[18:03:05][ 0.000000] Booting Linux on physical CPU 0x0
[18:03:05][ 0.000000] Initializing cgroup subsys cpu
[18:03:05][ 0.000000] Initializing cgroup subsys cpuacct
[18:03:05][ 0.000000] Initializing cgroup subsys schedtune
[18:03:05][ 0.000000] schedtune configured to support 4 boost groups
[18:03:05][ 0.000000] Linux version 4.4.16 (qdeng@CRI-HZ) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #93 SMP PREEMPT Wed Mar 29 17:16:15 CST 2017
[18:03:05][ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[18:03:05][ 0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options ‘’)
[18:03:05][ 0.000000] bootconsole [uart0] enabled
[18:03:05][ 0.000000] hdmi init vic is 65536
[18:03:05][ 0.000000] Reserved memory: created CMA memory pool at 0x0000000075c00000, size 128 MiB
[18:03:05][ 0.000000] Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
[18:03:05][ 0.000000] On node 0 totalpages: 523776
[18:03:05][ 0.000000] DMA zone: 8184 pages used for memmap
[18:03:05][ 0.000000] DMA zone: 0 pages reserved
[18:03:05][ 0.000000] DMA zone: 523776 pages, LIFO batch:31
[18:03:05][ 0.000000] psci: probing for conduit method from DT.
[18:03:05][ 0.000000] psci: PSCIv1.0 detected in firmware.
[18:03:05][ 0.000000] psci: Using standard PSCI v0.2 function IDs
[18:03:05][ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[18:03:05][ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07ff09000 s45184 r8192 d32640 u86016
[18:03:05][ 0.000000] pcpu-alloc: s45184 r8192 d32640 u86016 alloc=21*4096
[18:03:05][ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[18:03:05][ 0.000000] Detected VIPT I-cache on CPU0
[18:03:05][ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[18:03:05][ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 515592
[18:03:05][ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=disabled androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x00008000@0x00010000(kernel),0x00010000@0x00018000(boot),0x00010000@0x00028000(recovery),0x00038000@0x00038000(backup),0x00040000@0x00070000(cache),0x00200000@0x000B0000(system),0x00008000@0x002B0000(metadata),0x00002000@0x002B8000(baseparamer),-@0x002BA000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000:0x01000000 loader.timestamp=2017-03-22_13:28:52 hdmi.vic=65536
[18:03:05][ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[18:03:05][ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[18:03:05][ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[18:03:05][ 0.000000] software IO TLB [mem 0x7fdb6000-0x7fdf6000] (0MB) mapped at [ffffffc07fdb6000-ffffffc07fdf5fff]
[18:03:05][ 0.000000] Memory: 1875912K/2095104K available (9474K kernel code, 1139K rwdata, 4348K rodata, 768K init, 1041K bss, 88120K reserved, 131072K cma-reserved)
[18:03:05][ 0.000000] Virtual kernel memory layout:
[18:03:05][ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[18:03:05][ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB)
[18:03:05][ 0.000000] .init : 0xffffff8008e00000 - 0xffffff8008ec0000 ( 768 KB)
[18:03:05][ 0.000000] .text : 0xffffff8008080000 - 0xffffff80089b0000 ( 9408 KB)
[18:03:05][ 0.000000] .rodata : 0xffffff80089b0000 - 0xffffff8008e00000 ( 4416 KB)
[18:03:05][ 0.000000] .data : 0xffffff8008ec0000 - 0xffffff8008fdcf40 ( 1140 KB)
[18:03:05][ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[18:03:05][ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc2000000 ( 31 MB actual)
[18:03:05][ 0.000000] fixed : 0xffffffbffe7fd000 - 0xffffffbffec00000 ( 4108 KB)
[18:03:05][ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB)
[18:03:05][ 0.000000] memory : 0xffffffc000200000 - 0xffffffc080000000 ( 2046 MB)
[18:03:05][ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[18:03:05][ 0.000000] Preemptible hierarchical RCU implementation.
[18:03:05][ 0.000000] Build-time adjustment of leaf fanout to 64.
[18:03:05][ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[18:03:05][ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[18:03:05][ 0.000000] NR_IRQS:64 nr_irqs:64 0
[18:03:05][ 0.000000] GIC: Using split EOI/Deactivate mode
[18:03:05][ 0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[18:03:05][ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[18:03:05][ 0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[18:03:05][ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[18:03:05][ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[18:03:05][ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[18:03:05][ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[18:03:05][ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[18:03:05][ 0.001686] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[18:03:05][ 0.002716] pid_max: default: 32768 minimum: 301
[18:03:05][ 0.003220] Security Framework initialized
[18:03:05][ 0.003616] SELinux: Initializing.
[18:03:05][ 0.003992] SELinux: Starting in permissive mode
[18:03:05][ 0.004033] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[18:03:05][ 0.004673] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[18:03:05][ 0.006115] Initializing cgroup subsys freezer
[18:03:05][ 0.006577] Initializing cgroup subsys debug
[18:03:05][ 0.007467] sched-energy: Sched-energy-costs installed from DT
[18:03:05][ 0.008025] CPU0: update cpu_capacity 401
[18:03:05][ 0.008458] ASID allocator initialised with 65536 entries
[18:03:05][ 0.042809] Detected VIPT I-cache on CPU1
[18:03:05][ 0.042841] CPU1: found redistributor 1 region 0:0x00000000fef20000
[18:03:05][ 0.042873] CPU1: update cpu_capacity 401
[18:03:05][ 0.042877] CPU1: Booted secondary processor [410fd034]
[18:03:05][ 0.054818] Detected VIPT I-cache on CPU2
[18:03:05][ 0.054836] CPU2: found redistributor 2 region 0:0x00000000fef40000
[18:03:05][ 0.054855] CPU2: update cpu_capacity 401
[18:03:05][ 0.054858] CPU2: Booted secondary processor [410fd034]
[18:03:05][ 0.066858] Detected VIPT I-cache on CPU3
[18:03:05][ 0.066876] CPU3: found redistributor 3 region 0:0x00000000fef60000
[18:03:05][ 0.066895] CPU3: update cpu_capacity 401
[18:03:05][ 0.066898] CPU3: Booted secondary processor [410fd034]
[18:03:05][ 0.078903] Detected PIPT I-cache on CPU4
[18:03:05][ 0.078931] CPU4: found redistributor 100 region 0:0x00000000fef80000
[18:03:05][ 0.078963] CPU4: update cpu_capacity 1024
[18:03:05][ 0.078966] CPU4: Booted secondary processor [410fd082]
[18:03:05][ 0.090926] Detected PIPT I-cache on CPU5
[18:03:05][ 0.090944] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[18:03:05][ 0.090964] CPU5: update cpu_capacity 1024
[18:03:05][ 0.090967] CPU5: Booted secondary processor [410fd082]
[18:03:05][ 0.091048] Brought up 6 CPUs
[18:03:05][ 0.100635] SMP: Total of 6 processors activated.
[18:03:05][ 0.101086] CPU features: detected feature: GIC system register CPU interface
[18:03:05][ 0.101768] CPU: All CPU(s) started at EL2
[18:03:05][ 0.102193] alternatives: patching kernel code
[18:03:05][ 0.103824] devtmpfs: initialized
[18:03:05][ 0.120653] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[18:03:05][ 0.125970] pinctrl core: initialized pinctrl subsystem
[18:03:05][ 0.129345] NET: Registered protocol family 16
[18:03:05][ 0.140861] cpuidle: using governor ladder
[18:03:05][ 0.150999] cpuidle: using governor menu
[18:03:05][ 0.151394] Registered FIQ tty driver
[18:03:05][ 0.152269] vdso: 2 pages (1 code @ ffffff80089b6000, 1 data @ ffffff8008ec4000)
[18:03:05][ 0.153001] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[18:03:05][ 0.154443] DMA: preallocated 256 KiB pool for atomic allocations
[18:03:05][ 0.169064] gpiochip_add: registered GPIOs 0 to 31 on device: gpio0
[18:03:05][ 0.169163] gpiochip_add: registered GPIOs 32 to 63 on device: gpio1
[18:03:05][ 0.169254] gpiochip_add: registered GPIOs 64 to 95 on device: gpio2
[18:03:05][ 0.169335] gpiochip_add: registered GPIOs 96 to 127 on device: gpio3
[18:03:05][ 0.169419] gpiochip_add: registered GPIOs 128 to 159 on device: gpio4
[18:03:05][ 0.177018] console [pstore0] enabled
[18:03:05][ 0.177566] pstore: Registered ramoops as persistent store backend
[18:03:05][ 0.178158] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[18:03:05][ 0.179417] rk_iommu ff650800.vpu_mmu: (vpu) Enter
[18:03:05][ 0.179979] rk_iommu ff650800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[18:03:05][ 0.180760] rk_iommu ff650800.vpu_mmu: (vpu) Initialized
[18:03:05][ 0.181612] rk_iommu ff660480.vdec_mmu: (vdec) Enter
[18:03:05][ 0.182175] rk_iommu ff660480.vdec_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[18:03:05][ 0.182964] rk_iommu ff660480.vdec_mmu: (vdec) Initialized
[18:03:05][ 0.183820] rk_iommu ff670800.iep-mmu: (iep) Enter
[18:03:05][ 0.184358] rk_iommu ff670800.iep-mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[18:03:05][ 0.185140] rk_iommu ff670800.iep-mmu: (iep) Initialized
[18:03:05][ 0.186200] rk_iommu ff903f00.vopb-mmu: (vop) Enter
[18:03:05][ 0.186750] rk_iommu ff903f00.vopb-mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[18:03:05][ 0.187550] rk_iommu ff903f00.vopb-mmu: (vop) Initialized
[18:03:05][ 0.188244] rk_iommu ff8f3f00.vopl-mmu: (vop) Enter
[18:03:05][ 0.188795] rk_iommu ff8f3f00.vopl-mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[18:03:05][ 0.189583] rk_iommu ff8f3f00.vopl-mmu: (vop) Initialized
[18:03:05][ 0.190290] rk_iommu ff914000.isp0_mmu: (isp0) Enter
[18:03:05][ 0.190844] rk_iommu ff914000.isp0_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[18:03:05][ 0.191645] rk_iommu ff914000.isp0_mmu: (isp0) Initialized
[18:03:05][ 0.192357] rk_iommu ff924000.isp1_mmu: (isp1) Enter
[18:03:05][ 0.192912] rk_iommu ff924000.isp1_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[18:03:05][ 0.193700] rk_iommu ff924000.isp1_mmu: (isp1) Initialized
[18:03:05][ 0.195311] console [ttyFIQ0] enabled
[18:03:05][ 0.195884] bootconsole [uart0] disabled
[18:03:05][ 0.197099] Registered fiq debugger ttyFIQ0
[18:03:05][ 0.233126] Rockchip hdmi driver version 2.0
[18:03:05][ 0.233126] .
