自己编译后,烧录进去,kernel卡住不动了,
6.267744] read descriptors
[ 6.267758] read strings
[ 6.267800] pcd_pullup, is_on 1
[ 6.272942] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts:
[ 6.310691] rk3288-lcdc lcdc0: blank mode:0
[ 8.763411] [otg id chg] last id -1 current id 1
[ 8.763426] PortPower off
[ 8.763432] rk_battery_charger_detect_cb , battery_charger_detect 6
[ 8.872643] Using Buffer DMA mode
[ 8.872649] Periodic Transfer Interrupt Enhancement - disabled
[ 8.872654] Multiprocessor Interrupt Enhancement - disabled
[ 8.872660] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 8.872665] ^^^^^^^^^^^^^^^^^Device Mode
[ 8.960262] type=1400 audit(1293891634.780:3): avc: denied { create } for pid=32 comm=“kworker/2:1” name=“es8323_mic_state” scontext=u:r:kernel:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
[ 8.960299] type=1400 audit(1293891634.780:4): avc: denied { write } for pid=32 comm=“kworker/2:1” path=“/data/es8323_mic_state” dev=“rootfs” ino=7988 scontext=u:r:kernel:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
[ 8.960321] es8323_mic_state_ctrl read:
[ 8.960332] mic_state_switch 0
[ 8.960338] hp_det = 0,insert hp
[ 8.960342] hp mic use intern
[ 9.363817] rk_battery_charger_detect_cb , battery_charger_detect 0
ddress
/sbin/sh: warning: won’t have full job control
# [ 11.300299] EXT4-fs (mmcblk0p12): recovery complete
[ 11.300319] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts:
[ 11.305202] EXT4-fs (mmcblk0p15): mounted filesystem with ordered data mode. Opts:
