谁帮忙看看RK-3288调用usb摄像头绿屏?
刚买回来的板子,装上app后,调用usb uvc摄像头,textview显示绿屏。video0,video1创建了。
换uvc确定是不是camera的问题
哥们 可否加个qq 最近我也在调试双摄像头问题
kris_fei 发表于 2017-5-31 11:02
换uvc确定是不是camera的问题
下了个ubantu的固件,正常使用
450339014
我这边用的libuvccamera,不是原生camera
dmesg
[ 16.207009] uvcvideo: uvc_v4l2_open
<7>[ 16.274324] uvcvideo: Resuming interface 0
<7>[ 16.274334] uvcvideo: Resuming interface 1
<7>[ 16.301325] uvcvideo: uvc_v4l2_ioctl(VIDIOC_QUERYCAP)
<7>[ 16.301387] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FMT)
<7>[ 16.301414] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FMT)
<7>[ 16.301438] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FMT)
<7>[ 16.301575] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMESIZES)
<7>[ 16.301603] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 16.301613] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 16.301620] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMESIZES)
<7>[ 16.301632] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 16.301640] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 16.301647] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMESIZES)
<7>[ 16.301659] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 16.301666] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 16.301674] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMESIZES)
<7>[ 16.301684] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 16.301692] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 16.301699] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMESIZES)
<7>[ 16.301708] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 16.301715] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 16.301722] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMESIZES)
<7>[ 16.301732] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 16.301739] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 16.301745] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMESIZES)
<7>[ 16.301754] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 16.301762] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 16.301768] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMESIZES)
<7>[ 16.301819] uvcvideo: uvc_v4l2_ioctl(VIDIOC_S_PARM)
<7>[ 16.301830] uvcvideo: Setting frame interval to 1/120 (83333).
<7>[ 16.356663] uvcvideo: uvc_v4l2_ioctl(VIDIOC_QUERYCTRL)
<7>[ 16.357698] uvcvideo: uvc_v4l2_ioctl(VIDIOC_QUERYCTRL)
<7>[ 16.362520] uvcvideo: uvc_v4l2_ioctl(VIDIOC_QUERYCTRL)
<7>[ 16.362535] uvcvideo: Control 0x009a0929 not found.
<7>[ 16.362542] uvcvideo: uvc_v4l2_ioctl(VIDIOC_QUERYCTRL)
<7>[ 16.363358] uvcvideo: uvc_v4l2_ioctl(VIDIOC_QUERYMENU)
<7>[ 16.363369] uvcvideo: uvc_v4l2_ioctl(VIDIOC_QUERYMENU)
<7>[ 16.363378] uvcvideo: uvc_v4l2_ioctl(VIDIOC_QUERYMENU)
<7>[ 16.363402] uvcvideo: uvc_v4l2_ioctl(VIDIOC_QUERYCTRL)
<7>[ 16.363410] uvcvideo: Control 0x009a092b not found.
<7>[ 16.363436] uvcvideo: uvc_v4l2_ioctl(VIDIOC_QUERYCTRL)
<7>[ 16.363444] uvcvideo: Control 0x009a092e not found.
<7>[ 16.363462] uvcvideo: uvc_v4l2_ioctl(VIDIOC_QUERYCTRL)
<3>[ 16.656610] uvcvideo: Failed to query (GET_DEF) UVC control 2 on unit 2: -110 (exp. 2).
<7>[ 16.656947] uvcvideo: uvc_v4l2_ioctl(VIDIOC_S_PARM)
<7>[ 16.656964] uvcvideo: Setting frame interval to 1/120 (83333).
<3>[ 17.014055] uvcvideo: Failed to set UVC probe control : -32 (exp. 26).
<6>[ 17.387267] binder: release 166:502 transaction 7245 in, still active
<6>[ 17.387286] binder: send failed reply for transaction 7245 to 587:587
<7>[ 17.387445] uvcvideo: uvc_v4l2_release
<4>[ 17.558819] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 17.558845] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 17.558852] D1:camsys_open(739): camsys_marvin(ddf23610) is opened!
