HDMI in调试失败 ,打开app,过几秒系统重启?打开摄像头应用也会重启,请问这可能是什么问题?
用的是firefly 的核心板 ,自己做的底板
核心板用开发板底板,hdmi in 是没有问题的
请联系一下商务处理
[ 218.656121] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 218.656133] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 218.656142] D1:camsys_open(739): camsys_marvin(ddf22a10) is opened!
[ 218.656684] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 420000000 Hz) in turn on
[ 218.656696] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 218.656803] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 218.656815] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 218.656909] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 218.658973] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 218.732845] Disconnect cb-Host
[ 218.941110] Indeed it is in host mode hprt0 = 00021501
[ 218.975662] D1:camsys_mrv_iommu_cb(276): map fd 18 ,client fd 48
[ 218.975662]
[ 218.975768] rk_iommu ff914000.isp_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eabb000
[ 218.978580] D1:camsys_mrv_iommu_cb(276): map fd 19 ,client fd 48
[ 218.978580]
[ 218.978608] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
[ 218.980614] D1:camsys_mrv_iommu_cb(276): map fd 20 ,client fd 48
[ 218.980614]
[ 218.980642] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
[ 218.987727] D1:camsys_mrv_iommu_cb(276): map fd 24 ,client fd 48
[ 218.987727]
[ 218.987774] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
[ 218.991251] D1:camsys_rk3288_mipihpy_cfg(104): mipi phy 0 standby!
[ 218.991282] W:camsys_phy_ops(478): mipiphy->phy_index(-1219539828) != extdev->phy.info.mipi.phy_index(0)!
[ 218.991511] D1:camsys_rk3288_mipihpy_cfg(219): mipi phy(0) turn on(lane: 0xf bit_rate: 648Mbps)
[ 219.003710] Disconnect cb-Host
[ 219.004825] start hdmiin detect
[ 219.004863] Unable to handle kernel NULL pointer dereference at virtual address 00000080
[ 219.070908] ff540000.usb suspend, HPRT0:0x21401
[ 219.072110] pgd = dd5a0000
[ 219.072117] [00000080] *pgd=00000000
[ 219.072130] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
[ 219.072137] Modules linked in: mali_kbase
[ 219.072147] CPU: 0 PID: 528 Comm: Binder_2 Not tainted 3.10.0 #31
[ 219.072152] task: dcd9bf00 ti: dc892000 task.ti: dc892000
[ 219.072161] PC is at snd_soc_write+0xa4/0xc0
[ 219.072172] LR is at es8323_codec_default+0x14/0x2b8
[ 219.072178] pc : [] lr : [] psr: 68070013
[ 219.072178] sp : dc893c70 ip : 00000000 fp : b51ca96e
[ 219.072188] r10: de01870c r9 : c0885520 r8 : 000000f3
[ 219.072192] r7 : 00000002 r6 : 00000000 r5 : 00000001 r4 : 00000000
[ 219.072196] r3 : 00000000 r2 : c0d73e6c r1 : 00000002 r0 : 00000000
[ 219.072202] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 219.072207] Control: 10c5387d Table: 1d5a006a DAC: 00000015
[ 219.072213]
[ 219.072213] PC: 0xc06435c4:
[ 219.072225] 35c4 e3c13d7f e3c3303f e5931004 e2811001 e5831004 e5925010 e3550000 0a00000d
[ 219.072236] 35e4 e285a008 e1a04005 e594c000 e1a03008 e5940004 e1a01006 e1a02007 e2844008
