Camera成功添加了2592x1944的分辨率,但是刚切换到这个分辨率时预览界面会绿屏,点击录制视频后又正常了。如果退出camera后再进入camera系统会自动重启。请问哪位大神知道是什么原因?
log如下:过程(打开camera->切换video(绿屏)->录制video(正常)->退出camera->打开camera->系统重启)
绿屏会一直输出:E/JPEG_DEC( 171): out offset big then 22bit iommu map may be error
--------- beginning of system
E/DrmService( 0): ----------------running drmservice---------------
E/DrmService( 0): ------------ set_iface ----------------
I/Vold ( 164): Vold 2.1 (the revenge) firing up
E/Vold ( 164): Volume::Volume mDiskVolumeLabel = USB_DISK0
E/Vold ( 164): Volume::Volume mLabel = internal_sd
D/Vold ( 164): Volume internal_sd state changing -1 (Initializing) → 0 (No-Media)
E/Vold ( 164): label internal_sd addPath /devices/ff0f0000.rksdmmc/mmc_host/mmc
E/Vold ( 164): Volume::Volume mLabel = external_sd
I/Vold ( 164): Error(call No.1) opening /sys/sd-sdio/rescan in the file of Volume.cpp
D/Vold ( 164): Volume external_sd state changing -1 (Initializing) → 0 (No-Media)
E/Vold ( 164): label external_sd addPath /devices/ff0c0000.rksdmmc/mmc_host/mmc
E/Vold ( 164): Volume::Volume mLabel = usb_storage
D/Vold ( 164): Volume usb_storage state changing -1 (Initializing) → 0 (No-Media)
E/Vold ( 164): label usb_storage addPath /devices/ff580000.usb
E/Vold ( 164): Volume::Volume mDiskVolumeLabel = USB_DISK1
E/Vold ( 164): label usb_storage addPath /devices/ff500000.usb
E/Vold ( 164): Volume::Volume mDiskVolumeLabel = USB_DISK2
E/Vold ( 164): label usb_storage addPath /devices/ff540000.usb
E/Vold ( 164): Volume::Volume mDiskVolumeLabel = USB_DISK3
E/Vold ( 164): Volume::Volume mDiskVolumeLabel = USB_DISK4
E/Vold ( 164): Volume::Volume mDiskVolumeLabel = USB_DISK5
E/Vold ( 164): Start Misc devices Manager…
D/Vold ( 164): Vendor path: /sys/bus/usb/devices/1-1/idVendor
D/Vold ( 164): === config_file is: 0000_0000
D/DirectVolume( 164): directvolume DEVPATH = /devices/virtual/block/loop0.
W/Vold ( 164): No volumes handled block event for ‘/devices/virtual/block/loop0’
D/DirectVolume( 164): directvolume DEVPATH = /devices/virtual/block/loop1.
W/Vold ( 164): No volumes handled block event for ‘/devices/virtual/block/loop1’
D/DirectVolume( 164): directvolume DEVPATH = /devices/virtual/block/loop2.
W/Vold ( 164): No volumes handled block event for ‘/devices/virtual/block/loop2’
D/DirectVolume( 164): directvolume DEVPATH = /devices/virtual/block/loop3.
W/Vold ( 164): No volumes handled block event for ‘/devices/virtual/block/loop3’
D/DirectVolume( 164): directvolume DEVPATH = /devices/virtual/block/loop4.
W/Vold ( 164): No volumes handled block event for ‘/devices/virtual/block/loop4’
D/DirectVolume( 164): directvolume DEVPATH = /devices/virtual/block/loop5.
W/Vold ( 164): No volumes handled block event for ‘/devices/virtual/block/loop5’
D/DirectVolume( 164): directvolume DEVPATH = /devices/virtual/block/loop6.
W/Vold ( 164): No volumes handled block event for ‘/devices/virtual/block/loop6’
D/DirectVolume( 164): directvolume DEVPATH = /devices/virtual/block/loop7.
W/Vold ( 164): No volumes handled block event for ‘/devices/virtual/block/loop7’
D/DirectVolume( 164): directvolume DEVPATH = /devices/virtual/block/zram0.
W/Vold ( 164): No volumes handled block event for ‘/devices/virtual/block/zram0’
D/DirectVolume( 164): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0.
W/DirectVolume( 164): Deprecated implied prefix pattern detected, please use ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc*’ instead
D/DirectVolume( 164): DEVTYPE = disk.
D/DirectVolume( 164): getLabel = internal_sd,devtype = disk,getDevPath = (null).
D/DirectVolume( 164): ----handleDiskAdded,mDiskNumParts =15,mDiskMajor=179,mDiskMinor=0
D/DirectVolume( 164): Dv::diskIns - waiting for 15 pending partitions
D/Vold ( 164): Volume internal_sd state changing 0 (No-Media) → 2 (Pending)
D/Vold ( 164): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0’ event handled by volume internal_sd
D/DirectVolume( 164): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p1.
D/DirectVolume( 164): DEVTYPE = partition.
D/DirectVolume( 164): getLabel = internal_sd,devtype = partition,getDevPath = (null).
D/DirectVolume( 164): —handlePartitionAdded,part_num=1,major=179,minor=1,mDiskMajor=179
D/DirectVolume( 164): Dv:partAdd: part_num = 1, minor = 1
D/DirectVolume( 164): Dv:partAdd: pending 14 disk
D/Vold ( 164): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p1’ event handled by volume internal_sd
D/DirectVolume( 164): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p2.
D/DirectVolume( 164): —handlePartitionAdded,part_num=2,major=179,minor=2,mDiskMajor=179
D/DirectVolume( 164): Dv:partAdd: part_num = 2, minor = 2
D/DirectVolume( 164): Dv:partAdd: pending 13 disk
D/Vold ( 164): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p2’ event handled by volume internal_sd
D/DirectVolume( 164): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p3.
D/DirectVolume( 164): —handlePartitionAdded,part_num=3,major=179,minor=3,mDiskMajor=179
D/DirectVolume( 164): Dv:partAdd: part_num = 3, minor = 3
D/DirectVolume( 164): Dv:partAdd: pending 12 disk
D/Vold ( 164): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p3’ event handled by volume internal_sd
D/DirectVolume( 164): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p4.
D/DirectVolume( 164): —handlePartitionAdded,part_num=4,major=179,minor=4,mDiskMajor=179
D/DirectVolume( 164): Dv:partAdd: part_num = 4, minor = 4
D/DirectVolume( 164): Dv:partAdd: pending 11 disk
D/Vold ( 164): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p4’ event handled by volume internal_sd
D/DirectVolume( 164): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p5.
D/DirectVolume( 164): —handlePartitionAdded,part_num=5,major=179,minor=5,mDiskMajor=179
D/DirectVolume( 164): Dv:partAdd: part_num = 5, minor = 5
D/DirectVolume( 164): Dv:partAdd: pending 10 disk
D/Vold ( 164): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p5’ event handled by volume internal_sd
D/DirectVolume( 164): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p6.
D/DirectVolume( 164): —handlePartitionAdded,part_num=6,major=179,minor=6,mDiskMajor=179
D/DirectVolume( 164): Dv:partAdd: part_num = 6, minor = 6
D/DirectVolume( 164): Dv:partAdd: pending 9 disk
D/Vold ( 164): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p6’ event handled by volume internal_sd
D/DirectVolume( 164): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p7.
D/DirectVolume( 164): —handlePartitionAdded,part_num=7,major=179,minor=7,mDiskMajor=179
D/DirectVolume( 164): Dv:partAdd: part_num = 7, minor = 7
D/DirectVolume( 164): Dv:partAdd: pending 8 disk
D/Vold ( 164): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p7’ event handled by volume internal_sd
D/DirectVolume( 164): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p8.
D/DirectVolume( 164): —handlePartitionAdded,part_num=8,major=179,minor=8,mDiskMajor=179
D/DirectVolume( 164): Dv:partAdd: part_num = 8, minor = 8
D/DirectVolume( 164): Dv:partAdd: pending 7 disk
D/Vold ( 164): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p8’ event handled by volume internal_sd
D/DirectVolume( 164): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p9.
D/DirectVolume( 164): —handlePartitionAdded,part_num=9,major=179,minor=9,mDiskMajor=179
D/DirectVolume( 164): Dv:partAdd: part_num = 9, minor = 9
D/DirectVolume( 164): Dv:partAdd: pending 6 disk
D/Vold ( 164): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p9’ event handled by volume internal_sd
D/DirectVolume( 164): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p10.
D/DirectVolume( 164): —handlePartitionAdded,part_num=10,major=179,minor=10,mDiskMajor=179
D/DirectVolume( 164): Dv:partAdd: part_num = 10, minor = 10
D/DirectVolume( 164): Dv:partAdd: pending 5 disk
D/Vold ( 164): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p10’ event handled by volume internal_sd
D/DirectVolume( 164): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p11.
D/DirectVolume( 164): —handlePartitionAdded,part_num=11,major=179,minor=11,mDiskMajor=179
D/DirectVolume( 164): Dv:partAdd: part_num = 11, minor = 11
D/DirectVolume( 164): Dv:partAdd: pending 4 disk
D/Vold ( 164): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p11’ event handled by volume internal_sd
D/DirectVolume( 164): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p12.
D/DirectVolume( 164): —handlePartitionAdded,part_num=12,major=179,minor=12,mDiskMajor=179
D/DirectVolume( 164): Dv:partAdd: part_num = 12, minor = 12
D/DirectVolume( 164): Dv:partAdd: pending 3 disk
D/Vold ( 164): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p12’ event handled by volume internal_sd
D/DirectVolume( 164): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p13.
D/DirectVolume( 164): —handlePartitionAdded,part_num=13,major=179,minor=13,mDiskMajor=179
D/DirectVolume( 164): Dv:partAdd: part_num = 13, minor = 13
D/DirectVolume( 164): Dv:partAdd: pending 2 disk
D/Vold ( 164): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p13’ event handled by volume internal_sd
D/DirectVolume( 164): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p14.
D/DirectVolume( 164): —handlePartitionAdded,part_num=14,major=179,minor=14,mDiskMajor=179
D/DirectVolume( 164): Dv:partAdd: part_num = 14, minor = 14
D/DirectVolume( 164): Dv:partAdd: pending 1 disk
D/Vold ( 164): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p14’ event handled by volume internal_sd
D/DirectVolume( 164): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p15.
D/DirectVolume( 164): —handlePartitionAdded,part_num=15,major=179,minor=15,mDiskMajor=179
D/DirectVolume( 164): Dv:partAdd: part_num = 15, minor = 15
D/DirectVolume( 164): Dv:partAdd: Got all partitions - ready to rock!
D/Vold ( 164): Volume internal_sd state changing 2 (Pending) → 1 (Idle-Unmounted)
D/Vold ( 164): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p15’ event handled by volume internal_sd
W/Vold ( 164): subsystem found in netlink event
D/Vold ( 164): handleEvent usb, 1
D/Vold ( 164): == current usb device: 1A40/0101 ===
E/DrmService( 174): [wlan0] interface is up
E/DrmService( 174): [wlan0] interface is down
D/Vold ( 164): == current usb device: 05A3/8530 ===
E/DrmService( 174): -------------generate_device_serialno,len =10,result=GB8ZATWHFM
E/DrmService( 174): auto generate serialno,serialno = GB8ZATWHFM
E/DrmService( 174): rknand_sys_storage open fail
E/DrmService( 174): detect keybox disabled
D/Vold ( 164): == current usb device: 093A/2510 ===
I/InstallerConnection( 474): connecting…
I/InstallerConnection( 474): disconnecting…
I/SystemServer( 474): Entered the Android system server!
--------- beginning of main
V/Sensors ( 474): enable - sensor LinearAccel (handle 1) dis → dis
V/Sensors ( 474): int poll__activate(sensors_poll_device_t*, int, int)
V/Sensors ( 474): int sensors_poll_context_t::activate(int, int)
V/Sensors ( 474): enable - sensor Gravity (handle 2) dis → dis
V/Sensors ( 474): enable - sensor Gyro (handle 3) dis → dis
V/Sensors ( 474): enable - sensor Accelerometer (handle 4) dis → dis
V/Sensors ( 474): enable - sensor MagneticField (handle 5) dis → dis
V/Sensors ( 474): enable - sensor Orientation (handle 6) dis → dis
D/SensorService( 474): new thread SensorEventAckReceiver
D/SensorService( 474): nuSensorService thread starting…
I/SystemServiceManager( 474): Starting com.android.server.pm.Installer
I/Installer( 474): Waiting for installd to be ready.
I/installd( 172): new connection
I/SystemServiceManager( 474): Starting com.android.server.am.ActivityManagerService$Lifecycle
I/ActivityManagerService( 474): Memory class: 192
I/ServiceThread( 474): Enabled StrictMode logging for ActivityManagerService looper.
I/AppOps ( 474): No existing app ops /data/system/appops.xml; starting empty
I/IntentFirewall( 474): Read new rules (A:0 B:0 S:0)
I/ServiceThread( 474): Enabled StrictMode logging for android.ui looper.
I/ServiceThread( 474): Enabled StrictMode logging for android.display looper.
I/PowerProfile( 474): Reading power values from XML resource
D/AppOps ( 474): AppOpsService published
I/SystemServiceManager( 474): Starting com.android.server.display.DisplayManagerService
I/SystemServiceManager( 474): Starting com.android.server.power.PowerManagerService
I/ServiceThread( 474): Enabled StrictMode logging for PowerManagerService looper.
D/RKPowerHAL( 474): version 3.0
W/libsuspend( 474): Error writing ‘on’ to /sys/power/state: Invalid argument
I/libsuspend( 474): Selected wakeup count
E/RKPowerHAL( 474): Error opening /sys/devices/system/cpu/cpufreq/interactive/input_boost: No such file or directory
E/RKPowerHAL( 474): Error opening /sys/devices/system/cpu/cpu7/online: No such file or directory
E/RKPowerHAL( 474): Error opening /sys/devices/system/cpu/cpu6/online: No such file or directory
E/RKPowerHAL( 474): Error opening /sys/devices/system/cpu/cpu5/online: No such file or directory
E/RKPowerHAL( 474): Error opening /sys/devices/system/cpu/cpu4/online: No such file or directory
I/DisplayManagerService( 474): Display device added: DisplayDeviceInfo{“Built-in Screen”: uniqueId=“local:0”, 1280 x 720, 69.096 fps, supportedRefreshRates [69.096], density 160, 160.15764 x 160.42105 dpi, appVsyncOff 0, presDeadline 15472617, touch INTERNAL, rotation 0, type BUILT_IN, state UNKNOWN, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
E/RKPowerHAL( 474): Error opening /sys/devices/system/cpu/cpu3/online: Permission denied
E/RKPowerHAL( 474): Error opening /sys/devices/system/cpu/cpu2/online: Permission denied
I/DisplayManagerService( 474): Display device added: DisplayDeviceInfo{“HDMI Screen”: uniqueId=“local:1”, 1366 x 768, 61724.586 fps, supportedRefreshRates [61724.586], density 227, 227.0 x 227.0 dpi, appVsyncOff 0, presDeadline 1016201, touch EXTERNAL, rotation 0, type HDMI, state UNKNOWN, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS, FLAG_PRESENTATION}
I/SystemServiceManager( 474): Starting phase 100
I/SystemServer( 474): Package Manager
W/SELinuxMMAC( 474): Error opening /data/system/seapp_hash. Assuming first boot.
W/FileUtils( 474): Failed to chmod(/data/system/packages.list): android.system.ErrnoException: chmod failed: ENOENT (No such file or directory)
D/DisplayManager( 474): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 720, real 1280 x 720, largest app 1280 x 720, smallest app 1280 x 720, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state UNKNOWN, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
W/SystemConfig( 474): No directory /system/etc/sysconfig, skipping
E/multiwindow_mode( 474): MultiWindow - appWindowModeConfigFile dosen’t exist, get it from init config file
D/SELinuxMMAC( 474): Using policy file /system/etc/security/mac_permissions.xml
I/PackageManager( 474): No settings file; creating initial state
I/dex2oat ( 527): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/com.android.location.provider.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@com.android.location.provider.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 527): Decided to run without swap.
I/dex2oat ( 527): dex2oat took 26.315ms (threads: 4) arena alloc=0B java alloc=76KB native alloc=78KB free=29KB
I/dex2oat ( 532): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/com.android.future.usb.accessory.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@com.android.future.usb.accessory.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 532): Decided to run without swap.
I/dex2oat ( 532): dex2oat took 20.059ms (threads: 4) arena alloc=0B java alloc=11KB native alloc=76KB free=31KB
I/dex2oat ( 537): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/javax.obex.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@javax.obex.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 537): Decided to run without swap.
I/dex2oat ( 537): dex2oat took 41.622ms (threads: 4) arena alloc=0B java alloc=38KB native alloc=78KB free=81KB
I/dex2oat ( 542): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/android.test.runner.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@android.test.runner.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 542): Decided to run without swap.
I/dex2oat ( 542): dex2oat took 192.582ms (threads: 4) arena alloc=0B java alloc=235KB native alloc=241KB free=102KB
I/dex2oat ( 547): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/com.android.media.remotedisplay.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@com.android.media.remotedisplay.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 547): Decided to run without swap.
I/dex2oat ( 547): dex2oat took 19.801ms (threads: 4) arena alloc=0B java alloc=15KB native alloc=76KB free=31KB
I/dex2oat ( 552): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/com.android.mediadrm.signer.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@com.android.mediadrm.signer.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 552): Decided to run without swap.
I/dex2oat ( 552): dex2oat took 22.654ms (threads: 4) arena alloc=0B java alloc=5KB native alloc=75KB free=32KB
I/dex2oat ( 557): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/am.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@am.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 557): Decided to run without swap.
I/dex2oat ( 557): dex2oat took 34.269ms (threads: 4) arena alloc=0B java alloc=35KB native alloc=76KB free=91KB
I/dex2oat ( 562): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/appops.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@appops.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 562): Decided to run without swap.
I/dex2oat ( 562): dex2oat took 18.995ms (threads: 4) arena alloc=0B java alloc=9KB native alloc=75KB free=36KB
I/dex2oat ( 567): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/appwidget.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@appwidget.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 567): Decided to run without swap.
I/dex2oat ( 567): dex2oat took 19.494ms (threads: 4) arena alloc=0B java alloc=5KB native alloc=75KB free=32KB
I/dex2oat ( 572): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/bmgr.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@bmgr.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 572): Decided to run without swap.
I/dex2oat ( 572): dex2oat took 22.865ms (threads: 4) arena alloc=0B java alloc=15KB native alloc=75KB free=32KB
I/dex2oat ( 577): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/bu.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@bu.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 577): Decided to run without swap.
I/dex2oat ( 577): dex2oat took 20.202ms (threads: 4) arena alloc=0B java alloc=8KB native alloc=75KB free=32KB
I/dex2oat ( 582): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/content.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@content.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 582): Decided to run without swap.
I/dex2oat ( 582): dex2oat took 62.216ms (threads: 4) arena alloc=0B java alloc=13KB native alloc=76KB free=39KB
I/dex2oat ( 587): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/dpm.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@dpm.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 587): Decided to run without swap.
I/dex2oat ( 587): dex2oat took 20.400ms (threads: 4) arena alloc=0B java alloc=4KB native alloc=75KB free=32KB
I/dex2oat ( 592): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/ime.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@ime.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 592): Decided to run without swap.
I/dex2oat ( 592): dex2oat took 22.158ms (threads: 4) arena alloc=0B java alloc=6KB native alloc=75KB free=32KB
I/dex2oat ( 597): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/input.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@input.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 597): Decided to run without swap.
I/dex2oat ( 597): dex2oat took 20.580ms (threads: 4) arena alloc=0B java alloc=5KB native alloc=75KB free=32KB
I/dex2oat ( 602): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/media_cmd.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@media_cmd.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 602): Decided to run without swap.
I/dex2oat ( 602): dex2oat took 22.423ms (threads: 4) arena alloc=0B java alloc=29KB native alloc=75KB free=32KB
I/dex2oat ( 607): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/monkey.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@monkey.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 607): Decided to run without swap.
I/dex2oat ( 607): dex2oat took 69.427ms (threads: 4) arena alloc=0B java alloc=119KB native alloc=81KB free=202KB
I/dex2oat ( 612): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/pm.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@pm.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 612): Decided to run without swap.
I/dex2oat ( 612): dex2oat took 71.587ms (threads: 4) arena alloc=0B java alloc=38KB native alloc=76KB free=43KB
I/dex2oat ( 617): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/requestsync.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@requestsync.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 617): Decided to run without swap.
I/dex2oat ( 617): dex2oat took 16.865ms (threads: 4) arena alloc=0B java alloc=3KB native alloc=75KB free=36KB
I/dex2oat ( 622): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/settings.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@settings.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 622): Decided to run without swap.
I/dex2oat ( 622): dex2oat took 17.771ms (threads: 4) arena alloc=0B java alloc=5KB native alloc=75KB free=32KB
I/dex2oat ( 627): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/svc.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@svc.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 627): Decided to run without swap.
I/dex2oat ( 627): dex2oat took 58.265ms (threads: 4) arena alloc=0B java alloc=14KB native alloc=75KB free=32KB
I/dex2oat ( 632): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/uiautomator.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@uiautomator.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 632): Decided to run without swap.
I/dex2oat ( 632): dex2oat took 144.060ms (threads: 4) arena alloc=0B java alloc=129KB native alloc=81KB free=74KB
I/dex2oat ( 637): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/wm.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@wm.jar@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 637): Decided to run without swap.
I/dex2oat ( 637): dex2oat took 15.893ms (threads: 4) arena alloc=0B java alloc=3KB native alloc=75KB free=32KB
D/PackageManager( 474): No files in app dir /vendor/overlay
I/PackageManager( 474): /system/framework/framework-res.apk changed; collecting certs
E/StrictMode( 474): A resource was acquired at attached stack trace but never released. See java.io.Closeable for information on avoiding resource leaks.
E/StrictMode( 474): java.lang.Throwable: Explicit termination method ‘close’ not called
E/StrictMode( 474): at dalvik.system.CloseGuard.open(CloseGuard.java:184)
E/StrictMode( 474): at java.io.FileInputStream.(FileInputStream.java:78)
E/StrictMode( 474): at com.android.server.pm.PackageManagerService.getAppMultiWindowMode(PackageManagerService.java:14060)
E/StrictMode( 474): at com.android.server.pm.PackageManagerService.(PackageManagerService.java:1380)
E/StrictMode( 474): at com.android.server.pm.PackageManagerService.main(PackageManagerService.java:1283)
E/StrictMode( 474): at com.android.server.SystemServer.startBootstrapServices(SystemServer.java:353)
E/StrictMode( 474): at com.android.server.SystemServer.run(SystemServer.java:258)
E/StrictMode( 474): at com.android.server.SystemServer.main(SystemServer.java:174)
E/StrictMode( 474): at java.lang.reflect.Method.invoke(Native Method)
E/StrictMode( 474): at java.lang.reflect.Method.invoke(Method.java:372)
E/StrictMode( 474): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:963)
E/StrictMode( 474): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:758)
D/StrictMode( 474): No activity manager; failed to Dropbox violation.
E/StrictMode( 474): at com.android.server.pm.Settings.(Settings.java:289)
E/StrictMode( 474): at com.android.server.pm.Settings.(Settings.java:264)
E/StrictMode( 474): at com.android.server.pm.PackageManagerService.(PackageManagerService.java:1331)
I/PackageManager( 474): /system/priv-app/BackupRestoreConfirmation changed; collecting certs
I/PackageManager( 474): /system/priv-app/CalendarProvider changed; collecting certs
I/PackageManager( 474): New shared user android.uid.calendar: id=10001
W/PackageParser( 474): No actions in intent filter at /system/priv-app/Contacts/Contacts.apk Binary XML file line #356
I/PackageManager( 474): /system/priv-app/Contacts changed; collecting certs
I/PackageManager( 474): New shared user android.uid.shared: id=10002
I/PackageManager( 474): /system/priv-app/ContactsProvider changed; collecting certs
I/PackageManager( 474): /system/priv-app/DefaultContainerService changed; collecting certs
I/PackageManager( 474): /system/priv-app/DownloadProvider changed; collecting certs
I/PackageManager( 474): New shared user android.media: id=10004
I/PackageManager( 474): /system/priv-app/ExternalStorageProvider changed; collecting certs
I/PackageManager( 474): /system/priv-app/FusedLocation changed; collecting certs
I/PackageManager( 474): /system/priv-app/InputDevices changed; collecting certs
I/PackageManager( 474): /system/priv-app/ManagedProvisioning changed; collecting certs
I/PackageManager( 474): /system/priv-app/MediaProvider changed; collecting certs
I/PackageManager( 474): /system/priv-app/MmsService changed; collecting certs
I/PackageManager( 474): /system/priv-app/MusicFX changed; collecting certs
I/PackageManager( 474): /system/priv-app/OneTimeInitializer changed; collecting certs
I/PackageManager( 474): /system/priv-app/ProxyHandler changed; collecting certs
I/PackageManager( 474): /system/priv-app/Settings changed; collecting certs
I/PackageManager( 474): /system/priv-app/SettingsProvider changed; collecting certs
I/PackageManager( 474): /system/priv-app/SharedStorageBackup changed; collecting certs
I/PackageManager( 474): /system/priv-app/Shell changed; collecting certs
W/PackageParser( 474): No actions in intent filter at /system/priv-app/StressTest/StressTest.apk Binary XML file line #42
I/PackageManager( 474): /system/priv-app/StressTest changed; collecting certs
I/PackageManager( 474): /system/priv-app/SystemUI changed; collecting certs
I/PackageManager( 474): New shared user android.uid.systemui: id=10011
W/ResourceType( 474): Failure getting entry for 0x7f08026f (t=7 e=623) (error -75)
I/PackageManager( 474): /system/priv-app/TeleService changed; collecting certs
W/PackageParser( 474): Unknown element under : android at /system/priv-app/Telecom/Telecom.apk Binary XML file line #232
I/PackageManager( 474): /system/priv-app/Telecom changed; collecting certs
I/PackageManager( 474): /system/priv-app/TelephonyProvider changed; collecting certs
I/PackageManager( 474): /system/priv-app/VpnDialogs changed; collecting certs
I/PackageManager( 474): /system/priv-app/WallpaperCropper changed; collecting certs
I/PackageManager( 474): /system/app/BasicDreams changed; collecting certs
W/PackageParser( 474): No actions in intent filter at /system/app/Bluetooth/Bluetooth.apk Binary XML file line #209
I/PackageManager( 474): /system/app/Bluetooth changed; collecting certs
I/PackageManager( 474): /system/app/Browser changed; collecting certs
I/PackageManager( 474): /system/app/Calculator changed; collecting certs
I/PackageManager( 474): /system/app/Calendar changed; collecting certs
I/PackageManager( 474): /system/app/Camera2 changed; collecting certs
I/PackageManager( 474): /system/app/CaptivePortalLogin changed; collecting certs
I/PackageManager( 474): /system/app/CertInstaller changed; collecting certs
I/PackageManager( 474): /system/app/DeskClock changed; collecting certs
I/PackageManager( 474): /system/app/Development changed; collecting certs
I/PackageManager( 474): /system/app/DeviceTest changed; collecting certs
I/PackageManager( 474): /system/app/DocumentsUI changed; collecting certs
I/PackageManager( 474): /system/app/DownloadProviderUi changed; collecting certs
I/PackageManager( 474): /system/app/DualScreenApk changed; collecting certs
I/PackageManager( 474): /system/app/Exchange2 changed; collecting certs
I/PackageManager( 474): /system/app/Galaxy4 changed; collecting certs
W/PackageParser( 474): Unknown element under : permission at /system/app/Gallery2/Gallery2.apk Binary XML file line #243
W/PackageParser( 474): Unknown element under : permission at /system/app/Gallery2/Gallery2.apk Binary XML file line #246
I/PackageManager( 474): /system/app/Gallery2 changed; collecting certs
I/PackageManager( 474): /system/app/GoogleEmail changed; collecting certs
I/PackageManager( 474): /system/app/HTMLViewer changed; collecting certs
I/PackageManager( 474): /system/app/HoloSpiralWallpaper changed; collecting certs
I/PackageManager( 474): /system/app/KeyChain changed; collecting certs
I/PackageManager( 474): /system/app/LatinIME changed; collecting certs
I/PackageManager( 474): /system/app/Launcher3 changed; collecting certs
I/PackageManager( 474): /system/app/LiveWallpapers changed; collecting certs
I/PackageManager( 474): /system/app/LiveWallpapersPicker changed; collecting certs
I/PackageManager( 474): /system/app/MediaFloat changed; collecting certs
I/PackageManager( 474): /system/app/NoiseField changed; collecting certs
I/PackageManager( 474): /system/app/OpenWnn changed; collecting certs
I/PackageManager( 474): /system/app/PacProcessor changed; collecting certs
I/PackageManager( 474): /system/app/PackageInstaller changed; collecting certs
I/PackageManager( 474): /system/app/PhaseBeam changed; collecting certs
I/PackageManager( 474): /system/app/PhotoTable changed; collecting certs
I/PackageManager( 474): /system/app/PicoTts changed; collecting certs
I/PackageManager( 474): /system/app/PrintSpooler changed; collecting certs
I/PackageManager( 474): /system/app/Provision changed; collecting certs
I/PackageManager( 474): /system/app/QuickSearchBox changed; collecting certs
I/PackageManager( 474): /system/app/RKApkinstaller changed; collecting certs
W/ResourceType( 474): Failure getting entry for 0x7f02001c (t=1 e=28) (error -75)
I/PackageManager( 474): /system/app/RKExplorer changed; collecting certs
I/PackageManager( 474): /system/app/RKGameControlSettingV1.0.1 changed; collecting certs
I/PackageManager( 474): /system/app/RKMusic changed; collecting certs
I/PackageManager( 474): /system/app/RKUpdateService changed; collecting certs
I/PackageManager( 474): /system/app/RKVideoPlayer changed; collecting certs
I/PackageManager( 474): /system/app/SoundRecorder changed; collecting certs
I/PackageManager( 474): /system/app/SpeechRecorder changed; collecting certs
I/PackageManager( 474): /system/app/UserDictionaryProvider changed; collecting certs
I/PackageManager( 474): /system/app/VisualizationWallpapers changed; collecting certs
I/PackageManager( 474): /system/app/WAPPushManager changed; collecting certs
I/PackageManager( 474): /system/app/WinStartService changed; collecting certs
I/PackageManager( 474): /system/app/eHomeMediaCenter_box changed; collecting certs
I/PackageManager( 474): /system/app/hdmiin changed; collecting certs
I/PackageManager( 474): /system/app/webview changed; collecting certs
D/PackageManager( 474): No files in app dir /system/vendor/app
D/PackageManager( 474): No files in app dir /oem/app
D/PackageManager( 474): No files in app dir /system/vendor/3rd-app
D/PackageManager( 474): No files in app dir /data/app
D/PackageManager( 474): No files in app dir /data/app-private
W/PackageManager( 474): Package com.android.gallery3d desires unavailable shared library com.google.android.media.effects; ignoring!