<4>[ 17.558927] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 17.558939] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 17.558949] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
<7>[ 17.558967] of_get_named_gpio_flags exited with status 237
<7>[ 17.558973] of_get_named_gpio_flags exited with status 237
<7>[ 17.558978] _gpio_request: gpio-237 (camsys_gpio) status -16
<4>[ 17.558985] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 17.558990] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 17.558999] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x15
<4>[ 17.559009] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7400,result=0x7400
<4>[ 17.559016] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 17.559037] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
<4>[ 17.564125] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 17.564137] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 17.564242] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 17.564273] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 17.565348] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 17.566415] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 17.567480] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
<3>[ 17.570718] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
<3>[ 17.571919] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
<4>[ 17.571999] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
<4>[ 17.572010] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 17.572021] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 17.573534] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 17.573568] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 17.575634] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 17.575651] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 17.575661] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 17.575669] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 17.575675] D1:camsys_release(763): camsys_marvin(ddf23610) is closed
<4>[ 17.576752] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 17.576762] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 17.576770] D1:camsys_open(739): camsys_marvin(ddf23610) is opened!
<4>[ 17.576845] D1:camsys_extdev_register(243): Get RK30_PIN3_PB4(108) gpio(active: 1) for dev_id 0x4000000 success!
<4>[ 17.576856] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x4000000 success!
<4>[ 17.576866] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x4000000 success!
<4>[ 17.576875] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
<4>[ 17.576964] D1:camsys_extdev_register(268): Extdev(dev_id: 0x4000000 dev_name: OV5640) register success
<4>[ 17.582147] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 17.582161] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 17.582265] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 17.582297] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 17.583375] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
<4>[ 17.584456] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
<4>[ 17.585524] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(108) set 0
<3>[ 17.588768] E:camsys_i2c_write(78): i2c write dev(addr:0x78) failed!
<4>[ 17.588855] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(108) set 1
<4>[ 17.588867] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
<4>[ 17.588879] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
<4>[ 17.589984] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 17.590018] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 17.592086] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x4000000) is deregister success
<4>[ 17.592103] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 17.592112] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 17.592118] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 17.592124] D1:camsys_release(763): camsys_marvin(ddf23610) is closed
<4>[ 17.593001] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 17.593017] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 17.593024] D1:camsys_open(739): camsys_marvin(ddf23610) is opened!
<4>[ 17.593096] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
<4>[ 17.593122] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
<4>[ 17.598174] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 17.598188] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 17.598293] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 17.598320] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
<3>[ 17.599383] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<3>[ 17.600451] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 17.601516] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 17.605129] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
