添加2592x1944分辨率后,进入相机黑屏重启
log显示vpu一直在复位
<14>[ 2.286041] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
<4>[ 2.286336] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
<6>[ 2.336430] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
<4>[ 2.336462] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
<4>[ 2.336556] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
<4>[ 2.338382] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
<6>[ 2.338415] mmc2: new high speed SDIO card at address 0001
<6>[ 2.352384] EXT4-fs (mmcblk0p13): recovery complete
<6>[ 2.352794] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 2.352819] SELinux: initialized (dev mmcblk0p13, type ext4), uses xattr
<14>[ 2.352874] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
<14>[ 2.354553] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
<4>[ 2.354634] bcmsdh_register: register client driver
<4>[ 2.354740] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
<4>[ 2.354823] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
<4>[ 2.354839] bus num (host idx)=2, slot num (rca)=1
<4>[ 2.354851] found adapter info ‘DHD generic adapter’
<4>[ 2.355100] F1 signature read @0x18000000=0x16224335
<4>[ 2.357077] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
<4>[ 2.357381] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
<4>[ 2.357427] wifi_platform_get_mac_addr
<4>[ 2.357447] ======== bcm_wlan_get_mac_address ========
<6>[ 2.357457] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
<6>[ 2.357471] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
<6>[ 2.357478] [WLAN_RFKILL]: This mac address is not valid, ignored…
<4>[ 2.357490] dhd_conf_set_chiprev: chip=0x4339, chiprev=1
<4>[ 2.357535] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
<4>[ 2.357880] wl_create_event_handler(): thread:wl_event_handler:97 started
<4>[ 2.358001] tsk Enter, tsk = 0xc5bc149c
<4>[ 2.358352] dhd_attach(): thread:dhd_watchdog_thread:98 started
<4>[ 2.358405] dhd_attach(): thread:dhd_dpc:99 started
<4>[ 2.358451] dhd_attach(): thread:dhd_rxf:9a started
<4>[ 2.358469] dhd_deferred_work_init: work queue initialized
<4>[ 2.358688] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
<4>[ 2.358774] dhdsdio_probe_init: set use_rxchain 1 from config.txt
<14>[ 2.359428] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 2.359463] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 539/65536 files, 24908/262144 blocks
<6>[ 2.363458] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
<7>[ 2.363482] SELinux: initialized (dev mmcblk0p13, type ext4), uses xattr
<14>[ 2.363526] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
<11>[ 2.363547] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs
<7>[ 2.364187] SELinux: initialized (dev functionfs, type functionfs), uses genfs_contexts
<4>[ 2.364630] Dongle Host Driver, version 1.201.59.5 (r506368)
<4>[ 2.364630] Compiled in drivers/net/wireless/bcmdhd on Mar 22 2017 at 09:44:28
<4>[ 2.364994] Register interface [wlan0] MAC: ac:83:f3:ab:1b:c5
<4>[ 2.364994]
<4>[ 2.365016] dhd_prot_ioctl : bus is down. we have nothing to do
<4>[ 2.365053] bcmsdh_oob_intr_unregister: Enter
<4>[ 2.365060] bcmsdh_oob_intr_unregister: irq is not registered
<4>[ 2.365070] dhd_txglom_enable: enable 0
<4>[ 2.365077] dhd_bus_devreset: WLAN OFF DONE
<4>[ 2.365113] wifi_platform_set_power = 0
<4>[ 2.365120] ======== PULL WL_REG_ON LOW! ========
<6>[ 2.365127] [WLAN_RFKILL]: rockchip_wifi_power: 0
<6>[ 2.377312] arm_release_ver of this mali_ko is ‘r6p0-02rel0’, rk_ko_ver is ‘13’, built at ‘09:15:10’, on ‘Oct 22 2015’.
<6>[ 2.377393] mali ffa30000.gpu: Continuing without Mali clock control
<4>[ 2.377440] mali pd enabled
<4>[ 2.377452] clk enabled
<4>[ 2.377465] MALI_DVFS_STEP = 4, div_dvfs = 10
<6>[ 2.377475] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
<6>[ 2.377485] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
<6>[ 2.377496] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
<6>[ 2.377506] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
<3>[ 2.377613] turn on mali power
<6>[ 2.377627] kbase_platform_rk_init,register_reboot_notifier
<4>[ 2.377671] hrtimer: interrupt took 13125 ns
<6>[ 2.377794] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
<6>[ 2.380056] mali ffa30000.gpu: Probed as mali0
<3>[ 2.381043] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<3>[ 2.381652] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<3>[ 2.382226] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<6>[ 2.383026] zram0: detected capacity change from 0 to 533413888
<6>[ 2.429921] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
<3>[ 2.458985] EXT4-fs (mmcblk0p13): Unrecognized mount option “background_gc=on” or missing value
<6>[ 2.467406] [WLAN_RFKILL]: wifi shut off power.
<6>[ 2.467427] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
<6>[ 2.467438] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<4>[ 2.467501] dhd_module_init: Exit err=0
<14>[ 2.467820] bat_cap: oldcap path is /sys/devices/ff100000.adc
<11>[ 2.467880] bat_cap: oldcap_path no exist
<6>[ 2.468032] binder: 160:160 transaction failed 29189, size 0-0
<11>[ 2.468416] init: Warning! Service displayd needs a SELinux domain defined; please fix!
<11>[ 2.472267] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
<11>[ 2.472298] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
<11>[ 2.472529] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
<6>[ 2.473006] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 2.473025] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 2.473042] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 2.473052] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 2.473075] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 2.473085] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 2.473100] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 2.473111] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<4>[ 2.489608] 0,baud is:9600
<4>[ 2.489721] 1, baud is:115200
<4>[ 2.489858] 1, baud is:115200
<4>[ 2.489941] 0,baud is:9600
<38>[ 2.541731] logd.auditd: start
<4>[ 2.542471] firefly_vga_get_enable 180, 1
<4>[ 2.542592] firefly_vga_get_status 186
<4>[ 2.543220] firefly_vga_set_mode 203
<11>[ 2.543312] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
<11>[ 2.544786] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’
<11>[ 2.545226] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
<11>[ 2.545431] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
<11>[ 2.545666] init: cannot find ‘/system/bin/akmd’, disabling ‘akmd’
<4>[ 2.546131] 2, baud is:115200
<4>[ 2.546598] firefly_vga_set_enable 159 enable:1
<7>[ 2.548094] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<3>[ 2.548646] android_usb: already disabled
<6>[ 2.551494] read descriptors
<6>[ 2.551509] read strings
<4>[ 2.551543] pcd_pullup, is_on 1
<6>[ 2.762595] EHCI: rk_ehci_hcd_enable, disable host controller
<4>[ 2.762612] dwc_otg_hcd_enable, enable host controller
<4>[ 2.875760] Using Buffer DMA mode
<4>[ 2.875771] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 2.875776] Multiprocessor Interrupt Enhancement - disabled
<4>[ 2.875782] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 2.875787] ^^^^^^^^^^^^^^^^^^Host Mode
<4>[ 2.920121] Init: Power Port (0)
<4>[ 3.254615] Indeed it is in host mode hprt0 = 00021501
<6>[ 3.358976] rk3288-lcdc lcdc0: blank mode:0
<6>[ 3.381704] rk_iommu ff940300.vopl_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eac0000
<6>[ 3.431761] usb 3-1: new high-speed USB device number 2 using usb20_host
<4>[ 3.431831] Indeed it is in host mode hprt0 = 00001101
<11>[ 3.452622] healthd: No charger supplies found
<12>[ 3.452636] healthd: No battery devices found
<6>[ 3.648423] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
<6>[ 3.648437] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
<6>[ 3.648444] usb 3-1: Product: USB 2.0 Hub [MTT]
<6>[ 3.648911] hub 3-1:1.0: USB hub found
<6>[ 3.648976] hub 3-1:1.0: 4 ports detected
<6>[ 3.923794] usb 3-1.1: new high-speed USB device number 3 using usb20_host
<6>[ 4.047481] usb 3-1.1: New USB device found, idVendor=05a3, idProduct=8530
<6>[ 4.047495] usb 3-1.1: New USB device strings: Mfr=2, Product=1, SerialNumber=3
<6>[ 4.047502] usb 3-1.1: Product: USB 2.0 Camera
<6>[ 4.047508] usb 3-1.1: Manufacturer: Sonix Technology Co., Ltd.
<6>[ 4.047514] usb 3-1.1: SerialNumber: SN5100
<6>[ 4.049033] uvcvideo: Found UVC 1.00 device USB 2.0 Camera (05a3:8530)
<6>[ 4.064457] input: USB 2.0 Camera as /devices/ff540000.usb/usb3/3-1/3-1.1/3-1.1:1.0/input/input3
<6>[ 4.140332] usb 3-1.3: new low-speed USB device number 4 using usb20_host
<6>[ 4.242614] usb 3-1.3: New USB device found, idVendor=093a, idProduct=2510
<6>[ 4.242628] usb 3-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
<6>[ 4.242636] usb 3-1.3: Product: USB Optical Mouse
<6>[ 4.242644] usb 3-1.3: Manufacturer: PixArt
<6>[ 4.245621] input: PixArt USB Optical Mouse as /devices/ff540000.usb/usb3/3-1/3-1.3/3-1.3:1.0/input/input4
<6>[ 4.245890] hid-generic 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-ff540000.usb-1.3/input0
<6>[ 4.597587] warning: `system_server’ uses 32-bit capabilities (legacy support in use)
<4>[ 5.029504] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 5.029516] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 5.029523] D1:camsys_open(739): camsys_marvin(de01f810) is opened!
<4>[ 5.029600] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 5.029611] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 5.029621] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
<7>[ 5.029635] of_get_named_gpio_flags exited with status 237
<7>[ 5.029640] of_get_named_gpio_flags exited with status 237
<4>[ 5.029644] rockchip_gpio_request:GPIO7-13
<4>[ 5.029653] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 5.029658] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 5.029667] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x15
<4>[ 5.029675] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7400,result=0x7400
<4>[ 5.029682] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 5.029701] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
<4>[ 5.034731] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 5.034740] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 5.034844] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 5.034870] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 5.035933] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 5.037002] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 5.038066] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
<3>[ 5.041288] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
<3>[ 5.042624] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
<4>[ 5.042692] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 5.042703] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 5.042712] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 5.043795] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 5.043819] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 5.045868] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 5.045881] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 5.045889] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 5.045895] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 5.045901] D1:camsys_release(763): camsys_marvin(de01f810) is closed
<4>[ 5.052591] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 5.052602] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 5.052610] D1:camsys_open(739): camsys_marvin(de01f810) is opened!
<4>[ 5.052695] D1:camsys_extdev_register(243): Get RK30_PIN3_PB4(108) gpio(active: 1) for dev_id 0x4000000 success!
<4>[ 5.052706] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x4000000 success!
<4>[ 5.052716] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x4000000 success!
<4>[ 5.052724] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
<4>[ 5.052810] D1:camsys_extdev_register(268): Extdev(dev_id: 0x4000000 dev_name: OV5640) register success
<4>[ 5.057842] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 5.057852] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 5.057957] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 5.057982] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 5.059043] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 5.060097] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 5.061161] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(108) set 0
<3>[ 5.064371] E:camsys_i2c_write(78): i2c write dev(addr:0x78) failed!
<4>[ 5.064454] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(108) set 1
<4>[ 5.064468] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 5.064480] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 5.065565] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 5.065591] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 5.067640] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x4000000) is deregister success
<4>[ 5.067653] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 5.067662] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 5.067668] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 5.067674] D1:camsys_release(763): camsys_marvin(de01f810) is closed
<4>[ 5.071511] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 5.071521] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 5.071527] D1:camsys_open(739): camsys_marvin(de01f810) is opened!
<4>[ 5.071600] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
<4>[ 5.071623] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
<4>[ 5.076650] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 5.076658] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 5.076762] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 5.076784] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
<3>[ 5.077843] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<3>[ 5.078895] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 5.079953] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 5.083856] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
<3>[ 5.085333] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
<3>[ 5.085408] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 5.085416] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 5.085427] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<4>[ 5.086530] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 5.086567] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 5.088617] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
<4>[ 5.088636] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 5.088646] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 5.088652] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 5.088658] D1:camsys_release(763): camsys_marvin(de01f810) is closed
<38>[ 5.101360] type=1400 audit(1294230610.930:3): avc: denied { execute } for pid=493 comm=“mediaserver” name=“sh” dev=“mmcblk0p10” ino=332 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 5.101567] type=1400 audit(1294230610.930:4): avc: denied { read open } for pid=493 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=332 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 5.101646] type=1400 audit(1294230610.930:5): avc: denied { execute_no_trans } for pid=493 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=332 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 5.103528] type=1400 audit(1294230610.930:6): avc: denied { getattr } for pid=493 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=348 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 5.103640] type=1400 audit(1294230610.930:7): avc: denied { execute } for pid=493 comm=“sh” name=“toolbox” dev=“mmcblk0p10” ino=348 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 5.103706] type=1400 audit(1294230610.930:8): avc: denied { read open } for pid=493 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=348 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 5.103772] type=1400 audit(1294230610.930:9): avc: denied { execute_no_trans } for pid=493 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=348 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<6>[ 8.676449] [otg id chg] last id -1 current id 1
<4>[ 8.676473] PortPower off
<4>[ 8.676481] rk_battery_charger_detect_cb , battery_charger_detect 6
<4>[ 8.775907] Using Buffer DMA mode
<4>[ 8.775929] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 8.775936] Multiprocessor Interrupt Enhancement - disabled
<4>[ 8.775943] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 8.775950] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 8.854041] es8323_mic_state_ctrl read: 0
<4>[ 8.854071] mic_state_switch 0
<4>[ 8.854079] hp_det = 0,insert hp
<4>[ 8.854085] hp mic use intern
<4>[ 9.266851] vbus detect**
<4>[ 9.269044] rk_battery_charger_detect_cb , battery_charger_detect 1
<4>[ 9.446093] Using Buffer DMA mode
<4>[ 9.446112] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 9.446119] Multiprocessor Interrupt Enhancement - disabled
<4>[ 9.446127] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 9.446133] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 9.446174] soft connect!!!
<4>[ 9.569528] USB RESET
<6>[ 9.680232] android_work: sent uevent USB_STATE=CONNECTED
<4>[ 9.683374] USB RESET
<6>[ 9.807580] android_usb gadget: high-speed config #1: android
<6>[ 9.815478] android_work: sent uevent USB_STATE=CONFIGURED
<12>[ 10.134531] healthd: battery none chg=
<6>[ 10.509699] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
<6>[ 10.509722] lowmemorykiller: oom_adj 0 => oom_score_adj 0
<6>[ 10.509730] lowmemorykiller: oom_adj 1 => oom_score_adj 58
<6>[ 10.509736] lowmemorykiller: oom_adj 2 => oom_score_adj 117
<6>[ 10.509742] lowmemorykiller: oom_adj 3 => oom_score_adj 176
<6>[ 10.509748] lowmemorykiller: oom_adj 9 => oom_score_adj 529
<6>[ 10.509754] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
<6>[ 11.401096] acc_open
<6>[ 11.401126] acc_release
<4>[ 11.644845] phy_power_on: enable = 1
<4>[ 11.684351] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
<4>[ 11.684393] eth0: device MAC address 9a:05:24:33:f7:69
<6>[ 11.688382] libphy: stmmac: probed
<6>[ 11.688393] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
<6>[ 11.688399] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
<4>[ 12.497461] FAT-fs (mmcblk0p15): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
<7>[ 12.497520] SELinux: initialized (dev mmcblk0p15, type vfat), uses genfs_contexts
<11>[ 12.519079] init: no such service ‘fuse_internal_sd’
<6>[ 13.371028] pm policy 0 → 1
<38>[ 15.519066] type=1400 audit(1294230621.520:10): avc: denied { write } for pid=1021 comm=“Binder_1” name=“/” dev=“mmcblk0p13” ino=2 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1
<38>[ 15.519345] type=1400 audit(1294230621.520:11): avc: denied { remove_name } for pid=1021 comm=“Binder_1” name=“vpumem_observer” dev=“mmcblk0p13” ino=15 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1
<38>[ 15.525186] type=1400 audit(1294230621.520:12): avc: denied { unlink } for pid=1021 comm=“Binder_1” name=“vpumem_observer” dev=“mmcblk0p13” ino=15 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=sock_file permissive=1
<38>[ 15.525286] type=1400 audit(1294230621.520:13): avc: denied { add_name } for pid=1021 comm=“Binder_1” name=“vpumem_observer” scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1
<38>[ 15.525354] type=1400 audit(1294230621.520:14): avc: denied { create } for pid=1021 comm=“Binder_1” name=“vpumem_observer” scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=sock_file permissive=1
<38>[ 15.751775] type=1400 audit(1294230621.760:15): avc: denied { write } for pid=970 comm=“chip.devicetest” name=“force_usb_mode” dev=“sysfs” ino=12777 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
<4>[ 15.757626] force_usb_mode_store 0->0
<4>[ 21.539009] force_usb_mode_store 0->0
<4>[ 1095.996438] mic use intern
<6>[ 1098.544915] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 1098.646595] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1098.646642] vcodec_service: for 3288/3368…<6>[ 1098.648843] vcodec_service: reset in
<6>[ 1098.648902] vcodec_service: done
<6>[ 1098.698965] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1098.699023] vcodec_service: for 3288/3368…<6>[ 1098.699052] vcodec_service: reset in