[18:03:05][ 0.233530] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vcc3v3-sys[0]’
[18:03:05][ 0.234085] of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/vcc5v0-host-regulator[0]’ - status (0)
[18:03:05][ 0.234318] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vcc5v0-sys[0]’
[18:03:05][ 0.234513] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vcc-phy-regulator[0]’
[18:03:05][ 0.235325] SCSI subsystem initialized
[18:03:05][ 0.235580] usbcore: registered new interface driver usbfs
[18:03:05][ 0.235643] usbcore: registered new interface driver hub
[18:03:05][ 0.235757] usbcore: registered new device driver usb
[18:03:05][ 0.236284] media: Linux media interface: v0.10
[18:03:05][ 0.236339] Linux video capture interface: v2.00
[18:03:05][ 0.236502] pps_core: LinuxPPS API ver. 1 registered
[18:03:05][ 0.236515] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[18:03:05][ 0.236547] PTP clock support registered
[18:03:05][ 0.236996] rockchip ion: success to create - cma-heap
[18:03:05][ 0.237019] rockchip ion: success to create - system-heap
[18:03:05][ 0.237599] Advanced Linux Sound Architecture Driver Initialized.
[18:03:05][ 0.238220] Bluetooth: Core ver 2.21
[18:03:05][ 0.238258] NET: Registered protocol family 31
[18:03:05][ 0.238270] Bluetooth: HCI device and connection manager initialized
[18:03:05][ 0.238287] Bluetooth: HCI socket layer initialized
[18:03:05][ 0.238302] Bluetooth: L2CAP socket layer initialized
[18:03:05][ 0.238336] Bluetooth: SCO socket layer initialized
[18:03:05][ 0.240197] clocksource: Switched to clocksource arch_sys_counter
[18:03:05][ 0.296810] fb disp policy is box
[18:03:05][ 0.296844] uboot-logo-on:1
[18:03:05][ 0.296890] rk-fb rockchip-fb: rk fb ion client create success!
[18:03:05][ 0.297110] logo: base=0x7dc00000, size=0x2000000, offset=0x1000000
[18:03:05][ 0.297124] rk-fb rockchip-fb: rockchip framebuffer driver probe
[18:03:05][ 0.297549] rk-screen screen: rockchip screen probe success
[18:03:05][ 0.299008] rk322x-lcdc ff900000.vop-rk-fb: vop_dev->regs=0xffffff8009228000
[18:03:05][ 0.299131] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/vop-rk-fb@ff900000/power_ctr/lcd-en[0]’ - status (0)
[18:03:05][ 0.299174] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/vop-rk-fb@ff900000/power_ctr/lcd-rst[0]’ - status (0)
[18:03:05][ 0.299552] graphics fb0: rockchip framebuffer registerd:fb0
[18:03:05][ 0.300003] graphics fb1: rockchip framebuffer registerd:fb1
[18:03:05][ 0.300219] graphics fb2: rockchip framebuffer registerd:fb2
[18:03:05][ 0.300421] graphics fb3: rockchip framebuffer registerd:fb3
[18:03:05][ 0.300610] graphics fb4: rockchip framebuffer registerd:fb4
[18:03:05][ 0.300727] rk322x-lcdc vop0: failed to get clk source
[18:03:05][ 0.300740] rk322x-lcdc vop0: failed to get clk source
[18:03:05][ 0.302603] rk322x-lcdc vop0: lcdc0: dclk:148500000>>fps:60
[18:03:05][ 0.302615] rk322x-lcdc vop0: dsp lut table is null
[18:03:05][ 0.302626] rk322x-lcdc vop0: cabc lut table is null
[18:03:05][ 0.324921] alloc_buffer:ion_phy_addr=0x10000000
[18:03:05][ 0.330269] fb0:phy:10000000>>vir:ffffff8009381000>>len:0x1800000
[18:03:05][ 0.346934] rk_iommu ff903f00.vopb-mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x72c55000
[18:03:05][ 0.346968] rk322x-lcdc vop0: lcdc0 probe ok, iommu enabled
[18:03:05][ 0.348561] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[18:03:05][ 0.348782] NET: Registered protocol family 2
[18:03:05][ 0.349219] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[18:03:05][ 0.349319] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[18:03:05][ 0.349452] TCP: Hash tables configured (established 16384 bind 16384)
[18:03:05][ 0.349526] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[18:03:05][ 0.349554] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[18:03:05][ 0.349703] NET: Registered protocol family 1
[18:03:05][ 0.350106] Trying to unpack rootfs image as initramfs…
[18:03:05][ 0.414836] Freeing initrd memory: 1320K (ffffffc005bf0000 - ffffffc005d3a000)
[18:03:05][ 0.415314] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[18:03:05][ 0.415396] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[18:03:05][ 0.417843] futex hash table entries: 2048 (order: 5, 131072 bytes)
[18:03:05][ 0.417948] audit: initializing netlink subsys (disabled)
[18:03:05][ 0.418002] audit: type=2000 audit(0.412:1): initialized
[18:03:05][ 0.427148] VFS: Disk quotas dquot_6.6.0
[18:03:05][ 0.427274] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[18:03:05][ 0.428672] fuse init (API version 7.23)
[18:03:05][ 0.429361] SELinux: Registering netfilter hooks
[18:03:05][ 0.432916] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[18:03:05][ 0.432945] io scheduler noop registered
[18:03:05][ 0.433110] io scheduler cfq registered (default)
[18:03:05][ 0.436720] rga2 ff680000.rga: rga ion client create success!
[18:03:05][ 0.436868] rga: Driver loaded succesfully
[18:03:05][ 0.437608] hdmi phy_table not exist
[18:03:05][ 0.438063] reset hdmi
[18:03:05][ 0.438193] rockchip-hdmiv2 ff940000.hdmi-rk-fb: rockchip hdmiv2 probe success.
[18:03:05][ 0.438593] iep: failed to find iep power down clock source.
[18:03:05][ 0.438856] IEP Power ON
[18:03:05][ 0.438887] iep ion client create success!
[18:03:05][ 0.439105] rk_iommu ff670800.iep-mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x72c50000
[18:03:05][ 0.439117] IEP Power OFF
[18:03:05][ 0.439178] IEP Driver loaded succesfully
[18:03:05][ 0.439240] Module initialized.
[18:03:05][ 0.439563] vcodec_service: No core reset resource define
[18:03:05][ 0.439624] vcodec ff650000.vpu_service: do not have pd_video
[18:03:05][ 0.439645] vcodec_service: probe device ff650000.vpu_service
[18:03:05][ 0.439657] vcodec_service: ff650000.vpu_service: power on
[18:03:05][ 0.439679] vcodec_service: checking hw id 0
[18:03:05][ 0.440360] vcodec_service: ff650000.vpu_service: power off…
[18:03:05][ 0.440424] vcodec_service: done
[18:03:05][ 0.440436] vcodec_service: init success
[18:03:05][ 0.440669] vcodec_service: No core reset resource define
[18:03:05][ 0.440786] vcodec ff660000.rkvdec: do not have pd_video
[18:03:05][ 0.440805] vcodec_service: probe device ff660000.rkvdec
[18:03:05][ 0.440816] vcodec_service: ff660000.rkvdec: power on
[18:03:05][ 0.440841] vcodec_service: checking hw id 6876
[18:03:05][ 0.441273] vcodec_service: ff660000.rkvdec: power off…
[18:03:05][ 0.441340] vcodec_service: done
[18:03:05][ 0.441351] vcodec_service: init success
[18:03:05][ 0.442664] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[18:03:05][ 0.442682] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[18:03:05][ 0.444013] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[18:03:05][ 0.444030] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[18:03:05][ 0.444836] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[18:03:05][ 0.446098] console [ttyS0] disabled
[18:03:05][ 0.446140] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[18:03:05][ 0.446601] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 36, base_baud = 1500000) is a 16550A
[18:03:05][ 0.447148] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
[18:03:05][ 0.447739] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 38, base_baud = 1500000) is a 16550A
[18:03:05][ 0.448133] dw-apb-uart: probe of ff370000.serial failed with error -28
[18:03:05][ 0.448305] [drm] Initialized drm 1.1.0 20060810
[18:03:05][ 0.450182] mali ff9a0000.gpu: Failed to get regulator
[18:03:05][ 0.450196] mali ff9a0000.gpu: Power control initialization failed
[18:03:05][ 0.450476] Unable to detect cache hierarchy from DT for CPU 0
[18:03:05][ 0.457976] brd: module loaded
[18:03:05][ 0.478482] loop: module loaded
[18:03:05][ 0.479009] zram: Added device: zram0
[18:03:05][ 0.479423] SCSI Media Changer driver v0.25
[18:03:05][ 0.479788] tun: Universal TUN/TAP device driver, 1.6
[18:03:05][ 0.479798] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[18:03:05][ 0.480248] rockchip-pinctrl pinctrl: pin gpio3-14 already requested by ff1b0000.serial; cannot claim for fe300000.eth
[18:03:05][ 0.480272] rockchip-pinctrl pinctrl: pin-110 (fe300000.eth) status -22
[18:03:05][ 0.480288] rockchip-pinctrl pinctrl: could not request pin 110 (gpio3-14) from group rgmii-pins on device rockchip-pinctrl
[18:03:05][ 0.480305] rk_gmac-dwmac fe300000.eth: Error applying setting, reverse things back
[18:03:05][ 0.480859] rk_gmac-dwmac fe300000.eth: clock input or output? (input).
[18:03:05][ 0.480874] rk_gmac-dwmac fe300000.eth: TX delay(0x28).
[18:03:05][ 0.480886] rk_gmac-dwmac fe300000.eth: RX delay(0x11).
