状况如下:
- 用fireprime官方源码编译
- 开机MIPI屏无任何显示
- HDMI不接,mipi Reset pin就不会动作。
- 波形图如下:
5. 相关源码在附件
mipi.zip (37 KB)
有人点过FirePrime的MIPI屏吗?
1.把内核log 贴出来看看2.代码一般最好不要打包上传,帮你解决问题的还得下载下来
3.是否有参考过文档进行《Rockchip平台Linux 3.10上MIPI驱动介绍和调试说明V1.0》
<6>[ 0.000000] Initializing cgroup subsys cpu
<6>[ 0.000000] Initializing cgroup subsys cpuacct
<5>[ 0.000000] Linux version 3.10.0 (builder@Builder-virtual-machine) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #56 SMP PREEMPT Thu Apr 6 11:47:43 CST 2017
<4>[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
<4>[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
<6>[ 0.000000] Machine: Rockchip RK3128, model: rockchip,rk3128
<6>[ 0.000000] rockchip_uboot_logo_setup: mem: 2000000@ddc00000, offset:0
<6>[ 0.000000] rockchip_uboot_mem_reserve: reserve 2000000@ddc00000 for uboot logo
<4>[ 0.000000] rockchip_ion_reserve
<6>[ 0.000000] ion heap(cma): base(0) size(800000) align(0)
<6>[ 0.000000] ion heap(vmalloc): base(0) size(0) align(0)
<6>[ 0.000000] cma: CMA: reserved 8 MiB at dd400000
<6>[ 0.000000] ion_reserve: cma reserved base dd400000 size 8388608
<6>[ 0.000000] cma: CMA: reserved 16 MiB at 7f000000
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
<7>[ 0.000000] On node 0 totalpages: 524288
<7>[ 0.000000] free_area_init_node: node 0, pgdat c0d07ec0, node_mem_map c0e31000
<7>[ 0.000000] Normal zone: 1024 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
<7>[ 0.000000] HighMem zone: 3072 pages used for memmap
<7>[ 0.000000] HighMem zone: 393216 pages, LIFO batch:31
<6>[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1e68000 s14016 r8192 d14656 u36864
<7>[ 0.000000] pcpu-alloc: s14016 r8192 d14656 u36864 alloc=9*4096
<7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
<5>[ 0.000000] Kernel command line: vmalloc=496M rockchip_jtag console=ttyFIQ0,115200 earlyprintk androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00006000@0x0000E000(kernel),0x00006000@0x00014000(boot),0x00010000@0x0001A000(recovery),0x00020000@0x0002A000(backup),0x00040000@0x0004A000(cache),0x001FE000@0x0008A000(userdata),0x00008000@0x00288000(metadata),0x00002000@0x00290000(kpanic),0x00200000@0x00292000(system),0x00020000@0x00492000(radical_update),-@0x004B2000(user) storagemedia=emmc uboot_logo=0x02000000@0xddc00000 loader.timestamp=2017-04-06_13:22:39
<4>[ 0.000000] rockchip jtag enabled
<6>[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[ 0.000000] allocated 4194304 bytes of page_cgroup
<6>[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
<6>[ 0.000000] Memory: 2048MB = 2048MB total
<5>[ 0.000000] Memory: 2002328k/2002328k available, 94824k reserved, 1531904K highmem
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .text : 0xc0008000 - 0xc0b9b1f0 (11853 kB)
<5>[ 0.000000] .init : 0xc0b9c000 - 0xc0bf46c0 ( 354 kB)
<5>[ 0.000000] .data : 0xc0bf6000 - 0xc0d0f6f8 (1126 kB)
<5>[ 0.000000] .bss : 0xc0d0f6f8 - 0xc0e30a3c (1157 kB)
<6>[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
<6>[ 0.000000] Preemptible hierarchical RCU implementation.
<6>[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
<6>[ 0.000000] NR_IRQS:16 nr_irqs:16 16
<4>[ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000
<4>[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
<4>[ 0.000000] rkclk_init_clks: cnt_parent = 25
<4>[ 0.000000] rkclk_init_clks: cnt_rate = 17
<6>[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
<6>[ 0.000000] Switching to timer-based delay loop
<6>[ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns
<6>[ 0.000000] process version: 0
<6>[ 0.000000] channel:0, lkg:34
<6>[ 0.000000] target-temp:85
<4>[ 0.000000] FirePrime hardware version: V01
<6>[ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
<6>[ 1.364045] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
<6>[ 1.364073] pid_max: default: 32768 minimum: 301
<6>[ 1.364278] Security Framework initialized
<6>[ 1.364308] SELinux: Initializing.
<7>[ 1.364354] SELinux: Starting in permissive mode
<6>[ 1.364441] Mount-cache hash table entries: 512
<6>[ 1.365651] Initializing cgroup subsys debug
<6>[ 1.365677] Initializing cgroup subsys memory
<6>[ 1.365730] Initializing cgroup subsys freezer
<6>[ 1.365790] CPU: Testing write buffer coherency: ok
<3>[ 1.366299] /cpus/cpu@0 missing clock-frequency property
<3>[ 1.366327] /cpus/cpu@1 missing clock-frequency property
<3>[ 1.366347] /cpus/cpu@2 missing clock-frequency property
<3>[ 1.366365] /cpus/cpu@3 missing clock-frequency property
<6>[ 1.366476] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
<6>[ 1.366548] Setting up static identity map for 0xc08488d8 - 0xc0848930
<6>[ 1.368723] last_log: 0x7e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x176a (version 3.0)
<4>[ 1.441612] CPU1: Booted secondary processor
<6>[ 1.441669] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
<4>[ 1.461308] CPU2: Booted secondary processor
<6>[ 1.461352] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
<4>[ 1.481061] CPU3: Booted secondary processor
<6>[ 1.481106] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
<6>[ 1.481286] Brought up 4 CPUs
<6>[ 1.481338] SMP: Total of 4 processors activated (192.00 BogoMIPS).
<6>[ 1.481353] CPU: All CPU(s) started in SVC mode.
<6>[ 1.482754] devtmpfs: initialized
<6>[ 1.492923] pinctrl core: initialized pinctrl subsystem
<6>[ 1.493409] regulator-dummy: no parameters
<6>[ 1.494904] NET: Registered protocol family 16
<6>[ 1.498292] DMA: preallocated 256 KiB pool for atomic coherent allocations
<6>[ 1.498842] ion_snapshot: 0x7ea18000 map to 0xe0907000 and copy to 0xc0e0bf44 (version 0.1)
<6>[ 1.499063] Registered FIQ tty driver
<6>[ 1.501405] console [ttyFIQ0] enabled
<6>[ 1.501807] Registered fiq debugger ttyFIQ0
<4>[ 1.503570] rockchip_get_bank_data:name=/pinctrl@20008000/gpio0@2007c000 start=0x2007c000,end=0x2007c0ff
<4>[ 1.503707] rockchip_get_bank_data:name=/pinctrl@20008000/gpio1@20080000 start=0x20080000,end=0x200800ff
<4>[ 1.503790] rockchip_get_bank_data:name=/pinctrl@20008000/gpio2@20084000 start=0x20084000,end=0x200840ff
<4>[ 1.503869] rockchip_get_bank_data:name=/pinctrl@20008000/gpio3@20088000 start=0x20088000,end=0x200880ff
<4>[ 1.503957] rockchip_get_bank_data:name=/pinctrl@20008000/gpio15@2008A000 start=0x20086000,end=0x200860ff
<4>[ 1.504030] rockchip_pinctrl_probe:name=rk312x-GPIO,type=5
<4>[ 1.504073] rockchip_pinctrl_probe:name=base start=0x20008000,end=0x200080a7
<4>[ 1.504104] rockchip_pinctrl_probe:name=mux start=0x200080a8,end=0x200080f3
<4>[ 1.504132] rockchip_pinctrl_probe:name=pull start=0x20008118,end=0x20008137
<4>[ 1.504160] rockchip_pinctrl_probe:name=drv start=0x20008100,end=0x20008103
<7>[ 1.504300] gpiochip_add: registered GPIOs 0 to 31 on device: gpio0
<7>[ 1.504397] gpiochip_add: registered GPIOs 32 to 63 on device: gpio1
<7>[ 1.504503] gpiochip_add: registered GPIOs 64 to 95 on device: gpio2
<7>[ 1.504600] gpiochip_add: registered GPIOs 96 to 127 on device: gpio3
<7>[ 1.504696] gpiochip_add: registered GPIOs 128 to 159 on device: gpio15
<4>[ 1.506865] rockchip_pinctrl_probe:init ok
<6>[ 1.514351] rk_iommu 1010e300.vop_mmu: (vop) Enter
<6>[ 1.514405] rk_iommu 1010e300.vop_mmu: skip request vop mmu irq
<6>[ 1.514515] rk_iommu 1010e300.vop_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 1.514544] rk_iommu 1010e300.vop_mmu: (vop) Initialized
<6>[ 1.514830] rk_iommu 10104440.hevc_mmu: (hevc) Enter
<6>[ 1.514977] rk_iommu 10104440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 1.515007] rk_iommu 10104440.hevc_mmu: (hevc) Initialized
<6>[ 1.515270] rk_iommu 10106800.vpu_mmu: (vpu) Enter
<6>[ 1.515396] rk_iommu 10106800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 1.515426] rk_iommu 10106800.vpu_mmu: (vpu) Initialized
<6>[ 1.515685] rk_iommu 10108800.iep_mmu: (iep) Enter
<6>[ 1.515809] rk_iommu 10108800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 1.515839] rk_iommu 10108800.iep_mmu: (iep) Initialized
<6>[ 1.517900] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
<6>[ 1.517931] hw-breakpoint: maximum watchpoint size is 8 bytes.
<4>[ 1.518213] DDR DEBUG: version 1.02 20140828
<4>[ 1.518237] DDR DEBUG: DRAM Type:DDR3
<4>[ 1.518262] DDR DEBUG: 2 CS, ROW=15, Bank=8, COL=10, Total Capability=2048MB
<4>[ 1.518309] DDR DEBUG: init success!!! freq=300MHz
<6>[ 1.571784] bio: create slab at 0
<6>[ 1.572808] Rockchip hdmi driver version 2.0
<6>[ 1.572808] .
<5>[ 1.574663] SCSI subsystem initialized
<6>[ 1.575041] usbcore: registered new interface driver usbfs
<6>[ 1.575149] usbcore: registered new interface driver hub
<6>[ 1.575358] usbcore: registered new device driver usb
<7>[ 1.576386] of_get_named_gpio_flags exited with status 116
<4>[ 1.576421] drivers/gpio/gpiolib.c //Leo mipi
<7>[ 1.576465] of_get_named_gpio_flags exited with status 30
<4>[ 1.576488] drivers/gpio/gpiolib.c //Leo mipi
<7>[ 1.577307] of_get_named_gpio_flags exited with status 1
<7>[ 1.577349] of_get_named_gpio_flags exited with status 0
<6>[ 1.577601] rockchip_i2c 20072000.i2c: i2c-0: Rockchip I2C adapter
<6>[ 1.579799] media: Linux media interface: v0.10
<6>[ 1.579890] Linux video capture interface: v2.00
<6>[ 1.580104] pps_core: LinuxPPS API ver. 1 registered
<6>[ 1.580128] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
<6>[ 1.580178] PTP clock support registered
<4>[ 1.580273] i2c-core: driver [bq24296] using legacy suspend method
<4>[ 1.580296] i2c-core: driver [bq24296] using legacy resume method
<6>[ 1.581689] Rockchip ion module is successfully loaded (v1.1)
<6>[ 1.581962] Advanced Linux Sound Architecture Driver Initialized.
<6>[ 1.582719] Bluetooth: Core ver 2.16
<6>[ 1.582797] NET: Registered protocol family 31
<6>[ 1.582819] Bluetooth: HCI device and connection manager initialized
<6>[ 1.582853] Bluetooth: HCI socket layer initialized
<6>[ 1.582883] Bluetooth: L2CAP socket layer initialized
<6>[ 1.582935] Bluetooth: SCO socket layer initialized
<6>[ 1.583370] cfg80211: Calling CRDA to update world regulatory domain
<4>[ 1.585167] rk_mipi_screen_init_dt //Leo mipi
<3>[ 1.585338] rk_mipi_screen_init_dt: lcd->screen_init = 1.
<3>[ 1.585362] rk_mipi_screen_init_dt: mipi_lcd->dsi_lane = 4.
<3>[ 1.585385] rk_mipi_screen_init_dt: lcd->screen->hs_tx_clk = 220000000.
<3>[ 1.585408] rk_mipi_screen_init_dt: lcd->screen.mipi_dsi_num = 1.
<3>[ 1.585489] rk_mipi_screen_init_dt: lcd->screen->lcd_rst_delay = 10.
<7>[ 1.585527] of_get_named_gpio_flags exited with status 39
<3>[ 1.585561] lcd->lcd_rst_gpio=39,dsi->lcd_rst_atv_val=1
<3>[ 1.585583] rk_mipi_screen_init_dt: Can not read property: mipi_lcd_en.
<3>[ 1.585664]
<3>[ 1.585664] childnode->name =rockchip,on-cmds1:length=3
<3>[ 1.585695] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.585719]
<3>[ 1.585719] childnode->name =rockchip,on-cmds2:length=3
<3>[ 1.585749] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.585772]
<3>[ 1.585772] childnode->name =rockchip,on-cmds3:length=3
<3>[ 1.585801] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.585825]
<3>[ 1.585825] childnode->name =rockchip,on-cmds4:length=3
<3>[ 1.585854] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.585878]
<3>[ 1.585878] childnode->name =rockchip,on-cmds5:length=3
<3>[ 1.585907] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.585931]
<3>[ 1.585931] childnode->name =rockchip,on-cmds6:length=3
<3>[ 1.585960] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.585983]
<3>[ 1.585983] childnode->name =rockchip,on-cmds7:length=3
<3>[ 1.586013] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.586036]
<3>[ 1.586036] childnode->name =rockchip,on-cmds8:length=3
<3>[ 1.586065] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.586089]
<3>[ 1.586089] childnode->name =rockchip,on-cmds9:length=3
<3>[ 1.586118] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.586141]
<3>[ 1.586141] childnode->name =rockchip,on-cmds10:length=3
<3>[ 1.586170] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.586193]
<3>[ 1.586193] childnode->name =rockchip,on-cmds11:length=3
<3>[ 1.586223] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.586246]
<3>[ 1.586246] childnode->name =rockchip,on-cmds12:length=3
<3>[ 1.586275] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.586298]
<3>[ 1.586298] childnode->name =rockchip,on-cmds13:length=3
<3>[ 1.586328] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.586351]
<3>[ 1.586351] childnode->name =rockchip,on-cmds14:length=3
<3>[ 1.586381] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.586404]
<3>[ 1.586404] childnode->name =rockchip,on-cmds15:length=3
<3>[ 1.586433] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.586456]
<3>[ 1.586456] childnode->name =rockchip,on-cmds16:length=3
<3>[ 1.586486] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.586509]
<3>[ 1.586509] childnode->name =rockchip,on-cmds17:length=3
<3>[ 1.586538] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.586561]
<3>[ 1.586561] childnode->name =rockchip,on-cmds18:length=3
<3>[ 1.586591] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.586613]
<3>[ 1.586613] childnode->name =rockchip,on-cmds19:length=3
<3>[ 1.586643] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.586666]
<3>[ 1.586666] childnode->name =rockchip,on-cmds20:length=3
<3>[ 1.586695] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.586729]
<3>[ 1.586729] childnode->name =rockchip,on-cmds21:length=3
<3>[ 1.586760] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.586783]
<3>[ 1.586783] childnode->name =rockchip,on-cmds22:length=3
<3>[ 1.586813] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.586836]
<3>[ 1.586836] childnode->name =rockchip,on-cmds23:length=3
<3>[ 1.586866] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.586889]
<3>[ 1.586889] childnode->name =rockchip,on-cmds24:length=3
<3>[ 1.586918] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.586942]
<3>[ 1.586942] childnode->name =rockchip,on-cmds25:length=3
<3>[ 1.586971] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.586994]
<3>[ 1.586994] childnode->name =rockchip,on-cmds26:length=3
<3>[ 1.587023] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.587046]
<3>[ 1.587046] childnode->name =rockchip,on-cmds27:length=3
<3>[ 1.587075] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.587099]
<3>[ 1.587099] childnode->name =rockchip,on-cmds28:length=3
<3>[ 1.587128] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.587151]
<3>[ 1.587151] childnode->name =rockchip,on-cmds29:length=3
<3>[ 1.587181] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.587204]
<3>[ 1.587204] childnode->name =rockchip,on-cmds30:length=3
<3>[ 1.587233] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.587256]
<3>[ 1.587256] childnode->name =rockchip,on-cmds31:length=3
<3>[ 1.587286] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.587309]
<3>[ 1.587309] childnode->name =rockchip,on-cmds32:length=3
<3>[ 1.587338] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.587361]
<3>[ 1.587361] childnode->name =rockchip,on-cmds33:length=3
<3>[ 1.587391] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.587414]
<3>[ 1.587414] childnode->name =rockchip,on-cmds34:length=3
<3>[ 1.587443] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.587466]
<3>[ 1.587466] childnode->name =rockchip,on-cmds35:length=3
<3>[ 1.587496] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.587519]
<3>[ 1.587519] childnode->name =rockchip,on-cmds36:length=3
<3>[ 1.587548] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.587571]
<3>[ 1.587571] childnode->name =rockchip,on-cmds37:length=3
<3>[ 1.587600] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.587624]
<3>[ 1.587624] childnode->name =rockchip,on-cmds38:length=3
<3>[ 1.587653] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.587676]
<3>[ 1.587676] childnode->name =rockchip,on-cmds39:length=3
<3>[ 1.587705] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.587728]
<3>[ 1.587728] childnode->name =rockchip,on-cmds40:length=3
<3>[ 1.587758] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.587781]
<3>[ 1.587781] childnode->name =rockchip,on-cmds41:length=3
<3>[ 1.587810] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.587838]
<3>[ 1.587838] childnode->name =rockchip,on-cmds42:length=3
<3>[ 1.587868] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.587891]
<3>[ 1.587891] childnode->name =rockchip,on-cmds43:length=3
<3>[ 1.587920] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.587944]
<3>[ 1.587944] childnode->name =rockchip,on-cmds44:length=3
<3>[ 1.587973] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.587996]
<3>[ 1.587996] childnode->name =rockchip,on-cmds45:length=3
<3>[ 1.588026] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.588049]
<3>[ 1.588049] childnode->name =rockchip,on-cmds46:length=3
<3>[ 1.588079] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.588102]
<3>[ 1.588102] childnode->name =rockchip,on-cmds47:length=3
<3>[ 1.588131] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.588154]
<3>[ 1.588154] childnode->name =rockchip,on-cmds48:length=3
<3>[ 1.588183] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.588207]
<3>[ 1.588207] childnode->name =rockchip,on-cmds49:length=3
<3>[ 1.588236] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.588260]
<3>[ 1.588260] childnode->name =rockchip,on-cmds50:length=3
<3>[ 1.588289] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.588312]
<3>[ 1.588312] childnode->name =rockchip,on-cmds51:length=3
<3>[ 1.588342] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.588365]
<3>[ 1.588365] childnode->name =rockchip,on-cmds52:length=3
<3>[ 1.588394] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.588418]
<3>[ 1.588418] childnode->name =rockchip,on-cmds53:length=3
<3>[ 1.588447] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.588470]
<3>[ 1.588470] childnode->name =rockchip,on-cmds54:length=3
<3>[ 1.588500] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.588523]
<3>[ 1.588523] childnode->name =rockchip,on-cmds55:length=3
<3>[ 1.588552] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.588575]
<3>[ 1.588575] childnode->name =rockchip,on-cmds56:length=3
<3>[ 1.588605] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.588628]
<3>[ 1.588628] childnode->name =rockchip,on-cmds57:length=3
<3>[ 1.588658] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.588681]
<3>[ 1.588681] childnode->name =rockchip,on-cmds58:length=3
<3>[ 1.588710] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.588733]
<3>[ 1.588733] childnode->name =rockchip,on-cmds59:length=3
<3>[ 1.588763] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.588786]
<3>[ 1.588786] childnode->name =rockchip,on-cmds60:length=3
<3>[ 1.588815] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.588838]
<3>[ 1.588838] childnode->name =rockchip,on-cmds61:length=3
<3>[ 1.588868] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.588891]
<3>[ 1.588891] childnode->name =rockchip,on-cmds62:length=3
<3>[ 1.588920] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.588947]
<3>[ 1.588947] childnode->name =rockchip,on-cmds63:length=3
<3>[ 1.588976] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.588999]
<3>[ 1.588999] childnode->name =rockchip,on-cmds64:length=3
<3>[ 1.589029] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.589053]
<3>[ 1.589053] childnode->name =rockchip,on-cmds65:length=3
<3>[ 1.589082] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.589105]
<3>[ 1.589105] childnode->name =rockchip,on-cmds66:length=3
<3>[ 1.589135] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.589158]
<3>[ 1.589158] childnode->name =rockchip,on-cmds67:length=3
<3>[ 1.589188] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.589211]
<3>[ 1.589211] childnode->name =rockchip,on-cmds68:length=3
<3>[ 1.589241] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.589264]
<3>[ 1.589264] childnode->name =rockchip,on-cmds69:length=3
<3>[ 1.589294] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.589317]
<3>[ 1.589317] childnode->name =rockchip,on-cmds70:length=3
<3>[ 1.589346] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.589369]
<3>[ 1.589369] childnode->name =rockchip,on-cmds71:length=3
<3>[ 1.589437] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.589464]
<3>[ 1.589464] childnode->name =rockchip,on-cmds72:length=3
<3>[ 1.589494] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.589517]
<3>[ 1.589517] childnode->name =rockchip,on-cmds73:length=3
<3>[ 1.589546] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.589570]
<3>[ 1.589570] childnode->name =rockchip,on-cmds74:length=3
<3>[ 1.589599] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.589623]
<3>[ 1.589623] childnode->name =rockchip,on-cmds75:length=3
<3>[ 1.589652] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.589675]
<3>[ 1.589675] childnode->name =rockchip,on-cmds76:length=3
<3>[ 1.589704] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.589728]
<3>[ 1.589728] childnode->name =rockchip,on-cmds77:length=3
<3>[ 1.589757] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.589780]
<3>[ 1.589780] childnode->name =rockchip,on-cmds78:length=3
<3>[ 1.589809] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.589832]
<3>[ 1.589832] childnode->name =rockchip,on-cmds79:length=3
<3>[ 1.589862] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.589885]
<3>[ 1.589885] childnode->name =rockchip,on-cmds80:length=3
<3>[ 1.589914] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.589938]
<3>[ 1.589938] childnode->name =rockchip,on-cmds81:length=3
<3>[ 1.589967] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.589991]
<3>[ 1.589991] childnode->name =rockchip,on-cmds82:length=3
<3>[ 1.590020] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.590043]
<3>[ 1.590043] childnode->name =rockchip,on-cmds83:length=3
<3>[ 1.590073] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.590101]
<3>[ 1.590101] childnode->name =rockchip,on-cmds84:length=3
<3>[ 1.590131] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.590154]
<3>[ 1.590154] childnode->name =rockchip,on-cmds85:length=3
<3>[ 1.590183] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.590207]
<3>[ 1.590207] childnode->name =rockchip,on-cmds86:length=3
<3>[ 1.590236] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.590260]
<3>[ 1.590260] childnode->name =rockchip,on-cmds87:length=3
<3>[ 1.590289] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.590312]
<3>[ 1.590312] childnode->name =rockchip,on-cmds88:length=3
<3>[ 1.590341] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.590364]
<3>[ 1.590364] childnode->name =rockchip,on-cmds89:length=3
<3>[ 1.590394] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.590417]
<3>[ 1.590417] childnode->name =rockchip,on-cmds90:length=3
<3>[ 1.590446] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.590469]
<3>[ 1.590469] childnode->name =rockchip,on-cmds91:length=3
<3>[ 1.590499] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.590522]
<3>[ 1.590522] childnode->name =rockchip,on-cmds92:length=3
<3>[ 1.590552] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.590575]
<3>[ 1.590575] childnode->name =rockchip,on-cmds93:length=3
<3>[ 1.590604] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.590627]
<3>[ 1.590627] childnode->name =rockchip,on-cmds94:length=3
<3>[ 1.590657] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.590680]
<3>[ 1.590680] childnode->name =rockchip,on-cmds95:length=3
<3>[ 1.590709] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.590732]
<3>[ 1.590732] childnode->name =rockchip,on-cmds96:length=3
<3>[ 1.590761] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.590785]
<3>[ 1.590785] childnode->name =rockchip,on-cmds97:length=3
<3>[ 1.590814] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.590837]
<3>[ 1.590837] childnode->name =rockchip,on-cmds98:length=3
<3>[ 1.590867] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.590890]
<3>[ 1.590890] childnode->name =rockchip,on-cmds99:length=3
<3>[ 1.590919] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.590943]
<3>[ 1.590943] childnode->name =rockchip,on-cmds100:length=3
<3>[ 1.590973] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.590996]
<3>[ 1.590996] childnode->name =rockchip,on-cmds101:length=3
<3>[ 1.591025] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.591049]
<3>[ 1.591049] childnode->name =rockchip,on-cmds102:length=3
<3>[ 1.591078] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.591101]
<3>[ 1.591101] childnode->name =rockchip,on-cmds103:length=3
<3>[ 1.591131] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.591154]
<3>[ 1.591154] childnode->name =rockchip,on-cmds104:length=3
<3>[ 1.591184] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.591211]
<3>[ 1.591211] childnode->name =rockchip,on-cmds105:length=3
<3>[ 1.591241] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.591264]
<3>[ 1.591264] childnode->name =rockchip,on-cmds106:length=3
<3>[ 1.591294] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.591317]
<3>[ 1.591317] childnode->name =rockchip,on-cmds107:length=3
<3>[ 1.591347] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.591370]
<3>[ 1.591370] childnode->name =rockchip,on-cmds108:length=3
<3>[ 1.591399] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.591423]
<3>[ 1.591423] childnode->name =rockchip,on-cmds109:length=3
<3>[ 1.591452] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.591475]
<3>[ 1.591475] childnode->name =rockchip,on-cmds110:length=3
<3>[ 1.591505] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.591528]
<3>[ 1.591528] childnode->name =rockchip,on-cmds111:length=3
<3>[ 1.591557] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.591581]
<3>[ 1.591581] childnode->name =rockchip,on-cmds112:length=3
<3>[ 1.591610] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.591634]
<3>[ 1.591634] childnode->name =rockchip,on-cmds113:length=3
<3>[ 1.591663] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.591686]
<3>[ 1.591686] childnode->name =rockchip,on-cmds114:length=3
<3>[ 1.591716] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.591739]
<3>[ 1.591739] childnode->name =rockchip,on-cmds115:length=3
<3>[ 1.591769] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.591792]
<3>[ 1.591792] childnode->name =rockchip,on-cmds116:length=3
<3>[ 1.591822] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.591845]
<3>[ 1.591845] childnode->name =rockchip,on-cmds117:length=3
<3>[ 1.591875] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.591898]
<3>[ 1.591898] childnode->name =rockchip,on-cmds118:length=3
<3>[ 1.591927] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.591951]
<3>[ 1.591951] childnode->name =rockchip,on-cmds119:length=3
<3>[ 1.591980] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.592003]
<3>[ 1.592003] childnode->name =rockchip,on-cmds120:length=3
<3>[ 1.592033] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.592057]
<3>[ 1.592057] childnode->name =rockchip,on-cmds121:length=3
<3>[ 1.592086] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.592109]
<3>[ 1.592109] childnode->name =rockchip,on-cmds122:length=3
<3>[ 1.592139] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.592162]
<3>[ 1.592162] childnode->name =rockchip,on-cmds123:length=3
<3>[ 1.592192] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.592215]
<3>[ 1.592215] childnode->name =rockchip,on-cmds124:length=3
<3>[ 1.592245] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.592268]
<3>[ 1.592268] childnode->name =rockchip,on-cmds125:length=3
<3>[ 1.592298] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.592326]
<3>[ 1.592326] childnode->name =rockchip,on-cmds126:length=3
<3>[ 1.592355] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.592379]
<3>[ 1.592379] childnode->name =rockchip,on-cmds127:length=3
<3>[ 1.592408] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.592431]
<3>[ 1.592431] childnode->name =rockchip,on-cmds128:length=3
<3>[ 1.592461] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.592484]
<3>[ 1.592484] childnode->name =rockchip,on-cmds129:length=3
<3>[ 1.592513] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.592537]
<3>[ 1.592537] childnode->name =rockchip,on-cmds130:length=3
<3>[ 1.592566] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.592589]
<3>[ 1.592589] childnode->name =rockchip,on-cmds131:length=3
<3>[ 1.592619] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.592642]
<3>[ 1.592642] childnode->name =rockchip,on-cmds132:length=3
<3>[ 1.592671] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.592695]
<3>[ 1.592695] childnode->name =rockchip,on-cmds133:length=3
<3>[ 1.592724] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.592747]
<3>[ 1.592747] childnode->name =rockchip,on-cmds134:length=3
<3>[ 1.592777] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.592800]
<3>[ 1.592800] childnode->name =rockchip,on-cmds135:length=3
<3>[ 1.592830] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.592853]
<3>[ 1.592853] childnode->name =rockchip,on-cmds136:length=3
<3>[ 1.592882] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.592906]
<3>[ 1.592906] childnode->name =rockchip,on-cmds137:length=3
<3>[ 1.592935] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.592959]
<3>[ 1.592959] childnode->name =rockchip,on-cmds138:length=3
<3>[ 1.592988] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.593011]
<3>[ 1.593011] childnode->name =rockchip,on-cmds139:length=3
<3>[ 1.593041] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.593065]
<3>[ 1.593065] childnode->name =rockchip,on-cmds140:length=3
<3>[ 1.593094] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.593117]
<3>[ 1.593117] childnode->name =rockchip,on-cmds141:length=3
<3>[ 1.593147] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.593170]
<3>[ 1.593170] childnode->name =rockchip,on-cmds142:length=3
<3>[ 1.593200] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.593223]
<3>[ 1.593223] childnode->name =rockchip,on-cmds143:length=3
<3>[ 1.593253] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.593275]
<3>[ 1.593275] childnode->name =rockchip,on-cmds144:length=3
<3>[ 1.593305] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.593328]