<3>[ 17.606600] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
<3>[ 17.606655] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 17.606664] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
<3>[ 17.606673] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
<4>[ 17.607765] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 17.607796] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 17.609857] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
<4>[ 17.609878] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 17.609888] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 17.609894] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 17.609900] D1:camsys_release(763): camsys_marvin(ddf23610) is closed
<7>[ 17.610178] uvcvideo: uvc_v4l2_open
<7>[ 17.610220] uvcvideo: uvc_v4l2_ioctl(VIDIOC_QUERYCAP)
<7>[ 17.610535] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FMT)
<7>[ 17.610549] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FMT)
<7>[ 17.610555] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FMT)
<7>[ 17.610561] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMESIZES)
<7>[ 17.610569] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMESIZES)
<7>[ 17.610574] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMESIZES)
<7>[ 17.610578] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMESIZES)
<7>[ 17.610583] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMESIZES)
<7>[ 17.610588] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMESIZES)
<7>[ 17.610593] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMESIZES)
<7>[ 17.610597] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMESIZES)
<7>[ 17.610603] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 17.610613] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 17.610619] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 17.610625] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 17.610631] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 17.610637] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 17.610642] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 17.610653] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 17.610659] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 17.610666] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 17.610671] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 17.610677] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 17.610682] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 17.610687] uvcvideo: uvc_v4l2_ioctl(VIDIOC_ENUM_FRAMEINTERVALS)
<7>[ 17.610699] uvcvideo: uvc_v4l2_release
<38>[ 17.612744] type=1400 audit(1293883217.630:18): avc: denied { execute } for pid=1070 comm=“mediaserver” name=“sh” dev=“mmcblk0p10” ino=332 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 17.613038] type=1400 audit(1293883217.630:19): avc: denied { read open } for pid=1070 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=332 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 17.613219] type=1400 audit(1293883217.630:20): avc: denied { execute_no_trans } for pid=1070 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=332 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
<38>[ 17.615788] type=1400 audit(1293883217.630:21): avc: denied { getattr } for pid=1070 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=348 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 17.615967] type=1400 audit(1293883217.630:22): avc: denied { execute } for pid=1070 comm=“sh” name=“toolbox” dev=“mmcblk0p10” ino=348 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 17.620980] type=1400 audit(1293883217.630:23): avc: denied { read open } for pid=1070 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=348 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<38>[ 17.621090] type=1400 audit(1293883217.630:24): avc: denied { execute_no_trans } for pid=1070 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=348 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
<7>[ 19.982565] uvcvideo: Suspending interface 1
<7>[ 19.982575] uvcvideo: Suspending interface 0
<4>[ 23.181486] force_usb_mode_store 0->0
<4>[ 39.022924] mic use intern
<3>[ 47.981582] win[2]->area[2],not support scale
<3>[ 47.981619] xact=16,yact=28,xsize=17,ysize=28
<7>[ 53.292581] uvcvideo: Resuming interface 0
<7>[ 53.292595] uvcvideo: Resuming interface 1
<3>[ 55.641361] binder: 1306: binder_alloc_buf, no vma
<6>[ 55.641380] binder: 458:486 transaction failed 29201, size 60-0
<3>[ 55.655927] binder: 1306: binder_alloc_buf, no vma
<6>[ 55.655953] binder: 458:1356 transaction failed 29201, size 104-4
D/EventHub( 458): No input device configuration file found for device ‘USB 2.0 Camera’.
