我自己编译的内核和ubuntu系统反复重启。我不装界面系统不会重启。后来我测试我装了network-manager后也会反复重启。无奈我下载官网的也是反复重启。
求解答,应该如何解决。
可以把完整的内核log用附件附上来
zhansb 发表于 2017-5-4 09:15
可以把完整的内核log用附件附上来
DDR Version 1.00 20141007
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-01 (Jan 21 2015 - 16:36:44)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_MODEL:rk3288!
Unknow param: MACHINE_ID:007!
Unknow param: MANUFACTURER:RK3288!
no adc node
can’t find dts node for led
pmic:act8846
#Boot ver: 2015-01-21#2.19
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
failed to find part:misc
misc partition not found!
Hit any key to stop autoboot: 1 0
kernel @ 0x02000000 (0x004f9040)
ramdisk @ 0x04bf0000 (0x00299a2c)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 0481e000, end 0482a9f2 … OK
Uncompressing Linux… done, booting the kernel.
[ 0.000000] Linux version 3.14.0 (wanghh@tchipserver2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #129 SMP Mon Jun 6 15:15:00 CST 2016
[ 0.000000] Machine model: Firefly rk3288
[ 0.000000] ion heap(cma): base(0) size(28000000) align(0)
[ 0.000000] ion_reserve: dma_declare_contiguous failed -38
[ 0.000000] Boot mode: RAMFS (10) flag: (0x5242c30c)
[ 0.000000] PERCPU: Embedded 9 pages/cpu @ee7af000 s14144 r8192 d14528 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768
[ 0.000000] Kernel command line: earlyprintk=ttyS2,115200 console=tty0 console=ttyS2,115200 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00010000@0x00002000(boot),0x00002000@0x00012000(backup),-@0x00014000(linuxroot) storagemedia=emmc loader.timestamp=2015-01-21_16:36:44
[ 0.000000] Memory: 2063600K/2097152K available (8830K kernel code, 424K rwdata, 2224K rodata, 501K init, 631K bss, 33552K reserved, 1318912K highmem)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0bcb9fc (12047 kB)
[ 0.000000] .init : 0xc0c00000 - 0xc0c7d740 ( 502 kB)
[ 0.000000] .data : 0xc0d00000 - 0xc0d6a028 ( 425 kB)
[ 0.000000] .bss : 0xc0d6a028 - 0xc0e08000 ( 632 kB)
[ 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 2863311519744ns
[ 0.000021] Switching to timer-based delay loop
[ 0.001705] Console: colour dummy device 80x30
[ 0.002816] console [tty0] enabled
[ 0.002872] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.002933] pid_max: default: 32768 minimum: 301
[ 0.003144] Security Framework initialized
[ 0.003181] Yama: becoming mindful.
[ 0.003283] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.003326] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.018480] Initializing cgroup subsys devices
[ 0.018526] Initializing cgroup subsys freezer
[ 0.018595] CPU: Testing write buffer coherency: ok
[ 0.018673] ftrace: allocating 27728 entries in 82 pages
[ 0.073891] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.074176] Setting up static identity map for 0x844608 - 0x8446c0
[ 0.077221] CPU1: Booted secondary processor
[ 0.077261] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.079080] CPU2: Booted secondary processor
[ 0.079110] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.080939] CPU3: Booted secondary processor
[ 0.080969] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.081105] Brought up 4 CPUs
[ 0.081207] SMP: Total of 4 processors activated.
[ 0.081225] CPU: All CPU(s) started in SVC mode.
