deferral
[ 1.323962] brd: module loaded
[ 1.334727] loop: module loaded
[ 1.338764] zram: Added device: zram0
[ 1.342481] lkdtm: No crash points registered, enable through debugfs
[ 1.350918] tun: Universal TUN/TAP device driver, 1.6
[ 1.356029] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.363751] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[ 1.372737] platform ff290000.ethernet: Driver rk_gmac-dwmac requests probe deferral
[ 1.381120] PPP generic driver version 2.4.2
[ 1.385779] usbcore: registered new interface driver rndis_wlan
[ 1.391966] usbcore: registered new interface driver rt2800usb
[ 1.398119] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.405635] usbcore: registered new interface driver pegasus
[ 1.411369] usbcore: registered new interface driver rtl8150
[ 1.417124] usbcore: registered new interface driver r8152
[ 1.422693] usbcore: registered new interface driver asix
[ 1.428185] usbcore: registered new interface driver ax88179_178a
[ 1.434377] usbcore: registered new interface driver cdc_ether
[ 1.440281] usbcore: registered new interface driver dm9601
[ 1.445965] usbcore: registered new interface driver smsc75xx
[ 1.451800] usbcore: registered new interface driver smsc95xx
[ 1.457645] usbcore: registered new interface driver net1080
[ 1.463377] usbcore: registered new interface driver rndis_host
[ 1.469393] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.476945] usbcore: registered new interface driver cdc_ncm
[ 1.482676] usbcore: registered new interface driver cdc_mbim
[ 1.488871] ff540000.usb supply vusb_d not found, using dummy regulator
[ 1.495592] ff540000.usb supply vusb_a not found, using dummy regulator
[ 1.662622] dwc2 ff540000.usb: DWC OTG Controller
[ 1.667413] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
[ 1.674531] dwc2 ff540000.usb: irq 43, io mem 0x00000000
[ 1.680146] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.686977] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.694243] usb usb1: Product: DWC OTG Controller
[ 1.698965] usb usb1: Manufacturer: Linux 4.4.16 dwc2_hsotg
[ 1.704566] usb usb1: SerialNumber: ff540000.usb
[ 1.709952] hub 1-0:1.0: USB hub found
[ 1.713760] hub 1-0:1.0: 1 port detected
[ 1.718406] ff580000.usb supply vusb_d not found, using dummy regulator
[ 1.725149] ff580000.usb supply vusb_a not found, using dummy regulator
[ 2.024155] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 2.031842] dwc2 ff580000.usb: DWC OTG Controller
[ 2.036622] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
[ 2.043712] dwc2 ff580000.usb: irq 44, io mem 0x00000000
[ 2.049330] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.056162] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.063410] usb usb2: Product: DWC OTG Controller
[ 2.068147] usb usb2: Manufacturer: Linux 4.4.16 dwc2_hsotg
[ 2.073735] usb usb2: SerialNumber: ff580000.usb
[ 2.079139] hub 2-0:1.0: USB hub found
[ 2.082947] hub 2-0:1.0: 1 port detected
[ 2.088375] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.094959] ehci-platform: EHCI generic platform driver
[ 2.100571] usbcore: registered new interface driver cdc_acm
[ 2.106280] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.114351] usb 1-1: new high-speed USB device number 2 using dwc2
[ 2.120703] usbcore: registered new interface driver cdc_wdm
[ 2.126534] usbcore: registered new interface driver usb-storage
[ 2.132673] usbcore: registered new interface driver usbserial
[ 2.138602] usbcore: registered new interface driver usbserial_generic
[ 2.145206] usbserial: USB Serial support registered for generic
[ 2.151288] usbcore: registered new interface driver cp210x
[ 2.156936] usbserial: USB Serial support registered for cp210x
[ 2.162945] usbcore: registered new interface driver ftdi_sio
[ 2.168767] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.176252] usbcore: registered new interface driver keyspan
