新的sdk降低分辨率至720p systemUI 崩溃
在rk3399- firefly.dts修改默认分辨率为720p,,systemUI会崩溃 ,可以测试 一下
[ 157.185650] binder: 1228: binder_alloc_buf, no vma
[ 157.185693] binder: 631:631 transaction failed 29201, size 100-0
[ 157.185980] binder: 1228: binder_alloc_buf, no vma
[ 157.185997] binder: 631:631 transaction failed 29201, size 96-0
[ 157.214429] binder: 631:1080 transaction failed 29189, size 328-0
[ 157.215145] binder: 631:631 transaction failed 29189, size 100-0
[ 157.339147] binder: 631:631 transaction failed 29189, size 84-0
[ 159.462375] binder: undelivered transaction 39346
[ 159.462663] binder: undelivered transaction 39345
[ 159.465771] binder: 631:1080 transaction failed 29189, size 328-0
[ 159.469153] binder: 631:631 transaction failed 29189, size 100-0
[ 159.630833] binder: 631:631 transaction failed 29189, size 84-0
[ 161.596982] binder: undelivered transaction 48467
[ 161.597229] binder: undelivered transaction 48465
[ 161.599424] binder: 631:1080 transaction failed 29189, size 328-0
[ 161.622210] binder: 631:631 transaction failed 29189, size 100-0
[ 161.732233] binder: 631:631 transaction failed 29189, size 84-0
截屏
这是串口信息,具体systemUI信息在AS下看
可不可以提供一下logcat的信息
01-18 16:59:26.215 627-654/system_process V/sjf: onDown
01-18 16:59:26.348 627-654/system_process V/sjf: onUpOrCancel
01-18 16:59:26.350 2738-2738/com.android.systemui I/Process: Sending signal. PID: 2738 SIG: 9
                                                         --------- beginning of system
01-18 16:59:26.362 627-654/system_process V/WindowManagerService: Remove Window{fcf584c u0 Application Error: com.android.systemui} client=63f407f, surface=Surface(name=Application Error: com.android.systemui_Force_To_Dual) Callers=com.android.server.wm.WindowManagerService.removeWindow:3552 com.android.server.wm.Session.remove:226 android.view.ViewRootImpl.dispatchDetachedFromWindow:3099 android.view.ViewRootImpl.doDie:5606
01-18 16:59:26.364 627-654/system_process I/DualScreen: WindowManagerService->findFocusedWindowLocked->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:26.364 627-654/system_process I/DualScreen: WindowManagerService->findFocusedWindowLocked->windows:[Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}, Window{a4382bd u0 KeyguardScrim}, Window{2f7d58f u0 StatusBar}, Window{fcf584c u0 Application Error: com.android.systemui EXITING}]
01-18 16:59:26.364 627-654/system_process V/WindowManagerService: Looking for focus: 3 = Window{fcf584c u0 Application Error: com.android.systemui EXITING}, flags=25296898, canReceive=false
01-18 16:59:26.364 627-654/system_process V/WindowManagerService: Looking for focus: 2 = Window{2f7d58f u0 StatusBar}, flags=-2122055608, canReceive=false
01-18 16:59:26.364 627-654/system_process V/WindowManagerService: Looking for focus: 1 = Window{a4382bd u0 KeyguardScrim}, flags=17893632, canReceive=false
01-18 16:59:26.364 627-654/system_process V/WindowManagerService: Looking for focus: 0 = Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}, flags=-2121203456, canReceive=true
01-18 16:59:26.365 627-654/system_process V/WindowManagerService: findFocusedWindow: Found new focus @ 0 = Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}
01-18 16:59:26.365 627-654/system_process I/DualScreen: findFocusedWindow->win:Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}
01-18 16:59:26.365 627-654/system_process V/WindowManagerService: Changing focus from Window{fcf584c u0 Application Error: com.android.systemui EXITING} to Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher} Callers=com.android.server.wm.WindowManagerService.removeWindowLocked:3623 com.android.server.wm.WindowManagerService.removeWindow:3552 com.android.server.wm.Session.remove:226 android.view.ViewRootImpl.dispatchDetachedFromWindow:3099
01-18 16:59:26.366 627-654/system_process D/WindowManagerService: Input focus has changed to Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}
01-18 16:59:26.366 627-654/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:26.369 627-658/system_process I/WindowManagerService: Focus moving from Window{fcf584c u0 Application Error: com.android.systemui EXITING} to Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}
01-18 16:59:26.370 627-658/system_process I/WindowManagerService: Gaining focus: Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}
01-18 16:59:26.370 627-658/system_process I/WindowManagerService: Losing focus: Window{fcf584c u0 Application Error: com.android.systemui EXITING}
01-18 16:59:26.371 627-2394/system_process W/InputMethodManagerService: Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@eb40111 attribute=null, token = android.os.BinderProxy@2407042
01-18 16:59:26.397 237-374/? D/AudioHardwareTiny: start_output_stream
01-18 16:59:26.398 237-374/? D/AudioHardwareTiny: Device : 0x8040a
01-18 16:59:26.398 237-374/? D/AudioHardwareTiny: SampleRate : 44100
01-18 16:59:26.398 237-374/? D/AudioHardwareTiny: Channels : 2
01-18 16:59:26.398 237-374/? D/AudioHardwareTiny: Formate : 0
01-18 16:59:26.398 237-374/? D/AudioHardwareTiny: PreiodSize : 2048
01-18 16:59:26.398 237-374/? D/alsa_route: route_info->sound_card 1, route_info->devices 0
01-18 16:59:26.398 237-374/? D/alsa_route: route_set_controls() set route 11
01-18 16:59:26.410 627-880/system_process W/InputDispatcher: channel ‘2f7d58f StatusBar (server)’ ~ Consumer closed input channel or an error occurred. events=0x9
01-18 16:59:26.410 627-880/system_process E/InputDispatcher: channel ‘2f7d58f StatusBar (server)’ ~ Channel is unrecoverably broken and will be disposed!
01-18 16:59:26.415 627-1190/system_process W/AudioService: Current remote volume controller died, unregistering
01-18 16:59:26.415 627-1074/system_process D/WifiService: Client connection lost with reason: 4
01-18 16:59:26.415 627-1188/system_process V/ActivityManager: Death received in com.android.server.am.ActivityManagerService$AppDeathRecipient@42a5a4f for thread android.os.BinderProxy@5a6b5dc
01-18 16:59:26.415 627-1190/system_process W/VolumeController: Error calling dismiss
android.os.DeadObjectException
at android.os.BinderProxy.transactNative(Native Method)
at android.os.BinderProxy.transact(Binder.java:503)
at android.media.IVolumeController$Stub$Proxy.dismiss(IVolumeController.java:162)
at com.android.server.audio.AudioService$VolumeController.postDismiss(AudioService.java:5902)
at com.android.server.audio.AudioService.setVolumeController(AudioService.java:5750)
at com.android.server.audio.AudioService$4.binderDied(AudioService.java:5759)
at android.os.BinderProxy.sendDeathNotice(Binder.java:558)
01-18 16:59:26.415 627-1189/system_process D/GraphicsStats: Buffer count: 2
01-18 16:59:26.416 627-1190/system_process I/WindowManagerService: WIN DEATH: Window{2f7d58f u0 StatusBar}
01-18 16:59:26.416 627-2737/system_process D/ConnectivityService: ConnectivityService NetworkRequestInfo binderDied(NetworkRequest [ id=6, legacyType=-1, ], android.os.BinderProxy@316c077)
01-18 16:59:26.416 627-1075/system_process D/ConnectivityService: releasing NetworkRequest NetworkRequest [ id=6, legacyType=-1, ]
01-18 16:59:26.416 627-1075/system_process D/ConnectivityService: sending notification RELEASED for NetworkRequest [ id=6, legacyType=-1, ]
01-18 16:59:26.417 627-627/system_process W/WallpaperManagerService: Wallpaper service gone: ComponentInfo{com.android.systemui/com.android.systemui.ImageWallpaper}
01-18 16:59:26.418 627-1190/system_process V/WindowManagerService: Remove Window{2f7d58f u0 StatusBar} client=fa02cee, surface=null Callers=com.android.server.wm.WindowState$DeathRecipient.binderDied:1219 android.os.BinderProxy.sendDeathNotice:558
01-18 16:59:26.418 627-1190/system_process W/InputDispatcher: Attempted to unregister already unregistered input channel ‘2f7d58f StatusBar (server)’
01-18 16:59:26.418 627-1190/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:26.418 627-1075/system_process E/ConnectivityService: RemoteException caught trying to send a callback msg for NetworkRequest [ id=6, legacyType=-1, ]
01-18 16:59:26.419 627-1190/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:26.421 627-1190/system_process I/DualScreen: WindowManagerService->findFocusedWindowLocked->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:26.421 627-1190/system_process I/DualScreen: WindowManagerService->findFocusedWindowLocked->windows:[Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}, Window{a4382bd u0 KeyguardScrim}, Window{fcf584c u0 Application Error: com.android.systemui EXITING}]
01-18 16:59:26.421 627-1190/system_process V/WindowManagerService: Looking for focus: 2 = Window{fcf584c u0 Application Error: com.android.systemui EXITING}, flags=25296898, canReceive=false
01-18 16:59:26.421 627-1190/system_process V/WindowManagerService: Looking for focus: 1 = Window{a4382bd u0 KeyguardScrim}, flags=17893632, canReceive=false
01-18 16:59:26.421 627-1190/system_process V/WindowManagerService: Looking for focus: 0 = Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}, flags=-2121203456, canReceive=true
01-18 16:59:26.421 627-1188/system_process I/ActivityManager: Process com.android.systemui (pid 2738) has died
01-18 16:59:26.421 627-1188/system_process V/ActivityManager: Dying app: ProcessRecord{ba2d4e9 2738:com.android.systemui/u0a15}, pid: 2738, thread: android.os.BinderProxy@5a6b5dc
01-18 16:59:26.421 627-1188/system_process V/ActivityManager: Disconnecting binding IntentBindRecord{f19d00a com.android.bluetooth/.pbap.BluetoothPbapService:act=android.bluetooth.IBluetoothPbap}: shouldUnbind=false
01-18 16:59:26.421 627-1190/system_process V/WindowManagerService: findFocusedWindow: Found new focus @ 0 = Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}
01-18 16:59:26.421 627-1188/system_process V/ActivityManager: Disconnecting binding IntentBindRecord{6d9e875 com.android.bluetooth/.hid.HidService:act=android.bluetooth.IBluetoothInputDevice}: shouldUnbind=false
01-18 16:59:26.421 627-1190/system_process I/DualScreen: findFocusedWindow->win:Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}
01-18 16:59:26.421 627-1188/system_process V/ActivityManager: Disconnecting binding IntentBindRecord{b60c3ac com.android.bluetooth/.pan.PanService:act=android.bluetooth.IBluetoothPan}: shouldUnbind=false
01-18 16:59:26.421 627-1188/system_process V/ActivityManager: Killing binding IntentBindRecord{1fefa45 CR com.android.systemui/.ImageWallpaper:act=android.service.wallpaper.WallpaperService}: shouldUnbind=true
01-18 16:59:26.421 627-1188/system_process W/ActivityManager: Scheduling restart of crashed service com.android.systemui/.SystemUIService in 0ms
01-18 16:59:26.422 627-1188/system_process W/ActivityManager: Scheduling restart of crashed service com.android.systemui/.ImageWallpaper in 0ms
01-18 16:59:26.422 627-1188/system_process I/ActivityManager: No more processes in UidRecord{a025eb0 u0a15 P / 0 procs}
01-18 16:59:26.422 627-1188/system_process I/ActivityManager: *** Enqueueing dispatch uid changed!
01-18 16:59:26.423 627-1188/system_process I/ActivityManager: Retrieving available item: com.android.server.am.UidRecord$ChangeItem@a1e4310
01-18 16:59:26.423 627-1188/system_process W/ActivityManager: Re-adding persistent process ProcessRecord{ba2d4e9 2738:com.android.systemui/u0a15}
01-18 16:59:26.423 627-1188/system_process I/ActivityManager: Creating new process uid: UidRecord{25e64e4 u0a15 CE / 0 procs}
01-18 16:59:26.423 627-1188/system_process I/ActivityManager: Retrieving available item: com.android.server.am.UidRecord$ChangeItem@c282758
01-18 16:59:26.438 627-1188/system_process I/ActivityManager: Start proc 2814:com.android.systemui/u0a15 for restart com.android.systemui
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Removing app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} from list mLRUActivities with 1 entries
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Record #0 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Removing app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} from list mStoppingActivities with 0 entries
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Removing app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} from list mGoingToSleepActivities with 0 entries
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Removing app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} from list mWaitingVisibleActivities with 0 entries
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Removing app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} from list mFinishingActivities with 0 entries
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Removing app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} from history with 1 entries
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Record #0 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}: app=ProcessRecord{49f77a9 1816:com.android.launcher3/u0a6}
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Set 1291 android.process.acore adj 9: cch-empty
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Setting process group of android.process.acore to 0
01-18 16:59:26.440 627-1188/system_process D/ActivityManager: Process state change from SB to CE next pss in 30000: ProcessRecord{d5976f9 1291:android.process.acore/u0a2}
01-18 16:59:26.440 627-1188/system_process V/ActivityManager: Proc state change of android.process.acore to 16
01-18 16:59:26.440 627-1188/system_process D/ActivityManager: Checking proc [[com.android.providers.userdictionary, com.android.providers.contacts]] state changes: old = 3, new = 16
01-18 16:59:26.440 627-1188/system_process I/ActivityManager: Changes in ProcessRecord{d5976f9 1291:android.process.acore/u0a2}: 2
01-18 16:59:26.440 627-1188/system_process I/ActivityManager: Retrieving available item: com.android.server.am.ActivityManagerService$ProcessChangeItem@14a31b8
01-18 16:59:26.440 627-1188/system_process I/ActivityManager: *** Enqueueing dispatch processes changed!
01-18 16:59:26.440 627-1188/system_process I/ActivityManager: Item 14a31b8 1291:android.process.acore/u0a2: changes=2 procState=16 foreground=false type=cch-empty source=null target=null
01-18 16:59:26.440 627-1188/system_process V/ActivityManager: Set 2133 com.android.onetimeinitializer adj 11: cch-empty
01-18 16:59:26.440 627-1188/system_process V/ActivityManager: Set 1764 com.android.settings adj 13: cch-empty
01-18 16:59:26.441 627-1188/system_process W/ActivityManager: Wtf, activity ActivityRecord{6bf4494 u0 com.android.provision/.DefaultActivity t2 f} in proc activity list not using proc ProcessRecord{19b8e39 1794:com.android.provision/u0a11}?!? Using null instead.