<6>[ 1098.699123] vcodec_service: done
<6>[ 1098.745690] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1098.745714] vcodec_service: for 3288/3368…<6>[ 1098.745727] vcodec_service: reset in
<6>[ 1098.745784] vcodec_service: done
<6>[ 1098.784855] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1098.784892] vcodec_service: for 3288/3368…<6>[ 1098.791564] vcodec_service: reset in
<6>[ 1098.791861] vcodec_service: done
<6>[ 1098.835071] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1098.835129] vcodec_service: for 3288/3368…<6>[ 1098.835139] vcodec_service: reset in
<6>[ 1098.835244] vcodec_service: done
<6>[ 1098.919405] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1098.919468] vcodec_service: for 3288/3368…<6>[ 1098.919487] vcodec_service: reset in
<6>[ 1098.919558] vcodec_service: done
<6>[ 1098.960218] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1098.960297] vcodec_service: for 3288/3368…<6>[ 1098.960316] vcodec_service: reset in
<6>[ 1098.960391] vcodec_service: done
<6>[ 1098.997317] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1098.997344] vcodec_service: for 3288/3368…<6>[ 1098.997354] vcodec_service: reset in
<6>[ 1098.997400] vcodec_service: done
<6>[ 1099.034877] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.034904] vcodec_service: for 3288/3368…<6>[ 1099.037262] vcodec_service: reset in
<6>[ 1099.037382] vcodec_service: done
<6>[ 1099.074538] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.074591] vcodec_service: for 3288/3368…<6>[ 1099.074607] vcodec_service: reset in
<6>[ 1099.074679] vcodec_service: done
<6>[ 1099.112706] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.112741] vcodec_service: for 3288/3368…<6>[ 1099.112751] vcodec_service: reset in
<6>[ 1099.112816] vcodec_service: done
<6>[ 1099.155390] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.155444] vcodec_service: for 3288/3368…<6>[ 1099.155456] vcodec_service: reset in
<6>[ 1099.155525] vcodec_service: done
<6>[ 1099.194656] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.194682] vcodec_service: for 3288/3368…<6>[ 1099.194692] vcodec_service: reset in
<6>[ 1099.204279] vcodec_service: done
<6>[ 1099.248668] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.248769] vcodec_service: for 3288/3368…<6>[ 1099.248782] vcodec_service: reset in
<6>[ 1099.248833] vcodec_service: done
<6>[ 1099.288007] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.288070] vcodec_service: for 3288/3368…<6>[ 1099.288087] vcodec_service: reset in
<6>[ 1099.288153] vcodec_service: done
<6>[ 1099.327128] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.327165] vcodec_service: for 3288/3368…<6>[ 1099.327181] vcodec_service: reset in
<6>[ 1099.332197] vcodec_service: done
<6>[ 1099.371238] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.371286] vcodec_service: for 3288/3368…<6>[ 1099.371302] vcodec_service: reset in
<6>[ 1099.371384] vcodec_service: done
<6>[ 1099.410882] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.411011] vcodec_service: for 3288/3368…<6>[ 1099.411030] vcodec_service: reset in
<6>[ 1099.411085] vcodec_service: done
<6>[ 1099.450177] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.450213] vcodec_service: for 3288/3368…<6>[ 1099.450225] vcodec_service: reset in
<6>[ 1099.450379] vcodec_service: done
<6>[ 1099.528906] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.528940] vcodec_service: for 3288/3368…<6>[ 1099.528953] vcodec_service: reset in
<6>[ 1099.529154] vcodec_service: done
<6>[ 1099.567034] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.567073] vcodec_service: for 3288/3368…<6>[ 1099.567084] vcodec_service: reset in
<6>[ 1099.567133] vcodec_service: done
<6>[ 1099.605260] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.605294] vcodec_service: for 3288/3368…<6>[ 1099.605305] vcodec_service: reset in
<6>[ 1099.605353] vcodec_service: done
<6>[ 1099.645270] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.645327] vcodec_service: for 3288/3368…<6>[ 1099.645349] vcodec_service: reset in
<6>[ 1099.645445] vcodec_service: done
<6>[ 1099.684436] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.684474] vcodec_service: for 3288/3368…<6>[ 1099.684486] vcodec_service: reset in
<6>[ 1099.684548] vcodec_service: done
<6>[ 1099.721021] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.721049] vcodec_service: for 3288/3368…<6>[ 1099.721060] vcodec_service: reset in
<6>[ 1099.721110] vcodec_service: done
<6>[ 1099.760167] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.760208] vcodec_service: for 3288/3368…<6>[ 1099.760223] vcodec_service: reset in
<6>[ 1099.760281] vcodec_service: done
<6>[ 1099.799659] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.799693] vcodec_service: for 3288/3368…<6>[ 1099.799706] vcodec_service: reset in
<6>[ 1099.799757] vcodec_service: done
<6>[ 1099.838539] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.838573] vcodec_service: for 3288/3368…<6>[ 1099.838586] vcodec_service: reset in
<6>[ 1099.838635] vcodec_service: done
<6>[ 1099.919127] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.919160] vcodec_service: for 3288/3368…<6>[ 1099.919170] vcodec_service: reset in
<6>[ 1099.919531] vcodec_service: done
<6>[ 1099.957193] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.957224] vcodec_service: for 3288/3368…<6>[ 1099.957233] vcodec_service: reset in
<6>[ 1099.957284] vcodec_service: done
<6>[ 1099.994815] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1099.994882] vcodec_service: for 3288/3368…<6>[ 1099.994900] vcodec_service: reset in
<6>[ 1099.994967] vcodec_service: done
<6>[ 1100.037204] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.037237] vcodec_service: for 3288/3368…<6>[ 1100.037260] vcodec_service: reset in
<6>[ 1100.037317] vcodec_service: done
<6>[ 1100.075477] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.075509] vcodec_service: for 3288/3368…<6>[ 1100.075519] vcodec_service: reset in
<6>[ 1100.075565] vcodec_service: done
<6>[ 1100.114557] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.114598] vcodec_service: for 3288/3368…<6>[ 1100.114608] vcodec_service: reset in
<6>[ 1100.119453] vcodec_service: done
<6>[ 1100.202866] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.202900] vcodec_service: for 3288/3368…<6>[ 1100.202914] vcodec_service: reset in
<6>[ 1100.202972] vcodec_service: done
<6>[ 1100.241380] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.241453] vcodec_service: for 3288/3368…<6>[ 1100.241467] vcodec_service: reset in
<6>[ 1100.241547] vcodec_service: done
<6>[ 1100.284208] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.284235] vcodec_service: for 3288/3368…<6>[ 1100.284244] vcodec_service: reset in
<6>[ 1100.284290] vcodec_service: done
<6>[ 1100.322668] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.322693] vcodec_service: for 3288/3368…<6>[ 1100.322704] vcodec_service: reset in