[ 2.181979] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 2.190081] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 2.197483] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 2.204876] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 2.212277] usbcore: registered new interface driver option
[ 2.217927] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.225086] usbcore: registered new interface driver oti6858
[ 2.230800] usbserial: USB Serial support registered for oti6858
[ 2.236904] usbcore: registered new interface driver pl2303
[ 2.242530] usbserial: USB Serial support registered for pl2303
[ 2.248651] usbcore: registered new interface driver qcserial
[ 2.254487] usbserial: USB Serial support registered for Qualcomm USB modem
[ 2.261537] usbcore: registered new interface driver sierra
[ 2.267188] usbserial: USB Serial support registered for Sierra USB modem
[ 2.274819] usbcore: registered new interface driver iforce
[ 2.280510] usbcore: registered new interface driver xpad
[ 2.286157] usbcore: registered new interface driver usbtouchscreen
[ 2.292774] i2c /dev entries driver
[ 2.297186] rk3x-i2c ff140000.i2c: Initialized RK3xxx I2C bus at f08be000
[ 2.304784] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at f08d2000
[ 2.312247] rk3x-i2c ff170000.i2c: Initialized RK3xxx I2C bus at f08d4000
[ 2.319927] fan53555-regulator 0-0040: GPIO lookup for consumer vsel
[ 2.319942] fan53555-regulator 0-0040: using device tree for GPIO lookup
[ 2.319958] of_get_named_gpiod_flags: can’t parse ‘vsel-gpios’ property of node ‘/i2c@ff650000/syr827@40[0]’
[ 2.319971] of_get_named_gpiod_flags: can’t parse ‘vsel-gpio’ property of node ‘/i2c@ff650000/syr827@40[0]’
[ 2.319982] fan53555-regulator 0-0040: using lookup tables for GPIO lookup
[ 2.319995] fan53555-regulator 0-0040: lookup for GPIO vsel failed
[ 2.320371] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 2.327718] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[ 2.334476] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.334662] vdd_cpu: No configuration
[ 2.335964] fan53555-regulator 0-0041: GPIO lookup for consumer vsel
[ 2.335971] fan53555-regulator 0-0041: using device tree for GPIO lookup
[ 2.335980] of_get_named_gpiod_flags: can’t parse ‘vsel-gpios’ property of node ‘/i2c@ff650000/syr828@41[0]’
[ 2.335987] of_get_named_gpiod_flags: can’t parse ‘vsel-gpio’ property of node ‘/i2c@ff650000/syr828@41[0]’
[ 2.335994] fan53555-regulator 0-0041: using lookup tables for GPIO lookup
[ 2.336001] fan53555-regulator 0-0041: lookup for GPIO vsel failed
[ 2.336350] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 2.336713] vdd_gpu: No configuration
[ 2.338988] rtc-hym8563 0-0051: no valid clock/calendar values available
[ 2.362625] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 2.367296] rtc-hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 2.367921] hub 1-1:1.0: USB hub found
[ 2.368010] hub 1-1:1.0: 4 ports detected
[ 2.390563] rk3x-i2c ff650000.i2c: Initialized RK3xxx I2C bus at f08d6000
[ 2.398296] rk3x-i2c ff660000.i2c: Initialized RK3xxx I2C bus at f08d8000
[ 2.405838] probe device ff9a0000.video-codec
[ 2.411296] rockchip-vpu ff9a0000.video-codec: Rockchip VPU encoder registered as /vpu/video0
[ 2.420109] rockchip-vpu ff9a0000.video-codec: Rockchip VPU decoder registered as /vpu/video1
[ 2.428948] usbcore: registered new interface driver uvcvideo
[ 2.434735] USB Video Class driver (1.1.1)
[ 2.439659] vcc_io: supplied by vcc_sys
[ 2.444176] vcc28_dvp: supplied by vcc_io
[ 2.448404] dovdd_1v8: supplied by vcc28_dvp
[ 2.452849] vcc_flash: supplied by vcc_io
[ 2.457190] vcc_lan: supplied by vcc_sys
[ 2.461598] vcc_20: supplied by vcc_sys
[ 2.465675] vcc_18: supplied by vcc_20
[ 2.470504] vcca_33: supplied by vcc_sys
[ 2.475070] vccio_sd: supplied by vcc_sys
[ 2.481605] rk_tsadcv2_initialize: Missing rockchip,grf property