[ 0.082006] devtmpfs: initialized
[ 0.088755] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.090190] pinctrl core: initialized pinctrl subsystem
[ 0.090639] regulator-dummy: no parameters
[ 0.090960] NET: Registered protocol family 16
[ 0.091726] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.092323] cpuidle: using governor ladder
[ 0.092346] cpuidle: using governor menu
[ 0.109559] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.109596] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.109681] Switched to clocksource arch_sys_counter
[ 0.119699] bio: create slab at 0
[ 0.120558] vccsys: no parameters
[ 0.120855] vcc33_io: no parameters
[ 0.120914] reg-fixed-voltage vcc33-io.15: Failed to find supply vin
[ 0.121043] reg-fixed-voltage vcc33-io.15: Failed to register regulator: -517
[ 0.121081] platform vcc33-io.15: Driver reg-fixed-voltage requests probe deferral
[ 0.121320] vcc_5v: 5000 mV
[ 0.121398] vcc_5v: supplied by vccsys
[ 0.121823] vcc5_host1: no parameters
[ 0.122227] sata_pwr: no parameters
[ 0.122645] vcc5_host2: no parameters
[ 0.123033] wifi_regulator: no parameters
[ 0.123719] SCSI subsystem initialized
[ 0.124027] usbcore: registered new interface driver usbfs
[ 0.124112] usbcore: registered new interface driver hub
[ 0.124270] usbcore: registered new device driver usb
[ 0.124467] Linux video capture interface: v2.00
[ 0.124547] pps_core: LinuxPPS API ver. 1 registered
[ 0.124567] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.124621] PTP clock support registered
[ 0.125316] ion_drm_heap_create: 0@0
[ 0.125515] Rockchip ion module is successfully loaded (v1.1)
[ 0.125887] platform ff9a0000.vpu_service: of_parse_phandle_with_args(/vpu_service@ff9a0000) => -2
[ 0.126761] Advanced Linux Sound Architecture Driver Initialized.
[ 0.127433] Bluetooth: Core ver 2.20
[ 0.127492] NET: Registered protocol family 31
[ 0.127512] Bluetooth: HCI device and connection manager initialized
[ 0.127543] Bluetooth: HCI socket layer initialized
[ 0.127568] Bluetooth: L2CAP socket layer initialized
[ 0.127619] Bluetooth: SCO socket layer initialized
[ 0.128067] cfg80211: Calling CRDA to update world regulatory domain
[ 0.129609] Could not create debugfs ‘set_ftrace_filter’ entry
[ 0.129639] Could not create debugfs ‘set_ftrace_notrace’ entry
[ 0.176436] NET: Registered protocol family 2
[ 0.177088] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.177206] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[ 0.177652] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.177746] TCP: reno registered
[ 0.177778] UDP hash table entries: 512 (order: 2, 24576 bytes)
[ 0.177847] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[ 0.178205] NET: Registered protocol family 1
[ 0.178501] Unpacking initramfs…
[ 0.375551] Freeing initrd memory: 2660K (c4bf0000 - c4e89000)
[ 0.376207] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 0.377059] probe device ff9a0000.vpu_service
[ 0.377418] ff9a0000.vpu_service: power on
[ 0.377504] reg_base f0056000
[ 0.377525] probe device ff9a0000.vpu_service
[ 0.377555] checking hw id 4831
[ 0.378128] vpu_service: power off…
[ 0.378179] done
[ 0.378200] init success
[ 0.379572] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.380921] bounce pool size: 64 pages
[ 0.391046] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.392328] NTFS driver 2.1.30 [Flags: R/W].
[ 0.392739] fuse init (API version 7.22)
[ 0.393348] msgmni has been set to 1459
[ 0.395002] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.395037] io scheduler noop registered
[ 0.395056] io scheduler deadline registered
[ 0.395429] io scheduler cfq registered (default)
[ 0.397280] backlight.10 supply power not found, using dummy regulator
[ 0.400469] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-2364208
[ 0.400509] dma-pl330 ff250000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.401453] dma-pl330 ffb20000.dma-controller: Loaded driver for PL330 DMAC-2364208
[ 0.401490] dma-pl330 ffb20000.dma-controller: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.401952] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.403905] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87, base_baud = 1500000) is a 16550A
[ 0.404737] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88, base_baud = 1500000) is a 16550A
[ 0.405561] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89, base_baud = 1500000) is a 16550A
[ 1.220764] console [ttyS2] enabled
[ 1.225055] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90, base_baud = 1500000) is a 16550A
[ 1.235345] [drm] Initialized drm 1.1.0 20060810
[ 1.240444] rockchip-lvds ff96c000.lvds: Failed to get supply ‘avdd1v0’: -517
[ 1.247639] platform ff96c000.lvds: Driver rockchip-lvds requests probe deferral
[ 1.256216] usbcore: registered new interface driver udl