<3>[ 1.593328] childnode->name =rockchip,on-cmds145:length=3
<3>[ 1.593358] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.593381]
<3>[ 1.593381] childnode->name =rockchip,on-cmds146:length=3
<3>[ 1.593411] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.593438]
<3>[ 1.593438] childnode->name =rockchip,on-cmds147:length=3
<3>[ 1.593468] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.593492]
<3>[ 1.593492] childnode->name =rockchip,on-cmds148:length=3
<3>[ 1.593522] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.593545]
<3>[ 1.593545] childnode->name =rockchip,on-cmds149:length=3
<3>[ 1.593575] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.593598]
<3>[ 1.593598] childnode->name =rockchip,on-cmds150:length=3
<3>[ 1.593628] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.593651]
<3>[ 1.593651] childnode->name =rockchip,on-cmds151:length=3
<3>[ 1.593680] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.593703]
<3>[ 1.593703] childnode->name =rockchip,on-cmds152:length=3
<3>[ 1.593733] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.593756]
<3>[ 1.593756] childnode->name =rockchip,on-cmds153:length=3
<3>[ 1.593786] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.593809]
<3>[ 1.593809] childnode->name =rockchip,on-cmds154:length=3
<3>[ 1.593839] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.593862]
<3>[ 1.593862] childnode->name =rockchip,on-cmds155:length=3
<3>[ 1.593891] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.593915]
<3>[ 1.593915] childnode->name =rockchip,on-cmds156:length=3
<3>[ 1.593944] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.593967]
<3>[ 1.593967] childnode->name =rockchip,on-cmds157:length=3
<3>[ 1.593997] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.594020]
<3>[ 1.594020] childnode->name =rockchip,on-cmds158:length=3
<3>[ 1.594050] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.594073]
<3>[ 1.594073] childnode->name =rockchip,on-cmds159:length=3
<3>[ 1.594103] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.594126]
<3>[ 1.594126] childnode->name =rockchip,on-cmds160:length=3
<3>[ 1.594156] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.594179]
<3>[ 1.594179] childnode->name =rockchip,on-cmds161:length=3
<3>[ 1.594209] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.594232]
<3>[ 1.594232] childnode->name =rockchip,on-cmds162:length=3
<3>[ 1.594262] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.594285]
<3>[ 1.594285] childnode->name =rockchip,on-cmds163:length=3
<3>[ 1.594315] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.594338]
<3>[ 1.594338] childnode->name =rockchip,on-cmds164:length=3
<3>[ 1.594367] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.594391]
<3>[ 1.594391] childnode->name =rockchip,on-cmds165:length=3
<3>[ 1.594421] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.594444]
<3>[ 1.594444] childnode->name =rockchip,on-cmds166:length=3
<3>[ 1.594474] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.594497]
<3>[ 1.594497] childnode->name =rockchip,on-cmds167:length=3
<3>[ 1.594526] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.594553]
<3>[ 1.594553] childnode->name =rockchip,on-cmds168:length=3
<3>[ 1.594583] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.594606]
<3>[ 1.594606] childnode->name =rockchip,on-cmds169:length=3
<3>[ 1.594635] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.594659]
<3>[ 1.594659] childnode->name =rockchip,on-cmds170:length=3
<3>[ 1.594688] dcs_cmd->dcs_cmd.cmd_len=3
<3>[ 1.594712]
<3>[ 1.594712] childnode->name =rockchip,on-cmds171:length=2
<3>[ 1.594741] dcs_cmd->dcs_cmd.cmd_len=2
<3>[ 1.594765]
<3>[ 1.594765] childnode->name =rockchip,on-cmds172:length=2
<3>[ 1.594794] dcs_cmd->dcs_cmd.cmd_len=2
<3>[ 1.594817]
<3>[ 1.594817] childnode->name =rockchip,on-cmds173:length=3
<3>[ 1.594847] dcs_cmd->dcs_cmd.cmd_len=3
<4>[ 1.594872]
<4>[ 1.594872] dcs_name:rockchip,on-cmds1,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.594872]
<4>[ 1.594912] [1]=15,[2]=e0,[3]=00,
<4>[ 1.594912] dcs_name:rockchip,on-cmds2,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.594912]
<4>[ 1.594963] [1]=15,[2]=e1,[3]=93,
<4>[ 1.594963] dcs_name:rockchip,on-cmds3,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.594963]
<4>[ 1.595012] [1]=15,[2]=e2,[3]=65,
<4>[ 1.595012] dcs_name:rockchip,on-cmds4,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595012]
<4>[ 1.595061] [1]=15,[2]=e3,[3]=f8,
<4>[ 1.595061] dcs_name:rockchip,on-cmds5,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595061]
<4>[ 1.595110] [1]=15,[2]=80,[3]=03,
<4>[ 1.595110] dcs_name:rockchip,on-cmds6,dcs_type:1,side_id:0,cmd_len:3,delay:120
<4>[ 1.595110]
<4>[ 1.595158] [1]=15,[2]=e0,[3]=04,
<4>[ 1.595158] dcs_name:rockchip,on-cmds7,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595158]
<4>[ 1.595207] [1]=15,[2]=2b,[3]=2b,
<4>[ 1.595207] dcs_name:rockchip,on-cmds8,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595207]
<4>[ 1.595256] [1]=15,[2]=2d,[3]=03,
<4>[ 1.595256] dcs_name:rockchip,on-cmds9,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595256]
<4>[ 1.595305] [1]=15,[2]=2e,[3]=44,
<4>[ 1.595305] dcs_name:rockchip,on-cmds10,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595305]
<4>[ 1.595354] [1]=15,[2]=e0,[3]=01,
<4>[ 1.595354] dcs_name:rockchip,on-cmds11,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595354]
<4>[ 1.595402] [1]=15,[2]=00,[3]=00,
<4>[ 1.595402] dcs_name:rockchip,on-cmds12,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595402]
<4>[ 1.595450] [1]=15,[2]=01,[3]=6a,
<4>[ 1.595450] dcs_name:rockchip,on-cmds13,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595450]
<4>[ 1.595499] [1]=15,[2]=17,[3]=00,
<4>[ 1.595499] dcs_name:rockchip,on-cmds14,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595499]
<4>[ 1.595548] [1]=15,[2]=18,[3]=c0,
<4>[ 1.595548] dcs_name:rockchip,on-cmds15,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595548]
<4>[ 1.595596] [1]=15,[2]=19,[3]=01,
<4>[ 1.595596] dcs_name:rockchip,on-cmds16,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595596]
<4>[ 1.595645] [1]=15,[2]=1a,[3]=00,
<4>[ 1.595645] dcs_name:rockchip,on-cmds17,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595645]
<4>[ 1.595694] [1]=15,[2]=1b,[3]=c0,
<4>[ 1.595694] dcs_name:rockchip,on-cmds18,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595694]
<4>[ 1.595743] [1]=15,[2]=1c,[3]=01,
<4>[ 1.595743] dcs_name:rockchip,on-cmds19,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595743]
<4>[ 1.595792] [1]=15,[2]=1f,[3]=6a,
<4>[ 1.595792] dcs_name:rockchip,on-cmds20,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595792]
<4>[ 1.595840] [1]=15,[2]=20,[3]=23,
<4>[ 1.595840] dcs_name:rockchip,on-cmds21,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595840]
<4>[ 1.595889] [1]=15,[2]=21,[3]=23,
<4>[ 1.595889] dcs_name:rockchip,on-cmds22,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595889]
<4>[ 1.595938] [1]=15,[2]=22,[3]=0e,
<4>[ 1.595938] dcs_name:rockchip,on-cmds23,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595938]
<4>[ 1.595986] [1]=15,[2]=35,[3]=28,
<4>[ 1.595986] dcs_name:rockchip,on-cmds24,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.595986]
<4>[ 1.596036] [1]=15,[2]=37,[3]=59,
<4>[ 1.596036] dcs_name:rockchip,on-cmds25,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596036]
<4>[ 1.596085] [1]=15,[2]=38,[3]=05,
<4>[ 1.596085] dcs_name:rockchip,on-cmds26,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596085]
<4>[ 1.596133] [1]=15,[2]=39,[3]=04,
<4>[ 1.596133] dcs_name:rockchip,on-cmds27,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596133]
<4>[ 1.596182] [1]=15,[2]=3a,[3]=08,
<4>[ 1.596182] dcs_name:rockchip,on-cmds28,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596182]
<4>[ 1.596231] [1]=15,[2]=3b,[3]=08,
<4>[ 1.596231] dcs_name:rockchip,on-cmds29,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596231]
<4>[ 1.596280] [1]=15,[2]=3c,[3]=7c,
<4>[ 1.596280] dcs_name:rockchip,on-cmds30,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596280]
<4>[ 1.596329] [1]=15,[2]=3d,[3]=ff,
<4>[ 1.596329] dcs_name:rockchip,on-cmds31,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596329]
<4>[ 1.596378] [1]=15,[2]=3e,[3]=ff,
<4>[ 1.596378] dcs_name:rockchip,on-cmds32,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596378]
<4>[ 1.596426] [1]=15,[2]=3f,[3]=ff,
<4>[ 1.596426] dcs_name:rockchip,on-cmds33,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596426]
<4>[ 1.596475] [1]=15,[2]=40,[3]=06,
<4>[ 1.596475] dcs_name:rockchip,on-cmds34,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596475]
<4>[ 1.596524] [1]=15,[2]=41,[3]=a0,
<4>[ 1.596524] dcs_name:rockchip,on-cmds35,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596524]
<4>[ 1.596573] [1]=15,[2]=43,[3]=08,
<4>[ 1.596573] dcs_name:rockchip,on-cmds36,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596573]
<4>[ 1.596622] [1]=15,[2]=44,[3]=0b,
<4>[ 1.596622] dcs_name:rockchip,on-cmds37,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596622]
<4>[ 1.596670] [1]=15,[2]=45,[3]=88,
<4>[ 1.596670] dcs_name:rockchip,on-cmds38,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596670]
<4>[ 1.596719] [1]=15,[2]=55,[3]=0f,
<4>[ 1.596719] dcs_name:rockchip,on-cmds39,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596719]
<4>[ 1.596768] [1]=15,[2]=56,[3]=01,
<4>[ 1.596768] dcs_name:rockchip,on-cmds40,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596768]
<4>[ 1.596816] [1]=15,[2]=57,[3]=ad,
<4>[ 1.596816] dcs_name:rockchip,on-cmds41,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596816]
<4>[ 1.596865] [1]=15,[2]=58,[3]=0a,
<4>[ 1.596865] dcs_name:rockchip,on-cmds42,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596865]
<4>[ 1.596914] [1]=15,[2]=59,[3]=0a,
<4>[ 1.596914] dcs_name:rockchip,on-cmds43,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596914]
<4>[ 1.596962] [1]=15,[2]=5a,[3]=28,
<4>[ 1.596962] dcs_name:rockchip,on-cmds44,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.596962]
<4>[ 1.597011] [1]=15,[2]=5b,[3]=1e,
<4>[ 1.597011] dcs_name:rockchip,on-cmds45,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597011]
<4>[ 1.597060] [1]=15,[2]=5d,[3]=5c,
<4>[ 1.597060] dcs_name:rockchip,on-cmds46,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597060]
<4>[ 1.597108] [1]=15,[2]=5e,[3]=40,
<4>[ 1.597108] dcs_name:rockchip,on-cmds47,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597108]
<4>[ 1.597157] [1]=15,[2]=5f,[3]=30,
<4>[ 1.597157] dcs_name:rockchip,on-cmds48,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597157]
<4>[ 1.597206] [1]=15,[2]=60,[3]=24,
<4>[ 1.597206] dcs_name:rockchip,on-cmds49,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597206]
<4>[ 1.597255] [1]=15,[2]=61,[3]=21,
<4>[ 1.597255] dcs_name:rockchip,on-cmds50,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597255]
<4>[ 1.597303] [1]=15,[2]=62,[3]=13,
<4>[ 1.597303] dcs_name:rockchip,on-cmds51,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597303]
<4>[ 1.597352] [1]=15,[2]=63,[3]=1a,
<4>[ 1.597352] dcs_name:rockchip,on-cmds52,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597352]
<4>[ 1.597401] [1]=15,[2]=64,[3]=07,
<4>[ 1.597401] dcs_name:rockchip,on-cmds53,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597401]
<4>[ 1.597450] [1]=15,[2]=65,[3]=23,
<4>[ 1.597450] dcs_name:rockchip,on-cmds54,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597450]
<4>[ 1.597499] [1]=15,[2]=66,[3]=25,
<4>[ 1.597499] dcs_name:rockchip,on-cmds55,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597499]
<4>[ 1.597548] [1]=15,[2]=67,[3]=27,
<4>[ 1.597548] dcs_name:rockchip,on-cmds56,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597548]
<4>[ 1.597597] [1]=15,[2]=68,[3]=47,
<4>[ 1.597597] dcs_name:rockchip,on-cmds57,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597597]
<4>[ 1.597645] [1]=15,[2]=69,[3]=37,
<4>[ 1.597645] dcs_name:rockchip,on-cmds58,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597645]
<4>[ 1.597694] [1]=15,[2]=6a,[3]=3f,
<4>[ 1.597694] dcs_name:rockchip,on-cmds59,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597694]
<4>[ 1.597743] [1]=15,[2]=6b,[3]=32,
<4>[ 1.597743] dcs_name:rockchip,on-cmds60,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597743]
<4>[ 1.597792] [1]=15,[2]=6c,[3]=2e,
<4>[ 1.597792] dcs_name:rockchip,on-cmds61,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597792]
<4>[ 1.597840] [1]=15,[2]=6d,[3]=22,
<4>[ 1.597840] dcs_name:rockchip,on-cmds62,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597840]
<4>[ 1.597889] [1]=15,[2]=6e,[3]=11,
<4>[ 1.597889] dcs_name:rockchip,on-cmds63,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597889]
<4>[ 1.597937] [1]=15,[2]=6f,[3]=00,
<4>[ 1.597937] dcs_name:rockchip,on-cmds64,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597937]
<4>[ 1.597986] [1]=15,[2]=70,[3]=5c,
<4>[ 1.597986] dcs_name:rockchip,on-cmds65,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.597986]
<4>[ 1.598035] [1]=15,[2]=71,[3]=40,
<4>[ 1.598035] dcs_name:rockchip,on-cmds66,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598035]
<4>[ 1.598084] [1]=15,[2]=72,[3]=30,
<4>[ 1.598084] dcs_name:rockchip,on-cmds67,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598084]
<4>[ 1.598132] [1]=15,[2]=73,[3]=24,
<4>[ 1.598132] dcs_name:rockchip,on-cmds68,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598132]
<4>[ 1.598181] [1]=15,[2]=74,[3]=21,
<4>[ 1.598181] dcs_name:rockchip,on-cmds69,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598181]
<4>[ 1.598230] [1]=15,[2]=75,[3]=13,
<4>[ 1.598230] dcs_name:rockchip,on-cmds70,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598230]
<4>[ 1.598279] [1]=15,[2]=76,[3]=1a,
<4>[ 1.598279] dcs_name:rockchip,on-cmds71,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598279]
<4>[ 1.598328] [1]=15,[2]=77,[3]=07,
<4>[ 1.598328] dcs_name:rockchip,on-cmds72,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598328]
<4>[ 1.598376] [1]=15,[2]=78,[3]=23,
<4>[ 1.598376] dcs_name:rockchip,on-cmds73,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598376]
<4>[ 1.598425] [1]=15,[2]=79,[3]=25,
<4>[ 1.598425] dcs_name:rockchip,on-cmds74,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598425]
<4>[ 1.598474] [1]=15,[2]=7a,[3]=27,
<4>[ 1.598474] dcs_name:rockchip,on-cmds75,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598474]
<4>[ 1.598522] [1]=15,[2]=7b,[3]=47,
<4>[ 1.598522] dcs_name:rockchip,on-cmds76,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598522]
<4>[ 1.598571] [1]=15,[2]=7c,[3]=37,
<4>[ 1.598571] dcs_name:rockchip,on-cmds77,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598571]
<4>[ 1.598620] [1]=15,[2]=7d,[3]=3f,
<4>[ 1.598620] dcs_name:rockchip,on-cmds78,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598620]
<4>[ 1.598669] [1]=15,[2]=7e,[3]=32,
<4>[ 1.598669] dcs_name:rockchip,on-cmds79,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598669]
<4>[ 1.598718] [1]=15,[2]=7f,[3]=2e,
<4>[ 1.598718] dcs_name:rockchip,on-cmds80,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598718]
<4>[ 1.598767] [1]=15,[2]=80,[3]=22,
<4>[ 1.598767] dcs_name:rockchip,on-cmds81,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598767]
<4>[ 1.598815] [1]=15,[2]=81,[3]=11,
<4>[ 1.598815] dcs_name:rockchip,on-cmds82,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598815]
<4>[ 1.598864] [1]=15,[2]=82,[3]=00,
<4>[ 1.598864] dcs_name:rockchip,on-cmds83,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598864]
<4>[ 1.598913] [1]=15,[2]=e0,[3]=02,
<4>[ 1.598913] dcs_name:rockchip,on-cmds84,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598913]
<4>[ 1.598961] [1]=15,[2]=00,[3]=44,
<4>[ 1.598961] dcs_name:rockchip,on-cmds85,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.598961]
<4>[ 1.599010] [1]=15,[2]=01,[3]=44,
<4>[ 1.599010] dcs_name:rockchip,on-cmds86,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599010]
<4>[ 1.599059] [1]=15,[2]=02,[3]=45,
<4>[ 1.599059] dcs_name:rockchip,on-cmds87,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599059]
<4>[ 1.599108] [1]=15,[2]=03,[3]=45,
<4>[ 1.599108] dcs_name:rockchip,on-cmds88,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599108]
<4>[ 1.599156] [1]=15,[2]=04,[3]=46,
<4>[ 1.599156] dcs_name:rockchip,on-cmds89,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599156]
<4>[ 1.599205] [1]=15,[2]=05,[3]=46,
<4>[ 1.599205] dcs_name:rockchip,on-cmds90,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599205]
<4>[ 1.599254] [1]=15,[2]=06,[3]=47,
<4>[ 1.599254] dcs_name:rockchip,on-cmds91,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599254]
<4>[ 1.599333] [1]=15,[2]=07,[3]=47,
<4>[ 1.599333] dcs_name:rockchip,on-cmds92,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599333]
<4>[ 1.599382] [1]=15,[2]=08,[3]=1d,
<4>[ 1.599382] dcs_name:rockchip,on-cmds93,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599382]
<4>[ 1.599430] [1]=15,[2]=09,[3]=1d,
<4>[ 1.599430] dcs_name:rockchip,on-cmds94,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599430]
<4>[ 1.599479] [1]=15,[2]=0a,[3]=1d,
<4>[ 1.599479] dcs_name:rockchip,on-cmds95,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599479]
<4>[ 1.599528] [1]=15,[2]=0b,[3]=1d,
<4>[ 1.599528] dcs_name:rockchip,on-cmds96,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599528]
<4>[ 1.599576] [1]=15,[2]=0c,[3]=1d,
<4>[ 1.599576] dcs_name:rockchip,on-cmds97,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599576]
<4>[ 1.599625] [1]=15,[2]=0d,[3]=1d,
<4>[ 1.599625] dcs_name:rockchip,on-cmds98,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599625]
<4>[ 1.599674] [1]=15,[2]=0e,[3]=1d,
<4>[ 1.599674] dcs_name:rockchip,on-cmds99,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599674]
<4>[ 1.599723] [1]=15,[2]=0f,[3]=57,
<4>[ 1.599723] dcs_name:rockchip,on-cmds100,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599723]
<4>[ 1.599772] [1]=15,[2]=10,[3]=57,
<4>[ 1.599772] dcs_name:rockchip,on-cmds101,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599772]
<4>[ 1.599820] [1]=15,[2]=11,[3]=58,
<4>[ 1.599820] dcs_name:rockchip,on-cmds102,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599820]
<4>[ 1.599870] [1]=15,[2]=12,[3]=58,
<4>[ 1.599870] dcs_name:rockchip,on-cmds103,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599870]
<4>[ 1.599918] [1]=15,[2]=13,[3]=40,
<4>[ 1.599918] dcs_name:rockchip,on-cmds104,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599918]
<4>[ 1.599968] [1]=15,[2]=14,[3]=55,
<4>[ 1.599968] dcs_name:rockchip,on-cmds105,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.599968]
<4>[ 1.600017] [1]=15,[2]=15,[3]=55,
<4>[ 1.600017] dcs_name:rockchip,on-cmds106,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600017]
<4>[ 1.600066] [1]=15,[2]=16,[3]=44,
<4>[ 1.600066] dcs_name:rockchip,on-cmds107,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600066]
<4>[ 1.600114] [1]=15,[2]=17,[3]=44,
<4>[ 1.600114] dcs_name:rockchip,on-cmds108,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600114]
<4>[ 1.600163] [1]=15,[2]=18,[3]=45,
<4>[ 1.600163] dcs_name:rockchip,on-cmds109,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600163]
<4>[ 1.600212] [1]=15,[2]=19,[3]=45,
<4>[ 1.600212] dcs_name:rockchip,on-cmds110,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600212]
<4>[ 1.600261] [1]=15,[2]=1a,[3]=46,
<4>[ 1.600261] dcs_name:rockchip,on-cmds111,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600261]
<4>[ 1.600310] [1]=15,[2]=1b,[3]=46,
<4>[ 1.600310] dcs_name:rockchip,on-cmds112,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600310]
<4>[ 1.600359] [1]=15,[2]=1c,[3]=47,
<4>[ 1.600359] dcs_name:rockchip,on-cmds113,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600359]
<4>[ 1.600408] [1]=15,[2]=1d,[3]=47,
<4>[ 1.600408] dcs_name:rockchip,on-cmds114,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600408]
<4>[ 1.600457] [1]=15,[2]=1e,[3]=1d,
<4>[ 1.600457] dcs_name:rockchip,on-cmds115,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600457]
<4>[ 1.600506] [1]=15,[2]=1f,[3]=1d,
<4>[ 1.600506] dcs_name:rockchip,on-cmds116,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600506]
<4>[ 1.600555] [1]=15,[2]=20,[3]=1d,
<4>[ 1.600555] dcs_name:rockchip,on-cmds117,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600555]
<4>[ 1.600604] [1]=15,[2]=21,[3]=1d,
<4>[ 1.600604] dcs_name:rockchip,on-cmds118,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600604]
<4>[ 1.600652] [1]=15,[2]=22,[3]=1d,
<4>[ 1.600652] dcs_name:rockchip,on-cmds119,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600652]
<4>[ 1.600701] [1]=15,[2]=23,[3]=1d,
<4>[ 1.600701] dcs_name:rockchip,on-cmds120,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600701]
<4>[ 1.600750] [1]=15,[2]=24,[3]=1d,
<4>[ 1.600750] dcs_name:rockchip,on-cmds121,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600750]
<4>[ 1.600799] [1]=15,[2]=25,[3]=57,
<4>[ 1.600799] dcs_name:rockchip,on-cmds122,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600799]
<4>[ 1.600849] [1]=15,[2]=26,[3]=57,
<4>[ 1.600849] dcs_name:rockchip,on-cmds123,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600849]
<4>[ 1.600898] [1]=15,[2]=27,[3]=58,
<4>[ 1.600898] dcs_name:rockchip,on-cmds124,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600898]
<4>[ 1.600946] [1]=15,[2]=28,[3]=58,
<4>[ 1.600946] dcs_name:rockchip,on-cmds125,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600946]
<4>[ 1.600995] [1]=15,[2]=29,[3]=40,
<4>[ 1.600995] dcs_name:rockchip,on-cmds126,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.600995]
<4>[ 1.601045] [1]=15,[2]=2a,[3]=55,
<4>[ 1.601045] dcs_name:rockchip,on-cmds127,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601045]
<4>[ 1.601093] [1]=15,[2]=2b,[3]=55,
<4>[ 1.601093] dcs_name:rockchip,on-cmds128,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601093]
<4>[ 1.601142] [1]=15,[2]=58,[3]=40,
<4>[ 1.601142] dcs_name:rockchip,on-cmds129,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601142]
<4>[ 1.601191] [1]=15,[2]=59,[3]=00,
<4>[ 1.601191] dcs_name:rockchip,on-cmds130,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601191]
<4>[ 1.601241] [1]=15,[2]=5a,[3]=00,
<4>[ 1.601241] dcs_name:rockchip,on-cmds131,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601241]
<4>[ 1.601290] [1]=15,[2]=5b,[3]=00,
<4>[ 1.601290] dcs_name:rockchip,on-cmds132,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601290]
<4>[ 1.601338] [1]=15,[2]=5c,[3]=0a,
<4>[ 1.601338] dcs_name:rockchip,on-cmds133,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601338]
<4>[ 1.601387] [1]=15,[2]=5d,[3]=10,
<4>[ 1.601387] dcs_name:rockchip,on-cmds134,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601387]
<4>[ 1.601436] [1]=15,[2]=5e,[3]=01,
<4>[ 1.601436] dcs_name:rockchip,on-cmds135,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601436]
<4>[ 1.601485] [1]=15,[2]=5f,[3]=02,
<4>[ 1.601485] dcs_name:rockchip,on-cmds136,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601485]
<4>[ 1.601533] [1]=15,[2]=60,[3]=10,
<4>[ 1.601533] dcs_name:rockchip,on-cmds137,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601533]
<4>[ 1.601582] [1]=15,[2]=61,[3]=01,
<4>[ 1.601582] dcs_name:rockchip,on-cmds138,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601582]
<4>[ 1.601631] [1]=15,[2]=62,[3]=02,
<4>[ 1.601631] dcs_name:rockchip,on-cmds139,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601631]
<4>[ 1.601679] [1]=15,[2]=63,[3]=0b,
<4>[ 1.601679] dcs_name:rockchip,on-cmds140,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601679]
<4>[ 1.601728] [1]=15,[2]=64,[3]=54,
<4>[ 1.601728] dcs_name:rockchip,on-cmds141,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601728]
<4>[ 1.601777] [1]=15,[2]=65,[3]=45,
<4>[ 1.601777] dcs_name:rockchip,on-cmds142,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601777]
<4>[ 1.601826] [1]=15,[2]=66,[3]=07,
<4>[ 1.601826] dcs_name:rockchip,on-cmds143,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601826]
<4>[ 1.601874] [1]=15,[2]=67,[3]=31,
<4>[ 1.601874] dcs_name:rockchip,on-cmds144,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601874]
<4>[ 1.601924] [1]=15,[2]=68,[3]=0b,
<4>[ 1.601924] dcs_name:rockchip,on-cmds145,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601924]
<4>[ 1.601972] [1]=15,[2]=69,[3]=1e,
<4>[ 1.601972] dcs_name:rockchip,on-cmds146,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.601972]
<4>[ 1.602021] [1]=15,[2]=6a,[3]=54,
<4>[ 1.602021] dcs_name:rockchip,on-cmds147,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602021]
<4>[ 1.602070] [1]=15,[2]=6b,[3]=04,
<4>[ 1.602070] dcs_name:rockchip,on-cmds148,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602070]
<4>[ 1.602119] [1]=15,[2]=6c,[3]=00,
<4>[ 1.602119] dcs_name:rockchip,on-cmds149,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602119]
<4>[ 1.602168] [1]=15,[2]=6d,[3]=04,
<4>[ 1.602168] dcs_name:rockchip,on-cmds150,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602168]
<4>[ 1.602216] [1]=15,[2]=6e,[3]=00,
<4>[ 1.602216] dcs_name:rockchip,on-cmds151,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602216]
<4>[ 1.602266] [1]=15,[2]=6f,[3]=88,
<4>[ 1.602266] dcs_name:rockchip,on-cmds152,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602266]
<4>[ 1.602315] [1]=15,[2]=70,[3]=00,
<4>[ 1.602315] dcs_name:rockchip,on-cmds153,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602315]
<4>[ 1.602363] [1]=15,[2]=71,[3]=00,
<4>[ 1.602363] dcs_name:rockchip,on-cmds154,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602363]
<4>[ 1.602412] [1]=15,[2]=72,[3]=06,
<4>[ 1.602412] dcs_name:rockchip,on-cmds155,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602412]
<4>[ 1.602460] [1]=15,[2]=73,[3]=7b,
<4>[ 1.602460] dcs_name:rockchip,on-cmds156,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602460]
<4>[ 1.602509] [1]=15,[2]=74,[3]=00,
<4>[ 1.602509] dcs_name:rockchip,on-cmds157,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602509]
<4>[ 1.602558] [1]=15,[2]=75,[3]=f8,
<4>[ 1.602558] dcs_name:rockchip,on-cmds158,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602558]
<4>[ 1.602607] [1]=15,[2]=76,[3]=00,
<4>[ 1.602607] dcs_name:rockchip,on-cmds159,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602607]
<4>[ 1.602656] [1]=15,[2]=77,[3]=0d,
<4>[ 1.602656] dcs_name:rockchip,on-cmds160,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602656]
<4>[ 1.602704] [1]=15,[2]=78,[3]=14,
<4>[ 1.602704] dcs_name:rockchip,on-cmds161,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602704]
<4>[ 1.602753] [1]=15,[2]=79,[3]=00,
<4>[ 1.602753] dcs_name:rockchip,on-cmds162,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602753]
<4>[ 1.602802] [1]=15,[2]=7a,[3]=00,
<4>[ 1.602802] dcs_name:rockchip,on-cmds163,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602802]
<4>[ 1.602851] [1]=15,[2]=7b,[3]=00,
<4>[ 1.602851] dcs_name:rockchip,on-cmds164,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602851]
<4>[ 1.602900] [1]=15,[2]=7c,[3]=00,
<4>[ 1.602900] dcs_name:rockchip,on-cmds165,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602900]
<4>[ 1.602949] [1]=15,[2]=7d,[3]=03,
<4>[ 1.602949] dcs_name:rockchip,on-cmds166,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602949]
<4>[ 1.602998] [1]=15,[2]=7e,[3]=7b,
<4>[ 1.602998] dcs_name:rockchip,on-cmds167,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.602998]
<4>[ 1.603046] [1]=15,[2]=e0,[3]=00,
<4>[ 1.603046] dcs_name:rockchip,on-cmds168,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.603046]
<4>[ 1.603095] [1]=15,[2]=09,[3]=10,
<4>[ 1.603095] dcs_name:rockchip,on-cmds169,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.603095]
<4>[ 1.603144] [1]=15,[2]=e6,[3]=02,
<4>[ 1.603144] dcs_name:rockchip,on-cmds170,dcs_type:1,side_id:0,cmd_len:3,delay:0
<4>[ 1.603144]
<4>[ 1.603193] [1]=15,[2]=e7,[3]=06,
<4>[ 1.603193] dcs_name:rockchip,on-cmds171,dcs_type:1,side_id:0,cmd_len:2,delay:120
<4>[ 1.603193]
<4>[ 1.603242] [1]=05,[2]=11,
<4>[ 1.603242] dcs_name:rockchip,on-cmds172,dcs_type:1,side_id:0,cmd_len:2,delay:50
<4>[ 1.603242]
<4>[ 1.603285] [1]=05,[2]=29,
<4>[ 1.603285] dcs_name:rockchip,on-cmds173,dcs_type:1,side_id:0,cmd_len:3,delay:10
<4>[ 1.603285]
<4>[ 1.603329] [1]=15,[2]=35,[3]=00,
<3>[ 1.603355] —rk_mipi_screen_probe–end
<6>[ 1.603503] act8931_i2c_probe,line=715
<3>[ 1.604320] The device is not act8931
<4>[ 1.605004] rk818_i2c_probe,line=1286
<4>[ 1.605313] rk818_pre_init,line=1201
<7>[ 1.613531] of_get_named_gpio_flags exited with status 118
<7>[ 1.613567] of_get_named_gpio_flags exited with status 113
<7>[ 1.613592] of_get_named_gpio_flags exited with status 25
<4>[ 1.613619] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 1.613648] cpu_det_gpio up
<7>[ 1.613675] of_get_named_gpio_flags exited with status 64
<4>[ 1.613697] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 1.613718] power_hold_gpio up
<4>[ 1.613741] drivers/gpio/gpiolib.c //Leo mipi
<6>[ 1.613771] rk818_i2c_probe: rk818_pmic_sleep=0
<6>[ 1.617756] vdd_arm: 712 ↔ 1500 mV at 1100 mV
<6>[ 1.622132] vdd_logic: 712 ↔ 1500 mV at 1100 mV
<6>[ 1.625990] rk818_dcdc3: 1200 mV
<6>[ 1.630317] vccio: 1800 ↔ 3300 mV at 3000 mV
<6>[ 1.634218] rk818_ldo1: 3300 mV
<6>[ 1.638053] rk818_ldo2: 3000 mV
<6>[ 1.641911] rk818_ldo3: 1100 mV
<6>[ 1.645758] rk818_ldo4: 2800 mV
<6>[ 1.649592] rk818_ldo5: 3000 mV
<6>[ 1.653441] rk818_ldo6: 1200 mV
<6>[ 1.657315] rk818_ldo7: 1800 mV
<6>[ 1.661170] rk818_ldo8: 1800 mV
<6>[ 1.664046] vcc_sd: 1800 ↔ 3000 mV at 3000 mV
<6>[ 1.665532] rk818_ldo10: at 3000 mV
<6>[ 1.667339] rk818_irq_init: rk818_pmic_irq=1
<4>[ 1.667961] fireprime_rk818_hdmi_5v_en enable:1
<4>[ 1.668818] i2c-core: driver [rk818] using legacy suspend method
<4>[ 1.668847] i2c-core: driver [rk818] using legacy resume method
<4>[ 1.670877] rk_battery_charger_detect_cb , battery_charger_detect 1
<6>[ 1.671079] Switching to clocksource arch_sys_counter
<6>[ 1.706837] fb disp policy is box
<7>[ 1.706869] uboot-logo-on:1
<6>[ 1.706945] rk-fb rockchip-fb: rk fb ion client create success!