[ 2.488797] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.497660] Bluetooth: Virtual HCI driver ver 1.5
[ 2.502578] Bluetooth: HCI UART driver ver 2.3
[ 2.507069] Bluetooth: HCI UART protocol H4 registered
[ 2.512222] Bluetooth: HCI UART protocol LL registered
[ 2.517389] Bluetooth: HCI UART protocol ATH3K registered
[ 2.522906] usbcore: registered new interface driver bfusb
[ 2.528530] usbcore: registered new interface driver btusb
[ 2.534328] vdd_cpu: supplied by vcc_sys
[ 2.541547] cpufreq-dt cpufreq-dt: failed register driver: -17
[ 2.547406] cpufreq-dt: probe of cpufreq-dt failed with error -17
[ 2.553541] sdhci: Secure Digital Host Controller Interface driver
[ 2.559726] sdhci: Copyright(c) Pierre Ossman
[ 2.564083] Synopsys Designware Multimedia Card Interface Driver
[ 2.570514] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.577769] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
[ 2.584563] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
[ 2.590336] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
[ 2.600139] vcc_sd: supplied by vcc_io
[ 2.604258] dwmmc_rockchip ff0c0000.dwmmc: GPIO lookup for consumer cd
[ 2.604265] dwmmc_rockchip ff0c0000.dwmmc: using device tree for GPIO lookup
[ 2.604271] of_get_named_gpiod_flags: can’t parse ‘cd-gpios’ property of node ‘/dwmmc@ff0c0000[0]’
[ 2.604277] of_get_named_gpiod_flags: can’t parse ‘cd-gpio’ property of node ‘/dwmmc@ff0c0000[0]’
[ 2.604282] dwmmc_rockchip ff0c0000.dwmmc: using lookup tables for GPIO lookup
[ 2.604288] dwmmc_rockchip ff0c0000.dwmmc: lookup for GPIO cd failed
[ 2.604294] dwmmc_rockchip ff0c0000.dwmmc: GPIO lookup for consumer wp
[ 2.604299] dwmmc_rockchip ff0c0000.dwmmc: using device tree for GPIO lookup
[ 2.604304] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@ff0c0000[0]’
[ 2.604309] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@ff0c0000[0]’
[ 2.604313] dwmmc_rockchip ff0c0000.dwmmc: using lookup tables for GPIO lookup
[ 2.604317] dwmmc_rockchip ff0c0000.dwmmc: lookup for GPIO wp failed
[ 2.664108] usb 1-1.1: new low-speed USB device number 3 using dwc2
[ 2.734140] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.755167] dwmmc_rockchip ff0c0000.dwmmc: 1 slots initialized
[ 2.761253] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.768319] usb 1-1.1: New USB device found, idVendor=17ef, idProduct=608d
[ 2.768323] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.768326] usb 1-1.1: Product: lenovo USB Optical Mouse
[ 2.768329] usb 1-1.1: Manufacturer: PixArt
[ 2.792177] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
[ 2.798969] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
[ 2.804739] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
[ 2.814677] dwmmc_rockchip ff0d0000.dwmmc: No vmmc regulator found
[ 2.820861] dwmmc_rockchip ff0d0000.dwmmc: GPIO lookup for consumer wp
[ 2.820866] dwmmc_rockchip ff0d0000.dwmmc: using device tree for GPIO lookup
[ 2.820872] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@ff0d0000[0]’
[ 2.820877] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@ff0d0000[0]’
[ 2.820882] dwmmc_rockchip ff0d0000.dwmmc: using lookup tables for GPIO lookup
[ 2.820887] dwmmc_rockchip ff0d0000.dwmmc: lookup for GPIO wp failed
[ 2.820965] platform sdio-pwrseq: GPIO lookup for consumer reset
[ 2.820970] platform sdio-pwrseq: using device tree for GPIO lookup
[ 2.820982] of_get_named_gpiod_flags: parsed ‘reset-gpios’ property of node ‘/sdio-pwrseq[0]’ - status (0)
[ 2.821011] dwmmc_rockchip ff0d0000.dwmmc: allocated mmc-pwrseq
[ 2.844106] usb 1-1.4: new low-speed USB device number 4 using dwc2
[ 2.844139] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.864150] dwmmc_rockchip ff0d0000.dwmmc: 1 slots initialized
[ 2.870250] dwmmc_rockchip ff0f0000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.878508] dwmmc_rockchip ff0f0000.dwmmc: Using internal DMA controller.
[ 2.885304] dwmmc_rockchip ff0f0000.dwmmc: Version ID is 270a
[ 2.893076] dwmmc_rockchip ff0f0000.dwmmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo
[ 2.903058] dwmmc_rockchip ff0f0000.dwmmc: GPIO lookup for consumer wp
[ 2.903064] dwmmc_rockchip ff0f0000.dwmmc: using device tree for GPIO lookup
[ 2.903070] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@ff0f0000[0]’
[ 2.903075] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@ff0f0000[0]’
[ 2.903079] dwmmc_rockchip ff0f0000.dwmmc: using lookup tables for GPIO lookup
[ 2.903084] dwmmc_rockchip ff0f0000.dwmmc: lookup for GPIO wp failed
[ 2.914131] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.934143] dwmmc_rockchip ff0f0000.dwmmc: 1 slots initialized
[ 2.939975] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.946629] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.954230] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/leds/work[0]’ - status (0)
[ 2.954325] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/leds/power[0]’ - status (0)
[ 2.954458] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.958133] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.959639] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.962341] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.978766] input: PixArt lenovo USB Optical Mouse as /devices/platform/ff540000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:17EF:608D.0001/input/input0
[ 2.991803] hid-generic 0003:17EF:608D.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt lenovo USB Optical Mouse] on usb-ff540000.usb-1.1/input0
[ 2.996793] mmc2: MAN_BKOPS_EN bit is not set
[ 2.997769] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
[ 2.997910] mmc2: new high speed MMC card at address 0001
[ 2.998251] mmcblk2: mmc2:0001 AWMB3R 14.6 GiB
[ 2.998380] mmcblk2boot0: mmc2:0001 AWMB3R partition 1 4.00 MiB
[ 2.998505] mmcblk2boot1: mmc2:0001 AWMB3R partition 2 4.00 MiB
[ 2.998615] mmcblk2rpmb: mmc2:0001 AWMB3R partition 3 4.00 MiB
[ 2.998951] boot: 0x000400000 – 0x002400000 (32 MB)
[ 2.998955] backup: 0x002400000 – 0x002800000 (4 MB)
[ 2.998958] linuxroot: 0x002800000 – 0x3a3a00000 (14866 MB)
[ 3.017354] mmcblk2: p1 p2 p3
[ 3.017355] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 3.075931] usbcore: registered new interface driver usbhid
[ 3.079852] random: nonblocking pool is initialized
[ 3.086064] usb 1-1.4: New USB device found, idVendor=17ef, idProduct=602d
[ 3.086068] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.086071] usb 1-1.4: Product: Lenovo Black Silk USB Keyboard
[ 3.086073] usb 1-1.4: Manufacturer: Lenovo
[ 3.097457] input: Lenovo Lenovo Black Silk USB Keyboard as /devices/platform/ff540000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:17EF:602D.0002/input/input1
[ 3.123866] usbhid: USB HID core driver
[ 3.129203] usbcore: registered new interface driver snd-usb-audio
[ 3.135965] of_get_named_gpiod_flags: parsed ‘spk-con-gpio’ property of node ‘/i2c@ff660000/es8323@10[0]’ - status (0)
[ 3.136016] of_get_named_gpiod_flags: parsed ‘hp-det-gpio’ property of node ‘/i2c@ff660000/es8323@10[0]’ - status (0)
[ 3.136571] platform sound_i2s: Driver asoc-simple-card requests probe deferral
[ 3.144978] u32 classifier
[ 3.147699] Netfilter messages via NETLINK v0.30.
[ 3.152443] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 3.158940] hid-generic 0003:17EF:602D.0002: input,hidraw1: USB HID v1.11 Keyboard [Lenovo Lenovo Black Silk USB Keyboard] on usb-ff540000.usb-1.4/input0
[ 3.172965] ctnetlink v0.93: registering with nfnetlink.
[ 3.178579] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.183956] Initializing XFRM netlink socket
[ 3.188742] NET: Registered protocol family 10
[ 3.193983] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.199563] sit: IPv6 over IPv4 tunneling driver
[ 3.204569] NET: Registered protocol family 17
[ 3.209027] NET: Registered protocol family 15
[ 3.213098] input: Lenovo Lenovo Black Silk USB Keyboard as /devices/platform/ff540000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:17EF:602D.0003/input/input2
[ 3.226813] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.239509] Bluetooth: RFCOMM socket layer initialized
[ 3.244667] Bluetooth: RFCOMM ver 1.11
[ 3.248424] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.254350] Bluetooth: HIDP socket layer initialized
[ 3.259316] 8021q: 802.1Q VLAN Support v1.8
[ 3.263513] lib80211: common routines for IEEE802.11 drivers
[ 3.264319] hid-generic 0003:17EF:602D.0003: input,hidraw2: USB HID v1.11 Device [Lenovo Lenovo Black Silk USB Keyboard] on usb-ff540000.usb-1.4/input1
[ 3.282724] lib80211_crypt: registered algorithm ‘NULL’
[ 3.282732] lib80211_crypt: registered algorithm ‘WEP’
[ 3.282739] lib80211_crypt: registered algorithm ‘CCMP’
[ 3.282745] lib80211_crypt: registered algorithm ‘TKIP’
[ 3.282753] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 3.287621] [BT_RFKILL]: Enter rfkill_rk_init
[ 3.292226] of_get_named_gpiod_flags: parsed ‘uart_rts_gpios’ property of node ‘/wireless-bluetooth[0]’ - status (0)
[ 3.292233] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 139.
[ 3.300425] of_get_named_gpiod_flags: can’t parse ‘BT,power_gpio’ property of node ‘/wireless-bluetooth[0]’
[ 3.300437] of_get_named_gpiod_flags: parsed ‘BT,reset_gpio’ property of node ‘/wireless-bluetooth[0]’ - status (0)
[ 3.300441] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 149.
[ 3.308538] of_get_named_gpiod_flags: parsed ‘BT,wake_gpio’ property of node ‘/wireless-bluetooth[0]’ - status (0)
[ 3.308542] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 146.