[ 1.262064] panel.11 supply power not found, using dummy regulator
[ 1.268479] platform panel.11: Driver panel-simple requests probe deferral
[ 1.276139] platform vga-encoder.23: Driver vga-encoder requests probe deferral
[ 1.284019] platform vga-connector.24: Driver vga-connector requests probe deferral
[ 1.296869] loop: module loaded
[ 1.300076] lkdtm: No crash points registered, enable through debugfs
[ 1.307286] tun: Universal TUN/TAP device driver, 1.6
[ 1.312372] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.319511] stmmaceth ff290000.ethernet: phy regulator is not available yet, deferred probing
[ 1.328191] platform ff290000.ethernet: Driver stmmaceth requests probe deferral
[ 1.335872] PPP generic driver version 2.4.2
[ 1.340401] PPP BSD Compression module registered
[ 1.345116] PPP Deflate Compression module registered
[ 1.350208] PPP MPPE Compression module registered
[ 1.355009] NET: Registered protocol family 24
[ 1.359494] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.369172] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.376634] Broadcom 43xx driver loaded [ Features: LS ]
[ 1.382442] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.388982] ehci-platform: EHCI generic platform driver
[ 1.394392] platform ff500000.usb: Driver ehci-platform requests probe deferral
[ 1.401975] usbcore: registered new interface driver cdc_acm
[ 1.407644] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.415753] usbcore: registered new interface driver usb-storage
[ 1.421920] usbcore: registered new interface driver usbserial
[ 1.427807] usbcore: registered new interface driver usbserial_generic
[ 1.434404] usbserial: USB Serial support registered for generic
[ 1.441349] rk3x-i2c ff140000.i2c: using default SCL frequency: 100000
[ 1.992919] dwc2 ff540000.usb: DWC OTG Controller
[ 1.997931] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
[ 2.005064] dwc2 ff540000.usb: irq 57, io mem 0x00000000
[ 2.010694] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.017498] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.024748] usb usb1: Product: DWC OTG Controller
[ 2.029463] usb usb1: Manufacturer: Linux 3.14.0 dwc2_hsotg
[ 2.035072] usb usb1: SerialNumber: ff540000.usb
[ 2.040443] hub 1-0:1.0: USB hub found
[ 2.044243] hub 1-0:1.0: 1 port detected
[ 2.200582] tpm_i2c_infineon 1-0020: could not request locality
[ 2.229968] rk3x-i2c ff140000.i2c: Initialized RK3xxx I2C bus at f0074000
[ 2.236919] rk3x-i2c ff150000.i2c: using default SCL frequency: 100000
[ 2.243790] rk3x-i2c ff150000.i2c: Initialized RK3xxx I2C bus at f007e000
[ 2.250811] rk3x-i2c ff160000.i2c: using default SCL frequency: 100000
[ 2.257574] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at f0092000
[ 2.264605] rk3x-i2c ff170000.i2c: using default SCL frequency: 100000
[ 2.271382] rk3x-i2c ff170000.i2c: Initialized RK3xxx I2C bus at f0094000
[ 2.284592] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 2.295505] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 2.304410] act8846_i2c_probe,line=898
[ 2.309168] act8846_parse_dt,line=746
[ 2.313348] act8846_i2c_probe: act8846_pmic_hold=1
[ 2.318169] act8846_i2c_probe: act8846_pmic_sleep=1
[ 2.323092] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 2.328600] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 2.336526] vcc_sys: 1200 mV
[ 2.341710] vcc_io: 3300 mV
[ 2.345936] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 2.353122] act_dcdc4: 2000 mV
[ 2.358464] vccio_sd: 3300 mV
[ 2.363750] vdd10_lcd: 1050 mV
[ 2.369077] afvdd_28: 1800 mV
[ 2.374390] vcca_33: 3300 mV
[ 2.379544] vcc_lan: 3300 mV
[ 2.384748] vdd_10: 1100 mV
[ 2.389844] vcc_18: 1800 mV
[ 2.394915] vcc18_lcd: 1850 mV
[ 2.398412] rk3x-i2c ff650000.i2c: Initialized RK3xxx I2C bus at f0096000
[ 2.409716] rk3x-i2c ff660000.i2c: Initialized RK3xxx I2C bus at f0098000
[ 2.416838] lirc_dev: IR Remote Control driver registered, major 245
[ 2.423332] IR NEC protocol handler initialized
[ 2.427871] IR RC5(x) protocol handler initialized
[ 2.429758] usb 1-1: new high-speed USB device number 2 using dwc2
[ 2.438871] IR RC6 protocol handler initialized
[ 2.443432] IR JVC protocol handler initialized
[ 2.447969] IR Sony protocol handler initialized
[ 2.452605] IR RC5 (streamzap) protocol handler initialized
[ 2.458183] IR SANYO protocol handler initialized
[ 2.462906] IR Sharp protocol handler initialized
[ 2.467616] IR MCE Keyboard/mouse protocol handler initialized
[ 2.473466] IR LIRC bridge handler initialized
[ 2.478284] Registered IR keymap rc-empty
[ 2.482708] input: gpio_ir_recv as /devices/gpio-ir-receiver.13/rc/rc0/input0
[ 2.490140] rc0: gpio_ir_recv as /devices/gpio-ir-receiver.13/rc/rc0
[ 2.496935] input: MCE IR Keyboard/Mouse (gpio-rc-recv) as /devices/virtual/input/input1
