rk3288点双屏(mipi为主屏,edp为副屏),开机直接死机。打印信息如下:
DDR Version 1.00 20160530
SRX
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
U-Boot 2014.10-RK3288-10-gc28aaca-dirty (May 04 2017 - 04:08:32)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 20
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2017-05-04#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x00697460)
ramdisk @ 0x05bf0000 (0x00138ef0)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561b919 … OK
[ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (xxl@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #3 SMP PREEMPT Thu May 11 03:38:13 EDT 2017 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288 [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(drm): base(0) size(0) align(0) [ 0.000000] ion heap(cma): base(0) size(28000000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 640 MiB at 58000000 [ 0.000000] ion_reserve: cma reserved base 58000000 size 671088640 [ 0.000000] cma: CMA: reserved 16 MiB at 1f000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] Boot mode: REBOOT (6) flag: LOADER (0xc3524201) [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1eee000 s13376 r8192 d15296 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264 [ 0.000000] Kernel command line: vmalloc=496M console=ttyFIQ0 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),0x00200000@0x0039C000(userdata),0x00020000@0x0059C000(radical_update),-@0x005BC000(user) storagemedia=emmc loader.timestamp=2017-05-04_04:08:32 [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] allocated 4194304 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 1387700k/1387700k available, 709452k reserved, 917504K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0b878ac (11775 kB) [ 0.000000] .init : 0xc0b88000 - 0xc0be3440 ( 366 kB) [ 0.000000] .data : 0xc0be4000 - 0xc0d73d40 (1600 kB) [ 0.000000] .bss : 0xc0d73d40 - 0xc0e949bc (1156 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! [ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div [ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0 [ 0.000000] rkclk_init_clks: cnt_parent = 7 [ 0.000000] rkclk_init_clks: cnt_rate = 28 [ 0.000000] rk3288 set GPLL BW 20 for HDMI! [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 3 [ 0.000000] channel:0, lkg:16 [ 0.000000] target-temp:80 [ 0.000000] channel:2, lkg:0 [ 0.000000] channel:0, lkg:16 [ 0.000000] channel:1, lkg:13 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 0.350387] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.350402] pid_max: default: 32768 minimum: 301 [ 0.350515] Security Framework initialized [ 0.350532] SELinux: Initializing. [ 0.350605] Mount-cache hash table entries: 512 [ 0.351243] Initializing cgroup subsys debug [ 0.351258] Initializing cgroup subsys memory [ 0.351284] Initializing cgroup subsys freezer [ 0.351312] CPU: Testing write buffer coherency: ok [ 0.351631] /cpus/cpu@0 missing clock-frequency property [ 0.351645] /cpus/cpu@1 missing clock-frequency property [ 0.351654] /cpus/cpu@2 missing clock-frequency property [ 0.351664] /cpus/cpu@3 missing clock-frequency property [ 0.351713] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500 [ 0.351764] Setting up static identity map for 0xc0859320 - 0xc0859378 [ 0.354041] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x174d (version 3.1) [ 0.428544] CPU1: Booted secondary processor [ 0.428576] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501 [ 0.448215] CPU2: Booted secondary processor [ 0.448238] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502 [ 0.467928] CPU3: Booted secondary processor [ 0.467951] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503 [ 0.468054] Brought up 4 CPUs [ 0.468082] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.468091] CPU: All CPU(s) started in SVC mode. [ 0.468819] devtmpfs: initialized [ 0.472984] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0 [ 0.474070] pinctrl core: initialized pinctrl subsystem [ 0.474323] regulator-dummy: no parameters [ 0.498905] NET: Registered protocol family 16 [ 0.500667] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.500988] ion_snapshot: 0x1ea90000 map to 0xe0907000 and copy to 0xc0e6fecc (version 0.1) [ 0.501246] Registered FIQ tty driver [ 0.502537] console [ttyFIQ0] enabled [ 0.502768] Registered fiq debugger ttyFIQ0 [ 0.503365] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff [ 0.503390] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f [ 0.503410] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f [ 0.503429] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b [ 0.503524] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff [ 0.503593] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff [ 0.503658] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff [ 0.503725] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff [ 0.503790] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff [ 0.503856] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff [ 0.503922] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff [ 0.503987] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff [ 0.504059] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff [ 0.504128] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3 [ 0.504143] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f [ 0.504157] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf [ 0.504172] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f [ 0.504794] rockchip_interrupts_register:bank_num=7 [ 0.506707] of_get_gpio_init_config:gpio[0] = 6, value = 0 [ 0.506767] rockchip_pinctrl_probe:init ok [ 0.513510] rk_iommu ff900800.iep_mmu: (iep) Enter [ 0.513597] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.513614] rk_iommu ff900800.iep_mmu: (iep) Initialized [ 0.513775] rk_iommu ff950800.vip_mmu: (vip) Enter [ 0.513847] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.513863] rk_iommu ff950800.vip_mmu: (vip) Initialized [ 0.514023] rk_iommu ff930300.vopb_mmu: (vopb) Enter [ 0.514101] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.514117] rk_iommu ff930300.vopb_mmu: (vopb) Initialized [ 0.514285] rk_iommu ff940300.vopl_mmu: (vopl) Enter [ 0.514356] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.514372] rk_iommu ff940300.vopl_mmu: (vopl) Initialized [ 0.514542] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter [ 0.514624] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.514640] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized [ 0.514806] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter [ 0.514881] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.514897] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized [ 0.515067] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter [ 0.515152] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.515169] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized [ 0.516844] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.516861] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.517487] rk3368_init_rockchip_pmu_ops: could not find pmu dt node [ 0.517514] DDR DEBUG: version 1.00 20150126 [ 0.517543] DDR DEBUG: Channel a: [ 0.517554] DDR DEBUG: DDR3 Device [ 0.517569] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.517580] DDR DEBUG: Channel b: [ 0.517589] DDR DEBUG: DDR3 Device [ 0.517602] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.517614] DDR DEBUG: addr=0xd7d000 [ 0.517625] DDR DEBUG: stride=9, size=256, halfcap=40000000 [ 0.517637] DDR DEBUG: socAddr[0]=0xd7d000, socAddr[1]=0xd7d100 [ 0.517648] DDR DEBUG: chAddr[0]=0xd7d000, chAddr[1]=0xd7d000 [ 0.517661] DDR DEBUG: dtar[0]=0x501af000, dtar[1]=0x501af000 [ 0.517719] DDR DEBUG: init success!!! freq=200MHz [ 0.517729] DDR DEBUG: Channel a: [ 0.517742] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.517758] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.517774] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.517789] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.517804] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.517815] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.517826] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.517835] DDR DEBUG: Channel b: [ 0.517848] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.517863] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.517879] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.517894] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.517909] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.517920] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.517930] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.542564] bio: create slab at 0 [ 0.543093] Rockchip hdmi driver version 2.0 . [ 0.544243] SCSI subsystem initialized [ 0.544406] usbcore: registered new interface driver usbfs [ 0.544453] usbcore: registered new interface driver hub [ 0.544542] usbcore: registered new device driver usb [ 0.547299] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter [ 0.547965] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter [ 0.548426] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter [ 0.548882] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter [ 0.549005] media: Linux media interface: v0.10 [ 0.549051] Linux video capture interface: v2.00 [ 0.549172] pps_core: LinuxPPS API ver. 1 registered [ 0.549186] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.549210] PTP clock support registered [ 0.549265] i2c-core: driver [bq24296] using legacy suspend method [ 0.549277] i2c-core: driver [bq24296] using legacy resume method [ 0.549949] ion_drm_heap_create: 0@0 [ 0.550084] Rockchip ion module is successfully loaded (v1.1) [ 0.550255] Advanced Linux Sound Architecture Driver Initialized. [ 0.550660] Bluetooth: Core ver 2.16 [ 0.550700] NET: Registered protocol family 31 [ 0.550711] Bluetooth: HCI device and connection manager initialized [ 0.550730] Bluetooth: HCI socket layer initialized [ 0.550746] Bluetooth: L2CAP socket layer initialized [ 0.550776] Bluetooth: SCO socket layer initialized [ 0.551032] cfg80211: Calling CRDA to update world regulatory domain [ 0.552060] act8846_i2c_probe,line=881 [ 0.553086] act8846_parse_dt,line=744 [ 0.553527] act8846_i2c_probe: act8846_pmic_hold=1 [ 0.555620] act_dcdc1: 1200 mV [ 0.558602] vccio: 3300 mV [ 0.560483] vdd_logic: 700 <--> 1500 mV at 1125 mV [ 0.563444] act_dcdc4: 2000 mV [ 0.564704] vccio_sd: 1800 <--> 3300 mV at 3300 mV [ 0.567039] act_ldo2: 1000 mV [ 0.569364] act_ldo3: 3300 mV [ 0.571686] act_ldo4: 3300 mV [ 0.574000] act_ldo5: 3300 mV [ 0.576308] act_ldo6: 1000 mV [ 0.578648] vcc_18: 1800 mV [ 0.580953] act_ldo8: 1800 mV [ 0.585803] vdd_arm: 712 <--> 1500 mV at 1100 mV [ 0.590526] vdd_gpu: 712 <--> 1500 mV at 900 mV [ 0.591252] rk808_i2c_probe,line=1355 [ 0.592582] The device is not rk808 -11 [ 0.592669] rk808: probe of 0-001b failed with error -11 [ 0.592743] i2c-core: driver [rk816] using legacy suspend method [ 0.592755] i2c-core: driver [rk816] using legacy resume method [ 0.592798] i2c-core: driver [rk818] using legacy suspend method [ 0.592810] i2c-core: driver [rk818] using legacy resume method [ 0.594555] Switching to clocksource arch_sys_counter [ 0.618445] rga: Module initialized. [ 0.619148] rga2 ff920000.rga: rga ion client create success! [ 0.619349] rga: Driver loaded succesfully [ 0.619593] rk-fb rockchip-fb: rk fb ion client create success! [ 0.619608] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 0.619875] hjc>>>prop:1, x:1366, y:768, dclk:76420000 [ 0.619889] prmry screen timing parse success [ 0.619953] prmry screen power ctrl parse success [ 0.620024] hjc>>>prop:2, x:1366, y:768, dclk:76420000 [ 0.620036] extend screen timing parse success [ 0.620074] rk-screen rk_screen.9: request lcd_en gpio fail:-16 [ 0.620110] rk-screen rk_screen.9: request lcd_cs gpio fail:-16 [ 0.620123] extend screen power ctrl parse success [ 0.620136] rk-screen rk_screen.9: rockchip screen probe success [ 0.620300] rk32-lvds ff96c000.lvds: screen is not lvds/rgb! [ 0.620323] rk32-lvds: probe of ff96c000.lvds failed with error -22 [ 0.620675] Use EDP as extend screen [ 0.620830] rk32-edp rk32-edp: failed to get reset [ 0.620845] rk32-edp rk32-edp: failed to get reset [ 0.621566] rk32-edp rk32-edp: rk32 edp driver probe success [ 0.621758] Use mipi as prmry screen [ 0.621770] rk32-dsi [ 0.621890] dsi->host.irq =51 [ 0.621909] mipi dsi chip is not found, read id:ffffffff, but 3133302a is correct [ 0.621926] rk32-mipi ff960000.mipi: rk mipi_dsi probe fail! [ 0.621940] rk32-mipi ff960000.mipi: rockchip mipi_dsi v1.1 2014-06-17 [ 0.621969] rk32-mipi: probe of ff960000.mipi failed with error -1 [ 0.622706] graphics fb0: rockchip framebuffer registerd:fb0 [ 0.623025] graphics fb1: rockchip framebuffer registerd:fb1 [ 0.623194] graphics fb2: rockchip framebuffer registerd:fb2 [ 0.623369] graphics fb3: rockchip framebuffer registerd:fb3 [ 0.643299] @@@@@@lt8911_probe() [ 0.643352] LT8911 1-0029: edp lt8911 probe ok [ 0.646158] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 0.745265] rk3288-lcdc lcdc0: lcdc0: dclk:66867188>>fps:53 [ 0.745282] rk3288-lcdc lcdc0: wakeup from standby! [ 0.763738] alloc_buffer:ion_phy_addr=0x58000000 [ 0.770530] fb0:phy:58000000>>vir:e0991000>>len:0xd00000 [ 0.770954] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled [ 0.771366] graphics fb4: rockchip framebuffer registerd:fb4 [ 0.771688] graphics fb5: rockchip framebuffer registerd:fb5 [ 0.771867] graphics fb6: rockchip framebuffer registerd:fb6 [ 0.772035] graphics fb7: rockchip framebuffer registerd:fb7 [ 0.791955] Error: Driver 'LT8911' is already registered, aborting... [ 0.890469] rk3288-lcdc lcdc1: lcdc1: dclk:89156250>>fps:70 [ 0.890691] rk32-edp rk32-edp: edp pll locked [ 0.891328] rk32-edp rk32-edp: max link rate:2.70Gps max number of lanes:1 [ 0.895296] rk32-edp rk32-edp: link training success. [ 0.938715] rk3288-lcdc