[ 219.072245] 3604 e12fff3c e0653004 e083300a e5133008 e3530000 1afffff3 e1a0200d e3c23d7f
[ 219.072254] 3624 e3c3303f e5932004 e2422001 e5832004 e5933000 e3130002 0a000000 eb081f66
[ 219.072263] 3644 e5963080 e1a00006 e1a01007 e1a02008 e12fff33 e8bd85f8 c0d73e6c e92d4070
[ 219.072275] 3664 e24dd028 e352001f 31a04002 23a0401f e5906084 e1a0000d e3c02d7f e3c2203f
[ 219.072284] 3684 e28d3008 e58d3000 e5922008 e0910004 30d00002 33a02000 e3520000 1a000005
[ 219.072294] 36a4 e1a00003 e1a02004 ebf0cc24 e3500000 0a000006 ea00002a e3540000 0a000003
[ 219.072300]
[ 219.072300] LR: 0xc0651050:
[ 219.072311] 1050 e3a020c0 ebffc951 e1a00004 e3a01002 e3a020f3 ebffc94d e3a01000 e1a02001
[ 219.072321] 1070 e1a00004 ebffc949 e1a00004 e3a01001 e3a02058 ebffc945 e3a0209c e3a0102b
[ 219.072330] 1090 e1a00004 ebffc941 e3a00032 ebe7cf84 e59f3010 e3a01000 e5930108 ebf12c7c
[ 219.072339] 10b0 e3a00000 e8bd8010 c0d521d0 e92d4010 e3a01002 e1a04000 e3a020f3 ebffc933
[ 219.072350] 10d0 e1a00004 e3a0102b e3a02080 ebffc92f e1a00004 e3a01008 e3a02000 ebffc92b
[ 219.072361] 10f0 e1a00004 e3a01000 e3a02032 ebffc927 e1a00004 e3a01001 e3a02072 ebffc923
[ 219.072370] 1110 e1a00004 e3a01003 e3a02059 ebffc91f e1a00004 e3a01005 e3a02000 ebffc91b
[ 219.072379] 1130 e1a00004 e3a01006 e3a020c3 ebffc917 e1a00004 e3a01009 e3a02088 ebffc913
[ 219.072387]
[ 219.072387] SP: 0xdc893bf0:
[ 219.072398] 3bf0 00100000 c5b81a78 c5b16210 c1ef06f0 c05c4f64 c0079818 000000de 00000000
[ 219.072407] 3c10 b37f7c1d c0643644 68070013 ffffffff dc893c5c c000d598 00000000 00000002
[ 219.072416] 3c30 c0d73e6c 00000000 00000000 00000001 00000000 00000002 000000f3 c0885520
[ 219.072425] 3c50 de01870c b51ca96e 00000000 dc893c70 c06510d0 c0643644 68070013 ffffffff
[ 219.072437] 3c70 c0e8af98 00000000 00000001 dc893cac dbde3600 dbde3618 de01870c c06510d0
[ 219.072446] 3c90 00000000 c065146c c0e8b2a8 00000000 dc893cac c065b15c c1ef0758 000000d0
[ 219.072457] 3cb0 00000000 01ffffff 000000d0 dc893d9c 00000000 c0d6e7c0 00000000 c00d13e8
[ 219.072465] 3cd0 00000000 00000041 c0d6dc80 00000000 00000037 c0059f00 b37f853b 00000033
[ 219.072474]
[ 219.072474] R2: 0xc0d73dec:
[ 219.072484] 3dec 00000000 00000000 c0afcd49 00000000 00000000 00000000 00000000 c0afcd9a
[ 219.072494] 3e0c 00000000 00000000 00000000 00000000 c0afcea0 00000000 00000000 00000000
[ 219.072502] 3e2c 00000000 c0afce8f 00000000 00000000 00000000 00000000 c0afceec 00000000
[ 219.072511] 3e4c 00000000 00000000 00000000 c0afceb2 00000000 00000000 00000000 00000000
[ 219.072524] 3e6c c0afd089 00000000 00000000 00000000 00000000 c0afd065 00000000 00000000
[ 219.072533] 3e8c 00000000 00000000 c0afd053 00000000 00000000 00000000 00000000 c0afd078
[ 219.072544] 3eac 00000000 00000000 00000000 00000000 c0afcef9 00000000 00000000 00000000
[ 219.072552] 3ecc 00000000 c0afcf0c 00000000 00000000 00000000 00000000 c0afcf20 00000000
[ 219.072563]
[ 219.072563] R9: 0xc08854a0:
[ 219.072573] 54a0 c03012fc 00000000 5f737562 5f646461 76697264 00007265 c03032b0 00000000