01-18 16:59:26.441 627-1188/system_process V/ActivityManager: Set 1592 com.android.externalstorage adj 15: cch-empty
01-18 16:59:26.441 627-1188/system_process D/ActivityManager: oom: memFactor=0 last=0 allowLow=true numProcs=23 last=23
01-18 16:59:26.441 627-1188/system_process I/ActivityManager: Changes in UidRecord{25e64e4 u0a15 CE / 1 procs}: proc state from -1 to 16
01-18 16:59:26.441 627-1188/system_process I/ActivityManager: Changes in UidRecord{f969c54 u0a2 CE / 1 procs}: proc state from 3 to 16
01-18 16:59:26.441 627-1188/system_process I/ActivityManager: Retrieving available item: com.android.server.am.UidRecord$ChangeItem@237f68e
01-18 16:59:26.441 627-1188/system_process D/ActivityManager: Did OOM ADJ in 2ms
01-18 16:59:26.441 627-653/system_process V/ActivityManager: Bringing up ServiceRecord{ffb6939 u0 com.android.systemui/.SystemUIService} android.content.Intent$FilterComparison@773cd02
01-18 16:59:26.441 627-653/system_process V/ActivityManager_MU: bringUpServiceLocked: appInfo.uid=10015 app=ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.441 627-654/system_process I/ActivityManager: *** Delivering 3 uid changes
01-18 16:59:26.441 627-654/system_process I/ActivityManager: UID gone uid=10015
01-18 16:59:26.441 627-653/system_process V/ActivityManager: Bringing up ServiceRecord{2cabaa1 u0 com.android.systemui/.ImageWallpaper} android.content.Intent$FilterComparison@281e5e6c
01-18 16:59:26.442 627-654/system_process I/ActivityManager: UID CHANGED uid=10015: 16
01-18 16:59:26.442 627-654/system_process I/ActivityManager: UID CHANGED uid=10002: 16
01-18 16:59:26.442 627-653/system_process V/ActivityManager_MU: bringUpServiceLocked: appInfo.uid=10015 app=ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.442 627-654/system_process I/ActivityManager: *** Delivering 1 process changes
01-18 16:59:26.489 627-2394/system_process V/ActivityManager: Binding process pid 2814 to record ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.489 627-2394/system_process V/ActivityManager: New death recipient com.android.server.am.ActivityManagerService$AppDeathRecipient@1469d4d for thread android.os.BinderProxy@58ca002
01-18 16:59:26.490 627-2394/system_process V/ActivityManager_MU: generateApplicationProvidersLocked, app.info.uid = 10015
01-18 16:59:26.490 627-2394/system_process V/ActivityManager: New app record ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} thread=android.os.BinderProxy@58ca002 pid=2814
01-18 16:59:26.490 627-2394/system_process V/ActivityManager: Binding proc com.android.systemui with config {1.0 dualscreenflag=DISABLE ?mcc?mnc zh_CN ldltr sw540dp w961dp h468dp 213dpi lrg long land -touch -keyb/v/h dpad/v s.5}
01-18 16:59:26.490 627-2394/system_process D/ActivityManager: Not moving, persistent: ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: ensureActivitiesVisible behind ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3} configChanges=0x0
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: Make visible? ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3} finishing=false state=RESUMED
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: Ensuring correct configuration: ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: Configuration unchanged in ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: Skipping: already visible at ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: Fullscreen: at ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}
01-18 16:59:26.491 627-2394/system_process V/ActivityManager_MU: realStartServiceLocked, ServiceRecord.uid = 10015, ProcessRecord.uid = 10015
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: >>> EXECUTING create of ServiceRecord{ffb6939 u0 com.android.systemui/.SystemUIService} in app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.491 627-2394/system_process D/ActivityManager: Not moving, persistent: ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: Set 2133 com.android.onetimeinitializer adj 9: cch-empty
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: Set 1764 com.android.settings adj 11: cch-empty
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: Set 1634 com.rockchip.devicetest adj 11: cch-empty
01-18 16:59:26.491 627-2394/system_process W/ActivityManager: Wtf, activity ActivityRecord{6bf4494 u0 com.android.provision/.DefaultActivity t2 f} in proc activity list not using proc ProcessRecord{19b8e39 1794:com.android.provision/u0a11}?!? Using null instead.
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: Set 1592 com.android.externalstorage adj 13: cch-empty
01-18 16:59:26.492 627-2394/system_process V/ActivityManager: Set 1597 com.android.music adj 13: cch-empty
01-18 16:59:26.492 627-2394/system_process V/ActivityManager: Set 2814 com.android.systemui adj -12: fixed
01-18 16:59:26.492 627-2394/system_process D/ActivityManager: oom: memFactor=0 last=0 allowLow=true numProcs=23 last=23
01-18 16:59:26.492 627-2394/system_process I/ActivityManager: Changes in UidRecord{25e64e4 u0a15 P / 1 procs}: proc state from 16 to 0
01-18 16:59:26.492 627-2394/system_process I/ActivityManager: *** Enqueueing dispatch uid changed!
01-18 16:59:26.492 627-2394/system_process I/ActivityManager: Retrieving available item: com.android.server.am.UidRecord$ChangeItem@237f68e
01-18 16:59:26.492 627-2394/system_process D/ActivityManager: Did OOM ADJ in 2ms
01-18 16:59:26.494 627-2394/system_process V/ActivityManager: Sending arguments to: ServiceRecord{ffb6939 u0 com.android.systemui/.SystemUIService} android.content.Intent$FilterComparison@773cd02 args=null
01-18 16:59:26.494 627-2394/system_process V/ActivityManager: >>> EXECUTING start of ServiceRecord{ffb6939 u0 com.android.systemui/.SystemUIService} in app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.494 627-2394/system_process V/ActivityManager_MU: realStartServiceLocked, ServiceRecord.uid = 10015, ProcessRecord.uid = 10015
01-18 16:59:26.494 627-2394/system_process V/ActivityManager: >>> EXECUTING create of ServiceRecord{2cabaa1 u0 com.android.systemui/.ImageWallpaper} in app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.494 627-2394/system_process D/ActivityManager: Not moving, persistent: ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.495 627-2394/system_process V/ActivityManager: Set 2133 com.android.onetimeinitializer adj 11: cch-empty
01-18 16:59:26.495 627-2394/system_process V/ActivityManager: Set 1764 com.android.settings adj 13: cch-empty
01-18 16:59:26.495 627-2394/system_process V/ActivityManager: Set 1634 com.rockchip.devicetest adj 13: cch-empty
01-18 16:59:26.495 627-2394/system_process W/ActivityManager: Wtf, activity ActivityRecord{6bf4494 u0 com.android.provision/.DefaultActivity t2 f} in proc activity list not using proc ProcessRecord{19b8e39 1794:com.android.provision/u0a11}?!? Using null instead.
01-18 16:59:26.495 627-2394/system_process V/ActivityManager: Set 1592 com.android.externalstorage adj 15: cch-empty
01-18 16:59:26.495 627-2394/system_process V/ActivityManager: Set 1597 com.android.music adj 15: cch-empty
01-18 16:59:26.496 627-2394/system_process D/ActivityManager: oom: memFactor=0 last=0 allowLow=true numProcs=23 last=23
01-18 16:59:26.496 627-2394/system_process D/ActivityManager: Did OOM ADJ in 1ms
01-18 16:59:26.496 627-2394/system_process V/ActivityManager: >>> EXECUTING bind of ServiceRecord{2cabaa1 u0 com.android.systemui/.ImageWallpaper} in app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.497 627-654/system_process I/ActivityManager: *** Delivering 1 uid changes
01-18 16:59:26.497 627-654/system_process I/ActivityManager: UID CHANGED uid=10015: 0
01-18 16:59:26.514 2814-2814/com.android.systemui W/System: ClassLoader referenced unknown path: /system/priv-app/SystemUI/lib/arm64
01-18 16:59:26.523 627-1188/system_process V/ActivityManager: Register receiver android.content.IntentFilter@92ced13: null
01-18 16:59:26.524 2814-2814/com.android.systemui V/SystemUIService: Starting SystemUI services.
01-18 16:59:26.528 627-650/system_process V/ActivityManager: Register receiver android.content.IntentFilter@46f476f: null
01-18 16:59:26.533 627-651/system_process V/ActivityManager: Register receiver android.content.IntentFilter@4d2eb8b: null
01-18 16:59:26.542 627-2737/system_process V/ActivityManager: Register receiver android.content.IntentFilter@a82b567: null
01-18 16:59:26.544 627-658/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:26.544 627-1188/system_process V/ActivityManager: Register receiver android.content.IntentFilter@37b4103: null
01-18 16:59:26.546 627-658/system_process W/AppOps: Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
01-18 16:59:26.547 627-658/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:26.556 627-1190/system_process D/ActivityManager: Not moving, persistent: ProcessRecord{ec76eaf 627:system/1000}
01-18 16:59:26.556 627-1190/system_process I/ActivityManager: Adjust success: true
01-18 16:59:26.559 627-1188/system_process V/ActivityManager: Register receiver android.content.IntentFilter@fad5d75: Intent { act=android.intent.action.BATTERY_CHANGED flg=0x60000010 (has extras) }
01-18 16:59:26.559 627-1188/system_process I/ActivityManager: Broadcast intent Intent { act=android.intent.action.BATTERY_CHANGED flg=0x60000010 (has extras) } on background queue
01-18 16:59:26.559 627-1188/system_process V/BroadcastQueue: Schedule broadcasts [background]: current=false
01-18 16:59:26.559 627-1188/system_process I/ActivityManager: Broadcast intent Intent { act=android.intent.action.SIM_STATE_CHANGED flg=0x4000010 (has extras) } on background queue
01-18 16:59:26.559 627-653/system_process V/BroadcastQueue: Received BROADCAST_INTENT_MSG
01-18 16:59:26.559 627-1188/system_process V/BroadcastQueue: Schedule broadcasts [background]: current=true
01-18 16:59:26.559 627-1188/system_process I/ActivityManager: Broadcast intent Intent { act=android.intent.action.SERVICE_STATE flg=0x10 (has extras) } on background queue
01-18 16:59:26.559 627-1188/system_process I/ActivityManager: Broadcast intent Intent { act=android.media.RINGER_MODE_CHANGED flg=0x34000010 (has extras) } on foreground queue
01-18 16:59:26.559 627-1188/system_process V/BroadcastQueue: Schedule broadcasts [foreground]: current=false
01-18 16:59:26.559 627-653/system_process V/BroadcastQueue: processNextBroadcast [background]: 3 broadcasts, 0 ordered broadcasts
01-18 16:59:26.559 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [background] BroadcastRecord{9035bf1 u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:26.559 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [background] to registered BroadcastFilter{f5a2798 u0 ReceiverList{a39cd7b 2814 com.android.systemui/10015/u0 remote:cc8a10a}}: BroadcastRecord{9035bf1 u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:26.560 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{f5a2798 u0 ReceiverList{a39cd7b 2814 com.android.systemui/10015/u0 remote:cc8a10a}} : BroadcastRecord{9035bf1 u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:26.560 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [background] BroadcastRecord{9035bf1 u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:26.560 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [background] BroadcastRecord{9d7c3d6 u-1 android.intent.action.SIM_STATE_CHANGED}
01-18 16:59:26.560 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [background] to registered BroadcastFilter{f5a2798 u0 ReceiverList{a39cd7b 2814 com.android.systemui/10015/u0 remote:cc8a10a}}: BroadcastRecord{9d7c3d6 u-1 android.intent.action.SIM_STATE_CHANGED}
01-18 16:59:26.560 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{f5a2798 u0 ReceiverList{a39cd7b 2814 com.android.systemui/10015/u0 remote:cc8a10a}} : BroadcastRecord{9d7c3d6 u-1 android.intent.action.SIM_STATE_CHANGED}
01-18 16:59:26.560 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [background] BroadcastRecord{9d7c3d6 u-1 android.intent.action.SIM_STATE_CHANGED}
01-18 16:59:26.560 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [background] BroadcastRecord{c0dc657 u-1 android.intent.action.SERVICE_STATE}
01-18 16:59:26.560 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [background] to registered BroadcastFilter{f5a2798 u0 ReceiverList{a39cd7b 2814 com.android.systemui/10015/u0 remote:cc8a10a}}: BroadcastRecord{c0dc657 u-1 android.intent.action.SERVICE_STATE}
01-18 16:59:26.560 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{f5a2798 u0 ReceiverList{a39cd7b 2814 com.android.systemui/10015/u0 remote:cc8a10a}} : BroadcastRecord{c0dc657 u-1 android.intent.action.SERVICE_STATE}
01-18 16:59:26.561 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [background] BroadcastRecord{c0dc657 u-1 android.intent.action.SERVICE_STATE}
01-18 16:59:26.561 627-653/system_process V/BroadcastQueue: Received BROADCAST_INTENT_MSG
01-18 16:59:26.561 627-653/system_process V/BroadcastQueue: processNextBroadcast [foreground]: 1 broadcasts, 0 ordered broadcasts
01-18 16:59:26.561 627-908/system_process V/ActivityManager: Register receiver android.content.IntentFilter@2962544: null
01-18 16:59:26.561 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [foreground] BroadcastRecord{fe0c62d u-1 android.media.RINGER_MODE_CHANGED}
01-18 16:59:26.561 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [foreground] to registered BroadcastFilter{f5a2798 u0 ReceiverList{a39cd7b 2814 com.android.systemui/10015/u0 remote:cc8a10a}}: BroadcastRecord{fe0c62d u-1 android.media.RINGER_MODE_CHANGED}
01-18 16:59:26.561 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{f5a2798 u0 ReceiverList{a39cd7b 2814 com.android.systemui/10015/u0 remote:cc8a10a}} : BroadcastRecord{fe0c62d u-1 android.media.RINGER_MODE_CHANGED}
01-18 16:59:26.561 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [foreground] BroadcastRecord{fe0c62d u-1 android.media.RINGER_MODE_CHANGED}
01-18 16:59:26.564 627-650/system_process V/ActivityManager: Register receiver android.content.IntentFilter@be70f3: null
01-18 16:59:26.568 627-651/system_process V/ActivityManager: Register receiver android.content.IntentFilter@4a2d8dc: null
01-18 16:59:26.570 627-627/system_process D/TrustManagerService: Removing dead TrustListener.
01-18 16:59:26.577 627-658/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:26.594 237-374/? D/AudioFlinger: mixer(0xf3999008) throttle end: throttle time(46)
01-18 16:59:26.608 2814-2828/com.android.systemui D/WVMExtractor: Failed to open libwvm.so
01-18 16:59:26.618 2814-2830/com.android.systemui I/OMXClient: Using client-side OMX mux.
01-18 16:59:26.625 627-1189/system_process V/ActivityManager: Register receiver android.content.IntentFilter@d46ce86: null
01-18 16:59:26.678 2814-2837/com.android.systemui I/OMXClient: Using client-side OMX mux.
01-18 16:59:26.682 627-651/system_process D/ActivityManager: Skipping, home stack task: TaskRecord{aa0a518 #3 ?? U=0 sz=1}
01-18 16:59:26.696 2814-2814/com.android.systemui I/vol.Events: writeEvent collection_started
01-18 16:59:26.701 627-1189/system_process V/ActivityManager: Register receiver android.content.IntentFilter@3b14d12: Intent { act=android.media.RINGER_MODE_CHANGED flg=0x34000010 (has extras) }
01-18 16:59:26.702 627-1189/system_process I/ActivityManager: Broadcast intent Intent { act=android.media.RINGER_MODE_CHANGED flg=0x34000010 (has extras) } on foreground queue
01-18 16:59:26.702 627-1189/system_process V/BroadcastQueue: Schedule broadcasts [foreground]: current=false
01-18 16:59:26.702 627-1189/system_process I/ActivityManager: Broadcast intent Intent { act=android.media.INTERNAL_RINGER_MODE_CHANGED_ACTION flg=0x34000010 (has extras) } on foreground queue
01-18 16:59:26.702 627-653/system_process V/BroadcastQueue: Received BROADCAST_INTENT_MSG
01-18 16:59:26.702 627-1189/system_process V/BroadcastQueue: Schedule broadcasts [foreground]: current=true
01-18 16:59:26.702 627-653/system_process V/BroadcastQueue: processNextBroadcast [foreground]: 2 broadcasts, 0 ordered broadcasts
01-18 16:59:26.702 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [foreground] BroadcastRecord{4d3285e u-1 android.media.RINGER_MODE_CHANGED}
01-18 16:59:26.702 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [foreground] to registered BroadcastFilter{9c2dd99 u0 ReceiverList{95586e0 2814 com.android.systemui/10015/u0 remote:5e57ce3}}: BroadcastRecord{4d3285e u-1 android.media.RINGER_MODE_CHANGED}
01-18 16:59:26.702 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{9c2dd99 u0 ReceiverList{95586e0 2814 com.android.systemui/10015/u0 remote:5e57ce3}} : BroadcastRecord{4d3285e u-1 android.media.RINGER_MODE_CHANGED}
01-18 16:59:26.702 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [foreground] BroadcastRecord{4d3285e u-1 android.media.RINGER_MODE_CHANGED}
01-18 16:59:26.702 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [foreground] BroadcastRecord{ae9043f u-1 android.media.INTERNAL_RINGER_MODE_CHANGED_ACTION}
01-18 16:59:26.702 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [foreground] to registered BroadcastFilter{9c2dd99 u0 ReceiverList{95586e0 2814 com.android.systemui/10015/u0 remote:5e57ce3}}: BroadcastRecord{ae9043f u-1 android.media.INTERNAL_RINGER_MODE_CHANGED_ACTION}
01-18 16:59:26.702 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{9c2dd99 u0 ReceiverList{95586e0 2814 com.android.systemui/10015/u0 remote:5e57ce3}} : BroadcastRecord{ae9043f u-1 android.media.INTERNAL_RINGER_MODE_CHANGED_ACTION}
01-18 16:59:26.703 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [foreground] BroadcastRecord{ae9043f u-1 android.media.INTERNAL_RINGER_MODE_CHANGED_ACTION}
01-18 16:59:26.703 2814-2814/com.android.systemui W/Vibrator: Failed to vibrate; no vibrator service.