[18:03:05][ 0.481071] rk_gmac-dwmac fe300000.eth: clock input from PHY
[18:03:05][ 0.481082] rk_gmac-dwmac fe300000.eth: init for RGMII
[18:03:05][ 0.486160] stmmac - user ID: 0x10, Synopsys ID: 0x35
[18:03:05][ 0.486170] Ring mode enabled
[18:03:05][ 0.486178] DMA HW capability register supported
[18:03:05][ 0.486187] Normal descriptors
[18:03:05][ 0.486197] RX Checksum Offload Engine supported (type 2)
[18:03:05][ 0.486206] TX Checksum insertion supported
[18:03:05][ 0.486214] Wake-Up On Lan supported
[18:03:05][ 0.486260] Enable RX Mitigation via HW Watchdog Timer
[18:03:05][ 0.486726] of_get_named_gpiod_flags: parsed ‘snps,reset-gpio’ property of node ‘/eth@fe300000[0]’ - status (0)
[18:03:05][ 0.563214] libphy: stmmac: probed
[18:03:05][ 0.563239] eth0: PHY ID 00000000 at 0 IRQ POLL (stmmac-0:00) active
[18:03:05][ 0.563253] eth0: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01)
[18:03:05][ 0.563264] eth0: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02)
[18:03:05][ 0.563275] eth0: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03)
[18:03:05][ 0.563286] eth0: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04)
[18:03:05][ 0.563297] eth0: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05)
[18:03:05][ 0.563306] eth0: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06)
[18:03:05][ 0.563316] eth0: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07)
[18:03:05][ 0.563326] eth0: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08)
[18:03:05][ 0.563336] eth0: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09)
[18:03:05][ 0.563346] eth0: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a)
[18:03:05][ 0.563356] eth0: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b)
[18:03:05][ 0.563365] eth0: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c)
[18:03:05][ 0.563375] eth0: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d)
[18:03:05][ 0.563385] eth0: PHY ID 00000000 at 14 IRQ POLL (stmmac-0:0e)
[18:03:05][ 0.563395] eth0: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f)
[18:03:05][ 0.563405] eth0: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10)
[18:03:05][ 0.563415] eth0: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11)
[18:03:05][ 0.563425] eth0: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12)
[18:03:05][ 0.563434] eth0: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13)
[18:03:05][ 0.563444] eth0: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:14)
[18:03:05][ 0.563453] eth0: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15)
[18:03:05][ 0.563463] eth0: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16)
[18:03:05][ 0.563473] eth0: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17)
[18:03:05][ 0.563482] eth0: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18)
[18:03:05][ 0.563492] eth0: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19)
[18:03:05][ 0.563502] eth0: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a)
[18:03:05][ 0.563512] eth0: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b)
[18:03:05][ 0.563521] eth0: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c)
[18:03:05][ 0.563530] eth0: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d)
[18:03:05][ 0.563540] eth0: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e)
[18:03:05][ 0.563550] eth0: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f)
[18:03:05][ 0.564103] PPP generic driver version 2.4.2
[18:03:05][ 0.564281] PPP BSD Compression module registered
[18:03:05][ 0.564298] PPP Deflate Compression module registered
[18:03:05][ 0.564326] PPP MPPE Compression module registered
[18:03:05][ 0.564348] NET: Registered protocol family 24
[18:03:05][ 0.564394] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[18:03:05][ 0.564406] CSLIP: code copyright 1989 Regents of the University of California.
[18:03:05][ 0.564428] Rockchip WiFi SYS interface (V1.00) …
[18:03:05][ 0.564513] usbcore: registered new interface driver catc
[18:03:05][ 0.564557] usbcore: registered new interface driver kaweth
[18:03:05][ 0.564575] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[18:03:05][ 0.564617] usbcore: registered new interface driver pegasus
[18:03:05][ 0.564659] usbcore: registered new interface driver rtl8150
[18:03:05][ 0.564702] usbcore: registered new interface driver r8152
[18:03:05][ 0.564718] hso: drivers/net/usb/hso.c: Option Wireless
[18:03:05][ 0.564778] usbcore: registered new interface driver hso
[18:03:05][ 0.564831] usbcore: registered new interface driver asix
[18:03:05][ 0.564874] usbcore: registered new interface driver ax88179_178a
[18:03:05][ 0.564917] usbcore: registered new interface driver cdc_ether
[18:03:05][ 0.564960] usbcore: registered new interface driver cdc_eem
[18:03:05][ 0.565002] usbcore: registered new interface driver dm9601
[18:03:05][ 0.565058] usbcore: registered new interface driver smsc75xx
[18:03:05][ 0.565110] usbcore: registered new interface driver smsc95xx
[18:03:05][ 0.565152] usbcore: registered new interface driver gl620a
[18:03:05][ 0.565197] usbcore: registered new interface driver net1080
[18:03:05][ 0.565240] usbcore: registered new interface driver plusb
[18:03:05][ 0.565283] usbcore: registered new interface driver rndis_host
[18:03:05][ 0.565329] usbcore: registered new interface driver cdc_subset
[18:03:05][ 0.565372] usbcore: registered new interface driver zaurus
[18:03:05][ 0.565416] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[18:03:05][ 0.565476] usbcore: registered new interface driver int51x1
[18:03:05][ 0.565519] usbcore: registered new interface driver kalmia
[18:03:05][ 0.565565] usbcore: registered new interface driver ipheth
[18:03:05][ 0.565612] usbcore: registered new interface driver sierra_net
[18:03:05][ 0.565656] usbcore: registered new interface driver cx82310_eth
[18:03:05][ 0.565709] usbcore: registered new interface driver cdc_ncm
[18:03:05][ 0.565752] usbcore: registered new interface driver qmi_wwan
[18:03:05][ 0.565798] usbcore: registered new interface driver cdc_mbim
[18:03:05][ 0.566867] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[18:03:05][ 0.570060] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[18:03:05][ 0.570080] ehci-platform: EHCI generic platform driver
[18:03:05][ 0.570558] ehci-platform fe3c0000.usb: EHCI Host Controller
[18:03:05][ 0.570589] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[18:03:05][ 0.570717] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[18:03:05][ 0.580203] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[18:03:05][ 0.580331] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[18:03:05][ 0.580346] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[18:03:05][ 0.580359] usb usb1: Product: EHCI Host Controller
[18:03:05][ 0.580369] usb usb1: Manufacturer: Linux 4.4.16 ehci_hcd
[18:03:05][ 0.580380] usb usb1: SerialNumber: fe3c0000.usb
[18:03:05][ 0.580850] hub 1-0:1.0: USB hub found
[18:03:05][ 0.580882] hub 1-0:1.0: 1 port detected
[18:03:05][ 0.581339] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[18:03:05][ 0.581372] ohci-platform: OHCI generic platform driver
[18:03:05][ 0.581836] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[18:03:05][ 0.581861] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[18:03:05][ 0.581971] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[18:03:05][ 0.640324] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[18:03:05][ 0.640343] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[18:03:05][ 0.640356] usb usb2: Product: Generic Platform OHCI controller
[18:03:05][ 0.640368] usb usb2: Manufacturer: Linux 4.4.16 ohci_hcd
[18:03:05][ 0.640379] usb usb2: SerialNumber: fe3e0000.usb
[18:03:05][ 0.640841] hub 2-0:1.0: USB hub found
[18:03:05][ 0.640872] hub 2-0:1.0: 1 port detected
[18:03:05][ 0.641520] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[18:03:05][ 0.641543] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
[18:03:05][ 0.641753] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00030010
[18:03:05][ 0.641798] xhci-hcd xhci-hcd.0.auto: irq 233, io mem 0xfe900000
[18:03:05][ 0.641922] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[18:03:05][ 0.641936] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[18:03:05][ 0.641949] usb usb3: Product: xHCI Host Controller
[18:03:05][ 0.641959] usb usb3: Manufacturer: Linux 4.4.16 xhci-hcd
[18:03:05][ 0.641970] usb usb3: SerialNumber: xhci-hcd.0.auto
[18:03:05][ 0.642429] hub 3-0:1.0: USB hub found
[18:03:05][ 0.642461] hub 3-0:1.0: 1 port detected
[18:03:05][ 0.642719] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[18:03:05][ 0.642737] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4
[18:03:05][ 0.642796] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[18:03:05][ 0.642881] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[18:03:05][ 0.642895] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[18:03:05][ 0.642906] usb usb4: Product: xHCI Host Controller
[18:03:05][ 0.642917] usb usb4: Manufacturer: Linux 4.4.16 xhci-hcd
[18:03:05][ 0.642927] usb usb4: SerialNumber: xhci-hcd.0.auto
[18:03:05][ 0.643410] hub 4-0:1.0: USB hub found
[18:03:05][ 0.643440] hub 4-0:1.0: 1 port detected
[18:03:05][ 0.643773] usbcore: registered new interface driver cdc_acm
[18:03:05][ 0.643784] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[18:03:05][ 0.643846] usbcore: registered new interface driver usblp
[18:03:05][ 0.643897] usbcore: registered new interface driver cdc_wdm
[18:03:05][ 0.643985] usbcore: registered new interface driver usb-storage
[18:03:05][ 0.644027] usbcore: registered new interface driver ums-alauda
[18:03:05][ 0.644069] usbcore: registered new interface driver ums-cypress
[18:03:05][ 0.644111] usbcore: registered new interface driver ums-datafab
[18:03:05][ 0.644152] usbcore: registered new interface driver ums_eneub6250
[18:03:05][ 0.644213] usbcore: registered new interface driver ums-freecom
[18:03:05][ 0.644261] usbcore: registered new interface driver ums-isd200
[18:03:05][ 0.644302] usbcore: registered new interface driver ums-jumpshot
[18:03:05][ 0.644342] usbcore: registered new interface driver ums-karma
[18:03:05][ 0.644383] usbcore: registered new interface driver ums-onetouch
[18:03:05][ 0.644425] usbcore: registered new interface driver ums-sddr09
[18:03:05][ 0.644466] usbcore: registered new interface driver ums-sddr55
[18:03:05][ 0.644506] usbcore: registered new interface driver ums-usbat
[18:03:05][ 0.644588] usbcore: registered new interface driver usbserial
[18:03:05][ 0.644628] usbcore: registered new interface driver usbserial_generic
[18:03:05][ 0.644660] usbserial: USB Serial support registered for generic
[18:03:05][ 0.644704] usbcore: registered new interface driver option
[18:03:05][ 0.644735] usbserial: USB Serial support registered for GSM modem (1-port)
[18:03:05][ 0.644888] usbcore: registered new interface driver trancevibrator
[18:03:05][ 0.644903] usb20_otg: version 3.10a 21-DEC-2012
[18:03:05][ 0.645098] usb20_host: version 3.10a 21-DEC-2012
[18:03:05][ 0.649485] usbcore: registered new interface driver xpad
[18:03:05][ 0.649537] usbcore: registered new interface driver usb_acecad
[18:03:05][ 0.649586] usbcore: registered new interface driver aiptek
[18:03:05][ 0.649637] usbcore: registered new interface driver gtco
[18:03:05][ 0.649683] usbcore: registered new interface driver hanwang
[18:03:05][ 0.649730] usbcore: registered new interface driver kbtab
[18:03:05][ 0.656491] .. rk pwm remotectl v1.1 init
[18:03:05][ 0.656731] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[18:03:05][ 0.657066] sensor_register_slave:mma8452,id=17
[18:03:05][ 0.657081] sensor_register_slave:lis3dh,id=7
[18:03:05][ 0.657093] sensor_register_slave:mma7660,id=18
[18:03:05][ 0.657105] sensor_register_slave:lsm303d,id=22
[18:03:05][ 0.657118] sensor_register_slave:mpu6880_acc,id=24
[18:03:05][ 0.657131] sensor_register_slave:mpu6500_acc,id=25
[18:03:05][ 0.657143] sensor_register_slave:lsm330_acc,id=26
[18:03:05][ 0.657156] sensor_register_slave:akm8975,id=28
[18:03:05][ 0.657168] sensor_register_slave:akm8963,id=29
[18:03:05][ 0.657180] sensor_register_slave:l3g4200d,id=43