[ 219.072587] 54c0 00000000 c0303208 c0303230 00000000 c030325c c0303284 00000000 76697264
[ 219.072597] 54e0 625f7265 646e756f 61657200 5f796c6c 626f7270 00000065 73616c63 69665f73
[ 219.072613] 5500 645f646e 63697665 6c630065 5f737361 5f726f66 68636165 7665645f 00656369
[ 219.072622] 5520 c03055fc c0305620 c0305644 00000000 00000000 c0305e80 c0305edc 00000000
[ 219.072632] 5540 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 219.072641] 5560 00000000 00000000 00000000 00000000 00000000 00000000 00000000 c03092c4
[ 219.072657] 5580 c0309304 00000000 61736964 64656c62 616e6500 64656c62 74756100 6e6f006f
[ 219.072661]
[ 219.072661] R10: 0xde01868c:
[ 219.072676] 868c 00000000 00000000 00000000 00000000 00000000 de0186a0 de0186a0 00000000
[ 219.072685] 86ac 00000000 de0186b0 de0186b0 00000000 00000000 00000000 00000000 00000001
[ 219.072700] 86cc 00000001 00000000 c0ca6f60 00000000 00000000 00000000 00000000 00000000
[ 219.072709] 86ec 00000000 00000000 00000000 00000000 00000000 de018700 de018700 00000000
[ 219.072721] 870c ddd3ea40 de018810 de018610 de9816cc de9816c0 c0ca68e4 ddd3eac0 00000001
[ 219.072730] 872c 00000007 00000000 00000000 de018738 de018738 00000001 00000000 de018748
[ 219.072745] 874c de018748 00000000 00000000 00000000 00000000 de018760 de018760 c03057ec
[ 219.072754] 876c c03059c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 219.072758] Process Binder_2 (pid: 528, stack limit = 0xdc892238)
[ 219.072763] Stack: (0xdc893c70 to 0xdc894000)
[ 219.072769] 3c60: c0e8af98 00000000 00000001 dc893cac
[ 219.072776] 3c80: dbde3600 dbde3618 de01870c c06510d0 00000000 c065146c c0e8b2a8 00000000
[ 219.072787] 3ca0: dc893cac c065b15c c1ef0758 000000d0 00000000 01ffffff 000000d0 dc893d9c
[ 219.072794] 3cc0: 00000000 c0d6e7c0 00000000 c00d13e8 00000000 00000041 c0d6dc80 00000000
[ 219.072804] 3ce0: 00000037 c0059f00 b37f853b 00000033 b385969d c1203f20 00000000 00000033
[ 219.072811] 3d00: dc860d80 00000003 b37f853b de74e990 dc893d3c de68e84c dc893d34 db679fe1
[ 219.072817] 3d20: c0d968f3 00000006 00000001 c028223c 00000001 c028223c 000012d9 00000000
[ 219.072829] 3d40: 00000000 00000000 00000000 00000000 00000000 32359080 00003438 323500a1
[ 219.072836] 3d60: 00003438 dc893d88 00040006 c0234b24 dc893d9c ddb9d908 dc893d9c 00000000
[ 219.072843] 3d80: dbc7bfc0 db8da6e0 00040257 00000000 ffffffff 00000001 00000000 dc893e18
[ 219.072850] 3da0: ffffffff c0d968ec c0a39072 c0a39074 00000034 c0d968f9 dc893e18 c028336c
[ 219.072857] 3dc0: 00000001 0000000a 00000006 ffffffff 6c0a0100 ffff0006 6c0a0100 fdb470c5
[ 219.072864] 3de0: 00000032 00000000 c0d968ec c0d968ec c0dd8b40 00000014 00000014 c0283630
[ 219.072874] 3e00: c0d968ec dc893e10 c0037528 c0a39067 000000db 000012d9 00000024 c0dd8b30
[ 219.072880] 3e20: c0e61bd8 c0ca619c dc892000 00000024 c0d95fc8 c0d95fc8 00000d30 c0d95fc8
[ 219.072887] 3e40: 68070093 c0038210 00000024 c0dd8b30 00000000 00000024 c0dd8b30 c0038684