01-18 16:59:26.704 2814-2840/com.android.systemui I/vol.Events: writeEvent external_ringer_mode_changed normal
01-18 16:59:26.704 2814-2840/com.android.systemui I/vol.Events: writeEvent internal_ringer_mode_changed normal
01-18 16:59:26.740 2814-2841/com.android.systemui I/OMXClient: Using client-side OMX mux.
01-18 16:59:26.786 2814-2840/com.android.systemui I/vol.Events: writeEvent level_changed STREAM_ALARM 6
01-18 16:59:26.787 627-1191/system_process V/ActivityManager: Register receiver android.content.IntentFilter@c3c310c: null
01-18 16:59:26.788 2814-2840/com.android.systemui I/vol.Events: writeEvent level_changed STREAM_BLUETOOTH_SCO 7
01-18 16:59:26.789 627-1191/system_process V/ActivityManager: Register receiver android.content.IntentFilter@10151f8: null
01-18 16:59:26.791 627-2395/system_process V/ActivityManager: Register receiver android.content.IntentFilter@af595a4: null
01-18 16:59:26.791 2814-2840/com.android.systemui I/vol.Events: writeEvent level_changed STREAM_MUSIC 11
01-18 16:59:26.795 627-1191/system_process V/ActivityManager: Register receiver android.content.IntentFilter@4695f09: null
01-18 16:59:26.795 2814-2840/com.android.systemui I/vol.Events: writeEvent level_changed STREAM_RING 5
01-18 16:59:26.795 627-1190/system_process V/ActivityManager: Register receiver android.content.IntentFilter@fbfe2c5: null
01-18 16:59:26.796 2814-2840/com.android.systemui I/vol.Events: writeEvent level_changed STREAM_SYSTEM 5
01-18 16:59:26.799 2814-2840/com.android.systemui I/vol.Events: writeEvent level_changed STREAM_VOICE_CALL 4
01-18 16:59:26.799 2814-2814/com.android.systemui D/StorageNotification: Notifying about private volume: VolumeInfo{private}:
type=PRIVATE diskId=null partGuid=null mountFlags=0 mountUserId=-1
state=MOUNTED
fsType=null fsUuid=null fsLabel=null
path=/data internalPath=null
01-18 16:59:26.806 627-2395/system_process V/ActivityManager: Register receiver android.content.IntentFilter@b1007e6: null
01-18 16:59:26.809 627-651/system_process V/ActivityManager: Register receiver android.content.IntentFilter@9c4bc72: Intent { act=android.intent.action.BATTERY_CHANGED flg=0x60000010 (has extras) }
01-18 16:59:26.809 627-651/system_process I/ActivityManager: Broadcast intent Intent { act=android.intent.action.BATTERY_CHANGED flg=0x60000010 (has extras) } on background queue
01-18 16:59:26.809 627-651/system_process V/BroadcastQueue: Schedule broadcasts [background]: current=false
01-18 16:59:26.809 627-653/system_process V/BroadcastQueue: Received BROADCAST_INTENT_MSG
01-18 16:59:26.809 627-653/system_process V/BroadcastQueue: processNextBroadcast [background]: 1 broadcasts, 0 ordered broadcasts
01-18 16:59:26.809 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [background] BroadcastRecord{c9e2dbe u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:26.809 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [background] to registered BroadcastFilter{d2b1c79 u0 ReceiverList{30df540 2814 com.android.systemui/10015/u0 remote:c5b28c3}}: BroadcastRecord{c9e2dbe u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:26.810 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{d2b1c79 u0 ReceiverList{30df540 2814 com.android.systemui/10015/u0 remote:c5b28c3}} : BroadcastRecord{c9e2dbe u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:26.810 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [background] BroadcastRecord{c9e2dbe u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:26.814 627-908/system_process V/ActivityManager: <<< DONE EXECUTING ServiceRecord{ffb6939 u0 com.android.systemui/.SystemUIService}: nesting=2, inDestroying=false, app=ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.816 627-651/system_process V/ActivityManager: <<< DONE EXECUTING ServiceRecord{ffb6939 u0 com.android.systemui/.SystemUIService}: nesting=1, inDestroying=false, app=ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.816 627-651/system_process V/ActivityManager: Nesting at 0 of com.android.systemui/.SystemUIService
01-18 16:59:26.818 627-1190/system_process V/ActivityManager: <<< DONE EXECUTING ServiceRecord{2cabaa1 u0 com.android.systemui/.ImageWallpaper}: nesting=2, inDestroying=false, app=ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.819 627-1188/system_process V/ActivityManager: PUBLISHING ServiceRecord{2cabaa1 u0 com.android.systemui/.ImageWallpaper} Intent { act=android.service.wallpaper.WallpaperService cmp=com.android.systemui/.ImageWallpaper }: android.os.BinderProxy@3d8e1f
01-18 16:59:26.819 627-1188/system_process V/ActivityManager: Publishing to: ConnectionRecord{c1e1308 u0 CR FGSA UI com.android.systemui/.ImageWallpaper:@a2362fa}
01-18 16:59:26.819 627-1188/system_process V/ActivityManager: <<< DONE EXECUTING ServiceRecord{2cabaa1 u0 com.android.systemui/.ImageWallpaper}: nesting=1, inDestroying=false, app=ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.819 627-1188/system_process V/ActivityManager: Nesting at 0 of com.android.systemui/.ImageWallpaper
01-18 16:59:26.819 627-1188/system_process V/ActivityManager: No more executingServices of com.android.systemui/.ImageWallpaper
01-18 16:59:26.842 627-650/system_process I/StatusBarManagerService: registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@67d256c
01-18 16:59:26.843 627-908/system_process V/ActivityManager: Register receiver android.content.IntentFilter@2380735: null
01-18 16:59:26.977 627-1074/system_process D/WifiService: New client listening to asynchronous messages
01-18 16:59:26.992 627-2395/system_process V/ActivityManager: Register receiver android.content.IntentFilter@8eee1b1: null
01-18 16:59:27.145 627-908/system_process V/ActivityManager: Register receiver android.content.IntentFilter@85ee7ed: null
01-18 16:59:27.150 627-1190/system_process V/ActivityManager: Register receiver android.content.IntentFilter@f4f15e9: null
01-18 16:59:27.153 627-2737/system_process V/ActivityManager: Register receiver android.content.IntentFilter@7fa27a5: Intent { act=android.intent.action.BATTERY_CHANGED flg=0x60000010 (has extras) }
01-18 16:59:27.154 627-2737/system_process I/ActivityManager: Broadcast intent Intent { act=android.intent.action.BATTERY_CHANGED flg=0x60000010 (has extras) } on background queue
01-18 16:59:27.154 627-2737/system_process V/BroadcastQueue: Schedule broadcasts [background]: current=false
01-18 16:59:27.154 627-653/system_process V/BroadcastQueue: Received BROADCAST_INTENT_MSG
01-18 16:59:27.154 627-653/system_process V/BroadcastQueue: processNextBroadcast [background]: 1 broadcasts, 0 ordered broadcasts
01-18 16:59:27.154 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [background] BroadcastRecord{b8a9921 u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:27.154 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [background] to registered BroadcastFilter{b905b88 u0 ReceiverList{5b99b2b 2814 com.android.systemui/10015/u0 remote:c35577a}}: BroadcastRecord{b8a9921 u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:27.154 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{b905b88 u0 ReceiverList{5b99b2b 2814 com.android.systemui/10015/u0 remote:c35577a}} : BroadcastRecord{b8a9921 u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:27.154 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [background] BroadcastRecord{b8a9921 u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:27.167 627-657/system_process D/BluetoothManagerService: Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@8b4bf07:true
01-18 16:59:27.168 627-1189/system_process V/ActivityManager: Register receiver android.content.IntentFilter@d93a834: Intent { act=android.intent.action.SIM_STATE_CHANGED flg=0x4000010 (has extras) }
01-18 16:59:27.168 627-1189/system_process I/ActivityManager: Broadcast intent Intent { act=android.intent.action.SIM_STATE_CHANGED flg=0x4000010 (has extras) } on background queue
01-18 16:59:27.168 627-1189/system_process V/BroadcastQueue: Schedule broadcasts [background]: current=false
01-18 16:59:27.168 627-1189/system_process I/ActivityManager: Broadcast intent Intent { act=android.intent.action.SERVICE_STATE flg=0x10 (has extras) } on background queue
01-18 16:59:27.168 627-1189/system_process V/BroadcastQueue: Schedule broadcasts [background]: current=true
01-18 16:59:27.168 627-1189/system_process I/ActivityManager: Broadcast intent Intent { act=android.provider.Telephony.SPN_STRINGS_UPDATED flg=0x20000010 (has extras) } on background queue
01-18 16:59:27.168 627-653/system_process V/BroadcastQueue: Received BROADCAST_INTENT_MSG
01-18 16:59:27.168 627-653/system_process V/BroadcastQueue: processNextBroadcast [background]: 3 broadcasts, 0 ordered broadcasts
01-18 16:59:27.168 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [background] BroadcastRecord{6dd13a0 u-1 android.intent.action.SIM_STATE_CHANGED}
01-18 16:59:27.169 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [background] to registered BroadcastFilter{15444a3 u0 ReceiverList{1835bd2 2814 com.android.systemui/10015/u0 remote:156a65d}}: BroadcastRecord{6dd13a0 u-1 android.intent.action.SIM_STATE_CHANGED}
01-18 16:59:27.169 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{15444a3 u0 ReceiverList{1835bd2 2814 com.android.systemui/10015/u0 remote:156a65d}} : BroadcastRecord{6dd13a0 u-1 android.intent.action.SIM_STATE_CHANGED}
01-18 16:59:27.169 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [background] BroadcastRecord{6dd13a0 u-1 android.intent.action.SIM_STATE_CHANGED}
01-18 16:59:27.169 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [background] BroadcastRecord{5dc4b59 u-1 android.intent.action.SERVICE_STATE}
01-18 16:59:27.169 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [background] to registered BroadcastFilter{15444a3 u0 ReceiverList{1835bd2 2814 com.android.systemui/10015/u0 remote:156a65d}}: BroadcastRecord{5dc4b59 u-1 android.intent.action.SERVICE_STATE}
01-18 16:59:27.169 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{15444a3 u0 ReceiverList{1835bd2 2814 com.android.systemui/10015/u0 remote:156a65d}} : BroadcastRecord{5dc4b59 u-1 android.intent.action.SERVICE_STATE}
01-18 16:59:27.169 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [background] BroadcastRecord{5dc4b59 u-1 android.intent.action.SERVICE_STATE}
01-18 16:59:27.169 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [background] BroadcastRecord{d97631e u-1 android.provider.Telephony.SPN_STRINGS_UPDATED}
01-18 16:59:27.169 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [background] to registered BroadcastFilter{15444a3 u0 ReceiverList{1835bd2 2814 com.android.systemui/10015/u0 remote:156a65d}}: BroadcastRecord{d97631e u-1 android.provider.Telephony.SPN_STRINGS_UPDATED}
01-18 16:59:27.169 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{15444a3 u0 ReceiverList{1835bd2 2814 com.android.systemui/10015/u0 remote:156a65d}} : BroadcastRecord{d97631e u-1 android.provider.Telephony.SPN_STRINGS_UPDATED}
01-18 16:59:27.170 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [background] BroadcastRecord{d97631e u-1 android.provider.Telephony.SPN_STRINGS_UPDATED}
01-18 16:59:27.170 627-650/system_process V/ActivityManager: Register receiver android.content.IntentFilter@dc87ff: null
01-18 16:59:27.174 627-651/system_process V/ActivityManager: bindService: Intent { act=android.bluetooth.IBluetoothInputDevice cmp=com.android.bluetooth/.hid.HidService } type=null conn=android.os.BinderProxy@4d5b6b8 flags=0x0
01-18 16:59:27.174 627-651/system_process V/xzj: bindService: Intent { act=android.bluetooth.IBluetoothInputDevice cmp=com.android.bluetooth/.hid.HidService }callerApp = ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} type=null conn=android.os.BinderProxy@4d5b6b8 flags=0x0
01-18 16:59:27.175 627-651/system_process V/ActivityManager: retrieveServiceLocked: Intent { act=android.bluetooth.IBluetoothInputDevice cmp=com.android.bluetooth/.hid.HidService } type=null callingUid=10015
01-18 16:59:27.175 627-651/system_process V/ActivityManager: Bind ServiceRecord{5bffc5d u0 com.android.bluetooth/.hid.HidService} with AppBindRecord{fdeb7f6 com.android.bluetooth/.hid.HidService:com.android.systemui}: received=false apps=1 doRebind=false
01-18 16:59:27.178 627-908/system_process V/ActivityManager: bindService: Intent { act=android.bluetooth.IBluetoothPan cmp=com.android.bluetooth/.pan.PanService } type=null conn=android.os.BinderProxy@1b2e0cd flags=0x0
01-18 16:59:27.178 627-908/system_process V/xzj: bindService: Intent { act=android.bluetooth.IBluetoothPan cmp=com.android.bluetooth/.pan.PanService }callerApp = ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} type=null conn=android.os.BinderProxy@1b2e0cd flags=0x0
01-18 16:59:27.178 627-908/system_process V/ActivityManager: retrieveServiceLocked: Intent { act=android.bluetooth.IBluetoothPan cmp=com.android.bluetooth/.pan.PanService } type=null callingUid=10015
01-18 16:59:27.178 627-908/system_process V/ActivityManager: Bind ServiceRecord{e0e11e u0 com.android.bluetooth/.pan.PanService} with AppBindRecord{d2f9c93 com.android.bluetooth/.pan.PanService:com.android.systemui}: received=false apps=1 doRebind=false
01-18 16:59:27.179 2814-2814/com.android.systemui D/LocalBluetoothProfileManager: Adding local MAP profile
01-18 16:59:27.181 2814-2814/com.android.systemui D/BluetoothMap: Create BluetoothMap proxy object
01-18 16:59:27.182 2814-2814/com.android.systemui E/BluetoothMap: Could not bind to Bluetooth MAP Service with Intent { act=android.bluetooth.IBluetoothMap }
01-18 16:59:27.185 627-1188/system_process V/ActivityManager: bindService: Intent { act=android.bluetooth.IBluetoothPbap cmp=com.android.bluetooth/.pbap.BluetoothPbapService } type=null conn=android.os.BinderProxy@470cfce flags=0x0
01-18 16:59:27.185 627-1188/system_process V/xzj: bindService: Intent { act=android.bluetooth.IBluetoothPbap cmp=com.android.bluetooth/.pbap.BluetoothPbapService }callerApp = ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} type=null conn=android.os.BinderProxy@470cfce flags=0x0
01-18 16:59:27.185 627-1188/system_process V/ActivityManager: retrieveServiceLocked: Intent { act=android.bluetooth.IBluetoothPbap cmp=com.android.bluetooth/.pbap.BluetoothPbapService } type=null callingUid=10015
01-18 16:59:27.185 627-1188/system_process V/ActivityManager: Bind ServiceRecord{92344b8 u0 com.android.bluetooth/.pbap.BluetoothPbapService} with AppBindRecord{f7f3dfc com.android.bluetooth/.pbap.BluetoothPbapService:com.android.systemui}: received=false apps=1 doRebind=false
01-18 16:59:27.185 2814-2814/com.android.systemui D/LocalBluetoothProfileManager: LocalBluetoothProfileManager construction complete
01-18 16:59:27.186 627-651/system_process V/ActivityManager: Unregister receiver: android.content.IIntentReceiver$Stub$Proxy@af85c85
01-18 16:59:27.187 627-1190/system_process V/ActivityManager: Register receiver android.content.IntentFilter@bce1ada: null
01-18 16:59:27.188 627-2737/system_process V/ActivityManager: Register receiver android.content.IntentFilter@b830aa6: null
01-18 16:59:27.193 627-650/system_process D/ConnectivityService: listenForNetwork for Listen from uid/pid:10015/2814 for NetworkRequest [ id=7, legacyType=-1, ]
01-18 16:59:27.199 627-1191/system_process V/ActivityManager: Register receiver android.content.IntentFilter@a0f5094: null
01-18 16:59:27.200 627-1188/system_process V/ActivityManager: Register receiver android.content.IntentFilter@5dae200: null
01-18 16:59:27.207 2814-2814/com.android.systemui I/CameraManagerGlobal: Connecting to camera service
01-18 16:59:27.213 237-1082/? I/CameraService: getCameraCharacteristics: Switching to HAL1 shim implementation…
01-18 16:59:27.213 237-1082/? D/CameraHal: camera_get_camera_info(1437): camera_get_camera_info(1437): camera_0 facing(0), orientation(180)
01-18 16:59:27.214 237-1081/? I/CameraService: getCameraCharacteristics: Switching to HAL1 shim implementation…
01-18 16:59:27.214 237-1081/? D/CameraHal: camera_get_camera_info(1437): camera_get_camera_info(1437): camera_1 facing(0), orientation(180)
01-18 16:59:27.214 237-1559/? D/CameraHal: camera_get_camera_info(1437): camera_get_camera_info(1437): camera_0 facing(0), orientation(180)
01-18 16:59:27.216 237-909/? D/CameraHal: camera_get_camera_info(1437): camera_get_camera_info(1437): camera_0 facing(0), orientation(180)
01-18 16:59:27.250 627-2394/system_process V/ActivityManager: Register receiver android.content.IntentFilter@46270f5: null
01-18 16:59:27.256 627-1191/system_process V/ActivityManager: Register receiver android.content.IntentFilter@2b62771: null
01-18 16:59:27.258 627-1188/system_process V/ActivityManager: Register receiver android.content.IntentFilter@cb4c9ad: null
01-18 16:59:27.259 627-651/system_process V/ActivityManager: Register receiver android.content.IntentFilter@e8153a9: null
01-18 16:59:27.270 627-1188/system_process V/ActivityManager: Register receiver android.content.IntentFilter@62d10cf: null
01-18 16:59:27.285 627-2737/system_process V/ActivityManager: Register receiver android.content.IntentFilter@193eaeb: null
01-18 16:59:27.289 627-2394/system_process V/ActivityManager: Register receiver android.content.IntentFilter@e444ac7: null
01-18 16:59:27.297 627-908/system_process V/ActivityManager: Register receiver android.content.IntentFilter@cb0cc63: null
01-18 16:59:27.366 627-651/system_process D/ActivityManager: Not moving, already top other: ProcessRecord{d5976f9 1291:android.process.acore/u0a2}
01-18 16:59:27.367 627-651/system_process V/ActivityManager: Set 1291 android.process.acore adj 0: provider
01-18 16:59:27.367 627-651/system_process V/ActivityManager: Setting process group of android.process.acore to -1
01-18 16:59:27.368 627-651/system_process D/ActivityManager: Process state change from CE to SB next pss in 20000: ProcessRecord{d5976f9 1291:android.process.acore/u0a2}
01-18 16:59:27.368 627-651/system_process V/ActivityManager: Proc state change of android.process.acore to 3
01-18 16:59:27.368 627-651/system_process D/ActivityManager: Checking proc [[com.android.providers.userdictionary, com.android.providers.contacts]] state changes: old = 16, new = 3
01-18 16:59:27.369 627-651/system_process I/ActivityManager: Changes in ProcessRecord{d5976f9 1291:android.process.acore/u0a2}: 2
01-18 16:59:27.369 627-651/system_process I/ActivityManager: Retrieving available item: com.android.server.am.ActivityManagerService$ProcessChangeItem@14a31b8
01-18 16:59:27.369 627-651/system_process I/ActivityManager: *** Enqueueing dispatch processes changed!