[18:03:05][ 0.657191] sensor_register_slave:l3g20d,id=44
[18:03:05][ 0.657203] sensor_register_slave:ewtsa,id=45
[18:03:05][ 0.657216] sensor_register_slave:lsm330_gyro,id=48
[18:03:05][ 0.657228] sensor_register_slave:cm3217,id=50
[18:03:05][ 0.657240] sensor_register_slave:cm3218,id=51
[18:03:05][ 0.657836] i2c /dev entries driver
[18:03:05][ 0.658464] fan53555-regulator 0-0040: GPIO lookup for consumer vsel
[18:03:05][ 0.658472] fan53555-regulator 0-0040: using device tree for GPIO lookup
[18:03:05][ 0.658481] of_get_named_gpiod_flags: can’t parse ‘vsel-gpios’ property of node ‘/i2c@ff3c0000/syr827@40[0]’
[18:03:05][ 0.658489] of_get_named_gpiod_flags: can’t parse ‘vsel-gpio’ property of node ‘/i2c@ff3c0000/syr827@40[0]’
[18:03:05][ 0.658496] fan53555-regulator 0-0040: using lookup tables for GPIO lookup
[18:03:05][ 0.658503] fan53555-regulator 0-0040: lookup for GPIO vsel failed
[18:03:05][ 0.658850] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[18:03:05][ 0.660616] fan53555-regulator 0-0041: GPIO lookup for consumer vsel
[18:03:05][ 0.660623] fan53555-regulator 0-0041: using device tree for GPIO lookup
[18:03:05][ 0.660631] of_get_named_gpiod_flags: can’t parse ‘vsel-gpios’ property of node ‘/i2c@ff3c0000/syr828@41[0]’
[18:03:05][ 0.660638] of_get_named_gpiod_flags: can’t parse ‘vsel-gpio’ property of node ‘/i2c@ff3c0000/syr828@41[0]’
[18:03:05][ 0.660644] fan53555-regulator 0-0041: using lookup tables for GPIO lookup
[18:03:05][ 0.660650] fan53555-regulator 0-0041: lookup for GPIO vsel failed
[18:03:05][ 0.660985] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[18:03:05][ 0.665782] rk808 0-001b: GPIO lookup for consumer dvs
[18:03:05][ 0.665790] rk808 0-001b: using device tree for GPIO lookup
[18:03:05][ 0.665799] of_get_named_gpiod_flags: can’t parse ‘dvs-gpios’ property of node ‘/i2c@ff3c0000/pmic@1b[0]’
[18:03:05][ 0.665806] of_get_named_gpiod_flags: can’t parse ‘dvs-gpio’ property of node ‘/i2c@ff3c0000/pmic@1b[0]’
[18:03:05][ 0.665812] rk808 0-001b: using lookup tables for GPIO lookup
[18:03:05][ 0.665819] rk808 0-001b: lookup for GPIO dvs failed
[18:03:05][ 0.665826] rk808-regulator rk808-regulator: there is no dvs0 gpio
[18:03:05][ 0.665838] rk808 0-001b: GPIO lookup for consumer dvs
[18:03:05][ 0.665844] rk808 0-001b: using device tree for GPIO lookup
[18:03:05][ 0.665851] of_get_named_gpiod_flags: can’t parse ‘dvs-gpios’ property of node ‘/i2c@ff3c0000/pmic@1b[1]’
[18:03:05][ 0.665857] of_get_named_gpiod_flags: can’t parse ‘dvs-gpio’ property of node ‘/i2c@ff3c0000/pmic@1b[1]’
[18:03:05][ 0.665863] rk808 0-001b: using lookup tables for GPIO lookup
[18:03:05][ 0.665869] rk808 0-001b: lookup for GPIO dvs failed
[18:03:05][ 0.665876] rk808-regulator rk808-regulator: there is no dvs1 gpio
[18:03:05][ 0.676750] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[18:03:05][ 0.677141] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff800bc44000
[18:03:05][ 0.677683] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff800bc46000
[18:03:05][ 0.678354] fusb302 4-0022: GPIO lookup for consumer int-n
[18:03:05][ 0.678362] fusb302 4-0022: using device tree for GPIO lookup
[18:03:05][ 0.678387] of_get_named_gpiod_flags: parsed ‘int-n-gpios’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’ - status (0)
[18:03:05][ 0.678409] fusb302 4-0022: GPIO lookup for consumer vbus-5v
[18:03:05][ 0.678416] fusb302 4-0022: using device tree for GPIO lookup
[18:03:05][ 0.678423] of_get_named_gpiod_flags: can’t parse ‘vbus-5v-gpios’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’
[18:03:05][ 0.678430] of_get_named_gpiod_flags: can’t parse ‘vbus-5v-gpio’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’
[18:03:05][ 0.678436] fusb302 4-0022: using lookup tables for GPIO lookup
[18:03:05][ 0.678443] fusb302 4-0022: lookup for GPIO vbus-5v failed
[18:03:05][ 0.678450] fusb302 4-0022: GPIO lookup for consumer vbus-other
[18:03:05][ 0.678456] fusb302 4-0022: using device tree for GPIO lookup
[18:03:05][ 0.678462] of_get_named_gpiod_flags: can’t parse ‘vbus-other-gpios’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’
[18:03:05][ 0.678469] of_get_named_gpiod_flags: can’t parse ‘vbus-other-gpio’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’
[18:03:05][ 0.678475] fusb302 4-0022: using lookup tables for GPIO lookup
[18:03:05][ 0.678480] fusb302 4-0022: lookup for GPIO vbus-other failed
[18:03:05][ 0.682382] fusb302 4-0022: port 0 probe success
[18:03:05][ 0.682505] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff800bc48000
[18:03:05][ 0.683267] IR NEC protocol handler initialized
[18:03:05][ 0.683288] IR RC5(x/sz) protocol handler initialized
[18:03:05][ 0.683304] IR RC6 protocol handler initialized
[18:03:05][ 0.683318] IR JVC protocol handler initialized
[18:03:05][ 0.683333] IR Sony protocol handler initialized
[18:03:05][ 0.683348] IR SANYO protocol handler initialized
[18:03:05][ 0.683363] IR Sharp protocol handler initialized
[18:03:05][ 0.683377] IR MCE Keyboard/mouse protocol handler initialized
[18:03:05][ 0.683392] IR XMP protocol handler initialized
[18:03:05][ 0.683485] usbcore: registered new interface driver uvcvideo
[18:03:05][ 0.683495] USB Video Class driver (1.1.1)
[18:03:05][ 0.683513] CamSys driver version: v0.33.5, CamSys head file version: v0.13.0
[18:03:05][ 0.684003] __power_supply_register: Expected proper parent device for ‘test_ac’
[18:03:05][ 0.684132] __power_supply_register: Expected proper parent device for ‘test_battery’
[18:03:05][ 0.684402] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[18:03:05][ 0.684505] __power_supply_register: Expected proper parent device for ‘test_usb’
[18:03:05][ 0.685020] vcc_1v8: supplied by vcc3v3_sys
[18:03:05][ 0.685140] vcca1v8_codec: supplied by vcc3v3_sys
[18:03:05][ 0.685237] vcc_sd: supplied by vcc3v3_sys
[18:03:05][ 0.686546] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[18:03:05][ 0.687024] device-mapper: uevent: version 1.0.3
[18:03:05][ 0.687290] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[18:03:05][ 0.687420] Bluetooth: HCI UART driver ver 2.3
[18:03:05][ 0.687432] Bluetooth: HCI UART protocol H4 registered
[18:03:05][ 0.687442] Bluetooth: HCI UART protocol LL registered
[18:03:05][ 0.687761] vdd_cpu_l: supplied by vcc3v3_sys
[18:03:05][ 0.688736] vdd_cpu_b: supplied by vcc5v0_sys
[18:03:05][ 0.690248] sdhci: Secure Digital Host Controller Interface driver
[18:03:05][ 0.690261] sdhci: Copyright(c) Pierre Ossman
[18:03:05][ 0.690272] Synopsys Designware Multimedia Card Interface Driver
[18:03:05][ 0.691020] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[18:03:05][ 0.691110] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[18:03:05][ 0.691130] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[18:03:05][ 0.691186] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[18:03:05][ 0.691250] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[18:03:05][ 0.691262] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[18:03:05][ 0.691282] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp
[18:03:05][ 0.691288] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup
[18:03:05][ 0.691297] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@fe310000[0]’
[18:03:05][ 0.691304] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@fe310000[0]’
[18:03:05][ 0.691311] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup
[18:03:05][ 0.691318] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
[18:03:05][ 0.691975] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[18:03:05][ 0.692022] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[18:03:05][ 0.692041] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[18:03:05][ 0.692086] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[18:03:05][ 0.692170] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[18:03:05][ 0.692253] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer cd
[18:03:05][ 0.692260] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[18:03:05][ 0.692268] of_get_named_gpiod_flags: can’t parse ‘cd-gpios’ property of node ‘/dwmmc@fe320000[0]’
[18:03:05][ 0.692276] of_get_named_gpiod_flags: can’t parse ‘cd-gpio’ property of node ‘/dwmmc@fe320000[0]’
[18:03:05][ 0.692282] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[18:03:05][ 0.692288] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO cd failed
[18:03:05][ 0.692295] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer wp
[18:03:05][ 0.692301] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[18:03:05][ 0.692308] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@fe320000[0]’
[18:03:05][ 0.692314] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@fe320000[0]’
[18:03:05][ 0.692320] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[18:03:05][ 0.692327] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO wp failed
[18:03:05][ 0.692461] rockchip-iodomain io-domains: Setting to 3300000 done
[18:03:05][ 0.692597] rockchip-iodomain io-domains: Setting to 3300000 done
[18:03:05][ 0.708365] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[18:03:05][ 0.725337] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[18:03:05][ 0.725577] sdhci-pltfm: SDHCI platform and OF driver helper
[18:03:05][ 0.726019] sdhci-arasan fe330000.sdhci: GPIO lookup for consumer wp
[18:03:05][ 0.726027] sdhci-arasan fe330000.sdhci: using device tree for GPIO lookup
[18:03:05][ 0.726035] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/sdhci@fe330000[0]’
[18:03:05][ 0.726043] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/sdhci@fe330000[0]’
[18:03:05][ 0.726050] sdhci-arasan fe330000.sdhci: using lookup tables for GPIO lookup
[18:03:05][ 0.726057] sdhci-arasan fe330000.sdhci: lookup for GPIO wp failed
[18:03:05][ 0.727270] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[18:03:05][ 0.727290] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[18:03:05][ 0.762315] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[18:03:05][ 0.766934] hidraw: raw HID events driver (C) Jiri Kosina
[18:03:05][ 0.772058] usbcore: registered new interface driver usbhid
[18:03:05][ 0.772567] usbhid: USB HID core driver
[18:03:05][ 0.773112] of_get_named_gpiod_flags: parsed ‘irq-gpio’ property of node ‘/i2c@ff3d0000/mpu6500@68[0]’ - status (0)
[18:03:05][ 0.773142] inv-mpu-iio 4-0068: int_config=0,level_shifter=0,client.addr=68,client.irq=71
[18:03:05][ 0.773874] inv-mpu-iio 4-0068: 0
[18:03:05][ 0.773890] inv-mpu-iio 4-0068: -1
[18:03:05][ 0.773899] inv-mpu-iio 4-0068: 0
[18:03:05][ 0.773908] inv-mpu-iio 4-0068: 1
[18:03:05][ 0.773916] inv-mpu-iio 4-0068: 0
[18:03:05][ 0.773925] inv-mpu-iio 4-0068: 0
[18:03:05][ 0.773934] inv-mpu-iio 4-0068: 0
[18:03:05][ 0.773942] inv-mpu-iio 4-0068: 0
[18:03:05][ 0.773950] inv-mpu-iio 4-0068: 1
[18:03:05][ 0.773959] inv-mpu-iio 4-0068:
[18:03:05][ 0.773968] inv_mpu_iio: secondary_i2c_addr=0
[18:03:05][ 0.802861] mmc1: MAN_BKOPS_EN bit is not set
[18:03:05][ 0.821970] mmc1: new HS400 MMC card at address 0001
[18:03:05][ 0.826425] mmcblk0: mmc1:0001 M8G1GC 7.28 GiB
[18:03:05][ 0.826869] mmcblk0boot0: mmc1:0001 M8G1GC partition 1 4.00 MiB
[18:03:05][ 0.831147] mmcblk0boot1: mmc1:0001 M8G1GC partition 2 4.00 MiB
[18:03:05][ 0.836451] mmcblk0rpmb: mmc1:0001 M8G1GC partition 3 512 KiB
[18:03:05][ 0.836885] uboot: 0x000400000 – 0x000800000 (4 MB)
[18:03:05][ 0.836900] trust: 0x000800000 – 0x000c00000 (4 MB)
[18:03:05][ 0.836912] misc: 0x000c00000 – 0x001000000 (4 MB)
[18:03:05][ 0.836924] resource: 0x001000000 – 0x002000000 (16 MB)
[18:03:05][ 0.836934] kernel: 0x002000000 – 0x003000000 (16 MB)
[18:03:05][ 0.836944] boot: 0x003000000 – 0x005000000 (32 MB)
[18:03:05][ 0.836954] recovery: 0x005000000 – 0x007000000 (32 MB)
[18:03:05][ 0.836964] backup: 0x007000000 – 0x00e000000 (112 MB)
[18:03:05][ 0.836975] cache: 0x00e000000 – 0x016000000 (128 MB)
[18:03:05][ 0.836985] system: 0x016000000 – 0x056000000 (1024 MB)
[18:03:05][ 0.836995] metadata: 0x056000000 – 0x057000000 (16 MB)
[18:03:05][ 0.837005] baseparamer: 0x057000000 – 0x057400000 (4 MB)
[18:03:05][ 0.837016] userdata: 0x057400000 – 0x1d1c00000 (6056 MB)
[18:03:05][ 0.837045] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
[18:03:05][ 1.096795] inv-mpu-iio 4-0068: mpu6500 is ready to go!