[ 3.316551] of_get_named_gpiod_flags: parsed ‘BT,wake_host_irq’ property of node ‘/wireless-bluetooth[0]’ - status (0)
[ 3.316555] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 151.
[ 3.324910] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 3.331634] [BT_RFKILL]: Request irq for bt wakeup host
[ 3.336884] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[ 3.336898] [BT_RFKILL]: ** disable irq
[ 3.345337] [BT_RFKILL]: bt_default device registered.
[ 3.350839] ThumbEE CPU extension supported.
[ 3.355129] Registering SWP/SWPB emulation handler
[ 3.360346] Loading compiled-in X.509 certificates
[ 3.365634] vdd10_lcd: supplied by vcc_sys
[ 3.370103] vcc18_lcd: supplied by vcc_20
[ 3.374830] rockchip-lvds ff96c000.lvds: neither panel nor encoder found
[ 3.381655] platform ff96c000.lvds: Driver rockchip-lvds requests probe deferral
[ 3.389257] vga-encoder vga-encoder: GPIO lookup for consumer psave
[ 3.389263] vga-encoder vga-encoder: using device tree for GPIO lookup
[ 3.389281] of_get_named_gpiod_flags: parsed ‘psave-gpios’ property of node ‘/vga-encoder[0]’ - status (0)
[ 3.389364] platform vga-encoder: Driver vga-encoder requests probe deferral
[ 3.396725] vdd_gpu: supplied by vcc_sys
[ 3.401395] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 3.408489] mali ffa30000.gpu: Probed as mali0
[ 3.413489] rk_gmac-dwmac ff290000.ethernet: clock input or output? (input).
[ 3.420554] rk_gmac-dwmac ff290000.ethernet: TX delay(0x30).
[ 3.426217] rk_gmac-dwmac ff290000.ethernet: RX delay(0x10).
[ 3.431926] rk_gmac-dwmac ff290000.ethernet: clock input from PHY
[ 3.438021] rk_gmac-dwmac ff290000.ethernet: init for RGMII
[ 3.448765] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 3.453813] Ring mode enabled
[ 3.456875] DMA HW capability register supported
[ 3.461397] Normal descriptors
[ 3.464728] RX Checksum Offload Engine supported (type 2)
[ 3.470207] TX Checksum insertion supported
[ 3.474477] Wake-Up On Lan supported
[ 3.478163] Enable RX Mitigation via HW Watchdog Timer
[ 3.483832] of_get_named_gpiod_flags: parsed ‘snps,reset-gpio’ property of node ‘/ethernet@ff290000[0]’ - status (0)
[ 3.714125] dwmmc_rockchip ff0d0000.dwmmc: Successfully tuned phase to 112
[ 3.723076] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.728587] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 3.738230] brcmfmac: brcmf_sdio_drivestrengthinit: No SDIO Drive strength init done for chip 4339 rev 2 pmurev 23
[ 3.855140] vendor storage:20160801 ret = 0
[ 3.960201] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Jul 25 2013 00:04:02 version 6.37.32.5 (r414538)
[ 4.007120] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[ 4.512032] libphy: stmmac: probed
[ 4.515473] eth0: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 4.521823] eth0: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 4.527885] platform sound_i2s: Driver asoc-simple-card requests probe deferral
[ 4.536011] rockchip-lvds ff96c000.lvds: neither panel nor encoder found
[ 4.542833] platform ff96c000.lvds: Driver rockchip-lvds requests probe deferral
[ 4.550385] vga-encoder vga-encoder: GPIO lookup for consumer psave
[ 4.550391] vga-encoder vga-encoder: using device tree for GPIO lookup
[ 4.550410] of_get_named_gpiod_flags: parsed ‘psave-gpios’ property of node ‘/vga-encoder[0]’ - status (0)
[ 4.550608] platform sound_i2s: Driver asoc-simple-card requests probe deferral
[ 4.559095] iommu: Adding device display-subsystem to group 3
[ 4.564866] rockchip-drm display-subsystem: Possibly a virtual device
[ 4.571475] rockchip-drm display-subsystem: bound ff940000.vop (ops vop_component_ops)
[ 4.579536] rockchip-drm display-subsystem: bound ff930000.vop (ops vop_component_ops)
[ 4.587542] dwhdmi-rockchip ff980000.hdmi: Detected HDMI controller 0x20:0xa:0xa0:0xc1
[ 4.595880] rockchip-drm display-subsystem: bound ff980000.hdmi (ops dw_hdmi_rockchip_ops)
[ 4.604255] vga-encoder vga-encoder: bound vga-connector (ops vga_connector_ops)
[ 4.611651] rockchip-lvds ff96c000.lvds: bound vga-encoder (ops vga_encoder_ops)
[ 4.619077] rockchip-drm display-subsystem: bound ff96c000.lvds (ops rockchip_lvds_component_ops)
[ 4.628103] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.634719] [drm] No driver support for vblank timestamp query.