I/PackageManager( 474): Adjusting ABI for : com.android.location.fused to armeabi-v7a
I/PackageManager( 474): Running dexopt on: /system/priv-app/FusedLocation/FusedLocation.apk pkg=com.android.location.fused isa=arm vmSafeMode=false
I/dex2oat ( 644): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/FusedLocation/FusedLocation.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@FusedLocation@FusedLocation.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 644): Decided to run without swap.
I/dex2oat ( 644): dex2oat took 18.911ms (threads: 4) arena alloc=0B java alloc=39KB native alloc=76KB free=31KB
I/PackageManager( 474): Adjusting ABI for : com.android.providers.settings to armeabi-v7a
I/PackageManager( 474): Running dexopt on: /system/priv-app/SettingsProvider/SettingsProvider.apk pkg=com.android.providers.settings isa=arm vmSafeMode=false
I/dex2oat ( 649): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/SettingsProvider/SettingsProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@SettingsProvider@SettingsProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 649): Decided to run without swap.
I/dex2oat ( 649): dex2oat took 42.078ms (threads: 4) arena alloc=0B java alloc=106KB native alloc=77KB free=322KB
I/PackageManager( 474): Adjusting ABI for : com.android.server.telecom to armeabi-v7a
I/PackageManager( 474): Running dexopt on: /system/priv-app/Telecom/Telecom.apk pkg=com.android.server.telecom isa=arm vmSafeMode=false
I/dex2oat ( 654): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/Telecom/Telecom.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@Telecom@Telecom.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 654): Decided to run without swap.
I/dex2oat ( 654): dex2oat took 110.900ms (threads: 4) arena alloc=0B java alloc=381KB native alloc=319KB free=60KB
I/PackageManager( 474): Adjusting ABI for : com.cghs.stresstest to armeabi-v7a
I/PackageManager( 474): Running dexopt on: /system/priv-app/StressTest/StressTest.apk pkg=com.cghs.stresstest isa=arm vmSafeMode=false
I/dex2oat ( 659): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/StressTest/StressTest.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@StressTest@StressTest.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 659): Decided to run without swap.
I/dex2oat ( 659): dex2oat took 170.189ms (threads: 4) arena alloc=0B java alloc=413KB native alloc=322KB free=45KB
I/PackageManager( 474): Adjusting ABI for : com.android.inputdevices to armeabi-v7a
I/PackageManager( 474): Running dexopt on: /system/priv-app/InputDevices/InputDevices.apk pkg=com.android.inputdevices isa=arm vmSafeMode=false
I/dex2oat ( 664): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/InputDevices/InputDevices.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@InputDevices@InputDevices.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 664): Decided to run without swap.
I/dex2oat ( 664): dex2oat took 20.597ms (threads: 4) arena alloc=0B java alloc=1984B native alloc=75KB free=32KB
I/PackageManager( 474): Adjusting ABI for : com.android.keychain to armeabi-v7a
I/PackageManager( 474): Running dexopt on: /system/app/KeyChain/KeyChain.apk pkg=com.android.keychain isa=arm vmSafeMode=false
I/dex2oat ( 669): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/KeyChain/KeyChain.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@KeyChain@KeyChain.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 669): Decided to run without swap.
I/dex2oat ( 669): dex2oat took 29.589ms (threads: 4) arena alloc=0B java alloc=79KB native alloc=77KB free=50KB
I/PackageManager( 474): Adjusting ABI for : com.android.rockchip to armeabi-v7a
I/PackageManager( 474): Running dexopt on: /system/app/RKExplorer/RKExplorer.apk pkg=com.android.rockchip isa=arm vmSafeMode=false
I/dex2oat ( 674): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/RKExplorer/RKExplorer.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@RKExplorer@RKExplorer.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 674): Decided to run without swap.
I/dex2oat ( 674): dex2oat took 230.305ms (threads: 4) arena alloc=0B java alloc=682KB native alloc=342KB free=105KB
I/PackageManager( 474): Adjusting ABI for : com.android.settings to armeabi-v7a
I/PackageManager( 474): Running dexopt on: /system/priv-app/Settings/Settings.apk pkg=com.android.settings isa=arm vmSafeMode=false
I/dex2oat ( 679): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/Settings/Settings.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@Settings@Settings.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 679): Decided to run without swap.
I/dex2oat ( 679): dex2oat took 1.123s (threads: 4) arena alloc=0B java alloc=4MB native alloc=504KB free=1059KB
I/PackageManager( 474): Adjusting ABI for : com.android.winstart to armeabi-v7a
I/PackageManager( 474): Running dexopt on: /system/app/WinStartService/WinStartService.apk pkg=com.android.winstart isa=arm vmSafeMode=false
I/dex2oat ( 684): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/WinStartService/WinStartService.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@WinStartService@WinStartService.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 684): Decided to run without swap.
I/dex2oat ( 684): dex2oat took 54.839ms (threads: 4) arena alloc=0B java alloc=178KB native alloc=81KB free=90KB
I/PackageManager( 474): Time to scan packages: 29.89 seconds
W/PackageManager( 474): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
W/PackageManager( 474): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
W/PackageManager( 474): Not granting permission android.permission.GLOBAL_SEARCH to package com.android.quicksearchbox (protectionLevel=18 flags=0x8be45)
W/PackageManager( 474): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.winstart
W/PackageManager( 474): Not granting permission android.permission.ACCESS_DOWNLOAD_MANAGER to package com.android.browser (protectionLevel=18 flags=0x9be45)
W/PackageManager( 474): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
W/PackageManager( 474): Not granting permission android.permission.BIND_WALLPAPER to package com.android.camera2 (protectionLevel=18 flags=0x58bc45)
W/PackageManager( 474): Not granting permission android.permission.BIND_APPWIDGET to package com.android.launcher3 (protectionLevel=18 flags=0x583e45)
W/PackageManager( 474): Unknown permission android.permission.READ_SETTINGS in package com.android.launcher3
W/PackageManager( 474): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.launcher3
W/PackageManager( 474): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.launcher3
W/PackageManager( 474): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
W/PackageManager( 474): Not granting permission android.permission.INSTALL_PACKAGES to package com.android.apkinstaller (protectionLevel=18 flags=0x8be45)
W/PackageManager( 474): Not granting permission android.permission.DELETE_PACKAGES to package com.android.apkinstaller (protectionLevel=18 flags=0x8be45)
W/PackageManager( 474): Unknown permission android.Manifest.permission.INJECT_EVENTS in package com.rockchip.devicetest
W/PackageManager( 474): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.onetimeinitializer
W/PackageManager( 474): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.onetimeinitializer
W/PackageManager( 474): Unknown permission android.permission.READ_MEDIA_STORAGE in package com.android.packageinstaller
W/PackageManager( 474): Not granting permission android.permission.DELETE_PACKAGES to package com.svox.pico (protectionLevel=18 flags=0x8be45)
W/PackageManager( 474): Unknown permission com.google.android.gallery3d.permission.PICASA_STORE in package com.android.dreams.phototable
W/PackageManager( 474): Unknown permission android.permission.RECORD_VIDEO in package teaonly.rk.droidipcam
W/PackageManager( 474): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
W/PackageManager( 474): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.settings
W/PackageManager( 474): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.settings
W/PackageManager( 474): Not granting permission android.permission.MOUNT_UNMOUNT_FILESYSTEMS to package com.rockchip.mediacenter (protectionLevel=18 flags=0x8be45)
W/PackageManager( 474): Not granting permission android.permission.DEVICE_POWER to package com.rockchip.mediacenter (protectionLevel=2 flags=0x8be45)
W/PackageManager( 474): Unknown permission com.android.email.permission.READ_ATTACHMENT in package com.rockchip.mediacenter
W/PackageManager( 474): Not granting permission android.permission.WRITE_MEDIA_STORAGE to package com.android.music (protectionLevel=18 flags=0x8be65)
W/PackageManager( 474): Not granting permission android.permission.DEVICE_POWER to package com.android.music (protectionLevel=2 flags=0x8be65)
W/PackageManager( 474): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x48be45)
W/PackageManager( 474): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.systemui
W/PackageManager( 474): Unknown permission com.android.email.permission.READ_ATTACHMENT in package com.android.exchange
W/PackageManager( 474): Unknown permission com.android.email.permission.ACCESS_PROVIDER in package com.android.exchange
W/PackageManager( 474): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
W/PackageManager( 474): Unknown permission android.permission.MMS_SEND_OUTBOX_MSG in package com.android.bluetooth
W/PackageManager( 474): Unknown permission com.google.android.googleapps.permission.ACCESS_GOOGLE_PASSWORD in package com.android.development
W/PackageManager( 474): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.development
W/PackageManager( 474): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.ALL_SERVICES in package com.android.development
W/PackageManager( 474): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.YouTubeUser in package com.android.development
W/PackageManager( 474): Unknown permission rockchip.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
W/PackageManager( 474): Unknown permission android.permission.RAISED_THREAD_PRIORITY in package android.rk.RockVideoPlayer
W/PackageManager( 474): Unknown permission android.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
W/PackageManager( 474): Unknown permission archos.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
I/art ( 474): Explicit concurrent mark sweep GC freed 307(50KB) AllocSpace objects, 2(32KB) LOS objects, 33% free, 2MB/3MB, paused 284us total 16.095ms
I/SystemServer( 474): User Service
I/lowmemorykiller( 161): ActivityManager connected
I/SystemServiceManager( 474): Starting com.android.server.lights.LightsService
I/Lights ( 474): >>> Enter light_device_open:backlight
I/Lights ( 474): >>> Enter light_device_open:keyboard
I/Lights ( 474): >>> Enter light_device_open:buttons
I/Lights ( 474): >>> Enter light_device_open:battery
I/Lights ( 474): >>> Enter light_device_open:notifications
I/Lights ( 474): >>> Enter light_device_open:attention
I/Lights ( 474): >>> Enter light_device_open:bluetooth
I/Lights ( 474): >>> undefine light id
I/Lights ( 474): >>> Enter light_device_open:wifi
I/SystemServiceManager( 474): Starting com.android.server.BatteryService
I/BatteryStatsImpl( 474): Resetting battery stats: level=100 status=4 dischargeLevel=100 lowAmount=0 highAmount=0
I/SystemServiceManager( 474): Starting com.android.server.usage.UsageStatsService
I/UsageStatsDatabase( 474): Upgrading from version 0 to 2
I/UsageStatsDatabase( 474): Deleting all usage stats files
I/UsageStatsService( 474): User[0] Rollover scheduled @ 2011-01-02 00:00:00(1293926400000)
I/SystemServiceManager( 474): Starting com.android.server.webkit.WebViewUpdateService
I/SystemServer( 474): Reading configuration…
I/SystemServer( 474): Scheduling Policy
I/SystemServiceManager( 474): Starting com.android.server.telecom.TelecomLoaderService
I/SystemServer( 474): Telephony Registry
I/SystemServer( 474): Entropy Mixer
W/EntropyMixer( 474): No existing entropy file – first boot?
I/EntropyMixer( 474): Writing entropy…
I/SystemServer( 474): Account Manager
I/SystemServer( 474): Start SimStateChange Service
W/ActivityManagerService( 474): Unable to start service Intent { cmp=com.android.contacts/.SimStateChangedService } U=0: not found
I/SystemServer( 474): Content Manager
I/SystemServer( 474): System Content Providers
I/SyncManager( 474): No initial accounts
I/SyncManager( 474): No initial status
I/SyncManager( 474): No initial statistics
D/SettingsProvider( 474): Generated and saved new ANDROID_ID [8b504081fa3c7e9f] for user 0
I/SystemServer( 474): Vibrator Service
I/SystemServer( 474): Consumer IR Service
E/ConsumerIrService( 474): Can’t open consumer IR HW Module, error: -2
I/SystemServiceManager( 474): Starting com.android.server.AlarmManagerService
D/AlarmManager( 474): Failed while trying resolve alarm filter file, not exists
I/SystemServer( 474): Init Watchdog
I/SystemServer( 474): Input Manager
I/InputManager( 474): Initializing input manager, mUseDevInputEventForAudioJack=true
I/SystemServer( 474): Window Manager
I/WindowManagerService( 474): No existing display settings /data/system/display_settings.xml; starting empty
D/PermissionCache( 165): checking android.permission.ACCESS_SURFACE_FLINGER for uid=1000 => granted (444 us)
D/DisplayManager( 474): getDisplayInfo: displayId=1, info=DisplayInfo{“HDMI Screen”, uniqueId “local:1”, app 1366 x 768, real 1366 x 768, largest app 1366 x 768, smallest app 1366 x 768, 61724.586 fps, supportedRefreshRates [61724.586], rotation 0, density 227 (227.0 x 227.0) dpi, layerStack 1, appVsyncOff 0, presDeadline 1016201, type HDMI, state UNKNOWN, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS, FLAG_PRESENTATION}
D/DisplayManager( 474): onDisplayEvent: displayId=0, event=2
D/DisplayManager( 474): onDisplayEvent: displayId=1, event=2
I/InputManager( 474): Starting input manager
D/EventHub( 474): No input device configuration file found for device ‘PixArt USB Optical Mouse’.
I/EventHub( 474): New device: id=1, fd=87, path=‘/dev/input/event4’, name=‘PixArt USB Optical Mouse’, classes=0x80000008, configuration=‘’, keyLayout=‘’, keyCharacterMap=‘’, builtinKeyboard=false, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
D/EventHub( 474): No input device configuration file found for device ‘USB 2.0 Camera’.
I/SystemServer( 474): Bluetooth Manager Service
W/EventHub( 474): Unable to disable kernel key repeat for /dev/input/event3: Function not implemented
I/EventHub( 474): New device: id=2, fd=88, path=‘/dev/input/event3’, name=‘USB 2.0 Camera’, classes=0x80000401, configuration=‘’, keyLayout=‘/system/usr/keylayout/Generic.kl’, keyCharacterMap=‘/system/usr/keychars/Generic.kcm’, builtinKeyboard=false, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
D/EventHub( 474): No input device configuration file found for device ‘RK_ES8323 Headphone Jack’.
I/EventHub( 474): New device: id=3, fd=89, path=‘/dev/input/event2’, name=‘RK_ES8323 Headphone Jack’, classes=0x80, configuration=‘’, keyLayout=‘’, keyCharacterMap=‘’, builtinKeyboard=false, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
D/EventHub( 474): No input device configuration file found for device ‘rk29-keypad’.
D/BluetoothManagerService( 474): Loading stored name and address
W/EventHub( 474): Unable to disable kernel key repeat for /dev/input/event1: Function not implemented
I/EventHub( 474): New device: id=4, fd=90, path=‘/dev/input/event1’, name=‘rk29-keypad’, classes=0x401, configuration=‘’, keyLayout=‘/system/usr/keylayout/rk29-keypad.kl’, keyCharacterMap=‘/system/usr/keychars/Generic.kcm’, builtinKeyboard=true, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
D/BluetoothManagerService( 474): Stored bluetooth Name=null,Address=null
D/EventHub( 474): No input device configuration file found for device ‘ff680000.pwm’.
I/SystemServer( 474): Input Method Service
W/EventHub( 474): Unable to disable kernel key repeat for /dev/input/event0: Function not implemented
I/EventHub( 474): New device: id=5, fd=91, path=‘/dev/input/event0’, name=‘ff680000.pwm’, classes=0x421, configuration=‘’, keyLayout=‘/system/usr/keylayout/ff680000_pwm.kl’, keyCharacterMap=‘/system/usr/keychars/Generic.kcm’, builtinKeyboard=false, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
I/InputReader( 474): Device added: id=-1, name=‘Virtual’, sources=0x00000301
I/InputReader( 474): Device added: id=5, name=‘ff680000.pwm’, sources=0x00002303
I/InputReader( 474): Device added: id=0, name=‘rk29-keypad’, sources=0x00002103
I/InputReader( 474): Device added: id=3, name=‘RK_ES8323 Headphone Jack’, sources=0x80000000
I/InputReader( 474): Device added: id=2, name=‘USB 2.0 Camera’, sources=0x00002103
I/InputReader( 474): Device added: id=1, name=‘PixArt USB Optical Mouse’, sources=0x00002002
W/InputMethodManagerService( 474): No IME selected. Choose the most applicable IME.
I/InputMethodManagerService( 474): Default found, using com.android.inputmethod.latin/.LatinIME
I/SystemServer( 474): Accessibility Manager
I/ActivityManagerService( 474): Config changes=80009df8 {1.15 multiwindowflag=DISABLE dualscreenflag=DISABLE ?mcc?mnc en_US ?layoutDir sw720dp w1280dp h720dp 160dpi xlrg long land ?uimode ?night -touch -keyb/h/h dpad/v s.2}
I/InputReader( 474): Reconfiguring input devices. changes=0x00000004
I/SurfaceFlinger( 165): 511,[1366,768]
D/ActivityManagerService( 474): ---------clean the all task
D/ActivityManagerService( 474): ---------Move Home To Top & CLEAN THE ALL TASK
I/ActivityManagerService( 474): Config changes=500 {1.15 multiwindowflag=DISABLE dualscreenflag=DISABLE ?mcc?mnc en_US ?layoutDir sw720dp w1280dp h647dp 160dpi lrg long land ?uimode ?night -touch -keyb/h/h dpad/v s.3}
D/DisplayManager( 474): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1280, smallest app 720 x 720, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state UNKNOWN, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/SystemServer( 474): Mount Service
D/MountService( 474): got storage path: /storage/sdcard0 description: SD card primary: true removable: true emulated: true mtpReserve: 100 allowMassStorage: false maxFileSize: 0
D/MountService( 474): —getMaxSupportedUsers,we has UMS,ignore emulated storage—
D/MountService( 474): got storage path: /mnt/internal_sd description: NAND FLASH primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService( 474): —getMaxSupportedUsers,we has UMS,force NAND FLASH to primary storage—
D/MountService( 474): addVolumeLocked() StorageVolume:
D/MountService( 474): mStorageId=0 mPath=/mnt/internal_sd mDescriptionId=17041224 mPrimary=true
D/MountService( 474): mRemovable=true mEmulated=false mMtpReserveSpace=100
D/MountService( 474): mAllowMassStorage=true mMaxFileSize=0 mOwner=null mUuid=null
D/MountService( 474): mUserLabel=null mState=null
D/MountService( 474): got storage path: /mnt/external_sd description: SD card primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService( 474): mStorageId=0 mPath=/mnt/external_sd mDescriptionId=17040811 mPrimary=false
D/MountService( 474): got storage path: /mnt/usb_storage/USB_DISK0 description: USB storage 0 primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService( 474): mStorageId=0 mPath=/mnt/usb_storage/USB_DISK0 mDescriptionId=17041128
D/MountService( 474): mPrimary=false mRemovable=true mEmulated=false mMtpReserveSpace=100
D/MountService( 474): got storage path: /mnt/usb_storage/USB_DISK1 description: USB storage 1 primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService( 474): mStorageId=0 mPath=/mnt/usb_storage/USB_DISK1 mDescriptionId=17041129
D/MountService( 474): got storage path: /mnt/usb_storage/USB_DISK2 description: USB storage 2 primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService( 474): mStorageId=0 mPath=/mnt/usb_storage/USB_DISK2 mDescriptionId=17041130
D/MountService( 474): got storage path: /mnt/usb_storage/USB_DISK3 description: USB storage 3 primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService( 474): mStorageId=0 mPath=/mnt/usb_storage/USB_DISK3 mDescriptionId=17041131
D/MountService( 474): got storage path: /mnt/usb_storage/USB_DISK4 description: USB storage 4 primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService( 474): mStorageId=0 mPath=/mnt/usb_storage/USB_DISK4 mDescriptionId=17041132
D/MountService( 474): got storage path: /mnt/usb_storage/USB_DISK5 description: USB storage 5 primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService( 474): mStorageId=0 mPath=/mnt/usb_storage/USB_DISK5 mDescriptionId=17041133
W/PackageManager( 474): No disk maintenance in 1293886325008; running immediately
D/VoldCmdListener( 164): volume list broadcast
D/Vold ( 164): listVolumes :internal_sd /mnt/internal_sd 1
D/Vold ( 164): listVolumes :external_sd /mnt/external_sd 0
D/Vold ( 164): listVolumes :usb_storage /mnt/usb_storage/USB_DISK0 0
D/Vold ( 164): listVolumes :usb_storage /mnt/usb_storage/USB_DISK1 0
D/Vold ( 164): listVolumes :usb_storage /mnt/usb_storage/USB_DISK2 0
D/Vold ( 164): listVolumes :usb_storage /mnt/usb_storage/USB_DISK3 0
D/Vold ( 164): listVolumes :usb_storage /mnt/usb_storage/USB_DISK4 0
D/Vold ( 164): listVolumes :usb_storage /mnt/usb_storage/USB_DISK5 0
I/SystemServer( 474): LockSettingsService
I/SystemServiceManager( 474): Starting com.android.server.devicepolicy.DevicePolicyManagerService$Lifecycle
I/MountService( 474): /mnt/internal_sdUpdating valid state unmounted st 1
D/MountService( 474): volume state changed for /mnt/internal_sd (mounted → unmounted)
I/PackageManager( 474): Updating external media status from unmounted to unmounted
I/MountService( 474): /mnt/external_sdUpdating valid state removed st 0
D/MountService( 474): volume state changed for /mnt/external_sd (unmounted → removed)
I/MountService( 474): /mnt/usb_storage/USB_DISK0Updating valid state removed st 0
D/MountService( 474): volume state changed for /mnt/usb_storage/USB_DISK0 (unmounted → removed)
I/MountService( 474): /mnt/usb_storage/USB_DISK1Updating valid state removed st 0
D/MountService( 474): volume state changed for /mnt/usb_storage/USB_DISK1 (unmounted → removed)
I/MountService( 474): /mnt/usb_storage/USB_DISK2Updating valid state removed st 0
D/MountService( 474): volume state changed for /mnt/usb_storage/USB_DISK2 (unmounted → removed)
I/MountService( 474): /mnt/usb_storage/USB_DISK3Updating valid state removed st 0
D/MountService( 474): volume state changed for /mnt/usb_storage/USB_DISK3 (unmounted → removed)
I/MountService( 474): /mnt/usb_storage/USB_DISK4Updating valid state removed st 0
D/MountService( 474): volume state changed for /mnt/usb_storage/USB_DISK4 (unmounted → removed)
I/MountService( 474): /mnt/usb_storage/USB_DISK5Updating valid state removed st 0
D/MountService( 474): volume state changed for /mnt/usb_storage/USB_DISK5 (unmounted → removed)
I/MountService( 474): Running fstrim idle maintenance
I/SystemServer( 474): Status Bar
D/VoldCmdListener( 164): fstrim dotrim
I/fstrim ( 164): Starting fstrim work…
I/fstrim ( 164): Invoking FITRIM ioctl on /cache
I/SystemServer( 474): Clipboard Service
D/VoldCmdListener( 164): cryptfs getfield SystemLocale
I/SystemServer( 474): NetworkManagement Service
I/fstrim ( 164): Trimmed 127586304 bytes on /cache
I/fstrim ( 164): Invoking FITRIM ioctl on /metadata
W/MountService( 474): getSecureContainerList() called when storage not mounted
I/SystemServer( 474): Text Service Manager Service
D/VoldCmdListener( 164): asec list
I/PackageManager( 474): No secure containers found
I/fstrim ( 164): Trimmed 12263424 bytes on /metadata
I/fstrim ( 164): Invoking FITRIM ioctl on /data
I/fstrim ( 164): Trimmed 989003776 bytes on /data
I/fstrim ( 164): Trimmed 0 bytes on /data
E/fstrim ( 164): Cannot stat mount point none
I/fstrim ( 164): Finished fstrim work.
