Hi Firefly,
我手边买了一块2017-03-08的3288板子
使用了官网上的SDK(已经git更新过了)
依照教学流程编译 烧入后
开机就变得不正常(无法下指令 无法使用adb)
之后使用官网给的固件
问题依然存在
这是什么原因造成的阿
如下为开机时候的log
DDR Version 1.00 20160217
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (Jul 15 2016 - 09:57:27)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks: 1
128 MiB
G�[ 0.000000] Booting Linux on physical CPU 0x500
[ 0.000000] Linux version 3.10.0 (firefly@tchip-server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #70 SMP PREEMPT Fri Jul 15 10:07:04 CST 2016
[ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x00000000
[ 0.000000] hdmi init vic is 16
[ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo
[ 0.000000] ion heap(cma): base(0) size(28000000) align(0)
[ 0.000000] cma: CMA: reserved 640 MiB at 55c00000
[ 0.000000] ion_reserve: cma reserved base 55c00000 size 671088640
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203)
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f14000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(param1
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 1353188k/1353188k available, 743964k reserved, 884736K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0bab728 (11918 kB)
[ 0.000000] .init : 0xc0bac000 - 0xc0c05440 ( 358 kB)
[ 0.000000] .data : 0xc0c06000 - 0xc0d98840 (1611 kB)
[ 0.000000] .bss : 0xc0d98840 - 0xc0eb9afc (1157 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_rate = 28
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:18
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:14
[ 0.341921] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.341936] pid_max: default: 32768 minimum: 301
[ 0.342051] Security Framework initialized
[ 0.342067] SELinux: Initializing.
[ 0.342139] Mount-cache hash table entries: 512
[ 0.342784] Initializing cgroup subsys debug
[ 0.342798] Initializing cgroup subsys memory
[ 0.342826] Initializing cgroup subsys freezer
[ 0.342854] CPU: Testing write buffer coherency: ok
[ 0.343164] /cpus/cpu@0 missing clock-frequency property
[ 0.343177] /cpus/cpu@1 missing clock-frequency property
[ 0.343187] /cpus/cpu@2 missing clock-frequency property
[ 0.343196] /cpus/cpu@3 missing clock-frequency property
[ 0.343246] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.343298] Setting up static identity map for 0xc0858180 - 0xc08581d8
[ 0.345754] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x188f (version 3.1)
[ 0.420070] CPU1: Booted secondary processor
[ 0.420103] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.439739] CPU2: Booted secondary processor
[ 0.439763] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.459447] CPU3: Booted secondary processor
[ 0.459470] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.459573] Brought up 4 CPUs
[ 0.459601] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.459610] CPU: All CPU(s) started in SVC mode.
[ 0.460354] devtmpfs: initialized
[ 0.464752] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.465845] pinctrl core: initialized pinctrl subsystem
[ 0.466098] regulator-dummy: no parameters
[ 0.490604] NET: Registered protocol family 16
[ 0.492510] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.492901] ion_snapshot: 0x1eaa0000 map to 0xe0907000 and copy to 0xc0e94e0c (version 0.1)
[ 0.493141] Registered FIQ tty driver
[ 0.493545] fiq-debugger is disabled in device tree
[ 0.494277] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.494300] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.494317] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.494334] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.494429] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.494494] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.494555] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.494615] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.494676] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.494737] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.494797] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.494859] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.494927] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.494991] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.495004] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.495015] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.495027] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.495633] rockchip_interrupts_register:bank_num=7
[ 0.497591] of_get_gpio_init_config:gpio[0] = 256, value = 0
[ 0.497611] of_get_gpio_init_config:gpio[1] = 136, value = 0
[ 0.497664] rockchip_pinctrl_probe:init ok