[ 4.640646] rockchip-drm display-subsystem: failed to parse display resources
[ 4.671890] aaaaa vga_encoder_atomic_check 125 1
[ 4.689199] aaaaa vga_encoder_atomic_check 125 1
[ 4.713841] Console: switching to colour frame buffer device 240x67
[ 4.713860] aaaaa vga_encoder_atomic_check 125 1
[ 4.759729] rockchip-drm display-subsystem: fb0: frame buffer device
[ 4.794439] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,hp-det-gpio’ property of node ‘/sound_i2s[0]’
[ 4.794446] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,mic-det-gpio’ property of node ‘/sound_i2s[0]’
[ 4.912559] asoc-simple-card sound_i2s: i2s-hifi ↔ ff890000.i2s mapping ok
[ 4.921627] asoc-simple-card sound_i2s: ES8323 HiFi ↔ ff890000.i2s mapping ok
[ 4.931637] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/gpio-keys/button@0[0]’ - status (0)
[ 4.931685] gpio-5 (GPIO Power): gpiod_set_debounce: missing set() or set_debounce() operations
[ 4.931847] input: gpio-keys as /devices/platform/gpio-keys/input/input3
[ 4.938920] rtc-hym8563 0-0051: no valid clock/calendar values available
[ 4.945748] rtc-hym8563 0-0051: hctosys: unable to read the hardware clock
[ 4.959905] dovdd_1v8: disabling
[ 4.963223] vcc_sd: disabling
[ 4.966766] ALSA device list:
[ 4.969790] #0: rockchip,firefly-codec
[ 4.974010] ttyS2 - failed to request DMA
[ 4.978917] Freeing unused kernel memory: 1024K (c0e00000 - c0f00000)
[ 5.012001] udevd[144]: starting version 175
[ 6.228866] EXT4-fs (mmcblk2p3): 2 orphan inodes deleted
[ 6.234318] EXT4-fs (mmcblk2p3): recovery complete
[ 6.244886] EXT4-fs (mmcblk2p3): mounted filesystem with ordered data mode. Opts: (null)
[ 6.407910] systemd[1]: System time before build time, advancing clock.
[ 6.420937] systemd[1]: Failed to insert module ‘autofs4’: No such file or directory
[ 6.444027] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 6.462850] systemd[1]: Detected architecture arm.
[ 6.484676] systemd[1]: Set hostname to <localhost.localdomain>.
[ 6.785758] systemd[1]: Listening on udev Control Socket.
[ 6.804226] systemd[1]: Reached target Swap.
[ 6.824327] systemd[1]: Listening on Syslog Socket.
[ 6.844261] systemd[1]: Listening on Journal Socket.
[ 6.864188] systemd[1]: Reached target User and Group Name Lookups.
[ 6.890111] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.914313] systemd[1]: Listening on LVM2 poll daemon socket.
[ 6.934253] systemd[1]: Listening on udev Kernel Socket.
[ 6.954250] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 6.974172] systemd[1]: Reached target Encrypted Volumes.
[ 6.994302] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 7.014223] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 7.034465] systemd[1]: Created slice User and Session Slice.
[ 7.064376] systemd[1]: Created slice System Slice.
[ 7.134483] systemd[1]: Starting Set console keymap…
[ 7.166001] systemd[1]: Started Braille Device Support.
[ 7.197829] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 7.225997] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 7.266052] systemd[1]: Mounting Debug File System…
[ 7.301052] systemd[1]: Starting Load Kernel Modules…
[ 7.326052] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 7.356008] systemd[1]: Starting Create Static Device Nodes in /dev…
[ 7.384480] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.444540] systemd[1]: Starting Journal Service…
[ 7.474355] systemd[1]: Reached target Remote File Systems (Pre).
[ 7.504423] systemd[1]: Reached target Remote File Systems.
[ 7.534281] systemd[1]: Reached target Slices.
[ 7.596589] systemd[1]: Mounted Debug File System.
[ 7.624521] systemd[1]: Started Journal Service.
[ 8.386762] systemd-journald[328]: Received request to flush runtime journal from PID 1
[ 8.550842] aaaaa vga_encoder_atomic_check 125 1
[ 8.617726] aaaaa vga_encoder_atomic_check 125 1
[ 8.690293] [WLAN_RFKILL]: rfkill_get_wifi_power_state: rfkill-wlan driver has not Successful initialized
[ 8.690306] [BT_RFKILL]: rfkill_rk_set_power: cannot get wifi power state!
[ 9.119448] aaaaa vga_encoder_atomic_check 125 1
[ 9.737601] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[ 9.749252] cfg80211: World regulatory domain updated:
[ 9.749257] cfg80211: DFS Master region: unset
[ 9.749263] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 9.749269] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.749274] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.749279] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.749284] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 9.749290] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 9.749294] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 9.749298] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.749303] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 11.567903] aaaaa vga_encoder_atomic_check 125 1
[ 11.584402] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.584562] eth0: device MAC address 9e:f0:26:3b:31:44
[ 11.621224] aaaaa vga_encoder_atomic_check 125 1
[ 11.646275] aaaaa vga_encoder_atomic_check 125 1
[ 11.755374] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 11.806393] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 11.812942] brcmfmac: brcmf_add_if: ignore IF event
[ 11.820139] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 12.051418] aaaaa vga_encoder_atomic_check 125 1
[ 12.170813] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 12.177435] brcmfmac: brcmf_add_if: ignore IF event
[ 12.209415] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 12.622074] aaaaa vga_encoder_atomic_check 125 1
[ 16.726498] dwhdmi-rockchip ff980000.hdmi: Rate 0 missing; compute N dynamically
[ 16.743001] dwhdmi-rockchip ff980000.hdmi: Rate 0 missing; compute N dynamically
[ 21.783001] [WLAN_RFKILL]: rfkill_get_wifi_power_state: rfkill-wlan driver has not Successful initialized
[ 21.783016] [BT_RFKILL]: rfkill_rk_set_power: cannot get wifi power state!
[ 57.132286] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 57.174483] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 102.143954] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 102.223025] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 147.147132] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 147.197015] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 163.724641] rk_gmac-dwmac ff290000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 163.724714] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 252.544204] dwhdmi-rockchip ff980000.hdmi: Rate 0 missing; compute N dynamically
[ 440.709614] usb 1-1.4: USB disconnect, device number 4
[ 446.575542] usb 1-1.4: new high-speed USB device number 5 using dwc2
[ 446.677434] usb 1-1.4: New USB device found, idVendor=058f, idProduct=6366
[ 446.677465] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 446.677497] usb 1-1.4: Product: Flash Card Reader/Writer
[ 446.677516] usb 1-1.4: Manufacturer: Generic
[ 446.677533] usb 1-1.4: SerialNumber: 058F63666438
[ 446.679087] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[ 446.679725] scsi host0: usb-storage 1-1.4:1.0
[ 447.676649] scsi 0:0:0:0: Direct-Access Multiple Card Reader 1.00 PQ: 0 ANSI: 0
[ 448.210021] sd 0:0:0:0: [sda] 15638528 512-byte logical blocks: (8.01 GB/7.46 GiB)
[ 448.211122] sd 0:0:0:0: [sda] Write Protect is off
[ 448.211153] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 448.211856] sd 0:0:0:0: [sda] No Caching mode page found
[ 448.217310] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 448.228684] sda: sda1
[ 448.232880] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 454.262938] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 459.146536] usb 1-1.4: USB disconnect, device number 5
[ 465.785556] usb 1-1.4: new low-speed USB device number 6 using dwc2
[ 465.915859] usb 1-1.4: New USB device found, idVendor=17ef, idProduct=602d
[ 465.915912] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 465.915939] usb 1-1.4: Product: Lenovo Black Silk USB Keyboard
[ 465.915962] usb 1-1.4: Manufacturer: Lenovo
[ 465.939420] input: Lenovo Lenovo Black Silk USB Keyboard as /devices/platform/ff540000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:17EF:602D.0004/input/input4