[18:03:05][ 1.096898] inv_mpu_iio: inv_mpu_init:744
[18:03:05][ 1.098072] ashmem: initialized
[18:03:05][ 1.100351] ff100000.saradc supply vref not found, using dummy regulator
[18:03:05][ 1.107009] rknandbase v1.1 2016-01-08
[18:03:05][ 1.107939] usbcore: registered new interface driver snd-usb-audio
[18:03:05][ 1.109720] rt5651 1-001a: Device with ID register 0xffffff80 is not rt5651
[18:03:05][ 1.114225] u32 classifier
[18:03:05][ 1.114258] Actions configured
[18:03:05][ 1.114332] Netfilter messages via NETLINK v0.30.
[18:03:05][ 1.114449] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[18:03:05][ 1.115101] ctnetlink v0.93: registering with nfnetlink.
[18:03:05][ 1.116500] xt_time: kernel timezone is -0000
[18:03:05][ 1.118423] ip_tables: (C) 2000-2006 Netfilter Core Team
[18:03:05][ 1.118864] arp_tables: (C) 2002 David S. Miller
[18:03:05][ 1.119457] Initializing XFRM netlink socket
[18:03:05][ 1.120607] NET: Registered protocol family 10
[18:03:05][ 1.124698] mip6: Mobile IPv6
[18:03:05][ 1.124786] ip6_tables: (C) 2000-2006 Netfilter Core Team
[18:03:05][ 1.126801] sit: IPv6 over IPv4 tunneling driver
[18:03:05][ 1.127874] NET: Registered protocol family 17
[18:03:05][ 1.127945] NET: Registered protocol family 15
[18:03:05][ 1.128040] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[18:03:05][ 1.129821] Bridge firewalling registered
[18:03:05][ 1.129853] Ebtables v2.0 registered
[18:03:05][ 1.130315] Bluetooth: RFCOMM TTY layer initialized
[18:03:05][ 1.130352] Bluetooth: RFCOMM socket layer initialized
[18:03:05][ 1.130410] Bluetooth: RFCOMM ver 1.11
[18:03:05][ 1.130453] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[18:03:05][ 1.130472] Bluetooth: BNEP filters: protocol multicast
[18:03:05][ 1.130501] Bluetooth: BNEP socket layer initialized
[18:03:05][ 1.130527] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[18:03:05][ 1.130553] Bluetooth: HIDP socket layer initialized
[18:03:05][ 1.130637] l2tp_core: L2TP core driver, V2.0
[18:03:05][ 1.130679] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[18:03:05][ 1.130715] [WLAN_RFKILL]: Enter rfkill_wlan_init
[18:03:05][ 1.131272] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[18:03:05][ 1.131400] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354
[18:03:05][ 1.131421] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[18:03:05][ 1.131441] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[18:03:05][ 1.131466] of_get_named_gpiod_flags: can’t parse ‘WIFI,poweren_gpio’ property of node ‘/wireless-wlan[0]’
[18:03:05][ 1.131539] of_get_named_gpiod_flags: parsed ‘WIFI,host_wake_irq’ property of node ‘/wireless-wlan[0]’ - status (0)
[18:03:05][ 1.131555] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[18:03:05][ 1.131575] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[18:03:05][ 1.131615] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[18:03:05][ 1.131814] [BT_RFKILL]: Enter rfkill_rk_init
[18:03:05][ 1.132478] sensor_register_slave:mpu6880_gyro,id=47
[18:03:05][ 1.133731] Registered cp15_barrier emulation handler
[18:03:05][ 1.133899] Registered setend emulation handler
[18:03:05][ 1.134037] schedtune: init normalization constants…
[18:03:05][ 1.134066] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[18:03:05][ 1.134089] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[18:03:05][ 1.134111] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[18:03:05][ 1.134132] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[18:03:05][ 1.134154] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[18:03:05][ 1.134177] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[18:03:05][ 1.134198] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[18:03:05][ 1.134220] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[18:03:05][ 1.134240] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[18:03:05][ 1.134261] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[18:03:05][ 1.134279] schedtune: verify normalization constants…
[18:03:05][ 1.134298] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[18:03:05][ 1.134316] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[18:03:05][ 1.134333] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[18:03:05][ 1.134351] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[18:03:05][ 1.134370] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[18:03:05][ 1.134387] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[18:03:05][ 1.135997] registered taskstats version 1
[18:03:05][ 1.148779] Freeing logo memory: 32768K (ffffffc07dc00000 - ffffffc07fc00000)
[18:03:05][ 1.152634] vdd_gpu: supplied by vcc5v0_sys
[18:03:05][ 1.159206] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[18:03:05][ 1.160814] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 265; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[18:03:05][ 1.161787] mali ff9a0000.gpu: Probed as mali0
[18:03:05][ 1.166609] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[18:03:05][ 1.166666] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 5
[18:03:05][ 1.167026] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00030010
[18:03:05][ 1.167116] xhci-hcd xhci-hcd.1.auto: irq 232, io mem 0xfe800000
[18:03:05][ 1.167357] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[18:03:05][ 1.167388] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[18:03:05][ 1.167414] usb usb5: Product: xHCI Host Controller
[18:03:05][ 1.167435] usb usb5: Manufacturer: Linux 4.4.16 xhci-hcd
[18:03:05][ 1.167456] usb usb5: SerialNumber: xhci-hcd.1.auto
[18:03:05][ 1.168401] hub 5-0:1.0: USB hub found
[18:03:05][ 1.168465] hub 5-0:1.0: 1 port detected
[18:03:05][ 1.168949] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[18:03:05][ 1.168985] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 6
[18:03:05][ 1.169100] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[18:03:05][ 1.169268] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[18:03:05][ 1.169295] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[18:03:05][ 1.169319] usb usb6: Product: xHCI Host Controller
[18:03:05][ 1.169339] usb usb6: Manufacturer: Linux 4.4.16 xhci-hcd
[18:03:05][ 1.169360] usb usb6: SerialNumber: xhci-hcd.1.auto
[18:03:05][ 1.170219] hub 6-0:1.0: USB hub found
[18:03:05][ 1.170284] hub 6-0:1.0: 1 port detected
[18:03:06][ 1.172660] xhci-hcd xhci-hcd.1.auto: remove, state 1
[18:03:06][ 1.172707] usb usb6: USB disconnect, device number 1
[18:03:06][ 1.201622] xhci-hcd xhci-hcd.1.auto: Host not halted after 16000 microseconds.
[18:03:06][ 1.201653] xhci-hcd xhci-hcd.1.auto: Host controller not halted, aborting reset.