[ 219.072894] 3e60: 00000400 c0037d70 000010e0 00000000 000010e0 00000000 00000006 00000001
[ 219.072900] 3e80: 00000000 00000014 00000006 c0d96d12 00000006 00000000 00000000 68070013
[ 219.072907] 3ea0: 00000000 c0038ce0 00000000 00000000 00000000 00000000 c0d96d12 00000014
[ 219.072915] 3ec0: c58b1910 ddb9d908 00000000 00000000 dc893f00 db679000 00000001 ddd3eb40
[ 219.072923] 3ee0: dbde3600 dbde3618 c0885520 de01870c b51ca96e c0831188 c0ab275f dc893f14
[ 219.072930] 3f00: dc893f00 dc893f14 db679000 00000001 ddd3eb40 c065b310 00000000 c0546ad4
[ 219.072936] 3f20: ddd3ea00 db679001 dc893f80 c0305638 00000001 c015b9e8 db465e40 00000001
[ 219.072943] 3f40: b51ca96e dc893f80 00000000 00000000 00000000 c010b570 db465e40 b51ca96e
[ 219.072950] 3f60: 00000001 db465e40 00000001 b51ca96e 00000001 00000000 00000000 c010b8b0
[ 219.072959] 3f80: 00000000 00000000 00000001 b75550d0 b51d34c0 00000000 00000004 c000db84
[ 219.072966] 3fa0: dc892000 c000da00 b75550d0 b51d34c0 0000001a b51ca96e 00000001 00000000
[ 219.072974] 3fc0: b75550d0 b51d34c0 00000000 00000004 0000001a b485a8cc b51c6941 b51ca96e
[ 219.072981] 3fe0: b51cfcfb b485a8b0 b51b7bfd b6e6c6e4 28070010 0000001a e3b0eb95 c518d37a
[ 219.073000] [] (snd_soc_write+0xa4/0xc0) from [] (es8323_codec_default+0x14/0x2b8)
[ 219.073012] [] (es8323_codec_default+0x14/0x2b8) from [] (es8323_codec_set_reg+0x18/0xf4)
[ 219.073029] [] (es8323_codec_set_reg+0x18/0xf4) from [] (snd_start_hdmi_in_audio_route_l.part.3+0x30/0x158)
[ 219.073042] [] (snd_start_hdmi_in_audio_route_l.part.3+0x30/0x158) from [] (snd_start_hdmi_in_audio_route+0x20/0x38)
[ 219.073054] [] (snd_start_hdmi_in_audio_route+0x20/0x38) from [] (hdmiin_audio_store+0x50/0x90)
[ 219.073070] [] (hdmiin_audio_store+0x50/0x90) from [] (class_attr_store+0x18/0x24)
[ 219.073088] [] (class_attr_store+0x18/0x24) from [] (sysfs_write_file+0x7c/0xb0)
[ 219.073102] [] (sysfs_write_file+0x7c/0xb0) from [] (vfs_write+0xd4/0x16c)
[ 219.073113] [] (vfs_write+0xd4/0x16c) from [] (SyS_write+0x3c/0x60)
[ 219.073131] [] (SyS_write+0x3c/0x60) from [] (ret_fast_syscall+0x0/0x30)
[ 219.073139] Code: e5933000 e3130002 0a000000 eb081f66 (e5963080)
[ 219.073423] —[ end trace b7279e05dd2dae0c ]—
[ 219.073437] Kernel panic - not syncing: Fatal exception
[ 219.073444] CPU3: stopping
[ 219.073454] CPU: 3 PID: 153 Comm: surfaceflinger Tainted: G D 3.10.0 #31
[ 219.073471] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 219.073487] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x154/0x2c8)
[ 219.073500] [] (handle_IPI+0x154/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 219.073508] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 219.073513] Exception stack(0xdd511fb0 to 0xdd511ff8)
[ 219.073525] 1fa0: b83ab4f8 b6f74400 b6f48a75 b6f75000
[ 219.073532] 1fc0: 00000000 00000000 00000000 b83ab4f8 b8576458 b83cea24 be9cbe64 b83ce990
[ 219.073538] 1fe0: b6eb3a58 be9cb900 b6f2f259 b6f48a7a 600f0030 ffffffff
[ 219.073547] CPU1: stopping
[ 219.073555] CPU: 1 PID: 466 Comm: Binder_1 Tainted: G D 3.10.0 #31
[ 219.073572] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 219.073581] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x154/0x2c8)
[ 219.073594] [] (handle_IPI+0x154/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 219.073602] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 219.073606] Exception stack(0xdd2f5fb0 to 0xdd2f5ff8)
[ 219.073616] 5fa0: d30c01bf 00000007 00000002 b3db01a8
[ 219.073623] 5fc0: 13080000 00000007 00000005 001effb8 00000080 b7d67030 b7d6704c d30c019f
[ 219.073629] 5fe0: 001efe1a b3db0170 b4f9c4e1 b4ff2f34 000d0030 ffffffff
[ 220.056600] CPU2: stopping
[ 220.059245] CPU: 2 PID: 32 Comm: kworker/2:1 Tainted: G D 3.10.0 #31
[ 220.066327] Workqueue: pm pm_runtime_work
[ 220.070251] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 220.078606] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x154/0x2c8)
[ 220.086707] [] (handle_IPI+0x154/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 220.095150] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 220.103333] Exception stack(0xde9b3d18 to 0xde9b3d60)
[ 220.108280] 3d00: c0d95fc8 600f0093
[ 220.116298] 3d20: 00000000 00000002 00000023 00000002 c0d96d10 00000004 00000000 00000000
[ 220.124314] 3d40: 600f0013 00000002 00000000 de9b3d60 c0038ce0 c0038ce4 200f0013 ffffffff
[ 220.132336] [] (__irq_svc+0x40/0x70) from [] (vprintk_emit+0x3f0/0x444)
[ 220.140520] [] (vprintk_emit+0x3f0/0x444) from [] (vprintk+0x1c/0x20)
[ 220.148543] [] (vprintk+0x1c/0x20) from [] (DWC_PRINTF+0x18/0x24)
[ 220.156213] [] (DWC_PRINTF+0x18/0x24) from [] (dwc_otg_hcd_suspend+0x70/0x1b8)
[ 220.164995] [] (dwc_otg_hcd_suspend+0x70/0x1b8) from [] (hcd_suspend+0x8/0x10)
[ 220.173780] [] (hcd_suspend+0x8/0x10) from [] (hcd_bus_suspend+0x54/0xe8)
[ 220.182137] [] (hcd_bus_suspend+0x54/0xe8) from [] (usb_suspend_both+0xf8/0x19c)
[ 220.191091] [] (usb_suspend_both+0xf8/0x19c) from [] (usb_runtime_suspend+0x28/0x60)
[ 220.200387] [] (usb_runtime_suspend+0x28/0x60) from [] (__rpm_callback+0x38/0x68)
[ 220.209427] [] (__rpm_callback+0x38/0x68) from [] (rpm_callback+0x64/0x7c)
[ 220.217869] [] (rpm_callback+0x64/0x7c) from [] (rpm_suspend+0x2d8/0x534)
[ 220.221442] SMP: failed to stop secondary CPUs
[ 220.221447] CRU:
[ 220.221457] 00000000: 00000000 9fff0031 0fff0019 00000008 00000001 9fff0025 0fff0012 00000008
[ 220.221466] 00000020: 00000007 9fff00c5 00000000 00000008 00000007 9fff00c5 0fff0014 00000008
[ 220.221479] 00000040: 00000b00 9fff0270 0fff0138 00000008 00005111 00000000 00000000 00000000
[ 220.221488] 00000060: 00004031 0000b108 00000003 00000200 00008100 00008100 00008282 00010014
[ 220.221496] 00000080: 01885091 00c45091 0000a101 00002745 00004345 00008a00 00000200 00000200
[ 220.221505] 000000a0: 00000200 0bb8ea60 00010014 00010014 00010014 00000910 00000900 001f05dc
[ 220.221513] 000000c0: 00001703 00000707 00000040 00001501 00000242 00000742 00004141 00004041
