如何挂载已经编译好的kernel.img
新手,编译好的kernel文件。想挂载到目录上查看内容。但是
sudo mount -t ext[234] [-o loop] kernel.img testmount/
mount: wrong fs type, bad option, bad superblock on /dev/loop3,
       missing codepage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail  or so
dmesg|tail:
[13035.226684] EXT4-fs (loop3): VFS: Can't find ext4 filesystem
fdisk -l kernel.img
Disk kernel.img: 6 MB, 6330880 bytes
255 heads, 63 sectors/track, 0 cylinders, total 12365 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x1a000003
Disk kernel.img doesn't contain a valid partition table
ubuntu14.4的发行版
按照网上资料,查了下没有没有 /etc/filesystems 和 /etc/vfs
完全不知道怎么办了。
kernel.img只能刷哦,不能想system那样挂载
那请问有没有什么方法查看编译好的目录结构呢?
楼主可以看看这个文件arch/arm/Makefile:
332 kernel.img: zImage
333     $(Q)$(srctree)/mkkrnlimg $(objtree)/arch/arm/boot/zImage $(objtree)/kernel.img >/dev/null
334     @echo '  Image:  kernel.img is ready'
335
336 %_kernel.img: %.dtb zImage
337     $(Q)cat $(objtree)/arch/arm/boot/zImage $(objtree)/arch/arm/boot/dts/$*.dtb > $(objtree)/zImage-dtb && \
338     $(srctree)/mkkrnlimg $(objtree)/zImage-dtb $(objtree)/kernel.img >/dev/null && \
339     rm -f $(objtree)/zImage-dtb
340     @echo '  Image:  kernel.img (with $*.dtb) is ready'
341
342 LOGO := $(notdir $(wildcard $(srctree)/logo.bmp))
343 %.img: %.dtb kernel.img $(LOGO)
344     $(Q)$(srctree)/resource_tool $(objtree)/arch/arm/boot/dts/$*.dtb $(LOGO)
345     @echo '  Image:  resource.img (with $*.dtb $(LOGO)) is ready'
了解一下kernel.img和zImage的格式