lcdc1: wakeup from standby! [ 0.938731] fb4:phy:58000000>>vir:e0991000>>len:0xd00000 [ 0.938746] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled [ 0.939621] rockchip_set_mux:warning ignore bank num 15 [ 0.939756] rockchip_set_mux:warning ignore bank num 15 [ 0.939884] rockchip_set_mux:warning ignore bank num 15 [ 0.940004] rockchip_set_mux:warning ignore bank num 15 [ 0.940124] rockchip_set_mux:warning ignore bank num 15 [ 0.940242] rockchip_set_mux:warning ignore bank num 15 [ 0.940827] rockchip_set_mux:warning ignore bank num 15 [ 0.941010] rockchip_set_mux:warning ignore bank num 15 [ 0.941570] rockchip_set_mux:warning ignore bank num 15 [ 0.941719] rockchip_set_mux:warning ignore bank num 15 [ 0.942267] rockchip_set_mux:warning ignore bank num 15 [ 0.942414] rockchip_set_mux:warning ignore bank num 15 [ 0.942991] rockchip_set_mux:warning ignore bank num 15 [ 0.943144] rockchip_set_mux:warning ignore bank num 15 [ 0.944583] NET: Registered protocol family 2 [ 0.945276] TCP established hash table entries: 4096 (order: 3, 32768 bytes) [ 0.945359] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 0.945435] TCP: Hash tables configured (established 4096 bind 4096) [ 0.945502] TCP: reno registered [ 0.945519] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.945546] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.945735] NET: Registered protocol family 1 [ 0.946464] Unpacking initramfs... [ 1.013700] Freeing initrd memory: 1248K (c5bf0000 - c5d28000) [ 1.014379] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available [ 1.014934] vcodec_service: probe device ff9a0000.vpu_service [ 1.015134] vcodec_service: No reset resource define [ 1.015330] vcodec_service: ff9a0000.vpu_service: power on [ 1.015414] vcodec_service: probe device ff9a0000.vpu_service [ 1.015432] vcodec_service: checking hw id 4831 [ 1.015914] vcodec_service: ff9a0000.vpu_service: power off... [ 1.015962] vcodec_service: done [ 1.015973] vcodec_service: init success [ 1.016033] vcodec_service: probe device ff9c0000.hevc_service [ 1.016361] vcodec_service: ff9c0000.hevc_service: power on [ 1.016420] vcodec_service: probe device ff9c0000.hevc_service [ 1.016435] vcodec_service: checking hw id 6867 [ 1.016719] vcodec_service: ff9c0000.hevc_service: power off... [ 1.016762] vcodec_service: done [ 1.016773] vcodec_service: init success [ 1.016909] rknandbase v1.0 2014-03-31 [ 1.017039] rknand: probe of ff400000.nandc failed with error -1 [ 1.017157] rknand_driver:ret = 0 [ 1.018425] audit: initializing netlink socket (disabled) [ 1.018471] type=2000 audit(0.670:1): initialized [ 1.019311] bounce pool size: 64 pages [ 1.023991] fuse init (API version 7.22) [ 1.024385] msgmni has been set to 952 [ 1.026304] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 1.026322] io scheduler noop registered [ 1.026333] io scheduler deadline registered [ 1.026423] io scheduler cfq registered (default) [ 1.027270] pwm-backlight backlight.23: failed to request GPIO#226: -16 [ 1.027293] pwm-backlight: probe of backlight.23 failed with error -16 [ 1.028151] IEP Driver loaded succesfully [ 1.028242] Module initialized. [ 1.029217] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208 [ 1.029238] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10 [ 1.030634] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208 [ 1.030655] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 1.031029] vdd_logic: 925 <--> 1400 mV at 1000 mV [ 1.031084] vdd_logic: Failed to create debugfs directory [ 1.031361] rk_serial.c v1.8 2014-03-04 [ 1.031600] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0 [ 1.031788] serial ff180000.serial: membase e1692000 [ 1.031944] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1 [ 1.032110] serial ff190000.serial: membase e16be000 [ 1.032265] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3 [ 1.032431] serial ff1b0000.serial: membase e16c6000 [ 1.032581] ff1c0000.serial: ttyS4 at MMIO 0xff1c0000 (irq = 91) is a rk29_serial.4 [ 1.032750] serial ff1c0000.serial: membase e16ce000 [ 1.035521] loop: module loaded [ 1.035905] zram: Created 1 device(s) ... [ 1.035983] i2c-core: driver [mpu6050B1] using legacy suspend method [ 1.035996] i2c-core: driver [mpu6050B1] using legacy resume method [ 1.036013] mpu_init: Probe name mpu6050B1 [ 1.036163] ak8963_mod_init: Probe name ak8963_mod [ 1.036873] SCSI Media Changer driver v0.25 [ 1.037210] tun: Universal TUN/TAP device driver, 1.6 [ 1.037224] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 1.037347] vmac_init. [ 1.037955] stmmac_probe_config_dt: Can not read property: pmu_regulator. [ 1.037973] stmmac_probe_config_dt: clock input/output? (input). [ 1.037987] stmmac_probe_config_dt: TX delay(0x30). [ 1.038000] stmmac_probe_config_dt: RX delay(0x20). [ 1.038052] stmmac_probe_config_dt: is rockchip,rk3288-gmac [ 1.038063] stmmc_pltfr_init: [ 1.038072] stmmc_pltfr_init: ERROR: Get power-gpio failed. [ 1.038130] stmmc_pltfr_init: init for RGMII [ 1.038142] tx delay=0x30 [ 1.038142] rx delay=0x20 [ 1.038159] tx delay=0x30 [ 1.038159] rx delay=0x20 [ 1.038617] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 1.038630] Normal descriptors [ 1.038639] Ring mode enabled [ 1.038649] DMA HW capability register supported [ 1.038661] RX Checksum Offload Engine supported (type 2) [ 1.038672] TX Checksum insertion supported [ 1.038682] Wake-Up On Lan supported [ 1.038721] Enable RX Mitigation via HW Watchdog Timer [ 1.039194] PPP generic driver version 2.4.2 [ 1.039350] PPP BSD Compression module registered [ 1.039364] PPP Deflate Compression module registered [ 1.039384] PPP MPPE Compression module registered [ 1.039398] NET: Registered protocol family 24 [ 1.039435] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 1.039450] CSLIP: code copyright 1989 Regents of the University of California. [ 1.039462] Rockchip WiFi SYS interface (V1.00) ... [ 1.039497] esp_mem_init enter date May 4 2017 06:40:03 [ 1.039508] esp_mem_init VERSION [V2.5] [ 1.039555] esp_mem_init complete [ 1.039642] usbcore: registered new interface driver catc [ 1.039683] usbcore: registered new interface driver kaweth [ 1.039696] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 1.039742] usbcore: registered new interface driver pegasus [ 1.039781] usbcore: registered new interface driver rtl8150 [ 1.039820] usbcore: registered new interface driver r8152 [ 1.039832] hso: drivers/net/usb/hso.c: Option Wireless [ 1.039898] usbcore: registered new interface driver hso [ 1.039941] usbcore: registered new interface driver asix [ 1.039980] usbcore: registered new interface driver ax88179_178a [ 1.040022] usbcore: registered new interface driver cdc_ether [ 1.040064] usbcore: registered new interface driver cdc_eem [ 1.040102] usbcore: registered new interface driver dm9601 [ 1.040139] usbcore: registered new interface driver dm9620 [ 1.040185] usbcore: registered new interface driver smsc75xx [ 1.040231] usbcore: registered new