[18:03:06][ 1.201725] xhci-hcd xhci-hcd.1.auto: USB bus 6 deregistered
[18:03:06][ 1.201760] xhci-hcd xhci-hcd.1.auto: remove, state 1
[18:03:06][ 1.201803] usb usb5: USB disconnect, device number 1
[18:03:06][ 1.202574] xhci-hcd xhci-hcd.1.auto: USB bus 5 deregistered
[18:03:06][ 1.203125] ehci-platform fe380000.usb: EHCI Host Controller
[18:03:06][ 1.203160] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[18:03:06][ 1.203351] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[18:03:06][ 1.212311] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[18:03:06][ 1.212484] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[18:03:06][ 1.212506] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[18:03:06][ 1.212524] usb usb5: Product: EHCI Host Controller
[18:03:06][ 1.212539] usb usb5: Manufacturer: Linux 4.4.16 ehci_hcd
[18:03:06][ 1.212553] usb usb5: SerialNumber: fe380000.usb
[18:03:06][ 1.213267] hub 5-0:1.0: USB hub found
[18:03:06][ 1.213315] hub 5-0:1.0: 1 port detected
[18:03:06][ 1.214078] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[18:03:06][ 1.214113] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[18:03:06][ 1.214279] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[18:03:06][ 1.272532] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[18:03:06][ 1.272598] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[18:03:06][ 1.272626] usb usb6: Product: Generic Platform OHCI controller
[18:03:06][ 1.272650] usb usb6: Manufacturer: Linux 4.4.16 ohci_hcd
[18:03:06][ 1.272671] usb usb6: SerialNumber: fe3a0000.usb
[18:03:06][ 1.275875] hub 6-0:1.0: USB hub found
[18:03:06][ 1.275979] hub 6-0:1.0: 1 port detected
[18:03:06][ 1.278818] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[18:03:06][ 1.279068] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[18:03:06][ 1.279107] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[18:03:06][ 1.279172] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[18:03:06][ 1.279289] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[18:03:06][ 1.279315] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[18:03:06][ 1.279356] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp
[18:03:06][ 1.279373] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup
[18:03:06][ 1.279394] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@fe310000[0]’
[18:03:06][ 1.279413] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@fe310000[0]’
[18:03:06][ 1.279430] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup
[18:03:06][ 1.279449] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
[18:03:06][ 1.279778] platform sdio-pwrseq: GPIO lookup for consumer reset
[18:03:06][ 1.279795] platform sdio-pwrseq: using device tree for GPIO lookup
[18:03:06][ 1.279846] of_get_named_gpiod_flags: parsed ‘reset-gpios’ property of node ‘/sdio-pwrseq[0]’ - status (0)
[18:03:06][ 1.279921] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[18:03:06][ 1.296396] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[18:03:06][ 1.312460] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[18:03:06][ 1.313425] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,hp-det-gpio’ property of node ‘/hdmi-sound[0]’
[18:03:06][ 1.313446] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,mic-det-gpio’ property of node ‘/hdmi-sound[0]’
[18:03:06][ 1.314436] asoc-simple-card hdmi-sound: dw-hdmi-hifi ↔ ff8a0000.i2s mapping ok
[18:03:06][ 1.316740] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,hp-det-gpio’ property of node ‘/spdif-sound[0]’
[18:03:06][ 1.316758] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,mic-det-gpio’ property of node ‘/spdif-sound[0]’
[18:03:06][ 1.317711] asoc-simple-card spdif-sound: dit-hifi ↔ ff870000.spdif mapping ok
[18:03:06][ 1.320298] otg_wakelock_init: No USB transceiver found
[18:03:06][ 1.320385] dhd_module_init: in
[18:03:06][ 1.320413] DQ_WCRD 0
[18:03:06][ 1.320429] DQ_WCRD 6
[18:03:06][ 1.320444] DQ_WCRD 11
[18:03:06][ 1.320457] DQ_WCRD 12
[18:03:06][ 1.320469] DQ_WCRD 13
[18:03:06][ 1.320484] adapter->wifi_plat_data: 0
[18:03:06][ 1.320501] ======== bcm_wlan_set_plat_data ========
[18:03:06][ 1.320517] DQ_WCRD 14
[18:03:06][ 1.320533] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[18:03:06][ 1.320554] host_oob_irq: 62
[18:03:06][ 1.320569] irq_num: 62
[18:03:06][ 1.320583] host_oob_irq_flags=0x4
[18:03:06][ 1.320594] sensor_init: Probe name sensors
[18:03:06][ 1.320610] intr_flags: 4
[18:03:06][ 1.320615] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[18:03:06][ 1.320644] DQ_WCRD 16
[18:03:06][ 1.320657] dhd_wifi_platform_load: Enter
[18:03:06][ 1.320700] DQ_DWPLS 0
[18:03:06][ 1.320712] DQ_DWPLS 1
[18:03:06][ 1.320724] DQ_DWPLS 2
[18:03:06][ 1.320739] dhd_wifi_platdata->num_adapters: 1
[18:03:06][ 1.320755] retry: 1
[18:03:06][ 1.320769] Power-up adapter ‘DHD generic adapter’
[18:03:06][ 1.320786] aaa DQ_DT_sem->count: 0
[18:03:06][ 1.320800] bbb DQ_DT_sem->count: 0
[18:03:06][ 1.320871] err: 0
[18:03:06][ 1.320886] ccc DQ_DT_sem->count: 0
[18:03:06][ 1.320901] ddd DQ_DT_sem->count: 0
[18:03:06][ 1.320914] DQ_WPSP 2
[18:03:06][ 1.320928] 139596516DQ_WPSP 3
[18:03:06][ 1.320950] wifi_platform_set_power = 1
[18:03:06][ 1.320964] DQ_WPSP 3.0
[18:03:06][ 1.320977] DQ_WPSP 3.1
[18:03:06][ 1.320991] ======== PULL WL_REG_ON HIGH! ========
[18:03:06][ 1.321009] [WLAN_RFKILL]: rockchip_wifi_power: 1
[18:03:06][ 1.321028] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[18:03:06][ 1.321054] poweron.io:-1, poweron.enable:0, poweron.iomux.fgpio: 0, poweron.iomux.fmux: 0
[18:03:06][ 1.321078] reset.io:0, reset.enable:0, reset.iomux.fgpio: 0, reset.iomux.fmux: 0
[18:03:06][ 1.321096] DQ_RWP 16
[18:03:06][ 1.321109] DQ_RWP 20
[18:03:06][ 1.321133] reset.io:0, reset.enable:0
[18:03:06][ 1.321569] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:02 UTC (1358499002)
[18:03:06][ 1.353202] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/rockchip-key/power-key[0]’ - status (0)
[18:03:06][ 1.353229] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/rockchip-key/power-key[0]’ - status (0)
[18:03:06][ 1.353410] input: rk29-keypad as /devices/platform/rockchip-key/input/input1
[18:03:06][ 1.354455] SNDRV_CARDS: 32
[18:03:06][ 1.354473] ALSA device list:
[18:03:06][ 1.354481] #0: rockchip,hdmi
[18:03:06][ 1.354488] #1: ROCKCHIP,SPDIF
[18:03:06][ 1.354967] Freeing unused kernel memory: 768K (ffffff8008e00000 - ffffff8008ec0000)
[18:03:06][ 1.356284] init: error to open scaling_available_frequenciesinit: OK,EMMC DRIVERS INIT OK
[18:03:06][ 1.359846] init: property_set(“ro.boot.mode”, “emmc”) failed
[18:03:06][ 1.359876] init: property_set(“ro.hardware”, “rk30board”) failed
[18:03:06][ 1.360029] init: waitpid failed: No child processes
[18:03:06][ 1.362432] init: could not import file ‘/init.stt_trace.rc’ from ‘/init.debug.rc’
[18:03:06][ 1.363049] init: init.box.rc: 1: ignored duplicate definition of service ‘media’
[18:03:06][ 1.363086] init: could not import file ‘init.car.rc’ from ‘/init.rk30board.rc’
[18:03:06][ 1.364645] ueventd: ueventd started!
[18:03:06][ 1.364960] ueventd: invalid gid ‘trace’
[18:03:06][ 1.409060] ueventd: Coldboot took 0.04s.
[18:03:06][ 1.414611] init: /dev/hw_random not found
[18:03:06][ 1.414692] keychord: using input dev ff420030.pwm for fevent
[18:03:06][ 1.414703] keychord: using input dev rk29-keypad for fevent
[18:03:06][ 1.418141] Registered swp emulation handler
[18:03:06][ 1.418449] init: /dev/hw_random not found
[18:03:06][ 1.419323] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/fe330000.sdhci/by-name/system
[18:03:06][ 1.420517] resize2fs: resize2fs 1.42.9 (28-Dec-2013)
[18:03:06][ 1.421433] resize2fs: The filesystem is already 262144 blocks long. Nothing to do!
[18:03:06][ 1.422140] resize2fs:
[18:03:06][ 1.424861] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[18:03:06][ 1.425679] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/system,target=/system,type=ext4)=0
[18:03:06][ 1.426141] EXT4-fs (mmcblk0p9): Ignoring removed nomblk_io_submit option
[18:03:06][ 1.428189] DQ_RWP 22
[18:03:06][ 1.428198] DQ_RWP 22.11
[18:03:06][ 1.428202] [WLAN_RFKILL]: wifi turn on power. -1
[18:03:06][ 1.428207] DQ_RWP 28
[18:03:06][ 1.428210] DQ_BWSP 0
[18:03:06][ 1.428214] DQ_WPSP 5
[18:03:06][ 1.433047] EXT4-fs (mmcblk0p9): recovery complete
[18:03:06][ 1.433588] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[18:03:06][ 1.433619] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/cache,/cache,ext4)=0: Success
[18:03:06][ 1.445730] fs_mgr: check_fs(): unmount(/cache) succeeded
[18:03:06][ 1.446247] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/cache
[18:03:06][ 1.481468] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[18:03:06][ 1.481525] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: clean, 12/8192 files, 1551/32768 blocks
[18:03:06][ 1.484767] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[18:03:06][ 1.484807] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/cache,target=/cache,type=ext4)=0
[18:03:06][ 1.485109] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
[18:03:06][ 1.487556] EXT4-fs (mmcblk0p11): recovery complete
[18:03:06][ 1.487570] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[18:03:06][ 1.487594] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/metadata,/metadata,ext4)=0: Success
[18:03:06][ 1.497549] fs_mgr: check_fs(): unmount(/metadata) succeeded
[18:03:06][ 1.497574] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/metadata
[18:03:06][ 1.505590] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[18:03:06][ 1.505626] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
[18:03:06][ 1.508876] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[18:03:06][ 1.508916] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/metadata,target=/metadata,type=ext4)=0
[18:03:06][ 1.508953] fs_mgr: Running /system/bin/fsck.f2fs -a /dev/block/platform/fe330000.sdhci/by-name/userdata
[18:03:06][ 1.515803] fsck.f2fs: Info: Fix the reported corruption.
[18:03:06][ 1.515836] fsck.f2fs: Info: sector size = 512
[18:03:06][ 1.515845] fsck.f2fs: Info: total sectors = 12402688 (in 512 bytes)
[18:03:06][ 1.515853] fsck.f2fs: Info: MKFS version
[18:03:06][ 1.515862] fsck.f2fs: “Linux version 4.4.16 (qdeng@CRI-HZ) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #37 SMP PREEMPT Wed Mar 22 11:02:20 CST 2017”
[18:03:06][ 1.515873] fsck.f2fs: Info: FSCK version
[18:03:06][ 1.515881] fsck.f2fs: from “Linux version 4.4.16 (qdeng@CRI-HZ) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #93 SMP PREEMPT Wed Mar 29 17:16:15 CST 2017”
[18:03:06][ 1.515892] fsck.f2fs: to “Linux version 4.4.16 (qdeng@CRI-HZ) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #93 SMP PREEMPT Wed Mar 29 17:16:15 CST 2017”
[18:03:06][ 1.515903] fsck.f2fs:
[18:03:06][ 1.515910] fsck.f2fs: Done.