<6>[ 1100.322754] vcodec_service: done
<6>[ 1100.361412] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.361445] vcodec_service: for 3288/3368…<6>[ 1100.361457] vcodec_service: reset in
<6>[ 1100.365499] vcodec_service: done
<6>[ 1100.443484] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.443514] vcodec_service: for 3288/3368…<6>[ 1100.450843] vcodec_service: reset in
<6>[ 1100.450899] vcodec_service: done
<6>[ 1100.492803] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.501056] vcodec_service: for 3288/3368…<6>[ 1100.501069] vcodec_service: reset in
<6>[ 1100.501118] vcodec_service: done
<6>[ 1100.538354] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.538379] vcodec_service: for 3288/3368…<6>[ 1100.538388] vcodec_service: reset in
<6>[ 1100.538437] vcodec_service: done
<6>[ 1100.578664] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.578688] vcodec_service: for 3288/3368…<6>[ 1100.578699] vcodec_service: reset in
<6>[ 1100.581880] vcodec_service: done
<6>[ 1100.622230] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.625501] vcodec_service: for 3288/3368…<6>[ 1100.625523] vcodec_service: reset in
<6>[ 1100.625564] vcodec_service: done
<6>[ 1100.667033] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.670171] vcodec_service: for 3288/3368…<6>[ 1100.670181] vcodec_service: reset in
<6>[ 1100.670223] vcodec_service: done
<6>[ 1100.711211] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.711263] vcodec_service: for 3288/3368…<6>[ 1100.711271] vcodec_service: reset in
<6>[ 1100.711320] vcodec_service: done
<6>[ 1100.751958] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.752027] vcodec_service: for 3288/3368…<6>[ 1100.761269] vcodec_service: reset in
<6>[ 1100.761321] vcodec_service: done
<6>[ 1100.799004] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.799040] vcodec_service: for 3288/3368…<6>[ 1100.799051] vcodec_service: reset in
<6>[ 1100.799102] vcodec_service: done
<6>[ 1100.836783] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.836808] vcodec_service: for 3288/3368…<6>[ 1100.836819] vcodec_service: reset in
<6>[ 1100.836886] vcodec_service: done
<6>[ 1100.915821] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.915843] vcodec_service: for 3288/3368…<6>[ 1100.915851] vcodec_service: reset in
<6>[ 1100.915895] vcodec_service: done
<6>[ 1100.958676] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.958720] vcodec_service: for 3288/3368…<6>[ 1100.958733] vcodec_service: reset in
<6>[ 1100.958788] vcodec_service: done
<6>[ 1100.996024] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1100.996056] vcodec_service: for 3288/3368…<6>[ 1100.996068] vcodec_service: reset in
<6>[ 1100.996122] vcodec_service: done
<6>[ 1101.033846] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.033903] vcodec_service: for 3288/3368…<6>[ 1101.041408] vcodec_service: reset in
<6>[ 1101.041459] vcodec_service: done
<6>[ 1101.158497] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.158537] vcodec_service: for 3288/3368…<6>[ 1101.158553] vcodec_service: reset in
<6>[ 1101.158614] vcodec_service: done
<6>[ 1101.196688] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.196721] vcodec_service: for 3288/3368…<6>[ 1101.196733] vcodec_service: reset in
<6>[ 1101.196942] vcodec_service: done
<6>[ 1101.234191] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.234227] vcodec_service: for 3288/3368…<6>[ 1101.234235] vcodec_service: reset in
<6>[ 1101.236651] vcodec_service: done
<6>[ 1101.274463] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.274504] vcodec_service: for 3288/3368…<6>[ 1101.274520] vcodec_service: reset in
<6>[ 1101.274581] vcodec_service: done
<6>[ 1101.311792] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.311827] vcodec_service: for 3288/3368…<6>[ 1101.311837] vcodec_service: reset in
<6>[ 1101.311883] vcodec_service: done
<6>[ 1101.353357] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.353397] vcodec_service: for 3288/3368…<6>[ 1101.353409] vcodec_service: reset in
<6>[ 1101.353483] vcodec_service: done
<6>[ 1101.436930] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.436951] vcodec_service: for 3288/3368…<6>[ 1101.436959] vcodec_service: reset in
<6>[ 1101.437005] vcodec_service: done
<6>[ 1101.474396] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.474418] vcodec_service: for 3288/3368…<6>[ 1101.474426] vcodec_service: reset in
<6>[ 1101.474472] vcodec_service: done
<6>[ 1101.512297] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.512350] vcodec_service: for 3288/3368…<6>[ 1101.516242] vcodec_service: reset in
<6>[ 1101.516579] vcodec_service: done
<6>[ 1101.593043] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.593076] vcodec_service: for 3288/3368…<6>[ 1101.595421] vcodec_service: reset in
<6>[ 1101.595478] vcodec_service: done
<6>[ 1101.634608] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.634644] vcodec_service: for 3288/3368…<6>[ 1101.634656] vcodec_service: reset in
<6>[ 1101.634699] vcodec_service: done
<6>[ 1101.672019] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.672046] vcodec_service: for 3288/3368…<6>[ 1101.672056] vcodec_service: reset in
<6>[ 1101.672100] vcodec_service: done
<6>[ 1101.711207] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.711238] vcodec_service: for 3288/3368…<6>[ 1101.711247] vcodec_service: reset in
<6>[ 1101.711302] vcodec_service: done
<6>[ 1101.749567] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.749589] vcodec_service: for 3288/3368…<6>[ 1101.749599] vcodec_service: reset in
<6>[ 1101.749645] vcodec_service: done
<6>[ 1101.789223] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.789277] vcodec_service: for 3288/3368…<6>[ 1101.789296] vcodec_service: reset in
<6>[ 1101.789380] vcodec_service: done
<6>[ 1101.830168] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.830230] vcodec_service: for 3288/3368…<6>[ 1101.830243] vcodec_service: reset in
<6>[ 1101.830321] vcodec_service: done
<6>[ 1101.871224] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.871251] vcodec_service: for 3288/3368…<6>[ 1101.875145] vcodec_service: reset in
<6>[ 1101.876362] vcodec_service: done
<6>[ 1101.915717] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.915737] vcodec_service: for 3288/3368…<6>[ 1101.915745] vcodec_service: reset in
<6>[ 1101.916898] vcodec_service: done
<6>[ 1101.956510] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.956565] vcodec_service: for 3288/3368…<6>[ 1101.956588] vcodec_service: reset in
<6>[ 1101.957308] vcodec_service: done
<6>[ 1101.998371] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1101.998423] vcodec_service: for 3288/3368…<6>[ 1101.998435] vcodec_service: reset in
<6>[ 1101.998486] vcodec_service: done
<6>[ 1102.041647] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.041686] vcodec_service: for 3288/3368…<6>[ 1102.041718] vcodec_service: reset in
<6>[ 1102.041785] vcodec_service: done