[ 220.221521] 000000e0: 00004141 00000505 00008041 00008f8f 00000000 00000631 00001ee5 00008307
[ 220.221529] 00000100: 00001200 00010014 00004141 00000000 00000000 00000000 00000000 00000000
[ 220.221536] 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 220.221544] 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 220.221551] 00000160: 00001000 0000ff00 00003f60 00003af0 00004f80 00002e7d 0000fbf0 0000c13b
[ 220.221560] 00000180: 00000fb4 00000000 00000809 000005cc 00000000 0000fe96 00000000 0000c01e
[ 220.221572] 000001a0: 00000131 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 220.221580] 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 220.221587] 000001e0: 00000000 00000000 00000000 00640064 00000004 00000000 00000000 00000000
[ 220.221595] 00000200: 00000002 00000000 00000002 00000000 00000002 00000000 00000004 000004e0
[ 220.221602] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 220.221610] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 220.221617] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 220.221625] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 220.221635] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 220.221642] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 220.221650] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 220.221660] 00000300: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 220.221667] 00000320: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 220.221674] 00000340: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 220.221682] 00000360: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 220.221689] 00000380: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 220.221697] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 220.221709] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 220.221717] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 220.221725] 00000400: 00000000 9fff0031 0fff0019 00000008 00000001 9fff0025 0fff0012 00000008
[ 220.508163] [] (rpm_suspend+0x2d8/0x534) from [] (__pm_runtime_suspend+0x5c/0x74)
[ 220.517201] [] (__pm_runtime_suspend+0x5c/0x74) from [] (usb_runtime_idle+0x24/0x2c)
[ 220.526497] [] (usb_runtime_idle+0x24/0x2c) from [] (__rpm_callback+0x38/0x68)
[ 220.535281] [] (__rpm_callback+0x38/0x68) from [] (rpm_idle+0x270/0x368)
[ 220.543553] [] (rpm_idle+0x270/0x368) from [] (pm_runtime_work+0x68/0x94)
[ 220.551911] [] (pm_runtime_work+0x68/0x94) from [] (process_one_work+0x29c/0x458)
[ 220.560949] [] (process_one_work+0x29c/0x458) from [] (worker_thread+0x194/0x2d4)
[ 220.569996] [] (worker_thread+0x194/0x2d4) from [] (kthread+0xa0/0xac)
[ 220.578092] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x3c)
DDR Version 1.00 20160217
SRX
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
U-Boot 2014.10-RK3288-10 (Jun 20 2016 - 14:47:54)
CPU: rk3288
这是重启部分的打印信息
我用的TC358749XBG芯片,出现了下面的问题:
E/CameraHal_Marvin( 146): HAL-MOCKUP: HalReadI2CMem(1230): bus_num(4) or reg_addr_size(2) is invalidate
请问版主知道怎么解决吗?