[18:03:06][ 1.576526] F2FS-fs (mmcblk0p13): recover_inode: ino = 14ee, name = .booting
[18:03:06][ 1.576552] F2FS-fs (mmcblk0p13): recover_data: ino = 14ee, recovered = 0 blocks, err = 0
[18:03:06][ 1.576573] F2FS-fs (mmcblk0p13): recover_inode: ino = 14ef, name = .booting
[18:03:06][ 1.576585] F2FS-fs (mmcblk0p13): recover_data: ino = 14ef, recovered = 0 blocks, err = 0
[18:03:06][ 1.576595] F2FS-fs (mmcblk0p13): recover_inode: ino = 1517, name = .temp.izI8NZ
[18:03:06][ 1.580859] F2FS-fs (mmcblk0p13): recover_dentry: ino = 1517, name = .temp.izI8NZ, dir = 25, err = 0
[18:03:06][ 1.580883] F2FS-fs (mmcblk0p13): recover_data: ino = 1517, recovered = 0 blocks, err = 0
[18:03:06][ 1.580897] F2FS-fs (mmcblk0p13): recover_inode: ino = 1518, name = batterystats.bin.tmp
[18:03:06][ 1.583632] F2FS-fs (mmcblk0p13): recover_dentry: ino = 1518, name = batterystats.bin.tmp, dir = 32, err = 0
[18:03:06][ 1.583668] F2FS-fs (mmcblk0p13): recover_data: ino = 1518, recovered = 5 blocks, err = 0
[18:03:06][ 1.583682] F2FS-fs (mmcblk0p13): recover_inode: ino = 1519, name = userlist.xml
[18:03:06][ 1.586394] F2FS-fs (mmcblk0p13): recover_dentry: ino = 1519, name = userlist.xml, dir = 9b, err = 0
[18:03:06][ 1.586417] F2FS-fs (mmcblk0p13): recover_data: ino = 1519, recovered = 0 blocks, err = 0
[18:03:06][ 1.586428] F2FS-fs (mmcblk0p13): recover_inode: ino = 1521, name = packages.xml
[18:03:06][ 1.588580] F2FS-fs (mmcblk0p13): recover_dentry: ino = 1521, name = packages.xml, dir = 32, err = 0
[18:03:06][ 1.588652] F2FS-fs (mmcblk0p13): recover_data: ino = 1521, recovered = 61 blocks, err = 0
[18:03:06][ 1.588663] F2FS-fs (mmcblk0p13): recover_inode: ino = 1522, name = packages.list.tmp
[18:03:06][ 1.590797] F2FS-fs (mmcblk0p13): recover_dentry: ino = 1522, name = packages.list.tmp, dir = 32, err = 0
[18:03:06][ 1.590827] F2FS-fs (mmcblk0p13): recover_data: ino = 1522, recovered = 2 blocks, err = 0
[18:03:06][ 1.590839] F2FS-fs (mmcblk0p13): recover_inode: ino = 1523, name = package-restrictions.xml
[18:03:06][ 1.593642] F2FS-fs (mmcblk0p13): recover_dentry: ino = 1523, name = package-restrictions.xml, dir = 9c, err = 0
[18:03:06][ 1.593664] F2FS-fs (mmcblk0p13): recover_data: ino = 1523, recovered = 0 blocks, err = 0
[18:03:06][ 1.593675] F2FS-fs (mmcblk0p13): recover_inode: ino = 1524, name = accounts.xml
[18:03:06][ 1.596425] F2FS-fs (mmcblk0p13): recover_dentry: ino = 1524, name = accounts.xml, dir = 18e, err = 0
[18:03:06][ 1.596446] F2FS-fs (mmcblk0p13): recover_data: ino = 1524, recovered = 0 blocks, err = 0
[18:03:06][ 1.596457] F2FS-fs (mmcblk0p13): recover_inode: ino = 1525, name = status.bin
[18:03:06][ 1.598579] F2FS-fs (mmcblk0p13): recover_dentry: ino = 1525, name = status.bin, dir = 18e, err = 0
[18:03:06][ 1.598600] F2FS-fs (mmcblk0p13): recover_data: ino = 1525, recovered = 0 blocks, err = 0
[18:03:06][ 1.598611] F2FS-fs (mmcblk0p13): recover_inode: ino = 193, name = pending.xml
[18:03:06][ 1.598622] F2FS-fs (mmcblk0p13): recover_data: ino = 193, recovered = 0 blocks, err = 0
[18:03:06][ 1.598632] F2FS-fs (mmcblk0p13): recover_inode: ino = 1526, name = stats.bin
[18:03:06][ 1.598994] F2FS-fs (mmcblk0p13): recover_dentry: ino = 1526, name = stats.bin, dir = 18e, err = 0
[18:03:06][ 1.599014] F2FS-fs (mmcblk0p13): recover_data: ino = 1526, recovered = 0 blocks, err = 0
[18:03:06][ 1.599026] F2FS-fs (mmcblk0p13): recover_inode: ino = 1527, name = .temp.cjc4mG
[18:03:06][ 1.599706] F2FS-fs (mmcblk0p13): recover_dentry: ino = 1527, name = .temp.cjc4mG, dir = 25, err = 0
[18:03:06][ 1.599726] F2FS-fs (mmcblk0p13): recover_data: ino = 1527, recovered = 0 blocks, err = 0
[18:03:06][ 1.599738] F2FS-fs (mmcblk0p13): recover_inode: ino = 1528, name = .temp.3MeAg4
[18:03:06][ 1.599923] F2FS-fs (mmcblk0p13): recover_dentry: ino = 1528, name = .temp.3MeAg4, dir = 25, err = 0
[18:03:06][ 1.599942] F2FS-fs (mmcblk0p13): recover_data: ino = 1528, recovered = 0 blocks, err = 0
[18:03:06][ 1.599954] F2FS-fs (mmcblk0p13): recover_inode: ino = 1529, name = packages.xml
[18:03:06][ 1.599995] F2FS-fs (mmcblk0p13): recover_dentry: ino = 1529, name = packages.xml, dir = 32, err = 0
[18:03:06][ 1.600067] F2FS-fs (mmcblk0p13): recover_data: ino = 1529, recovered = 61 blocks, err = 0
[18:03:06][ 1.600079] F2FS-fs (mmcblk0p13): recover_inode: ino = 152a, name = packages.list.tmp
[18:03:06][ 1.600111] F2FS-fs (mmcblk0p13): recover_dentry: ino = 152a, name = packages.list.tmp, dir = 32, err = 0
[18:03:06][ 1.600131] F2FS-fs (mmcblk0p13): recover_data: ino = 152a, recovered = 2 blocks, err = 0
[18:03:06][ 1.600142] F2FS-fs (mmcblk0p13): recover_inode: ino = 152b, name = package-restrictions.xml
[18:03:06][ 1.600168] F2FS-fs (mmcblk0p13): recover_dentry: ino = 152b, name = package-restrictions.xml, dir = 9c, err = 0
[18:03:06][ 1.600202] F2FS-fs (mmcblk0p13): recover_data: ino = 152b, recovered = 0 blocks, err = 0
[18:03:06][ 1.600214] F2FS-fs (mmcblk0p13): recover_inode: ino = 152c, name = runtime-permissions.xml
[18:03:06][ 1.600447] F2FS-fs (mmcblk0p13): recover_dentry: ino = 152c, name = runtime-permissions.xml, dir = 9c, err = 0
[18:03:06][ 1.600472] F2FS-fs (mmcblk0p13): recover_data: ino = 152c, recovered = 2 blocks, err = 0
[18:03:06][ 1.600483] F2FS-fs (mmcblk0p13): recover_inode: ino = 152d, name = .temp.PSUgZf
[18:03:06][ 1.600501] F2FS-fs (mmcblk0p13): recover_dentry: ino = 152d, name = .temp.PSUgZf, dir = 25, err = 0
[18:03:06][ 1.600522] F2FS-fs (mmcblk0p13): recover_data: ino = 152d, recovered = 0 blocks, err = 0
[18:03:06][ 1.600924] F2FS-fs (mmcblk0p13): recover_dentry: ino = 152e, name = journal1592865612.tmp, dir = 24e, err = 0
[18:03:06][ 1.600943] F2FS-fs (mmcblk0p13): recover_data: ino = 152e, recovered = 0 blocks, err = 0
[18:03:06][ 1.600954] F2FS-fs (mmcblk0p13): recover_data: ino = 152e, recovered = 0 blocks, err = 0
[18:03:06][ 1.600964] F2FS-fs (mmcblk0p13): recover_data: ino = 152e, recovered = 0 blocks, err = 0
[18:03:06][ 1.600974] F2FS-fs (mmcblk0p13): recover_data: ino = 152e, recovered = 0 blocks, err = 0
[18:03:06][ 1.600983] F2FS-fs (mmcblk0p13): recover_data: ino = 152e, recovered = 0 blocks, err = 0
[18:03:06][ 1.600990] F2FS-fs (mmcblk0p13): recover_inode: ino = 152e, name = journal1592865612.tmp
[18:03:06][ 1.600999] F2FS-fs (mmcblk0p13): recover_data: ino = 152e, recovered = 0 blocks, err = 0
[18:03:06][ 1.601010] F2FS-fs (mmcblk0p13): recover_inode: ino = 1530, name = .temp.7Ezct8
[18:03:06][ 1.601028] F2FS-fs (mmcblk0p13): recover_dentry: ino = 1530, name = .temp.7Ezct8, dir = 25, err = 0
[18:03:06][ 1.601045] F2FS-fs (mmcblk0p13): recover_data: ino = 1530, recovered = 0 blocks, err = 0
[18:03:06][ 1.601055] F2FS-fs (mmcblk0p13): recover_inode: ino = 1533, name = wallpaper_info.xml.tmp
[18:03:06][ 1.601266] F2FS-fs (mmcblk0p13): recover_dentry: ino = 1533, name = wallpaper_info.xml.tmp, dir = 9c, err = 0
[18:03:06][ 1.601286] F2FS-fs (mmcblk0p13): recover_data: ino = 1533, recovered = 0 blocks, err = 0
[18:03:06][ 1.601297] F2FS-fs (mmcblk0p13): recover_inode: ino = 1534, name = subtypes.xml
[18:03:06][ 1.601847] F2FS-fs (mmcblk0p13): recover_dentry: ino = 1534, name = subtypes.xml, dir = 196, err = 0
[18:03:06][ 1.601866] F2FS-fs (mmcblk0p13): recover_data: ino = 1534, recovered = 0 blocks, err = 0
[18:03:06][ 1.601877] F2FS-fs (mmcblk0p13): recover_inode: ino = 1535, name = .temp.Tv97wX
[18:03:06][ 1.601898] F2FS-fs (mmcblk0p13): recover_dentry: ino = 1535, name = .temp.Tv97wX, dir = 25, err = 0
[18:03:06][ 1.601914] F2FS-fs (mmcblk0p13): recover_data: ino = 1535, recovered = 0 blocks, err = 0
[18:03:06][ 1.601925] F2FS-fs (mmcblk0p13): recover_inode: ino = 1536, name = 0.xml
[18:03:06][ 1.602116] F2FS-fs (mmcblk0p13): recover_dentry: ino = 1536, name = 0.xml, dir = 9b, err = 0
[18:03:06][ 1.602134] F2FS-fs (mmcblk0p13): recover_data: ino = 1536, recovered = 0 blocks, err = 0
[18:03:06][ 1.619889] F2FS-fs (mmcblk0p13): checkpoint: version = a00
[18:03:06][ 1.619990] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/userdata,target=/data,type=f2fs)=0
[18:03:06][ 1.625088] init: property_set(“ro.opengles.version”, “196609”) failed
[18:03:06][ 1.626389] init: property_set(“ro.rk.screenoff_time”, “2147483647”) failed
[18:03:06][ 1.627656] init: /recovery not specified in fstab
[18:03:06][ 1.628186] DQ_WPSP 6
[18:03:06][ 1.628191] DQ_WPSP 7
[18:03:06][ 1.628195] DQ_WPSP 8
[18:03:06][ 1.628199] err: 0
[18:03:06][ 1.628202] eee DQ_DT_sem->count: 0
[18:03:06][ 1.628207] wifi_platform_bus_enumerate device present 1
[18:03:06][ 1.628212] ======== Card detection to detect SDIO card! ========
[18:03:06][ 1.628218] mmc2:mmc host rescan start!