01-18 16:59:27.369 627-651/system_process I/ActivityManager: Item 14a31b8 1291:android.process.acore/u0a2: changes=2 procState=3 foreground=false type=provider source=ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} target=ComponentInfo{com.android.providers.contacts/com.android.providers.contacts.ContactsProvider2}
01-18 16:59:27.370 627-651/system_process V/ActivityManager: Set 2133 com.android.onetimeinitializer adj 9: cch-empty
01-18 16:59:27.370 627-651/system_process V/ActivityManager: Set 1764 com.android.settings adj 11: cch-empty
01-18 16:59:27.370 627-651/system_process W/ActivityManager: Wtf, activity ActivityRecord{6bf4494 u0 com.android.provision/.DefaultActivity t2 f} in proc activity list not using proc ProcessRecord{19b8e39 1794:com.android.provision/u0a11}?!? Using null instead.
01-18 16:59:27.370 627-651/system_process V/ActivityManager: Set 1592 com.android.externalstorage adj 13: cch-empty
01-18 16:59:27.370 627-651/system_process D/ActivityManager: oom: memFactor=0 last=0 allowLow=true numProcs=23 last=23
01-18 16:59:27.370 627-651/system_process I/ActivityManager: Changes in UidRecord{f969c54 u0a2 SB / 1 procs}: proc state from 16 to 3
01-18 16:59:27.371 627-651/system_process I/ActivityManager: *** Enqueueing dispatch uid changed!
01-18 16:59:27.371 627-651/system_process I/ActivityManager: Retrieving available item: com.android.server.am.UidRecord$ChangeItem@237f68e
01-18 16:59:27.371 627-651/system_process D/ActivityManager: Did OOM ADJ in 1ms
01-18 16:59:27.371 627-651/system_process I/ActivityManager: Adjust success: true
01-18 16:59:27.372 627-650/system_process V/ActivityManager: Register receiver android.content.IntentFilter@7d9cbbf: null
01-18 16:59:27.372 627-654/system_process I/ActivityManager: *** Delivering 1 process changes
01-18 16:59:27.372 627-654/system_process I/ActivityManager: *** Delivering 1 uid changes
01-18 16:59:27.372 627-654/system_process I/ActivityManager: UID CHANGED uid=10002: 3
01-18 16:59:27.374 627-1191/system_process V/ActivityManager: Register receiver android.content.IntentFilter@6964db: null
01-18 16:59:27.392 2814-2855/com.android.systemui D/OpenGLRenderer: Use EGL_SWAP_BEHAVIOR_PRESERVED: true
01-18 16:59:27.392 2814-2855/com.android.systemui D/OpenGLRenderer: profile bars disabled
01-18 16:59:27.392 2814-2855/com.android.systemui D/OpenGLRenderer: ambientRatio = 1.50
01-18 16:59:27.421 627-2395/system_process D/WindowManagerService: addWindowToListInOrderLocked: win=Window{6c65c42 u0 StatusBar} Callers=com.android.server.wm.WindowManagerService.addWindow:3419 com.android.server.wm.Session.addToDisplay:207 android.view.IWindowSession$Stub.onTransact:124 com.android.server.wm.Session.onTransact:168
01-18 16:59:27.421 627-2395/system_process V/WindowManagerService: Free window: Adding window Window{6c65c42 u0 StatusBar} at 2 of 2
01-18 16:59:27.432 2814-2814/com.android.systemui D/PhoneStatusBar: disable: < expand icons alerts system_info back home recent clock search quick_settings >
01-18 16:59:27.440 627-1191/system_process V/ActivityManager: Register receiver android.content.IntentFilter@f9d9453: null
01-18 16:59:27.443 627-1189/system_process V/ActivityManager: Register receiver android.content.IntentFilter@6322af: null
01-18 16:59:27.460 2814-2814/com.android.systemui D/AndroidRuntime: Shutting down VM
        --------- beginning of crash
01-18 16:59:27.461 2814-2814/com.android.systemui E/AndroidRuntime: FATAL EXCEPTION: main
Process: com.android.systemui, PID: 2814
java.lang.NullPointerException: Attempt to invoke virtual method ‘void android.view.View.setOnTouchListener(android.view.View$OnTouchListener)’ on a null object reference
at com.android.systemui.statusbar.phone.PhoneStatusBar.prepareNavigationBarView(PhoneStatusBar.java:1299)
at com.android.systemui.statusbar.phone.PhoneStatusBar.addNavigationBar(PhoneStatusBar.java:1468)
at com.android.systemui.statusbar.phone.PhoneStatusBar.start(PhoneStatusBar.java:650)
at com.android.systemui.statusbar.SystemBars.createStatusBarFromConfig(SystemBars.java:111)
at com.android.systemui.statusbar.SystemBars.onNoService(SystemBars.java:58)
at com.android.systemui.statusbar.ServiceMonitor.startService(ServiceMonitor.java:230)
at com.android.systemui.statusbar.ServiceMonitor.-wrap5(ServiceMonitor.java)
at com.android.systemui.statusbar.ServiceMonitor$1.handleMessage(ServiceMonitor.java:73)
at android.os.Handler.dispatchMessage(Handler.java:102)
at android.os.Looper.loop(Looper.java:148)
at android.app.ActivityThread.main(ActivityThread.java:5426)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:772)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:662)
01-18 16:59:27.465 627-2737/system_process W/ActivityManager: Process com.android.systemui has crashed too many times: killing!
01-18 16:59:27.465 627-2737/system_process I/DualScreen: ActivityStackSupervisor->targetStack:ActivityStack{d27a564 stackId=0, 1 tasks}
01-18 16:59:27.465 627-2737/system_process I/DualScreen: ActivityStackSupervisor->resumeTopActivitiesLocked->defaultStacks:[ActivityStack{d27a564 stackId=0, 1 tasks}]
01-18 16:59:27.465 627-2737/system_process I/DualScreen: ActivityStack->resumeTopActivityLockedActivityStack{d27a564 stackId=0, 1 tasks}
01-18 16:59:27.465 627-2737/system_process I/DualScreen: ActivityStack->resumeTopActivityInnerLocked:ActivityStack{d27a564 stackId=0, 1 tasks}
01-18 16:59:27.466 627-2737/system_process I/DualScreen: ActivityStack->resumeTopActivityInnerLocked->mResumedActivity:ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}
01-18 16:59:27.466 627-2737/system_process I/DualScreen: resumeTopActivityInnerLocked->prev:null
01-18 16:59:27.467 627-2737/system_process D/ActivityManager: com.android.server.am.ActivityStack.resumeTopActivityInnerLocked:1779 com.android.server.am.ActivityStack.resumeTopActivityLocked:1708 : mLockScreenShown=LOCK_SCREEN_HIDDEN mWakefulness=Awake mSleeping=false
01-18 16:59:27.468 627-2737/system_process I/DualScreen: ActivityStack->resumeTopActivityInnerLocked->next:ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}
01-18 16:59:27.468 627-2737/system_process I/DualScreen: ActivityStack->resumeTopActivityInnerLocked->this = ActivityStack{d27a564 stackId=0, 1 tasks}
01-18 16:59:27.468 627-2737/system_process I/DualScreen: ActivityStack->resumeTopActivityInnerLocked->getFirstStack = ActivityStack{d27a564 stackId=0, 1 tasks}
01-18 16:59:27.469 627-2737/system_process D/ActivityManager: allResumedActivitiesComplete: mLastFocusedStack changing from=ActivityStack{d27a564 stackId=0, 1 tasks} to=ActivityStack{d27a564 stackId=0, 1 tasks}
01-18 16:59:27.469 627-2737/system_process D/ActivityManager: resumeTopActivityLocked: Top activity resumed ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}
01-18 16:59:27.470 627-2737/system_process I/DualScreen: ActivityStackSupervisor->targetStack:ActivityStack{d27a564 stackId=0, 1 tasks}
01-18 16:59:27.514 627-654/system_process D/WindowManagerService: addWindowToListInOrderLocked: win=Window{8233e u0 Application Error: com.android.systemui} Callers=com.android.server.wm.WindowManagerService.addWindow:3419 com.android.server.wm.Session.addToDisplay:207 android.view.ViewRootImpl.setView:531 android.view.WindowManagerGlobal.addView:310
01-18 16:59:27.514 627-654/system_process V/WindowManagerService: Free window: Adding window Window{8233e u0 Application Error: com.android.systemui} at 3 of 3
01-18 16:59:27.514 627-654/system_process I/DualScreen: WindowManagerService->findFocusedWindowLocked->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:27.514 627-654/system_process I/DualScreen: WindowManagerService->findFocusedWindowLocked->windows:[Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}, Window{a4382bd u0 KeyguardScrim}, Window{6c65c42 u0 StatusBar}, Window{8233e u0 Application Error: com.android.systemui}]
01-18 16:59:27.514 627-654/system_process V/WindowManagerService: Looking for focus: 3 = Window{8233e u0 Application Error: com.android.systemui}, flags=25296898, canReceive=true
01-18 16:59:27.515 627-654/system_process V/WindowManagerService: findFocusedWindow: Found new focus @ 3 = Window{8233e u0 Application Error: com.android.systemui}
01-18 16:59:27.515 627-654/system_process I/DualScreen: findFocusedWindow->win:Window{8233e u0 Application Error: com.android.systemui}
01-18 16:59:27.515 627-654/system_process V/WindowManagerService: Changing focus from Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher} to Window{8233e u0 Application Error: com.android.systemui} Callers=com.android.server.wm.WindowManagerService.addWindow:3459 com.android.server.wm.Session.addToDisplay:207 android.view.ViewRootImpl.setView:531 android.view.WindowManagerGlobal.addView:310
01-18 16:59:27.516 627-654/system_process D/WindowManagerService: Input focus has changed to Window{8233e u0 Application Error: com.android.systemui}
01-18 16:59:27.516 627-658/system_process I/WindowManagerService: Focus moving from Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher} to Window{8233e u0 Application Error: com.android.systemui}
01-18 16:59:27.516 627-658/system_process I/WindowManagerService: Gaining focus: Window{8233e u0 Application Error: com.android.systemui}
01-18 16:59:27.530 627-654/system_process D/WindowStateAnimator: rk_debug2 Application Error: com.android.systemui_Force_To_Dual
01-18 16:59:27.532 627-654/system_process I/DualScreen: WindowManagerService->findFocusedWindowLocked->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:27.532 627-654/system_process I/DualScreen: WindowManagerService->findFocusedWindowLocked->windows:[Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}, Window{a4382bd u0 KeyguardScrim}, Window{6c65c42 u0 StatusBar}, Window{8233e u0 Application Error: com.android.systemui}]
01-18 16:59:27.532 627-654/system_process V/WindowManagerService: Looking for focus: 3 = Window{8233e u0 Application Error: com.android.systemui}, flags=25296898, canReceive=true
01-18 16:59:27.533 627-654/system_process V/WindowManagerService: findFocusedWindow: Found new focus @ 3 = Window{8233e u0 Application Error: com.android.systemui}
01-18 16:59:27.533 627-654/system_process I/DualScreen: findFocusedWindow->win:Window{8233e u0 Application Error: com.android.systemui}
01-18 16:59:27.533 627-654/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:27.545 627-654/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:27.548 627-654/system_process V/WindowManagerService: Relayout of Window{8233e u0 Application Error: com.android.systemui}: focusMayChange=true
01-18 16:59:27.548 627-1726/system_process I/OpenGLRenderer: Initialized EGL, version 1.4
01-18 16:59:27.554 212-254/? E/BufferQueueProducer: [Application Error: com.android.systemui_Force_To_Dual] connect(P): already connected (cur=1 req=1)
01-18 16:59:27.554 627-1726/system_process D/mali_winsys: EGLint new_window_surface(egl_winsys_display*, void*, EGLSurface, EGLConfig, egl_winsys_surface**, egl_color_buffer_format*, EGLBoolean) returns 0x3000
01-18 16:59:27.555 212-254/? D/gralloc: Isfb=0, [918,266,928,3712], fmt=1, byte_stride=3712
01-18 16:59:27.585 627-658/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:27.589 627-658/system_process I/WindowManagerService: Losing delayed focus: Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}
01-18 16:59:27.596 627-658/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:27.761 627-658/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:29.637 237-374/? D/alsa_route: route_set_controls() set route 24
01-18 16:59:29.723 237-374/? D/AudioHardwareTiny: close device
风之空响 发表于 2017-5-4 18:39
可不可以提供一下logcat的信息
01-18 16:59:26.215 627-654/system_process V/sjf: onDown
01-18 16:59:26.348 627-654/system_process V/sjf: onUpOrCancel
01-18 16:59:26.350 2738-2738/com.android.systemui I/Process: Sending signal. PID: 2738 SIG: 9
                                                         --------- beginning of system
01-18 16:59:26.362 627-654/system_process V/WindowManagerService: Remove Window{fcf584c u0 Application Error: com.android.systemui} client=63f407f, surface=Surface(name=Application Error: com.android.systemui_Force_To_Dual) Callers=com.android.server.wm.WindowManagerService.removeWindow:3552 com.android.server.wm.Session.remove:226 android.view.ViewRootImpl.dispatchDetachedFromWindow:3099 android.view.ViewRootImpl.doDie:5606
01-18 16:59:26.364 627-654/system_process I/DualScreen: WindowManagerService->findFocusedWindowLocked->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:26.364 627-654/system_process I/DualScreen: WindowManagerService->findFocusedWindowLocked->windows:[Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}, Window{a4382bd u0 KeyguardScrim}, Window{2f7d58f u0 StatusBar}, Window{fcf584c u0 Application Error: com.android.systemui EXITING}]
01-18 16:59:26.364 627-654/system_process V/WindowManagerService: Looking for focus: 3 = Window{fcf584c u0 Application Error: com.android.systemui EXITING}, flags=25296898, canReceive=false
01-18 16:59:26.364 627-654/system_process V/WindowManagerService: Looking for focus: 2 = Window{2f7d58f u0 StatusBar}, flags=-2122055608, canReceive=false
01-18 16:59:26.364 627-654/system_process V/WindowManagerService: Looking for focus: 1 = Window{a4382bd u0 KeyguardScrim}, flags=17893632, canReceive=false
01-18 16:59:26.364 627-654/system_process V/WindowManagerService: Looking for focus: 0 = Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}, flags=-2121203456, canReceive=true
01-18 16:59:26.365 627-654/system_process V/WindowManagerService: findFocusedWindow: Found new focus @ 0 = Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}
01-18 16:59:26.365 627-654/system_process I/DualScreen: findFocusedWindow->win:Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}
01-18 16:59:26.365 627-654/system_process V/WindowManagerService: Changing focus from Window{fcf584c u0 Application Error: com.android.systemui EXITING} to Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher} Callers=com.android.server.wm.WindowManagerService.removeWindowLocked:3623 com.android.server.wm.WindowManagerService.removeWindow:3552 com.android.server.wm.Session.remove:226 android.view.ViewRootImpl.dispatchDetachedFromWindow:3099
01-18 16:59:26.366 627-654/system_process D/WindowManagerService: Input focus has changed to Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}
01-18 16:59:26.366 627-654/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:26.369 627-658/system_process I/WindowManagerService: Focus moving from Window{fcf584c u0 Application Error: com.android.systemui EXITING} to Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}
01-18 16:59:26.370 627-658/system_process I/WindowManagerService: Gaining focus: Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}
01-18 16:59:26.370 627-658/system_process I/WindowManagerService: Losing focus: Window{fcf584c u0 Application Error: com.android.systemui EXITING}
01-18 16:59:26.371 627-2394/system_process W/InputMethodManagerService: Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@eb40111 attribute=null, token = android.os.BinderProxy@2407042
01-18 16:59:26.397 237-374/? D/AudioHardwareTiny: start_output_stream
01-18 16:59:26.398 237-374/? D/AudioHardwareTiny: Device : 0x8040a
01-18 16:59:26.398 237-374/? D/AudioHardwareTiny: SampleRate : 44100
01-18 16:59:26.398 237-374/? D/AudioHardwareTiny: Channels : 2
01-18 16:59:26.398 237-374/? D/AudioHardwareTiny: Formate : 0
01-18 16:59:26.398 237-374/? D/AudioHardwareTiny: PreiodSize : 2048
01-18 16:59:26.398 237-374/? D/alsa_route: route_info->sound_card 1, route_info->devices 0
01-18 16:59:26.398 237-374/? D/alsa_route: route_set_controls() set route 11
01-18 16:59:26.410 627-880/system_process W/InputDispatcher: channel ‘2f7d58f StatusBar (server)’ ~ Consumer closed input channel or an error occurred. events=0x9
01-18 16:59:26.410 627-880/system_process E/InputDispatcher: channel ‘2f7d58f StatusBar (server)’ ~ Channel is unrecoverably broken and will be disposed!