<6>[ 1.706973] rk-fb rockchip-fb: rockchip framebuffer driver probe
<6>[ 1.707473] rk-screen rk_screen.9: rockchip screen probe success
<6>[ 1.707980] rk312-dsi
<4>[ 1.708150] dsi->host.irq =51
<4>[ 1.708186] load mipi dsi chip:rk_mipi_dsi.0 id:3132312a
<4>[ 1.708206] mipi_dsi v1.3 2014-04-17
<6>[ 1.708300] rk32-mipi 10110000.mipi: rk mipi_dsi probe success!
<6>[ 1.708328] rk32-mipi 10110000.mipi: rockchip mipi_dsi v1.1 2014-06-17
<3>[ 1.709281] rk312x-lcdc lcdc0: can’t find power_ctr node for lcdc0
<6>[ 1.709817] graphics fb0: rockchip framebuffer registerd:fb0
<6>[ 1.710623] graphics fb1: rockchip framebuffer registerd:fb1
<6>[ 1.711029] graphics fb2: rockchip framebuffer registerd:fb2
<3>[ 1.711629] rk312x-lcdc lcdc0: set lcdc0 dclk failed
<6>[ 1.711664] rk312x-lcdc lcdc0: lcdc0: dclk:66000000>>fps:58
<6>[ 1.711690] rk312x-lcdc lcdc0: wakeup from standby!
<6>[ 1.731852] alloc_buffer:ion_phy_addr=0x10000000
<6>[ 1.739160] fb0:phy:10000000>>vir:e093d000>>len:0xc00000
<6>[ 1.752140] rk312x-lcdc lcdc0: lcdc0 probe ok, iommu enabled
<6>[ 1.755405] NET: Registered protocol family 2
<6>[ 1.756308] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 1.756442] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 1.756556] TCP: Hash tables configured (established 4096 bind 4096)
<6>[ 1.756663] TCP: reno registered
<6>[ 1.756692] UDP hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 1.756738] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 1.757119] NET: Registered protocol family 1
<7>[ 1.757565] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.759221] rk818-battery rk818-battery: invalid fcc(0x0), use design capacity
<6>[ 1.760088] rk818-battery rk818-battery: update fcc : 2100
<6>[ 1.760379] rk818-battery rk818-battery: not battery, enter test power mode
<6>[ 1.781908] rk818-battery rk818-battery: v=4200, ov=4200, rv=0, c=0, pwroff_min=0
<6>[ 1.788127] rk818-battery rk818-battery: c=0, v=4200, relax=0, ocv=4200, est=4200, calib=-1
<6>[ 1.788889] rk818-battery rk818-battery: reg soc=0, init soc = 0, init cap=0
<6>[ 1.817536] rk818-battery rk818-battery: battery driver version 4.0.0
<6>[ 1.818278] Unpacking initramfs…
<6>[ 1.963153] Freeing initrd memory: 1556K (c5bf0000 - c5d75000)
<6>[ 1.964733] hw perfevents: enabled with ARMv7_Cortex_A7 PMU driver, 5 counters available
<6>[ 1.965428] vcodec_service: probe device vpu_combo.10
<4>[ 1.965467] vcodec_service: No reset resource define
<4>[ 1.965485] vcodec_service: No reset resource define
<4>[ 1.965503] vcodec_service: No reset resource define
<3>[ 1.965623] vcodec vpu_combo.10: failed on clk_get clk_cabac
<6>[ 1.965731] vcodec_service: vpu_combo.10: power on
<6>[ 1.965878] vcodec_service: probe device 10106000.vpu_service
<6>[ 1.965942] vcodec_service: checking hw id 4831
<6>[ 1.967270] vcodec_service: probe device 10104000.hevc_service
<6>[ 1.967337] vcodec_service: checking hw id 6867
<6>[ 1.968321] vcodec_service: vpu_combo.10: power off…
<6>[ 1.968392] vcodec_service: done
<6>[ 1.968411] vcodec_service: init success
<4>[ 1.968585] rknandbase v1.0 2014-03-31
<4>[ 1.968838] rknand_probe clk rate = 148500000
<4>[ 1.969026] rknand_driver:ret = 0
<4>[ 1.970578] rk_dts_sensor_probe:Get s5k4ec rockchip,power failed!
<4>[ 1.970619] s5k4ec_io==1
<7>[ 1.970658] of_get_named_gpio_flags exited with status 107
<4>[ 1.970673] the gpiorst1 is 107
<4>[ 1.970703] the gpiorst2 is 107
<4>[ 1.970721] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 1.970777] rk_dts_sensor_probe:Get ov2659 rockchip,power failed!
<4>[ 1.970807] s5k4ec_io==2
<4>[ 1.970845] rk_dts_sensor_probe:Get gc0329 rockchip,power failed!
<4>[ 1.970874] s5k4ec_io==2
<4>[ 1.970909] rk_dts_sensor_probe:Get gc2035 rockchip,powerdown failed!
<4>[ 1.970939] s5k4ec_io==2
<4>[ 1.970981] s5k4ec_io==2
<6>[ 1.972711] audit: initializing netlink socket (disabled)
<5>[ 1.972794] type=2000 audit(0.610:1): initialized
<4>[ 1.974278] bounce pool size: 64 pages
<6>[ 1.984742] fuse init (API version 7.22)
<6>[ 1.985623] msgmni has been set to 953
<7>[ 1.985715] SELinux: Registering netfilter hooks
<6>[ 1.989059] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
<6>[ 1.989094] io scheduler noop registered
<6>[ 1.989115] io scheduler deadline registered
<6>[ 1.989337] io scheduler cfq registered (default)
<7>[ 1.990274] of_get_named_gpio_flags: can’t parse gpios property
<6>[ 1.995064] rga 1010c000.rga: rga ion client create success!
<6>[ 1.995368] rga: Driver loaded succesfully
<6>[ 1.995520] rga: Module initialized.
<6>[ 2.104423] rk-hdmi 20034000.hdmi: rockchip_hdmiv1_set_pwr_mode change pwr_mode 0 → 1
<6>[ 2.104461] rk-hdmi 20034000.hdmi: rockchip_hdmiv1_set_pwr_mode change pwr_mode LOWER_PWR
<6>[ 2.104553] rk-hdmi 20034000.hdmi: rockchip_hdmiv1_set_pwr_mode change pwr_mode 1 → 0
<6>[ 2.104585] rk-hdmi 20034000.hdmi: rockchip_hdmiv1_set_pwr_mode change pwr_mode NORMAL
<6>[ 2.104627] rk-hdmi 20034000.hdmi: EDID DATA (Segment = 0 Block = 0 Offset = 0):
<3>[ 4.124429] rk-hdmi 20034000.hdmi: [HDMI] read edid base block error
<6>[ 4.180414] rk-hdmi 20034000.hdmi: EDID DATA (Segment = 0 Block = 0 Offset = 0):
<3>[ 6.201307] rk-hdmi 20034000.hdmi: [HDMI] read edid base block error
<6>[ 6.256656] rk-hdmi 20034000.hdmi: EDID DATA (Segment = 0 Block = 0 Offset = 0):
<6>[ 6.748825] rk818-battery rk818-battery: changed: dsoc=0, rsoc=0
<6>[ 7.742605] rk818-battery rk818-battery: changed: dsoc=0, rsoc=0
<6>[ 7.743314] rk818-battery rk818-battery: set charge to digital termination mode
<3>[ 8.277720] rk-hdmi 20034000.hdmi: [HDMI] read edid base block error
<3>[ 8.277764] rk-hdmi 20034000.hdmi: warning: EDID error, assume sink as HDMI !!!
<6>[ 8.277792] rk-hdmi 20034000.hdmi: warning: no CEA video mode parsed from EDID !!!
<6>[ 8.277839] ******** Show Sink Info ********
<6>[ 8.277858] Max tmds clk is 0
<6>[ 8.277874] Support video mode:
<6>[ 8.277891] 1920x1080p@60Hz
<6>[ 8.277906] 1920x1080p@50Hz
<6>[ 8.277922] 1920x1080i@60Hz
<6>[ 8.277938] 1920x1080i@50Hz
<6>[ 8.277953] 1920x1080p@30Hz
<6>[ 8.277969] 1920x1080p@25Hz
<6>[ 8.277985] 1920x1080p@24Hz
<6>[ 8.278000] 1280x720p@60Hz
<6>[ 8.278016] 1280x720p@50Hz
<6>[ 8.278031] 1280x720p@30Hz
<6>[ 8.278047] 1280x720p@25Hz
<6>[ 8.278063] 1280x720p@24Hz
<6>[ 8.278078] 720x576p@50Hz
<6>[ 8.278094] 720x576i@50Hz
<6>[ 8.278109] 720x480p@60Hz
<6>[ 8.278125] 720x480i@60Hz
<6>[ 8.278140] Support video color mode:
<6>[ 8.278156] RGB
<6>[ 8.278171] Support video color depth:
<6>[ 8.278187] 24bit
<6>[ 8.278202] Support audio type:
<6>[ 8.278218] ******** Show Sink Info ********
<6>[ 8.278260] hdmi output corlor mode is 2
<4>[ 8.278286] hdmi connect to lcdc0
<6>[ 8.278341] rk312x-lcdc lcdc0: lcdc0: dclk:74250000>>fps:60
<6>[ 8.278362] rk32_dsi_enable-------
<6>[ 8.278380] rk32_init_phy_mode----------lcdc_id=0
<4>[ 8.278403] dsi->phy.sys_clk =12000000
<6>[ 8.278425] prediv:3, fbdiv:55,dsi->phy.ddr_clk:220000000
<6>[ 8.278445] dsi->phy.ddr_clk =220000000
<6>[ 8.278465] UI:4545
<6>[ 8.278481] ref_clk:12000000
<6>[ 8.278498] pclk:74250074, Tpclk:13468
<6>[ 8.278517] sys_clk:12000000, Tsys_clk:83333
<6>[ 8.278536] ddr_clk:220000000, Tddr_clk:4545
<6>[ 8.278556] txbyte_clk:27500000, Ttxbyte_clk:36363
<6>[ 8.278575] txclkesc:13750000, Ttxclkesc:72727
<4>[ 8.288580] rk312x_mipi_dsi_phy_set_gotp : ddr_clk 220000000
<6>[ 8.288605] set DPHY_LANE3_OFFSET gotp
<4>[ 8.288625] rk312x_mipi_dsi_phy_set_gotp reg_ths_settle = 0x3
<4>[ 8.288646] rk312x_mipi_dsi_phy_set_gotp reg_hs_ths_prepare = 0x5
<4>[ 8.288667] rk312x_mipi_dsi_phy_set_gotp reg_hs_the_zero = 0x5
<4>[ 8.288688] rk312x_mipi_dsi_phy_set_gotp reg_hs_ths_trail = 0x16
<6>[ 8.288710] reg_hs_ths_exit: 4, 145
<6>[ 8.288729] reg_hs_twakup: 12121, 1010079
<6>[ 8.288747] val is too large, 0x3ff is the largest
<6>[ 8.288766] Ttxclkesc:72727
<6>[ 8.288783] reg_hs_tlpx: 4, 145452
<6>[ 8.288802] reg_hs_tta_go: 8, 581816
<6>[ 8.288820] reg_hs_tta_sure: 3, 218181
<6>[ 8.288839] reg_hs_tta_wait: 10, 727270
<4>[ 8.288858] rk312x_mipi_dsi_phy_set_gotp : ddr_clk 220000000
<6>[ 8.288877] set DPHY_LANE2_OFFSET gotp
<4>[ 8.288896] rk312x_mipi_dsi_phy_set_gotp reg_ths_settle = 0x3
<4>[ 8.288916] rk312x_mipi_dsi_phy_set_gotp reg_hs_ths_prepare = 0x5
<4>[ 8.288936] rk312x_mipi_dsi_phy_set_gotp reg_hs_the_zero = 0x5
<4>[ 8.288957] rk312x_mipi_dsi_phy_set_gotp reg_hs_ths_trail = 0x16
<6>[ 8.288978] reg_hs_ths_exit: 4, 145
<6>[ 8.288997] reg_hs_twakup: 12121, 1010079
<6>[ 8.289014] val is too large, 0x3ff is the largest
<6>[ 8.289033] Ttxclkesc:72727
<6>[ 8.289050] reg_hs_tlpx: 4, 145452
<6>[ 8.289068] reg_hs_tta_go: 8, 581816
<6>[ 8.289086] reg_hs_tta_sure: 3, 218181
<6>[ 8.289105] reg_hs_tta_wait: 10, 727270
<4>[ 8.289124] rk312x_mipi_dsi_phy_set_gotp : ddr_clk 220000000
<6>[ 8.289143] set DPHY_LANE1_OFFSET gotp
<4>[ 8.289162] rk312x_mipi_dsi_phy_set_gotp reg_ths_settle = 0x3
<4>[ 8.289182] rk312x_mipi_dsi_phy_set_gotp reg_hs_ths_prepare = 0x5
<4>[ 8.289202] rk312x_mipi_dsi_phy_set_gotp reg_hs_the_zero = 0x5
<4>[ 8.289223] rk312x_mipi_dsi_phy_set_gotp reg_hs_ths_trail = 0x16
<6>[ 8.289244] reg_hs_ths_exit: 4, 145
<6>[ 8.289263] reg_hs_twakup: 12121, 1010079
<6>[ 8.289280] val is too large, 0x3ff is the largest
<6>[ 8.289299] Ttxclkesc:72727
<6>[ 8.289316] reg_hs_tlpx: 4, 145452
<6>[ 8.289334] reg_hs_tta_go: 8, 581816
<6>[ 8.289353] reg_hs_tta_sure: 3, 218181
<6>[ 8.289371] reg_hs_tta_wait: 10, 727270
<4>[ 8.289390] rk312x_mipi_dsi_phy_set_gotp : ddr_clk 220000000
<6>[ 8.289409] set DPHY_LANE0_OFFSET gotp
<4>[ 8.289428] rk312x_mipi_dsi_phy_set_gotp reg_ths_settle = 0x3
<4>[ 8.289448] rk312x_mipi_dsi_phy_set_gotp reg_hs_ths_prepare = 0x5
<4>[ 8.289468] rk312x_mipi_dsi_phy_set_gotp reg_hs_the_zero = 0x5
<4>[ 8.289489] rk312x_mipi_dsi_phy_set_gotp reg_hs_ths_trail = 0x16
<6>[ 8.289510] reg_hs_ths_exit: 4, 145
<6>[ 8.289528] reg_hs_twakup: 12121, 1010079
<6>[ 8.289546] val is too large, 0x3ff is the largest
<6>[ 8.289565] Ttxclkesc:72727
<6>[ 8.289582] reg_hs_tlpx: 4, 145452
<6>[ 8.289600] reg_hs_tta_go: 8, 581816
<6>[ 8.289619] reg_hs_tta_sure: 3, 218181
<6>[ 8.289637] reg_hs_tta_wait: 10, 727270
<4>[ 8.289656] rk312x_mipi_dsi_phy_set_gotp : ddr_clk 220000000
<6>[ 8.289675] set DPHY_CLOCK_OFFSET gotp
<4>[ 8.289693] rk312x_mipi_dsi_phy_set_gotp reg_ths_settle = 0x3
<4>[ 8.289714] rk312x_mipi_dsi_phy_set_gotp reg_hs_ths_prepare = 0x5
<4>[ 8.289735] rk312x_mipi_dsi_phy_set_gotp reg_hs_the_zero = 0x17
<4>[ 8.289755] rk312x_mipi_dsi_phy_set_gotp reg_hs_ths_trail = 0x16
<6>[ 8.289776] reg_hs_ths_exit: 4, 145
<6>[ 8.289795] reg_hs_tclk_post: 9, 327
<6>[ 8.289813] reg_hs_tclk_pre: 2, 72
<6>[ 8.289831] reg_hs_twakup: 12121, 1010079
<6>[ 8.289848] val is too large, 0x3ff is the largest
<6>[ 8.289867] Ttxclkesc:72727
<6>[ 8.289884] reg_hs_tlpx: 4, 145452
<6>[ 8.289902] reg_hs_tta_go: 8, 581816
<6>[ 8.289920] reg_hs_tta_sure: 3, 218181
<6>[ 8.289939] reg_hs_tta_wait: 10, 727270
<6>[ 8.289964] dsi->phy.Tpclk = 13468
<6>[ 8.289982] screen->left_margin = 20
<6>[ 8.289999] dsi->phy.Ttxbyte_clk = 36363
<6>[ 8.290017] screen->hsync_len = 20
<4>[ 8.290044] rk_mipi_screen //Leo mipi
<4>[ 8.290061] gmipi_screen->screen_init == 1 //Leo mipi
<4>[ 8.290079] rk_mipi_screen_pwr_enable //Leo mipi
<3>[ 8.290096] lcd_en_gpio is null
<4>[ 8.290115] screen->lcd_rst_gpio=39,screen->lcd_rst_atv_val=1 Leo
<4>[ 8.290134] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 8.303356] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 8.323033] rk_mipi_screen_cmd_init//Leo
<4>[ 8.323054] CONFIG_LCD_MIPI//Leo
<3>[ 8.323074] dcs_cmd.name:rockchip,on-cmds1
<4>[ 8.323091] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.323110] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.323128] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.323150] 1173 command sent in LP mode size:2
<6>[ 8.323169] write GEN_HDR:0000e015
<6>[ 8.323185] .
<3>[ 8.332872] dcs_cmd.name:rockchip,on-cmds2
<4>[ 8.332892] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.332911] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.332929] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.332950] 1173 command sent in LP mode size:2
<6>[ 8.332969] write GEN_HDR:0093e115
<6>[ 8.332985] .
<3>[ 8.342710] dcs_cmd.name:rockchip,on-cmds3
<4>[ 8.342731] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.342749] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.342767] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.342789] 1173 command sent in LP mode size:2
<6>[ 8.342808] write GEN_HDR:0065e215
<6>[ 8.342824] .
<3>[ 8.352551] dcs_cmd.name:rockchip,on-cmds4
<4>[ 8.352571] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.352590] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.352608] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.352629] 1173 command sent in LP mode size:2
<6>[ 8.352648] write GEN_HDR:00f8e315
<6>[ 8.352664] .
<3>[ 8.362391] dcs_cmd.name:rockchip,on-cmds5
<4>[ 8.362412] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.362430] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.362448] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.362469] 1173 command sent in LP mode size:2
<6>[ 8.362488] write GEN_HDR:00038015
<3>[ 8.372223] dcs_cmd.name:rockchip,on-cmds6
<4>[ 8.372244] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.372263] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.372281] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.372303] 1173 command sent in LP mode size:2
<6>[ 8.372321] write GEN_HDR:0004e015
<3>[ 8.500167] dcs_cmd.name:rockchip,on-cmds7
<4>[ 8.500188] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.500207] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.500225] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.500247] 1173 command sent in LP mode size:2
<6>[ 8.500266] write GEN_HDR:002b2b15
<6>[ 8.500282] .
<3>[ 8.510002] dcs_cmd.name:rockchip,on-cmds8
<4>[ 8.510022] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.510040] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.510058] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.510079] 1173 command sent in LP mode size:2
<6>[ 8.510098] write GEN_HDR:00032d15
<6>[ 8.510113] .
<3>[ 8.519842] dcs_cmd.name:rockchip,on-cmds9
<4>[ 8.519862] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.519881] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.519899] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.519920] 1173 command sent in LP mode size:2
<6>[ 8.519939] write GEN_HDR:00442e15
<6>[ 8.519955] .
<3>[ 8.529682] dcs_cmd.name:rockchip,on-cmds10
<4>[ 8.529702] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.529721] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.529739] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.529760] 1173 command sent in LP mode size:2
<6>[ 8.529779] write GEN_HDR:0001e015
<6>[ 8.529795] .
<3>[ 8.539521] dcs_cmd.name:rockchip,on-cmds11
<4>[ 8.539541] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.539560] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.539578] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.539599] 1173 command sent in LP mode size:2
<6>[ 8.539618] write GEN_HDR:00000015
<6>[ 8.539634] .
<3>[ 8.549361] dcs_cmd.name:rockchip,on-cmds12
<4>[ 8.549381] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.549400] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.549418] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.549439] 1173 command sent in LP mode size:2
<6>[ 8.549458] write GEN_HDR:006a0115
<6>[ 8.549474] .
<3>[ 8.559201] dcs_cmd.name:rockchip,on-cmds13
<4>[ 8.559221] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.559240] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.559258] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.559279] 1173 command sent in LP mode size:2
<6>[ 8.559298] write GEN_HDR:00001715
<6>[ 8.559314] .
<3>[ 8.569042] dcs_cmd.name:rockchip,on-cmds14
<4>[ 8.569062] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.569081] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.569099] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.569120] 1173 command sent in LP mode size:2
<6>[ 8.569139] write GEN_HDR:00c01815
<3>[ 8.578874] dcs_cmd.name:rockchip,on-cmds15
<4>[ 8.578895] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.578914] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.578932] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.578954] 1173 command sent in LP mode size:2
<6>[ 8.578973] write GEN_HDR:00011915
<6>[ 8.578989] .
<3>[ 8.588720] dcs_cmd.name:rockchip,on-cmds16
<4>[ 8.588741] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.588760] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.588778] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.588799] 1173 command sent in LP mode size:2
<6>[ 8.588818] write GEN_HDR:00001a15
<3>[ 8.598554] dcs_cmd.name:rockchip,on-cmds17
<4>[ 8.598575] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.598594] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.598612] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.598633] 1173 command sent in LP mode size:2
<6>[ 8.598651] write GEN_HDR:00c01b15
<6>[ 8.598667] .
<3>[ 8.608402] dcs_cmd.name:rockchip,on-cmds18
<4>[ 8.608422] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.608440] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.608458] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.608480] 1173 command sent in LP mode size:2
<6>[ 8.608498] write GEN_HDR:00011c15
<6>[ 8.608514] .
<3>[ 8.618242] dcs_cmd.name:rockchip,on-cmds19
<4>[ 8.618262] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.618280] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.618298] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.618320] 1173 command sent in LP mode size:2
<6>[ 8.618339] write GEN_HDR:006a1f15
<6>[ 8.618354] .
<3>[ 8.628080] dcs_cmd.name:rockchip,on-cmds20
<4>[ 8.628101] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.628119] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.628137] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.628159] 1173 command sent in LP mode size:2
<6>[ 8.628178] write GEN_HDR:00232015
<6>[ 8.628194] .
<3>[ 8.637922] dcs_cmd.name:rockchip,on-cmds21
<4>[ 8.637942] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.637961] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.637979] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.638000] 1173 command sent in LP mode size:2
<6>[ 8.638019] write GEN_HDR:00232115
<3>[ 8.647753] dcs_cmd.name:rockchip,on-cmds22
<4>[ 8.647774] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.647793] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.647811] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.647832] 1173 command sent in LP mode size:2
<6>[ 8.647851] write GEN_HDR:000e2215
<3>[ 8.657594] dcs_cmd.name:rockchip,on-cmds23
<4>[ 8.657615] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.657634] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.657652] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.657673] 1173 command sent in LP mode size:2
<6>[ 8.657692] write GEN_HDR:00283515
<6>[ 8.657708] .
<3>[ 8.667441] dcs_cmd.name:rockchip,on-cmds24
<4>[ 8.667461] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.667479] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.667497] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.667519] 1173 command sent in LP mode size:2
<6>[ 8.667538] write GEN_HDR:00593715
<6>[ 8.667553] .
<3>[ 8.677283] dcs_cmd.name:rockchip,on-cmds25
<4>[ 8.677303] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.677321] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.677339] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.677361] 1173 command sent in LP mode size:2
<6>[ 8.677379] write GEN_HDR:00053815
<6>[ 8.677395] .
<3>[ 8.687122] dcs_cmd.name:rockchip,on-cmds26
<4>[ 8.687141] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.687160] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.687178] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.687200] 1173 command sent in LP mode size:2
<6>[ 8.687219] write GEN_HDR:00043915
<6>[ 8.687234] .
<3>[ 8.696961] dcs_cmd.name:rockchip,on-cmds27
<4>[ 8.696981] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.697000] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.697018] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.697039] 1173 command sent in LP mode size:2
<6>[ 8.697058] write GEN_HDR:00083a15
<6>[ 8.697073] .
<3>[ 8.706802] dcs_cmd.name:rockchip,on-cmds28
<4>[ 8.706823] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.706841] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.706859] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.706881] 1173 command sent in LP mode size:2
<6>[ 8.706899] write GEN_HDR:00083b15
<6>[ 8.706915] .
<3>[ 8.716643] dcs_cmd.name:rockchip,on-cmds29
<4>[ 8.716663] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.716682] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.716700] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.716721] 1173 command sent in LP mode size:2
<6>[ 8.716740] write GEN_HDR:007c3c15
<6>[ 8.716756] .
<3>[ 8.726484] dcs_cmd.name:rockchip,on-cmds30
<4>[ 8.726504] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.726524] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.726542] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.726564] 1173 command sent in LP mode size:2
<6>[ 8.726582] write GEN_HDR:00ff3d15
<6>[ 8.726598] .
<3>[ 8.736327] dcs_cmd.name:rockchip,on-cmds31
<4>[ 8.736349] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.736368] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.736386] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.736408] 1173 command sent in LP mode size:2
<6>[ 8.736427] write GEN_HDR:00ff3e15
<3>[ 8.746155] dcs_cmd.name:rockchip,on-cmds32
<4>[ 8.746176] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.746195] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.746213] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.746235] 1173 command sent in LP mode size:2
<6>[ 8.746254] write GEN_HDR:00ff3f15
<6>[ 8.746269] .
<3>[ 8.756001] dcs_cmd.name:rockchip,on-cmds33
<4>[ 8.756021] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.756040] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.756058] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.756079] 1173 command sent in LP mode size:2
<6>[ 8.756098] write GEN_HDR:00064015
<6>[ 8.756114] .
<3>[ 8.765841] dcs_cmd.name:rockchip,on-cmds34
<4>[ 8.765862] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.765880] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.765898] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.765920] 1173 command sent in LP mode size:2
<6>[ 8.765938] write GEN_HDR:00a04115
<6>[ 8.765954] .
<3>[ 8.775681] dcs_cmd.name:rockchip,on-cmds35
<4>[ 8.775701] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.775719] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.775737] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.775759] 1173 command sent in LP mode size:2
<6>[ 8.775778] write GEN_HDR:00084315
<6>[ 8.775793] .
<3>[ 8.785522] dcs_cmd.name:rockchip,on-cmds36
<4>[ 8.785542] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.785561] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.785579] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.785600] 1173 command sent in LP mode size:2
<6>[ 8.785619] write GEN_HDR:000b4415
<6>[ 8.785635] .
<3>[ 8.795362] dcs_cmd.name:rockchip,on-cmds37
<4>[ 8.795382] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.795401] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.795419] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.795441] 1173 command sent in LP mode size:2
<6>[ 8.795459] write GEN_HDR:00884515
<6>[ 8.795475] .