[18:03:06][ 1.628223] err: 0
[18:03:06][ 1.628226] fff DQ_DT_sem->count: 0
[18:03:06][ 1.628230] 111 DQ_DT_sem->count: 0
[18:03:06][ 1.628234] 222 DQ_DT_sem->count: 0
[18:03:06][ 1.630366] bat_cap: oldcap_path no exist
[18:03:06][ 1.630452] binder: 225:225 transaction failed 29189, size 0-0
[18:03:06][ 1.631124] init: cannot find ‘/system/vendor/bin/pvrsrvctl’, disabling ‘pvrsrvctl’
[18:03:06][ 1.646375] zram0: detected capacity change from 0 to 533413888
[18:03:06][ 1.660079] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[18:03:06][ 1.668788] logd.auditd: start
[18:03:06][ 1.668814] logd.klogd: 1664633874
[18:03:06][ 1.789812] vendor storage:20160801 ret = 0
[18:03:06][ 1.998913] init: Failed to reload policy
[18:03:06][ 2.106647] F2FS-fs (mmcblk0p13): Unrecognized mount option “seclabel” or missing value
[18:03:06][ 2.123738] rk322x-lcdc vop0: blank mode:0
[18:03:06][ 2.129879] random: init urandom read with 51 bits of entropy available
[18:03:06][ 2.223020] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[18:03:06][ 2.223059] init: cannot expand ‘${ro.serialno}’ while writing to ‘/config/usb_gadget/g1/strings/0x409/serialnumber’
[18:03:06][ 2.223758] file system registered
[18:03:06][ 2.224165] using random self ethernet address
[18:03:06][ 2.224237] using random host ethernet address
[18:03:06][ 2.230205] logd.daemon: reinit
[18:03:06][ 2.233149] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’
[18:03:06][ 2.234738] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
[18:03:06][ 2.249267] eth0: device MAC address 52:6c:29:cf:ac:4f
[18:03:06][ 2.312376] stmmac_open: Cannot attach to PHY (error: -19)
[18:03:06][ 2.481956] read descriptors
[18:03:06][ 2.481997] read strings
[18:03:06][ 2.920295] mmc2: error -110 whilst initialising SDIO card
[18:03:06][ 2.936289] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[18:03:06][ 3.384316] phy phy-ff770000.syscon:usb2-phy@e450.5: charger = USB_SDP_CHARGER
[18:03:06][ 3.628219] failed to power up DHD generic adapter, 1 retry left
[18:03:06][ 3.644273] DQ_WPSP 2
[18:03:06][ 3.644290] 139596516DQ_WPSP 3
[18:03:06][ 3.644298] wifi_platform_set_power = 0
[18:03:06][ 3.644302] DQ_WPSP 3.0
[18:03:06][ 3.644306] DQ_WPSP 3.1
[18:03:06][ 3.644311] ======== PULL WL_REG_ON LOW! ========
[18:03:06][ 3.644318] [WLAN_RFKILL]: rockchip_wifi_power: 0
[18:03:06][ 3.644477] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[18:03:06][ 3.644498] poweron.io:-1, poweron.enable:0, poweron.iomux.fgpio: 0, poweron.iomux.fmux: 0
[18:03:06][ 3.644506] reset.io:0, reset.enable:0, reset.iomux.fgpio: 0, reset.iomux.fmux: 0
[18:03:06][ 3.644512] DQ_RWP 16
[18:03:06][ 3.644519] DQ_RWP 26
[18:03:06][ 3.644530] reset.io:0, reset.enable:0
[18:03:06][ 3.644535] DQ_RWP 27
[18:03:06][ 3.644540] [WLAN_RFKILL]: wifi shut off power.
[18:03:06][ 3.644545] DQ_RWP 28
[18:03:06][ 3.644550] DQ_WPSP 5
[18:03:06][ 3.644555] DQ_WPSP 8
[18:03:06][ 3.644560] wifi_platform_bus_enumerate device present 0
[18:03:06][ 3.644566] ======== Card detection to remove SDIO card! ========
[18:03:06][ 3.644573] mmc2:mmc host rescan start!
[18:03:06][ 3.644580] aaa DQ_DT_sem->count: 0
[18:03:06][ 3.644584] bbb DQ_DT_sem->count: 0
[18:03:06][ 3.644704] err: 0
[18:03:06][ 3.644710] ccc DQ_DT_sem->count: 0
[18:03:06][ 3.644716] ddd DQ_DT_sem->count: 0
[18:03:06][ 3.644722] DQ_WPSP 2
[18:03:06][ 3.644728] 139596516DQ_WPSP 3
[18:03:06][ 3.644737] wifi_platform_set_power = 1
[18:03:06][ 3.644742] DQ_WPSP 3.0
[18:03:06][ 3.644747] DQ_WPSP 3.1
[18:03:06][ 3.644752] ======== PULL WL_REG_ON HIGH! ========
[18:03:06][ 3.644758] [WLAN_RFKILL]: rockchip_wifi_power: 1
[18:03:06][ 3.644765] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[18:03:06][ 3.644776] poweron.io:-1, poweron.enable:0, poweron.iomux.fgpio: 0, poweron.iomux.fmux: 0
[18:03:06][ 3.644789] reset.io:0, reset.enable:0, reset.iomux.fgpio: 0, reset.iomux.fmux: 0
[18:03:06][ 3.644796] DQ_RWP 16
[18:03:06][ 3.644804] DQ_RWP 20
[18:03:06][ 3.644811] reset.io:0, reset.enable:0
[18:03:06][ 3.648835] capability: warning: `Thread-6’ uses 32-bit capabilities (legacy support in use)
[18:03:06][ 3.652666] mmc2: error -110 whilst initialising SDIO card
[18:03:06][ 3.668352] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[18:03:06][ 3.748198] DQ_RWP 22
[18:03:06][ 3.748223] DQ_RWP 22.11
[18:03:06][ 3.748230] [WLAN_RFKILL]: wifi turn on power. -1
[18:03:06][ 3.748237] DQ_RWP 28
[18:03:06][ 3.748242] DQ_BWSP 0
[18:03:06][ 3.748246] DQ_WPSP 5
[18:03:06][ 3.952310] DQ_WPSP 6
[18:03:06][ 3.952345] DQ_WPSP 7
[18:03:06][ 3.952351] DQ_WPSP 8
[18:03:06][ 3.952358] err: 0
[18:03:06][ 3.952364] eee DQ_DT_sem->count: 0
[18:03:06][ 3.952373] wifi_platform_bus_enumerate device present 1
[18:03:06][ 3.952381] ======== Card detection to detect SDIO card! ========
[18:03:06][ 3.952391] mmc2:mmc host rescan start!
[18:03:06][ 3.952397] err: 0
[18:03:06][ 3.952401] fff DQ_DT_sem->count: 0
[18:03:06][ 3.952407] 111 DQ_DT_sem->count: 0
[18:03:06][ 3.952412] 222 DQ_DT_sem->count: 0
[18:03:06][ 4.046178] zram: 579 (system_server) Attribute mem_used_total (and others) will be removed. See zram documentation.
[18:03:06][ 4.861477] random: nonblocking pool is initialized
[18:03:06][ 5.312343] mmc2: error -110 whilst initialising SDIO card
[18:03:06][ 5.956289] failed to power up DHD generic adapter, 0 retry left
[18:03:06][ 5.972405] DQ_WPSP 2
[18:03:06][ 5.972441] 139596516DQ_WPSP 3
[18:03:06][ 5.972451] wifi_platform_set_power = 0
[18:03:06][ 5.972456] DQ_WPSP 3.0
[18:03:06][ 5.972462] DQ_WPSP 3.1
[18:03:06][ 5.972467] ======== PULL WL_REG_ON LOW! ========
[18:03:06][ 5.972475] [WLAN_RFKILL]: rockchip_wifi_power: 0
[18:03:06][ 5.972493] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[18:03:06][ 5.972503] poweron.io:-1, poweron.enable:0, poweron.iomux.fgpio: 0, poweron.iomux.fmux: 0
[18:03:06][ 5.972510] reset.io:0, reset.enable:0, reset.iomux.fgpio: 0, reset.iomux.fmux: 0
[18:03:06][ 5.972516] DQ_RWP 16
[18:03:06][ 5.972522] DQ_RWP 26
[18:03:06][ 5.972530] reset.io:0, reset.enable:0
[18:03:06][ 5.972535] DQ_RWP 27
[18:03:06][ 5.972539] [WLAN_RFKILL]: wifi shut off power.
[18:03:06][ 5.972544] DQ_RWP 28
[18:03:06][ 5.972549] DQ_WPSP 5
[18:03:06][ 5.972553] DQ_WPSP 8
[18:03:06][ 5.972558] wifi_platform_bus_enumerate device present 0
[18:03:06][ 5.972563] ======== Card detection to remove SDIO card! ========
[18:03:06][ 5.972570] mmc2:mmc host rescan start!
[18:03:06][ 5.972577] failed to power up DHD generic adapter, max retry reached**
[18:03:06][ 5.972610] DQ_WCRD 17
[18:03:06][ 5.972615] DQ_WCRD 19
[18:03:06][ 5.972620] unregister wifi platform drivers
[18:03:06][ 5.972625] wifi_platform_bus_enumerate device present 0
[18:03:06][ 5.972631] ======== Card detection to remove SDIO card! ========
[18:03:06][ 5.972637] mmc2:mmc host rescan start!
[18:03:06][ 5.972644] dhd_module_init: Failed to load the driver, try cnt 0
[18:03:06][ 5.972670] dhd_module_init: Failed to load driver max retry reached**
[18:03:06][ 5.972676] dhd_module_init: Exit err=-19
[18:03:06][ 6.222896] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au 2013-01-18 08:50:07.401068669 UTC
[18:03:06][ 6.326002] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
[18:03:06][ 6.326044] lowmemorykiller: oom_adj 0 => oom_score_adj 0
[18:03:06][ 6.326051] lowmemorykiller: oom_adj 1 => oom_score_adj 58
[18:03:06][ 6.326057] lowmemorykiller: oom_adj 2 => oom_score_adj 117
[18:03:06][ 6.326063] lowmemorykiller: oom_adj 3 => oom_score_adj 176
[18:03:06][ 6.326070] lowmemorykiller: oom_adj 9 => oom_score_adj 529
[18:03:06][ 6.326076] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
[18:03:06][ 6.586155] acc_open
[18:03:06][ 6.586176] acc_release
[18:03:06][ 6.729373] Current WiFi chip is AP6354.
[18:03:06][ 6.940462] stmmac_open: Cannot attach to PHY (error: -19)
[18:03:06][ 8.526298] init: cannot find ‘/system/bin/glgps’, disabling ‘gpsd’
哪位大神能指点一下吗?谢谢了!