01-18 16:59:26.415 627-1190/system_process W/AudioService: Current remote volume controller died, unregistering
01-18 16:59:26.415 627-1074/system_process D/WifiService: Client connection lost with reason: 4
01-18 16:59:26.415 627-1188/system_process V/ActivityManager: Death received in com.android.server.am.ActivityManagerService$AppDeathRecipient@42a5a4f for thread android.os.BinderProxy@5a6b5dc
01-18 16:59:26.415 627-1190/system_process W/VolumeController: Error calling dismiss
android.os.DeadObjectException
at android.os.BinderProxy.transactNative(Native Method)
at android.os.BinderProxy.transact(Binder.java:503)
at android.media.IVolumeController$Stub$Proxy.dismiss(IVolumeController.java:162)
at com.android.server.audio.AudioService$VolumeController.postDismiss(AudioService.java:5902)
at com.android.server.audio.AudioService.setVolumeController(AudioService.java:5750)
at com.android.server.audio.AudioService$4.binderDied(AudioService.java:5759)
at android.os.BinderProxy.sendDeathNotice(Binder.java:558)
01-18 16:59:26.415 627-1189/system_process D/GraphicsStats: Buffer count: 2
01-18 16:59:26.416 627-1190/system_process I/WindowManagerService: WIN DEATH: Window{2f7d58f u0 StatusBar}
01-18 16:59:26.416 627-2737/system_process D/ConnectivityService: ConnectivityService NetworkRequestInfo binderDied(NetworkRequest [ id=6, legacyType=-1, ], android.os.BinderProxy@316c077)
01-18 16:59:26.416 627-1075/system_process D/ConnectivityService: releasing NetworkRequest NetworkRequest [ id=6, legacyType=-1, ]
01-18 16:59:26.416 627-1075/system_process D/ConnectivityService: sending notification RELEASED for NetworkRequest [ id=6, legacyType=-1, ]
01-18 16:59:26.417 627-627/system_process W/WallpaperManagerService: Wallpaper service gone: ComponentInfo{com.android.systemui/com.android.systemui.ImageWallpaper}
01-18 16:59:26.418 627-1190/system_process V/WindowManagerService: Remove Window{2f7d58f u0 StatusBar} client=fa02cee, surface=null Callers=com.android.server.wm.WindowState$DeathRecipient.binderDied:1219 android.os.BinderProxy.sendDeathNotice:558
01-18 16:59:26.418 627-1190/system_process W/InputDispatcher: Attempted to unregister already unregistered input channel ‘2f7d58f StatusBar (server)’
01-18 16:59:26.418 627-1190/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:26.418 627-1075/system_process E/ConnectivityService: RemoteException caught trying to send a callback msg for NetworkRequest [ id=6, legacyType=-1, ]
01-18 16:59:26.419 627-1190/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:26.421 627-1190/system_process I/DualScreen: WindowManagerService->findFocusedWindowLocked->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:26.421 627-1190/system_process I/DualScreen: WindowManagerService->findFocusedWindowLocked->windows:[Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}, Window{a4382bd u0 KeyguardScrim}, Window{fcf584c u0 Application Error: com.android.systemui EXITING}]
01-18 16:59:26.421 627-1190/system_process V/WindowManagerService: Looking for focus: 2 = Window{fcf584c u0 Application Error: com.android.systemui EXITING}, flags=25296898, canReceive=false
01-18 16:59:26.421 627-1190/system_process V/WindowManagerService: Looking for focus: 1 = Window{a4382bd u0 KeyguardScrim}, flags=17893632, canReceive=false
01-18 16:59:26.421 627-1190/system_process V/WindowManagerService: Looking for focus: 0 = Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}, flags=-2121203456, canReceive=true
01-18 16:59:26.421 627-1188/system_process I/ActivityManager: Process com.android.systemui (pid 2738) has died
01-18 16:59:26.421 627-1188/system_process V/ActivityManager: Dying app: ProcessRecord{ba2d4e9 2738:com.android.systemui/u0a15}, pid: 2738, thread: android.os.BinderProxy@5a6b5dc
01-18 16:59:26.421 627-1188/system_process V/ActivityManager: Disconnecting binding IntentBindRecord{f19d00a com.android.bluetooth/.pbap.BluetoothPbapService:act=android.bluetooth.IBluetoothPbap}: shouldUnbind=false
01-18 16:59:26.421 627-1190/system_process V/WindowManagerService: findFocusedWindow: Found new focus @ 0 = Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}
01-18 16:59:26.421 627-1188/system_process V/ActivityManager: Disconnecting binding IntentBindRecord{6d9e875 com.android.bluetooth/.hid.HidService:act=android.bluetooth.IBluetoothInputDevice}: shouldUnbind=false
01-18 16:59:26.421 627-1190/system_process I/DualScreen: findFocusedWindow->win:Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}
01-18 16:59:26.421 627-1188/system_process V/ActivityManager: Disconnecting binding IntentBindRecord{b60c3ac com.android.bluetooth/.pan.PanService:act=android.bluetooth.IBluetoothPan}: shouldUnbind=false
01-18 16:59:26.421 627-1188/system_process V/ActivityManager: Killing binding IntentBindRecord{1fefa45 CR com.android.systemui/.ImageWallpaper:act=android.service.wallpaper.WallpaperService}: shouldUnbind=true
01-18 16:59:26.421 627-1188/system_process W/ActivityManager: Scheduling restart of crashed service com.android.systemui/.SystemUIService in 0ms
01-18 16:59:26.422 627-1188/system_process W/ActivityManager: Scheduling restart of crashed service com.android.systemui/.ImageWallpaper in 0ms
01-18 16:59:26.422 627-1188/system_process I/ActivityManager: No more processes in UidRecord{a025eb0 u0a15 P / 0 procs}
01-18 16:59:26.422 627-1188/system_process I/ActivityManager: *** Enqueueing dispatch uid changed!
01-18 16:59:26.423 627-1188/system_process I/ActivityManager: Retrieving available item: com.android.server.am.UidRecord$ChangeItem@a1e4310
01-18 16:59:26.423 627-1188/system_process W/ActivityManager: Re-adding persistent process ProcessRecord{ba2d4e9 2738:com.android.systemui/u0a15}
01-18 16:59:26.423 627-1188/system_process I/ActivityManager: Creating new process uid: UidRecord{25e64e4 u0a15 CE / 0 procs}
01-18 16:59:26.423 627-1188/system_process I/ActivityManager: Retrieving available item: com.android.server.am.UidRecord$ChangeItem@c282758
01-18 16:59:26.438 627-1188/system_process I/ActivityManager: Start proc 2814:com.android.systemui/u0a15 for restart com.android.systemui
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Removing app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} from list mLRUActivities with 1 entries
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Record #0 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Removing app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} from list mStoppingActivities with 0 entries
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Removing app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} from list mGoingToSleepActivities with 0 entries
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Removing app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} from list mWaitingVisibleActivities with 0 entries
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Removing app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} from list mFinishingActivities with 0 entries
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Removing app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} from history with 1 entries
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Record #0 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}: app=ProcessRecord{49f77a9 1816:com.android.launcher3/u0a6}
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Set 1291 android.process.acore adj 9: cch-empty
01-18 16:59:26.439 627-1188/system_process V/ActivityManager: Setting process group of android.process.acore to 0
01-18 16:59:26.440 627-1188/system_process D/ActivityManager: Process state change from SB to CE next pss in 30000: ProcessRecord{d5976f9 1291:android.process.acore/u0a2}
01-18 16:59:26.440 627-1188/system_process V/ActivityManager: Proc state change of android.process.acore to 16
01-18 16:59:26.440 627-1188/system_process D/ActivityManager: Checking proc [[com.android.providers.userdictionary, com.android.providers.contacts]] state changes: old = 3, new = 16
01-18 16:59:26.440 627-1188/system_process I/ActivityManager: Changes in ProcessRecord{d5976f9 1291:android.process.acore/u0a2}: 2
01-18 16:59:26.440 627-1188/system_process I/ActivityManager: Retrieving available item: com.android.server.am.ActivityManagerService$ProcessChangeItem@14a31b8
01-18 16:59:26.440 627-1188/system_process I/ActivityManager: *** Enqueueing dispatch processes changed!
01-18 16:59:26.440 627-1188/system_process I/ActivityManager: Item 14a31b8 1291:android.process.acore/u0a2: changes=2 procState=16 foreground=false type=cch-empty source=null target=null
01-18 16:59:26.440 627-1188/system_process V/ActivityManager: Set 2133 com.android.onetimeinitializer adj 11: cch-empty
01-18 16:59:26.440 627-1188/system_process V/ActivityManager: Set 1764 com.android.settings adj 13: cch-empty
01-18 16:59:26.441 627-1188/system_process W/ActivityManager: Wtf, activity ActivityRecord{6bf4494 u0 com.android.provision/.DefaultActivity t2 f} in proc activity list not using proc ProcessRecord{19b8e39 1794:com.android.provision/u0a11}?!? Using null instead.
01-18 16:59:26.441 627-1188/system_process V/ActivityManager: Set 1592 com.android.externalstorage adj 15: cch-empty
01-18 16:59:26.441 627-1188/system_process D/ActivityManager: oom: memFactor=0 last=0 allowLow=true numProcs=23 last=23
01-18 16:59:26.441 627-1188/system_process I/ActivityManager: Changes in UidRecord{25e64e4 u0a15 CE / 1 procs}: proc state from -1 to 16
01-18 16:59:26.441 627-1188/system_process I/ActivityManager: Changes in UidRecord{f969c54 u0a2 CE / 1 procs}: proc state from 3 to 16
01-18 16:59:26.441 627-1188/system_process I/ActivityManager: Retrieving available item: com.android.server.am.UidRecord$ChangeItem@237f68e
01-18 16:59:26.441 627-1188/system_process D/ActivityManager: Did OOM ADJ in 2ms
01-18 16:59:26.441 627-653/system_process V/ActivityManager: Bringing up ServiceRecord{ffb6939 u0 com.android.systemui/.SystemUIService} android.content.Intent$FilterComparison@773cd02
01-18 16:59:26.441 627-653/system_process V/ActivityManager_MU: bringUpServiceLocked: appInfo.uid=10015 app=ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.441 627-654/system_process I/ActivityManager: *** Delivering 3 uid changes
01-18 16:59:26.441 627-654/system_process I/ActivityManager: UID gone uid=10015
01-18 16:59:26.441 627-653/system_process V/ActivityManager: Bringing up ServiceRecord{2cabaa1 u0 com.android.systemui/.ImageWallpaper} android.content.Intent$FilterComparison@281e5e6c
01-18 16:59:26.442 627-654/system_process I/ActivityManager: UID CHANGED uid=10015: 16
01-18 16:59:26.442 627-654/system_process I/ActivityManager: UID CHANGED uid=10002: 16
01-18 16:59:26.442 627-653/system_process V/ActivityManager_MU: bringUpServiceLocked: appInfo.uid=10015 app=ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.442 627-654/system_process I/ActivityManager: *** Delivering 1 process changes
01-18 16:59:26.489 627-2394/system_process V/ActivityManager: Binding process pid 2814 to record ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.489 627-2394/system_process V/ActivityManager: New death recipient com.android.server.am.ActivityManagerService$AppDeathRecipient@1469d4d for thread android.os.BinderProxy@58ca002
01-18 16:59:26.490 627-2394/system_process V/ActivityManager_MU: generateApplicationProvidersLocked, app.info.uid = 10015
01-18 16:59:26.490 627-2394/system_process V/ActivityManager: New app record ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} thread=android.os.BinderProxy@58ca002 pid=2814
01-18 16:59:26.490 627-2394/system_process V/ActivityManager: Binding proc com.android.systemui with config {1.0 dualscreenflag=DISABLE ?mcc?mnc zh_CN ldltr sw540dp w961dp h468dp 213dpi lrg long land -touch -keyb/v/h dpad/v s.5}
01-18 16:59:26.490 627-2394/system_process D/ActivityManager: Not moving, persistent: ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: ensureActivitiesVisible behind ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3} configChanges=0x0
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: Make visible? ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3} finishing=false state=RESUMED
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: Ensuring correct configuration: ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: Configuration unchanged in ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: Skipping: already visible at ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: Fullscreen: at ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}
01-18 16:59:26.491 627-2394/system_process V/ActivityManager_MU: realStartServiceLocked, ServiceRecord.uid = 10015, ProcessRecord.uid = 10015
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: >>> EXECUTING create of ServiceRecord{ffb6939 u0 com.android.systemui/.SystemUIService} in app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.491 627-2394/system_process D/ActivityManager: Not moving, persistent: ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: Set 2133 com.android.onetimeinitializer adj 9: cch-empty
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: Set 1764 com.android.settings adj 11: cch-empty
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: Set 1634 com.rockchip.devicetest adj 11: cch-empty
01-18 16:59:26.491 627-2394/system_process W/ActivityManager: Wtf, activity ActivityRecord{6bf4494 u0 com.android.provision/.DefaultActivity t2 f} in proc activity list not using proc ProcessRecord{19b8e39 1794:com.android.provision/u0a11}?!? Using null instead.