<6>[ 1102.080173] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.080193] vcodec_service: for 3288/3368…<6>[ 1102.080201] vcodec_service: reset in
<6>[ 1102.080239] vcodec_service: done
<6>[ 1102.116323] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.116354] vcodec_service: for 3288/3368…<6>[ 1102.116363] vcodec_service: reset in
<6>[ 1102.116449] vcodec_service: done
<6>[ 1102.152759] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.152800] vcodec_service: for 3288/3368…<6>[ 1102.152810] vcodec_service: reset in
<6>[ 1102.152869] vcodec_service: done
<6>[ 1102.189863] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.189910] vcodec_service: for 3288/3368…<6>[ 1102.189923] vcodec_service: reset in
<6>[ 1102.189976] vcodec_service: done
<6>[ 1102.226643] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.226681] vcodec_service: for 3288/3368…<6>[ 1102.226693] vcodec_service: reset in
<6>[ 1102.226745] vcodec_service: done
<6>[ 1102.262097] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.262125] vcodec_service: for 3288/3368…<6>[ 1102.266818] vcodec_service: reset in
<6>[ 1102.267251] vcodec_service: done
<6>[ 1102.303117] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.303152] vcodec_service: for 3288/3368…<6>[ 1102.303162] vcodec_service: reset in
<6>[ 1102.303224] vcodec_service: done
<6>[ 1102.339580] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.339617] vcodec_service: for 3288/3368…<6>[ 1102.339626] vcodec_service: reset in
<6>[ 1102.339681] vcodec_service: done
<6>[ 1102.375792] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.375813] vcodec_service: for 3288/3368…<6>[ 1102.375820] vcodec_service: reset in
<6>[ 1102.375866] vcodec_service: done
<6>[ 1102.417808] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.421461] vcodec_service: for 3288/3368…<6>[ 1102.421471] vcodec_service: reset in
<6>[ 1102.421517] vcodec_service: done
<6>[ 1102.459893] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.459916] vcodec_service: for 3288/3368…<6>[ 1102.459924] vcodec_service: reset in
<6>[ 1102.459968] vcodec_service: done
<6>[ 1102.497170] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.497194] vcodec_service: for 3288/3368…<6>[ 1102.497202] vcodec_service: reset in
<6>[ 1102.497241] vcodec_service: done
<6>[ 1102.535293] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.535332] vcodec_service: for 3288/3368…<6>[ 1102.535341] vcodec_service: reset in
<6>[ 1102.535525] vcodec_service: done
<6>[ 1102.575923] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.575958] vcodec_service: for 3288/3368…<6>[ 1102.575967] vcodec_service: reset in
<6>[ 1102.576021] vcodec_service: done
<6>[ 1102.617459] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.617525] vcodec_service: for 3288/3368…<6>[ 1102.617541] vcodec_service: reset in
<6>[ 1102.617613] vcodec_service: done
<6>[ 1102.655050] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.655076] vcodec_service: for 3288/3368…<6>[ 1102.655084] vcodec_service: reset in
<6>[ 1102.655127] vcodec_service: done
<6>[ 1102.729810] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.729850] vcodec_service: for 3288/3368…<6>[ 1102.729865] vcodec_service: reset in
<6>[ 1102.729916] vcodec_service: done
<6>[ 1102.772484] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.772554] vcodec_service: for 3288/3368…<6>[ 1102.772570] vcodec_service: reset in
<6>[ 1102.772659] vcodec_service: done
<6>[ 1102.814063] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.814122] vcodec_service: for 3288/3368…<6>[ 1102.814135] vcodec_service: reset in
<6>[ 1102.814212] vcodec_service: done
<6>[ 1102.857131] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.857175] vcodec_service: for 3288/3368…<6>[ 1102.857188] vcodec_service: reset in
<6>[ 1102.857246] vcodec_service: done
<6>[ 1102.897802] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1102.897854] vcodec_service: for 3288/3368…<6>[ 1102.897868] vcodec_service: reset in
<6>[ 1102.897933] vcodec_service: done
<6>[ 1106.554761] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 1106.554811] vcodec_service: done
<6>[ 1109.512157] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 1109.512215] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1109.512220] vcodec_service: for 3288/3368…<6>[ 1109.512225] vcodec_service: reset in
<6>[ 1109.512266] vcodec_service: done
<6>[ 1109.549523] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1109.549567] vcodec_service: for 3288/3368…<6>[ 1109.549578] vcodec_service: reset in
<6>[ 1109.549631] vcodec_service: done
<6>[ 1109.586597] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1109.586642] vcodec_service: for 3288/3368…<6>[ 1109.586650] vcodec_service: reset in
<6>[ 1109.586698] vcodec_service: done
<6>[ 1109.630662] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1109.630710] vcodec_service: for 3288/3368…<6>[ 1109.630820] vcodec_service: reset in
<6>[ 1109.630892] vcodec_service: done
<6>[ 1109.673867] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1109.673935] vcodec_service: for 3288/3368…<6>[ 1109.673964] vcodec_service: reset in
<6>[ 1109.674736] vcodec_service: done
<6>[ 1109.718803] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1109.718859] vcodec_service: for 3288/3368…<6>[ 1109.718869] vcodec_service: reset in
<6>[ 1109.718925] vcodec_service: done
<6>[ 1109.761510] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1109.761582] vcodec_service: for 3288/3368…<6>[ 1109.761598] vcodec_service: reset in
<6>[ 1109.761676] vcodec_service: done
<6>[ 1109.803489] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1109.803552] vcodec_service: for 3288/3368…<6>[ 1109.803565] vcodec_service: reset in
<6>[ 1109.803620] vcodec_service: done
<6>[ 1109.844456] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1109.844498] vcodec_service: for 3288/3368…<6>[ 1109.844508] vcodec_service: reset in
<6>[ 1109.844556] vcodec_service: done
<6>[ 1109.920172] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1109.920213] vcodec_service: for 3288/3368…<6>[ 1109.920236] vcodec_service: reset in
<6>[ 1109.922044] vcodec_service: done
<6>[ 1109.960069] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1109.960109] vcodec_service: for 3288/3368…<6>[ 1109.960119] vcodec_service: reset in
<6>[ 1109.960163] vcodec_service: done
<6>[ 1109.996074] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1109.996115] vcodec_service: for 3288/3368…<6>[ 1109.996125] vcodec_service: reset in
<6>[ 1109.996177] vcodec_service: done
<6>[ 1110.032419] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.032447] vcodec_service: for 3288/3368…<6>[ 1110.032459] vcodec_service: reset in
<6>[ 1110.032507] vcodec_service: done
<6>[ 1110.068884] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.068920] vcodec_service: for 3288/3368…<6>[ 1110.068932] vcodec_service: reset in
<6>[ 1110.068994] vcodec_service: done