W/EventHub( 458): Unable to disable kernel key repeat for /dev/input/event4: Function not implemented
I/EventHub( 458): New device: id=6, fd=199, path=‘/dev/input/event4’, name=‘USB 2.0 Camera’, classes=0x80000401, configuration=‘’, keyLayout=‘/system/usr/keylayout/Generic.kl’, keyCharacterMap=‘/system/usr/keychars/Generic.kcm’, builtinKeyboard=false, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
I/InputReader( 458): Device added: id=6, name=‘USB 2.0 Camera’, sources=0x00002103
W/AppOps ( 458): Bad call: specified package media under uid 1000 but it is really 1013
W/AudioTrack( 458): AUDIO_OUTPUT_FLAG_FAST denied by client
D/DisplayManager( 1363): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1920 x 1032, real 1920 x 1080, largest app 1920 x 1847, smallest app 1080 x 1007, 120.00001 fps, supportedRefreshRates [120.00001], rotation 0, density 160 (159.89508 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/PhoneWindow( 1363): DecorView - SCREEN_WEITH = 1920 - SCREE_HEIGHT = 1032
V/WindowManagerService( 458): not Base app: Adding window Window{14317548 u0 com.serenegiant.usbcameratest0/com.serenegiant.usbcameratest0.MainActivity} at 4 of 9
D/WindowManagerService( 458): Window{14317548 u0 com.serenegiant.usbcameratest0/com.serenegiant.usbcameratest0.MainActivity} ==========setInputFocusLw ========== =======
D/ViewRootImpl( 1363): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(wrapxwrap)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#ffffffff sim=#120 ty=2 fl=#1860002 fmt=-2 wanim=0x10303e6 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.serenegiant.usbcameratest0token=android.os.BinderProxy@3b7b1b0e}
D/ViewRootImpl( 1363): 864<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(wrapxwrap)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#ffffffff sim=#120 ty=2 fl=#1860002 fmt=-2 wanim=0x10303e6 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.serenegiant.usbcameratest0token=android.os.BinderProxy@3b7b1b0e}
W/gralloc ( 160): Debugmem The fd=117, in vmalloc !!! Ishwc=0
W/gralloc ( 160): Debugmem The fd=118, in vmalloc !!! Ishwc=0
W/gralloc ( 160): Debugmem The fd=119, in vmalloc !!! Ishwc=0
D/PopupWindow( 1363): findDropDownPosition mDrawingLocation(32,112) xoff=-4 yOff=-8 anchroHeight=53
D/PopupWindow( 1363): ----displayFrame=Rect(0, 25 - 1920, 1032)
D/PopupWindow( 1363): root.getWidth=864screenY=563 anchorHeight=53mPopupWidth=796
D/PopupWindow( 1363): final p.x=28 p.y=157
V/WindowManagerService( 458): Adding window Window{20b7c91d u0 PopupWindow:303c5f56} at 5 of 10 (after Window{14317548 u0 com.serenegiant.usbcameratest0/com.serenegiant.usbcameratest0.MainActivity})
D/WindowManagerService( 458): Window{20b7c91d u0 PopupWindow:303c5f56} ==========setInputFocusLw ========== =======
D/ViewRootImpl( 1363): onAttachToWindow register content observer attrs=WM.LayoutParams{(28,157)(796x54)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#10000033 sim=#1 ty=1000 fl=#41860200 fmt=-3 wanim=0x10302e1 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.serenegiant.usbcameratest0token=android.view.ViewRootImpl$W@144fbd7}
D/ViewRootImpl( 1363): 796<<<<<< BACK FROM relayoutWM.LayoutParams{(28,157)(796x54)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#10000033 sim=#11 ty=1000 fl=#41860200 fmt=-3 wanim=0x10302e1 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.serenegiant.usbcameratest0token=android.view.ViewRootImpl$W@144fbd7}
W/gralloc ( 160): Debugmem The fd=101, in vmalloc !!! Ishwc=0
W/gralloc ( 160): Debugmem The fd=124, in vmalloc !!! Ishwc=0
W/gralloc ( 160): Debugmem The fd=126, in vmalloc !!! Ishwc=0
D/ViewRootImpl( 1363): onDetachedFromWindow ungister contentObserver
W/InputEventReceiver( 1363): Attempted to finish an input event but the input event receiver has already been disposed.
W/ViewRootImpl( 1363): Dropping event due to root view being removed: MotionEvent { action=ACTION_HOVER_ENTER, id[0]=0, x[0]=232.45123, y[0]=25.545471, toolType[0]=TOOL_TYPE_MOUSE, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=223183, downTime=223023, deviceId=2, source=0x2002 }
D/UsbDeviceConnectionJNI( 1363): close
I/USBMonitor( 1363): name=/dev/bus/usb/003/005,desc=47,busnum=3,devnum=5,rawDesc=[B@24b4b7ad
V/MainActivity( 1363): onConnect:
D/WindowManagerService( 458): Window{2d6a62e8 u0 com.serenegiant.usbcameratest0/com.serenegiant.usbcameratest0.MainActivity} ==========setInputFocusLw ========== =======
I/libusb/core( 1363): [1381core.c:2085:libusb_init2]:libusb v1.0.19.10903
I/libusb/usbfs( 1363): [1381
android_usbfs.c:504:op_init2]:start up hotplug event handler
I/libusb/usbfs( 1363): [1381android_usbfs.c:512:op_init2]:call android_scan_devices
I/EventHub( 458): Removing device USB 2.0 Camera due to epoll hang-up event.