<3>[ 8.805201] dcs_cmd.name:rockchip,on-cmds38
<4>[ 8.805221] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.805240] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.805258] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.805280] 1173 command sent in LP mode size:2
<6>[ 8.805298] write GEN_HDR:000f5515
<6>[ 8.805314] .
<3>[ 8.815041] dcs_cmd.name:rockchip,on-cmds39
<4>[ 8.815061] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.815079] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.815097] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.815119] 1173 command sent in LP mode size:2
<6>[ 8.815138] write GEN_HDR:00015615
<6>[ 8.815154] .
<3>[ 8.824882] dcs_cmd.name:rockchip,on-cmds40
<4>[ 8.824902] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.824921] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.824938] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.824961] 1173 command sent in LP mode size:2
<6>[ 8.824979] write GEN_HDR:00ad5715
<6>[ 8.824995] .
<3>[ 8.834721] dcs_cmd.name:rockchip,on-cmds41
<4>[ 8.834742] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.834761] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.834779] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.834800] 1173 command sent in LP mode size:2
<6>[ 8.834819] write GEN_HDR:000a5815
<6>[ 8.834835] .
<3>[ 8.844561] dcs_cmd.name:rockchip,on-cmds42
<4>[ 8.844582] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.844601] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.844618] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.844640] 1173 command sent in LP mode size:2
<6>[ 8.844659] write GEN_HDR:000a5915
<6>[ 8.844675] .
<3>[ 8.854400] dcs_cmd.name:rockchip,on-cmds43
<4>[ 8.854420] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.854439] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.854457] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.854478] 1173 command sent in LP mode size:2
<6>[ 8.854497] write GEN_HDR:00285a15
<6>[ 8.854513] .
<3>[ 8.864243] dcs_cmd.name:rockchip,on-cmds44
<4>[ 8.864262] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.864281] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.864299] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.864321] 1173 command sent in LP mode size:2
<6>[ 8.864339] write GEN_HDR:001e5b15
<6>[ 8.864355] .
<3>[ 8.874081] dcs_cmd.name:rockchip,on-cmds45
<4>[ 8.874101] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.874120] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.874138] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.874159] 1173 command sent in LP mode size:2
<6>[ 8.874178] write GEN_HDR:005c5d15
<6>[ 8.874194] .
<3>[ 8.883921] dcs_cmd.name:rockchip,on-cmds46
<4>[ 8.883942] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.883960] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.883978] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.884000] 1173 command sent in LP mode size:2
<6>[ 8.884019] write GEN_HDR:00405e15
<6>[ 8.884035] .
<3>[ 8.893762] dcs_cmd.name:rockchip,on-cmds47
<4>[ 8.893782] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.893801] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.893819] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.893840] 1173 command sent in LP mode size:2
<6>[ 8.893859] write GEN_HDR:00305f15
<6>[ 8.893875] .
<3>[ 8.903601] dcs_cmd.name:rockchip,on-cmds48
<4>[ 8.903622] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.903640] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.903658] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.903680] 1173 command sent in LP mode size:2
<6>[ 8.903699] write GEN_HDR:00246015
<6>[ 8.903714] .
<3>[ 8.913441] dcs_cmd.name:rockchip,on-cmds49
<4>[ 8.913462] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.913480] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.913498] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.913520] 1173 command sent in LP mode size:2
<6>[ 8.913538] write GEN_HDR:00216115
<6>[ 8.913555] .
<3>[ 8.923282] dcs_cmd.name:rockchip,on-cmds50
<4>[ 8.923303] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.923321] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.923339] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.923360] 1173 command sent in LP mode size:2
<6>[ 8.923379] write GEN_HDR:00136215
<6>[ 8.923395] .
<3>[ 8.933121] dcs_cmd.name:rockchip,on-cmds51
<4>[ 8.933141] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.933159] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.933177] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.933199] 1173 command sent in LP mode size:2
<6>[ 8.933218] write GEN_HDR:001a6315
<6>[ 8.933234] .
<3>[ 8.942961] dcs_cmd.name:rockchip,on-cmds52
<4>[ 8.942981] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.943000] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.943018] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.943039] 1173 command sent in LP mode size:2
<6>[ 8.943058] write GEN_HDR:00076415
<6>[ 8.943074] .
<3>[ 8.952801] dcs_cmd.name:rockchip,on-cmds53
<4>[ 8.952822] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.952841] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.952859] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.952880] 1173 command sent in LP mode size:2
<6>[ 8.952899] write GEN_HDR:00236515
<6>[ 8.952915] .
<3>[ 8.962643] dcs_cmd.name:rockchip,on-cmds54
<4>[ 8.962664] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.962682] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.962700] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.962722] 1173 command sent in LP mode size:2
<6>[ 8.962740] write GEN_HDR:00256615
<6>[ 8.962756] .
<3>[ 8.972482] dcs_cmd.name:rockchip,on-cmds55
<4>[ 8.972502] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.972520] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.972539] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.972561] 1173 command sent in LP mode size:2
<6>[ 8.972579] write GEN_HDR:00276715
<6>[ 8.972595] .
<3>[ 8.982322] dcs_cmd.name:rockchip,on-cmds56
<4>[ 8.982342] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.982361] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.982379] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.982400] 1173 command sent in LP mode size:2
<6>[ 8.982419] write GEN_HDR:00476815
<6>[ 8.982435] .
<3>[ 8.992162] dcs_cmd.name:rockchip,on-cmds57
<4>[ 8.992182] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 8.992201] dcs_cmd.dsi_id == 0 line=127
<4>[ 8.992219] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 8.992240] 1173 command sent in LP mode size:2
<6>[ 8.992259] write GEN_HDR:00376915
<6>[ 8.992275] .
<3>[ 9.002001] dcs_cmd.name:rockchip,on-cmds58
<4>[ 9.002021] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.002040] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.002057] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.002079] 1173 command sent in LP mode size:2
<6>[ 9.002098] write GEN_HDR:003f6a15
<6>[ 9.002113] .
<3>[ 9.011842] dcs_cmd.name:rockchip,on-cmds59
<4>[ 9.011862] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.011880] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.011898] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.011919] 1173 command sent in LP mode size:2
<6>[ 9.011937] write GEN_HDR:00326b15
<6>[ 9.011954] .
<3>[ 9.021681] dcs_cmd.name:rockchip,on-cmds60
<4>[ 9.021701] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.021720] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.021737] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.021759] 1173 command sent in LP mode size:2
<6>[ 9.021777] write GEN_HDR:002e6c15
<6>[ 9.021793] .
<3>[ 9.031521] dcs_cmd.name:rockchip,on-cmds61
<4>[ 9.031541] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.031559] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.031577] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.031598] 1173 command sent in LP mode size:2
<6>[ 9.031616] write GEN_HDR:00226d15
<6>[ 9.031632] .
<3>[ 9.041361] dcs_cmd.name:rockchip,on-cmds62
<4>[ 9.041381] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.041400] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.041417] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.041438] 1173 command sent in LP mode size:2
<6>[ 9.041457] write GEN_HDR:00116e15
<6>[ 9.041473] .
<3>[ 9.051202] dcs_cmd.name:rockchip,on-cmds63
<4>[ 9.051222] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.051240] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.051258] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.051280] 1173 command sent in LP mode size:2
<6>[ 9.051298] write GEN_HDR:00006f15
<6>[ 9.051314] .
<3>[ 9.061041] dcs_cmd.name:rockchip,on-cmds64
<4>[ 9.061061] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.061079] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.061097] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.061118] 1173 command sent in LP mode size:2
<6>[ 9.061137] write GEN_HDR:005c7015
<6>[ 9.061152] .
<3>[ 9.070881] dcs_cmd.name:rockchip,on-cmds65
<4>[ 9.070901] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.070920] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.070937] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.070958] 1173 command sent in LP mode size:2
<6>[ 9.070977] write GEN_HDR:00407115
<6>[ 9.070992] .
<3>[ 9.080721] dcs_cmd.name:rockchip,on-cmds66
<4>[ 9.080741] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.080760] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.080777] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.080799] 1173 command sent in LP mode size:2
<6>[ 9.080817] write GEN_HDR:00307215
<6>[ 9.080833] .
<3>[ 9.090561] dcs_cmd.name:rockchip,on-cmds67
<4>[ 9.090581] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.090599] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.090617] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.090638] 1173 command sent in LP mode size:2
<6>[ 9.090657] write GEN_HDR:00247315
<6>[ 9.090673] .
<3>[ 9.100402] dcs_cmd.name:rockchip,on-cmds68
<4>[ 9.100422] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.100441] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.100458] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.100480] 1173 command sent in LP mode size:2
<6>[ 9.100499] write GEN_HDR:00217415
<6>[ 9.100515] .
<3>[ 9.110241] dcs_cmd.name:rockchip,on-cmds69
<4>[ 9.110262] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.110280] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.110298] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.110319] 1173 command sent in LP mode size:2
<6>[ 9.110338] write GEN_HDR:00137515
<6>[ 9.110354] .
<3>[ 9.120082] dcs_cmd.name:rockchip,on-cmds70
<4>[ 9.120102] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.120120] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.120138] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.120160] 1173 command sent in LP mode size:2
<6>[ 9.120178] write GEN_HDR:001a7615
<6>[ 9.120194] .
<3>[ 9.129921] dcs_cmd.name:rockchip,on-cmds71
<4>[ 9.129941] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.129960] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.129978] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.129999] 1173 command sent in LP mode size:2
<6>[ 9.130018] write GEN_HDR:00077715
<6>[ 9.130033] .
<3>[ 9.139761] dcs_cmd.name:rockchip,on-cmds72
<4>[ 9.139781] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.139800] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.139818] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.139839] 1173 command sent in LP mode size:2
<6>[ 9.139858] write GEN_HDR:00237815
<6>[ 9.139874] .
<3>[ 9.149601] dcs_cmd.name:rockchip,on-cmds73
<4>[ 9.149622] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.149640] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.149658] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.149680] 1173 command sent in LP mode size:2
<6>[ 9.149699] write GEN_HDR:00257915
<3>[ 9.159433] dcs_cmd.name:rockchip,on-cmds74
<4>[ 9.159454] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.159473] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.159491] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.159512] 1173 command sent in LP mode size:2
<6>[ 9.159531] write GEN_HDR:00277a15
<6>[ 9.159547] .
<3>[ 9.169282] dcs_cmd.name:rockchip,on-cmds75
<4>[ 9.169303] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.169321] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.169339] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.169360] 1173 command sent in LP mode size:2
<6>[ 9.169379] write GEN_HDR:00477b15
<6>[ 9.169395] .
<3>[ 9.179121] dcs_cmd.name:rockchip,on-cmds76
<4>[ 9.179141] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.179160] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.179178] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.179200] 1173 command sent in LP mode size:2
<6>[ 9.179218] write GEN_HDR:00377c15
<6>[ 9.179234] .
<3>[ 9.188963] dcs_cmd.name:rockchip,on-cmds77
<4>[ 9.188984] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.189003] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.189021] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.189042] 1173 command sent in LP mode size:2
<6>[ 9.189061] write GEN_HDR:003f7d15
<6>[ 9.189077] .
<3>[ 9.198802] dcs_cmd.name:rockchip,on-cmds78
<4>[ 9.198823] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.198841] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.198860] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.198881] 1173 command sent in LP mode size:2
<6>[ 9.198900] write GEN_HDR:00327e15
<6>[ 9.198916] .
<3>[ 9.208642] dcs_cmd.name:rockchip,on-cmds79
<4>[ 9.208662] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.208681] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.208698] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.208720] 1173 command sent in LP mode size:2
<6>[ 9.208739] write GEN_HDR:002e7f15
<6>[ 9.208754] .
<3>[ 9.218481] dcs_cmd.name:rockchip,on-cmds80
<4>[ 9.218502] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.218520] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.218539] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.218560] 1173 command sent in LP mode size:2
<6>[ 9.218579] write GEN_HDR:00228015
<6>[ 9.218595] .
<3>[ 9.228323] dcs_cmd.name:rockchip,on-cmds81
<4>[ 9.228343] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.228362] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.228379] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.228401] 1173 command sent in LP mode size:2
<6>[ 9.228420] write GEN_HDR:00118115
<6>[ 9.228436] .
<3>[ 9.238161] dcs_cmd.name:rockchip,on-cmds82
<4>[ 9.238181] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.238200] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.238218] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.238239] 1173 command sent in LP mode size:2
<6>[ 9.238258] write GEN_HDR:00008215
<6>[ 9.238274] .
<3>[ 9.248015] dcs_cmd.name:rockchip,on-cmds83
<4>[ 9.248037] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.248055] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.248073] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.248096] 1173 command sent in LP mode size:2
<6>[ 9.248114] write GEN_HDR:0002e015
<6>[ 9.248130] .
<3>[ 9.257895] dcs_cmd.name:rockchip,on-cmds84
<4>[ 9.257918] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.257936] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.257954] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.257977] 1173 command sent in LP mode size:2
<6>[ 9.257996] write GEN_HDR:00440015
<6>[ 9.258011] .
<3>[ 9.267688] dcs_cmd.name:rockchip,on-cmds85
<4>[ 9.267708] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.267727] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.267744] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.267766] 1173 command sent in LP mode size:2
<6>[ 9.267784] write GEN_HDR:00440115
<6>[ 9.267800] .
<3>[ 9.277531] dcs_cmd.name:rockchip,on-cmds86
<4>[ 9.277552] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.277571] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.277588] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.277610] 1173 command sent in LP mode size:2
<6>[ 9.277629] write GEN_HDR:00450215
<3>[ 9.287356] dcs_cmd.name:rockchip,on-cmds87
<4>[ 9.287378] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.287396] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.287414] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.287435] 1173 command sent in LP mode size:2
<6>[ 9.287454] write GEN_HDR:00450315
<6>[ 9.287470] .
<3>[ 9.297203] dcs_cmd.name:rockchip,on-cmds88
<4>[ 9.297223] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.297242] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.297259] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.297281] 1173 command sent in LP mode size:2
<6>[ 9.297300] write GEN_HDR:00460415
<6>[ 9.297315] .
<3>[ 9.307043] dcs_cmd.name:rockchip,on-cmds89
<4>[ 9.307064] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.307082] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.307100] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.307122] 1173 command sent in LP mode size:2
<6>[ 9.307140] write GEN_HDR:00460515
<3>[ 9.316881] dcs_cmd.name:rockchip,on-cmds90
<4>[ 9.316904] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.316922] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.316940] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.316962] 1173 command sent in LP mode size:2
<6>[ 9.316981] write GEN_HDR:00470615
<3>[ 9.326717] dcs_cmd.name:rockchip,on-cmds91
<4>[ 9.326738] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.326757] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.326775] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.326796] 1173 command sent in LP mode size:2
<6>[ 9.326815] write GEN_HDR:00470715
<6>[ 9.326831] .
<3>[ 9.336568] dcs_cmd.name:rockchip,on-cmds92
<4>[ 9.336589] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.336607] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.336625] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.336647] 1173 command sent in LP mode size:2
<6>[ 9.336666] write GEN_HDR:001d0815
<6>[ 9.336682] .
<3>[ 9.346406] dcs_cmd.name:rockchip,on-cmds93
<4>[ 9.346426] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.346444] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.346462] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.346484] 1173 command sent in LP mode size:2
<6>[ 9.346502] write GEN_HDR:001d0915
<6>[ 9.346518] .
<3>[ 9.356232] dcs_cmd.name:rockchip,on-cmds94
<4>[ 9.356253] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.356272] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.356290] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.356311] 1173 command sent in LP mode size:2
<6>[ 9.356330] write GEN_HDR:001d0a15
<6>[ 9.356346] .
<3>[ 9.366083] dcs_cmd.name:rockchip,on-cmds95
<4>[ 9.366103] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.366122] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.366140] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.366162] 1173 command sent in LP mode size:2
<6>[ 9.366181] write GEN_HDR:001d0b15
<6>[ 9.366196] .
<3>[ 9.375920] dcs_cmd.name:rockchip,on-cmds96
<4>[ 9.375941] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.375959] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.375977] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.375999] 1173 command sent in LP mode size:2
<6>[ 9.376017] write GEN_HDR:001d0c15
<6>[ 9.376033] .
<3>[ 9.385760] dcs_cmd.name:rockchip,on-cmds97
<4>[ 9.385781] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.385800] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.385818] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.385839] 1173 command sent in LP mode size:2
<6>[ 9.385858] write GEN_HDR:001d0d15
<6>[ 9.385874] .
<3>[ 9.395601] dcs_cmd.name:rockchip,on-cmds98
<4>[ 9.395622] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.395640] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.395658] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.395680] 1173 command sent in LP mode size:2
<6>[ 9.395698] write GEN_HDR:001d0e15
<6>[ 9.395714] .
<3>[ 9.405440] dcs_cmd.name:rockchip,on-cmds99
<4>[ 9.405461] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.405479] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.405497] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.405518] 1173 command sent in LP mode size:2
<6>[ 9.405537] write GEN_HDR:00570f15
<6>[ 9.405553] .
<3>[ 9.415282] dcs_cmd.name:rockchip,on-cmds100
<4>[ 9.415302] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.415320] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.415338] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.415360] 1173 command sent in LP mode size:2
<6>[ 9.415378] write GEN_HDR:00571015
<6>[ 9.415395] .
<3>[ 9.425120] dcs_cmd.name:rockchip,on-cmds101
<4>[ 9.425140] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.425159] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.425177] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.425198] 1173 command sent in LP mode size:2
<6>[ 9.425217] write GEN_HDR:00581115
<6>[ 9.425233] .
<3>[ 9.434960] dcs_cmd.name:rockchip,on-cmds102
<4>[ 9.434980] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.434999] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.435017] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.435038] 1173 command sent in LP mode size:2
<6>[ 9.435057] write GEN_HDR:00581215
<6>[ 9.435073] .
<3>[ 9.444802] dcs_cmd.name:rockchip,on-cmds103
<4>[ 9.444823] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.444841] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.444859] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.444880] 1173 command sent in LP mode size:2
<6>[ 9.444899] write GEN_HDR:00401315
<6>[ 9.444915] .
<3>[ 9.454640] dcs_cmd.name:rockchip,on-cmds104
<4>[ 9.454660] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.454679] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.454697] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.454718] 1173 command sent in LP mode size:2
<6>[ 9.454737] write GEN_HDR:00551415
<6>[ 9.454753] .
<3>[ 9.464481] dcs_cmd.name:rockchip,on-cmds105
<4>[ 9.464502] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.464521] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.464539] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.464560] 1173 command sent in LP mode size:2
<6>[ 9.464579] write GEN_HDR:00551515
<6>[ 9.464595] .
<3>[ 9.474320] dcs_cmd.name:rockchip,on-cmds106
<4>[ 9.474340] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.474358] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.474376] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.474397] 1173 command sent in LP mode size:2
<6>[ 9.474416] write GEN_HDR:00441615
<6>[ 9.474432] .
<3>[ 9.484159] dcs_cmd.name:rockchip,on-cmds107
<4>[ 9.484179] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.484198] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.484216] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.484239] 1173 command sent in LP mode size:2
<6>[ 9.484258] write GEN_HDR:00441715
<6>[ 9.484273] .
<3>[ 9.494002] dcs_cmd.name:rockchip,on-cmds108
<4>[ 9.494022] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.494040] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.494059] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.494080] 1173 command sent in LP mode size:2
<6>[ 9.494098] write GEN_HDR:00451815
<6>[ 9.494115] .
<3>[ 9.503840] dcs_cmd.name:rockchip,on-cmds109
<4>[ 9.503860] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.503879] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.503897] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.503919] 1173 command sent in LP mode size:2
<6>[ 9.503937] write GEN_HDR:00451915
<6>[ 9.503953] .
<3>[ 9.513681] dcs_cmd.name:rockchip,on-cmds110
<4>[ 9.513702] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.513720] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.513738] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.513760] 1173 command sent in LP mode size:2
<6>[ 9.513779] write GEN_HDR:00461a15
<6>[ 9.513795] .
<3>[ 9.523521] dcs_cmd.name:rockchip,on-cmds111
<4>[ 9.523541] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.523560] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.523578] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.523599] 1173 command sent in LP mode size:2
<6>[ 9.523618] write GEN_HDR:00461b15
<6>[ 9.523634] .
<3>[ 9.533360] dcs_cmd.name:rockchip,on-cmds112
<4>[ 9.533380] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.533399] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.533417] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.533439] 1173 command sent in LP mode size:2
<6>[ 9.533457] write GEN_HDR:00471c15
<3>[ 9.543193] dcs_cmd.name:rockchip,on-cmds113
<4>[ 9.543214] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.543233] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.543251] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.543272] 1173 command sent in LP mode size:2
<6>[ 9.543291] write GEN_HDR:00471d15
<6>[ 9.543307] .
<3>[ 9.553040] dcs_cmd.name:rockchip,on-cmds114
<4>[ 9.553060] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.553078] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.553096] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.553118] 1173 command sent in LP mode size:2
<6>[ 9.553136] write GEN_HDR:001d1e15
<6>[ 9.553152] .
<3>[ 9.562881] dcs_cmd.name:rockchip,on-cmds115
<4>[ 9.562901] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.562920] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.562938] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.562959] 1173 command sent in LP mode size:2
<6>[ 9.562978] write GEN_HDR:001d1f15
<6>[ 9.562994] .
<3>[ 9.572720] dcs_cmd.name:rockchip,on-cmds116
<4>[ 9.572741] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.572759] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.572777] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.572799] 1173 command sent in LP mode size:2
<6>[ 9.572817] write GEN_HDR:001d2015
<6>[ 9.572833] .
<3>[ 9.582560] dcs_cmd.name:rockchip,on-cmds117
<4>[ 9.582580] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.582599] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.582616] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.582638] 1173 command sent in LP mode size:2
<6>[ 9.582657] write GEN_HDR:001d2115
<6>[ 9.582673] .
<3>[ 9.592401] dcs_cmd.name:rockchip,on-cmds118
<4>[ 9.592421] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.592440] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.592458] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.592479] 1173 command sent in LP mode size:2
<6>[ 9.592498] write GEN_HDR:001d2215
<6>[ 9.592514] .
<3>[ 9.602240] dcs_cmd.name:rockchip,on-cmds119
<4>[ 9.602260] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.602279] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.602297] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.602319] 1173 command sent in LP mode size:2
<6>[ 9.602337] write GEN_HDR:001d2315
<6>[ 9.602353] .
<3>[ 9.612081] dcs_cmd.name:rockchip,on-cmds120
<4>[ 9.612101] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.612120] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.612138] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.612160] 1173 command sent in LP mode size:2
<6>[ 9.612179] write GEN_HDR:001d2415
<6>[ 9.612195] .
<3>[ 9.621920] dcs_cmd.name:rockchip,on-cmds121
<4>[ 9.621940] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.621959] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.621977] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.621999] 1173 command sent in LP mode size:2
<6>[ 9.622017] write GEN_HDR:00572515
<6>[ 9.622033] .
<3>[ 9.631760] dcs_cmd.name:rockchip,on-cmds122
<4>[ 9.631781] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.631799] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.631817] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.631838] 1173 command sent in LP mode size:2
<6>[ 9.631857] write GEN_HDR:00572615
<3>[ 9.641593] dcs_cmd.name:rockchip,on-cmds123
<4>[ 9.641614] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.641633] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.641651] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.641672] 1173 command sent in LP mode size:2
<6>[ 9.641691] write GEN_HDR:00582715
<6>[ 9.641707] .
<3>[ 9.651440] dcs_cmd.name:rockchip,on-cmds124
<4>[ 9.651461] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.651479] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.651497] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.651519] 1173 command sent in LP mode size:2
<6>[ 9.651538] write GEN_HDR:00582815
<6>[ 9.651554] .
<3>[ 9.661281] dcs_cmd.name:rockchip,on-cmds125
<4>[ 9.661302] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.661320] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.661338] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.661360] 1173 command sent in LP mode size:2
<6>[ 9.661379] write GEN_HDR:00402915
<6>[ 9.661394] .
<3>[ 9.671121] dcs_cmd.name:rockchip,on-cmds126
<4>[ 9.671142] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.671160] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.671178] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.671200] 1173 command sent in LP mode size:2
<6>[ 9.671219] write GEN_HDR:00552a15
<6>[ 9.671235] .
<3>[ 9.680959] dcs_cmd.name:rockchip,on-cmds127
<4>[ 9.680980] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.680999] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.681017] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.681038] 1173 command sent in LP mode size:2
<6>[ 9.681057] write GEN_HDR:00552b15
<6>[ 9.681073] .
<3>[ 9.690801] dcs_cmd.name:rockchip,on-cmds128
<4>[ 9.690822] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.690841] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.690859] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.690881] 1173 command sent in LP mode size:2
<6>[ 9.690900] write GEN_HDR:00405815
<6>[ 9.690916] .
<3>[ 9.700640] dcs_cmd.name:rockchip,on-cmds129
<4>[ 9.700660] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.700679] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.700697] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.700718] 1173 command sent in LP mode size:2
<6>[ 9.700737] write GEN_HDR:00005915
<6>[ 9.700753] .
<3>[ 9.710482] dcs_cmd.name:rockchip,on-cmds130
<4>[ 9.710502] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.710521] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.710539] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.710560] 1173 command sent in LP mode size:2
<6>[ 9.710579] write GEN_HDR:00005a15
<6>[ 9.710595] .
<3>[ 9.720331] dcs_cmd.name:rockchip,on-cmds131
<4>[ 9.720353] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.720372] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.720390] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.720412] 1173 command sent in LP mode size:2
<6>[ 9.720431] write GEN_HDR:00005b15
<6>[ 9.720447] .
<3>[ 9.730169] dcs_cmd.name:rockchip,on-cmds132
<4>[ 9.730190] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.730208] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.730226] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.730248] 1173 command sent in LP mode size:2
<6>[ 9.730266] write GEN_HDR:000a5c15
<6>[ 9.730282] .
<3>[ 9.740003] dcs_cmd.name:rockchip,on-cmds133
<4>[ 9.740024] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.740043] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.740061] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.740082] 1173 command sent in LP mode size:2
<6>[ 9.740101] write GEN_HDR:00105d15
<6>[ 9.740117] .
<3>[ 9.749842] dcs_cmd.name:rockchip,on-cmds134
<4>[ 9.749862] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.749880] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.749898] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.749920] 1173 command sent in LP mode size:2
<6>[ 9.749938] write GEN_HDR:00015e15
<6>[ 9.749954] .
<3>[ 9.759681] dcs_cmd.name:rockchip,on-cmds135
<4>[ 9.759701] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.759720] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.759738] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.759759] 1173 command sent in LP mode size:2
<6>[ 9.759778] write GEN_HDR:00025f15
<6>[ 9.759794] .
<3>[ 9.769521] dcs_cmd.name:rockchip,on-cmds136
<4>[ 9.769541] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.769560] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.769578] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.769599] 1173 command sent in LP mode size:2
<6>[ 9.769618] write GEN_HDR:00106015
<6>[ 9.769634] .
<3>[ 9.779362] dcs_cmd.name:rockchip,on-cmds137
<4>[ 9.779382] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.779400] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.779418] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.779440] 1173 command sent in LP mode size:2
<6>[ 9.779458] write GEN_HDR:00016115
<6>[ 9.779474] .
<3>[ 9.789202] dcs_cmd.name:rockchip,on-cmds138
<4>[ 9.789222] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.789241] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.789259] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.789280] 1173 command sent in LP mode size:2
<6>[ 9.789299] write GEN_HDR:00026215
<3>[ 9.799034] dcs_cmd.name:rockchip,on-cmds139
<4>[ 9.799055] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.799073] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.799091] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.799113] 1173 command sent in LP mode size:2
<6>[ 9.799131] write GEN_HDR:000b6315
<6>[ 9.799147] .
<3>[ 9.808881] dcs_cmd.name:rockchip,on-cmds140
<4>[ 9.808901] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.808920] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.808938] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.808959] 1173 command sent in LP mode size:2
<6>[ 9.808978] write GEN_HDR:00546415
<6>[ 9.808994] .
<3>[ 9.818722] dcs_cmd.name:rockchip,on-cmds141
<4>[ 9.818742] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.818760] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.818778] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.818800] 1173 command sent in LP mode size:2
<6>[ 9.818819] write GEN_HDR:00456515
<6>[ 9.818834] .
<3>[ 9.828562] dcs_cmd.name:rockchip,on-cmds142
<4>[ 9.828582] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.828601] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.828619] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.828640] 1173 command sent in LP mode size:2
<6>[ 9.828659] write GEN_HDR:00076615
<6>[ 9.828675] .
<3>[ 9.838402] dcs_cmd.name:rockchip,on-cmds143
<4>[ 9.838422] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.838440] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.838459] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.838480] 1173 command sent in LP mode size:2
<6>[ 9.838499] write GEN_HDR:00316715
<6>[ 9.838515] .
<3>[ 9.848242] dcs_cmd.name:rockchip,on-cmds144
<4>[ 9.848262] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.848280] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.848298] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.848320] 1173 command sent in LP mode size:2
<6>[ 9.848339] write GEN_HDR:000b6815
<6>[ 9.848354] .
<3>[ 9.858082] dcs_cmd.name:rockchip,on-cmds145
<4>[ 9.858103] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.858121] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.858139] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.858161] 1173 command sent in LP mode size:2
<6>[ 9.858179] write GEN_HDR:001e6915
<6>[ 9.858195] .
<3>[ 9.867923] dcs_cmd.name:rockchip,on-cmds146
<4>[ 9.867943] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.867961] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.867979] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.868001] 1173 command sent in LP mode size:2
<6>[ 9.868019] write GEN_HDR:00546a15
<6>[ 9.868035] .
<3>[ 9.877761] dcs_cmd.name:rockchip,on-cmds147
<4>[ 9.877782] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.877800] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.877818] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.877840] 1173 command sent in LP mode size:2
<6>[ 9.877858] write GEN_HDR:00046b15
<6>[ 9.877874] .
<3>[ 9.887602] dcs_cmd.name:rockchip,on-cmds148
<4>[ 9.887622] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.887641] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.887659] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.887680] 1173 command sent in LP mode size:2
<6>[ 9.887699] write GEN_HDR:00006c15
<3>[ 9.897433] dcs_cmd.name:rockchip,on-cmds149
<4>[ 9.897454] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.897472] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.897490] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.897512] 1173 command sent in LP mode size:2
<6>[ 9.897530] write GEN_HDR:00046d15
<6>[ 9.897546] .