I/SystemServer( 474): Network Score Service
I/SystemServer( 474): NetworkStats Service
I/SystemServer( 474): NetworkPolicy Service
I/SystemServiceManager( 474): Starting com.android.server.wifi.p2p.WifiP2pService
I/WifiP2pService( 474): Registering wifip2p
I/SystemServiceManager( 474): Starting com.android.server.wifi.WifiService
E/WifiConfigStore( 474): associatedPartialScanPeriodMilli set to 20000
D/WifiController( 474): isAirplaneModeOn = false, isWifiEnabled = false, isScanningAvailable = false
I/WifiService( 474): Registering wifi
I/SystemServiceManager( 474): Starting com.android.server.wifi.WifiScanningService
I/WifiScanningService( 474): Creating wifiscanner
I/WifiScanningService( 474): Starting wifiscanner
I/SystemServiceManager( 474): Starting com.android.server.wifi.RttService
I/RttService( 474): Creating rttmanager
I/RttService( 474): Starting rttmanager
I/SystemServiceManager( 474): Starting com.android.server.ethernet.EthernetService
I/EthernetServiceImpl( 474): Creating EthernetConfigStore
E/IpConfigStore( 474): Error parsing configuration: java.io.FileNotFoundException: /data/misc/ethernet/ipconfig.txt: open failed: ENOENT (No such file or directory)
W/EthernetConfigStore( 474): No Ethernet configuration found. Using default.
I/EthernetServiceImpl( 474): Read stored IP configuration: IP assignment: DHCP
I/EthernetServiceImpl( 474): Proxy settings: NONE
I/EthernetService( 474): Registering service ethernet
I/SystemServer( 474): PppoeService
I/SystemServiceManager( 474): Starting com.android.server.pppoe.PppoeService
I/PppoeServiceImpl( 474): Creating PppoeServiceImpl
I/PppoeService( 474): Registering service pppoe
I/SystemServer( 474): Connectivity Service
D/ConnectivityService( 474): ConnectivityService starting up
D/ConnectivityService( 474): wifiOnly=false
E/ConnectivityService( 474): Ignoring protectedNetwork 14
I/SystemServer( 474): Network Service Discovery Service
D/NsdService( 474): Network service discovery enabled true
I/SystemServer( 474): UpdateLock Service
I/SystemServiceManager( 474): Starting com.android.server.notification.NotificationManagerService
D/ZenLog ( 474): set_zen_mode: off,setting
I/SystemServiceManager( 474): Starting com.android.server.storage.DeviceStorageMonitorService
I/SystemServer( 474): Location Manager
I/SystemServer( 474): Country Detector
I/SystemServer( 474): Search Service
I/SystemServer( 474): DropBox Service
I/SystemServer( 474): Wallpaper Service
W/WallpaperManagerService( 474): no current wallpaper – first boot?
I/SystemServer( 474): Audio Service
W/TelecomManager( 474): Telecom Service not found.
D/RkWifiCtrl( 474): check_wifi_preload: Wifi driver is preload when bootup.
E/WifiStateMachine( 474): setWifiState: disabled
D/WifiApConfigStore( 474): transitionTo: destState=ActiveState
V/AudioService( 474): monitoring device orientation
D/WifiApConfigStore( 474): transitionTo: destState=InactiveState
I/SystemServiceManager( 474): Starting com.android.server.DockObserver
W/DockObserver( 474): This kernel does not have dock station support
I/SystemServer( 474): Wired Accessory Manager
I/SystemServiceManager( 474): Starting com.android.server.usb.UsbService$Lifecycle
I/SystemServer( 474): Serial Service
I/SystemServiceManager( 474): Starting com.android.server.twilight.TwilightService
I/SystemServiceManager( 474): Starting com.android.server.UiModeManagerService
I/SystemServiceManager( 474): Starting com.android.server.job.JobSchedulerService
I/SystemServiceManager( 474): Starting com.android.server.backup.BackupManagerService$Lifecycle
I/SystemServiceManager( 474): Starting com.android.server.appwidget.AppWidgetService
I/SystemServiceManager( 474): Starting com.android.server.voiceinteraction.VoiceInteractionManagerService
W/SoundTriggerHelper( 474): listModules status=0, # of modules=0
I/SystemServer( 474): DiskStats Service
I/SystemServer( 474): SamplingProfiler Service
I/SystemServer( 474): NetworkTimeUpdateService
I/SystemServer( 474): CommonTimeManagementService
I/SystemServer( 474): CertBlacklister
I/SystemServiceManager( 474): Starting com.android.server.dreams.DreamManagerService
I/SystemServer( 474): Assets Atlas Service
D/AssetAtlas( 474): Computing best atlas configuration…
I/SystemServiceManager( 474): Starting com.android.server.print.PrintManagerService
D/AssetAtlas( 474): Running Atlas Worker #1
D/AssetAtlas( 474): Running Atlas Worker #2
D/AssetAtlas( 474): Running Atlas Worker #3
D/AssetAtlas( 474): Running Atlas Worker #4
I/SystemServiceManager( 474): Starting com.android.server.restrictions.RestrictionsManagerService
I/SystemServiceManager( 474): Starting com.android.server.media.MediaSessionService
D/AssetAtlas( 474): Found best atlas configuration in 0.01s
D/AssetAtlas( 474): Loaded configuration: SliceMinArea (768x768) flags=0x2 count=9
I/SystemServiceManager( 474): Starting com.android.server.hdmi.HdmiControlService
W/gralloc ( 165): Debugmem The fd=48, in vmalloc !!! Ishwc=0
E/HdmiCecControllerJni( 474): Error acquiring hardware module: -2
I/HdmiControlService( 474): Device does not support HDMI-CEC.
I/SystemServer( 474): Media Router Service
I/mali_so ( 474): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 780; [Func] : base_context_deal_with_version_affairs_rk_ext;
I/mali_so ( 474): arm_release_ver of this mali_so is ‘r6p0-02rel0’, rk_so_ver is ‘11@0’, built at ‘16:20:19’ for 3288w, on ‘Aug 1 2016’.
I/mali_so ( 474): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 807; [Func] : base_context_deal_with_version_affairs_rk_ext;
I/mali_so ( 474): mali_ver_property has been set to ‘r6p0-02rel0-13-11@0’, to return.
I/SystemServer( 474): DisplayDeviceManagementService Service
D/DisplayDeviceManagementService( 474): DisplayDeviceManagementService start
I/SystemServiceManager( 474): Starting com.android.server.trust.TrustManagerService
I/SystemServiceManager( 474): Starting com.android.server.fingerprint.FingerprintService
V/Fingerprint-JNI( 474): nativeInit()
V/Fingerprint-JNI( 474): nativeOpenHal()
E/Fingerprint-JNI( 474): Can’t open fingerprint HW Module, error: -2
I/SystemServer( 474): BackgroundDexOptService
D/AssetAtlas( 474): Rendered atlas in 14.77ms (0.58+14.19ms)
I/SystemServiceManager( 474): Starting com.android.server.pm.LauncherAppsService
I/SystemServiceManager( 474): Starting com.android.server.media.projection.MediaProjectionManagerService
I/WindowManagerService( 474): SAFE MODE not enabled
I/SystemServiceManager( 474): Starting com.android.server.MmsServiceBroker
E/SQLiteLog( 474): (1) no such table: locksettings
I/LockSettingsService( 474): Migrated lock settings to new location
I/LockSettingsService( 474): Migrated per-user lock settings to new location
E/LockSettingsStorage( 474): Cannot read file java.io.FileNotFoundException: /data/system/password.key: open failed: ENOENT (No such file or directory)
E/LockSettingsStorage( 474): Cannot read file java.io.FileNotFoundException: /data/system/gesture.key: open failed: ENOENT (No such file or directory)
I/SystemServiceManager( 474): Starting phase 480
I/SystemServiceManager( 474): Starting phase 500
I/WifiService( 474): WifiService starting up with Wi-Fi disabled
D/WifiService( 474): New client listening to asynchronous messages
I/WifiScanningService( 474): Registering wifiscanner
D/WifiScanningService( 474): New client, channel: null messenger: null
D/WifiScanningService( 474): DefaultState
I/RttService( 474): Registering rttmanager
D/WifiChangeStateMachine( 474): Entering IdleState
I/EthernetServiceImpl( 474): Starting Ethernet service
D/Ethernet( 474): Registering NetworkFactory
D/ConnectivityService( 474): Got NetworkFactory Messenger for Ethernet
D/Ethernet( 474): got request NetworkRequest [ id=1, legacyType=-1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
D/EthernetNetworkFactory( 474): Started tracking interface eth0
D/CommandListener( 167): Setting iface cfg
D/CommandListener( 167): Trying to bring up eth0
D/EthernetNetworkFactory( 474): updateInterface: eth0 link up
I/PppoeServiceImpl( 474): Starting PPPOE service
D/PppoeManager( 474): PppoeManager() : start ‘pppoe handle thread’.
I/EthernetNetworkFactory( 474): dhcpThread(+eth0): mNetworkInfo=[type: Ethernet, state: UNKNOWN/IDLE, reason: (unspecified), extra: 06:a8:f7:ad:b0:91, roaming: false, failover: false, isAvailable: true, isConnectedToProvisioningNetwork: false]
D/PPPOE ( 474): Registering NetworkFactory
D/ConnectivityService( 474): Got NetworkFactory Messenger for PPPOE
D/PPPOE ( 474): got request NetworkRequest [ id=1, legacyType=-1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
I/ActivityManagerService( 474): Config changes=200 {1.15 multiwindowflag=DISABLE dualscreenflag=DISABLE ?mcc?mnc en_US ?layoutDir sw720dp w1280dp h647dp 160dpi lrg long land -touch -keyb/h/h dpad/v s.4}
I/dhcpcd ( 743): version 5.5.6 starting
E/dhcpcd ( 743): get_duid: Read-only file system
I/SELinux ( 474): SELinux: Loaded file_contexts from /file_contexts
V/BackupManagerService( 474): No ancestral data
D/BackupManagerService( 474): Now staging backup of com.android.browser
I/dhcpcd ( 743): eth0: broadcasting for a lease
D/BackupManagerService( 474): Now staging backup of android
D/BackupManagerService( 474): Now staging backup of com.android.calendar
D/BackupManagerService( 474): Now staging backup of com.android.providers.settings
D/BackupManagerService( 474): Now staging backup of com.android.sharedstoragebackup
D/BackupManagerService( 474): Now staging backup of com.android.providers.userdictionary
V/BackupManagerService( 474): Starting with transport android/com.android.internal.backup.LocalTransport
V/BackupManagerService( 474): Found transports: 1
I/BackupManagerService( 474): Binding to transport host ComponentInfo{android/com.android.internal.backup.LocalTransportService}
D/WindowManagerService( 474): Window{3da7a62f u0 KeyguardScrim} ==========setInputFocusLw ========== =======
D/DisplayManager( 474): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state UNKNOWN, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/ActivityManagerService( 474): Sending system update to ComponentInfo{com.android.providers.calendar/com.android.providers.calendar.CalendarUpgradeReceiver} for user 0
I/ActivityManagerService( 474): Sending system update to ComponentInfo{com.android.providers.contacts/com.android.providers.contacts.ContactsUpgradeReceiver} for user 0
I/ActivityManagerService( 474): Sending system update to ComponentInfo{com.android.managedprovisioning/com.android.managedprovisioning.PreBootListener} for user 0
I/ActivityManagerService( 474): Sending system update to ComponentInfo{com.android.providers.media/com.android.providers.media.MediaUpgradeReceiver} for user 0
I/ActivityManagerService( 474): Sending system update to ComponentInfo{com.android.settings/com.android.settings.ManagedProfileSetup} for user 0
I/SystemServer( 474): Enabled StrictMode for system server main thread.
I/Zygote ( 474): Process: zygote socket opened, supported ABIS: armeabi-v7a,armeabi
E/Lights ( 474): write_int failed to open sys/class/leds/rk29_key_led/brightness
I/Lights ( 474): >>> Enter set_keyboard_light
D/DisplayPowerController( 474): button lights toggle
D/DisplayPowerController( 474): send timeout msg after 1500
D/SurfaceFlinger( 165): Set power mode=2, type=0 flinger=0xb74a3550
D/SurfaceFlinger( 165): Screen type=0 is already mode=2
D/SurfaceFlinger( 165): Set power mode=2, type=1 flinger=0xb74a3550
I/hwcomposer( 165): hwc_blank dpy[1],blank[0]
E/Lights ( 474): write_int failed to open /sys/class/backlight/rk28_bl/brightness
I/ActivityManagerService( 474): Start proc 753:com.android.providers.calendar/u0a1 for broadcast com.android.providers.calendar/.CalendarUpgradeReceiver
V/ActivityStackSupervisor( 474): Display changed displayId=0
V/ActivityStackSupervisor( 474): Display changed displayId=1
D/WifiScanningService( 474): SCAN_AVAILABLE : 1
D/RttService( 474): SCAN_AVAILABLE : 1
D/WifiScanningService( 474): DefaultState got{ when=0 what=160007 target=com.android.internal.util.StateMachine$SmHandler }
D/RttService( 474): DefaultState got{ when=0 what=160513 target=com.android.internal.util.StateMachine$SmHandler }
W/gralloc ( 165): Debugmem The fd=40, in vmalloc !!! Ishwc=0
I/DisplayManagerService( 474): Display device changed: DisplayDeviceInfo{“Built-in Screen”: uniqueId=“local:0”, 1280 x 720, 69.096 fps, supportedRefreshRates [69.096], density 160, 160.15764 x 160.42105 dpi, appVsyncOff 0, presDeadline 15472617, touch INTERNAL, rotation 0, type BUILT_IN, state ON, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/DisplayManagerService( 474): Display device changed: DisplayDeviceInfo{“HDMI Screen”: uniqueId=“local:1”, 1366 x 768, 61724.586 fps, supportedRefreshRates [61724.586], density 227, 227.0 x 227.0 dpi, appVsyncOff 0, presDeadline 1016201, touch EXTERNAL, rotation 0, type HDMI, state ON, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS, FLAG_PRESENTATION}
D/DisplayManager( 474): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/DisplayManager( 474): getDisplayInfo: displayId=1, info=DisplayInfo{“HDMI Screen”, uniqueId “local:1”, app 1366 x 768, real 1366 x 768, largest app 1366 x 768, smallest app 1366 x 768, 61724.586 fps, supportedRefreshRates [61724.586], rotation 0, density 227 (227.0 x 227.0) dpi, layerStack 1, appVsyncOff 0, presDeadline 1016201, type HDMI, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS, FLAG_PRESENTATION}
D/ViewRootImpl( 474): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 sim=#10 ty=2029 fl=#1110900 pfl=0x1 fmt=-3 or=5 surfaceInsets=Rect(0, 0 - 0, 0)packageName=androidtoken=null}
D/WifiDisplayAdapter( 474): getWifiDisplayStatusLocked: result=WifiDisplayStatus{featureState=1, scanState=0, activeDisplayState=0, activeDisplay=null, displays=, sessionInfo=WifiDisplaySessionInfo:
D/WifiDisplayAdapter( 474): Client/Owner: Client
D/WifiDisplayAdapter( 474): GroupId:
D/WifiDisplayAdapter( 474): Passphrase:
D/WifiDisplayAdapter( 474): SessionId: 0
D/WifiDisplayAdapter( 474): IP Address: }
D/ViewRootImpl( 474): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 sim=#10 ty=2029 fl=#1110900 pfl=0x1 fmt=-3 or=5 vsysui=0x3610000 surfaceInsets=Rect(0, 0 - 0, 0)packageName=androidtoken=null}
I/ActivityManagerService( 474): Launching preboot mode app: ProcessRecord{14980d70 753:com.android.providers.calendar/u0a1}
I/PackageManager( 474): Running dexopt on: /system/priv-app/CalendarProvider/CalendarProvider.apk pkg=com.android.providers.calendar isa=arm vmSafeMode=false
V/BackupManagerService( 474): Connected to transport ComponentInfo{android/com.android.internal.backup.LocalTransportService}
V/BackupManagerService( 474): Registering transport android/com.android.internal.backup.LocalTransportService::android/com.android.internal.backup.LocalTransport = android.app.backup.BackupTransport$TransportImpl@2d7608e9
W/gralloc ( 165): Debugmem The fd=47, in vmalloc !!! Ishwc=0
I/dex2oat ( 772): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/CalendarProvider/CalendarProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@CalendarProvider@CalendarProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 772): Decided to run without swap.
I/dex2oat ( 772): dex2oat took 331.201ms (threads: 4) arena alloc=0B java alloc=429KB native alloc=327KB free=180KB
D/DisplayManager( 753): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
W/ResourcesManager( 753): Asset path ‘/system/framework/android.test.runner.jar’ does not exist or contains no resources.
I/ActivityManagerService( 474): Start proc 779:android.process.acore/u0a2 for broadcast com.android.providers.contacts/.ContactsUpgradeReceiver
I/ActivityManagerService( 474): Launching preboot mode app: ProcessRecord{1f2ef96e 779:android.process.acore/u0a2}
I/PackageManager( 474): Running dexopt on: /system/priv-app/ContactsProvider/ContactsProvider.apk pkg=com.android.providers.contacts isa=arm vmSafeMode=false
I/dex2oat ( 798): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/ContactsProvider/ContactsProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@ContactsProvider@ContactsProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 798): Decided to run without swap.
I/dex2oat ( 798): dex2oat took 478.855ms (threads: 4) arena alloc=0B java alloc=735KB native alloc=344KB free=535KB
D/DisplayManager( 779): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/ContactsUpgradeReceiver( 779): Creating or opening contacts database
I/ContactsDatabaseHelper( 779): Bootstrapping database version: 910
D/DisplayPowerController( 474): MSG_BUTTON_LIGHTS_TIME_OUT
D/EthernetNetworkFactory( 474): updateInterface: eth0 link down
I/ContactsProviderV1( 779): Bootstrapping database legacy support
I/ContactsProvider( 779): Locale has changed from null to en-US
I/ContactsDatabaseHelper( 779): Switching to locale en-US (ICU v53.1.0.1)
I/ContactsDatabaseHelper( 779): Locale change completed in 223ms
I/ContactsDatabaseHelper( 779): Locale change completed in 224ms
I/ActivityManagerService( 474): Start proc 805:com.android.managedprovisioning/u0a6 for broadcast com.android.managedprovisioning/.PreBootListener
I/ActivityManagerService( 474): Launching preboot mode app: ProcessRecord{3013e80f 805:com.android.managedprovisioning/u0a6}
I/PackageManager( 474): Running dexopt on: /system/priv-app/ManagedProvisioning/ManagedProvisioning.apk pkg=com.android.managedprovisioning isa=arm vmSafeMode=false
I/dex2oat ( 823): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/ManagedProvisioning/ManagedProvisioning.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@ManagedProvisioning@ManagedProvisioning.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 823): Decided to run without swap.
I/dex2oat ( 823): dex2oat took 236.665ms (threads: 4) arena alloc=0B java alloc=547KB native alloc=326KB free=69KB
D/DisplayManager( 805): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/ActivityManagerService( 474): Start proc 828:android.process.media/u0a4 for broadcast com.android.providers.media/.MediaUpgradeReceiver
I/PackageManager( 474): Running dexopt on: /system/priv-app/MediaProvider/MediaProvider.apk pkg=com.android.providers.media isa=arm vmSafeMode=false
I/dex2oat ( 846): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/MediaProvider/MediaProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@MediaProvider@MediaProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 846): Decided to run without swap.
I/dex2oat ( 846): dex2oat took 70.921ms (threads: 4) arena alloc=0B java alloc=154KB native alloc=80KB free=127KB
I/PackageManager( 474): Running dexopt on: /system/priv-app/DownloadProvider/DownloadProvider.apk pkg=com.android.providers.downloads isa=arm vmSafeMode=false
I/dex2oat ( 851): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/DownloadProvider/DownloadProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@DownloadProvider@DownloadProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 851): Decided to run without swap.
I/dex2oat ( 851): dex2oat took 522.357ms (threads: 4) arena alloc=0B java alloc=418KB native alloc=329KB free=82KB
D/DisplayManager( 828): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/ActivityManagerService( 474): Start proc 858:com.android.settings/1000 for broadcast com.android.settings/.ManagedProfileSetup
I/ActivityManagerService( 474): Launching preboot mode app: ProcessRecord{133cec21 858:com.android.settings/1000}
I/DownloadManager( 828): Upgrading downloads database from version 0 to version 109, which will destroy all old data
D/DisplayManager( 858): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/ActivityManagerService( 474): OK, system ready!
I/ActivityManagerService( 474): Removing system update proc: ProcessRecord{14980d70 753:com.android.providers.calendar/u0a1}
I/ActivityManagerService( 474): Killing 753:com.android.providers.calendar/u0a1 (adj 15): system update done
I/ActivityManagerService( 474): Removing system update proc: ProcessRecord{1f2ef96e 779:android.process.acore/u0a2}
I/ActivityManagerService( 474): Killing 779:android.process.acore/u0a2 (adj 15): system update done
I/ActivityManagerService( 474): Removing system update proc: ProcessRecord{3013e80f 805:com.android.managedprovisioning/u0a6}
I/ActivityManagerService( 474): Killing 805:com.android.managedprovisioning/u0a6 (adj 13): system update done
I/ActivityManagerService( 474): Removing system update proc: ProcessRecord{133cec21 858:com.android.settings/1000}
I/ActivityManagerService( 474): Killing 858:com.android.settings/1000 (adj 9): system update done
I/ActivityManagerService( 474): System now ready
W/ActivityManagerService( 474): Spurious death for ProcessRecord{14980d70 753:com.android.providers.calendar/u0a1}, curProc for 753: null
W/ActivityManagerService( 474): Spurious death for ProcessRecord{1f2ef96e 779:android.process.acore/u0a2}, curProc for 779: null
W/ActivityManagerService( 474): Spurious death for ProcessRecord{3013e80f 805:com.android.managedprovisioning/u0a6}, curProc for 805: null
W/ActivityManagerService( 474): Spurious death for ProcessRecord{133cec21 858:com.android.settings/1000}, curProc for 858: null
I/SystemServer( 474): Making services ready
I/SystemServiceManager( 474): Starting phase 550
I/Telecom ( 474): TelecomGlobals: TelecomGlobals initializing
I/SystemServer( 474): WebViewFactory preparation
D/UsbHostManager( 474): Added device UsbDevice[mName=/dev/bus/usb/003/004,mVendorId=2362,mProductId=9488,mClass=0,mSubclass=0,mProtocol=0,mManufacturerName=PixArt,mProductName=USB Optical Mouse,mSerialNumber=null,mConfigurations=[
D/UsbHostManager( 474): UsbConfiguration[mId=1,mName=null,mAttributes=160,mMaxPower=50,mInterfaces=[
D/UsbHostManager( 474): UsbInterface[mId=0,mAlternateSetting=0,mName=null,mClass=3,mSubclass=1,mProtocol=2,mEndpoints=[
D/UsbHostManager( 474): UsbEndpoint[mAddress=129,mAttributes=3,mMaxPacketSize=4,mInterval=10]]]]
W/ContextImpl( 474): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1344 com.android.server.usb.UsbSettingsManager.deviceAttached:741 com.android.server.usb.UsbHostManager.endUsbDeviceAdded:224 com.android.server.usb.UsbHostManager.monitorUsbHostBus:-2 com.android.server.usb.UsbHostManager.access$000:42
I/ActivityManagerService( 474): Start proc 882:android.process.acore/u0a2 for content provider com.android.providers.contacts/.CallLogProvider
D/UsbDeviceManager( 474): Usb state is true true true
I/ActivityManagerService( 474): Start proc 900:WebViewLoader-armeabi-v7a/1037 [android.webkit.WebViewFactory$RelroFileCreator] for
D/BluetoothManagerService( 474): Message: 20
D/BluetoothManagerService( 474): Added callback: android.bluetooth.BluetoothAdapter$1@c3a3a2a:true
D/BluetoothManagerService( 474): Message: 30
D/BluetoothManagerService( 474): Trying to bind to profile: 1, while Bluetooth was disabled
I/PackageManager( 474): Running dexopt on: /system/app/UserDictionaryProvider/UserDictionaryProvider.apk pkg=com.android.providers.userdictionary isa=arm vmSafeMode=false
V/WebViewFactory( 900): RelroFileCreator (64bit = false), 32-bit lib: /system/app/webview/lib/arm/libwebviewchromium.so, 64-bit lib:
I/dex2oat ( 915): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/UserDictionaryProvider/UserDictionaryProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@UserDictionaryProvider@UserDictionaryProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 915): Decided to run without swap.
D/UsbHostManager( 474): Added device UsbDevice[mName=/dev/bus/usb/003/003,mVendorId=1443,mProductId=34096,mClass=239,mSubclass=2,mProtocol=1,mManufacturerName=Sonix Technology Co., Ltd.,mProductName=USB 2.0 Camera,mSerialNumber=SN5100,mConfigurations=[
D/UsbHostManager( 474): UsbConfiguration[mId=1,mName=null,mAttributes=128,mMaxPower=128,mInterfaces=[
D/UsbHostManager( 474): UsbInterface[mId=0,mAlternateSetting=0,mName=HD USB Camera,mClass=14,mSubclass=1,mProtocol=0,mEndpoints=[
D/UsbHostManager( 474): UsbEndpoint[mAddress=131,mAttributes=3,mMaxPacketSize=16,mInterval=6]]
D/UsbHostManager( 474): UsbInterface[mId=1,mAlternateSetting=0,mName=null,mClass=14,mSubclass=2,mProtocol=0,mEndpoints=
D/UsbHostManager( 474): UsbInterface[mId=1,mAlternateSetting=1,mName=null,mClass=14,mSubclass=2,mProtocol=0,mEndpoints=[
D/UsbHostManager( 474): UsbEndpoint[mAddress=129,mAttributes=5,mMaxPacketSize=128,mInterval=1]]
D/UsbHostManager( 474): UsbInterface[mId=1,mAlternateSetting=2,mName=null,mClass=14,mSubclass=2,mProtocol=0,mEndpoints=[
D/UsbHostManager( 474): UsbEndpoint[mAddress=129,mAttributes=5,mMaxPacketSize=256,mInterval=1]]
D/UsbHostManager( 474): UsbInterface[mId=1,mAlternateSetting=3,mName=null,mClass=14,mSubclass=2,mProtocol=0,mEndpoints=[
D/UsbHostManager( 474): UsbEndpoint[mAddress=129,mAttributes=5,mMaxPacketSize=800,mInterval=1]]
D/UsbHostManager( 474): UsbInterface[mId=1,mAlternateSetting=4,mName=null,mClass=14,mSubclass=2,mProtocol=0,mEndpoints=[
D/UsbHostManager( 474): UsbEndpoint[mAddress=129,mAttributes=5,mMaxPacketSize=2848,mInterval=1]]
D/UsbHostManager( 474): UsbInterface[mId=1,mAlternateSetting=5,mName=null,mClass=14,mSubclass=2,mProtocol=0,mEndpoints=[
D/UsbHostManager( 474): UsbEndpoint[mAddress=129,mAttributes=5,mMaxPacketSize=4896,mInterval=1]]
D/UsbHostManager( 474): UsbInterface[mId=1,mAlternateSetting=6,mName=null,mClass=14,mSubclass=2,mProtocol=0,mEndpoints=[
D/UsbHostManager( 474): UsbEndpoint[mAddress=129,mAttributes=5,mMaxPacketSize=5120,mInterval=1]]]]
I/dex2oat ( 915): dex2oat took 106.660ms (threads: 4) arena alloc=0B java alloc=20KB native alloc=76KB free=39KB
I/art ( 900): System.exit called, status: 0
I/AndroidRuntime( 900): VM exiting with result code 0, cleanup skipped.
D/DisplayManager( 882): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/ActivityManagerService( 474): Start proc 924:com.android.systemui/u0a11 for service com.android.systemui/.SystemUIService
I/MountService( 474): doMountVolume: Mouting /mnt/internal_sd
D/VoldCmdListener( 164): volume mount /mnt/internal_sd
D/Vold ( 164): volume status = 1----------------------
D/DirectVolume( 164): getDeviceNodes mPartIdx = 15, mDiskNumParts = 15.
E/Vold ( 164): deviceNodes[0]= 0x0000b30f,[1]= 0x00000000,[2]= 0x00000000,[3]= 0x00000000
I/Vold ( 164): /dev/block/vold/179:15 being considered for volume internal_sd,1
I/Vold ( 164):
D/Vold ( 164): Volume internal_sd state changing 1 (Idle-Unmounted) → 3 (Checking)
I/MountService( 474): onEvent:: raw= 605 Volume internal_sd /mnt/internal_sd state changed from 1 (Idle-Unmounted) to 3 (Checking) cooked = 605 Volume internal_sd /mnt/internal_sd state changed from 1 (Idle-Unmounted) to 3 (Checking)
I/MountService( 474): notifyVolumeStateChange::unmounted
I/MountService( 474): updating volume state checking
D/MountService( 474): volume state changed for /mnt/internal_sd (unmounted → checking)
D/MountService( 474): sendStorageIntent Intent { act=android.intent.action.MEDIA_CHECKING dat=file:///mnt/internal_sd flg=0x4000000 (has extras) } to UserHandle{-1}
I/fsck_msdos( 164): ** /dev/block/vold/179:15
I/fsck_msdos( 164): ** Phase 1 - Read FAT (compare skipped)
I/fsck_msdos( 164): Attempting to allocate 5984 KB for FAT
I/Telecom ( 474): TelecomGlobals: CallsManager initialized
W/ContextImpl( 474): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1709 android.content.ContextWrapper.startService:516 com.android.server.telecom.BluetoothPhoneService.start:440 com.android.server.telecom.TelecomGlobals.initialize:93 com.android.server.telecom.TelecomService.onCreate:164
I/art ( 175): Explicit concurrent mark sweep GC freed 703(30KB) AllocSpace objects, 0(0B) LOS objects, 86% free, 159KB/1183KB, paused 109us total 17.164ms
I/ValidateNoPeople( 474): skipping global notification
I/art ( 175): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 86% free, 159KB/1183KB, paused 113us total 13.180ms
I/art ( 175): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 86% free, 159KB/1183KB, paused 92us total 9.438ms
I/PackageManager( 474): Running dexopt on: /system/priv-app/SystemUI/SystemUI.apk pkg=com.android.systemui isa=arm vmSafeMode=false
I/dex2oat ( 944): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/SystemUI/SystemUI.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@SystemUI@SystemUI.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
D/NetworkManagementService( 474): enabling bandwidth control
I/fsck_msdos( 164): ** Phase 2 - Check Cluster Chains
I/fsck_msdos( 164): ** Phase 3 - Checking Directories
I/fsck_msdos( 164): ** Phase 4 - Checking for Lost Files
I/fsck_msdos( 164): Free space in FSInfo block (-1) not correct (1530661)
I/fsck_msdos( 164): FIXED
I/fsck_msdos( 164): Next free cluster in FSInfo block (2) not free
I/fsck_msdos( 164): 1 files, 3856680 free (1530661 clusters)
I/Vold ( 164): Filesystem check completed OK
E/Vold ( 164): ---------set mSkipAsec to enable app2sd because mount Vfat succeed for internal_sd, mountpoint =/mnt/internal_sd
I/dex2oat ( 944): Decided to run without swap.
D/Vold ( 164): blkid identified as /dev/block/vold/179:15: LABEL=“ROCKCHIP” UUID=“714B-140E” TYPE=“vfat”
I/MountService( 474): onEvent:: raw= 613 internal_sd /mnt/internal_sd “714B-140E” cooked = 613 internal_sd /mnt/internal_sd 714B-140E
D/Vold ( 164): Volume internal_sd state changing 3 (Checking) → 4 (Mounted)
I/MountService( 474): onEvent:: raw= 614 internal_sd /mnt/internal_sd “ROCKCHIP” cooked = 614 internal_sd /mnt/internal_sd ROCKCHIP
I/MountService( 474): onEvent:: raw= 605 Volume internal_sd /mnt/internal_sd state changed from 3 (Checking) to 4 (Mounted) cooked = 605 Volume internal_sd /mnt/internal_sd state changed from 3 (Checking) to 4 (Mounted)
I/MountService( 474): notifyVolumeStateChange::checking
I/MountService( 474): updating volume state mounted
D/MountService( 474): volume state changed for /mnt/internal_sd (checking → mounted)
I/PackageManager( 474): Updating external media status from unmounted to mounted
D/MountService( 474): sendStorageIntent Intent { act=android.intent.action.MEDIA_MOUNTED dat=file:///mnt/internal_sd flg=0x4000000 (has extras) } to UserHandle{-1}
I/ContactLocale( 882): AddressBook Labels [en-US]: [, A, B, C, D, E, F, G, H, I, J, K, L, M, N, O, P, Q, R, S, T, U, V, W, X, Y, Z, Α, Β, Γ, Δ, Ε, Ζ, Η, Θ, Ι, Κ, Λ, Μ, Ν, Ξ, Ο, Π, Ρ, Σ, Τ, Υ, Φ, Χ, Ψ, Ω, , А, Б, В, Г, Д, Ђ, Е, Є, Ж, З, И, І, Ї, Й, Ј, К, Л, Љ, М, Н, Њ, О, П, Р, С, Т, Ћ, У, Ф, Х, Ц, Ч, Џ, Ш, Щ, Ю, Я, , א, ב, ג, ד, ה, ו, ז, ח, ט, י, כ, ל, מ, נ, ס, ע, פ, צ, ק, ר, ש, ת, , ا, ب, ت, ث, ج, ح, خ, د, ذ, ر, ز, س, ش, ص, ض, ط, ظ, ع, غ, ف, ق, ك, ل, م, ن, ه, و, ي, , ก, ข, ฃ, ค, ฅ, ฆ, ง, จ, ฉ, ช, ซ, ฌ, ญ, ฎ, ฏ, ฐ, ฑ, ฒ, ณ, ด, ต, ถ, ท, ธ, น, บ, ป, ผ, ฝ, พ, ฟ, ภ, ม, ย, ร, ฤ, ล, ฦ, ว, ศ, ษ, ส, ห, ฬ, อ, ฮ, , ㄱ, ㄴ, ㄷ, ㄹ, ㅁ, ㅂ, ㅅ, ㅇ, ㅈ, ㅊ, ㅋ, ㅌ, ㅍ, ㅎ, , あ, か, さ, た, な, は, ま, や, ら, わ, #, ]
W/PackageManager( 474): Not granting permission android.permission.GLOBAL_SEARCH to package com.android.quicksearchbox (protectionLevel=18 flags=0x88be45)
W/PackageManager( 474): Not granting permission android.permission.ACCESS_DOWNLOAD_MANAGER to package com.android.browser (protectionLevel=18 flags=0x89be45)
W/PackageManager( 474): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x89be45)
W/PackageManager( 474): Not granting permission android.permission.BIND_WALLPAPER to package com.android.camera2 (protectionLevel=18 flags=0xd8bc45)
W/PackageManager( 474): Not granting permission android.permission.BIND_APPWIDGET to package com.android.launcher3 (protectionLevel=18 flags=0xd83e45)
W/PackageManager( 474): Not granting permission android.permission.INSTALL_PACKAGES to package com.android.apkinstaller (protectionLevel=18 flags=0x88be45)
W/PackageManager( 474): Not granting permission android.permission.DELETE_PACKAGES to package com.android.apkinstaller (protectionLevel=18 flags=0x88be45)
W/PackageManager( 474): Not granting permission android.permission.DELETE_PACKAGES to package com.svox.pico (protectionLevel=18 flags=0x88be45)
W/PackageManager( 474): Not granting permission android.permission.MOUNT_UNMOUNT_FILESYSTEMS to package com.rockchip.mediacenter (protectionLevel=18 flags=0x88be45)
W/PackageManager( 474): Not granting permission android.permission.DEVICE_POWER to package com.rockchip.mediacenter (protectionLevel=2 flags=0x88be45)
W/PackageManager( 474): Not granting permission android.permission.WRITE_MEDIA_STORAGE to package com.android.music (protectionLevel=18 flags=0x88be65)
W/PackageManager( 474): Not granting permission android.permission.DEVICE_POWER to package com.android.music (protectionLevel=2 flags=0x88be65)
W/PackageManager( 474): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0xc8be45)
I/dex2oat ( 944): dex2oat took 1.287s (threads: 4) arena alloc=0B java alloc=4MB native alloc=554KB free=1217KB
D/DisplayManager( 924): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/PermissionMonitor( 474): Monitoring
D/PermissionMonitor( 474): Users: 1, Apps: 61
D/ContactDirectoryManager( 882): Found com.android.exchange.directory.provider
V/SystemUIService( 924): Starting SystemUI services.
I/SystemServiceManager( 474): Starting phase 600
I/ActivityManagerService( 474): Start proc 1000:com.android.exchange/u0a25 for content provider com.android.exchange/.provider.ExchangeDirectoryProvider
D/ZenLog ( 474): downtime: Autotrigger skipped: not in downtime
I/BackupManagerService( 474): Backup enabled => false
I/BackupManagerService( 474): Opting out of backup
D/DisplayManager( 924): getDisplayInfo: displayId=1, info=DisplayInfo{“HDMI Screen”, uniqueId “local:1”, app 1366 x 768, real 1366 x 768, largest app 1366 x 768, smallest app 1366 x 768, 61724.586 fps, supportedRefreshRates [61724.586], rotation 0, density 227 (227.0 x 227.0) dpi, layerStack 1, appVsyncOff 0, presDeadline 1016201, type HDMI, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS, FLAG_PRESENTATION}
I/AwesomePlayer( 171): AwesomePlayer::AwesomePlayer()in
E/InputMethodManagerService( 474): Ignoring setImeWindowStatus due to an invalid token. uid:1000 token:null
I/libstagefrighthw( 171): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.avc
I/libstagefrighthw( 171): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.m4v
I/libstagefrighthw( 171): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.h263
I/libstagefrighthw( 171): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.flv1
I/libstagefrighthw( 171): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.m2v
I/libstagefrighthw( 171): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.rv
I/libstagefrighthw( 171): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vp8
I/libstagefrighthw( 171): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vc1
I/libstagefrighthw( 171): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.wmv3
I/libstagefrighthw( 171): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vp6
I/libstagefrighthw( 171): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.hevc
I/libstagefrighthw( 171): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.mjpeg
I/libstagefrighthw( 171): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.avc.secure
I/libstagefrighthw( 171): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vp9
I/libstagefrighthw( 171): OMX IL core libOMX_Core.so: declares component OMX.rk.video_encoder.avc
I/libstagefrighthw( 171): OMX IL core libOMX_Core.so: declares component OMX.rk.video_encoder.vp8
I/libstagefrighthw( 171): OMX IL core libOMX_Core.so: contains 16 components
I/AwesomePlayer( 171): AwesomePlayer::AwesomePlayer()aftermClient.connect()
V/FingerprintService( 474): startListening(android.service.fingerprint.IFingerprintServiceReceiver$Stub$Proxy@2c697e5)
W/InputMethodManagerService( 474): Reset the default IME as “Resource” is ready here.
E/OMXNodeInstance( 171): getParameter(1:google.mp3.decoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(1:google.mp3.decoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(2:google.amrnb.decoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(2:google.amrnb.decoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
I/InputMethodManagerService( 474): Selected default: com.android.inputmethod.latin/.LatinIME
E/OMXNodeInstance( 171): getParameter(3:google.amrwb.decoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(3:google.amrwb.decoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(4:google.aac.decoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(4:google.aac.decoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(5:google.g711.alaw.decoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
I/PackageManager( 474): Running dexopt on: /system/app/Exchange2/Exchange2.apk pkg=com.android.exchange isa=arm vmSafeMode=false
E/OMXNodeInstance( 171): getParameter(5:google.g711.alaw.decoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(6:google.g711.mlaw.decoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(6:google.g711.mlaw.decoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(7:google.vorbis.decoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(7:google.vorbis.decoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(8:google.opus.decoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(8:google.opus.decoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(9:google.raw.decoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(9:google.raw.decoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(a:google.aac.encoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(a:google.aac.encoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(b:google.amrnb.encoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(b:google.amrnb.encoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(c:google.amrwb.encoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(c:google.amrwb.encoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(d:google.flac.encoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 171): getParameter(d:google.flac.encoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/ROCKCHIP_VIDEO_DECCONTROL( 171): OMX_IndexParamdescribeColorFormat get
W/OMXNodeInstance( 171): [e:rk._decoder.avc] component does not support metadata mode; using fallback
W/OMXNodeInstance( 171): [f:rk._decoder.m2v] component does not support metadata mode; using fallback
W/OMXNodeInstance( 171): [10:rk._decoder.vp8] component does not support metadata mode; using fallback
I/dex2oat ( 1035): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Exchange2/Exchange2.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Exchange2@Exchange2.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
W/OMXNodeInstance( 171): [11:google.vp9.decoder] component does not support metadata mode; using fallback
W/OMXNodeInstance( 171): [12:rk._decoder.h263] component does not support metadata mode; using fallback
W/OMXNodeInstance( 171): [13:rk._decoder.m4v] component does not support metadata mode; using fallback
W/OMXNodeInstance( 171): [14:rk._decoder.flv1] component does not support metadata mode; using fallback
W/OMXNodeInstance( 171): [15:rk._decoder.mjpeg] component does not support metadata mode; using fallback
W/OMXNodeInstance( 171): [16:rk._decoder.hevc] component does not support metadata mode; using fallback
W/ACodec ( 171): do not know color format 0x7f000789 = 2130708361
W/OMXNodeInstance( 171): [18:google.h264.decoder] component does not support metadata mode; using fallback
W/OMXNodeInstance( 171): [19:google.vp9.decoder] component does not support metadata mode; using fallback
I/SoftMPEG4Encoder( 171): Construct SoftMPEG4Encoder
I/OMXCodec( 171): —>InstantiateSoftwareCodec create OMX.google.vorbis.decoder codec
I/OMXCodec( 171): Successfully allocated OMX node ‘OMX.google.vorbis.decoder’
I/OMXCodec( 171): mOutputPortSettingsHaveChanged set true
I/OMXCodec( 171): found informat change ComponentName = OMX.google.vorbis.decoder
W/AudioCache( 171): Battery track warning: refCount is already 0
I/FrameQueueManage( 171): FrameQueueManage::~FrameQueueManage end!
I/dex2oat ( 1035): Decided to run without swap.
I/dex2oat ( 1035): dex2oat took 1.818s (threads: 4) arena alloc=0B java alloc=3MB native alloc=578KB free=689KB
D/DisplayManager( 882): onDisplayEvent: displayId=0, event=2
D/DisplayManager( 828): onDisplayEvent: displayId=0, event=2
D/DisplayManager( 924): onDisplayEvent: displayId=0, event=2
I/ActivityManagerService( 474): Config changes=20 {1.15 multiwindowflag=DISABLE dualscreenflag=DISABLE ?mcc?mnc en_US ?layoutDir sw720dp w1280dp h647dp 160dpi lrg long land -touch -keyb/v/h dpad/v s.5}
D/DisplayManager( 1000): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/ActivityManagerService( 474): Start proc 1124:com.android.inputmethod.latin/u0a31 for service com.android.inputmethod.latin/.LatinIME
V/InputMethodManagerService( 474): Adding window token: android.os.Binder@30f3d6e3
W/InputMethodManagerService( 474): Illegal subtype state: old subtype = null, new subtype = android.view.inputmethod.InputMethodSubtype@c9194f98
E/ActivityThread( 1000): Failed to find provider info for com.android.email.provider
D/GpsLocationProvider( 474): Reset GPS properties, previous size = 0
D/GpsLocationProvider( 474): GpsParamsResource: SUPL_HOST=supl.google.com
D/GpsLocationProvider( 474): GpsParamsResource: SUPL_PORT=7275
D/GpsLocationProvider( 474): GpsParamsResource: NTP_SERVER=north-america.pool.ntp.org
D/GpsLocationProvider( 474): GpsParamsResource: SUPL_VER=0x20000
D/GpsLocationProvider( 474): GpsParamsResource: SUPL_MODE=1
W/GpsLocationProvider( 474): Could not open GPS configuration file /etc/gps.conf
D/GpsLocationProvider( 474): GPS properties reloaded, size = 5
E/GpsLocationProvider( 474): no AGPS interface in set_agps_server
E/GpsLocationProvider( 474): no GPS configuration interface in configuraiton_update
D/GpsLocationProvider( 474): final config = #Sat Jan 01 12:52:15 GMT+00:00 2011
D/GpsLocationProvider( 474): SUPL_VER=0x20000
D/GpsLocationProvider( 474): SUPL_HOST=supl.google.com
D/GpsLocationProvider( 474): NTP_SERVER=north-america.pool.ntp.org
D/GpsLocationProvider( 474): SUPL_PORT=7275
D/GpsLocationProvider( 474): SUPL_MODE=1
D/ViewRootImpl( 474): 1280<<<<<< BACK FROM relayoutnull
W/ServiceWatcher( 474): com.google.android.gms not found
W/LocationManagerService( 474): no network location provider found
E/LocationManagerService( 474): no geocoder provider found
E/FlpHardwareProvider( 474): Error hw_get_module ‘flp’: -2
E/LocationManagerService( 474): FLP HAL not supported
W/ResourcesManager( 474): Asset path ‘/system/framework/com.android.location.provider.jar’ does not exist or contains no resources.
E/LocationManagerService( 474): Unable to bind FLP Geofence proxy.
E/ActivityRecognitionHardware( 474): Error hw_get_module: -2
E/LocationManagerService( 474): Hardware Activity-Recognition not supported.
D/PhoneWindow( 924): DecorView - SCREEN_WEITH = 1280 - SCREE_HEIGHT = 672
I/CommonTimeManagementService( 474): No common time service detected on this platform. Common time services will be unavailable.
I/InputReader( 474): Reconfiguring input devices. changes=0x00000020
I/MmsServiceBroker( 474): Delay connecting to MmsService until an API is called
W/VoiceInteractionManagerService( 474): no available voice interaction services found for user 0
W/VoiceInteractionManagerService( 474): no available voice recognition services found for user 0
I/InputReader( 474): Reconfiguring input devices. changes=0x00000010
I/ContactDirectoryManager( 882): deleted 0 stale rows which don’t have any relevant directory
I/ContactDirectoryManager( 882): Discovered 0 contact directories in 2348ms
I/ContactsProvider( 882): Upgrading aggregation algorithm
I/ContactAggregator( 882): Marked all visible contacts for aggregation: 0 raw contacts, 2 ms
I/ActivityManagerService( 474): Start proc 1143:com.android.inputmethod.latin/u0a31 for added application com.android.inputmethod.latin
I/ActivityManagerService( 474): Start proc 1158:com.cghs.stresstest/1000 for added application com.cghs.stresstest
I/ContactsProvider( 882): Aggregation algorithm upgraded for 0 raw contacts in 92ms
I/ActivityManagerService( 474): Start proc 1177:com.android.phone/1001 for added application com.android.phone
I/ActivityStackSupervisor( 474): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.settings/.CryptKeeper} from uid 0 on display 0
I/System.out( 474): com.android.settings.CryptKeeperaddAppToken taskId:1
I/ContactsFTS( 882): Rebuild contact search index in 67ms, 0 contacts
I/ActivityManagerService( 474): Start proc 1197:com.android.settings/1000 for activity com.android.settings/.CryptKeeper
W/ActivityManagerService( 474): No pending application record for pid 1124 (IApplicationThread android.app.ApplicationThreadProxy@260f76d0); dropping process
V/WiredAccessoryManager( 474): notifyWiredAccessoryChanged: when=0 bits= mask=54
V/WiredAccessoryManager( 474): newName=h2w newState=0 headsetState=0 prev headsetState=0
E/WiredAccessoryManager( 474): No state change.
V/WiredAccessoryManager( 474): init()
I/PackageManager( 474): Running dexopt on: /system/app/LatinIME/LatinIME.apk pkg=com.android.inputmethod.latin isa=arm vmSafeMode=false
I/art ( 828): Explicit concurrent mark sweep GC freed 5982(556KB) AllocSpace objects, 1(16KB) LOS objects, 71% free, 406KB/1430KB, paused 346us total 14.898ms
I/dex2oat ( 1212): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/LatinIME/LatinIME.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@LatinIME@LatinIME.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 1212): Decided to run without swap.
I/dex2oat ( 1212): dex2oat took 585.938ms (threads: 4) arena alloc=0B java alloc=1626KB native alloc=381KB free=566KB
I/PackageManager( 474): Running dexopt on: /system/priv-app/TelephonyProvider/TelephonyProvider.apk pkg=com.android.providers.telephony isa=arm vmSafeMode=false
D/DisplayManager( 1143): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/dex2oat ( 1221): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/TelephonyProvider/TelephonyProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@TelephonyProvider@TelephonyProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 1221): Decided to run without swap.
I/dex2oat ( 1221): dex2oat took 92.448ms (threads: 4) arena alloc=0B java alloc=112KB native alloc=78KB free=117KB
I/PackageManager( 474): Running dexopt on: /system/priv-app/TeleService/TeleService.apk pkg=com.android.phone isa=arm vmSafeMode=false
I/dex2oat ( 1226): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/TeleService/TeleService.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@TeleService@TeleService.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 1226): Decided to run without swap.
I/dex2oat ( 1226): dex2oat took 420.465ms (threads: 4) arena alloc=0B java alloc=1445KB native alloc=356KB free=215KB
D/DisplayManager( 1177): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/DisplayManager( 1158): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/ActivityManagerService( 474): Start proc 1231:com.android.printspooler/u0a43 for service com.android.printspooler/.model.PrintSpoolerService
I/ValidateNoPeople( 474): mEvictionCount: 0
D/Tethering( 474): UsbManager.ACTION_USB_STATE: true, false, false
D/GpsNetInitiatedHandler( 474): location enabled :false
D/MountService( 474): sharedvolumeNum: 0 ;avail: true
D/VolumeUI( 924): Registering volume controller
D/xzj ( 828): true---------------------------ooooooooooo,stop mtp service---------------false
D/DisplayManager( 1197): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/LatinIME( 1143): Hardware accelerated drawing: true
I/ActivityManagerService( 474): Start proc 1250:android.rockchip.update.service/1000 for broadcast android.rockchip.update.service/.RKUpdateReceiver
I/PackageManager( 474): Running dexopt on: /system/app/PrintSpooler/PrintSpooler.apk pkg=com.android.printspooler isa=arm vmSafeMode=false
I/dex2oat ( 1266): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/PrintSpooler/PrintSpooler.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@PrintSpooler@PrintSpooler.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 1266): Decided to run without swap.
I/dex2oat ( 1266): dex2oat took 349.692ms (threads: 4) arena alloc=0B java alloc=991KB native alloc=354KB free=233KB
I/PackageManager( 474): Running dexopt on: /system/app/RKUpdateService/RKUpdateService.apk pkg=android.rockchip.update.service isa=arm vmSafeMode=false
D/DisplayManager( 1231): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
W/AppWidgetServiceImpl( 474): Failed to read state: java.io.FileNotFoundException: /data/system/users/0/appwidgets.xml: open failed: ENOENT (No such file or directory)
V/AppWidgetServiceImpl( 474): Upgrading widget database from 0 to 1
D/BluetoothManagerService( 474): Message: 300
D/BluetoothManagerService( 474): MESSAGE_USER_SWITCHED
I/dex2oat ( 1276): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/RKUpdateService/RKUpdateService.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@RKUpdateService@RKUpdateService.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
D/PermissionCache( 165): checking android.permission.HARDWARE_TEST for uid=1000 => granted (258 us)
I/dex2oat ( 1276): Decided to run without swap.
I/PrintSpoolerService( 1231): No existing print spooler state.
I/dex2oat ( 1276): dex2oat took 63.577ms (threads: 4) arena alloc=0B java alloc=171KB native alloc=86KB free=77KB
D/PhoneWindow( 1143): DecorView - SCREEN_WEITH = 1280 - SCREE_HEIGHT = 672
D/DisplayManager( 1250): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
W/AppOps ( 474): Bad call: specified package media under uid 1000 but it is really 1013
W/InputAttributes( 1143): No editor info for this field. Bug?
D/RKUpdateReceiver( 1250): action = android.hardware.usb.action.USB_STATE
I/ResourceUtils( 1143): Found default value: resource=keypress_vibration_durations build=[HARDWARE=rk30board MODEL=firefly-rk3288 BRAND=firefly MANUFACTURER=rockchip] default=-1
I/ResourceUtils( 1143): Found default value: resource=keypress_volumes build=[HARDWARE=rk30board MODEL=firefly-rk3288 BRAND=firefly MANUFACTURER=rockchip] default=-1.0f
I/FusedLocation( 474): engine started (com.android.location.fused)
D/ActivityManagerService( 474): moveHomeStackTaskToTop: moving TaskRecord{4b43606 #1 I=com.android.settings/.CryptKeeper U=0 sz=1}
I/ActivityStackSupervisor( 474): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.provision/.DefaultActivity} from uid 0 on display 0
I/System.out( 474): com.android.provision.DefaultActivityaddAppToken taskId:2
I/ActivityManagerService( 474): Start proc 1285:com.android.provision/u0a44 for activity com.android.provision/.DefaultActivity
I/LatinIME:LogUtils( 1143): Dictionary info: dictionary = UserHistoryDictionary.en_US.dic ; version = ? ; date = 1293886337
I/LatinIME:LogUtils( 1143): Dictionary info: dictionary = personalization.en_US.dict ; version = ? ; date = 1293886337
I/LatinIME:LogUtils( 1143): Dictionary info: dictionary = PersonalizationPredictionDictio ; version = ? ; date = 1293886337
I/PackageManager( 474): Running dexopt on: /system/app/Provision/Provision.apk pkg=com.android.provision isa=arm vmSafeMode=false
I/dex2oat ( 1307): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Provision/Provision.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Provision@Provision.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 1307): Decided to run without swap.
I/dex2oat ( 1307): dex2oat took 50.475ms (threads: 4) arena alloc=0B java alloc=7KB native alloc=75KB free=32KB
I/Choreographer( 924): Skipped 97 frames! The application may be doing too much work on its main thread.
I/LatinIME:LogUtils( 1143): Dictionary info: dictionary = userunigram.en_US.dict ; version = ? ; date = ?