[ 2.505481] rc rc0: lirc_dev: driver ir-lirc-codec (gpio-rc-recv) registered at minor = 0
[ 2.514246] usbcore: registered new interface driver uvcvideo
[ 2.520039] USB Video Class driver (1.1.1)
[ 2.526395] rockchip-thermal ff280000.tsadc: Missing tshut mode property, using default (gpio)
[ 2.535057] rockchip-thermal ff280000.tsadc: Missing tshut-polarity property, using default (low)
[ 2.545128] device-mapper: ioctl: 4.27.0-ioctl (2013-10-30) initialised: dm-devel@redhat.com
[ 2.553835] device-mapper: verity-chromeos: dm-verity-chromeos registered
[ 2.560658] device-mapper: bootcache: version 0.1.0 loaded
[ 2.567641] sdhci: Secure Digital Host Controller Interface driver
[ 2.573861] sdhci: Copyright(c) Pierre Ossman
[ 2.578226] Synopsys Designware Multimedia Card Interface Driver
[ 2.585039] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
[ 2.591889] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
[ 2.597676] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 2.608748] ERROR: could not get clock /dwmmc@ff0d0000:card_ext_clock(2)
[ 2.615550] wifi_regulator: could not add device link mmc2 err -2
[ 2.629923] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[ 2.636618] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.643756] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 2.648601] hub 1-1:1.0: USB hub found
[ 2.652399] hub 1-1:1.0: 4 ports detected
[ 2.699710] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.719710] dwmmc_rockchip ff0d0000.dwmmc: 1 slots initialized
[ 2.725894] dwmmc_rockchip ff0f0000.dwmmc: Using internal DMA controller.
[ 2.732705] dwmmc_rockchip ff0f0000.dwmmc: Version ID is 270a
[ 2.738465] dwmmc_rockchip ff0f0000.dwmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 2.748408] ff0f0000.dwmmc supply vmmc not found, using dummy regulator
[ 2.755065] dwmmc_rockchip ff0f0000.dwmmc: Failed getting OCR mask: -22
[ 2.761740] mmc0 supply card-external-vcc not found, using dummy regulator
[ 2.768624] regulator-dummy: could not add device link mmc0 err -2
[ 2.782982] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.789978] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.796955] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.805166] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.829680] dwmmc_rockchip ff0f0000.dwmmc: could not set regulator OCR (-22)
[ 2.836728] dwmmc_rockchip ff0f0000.dwmmc: failed to enable vmmc regulator
[ 2.859868] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.880030] dwmmc_rockchip ff0f0000.dwmmc: 1 slots initialized
[ 2.886786] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.894078] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.900223] dwc2 ff580000.usb: DWC OTG Controller
[ 2.906175] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
[ 2.906483] usbcore: registered new interface driver usbhid
[ 2.906490] usbhid: USB HID core driver
[ 2.907173] ashmem: initialized
[ 2.908774] rk3288-dmc ff610000.dmc: DDR3 Device
[ 2.908795] rk3288-dmc ff610000.dmc: DDR3 Device
[ 2.935561] dwc2 ff580000.usb: irq 55, io mem 0x00000000
[ 2.938586] ES8323 2-0010: es8323_i2c_probe() Can not read property spk-con-gpio
[ 2.948837] ES8323 2-0010: es8323 probe i2c recv ok
[ 2.949314] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.949342] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.949363] usb usb2: Product: DWC OTG Controller
[ 2.949400] usb usb2: Manufacturer: Linux 3.14.0 dwc2_hsotg
[ 2.949418] usb usb2: SerialNumber: ff580000.usb
[ 2.958867] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 2.969189] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.969278] mmc2: new high speed SDIO card at address 0001
[ 2.979864] brcmfmac: brcmf_sdio_drivestrengthinit: No SDIO Drive strength init done for chip 4339 rev 2 pmurev 23
[ 2.981877] brcmfmac_sdio mmc2:0001:1: Direct firmware load failed with error -2
[ 2.981914] brcmfmac_sdio mmc2:0001:1: Falling back to user helper
[ 3.022737] mmc0: unrecognised EXT_CSD revision 8
[ 3.022762] mmc0: error -22 whilst initialising MMC card
[ 3.038328] usb 1-1.1: new full-speed USB device number 3 using dwc2
[ 3.039486] hub 2-0:1.0: USB hub found
[ 3.039507] hub 2-0:1.0: 1 port detected
[ 3.039717] clk: failed to reparent sclk_i2s0 to sclk_i2s0: -22
[ 3.039966] rockchip-hdmi-audio hdmi_audio.6: ASoC: CODEC dw-hdmi-audio not registered
[ 3.039986] rockchip-hdmi-audio hdmi_audio.6: register card failed (-517)
[ 3.039994] platform hdmi_audio.6: Driver rockchip-hdmi-audio requests probe deferral
[ 3.040254] ES8323 2-0010: es8323_probe:register ISR (irq=193)
[ 3.184461] usb 1-1.1: New USB device found, idVendor=062a, idProduct=4182
[ 3.191578] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.199024] usb 1-1.1: Product: 2.4G Keyboard Mouse
[ 3.204117] usb 1-1.1: Manufacturer: MOSART Semi.