[ 0.504282] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.504369] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.504383] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.504558] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.504629] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.504641] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.504807] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.504878] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.504890] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.505061] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.505133] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.505146] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.505316] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.505393] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.505405] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.505576] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.505649] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.505661] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.505831] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.505903] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.505916] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.507685] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.507697] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.508281] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.508304] DDR DEBUG: version 1.00 20150126
[ 0.508334] DDR DEBUG: Channel a:
[ 0.508343] DDR DEBUG: DDR3 Device
[ 0.508357] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.508366] DDR DEBUG: Channel b:
[ 0.508373] DDR DEBUG: DDR3 Device
[ 0.508386] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.508394] DDR DEBUG: addr=0xda2000
[ 0.508404] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.508413] DDR DEBUG: socAddr[0]=0xda2000, socAddr[1]=0xda2100
[ 0.508422] DDR DEBUG: chAddr[0]=0xda2000, chAddr[1]=0xda2000
[ 0.508434] DDR DEBUG: dtar[0]=0x201b4000, dtar[1]=0x201b4000
[ 0.508487] DDR DEBUG: init success!!! freq=200MHz
[ 0.508496] DDR DEBUG: Channel a:
[ 0.508509] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.508521] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.508534] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.508546] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.508558] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.508567] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.508576] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.508583] DDR DEBUG: Channel b:
[ 0.508594] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.508607] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.508619] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.508631] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.508642] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.508651] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.508659] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.533154] bio: create slab at 0
[ 0.533682] Rockchip hdmi driver version 2.0
[ 0.533682] .
[ 0.534859] SCSI subsystem initialized
[ 0.535015] usbcore: registered new interface driver usbfs
[ 0.535060] usbcore: registered new interface driver hub
[ 0.535147] usbcore: registered new device driver usb
[ 0.537760] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.538253] rock3] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.538962] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.539928] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.540052] media: Linux media interface: v0.10
[ 0.540092] Linux video capture interface: v2.00
[ 0.540155] pps_core: LinuxPPS API ver. 1 registered
[ 0.540165] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.540185] PTP clock support registered
[ 0.540241] i2c-core: driver [bq24296] using legacy suspend method
[ 0.540251] i2c-core: driver [bq24296] using legacy resume method
[ 0.540930] ion_drm_heap_create: 0@0
[ 0.541067] Rockchip ion module is successfully loaded (v1.1)
[ 0.541228] Advanced Linux Sound Architecture Driver Initialized.
[ 0.541652] Bluetooth: Core ver 2.16
[ 0.541691] NET: Registered protocol family 31
[ 0.541701] Bluetooth: HCI device and connection manager initialized
[ 0.541717] Bluetooth: HCI socket layer initialized
[ 0.541731] Bluetooth: L2CAP socket layer initialized
[ 0.541757] Bluetooth: SCO socket layer initialized
[ 0.541988] cfg80211: Calling CRDA to update world regulatory domain
[ 0.542712] act8846_i2c_probe,line=898
[ 0.543713] act8846_parse_dt,line=746
4210] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.544224] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.544239] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.546339] act_dcdc1: 1200 mV
[ 0.549319] vccio: 3300 mV
[ 0.551188] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 0.554143] act_dcdc4: 2000 mV
[ 0.555405] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.557697] act_ldo2: 1050 mV
[ 0.560050] act_ldo3: 2800 mV
[ 0.562357] act_ldo4: 3300 mV
[ 0.564648] act_ldo5: 3300 mV
[ 0.566961] act_ldo6: 1100 mV
[ 0.569264] vcc_18: 1800 mV
[ 0.571563] act_ldo8: 1850 mV
[ 0.576324] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 0.581020] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 0.581780] rk808_i2c_probe,line=1355
[ 0.583109] The device is not rk808 -11
[ 0.583194] rk808: probe of 0-001b failed with error -11
[ 0.583271] i2c-core: driver [rk818] using legacy suspend method
[ 0.583281] i2c-core: driver [rk818] using legacy resume method
[ 0.585054] Switching to clocksource arch_sys_counter
[ 0.608849] rga: Module initialized.
[ 0.609560] rga2 ff920000.rga: rga ion client create success!