<3>[ 9.907281] dcs_cmd.name:rockchip,on-cmds150
<4>[ 9.907302] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.907320] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.907338] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.907359] 1173 command sent in LP mode size:2
<6>[ 9.907378] write GEN_HDR:00006e15
<6>[ 9.907394] .
<3>[ 9.917123] dcs_cmd.name:rockchip,on-cmds151
<4>[ 9.917143] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.917161] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.917179] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.917201] 1173 command sent in LP mode size:2
<6>[ 9.917220] write GEN_HDR:00886f15
<6>[ 9.917236] .
<3>[ 9.926962] dcs_cmd.name:rockchip,on-cmds152
<4>[ 9.926982] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.927000] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.927018] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.927040] 1173 command sent in LP mode size:2
<6>[ 9.927058] write GEN_HDR:00007015
<6>[ 9.927074] .
<3>[ 9.936802] dcs_cmd.name:rockchip,on-cmds153
<4>[ 9.936823] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.936841] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.936859] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.936881] 1173 command sent in LP mode size:2
<6>[ 9.936899] write GEN_HDR:00007115
<6>[ 9.936915] .
<3>[ 9.946642] dcs_cmd.name:rockchip,on-cmds154
<4>[ 9.946662] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.946681] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.946699] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.946720] 1173 command sent in LP mode size:2
<6>[ 9.946738] write GEN_HDR:00067215
<6>[ 9.946754] .
<3>[ 9.956482] dcs_cmd.name:rockchip,on-cmds155
<4>[ 9.956502] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.956521] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.956539] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.956560] 1173 command sent in LP mode size:2
<6>[ 9.956579] write GEN_HDR:007b7315
<6>[ 9.956595] .
<3>[ 9.966321] dcs_cmd.name:rockchip,on-cmds156
<4>[ 9.966341] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.966360] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.966378] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.966399] 1173 command sent in LP mode size:2
<6>[ 9.966418] write GEN_HDR:00007415
<6>[ 9.966434] .
<3>[ 9.976162] dcs_cmd.name:rockchip,on-cmds157
<4>[ 9.976183] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.976201] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.976219] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.976240] 1173 command sent in LP mode size:2
<6>[ 9.976259] write GEN_HDR:00f87515
<6>[ 9.976275] .
<3>[ 9.986002] dcs_cmd.name:rockchip,on-cmds158
<4>[ 9.986023] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.986041] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.986059] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.986081] 1173 command sent in LP mode size:2
<6>[ 9.986099] write GEN_HDR:00007615
<6>[ 9.986115] .
<3>[ 9.995842] dcs_cmd.name:rockchip,on-cmds159
<4>[ 9.995862] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 9.995881] dcs_cmd.dsi_id == 0 line=127
<4>[ 9.995899] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 9.995921] 1173 command sent in LP mode size:2
<6>[ 9.995939] write GEN_HDR:000d7715
<6>[ 9.995955] .
<3>[ 10.005682] dcs_cmd.name:rockchip,on-cmds160
<4>[ 10.005702] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 10.005721] dcs_cmd.dsi_id == 0 line=127
<4>[ 10.005739] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 10.005761] 1173 command sent in LP mode size:2
<6>[ 10.005780] write GEN_HDR:00147815
<3>[ 10.015515] dcs_cmd.name:rockchip,on-cmds161
<4>[ 10.015536] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 10.015555] dcs_cmd.dsi_id == 0 line=127
<4>[ 10.015573] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 10.015594] 1173 command sent in LP mode size:2
<6>[ 10.015613] write GEN_HDR:00007915
<6>[ 10.015629] .
<3>[ 10.025362] dcs_cmd.name:rockchip,on-cmds162
<4>[ 10.025382] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 10.025401] dcs_cmd.dsi_id == 0 line=127
<4>[ 10.025419] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 10.025440] 1173 command sent in LP mode size:2
<6>[ 10.025459] write GEN_HDR:00007a15
<6>[ 10.025475] .
<3>[ 10.035201] dcs_cmd.name:rockchip,on-cmds163
<4>[ 10.035222] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 10.035240] dcs_cmd.dsi_id == 0 line=127
<4>[ 10.035259] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 10.035280] 1173 command sent in LP mode size:2
<6>[ 10.035299] write GEN_HDR:00007b15
<6>[ 10.035315] .
<3>[ 10.045043] dcs_cmd.name:rockchip,on-cmds164
<4>[ 10.045063] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 10.045082] dcs_cmd.dsi_id == 0 line=127
<4>[ 10.045100] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 10.045122] 1173 command sent in LP mode size:2
<6>[ 10.045140] write GEN_HDR:00007c15
<3>[ 10.054874] dcs_cmd.name:rockchip,on-cmds165
<4>[ 10.054895] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 10.054914] dcs_cmd.dsi_id == 0 line=127
<4>[ 10.054932] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 10.054953] 1173 command sent in LP mode size:2
<6>[ 10.054972] write GEN_HDR:00037d15
<6>[ 10.054988] .
<3>[ 10.064721] dcs_cmd.name:rockchip,on-cmds166
<4>[ 10.064741] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 10.064760] dcs_cmd.dsi_id == 0 line=127
<4>[ 10.064778] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 10.064800] 1173 command sent in LP mode size:2
<6>[ 10.064819] write GEN_HDR:007b7e15
<6>[ 10.064836] .
<3>[ 10.074561] dcs_cmd.name:rockchip,on-cmds167
<4>[ 10.074581] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 10.074600] dcs_cmd.dsi_id == 0 line=127
<4>[ 10.074618] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 10.074640] 1173 command sent in LP mode size:2
<6>[ 10.074658] write GEN_HDR:0000e015
<6>[ 10.074675] .
<3>[ 10.084402] dcs_cmd.name:rockchip,on-cmds168
<4>[ 10.084423] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 10.084442] dcs_cmd.dsi_id == 0 line=127
<4>[ 10.084460] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 10.084482] 1173 command sent in LP mode size:2
<6>[ 10.084500] write GEN_HDR:00100915
<3>[ 10.094234] dcs_cmd.name:rockchip,on-cmds169
<4>[ 10.094255] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 10.094274] dcs_cmd.dsi_id == 0 line=127
<4>[ 10.094292] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 10.094313] 1173 command sent in LP mode size:2
<6>[ 10.094332] write GEN_HDR:0002e615
<6>[ 10.094348] .
<3>[ 10.104083] dcs_cmd.name:rockchip,on-cmds170
<4>[ 10.104103] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 10.104122] dcs_cmd.dsi_id == 0 line=127
<4>[ 10.104140] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 10.104161] 1173 command sent in LP mode size:2
<6>[ 10.104180] write GEN_HDR:0006e715
<6>[ 10.104196] .
<3>[ 10.113921] dcs_cmd.name:rockchip,on-cmds171
<4>[ 10.113942] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 10.113961] dcs_cmd.dsi_id == 0 line=127
<4>[ 10.113979] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 10.114001] 1173 command sent in LP mode size:1
<6>[ 10.114019] write GEN_HDR:00001105
<6>[ 10.114035] .
<3>[ 10.241858] dcs_cmd.name:rockchip,on-cmds172
<4>[ 10.241879] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 10.241898] dcs_cmd.dsi_id == 0 line=127
<4>[ 10.241916] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 10.241938] 1173 command sent in LP mode size:1
<6>[ 10.241956] write GEN_HDR:00002905
<6>[ 10.241973] .
<3>[ 10.300897] dcs_cmd.name:rockchip,on-cmds173
<4>[ 10.300919] dcs_cmd->dcs_cmd.type == LPDT//Leo
<3>[ 10.300939] dcs_cmd.dsi_id == 0 line=127
<4>[ 10.300957] dcs_cmd.dsi_id == 0 line=128 Leo
<6>[ 10.300979] 1173 command sent in LP mode size:2
<6>[ 10.300998] write GEN_HDR:00003515
<6>[ 10.301014] .
<3>[ 10.320577] ++++++++++++++++rk_mipi_screen:255
<6>[ 10.320641] rk-hdmi 20034000.hdmi: [rockchip_hdmiv1_video_csc] input_color=1,output_color=2
<6>[ 10.320680] rk-hdmi 20034000.hdmi: [rockchip_hdmiv1_config_video] sucess output HDMI.
<6>[ 10.321224] rk-hdmi 20034000.hdmi: hdmi probe success.
<4>[ 10.322219] IEP Power ON
<4>[ 10.322298] iep ion client create success!
<4>[ 10.322750] IEP Power OFF
<4>[ 10.322785] IEP Driver loaded succesfully
<4>[ 10.322936] Module initialized.
<6>[ 10.325889] dma-pl330 20078000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 10.325931] dma-pl330 20078000.pdma: DBUFF-64x8bytes Num_Chans-8 Num_Peri-16 Num_Events-16
<4>[ 10.326784] rk_serial.c v1.8 2014-03-04
<6>[ 10.327118] 20060000.serial: ttyS0 at MMIO 0x20060000 (irq = 52) is a rk29_serial.0
<6>[ 10.327550] serial 20060000.serial: membase e355c000
<6>[ 10.333872] loop: module loaded
<4>[ 10.333996] i2c-core: driver [mpu6050B1] using legacy suspend method
<4>[ 10.334021] i2c-core: driver [mpu6050B1] using legacy resume method
<6>[ 10.334047] mpu_init: Probe name mpu6050B1
<6>[ 10.334383] ak8963_mod_init: Probe name ak8963_mod
<6>[ 10.335667] SCSI Media Changer driver v0.25
<6>[ 10.336321] tun: Universal TUN/TAP device driver, 1.6
<6>[ 10.336348] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
<4>[ 10.336647] vmac_init.
<3>[ 10.337753] stmmac_probe_config_dt: Can not read property: pmu_regulator.
<3>[ 10.337785] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
<6>[ 10.337810] stmmac_probe_config_dt: clock input or output? (input).
<6>[ 10.337833] stmmac_probe_config_dt: TX delay(0x30).
<6>[ 10.337854] stmmac_probe_config_dt: RX delay(0x10).
<7>[ 10.337891] of_get_named_gpio_flags exited with status 24
<7>[ 10.337916] of_get_named_gpio_flags exited with status 88
<7>[ 10.337933] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 10.337955] stmmac_probe_config_dt: is rockchip,rk312x-gmac
<6>[ 10.337974] stmmc_pltfr_init:
<3>[ 10.337993] stmmc_pltfr_init: ERROR: Get power-gpio failed.
<6>[ 10.338088] stmmc_pltfr_init: init for RGMII
<6>[ 10.338113] tx delay=0x30
<6>[ 10.338113] rx delay=0x10
<6>[ 10.338350] stmmac - user ID: 0x10, Synopsys ID: 0x35
<6>[ 10.338374] Normal descriptors
<6>[ 10.338391] Ring mode enabled
<6>[ 10.338409] DMA HW capability register supported
<6>[ 10.338428] RX Checksum Offload Engine supported (type 2)
<6>[ 10.338448] TX Checksum insertion supported
<6>[ 10.338465] Wake-Up On Lan supported
<6>[ 10.338577] Enable RX Mitigation via HW Watchdog Timer
<6>[ 10.339419] PPP generic driver version 2.4.2
<6>[ 10.339806] PPP BSD Compression module registered
<6>[ 10.339833] PPP Deflate Compression module registered
<6>[ 10.339881] PPP MPPE Compression module registered
<6>[ 10.339905] NET: Registered protocol family 24
<6>[ 10.339967] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
<6>[ 10.339994] CSLIP: code copyright 1989 Regents of the University of California.
<4>[ 10.340017] Rockchip WiFi SYS interface (V1.00) …
<4>[ 10.340112] esp_mem_init enter date Apr 6 2017 11:47:18
<4>[ 10.340136] esp_mem_init VERSION [V2.5]
<4>[ 10.340253] esp_mem_init complete
<6>[ 10.340384] usbcore: registered new interface driver catc
<6>[ 10.340469] usbcore: registered new interface driver kaweth
<6>[ 10.340494] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
<6>[ 10.340574] usbcore: registered new interface driver pegasus
<6>[ 10.340653] usbcore: registered new interface driver rtl8150
<6>[ 10.340730] usbcore: registered new interface driver r8152
<6>[ 10.340753] hso: drivers/net/usb/hso.c: Option Wireless
<6>[ 10.340904] usbcore: registered new interface driver hso
<6>[ 10.340998] usbcore: registered new interface driver asix
<6>[ 10.341080] usbcore: registered new interface driver ax88179_178a
<6>[ 10.341160] usbcore: registered new interface driver cdc_ether
<6>[ 10.341239] usbcore: registered new interface driver cdc_eem
<6>[ 10.341316] usbcore: registered new interface driver dm9601
<6>[ 10.341394] usbcore: registered new interface driver dm9620
<6>[ 10.341505] usbcore: registered new interface driver smsc75xx
<6>[ 10.341605] usbcore: registered new interface driver smsc95xx
<6>[ 10.341686] usbcore: registered new interface driver gl620a
<6>[ 10.341766] usbcore: registered new interface driver net1080
<6>[ 10.341845] usbcore: registered new interface driver plusb
<6>[ 10.341925] usbcore: registered new interface driver rndis_host
<6>[ 10.342016] usbcore: registered new interface driver cdc_subset
<6>[ 10.342096] usbcore: registered new interface driver zaurus
<6>[ 10.342180] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
<6>[ 10.342305] usbcore: registered new interface driver int51x1
<6>[ 10.342388] usbcore: registered new interface driver kalmia
<6>[ 10.342469] usbcore: registered new interface driver ipheth
<6>[ 10.342556] usbcore: registered new interface driver sierra_net
<6>[ 10.342639] usbcore: registered new interface driver cx82310_eth
<6>[ 10.342752] usbcore: registered new interface driver cdc_ncm
<6>[ 10.342836] usbcore: registered new interface driver qmi_wwan
<6>[ 10.342918] usbcore: registered new interface driver cdc_mbim
<6>[ 10.342942] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
<6>[ 10.344889] EHCI: ehci_rk_probe e3580000 e3580010
<6>[ 10.344924] rockchip_ehci_host 101c0000.usb: EHCI Host Controller
<6>[ 10.344977] rockchip_ehci_host 101c0000.usb: new USB bus registered, assigned bus number 1
<6>[ 10.345599] rockchip_ehci_host 101c0000.usb: irq 43, io mem 0x101c0000
<6>[ 10.359941] rockchip_ehci_host 101c0000.usb: USB 2.0 started, EHCI 1.00
<6>[ 10.360123] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 10.360156] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 10.360183] usb usb1: Product: EHCI Host Controller
<6>[ 10.360207] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
<6>[ 10.360232] usb usb1: SerialNumber: 101c0000.usb
<6>[ 10.361101] hub 1-0:1.0: USB hub found
<6>[ 10.361150] hub 1-0:1.0: 1 port detected
<6>[ 10.361514] EHCI: ehci_rk_probe ok
<6>[ 10.361695] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
<6>[ 10.361920] ohci-rockchip 101e0000.usb: RK OHCI Host Controller
<6>[ 10.361972] ohci-rockchip 101e0000.usb: new USB bus registered, assigned bus number 2
<6>[ 10.362053] ohci-rockchip 101e0000.usb: irq 64, io mem 0x101e0000
<6>[ 10.423004] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
<6>[ 10.423039] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 10.423067] usb usb2: Product: RK OHCI Host Controller
<6>[ 10.423092] usb usb2: Manufacturer: Linux 3.10.0 ohci_hcd
<6>[ 10.423117] usb usb2: SerialNumber: 101e0000.usb
<6>[ 10.423986] hub 2-0:1.0: USB hub found
<6>[ 10.424035] hub 2-0:1.0: 1 port detected
<6>[ 10.424673] usbcore: registered new interface driver cdc_acm
<6>[ 10.424699] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
<6>[ 10.424820] usbcore: registered new interface driver usblp
<6>[ 10.424913] usbcore: registered new interface driver cdc_wdm
<6>[ 10.425072] usbcore: registered new interface driver usb-storage
<6>[ 10.425158] usbcore: registered new interface driver ums-alauda
<6>[ 10.425240] usbcore: registered new interface driver ums-cypress
<6>[ 10.425320] usbcore: registered new interface driver ums-datafab
<6>[ 10.425399] usbcore: registered new interface driver ums_eneub6250
<6>[ 10.425478] usbcore: registered new interface driver ums-freecom
<6>[ 10.425558] usbcore: registered new interface driver ums-isd200
<6>[ 10.425637] usbcore: registered new interface driver ums-jumpshot
<6>[ 10.425716] usbcore: registered new interface driver ums-karma
<6>[ 10.425795] usbcore: registered new interface driver ums-onetouch
<6>[ 10.425888] usbcore: registered new interface driver ums-sddr09
<6>[ 10.425971] usbcore: registered new interface driver ums-sddr55
<6>[ 10.426052] usbcore: registered new interface driver ums-usbat
<6>[ 10.426239] usbcore: registered new interface driver usbserial
<6>[ 10.426323] usbcore: registered new interface driver usbserial_generic
<6>[ 10.426394] usbserial: USB Serial support registered for generic
<6>[ 10.426480] usbcore: registered new interface driver option
<6>[ 10.426548] usbserial: USB Serial support registered for GSM modem (1-port)
<6>[ 10.426777] usbcore: registered new interface driver trancevibrator
<6>[ 10.426804] usb20_otg: version 3.10a 21-DEC-2012
<4>[ 10.427458] e3600040
<4>[ 10.427486] Core Release: 2.91a
<4>[ 10.427507] Setting default values for core params
<4>[ 10.427765] Using Buffer DMA mode
<4>[ 10.427788] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 10.427808] Multiprocessor Interrupt Enhancement - disabled
<4>[ 10.427829] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 10.427848] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 10.427874] Dedicated Tx FIFOs mode
<4>[ 10.427923] pcd_init otg_dev = c5987300
<6>[ 10.428244] usb20_otg 10180000.usb: DWC OTG Controller
<6>[ 10.428300] usb20_otg 10180000.usb: new USB bus registered, assigned bus number 3
<6>[ 10.428357] usb20_otg 10180000.usb: irq 42, io mem 0x00000000
<6>[ 10.428478] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 10.428510] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 10.428538] usb usb3: Product: DWC OTG Controller
<6>[ 10.428562] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 10.428587] usb usb3: SerialNumber: 10180000.usb
<6>[ 10.429536] hub 3-0:1.0: USB hub found
<6>[ 10.429585] hub 3-0:1.0: 1 port detected
<6>[ 10.430224] usb20_host: version 3.10a 21-DEC-2012
<6>[ 10.431169] usbcore: registered new interface driver xpad
<6>[ 10.431301] usbcore: registered new interface driver usb_acecad
<6>[ 10.431402] usbcore: registered new interface driver aiptek
<6>[ 10.431508] usbcore: registered new interface driver gtco
<6>[ 10.431605] usbcore: registered new interface driver hanwang
<6>[ 10.431700] usbcore: registered new interface driver kbtab
<6>[ 10.431811] usbcore: registered new interface driver wacom
<4>[ 10.432645] sensor_register_slave:mma8452,id=17
<4>[ 10.432674] sensor_register_slave:gs_mc3230,id=23
<4>[ 10.432693] gsensor_init
<4>[ 10.432712] sensor_register_slave:mpu6880_acc,id=24
<4>[ 10.432733] sensor_register_slave:cm3217,id=47
<4>[ 10.432753] sensor_register_slave:cm3218,id=48
<3>[ 10.433149] .. rk pwm remotectl v1.1 init
<6>[ 10.433546] input: 20050030.pwm as /devices/20050030.pwm/input/input0
<6>[ 10.436702] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed
<7>[ 10.437773] of_get_named_gpio_flags exited with status 28
<6>[ 10.440225] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
<6>[ 10.440308] i2c /dev entries driver
<6>[ 10.440898] IR NEC protocol handler initialized
<6>[ 10.440924] IR RC5(x) protocol handler initialized
<6>[ 10.440944] IR RC6 protocol handler initialized
<6>[ 10.440962] IR JVC protocol handler initialized
<6>[ 10.440980] IR Sony protocol handler initialized
<6>[ 10.440999] IR RC5 (streamzap) protocol handler initialized
<6>[ 10.441018] IR SANYO protocol handler initialized
<6>[ 10.441037] IR MCE Keyboard/mouse protocol handler initialized
<6>[ 10.441513] usbcore: registered new interface driver uvcvideo
<6>[ 10.441539] USB Video Class driver (1.1.1)
<4>[ 10.441564] CamSys driver version: v0.27.1, CamSys head file version: v0.10.0
<3>[ 10.441590] E:camsys_soc_init(87): camsys isn’t support soc: 0x31260001!
<4>[ 10.443706] i2c-core: driver [bq27320] using legacy suspend method
<4>[ 10.443737] i2c-core: driver [bq27320] using legacy resume method
<6>[ 10.444522] device-mapper: uevent: version 1.0.3
<6>[ 10.445039] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
<6>[ 10.445718] Bluetooth: HCI UART driver ver 2.2
<6>[ 10.445748] Bluetooth: HCI H4 protocol initialized
<6>[ 10.445769] Bluetooth: HCILL protocol initialized
<6>[ 10.445789] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.19
<6>[ 10.445811] rtk_btusb: Register usb char device interface for BT driver
<6>[ 10.446214] usbcore: registered new interface driver rtk_btusb
<4>[ 10.450470] cpufreq version 1.0, suspend freq 1008 MHz
<6>[ 10.450876] cpuidle: using governor ladder
<6>[ 10.450902] cpuidle: using governor menu
<6>[ 10.450975] Synopsys Designware Multimedia Card Interface Driver
<6>[ 10.450997] MHSC version = Ver 2.00 2015-06-10
<4>[ 10.451432] dw cru_regsbase addr 0x124.
<4>[ 10.451458] dw cru_reset_offset val 3.
<6>[ 10.451486] dwmmc_rockchip 1021c000.rksdmmc: Version ID is 270a
<3>[ 10.451547] dwmmc_rockchip 1021c000.rksdmmc: failed to get hpclk_mmc
<6>[ 10.452019] dwmmc_rockchip 1021c000.rksdmmc: Using external DMA controller.
<4>[ 10.452463] dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc0]
<7>[ 10.452513] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 10.452718] 1358..dw_mci_set_ios: no card. [mmc0]
<4>[ 10.468208] 1358..dw_mci_set_ios: no card. [mmc0]
<4>[ 10.487931] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
<6>[ 10.489126] dwmmc_rockchip 1021c000.rksdmmc: DW MMC controller at irq 48, 32 bit host data width, 256 deep fifo
<6>[ 10.489160] dwmmc_rockchip 1021c000.rksdmmc: 1 slots initialized
<4>[ 10.489633] dw cru_regsbase addr 0x124.
<4>[ 10.489654] dw cru_reset_offset val 1.
<6>[ 10.489674] dwmmc_rockchip 10214000.rksdmmc: Version ID is 270a
<3>[ 10.489724] dwmmc_rockchip 10214000.rksdmmc: failed to get hpclk_mmc
<6>[ 10.491579] dwmmc_rockchip 10214000.rksdmmc: Using external DMA controller.
<4>[ 10.491919] dw_mci_init_slot: fmin=400000, fmax=37500000 [mmc1]
<7>[ 10.491960] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 10.492560] 1358..dw_mci_set_ios: no card. [mmc1]
<4>[ 10.507554] 1358..dw_mci_set_ios: no card. [mmc1]
<6>[ 10.520155] mmc0: BKOPS_EN bit is not set
<6>[ 10.522137] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
<4>[ 10.522172] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
<4>[ 10.522192] rk_sdmmc: BOOT dw_mci_setup_bus: workaround div = 1, host->bus_hz = 100000000 [mmc0]
<4>[ 10.522303] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=8bits.[mmc0]
<6>[ 10.522525] mmc0: new high speed DDR MMC card at address 0001
<6>[ 10.523138] mmcblk0: mmc0:0001 8GND3R 7.28 GiB
<6>[ 10.523741] uboot: 0x000400000 – 0x000800000 (4 MB)
<6>[ 10.523767] misc: 0x000800000 – 0x000c00000 (4 MB)
<6>[ 10.523786] resource: 0x000c00000 – 0x001c00000 (16 MB)
<6>[ 10.523804] kernel: 0x001c00000 – 0x002800000 (12 MB)
<6>[ 10.523823] boot: 0x002800000 – 0x003400000 (12 MB)
<6>[ 10.523841] recovery: 0x003400000 – 0x005400000 (32 MB)
<6>[ 10.523860] backup: 0x005400000 – 0x009400000 (64 MB)
<6>[ 10.523878] cache: 0x009400000 – 0x011400000 (128 MB)
<6>[ 10.523897] userdata: 0x011400000 – 0x051000000 (1020 MB)
<6>[ 10.523916] metadata: 0x051000000 – 0x052000000 (16 MB)
<6>[ 10.523935] kpanic: 0x052000000 – 0x052400000 (4 MB)
<6>[ 10.523953] system: 0x052400000 – 0x092400000 (1024 MB)
<6>[ 10.523973] radical_update: 0x092400000 – 0x096400000 (64 MB)
<6>[ 10.523992] user: 0x096400000 – 0x1d1c00000 (5048 MB)
<4>[ 10.527388] dwc_otg_hcd_suspend, usb device mode
<6>[ 10.527472] dwmmc_rockchip 10214000.rksdmmc: DW MMC controller at irq 46, 32 bit host data width, 256 deep fifo
<6>[ 10.527498] dwmmc_rockchip 10214000.rksdmmc: 1 slots initialized
<6>[ 10.524045] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141358..dw_mci_set_ios: no card. [mmc1]
<4>[ 10.527905] dw cru_regsbase addr 0x124.
<4>[ 10.527924] dw cru_reset_offset val 2.
<6>[ 10.527944] dwmmc_rockchip 10218000.rksdmmc: Version ID is 270a
<3>[ 10.527997] dwmmc_rockchip 10218000.rksdmmc: failed to get hpclk_mmc
<6>[ 10.528402] dwmmc_rockchip 10218000.rksdmmc: Using external DMA controller.
<4>[ 10.528738] dw_mci_init_slot: fmin=200000, fmax=37500000 [mmc2]
<7>[ 10.528772] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 10.528978] 1358..dw_mci_set_ios: no card. [mmc2]
<4>[ 10.546889] 1358..dw_mci_set_ios: no card. [mmc2]
<4>[ 10.566579] 1358..dw_mci_set_ios: no card. [mmc2]
<6>[ 10.566611] dwmmc_rockchip 10218000.rksdmmc: DW MMC controller at irq 47, 32 bit host data width, 256 deep fifo
<6>[ 10.566627] dwmmc_rockchip 10218000.rksdmmc: 1 slots initialized
<4>[ 10.566913] leds-gpio leds.22: pins are not configured from the driver
<7>[ 10.566958] of_get_named_gpio_flags exited with status 55
<7>[ 10.566972] of_get_named_gpio_flags exited with status 54
<7>[ 10.566983] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 10.566996] of_get_named_gpio_flags exited with status 55
<4>[ 10.567018] drivers/gpio/gpiolib.c //Leo mipi
<7>[ 10.567144] of_get_named_gpio_flags exited with status 67
<4>[ 10.567161] drivers/gpio/gpiolib.c //Leo mipi
<6>[ 10.567350] hidraw: raw HID events driver (C) Jiri Kosina
<6>[ 10.569658] usbcore: registered new interface driver usbhid
<6>[ 10.569675] usbhid: USB HID core driver
<6>[ 10.570194] zram: Created 1 device(s) …
<6>[ 10.570732] ashmem: initialized
<6>[ 10.570921] logger: created 256K log ‘log_main’
<6>[ 10.571108] logger: created 256K log ‘log_events’
<6>[ 10.571278] logger: created 256K log ‘log_radio’
<6>[ 10.571434] logger: created 256K log ‘log_system’
<7>[ 10.572588] of_get_named_gpio_flags exited with status 119
<7>[ 10.572606] of_get_named_gpio_flags exited with status 119
<6>[ 10.572968] input: rk29-keypad as /devices/2006c000.adc/key.25/input/input1
<7>[ 10.574357] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 10.574399] of_get_named_gpio_flags exited with status 117
<4>[ 10.574419] drivers/gpio/gpiolib.c //Leo mipi
<7>[ 10.574452] of_get_named_gpio_flags exited with status 27
<4>[ 10.574461] ------------[ cut here ]------------
<4>[ 10.574482] WARNING: at drivers/gpio/gpiolib.c:160 gpio_ensure_requested+0x4c/0xb4()
<4>[ 10.574494] autorequest GPIO-27
<4>[ 10.574502] Modules linked in:
<4>[ 10.574519] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.0 #56
<4>[ 10.574549] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
<4>[ 10.574572] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
<4>[ 10.574593] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
<4>[ 10.574613] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_ensure_requested+0x4c/0xb4)
<4>[ 10.574635] [] (gpio_ensure_requested+0x4c/0xb4) from [] (gpiod_direction_input+0x58/0x1f0)
<4>[ 10.574659] [] (gpiod_direction_input+0x58/0x1f0) from [] (rk312x_platform_probe+0x46c/0x5a4)
<4>[ 10.574684] [] (rk312x_platform_probe+0x46c/0x5a4) from [] (platform_drv_probe+0x14/0x18)
<4>[ 10.574707] [] (platform_drv_probe+0x14/0x18) from [] (really_probe+0xa8/0x20c)
<4>[ 10.574727] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48)
<4>[ 10.574747] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84)
<4>[ 10.574767] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90)
<4>[ 10.574786] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c)
<4>[ 10.574806] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138)
<4>[ 10.574826] [] (driver_register+0x9c/0x138) from [] (do_one_initcall+0x34/0xc8)
<4>[ 10.574847] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0)
<4>[ 10.574868] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130)
<4>[ 10.574889] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4)
<4>[ 10.574911] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c)
<4>[ 10.574951] —[ end trace fdcb50af4b16111c ]—
<4>[ 10.575224] This platfrom have not i2s_mclk,no need to set i2s_mclk.
<6>[ 10.575688] rockchip-spdif 10204000.spdif: spdif ready.