[ 3.221570] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/ff540000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:062A:4182.0001/input/input2
[ 3.235780] hid-generic 0003:062A:4182.0001: input,hidraw0: USB HID v1.10 Keyboard [MOSART Semi. 2.4G Keyboard Mouse] on usb-ff540000.usb-1.1/input0
[ 3.256214] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/ff540000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:062A:4182.0002/input/input3
[ 3.268551] hid-generic 0003:062A:4182.0002: input,hiddev0,hidraw1: USB HID v1.10 Mouse [MOSART Semi. 2.4G Keyboard Mouse] on usb-ff540000.usb-1.1/input1
[ 3.641854] random: nonblocking pool is initialized
[ 3.716142] rockchip-es8323 sound.22: ES8323 HiFi ↔ ff890000.i2s mapping ok
[ 3.728628] rockchip-es8323 sound.22: es8323 audio init success.
[ 3.734746] u32 classifier
[ 3.737449] Actions configured
[ 3.740861] Netfilter messages via NETLINK v0.30.
[ 3.745595] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 3.751946] ctnetlink v0.93: registering with nfnetlink.
[ 3.757466] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.762844] TCP: cubic registered
[ 3.766156] Initializing XFRM netlink socket
[ 3.770755] NET: Registered protocol family 10
[ 3.775718] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.781288] sit: IPv6 over IPv4 tunneling driver
[ 3.786225] NET: Registered protocol family 17
[ 3.790700] NET: Registered protocol family 15
[ 3.795182] Bridge firewalling registered
[ 3.799201] l2tp_core: L2TP core driver, V2.0
[ 3.803565] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 3.808350] lib80211: common routines for IEEE802.11 drivers
[ 3.814574] mali ffa30000.gpu: freq:600000000 Hz volt:1250000 uV
[ 3.821746] mali ffa30000.gpu: initial freq = 594000000
[ 3.827206] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 3.834014] mali ffa30000.gpu: Probed as mali0
[ 3.838683] ThumbEE CPU extension supported.
[ 3.842976] Registering SWP/SWPB emulation handler
[ 3.848207] regulator-dummy: disabling
[ 3.852167] vcc33_io: no parameters
[ 3.855679] vcc33_io: supplied by vcc_io
[ 3.860842] rockchip-lvds ff96c000.lvds: neither panel nor encoder found
[ 3.867647] platform ff96c000.lvds: Driver rockchip-lvds requests probe deferral
[ 3.875206] panel.11 supply power not found, using dummy regulator
[ 3.881610] platform vga-encoder.23: Driver vga-encoder requests probe deferral
[ 3.889548] stmmaceth ff290000.ethernet: rk_gmac_setup: clock input or output? (input).
[ 3.897575] stmmaceth ff290000.ethernet: rk_gmac_setup: TX delay(0x30).
[ 3.904203] stmmaceth ff290000.ethernet: rk_gmac_setup: RX delay(0x10).