01-18 16:59:26.491 627-2394/system_process V/ActivityManager: Set 1592 com.android.externalstorage adj 13: cch-empty
01-18 16:59:26.492 627-2394/system_process V/ActivityManager: Set 1597 com.android.music adj 13: cch-empty
01-18 16:59:26.492 627-2394/system_process V/ActivityManager: Set 2814 com.android.systemui adj -12: fixed
01-18 16:59:26.492 627-2394/system_process D/ActivityManager: oom: memFactor=0 last=0 allowLow=true numProcs=23 last=23
01-18 16:59:26.492 627-2394/system_process I/ActivityManager: Changes in UidRecord{25e64e4 u0a15 P / 1 procs}: proc state from 16 to 0
01-18 16:59:26.492 627-2394/system_process I/ActivityManager: *** Enqueueing dispatch uid changed!
01-18 16:59:26.492 627-2394/system_process I/ActivityManager: Retrieving available item: com.android.server.am.UidRecord$ChangeItem@237f68e
01-18 16:59:26.492 627-2394/system_process D/ActivityManager: Did OOM ADJ in 2ms
01-18 16:59:26.494 627-2394/system_process V/ActivityManager: Sending arguments to: ServiceRecord{ffb6939 u0 com.android.systemui/.SystemUIService} android.content.Intent$FilterComparison@773cd02 args=null
01-18 16:59:26.494 627-2394/system_process V/ActivityManager: >>> EXECUTING start of ServiceRecord{ffb6939 u0 com.android.systemui/.SystemUIService} in app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.494 627-2394/system_process V/ActivityManager_MU: realStartServiceLocked, ServiceRecord.uid = 10015, ProcessRecord.uid = 10015
01-18 16:59:26.494 627-2394/system_process V/ActivityManager: >>> EXECUTING create of ServiceRecord{2cabaa1 u0 com.android.systemui/.ImageWallpaper} in app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.494 627-2394/system_process D/ActivityManager: Not moving, persistent: ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.495 627-2394/system_process V/ActivityManager: Set 2133 com.android.onetimeinitializer adj 11: cch-empty
01-18 16:59:26.495 627-2394/system_process V/ActivityManager: Set 1764 com.android.settings adj 13: cch-empty
01-18 16:59:26.495 627-2394/system_process V/ActivityManager: Set 1634 com.rockchip.devicetest adj 13: cch-empty
01-18 16:59:26.495 627-2394/system_process W/ActivityManager: Wtf, activity ActivityRecord{6bf4494 u0 com.android.provision/.DefaultActivity t2 f} in proc activity list not using proc ProcessRecord{19b8e39 1794:com.android.provision/u0a11}?!? Using null instead.
01-18 16:59:26.495 627-2394/system_process V/ActivityManager: Set 1592 com.android.externalstorage adj 15: cch-empty
01-18 16:59:26.495 627-2394/system_process V/ActivityManager: Set 1597 com.android.music adj 15: cch-empty
01-18 16:59:26.496 627-2394/system_process D/ActivityManager: oom: memFactor=0 last=0 allowLow=true numProcs=23 last=23
01-18 16:59:26.496 627-2394/system_process D/ActivityManager: Did OOM ADJ in 1ms
01-18 16:59:26.496 627-2394/system_process V/ActivityManager: >>> EXECUTING bind of ServiceRecord{2cabaa1 u0 com.android.systemui/.ImageWallpaper} in app ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.497 627-654/system_process I/ActivityManager: *** Delivering 1 uid changes
01-18 16:59:26.497 627-654/system_process I/ActivityManager: UID CHANGED uid=10015: 0
01-18 16:59:26.514 2814-2814/com.android.systemui W/System: ClassLoader referenced unknown path: /system/priv-app/SystemUI/lib/arm64
01-18 16:59:26.523 627-1188/system_process V/ActivityManager: Register receiver android.content.IntentFilter@92ced13: null
01-18 16:59:26.524 2814-2814/com.android.systemui V/SystemUIService: Starting SystemUI services.
01-18 16:59:26.528 627-650/system_process V/ActivityManager: Register receiver android.content.IntentFilter@46f476f: null
01-18 16:59:26.533 627-651/system_process V/ActivityManager: Register receiver android.content.IntentFilter@4d2eb8b: null
01-18 16:59:26.542 627-2737/system_process V/ActivityManager: Register receiver android.content.IntentFilter@a82b567: null
01-18 16:59:26.544 627-658/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:26.544 627-1188/system_process V/ActivityManager: Register receiver android.content.IntentFilter@37b4103: null
01-18 16:59:26.546 627-658/system_process W/AppOps: Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
01-18 16:59:26.547 627-658/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:26.556 627-1190/system_process D/ActivityManager: Not moving, persistent: ProcessRecord{ec76eaf 627:system/1000}
01-18 16:59:26.556 627-1190/system_process I/ActivityManager: Adjust success: true
01-18 16:59:26.559 627-1188/system_process V/ActivityManager: Register receiver android.content.IntentFilter@fad5d75: Intent { act=android.intent.action.BATTERY_CHANGED flg=0x60000010 (has extras) }
01-18 16:59:26.559 627-1188/system_process I/ActivityManager: Broadcast intent Intent { act=android.intent.action.BATTERY_CHANGED flg=0x60000010 (has extras) } on background queue
01-18 16:59:26.559 627-1188/system_process V/BroadcastQueue: Schedule broadcasts [background]: current=false
01-18 16:59:26.559 627-1188/system_process I/ActivityManager: Broadcast intent Intent { act=android.intent.action.SIM_STATE_CHANGED flg=0x4000010 (has extras) } on background queue
01-18 16:59:26.559 627-653/system_process V/BroadcastQueue: Received BROADCAST_INTENT_MSG
01-18 16:59:26.559 627-1188/system_process V/BroadcastQueue: Schedule broadcasts [background]: current=true
01-18 16:59:26.559 627-1188/system_process I/ActivityManager: Broadcast intent Intent { act=android.intent.action.SERVICE_STATE flg=0x10 (has extras) } on background queue
01-18 16:59:26.559 627-1188/system_process I/ActivityManager: Broadcast intent Intent { act=android.media.RINGER_MODE_CHANGED flg=0x34000010 (has extras) } on foreground queue
01-18 16:59:26.559 627-1188/system_process V/BroadcastQueue: Schedule broadcasts [foreground]: current=false
01-18 16:59:26.559 627-653/system_process V/BroadcastQueue: processNextBroadcast [background]: 3 broadcasts, 0 ordered broadcasts
01-18 16:59:26.559 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [background] BroadcastRecord{9035bf1 u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:26.559 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [background] to registered BroadcastFilter{f5a2798 u0 ReceiverList{a39cd7b 2814 com.android.systemui/10015/u0 remote:cc8a10a}}: BroadcastRecord{9035bf1 u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:26.560 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{f5a2798 u0 ReceiverList{a39cd7b 2814 com.android.systemui/10015/u0 remote:cc8a10a}} : BroadcastRecord{9035bf1 u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:26.560 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [background] BroadcastRecord{9035bf1 u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:26.560 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [background] BroadcastRecord{9d7c3d6 u-1 android.intent.action.SIM_STATE_CHANGED}
01-18 16:59:26.560 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [background] to registered BroadcastFilter{f5a2798 u0 ReceiverList{a39cd7b 2814 com.android.systemui/10015/u0 remote:cc8a10a}}: BroadcastRecord{9d7c3d6 u-1 android.intent.action.SIM_STATE_CHANGED}
01-18 16:59:26.560 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{f5a2798 u0 ReceiverList{a39cd7b 2814 com.android.systemui/10015/u0 remote:cc8a10a}} : BroadcastRecord{9d7c3d6 u-1 android.intent.action.SIM_STATE_CHANGED}
01-18 16:59:26.560 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [background] BroadcastRecord{9d7c3d6 u-1 android.intent.action.SIM_STATE_CHANGED}
01-18 16:59:26.560 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [background] BroadcastRecord{c0dc657 u-1 android.intent.action.SERVICE_STATE}
01-18 16:59:26.560 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [background] to registered BroadcastFilter{f5a2798 u0 ReceiverList{a39cd7b 2814 com.android.systemui/10015/u0 remote:cc8a10a}}: BroadcastRecord{c0dc657 u-1 android.intent.action.SERVICE_STATE}
01-18 16:59:26.560 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{f5a2798 u0 ReceiverList{a39cd7b 2814 com.android.systemui/10015/u0 remote:cc8a10a}} : BroadcastRecord{c0dc657 u-1 android.intent.action.SERVICE_STATE}
01-18 16:59:26.561 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [background] BroadcastRecord{c0dc657 u-1 android.intent.action.SERVICE_STATE}
01-18 16:59:26.561 627-653/system_process V/BroadcastQueue: Received BROADCAST_INTENT_MSG
01-18 16:59:26.561 627-653/system_process V/BroadcastQueue: processNextBroadcast [foreground]: 1 broadcasts, 0 ordered broadcasts
01-18 16:59:26.561 627-908/system_process V/ActivityManager: Register receiver android.content.IntentFilter@2962544: null
01-18 16:59:26.561 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [foreground] BroadcastRecord{fe0c62d u-1 android.media.RINGER_MODE_CHANGED}
01-18 16:59:26.561 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [foreground] to registered BroadcastFilter{f5a2798 u0 ReceiverList{a39cd7b 2814 com.android.systemui/10015/u0 remote:cc8a10a}}: BroadcastRecord{fe0c62d u-1 android.media.RINGER_MODE_CHANGED}
01-18 16:59:26.561 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{f5a2798 u0 ReceiverList{a39cd7b 2814 com.android.systemui/10015/u0 remote:cc8a10a}} : BroadcastRecord{fe0c62d u-1 android.media.RINGER_MODE_CHANGED}
01-18 16:59:26.561 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [foreground] BroadcastRecord{fe0c62d u-1 android.media.RINGER_MODE_CHANGED}
01-18 16:59:26.564 627-650/system_process V/ActivityManager: Register receiver android.content.IntentFilter@be70f3: null
01-18 16:59:26.568 627-651/system_process V/ActivityManager: Register receiver android.content.IntentFilter@4a2d8dc: null
01-18 16:59:26.570 627-627/system_process D/TrustManagerService: Removing dead TrustListener.
01-18 16:59:26.577 627-658/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:26.594 237-374/? D/AudioFlinger: mixer(0xf3999008) throttle end: throttle time(46)
01-18 16:59:26.608 2814-2828/com.android.systemui D/WVMExtractor: Failed to open libwvm.so
01-18 16:59:26.618 2814-2830/com.android.systemui I/OMXClient: Using client-side OMX mux.
01-18 16:59:26.625 627-1189/system_process V/ActivityManager: Register receiver android.content.IntentFilter@d46ce86: null
01-18 16:59:26.678 2814-2837/com.android.systemui I/OMXClient: Using client-side OMX mux.
01-18 16:59:26.682 627-651/system_process D/ActivityManager: Skipping, home stack task: TaskRecord{aa0a518 #3 ?? U=0 sz=1}
01-18 16:59:26.696 2814-2814/com.android.systemui I/vol.Events: writeEvent collection_started
01-18 16:59:26.701 627-1189/system_process V/ActivityManager: Register receiver android.content.IntentFilter@3b14d12: Intent { act=android.media.RINGER_MODE_CHANGED flg=0x34000010 (has extras) }
01-18 16:59:26.702 627-1189/system_process I/ActivityManager: Broadcast intent Intent { act=android.media.RINGER_MODE_CHANGED flg=0x34000010 (has extras) } on foreground queue
01-18 16:59:26.702 627-1189/system_process V/BroadcastQueue: Schedule broadcasts [foreground]: current=false
01-18 16:59:26.702 627-1189/system_process I/ActivityManager: Broadcast intent Intent { act=android.media.INTERNAL_RINGER_MODE_CHANGED_ACTION flg=0x34000010 (has extras) } on foreground queue
01-18 16:59:26.702 627-653/system_process V/BroadcastQueue: Received BROADCAST_INTENT_MSG
01-18 16:59:26.702 627-1189/system_process V/BroadcastQueue: Schedule broadcasts [foreground]: current=true
01-18 16:59:26.702 627-653/system_process V/BroadcastQueue: processNextBroadcast [foreground]: 2 broadcasts, 0 ordered broadcasts
01-18 16:59:26.702 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [foreground] BroadcastRecord{4d3285e u-1 android.media.RINGER_MODE_CHANGED}
01-18 16:59:26.702 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [foreground] to registered BroadcastFilter{9c2dd99 u0 ReceiverList{95586e0 2814 com.android.systemui/10015/u0 remote:5e57ce3}}: BroadcastRecord{4d3285e u-1 android.media.RINGER_MODE_CHANGED}
01-18 16:59:26.702 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{9c2dd99 u0 ReceiverList{95586e0 2814 com.android.systemui/10015/u0 remote:5e57ce3}} : BroadcastRecord{4d3285e u-1 android.media.RINGER_MODE_CHANGED}
01-18 16:59:26.702 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [foreground] BroadcastRecord{4d3285e u-1 android.media.RINGER_MODE_CHANGED}
01-18 16:59:26.702 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [foreground] BroadcastRecord{ae9043f u-1 android.media.INTERNAL_RINGER_MODE_CHANGED_ACTION}
01-18 16:59:26.702 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [foreground] to registered BroadcastFilter{9c2dd99 u0 ReceiverList{95586e0 2814 com.android.systemui/10015/u0 remote:5e57ce3}}: BroadcastRecord{ae9043f u-1 android.media.INTERNAL_RINGER_MODE_CHANGED_ACTION}
01-18 16:59:26.702 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{9c2dd99 u0 ReceiverList{95586e0 2814 com.android.systemui/10015/u0 remote:5e57ce3}} : BroadcastRecord{ae9043f u-1 android.media.INTERNAL_RINGER_MODE_CHANGED_ACTION}
01-18 16:59:26.703 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [foreground] BroadcastRecord{ae9043f u-1 android.media.INTERNAL_RINGER_MODE_CHANGED_ACTION}
01-18 16:59:26.703 2814-2814/com.android.systemui W/Vibrator: Failed to vibrate; no vibrator service.
01-18 16:59:26.704 2814-2840/com.android.systemui I/vol.Events: writeEvent external_ringer_mode_changed normal
01-18 16:59:26.704 2814-2840/com.android.systemui I/vol.Events: writeEvent internal_ringer_mode_changed normal
01-18 16:59:26.740 2814-2841/com.android.systemui I/OMXClient: Using client-side OMX mux.