interface driver smsc95xx [ 1.040275] usbcore: registered new interface driver gl620a [ 1.040315] usbcore: registered new interface driver net1080 [ 1.040354] usbcore: registered new interface driver plusb [ 1.040395] usbcore: registered new interface driver rndis_host [ 1.040434] usbcore: registered new interface driver cdc_subset [ 1.040471] usbcore: registered new interface driver zaurus [ 1.040511] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 1.040575] usbcore: registered new interface driver simcom_wwan [ 1.040622] usbcore: registered new interface driver int51x1 [ 1.040663] usbcore: registered new interface driver kalmia [ 1.040704] usbcore: registered new interface driver ipheth [ 1.040746] usbcore: registered new interface driver sierra_net [ 1.040786] usbcore: registered new interface driver cx82310_eth [ 1.040833] usbcore: registered new interface driver cdc_ncm [ 1.040879] usbcore: registered new interface driver qmi_wwan [ 1.040920] usbcore: registered new interface driver cdc_mbim [ 1.040933] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.043383] EHCI: ehci_rk_probe e1700000 e1700010 [ 1.043403] rockchip_ehci_host ff500000.usb: EHCI Host Controller [ 1.043434] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1 [ 1.043760] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000 [ 1.057124] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00 [ 1.057208] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.057225] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.057240] usb usb1: Product: EHCI Host Controller [ 1.057254] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd [ 1.057267] usb usb1: SerialNumber: ff500000.usb [ 1.057709] hub 1-0:1.0: USB hub found [ 1.057736] hub 1-0:1.0: 1 port detected [ 1.057907] EHCI: ehci_rk_probe ok [ 1.058009] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.058221] usbcore: registered new interface driver cdc_acm [ 1.058234] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.058288] usbcore: registered new interface driver usblp [ 1.058331] usbcore: registered new interface driver cdc_wdm [ 1.058398] usbcore: registered new interface driver usb-storage [ 1.058448] usbcore: registered new interface driver ums-alauda [ 1.058489] usbcore: registered new interface driver ums-cypress [ 1.058530] usbcore: registered new interface driver ums-datafab [ 1.058567] usbcore: registered new interface driver ums_eneub6250 [ 1.058607] usbcore: registered new interface driver ums-freecom [ 1.058646] usbcore: registered new interface driver ums-isd200 [ 1.058685] usbcore: registered new interface driver ums-jumpshot [ 1.058723] usbcore: registered new interface driver ums-karma [ 1.058762] usbcore: registered new interface driver ums-onetouch [ 1.058802] usbcore: registered new interface driver ums-sddr09 [ 1.058848] usbcore: registered new interface driver ums-sddr55 [ 1.058889] usbcore: registered new interface driver ums-usbat [ 1.058985] usbcore: registered new interface driver usbserial [ 1.059027] usbcore: registered new interface driver usbserial_generic [ 1.059060] usbserial: USB Serial support registered for generic [ 1.059101] usbcore: registered new interface driver option [ 1.059132] usbserial: USB Serial support registered for GSM modem (1-port) [ 1.059226] usbcore: registered new interface driver trancevibrator [ 1.059239] usb20_otg: version 3.10a 21-DEC-2012 [ 1.059682] e1780040 [ 1.059697] Core Release: 3.10a [ 1.059708] Setting default values for core params [ 1.059838] Using Buffer DMA mode [ 1.059850] Periodic Transfer Interrupt Enhancement - disabled [ 1.059861] Multiprocessor Interrupt Enhancement - disabled [ 1.059872] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 1.059883] ^^^^^^^^^^^^^^^^^Device Mode [ 1.059897] Dedicated Tx FIFOs mode [ 1.059916] pcd_init otg_dev = ddef11c0 [ 1.060076] usb20_otg ff580000.usb: DWC OTG Controller [ 1.060105] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2 [ 1.060136] usb20_otg ff580000.usb: irq 55, io mem 0x00000000 [ 1.060191] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.060209] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.060224] usb usb2: Product: DWC OTG Controller [ 1.060237] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 1.060250] usb usb2: SerialNumber: ff580000.usb [ 1.060669] hub 2-0:1.0: USB hub found [ 1.060694] hub 2-0:1.0: 1 port detected [ 1.061006] usb20_host: version 3.10a 21-DEC-2012 [ 1.063508] e1800040 [ 1.063521] Core Release: 3.10a [ 1.063532] Setting default values for core params [ 1.063645] Using Buffer DMA mode [ 1.063658] Periodic Transfer Interrupt Enhancement - disabled [ 1.063669] Multiprocessor Interrupt Enhancement - disabled [ 1.063680] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 1.063691] ^^^^^^^^^^^^^^^^^^Host Mode [ 1.063718] usb20_host ff540000.usb: DWC OTG Controller [ 1.063744] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3 [ 1.063775] usb20_host ff540000.usb: irq 57, io mem 0x00000000 [ 1.063867] Init: Power Port (0) [ 1.063921] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.063938] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.063953] usb usb3: Product: DWC OTG Controller [ 1.063966] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 1.063979] usb usb3: SerialNumber: ff540000.usb [ 1.064375] hub 3-0:1.0: USB hub found [ 1.064405] hub 3-0:1.0: 1 port detected [ 1.065121] usbcore: registered new interface driver xpad [ 1.065183] usbcore: registered new interface driver usb_acecad [ 1.065231] usbcore: registered new interface driver aiptek [ 1.065278] usbcore: registered new interface driver gtco [ 1.065326] usbcore: registered new interface driver hanwang [ 1.065378] usbcore: registered new interface driver kbtab [ 1.06436] usbcore: registered new interface driver wacom [ 1.065449] ILITEK line = 3281: Enter [ 1.065568] ILITEK line = 2937: Enter ilitek_i2c_probe +++++++++ client->addr = 0x41++++++ [ 1.065617] ILITEK line = 2639: 2639,ilitek_request_io_port,ilitek_request_io_port gpio_free(i2c.reset_gpio); reset_gpio = 229 i2c.irq_gpio = 230 [ 1.065635] ------------[ cut here ]------------ [ 1.065659] WARNING: at drivers/gpio/gpiolib.c:1519 gpiod_free+0xe0/0xfc() [ 1.065671] Modules linked in: [ 1.065689] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 3.10.0 #3 [ 1.065727] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14) [ 1.065753] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68) [ 1.065775] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_null+0x18/0x1c) [ 1.065796] [] (warn_slowpath_null+0x18/0x1c) from [] (gpiod_free+0xe0/0xfc) [ 1.065825] [] (gpiod_free+0xe0/0xfc) from [] (ilitek_request_io_port+0xe4/0x1e8) [ 1.065850] [] (ilitek_request_io_port+0xe4/0x1e8) from [] (ilitek_i2c_probe+0xe4/0x3d4) [ 1.065873] [] (ilitek_i2c_probe+0xe4/0x3d4) from [] (i2c_device_probe+0xa8/0xd4) [ 1.065898] [] (i2c_device_probe+0xa8/0xd4) from [] (really_probe+0xa8/0x20c) [ 1.065919] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48) [ 