<6>[ 1110.143388] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.143438] vcodec_service: for 3288/3368…<6>[ 1110.143454] vcodec_service: reset in
<6>[ 1110.143528] vcodec_service: done
<6>[ 1110.186076] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.186152] vcodec_service: for 3288/3368…<6>[ 1110.186170] vcodec_service: reset in
<6>[ 1110.186263] vcodec_service: done
<6>[ 1110.231096] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.234112] vcodec_service: for 3288/3368…<6>[ 1110.234127] vcodec_service: reset in
<6>[ 1110.234180] vcodec_service: done
<6>[ 1110.273009] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.274409] vcodec_service: for 3288/3368…<6>[ 1110.274425] vcodec_service: reset in
<6>[ 1110.279710] vcodec_service: done
<6>[ 1110.319349] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.319389] vcodec_service: for 3288/3368…<6>[ 1110.319401] vcodec_service: reset in
<6>[ 1110.319448] vcodec_service: done
<6>[ 1110.355265] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.355306] vcodec_service: for 3288/3368…<6>[ 1110.355317] vcodec_service: reset in
<6>[ 1110.355384] vcodec_service: done
<6>[ 1110.394031] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.394079] vcodec_service: for 3288/3368…<6>[ 1110.394089] vcodec_service: reset in
<6>[ 1110.394142] vcodec_service: done
<6>[ 1110.474349] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.474387] vcodec_service: for 3288/3368…<6>[ 1110.481010] vcodec_service: reset in
<6>[ 1110.481061] vcodec_service: done
<6>[ 1110.524663] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.524716] vcodec_service: for 3288/3368…<6>[ 1110.524731] vcodec_service: reset in
<6>[ 1110.524782] vcodec_service: done
<6>[ 1110.565173] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.565204] vcodec_service: for 3288/3368…<6>[ 1110.565216] vcodec_service: reset in
<6>[ 1110.565266] vcodec_service: done
<6>[ 1110.609167] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.612709] vcodec_service: for 3288/3368…<6>[ 1110.612724] vcodec_service: reset in
<6>[ 1110.614372] vcodec_service: done
<6>[ 1110.657086] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.657122] vcodec_service: for 3288/3368…<6>[ 1110.661042] vcodec_service: reset in
<6>[ 1110.661136] vcodec_service: done
<6>[ 1110.700581] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.700623] vcodec_service: for 3288/3368…<6>[ 1110.700634] vcodec_service: reset in
<6>[ 1110.700693] vcodec_service: done
<6>[ 1110.780760] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.780789] vcodec_service: for 3288/3368…<6>[ 1110.782593] vcodec_service: reset in
<6>[ 1110.783061] vcodec_service: done
<6>[ 1110.822690] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.822719] vcodec_service: for 3288/3368…<6>[ 1110.822730] vcodec_service: reset in
<6>[ 1110.822820] vcodec_service: done
<6>[ 1110.861067] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.861093] vcodec_service: for 3288/3368…<6>[ 1110.861103] vcodec_service: reset in
<6>[ 1110.864720] vcodec_service: done
<6>[ 1110.906047] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.912037] vcodec_service: for 3288/3368…<6>[ 1110.912055] vcodec_service: reset in
<6>[ 1110.912434] vcodec_service: done
<6>[ 1110.954194] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1110.957758] vcodec_service: for 3288/3368…<6>[ 1110.957788] vcodec_service: reset in
<6>[ 1110.958703] vcodec_service: done
<6>[ 1111.001255] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.001277] vcodec_service: for 3288/3368…<6>[ 1111.007408] vcodec_service: reset in
<6>[ 1111.007474] vcodec_service: done
<6>[ 1111.049701] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.049740] vcodec_service: for 3288/3368…<6>[ 1111.049752] vcodec_service: reset in
<6>[ 1111.049812] vcodec_service: done
<6>[ 1111.086316] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.086346] vcodec_service: for 3288/3368…<6>[ 1111.086358] vcodec_service: reset in
<6>[ 1111.086402] vcodec_service: done
<6>[ 1111.125521] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.125559] vcodec_service: for 3288/3368…<6>[ 1111.125568] vcodec_service: reset in
<6>[ 1111.125618] vcodec_service: done
<6>[ 1111.164946] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.164981] vcodec_service: for 3288/3368…<6>[ 1111.164993] vcodec_service: reset in
<6>[ 1111.165046] vcodec_service: done
<6>[ 1111.206295] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.206353] vcodec_service: for 3288/3368…<6>[ 1111.206367] vcodec_service: reset in
<6>[ 1111.206423] vcodec_service: done
<6>[ 1111.244735] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.244774] vcodec_service: for 3288/3368…<6>[ 1111.244785] vcodec_service: reset in
<6>[ 1111.244838] vcodec_service: done
<6>[ 1111.284830] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.284865] vcodec_service: for 3288/3368…<6>[ 1111.284879] vcodec_service: reset in
<6>[ 1111.284933] vcodec_service: done
<6>[ 1111.322726] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.322760] vcodec_service: for 3288/3368…<6>[ 1111.322770] vcodec_service: reset in
<6>[ 1111.322817] vcodec_service: done
<6>[ 1111.360984] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.361027] vcodec_service: for 3288/3368…<6>[ 1111.361038] vcodec_service: reset in
<6>[ 1111.361095] vcodec_service: done
<6>[ 1111.399150] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.399224] vcodec_service: for 3288/3368…<6>[ 1111.399240] vcodec_service: reset in
<6>[ 1111.399302] vcodec_service: done
<6>[ 1111.474972] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.475006] vcodec_service: for 3288/3368…<6>[ 1111.475019] vcodec_service: reset in
<6>[ 1111.475064] vcodec_service: done
<6>[ 1111.512871] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.512936] vcodec_service: for 3288/3368…<6>[ 1111.518134] vcodec_service: reset in
<6>[ 1111.518185] vcodec_service: done
<6>[ 1111.560227] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.560274] vcodec_service: for 3288/3368…<6>[ 1111.560284] vcodec_service: reset in
<6>[ 1111.560334] vcodec_service: done
<6>[ 1111.597096] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.597151] vcodec_service: for 3288/3368…<6>[ 1111.597168] vcodec_service: reset in
<6>[ 1111.597240] vcodec_service: done
<6>[ 1111.633984] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.634020] vcodec_service: for 3288/3368…<6>[ 1111.634030] vcodec_service: reset in
<6>[ 1111.634081] vcodec_service: done
<6>[ 1111.670867] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.670903] vcodec_service: for 3288/3368…<6>[ 1111.670915] vcodec_service: reset in
<6>[ 1111.670974] vcodec_service: done
<6>[ 1111.707360] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.707390] vcodec_service: for 3288/3368…<6>[ 1111.707402] vcodec_service: reset in
<6>[ 1111.707509] vcodec_service: done