<6>[ 10.577799] audio-rk312x audio-rk312x.14: rk312x-hifi ↔ rockchip-i2s.1 mapping ok
<6>[ 10.578514] audio-rk312x audio-rk312x.14: rk312x-voice ↔ rockchip-i2s.1 mapping ok
<3>[ 10.578554] audio-rk312x audio-rk312x.14: ASoC: no sink widget found for Mic Bias
<3>[ 10.578570] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Mic Jack → direct → Mic Bias
<3>[ 10.578584] audio-rk312x audio-rk312x.14: ASoC: no source widget found for Mic Bias
<3>[ 10.578599] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Mic Bias → direct → MICP
<3>[ 10.578613] audio-rk312x audio-rk312x.14: ASoC: no source widget found for Mic Bias
<3>[ 10.578627] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Mic Bias → direct → MICN
<3>[ 10.578642] audio-rk312x audio-rk312x.14: ASoC: no sink widget found for Mic Bias
<3>[ 10.578655] audio-rk312x audio-rk312x.14: ASoC: Failed to add route Headset Jack → direct → Mic Bias
<3>[ 10.578671] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTR
<3>[ 10.578684] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTR → direct → Ext Spk
<3>[ 10.578699] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTL
<3>[ 10.578712] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTL → direct → Ext Spk
<3>[ 10.578727] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTR
<3>[ 10.578741] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTR → direct → Headphone Jack
<3>[ 10.578755] audio-rk312x audio-rk312x.14: ASoC: no source widget found for HPOUTL
<3>[ 10.578770] audio-rk312x audio-rk312x.14: ASoC: Failed to add route HPOUTL → direct → Headphone Jack
<6>[ 10.580164] u32 classifier
<6>[ 10.580183] Actions configured
<6>[ 10.580198] Netfilter messages via NETLINK v0.30.
<6>[ 10.580281] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
<6>[ 10.580802] ctnetlink v0.93: registering with nfnetlink.
<6>[ 10.580894] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[ 10.580906] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[ 10.581386] xt_time: kernel timezone is -0000
<6>[ 10.581702] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 10.581940] arp_tables: (C) 2002 David S. Miller
<6>[ 10.582000] TCP: cubic registered
<6>[ 10.582012] Initializing XFRM netlink socket
<6>[ 10.582419] NET: Registered protocol family 10
<6>[ 10.583232] mip6: Mobile IPv6
<6>[ 10.583280] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 10.583465] sit: IPv6 over IPv4 tunneling driver
<6>[ 10.584023] NET: Registered protocol family 17
<6>[ 10.584071] NET: Registered protocol family 15
<5>[ 10.584167] Bridge firewalling registered
<6>[ 10.584187] Ebtables v2.0 registered
<6>[ 10.584442] Bluetooth: RFCOMM TTY layer initialized
<6>[ 10.584487] Bluetooth: RFCOMM socket layer initialized
<6>[ 10.584499] Bluetooth: RFCOMM ver 1.11
<6>[ 10.584510] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[ 10.584521] Bluetooth: BNEP filters: protocol multicast
<6>[ 10.584537] Bluetooth: BNEP socket layer initialized
<6>[ 10.584549] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[ 10.584566] Bluetooth: HIDP socket layer initialized
<6>[ 10.584613] l2tp_core: L2TP core driver, V2.0
<6>[ 10.584636] l2tp_ppp: PPPoL2TP kernel driver, V2.0
<6>[ 10.584647] [WLAN_RFKILL]: Enter rfkill_wlan_init
<6>[ 10.584849] [WLAN_RFKILL]: Enter rfkill_wlan_probe
<6>[ 10.584868] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
<6>[ 10.584881] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
<6>[ 10.584893] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
<6>[ 10.584906] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
<7>[ 10.584950] of_get_named_gpio_flags exited with status 43
<6>[ 10.584960] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 43, flags = 0.
<7>[ 10.584973] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 10.584987] of_get_named_gpio_flags exited with status 2
<6>[ 10.584996] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 2, flags = 0.
<6>[ 10.585008] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
<4>[ 10.585032] drivers/gpio/gpiolib.c //Leo mipi
<6>[ 10.585053] [WLAN_RFKILL]: Exit rfkill_wlan_probe
<6>[ 10.585114] [BT_RFKILL]: Enter rfkill_rk_init
<7>[ 10.585300] of_get_named_gpio_flags exited with status 17
<6>[ 10.585312] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 17.
<7>[ 10.585327] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 10.585340] of_get_named_gpio_flags exited with status 35
<6>[ 10.585349] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 35.
<7>[ 10.585365] of_get_named_gpio_flags exited with status 42
<6>[ 10.585373] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 42.
<7>[ 10.585388] of_get_named_gpio_flags exited with status 41
<6>[ 10.585396] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 41.
<6>[ 10.585466] [BT_RFKILL]: Request irq for bt wakeup host
<6>[ 10.585586] [BT_RFKILL]: ** disable irq
<4>[ 10.585721] drivers/gpio/gpiolib.c //Leo mipi
<6>[ 10.585741] [BT_RFKILL]: ap6212 device registered.
<3>[ 10.586055] rk_cam_cif(3083):rk312x-camera version: v0.1.14 Zoom by ipp
<3>[ 10.586166] rk_cif 1010a000.cif: rk_camera_cif_iomux:could not get cif_pin_all pinstate
<7>[ 10.586264] of_get_named_gpio_flags exited with status 127
<4>[ 10.586286] drivers/gpio/gpiolib.c //Leo mipi
<7>[ 10.586311] of_get_named_gpio_flags exited with status 127
<7>[ 10.586322] _gpio_request: gpio-127 (camera powerdown) status -16
<4>[ 10.586331] drivers/gpio/gpiolib.c //Leo mipi
<7>[ 10.586350] of_get_named_gpio_flags exited with status 127
<7>[ 10.586359] _gpio_request: gpio-127 (camera powerdown) status -16
<4>[ 10.586367] drivers/gpio/gpiolib.c //Leo mipi
<7>[ 10.586384] of_get_named_gpio_flags exited with status 74
<4>[ 10.586397] drivers/gpio/gpiolib.c //Leo mipi
<7>[ 10.586415] of_get_named_gpio_flags exited with status 74
<7>[ 10.586424] _gpio_request: gpio-74 (camera power) status -16
<4>[ 10.586433] drivers/gpio/gpiolib.c //Leo mipi
<7>[ 10.586449] of_get_named_gpio_flags exited with status 127
<7>[ 10.586458] _gpio_request: gpio-127 (camera powerdown) status -16
<4>[ 10.586467] drivers/gpio/gpiolib.c //Leo mipi
<6>[ 10.586713] soc-camera-pdrv s5k4ec_back_3: Probing s5k4ec_back_3
<4>[ 10.586735] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 10.586752] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 10.586767] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 10.586779] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 10.586823] drivers/gpio/gpiolib.c //Leo mipi
<6>[ 10.587277] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
<6>[ 10.587306] rk312x_init_suspend
<6>[ 10.587316] rk312x_suspend_init
<5>[ 10.587628] Registering SWP/SWPB emulation handler
<6>[ 10.587646] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 2000000@ddc00000
<6>[ 10.592886] ddrfreq: verion 1.2 20140526
<6>[ 10.592910] ddrfreq: normal 492MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 198MHz reboot 492MHz
<6>[ 10.592923] ddrfreq: auto-freq=0
<6>[ 10.592933] ddrfreq: auto-freq-table[0] 240MHz
<6>[ 10.592943] ddrfreq: auto-freq-table[1] 324MHz
<6>[ 10.592953] ddrfreq: auto-freq-table[2] 396MHz
<6>[ 10.592962] ddrfreq: auto-freq-table[3] 528MHz
<6>[ 10.599183] rk818_ldo8: disabling
<6>[ 10.600087] rk818_ldo4: disabling
<6>[ 10.600747] regulator-dummy: disabling
<4>[ 10.600896] =======================================================
<4>[ 10.600911] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
<4>[ 10.600921] =======================================================
<4>[ 10.600932] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
<4>[ 10.601012] dhd_module_init: in
<4>[ 10.601026] ======== bcm_wlan_set_plat_data ========
<6>[ 10.601037] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
<4>[ 10.601076] host_oob_irq: 169
<4>[ 10.601086] host_oob_irq_flags=4
<4>[ 10.601095] dhd_wifi_platform_load: Enter
<4>[ 10.601121] Power-up adapter ‘DHD generic adapter’
<4>[ 10.601127] pcd_pullup, is_on 0
<4>[ 10.601174] wifi_platform_set_power = 1
<4>[ 10.601185] ======== PULL WL_REG_ON HIGH! ========
<6>[ 10.601189] file system registered
<6>[ 10.601205] [WLAN_RFKILL]: rockchip_wifi_power: 1
<6>[ 10.601215] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
<6>[ 10.601226] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<6>[ 10.602267] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[ 10.602284] android_usb gadget: Number of LUNs=2
<6>[ 10.602296] lun0: LUN: removable file: (no medium)
<6>[ 10.602307] lun1: LUN: removable file: (no medium)
<6>[ 10.602562] android_usb gadget: android_usb ready
<6>[ 10.602670] sensor_init: Probe name sensors
<4>[ 10.602697] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
<6>[ 10.603269] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:00:00 UTC (1293883200)
<6>[ 10.609438] rockchip-spdif-card rockchip-spdif-card.23: rk-hdmi-spdif-hifi ↔ 10204000.spdif mapping ok
<6>[ 10.610608] usbcore: registered new interface driver snd-usb-audio
<6>[ 10.610625] ALSA device list:
<6>[ 10.610635] #0: RK_RK312X
<6>[ 10.610644] #1: RK-SPDIF-CARD
<6>[ 10.611095] Freeing unused kernel memory: 352K (c0b9c000 - c0bf4000)
<7>[ 10.617843] SELinux: 2048 avtab hash slots, 5368 rules.
<7>[ 10.621102] SELinux: 2048 avtab hash slots, 5368 rules.
<7>[ 10.621134] SELinux: 1 users, 2 roles, 442 types, 0 bools, 1 sens, 1024 cats
<7>[ 10.621148] SELinux: 86 classes, 5368 rules
<7>[ 10.622885] SELinux: Completing initialization.
<7>[ 10.622898] SELinux: Setting up existing superblocks.
<7>[ 10.622925] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<7>[ 10.622947] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
<7>[ 10.623013] SELinux: initialized (dev bdev, type bdev), not configured for labeling
<7>[ 10.623035] SELinux: initialized (dev proc, type proc), uses genfs_contexts
<7>[ 10.623066] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 10.623093] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
<7>[ 10.623371] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
<7>[ 10.627428] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
<7>[ 10.627454] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
<7>[ 10.627470] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
<7>[ 10.627486] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
<7>[ 10.627518] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
<7>[ 10.627577] SELinux: initialized (dev configfs, type configfs), not configured for labeling
<7>[ 10.627590] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 10.627625] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<6>[ 10.674810] usb 1-1: new high-speed USB device number 2 using rockchip_ehci_host
<4>[ 10.694450] Cam_Powerdowm
<3>[ 10.694558] rk818_ldo8: operation not allowed
<6>[ 10.704301] [WLAN_RFKILL]: wifi turn on power. 43
<3>[ 10.763426] rk818_ldo4: operation not allowed
<4>[ 10.802714] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 10.802740] ret: 0
<4>[ 10.823004] min_w = 800,min_h = 600 ,max_real_w = 2592,max_real_h = 1944,max_w = 2592,max_h =1944
<6>[ 10.823049] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
<6>[ 10.823071] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
<6>[ 10.823095] usb 1-1: Product: USB 2.0 Hub [MTT]
<6>[ 10.823959] hub 1-1:1.0: USB hub found
<6>[ 10.824142] hub 1-1:1.0: 4 ports detected
<3>[ 10.824650] s5k4ec_back_3(rk_cam_sensor:169): write reg(0xfcfc, val:0xd000) failed, try to write again!
<3>[ 10.826250] s5k4ec_back_3(rk_cam_sensor:169): write reg(0xfcfc, val:0xd000) failed, try to write again!
<3>[ 10.827816] s5k4ec_back_3(rk_cam_sensor:169): write reg(0xfcfc, val:0xd000) failed, try to write again!
<3>[ 10.827849] s5k4ec_back_3(rk_cam_sensor:387): write array failed!
<3>[ 10.827865] s5k4ec_back_3(rk_cam_sensor:671): soft reset failed
<3>[ 10.827865]
<5>[ 10.828361] type=1403 audit(1293883200.720:2): policy loaded auid=4294967295 ses=4294967295
<3>[ 10.843693] s5k4ec_back_3(rk_cam_sensor:169): write reg(0x2c, val:0x7000) failed, try to write again!
<3>[ 10.845260] s5k4ec_back_3(rk_cam_sensor:169): write reg(0x2c, val:0x7000) failed, try to write again!
<3>[ 10.846804] s5k4ec_back_3(rk_cam_sensor:169): write reg(0x2c, val:0x7000) failed, try to write again!
<3>[ 10.848346] s5k4ec_back_3(rk_cam_sensor:169): write reg(0x2e, val:0x1a4) failed, try to write again!
<3>[ 10.849892] s5k4ec_back_3(rk_cam_sensor:169): write reg(0x2e, val:0x1a4) failed, try to write again!
<3>[ 10.851439] s5k4ec_back_3(rk_cam_sensor:169): write reg(0x2e, val:0x1a4) failed, try to write again!
<3>[ 10.853272] s5k4ec_back_3(rk_cam_sensor:335): read reg(0xf12 val:0x0) failed, try to read again!
<3>[ 10.853304] s5k4ec_back_3(rk_cam_sensor:718): error: mismatched pid = 0xffff
<3>[ 10.853304]
<4>[ 10.853442] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 10.853465] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 10.853479] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 10.853492] drivers/gpio/gpiolib.c //Leo mipi
<11>[ 10.881511] init: could not import file ‘init.box.samba.rc’ from ‘/init.rk30board.rc’
<11>[ 10.886283] init: invalid gid ‘trace’
<4>[ 10.910966] wifi_platform_bus_enumerate device present 1
<4>[ 10.910991] ======== Card detection to detect SDIO card! ========
<6>[ 10.911008] mmc2:mmc host rescan start!
<4>[ 10.920877] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 10.920912] ret: 0
<4>[ 10.940515] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.048759] Cam_Powerdowm
<6>[ 11.058716] soc-camera-pdrv ov2659_front_4: Probing ov2659_front_4
<4>[ 11.058745] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.058768] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.058783] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.058799] drivers/gpio/gpiolib.c //Leo mipi
<11>[ 11.113492] init: /dev/hw_random not found
<6>[ 11.113610] keychord: using input dev 20050030.pwm for fevent
<6>[ 11.113633] keychord: using input dev rk29-keypad for fevent
<7>[ 11.114576] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 11.115198] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 11.115884] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 11.119003] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 11.119414] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 11.122264] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<11>[ 11.125973] init: /dev/hw_random not found
<4>[ 11.127462] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.127479] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
<4>[ 11.127525] ret: 0
<14>[ 11.128217] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/1021c000.rksdmmc/by-name/system
<14>[ 11.130933] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 262144 blocks long. Nothing to do!resize2fs:
<6>[ 11.139186] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
<7>[ 11.139237] SELinux: initialized (dev mmcblk0p12, type ext4), uses xattr
<14>[ 11.139373] fs_mgr: __mount(source=/dev/block/platform/1021c000.rksdmmc/by-name/system,target=/system,type=ext4)=0
<6>[ 11.152846] EXT4-fs (mmcblk0p8): recovery complete
<6>[ 11.153244] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 11.153286] SELinux: initialized (dev mmcblk0p8, type ext4), uses xattr
<14>[ 11.153394] fs_mgr: __mount(source=/dev/block/platform/1021c000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
<6>[ 11.158607] EXT4-fs (mmcblk0p10): recovery complete
<6>[ 11.158640] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 11.158679] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<14>[ 11.158786] fs_mgr: __mount(source=/dev/block/platform/1021c000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
<4>[ 11.166807] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.167793] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
<4>[ 11.169452] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 11.171145] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 11.174135] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
<6>[ 11.204440] EXT4-fs (mmcblk0p9): recovery complete
<6>[ 11.204840] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 11.204882] SELinux: initialized (dev mmcblk0p9, type ext4), uses xattr
<14>[ 11.204988] fs_mgr: __mount(source=/dev/block/platform/1021c000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
<6>[ 11.268036] Adding 65532k swap on /dev/block/zram0. Priority:-1 extents:1 across:65532k SS
<7>[ 11.269306] SELinux: initialized (dev functionfs, type functionfs), uses genfs_contexts
<6>[ 11.269554] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 37500000Hz, actual 37500000HZ div = 0)
<4>[ 11.269591] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
<4>[ 11.269732] rk_sdmmc: BOOT Bus speed=37500000Hz,Bus width=4bits.[mmc2]
<6>[ 11.272776] mmc2: new high speed SDIO card at address 0001
<4>[ 11.275068] Cam_Powerdowm
<4>[ 11.275768] min_w = 800,min_h = 600 ,max_real_w = 1600,max_real_h = 1200,max_w = 1600,max_h =1200
<3>[ 11.277108] ov2659_front_4(rk_cam_sensor:169): write reg(0x103, val:0x1) failed, try to write again!
<3>[ 11.278432] ov2659_front_4(rk_cam_sensor:169): write reg(0x103, val:0x1) failed, try to write again!
<3>[ 11.279694] ov2659_front_4(rk_cam_sensor:169): write reg(0x103, val:0x1) failed, try to write again!
<3>[ 11.279723] ov2659_front_4(rk_cam_sensor:387): write array failed!
<3>[ 11.279739] ov2659_front_4(rk_cam_sensor:671): soft reset failed
<3>[ 11.279739]
<6>[ 11.284375] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 382; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-6e9f168’, rk_ko_ver is ‘5’, built at ‘18:04:38’, on ‘Sep 7 2015’.
<6>[ 11.284567] mali-utgard 10091000.gpu: mali_platform_device->num_resources = 13
<6>[ 11.284591] mali-utgard 10091000.gpu: mali_platform_device->resource[0].start = 0x10091000
<6>[ 11.284611] mali-utgard 10091000.gpu: mali_platform_device->resource[1].start = 0x10090000
<6>[ 11.284631] mali-utgard 10091000.gpu: mali_platform_device->resource[2].start = 0x10093000
<6>[ 11.284650] mali-utgard 10091000.gpu: mali_platform_device->resource[3].start = 0x10098000
<6>[ 11.284670] mali-utgard 10091000.gpu: mali_platform_device->resource[4].start = 0x10094000
<6>[ 11.284690] mali-utgard 10091000.gpu: mali_platform_device->resource[5].start = 0x1009a000
<6>[ 11.284709] mali-utgard 10091000.gpu: mali_platform_device->resource[6].start = 0x10095000
<6>[ 11.284728] mali-utgard 10091000.gpu: mali_platform_device->resource[7].start = 0x00000023
<6>[ 11.284748] mali-utgard 10091000.gpu: mali_platform_device->resource[8].start = 0x00000024
<6>[ 11.284766] mali-utgard 10091000.gpu: mali_platform_device->resource[9].start = 0x00000025
<6>[ 11.284785] mali-utgard 10091000.gpu: mali_platform_device->resource[10].start = 0x00000024
<6>[ 11.284804] mali-utgard 10091000.gpu: mali_platform_device->resource[11].start = 0x00000025
<6>[ 11.284822] mali-utgard 10091000.gpu: mali_platform_device->resource[12].start = 0x00000024
<6>[ 11.284980] mali-utgard 10091000.gpu: freq: 200000000, min_threshold: 0, max_threshold: 70
<6>[ 11.285006] mali-utgard 10091000.gpu: freq: 297000000, min_threshold: 61, max_threshold: 85
<6>[ 11.285026] mali-utgard 10091000.gpu: freq: 400000000, min_threshold: 73, max_threshold: 100
<6>[ 11.285127] mali-utgard 10091000.gpu: initial freq = 200000000
<4>[ 11.287479] Mali: Mali device driver loaded
<3>[ 11.288787] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<4>[ 11.289533] bcmsdh_register: register client driver
<3>[ 11.289705] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<4>[ 11.289717] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
<4>[ 11.289843] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
<4>[ 11.289863] bus num (host idx)=2, slot num (rca)=1
<4>[ 11.289878] found adapter info ‘DHD generic adapter’
<4>[ 11.290617] F1 signature read @0x18000000=0x1540a9a6
<3>[ 11.290650] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<6>[ 11.291461] Cannot change disksize for initialized device
<4>[ 11.294316] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x0 pkg:0x4
<4>[ 11.295750] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
<4>[ 11.295955] wifi_platform_get_mac_addr
<4>[ 11.295972] ======== bcm_wlan_get_mac_address ========
<6>[ 11.295986] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
<6>[ 11.296011] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
<6>[ 11.296028] [WLAN_RFKILL]: This mac address is not valid, ignored…
<4>[ 11.296054] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=0
<4>[ 11.296141] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
<3>[ 11.296437] ov2659_front_4(rk_cam_sensor:335): read reg(0x300a val:0x0) failed, try to read again!
<3>[ 11.296470] ov2659_front_4(rk_cam_sensor:699): read chip id failed
<4>[ 11.297032] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.297062] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.297078] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.297093] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.297166] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.297381] wl_create_event_handler(): thread:wl_event_handler:7e started
<4>[ 11.297680] tsk Enter, tsk = 0xddfe149c
<4>[ 11.298086] dhd_attach(): thread:dhd_watchdog_thread:7f started
<4>[ 11.298246] dhd_attach(): thread:dhd_dpc:80 started
<4>[ 11.298273] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
<4>[ 11.298382] dhd_attach(): thread:dhd_rxf:81 started
<4>[ 11.298416] dhd_deferred_work_init: work queue initialized
<4>[ 11.298722] dhdsdio_probe_init: set use_rxchain 0 from config.txt
<11>[ 11.305624] fs_mgr: swapon failed for /dev/block/zram0
<4>[ 11.312375] Dongle Host Driver, version 1.201.59.5 (r506368)
<4>[ 11.312375] Compiled in drivers/net/wireless/bcmdhd on Apr 6 2017 at 11:47:30
<4>[ 11.313218] Register interface [wlan0] MAC: 94:a1:a2:a3:a1:a0
<4>[ 11.313218]
<4>[ 11.313249] dhd_prot_ioctl : bus is down. we have nothing to do
<4>[ 11.313333] bcmsdh_oob_intr_unregister: Enter
<4>[ 11.313351] bcmsdh_oob_intr_unregister: irq is not registered
<4>[ 11.313372] dhd_txglom_enable: enable 0
<4>[ 11.313386] dhd_bus_devreset: WLAN OFF DONE
<4>[ 11.313501] wifi_platform_set_power = 0
<4>[ 11.313518] ======== PULL WL_REG_ON LOW! ========
<6>[ 11.313532] [WLAN_RFKILL]: rockchip_wifi_power: 0
<3>[ 11.348434] EXT4-fs (mmcblk0p9): Unrecognized mount option “background_gc=on” or missing value
<14>[ 11.369046] bat_cap: oldcap path is /sys/devices/2006c000.adc
<11>[ 11.369165] bat_cap: oldcap_path no exist
<6>[ 11.369615] binder: 131:131 transaction failed 29189, size 0-0
<11>[ 11.381885] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
<11>[ 11.381945] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
<11>[ 11.382579] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
<6>[ 11.386430] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 11.386454] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 11.386490] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 11.386505] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 11.386548] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 11.386564] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 11.386594] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 11.386609] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<11>[ 11.400972] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
<4>[ 11.403049] Cam_Powerdowm
<11>[ 11.404762] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’
<11>[ 11.405969] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
<11>[ 11.406570] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
<11>[ 11.407613] init: Warning! Service mtdlink needs a SELinux domain defined; please fix!
<3>[ 11.412074] android_usb: already disabled
<6>[ 11.413670] [WLAN_RFKILL]: wifi shut off power.
<6>[ 11.413740] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
<6>[ 11.413783] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<4>[ 11.414007] dhd_module_init: Exit err=0
<6>[ 11.424748] read descriptors
<6>[ 11.424781] read strings
<4>[ 11.424841] pcd_pullup, is_on 1
<38>[ 11.469142] logd.auditd: start
<4>[ 11.491548] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.491583] ret: 0
<6>[ 11.521736] soc-camera-pdrv gc0329_front_5: Probing gc0329_front_5
<4>[ 11.521767] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.521792] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.521809] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.521824] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.590006] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.590048] ret: 0
<4>[ 11.629322] drivers/gpio/gpiolib.c //Leo mipi
<7>[ 11.729450] SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
<4>[ 11.737553] Cam_Powerdowm
<4>[ 11.738357] min_w = 640,min_h = 480 ,max_real_w = 640,max_real_h = 480,max_w = 640,max_h =480
<3>[ 11.758371] gc0329_front_5(rk_cam_sensor:169): write reg(0xfc, val:0x16) failed, try to write again!
<3>[ 11.759509] gc0329_front_5(rk_cam_sensor:169): write reg(0xfc, val:0x16) failed, try to write again!
<3>[ 11.760594] gc0329_front_5(rk_cam_sensor:169): write reg(0xfc, val:0x16) failed, try to write again!
<3>[ 11.788190] gc0329_front_5(rk_cam_sensor:335): read reg(0x0 val:0x0) failed, try to read again!
<3>[ 11.788246] gc0329(917): gc0329 read chip id high byte failed
<3>[ 11.788246]
<3>[ 11.788284] gc0329(924): error: gc0329 mismatched pid = 0x0
<3>[ 11.788284]
<3>[ 11.788329] gc0329_front_5(rk_cam_sensor:718): error: mismatched pid = 0x0
<3>[ 11.788329]
<4>[ 11.788574] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.788609] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.788632] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.788651] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.788735] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.894956] Cam_Powerdowm
<4>[ 11.963898] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 11.963936] ret: 0
<6>[ 12.006030] soc-camera-pdrv gc2035_back_6: Probing gc2035_back_6
<4>[ 12.006081] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.006126] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.006166] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.006206] drivers/gpio/gpiolib.c //Leo mipi
<6>[ 12.015805] rk312x-lcdc lcdc0: blank mode:0
<4>[ 12.121326] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.141019] ret: 0
<4>[ 12.189021] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.288595] Cam_Powerdowm
<3>[ 12.288623] rk_cam_io(1128):SENSOR_PWRSEQ_PWRDN failed
<3>[ 12.288718] soc-camera-pdrv gc2035_back_6: Cannot get I2C adapter #2. No driver?
<4>[ 12.288745] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.288767] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.288782] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.288797] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.288840] drivers/gpio/gpiolib.c //Leo mipi
<6>[ 12.342728] EHCI: rk_ehci_hcd_enable, enable host controller
<4>[ 12.396856] Cam_Powerdowm
<3>[ 12.396889] rk_cam_io(1128):SENSOR_PWRSEQ_PWRDN failed
<3>[ 12.396907] rk_cam_io(1117):SENSOR_PWRSEQ_HWRST failed
<4>[ 12.544443] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.544483] ret: 0
<6>[ 12.574811] soc-camera-pdrv gc0308_front_7: Probing gc0308_front_7
<4>[ 12.574843] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.574868] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.574886] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.574903] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.652690] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.672392] ret: 0
<4>[ 12.711730] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.819947] Cam_Powerdowm
<3>[ 12.820094] soc-camera-pdrv gc0308_front_7: Cannot get I2C adapter #2. No driver?
<4>[ 12.820123] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.820146] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.820161] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.820176] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.820223] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.928230] Cam_Powerdowm
<4>[ 12.997064] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 12.997106] ret: 0
<4>[ 13.538365] rk312x_delay_workq
<4>[ 13.656408] [off]
<6>[ 14.134044] warning: `system_server’ uses 32-bit capabilities (legacy support in use)
<4>[ 14.266489] iep dpi mode inactivity
<6>[ 18.310695] [otg id chg] last id -1 current id 256
<4>[ 18.310746] PortPower off
<4>[ 18.410290] Using Buffer DMA mode
<4>[ 18.410358] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 18.413268] Multiprocessor Interrupt Enhancement - disabled
<4>[ 18.413296] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 18.413309] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 18.901116] vbus detect**
<4>[ 19.078523] Using Buffer DMA mode
<4>[ 19.078571] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 19.078589] Multiprocessor Interrupt Enhancement - disabled
<4>[ 19.078604] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 19.078616] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 19.078667] soft connect!!!