1.065938] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84) [ 1.065961] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90) [ 1.065983] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c) [ 1.066002] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138) [ 1.066023] [] (driver_register+0x9c/0x138) from [] (i2c_register_driver+0x40/0xac) [ 1.066044] [] (i2c_register_driver+0x40/0xac) from [] (ilitek_init+0x34/0x78) [ 1.066066] [] (ilitek_init+0x34/0x78) from [] (do_one_initcall+0x34/0xc8) [ 1.066092] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0) [ 1.066115] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130) [ 1.066138] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4) [ 1.066163] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c) [ 1.066197] ---[ end trace 172810bd465c6297 ]--- [ 1.066261] ILITEK line = 2983: ilitek i2c.irq_gpio = 230, i2c.client->irq = 193 [ 1.066277] ILITEK line = 223: Enter 10 ilitek_reset [ 1.155600] dwc_otg_hcd_suspend, usb device mode [ 1.293082] ILITEK line = 350: ilitek_i2c_transfer err [ 1.342865] ILITEK line = 350: ilitek_i2c_transfer err [ 1.371994] usb 1-1: new high-speed USB device number 2 using rockchip_ehci_host [ 1.401904] ILITEK line = 350: ilitek_i2c_transfer err [ 1.460939] ILITEK line = 350: ilitek_i2c_transfer err [ 1.519593] ILITEK line = 453: ilitek_i2c_write_and_read, i2c write error, ret = -11 [ 1.520186] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101 [ 1.520204] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 1.520219] usb 1-1: Product: USB 2.0 Hub [ 1.520795] hub 1-1:1.0: USB hub found [ 1.520925] hub 1-1:1.0: 4 ports detected [ 1.540216] ILITEK line = 350: ilitek_i2c_transfer err [ 1.599240] ILITEK line = 350: ilitek_i2c_transfer err [ 1.658292] ILITEK line = 350: ilitek_i2c_transfer err [ 1.717319] ILITEK line = 350: ilitek_i2c_transfer err [ 1.775423] ILITEK line = 462: ilitek_i2c_write_and_read, i2c read error, ret = -11 [ 1.775441] ILITEK line = 2444: ilitek_i2c_read_tp_info, MCU KERNEL version:255.255.255.255.255 [ 1.775854] ILITEK line = 350: ilitek_i2c_transfer err [ 1.834858] ILITEK line = 350: ilitek_i2c_transfer err [ 1.893898] ILITEK line = 350: ilitek_i2c_transfer err [ 1.952943] ILITEK line = 350: ilitek_i2c_transfer err [ 2.011583] ILITEK line = 453: ilitek_i2c_write_and_read, i2c write error, ret = -11 [ 2.032063] ILITEK line = 350: ilitek_i2c_transfer err [ 2.091105] ILITEK line = 350: ilitek_i2c_transfer err [ 2.150144] ILITEK line = 350: ilitek_i2c_transfer err [ 2.209183] ILITEK line = 350: ilitek_i2c_transfer err [ 2.267423] ILITEK line = 462: ilitek_i2c_write_and_read, i2c read error, ret = -11 [ 2.267438] ILITEK line = 3035: ilitek read tp info fail free gpio [ 2.267468] ilitek_i2c: probe of 4-0041 failed with error -1 [ 2.267864] sensor_register_slave:mma8452,id=17 [ 2.267880] sensor_register_slave:gs_mc3230,id=23 [ 2.267890] gsensor_init [ 2.267901] sensor_register_slave:mpu6880_acc,id=24 [ 2.267911] sensor_register_slave:mpu6500_acc,id=25 [ 2.267923] sensor_register_slave:cm3217,id=48 [ 2.267934] sensor_register_slave:cm3218,id=49 [ 2.272847] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0 [ 2.272895] i2c /dev entries driver [ 2.273478] IR NEC protocol handler initialized [ 2.273491] IR RC5(x) protocol handler initialized [ 2.273502] IR RC6 protocol handler initialized [ 2.273512] IR JVC protocol handler initialized [ 2.273522] IR Sony protocol handler initialized [ 2.273532] IR RC5 (streamzap) protocol handler initialized [ 2.273542] IR SANYO protocol handler initialized [ 2.273552] IR MCE Keyboard/mouse protocol handler initialized [ 2.273724] usbcore: registered new interface driver uvcvideo [ 2.273737] USB Video Class driver (1.1.1) [ 2.273750] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0 [ 2.274775] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288 [ 2.274775] [ 2.274852] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0) [ 2.275001] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe16d0000 size: 0x4000) [ 2.275657] D1:camsys_platform_probe(1394): ff910000.isp memory: [ 2.275675] D1:camsys_platform_probe(1404): Register memory (phy: 0xff910000 vir: 0xe1740000 size: 0x10000) [ 2.275691] D1:camsys_platform_probe(1399): I2c memory (phy: 0x1df89000 vir: 0xddf89000 size: 0x1000) [ 2.275705] D1:camsys_init_ext_fsh_module(20): init external flash module [ 2.275718] D1:camsys_platform_probe(1419): Probe ff910000.isp device success [ 2.276066] not find test_power_init dev node [ 2.276122] i2c-core: driver [bq27320] using legacy suspend method [ 2.276134] i2c-core: driver [bq27320] using legacy resume method [ 2.276454] rockchip_temp_probe,line=362 [ 2.326471] tsadc ff280000.tsadc: initialized [ 2.326859] device-mapper: uevent: version 1.0.3 [ 2.327118] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email]dm-devel@redhat.com[/email] [ 2.327415] Bluetooth: HCI UART driver ver 2.2 [ 2.327433] Bluetooth: HCI H4 protocol initialized [ 2.327444] Bluetooth: HCILL protocol initialized [ 2.327455] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21 [ 2.327467] rtk_btusb: Register usb char device interface for BT driver [ 2.327661] usbcore: registered new interface driver rtk_btusb [ 2.327772] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller than default(534937), use default, just enable dvfs [ 2.330496] cpufreq version 1.0, suspend freq 1200 MHz [ 2.330692] cpuidle: using governor ladder [ 2.330705] cpuidle: using governor menu [ 2.330743] Synopsys Designware Multimedia Card Interface Driver [ 2.330755] MHSC version = Ver 2.00 2015-06-10 [ 2.331057] dw cru_regsbase addr 0x1d8. [ 2.331069] dw cru_reset_offset val 3. [ 2.331085] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a [ 2.331128] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc [ 2.331440] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller. [ 2.331614] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0] [ 2.331742] 1358..dw_mci_set_ios: no card. [mmc0] [ 2.346166] 1358..dw_mci_set_ios: no card. [mmc0] [ 2.365887] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0] [ 2.365914] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo [ 2.365935] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized [ 2.366244] dw cru_regsbase addr 0x1d8. [ 2.366257] dw cru_reset_offset val 0. [ 2.366272] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a [ 2.366308] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc [ 2.367038] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller. [ 2.367194] dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc1] [ 2.367643] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found! [ 2.367721] 1358..dw_mci_set_ios: no card. [mmc1] [ 2.385516] 1358..dw_mci_set_ios: no card. [mmc1] [ 2.397979] mmc0: BKOPS_EN bit is not set [ 2.399861] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0] [ 2.402145] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0) [ 