D/DisplayManager( 1285): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/LatinIME:LogUtils( 1143): Dictionary info: dictionary = main:en ; version = 42 ; date = 1381226429
W/BackupManagerService( 474): dataChanged but no participant pkg=‘com.android.providers.settings’ uid=10044
I/StatusBarManagerService( 474): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@85f17d5
D/ActivityManagerService( 474): moveHomeStackTaskToTop: moving TaskRecord{29b01c8e #2 A=com.android.provision U=0 sz=1}
I/ActivityStackSupervisor( 474): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.launcher3/.Launcher} from uid 0 on display 0
I/System.out( 474): com.android.launcher3.LauncheraddAppToken taskId:3
I/ActivityManagerService( 474): Start proc 1327:com.android.launcher3/u0a32 for activity com.android.launcher3/.Launcher
I/PackageManager( 474): Running dexopt on: /system/app/Launcher3/Launcher3.apk pkg=com.android.launcher3 isa=arm vmSafeMode=false
I/dex2oat ( 1345): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Launcher3/Launcher3.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Launcher3@Launcher3.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 1345): Decided to run without swap.
I/dex2oat ( 1345): dex2oat took 699.844ms (threads: 4) arena alloc=0B java alloc=1862KB native alloc=391KB free=552KB
D/DisplayManager( 1327): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
V/Launcher( 1327): LauncherAppState inited
D/Launcher.Model( 1327): Old launcher provider: content://com.android.launcher2.settings/favorites?notify=true
D/Launcher.Model( 1327): Old launcher provider does not exist.
W/Launcher( 1327): setApplicationContext called twice! old=com.android.launcher3.LauncherApplication@c52b64d new=com.android.launcher3.LauncherApplication@c52b64d
D/TelephonyProvider( 1177): dbh.onCreate:+ db=SQLiteDatabase: /data/data/com.android.providers.telephony/databases/telephony.db
D/TelephonyProvider( 1177): dbh.createSimInfoTable:+
D/TelephonyProvider( 1177): dbh.createSimInfoTable:-
D/TelephonyProvider( 1177): dbh.createCarriersTable:+
D/TelephonyProvider( 1177): dbh.createCarriersTable:-
D/TelephonyProvider( 1177): No APNs in OEM image = /oem/telephony/apns-conf.xml Load APNs from system image
D/TelephonyProvider( 1177): confFile = /system/etc/apns-conf.xml
D/PhoneWindow( 1327): DecorView - SCREEN_WEITH = 1280 - SCREE_HEIGHT = 672
W/ResourceType( 1327): Attempt to retrieve bag 0x7f0d0008 which is invalid or in a cycle.
I/ActivityManagerService( 474): Start proc 1357:com.rockchip.devicetest/1000 for broadcast com.rockchip.devicetest/.BootReceiver
I/art ( 175): Explicit concurrent mark sweep GC freed 706(30KB) AllocSpace objects, 0(0B) LOS objects, 86% free, 159KB/1183KB, paused 90us total 10.336ms
I/art ( 175): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 86% free, 159KB/1183KB, paused 92us total 8.049ms
I/art ( 175): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 86% free, 159KB/1183KB, paused 88us total 7.683ms
I/PackageManager( 474): Running dexopt on: /system/app/DeviceTest/DeviceTest.apk pkg=com.rockchip.devicetest isa=arm vmSafeMode=false
I/dex2oat ( 1378): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/DeviceTest/DeviceTest.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@DeviceTest@DeviceTest.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
D/Launcher.Model( 1327): 11683562 - loadWorkspace()
I/dex2oat ( 1378): Decided to run without swap.
D/HSbar ( 924): app_bar_item_size=(80,80)
W/ResourceType( 924): No package identifier when getting value for resource number 0x00000000
W/PackageManager( 924): Failure retrieving resources for com.android.providers.media: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.wallpapercropper: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.documentsui: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.externalstorage: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.htmlviewer: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.mms.service: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.winstart: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.defcontainer: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.pacprocessor: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.certinstaller: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.speechrecorder: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.backupconfirm: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.provision: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.wallpaper.holospiral: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.sharedstoragebackup: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.printspooler: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.dreams.basic: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.inputdevices: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.onetimeinitializer: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.keychain: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.packageinstaller: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.svox.pico: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.proxyhandler: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.managedprovisioning: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.smspush: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for jp.co.omronsoft.openwnn: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.vpndialogs: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.shell: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.providers.userdictionary: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.location.fused: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.Listappinfo: Resource ID #0x0
W/PackageManager( 924): Failure retrieving resources for com.android.captiveportallogin: Resource ID #0x0
I/dex2oat ( 1378): dex2oat took 944.787ms (threads: 4) arena alloc=0B java alloc=2MB native alloc=478KB free=869KB
D/Launcher.LauncherProvider( 1327): loading default workspace
E/DefaultLayoutParser( 1327): Default layout parser initialized
D/DisplayManager( 1357): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/WifiService( 474): New client listening to asynchronous messages
D/OpenGLRenderer( 1327): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
D/Atlas ( 1327): Validating map…
D/Launcher.LauncherProvider( 1327): 11683562 - initializeMaxScreenId(): 0
V/WindowManagerService( 474): Based on layer: Adding window Window{10844d80 u0 com.android.launcher3/com.android.launcher3.Launcher} at 0 of 1
D/Launcher.Model( 1327): 11683562 - loadedOldDb: false
V/TestService( 1357): action:android.intent.action.MEDIA_MOUNTED
V/TestService( 1357): pathfile:///mnt/internal_sd,bootcomplete=false
V/TestService( 1357): path1:file:///mnt/internal_sd
W/ContextImpl( 1357): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1709 android.content.ContextWrapper.startService:516 android.content.ContextWrapper.startService:516 com.rockchip.devicetest.BootReceiver.onReceive:58 android.app.ActivityThread.handleReceiver:2629
D/BluetoothManagerService( 474): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@2324fe0a:true
D/BluetoothAdapter( 924): 966669395: getState() : mService = null. Returning STATE_OFF
D/TestService( 1357): onCreate
D/Launcher.Model( 1327): 11683562 - loadWorkspaceScreensDb()
D/Launcher.Model( 1327): 11683562 - screens:
D/Launcher.Model( 1327): 11683562 - sBgWorkspaceScreens:
I/ActivityManagerService( 474): Start proc 1390:com.android.externalstorage/u0a5 for broadcast com.android.externalstorage/.MountReceiver
E/BluetoothA2dpSink( 924): Could not bind to Bluetooth A2DP Service with Intent { act=android.bluetooth.IBluetoothA2dpSink }
E/BluetoothAvrcpController( 924): Could not bind to Bluetooth AVRCP Controller Service with Intent { act=android.bluetooth.IBluetoothAvrcpController }
E/BluetoothHeadsetClient( 924): Could not bind to Bluetooth Headset Client Service with Intent { act=android.bluetooth.IBluetoothHeadsetClient }
D/BluetoothMap( 924): Create BluetoothMap proxy object
E/BluetoothMap( 924): Could not bind to Bluetooth MAP Service with Intent { act=android.bluetooth.IBluetoothMap }
D/TestService( 1357): onStartCommand,from:app
D/ConnectivityService( 474): listenForNetwork for NetworkRequest [ id=2, legacyType=-1, ]
D/StorageList( 1357): VolumnState:mounted
D/StorageList( 1357): Storage’paths:/mnt/internal_sd state:mounted
D/StorageList( 1357): VolumnState:removed
D/StorageList( 1357): Storage’paths:/mnt/external_sd state:removed
D/StorageList( 1357): Storage’paths:/mnt/usb_storage/USB_DISK0 state:removed
E/blb ( 924): mmEthernetVisible: false
I/CameraManagerGlobal( 924): getCameraService: Reconnecting to camera service
D/StorageList( 1357): Storage’paths:/mnt/usb_storage/USB_DISK1 state:removed
I/PackageManager( 474): Running dexopt on: /system/priv-app/ExternalStorageProvider/ExternalStorageProvider.apk pkg=com.android.externalstorage isa=arm vmSafeMode=false
D/StorageList( 1357): Storage’paths:/mnt/usb_storage/USB_DISK2 state:removed
D/StorageList( 1357): Storage’paths:/mnt/usb_storage/USB_DISK3 state:removed
I/dex2oat ( 1410): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/ExternalStorageProvider/ExternalStorageProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@ExternalStorageProvider@ExternalStorageProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
D/StorageList( 1357): Storage’paths:/mnt/usb_storage/USB_DISK4 state:removed
D/StorageList( 1357): Storage’paths:/mnt/usb_storage/USB_DISK5 state:removed
D/DeviceTest-FileUitls( 1357): find path:/mnt/internal_sd
D/DeviceTest-FileUitls( 1357): find path:/mnt/external_sd
D/DeviceTest-FileUitls( 1357): find path:/mnt/usb_storage/USB_DISK0
D/DeviceTest-FileUitls( 1357): find path:/mnt/usb_storage/USB_DISK1
D/DeviceTest-FileUitls( 1357): find path:/mnt/usb_storage/USB_DISK2
D/DeviceTest-FileUitls( 1357): find path:/mnt/usb_storage/USB_DISK3
D/DeviceTest-FileUitls( 1357): find path:/mnt/usb_storage/USB_DISK4
D/DeviceTest-FileUitls( 1357): find path:/mnt/usb_storage/USB_DISK5
D/ViewRootImpl( 1327): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=3 sim=#120 ty=1 fl=#81910100 fmt=-2 wanim=0x10303e5 vsysui=0x700 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.launcher3token=android.os.BinderProxy@104df80d}
I/dex2oat ( 1410): Decided to run without swap.
D/mmk ( 924): onStatusChangedLocked.+++++++
E/CameraManagerGlobal( 924): Camera id 0 has status changed to 0x1
I/CameraService( 171): getCameraCharacteristics: Switching to HAL1 shim implementation…
D/CameraHal( 171): camera_get_camera_info(1337): camera_get_camera_info(1337): camera_0 facing(0), orientation(0)
I/AwesomePlayer( 171): setDataSource_l()
D/DeviceTest-FileUitls( 1357): find file:/mnt/internal_sd/LOST.DIR
D/DeviceTest-FileUitls( 1357): find file:/mnt/internal_sd/.android_secure
D/TestService( 1357): no DeviceTest.apk
V/TestService( 1357): isSystemReady()=trueisBootComplete()=false
D/TestService( 1357): check home ,if need will set default home
I/Binder_2( 1423): type=1400 audit(0.0:10): avc: denied { write } for name=“/” dev=“mmcblk0p13” ino=2 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1
I/Binder_2( 1423): type=1400 audit(0.0:11): avc: denied { add_name } for name=“vpumem_observer” scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1
I/Binder_2( 1423): type=1400 audit(0.0:12): avc: denied { create } for name=“vpumem_observer” scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=sock_file permissive=1
I/CameraClient( 171): Opening camera 0
I/CameraHal( 171): camera_device_open(500): camera_device open
D/CameraHal( 171): gCameraHalLogLevel: 0
D/CameraHal( 171): CameraHal(121): it is a uvc camera!
D/CameraHal( 171): Calling process is: /system/bin/mediaserver
E/CameraManagerGlobal( 924): Camera id 0 has status changed to 0x80000000
I/vpu_mem_pool( 171): pid 171, open_vpu_memory_pool:473: success
I/vpu_mem_pool( 171): pid 171, vpu_memory_status_observer:927: observer: /data/vpumem_observer
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (80000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 33
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (160000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 39
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (240000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 40
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (320000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 41
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (400000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 42
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (480000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 43
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (560000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 44
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (640000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 45
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (720000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 46
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (800000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 47
D/ViewRootImpl( 1327): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=3 sim=#120 ty=1 fl=#81910100 fmt=-2 wanim=0x10303e5 vsysui=0x600 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.launcher3token=android.os.BinderProxy@104df80d}
D/TestService( 1357): factoryFilePath: agingFilePath: externalStorageFilePath:/mnt/internal_sd
I/mali_so ( 1327): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 780; [Func] : base_context_deal_with_version_affairs_rk_ext;
I/mali_so ( 1327): arm_release_ver of this mali_so is ‘r6p0-02rel0’, rk_so_ver is ‘11@0’, built at ‘16:20:19’ for 3288w, on ‘Aug 1 2016’.
I/mali_so ( 1327): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 807; [Func] : base_context_deal_with_version_affairs_rk_ext;
I/mali_so ( 1327): mali_ver_property has been set to ‘r6p0-02rel0-13-11@0’, to return.
I/OpenGLRenderer( 1327): Initialized EGL, version 1.4
D/OpenGLRenderer( 1327): Enabling debug mode 0
I/dex2oat ( 1410): dex2oat took 92.880ms (threads: 4) arena alloc=0B java alloc=36KB native alloc=77KB free=34KB
W/gralloc ( 165): Debugmem The fd=52, in vmalloc !!! Ishwc=0
W/gralloc ( 165): Debugmem The fd=65, in vmalloc !!! Ishwc=0
W/gralloc ( 165): Debugmem The fd=66, in vmalloc !!! Ishwc=0
D/DisplayManager( 1390): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/CameraHal( 171): cameraCreate(374): Camera driver: uvcvideo Driver version: 3.10.0 CameraHal version: 1.55.1
D/CameraHal( 171): cameraCreate(381): mCamDriverSupportFmt: fmt = 1196444237,index = 0
D/CameraHal( 171): cameraCreate(381): mCamDriverSupportFmt: fmt = 1448695129,index = 1
D/CameraHal( 171): cameraCreate(419): cameraCreate(419): mCamDriverPreviewFmt(MJPG) is cameraHal and camera driver is also supported!!
D/CameraHal( 171): cameraCreate(421): mCamDriverPreviewFmt = 1196444237
D/CameraHal( 171): cameraCreate(427): cameraCreate(427): Current driver is uvcvideo, v4l2 memory is V4L2_MEMORY_MMAP
D/TestService( 1357): onDestroy
I/chip.devicetest( 1357): type=1400 audit(0.0:13): avc: denied { write } for name=“force_usb_mode” dev=“sysfs” ino=12777 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
E/CameraHal( 171): initDefaultParameters(486): initDefaultParameters(486): mCamDriverCapability.card is error!
D/CameraHal( 171): initDefaultParameters(534): Support Preview format: yuv420sp,yuv420p .. yuv420sp
D/CameraHal( 171): initDefaultParameters(536): Support Preview sizes: 1600x1200,2592x1944,2048x1536,1920x1080,1280x1024,1280x720,1024x768,800x600,640x480,1600x1200 640x480
D/CameraHal( 171): initDefaultParameters(537): Support Preview FPS range: (15000,30000)
D/CameraHal( 171): initDefaultParameters(538): Support Preview framerate: 15,30
D/CameraHal( 171): initDefaultParameters(539): Support Picture sizes: 1600x1200,2592x1944,2048x1536,1920x1080,1280x1024,1280x720,1024x768,800x600,640x480,1600x1200
D/CameraHal( 171): initDefaultParameters(541): Support white balance: auto,incandescent,fluorescent,daylight,cloudy-daylight
D/CameraHal( 171): initDefaultParameters(549): Support focus: fixed focus zone: 0
D/CameraHal( 171): initDefaultParameters(551): Support zoom: true(ratios: 100,105,110,115,120,125,130,135,140,145,150,155,160,165,170,175,180,185,190,195,200,205,210,215,220,225,230,235,240,245,250,255,260,265,270,275,280,285,290,295,300,)
D/CameraHal( 171): initDefaultParameters(555): Support exposure: (-3 → 3)
D/CameraHal( 171): initDefaultParameters(559): Support anti-banding: off,50hz,60hz,auto anti-banding: off
D/CameraHal( 171): initDefaultParameters(561): Support hardware faces detecte: 0
D/CameraHal( 171): initDefaultParameters(562): Support software faces detecte: 0
D/CameraHal( 171): initDefaultParameters(563): Support video stabilization: false
D/CameraHal( 171): initDefaultParameters(564): Support recording hint: false
D/ExternalStorage( 1390): After updating volumes, found 1 active roots
D/MediaScannerReceiver( 828): action: android.intent.action.MEDIA_MOUNTED path: /mnt/internal_sd
D/CameraHal( 171): cameraConfig(696): cameraConfig(696): Set framerate(30 fps) success
D/CameraHal( 171): cameraConfig(739): cameraConfig(739): Set white balance(auto) success
D/CameraHal( 171): cameraConfig(816): cameraConfig(816): Set anti-banding Disabled
D/RKUpdateReceiver( 1250): action = android.intent.action.MEDIA_MOUNTED
D/CameraHal( 171): cameraConfig(897): cameraConfig(897): Set exposure 0 0
D/CameraHal( 171): enableSensor(213): orientation = 0xb8774168 (MPL accel)
V/Sensors ( 474): int poll__activate(sensors_poll_device_t*, int, int)
V/Sensors ( 474): int sensors_poll_context_t::activate(int, int)
V/Sensors ( 474): enable - sensor Accelerometer (handle 4) dis → en
E/Sensors ( 474): MPU is not available
V/Sensors ( 474): int poll__setDelay(sensors_poll_device_t*, int, int64_t)
V/Sensors ( 474): int sensors_poll_context_t::setDelay(int, int64_t)
V/Sensors ( 474): setDelay - sensor Accelerometer (handle 4), rate 20 ms (50.00 Hz)
V/Sensors ( 474): setDelay - sensor Accelerometer (handle 4), rate 100 ms (10.00 Hz)
W/CameraService( 171): CameraService::connect X (id 0, this pid is 171, name media)
D/CameraHal( 171): commandThread(983): commandThread(983): receive CMD_PREVIEW_CAPTURE_CANCEL
D/CameraHal( 171): setParameters(623): suppport focus modes:fixed, expect:fixed
D/CameraHal( 171): commandThread(991): commandThread(991): CMD_PREVIEW_CAPTURE_CANCEL out
D/CameraHal( 171): cancelPicture(561): cancel picture OK.
D/CameraHal( 171): commandThread(911): commandThread(911):receive CMD_PREVIEW_STOP
D/CameraHal( 171): stopPreview(235): stopPreview(235):IN
D/CameraHal( 171): stopPreview(255): stopPreview(255):OUT
D/CameraHal( 171): commandThread(932): commandThread(932): CMD_PREVIEW_STOP out
D/CameraHal( 171): stopPreview(362): stop preview OK.
I/CameraClient( 171): Destroying camera 0
D/CameraHal( 171): camera_device_close(451): camera_device_close
D/CameraHal( 171): disableSensor(237): orientation = 0xb8774168 (MPL accel)
V/Sensors ( 474): enable - sensor Accelerometer (handle 4) en → dis
D/CameraHal( 171): ~SensorListener(110): Kill looper thread
D/CameraHal( 171): ~SensorListener(122): Kill looper
D/CameraHal( 171): ~SensorListener(128): SensorListener destroyed
D/CameraHal( 171): displayThread(622): displayThread(622): receive CMD_DISPLAY_STOP
D/CameraHal( 171): cameraDisplayBufferDestory(399): cameraDisplayBufferDestory(399): mANativeWindow is NULL, destory is ignore
D/CameraHal( 171): encProcessThread(1632): encProcessThread(1632): receive CMD_ENCPROCESS_EXIT
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (720000)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (640000)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (560000)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (480000)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (400000)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (320000)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (240000)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (160000)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (80000)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (0)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:552:
D/CameraHal( 171): autofocusThread(820): wait out
D/CameraHal( 171): commandThread(1095): commandThread(1095): receive CMD_EXIT
D/CameraHal( 171): ~CameraHal(293): CameraHal destory success
W/CameraService( 171): removeClient: clear camera 0, package name media
D/Launcher( 1327): 11683562 - bindAddScreens()
D/Launcher( 1327): 11683562 - orderedScreenIds:
D/Launcher.Workspace( 1327): 11683562 - addExtraEmptyScreen()
D/Launcher.Workspace( 1327): 11683562 - insertNewWorkspaceScreen(): -201 at index: 0
I/ActivityManagerService( 474): Start proc 1444:com.android.music/u0a48 for broadcast com.android.music/.MediaButtonIntentReceiver
I/ActivityManagerService( 474): Displayed com.android.launcher3/.Launcher: +2s827ms (total +5s293ms)
D/UserManager( 924): —getMaxSupportedUsers,we has UMS,force disabled M-user—
D/MediaScannerService( 828): start scanning volume external: [/mnt/internal_sd]
W/MediaProvider( 828): no database for scanned volume external
I/PackageManager( 474): Running dexopt on: /system/app/RKMusic/RKMusic.apk pkg=com.android.music isa=arm vmSafeMode=false
I/dex2oat ( 1463): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/RKMusic/RKMusic.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@RKMusic@RKMusic.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/MediaProvider( 828): Upgrading media database from version 0 to 800, which will destroy all old data
I/dex2oat ( 1463): Decided to run without swap.
I/dex2oat ( 1463): dex2oat took 436.371ms (threads: 4) arena alloc=0B java alloc=1064KB native alloc=352KB free=971KB
D/DisplayManager( 1444): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
V/KeyguardServiceDelegate( 474): *** Keyguard: can’t bind to com.android.systemui.keyguard.KeyguardService
W/KeyguardServiceDelegate( 474): onScreenTurnedOn(): no keyguard service!
D/WindowManagerService( 474): Window{10844d80 u0 com.android.launcher3/com.android.launcher3.Launcher} ==========setInputFocusLw ========== =======
V/Sensors ( 474): setDelay - sensor Accelerometer (handle 4), rate 66 ms (15.00 Hz)
E/SQLiteLog( 828): (1) no such table: album_info
D/OpenGLRenderer( 924): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
D/Atlas ( 924): Validating map…
D/LyricManager( 1444): lrc layout w = 1110, lrc layout h = 115, left = 85, top = 595
W/BackupManagerService( 474): dataChanged but no participant pkg=‘com.android.providers.settings’ uid=10011
I/System.out( 924): ============================================================FourScreenCircleMenuView
D/PhoneStatusBar( 924): disable: < EXPAND* icons alerts system_info BACK* HOME* RECENT* clock SEARCH* >
W/ResourceType( 1327): No package identifier when getting value for resource number 0x00000000
W/PackageManager( 1327): Failure retrieving resources for com.android.speechrecorder: Resource ID #0x0
D/PhoneStatusBar( 924): heads up is enabled
D/Launcher.Model( 1327): going to save icon bitmap for info=ShortcutInfo(title=Galleryintent=Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.gallery3d/.app.Gallery (has extras) }id=4 type=0 container=-101 screen=5 cellX=5 cellY=0 spanX=1 spanY=1 dropPos=null user=UserHandle{0})
D/StatusBar( 924): user hasn’t seen notification about hidden notifications
D/StatusBar( 924): insecure lockscreen, skipping notification
W/BackupManagerService( 474): dataChanged but no participant pkg=‘com.android.launcher3’ uid=10032
D/Launcher.Model( 1327): going to save icon bitmap for info=ShortcutInfo(title=Settingsintent=Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.settings/.Settings (has extras) }id=2 type=0 container=-101 screen=2 cellX=2 cellY=0 spanX=1 spanY=1 dropPos=null user=UserHandle{0})
D/Launcher.Model( 1327): going to save icon bitmap for info=ShortcutInfo(title=Browserintent=Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 pkg=com.android.browser cmp=com.android.browser/.BrowserActivity (has extras) }id=3 type=0 container=-101 screen=4 cellX=4 cellY=0 spanX=1 spanY=1 dropPos=null user=UserHandle{0})
V/MediaScanner( 828): pruneDeadThumbnailFiles… android.database.sqlite.SQLiteCursor@1071981
V/MediaScanner( 828): /pruneDeadThumbnailFiles… android.database.sqlite.SQLiteCursor@1071981
D/Launcher.Model( 1327): going to save icon bitmap for info=ShortcutInfo(title=Videointent=Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=android.rk.RockVideoPlayer/.RockVideoPlayer (has extras) }id=1 type=0 container=-101 screen=1 cellX=1 cellY=0 spanX=1 spanY=1 dropPos=null user=UserHandle{0})
D/MediaScannerService( 828): done scanning volume external
D/ViewRootImpl( 1327): 1280<<<<<< BACK FROM relayoutnull
W/PhoneWindowManager( 474): Keyguard drawn timeout. Setting mKeyguardDrawComplete
I/mali_so ( 924): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 780; [Func] : base_context_deal_with_version_affairs_rk_ext;
I/mali_so ( 924): arm_release_ver of this mali_so is ‘r6p0-02rel0’, rk_so_ver is ‘11@0’, built at ‘16:20:19’ for 3288w, on ‘Aug 1 2016’.
I/mali_so ( 924): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 807; [Func] : base_context_deal_with_version_affairs_rk_ext;
I/mali_so ( 924): mali_ver_property has been set to ‘r6p0-02rel0-13-11@0’, to return.
W/gralloc ( 165): Debugmem The fd=47, in vmalloc !!! Ishwc=0
I/SurfaceFlinger( 165): Boot is finished (60037 ms)
I/Choreographer( 924): Skipped 346 frames! The application may be doing too much work on its main thread.
D/ViewRootImpl( 924): changeCanvasOpacity: opaque=true
D/mmk ( 924): updateCallbackLocked.+++++++
D/mmk ( 924): postSingleUpdate.+++++++++ status = 1
D/ViewRootImpl( 924): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillx25)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#30 sim=#10 ty=2000 fl=#81840048 fmt=-3 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.android.systemuitoken=null}
D/ViewRootImpl( 924): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillx25)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#30 sim=#10 ty=2000 fl=#81840048 fmt=-3 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.android.systemuitoken=null}
I/OpenGLRenderer( 924): Initialized EGL, version 1.4
D/OpenGLRenderer( 924): Enabling debug mode 0
W/gralloc ( 165): Debugmem The fd=35, in vmalloc !!! Ishwc=0
W/gralloc ( 165): Debugmem The fd=46, in vmalloc !!! Ishwc=0
W/gralloc ( 165): Debugmem The fd=49, in vmalloc !!! Ishwc=0
D/ViewRootImpl( 924): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#800053 sim=#31 ty=2024 fl=#1820100 fmt=-3 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.android.systemuitoken=null}
D/ViewRootImpl( 924): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#800053 sim=#31 ty=2024 fl=#1820100 fmt=-3 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.android.systemuitoken=null}
D/ViewRootImpl( 924): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 ty=2019 fl=#1840068 fmt=-3 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.android.systemuitoken=null}
D/ViewRootImpl( 924): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 sim=#20 ty=2019 fl=#1840068 fmt=-3 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.android.systemuitoken=null}
W/gralloc ( 165): Debugmem The fd=57, in vmalloc !!! Ishwc=0
W/gralloc ( 165): Debugmem The fd=68, in vmalloc !!! Ishwc=0
W/gralloc ( 165): Debugmem The fd=69, in vmalloc !!! Ishwc=0
D/ViewRootImpl( 924): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillx250)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#30 ty=2014 fl=#1820328 fmt=-3 wanim=0x7f0b002e surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.android.systemuitoken=null}
D/ViewRootImpl( 924): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillx250)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#30 sim=#20 ty=2014 fl=#1820328 fmt=-3 wanim=0x7f0b002e surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.android.systemuitoken=null}
E/NetworkController( 924): onReceive ETHERNET_STATE_CHANGED_ACTION
D/PhoneStatusBar( 924): disable: < expand* icons alerts system_info back* home* recent* clock search* >
D/TelephonyProvider( 1177): dbh.onCreate:- db=SQLiteDatabase: /data/data/com.android.providers.telephony/databases/telephony.db
D/TelephonyProvider( 1177): dbh.onOpen: ok, queried table=siminfo
D/TelephonyProvider( 1177): dbh.onOpen: ok, queried table=carriers
I/ActivityManagerService( 474): Start proc 1491:com.android.smspush/u0a53 for service com.android.smspush/.WapPushManager
D/GpsLocationProvider( 474): received SIM realted action:
E/DcSwitchStateMachine-0( 1177): DctController is not ready
E/ConnectivityService( 474): Failed to find Messenger in unregisterNetworkFactory
D/GpsLocationProvider( 474): SIM MCC/MNC is still not available
D/ConnectivityService( 474): Got NetworkFactory Messenger for Telephony
I/Choreographer( 924): Skipped 79 frames! The application may be doing too much work on its main thread.