<6>[ 1111.743695] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.743754] vcodec_service: for 3288/3368…<6>[ 1111.743765] vcodec_service: reset in
<6>[ 1111.743833] vcodec_service: done
<6>[ 1111.780660] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.780723] vcodec_service: for 3288/3368…<6>[ 1111.780734] vcodec_service: reset in
<6>[ 1111.780787] vcodec_service: done
<6>[ 1111.817382] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.817420] vcodec_service: for 3288/3368…<6>[ 1111.817434] vcodec_service: reset in
<6>[ 1111.817486] vcodec_service: done
<6>[ 1111.858266] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.858363] vcodec_service: for 3288/3368…<6>[ 1111.866858] vcodec_service: reset in
<6>[ 1111.866914] vcodec_service: done
<6>[ 1111.911455] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.911491] vcodec_service: for 3288/3368…<6>[ 1111.911503] vcodec_service: reset in
<6>[ 1111.911604] vcodec_service: done
<6>[ 1111.952198] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1111.952256] vcodec_service: for 3288/3368…<6>[ 1111.952270] vcodec_service: reset in
<6>[ 1111.952332] vcodec_service: done
<6>[ 1112.030171] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.030208] vcodec_service: for 3288/3368…<6>[ 1112.030222] vcodec_service: reset in
<6>[ 1112.030274] vcodec_service: done
<6>[ 1112.070767] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.070795] vcodec_service: for 3288/3368…<6>[ 1112.070805] vcodec_service: reset in
<6>[ 1112.073508] vcodec_service: done
<6>[ 1112.114882] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.117967] vcodec_service: for 3288/3368…<6>[ 1112.117988] vcodec_service: reset in
<6>[ 1112.119659] vcodec_service: done
<6>[ 1112.158158] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.158184] vcodec_service: for 3288/3368…<6>[ 1112.163558] vcodec_service: reset in
<6>[ 1112.169703] vcodec_service: done
<6>[ 1112.207327] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.207360] vcodec_service: for 3288/3368…<6>[ 1112.207372] vcodec_service: reset in
<6>[ 1112.212826] vcodec_service: done
<6>[ 1112.250155] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.250184] vcodec_service: for 3288/3368…<6>[ 1112.250195] vcodec_service: reset in
<6>[ 1112.250242] vcodec_service: done
<6>[ 1112.288699] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.288722] vcodec_service: for 3288/3368…<6>[ 1112.288732] vcodec_service: reset in
<6>[ 1112.288775] vcodec_service: done
<6>[ 1112.328909] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.328946] vcodec_service: for 3288/3368…<6>[ 1112.328958] vcodec_service: reset in
<6>[ 1112.329020] vcodec_service: done
<6>[ 1112.369488] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.369513] vcodec_service: for 3288/3368…<6>[ 1112.369524] vcodec_service: reset in
<6>[ 1112.369566] vcodec_service: done
<6>[ 1112.411315] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.411352] vcodec_service: for 3288/3368…<6>[ 1112.411367] vcodec_service: reset in
<6>[ 1112.411410] vcodec_service: done
<6>[ 1112.448408] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.448440] vcodec_service: for 3288/3368…<6>[ 1112.448451] vcodec_service: reset in
<6>[ 1112.448507] vcodec_service: done
<6>[ 1112.490607] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.490660] vcodec_service: for 3288/3368…<6>[ 1112.490673] vcodec_service: reset in
<6>[ 1112.490732] vcodec_service: done
<6>[ 1112.530791] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.530832] vcodec_service: for 3288/3368…<6>[ 1112.530848] vcodec_service: reset in
<6>[ 1112.530991] vcodec_service: done
<6>[ 1112.569937] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.569983] vcodec_service: for 3288/3368…<6>[ 1112.569993] vcodec_service: reset in
<6>[ 1112.570042] vcodec_service: done
<6>[ 1112.610649] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.610681] vcodec_service: for 3288/3368…<6>[ 1112.610689] vcodec_service: reset in
<6>[ 1112.610732] vcodec_service: done
<6>[ 1112.649319] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.649353] vcodec_service: for 3288/3368…<6>[ 1112.649364] vcodec_service: reset in
<6>[ 1112.649421] vcodec_service: done
<6>[ 1112.688457] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.688487] vcodec_service: for 3288/3368…<6>[ 1112.688499] vcodec_service: reset in
<6>[ 1112.690634] vcodec_service: done
<6>[ 1112.728694] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.730383] vcodec_service: for 3288/3368…<6>[ 1112.730398] vcodec_service: reset in
<6>[ 1112.730504] vcodec_service: done
<6>[ 1112.773118] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.773163] vcodec_service: for 3288/3368…<6>[ 1112.773173] vcodec_service: reset in
<6>[ 1112.773242] vcodec_service: done
<6>[ 1112.810558] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.810596] vcodec_service: for 3288/3368…<6>[ 1112.810608] vcodec_service: reset in
<6>[ 1112.810667] vcodec_service: done
<6>[ 1112.852039] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.852074] vcodec_service: for 3288/3368…<6>[ 1112.852091] vcodec_service: reset in
<6>[ 1112.852174] vcodec_service: done
<6>[ 1112.891518] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.891606] vcodec_service: for 3288/3368…<6>[ 1112.891625] vcodec_service: reset in
<6>[ 1112.891742] vcodec_service: done
<6>[ 1112.933460] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.933506] vcodec_service: for 3288/3368…<6>[ 1112.933519] vcodec_service: reset in
<6>[ 1112.933584] vcodec_service: done
<6>[ 1112.971015] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1112.971053] vcodec_service: for 3288/3368…<6>[ 1112.977575] vcodec_service: reset in
<6>[ 1112.977891] vcodec_service: done
<6>[ 1113.017139] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1113.017181] vcodec_service: for 3288/3368…<6>[ 1113.017195] vcodec_service: reset in
<6>[ 1113.017325] vcodec_service: done
<6>[ 1113.054436] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1113.054463] vcodec_service: for 3288/3368…<6>[ 1113.054472] vcodec_service: reset in
<6>[ 1113.054513] vcodec_service: done
<6>[ 1113.129790] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1113.129857] vcodec_service: for 3288/3368…<6>[ 1113.129870] vcodec_service: reset in
<6>[ 1113.129919] vcodec_service: done
<6>[ 1113.166741] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1113.166780] vcodec_service: for 3288/3368…<6>[ 1113.166793] vcodec_service: reset in
<6>[ 1113.166850] vcodec_service: done
<6>[ 1113.206992] vcodec_service: ff9a0000.vpu_service: resetting…
<6>[ 1113.207019] vcodec_service: for 3288/3368…<6>[ 1113.207026] vcodec_service: reset in
<6>[ 1113.207092] vcodec_service: done
<6>[ 1116.473510] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 1116.473581] vcodec_service: done
720P和1080P的显示都是正常的,2592x1944 VPU编解码一直复位,log还显示iommu溢出
E/JPEG_DEC( 171): out offset big then 22bit iommu map may be error
是内存不足吗?