[ 465.996391] hid-generic 0003:17EF:602D.0004: input,hidraw1: USB HID v1.11 Keyboard [Lenovo Lenovo Black Silk USB Keyboard] on usb-ff540000.usb-1.4/input0
[ 466.023324] input: Lenovo Lenovo Black Silk USB Keyboard as /devices/platform/ff540000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:17EF:602D.0005/input/input5
[ 466.076170] hid-generic 0003:17EF:602D.0005: input,hidraw2: USB HID v1.11 Device [Lenovo Lenovo Black Silk USB Keyboard] on usb-ff540000.usb-1.4/input1
[ 467.596738] usb 1-1.1: USB disconnect, device number 3
[ 470.905603] usb 1-1.1: new high-speed USB device number 7 using dwc2
[ 471.007419] usb 1-1.1: New USB device found, idVendor=058f, idProduct=6366
[ 471.007452] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 471.007483] usb 1-1.1: Product: Flash Card Reader/Writer
[ 471.007502] usb 1-1.1: Manufacturer: Generic
[ 471.007518] usb 1-1.1: SerialNumber: 058F63666438
[ 471.009188] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[ 471.009833] scsi host1: usb-storage 1-1.1:1.0
[ 472.006824] scsi 1:0:0:0: Direct-Access Multiple Card Reader 1.00 PQ: 0 ANSI: 0
[ 472.538963] sd 1:0:0:0: [sda] 15638528 512-byte logical blocks: (8.01 GB/7.46 GiB)
[ 472.539795] sd 1:0:0:0: [sda] Write Protect is off
[ 472.539831] sd 1:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 472.540670] sd 1:0:0:0: [sda] No Caching mode page found
[ 472.546191] sd 1:0:0:0: [sda] Assuming drive cache: write through
[ 472.560659] sda: sda1
[ 472.569201] sd 1:0:0:0: [sda] Attached SCSI removable disk
[ 478.254260] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 617.653260] usb 1-1.1: USB disconnect, device number 7
[ 627.616038] usb 1-1.1: new low-speed USB device number 8 using dwc2
[ 627.721297] usb 1-1.1: New USB device found, idVendor=17ef, idProduct=608d
[ 627.721338] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 627.721363] usb 1-1.1: Product: lenovo USB Optical Mouse
[ 627.721400] usb 1-1.1: Manufacturer: PixArt
[ 627.730473] input: PixArt lenovo USB Optical Mouse as /devices/platform/ff540000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:17EF:608D.0006/input/input6
[ 627.731704] hid-generic 0003:17EF:608D.0006: input,hidraw0: USB HID v1.11 Mouse [PixArt lenovo USB Optical Mouse] on usb-ff540000.usb-1.1/input0
这里有一些可能的结果出现在pulseaudio volume control的回放选项卡中:
A.程序播放出声音并且出现在回放标签的列表中
——程序正确的使用了pulseaudio声音系统
B.程序播放出声音但是没有出现在回放标签的列表中
——程序直接调用你的声卡或者通过ALSA的混音设备进行播放。这表示pulseaudio正确的运行但是导致了混音错误
C.程序没有播放出声音但是出现在回放标签列表中
——程序正式用pulseaudio但是遇到问题,比如:pulseaudio的bug;一些ALSA核心模块的问题或者库文件的问题;你的PCM音量或主音量被设置为静音
D.程序没有播放出声音同时没有出现在回放标签的列表里
——程序正试图通过直接调用声卡或者使用ALSA的dmix设备,但是声卡正在被使用。这与B的情况不同,但是都是由于混音错误所造成的。
E. pulseaudio volume control出现问题,显示:“Connection failed: Connection refused”
——pulseaudio 守护进程没有运行
F.其他(请详述)
提示:除非你所测试的程序与pulseaudio有已知的冲突,你应当坚信A结果是会在配置好的系统上出现的
我的情况是C,可是现在alsamixer不能控制声卡,根本就调不了音量,amixer:Unable to find simple control ‘PCM’(and ‘Master’), 0。用pavucontrol可以控制音量,但是不起作用,不知道是驱动的问题还是设备默认静音了。
自顶,up!up!up!
我们也遇到了同样的问题:
[ 3.644563] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 3.649299] [BT_RFKILL]: Enter rfkill_rk_init
[ 3.653900] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 139.
[ 3.662104] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 149.
[ 3.670207] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 146.
[ 3.678215] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 151.
[ 3.686572] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 3.693299] [BT_RFKILL]: Request irq for bt wakeup host
我出现的问题类似,log信息如下:
[root@rk3288:~]# aplay 1.wav
Playing WAVE ‘1.wav’ : Unsigned 8 bit, Rate 11025 Hz, Mono
[ 8150.973826] asoc-simple-card sound: ASoC: machine hw_params failed: -22
aplay: set_params:1403: Unable to install hw params:
ACCESS: RW_INTERLEAVED
FORMAT: U8
SUBFORMAT: STD
SAMPLE_BITS: 8
FRAME_BITS: 8
CHANNELS: 1
RATE: 11025
PERIOD_TIME: (124988 124989)
PERIOD_SIZE: 1378
PERIOD_BYTES: 1378
PERIODS: 4
BUFFER_TIME: (499954 499955)
BUFFER_SIZE: 5512
BUFFER_BYTES: 5512
TICK_TIME: 0
八龄先生 发表于 2021-4-15 18:05
我出现的问题类似,log信息如下:
Playing WAVE ‘1.wav’ : Unsigned 8 bi …
请问,有出现过underrun的情况吗?怎么解决?
这个说来话长
snap 发表于 2023-1-12 16:22
这个说来话长
请问rk3308的有办法解决吗?我卡了很长时间了
underrun 的问题吗?这个是代码的问题,需要在发送pcm数据的时候,考虑一下rate,别太快,也别太慢
