用Androidtool烧写固件镜像包的时候提示“linuxroot分区不够存放镜像 ”:
合成的固件包大小为update.img(42,98,009KB)。
但是单独烧写根文件系统(linuxroot.img)到linuxroot分区有可以成功烧写,烧写打包合成的update.img文件又这样提示!!????
请问剩余的全部分给linuxroot了怎么还是提示不够存放镜像 有人遇到过这个问题吗
可以查看分区大小剩余空间明明是足够的!!!!
如果真的是不够在哪里可以看到说明确实不够存放的信息,又如何扩展呢???
版主或高手能不能给些建议。
parameter文件:
FIRMWARE_VER:4.4.2
MACHINE_MODEL:rk30sdk
MACHINE_ID:007
MANUFACTURER:RK30SDK
MAGIC: 0x5041524B
ATAG: 0x60000800
MACHINE: 3066
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
#KERNEL_IMG: 0x62008000
#FDT_NAME: rk-kernel.dtb
#RECOVER_KEY: 1,1,0,20,0
CMDLINE:console=tty0 console=ttyFIQ0 earlyprintk root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00008000@0x00002000(resource),0x00008000@0x0000A000(boot),0x00002000@0x00012000(misc),0x0001a000@0x00014000(backup),-@0x0002e000(linuxroot)
linuxroot.img文件大小4,288,327KB
串口打印分区信息:
root@firefly:~#
root@firefly:~# cat /proc/partitions
major minor #blocks name
179 0 30535680 mmcblk0
179 1 16384 mmcblk0p1
179 2 16384 mmcblk0p2
179 3 4096 mmcblk0p3
179 4 53248 mmcblk0p4
179 5 30437376 mmcblk0p5
root@firefly:~#
root@firefly:~# cat /proc/cmdline
console=tty0 console=ttyFIQ0 earlyprintk root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00008000@0x00002000(resource),0x00008000@0x0000A000(boot),0x00002000@0x00012000(misc),0x0001a000@0x00014000(backup),-@0x0002e000(linuxroot) storagemedia=emmc loader.timestamp=2017-03-20_14:29:00 hdmi.vic=-1 androidboot.mode=emmc
root@firefly:~#
root@firefly:~#
root@firefly:~# df -l
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/mmcblk0p5 29838308 4096100 24466956 15% /
udev 2055032 4 2055028 1% /dev
tmpfs 826268 380 825888 1% /run
none 4 0 4 0% /sys/fs/cgroup
none 5120 0 5120 0% /run/lock
none 2065664 0 2065664 0% /run/shm
none 102400 16 102384 1% /run/user
overflow 1024 8 1016 1% /tmp
root@firefly:~#
root@firefly:~# df -lh
Filesystem Size Used Avail Use% Mounted on
/dev/mmcblk0p5 29G 4.0G 24G 15% /
udev 2.0G 4.0K 2.0G 1% /dev
tmpfs 807M 380K 807M 1% /run
none 4.0K 0 4.0K 0% /sys/fs/cgroup
none 5.0M 0 5.0M 0% /run/lock
none 2.0G 0 2.0G 0% /run/shm
none 100M 16K 100M 1% /run/user
overflow 1.0M 8.0K 1016K 1% /tmp
root@firefly:~#