[ 0.609737] rga: Driver loaded succesfully
[ 0.609929] fb disp policy is box
[ 0.609970] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.609982] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.610311] rk-screen rk_screen.8: rockchip screen probe success
[ 0.610565] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.610932] rk32-edp ff970000.edp: screen is not edp!
[ 0.610953] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.611429] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 0.611649] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.611954] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.612130] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.612288] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.612999] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 0.613015] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.636983] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 0.643793] alloc_buffer:ion_phy_addr=0x10000000
[ 0.656655] fb0:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.671202] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaba000
[ 0.671252] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 0.671459] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 0.671471] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 0.671734] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.672075] graphics fb5: rockchip framebuffer registerd:fb5
[ 0.672247] graphics fb6: rockchip framebuffer registerd:fb6
[ 0.672415] graphics fb7: rockchip framebuffer registerd:fb7
[ 0.673204] unknow screen type: 0
[ 0.673273] rk3288-lcdc lcdc1: lcdc1: dclk:148500000>>fps:868
[ 0.673286] rk3288-lcdc lcdc1: wakeup from standby!
[ 0.677068] fb4:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.677083] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
[ 0.677933] rockchip_set_mux:warning ignore bank num 15
[ 0.678066] rockchip_set_mux:warning ignore bank num 15
[ 0.678180] rockchip_set_mux:warning ignore bank num 15
[ 0.678303] rockchip_set_mux:warning ignore bank num 15
[ 0.678416] rockchip_set_mux:warning ignore bank num 15
[ 0.678537] rockchip_set_mux:warning ignore bank num 15
[ 0.679110] rockchip_set_mux:warning ignore bank num 15
[ 0.679269] rockchip_set_mux:warning ignore bank num 15
[ 0.679808] rockchip_set_mux:warning ignore bank num 15
[ 0.679969] rockchip_set_mux:warning ignore bank num 15
[ 0.680510] rockchip_set_mux:warning ignore bank num 15
[ 0.680655] rockchip_set_mux:warning ignore bank num 15
[ 0.681204] rockchip_set_mux:warning ignore bank num 15
[ 0.681350] rockchip_set_mux:warning ignore bank num 15
[ 0.682866] NET: Registered protocol family 2
[ 0.683591] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.683668] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.683741] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.683797] TCP: reno registered
[ 0.683813] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.683836] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.684032] NET: Registered protocol family 1
[ 0.684656] Unpacking initramfs…
[ 0.824159] Freeing initrd memory: 2840K (c5bf0000 - c5eb6000)
[ 0.824996] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 0.825552] vcodec_service: probe device ff9a0000.vpu_service
[ 0.825746] vcodec_service: No reset resource define
[ 0.825914] vcodec_service: ff9a0000.vpu_service: power on
[ 0.826050] vcodec_service: probe device ff9a0000.vpu_service
[ 0.826068] vcodec_service: checking hw id 4831
[ 0.827029] vcodec_service: ff9a0000.vpu_service: power off…
[ 0.827071] vcodec_service: done
[ 0.827081] vcodec_service: init success
[ 0.827167] vcodec_service: probe device ff9c0000.hevc_service
[ 0.827497] vcodec_service: ff9c0000.hevc_service: power on
[ 0.827555] vcodec_service: probe device ff9c0000.hevc_service
[ 0.827568] vcodec_service: checking hw id 6867
[ 0.827819] vcodec_service: ff9c0000.hevc_service: power off…
[ 0.827857] vcodec_service: done
[ 0.827865] vcodec_service: init success
[ 0.827998] rknandbase v1.0 2014-03-31
[ 0.828128] rknand: probe of ff400000.nandc failed with error -1
[ 0.828255] rknand_driver:ret = 0
[ 0.830196] audit: initializing netlink socket (disabled)
[ 0.830248] type=2000 audit(0.480:1): initialized
[ 0.831086] bounce pool size: 64 pages
/sbin/sh: No controlling tty: open /dev/tty: No such device or a
[ 0.836115] msgmni has been set to 952
[ 0.838005] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.838021] io scheduler noop regiddress
/sbin/sh: warning: won’t have full job control