<4>[ 19.303384] USB RESET
<6>[ 19.364851] android_work: sent uevent USB_STATE=CONNECTED
<4>[ 19.368360] USB RESET
<6>[ 19.461443] android_usb gadget: high-speed config #1: android
<6>[ 19.461693] android_work: sent uevent USB_STATE=CONFIGURED
<6>[ 27.355512] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
<6>[ 27.355553] lowmemorykiller: oom_adj 0 => oom_score_adj 0
<6>[ 27.355569] lowmemorykiller: oom_adj 1 => oom_score_adj 58
<6>[ 27.355582] lowmemorykiller: oom_adj 2 => oom_score_adj 117
<6>[ 27.355595] lowmemorykiller: oom_adj 3 => oom_score_adj 176
<6>[ 27.355607] lowmemorykiller: oom_adj 9 => oom_score_adj 529
<6>[ 27.355620] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
<6>[ 29.508716] acc_open
<6>[ 29.508770] acc_release
<4>[ 31.045712] phy_power_on: enable = 1
<4>[ 31.045750] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 31.050696] drivers/gpio/gpiolib.c //Leo mipi
<4>[ 31.085176] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
<4>[ 31.085267] eth0: device MAC address de:fe:91:e5:db:29
<6>[ 31.090027] libphy: stmmac: probed
<6>[ 31.090053] eth0: PHY ID 001cc915 at 0 IRQ 165 (stmmac-0:00) active
<6>[ 31.090069] eth0: PHY ID 001cc915 at 1 IRQ 165 (stmmac-0:01) active
<4>[ 31.670869] dwc_otg_hcd_resume, usb device mode
<4>[ 31.772052] dwc_otg_hcd_suspend, usb device mode
<4>[ 32.203405] FAT-fs (mmcblk0p14): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
<7>[ 32.203513] SELinux: initialized (dev mmcblk0p14, type vfat), uses genfs_contexts
<11>[ 32.258950] init: no such service ‘fuse_internal_sd’
<6>[ 34.644087] pm policy 0 → 1
<38>[ 38.918195] type=1400 audit(1293883229.270:3): avc: denied { write } for pid=896 comm=“chip.devicetest” name=“force_usb_mode” dev=“sysfs” ino=6802 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
<4>[ 38.966231] force_usb_mode_store 0->0
<4>[ 48.651707] force_usb_mode_store 0->0
2.dts的部分:
disp_mipi_init: mipi_dsi_init{
compatible = “rockchip,mipi_dsi_init”;
rockchip,screen_init = <1>;
rockchip,dsi_lane = <4>;
rockchip,dsi_hs_clk = <220>;//
rockchip,mipi_dsi_num = <1>;//
disp_mipi_power_ctr: mipi_power_ctr {
compatible = "rockchip,mipi_power_ctr";
mipi_lcd_rst:mipi_lcd_rst{
compatible = "rockchip,lcd_rst";
rockchip,gpios = <&gpio1 GPIO_A7 GPIO_ACTIVE_HIGH>;
rockchip,delay = <10>;
disp_mipi_init_cmds: screen-on-cmds {
rockchip,cmd_debug = <1>;
rockchip,on-cmds1 {
rockchip,cmd_type = <1>;
rockchip,dsi_id = <0>;
rockchip,cmd = <0x15 0xE0 0x00>;
rockchip,cmd_delay = <0>;
rockchip,on-cmds2 {
rockchip,cmd = <0x15 0xE1 0x93>;
rockchip,on-cmds3 {
rockchip,cmd = <0x15 0xE2 0x65>;
rockchip,on-cmds4 {
rockchip,cmd = <0x15 0xE3 0xF8>;
rockchip,on-cmds5 {
rockchip,cmd = <0x15 0x80 0x03>;
rockchip,on-cmds6 {
rockchip,cmd = <0x15 0xE0 0x04>;
rockchip,cmd_delay = <120>;
rockchip,on-cmds7 {
rockchip,cmd = <0x15 0x2B 0x2B>;
rockchip,on-cmds8 {
rockchip,cmd = <0x15 0x2D 0x03>;
rockchip,on-cmds9 {
rockchip,cmd = <0x15 0x2E 0x44>;
rockchip,on-cmds10 {
rockchip,cmd = <0x15 0xE0 0x01>;
rockchip,on-cmds11 {
rockchip,cmd = <0x15 0x00 0x00>;
rockchip,on-cmds12 {
rockchip,cmd = <0x15 0x01 0x6A>;
rockchip,on-cmds13 {
rockchip,cmd = <0x15 0x17 0x00>;
rockchip,on-cmds14 {
rockchip,cmd = <0x15 0x18 0xC0>;
rockchip,on-cmds15 {
rockchip,cmd = <0x15 0x19 0x01>;
rockchip,on-cmds16 {
rockchip,cmd = <0x15 0x1A 0x00>;
rockchip,on-cmds17 {
rockchip,cmd = <0x15 0x1B 0xC0>;
rockchip,on-cmds18 {
rockchip,cmd = <0x15 0x1C 0x01>;
rockchip,on-cmds19 {
rockchip,cmd = <0x15 0x1F 0x6A>;
rockchip,on-cmds20 {
rockchip,cmd = <0x15 0x20 0x23>;
rockchip,on-cmds21 {
rockchip,cmd = <0x15 0x21 0x23>;
rockchip,on-cmds22 {
rockchip,cmd = <0x15 0x22 0x0E>;
rockchip,on-cmds23 {
rockchip,cmd = <0x15 0x35 0x28>;
rockchip,on-cmds24 {
rockchip,cmd = <0x15 0x37 0x59>;
rockchip,on-cmds25 {
rockchip,cmd = <0x15 0x38 0x05>;
rockchip,on-cmds26 {
rockchip,cmd = <0x15 0x39 0x04>;
rockchip,on-cmds27 {
rockchip,cmd = <0x15 0x3A 0x08>;
rockchip,on-cmds28 {
rockchip,cmd = <0x15 0x3B 0x08>;
rockchip,on-cmds29 {
rockchip,cmd = <0x15 0x3C 0x7C>;
rockchip,on-cmds30 {
rockchip,cmd = <0x15 0x3D 0xFF>;
rockchip,on-cmds31 {
rockchip,cmd = <0x15 0x3E 0xFF>;
rockchip,on-cmds32 {
rockchip,cmd = <0x15 0x3F 0xFF>;
rockchip,on-cmds33 {
rockchip,cmd = <0x15 0x40 0x06>;
rockchip,on-cmds34 {
rockchip,cmd = <0x15 0x41 0xA0>;
rockchip,on-cmds35 {
rockchip,cmd = <0x15 0x43 0x08>;
rockchip,on-cmds36 {
rockchip,cmd = <0x15 0x44 0x0B>;
rockchip,on-cmds37 {
rockchip,cmd = <0x15 0x45 0x88>;
rockchip,on-cmds38 {
rockchip,cmd = <0x15 0x55 0x0F>;
rockchip,on-cmds39 {
rockchip,cmd = <0x15 0x56 0x01>;
rockchip,on-cmds40 {
rockchip,cmd = <0x15 0x57 0xAD>;
rockchip,on-cmds41 {
rockchip,cmd = <0x15 0x58 0x0A>;
rockchip,on-cmds42 {
rockchip,cmd = <0x15 0x59 0x0A>;
rockchip,on-cmds43 {
rockchip,cmd = <0x15 0x5A 0x28>;
rockchip,on-cmds44 {
rockchip,cmd = <0x15 0x5B 0x1E>;
rockchip,on-cmds45 {
rockchip,cmd = <0x15 0x5D 0x5C>;
rockchip,on-cmds46 {
rockchip,cmd = <0x15 0x5E 0x40>;
rockchip,on-cmds47 {
rockchip,cmd = <0x15 0x5F 0x30>;
rockchip,on-cmds48 {
rockchip,cmd = <0x15 0x60 0x24>;
rockchip,on-cmds49 {
rockchip,cmd = <0x15 0x61 0x21>;
rockchip,on-cmds50 {
rockchip,cmd = <0x15 0x62 0x13>;
rockchip,on-cmds51 {
rockchip,cmd = <0x15 0x63 0x1A>;
rockchip,on-cmds52 {
rockchip,cmd = <0x15 0x64 0x07>;
rockchip,on-cmds53 {
rockchip,cmd = <0x15 0x65 0x23>;
rockchip,on-cmds54 {
rockchip,cmd = <0x15 0x66 0x25>;
rockchip,on-cmds55 {
rockchip,cmd = <0x15 0x67 0x27>;
rockchip,on-cmds56 {
rockchip,cmd = <0x15 0x68 0x47>;
rockchip,on-cmds57 {
rockchip,cmd = <0x15 0x69 0x37>;
rockchip,on-cmds58 {
rockchip,cmd = <0x15 0x6A 0x3F>;
rockchip,on-cmds59 {
rockchip,cmd = <0x15 0x6B 0x32>;
rockchip,on-cmds60 {
rockchip,cmd = <0x15 0x6C 0x2E>;
rockchip,on-cmds61 {
rockchip,cmd = <0x15 0x6D 0x22>;
rockchip,on-cmds62 {
rockchip,cmd = <0x15 0x6E 0x11>;
rockchip,on-cmds63 {
rockchip,cmd = <0x15 0x6F 0x00>;
rockchip,on-cmds64 {
rockchip,cmd = <0x15 0x70 0x5C>;
rockchip,on-cmds65 {
rockchip,cmd = <0x15 0x71 0x40>;
rockchip,on-cmds66 {
rockchip,cmd = <0x15 0x72 0x30>;
rockchip,on-cmds67 {
rockchip,cmd = <0x15 0x73 0x24>;
rockchip,on-cmds68 {
rockchip,cmd = <0x15 0x74 0x21>;
rockchip,on-cmds69 {
rockchip,cmd = <0x15 0x75 0x13>;
rockchip,on-cmds70 {
rockchip,cmd = <0x15 0x76 0x1A>;
rockchip,on-cmds71 {
rockchip,cmd = <0x15 0x77 0x07>;
rockchip,on-cmds72 {
rockchip,cmd = <0x15 0x78 0x23>;
rockchip,on-cmds73 {
rockchip,cmd = <0x15 0x79 0x25>;
rockchip,on-cmds74 {
rockchip,cmd = <0x15 0x7A 0x27>;
rockchip,on-cmds75 {
rockchip,cmd = <0x15 0x7B 0x47>;
rockchip,on-cmds76 {
rockchip,cmd = <0x15 0x7C 0x37>;
rockchip,on-cmds77 {
rockchip,cmd = <0x15 0x7D 0x3F>;
rockchip,on-cmds78 {
rockchip,cmd = <0x15 0x7E 0x32>;
rockchip,on-cmds79 {
rockchip,cmd = <0x15 0x7F 0x2E>;
rockchip,on-cmds80 {
rockchip,cmd = <0x15 0x80 0x22>;
rockchip,on-cmds81 {
rockchip,cmd = <0x15 0x81 0x11>;
rockchip,on-cmds82 {
rockchip,cmd = <0x15 0x82 0x00>;
rockchip,on-cmds83 {
rockchip,cmd = <0x15 0xE0 0x02>;
rockchip,on-cmds84 {
rockchip,cmd = <0x15 0x00 0x44>;
rockchip,on-cmds85 {
rockchip,cmd = <0x15 0x01 0x44>;
rockchip,on-cmds86 {
rockchip,cmd = <0x15 0x02 0x45>;
rockchip,on-cmds87 {
rockchip,cmd = <0x15 0x03 0x45>;
rockchip,on-cmds88 {
rockchip,cmd = <0x15 0x04 0x46>;
rockchip,on-cmds89 {
rockchip,cmd = <0x15 0x05 0x46>;
rockchip,on-cmds90 {
rockchip,cmd = <0x15 0x06 0x47>;
rockchip,on-cmds91 {
rockchip,cmd = <0x15 0x07 0x47>;
rockchip,on-cmds92 {
rockchip,cmd = <0x15 0x08 0x1D>;
rockchip,on-cmds93 {
rockchip,cmd = <0x15 0x09 0x1D>;
rockchip,on-cmds94 {
rockchip,cmd = <0x15 0x0A 0x1D>;
rockchip,on-cmds95 {
rockchip,cmd = <0x15 0x0B 0x1D>;
rockchip,on-cmds96 {
rockchip,cmd = <0x15 0x0C 0x1D>;
rockchip,on-cmds97 {
rockchip,cmd = <0x15 0x0D 0x1D>;
rockchip,on-cmds98 {
rockchip,cmd = <0x15 0x0E 0x1D>;
rockchip,on-cmds99 {
rockchip,cmd = <0x15 0x0F 0x57>;
rockchip,on-cmds100 {
rockchip,cmd = <0x15 0x10 0x57>;
rockchip,on-cmds101 {
rockchip,cmd = <0x15 0x11 0x58>;
rockchip,on-cmds102 {
rockchip,cmd = <0x15 0x12 0x58>;
rockchip,on-cmds103 {
rockchip,cmd = <0x15 0x13 0x40>;
rockchip,on-cmds104 {
rockchip,cmd = <0x15 0x14 0x55>;
rockchip,on-cmds105 {
rockchip,cmd = <0x15 0x15 0x55>;
rockchip,on-cmds106 {
rockchip,cmd = <0x15 0x16 0x44>;
rockchip,on-cmds107 {
rockchip,cmd = <0x15 0x17 0x44>;
rockchip,on-cmds108 {
rockchip,cmd = <0x15 0x18 0x45>;
rockchip,on-cmds109 {
rockchip,cmd = <0x15 0x19 0x45>;
rockchip,on-cmds110 {
rockchip,cmd = <0x15 0x1A 0x46>;
rockchip,on-cmds111 {
rockchip,cmd = <0x15 0x1B 0x46>;
rockchip,on-cmds112 {
rockchip,cmd = <0x15 0x1C 0x47>;
rockchip,on-cmds113 {
rockchip,cmd = <0x15 0x1D 0x47>;
rockchip,on-cmds114 {
rockchip,cmd = <0x15 0x1E 0x1D>;
rockchip,on-cmds115 {
rockchip,cmd = <0x15 0x1F 0x1D>;
rockchip,on-cmds116 {
rockchip,cmd = <0x15 0x20 0x1D>;
rockchip,on-cmds117 {
rockchip,cmd = <0x15 0x21 0x1D>;
rockchip,on-cmds118 {
rockchip,cmd = <0x15 0x22 0x1D>;
rockchip,on-cmds119 {
rockchip,cmd = <0x15 0x23 0x1D>;
rockchip,on-cmds120 {
rockchip,cmd = <0x15 0x24 0x1D>;
rockchip,on-cmds121 {
rockchip,cmd = <0x15 0x25 0x57>;
rockchip,on-cmds122 {
rockchip,cmd = <0x15 0x26 0x57>;
rockchip,on-cmds123 {
rockchip,cmd = <0x15 0x27 0x58>;
rockchip,on-cmds124 {
rockchip,cmd = <0x15 0x28 0x58>;
rockchip,on-cmds125 {
rockchip,cmd = <0x15 0x29 0x40>;
rockchip,on-cmds126 {
rockchip,cmd = <0x15 0x2A 0x55>;
rockchip,on-cmds127 {
rockchip,cmd = <0x15 0x2B 0x55>;
rockchip,on-cmds128 {
rockchip,cmd = <0x15 0x58 0x40>;
rockchip,on-cmds129 {
rockchip,cmd = <0x15 0x59 0x00>;
rockchip,on-cmds130 {
rockchip,cmd = <0x15 0x5A 0x00>;
rockchip,on-cmds131 {
rockchip,cmd = <0x15 0x5B 0x00>;
rockchip,on-cmds132 {
rockchip,cmd = <0x15 0x5C 0x0A>;
rockchip,on-cmds133 {
rockchip,cmd = <0x15 0x5D 0x10>;
rockchip,on-cmds134 {
rockchip,cmd = <0x15 0x5E 0x01>;
rockchip,on-cmds135 {
rockchip,cmd = <0x15 0x5F 0x02>;
rockchip,on-cmds136 {
rockchip,cmd = <0x15 0x60 0x10>;
rockchip,on-cmds137 {
rockchip,cmd = <0x15 0x61 0x01>;
rockchip,on-cmds138 {
rockchip,cmd = <0x15 0x62 0x02>;
rockchip,on-cmds139 {
rockchip,cmd = <0x15 0x63 0x0B>;
rockchip,on-cmds140 {
rockchip,cmd = <0x15 0x64 0x54>;
rockchip,on-cmds141 {
rockchip,cmd = <0x15 0x65 0x45>;
rockchip,on-cmds142 {
rockchip,cmd = <0x15 0x66 0x07>;
rockchip,on-cmds143 {
rockchip,cmd = <0x15 0x67 0x31>;
rockchip,on-cmds144 {
rockchip,cmd = <0x15 0x68 0x0B>;
rockchip,on-cmds145 {
rockchip,cmd = <0x15 0x69 0x1E>;
rockchip,on-cmds146 {
rockchip,cmd = <0x15 0x6A 0x54>;
rockchip,on-cmds147 {
rockchip,cmd = <0x15 0x6B 0x04>;
rockchip,on-cmds148 {
rockchip,cmd = <0x15 0x6C 0x00>;
rockchip,on-cmds149 {
rockchip,cmd = <0x15 0x6D 0x04>;
rockchip,on-cmds150 {
rockchip,cmd = <0x15 0x6E 0x00>;
rockchip,on-cmds151 {
rockchip,cmd = <0x15 0x6F 0x88>;
rockchip,on-cmds152 {
rockchip,cmd = <0x15 0x70 0x00>;
rockchip,on-cmds153{
rockchip,cmd = <0x15 0x71 0x00>;
rockchip,on-cmds154 {
rockchip,cmd = <0x15 0x72 0x06>;
rockchip,on-cmds155 {
rockchip,cmd = <0x15 0x73 0x7B>;
rockchip,on-cmds156 {
rockchip,cmd = <0x15 0x74 0x00>;
rockchip,on-cmds157 {
rockchip,cmd = <0x15 0x75 0xF8>;
rockchip,on-cmds158 {
rockchip,cmd = <0x15 0x76 0x00>;
rockchip,on-cmds159 {
rockchip,cmd = <0x15 0x77 0x0D>;
rockchip,on-cmds160 {
rockchip,cmd = <0x15 0x78 0x14>;
rockchip,on-cmds161 {
rockchip,cmd = <0x15 0x79 0x00>;
rockchip,on-cmds162 {
rockchip,cmd = <0x15 0x7A 0x00>;
rockchip,on-cmds163 {
rockchip,cmd = <0x15 0x7B 0x00>;
rockchip,on-cmds164 {
rockchip,cmd = <0x15 0x7C 0x00>;
rockchip,on-cmds165 {
rockchip,cmd = <0x15 0x7D 0x03>;
rockchip,on-cmds166 {
rockchip,cmd = <0x15 0x7E 0x7B>;
rockchip,on-cmds167 {
rockchip,on-cmds168 {
rockchip,cmd = <0x15 0x09 0x10>;
rockchip,on-cmds169 {
rockchip,cmd = <0x15 0xE6 0x02>;
rockchip,on-cmds170 {
rockchip,cmd = <0x15 0xE7 0x06>;
rockchip,on-cmds171 {
rockchip,cmd = <0x05 0x11>;
rockchip,on-cmds172 {
rockchip,cmd = <0x05 0x29>;
rockchip,cmd_delay = <50>;
rockchip,on-cmds173 {
rockchip,cmd = <0x15 0x35 0x00>;
rockchip,cmd_delay = <10>;
backlight {
compatible = “pwm-backlight”;
pwms = <&pwm0 0 25000>;
rockchip,pwm_id= <1>;
/* | dark(255-221) | light scale(220-0) | , scale_div=255*/
brightness-levels = <0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255>; /Level Reverse Leo 9/22/
/<255 254 253 252 251 250 249 248 247 246 245 244 243 242 241 240 239 238 237 236 235 234 233 232 231 230 229 228 227
266 225 224 223 222 221 220 219 218 217 216 215 214 213 212 211 210 209 208 207 206 205 204 203 202 201 200 199 198 197 196 195 194 193 192 191 190 189
188 187 186 185 184 183 182 181 180 179 178 177 176 175 174 173 172 171 170 169 168 167 166 165 164 163 162 161 160 159 158 157 156 155 154 153 152 151
150 149 148 147 146 145 144 143 142 141 140 139 138 137 136 135 134 133 132 131 130 129 128 127 126 125 124 123 122 121 120 119 118 117 116 115 114 113
112 111 110 109 108 107 106 105 104 103 102 101 100 99 98 97 96 95 94 93 92 91 90 89 88 87 86 85 84 83 82 81 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66
65 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 48 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15
14 13 12 11 10 9 8 7 6 5 4 3 2 1 0>;/
default-brightness-level = <180>;
//enable-gpios = <&gpio1 GPIO_B0 GPIO_ACTIVE_HIGH>;
native-mode = <&timing0>;
compatible = “rockchip,display-timings”;
timing0: timing0 {
screen-type = <SCREEN_MIPI>;
lvds-format = <LVDS_8BIT_2>;
out-face = <OUT_P888>;
color-mode = <COLOR_RGB>;
clock-frequency = <67000000>;
hactive = <800>;
vactive = <1280>;
hsync-len = <20>;
hback-porch = <20>;
hfront-porch = <30>;
vsync-len = <4>;
vback-porch = <12>;
vfront-porch = <20>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <0>;
pixelclk-active = <0>;
swap-rb = <0>;
swap-rg = <0>;
swap-gb = <0>;
3.有
rk3128-fireprime.dts:
/dts-v1/;
#include “rk3128.dtsi”
#include “rk3128-cif-sensor.dtsi”
#include “rk312x-sdk.dtsi”
//#include “lcd-box.dtsi”
#include “lcd-test-mipi.dtsi”
#include <dt-bindings/input/input.h>
compatible = “rockchip,rk3128”;
backlight: backlight {
default-brightness-level = <128>;
enable-gpios = <&gpio0 GPIO_D3 GPIO_ACTIVE_HIGH>;
wireless-wlan {
compatible = “wlan-platdata”;
/* wifi_chip_type - wifi chip define
* bcmwifi ==> like ap6xxx, rk90, ...x;
* rtkwifi ==> like rtl8188xx, rtl8723xx, ...;
* esp8089 ==> esp8089;
* other ==> for other wifi;
wifi_chip_type = "bcmwifi";
sdio_vref = <3300>; //1800mv or 3300mv
//keep_wifi_power_on;
//power_ctrl_by_pmu;
power_pmu_regulator = "vccio";
power_pmu_enable_level = <1>; //1->HIGH, 0->LOW
//vref_ctrl_enable;
//vref_ctrl_gpio = <&gpio0 GPIO_A2 GPIO_ACTIVE_HIGH>;
//vref_pmu_regulator = "act_ldo3";
//vref_pmu_enable_level = <1>; //1->HIGH, 0->LOW
WIFI,poweren_gpio = <&gpio1 GPIO_B3 GPIO_ACTIVE_HIGH>;
WIFI,host_wake_irq = <&gpio0 GPIO_A2 GPIO_ACTIVE_HIGH>;
//WIFI,reset_gpio = <&gpio0 GPIO_A2 GPIO_ACTIVE_LOW>;
status = "okay";
wireless-bluetooth {
compatible = "bluetooth-platdata";
//wifi-bt-power-toggle;
uart_rts_gpios = <&gpio0 GPIO_C1 GPIO_ACTIVE_LOW>;
pinctrl-names = "default","rts_gpio";
pinctrl-0 = <&uart0_rts>;
pinctrl-1 = <&uart0_rts_gpio>;
//BT,power_gpio = <&gpio1 GPIO_B3 GPIO_ACTIVE_HIGH>;
BT,reset_gpio = <&gpio1 GPIO_A3 GPIO_ACTIVE_HIGH>;
BT,wake_gpio = <&gpio1 GPIO_B2 GPIO_ACTIVE_HIGH>;
BT,wake_host_irq = <&gpio1 GPIO_B1 GPIO_ACTIVE_LOW>;
status = "okay";
leds {
compatible = "gpio-leds";
power {
label = "firefly:blue:power";
linux,default-trigger = "ir-power-click";
default-state = "on";
gpios = <&gpio1 GPIO_C7 GPIO_ACTIVE_LOW>;
user {
label = "firefly:yellow:user";
linux,default-trigger = "ir-user-click";
default-state = "off";
gpios = <&gpio1 GPIO_C6 GPIO_ACTIVE_LOW>;
gpios-v01 = <&gpio2 GPIO_A3 GPIO_ACTIVE_LOW>;
rockchip-spdif-card {
compatible = "rockchip-spdif-card";
dais {
dai0 {
audio-codec = <&codec_hdmi_spdif>;
audio-controller = <&spdif>;
usb_control {
compatible = "rockchip,rk3126-usb-control";
host_drv_gpio = <&gpio3 GPIO_C4 GPIO_ACTIVE_LOW>;
otg_drv_gpio = <&gpio0 GPIO_D6 GPIO_ACTIVE_LOW>;
rockchip,remote_wakeup;
rockchip,usb_irq_wakeup;
rockchip_suspend {
rockchip,ctrbits = <
(0
|RKPM_CTR_PWR_DMNS
|RKPM_CTR_GTCLKS
|RKPM_CTR_PLLS
//|RKPM_CTR_ARMOFF_LPMD
|RKPM_CTR_DDR
|RKPM_CTR_IDLESRAM_MD
|RKPM_CTR_DDR
//|RKPM_CTR_BUS_IDLE
//|RKPM_CTR_VOLTS
//|RKPM_CTR_VOL_PWM1
//|RKPM_CTR_VOL_PWM2
rockchip,pmic-suspend_gpios = <GPIO3_C1>;
test-power {
status = “okay”;
&i2c0 {
status = “okay”;
rtc@51 {
compatible = “rtc,hym8563”;
reg = <0x51>;
irq_gpio = <&gpio0 GPIO_D4 IRQ_TYPE_EDGE_FALLING>;
ts@41 {
compatible = “tchip,gsl3680”;
reg = <0x41>;
touch-gpio = <&gpio1 GPIO_B4 IRQ_TYPE_EDGE_RISING>;
//reset-gpio = <&gpio8 GPIO_A6 GPIO_ACTIVE_LOW>;
max-x = <1280>;
max-y = <800>;
&fb {
rockchip,disp-mode = <NO_DUAL>;
rockchip,disp-policy = <DISPLAY_POLICY_BOX>;
rockchip,uboot-logo-on = <1>;
&disp_timings {
&tve {
status = “disabled”;
test_mode = <0>;
&rk_screen {
display-timings = <&disp_timings>;
&dsihost0 {
status = “okay”;
&lcdc {
status = “okay”;
rockchip,fb-win-map = <FB0_WIN0_FB1_WIN1_FB2_WIN2>;
&hdmi {
status = “okay”;
rockchip,hdmi_audio_source = <1>;
&uart0 {
status = “okay”;
clock-frequency = “<24000000>”;
dma-names = “!tx”, “!rx”;
pinctrl-0 = <&uart0_xfer &uart0_cts>;
&sdmmc {
status = “okay”;
cd-gpios = <&gpio1 GPIO_C1 GPIO_ACTIVE_HIGH>;/CD GPIO/
&key {
power-key {
gpios = <&gpio3 GPIO_C7 GPIO_ACTIVE_LOW>;
linux,code = <116>;
label = “power”;
gpio-key,wakeup;
recovery-key {
linux,code = <113>;
label = “recovery”;
rockchip,adc_value = <4>;
&dwc_control_usb {
usb_uart {
&codec {
spk_ctl_io = <&gpio3 GPIO_C5 GPIO_ACTIVE_HIGH>;
aux_det_io = <&gpio0 GPIO_D3 GPIO_ACTIVE_HIGH>;
spk-mute-delay = <200>;
hp-mute-delay = <100>;
rk312x_for_mid = <0>;
is_rk3128 = <0>;
spk_volume = <24>;
hp_volume = <24>;
capture_volume = <26>;
gpio_debug = <1>;
codec_hp_det = <0>;
&rk3128_cif_sensor{
status = “okay”;
&i2c2 {
&gmac_clkin {
clock-frequency = <125000000>;
&gmac {
//pmu_regulator = “act_ldo5”;
//pmu_enable_level = <1>; //1->HIGH, 0->LOW
//power-gpio = <&gpio0 GPIO_A6 GPIO_ACTIVE_HIGH>;
reset-gpio = <&gpio2 GPIO_D0 GPIO_ACTIVE_LOW>;
phyirq-gpio = <&gpio0 GPIO_D0 GPIO_ACTIVE_LOW>;
phy-mode = “rgmii”;
clock_in_out = “input”;
tx_delay = <0x30>;
rx_delay = <0x10>;
&pwm1 {
status = “okay”;
&clk_core_dvfs_table {
operating-points = <
/* KHz uV /
216000 925000
408000 925000
600000 950000
696000 975000
816000 1050000
1008000 1175000
1200000 1300000
