Android Studio No serial number
請問為什麼rk3399的板子沒有serial number
下面是studio所顯示的錯誤訊息
com.android.ddmlib.AdbCommandRejectedException: device ‘(no serial number)’ not found
Error while Installing APK
我遇到同样的问题,系统设置还原一次就好了,目前不清楚原因
終於可以了, 謝謝了
The factory reset trick only worked once for me. Now it looks like the serial number is lost permanently. This is a huge problem because not only Android Studio but also systrace.py refuses to cooperate with anonymous boards. I really would like a permanent solution to this issue. I connected a fresh ff board with factory firmware, and it also did not present any serial number to ADB. The HiKey 960 board has some information regarding serial number on https://source.android.com/setup/devices Perhaps we need a similar process? I think the empty string produced by the ‘lsusb’ command is a clue. It’s USB that can’t get hold of the proper string. Why? This is important, the boards are quickly becoming useless…
mansson 发表于 2017-12-1 17:15
The factory reset trick only worked once for me. Now it looks like the serial number is lost permane …
revert this commit
commit cfe088b8e25e93339895434ce8a0c5f24101ec2d
Author: Firefly-RK3288 <service@t-firefly.com>
Date: Thu Nov 23 10:57:25 2017 +0800
1.support EC20 4G dongle    2.fix status information    3.fix the seq of display
diff --git a/system/core/drmservice/drmservice.c b/system/core/drmservice/drmservice.c
index b40403b..4e23f8c 100644
— a/system/core/drmservice/drmservice.c
+++ b/system/core/drmservice/drmservice.c
@@ -81,7 +81,7 @@ typedef unsigned char uint8;
#define DEBUG_LOG 0 //open debug info
-#define SERIALNO_FROM_IDB 0 //if 1 read sn from idb3; if 0 generate sn auto
+#define SERIALNO_FROM_IDB 1 //if 1 read sn from idb3; if 0 generate sn auto
#define SET_IFACE_DELAY 300000
#define SET_IFACE_POLLING_LOOP 20
or take this patch,then use UpgradeDllTool.exe to burn the sn
— a/system/core/init/init.cpp
+++ b/system/core/init/init.cpp
@@ -468,7 +468,7 @@ static void export_kernel_boot_props() {
const char *dst_prop;
const char *default_value;
} prop_map = {
  •    //{ "ro.boot.serialno",   "ro.serialno",   "", },
  •    { "ro.boot.serialno",   "ro.serialno",   "", },
       { "ro.boot.mode",       "ro.bootmode",   "unknown", },
       { "ro.boot.baseband",   "ro.baseband",   "unknown", },
       { "ro.boot.bootloader", "ro.bootloader", "unknown", },