I/PackageManager( 474): Running dexopt on: /system/app/WAPPushManager/WAPPushManager.apk pkg=com.android.smspush isa=arm vmSafeMode=false
D/OpenGLRenderer( 924): setting property extraRasterBucket to 0.95
D/OpenGLRenderer( 924): failed
D/OpenGLRenderer( 924): setting property extraRasterBucket to 0.0
I/dex2oat ( 1515): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/WAPPushManager/WAPPushManager.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@WAPPushManager@WAPPushManager.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 1515): Decided to run without swap.
I/dex2oat ( 1515): dex2oat took 28.058ms (threads: 4) arena alloc=0B java alloc=65KB native alloc=77KB free=38KB
D/DisplayManager( 1491): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/BluetoothManagerService( 474): Message: 20
D/BluetoothManagerService( 474): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@2c3ab3a:true
D/BluetoothManagerService( 474): Trying to bind to profile: 1, while Bluetooth was disabled
I/Telephony( 1177): TtyManager: updateUiTtyMode -1 → 0
E/installd( 172): Unable to unlink boot marker at /data/dalvik-cache/arm/.booting, error=No such file or directory
E/ActivityManagerService( 474): Unable to mark boot complete for abi: armeabi-v7a
I/SystemServiceManager( 474): Starting phase 1000
D/DisplayManager( 924): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
V/KeyguardUpdateMonitor( 924): action android.intent.action.SIM_STATE_CHANGED state: NOT_READY slotId: 0 subid: 0
D/KeyguardUpdateMonitor( 924): handleSimStateChange(subId=0, slotId=0, state=NOT_READY)
D/BluetoothManagerService( 474): Retrieving Bluetooth Adapter name and address…
D/BluetoothManagerService( 474): getNameAndAddress(): mBluetooth = null mBinding = false
D/BluetoothManagerService( 474): Message: 200
D/BluetoothManagerService( 474): MESSAGE_GET_NAME_AND_ADDRESS
D/BluetoothManagerService( 474): Binding to service to get name and address
V/WindowManagerService( 474): Not allow rotate, force to ROTATION_0
V/KeyguardUpdateMonitor( 924): onSubscriptionInfoChanged()
V/KeyguardUpdateMonitor( 924): onSubscriptionInfoChanged: list is null
I/ActivityManagerService( 474): Start proc 1530:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
I/ActivityManagerService( 474): Start proc 1549:com.android.keychain/1000 for service com.android.keychain/.KeyChainService
I/PackageManager( 474): Running dexopt on: /system/app/Bluetooth/Bluetooth.apk pkg=com.android.bluetooth isa=arm vmSafeMode=false
I/dex2oat ( 1565): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Bluetooth/Bluetooth.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Bluetooth@Bluetooth.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
D/SurfaceFlinger( 165): shader cache generated - 24 shaders in 225.396790 ms
W/gralloc ( 165): Debugmem The fd=81, in vmalloc !!! Ishwc=0
W/gralloc ( 165): Debugmem The fd=74, in vmalloc !!! Ishwc=0
W/gralloc ( 165): Debugmem The fd=75, in vmalloc !!! Ishwc=0
I/dex2oat ( 1565): Decided to run without swap.
I/dex2oat ( 1565): dex2oat took 375.798ms (threads: 4) arena alloc=0B java alloc=1272KB native alloc=399KB free=336KB
I/Choreographer( 924): Skipped 31 frames! The application may be doing too much work on its main thread.
D/DisplayManager( 1530): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/DisplayManager( 1549): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
W/ResourcesManager( 1530): Asset path ‘/system/framework/javax.obex.jar’ does not exist or contains no resources.
I/RecoverySystem( 474): Deleted: /cache/recovery/log
D/DisplayOutputManager( 1197): main display iface num is 1
D/DisplayOutputManager( 1197): VGA
I/BootReceiver( 474): Copying /proc/last_kmsg to DropBox (SYSTEM_LAST_KMSG)
D/DisplayOutputManager( 1197): aux display iface num is 1
D/DisplayOutputManager( 1197): HDMI
D/HdmiReceiver( 1197): hdmi receiver action=android.intent.action.BOOT_COMPLETED
D/HdmiReceiver( 1197): BOOT_COMPLETED
D/StressTest( 1158): =========onReceive===rebootFlag:0
E/SystemUIBootReceiver( 924): BootReceiver:config.disable_systemui=true
D/AdapterServiceConfig( 1530): Adding HeadsetService
D/AdapterServiceConfig( 1530): Adding A2dpService
D/AdapterServiceConfig( 1530): Adding HidService
D/AdapterServiceConfig( 1530): Adding HealthService
D/AdapterServiceConfig( 1530): Adding PanService
D/AdapterServiceConfig( 1530): Adding GattService
D/BluetoothServiceJni( 1530): int android::check_wifi_chip_type_string(char*): AP6210
D/BluetoothServiceJni( 1530): void android::classInitNative(JNIEnv*, jclass), load bluetooth.default.so
V/TestService( 1357): action:android.intent.action.BOOT_COMPLETED
V/TestService( 1357): getSystemAbnormalRestartTime0:0
V/TestService( 1357): setSystemStart0:false
V/TestService( 1357): SystemUtils.isBootComplete()=true
I/art ( 474): WaitForGcToComplete blocked for 33.355ms for cause Explicit
I/BootReceiver( 474): Copying /cache/recovery/last_kmsg to DropBox (SYSTEM_RECOVERY_KMSG)
D/BluetoothManagerService( 474): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@283ff38d:true
D/BluetoothAdapterState( 1530): make
I/art ( 474): Explicit concurrent mark sweep GC freed 807(70KB) AllocSpace objects, 5(688KB) LOS objects, 33% free, 7MB/10MB, paused 836us total 38.121ms
I/BluetoothAdapterState( 1530): Entering OffState
I/bluedroid( 1530): init
E/bt-btif ( 1530): btif_config_get(L190): assert failed: section && *section && key && *key && name && name && bytes && type
I/BootReceiver( 474): Copying audit failures to DropBox
V/TestService( 1357): setLastShutDownIsUnsafety =false
I/BootReceiver( 474): Copied 0 worth of audits to DropBox
V/TestService( 1357): setSystemStart1:true
W/ContextImpl( 1357): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1709 android.content.ContextWrapper.startService:516 android.content.ContextWrapper.startService:516 com.rockchip.devicetest.BootReceiver.onReceive:85 android.app.ActivityThread.handleReceiver:2629
I/BootReceiver( 474): Checking for fsck errors
I/bte_conf( 1530): bte_load_conf attempt to load stack conf from /etc/bluetooth/bt_stack.conf
I/bte_conf( 1530): bte_load_ble_conf attempt to load ble stack conf from /etc/bluetooth/ble_stack.conf
E/bt_osi_config( 1530): config_new unable to open file ‘/etc/bluetooth/ble_stack.conf’: No such file or directory
I/bte_conf( 1530): bte_load_ble_conf file >/etc/bluetooth/ble_stack.conf< not found
V/TestService( 1357): getSystemAbnormalRestartTime1:0
I/bluedroid( 1530): get_profile_interface socket
I/GKI_LINUX( 1530): gki_task_entry task_id=1 [BTIF] starting
I/bluedroid( 1530): get_profile_interface map_client
D/BluetoothAdapterProperties( 1530): Address is:22:22:FD:96:E7:27
D/BluetoothManagerService( 474): Bluetooth Adapter name changed to avatar_robot
D/BluetoothAdapterProperties( 1530): Name is: avatar_robot
D/BluetoothManagerService( 474): Stored Bluetooth name: avatar_robot
I/ActivityManagerService( 474): Start proc 1583:com.rockchip.mediacenter/u0a54 for broadcast com.rockchip.mediacenter/.BootReceiver
D/BluetoothManagerService( 474): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
D/BluetoothManagerService( 474): Message: 40
D/BluetoothManagerService( 474): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
I/bluedroid( 1530): config_hci_snoop_log
D/BluetoothManagerService( 474): Message: 201
D/BluetoothManagerService( 474): MESSAGE_SAVE_NAME_AND_ADDRESS
D/BluetoothAdapterState( 1530): CURRENT_STATE=OFF, MESSAGE = USER_TURN_ON
D/BluetoothAdapterProperties( 1530): Setting state to 11
I/BluetoothAdapterState( 1530): Bluetooth adapter state changed: 10-> 11
D/BluetoothAdapterState:( 1530): transitionTo: destState=PendingCommandState
D/BluetoothBondStateMachine( 1530): make
I/BluetoothBondStateMachine( 1530): StableState(): Entering Off State
D/BluetoothAdapterService( 1530): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@3f514502
D/HeadsetService( 1530): Received start request. Starting profile…
I/BluetoothHeadsetServiceJni( 1530): classInitNative: succeeds
D/HeadsetStateMachine( 1530): make
D/HeadsetStateMachine( 1530): max_hf_connections = 1
I/bluedroid( 1530): get_profile_interface handsfree
D/HeadsetStateMachine( 1530): Enter Disconnected: -2, size: 0
I/BluetoothAdapterState( 1530): Entering PendingCommandState State: isTurningOn()=true, isTurningOff()=false
D/BluetoothA2dp( 474): Proxy object connected
D/BluetoothAdapter( 474): 112898371: getState() : mService = null. Returning STATE_OFF
D/A2dpService( 1530): Received start request. Starting profile…
I/BluetoothAvrcpServiceJni( 1530): classInitNative: succeeds
D/BluetoothA2dp( 924): Proxy object connected
I/bluedroid( 1530): get_profile_interface avrcp
I/PackageManager( 474): Running dexopt on: /system/app/eHomeMediaCenter_box/eHomeMediaCenter_box.apk pkg=com.rockchip.mediacenter isa=arm vmSafeMode=false
E/RemoteController( 1530): Cannot set synchronization mode on an unregistered RemoteController
I/BluetoothA2dpServiceJni( 1530): classInitNative: succeeds
D/A2dpStateMachine( 1530): make
I/bluedroid( 1530): get_profile_interface a2dp
I/GKI_LINUX( 1530): gki_task_entry task_id=2 [A2DP-MEDIA] starting
D/A2dpStateMachine( 1530): Enter Disconnected: -2
I/BluetoothHidServiceJni( 1530): classInitNative: succeeds
D/TestService( 1357): onStartCommand,from:boot
I/dex2oat ( 1605): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/eHomeMediaCenter_box/eHomeMediaCenter_box.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@eHomeMediaCenter_box@eHomeMediaCenter_box.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
D/DeviceTest-FileUitls( 1357): find file:/mnt/internal_sd/Music
D/DeviceTest-FileUitls( 1357): find file:/mnt/internal_sd/Podcasts
D/DeviceTest-FileUitls( 1357): find file:/mnt/internal_sd/Ringtones
D/DeviceTest-FileUitls( 1357): find file:/mnt/internal_sd/Alarms
D/DeviceTest-FileUitls( 1357): find file:/mnt/internal_sd/Notifications
D/DeviceTest-FileUitls( 1357): find file:/mnt/internal_sd/Pictures
D/DeviceTest-FileUitls( 1357): find file:/mnt/internal_sd/Movies
D/DeviceTest-FileUitls( 1357): find file:/mnt/internal_sd/Download
D/DeviceTest-FileUitls( 1357): find file:/mnt/internal_sd/DCIM
D/TestService( 1357): Rock Recv boot action. 65054
D/TestService( 1357): Rock check storage inter_path=/mnt/internal_sd
D/TestService( 1357): Rock check storage, mounted.
I/dex2oat ( 1605): Decided to run without swap.
I/dex2oat ( 1605): dex2oat took 1.167s (threads: 4) arena alloc=0B java alloc=1956KB native alloc=420KB free=155KB
D/BluetoothInputDevice( 924): Proxy object connected
D/HidService( 1530): Received start request. Starting profile…
I/bluedroid( 1530): get_profile_interface hidhost
I/BluetoothHealthServiceJni( 1530): classInitNative: succeeds
D/HealthService( 1530): Received start request. Starting profile…
I/bluedroid( 1530): get_profile_interface health
I/BluetoothPanServiceJni( 1530): classInitNative(L105): succeeds
D/PanService( 1530): Received start request. Starting profile…
D/BluetoothPanServiceJni( 1530): initializeNative(L110): pan
I/bluedroid( 1530): get_profile_interface pan
D/HeadsetStateMachine( 1530): Proxy object connected
D/BluetoothPan( 924): BluetoothPAN Proxy object connected
I/BtGatt.JNI( 1530): classInitNative(L873): classInitNative: Success!
D/BtGatt.DebugUtils( 1530): handleDebugAction() action=null
D/BtGatt.GattService( 1530): Received start request. Starting profile…
D/BtGatt.GattService( 1530): start()
I/bluedroid( 1530): get_profile_interface gatt
D/DisplayManager( 1583): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/BtGatt.AdvertiseManager( 1530): advertise manager created
D/HeadsetStateMachine( 1530): Disconnected process message: 10, size: 0
D/HeadsetPhoneState( 1530): sendDeviceStateChanged. mService=0 mSignal=0 mRoam=0 mBatteryCharge=5
D/HeadsetStateMachine( 1530): Disconnected process message: 11, size: 0
D/BluetoothAdapterState( 1530): CURRENT_STATE=PENDING, MESSAGE = STARTED, isTurningOn=true, isTurningOff=false
I/bluedroid( 1530): enable
I/GKI_LINUX( 1530): gki_task_entry task_id=0 [BTU] starting
I/bt-btu ( 1530): btu_task pending for preload complete event
I/bt_hci_bdroid( 1530): init
D/RkWifiCtrl( 1530): check_wifi_chip_type_string: AP6210
D/bt_vendor( 1530): vendor_open load libbt-vendor.so
I/bt_vendor( 1530): init
I/bt_vnd_conf( 1530): Attempt to load conf from /etc/bluetooth/bt_vendor.conf
I/bt_vnd_conf( 1530): vnd_load_conf file >/etc/bluetooth/bt_vendor.conf< not found
D/bt_hci_bdroid( 1530): init, use hci h4
D/bt_userial( 1530): userial_init
D/bt_upio ( 1530): Delay 500ms for bluetooth power up
I/ActivityManagerService( 474): Start proc 1621:com.rockchip.mediacenter:service/u0a54 for service com.rockchip.mediacenter/.SystemDeviceService
D/DisplayManager( 1621): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/TelephonyDebugService( 1177): TelephonyDebugService()
I/Telephony( 1177): PstnIncomingCallNotifier: Registering: Handler (com.android.internal.telephony.gsm.GSMPhone) {3d48a5d3}
D/WIFI ( 474): Registering NetworkFactory
D/WIFI_UT ( 474): Registering NetworkFactory
D/ConnectivityService( 474): Got NetworkFactory Messenger for WIFI
D/ConnectivityService( 474): Got NetworkFactory Messenger for WIFI_UT
D/WIFI ( 474): got request NetworkRequest [ id=1, legacyType=-1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
D/WIFI_UT ( 474): got request NetworkRequest [ id=1, legacyType=-1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
I/ActivityManagerService( 474): Start proc 1643:com.android.calendar/u0a17 for broadcast com.android.calendar/.UpgradeReceiver
I/PackageManager( 474): Running dexopt on: /system/app/Calendar/Calendar.apk pkg=com.android.calendar isa=arm vmSafeMode=false
D/DeviceTest-FileUitls( 1357): find file:/mnt/internal_sd/eHomeMediaCenter
I/dex2oat ( 1661): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Calendar/Calendar.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Calendar@Calendar.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 1661): Decided to run without swap.
I/dex2oat ( 1661): dex2oat took 791.635ms (threads: 4) arena alloc=0B java alloc=1979KB native alloc=390KB free=497KB
I/bt_userial_vendor( 1530): userial vendor open: opening /dev/ttyS0
I/bt_userial_vendor( 1530): device fd = 55 open
D/bt_userial( 1530): Entering userial_read_thread()
I/bt_hwcfg( 1530): bt vendor lib: set UART baud 1500000
D/bt_hwcfg( 1530): Chipset BCM4335C0
D/bt_hwcfg( 1530): Target name = [BCM4335C0]
I/bt_hwcfg( 1530): BT module name is: AP6210, p_chip_id_str = BCM4335C0
I/bt_hwcfg( 1530): Target HCD file name is: bcm4339a0.hcd
I/bt_hwcfg( 1530): Found patchfile: /vendor/firmware//bcm4339a0.hcd
E/BluetoothManagerService( 474): waitForOnOff time out
D/TestService( 1357): It is not in factory/aging test mode.
D/DisplayManager( 1643): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/BluetoothManagerService( 474): Stored Bluetoothaddress: 22:22:FD:96:E7:27
I/InputReader( 474): Reconfiguring input devices. changes=0x00000010
D/BluetoothAdapterState( 1530): CURRENT_STATE=PENDING, MESSAGE = USER_TURN_ON, isTurningOn=true, isTurningOff=false
I/BluetoothAdapterState( 1530): CURRENT_STATE=PENDING: Deferring request USER_TURN_OFF
I/chip.devicetest( 1357): type=1400 audit(0.0:14): avc: denied { write } for name=“force_usb_mode” dev=“sysfs” ino=12777 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
D/BackupManagerService( 474): Received broadcast Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.android.provision flg=0x4000010 (has extras) }
D/BackupManagerService( 474): Received broadcast Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.android.settings flg=0x4000010 (has extras) }
D/ExtensionsFactory( 1643): No custom extensions.
I/ActivityManagerService( 474): Start proc 1673:com.android.providers.calendar/u0a1 for broadcast com.android.providers.calendar/.CalendarReceiver
D/DisplayManager( 1673): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
W/ResourcesManager( 1673): Asset path ‘/system/framework/android.test.runner.jar’ does not exist or contains no resources.
I/bt_hwcfg( 1530): bt vendor lib: set UART baud 115200
D/bt_hwcfg( 1530): Settlement delay – 200 ms
I/bt_hwcfg( 1530): Setting fw settlement delay to 200
I/CalendarDatabaseHelper( 1673): Bootstrapping database
I/CalendarProvider2( 1673): Created com.android.providers.calendar.CalendarAlarmManager@1a1741e4(com.android.providers.calendar.CalendarProvider2@c52b64d)
I/bt_hwcfg( 1530): Setting local bd addr to 22:22:FD:96:E7:27
I/ActivityManagerService( 474): Start proc 1694:com.android.managedprovisioning/u0a6 for broadcast com.android.managedprovisioning/.BootReminder
I/bt_hwcfg( 1530): vendor lib fwcfg completed
I/bt-btu ( 1530): btu_task received preload complete event
I/ ( 1530): BTE_InitTraceLevels – TRC_HCI
I/ ( 1530): BTE_InitTraceLevels – TRC_L2CAP
I/ ( 1530): BTE_InitTraceLevels – TRC_RFCOMM
I/ ( 1530): BTE_InitTraceLevels – TRC_AVDT
I/ ( 1530): BTE_InitTraceLevels – TRC_AVRC
I/ ( 1530): BTE_InitTraceLevels – TRC_A2D
I/ ( 1530): BTE_InitTraceLevels – TRC_BNEP
I/ ( 1530): BTE_InitTraceLevels – TRC_BTM
I/ ( 1530): BTE_InitTraceLevels – TRC_GAP
I/ ( 1530): BTE_InitTraceLevels – TRC_PAN
I/ ( 1530): BTE_InitTraceLevels – TRC_SDP
I/ ( 1530): BTE_InitTraceLevels – TRC_GATT
I/ ( 1530): BTE_InitTraceLevels – TRC_SMP
I/ ( 1530): BTE_InitTraceLevels – TRC_BTAPP
I/ ( 1530): BTE_InitTraceLevels – TRC_BTIF
E/bt-btm ( 1530): BTM_SecRegister:p_cb_info->p_le_callback == 0xaf9242c9
E/bt-btm ( 1530): BTM_SecRegister: btm_cb.api.p_le_callback = 0xaf9242c9
E/bt-btif ( 1530): Calling BTA_HhEnable
E/bt-btif ( 1530): btif_config_get(L190): assert failed: section && section && key && key && name && name && bytes && type
E/bt-btif ( 1530): btif_storage_get_adapter_property service_mask:0x2140040
W/bt-btm ( 1530): Stopping oneshot timer
D/BluetoothAdapterProperties( 1530): Scan Mode:20
D/BluetoothAdapterProperties( 1530): Discoverable Timeout:120
D/bt_vendor( 1530): SCO config
D/DisplayManager( 1694): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/bte_conf( 1530): Device ID record 1 : primary
D/bte_conf( 1530): vendorId = 000f
D/bte_conf( 1530): vendorIdSource = 0001
D/bte_conf( 1530): product = 1200
D/bte_conf( 1530): version = 1436
D/bte_conf( 1530): clientExecutableURL =
D/bte_conf( 1530): serviceDescription =
D/bte_conf( 1530): documentationURL =
D/bte_conf( 1530): bte_load_did_conf no section named DID2.
D/BluetoothPanServiceJni( 1530): control_state_callback(L61): state:0, local_role:3, ifname:bt-pan
D/BluetoothAdapterState( 1530): CURRENT_STATE=PENDING, MESSAGE = ENABLE_READY, isTurningOn=true, isTurningOff=false
D/BluetoothAdapterProperties( 1530): ScanMode = 20
D/BluetoothAdapterProperties( 1530): State = 11
D/BluetoothAdapterState:( 1530): transitionTo: destState=OnState
D/BluetoothAdapterProperties( 1530): Scan Mode:21
D/BluetoothAdapterProperties( 1530): Setting state to 12
I/BluetoothAdapterState( 1530): Bluetooth adapter state changed: 11-> 12
I/BluetoothAdapterState( 1530): Entering On State
D/BluetoothAdapterState( 1530): CURRENT_STATE=ON, MESSAGE = USER_TURN_OFF
D/BluetoothAdapterProperties( 1530): Setting state to 13
I/BluetoothAdapterState( 1530): Bluetooth adapter state changed: 12-> 13
D/BluetoothAdapterProperties( 1530): onBluetoothDisable()
I/BluetoothAdapterState( 1530): Entering PendingCommandState State: isTurningOn()=false, isTurningOff()=true
D/BluetoothAdapterState( 1530): CURRENT_STATE=PENDING, MESSAGE = BEGIN_DISABLE, isTurningOn=false, isTurningOff=true
D/btif_config_util( 1530): btif_config_save_file(L188): in file name:/data/misc/bluedroid/bt_config.new
W/bt-btif ( 1530): bta_dm_disable BTA_DISABLE_DELAY set to 200 ms
W/bt-l2cap( 1530): L2CAP - PSM: 0x0019 not found for deregistration
W/bt-l2cap( 1530): L2CAP - PSM: 0x0017 not found for deregistration
E/bt_h4 ( 1530): vendor lib postload completed
W/bt-btif ( 1530): ag scb idx 1 not allocated
E/bt-btif ( 1530): BTA AG is already disabled, ignoring …
D/bt_userial( 1530): RX termination
W/bt_userial( 1530): select_read return size <=0:-1, exiting userial_read_thread
D/bt_userial( 1530): Leaving userial_read_thread()
D/bt_userial( 1530): userial_close_reader Joined userial reader thread: 0
D/bt_hwcfg( 1530): hw_epilog_process
I/bt_userial_vendor( 1530): device fd = 55 close
D/MediaScannerService( 828): start scanning volume internal: [/system/media, /oem/media]
D/xzj ( 828): true---------------------------ooooooooooo,stop mtp service---------------false
I/ActivityManagerService( 474): Start proc 1719:com.android.onetimeinitializer/u0a8 for broadcast com.android.onetimeinitializer/.OneTimeInitializerReceiver
I/art ( 175): Explicit concurrent mark sweep GC freed 703(30KB) AllocSpace objects, 0(0B) LOS objects, 86% free, 159KB/1183KB, paused 151us total 13.404ms
I/art ( 175): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 86% free, 159KB/1183KB, paused 154us total 12.810ms
I/art ( 175): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 86% free, 159KB/1183KB, paused 152us total 12.765ms
I/PackageManager( 474): Running dexopt on: /system/priv-app/OneTimeInitializer/OneTimeInitializer.apk pkg=com.android.onetimeinitializer isa=arm vmSafeMode=false
I/dex2oat ( 1737): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/OneTimeInitializer/OneTimeInitializer.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@OneTimeInitializer@OneTimeInitializer.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 1737): Decided to run without swap.
I/dex2oat ( 1737): dex2oat took 66.071ms (threads: 4) arena alloc=0B java alloc=61KB native alloc=77KB free=38KB
D/DisplayManager( 1719): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
V/OneTimeInitializerRece( 1719): OneTimeInitializerReceiver.onReceive
I/OneTimeInitializerServ( 1719): Updating to version 1.