[ 3.910833] stmmaceth ff290000.ethernet: rk_gmac_setup: init for RGMII
[ 3.917420] stmmaceth ff290000.ethernet: gmac_clk_init: clock input from PHY
[ 3.929511] stmmaceth ff290000.ethernet: no reset control found
[ 3.935439] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 3.940500] Ring mode enabled
[ 3.943557] DMA HW capability register supported
[ 3.948087] Normal descriptors
[ 3.951427] RX Checksum Offload Engine supported (type 2)
[ 3.956910] TX Checksum insertion supported
[ 3.961185] Wake-Up On Lan supported
[ 3.964875] Enable RX Mitigation via HW Watchdog Timer
[ 4.027625] libphy: stmmac: probed
[ 4.031078] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
[ 4.037166] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01)
[ 4.042990] platform ff500000.usb: Driver ehci-platform requests probe deferral
[ 4.050715] rockchip-hdmi-audio hdmi_audio.6: ASoC: CODEC dw-hdmi-audio not registered
[ 4.058687] rockchip-hdmi-audio hdmi_audio.6: register card failed (-517)
[ 4.065536] platform hdmi_audio.6: Driver rockchip-hdmi-audio requests probe deferral
[ 4.075994] rockchip-lvds ff96c000.lvds: neither panel nor encoder found
[ 4.082786] platform ff96c000.lvds: Driver rockchip-lvds requests probe deferral
[ 4.090404] platform ff500000.usb: Driver ehci-platform requests probe deferral
[ 4.097796] rockchip-hdmi-audio hdmi_audio.6: ASoC: CODEC dw-hdmi-audio not registered
[ 4.105720] rockchip-hdmi-audio hdmi_audio.6: register card failed (-517)
[ 4.112509] platform hdmi_audio.6: Driver rockchip-hdmi-audio requests probe deferral
[ 4.121891] rockchip-drm display-subsystem.4: bound ff940000.vop (ops vop_component_ops)
[ 4.130176] rockchip-drm display-subsystem.4: bound ff930000.vop (ops vop_component_ops)
[ 4.138353] dwhdmi-rockchip ff980000.hdmi: Detected HDMI controller 0x20:0xa:0xa0:0xc1
[ 4.146278] dwhdmi-rockchip ff980000.hdmi: Detected HDMI config_id 0xbf:0x22:0xc2:0x0
[ 4.154382] dw-hdmi-audio dw-hdmi-audio: hdmi audio init success.
[ 4.160490] rockchip-drm display-subsystem.4: bound ff980000.hdmi (ops dw_hdmi_rockchip_ops)
[ 4.168978] vga-encoder vga-encoder.23: bound vga-connector.24 (ops vga_connector_ops)
[ 4.172531] dwhdmi-rockchip ff980000.hdmi: monitor does not support audio
[ 4.183675] rockchip-lvds ff96c000.lvds: bound vga-encoder.23 (ops vga_encoder_ops)
[ 4.191344] rockchip-drm display-subsystem.4: bound ff96c000.lvds (ops rockchip_lvds_component_ops)
[ 4.200504] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.207101] [drm] No driver support for vblank timestamp query.
[ 4.261876] rockchip-vop ff940000.vop: Attached to iommu domain
[ 4.299616] rockchip-vop ff930000.vop: Attached to iommu domain
[ 4.299644] rk3288-dmc ff610000.dmc: suspending DVFS and going to max freq
[ 4.324471] Console: switching to colour frame buffer device 240x67
[ 4.360726] rockchip-drm display-subsystem.4: fb0: frame buffer device
[ 4.367385] rockchip-drm display-subsystem.4: registered panic notifier
[ 4.374051] rockchip-drm display-subsystem.4: rk drm load success
[ 4.380374] platform ff500000.usb: Driver ehci-platform requests probe deferral
[ 4.387884] dw-hdmi-audio dw-hdmi-audio: jack report [4]
[ 4.394126] rockchip-hdmi-audio hdmi_audio.6: dw-hdmi-hifi ↔ ff890000.i2s mapping ok
[ 4.402383] input: RockchipHDMI HDMI Jack as /devices/hdmi_audio.6/sound/card1/input4
[ 4.410443] rockchip-hdmi-audio hdmi_audio.6: hdmi audio init success.
[ 4.417107] platform ff500000.usb: Driver ehci-platform requests probe deferral
[ 4.424742] platform ff500000.usb: Driver ehci-pDDR Version 1.00 20141007
Memory OK
Memory OK
CPU: rk3288
128 MiB
storage init OK!
GetParam
no adc node
pmic:act8846
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
我使用的这个镜像是Firefly-rk3288_Ubuntu_1404_2016_6171712_Beta.img
我使用了很多镜像都是反复重启.
板子是Firefly-rk3288 2GB/16GB 2016-12-26
我的供电不足就会这样, 换城5v 2A INPUT