01-18 16:59:26.786 2814-2840/com.android.systemui I/vol.Events: writeEvent level_changed STREAM_ALARM 6
01-18 16:59:26.787 627-1191/system_process V/ActivityManager: Register receiver android.content.IntentFilter@c3c310c: null
01-18 16:59:26.788 2814-2840/com.android.systemui I/vol.Events: writeEvent level_changed STREAM_BLUETOOTH_SCO 7
01-18 16:59:26.789 627-1191/system_process V/ActivityManager: Register receiver android.content.IntentFilter@10151f8: null
01-18 16:59:26.791 627-2395/system_process V/ActivityManager: Register receiver android.content.IntentFilter@af595a4: null
01-18 16:59:26.791 2814-2840/com.android.systemui I/vol.Events: writeEvent level_changed STREAM_MUSIC 11
01-18 16:59:26.795 627-1191/system_process V/ActivityManager: Register receiver android.content.IntentFilter@4695f09: null
01-18 16:59:26.795 2814-2840/com.android.systemui I/vol.Events: writeEvent level_changed STREAM_RING 5
01-18 16:59:26.795 627-1190/system_process V/ActivityManager: Register receiver android.content.IntentFilter@fbfe2c5: null
01-18 16:59:26.796 2814-2840/com.android.systemui I/vol.Events: writeEvent level_changed STREAM_SYSTEM 5
01-18 16:59:26.799 2814-2840/com.android.systemui I/vol.Events: writeEvent level_changed STREAM_VOICE_CALL 4
01-18 16:59:26.799 2814-2814/com.android.systemui D/StorageNotification: Notifying about private volume: VolumeInfo{private}:
type=PRIVATE diskId=null partGuid=null mountFlags=0 mountUserId=-1
state=MOUNTED
fsType=null fsUuid=null fsLabel=null
path=/data internalPath=null
01-18 16:59:26.806 627-2395/system_process V/ActivityManager: Register receiver android.content.IntentFilter@b1007e6: null
01-18 16:59:26.809 627-651/system_process V/ActivityManager: Register receiver android.content.IntentFilter@9c4bc72: Intent { act=android.intent.action.BATTERY_CHANGED flg=0x60000010 (has extras) }
01-18 16:59:26.809 627-651/system_process I/ActivityManager: Broadcast intent Intent { act=android.intent.action.BATTERY_CHANGED flg=0x60000010 (has extras) } on background queue
01-18 16:59:26.809 627-651/system_process V/BroadcastQueue: Schedule broadcasts [background]: current=false
01-18 16:59:26.809 627-653/system_process V/BroadcastQueue: Received BROADCAST_INTENT_MSG
01-18 16:59:26.809 627-653/system_process V/BroadcastQueue: processNextBroadcast [background]: 1 broadcasts, 0 ordered broadcasts
01-18 16:59:26.809 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [background] BroadcastRecord{c9e2dbe u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:26.809 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [background] to registered BroadcastFilter{d2b1c79 u0 ReceiverList{30df540 2814 com.android.systemui/10015/u0 remote:c5b28c3}}: BroadcastRecord{c9e2dbe u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:26.810 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{d2b1c79 u0 ReceiverList{30df540 2814 com.android.systemui/10015/u0 remote:c5b28c3}} : BroadcastRecord{c9e2dbe u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:26.810 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [background] BroadcastRecord{c9e2dbe u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:26.814 627-908/system_process V/ActivityManager: <<< DONE EXECUTING ServiceRecord{ffb6939 u0 com.android.systemui/.SystemUIService}: nesting=2, inDestroying=false, app=ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.816 627-651/system_process V/ActivityManager: <<< DONE EXECUTING ServiceRecord{ffb6939 u0 com.android.systemui/.SystemUIService}: nesting=1, inDestroying=false, app=ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.816 627-651/system_process V/ActivityManager: Nesting at 0 of com.android.systemui/.SystemUIService
01-18 16:59:26.818 627-1190/system_process V/ActivityManager: <<< DONE EXECUTING ServiceRecord{2cabaa1 u0 com.android.systemui/.ImageWallpaper}: nesting=2, inDestroying=false, app=ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.819 627-1188/system_process V/ActivityManager: PUBLISHING ServiceRecord{2cabaa1 u0 com.android.systemui/.ImageWallpaper} Intent { act=android.service.wallpaper.WallpaperService cmp=com.android.systemui/.ImageWallpaper }: android.os.BinderProxy@3d8e1f
01-18 16:59:26.819 627-1188/system_process V/ActivityManager: Publishing to: ConnectionRecord{c1e1308 u0 CR FGSA UI com.android.systemui/.ImageWallpaper:@a2362fa}
01-18 16:59:26.819 627-1188/system_process V/ActivityManager: <<< DONE EXECUTING ServiceRecord{2cabaa1 u0 com.android.systemui/.ImageWallpaper}: nesting=1, inDestroying=false, app=ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15}
01-18 16:59:26.819 627-1188/system_process V/ActivityManager: Nesting at 0 of com.android.systemui/.ImageWallpaper
01-18 16:59:26.819 627-1188/system_process V/ActivityManager: No more executingServices of com.android.systemui/.ImageWallpaper
01-18 16:59:26.842 627-650/system_process I/StatusBarManagerService: registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@67d256c
01-18 16:59:26.843 627-908/system_process V/ActivityManager: Register receiver android.content.IntentFilter@2380735: null
01-18 16:59:26.977 627-1074/system_process D/WifiService: New client listening to asynchronous messages
01-18 16:59:26.992 627-2395/system_process V/ActivityManager: Register receiver android.content.IntentFilter@8eee1b1: null
01-18 16:59:27.145 627-908/system_process V/ActivityManager: Register receiver android.content.IntentFilter@85ee7ed: null
01-18 16:59:27.150 627-1190/system_process V/ActivityManager: Register receiver android.content.IntentFilter@f4f15e9: null
01-18 16:59:27.153 627-2737/system_process V/ActivityManager: Register receiver android.content.IntentFilter@7fa27a5: Intent { act=android.intent.action.BATTERY_CHANGED flg=0x60000010 (has extras) }
01-18 16:59:27.154 627-2737/system_process I/ActivityManager: Broadcast intent Intent { act=android.intent.action.BATTERY_CHANGED flg=0x60000010 (has extras) } on background queue
01-18 16:59:27.154 627-2737/system_process V/BroadcastQueue: Schedule broadcasts [background]: current=false
01-18 16:59:27.154 627-653/system_process V/BroadcastQueue: Received BROADCAST_INTENT_MSG
01-18 16:59:27.154 627-653/system_process V/BroadcastQueue: processNextBroadcast [background]: 1 broadcasts, 0 ordered broadcasts
01-18 16:59:27.154 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [background] BroadcastRecord{b8a9921 u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:27.154 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [background] to registered BroadcastFilter{b905b88 u0 ReceiverList{5b99b2b 2814 com.android.systemui/10015/u0 remote:c35577a}}: BroadcastRecord{b8a9921 u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:27.154 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{b905b88 u0 ReceiverList{5b99b2b 2814 com.android.systemui/10015/u0 remote:c35577a}} : BroadcastRecord{b8a9921 u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:27.154 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [background] BroadcastRecord{b8a9921 u-1 android.intent.action.BATTERY_CHANGED}
01-18 16:59:27.167 627-657/system_process D/BluetoothManagerService: Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@8b4bf07:true
01-18 16:59:27.168 627-1189/system_process V/ActivityManager: Register receiver android.content.IntentFilter@d93a834: Intent { act=android.intent.action.SIM_STATE_CHANGED flg=0x4000010 (has extras) }
01-18 16:59:27.168 627-1189/system_process I/ActivityManager: Broadcast intent Intent { act=android.intent.action.SIM_STATE_CHANGED flg=0x4000010 (has extras) } on background queue
01-18 16:59:27.168 627-1189/system_process V/BroadcastQueue: Schedule broadcasts [background]: current=false
01-18 16:59:27.168 627-1189/system_process I/ActivityManager: Broadcast intent Intent { act=android.intent.action.SERVICE_STATE flg=0x10 (has extras) } on background queue
01-18 16:59:27.168 627-1189/system_process V/BroadcastQueue: Schedule broadcasts [background]: current=true
01-18 16:59:27.168 627-1189/system_process I/ActivityManager: Broadcast intent Intent { act=android.provider.Telephony.SPN_STRINGS_UPDATED flg=0x20000010 (has extras) } on background queue
01-18 16:59:27.168 627-653/system_process V/BroadcastQueue: Received BROADCAST_INTENT_MSG
01-18 16:59:27.168 627-653/system_process V/BroadcastQueue: processNextBroadcast [background]: 3 broadcasts, 0 ordered broadcasts
01-18 16:59:27.168 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [background] BroadcastRecord{6dd13a0 u-1 android.intent.action.SIM_STATE_CHANGED}
01-18 16:59:27.169 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [background] to registered BroadcastFilter{15444a3 u0 ReceiverList{1835bd2 2814 com.android.systemui/10015/u0 remote:156a65d}}: BroadcastRecord{6dd13a0 u-1 android.intent.action.SIM_STATE_CHANGED}
01-18 16:59:27.169 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{15444a3 u0 ReceiverList{1835bd2 2814 com.android.systemui/10015/u0 remote:156a65d}} : BroadcastRecord{6dd13a0 u-1 android.intent.action.SIM_STATE_CHANGED}
01-18 16:59:27.169 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [background] BroadcastRecord{6dd13a0 u-1 android.intent.action.SIM_STATE_CHANGED}
01-18 16:59:27.169 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [background] BroadcastRecord{5dc4b59 u-1 android.intent.action.SERVICE_STATE}
01-18 16:59:27.169 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [background] to registered BroadcastFilter{15444a3 u0 ReceiverList{1835bd2 2814 com.android.systemui/10015/u0 remote:156a65d}}: BroadcastRecord{5dc4b59 u-1 android.intent.action.SERVICE_STATE}
01-18 16:59:27.169 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{15444a3 u0 ReceiverList{1835bd2 2814 com.android.systemui/10015/u0 remote:156a65d}} : BroadcastRecord{5dc4b59 u-1 android.intent.action.SERVICE_STATE}
01-18 16:59:27.169 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [background] BroadcastRecord{5dc4b59 u-1 android.intent.action.SERVICE_STATE}
01-18 16:59:27.169 627-653/system_process V/BroadcastQueue: Processing parallel broadcast [background] BroadcastRecord{d97631e u-1 android.provider.Telephony.SPN_STRINGS_UPDATED}
01-18 16:59:27.169 627-653/system_process V/BroadcastQueue: Delivering non-ordered on [background] to registered BroadcastFilter{15444a3 u0 ReceiverList{1835bd2 2814 com.android.systemui/10015/u0 remote:156a65d}}: BroadcastRecord{d97631e u-1 android.provider.Telephony.SPN_STRINGS_UPDATED}
01-18 16:59:27.169 627-653/system_process I/BroadcastQueue: Delivering to BroadcastFilter{15444a3 u0 ReceiverList{1835bd2 2814 com.android.systemui/10015/u0 remote:156a65d}} : BroadcastRecord{d97631e u-1 android.provider.Telephony.SPN_STRINGS_UPDATED}
01-18 16:59:27.170 627-653/system_process V/BroadcastQueue: Done with parallel broadcast [background] BroadcastRecord{d97631e u-1 android.provider.Telephony.SPN_STRINGS_UPDATED}
01-18 16:59:27.170 627-650/system_process V/ActivityManager: Register receiver android.content.IntentFilter@dc87ff: null
01-18 16:59:27.174 627-651/system_process V/ActivityManager: bindService: Intent { act=android.bluetooth.IBluetoothInputDevice cmp=com.android.bluetooth/.hid.HidService } type=null conn=android.os.BinderProxy@4d5b6b8 flags=0x0
01-18 16:59:27.174 627-651/system_process V/xzj: bindService: Intent { act=android.bluetooth.IBluetoothInputDevice cmp=com.android.bluetooth/.hid.HidService }callerApp = ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} type=null conn=android.os.BinderProxy@4d5b6b8 flags=0x0
01-18 16:59:27.175 627-651/system_process V/ActivityManager: retrieveServiceLocked: Intent { act=android.bluetooth.IBluetoothInputDevice cmp=com.android.bluetooth/.hid.HidService } type=null callingUid=10015
01-18 16:59:27.175 627-651/system_process V/ActivityManager: Bind ServiceRecord{5bffc5d u0 com.android.bluetooth/.hid.HidService} with AppBindRecord{fdeb7f6 com.android.bluetooth/.hid.HidService:com.android.systemui}: received=false apps=1 doRebind=false
01-18 16:59:27.178 627-908/system_process V/ActivityManager: bindService: Intent { act=android.bluetooth.IBluetoothPan cmp=com.android.bluetooth/.pan.PanService } type=null conn=android.os.BinderProxy@1b2e0cd flags=0x0
01-18 16:59:27.178 627-908/system_process V/xzj: bindService: Intent { act=android.bluetooth.IBluetoothPan cmp=com.android.bluetooth/.pan.PanService }callerApp = ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} type=null conn=android.os.BinderProxy@1b2e0cd flags=0x0
01-18 16:59:27.178 627-908/system_process V/ActivityManager: retrieveServiceLocked: Intent { act=android.bluetooth.IBluetoothPan cmp=com.android.bluetooth/.pan.PanService } type=null callingUid=10015
01-18 16:59:27.178 627-908/system_process V/ActivityManager: Bind ServiceRecord{e0e11e u0 com.android.bluetooth/.pan.PanService} with AppBindRecord{d2f9c93 com.android.bluetooth/.pan.PanService:com.android.systemui}: received=false apps=1 doRebind=false
01-18 16:59:27.179 2814-2814/com.android.systemui D/LocalBluetoothProfileManager: Adding local MAP profile
01-18 16:59:27.181 2814-2814/com.android.systemui D/BluetoothMap: Create BluetoothMap proxy object
01-18 16:59:27.182 2814-2814/com.android.systemui E/BluetoothMap: Could not bind to Bluetooth MAP Service with Intent { act=android.bluetooth.IBluetoothMap }
01-18 16:59:27.185 627-1188/system_process V/ActivityManager: bindService: Intent { act=android.bluetooth.IBluetoothPbap cmp=com.android.bluetooth/.pbap.BluetoothPbapService } type=null conn=android.os.BinderProxy@470cfce flags=0x0
01-18 16:59:27.185 627-1188/system_process V/xzj: bindService: Intent { act=android.bluetooth.IBluetoothPbap cmp=com.android.bluetooth/.pbap.BluetoothPbapService }callerApp = ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} type=null conn=android.os.BinderProxy@470cfce flags=0x0
01-18 16:59:27.185 627-1188/system_process V/ActivityManager: retrieveServiceLocked: Intent { act=android.bluetooth.IBluetoothPbap cmp=com.android.bluetooth/.pbap.BluetoothPbapService } type=null callingUid=10015
01-18 16:59:27.185 627-1188/system_process V/ActivityManager: Bind ServiceRecord{92344b8 u0 com.android.bluetooth/.pbap.BluetoothPbapService} with AppBindRecord{f7f3dfc com.android.bluetooth/.pbap.BluetoothPbapService:com.android.systemui}: received=false apps=1 doRebind=false
01-18 16:59:27.185 2814-2814/com.android.systemui D/LocalBluetoothProfileManager: LocalBluetoothProfileManager construction complete
01-18 16:59:27.186 627-651/system_process V/ActivityManager: Unregister receiver: android.content.IIntentReceiver$Stub$Proxy@af85c85
01-18 16:59:27.187 627-1190/system_process V/ActivityManager: Register receiver android.content.IntentFilter@bce1ada: null
01-18 16:59:27.188 627-2737/system_process V/ActivityManager: Register receiver android.content.IntentFilter@b830aa6: null
01-18 16:59:27.193 627-650/system_process D/ConnectivityService: listenForNetwork for Listen from uid/pid:10015/2814 for NetworkRequest [ id=7, legacyType=-1, ]
01-18 16:59:27.199 627-1191/system_process V/ActivityManager: Register receiver android.content.IntentFilter@a0f5094: null
01-18 16:59:27.200 627-1188/system_process V/ActivityManager: Register receiver android.content.IntentFilter@5dae200: null
01-18 16:59:27.207 2814-2814/com.android.systemui I/CameraManagerGlobal: Connecting to camera service
01-18 16:59:27.213 237-1082/? I/CameraService: getCameraCharacteristics: Switching to HAL1 shim implementation…
01-18 16:59:27.213 237-1082/? D/CameraHal: camera_get_camera_info(1437): camera_get_camera_info(1437): camera_0 facing(0), orientation(180)
01-18 16:59:27.214 237-1081/? I/CameraService: getCameraCharacteristics: Switching to HAL1 shim implementation…
01-18 16:59:27.214 237-1081/? D/CameraHal: camera_get_camera_info(1437): camera_get_camera_info(1437): camera_1 facing(0), orientation(180)
01-18 16:59:27.214 237-1559/? D/CameraHal: camera_get_camera_info(1437): camera_get_camera_info(1437): camera_0 facing(0), orientation(180)
01-18 16:59:27.216 237-909/? D/CameraHal: camera_get_camera_info(1437): camera_get_camera_info(1437): camera_0 facing(0), orientation(180)
01-18 16:59:27.250 627-2394/system_process V/ActivityManager: Register receiver android.content.IntentFilter@46270f5: null
01-18 16:59:27.256 627-1191/system_process V/ActivityManager: Register receiver android.content.IntentFilter@2b62771: null
01-18 16:59:27.258 627-1188/system_process V/ActivityManager: Register receiver android.content.IntentFilter@cb4c9ad: null
01-18 16:59:27.259 627-651/system_process V/ActivityManager: Register receiver android.content.IntentFilter@e8153a9: null
01-18 16:59:27.270 627-1188/system_process V/ActivityManager: Register receiver android.content.IntentFilter@62d10cf: null
01-18 16:59:27.285 627-2737/system_process V/ActivityManager: Register receiver android.content.IntentFilter@193eaeb: null
01-18 16:59:27.289 627-2394/system_process V/ActivityManager: Register receiver android.content.IntentFilter@e444ac7: null
01-18 16:59:27.297 627-908/system_process V/ActivityManager: Register receiver android.content.IntentFilter@cb0cc63: null
01-18 16:59:27.366 627-651/system_process D/ActivityManager: Not moving, already top other: ProcessRecord{d5976f9 1291:android.process.acore/u0a2}
01-18 16:59:27.367 627-651/system_process V/ActivityManager: Set 1291 android.process.acore adj 0: provider
01-18 16:59:27.367 627-651/system_process V/ActivityManager: Setting process group of android.process.acore to -1
01-18 16:59:27.368 627-651/system_process D/ActivityManager: Process state change from CE to SB next pss in 20000: ProcessRecord{d5976f9 1291:android.process.acore/u0a2}
01-18 16:59:27.368 627-651/system_process V/ActivityManager: Proc state change of android.process.acore to 3
01-18 16:59:27.368 627-651/system_process D/ActivityManager: Checking proc [[com.android.providers.userdictionary, com.android.providers.contacts]] state changes: old = 16, new = 3
01-18 16:59:27.369 627-651/system_process I/ActivityManager: Changes in ProcessRecord{d5976f9 1291:android.process.acore/u0a2}: 2
01-18 16:59:27.369 627-651/system_process I/ActivityManager: Retrieving available item: com.android.server.am.ActivityManagerService$ProcessChangeItem@14a31b8
01-18 16:59:27.369 627-651/system_process I/ActivityManager: *** Enqueueing dispatch processes changed!