E/ActivityThread( 1719): Failed to find provider info for com.android.launcher2.settings
E/SQLiteLog( 828): (1) no such table: files
D/AlertReceiver( 1643): onReceive: a=android.intent.action.BOOT_COMPLETED Intent { act=android.intent.action.BOOT_COMPLETED flg=0x8000010 cmp=com.android.calendar/.alerts.AlertReceiver (has extras) }
I/GKI_LINUX( 1530): gki_task task_id=0 [BTU] terminating
I/GKI_LINUX( 1530): GKI_exit_task 0 done
I/GKI_LINUX( 1530): GKI_shutdown(): task [BTU] terminated
D/BluetoothAdapterState( 1530): CURRENT_STATE=PENDING, MESSAGE = DISABLED, isTurningOn=false, isTurningOff=true
D/HeadsetService( 1530): Received stop request…Stopping profile…
I/CalendarProvider2( 1673): Sending notification intent: Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar }
W/ContentResolver( 1673): Failed to get type for: content://com.android.calendar (Unknown URL content://com.android.calendar)
D/AlertUtils( 1643): Flushing old alerts from shared prefs table
I/ActivityManagerService( 474): Start proc 1747:com.android.camera2/u0a18 for broadcast com.android.camera2/com.android.camera.DisableCameraReceiver
D/HeadsetStateMachine( 1530): transitionTo: destState=QuittingState
D/HeadsetStateMachine( 1530): Exit Disconnected: -1
D/A2dpService( 1530): Received stop request…Stopping profile…
D/A2dpStateMachine( 1530): transitionTo: destState=QuittingState
D/BluetoothAdapterState( 1530): Stopping profile services that were post enabled
D/A2dpStateMachine( 1530): Exit Disconnected: -1
D/AlertService( 1643): 0 Action = android.intent.action.BOOT_COMPLETED
D/BluetoothA2dp( 474): Proxy object disconnected
D/BluetoothA2dp( 924): Proxy object disconnected
D/HidService( 1530): Received stop request…Stopping profile…
D/AlertService( 1643): Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null
D/BluetoothInputDevice( 924): Proxy object disconnected
D/HealthService( 1530): Received stop request…Stopping profile…
D/HeadsetStateMachine( 1530): Unbinding service…
W/BluetoothHeadsetServiceJni( 1530): Cleaning up Bluetooth Handsfree Interface…
W/BluetoothHeadsetServiceJni( 1530): Cleaning up Bluetooth Handsfree callback object
D/PanService( 1530): Received stop request…Stopping profile…
D/BluetoothPan( 924): BluetoothPAN Proxy object disconnected
D/BtGatt.GattService( 1530): Received stop request…Stopping profile…
D/BtGatt.GattService( 1530): stop()
D/BtGatt.AdvertiseManager( 1530): advertise clients cleared
I/GKI_LINUX( 1530): gki_task task_id=2 [A2DP-MEDIA] terminating
I/GKI_LINUX( 1530): GKI_exit_task 2 done
I/GKI_LINUX( 1530): GKI_shutdown(): task [A2DP-MEDIA] terminated
W/BluetoothHidServiceJni( 1530): Cleaning up Bluetooth HID Interface…
W/bt-btif ( 1530): cleanup: HH disabling or disabled already, status = 0
W/BluetoothHidServiceJni( 1530): Cleaning up Bluetooth GID callback object
W/BluetoothHealthServiceJni( 1530): Cleaning up Bluetooth Health Interface…
W/BluetoothHealthServiceJni( 1530): Cleaning up Bluetooth Health object
W/BluetoothPanServiceJni( 1530): Cleaning up Bluetooth PAN Interface…
W/BluetoothPanServiceJni( 1530): Cleaning up Bluetooth PAN callback object
D/BtGatt.GattService( 1530): cleanup()
D/BluetoothAdapterState( 1530): CURRENT_STATE=PENDING, MESSAGE = STOPPED, isTurningOn=false, isTurningOff=true
W/bt-btif ( 1530): GATTC Module not enabled/already disabled
W/bt-btif ( 1530): GATTS Module not enabled/already disabled
D/BluetoothAdapterState:( 1530): transitionTo: destState=OffState
D/BluetoothAdapterProperties( 1530): Setting state to 10
I/BluetoothAdapterState( 1530): Bluetooth adapter state changed: 13-> 10
D/AlarmScheduler( 1643): No events found starting within 1 week.
I/PackageManager( 474): Running dexopt on: /system/app/Camera2/Camera2.apk pkg=com.android.camera2 isa=arm vmSafeMode=false
I/dex2oat ( 1766): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Camera2/Camera2.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Camera2@Camera2.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
D/BluetoothManagerService( 474): unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@17d4259e mBinding = false
D/BluetoothManagerService( 474): Sending unbind request.
I/dex2oat ( 1766): Decided to run without swap.
I/dex2oat ( 1766): dex2oat took 947.667ms (threads: 4) arena alloc=0B java alloc=2MB native alloc=465KB free=738KB
D/BluetoothAdapterState:( 1530): transitionTo: destState=QuittingState
D/BondStateMachine:( 1530): transitionTo: destState=QuittingState
I/GKI_LINUX( 1530): gki_task task_id=1 [BTIF] terminating
I/GKI_LINUX( 1530): GKI_exit_task 1 done
I/GKI_LINUX( 1530): GKI_shutdown(): task [BTIF] terminated
D/DisplayManager( 1747): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/BluetoothServiceJni( 1530): cleanupNative: return from cleanup
I/art ( 1530): System.exit called, status: 0
I/AndroidRuntime( 1530): VM exiting with result code 0, cleanup skipped.
I/ActivityManagerService( 474): Process com.android.bluetooth (pid 1530) has died
D/CAM_MemoryManagerImpl( 1747): Max native memory: 358 MB
I/ActivityManagerService( 474): Start proc 1773:com.android.deskclock/u0a21 for broadcast com.android.deskclock/.AlarmInitReceiver
I/PackageManager( 474): Running dexopt on: /system/app/DeskClock/DeskClock.apk pkg=com.android.deskclock isa=arm vmSafeMode=false
I/dex2oat ( 1791): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/DeskClock/DeskClock.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@DeskClock@DeskClock.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 1791): Decided to run without swap.
E/MetadataRetrieverClient( 171): failed to extract an album art
I/dex2oat ( 1791): dex2oat took 515.530ms (threads: 4) arena alloc=0B java alloc=1111KB native alloc=353KB free=226KB
D/DisplayManager( 1773): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
V/AlarmClock( 1773): AlarmInitReceiver android.intent.action.BOOT_COMPLETED
V/AlarmClock( 1773): AlarmInitReceiver - Reset timers and clear stopwatch data
V/AlarmClock( 1773): AlarmInitReceiver - resetting volume button default
I/AlarmClock( 1773): Alarms Table created
I/AlarmClock( 1773): Instance table created
I/AlarmClock( 1773): Cities table created
I/AlarmClock( 1773): Inserting default alarms
V/AlarmClock( 1773): AlarmInitReceiver finished
I/ActivityManagerService( 474): Start proc 1800:com.android.gallery3d/u0a27 for broadcast com.android.gallery3d/com.android.camera.DisableCameraReceiver
I/PackageManager( 474): Running dexopt on: /system/app/Gallery2/Gallery2.apk pkg=com.android.gallery3d isa=arm vmSafeMode=false
I/dex2oat ( 1818): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Gallery2/Gallery2.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Gallery2@Gallery2.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 1818): Decided to run without swap.
W/BackupManagerService( 474): dataChanged but no participant pkg=‘com.android.providers.settings’ uid=10004
I/dex2oat ( 1818): dex2oat took 1.660s (threads: 4) arena alloc=0B java alloc=3MB native alloc=574KB free=1237KB
D/DisplayManager( 1800): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/G:DisableCameraReceiver( 1800): back camera found: 0
I/LauncherIconVisibilityManager( 1143): Boot has been completed
I/LauncherIconVisibilityManager( 1143): Disable activity: ComponentInfo{com.android.inputmethod.latin/com.android.inputmethod.latin.setup.SetupActivity}
D/RKUpdateReceiver( 1250): action = android.intent.action.BOOT_COMPLETED
D/RKUpdateReceiver( 1250): RKUpdateReceiver recv ACTION_BOOT_COMPLETED.
W/ContextImpl( 1250): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1709 android.content.ContextWrapper.startService:516 android.content.ContextWrapper.startService:516 android.rockchip.update.service.RKUpdateReceiver.onReceive:59 android.app.ActivityThread.handleReceiver:2629
W/ContextImpl( 1250): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1709 android.content.ContextWrapper.startService:516 android.content.ContextWrapper.startService:516 android.rockchip.update.service.RKUpdateReceiver.onReceive:65 android.app.ActivityThread.handleReceiver:2629
I/android_rockchip_update_UpdateService.cpp( 1250): JNI_OnLoad
D/RKUpdateService( 1250): starting RKUpdateService, version is 1.8.1
D/RKUpdateService( 1250): remote uri is http://www.rockchip.com:2300/OtaUpdater/android?product=firefly-rk3288&version=1.0.0&sn=GB8ZATWHFM&country=US&language=en
D/RKUpdateService( 1250): remote uri backup is http://192.168.1.143:2300/OtaUpdater/android?product=firefly-rk3288&version=1.0.0&sn=GB8ZATWHFM&country=US&language=en
W/Launcher( 1327): setApplicationContext called twice! old=com.android.launcher3.LauncherApplication@c52b64d new=com.android.launcher3.LauncherApplication@c52b64d
D/RKUpdateService( 1250): first startup!!!
D/RKUpdateService( 1250): onStartCommand…
D/RKUpdateService( 1250): command = 1 delaytime = 20000
D/RKUpdateService( 1250): command = 2 delaytime = 25000
D/AlertReceiver( 1643): onReceive: a=android.intent.action.PROVIDER_CHANGED Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar flg=0x10 cmp=com.android.calendar/.alerts.AlertReceiver }
D/AlertService( 1643): 0 Action = android.intent.action.PROVIDER_CHANGED
E/SQLiteLog( 1673): (284) automatic index on view_events(_id)
I/ActivityManagerService( 474): Waited long enough for: ServiceRecord{119c367d u0 com.android.music/.MediaPlaybackService}
W/MediaScanner( 828): Error opening directory ‘/oem/media/’, skipping: No such file or directory.
D/MediaScannerService( 828): done scanning volume internal
D/MediaScannerService( 828): start scanning volume external: [/mnt/external_sd]
W/MediaScanner( 828): Error opening directory ‘/mnt/external_sd/’, skipping: Permission denied.
V/MediaScanner( 828): pruneDeadThumbnailFiles… android.database.sqlite.SQLiteCursor@1e2f87fe
V/MediaScanner( 828): /pruneDeadThumbnailFiles… android.database.sqlite.SQLiteCursor@1e2f87fe
D/MediaScannerService( 828): start scanning volume external: [/mnt/usb_storage]
V/MediaScanner( 828): pruneDeadThumbnailFiles… android.database.sqlite.SQLiteCursor@2207b5f
V/MediaScanner( 828): /pruneDeadThumbnailFiles… android.database.sqlite.SQLiteCursor@2207b5f
D/MediaScanner( 828): Skipping: /mnt/internal_sd/Android/
V/MediaScanner( 828): pruneDeadThumbnailFiles… android.database.sqlite.SQLiteCursor@17e5a9ac
V/MediaScanner( 828): /pruneDeadThumbnailFiles… android.database.sqlite.SQLiteCursor@17e5a9ac
D/BackupManagerService( 474): Received broadcast Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.android.camera2 flg=0x4000010 (has extras) }
D/BackupManagerService( 474): Received broadcast Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.android.calendar flg=0x4000010 (has extras) }
D/BackupManagerService( 474): Received broadcast Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.android.gallery3d flg=0x4000010 (has extras) }
D/BackupManagerService( 474): Received broadcast Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.android.inputmethod.latin flg=0x4000010 (has extras) }
D/Launcher.Workspace( 1327): 11683562 - stripEmptyScreens()
I/GlobalDismissManager( 1643): no sender configured
D/AlertService( 1643): Beginning updateAlertNotification
D/AlertService( 1643): No fired or scheduled alerts
I/ActivityManagerService( 474): Waited long enough for: ServiceRecord{184d1e9f u0 com.rockchip.mediacenter/.SystemDeviceService}
W/gralloc ( 165): Debugmem The fd=72, in vmalloc !!! Ishwc=0
I/ActivityManagerService( 474): Waited long enough for: ServiceRecord{34e087d9 u0 com.android.calendar/.alerts.InitAlarmsService}
W/AudioTrack( 474): AUDIO_OUTPUT_FLAG_FAST denied by client
W/AppOps ( 474): Bad call: specified package media under uid 1000 but it is really 1013
D/AudioHardwareTiny( 171): start_output_stream
D/AudioHardwareTiny( 171): Device : 0x80400
D/AudioHardwareTiny( 171): SampleRate : 44100
D/AudioHardwareTiny( 171): Channels : 2
D/AudioHardwareTiny( 171): Formate : 0
D/AudioHardwareTiny( 171): PreiodSize : 2048
I/ActivityStackSupervisor( 474): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.camera2/com.android.camera.CameraLauncher (has extras)} from uid 10032 on display 0
I/System.out( 474): com.android.camera.CameraActivityaddAppToken taskId:4
D/ViewRootImpl( 924): 1280<<<<<< BACK FROM relayoutnull
D/WindowManagerService( 474): null ==========setInputFocusLw ========== =======
D/DisplayManager( 474): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/PhoneWindow( 474): DecorView - SCREEN_WEITH = 1280 - SCREE_HEIGHT = 672
D/OpenGLRenderer( 474): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
D/Atlas ( 474): Validating map…
V/WindowManagerService( 474): Adding window Window{566cafe u0 Starting com.android.camera2} at 2 of 7 (after Window{10844d80 u0 com.android.launcher3/com.android.launcher3.Launcher})
D/ViewRootImpl( 474): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=4 ty=3 fl=#81830518 pfl=0x12 wanim=0x1030469 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.camera2token=Token{244f3d26 ActivityRecord{1152a881 u0 com.android.camera2/com.android.camera.CameraLauncher t4}}}
D/ViewRootImpl( 474): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=4 sim=#20 ty=3 fl=#81830518 pfl=0x12 wanim=0x1030469 vsysui=0x600 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.camera2token=Token{244f3d26 ActivityRecord{1152a881 u0 com.android.camera2/com.android.camera.CameraLauncher t4}}}
I/OpenGLRenderer( 474): Initialized EGL, version 1.4
D/OpenGLRenderer( 474): Enabling debug mode 0
W/gralloc ( 165): Debugmem The fd=37, in vmalloc !!! Ishwc=0
W/gralloc ( 165): Debugmem The fd=70, in vmalloc !!! Ishwc=0
W/gralloc ( 165): Debugmem The fd=77, in vmalloc !!! Ishwc=0
V/CAM_QuickActivity( 1747): START onCreate: Activity = com.android.camera.CameraActivity@37008a11
V/CAM_QuickActivity( 1747): Intent Action = android.intent.action.MAIN
I/CameraManagerGlobal( 1747): getCameraService: Reconnecting to camera service
D/mmk ( 1747): onStatusChangedLocked.+++++++
I/CameraService( 171): getCameraCharacteristics: Switching to HAL1 shim implementation…
D/CameraHal( 171): camera_get_camera_info(1337): camera_get_camera_info(1337): camera_0 facing(0), orientation(0)
E/CameraManagerGlobal( 1747): Camera id 0 has status changed to 0x1
W/AudioFlinger( 171): acquireAudioSessionId() unknown client 1747 for session 14
I/AwesomePlayer( 171): AwesomePlayer::AwesomePlayer()in
I/AwesomePlayer( 171): AwesomePlayer::AwesomePlayer()aftermClient.connect()
I/AwesomePlayer( 171): setDataSource_l()
I/OMXCodec( 171): —>InstantiateSoftwareCodec create OMX.google.vorbis.decoder codec
I/OMXCodec( 171): Successfully allocated OMX node ‘OMX.google.vorbis.decoder’
W/AudioFlinger( 171): acquireAudioSessionId() unknown client 1747 for session 15
I/CameraClient( 171): Opening camera 0
I/CameraHal( 171): camera_device_open(500): camera_device open
D/CameraHal( 171): gCameraHalLogLevel: 0
D/mmk ( 924): onStatusChangedLocked.+++++++
D/CameraHal( 171): CameraHal(121): it is a uvc camera!
D/CameraHal( 171): Calling process is: com.android.camera2
I/vpu_mem_pool( 171): pid 171, open_vpu_memory_pool:473: success
E/CameraManagerGlobal( 924): Camera id 0 has status changed to 0x80000000
E/CameraManagerGlobal( 1747): Camera id 0 has status changed to 0x80000000
D/mmk ( 924): postSingleUpdate.+++++++++ status = -2147483648
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (80000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 44
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (160000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 45
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (240000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 46
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (320000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 47
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (400000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 48
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (480000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 49
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (560000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 50
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (640000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 51
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (720000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 52
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:717: vpu memory pool size (800000)
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 53
D/CameraHal( 171): cameraCreate(374): Camera driver: uvcvideo Driver version: 3.10.0 CameraHal version: 1.55.1
D/CameraHal( 171): cameraCreate(381): mCamDriverSupportFmt: fmt = 1196444237,index = 0
D/CameraHal( 171): cameraCreate(381): mCamDriverSupportFmt: fmt = 1448695129,index = 1
D/CameraHal( 171): cameraCreate(419): cameraCreate(419): mCamDriverPreviewFmt(MJPG) is cameraHal and camera driver is also supported!!
D/CameraHal( 171): cameraCreate(421): mCamDriverPreviewFmt = 1196444237
D/CameraHal( 171): cameraCreate(427): cameraCreate(427): Current driver is uvcvideo, v4l2 memory is V4L2_MEMORY_MMAP
E/CameraHal( 171): initDefaultParameters(486): initDefaultParameters(486): mCamDriverCapability.card is error!
D/CameraHal( 171): initDefaultParameters(534): Support Preview format: yuv420sp,yuv420p .. yuv420sp
D/CameraHal( 171): initDefaultParameters(536): Support Preview sizes: 1600x1200,2592x1944,2048x1536,1920x1080,1280x1024,1280x720,1024x768,800x600,640x480,1600x1200 640x480
D/CameraHal( 171): initDefaultParameters(537): Support Preview FPS range: (15000,30000)
D/CameraHal( 171): initDefaultParameters(538): Support Preview framerate: 15,30
D/CameraHal( 171): initDefaultParameters(539): Support Picture sizes: 1600x1200,2592x1944,2048x1536,1920x1080,1280x1024,1280x720,1024x768,800x600,640x480,1600x1200
D/CameraHal( 171): initDefaultParameters(541): Support white balance: auto,incandescent,fluorescent,daylight,cloudy-daylight
D/CameraHal( 171): initDefaultParameters(549): Support focus: fixed focus zone: 0
D/CameraHal( 171): initDefaultParameters(551): Support zoom: true(ratios: 100,105,110,115,120,125,130,135,140,145,150,155,160,165,170,175,180,185,190,195,200,205,210,215,220,225,230,235,240,245,250,255,260,265,270,275,280,285,290,295,300,)
D/CameraHal( 171): initDefaultParameters(555): Support exposure: (-3 → 3)
D/CameraHal( 171): initDefaultParameters(559): Support anti-banding: off,50hz,60hz,auto anti-banding: off
D/CameraHal( 171): initDefaultParameters(561): Support hardware faces detecte: 0
D/CameraHal( 171): initDefaultParameters(562): Support software faces detecte: 0
D/CameraHal( 171): initDefaultParameters(563): Support video stabilization: false
D/CameraHal( 171): initDefaultParameters(564): Support recording hint: false
D/CameraHal( 171): cameraConfig(696): cameraConfig(696): Set framerate(30 fps) success
D/CameraHal( 171): cameraConfig(739): cameraConfig(739): Set white balance(auto) success
D/CameraHal( 171): cameraConfig(816): cameraConfig(816): Set anti-banding Disabled
D/CameraHal( 171): cameraConfig(897): cameraConfig(897): Set exposure 0 0
D/CameraHal( 171): enableSensor(213): orientation = 0xb8774168 (MPL accel)
V/Sensors ( 474): int poll__setDelay(sensors_poll_device_t, int, int64_t)
V/Sensors ( 474): int sensors_poll_context_t::setDelay(int, int64_t)
V/Sensors ( 474): setDelay - sensor Accelerometer (handle 4), rate 20 ms (50.00 Hz)
E/Sensors ( 474): MPU is not available
W/CameraService( 171): CameraService::connect X (id 0, this pid is 171, name com.android.camera2)
D/CameraHal( 171): commandThread(983): commandThread(983): receive CMD_PREVIEW_CAPTURE_CANCEL
D/CameraHal( 171): setParameters(623): suppport focus modes:fixed, expect:fixed
D/CameraHal( 171): commandThread(991): commandThread(991): CMD_PREVIEW_CAPTURE_CANCEL out
D/CameraHal( 171): cancelPicture(561): cancel picture OK.
D/CameraHal( 171): commandThread(911): commandThread(911):receive CMD_PREVIEW_STOP
D/CameraHal( 171): stopPreview(235): stopPreview(235):IN
D/CameraHal( 171): stopPreview(255): stopPreview(255):OUT
D/CameraHal( 171): commandThread(932): commandThread(932): CMD_PREVIEW_STOP out
D/CameraHal( 171): stopPreview(362): stop preview OK.
I/CameraClient( 171): Destroying camera 0
D/CameraHal( 171): camera_device_close(451): camera_device_close
D/CameraHal( 171): disableSensor(237): orientation = 0xb8774168 (MPL accel)
D/CameraHal( 171): ~SensorListener(110): Kill looper thread
D/CameraHal( 171): ~SensorListener(122): Kill looper
D/CameraHal( 171): ~SensorListener(128): SensorListener destroyed
D/CameraHal( 171): displayThread(622): displayThread(622): receive CMD_DISPLAY_STOP
D/CameraHal( 171): cameraDisplayBufferDestory(399): cameraDisplayBufferDestory(399): mANativeWindow is NULL, destory is ignore
D/CameraHal( 171): encProcessThread(1632): encProcessThread(1632): receive CMD_ENCPROCESS_EXIT
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (720000)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (640000)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (560000)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (480000)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (400000)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (320000)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (240000)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (160000)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (80000)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:501: vpu memory pool size (0)
I/vpu_mem_pool( 171): pid 171, close_vpu_memory_pool:552:
D/CameraHal( 171): autofocusThread(820): wait out
D/CameraHal( 171): commandThread(1095): commandThread(1095): receive CMD_EXIT
D/CameraHal( 171): ~CameraHal(293): CameraHal destory success
W/CameraService( 171): removeClient: clear camera 0, package name com.android.camera2
E/CameraManagerGlobal( 924): Camera id 0 has status changed to 0x1
I/FrameQueueManage( 171): FrameQueueManage::~FrameQueueManage end!
D/PhoneWindow( 1747): DecorView - SCREEN_WEITH = 1280 - SCREE_HEIGHT = 672
I/System.out( 1747): action Title!
D/CAM_LocationManager( 1747): Using legacy location provider.
D/SensorManager( 1747): aidl getSensorManager:null
V/CAM_SettingsManager( 1747): listeners: [com.android.camera.app.CameraAppUI@1ae07ca9]
V/CAM_SettingsManager( 1747): listeners: [com.android.camera.app.CameraAppUI@1ae07ca9, com.android.camera.ButtonManager@2180d33a]
V/CAM_SettingsManager( 1747): listeners: [com.android.camera.app.CameraAppUI@1ae07ca9, com.android.camera.ButtonManager@2180d33a, com.android.camera.widget.IndicatorIconController@2f779d48]
E/NFC ( 1747): could not retrieve NFC service
V/CAM_QuickActivity( 1747): END onCreate: Activity = com.android.camera.CameraActivity@37008a11
V/CAM_QuickActivity( 1747): START onStart: Activity = com.android.camera.CameraActivity@37008a11
V/CAM_QuickActivity( 1747): END onStart: Activity = com.android.camera.CameraActivity@37008a11
V/CAM_QuickActivity( 1747): START onResume: Activity = com.android.camera.CameraActivity@37008a11
V/CAM_CameraActivity( 1747): Build info: rk3288_box-eng 5.1.1 LMY49F eng.fscg.20170401.173219 test-keys
V/CAM_CameraDataAdapter( 1747): retrieved photo metadata, number of items: 0
V/CAM_CameraDataAdapter( 1747): retrieved video metadata, number of items: 0
V/CAM_CameraDataAdapter( 1747): sorting video/photo metadata
V/CAM_CameraDataAdapter( 1747): sorted video/photo metadata
D/CAM_Storage( 1747): External storage state=mounted
V/CAM_PhotoModule( 1747): requestCameraOpen
V/CAM_CameraController( 1747): requestCamera
V/CAM_CameraController( 1747): checkAndOpenCamera
D/CAM_MemoryQuery( 1747): timestamp=89013, availMem=1618, totalMem=2012, totalPSS=9, lastTrimLevel=0, largeMemoryClass=512, nativePSS=1, dalvikPSS=2, otherPSS=4,threshold=144, lowMemory=false
I/CAM2PORT_AndCamAgntImp( 1747): Opening camera 0 with camera1 API
W/AudioFlinger( 171): acquireAudioSessionId() unknown client 1747 for session 16
V/Sensors ( 474): setDelay - sensor Accelerometer (handle 4), rate 66 ms (15.00 Hz)
I/OMXCodec( 171): mOutputPortSettingsHaveChanged set true
I/OMXCodec( 171): found informat change ComponentName = OMX.google.vorbis.decoder
V/Sensors ( 474): int poll__activate(sensors_poll_device_t, int, int)
V/Sensors ( 474): int sensors_poll_context_t::activate(int, int)
V/Sensors ( 474): enable - sensor MagneticField (handle 5) dis → en
V/Sensors ( 474): setDelay - sensor MagneticField (handle 5), rate 200 ms (5.00 Hz)
V/CAM_QuickActivity( 1747): END onResume: Activity = com.android.camera.CameraActivity@37008a11
W/AudioFlinger( 171): acquireAudioSessionId() unknown client 1747 for session 17
W/AudioCache( 171): Battery track warning: refCount is already 0
D/OpenGLRenderer( 1747): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
D/Atlas ( 1747): Validating map…
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 54
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 55
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 56
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 57
I/vpu_mem_pool( 171): pid 171, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 58
V/WindowManagerService( 474): Adding window Window{2a5609b0 u0 com.android.camera2/com.android.camera.CameraLauncher} at 2 of 8 (before Window{566cafe u0 Starting com.android.camera2})
V/CAM_CameraActivity( 1747): ignoring storage callback after activity pause
E/Camera ( 1747): Invalid size parameter string=
D/ViewRootImpl( 1747): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=4 sim=#123 ty=1 fl=#81810580 wanim=0x1030469 rotAnim=1 vsysui=0x501 sysuil=true surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.camera2token=android.os.BinderProxy@15ca8f92}
D/WindowManagerService( 474): Window{2a5609b0 u0 com.android.camera2/com.android.camera.CameraLauncher} ==========setInputFocusLw ========== =======
D/ViewRootImpl( 1747): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=4 sim=#123 ty=1 fl=#81810580 wanim=0x1030469 rotAnim=1 vsysui=0x501 sysuil=true surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.camera2token=android.os.BinderProxy@15ca8f92}
I/mali_so ( 1747): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 780; [Func] : base_context_deal_with_version_affairs_rk_ext;
I/mali_so ( 1747): arm_release_ver of this mali_so is ‘r6p0-02rel0’, rk_so_ver is ‘11@0’, built at ‘16:20:19’ for 3288w, on ‘Aug 1 2016’.
I/mali_so ( 1747): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 807; [Func] : base_context_deal_with_version_affairs_rk_ext;
I/mali_so ( 1747): mali_ver_property has been set to ‘r6p0-02rel0-13-11@0’, to return.
I/OpenGLRenderer( 1747): Initialized EGL, version 1.4
D/OpenGLRenderer( 1747): Enabling debug mode 0
W/gralloc ( 165): Debugmem The fd=83, in vmalloc !!! Ishwc=0
W/gralloc ( 165): Debugmem The fd=87, in vmalloc !!! Ishwc=0
W/gralloc ( 165): Debugmem The fd=92, in vmalloc !!! Ishwc=0
V/CAM_TexViewHelper( 1747): onLayoutChange
V/CAM_TexViewHelper( 1747): updateTransform
V/CAM_CameraDataAdapter( 1747): new photos query return num items: 0
V/CAM_CameraController( 1747): onCameraOpened
V/CAM_CameraActivity( 1747): onCameraOpened
I/CAM_PhotoModule( 1747): onCameraAvailable
V/CAM_FocusOverlayMgr( 1747): stored focus setting for camera: continuous-picture
V/CAM_FocusOverlayMgr( 1747): focus mode resolved from setting: CONTINUOUS_PICTURE
V/CAM_FocusOverlayMgr( 1747): no supported focus mode, falling back to current: FIXED
V/CAM_SettingsManager( 1747): listeners: [com.android.camera.app.CameraAppUI@1ae07ca9, com.android.camera.ButtonManager@2180d33a, com.android.camera.widget.IndicatorIconController@2f779d48, com.android.camera.PhotoModule@1f7e12de]
W/CAM_PhotoModule( 1747): startPreview: surfaceTexture is not ready.
