[ 3.786619] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/platform/ff540000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:062A:4182.0002/input/input1
[ 3.825703] rockchip-drm display-subsystem: fb0: frame buffer device
[ 3.843748] hid-generic 0003:062A:4182.0002: input,hiddev0,hidraw1: USB HID v1.10 Mouse [MOSART Semi. 2.4G Keyboard Mouse] on usb-ff540000.usb-1.1/input1
[ 3.980848] asoc-simple-card sound_i2s: i2s-hifi ↔ ff890000.i2s mapping ok
[ 3.990119] asoc-simple-card sound_i2s: ES8323 HiFi ↔ ff890000.i2s mapping ok
[ 4.000487] input: gpio-keys as /devices/platform/gpio-keys/input/input2
[ 4.007646] rtc-hym8563 0-0051: no valid clock/calendar values available
[ 4.014500] rtc-hym8563 0-0051: hctosys: unable to read the hardware clock
[ 4.029565] dovdd_1v8: disabling
[ 4.032914] vcc_sd: disabling
[ 4.036526] ALSA device list:
[ 4.039573] #0: rockchip,firefly-codec
[ 4.043911] ttyS2 - failed to request DMA
[ 4.048987] Freeing unused kernel memory: 1024K (c0e00000 - c0f00000)
Loading, please wait…
/init: line 224: can’t create /sys/class/display/HDMI/enable: nonexistent directory
[ 4.082911] udevd[143]: starting version 175
Begin: Loading essential drivers … FATAL: Could not load /lib/modules/4.4.16/modules.dep: No such file or directory
done.
Begin: Running /scripts/init-premount … done.
[ 4.218951] random: nonblocking pool is initialized
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 2…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 3…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 4…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 5…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 6…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 7…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 8…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 9…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 10…
[ 13.657735] aaaaa vga_encoder_atomic_check 125 1
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 11…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 12…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 13…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 14…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 15…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 16…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 17…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 18…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 19…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 20…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 21…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 22…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 23…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 24…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 25…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 26…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 27…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 28…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 29…
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 30…
Gave up waiting for root device. Common problems:
- Boot args (cat /proc/cmdline)
- Check rootdelay= (did the system wait long enough?)
- Check root= (did the system wait for the right device?)
- Missing modules (cat /proc/modules; ls /dev)
ALERT! /dev/block/mtd/by-name/linuxroot does not exist. Dropping to a shell!
/bin/sh: can’t access tty; job control turned off
(initramfs)
上面是片段日志,我用官网的镜像我更新了内核启动就是这样.我制作的跟文件系统也是如此.