2.402168] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0] [ 2.402191] [mmc0] tuning regsbase addr 0x218. [ 2.402851] [mmc0] Data transmission error !!!! MINTSTS: [0x00000088] [ 2.402861] [mmc0] host was already tuning, Don't need to retry tune again ignore 0. [ 2.402892] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84 [ 2.403151] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-192 (18 len) [ 2.403163] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 214-282 (7 len) [ 2.403174] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-192 (18 len) [ 2.403184] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 102 [ 2.403227] mmc0: new HS200 MMC card at address 0001 [ 2.403490] mmcblk0: mmc0:0001 AWPD3R 14.5 GiB [ 2.403795] rkpart: partition size too small (0) [ 2.403815] uboot: 0x000400000 -- 0x000800000 (4 MB) [ 2.403824] misc: 0x000800000 -- 0x000c00000 (4 MB) [ 2.403833] resource: 0x000c00000 -- 0x001c00000 (16 MB) [ 2.403842] kernel: 0x001c00000 -- 0x002c00000 (16 MB) [ 2.403851] boot: 0x002c00000 -- 0x004c00000 (32 MB) [ 2.403859] recovery: 0x004c00000 -- 0x006c00000 (32 MB) [ 2.403867] backup: 0x006c00000 -- 0x00a000000 (52 MB) [ 2.403876] cache: 0x00a000000 -- 0x012000000 (128 MB) [ 2.403885] kpanic: 0x012000000 -- 0x012400000 (4 MB) [ 2.403893] system: 0x012400000 -- 0x072400000 (1536 MB) [ 2.403901] metadata: 0x072400000 -- 0x073400000 (16 MB) [ 2.403910] baseparamer: 0x073400000 -- 0x073800000 (4 MB) [ 2.403918] userdata: 0x073800000 -- 0x0b3800000 (1024 MB) [ 2.403926] radical_update: 0x0b3800000 -- 0x0b7800000 (64 MB) [ 2.403935] user: 0x0b7800000 -- 0x3a3a00000 (11970 MB) [ 2.403963] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15[ 2.405248] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo [ 2.405263] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized 1358..dw_mci_set_ios: no card. [mmc1] [ 2.405579] dw cru_regsbase addr 0x1d8. [ 2.405587] dw cru_reset_offset val 1. [ 2.405598] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a [ 2.405632] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc [ 2.405855] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller. [ 2.405986] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2] [ 2.406235] 1358..dw_mci_set_ios: no card. [mmc2] [ 2.424879] 1358..dw_mci_set_ios: no card. [mmc2] [ 2.444564] 1358..dw_mci_set_ios: no card. [mmc2] [ 2.444581] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo [ 2.444594] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized [ 2.444891] hidraw: raw HID events driver (C) Jiri Kosina [ 2.446355] usbcore: registered new interface driver usbhid [ 2.446365] usbhid: USB HID core driver [ 2.446476] ashmem: initialized [ 2.446592] logger: created 256K log 'log_main' [ 2.446687] logger: created 256K log 'log_events' [ 2.446782] logger: created 256K log 'log_radio' [ 2.446874] logger: created 256K log 'log_system' [ 2.448142] input: rk29-keypad as /devices/ff100000.adc/key.32/input/input0 [ 2.449038] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010 [ 2.449056] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22 [ 2.449068] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl [ 2.449079] ES8323 2-0010: Error applying setting, reverse things back [ 2.449521] es8323_i2c_probe:register ISR (irq=196) [ 2.450162] rockchip-spdif ff8b0000.rockchip-spdif: spdif ready. [ 2.450469] es8323_probe [ 3.039860] EHCI: rk_ehci_hcd_enable, enable host controller [ 3.197903] rockchip-es8323 rockchip-es8323.29: ES8323 HiFi <-> ff890000.rockchip-i2s mapping ok [ 3.200170] rockchip-hdmi-i2s rockchip-hdmi-i2s.27: rk-hdmi-i2s-hifi <-> ff890000.rockchip-i2s mapping ok [ 3.200538] u32 classifier [ 3.200544] Actions configured [ 3.200554] Netfilter messages via NETLINK v0.30. [ 3.200605] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 3.200862] ctnetlink v0.93: registering with nfnetlink. [ 3.200920] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 3.200926] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 3.201119] xt_time: kernel timezone is -0000 [ 3.201277] ip_tables: (C) 2000-2006 Netfilter Core Team [ 3.201383] arp_tables: (C) 2002 David S. Miller [ 3.201416] TCP: cubic registered [ 3.201422] Initializing XFRM netlink socket [ 3.201590] NET: Registered protocol family 10 [ 3.202004] mip6: Mobile IPv6 [ 3.202027] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 3.202127] sit: IPv6 over IPv4 tunneling driver [ 3.202423] NET: Registered protocol family 17 [ 3.202445] NET: Registered protocol family 15 [ 3.202488] Bridge firewalling registered [ 3.202497] Ebtables v2.0 registered [ 3.202661] Bluetooth: RFCOMM TTY layer initialized [ 3.202679] Bluetooth: RFCOMM socket layer initialized [ 3.202685] Bluetooth: RFCOMM ver 1.11 [ 3.202691] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 3.202696] Bluetooth: BNEP filters: protocol multicast [ 3.202706] Bluetooth: BNEP socket layer initialized [ 3.202712] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 3.202721] Bluetooth: HIDP socket layer initialized [ 3.202747] l2tp_core: L2TP core driver, V2.0 [ 3.202760] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 3.202766] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 3.202960] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 3.202969] [WLAN_RFKILL]: can't find rockchip,grf property [ 3.202976] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6212 [ 3.202982] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 3.202990] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control. [ 3.202997] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 3.203015] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0. [ 3.203032] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0. [ 3.203038] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 3.203062] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 3.3V [ 3.203069] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 3.203108] [BT_RFKILL]: Enter rfkill_rk_init [ 3.203225] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147. [ 3.203243] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157. [ 3.203254] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154. [ 3.203266] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159. [ 3.203303] [BT_RFKILL]: Request irq for bt wakeup host [ 3.203392] [BT_RFKILL]: ** disable irq [ 3.203463] [BT_RFKILL]: ap6335 device registered. [ 3.204029] rk3288_init_suspend [ 3.204041] rk3288_suspend_init enter [ 3.204247] rk3288_suspend_init: pm_ctrbits =200007 [ 3.204279] gpio_get_dts_info suspend:4 [ 3.204285] gpio_get_dts_info resume:4 [ 3.204290] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 3.204314] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 3.204432] clks_gating_suspend_init:clkgt info ok [ 3.204502] Registering SWP/SWPB emulation handler [ 3.204804] ddrfreq: verion 1.2 20140526 [ 3.204814] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz [ 3.204821] ddrfreq: auto-freq=0 [ 