V/CAM_CameraActivity( 1747): invoking onChangeCamera
W/CAM_IndicatorIconCtrlr( 1747): Trying to sync a pano indicator that is not initialized.
W/ResourceType( 1747): No package identifier when getting value for resource number 0x00000000
W/PackageManager( 1747): Failure retrieving resources for com.android.gallery3d: Resource ID #0x0
V/CAM_CameraAppUI( 1747): SurfaceTexture is available
I/CAM_PhotoModule( 1747): onPreviewUIReady
V/CAM_PhotoModule( 1747): setDisplayOrientation (screen:preview) 0:0
V/CAM_FocusOverlayMgr( 1747): returning override focus: FIXED
D/CAM_SettingsUtil( 1747): Selected 2592x1944 resolution: 2592x1944
V/CAM_PhotoModule( 1747): setting preview size. optimal: Size: (800 x 600)original: Size: (640 x 480)
I/ActivityManagerService( 474): Waited long enough for: ServiceRecord{3efe587f u0 android.rockchip.update.service/.RKUpdateService}
D/CameraHal( 171): setParameters(583): setParameters(583): Set preview size 800x600
V/CAM_PhotoModule( 1747): updating aspect ratio
V/CAM_TexViewHelper( 1747): updateAspectRatio
V/CAM_TexViewHelper( 1747): setAspectRatio: 1.3333334
V/CAM_TexViewHelper( 1747): aspect ratio changed from: 0.0
D/CAM_PhotoModule( 1747): Preview size is Size: (800 x 600)
V/CAM_FocusOverlayMgr( 1747): stored focus setting for camera: fixed
V/CAM_FocusOverlayMgr( 1747): focus mode resolved from setting: FIXED
I/CAM_PhotoModule( 1747): startPreview
V/CAM_CameraAppUI( 1747): onPreviewStarted
D/CameraHal( 171): commandThread(937): commandThread(937):receive CMD_SET_PREVIEW_WINDOW
D/CameraHal( 171): commandThread(953): commandThread(953): CMD_SET_PREVIEW_WINDOW out
D/CameraHal( 171): commandThread(832): commandThread(832):receive CMD_PREVIEW_START
D/CameraHal( 171): startPreview(177): startPreview177:preview_w = 800,preview_h = 600,drv_w = 800,drv_h = 600
D/CameraHal( 171): cameraSetSize(476): cameraSetSize(476):IN, w = 800,h = 600
D/CameraHal( 171): cameraStream(498): cameraStream(498):on = 1
V/WindowManagerService( 474): Adding window Window{3459efae u0 com.android.camera2/com.android.camera.CameraLauncher} at 3 of 9 (before Window{566cafe u0 Starting com.android.camera2})
D/WindowManagerService( 474): Window{3459efae u0 com.android.camera2/com.android.camera.CameraLauncher} ==========setInputFocusLw ========== =======
W/PathParser( 1747): Points are too far apart 4.000000596046461
D/ViewRootImpl( 474): onDetachedFromWindow ungister contentObserver
D/ViewRootImpl( 1747): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#ffffffff sim=#100 ty=2 fl=#1850500 wanim=0x1030001 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.camera2token=android.os.BinderProxy@15ca8f92}
D/ViewRootImpl( 1747): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#ffffffff sim=#120 ty=2 fl=#1850500 wanim=0x1030001 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.camera2token=android.os.BinderProxy@15ca8f92}
W/gralloc ( 165): Debugmem The fd=59, in vmalloc !!! Ishwc=0
W/gralloc ( 165): Debugmem The fd=78, in vmalloc !!! Ishwc=0
W/InputMethodManager( 1747): Ignoring onBind: cur seq=3, given seq=2
D/ViewRootImpl( 1747): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=4 sim=#23 ty=1 fl=#81810580 wanim=0x1030469 rotAnim=1 vsysui=0x500 sysuil=true surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.camera2token=android.os.BinderProxy@15ca8f92}
D/CameraHal( 171): startPreview(223): startPreview(223):OUT
D/CameraHal( 171): displayThread(596): displayThread(596): receive CMD_DISPLAY_START
W/gralloc ( 165): Debugmem The fd=94, in vmalloc !!! Ishwc=0
W/gralloc ( 165): Debugmem The fd=80, in vmalloc !!! Ishwc=0
D/CameraHal( 171): commandThread(905): commandThread(905): CMD_PREVIEW_START out
I/ActivityManagerService( 474): Displayed com.android.camera2/com.android.camera.CameraLauncher: +1s614ms
V/CAM_CameraAppUI( 1747): hiding cover via onSurfaceTextureUpdated
D/CameraPerformanceTracker( 1747): First preview frame received
D/CAM_LcyLocProvider( 1747): provider does not exist provider doesn’t exist: network
D/CAM_LcyLocProvider( 1747): provider does not exist provider doesn’t exist: gps
D/CAM_LcyLocProvider( 1747): startReceivingLocationUpdates
D/ViewRootImpl( 1747): onDetachedFromWindow ungister contentObserver
D/ViewRootImpl( 1747): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=4 sim=#23 ty=1 fl=#81810580 wanim=0x1030469 rotAnim=1 vsysui=0x500 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.camera2token=android.os.BinderProxy@15ca8f92}
D/ViewRootImpl( 1747): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=4 sim=#23 ty=1 fl=#81810580 wanim=0x1030469 rotAnim=1 vsysui=0x501 sysuil=true surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.camera2token=android.os.BinderProxy@15ca8f92}
D/ViewRootImpl( 1747): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=4 sim=#23 ty=1 fl=#81810580 wanim=0x1030469 rotAnim=1 vsysui=0x501 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.camera2token=android.os.BinderProxy@15ca8f92}
D/AudioHardwareTiny( 171): close device
V/CAM_PhotoModule( 1747): pause
V/Sensors ( 474): enable - sensor MagneticField (handle 5) en → dis
I/CAM_PhotoModule( 1747): stopPreview
D/CameraHal( 171): commandThread(1081): commandThread(1081): receive CMD_AF_CANCEL
D/CameraHal( 171): displayThread(610): displayThread(610): receive CMD_DISPLAY_PAUSE
D/CameraHal( 171): cameraStream(498): cameraStream(498):on = 0
D/CameraHal( 171): adapterReturnFrame(689): adapterReturnFrame(689): preview thread is pause, so buffer 0 isn’t enqueue to camera
D/RKUpdateService( 1250): WorkHandler::handleMessage() : To perform ‘COMMAND_CHECK_LOCAL_UPDATING’.
D/RKUpdateService( 1250): getValidFirmwareImageFile() : Target image file path : /data/media/0/update.zip
D/RKUpdateService( 1250): getValidFirmwareImageFile() : Target image file path : /mnt/internal_sd/update.zip
D/RKUpdateService( 1250): getValidFirmwareImageFile() : Target image file path : /mnt/external_sd/update.zip
D/RKUpdateService( 1250): getValidFirmwareImageFile() : Target image file path : /mnt/usb_storage/update.zip
V/CAM_CameraController( 1747): reconnecting to use the existing camera
D/CAM_VideoModule( 1747): Selected video quality for ‘large’ is 9
V/CAM_VideoModule( 1747): Selected =2592x1944 on WYSIWYG Priority
V/CAM_VideoModule( 1747): Updated DesiredPreview=2592x1944
I/CAM_VideoModule( 1747): startPreview
D/CAM_VideoModule( 1747): Video snapshot size is Size: (2592 x 1944)
V/CAM_VideoModule( 1747): on L, no one shot callback necessary
D/CameraHal( 171): setParameters(583): setParameters(583): Set preview size 2592x1944
D/CameraHal( 171): startPreview(177): startPreview177:preview_w = 2592,preview_h = 1944,drv_w = 2592,drv_h = 1944
D/CameraHal( 171): cameraSetSize(476): cameraSetSize(476):IN, w = 2592,h = 1944
W/gralloc ( 165): Debugmem The fd=86, in vmalloc !!! Ishwc=0
E/JPEG_DEC( 171): out offset big then 22bit iommu map may be error
W/ActivityThread( 1250): ClassLoader.loadClass: The class loader returned by Thread.getContextClassLoader() may fail for processes that host multiple applications. You should explicitly specify a context class loader. For example: Thread.setContextClassLoader(getClass().getClassLoader());
D/RKUpdateService( 1250): request remote server error…
D/InitAlarmsService( 1643): Clearing and rescheduling alarms.
E/dhcpcd ( 743): timed out
D/NetUtils( 474): dhcp_do_request failed : eth0 (new)
E/EthernetNetworkFactory( 474): DHCP request error:Timed out waiting for DHCP to finish
E/blb ( 924): mmEthernetVisible: false
E/NetworkController( 924): onReceive ETHERNET_STATE_CHANGED_ACTION
I/CAM_VideoModule( 1747): startVideoRecording: Thread[main,5,main]
I/CAM_VideoModule( 1747): initializeRecorder: Thread[main,5,main]
D/MediaProfiles( 171): CameraGroupFound(671): media_profiles_id: 0x0
D/MediaProfiles( 171): getInstance(766): Create instance from /data/camera/media_profiles.xml
W/StagefrightRecorder( 171): Max file duration is not positive: 0 us. Disabling duration limit.
W/StagefrightRecorder( 171): Target duration (0 us) too short to be respected
D/CAM_LcyLocProvider( 1747): No location received yet.
V/CAM_VideoModule( 1747): New video filename: /mnt/internal_sd/DCIM/Camera/VID_20110101_125311.mp4.tmp
D/bunchen ( 1747): setOrientationHint 0
I/MediaFocusControl( 474): AudioFocus requestAudioFocus() from android.media.AudioManager@33fc485e req=1flags=0x0
W/ACodec ( 171): do not know color format 0x7f000789 = 2130708361
W/StagefrightRecorder( 171): Intended video encoding frame width (2592) is too large and will be set to (1920)
W/StagefrightRecorder( 171): Intended video encoding frame height (1944) is too large and will be set to (1080)
D/CameraSource( 171): Camera does not support setVideoSize()
D/CameraHal( 171): setParameters(583): setParameters(583): Set preview size 1920x1080
D/CameraHal( 171): setParameters(585): setParameters(585):WARNING, set preview size during preview
E/CameraHal( 171): cameraConfig(699): cameraConfig(699): UVC isn’t support set framerate after start preview
D/CameraHal( 171): commandThread(974): commandThread:setparameter demand restart preview!
I/ACodec ( 171): setupVideoEncoder succeeded
I/MediaCodec( 171): MediaCodec will operate in async mode
D/ROCKCHIP_VIDEO_ENC( 171): EncParam.framerate = 15 outPort->sPortParam.format.video.xFramerate = 983040 3000000
E/ROCKCHIP_VIDEO_ENC( 171): pVideoEnc->AVCComponent[OUTPUT_PORT_INDEX].eProfile:1
E/ROCKCHIP_VIDEO_ENC( 171): ConvertOmxAvcLevelToAvcSpecLevel: 512
D/pv_avcenc_api( 171): cml->cabacintIdc 0 cml->enablaCabac 0 cml->intraPicRate 15
D/pv_avcenc_api( 171): init intraPeriodCnt 15
E/AudioHardwareTiny( 171): adev_open_input_stream:channel is not support
D/AudioHardwareTiny( 171): in->mSpeexFrameSize:512
I/AudioFlinger( 171): AudioFlinger’s thread 0xa6ff2008 ready to run
W/AudioFlinger( 171): acquireAudioSessionId() unknown client 1747 for session 20
D/ACodec ( 171): MEDIA_MIMETYPE_AUDIO_AAC sampleRate 44100 wifidisplay_flag 0 info b880d7d0
W/MPEG4Writer( 171): 32-bit file size limit (12489011072 bytes) too big. It is changed to 4294967295 bytes
I/MPEG4Writer( 171): limits: 4294967295/0 bytes/us, bit rate: 3061000 bps and the estimated moov size 405000 bytes
I/MPEG4Writer( 171): Start time offset: 1000000 us
I/MediaCodecSource( 171): MediaCodecSource (video) starting
D/AudioSink( 171): open(48000, 1, 0x0, 0x1, 4, 17 0x0)
I/AudioTrack( 171): minFrameCount: 8916, afFrameCount=2048, minBufCount=4, sampleRate=48000, afSampleRate=44100, afLatency=185
D/CameraHal( 171): adapterReturnFrame(689): adapterReturnFrame(689): preview thread is pause, so buffer 2 isn’t enqueue to camera
D/CameraHal( 171): startPreview(177): startPreview177:preview_w = 1920,preview_h = 1080,drv_w = 1920,drv_h = 1080
D/CameraHal( 171): cameraSetSize(476): cameraSetSize(476):IN, w = 1920,h = 1080
D/AudioHardwareTiny( 171): Device : 0x400
W/gralloc ( 165): Debugmem The fd=66, in vmalloc !!! Ishwc=0
D/CameraHal( 171): setParameters(599): setParameters(599): Set picture size 1920x1080
I/MediaCodecSource( 171): MediaCodecSource (video) started
I/MediaCodecSource( 171): MediaCodecSource (audio) starting
I/MediaCodecSource( 171): MediaCodecSource (audio) started
D/AudioHardwareTiny( 171): Device : 0x200
D/AudioHardwareTiny( 171): SampleRate : 0
D/AudioHardwareTiny( 171): Channels : 0
D/AudioHardwareTiny( 171): Formate : -1260723908
D/AudioHardwareTiny( 171): PreiodSize : 12
E/AudioHardwareTiny( 171): getInputRouteFromDevice:device:80000004
D/alsa_route( 171): route_info->sound_card 0, route_info->devices 0
V/WindowManagerService( 474): Not allow rotate, force to ROTATION_0
I/Choreographer( 1747): Skipped 38 frames! The application may be doing too much work on its main thread.
D/alsa_route( 171): route_set_controls() set route 21
I/MPEG4Writer( 171): setStartTimestampUs: 21560
I/MPEG4Writer( 171): Earliest track starting time: 21560
I/MPEG4Writer( 171): setStartTimestampUs: 6873
I/MPEG4Writer( 171): Earliest track starting time: 6873
V/CAM_VideoModule( 1747): stopVideoRecording
D/MPEG4Writer( 171): Video track stopping
D/MPEG4Writer( 171): Video track source stopping
I/MediaCodecSource( 171): encoder (video) stopping
I/MPEG4Writer( 171): Received total/0-length (66/0) buffers and encoded 65 frames. - Video
I/MediaCodecSource( 171): encoder (video) stopped
I/MediaCodecSource( 171): puller (video) stopping
D/CameraSource( 171): reset: E
D/CameraSource( 171): reset: X
I/MediaCodecSource( 171): puller (video) stopped
D/MPEG4Writer( 171): Video track source stopped
D/MPEG4Writer( 171): Video track stopped
D/MPEG4Writer( 171): Audio track stopping
D/MPEG4Writer( 171): Audio track source stopping
I/MediaCodecSource( 171): encoder (audio) stopping
I/MPEG4Writer( 171): Received total/0-length (134/0) buffers and encoded 133 frames. - Audio
I/MPEG4Writer( 171): Audio track drift time: 0 us
I/MediaCodecSource( 171): encoder (audio) stopped
I/MediaCodecSource( 171): puller (audio) stopping
I/MediaCodecSource( 171): puller (audio) stopped
D/MPEG4Writer( 171): Audio track source stopped
D/MPEG4Writer( 171): Audio track stopped
D/MPEG4Writer( 171): Duration from tracks range is [2996557, 3088260] us
D/MPEG4Writer( 171): Stopping writer thread
D/MPEG4Writer( 171): 0 chunks are written in the last batch
D/MPEG4Writer( 171): Writer thread stopped
V/CAM_VideoModule( 1747): stopVideoRecording: current video filename: /mnt/internal_sd/DCIM/Camera/VID_20110101_125311.mp4.tmp
D/CAM_OrientMgrImpl( 1747): unlock orientation
D/alsa_route( 171): route_set_controls() set route 25
I/CAM_VideoModule( 1747): Releasing media recorder.
W/AudioFlinger( 171): session id 20 not found for pid 1747
V/CAM_MediaSaverImpl( 1747): Current video URI: content://media/external/video/media/16
I/OMXCodec( 171): —>InstantiateSoftwareCodec create RkVpuDecoder codec
D/RkVpuDecoder( 171): mCodecId = 7 video code mine video/avc
I/RkVpuDecoder( 171): RkVpuDecoder::start in
I/H264_DEBUG( 171): init done status 0, ts_en = 0 debug 0
I/H264_DEBUG( 171): decoded width 1920 decoded height 1088
I/H264_DEBUG( 171): display width 1920, display height 1080
V/CAM_CameraActivity( 1747): ===============NULL pointer debug===================
V/CAM_FilmstripView( 1747): suggesting item bounds: 896x470
E/MediaMetadataRetrieverJNI( 1747): getEmbeddedPicture: Call to getEmbeddedPicture failed.
D/skia ( 1747): — SkImageDecoder::Factory returned null
I/H264_DEBUG( 171): deinit DONE
I/art ( 828): Background sticky concurrent mark sweep GC freed 1978(129KB) AllocSpace objects, 0(0B) LOS objects, 0% free, 5MB/5MB, paused 6.779ms total 12.455ms
W/MediaProvider( 828): java.io.FileNotFoundException: No such file or directory
W/MediaProvider( 828): at android.os.Parcel.openFileDescriptor(Native Method)
W/MediaProvider( 828): at android.os.ParcelFileDescriptor.openInternal(ParcelFileDescriptor.java:253)
W/MediaProvider( 828): at android.os.ParcelFileDescriptor.open(ParcelFileDescriptor.java:199)
W/MediaProvider( 828): at com.android.providers.media.MediaProvider.openFileAndEnforcePathPermissionsHelper(MediaProvider.java:4821)
W/MediaProvider( 828): at com.android.providers.media.MediaProvider.openFile(MediaProvider.java:4734)
W/MediaProvider( 828): at android.content.ContentProvider.openAssetFile(ContentProvider.java:1323)
W/MediaProvider( 828): at android.content.ContentProvider.openAssetFile(ContentProvider.java:1386)
W/MediaProvider( 828): at android.content.ContentProvider$Transport.openAssetFile(ContentProvider.java:359)
W/MediaProvider( 828): at android.content.ContentResolver.openAssetFileDescriptor(ContentResolver.java:939)
W/MediaProvider( 828): at android.content.ContentResolver.openOutputStream(ContentResolver.java:686)
W/MediaProvider( 828): at android.content.ContentResolver.openOutputStream(ContentResolver.java:662)
W/MediaProvider( 828): at com.android.providers.media.MediaThumbRequest.execute(MediaThumbRequest.java:189)
W/MediaProvider( 828): at com.android.providers.media.MediaProvider$4.handleMessage(MediaProvider.java:648)
W/MediaProvider( 828): at android.os.Handler.dispatchMessage(Handler.java:102)
W/MediaProvider( 828): at android.os.Looper.loop(Looper.java:135)
W/MediaProvider( 828): at android.os.HandlerThread.run(HandlerThread.java:61)
I/PhoneWindowManager( 474): Ignoring HOME; event canceled.
D/ViewRootImpl( 924): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#800053 sim=#31 ty=2024 fl=#1820100 fmt=-3 vsysui=0x8701 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.android.systemuitoken=null}
D/ViewRootImpl( 924): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 sim=#20 ty=2019 fl=#1840048 fmt=-3 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.android.systemuitoken=null}
I/ActivityStackSupervisor( 474): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10200000 cmp=com.android.launcher3/.Launcher} from uid 1000 on display 0
D/PermissionCache( 165): checking android.permission.READ_FRAME_BUFFER for uid=1000 => granted (436 us)
W/gralloc ( 165): Debugmem The fd=97, in vmalloc !!! Ishwc=0
V/CAM_QuickActivity( 1747): START onPause: Activity = com.android.camera.CameraActivity@37008a11
V/CAM_VideoModule( 1747): stopPreview
D/CameraHal( 171): adapterReturnFrame(689): adapterReturnFrame(689): preview thread is pause, so buffer 1 isn’t enqueue to camera
I/CAM_VideoModule( 1747): closeCamera
V/CAM_CameraController( 1747): Closing camera
D/CameraHal( 171): pauseDisplay(159): pauseDisplay(159): display thread is already stop
D/mmk ( 924): postSingleUpdate.+++++++++ status = 1
V/CAM_QuickActivity( 1747): END onPause: Activity = com.android.camera.CameraActivity@37008a11
W/AudioFlinger( 171): session id 17 not found for pid 1747
D/ViewRootImpl( 1327): 1280<<<<<< BACK FROM relayoutnull
D/ViewRootImpl( 1747): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=4 sim=#23 ty=1 fl=#81810500 wanim=0x1030469 rotAnim=1 vsysui=0x501 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.camera2token=android.os.BinderProxy@15ca8f92}
D/WindowManagerService( 474): Window{10844d80 u0 com.android.launcher3/com.android.launcher3.Launcher} ==========setInputFocusLw ========== =======
D/ViewRootImpl( 1327): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=3 sim=#120 ty=1 fl=#81910100 fmt=-2 wanim=0x10303e5 vsysui=0x600 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.launcher3token=android.os.BinderProxy@104df80d}
W/gralloc ( 165): Debugmem The fd=65, in vmalloc !!! Ishwc=0
W/gralloc ( 165): Debugmem The fd=79, in vmalloc !!! Ishwc=0
W/gralloc ( 165): Debugmem The fd=82, in vmalloc !!! Ishwc=0
D/ViewRootImpl( 1747): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=4 sim=#23 ty=1 fl=#81810500 wanim=0x1030469 rotAnim=1 vsysui=0x500 sysuil=true surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.camera2token=android.os.BinderProxy@15ca8f92}
D/DisplayManager( 924): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
V/CAM_CameraAppUI( 1747): SurfaceTexture is destroyed
V/CAM_VideoModule( 1747): Skip stopPreview since it’s not mPreviewing
D/CAM_VideoUI( 1747): surfaceTexture is destroyed
D/ViewRootImpl( 1747): 1280<<<<<< BACK FROM relayoutnull
D/ViewRootImpl( 924): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#800053 sim=#31 ty=2024 fl=#1820100 fmt=-3 vsysui=0x8700 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.android.systemuitoken=null}
V/CAM_QuickActivity( 1747): START onStop: Activity = com.android.camera.CameraActivity@37008a11
D/CAM_LcyLocProvider( 1747): disconnect
V/CAM_QuickActivity( 1747): END onStop: Activity = com.android.camera.CameraActivity@37008a11
W/OpenGLRenderer( 1327): Incorrectly called buildLayer on View: ShortcutAndWidgetContainer, destroying layer…
W/ResourceType( 924): No package identifier when getting value for resource number 0x00000000
W/PackageManager( 924): Failure retrieving resources for com.android.camera2: Resource ID #0x0
D/LyricManager( 1444): hide lrc
D/LyricManager( 1444): not attached to window manager
I/MediaFocusControl( 474): AudioFocus abandonAudioFocus() from android.media.AudioManager@2a56e97ccom.android.music.MediaPlaybackService$4@140d6205
I/ActivityManagerService( 474): Start proc 1983:com.android.musicfx/u0a7 for broadcast com.android.musicfx/.ControlPanelReceiver
I/PackageManager( 474): Running dexopt on: /system/priv-app/MusicFX/MusicFX.apk pkg=com.android.musicfx isa=arm vmSafeMode=false
I/dex2oat ( 2001): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/MusicFX/MusicFX.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@MusicFX@MusicFX.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m --compiler-filter=interpret-only --swap-fd=8
I/dex2oat ( 2001): Decided to run without swap.
I/dex2oat ( 2001): dex2oat took 116.011ms (threads: 4) arena alloc=0B java alloc=154KB native alloc=79KB free=156KB
V/CAM_QuickActivity( 1747): START onRestart: Activity = com.android.camera.CameraActivity@37008a11
V/CAM_QuickActivity( 1747): END onRestart: Activity = com.android.camera.CameraActivity@37008a11
D/DisplayManager( 1983): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1280 x 672, real 1280 x 720, largest app 1280 x 1207, smallest app 720 x 647, 69.096 fps, supportedRefreshRates [69.096], rotation 0, density 160 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 15472617, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
V/MusicFXControlPanelReceiver( 1983): onReceive
V/MusicFXControlPanelReceiver( 1983): Action: android.media.action.CLOSE_AUDIO_EFFECT_CONTROL_SESSION
V/MusicFXControlPanelReceiver( 1983): Package name: com.android.music
V/MusicFXControlPanelReceiver( 1983): Audio session: 10
V/MusicFXControlPanelEffect( 1983): closeSession(android.app.ReceiverRestrictedContext@2b4ba38, com.android.music, 10)
I/ActivityManagerService( 474): Killing 1000:com.android.exchange/u0a25 (adj 15): empty #17
D/ViewRootImpl( 1747): 1280<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=4 sim=#23 ty=1 fl=#81810500 wanim=0x1030469 rotAnim=1 vsysui=0x501 sysuil=true surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.camera2token=android.os.BinderProxy@15ca8f92}
W/gralloc ( 165): Debugmem The fd=102, in vmalloc !!! Ishwc=0
W/gralloc ( 165): Debugmem The fd=103, in vmalloc !!! Ishwc=0
W/gralloc ( 165): Debugmem The fd=104, in vmalloc !!! Ishwc=0
V/CAM_QuickActivity( 1747): START onNewIntent: Activity = com.android.camera.CameraActivity@37008a11
V/CAM_QuickActivity( 1747): END onNewIntent: Activity = com.android.camera.CameraActivity@37008a11
W/AudioFlinger( 171): acquireAudioSessionId() unknown client 1747 for session 25
W/AudioFlinger( 171): acquireAudioSessionId() unknown client 1747 for session 26
V/CAM_CameraController( 1747): getCurrentCameraId without an open camera… returning requested id
E/ActivityThread( 1327): Performing stop of activity that is not resumed: {com.android.launcher3/com.android.launcher3.Launcher}
E/ActivityThread( 1327): java.lang.RuntimeException: Performing stop of activity that is not resumed: {com.android.launcher3/com.android.launcher3.Launcher}
E/ActivityThread( 1327): at android.app.ActivityThread.performStopActivityInner(ActivityThread.java:3366)
E/ActivityThread( 1327): at android.app.ActivityThread.handleStopActivity(ActivityThread.java:3447)
E/ActivityThread( 1327): at android.app.ActivityThread.access$1100(ActivityThread.java:151)
E/ActivityThread( 1327): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1348)
E/ActivityThread( 1327): at android.os.Handler.dispatchMessage(Handler.java:102)
E/ActivityThread( 1327): at android.os.Looper.loop(Looper.java:135)
E/ActivityThread( 1327): at android.app.ActivityThread.main(ActivityThread.java:5280)
E/ActivityThread( 1327): at java.lang.reflect.Method.invoke(Native Method)
E/ActivityThread( 1327): at java.lang.reflect.Method.invoke(Method.java:372)
E/ActivityThread( 1327): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:963)
E/ActivityThread( 1327): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:758)
I/ActivityManagerService( 474): Activity reported stop, but no longer stopping: ActivityRecord{c839caf u0 com.android.launcher3/.Launcher t3}
W/gralloc ( 165): Debugmem The fd=36, in vmalloc !!! Ishwc=0
W/gralloc ( 165): Debugmem The fd=44, in vmalloc !!! Ishwc=0