1296000 1350000
1320000 1375000
virt-temp-limit-1-cpu-busy = <
/ target-temp limit-freq /
75 1008000
85 1200000
95 1200000
100 1200000
virt-temp-limit-2-cpu-busy = <
75 912000
85 1008000
95 1104000
100 1200000
virt-temp-limit-3-cpu-busy = <
75 816000
85 912000
95 100800
100 110400
virt-temp-limit-4-cpu-busy = <
/ target-temp limit-freq */
75 816000
85 912000
95 100800
100 110400
temp-limit-enable = <1>;
target-temp = <85>;
status=“okay”;
&clk_gpu_dvfs_table {
/* KHz uV */
200000 950000
300000 975000
400000 1075000
//480000 1175000
status=“okay”;
&clk_ddr_dvfs_table {
/* KHz uV */
200000 1250000
300000 1250000
400000 1250000
operating-points-v01 = <
/* KHz uV */
200000 950000
300000 950000
400000 1200000
533000 1250000
freq-table = <
/*status freq(KHz)*/
SYS_STATUS_NORMAL 500000
SYS_STATUS_SUSPEND 200000
SYS_STATUS_VIDEO_1080P 240000
SYS_STATUS_VIDEO_4K 400000
SYS_STATUS_PERFORMANCE 528000
SYS_STATUS_DUALVIEW 400000
SYS_STATUS_BOOST 324000
SYS_STATUS_ISP 533000
auto-freq-table = <
240000
324000
396000
528000
auto-freq=<0>;
status="okay";
&remotectl {
handle_cpu_id = <2>;
ir_key1{
rockchip,usercode = <0xff00>;
rockchip,key_table =
<0xeb KEY_POWER>,
<0xa3 250>,
<0xec KEY_MENU>,
<0xfc KEY_UP>,
<0xfd KEY_DOWN>,
<0xf1 KEY_LEFT>,
<0xe5 KEY_RIGHT>,
<0xf8 KEY_REPLY>,
<0xb7 KEY_HOME>,
<0xfe KEY_BACK>,
<0xa7 KEY_VOLUMEDOWN>,
<0xf4 KEY_VOLUMEUP>;
fireprime_defconfig:
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_KERNEL_LZO=y
CONFIG_SYSVIPC=y
CONFIG_AUDIT=y
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
CONFIG_RCU_FAST_NO_HZ=y
CONFIG_LOG_BUF_SHIFT=19
CONFIG_CGROUPS=y
CONFIG_CGROUP_DEBUG=y
CONFIG_CGROUP_FREEZER=y
CONFIG_CGROUP_CPUACCT=y
CONFIG_RESOURCE_COUNTERS=y
CONFIG_MEMCG=y
CONFIG_MEMCG_SWAP=y
CONFIG_CGROUP_SCHED=y
CONFIG_RT_GROUP_SCHED=y
CONFIG_NAMESPACES=y
# CONFIG_UTS_NS is not set
# CONFIG_IPC_NS is not set
# CONFIG_PID_NS is not set
CONFIG_RELAY=y
CONFIG_BLK_DEV_INITRD=y
CONFIG_RD_BZIP2=y
CONFIG_RD_LZMA=y
CONFIG_CC_OPTIMIZE_FOR_SIZE=y
CONFIG_PANIC_TIMEOUT=5
# CONFIG_UID16 is not set
CONFIG_KALLSYMS_ALL=y
CONFIG_EMBEDDED=y
CONFIG_PERF_EVENTS=y
# CONFIG_VM_EVENT_COUNTERS is not set
# CONFIG_SLUB_DEBUG is not set
CONFIG_JUMP_LABEL=y
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
CONFIG_PARTITION_ADVANCED=y
CONFIG_ARCH_ROCKCHIP=y
CONFIG_BLOCK_RKNAND=y
CONFIG_ARM_ERRATA_720789=y
CONFIG_PL310_ERRATA_753970=y
CONFIG_ARM_ERRATA_754322=y
CONFIG_SMP=y
CONFIG_SCHED_MC=y
CONFIG_PREEMPT=y
CONFIG_AEABI=y
# CONFIG_OABI_COMPAT is not set
CONFIG_HIGHMEM=y
CONFIG_KSM=y
CONFIG_DEFAULT_MMAP_MIN_ADDR=32768
# CONFIG_CROSS_MEMORY_ATTACH is not set
CONFIG_CMA=y
CONFIG_SECCOMP=y
CONFIG_ZBOOT_ROM_TEXT=0x0
CONFIG_ZBOOT_ROM_BSS=0x0
CONFIG_ARM_APPENDED_DTB=y
CONFIG_ARM_ATAG_DTB_COMPAT=y
CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND=y
CONFIG_CPU_FREQ_DEFAULT_GOV_INTERACTIVE=y
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
CONFIG_CPU_IDLE=y
CONFIG_VFP=y
CONFIG_NEON=y
# CONFIG_COREDUMP is not set
CONFIG_PM_AUTOSLEEP=y
CONFIG_PM_WAKELOCKS=y
CONFIG_PM_WAKELOCKS_LIMIT=0
# CONFIG_PM_WAKELOCKS_GC is not set
CONFIG_PM_RUNTIME=y
CONFIG_PM_DEBUG=y
CONFIG_WQ_POWER_EFFICIENT_DEFAULT=y
CONFIG_SUSPEND_TIME=y
CONFIG_NET=y
CONFIG_PACKET=y
CONFIG_UNIX=y
CONFIG_XFRM_USER=y
CONFIG_NET_KEY=y
CONFIG_INET=y
CONFIG_IP_ADVANCED_ROUTER=y
CONFIG_IP_MULTIPLE_TABLES=y
CONFIG_IP_ROUTE_VERBOSE=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_INET_AH=y
CONFIG_INET_ESP=y
CONFIG_INET_IPCOMP=y
# CONFIG_INET_LRO is not set
CONFIG_IPV6=y
CONFIG_IPV6_PRIVACY=y
CONFIG_IPV6_ROUTER_PREF=y
CONFIG_IPV6_ROUTE_INFO=y
CONFIG_IPV6_OPTIMISTIC_DAD=y
CONFIG_INET6_AH=y
CONFIG_INET6_ESP=y
CONFIG_INET6_IPCOMP=y
CONFIG_IPV6_MIP6=y
CONFIG_IPV6_MULTIPLE_TABLES=y
CONFIG_IPV6_SUBTREES=y
CONFIG_NETFILTER=y
CONFIG_NF_CONNTRACK=y
CONFIG_NF_CONNTRACK_SECMARK=y
CONFIG_NF_CONNTRACK_EVENTS=y
CONFIG_NF_CT_PROTO_DCCP=y
CONFIG_NF_CT_PROTO_SCTP=y
CONFIG_NF_CT_PROTO_UDPLITE=y
CONFIG_NF_CONNTRACK_AMANDA=y
CONFIG_NF_CONNTRACK_FTP=y
CONFIG_NF_CONNTRACK_H323=y
CONFIG_NF_CONNTRACK_IRC=y
CONFIG_NF_CONNTRACK_NETBIOS_NS=y
CONFIG_NF_CONNTRACK_PPTP=y
CONFIG_NF_CONNTRACK_SANE=y
CONFIG_NF_CONNTRACK_TFTP=y
CONFIG_NF_CT_NETLINK=y
CONFIG_NETFILTER_TPROXY=y
CONFIG_NETFILTER_XT_TARGET_CLASSIFY=y
CONFIG_NETFILTER_XT_TARGET_CONNMARK=y
CONFIG_NETFILTER_XT_TARGET_CONNSECMARK=y
CONFIG_NETFILTER_XT_TARGET_IDLETIMER=y
CONFIG_NETFILTER_XT_TARGET_LOG=y
CONFIG_NETFILTER_XT_TARGET_MARK=y
CONFIG_NETFILTER_XT_TARGET_NFLOG=y
CONFIG_NETFILTER_XT_TARGET_NFQUEUE=y
CONFIG_NETFILTER_XT_TARGET_TPROXY=y
CONFIG_NETFILTER_XT_TARGET_TRACE=y
CONFIG_NETFILTER_XT_TARGET_SECMARK=y
CONFIG_NETFILTER_XT_TARGET_TCPMSS=y
CONFIG_NETFILTER_XT_MATCH_COMMENT=y
CONFIG_NETFILTER_XT_MATCH_CONNLIMIT=y
CONFIG_NETFILTER_XT_MATCH_CONNMARK=y
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=y
CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=y
CONFIG_NETFILTER_XT_MATCH_HELPER=y
CONFIG_NETFILTER_XT_MATCH_IPRANGE=y
CONFIG_NETFILTER_XT_MATCH_LENGTH=y
CONFIG_NETFILTER_XT_MATCH_LIMIT=y
CONFIG_NETFILTER_XT_MATCH_MAC=y
CONFIG_NETFILTER_XT_MATCH_MARK=y
CONFIG_NETFILTER_XT_MATCH_MULTIPORT=y
CONFIG_NETFILTER_XT_MATCH_POLICY=y
CONFIG_NETFILTER_XT_MATCH_PKTTYPE=y
CONFIG_NETFILTER_XT_MATCH_QTAGUID=y
CONFIG_NETFILTER_XT_MATCH_QUOTA=y
CONFIG_NETFILTER_XT_MATCH_QUOTA2=y
CONFIG_NETFILTER_XT_MATCH_QUOTA2_LOG=y
CONFIG_NETFILTER_XT_MATCH_SOCKET=y
CONFIG_NETFILTER_XT_MATCH_STATE=y
CONFIG_NETFILTER_XT_MATCH_STATISTIC=y
CONFIG_NETFILTER_XT_MATCH_STRING=y
CONFIG_NETFILTER_XT_MATCH_TIME=y
CONFIG_NETFILTER_XT_MATCH_U32=y
CONFIG_NF_CONNTRACK_IPV4=y
CONFIG_IP_NF_IPTABLES=y
CONFIG_IP_NF_MATCH_AH=y
CONFIG_IP_NF_MATCH_ECN=y
CONFIG_IP_NF_MATCH_TTL=y
CONFIG_IP_NF_FILTER=y
CONFIG_IP_NF_TARGET_REJECT=y
CONFIG_IP_NF_TARGET_REJECT_SKERR=y
CONFIG_NF_NAT_IPV4=y
CONFIG_IP_NF_TARGET_MASQUERADE=y
CONFIG_IP_NF_TARGET_NETMAP=y
CONFIG_IP_NF_TARGET_REDIRECT=y
CONFIG_IP_NF_MANGLE=y
CONFIG_IP_NF_RAW=y
CONFIG_IP_NF_SECURITY=y
CONFIG_IP_NF_ARPTABLES=y
CONFIG_IP_NF_ARPFILTER=y
CONFIG_IP_NF_ARP_MANGLE=y
CONFIG_NF_CONNTRACK_IPV6=y
CONFIG_IP6_NF_IPTABLES=y
CONFIG_IP6_NF_FILTER=y
CONFIG_IP6_NF_TARGET_REJECT=y
CONFIG_IP6_NF_TARGET_REJECT_SKERR=y
CONFIG_IP6_NF_MANGLE=y
CONFIG_IP6_NF_RAW=y
CONFIG_BRIDGE_NF_EBTABLES=y
CONFIG_BRIDGE_EBT_BROUTE=y
CONFIG_L2TP=y
CONFIG_BRIDGE=y
CONFIG_NET_SCHED=y
CONFIG_NET_SCH_HTB=y
CONFIG_NET_SCH_PRIO=y
CONFIG_NET_CLS_FW=y
CONFIG_NET_CLS_U32=y
CONFIG_CLS_U32_MARK=y
CONFIG_NET_CLS_FLOW=y
CONFIG_NET_EMATCH=y
CONFIG_NET_EMATCH_CMP=y
CONFIG_NET_EMATCH_NBYTE=y
CONFIG_NET_EMATCH_U32=y
CONFIG_NET_EMATCH_META=y
CONFIG_NET_EMATCH_TEXT=y
CONFIG_NET_CLS_ACT=y
CONFIG_BT=y
CONFIG_BT_RFCOMM=y
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=y
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_HIDP=y
CONFIG_BT_RTKBTUSB=y
CONFIG_BT_HCIUART=y
CONFIG_BT_HCIUART_H4=y
CONFIG_BT_HCIUART_LL=y
CONFIG_CFG80211_WEXT=y
CONFIG_RFKILL=y
CONFIG_RFKILL_RK=y
CONFIG_DEVTMPFS=y
CONFIG_DMA_CMA=y
CONFIG_BLK_DEV_LOOP=y
CONFIG_UID_STAT=y
CONFIG_SRAM=y
CONFIG_MPU_SENSORS_TIMERIRQ=y
CONFIG_INV_SENSORS=y
CONFIG_MPU_SENSORS_MPU6050B1=y
CONFIG_MPU_SENSORS_MPU6050_ACCEL=y
CONFIG_MPU_SENSORS_AK8963=y
CONFIG_SCSI=y
CONFIG_SCSI_TGT=y
CONFIG_BLK_DEV_SD=y
CONFIG_CHR_DEV_SG=y
CONFIG_CHR_DEV_SCH=y
CONFIG_SCSI_MULTI_LUN=y
CONFIG_SCSI_CONSTANTS=y
CONFIG_SCSI_LOGGING=y
CONFIG_SCSI_SCAN_ASYNC=y
CONFIG_MD=y
CONFIG_BLK_DEV_DM=y
CONFIG_DM_CRYPT=y
CONFIG_DM_UEVENT=y
CONFIG_DM_VERITY=y
CONFIG_NETDEVICES=y
CONFIG_TUN=y
# CONFIG_NET_CADENCE is not set
# CONFIG_NET_VENDOR_BROADCOM is not set
# CONFIG_NET_VENDOR_CIRRUS is not set
# CONFIG_NET_VENDOR_FARADAY is not set
# CONFIG_NET_VENDOR_INTEL is not set
# CONFIG_NET_VENDOR_MARVELL is not set
# CONFIG_NET_VENDOR_MICREL is not set
# CONFIG_NET_VENDOR_MICROCHIP is not set
# CONFIG_NET_VENDOR_NATSEMI is not set
# CONFIG_NET_VENDOR_SEEQ is not set
# CONFIG_NET_VENDOR_SMSC is not set
# CONFIG_NET_VENDOR_STMICRO is not set
# CONFIG_NET_VENDOR_WIZNET is not set
CONFIG_RK_VMAC_ETH=y
CONFIG_RK_GMAC_ETH=y
CONFIG_PPP=y
CONFIG_PPP_BSDCOMP=y
CONFIG_PPP_DEFLATE=y
CONFIG_PPP_FILTER=y
CONFIG_PPP_MPPE=y
CONFIG_PPP_MULTILINK=y
CONFIG_PPPOE=y
CONFIG_PPPOL2TP=y
CONFIG_PPPOLAC=y
CONFIG_PPPOPNS=y
CONFIG_PPP_ASYNC=y
CONFIG_PPP_SYNC_TTY=y
CONFIG_SLIP=y
CONFIG_SLIP_COMPRESSED=y
CONFIG_SLIP_MODE_SLIP6=y
CONFIG_USB_CATC=y
CONFIG_USB_KAWETH=y
CONFIG_USB_PEGASUS=y
CONFIG_USB_RTL8150=y
CONFIG_USB_RTL8152=y
CONFIG_USB_USBNET=y
CONFIG_USB_NET_CDC_EEM=y
CONFIG_USB_NET_CDC_MBIM=y
CONFIG_USB_NET_DM9601=y
CONFIG_USB_NET_DM9620=y
CONFIG_USB_NET_SMSC75XX=y
CONFIG_USB_NET_SMSC95XX=y
CONFIG_USB_NET_GL620A=y
CONFIG_USB_NET_PLUSB=y
CONFIG_USB_NET_MCS7830=y
CONFIG_USB_NET_RNDIS_HOST=y
CONFIG_USB_ALI_M5632=y
CONFIG_USB_AN2720=y
CONFIG_USB_EPSON2888=y
CONFIG_USB_KC2190=y
CONFIG_USB_NET_CX82310_ETH=y
CONFIG_USB_NET_KALMIA=y
CONFIG_USB_NET_QMI_WWAN=y
CONFIG_USB_HSO=y
CONFIG_USB_NET_INT51X1=y
CONFIG_USB_IPHETH=y
CONFIG_USB_SIERRA_NET=y
CONFIG_RTL8188EU=y
CONFIG_ESP8089=y
CONFIG_RKWIFI=y
CONFIG_AP6212=y
# CONFIG_INPUT_MOUSEDEV is not set
CONFIG_INPUT_EVDEV=y
CONFIG_INPUT_KEYRESET=y
# CONFIG_KEYBOARD_ATKBD is not set
# CONFIG_INPUT_MOUSE is not set
CONFIG_INPUT_JOYSTICK=y
CONFIG_JOYSTICK_XPAD=y
CONFIG_JOYSTICK_XPAD_FF=y
CONFIG_JOYSTICK_XPAD_LEDS=y
CONFIG_INPUT_TABLET=y
CONFIG_TABLET_USB_ACECAD=y
CONFIG_TABLET_USB_AIPTEK=y
CONFIG_TABLET_USB_GTCO=y
CONFIG_TABLET_USB_HANWANG=y
CONFIG_TABLET_USB_KBTAB=y
CONFIG_TABLET_USB_WACOM=y
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_ZET62XX=y
CONFIG_TOUCHSCREEN_GT8XX=y
CONFIG_TOUCHSCREEN_VTL_CT36X=y
CONFIG_INPUT_MISC=y
CONFIG_INPUT_KEYCHORD=y
CONFIG_INPUT_RICOH619_PWRKEY=y
CONFIG_INPUT_UINPUT=y
CONFIG_INPUT_GPIO=y
# CONFIG_GS_LIS3DH is not set
# CONFIG_GS_MMA7660 is not set
CONFIG_GS_MC3230=y
# CONFIG_GS_LSM303D is not set
# CONFIG_COMPASS_DEVICE is not set
# CONFIG_GYROSCOPE_DEVICE is not set
# CONFIG_HALL_DEVICE is not set
CONFIG_ROCKCHIP_REMOTECTL=y
CONFIG_ROCKCHIP_REMOTECTL_PWM=y
# CONFIG_SERIO is not set
# CONFIG_VT is not set
# CONFIG_LEGACY_PTYS is not set
CONFIG_SERIAL_ROCKCHIP=y
# CONFIG_HW_RANDOM is not set
CONFIG_I2C=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_ROCKCHIP=y
CONFIG_I2C_ROCKCHIP_COMPAT=y
CONFIG_SPI=y
CONFIG_SPI_ROCKCHIP_CORE=y
CONFIG_SPI_ROCKCHIP=y
CONFIG_SPI_ROCKCHIP_DMA=y
CONFIG_SPI_ROCKCHIP_TEST=y
CONFIG_DEBUG_GPIO=y
CONFIG_GPIO_SYSFS=y
CONFIG_CHARGER_RT5025=y
CONFIG_BATTERY_RT5025=y
CONFIG_CHARGER_RT5036=y
CONFIG_RT_POWER=y
CONFIG_BATTERY_RICOH619=y
CONFIG_TEST_POWER=y
CONFIG_BATTERY_BQ24296=y
CONFIG_BATTERY_BQ27320=y
CONFIG_BATTERY_RK30_ADC_FAC=y
CONFIG_CW2015_BATTERY=y
CONFIG_BATTERY_RK818=y
CONFIG_POWER_RESET=y
CONFIG_POWER_RESET_GPIO=y
CONFIG_SENSORS_ROCKCHIP_TSADC=y
CONFIG_THERMAL=y
CONFIG_MFD_RT5025=y
CONFIG_MISC_RT5025=y
CONFIG_IRQ_RT5025=y
CONFIG_DEBUG_RT5025=y
CONFIG_MFD_RT5036=y
CONFIG_MISC_RT5036=y
CONFIG_IRQ_RT5036=y
CONFIG_MFD_RK808=y
CONFIG_MFD_RK818=y
CONFIG_MFD_RICOH619=y
CONFIG_REGULATOR=y
CONFIG_REGULATOR_FIXED_VOLTAGE=y
CONFIG_REGULATOR_ACT8846=y
CONFIG_ACT8846_SUPPORT_RESET=y
CONFIG_REGULATOR_ACT8931=y
CONFIG_REGULATOR_RT5025=y
CONFIG_REGULATOR_RT5036=y
CONFIG_ROCKCHIP_PWM_REGULATOR=y
CONFIG_REGULATOR_SYR82X=y
CONFIG_REGULATOR_RICOH619=y
CONFIG_MEDIA_SUPPORT=y
CONFIG_MEDIA_CAMERA_SUPPORT=y
CONFIG_MEDIA_RC_SUPPORT=y
CONFIG_MEDIA_CONTROLLER=y
CONFIG_VIDEO_V4L2_SUBDEV_API=y
CONFIG_MEDIA_USB_SUPPORT=y
CONFIG_USB_VIDEO_CLASS=y
CONFIG_V4L_PLATFORM_DRIVERS=y
CONFIG_CAMSYS_DRV=y
CONFIG_FLASHLIGHT=y
CONFIG_LEDS_RT8547=y
CONFIG_RK30_CAMERA_ONEFRAME=y
CONFIG_MALI_MIDGARD=m
CONFIG_MALI_MIDGARD_DVFS=y
CONFIG_MALI_MIDGARD_RT_PM=y
CONFIG_MALI_MIDGARD_DEBUG_SYS=y
CONFIG_MALI_EXPERT=y
CONFIG_MALI_DEBUG_SHADER_SPLIT_FS=y
CONFIG_MALI_PLATFORM_THIRDPARTY_NAME=“rk”
CONFIG_MALI400=m
# CONFIG_MALI400_PROFILING is not set
CONFIG_MALI_SHARED_INTERRUPTS=y
CONFIG_FB=y
CONFIG_BACKLIGHT_LCD_SUPPORT=y
# CONFIG_LCD_CLASS_DEVICE is not set
CONFIG_BACKLIGHT_CLASS_DEVICE=y
# CONFIG_BACKLIGHT_GENERIC is not set
CONFIG_BACKLIGHT_PWM=y
CONFIG_FB_ROCKCHIP=y
CONFIG_LCDC_RK3188=y
CONFIG_LCDC_RK3288=y
CONFIG_LCDC_RK3036=y
CONFIG_LCDC_RK312X=y
CONFIG_RK_TRSM=y
#CONFIG_RK32_LVDS=y
#CONFIG_RK31XX_LVDS=y
CONFIG_DP_ANX6345=y
CONFIG_RK32_DP=y
CONFIG_RK_HDMI=y
CONFIG_RK_TVENCODER=y
CONFIG_RK3036_TV_ENCODER=y
CONFIG_ROCKCHIP_RGA=y
CONFIG_ROCKCHIP_RGA2=y
CONFIG_SOUND=y
CONFIG_SND=y
# CONFIG_SND_SUPPORT_OLD_API is not set
CONFIG_SND_VERBOSE_PRINTK=y
# CONFIG_SND_DRIVERS is not set
# CONFIG_SND_ARM is not set
# CONFIG_SND_SPI is not set
CONFIG_SND_USB_AUDIO=y
CONFIG_SND_SOC=y
CONFIG_SND_RK_SOC=y
CONFIG_SND_RK_SOC_HDMI_I2S=y
CONFIG_SND_RK_SOC_SPDIF_CARD=y
CONFIG_SND_RK_SOC_RT5631=y
CONFIG_SND_RK_SOC_RT3224=y
CONFIG_SND_RK_SOC_RK3036=y
CONFIG_SND_RK_SOC_RK312X=y
CONFIG_HIDRAW=y
CONFIG_UHID=y
CONFIG_HID_A4TECH=y
CONFIG_HID_ACRUX=y
CONFIG_HID_ACRUX_FF=y
CONFIG_HID_APPLE=y
CONFIG_HID_APPLEIR=y
CONFIG_HID_AUREAL=y
CONFIG_HID_BELKIN=y
CONFIG_HID_CHERRY=y
CONFIG_HID_CHICONY=y
CONFIG_HID_PRODIKEYS=y
CONFIG_HID_CYPRESS=y
CONFIG_HID_DRAGONRISE=y
CONFIG_DRAGONRISE_FF=y
CONFIG_HID_EMS_FF=y
CONFIG_HID_ELECOM=y
CONFIG_HID_EZKEY=y
CONFIG_HID_HOLTEK=y
CONFIG_HID_KEYTOUCH=y
CONFIG_HID_KYE=y
CONFIG_HID_UCLOGIC=y
CONFIG_HID_WALTOP=y
CONFIG_HID_GYRATION=y
CONFIG_HID_ICADE=y
CONFIG_HID_TWINHAN=y
CONFIG_HID_KENSINGTON=y
CONFIG_HID_LCPOWER=y
CONFIG_HID_LENOVO_TPKBD=y
CONFIG_HID_LOGITECH=y
CONFIG_HID_LOGITECH_DJ=y
CONFIG_LOGITECH_FF=y
CONFIG_LOGIRUMBLEPAD2_FF=y
CONFIG_LOGIG940_FF=y
CONFIG_HID_MAGICMOUSE=y
CONFIG_HID_MICROSOFT=y
CONFIG_HID_MONTEREY=y
CONFIG_HID_MULTITOUCH=y
CONFIG_HID_NTRIG=y
CONFIG_HID_ORTEK=y
CONFIG_HID_PANTHERLORD=y
CONFIG_PANTHERLORD_FF=y
CONFIG_HID_PETALYNX=y
CONFIG_HID_PICOLCD=y
CONFIG_HID_PRIMAX=y
CONFIG_HID_PS3REMOTE=y
CONFIG_HID_ROCCAT=y
CONFIG_HID_SAITEK=y
CONFIG_HID_SAMSUNG=y
CONFIG_HID_SONY=y
CONFIG_HID_SPEEDLINK=y
CONFIG_HID_STEELSERIES=y
CONFIG_HID_SUNPLUS=y
CONFIG_HID_GREENASIA=y
CONFIG_GREENASIA_FF=y
CONFIG_HID_SMARTJOYPLUS=y
CONFIG_SMARTJOYPLUS_FF=y
CONFIG_HID_TIVO=y
CONFIG_HID_TOPSEED=y
CONFIG_HID_THINGM=y
CONFIG_HID_THRUSTMASTER=y
CONFIG_HID_WACOM=y
CONFIG_HID_WIIMOTE=y
CONFIG_HID_ZEROPLUS=y
CONFIG_HID_ZYDACRON=y
CONFIG_USB_HIDDEV=y
CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
CONFIG_USB_EHCI_HCD=y
CONFIG_USB_EHCI_RK=y
CONFIG_USB_OHCI_HCD=y
CONFIG_USB_OHCI_HCD_RK=y
CONFIG_USB_ACM=y
CONFIG_USB_PRINTER=y
CONFIG_USB_STORAGE=y
CONFIG_USB_STORAGE_DATAFAB=y
CONFIG_USB_STORAGE_FREECOM=y
CONFIG_USB_STORAGE_ISD200=y
CONFIG_USB_STORAGE_USBAT=y
CONFIG_USB_STORAGE_SDDR09=y
CONFIG_USB_STORAGE_SDDR55=y
CONFIG_USB_STORAGE_JUMPSHOT=y
CONFIG_USB_STORAGE_ALAUDA=y
CONFIG_USB_STORAGE_ONETOUCH=y
CONFIG_USB_STORAGE_KARMA=y
CONFIG_USB_STORAGE_CYPRESS_ATACB=y
CONFIG_USB_STORAGE_ENE_UB6250=y
CONFIG_USB_SERIAL=y
CONFIG_USB_SERIAL_GENERIC=y
CONFIG_USB_SERIAL_OPTION=y
CONFIG_USB_TRANCEVIBRATOR=y
CONFIG_USB_OTG_WAKELOCK=y
CONFIG_USB_GADGET=y
CONFIG_USB_GADGET_DEBUG_FILES=y
CONFIG_USB_GADGET_VBUS_DRAW=500
CONFIG_USB_G_ANDROID=y
CONFIG_USB20_HOST=y
CONFIG_USB20_OTG=y
CONFIG_MMC=y
CONFIG_MMC_PARANOID_SD_INIT=y
CONFIG_MMC_BLOCK_MINORS=32
# CONFIG_MMC_BLOCK_BOUNCE is not set
CONFIG_MMC_DW=y
CONFIG_MMC_DW_IDMAC=y
CONFIG_MMC_DW_ROCKCHIP=y
CONFIG_LEDS_GPIO=y
CONFIG_LEDS_TRIGGERS=y
CONFIG_LEDS_TRIGGER_BACKLIGHT=y
CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
CONFIG_SWITCH=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_HYM8563=y
CONFIG_RTC_RT5036=y
CONFIG_RTC_DRV_RC5T619=y
CONFIG_STAGING=y
CONFIG_ZSMALLOC=y
CONFIG_ZRAM=y
CONFIG_ANDROID=y
CONFIG_ANDROID_BINDER_IPC=y
CONFIG_ASHMEM=y
CONFIG_ANDROID_LOGGER=y
CONFIG_ANDROID_TIMED_GPIO=y
CONFIG_ANDROID_LOW_MEMORY_KILLER=y
CONFIG_ANDROID_INTF_ALARM_DEV=y
CONFIG_SYNC=y
CONFIG_SW_SYNC=y
CONFIG_SW_SYNC_USER=y
CONFIG_ION=y
CONFIG_ION_ROCKCHIP=y
CONFIG_ION_CMA_HIGHMEM=y
CONFIG_ION_ROCKCHIP_SNAPSHOT=y
CONFIG_ION_SNAPSHOT_BUF_SHIFT=15
CONFIG_FIQ_DEBUGGER=y
CONFIG_FIQ_DEBUGGER_NO_SLEEP=y
CONFIG_FIQ_DEBUGGER_CONSOLE=y
CONFIG_FIQ_DEBUGGER_CONSOLE_DEFAULT_ENABLE=y
CONFIG_COMMON_CLK_DEBUG=y
CONFIG_ROCKCHIP_IOMMU=y
CONFIG_ROCKCHIP_IOVMM=y
CONFIG_IIO=y
CONFIG_ROCKCHIP_ADC=y
CONFIG_PWM=y
CONFIG_PWM_ROCKCHIP=y
CONFIG_RESET_CONTROLLER=y
CONFIG_RK_HEADSET=y
CONFIG_EXT2_FS=y
CONFIG_EXT2_FS_XATTR=y
CONFIG_EXT3_FS=y
# CONFIG_EXT3_DEFAULTS_TO_ORDERED is not set
CONFIG_EXT4_FS=y
CONFIG_EXT4_FS_SECURITY=y
CONFIG_FUSE_FS=y
CONFIG_ISO9660_FS=y
CONFIG_JOLIET=y
CONFIG_ZISOFS=y
CONFIG_UDF_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_TMPFS=y
CONFIG_TMPFS_POSIX_ACL=y
# CONFIG_MISC_FILESYSTEMS is not set
CONFIG_CIFS=y
CONFIG_CIFS_XATTR=y
CONFIG_CIFS_POSIX=y
# CONFIG_CIFS_DEBUG is not set
CONFIG_NLS_CODEPAGE_437=y
CONFIG_NLS_ASCII=y
CONFIG_NLS_ISO8859_1=y
CONFIG_NLS_UTF8=y
CONFIG_PRINTK_TIME=y
CONFIG_MAGIC_SYSRQ=y
CONFIG_DEBUG_SECTION_MISMATCH=y
CONFIG_LOCKUP_DETECTOR=y
CONFIG_SCHEDSTATS=y
CONFIG_TIMER_STATS=y
# CONFIG_DEBUG_PREEMPT is not set
CONFIG_SCHED_TRACER=y
CONFIG_KEYS=y
CONFIG_SECURITY=y
CONFIG_SECURITY_NETWORK=y
CONFIG_LSM_MMAP_MIN_ADDR=4096
CONFIG_SECURITY_SELINUX=y
CONFIG_CRYPTO_NULL=y
CONFIG_CRYPTO_TWOFISH=y
# CONFIG_CRYPTO_ANSI_CPRNG is not set
CONFIG_LCD_MIPI=y
CONFIG_MIPI_DSI=y
CONFIG_RK32_MIPI_DSI=y
Leo.Chang 发表于 2017-4-7 17:54
有人点过FirePrime的MIPI屏吗?
你要回复一下我,,不然我看不到哈。。。
查一下这里,,,贴出来的 dts 没看到完整的
<3>[ 1.709281] rk312x-lcdc lcdc0: can’t find power_ctr node for lcdc0
<3>[ 1.711629] rk312x-lcdc lcdc0: set lcdc0 dclk failed
loading 发表于 2017-4-11 21:08
你要回复一下我,,不然我看不到哈。。。
&lcdc {
status = “okay”;
是这个部分?
我发现把HDMI关掉,就没任何波形了…
&hdmi {
//status = “okay”;
Leo.Chang 发表于 2017-4-12 10:06
我发现把HDMI关掉,就没任何波形了…
&hdmi {
//status = “okay”;
修正,我不小心把dts关掉了
把HDMI关闭dts重新开启后,时序图看起来比较正常了
Leo.Chang 发表于 2017-4-12 10:00
&lcdc {
status = “okay”;
rockchip,fb-win-map = ;
- 你改了哪里? pinctrl-names = “lcdc”; pinctrl-0 = ; 这两个是不是干掉了?
- 根据报错的log 跟一 …
从FirePrime直接下载的源码就是这样的,我没改这里:
&lcdc {
status = “okay”;
1,强烈支持楼主ing……
dianziit 发表于 2017-4-12 15:22
1,强烈支持楼主ing……
谢谢你喔
有人用FirePrimeS点过MIPI屏吗?
有代码可以参考一下
Leo.Chang 发表于 2017-4-12 13:33
从FirePrime直接下载的源码就是这样的,我没改这里:&lcdc {
这个跟你本地代码是一样的吗?
loading 发表于 2017-4-13 12:53
这个跟你本地代码是一样的吗?
完全一样
我的代码是依照FirePrime的wiki的步骤取得的:
git pull bitbucket fireprime:fireprime
Leo.Chang 发表于 2017-4-14 09:47
完全一样
那就不太清楚了,看log 跟踪代码吧
loading 发表于 2017-4-14 17:20
那就不太清楚了,看log 跟踪代码吧
我现在Driver LOG看起来正常了,可以帮我确定lcdc这里的code应该怎么改才会正确动作?
&lcdc {
status = “okay”;
&lcdc {
这块用默认的应该就可以
看一下这里
&lvds {
status = “okay”;
pinctrl-names = "lcdc";
pinctrl-0 = <&lcdc0_lcdc_d>;