3.204826] ddrfreq: auto-freq-table[0] 240MHz [ 3.204831] ddrfreq: auto-freq-table[1] 324MHz [ 3.204836] ddrfreq: auto-freq-table[2] 456MHz [ 3.204841] ddrfreq: auto-freq-table[3] 528MHz [ 3.213736] Unable to handle kernel NULL pointer dereference at virtual address 0000000c [ 4.743874] pgd = c0004000 [ 4.746530] [0000000c] *pgd=00000000 [ 4.750055] Internal error: Oops: 5 [#1] PREEMPT SMP ARM [ 4.755271] Modules linked in: [ 4.758282] CPU: 0 PID: 112 Comm: ddrfreqd Tainted: G W 3.10.0 #3 [ 4.765120] task: ddfc9f80 ti: c58a8000 task.ti: c58a8000 [ 4.770429] PC is at rk_fb_set_prmry_screen_status+0x40/0x7c [ 4.775991] LR is at rk_get_prmry_lcdc_drv+0x1c/0x58 [ 4.780866] pc : [] lr : [] psr: 800001d3 [ 4.780866] sp : c58a9dd0 ip : 00000001 fp : c0bec46c [ 4.792138] r10: c58a9e40 r9 : c0025878 r8 : 00000000 [ 4.797268] r7 : e0928000 r6 : fed00000 r5 : 40000113 r4 : 00000000 [ 4.803677] r3 : 00000000 r2 : de9d6a94 r1 : 00000002 r0 : ddc58018 [ 4.810089] Flags: Nzcv IRQs off FIQs off Mode SVC_32 ISA ARM Segment kernel [ 4.817436] Control: 10c5387d Table: 0000406a DAC: 00000015 [ 4.823078] [ 4.823078] PC: 0xc02b5368: [ 4.827270] 5368 e0a32195 e1a00922 e1800703 e8bd8038 d7b634db 431bde82 e92d4008 ebfff4e1 [ 4.835381] 5388 e3500000 0a000002 e3a03e19 e18000d3 e8bd8008 e3a00000 e3a01000 e8bd8008 [ 4.843490] 53a8 e92d4010 e1a04000 ebfff4d6 e3500000 0a000017 e3540000 e5903040 0a000002 [ 4.851600] 53c8 e3540001 1a000012 ea000007 e1d330bc e2433007 e6ff3073 e3530001 95903244 [ 4.859709] 53e8 9593300c 8a00000a ea000006 e1d330bc e2433007 e6ff3073 e3530001 8a000004 [ 4.867817] 5408 e5903244 e5933008 e3530000 0a000000 e12fff33 e3a00000 e8bd8010 e92d4008 [ 4.875927] 5428 ebfff4b8 e3500000 15900044 e8bd8008 e92d4008 ebfff4b3 e2503000 03a000fe [ 4.884036] 5448 08bd8008 e5933240 e5933068 e3530000 0a000001 e12fff33 e8bd8008 e3a000fe [ 4.892146] [ 4.892146] LR: 0xc02b26ac: [ 4.896337] 26ac e2800001 e2833004 e3500004 1afffff2 e2811001 e2822010 e2866010 e2855010 [ 4.904448] 26cc e28cc010 e1510007 baffffe7 e1a00009 e28dd058 e8bd87f0 c0e5e42c c0e5e51c [ 4.912556] 26ec c0a5e04d c0a5e05d c0a5e085 c0e5e568 fefefefe c0a5e09b c0a5e0a8 c0e5e4cc [ 4.920666] 270c c0a5e0ba e92d4008 e59f3048 e5930000 e3500000 08bd8008 e2800010 eb0169a3 [ 4.928775] 272c e3a03000 e5901040 e1a02000 ea000005 e5920038 e2822004 e590c00c e35c0001 [ 4.936884] 274c 08bd8008 e2833001 e1530001 bafffff7 e3a00000 e8bd8008 c0e5e420 e92d45f8 [ 4.944993] 276c e1a04002 e1a05003 ebffffe5 e59f6140 e5963174 e3530009 e2832001 e5862174 [ 4.953102] 278c e1a07000 ca000048 e1a01005 e1a02004 e59d3020 e286605c e59f0118 e3a05000 [ 4.961214] [ 4.961214] SP: 0xc58a9d50: [ 4.965406] 9d50 de78e580 c58a9d54 c58a9d54 c0059c74 ace64bf4 00000000 00000001 a0000113 [ 4.973516] 9d70 c58a9d70 c02b53e8 800001d3 ffffffff c58a9dbc c000d598 ddc58018 00000002 [ 4.981625] 9d90 de9d6a94 00000000 00000000 40000113 fed00000 e0928000 00000000 c0025878 [ 4.989734] 9db0 c58a9e40 c0bec46c 00000001 c58a9dd0 c02b272c c02b53e8 800001d3 ffffffff [ 4.997843] 9dd0 000001c8 c0025a98 c05d8cc8 00000c18 00000708 000001c8 00000000 00000000 [ 5.005952] 9df0 00000001 c0d7fff0 00000004 ace6efb0 00000000 c00252a0 e8819aed 00000000 [ 5.014061] 9e10 ace6efb0 00000000 000001c8 00000001 000001c8 0000225d 00004920 be6fef9d [ 5.022171] 9e30 00000000 8d4fdf3b 83126e97 c0025830 000001c8 c58a9e68 00004920 00000000 [ 5.030280] [ 5.030280] FP: 0xc0bec3ec: [ 5.034472] c3ec fbbc260d 3ab7828b f06b23d0 ae0ec13c 64d26067 00000000 00000000 c0010108 [ 5.042582] c40c ffffffff c0013894 00000009 002fb0d7 00000012 c001bb20 c001bb5c 90f00000 [ 5.050691] c42c c001b660 c001b624 ffffffff 00000000 00000000 00000000 00000000 00000000 [ 5.058800] c44c 00000000 00000000 00000000 00000000 00000029 00000000 00000000 00000000 [ 5.066909] c46c 0000000f 0000000f 0000000f 0000000f 00000000 de812d80 de812e40 de812f00 [ 5.075018] c48c de84f100 de85b000 de84f300 de84f500 00000000 00000015 00000001 00000000 [ 5.083127] c4ac 00002e7b 000003e8 00000001 00000001 00000020 00000001 00000000 0007a120 [ 5.091236] c4cc 00000028 00989680 00004e20 00000000 00000000 00000000 00000003 00000001 [ 5.099346] [ 5.099346] R0: 0xddc57f98: [ 5.103538] 7f98 ddc57fac de873df0 c0056040 00000000 00000000 c000da98 00000000 00000000 [ 5.111647] 7fb8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 5.119757] 7fd8 00000000 00000000 00000000 00000000 00000000 00000000 00000013 00000000 [ 5.127866] 7ff8 00000000 00000000 deaa8f40 deaa89c0 c030f5cc 00000000 00000000 00000000 [ 5.135975] 8018 6364636c 00000030 00000000 00000001 deae5210 ddd40000 ddd40400 ddd40800 [ 5.144084] 8038 ddd40c00 00000000 00000004 00000000 00000000 00000000 deaa6b10 00000000 [ 5.152193] 8058 deaa6b10 00003a6b 00000000 00000000 01000000 00000302 00000000 00000000 [ 5.160303] 8078 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 5.168412] [ 5.168412] R2: 0xde9d6a14: [ 5.172605] 6a14 c0ca702c deaa7a00 00000001 00000007 00010001 deac6428 deac6428 00000000 [ 5.180714] 6a34 00000000 de980670 de9d6bbc deb916bc 00000001 00000000 c0c1f6c8 00000000 [ 5.188823] 6a54 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 5.196933] 6a74 00000000 00000000 00000000 deaa9100 deae495c c030f5cc 00000000 00000002 [ 5.205044] 6a94 00000000 00000000 ddd41000 ddd41400 ddd41800 ddd41c00 ddd43000 ddd43400 [ 5.213152] 6ab4 ddd43800 ddd43c00 00000000 00000000 00000008 ddc58018 ddd4a018 00000002 [ 5.221262] 6ad4 de9d6b00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 5.229371] 6af4 00000000 00000000 00000000 00000001 deab8c00 de9d6900 debc8580 deaada8c [ 5.237480] [ 5.237480] R6: 0xfecfff80: [ 5.241672] ff80 ******** ******** ******** ******** ******** ******** ******** ******** [ 5.249785] ffa0 ******** ******** ******** ******** ******** ******** ******** ******** [ 5.257894] ffc0 ******** ******** ******** ******** ******** ******** ******** ******** [ 5.266004] ffe0 ******** ******** ******** ******** ******** ******** ******** ******** [ 5.274113] 0000 00000000 9fff004a 0fff0025 00000008 00000005 9fff0031 0fff0018 00000008 [ 5.282226] 0020 00001f03 9fff0b24 0fff0592 00000008 00000103 9fff00c5 0fff0014 00000008 [ 5.290339] 0040 00000b00 1fff0270 0fff0138 0000000a 00001111 00000000 00000000 00000000 [ 5.298452] 0060 00004031 0000b108 00000003 00000200 00008100 00008100 00008585 00010014 [ 5.306564] [ 5.306564] R7: 0xe0927f80: [ 5.310757] 7f80 c73993e6 44320a6d f4d0e789 2f574fe6 d94ed5c8 18515388 20c226d1 ba16842c [ 5.318865] 7fa0 722fe777 7e50c576 e1ca9a3c 8828c026 98e899f7 2c83be83 580603cc c83e14d0 [ 5.326975] 7fc0 041cbdbc 6263e469 e0b6cd67 4f368981 9373fddc 8d4bc777 ca2728e9 f22567b4 [ 5.335084] 7fe0 cfac610f 4986b9d5 177ce4e1 2cfedf68 3624d2d6 0a417ed3 ec5e66ea ae7ee4dc [ 5.343194] 8000 ******** ******** ******** ******** ******** ******** ******** ******** [ 5.351303] 8020 ******** ******** ******** ******** ******** ******** ******** ******** [ 5.359412] 8040 ******** ******** ******** ******** ******** ******** ******** ******** [ 5.367521] 8060 ******** ******** ******** ******** ******** ******** ******** ******** [ 5.375630] [ 5.375630] R9: 0xc00257f8: [ 5.379822] 57f8 eb007a10 ebffb6d9 e28de008 e28dc028 e58d5000 e8be000f e8ac000f e89e000f [ 5.387931] 5818 e88c000f e1a0100d e59f003c e28d3028 e58d3004 ebfffe51 e59f3038 e3500000 [ 5.396040] 5838 13a02e32 158326c4 1a000005 e59326c4 e3001bb7 e1520001 928220c8 958326c4 [ 5.404150] 5858 eaffff9a e28dd04c e8bd8ff0 c0025878 8d4fdf3b 83126e97 c0bf6944 fefefefe [ 5.412259] 5878 e92d40f0 e24dd01c e59f32f4 e59f52f4 e8900050 e5937000 e5153f40 e3530000 [ 5.420369] 5898 1a000012 e59f02e0 eb0a53e3 e5553f58 e3530000 1a000002 e2433613 e59320cc [ 5.428478] 58b8 ea000003 e3530001 1a000003 e59f32bc e59320d4 e7e73452 e5053e90 e59f32a4 [ 5.436587] 58d8 e5132e90 e1a02302 e282203f e5032e8c e3a00000 ebfff945 e58d0008 e3a00003 [ 5.444697] [ 5.444697] R10: 0xc58a9dc0: [ 5.448974] 9dc0 c02b272c c02b53e8 800001d3 ffffffff 000001c8 c0025a98 c05d8cc8 00000c18 [ 5.457083] 9de0 00000708 000001c8 00000000 00000000 00000001 c0d7fff0 00000004 ace6efb0 [ 5.465192] 9e00 00000000 c00252a0 e8819aed 00000000 ace6efb0 00000000 000001c8 00000001 [ 5.473301] 9e20 000001c8 0000225d 00004920 be6fef9d 00000000 8d4fdf3b 83126e97 c0025830 [ 5.481410] 9e40 000001c8 c58a9e68 00004920 00000000 be6fef9d 00000000 00000000 00000000 [ 5.489519] 9e60 00000000 00000000 00004920 00000000 be6fef9d 00000000 bf803afb 00000000 [ 5.497628] 9e80 01104b5e 00000000 de80cc00 de82f580 00000000 1b2e0200 1b2e0200 de82f580 [ 5.505738] 9ea0 0006f540 0bebc200 00112a88 c0028138 de80d000 c002ccb4 c0be4000 00106738 [ 5.513848] Process ddrfreqd (pid: 112, stack limit = 0xc58a8238) [ 5.519831] Stack: (0xc58a9dd0 to 0xc58aa000) [ 5.524110] 9dc0: 000001c8 c0025a98 c05d8cc8 00000c18 [ 5.532141] 9de0: 00000708 000001c8 00000000 00000000 00000001 c0d7fff0 00000004 ace6efb0 [ 5.540172] 9e00: 00000000 c00252a0 e8819aed 00000000 ace6efb0 00000000 000001c8 00000001 [ 5.548203] 9e20: 000001c8 0000225d 00004920 be6fef9d 00000000 8d4fdf3b 83126e97 c0025830 [ 5.556234] 9e40: 000001c8 c58a9e68 00004920 00000000 be6fef9d 00000000 00000000 00000000 [ 5.564264] 9e60: 00000000 00000000 00004920 00000000 be6fef9d 00000000 bf803afb 00000000 [ 5.572295] 9e80: 01104b5e 00000000 de80cc00 de82f580 00000000 1b2e0200 1b2e0200 de82f580 [ 5.580327] 9ea0: 0006f540 0bebc200 00112a88 c0028138 de80d000 c002ccb4 c0be4000 00106738 [ 5.588358] 9ec0: 00112a88 0006f540 c0be2cc0 de80d000 1b2e0200 1b2e0200 00000001 c0d91000 [ 5.596390] 9ee0: 00000c00 c00569b8 00000000 c002b31c c0a4e28b c0d91000 1b2e0200 c0028350 [ 5.604421] 9f00: 07829b80 6b49d200 00000c00 c0d91000 00000c00 c0028968 c58a9f40 c0028934 [ 5.612452] 9f20: c58a9f30 c0d91000 c58a8000 c00289a4 c0028968 00000000 00000000 00000000 [ 5.620483] 9f40: c58a9f64 de873ee0 de873ee0 00000000 00000000 c0028968 00000000 00000000 [ 5.628513] 9f60: 00000000 c00560e0 c58a9f64 00000000 00000027 00000000 00000000 00000000 [ 5.636544] 9f80: c58a9f80 c58a9f80 00000000 00000000 c58a9f90 c58a9f90 c58a9fac de873ee0 [ 5.644575] 9fa0: c0056040 00000000 00000000 c000da98 00000000 00000000 00000000 00000000 [ 5.652606] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 5.660636] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000 6c62616e 00372e65 [ 5.668680] [] (rk_fb_set_prmry_screen_status+0x40/0x7c) from [] (ddr_change_freq_sram+0x220/0x338) [ 5.679274] [] (ddr_change_freq_sram+0x220/0x338) from [] (call_with_single_cpu+0x128/0x180) [ 5.689267] [] (call_with_single_cpu+0x128/0x180) from [] (_ddr_change_freq+0x184/0x1cc) [ 5.698922] [] (_ddr_change_freq+0x184/0x1cc) from [] (ddrfreq_scale_rate_for_dvfs+0x20/0x74) [ 5.709004] [] (ddrfreq_scale_rate_for_dvfs+0x20/0x74) from [] (dvfs_target+0x158/0x1fc) [ 5.718659] [] (dvfs_target+0x158/0x1fc) from [] (dvfs_clk_set_rate+0x44/0x80) [ 5.727459] [] (dvfs_clk_set_rate+0x44/0x80) from [] (ddrfreq_mode+0xa0/0x154) [ 5.736258] [] (ddrfreq_mode+0xa0/0x154) from [] (ddrfreq_work+0x198/0x1cc) [ 5.744801] [] (ddrfreq_work+0x198/0x1cc) from [] (ddrfreq_task+0x3c/0x1bc) [ 5.753349] [] (ddrfreq_task+0x3c/0x1bc) from [] (kthread+0xa0/0xac) [ 5.761302] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x3c) [ 5.769250] Code: e2433007 e6ff3073 e3530001 95903244 (9593300c) [ 5.775234] ---[ end trace 172810bd465c6298 ]--- [ 5.779769] Kernel panic - not syncing: Fatal exception in interrupt [ 6.934007] SMP: failed to stop secondary CPUs [ 6.938370] CRU: [ 6.940181] 00000000: 00000000 9fff004a 0fff0025 00000008 00000005 9fff0031 0fff0018 00000008 [ 6.948555] 00000020: 00001f03 9fff0b24 0fff0592 00000008 00000103 9fff00c5 0fff0014 00000008 [ 6.956929] 00000040: 00000b00 1fff0270 0fff0138 0000000a 00001111 00000000 00000000 00000000 [ 6.965302] 00000060: 00004031 0000b108 00000003 00000200 00008100 00008100 00008585 00010014 [ 6.973676] 00000080: 01885091 01885091 0000a101 00002745 00004345 00008a00 00000200 00000200 [ 6.982050] 000000a0: 00000200 0bb8ea60 00010014 00010014 00010014 00000910 00000900 001f05dc [ 6.990423] 000000c0: 00001703 00000707 00000e40 00000700 00008542 00000502 00004141 00000000 [ 6.998797] 000000e0: 00004141 00000505 00008042 00008f8f 00000000 00000631 00001ee5 00008307 [ 7.007171] 00000100: 00001200 00010014 00004141 00000000 00000000 00000000 00000000 00000000 [ 7.015544] 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.023917] 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.032291] 00000160: 00000000 00000000 00000100 00000800 00000000 00000000 0000bb00 00000092 [ 7.040663] 00000180: 00000000 00000000 0000000c 00000000 00000000 0000e010 00000000 00000000 [ 7.049036] 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.057410] 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.065783] 000001e0: 00000000 00000000 00000000 00640064 00000004 00000000 00000002 00000000 [ 7.074156] 00000200: 00000002 00000000 00000002 00000000 00000002 00000000 00000004 00000001 [ 7.082529] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.090903] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.099275] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.107649] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.116022] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.124395] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.132768] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.141142] 00000300: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.149515] 00000320: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.157888] 00000340: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.166261] 00000360: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.174634] 00000380: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.183007] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.191379] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.199752] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 7.208126] 00000400: 00000000 9fff004a 0fff0025 00000008 00000005 9fff0031 0fff0018 00000008 [ 7.216497] Rebooting in 5 seconds..各位大神帮忙看看呗