01-18 16:59:27.369 627-651/system_process I/ActivityManager: Item 14a31b8 1291:android.process.acore/u0a2: changes=2 procState=3 foreground=false type=provider source=ProcessRecord{ba2d4e9 2814:com.android.systemui/u0a15} target=ComponentInfo{com.android.providers.contacts/com.android.providers.contacts.ContactsProvider2}
01-18 16:59:27.370 627-651/system_process V/ActivityManager: Set 2133 com.android.onetimeinitializer adj 9: cch-empty
01-18 16:59:27.370 627-651/system_process V/ActivityManager: Set 1764 com.android.settings adj 11: cch-empty
01-18 16:59:27.370 627-651/system_process W/ActivityManager: Wtf, activity ActivityRecord{6bf4494 u0 com.android.provision/.DefaultActivity t2 f} in proc activity list not using proc ProcessRecord{19b8e39 1794:com.android.provision/u0a11}?!? Using null instead.
01-18 16:59:27.370 627-651/system_process V/ActivityManager: Set 1592 com.android.externalstorage adj 13: cch-empty
01-18 16:59:27.370 627-651/system_process D/ActivityManager: oom: memFactor=0 last=0 allowLow=true numProcs=23 last=23
01-18 16:59:27.370 627-651/system_process I/ActivityManager: Changes in UidRecord{f969c54 u0a2 SB / 1 procs}: proc state from 16 to 3
01-18 16:59:27.371 627-651/system_process I/ActivityManager: *** Enqueueing dispatch uid changed!
01-18 16:59:27.371 627-651/system_process I/ActivityManager: Retrieving available item: com.android.server.am.UidRecord$ChangeItem@237f68e
01-18 16:59:27.371 627-651/system_process D/ActivityManager: Did OOM ADJ in 1ms
01-18 16:59:27.371 627-651/system_process I/ActivityManager: Adjust success: true
01-18 16:59:27.372 627-650/system_process V/ActivityManager: Register receiver android.content.IntentFilter@7d9cbbf: null
01-18 16:59:27.372 627-654/system_process I/ActivityManager: *** Delivering 1 process changes
01-18 16:59:27.372 627-654/system_process I/ActivityManager: *** Delivering 1 uid changes
01-18 16:59:27.372 627-654/system_process I/ActivityManager: UID CHANGED uid=10002: 3
01-18 16:59:27.374 627-1191/system_process V/ActivityManager: Register receiver android.content.IntentFilter@6964db: null
01-18 16:59:27.392 2814-2855/com.android.systemui D/OpenGLRenderer: Use EGL_SWAP_BEHAVIOR_PRESERVED: true
01-18 16:59:27.392 2814-2855/com.android.systemui D/OpenGLRenderer: profile bars disabled
01-18 16:59:27.392 2814-2855/com.android.systemui D/OpenGLRenderer: ambientRatio = 1.50
01-18 16:59:27.421 627-2395/system_process D/WindowManagerService: addWindowToListInOrderLocked: win=Window{6c65c42 u0 StatusBar} Callers=com.android.server.wm.WindowManagerService.addWindow:3419 com.android.server.wm.Session.addToDisplay:207 android.view.IWindowSession$Stub.onTransact:124 com.android.server.wm.Session.onTransact:168
01-18 16:59:27.421 627-2395/system_process V/WindowManagerService: Free window: Adding window Window{6c65c42 u0 StatusBar} at 2 of 2
01-18 16:59:27.432 2814-2814/com.android.systemui D/PhoneStatusBar: disable: < expand icons alerts system_info back home recent clock search quick_settings >
01-18 16:59:27.440 627-1191/system_process V/ActivityManager: Register receiver android.content.IntentFilter@f9d9453: null
01-18 16:59:27.443 627-1189/system_process V/ActivityManager: Register receiver android.content.IntentFilter@6322af: null
01-18 16:59:27.460 2814-2814/com.android.systemui D/AndroidRuntime: Shutting down VM
        --------- beginning of crash
01-18 16:59:27.461 2814-2814/com.android.systemui E/AndroidRuntime: FATAL EXCEPTION: main
Process: com.android.systemui, PID: 2814
java.lang.NullPointerException: Attempt to invoke virtual method ‘void android.view.View.setOnTouchListener(android.view.View$OnTouchListener)’ on a null object reference
at com.android.systemui.statusbar.phone.PhoneStatusBar.prepareNavigationBarView(PhoneStatusBar.java:1299)
at com.android.systemui.statusbar.phone.PhoneStatusBar.addNavigationBar(PhoneStatusBar.java:1468)
at com.android.systemui.statusbar.phone.PhoneStatusBar.start(PhoneStatusBar.java:650)
at com.android.systemui.statusbar.SystemBars.createStatusBarFromConfig(SystemBars.java:111)
at com.android.systemui.statusbar.SystemBars.onNoService(SystemBars.java:58)
at com.android.systemui.statusbar.ServiceMonitor.startService(ServiceMonitor.java:230)
at com.android.systemui.statusbar.ServiceMonitor.-wrap5(ServiceMonitor.java)
at com.android.systemui.statusbar.ServiceMonitor$1.handleMessage(ServiceMonitor.java:73)
at android.os.Handler.dispatchMessage(Handler.java:102)
at android.os.Looper.loop(Looper.java:148)
at android.app.ActivityThread.main(ActivityThread.java:5426)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:772)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:662)
01-18 16:59:27.465 627-2737/system_process W/ActivityManager: Process com.android.systemui has crashed too many times: killing!
01-18 16:59:27.465 627-2737/system_process I/DualScreen: ActivityStackSupervisor->targetStack:ActivityStack{d27a564 stackId=0, 1 tasks}
01-18 16:59:27.465 627-2737/system_process I/DualScreen: ActivityStackSupervisor->resumeTopActivitiesLocked->defaultStacks:[ActivityStack{d27a564 stackId=0, 1 tasks}]
01-18 16:59:27.465 627-2737/system_process I/DualScreen: ActivityStack->resumeTopActivityLockedActivityStack{d27a564 stackId=0, 1 tasks}
01-18 16:59:27.465 627-2737/system_process I/DualScreen: ActivityStack->resumeTopActivityInnerLocked:ActivityStack{d27a564 stackId=0, 1 tasks}
01-18 16:59:27.466 627-2737/system_process I/DualScreen: ActivityStack->resumeTopActivityInnerLocked->mResumedActivity:ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}
01-18 16:59:27.466 627-2737/system_process I/DualScreen: resumeTopActivityInnerLocked->prev:null
01-18 16:59:27.467 627-2737/system_process D/ActivityManager: com.android.server.am.ActivityStack.resumeTopActivityInnerLocked:1779 com.android.server.am.ActivityStack.resumeTopActivityLocked:1708 : mLockScreenShown=LOCK_SCREEN_HIDDEN mWakefulness=Awake mSleeping=false
01-18 16:59:27.468 627-2737/system_process I/DualScreen: ActivityStack->resumeTopActivityInnerLocked->next:ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}
01-18 16:59:27.468 627-2737/system_process I/DualScreen: ActivityStack->resumeTopActivityInnerLocked->this = ActivityStack{d27a564 stackId=0, 1 tasks}
01-18 16:59:27.468 627-2737/system_process I/DualScreen: ActivityStack->resumeTopActivityInnerLocked->getFirstStack = ActivityStack{d27a564 stackId=0, 1 tasks}
01-18 16:59:27.469 627-2737/system_process D/ActivityManager: allResumedActivitiesComplete: mLastFocusedStack changing from=ActivityStack{d27a564 stackId=0, 1 tasks} to=ActivityStack{d27a564 stackId=0, 1 tasks}
01-18 16:59:27.469 627-2737/system_process D/ActivityManager: resumeTopActivityLocked: Top activity resumed ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}
01-18 16:59:27.470 627-2737/system_process I/DualScreen: ActivityStackSupervisor->targetStack:ActivityStack{d27a564 stackId=0, 1 tasks}
01-18 16:59:27.514 627-654/system_process D/WindowManagerService: addWindowToListInOrderLocked: win=Window{8233e u0 Application Error: com.android.systemui} Callers=com.android.server.wm.WindowManagerService.addWindow:3419 com.android.server.wm.Session.addToDisplay:207 android.view.ViewRootImpl.setView:531 android.view.WindowManagerGlobal.addView:310
01-18 16:59:27.514 627-654/system_process V/WindowManagerService: Free window: Adding window Window{8233e u0 Application Error: com.android.systemui} at 3 of 3
01-18 16:59:27.514 627-654/system_process I/DualScreen: WindowManagerService->findFocusedWindowLocked->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:27.514 627-654/system_process I/DualScreen: WindowManagerService->findFocusedWindowLocked->windows:[Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}, Window{a4382bd u0 KeyguardScrim}, Window{6c65c42 u0 StatusBar}, Window{8233e u0 Application Error: com.android.systemui}]
01-18 16:59:27.514 627-654/system_process V/WindowManagerService: Looking for focus: 3 = Window{8233e u0 Application Error: com.android.systemui}, flags=25296898, canReceive=true
01-18 16:59:27.515 627-654/system_process V/WindowManagerService: findFocusedWindow: Found new focus @ 3 = Window{8233e u0 Application Error: com.android.systemui}
01-18 16:59:27.515 627-654/system_process I/DualScreen: findFocusedWindow->win:Window{8233e u0 Application Error: com.android.systemui}
01-18 16:59:27.515 627-654/system_process V/WindowManagerService: Changing focus from Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher} to Window{8233e u0 Application Error: com.android.systemui} Callers=com.android.server.wm.WindowManagerService.addWindow:3459 com.android.server.wm.Session.addToDisplay:207 android.view.ViewRootImpl.setView:531 android.view.WindowManagerGlobal.addView:310
01-18 16:59:27.516 627-654/system_process D/WindowManagerService: Input focus has changed to Window{8233e u0 Application Error: com.android.systemui}
01-18 16:59:27.516 627-658/system_process I/WindowManagerService: Focus moving from Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher} to Window{8233e u0 Application Error: com.android.systemui}
01-18 16:59:27.516 627-658/system_process I/WindowManagerService: Gaining focus: Window{8233e u0 Application Error: com.android.systemui}
01-18 16:59:27.530 627-654/system_process D/WindowStateAnimator: rk_debug2 Application Error: com.android.systemui_Force_To_Dual
01-18 16:59:27.532 627-654/system_process I/DualScreen: WindowManagerService->findFocusedWindowLocked->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:27.532 627-654/system_process I/DualScreen: WindowManagerService->findFocusedWindowLocked->windows:[Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}, Window{a4382bd u0 KeyguardScrim}, Window{6c65c42 u0 StatusBar}, Window{8233e u0 Application Error: com.android.systemui}]
01-18 16:59:27.532 627-654/system_process V/WindowManagerService: Looking for focus: 3 = Window{8233e u0 Application Error: com.android.systemui}, flags=25296898, canReceive=true
01-18 16:59:27.533 627-654/system_process V/WindowManagerService: findFocusedWindow: Found new focus @ 3 = Window{8233e u0 Application Error: com.android.systemui}
01-18 16:59:27.533 627-654/system_process I/DualScreen: findFocusedWindow->win:Window{8233e u0 Application Error: com.android.systemui}
01-18 16:59:27.533 627-654/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:27.545 627-654/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:27.548 627-654/system_process V/WindowManagerService: Relayout of Window{8233e u0 Application Error: com.android.systemui}: focusMayChange=true
01-18 16:59:27.548 627-1726/system_process I/OpenGLRenderer: Initialized EGL, version 1.4
01-18 16:59:27.554 212-254/? E/BufferQueueProducer: [Application Error: com.android.systemui_Force_To_Dual] connect(P): already connected (cur=1 req=1)
01-18 16:59:27.554 627-1726/system_process D/mali_winsys: EGLint new_window_surface(egl_winsys_display*, void*, EGLSurface, EGLConfig, egl_winsys_surface**, egl_color_buffer_format*, EGLBoolean) returns 0x3000
01-18 16:59:27.555 212-254/? D/gralloc: Isfb=0, [918,266,928,3712], fmt=1, byte_stride=3712
01-18 16:59:27.585 627-658/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:27.589 627-658/system_process I/WindowManagerService: Losing delayed focus: Window{cb01853 u0 com.android.launcher3/com.android.launcher3.Launcher}
01-18 16:59:27.596 627-658/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:27.761 627-658/system_process I/WindowManagerService: performLayoutLockedInner->displayContent:Display 0 info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 1280 x 656, real 1280 x 720, largest app 1280 x 1184, smallest app 720 x 624, mode 1, defaultMode 1, modes [{id=1, width=1280, height=720, fps=120.00001}], colorTransformId 1, defaultColorTransformId 1, supportedColorTransforms [{id=1, colorTransform=0}], rotation 0, density 213 (160.15764 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} stacks=[{stackId=0 tasks=[{taskId=3 appTokens=[AppWindowToken{c403d56 token=Token{143cb71 ActivityRecord{3bdd0fb u0 com.android.launcher3/.Launcher t3}}}] mdr=false}]}]
01-18 16:59:29.637 237-374/? D/alsa_route: route_set_controls() set route 24
01-18 16:59:29.723 237-374/? D/AudioHardwareTiny: close device
其中 Process: com.android.systemui, PID: 2814
java.lang.NullPointerException: Attempt to invoke virtual method ‘void android.view.View.setOnTouchListener(android.view.View$OnTouchListener)’ on a null object reference是代码中hidebar与rotationbar的touch监听
谢谢,我这边已经重现了问题,稍后给你修改补丁
另外修改为720p,在Androidstudio中显示为720p,开机logo还是1080p,在调试串口显示为1080p,这个也有问题
已解决问题,谢谢
0001-Android-SystemUI-fix-sw480dp-SystemUI.patch.tar.gz (3.61 KB)
补丁是修复崩溃问题的,后续会更新到SDK上
其中 Process: com
其中 Process: com