I/EventHub( 458): Removed device: path=/dev/input/event4 name=USB 2.0 Camera id=6 fd=199 classes=0x80000401
W/InputMethodManagerService( 458): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@62694bf attribute=null, token = android.os.BinderProxy@39e3a40b
I/InputReader( 458): Device removed: id=6, name=‘USB 2.0 Camera’, sources=0x00002103
I/EventHub( 458): Removing device ‘/dev/input/event4’ due to inotify event
I/MainActivity( 1363): supportedSize:{“formats”:[{“index”:1,“type”:6,“default”:1,“size”:[“1920x1080”,“1280x720”,“1024x768”,“640x480”,“800x600”,“1280x1024”,“320x240”]},{“index”:2,“type”:4,“default”:1,“size”:[“1920x1080”,“1280x720”,“1024x768”,“640x480”,“800x600”,“1280x1024”,“320x240”]}]}
I/libUVCCamera( 1363): [1432
UVCPreview.cpp:492:prepare_preview]:frameSize=(640,480)@YUYV
D/AudioHardwareTiny( 1063): close device
D/AudioHardwareTiny( 1063): start_output_stream
D/AudioHardwareTiny( 1063): Device : 0x80400
D/AudioHardwareTiny( 1063): SampleRate : 44100
D/AudioHardwareTiny( 1063): Channels : 2
D/AudioHardwareTiny( 1063): Formate : 0
D/AudioHardwareTiny( 1063): PreiodSize : 2048
V/MainActivity( 1363): onDisconnect:
I/EventHub( 458): New device: id=7, fd=199, path=‘/dev/input/event4’, name=‘USB 2.0 Camera’, classes=0x80000401, configuration=‘’, keyLayout=‘/system/usr/keylayout/Generic.kl’, keyCharacterMap=‘/system/usr/keychars/Generic.kcm’, builtinKeyboard=false, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
I/InputReader( 458): Device added: id=7, name=‘USB 2.0 Camera’, sources=0x00002103
V/WindowManagerService( 458): not Base app: Adding window Window{2e07fed5 u0 com.serenegiant.usbcameratest0/com.serenegiant.usbcameratest0.MainActivity} at 4 of 9
D/WindowManagerService( 458): Window{2e07fed5 u0 com.serenegiant.usbcameratest0/com.serenegiant.usbcameratest0.MainActivity} ==========setInputFocusLw ========== =======
W/gralloc ( 160): Debugmem The fd=44, in vmalloc !!! Ishwc=0
W/gralloc ( 160): Debugmem The fd=91, in vmalloc !!! Ishwc=0
W/gralloc ( 160): Debugmem The fd=95, in vmalloc !!! Ishwc=0
I/USBMonitor( 1363): name=/dev/bus/usb/003/005,desc=49,busnum=3,devnum=5,rawDesc=[B@7d9c719
I/EventHub( 458): Removed device: path=/dev/input/event4 name=USB 2.0 Camera id=7 fd=199 classes=0x80000401
W/InputMethodManagerService( 458): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@3139bddb attribute=null, token = android.os.BinderProxy@39e3a40b
I/InputReader( 458): Device removed: id=7, name=‘USB 2.0 Camera’, sources=0x00002103
I/libUVCCamera( 1363): [1442
D/ActivityManagerService( 458): moveHomeStackTaskToTop: moving TaskRecord{3f208b17 #24 A=com.android.launcher3 U=0 sz=1}
D/WindowManagerService( 458): null ==========setInputFocusLw ========== =======
D/DisplayManager( 458): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1920 x 1032, real 1920 x 1080, largest app 1920 x 1847, smallest app 1080 x 1007, 120.00001 fps, supportedRefreshRates [120.00001], rotation 0, density 160 (159.89508 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
W/gralloc ( 160): Debugmem The fd=83, in vmalloc !!! Ishwc=0
I/InputDispatcher( 458): Dropping event because there is no touchable window at (717, 478).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (718, 478).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (719, 478).
D/ViewRootImpl( 849): 1920<<<<<< BACK FROM relayoutnull
I/InputDispatcher( 458): Dropping event because there is no touchable window at (720, 478).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (721, 478).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (721, 479).
D/WindowManagerService( 458): Window{1cdac2c3 u0 com.android.launcher3/com.android.launcher3.Launcher} ==========setInputFocusLw ========== =======
I/InputDispatcher( 458): Dropping event because there is no touchable window at (722, 479).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (723, 479).
W/gralloc ( 160): Debugmem The fd=90, in vmalloc !!! Ishwc=0
W/gralloc ( 160): Debugmem The fd=98, in vmalloc !!! Ishwc=0
W/gralloc ( 160): Debugmem The fd=112, in vmalloc !!! Ishwc=0
D/DisplayManager( 587): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1920 x 1032, real 1920 x 1080, largest app 1920 x 1847, smallest app 1080 x 1007, 120.00001 fps, supportedRefreshRates [120.00001], rotation 0, density 160 (159.89508 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
V/MainActivity( 1363): surfaceDestroyed:
D/ViewRootImpl( 1363): 1920<<<<<< BACK FROM relayoutnull
V/MainActivity( 1363): onStop:
V/MainActivity( 1363): onDestroy:
I/EventHub( 458): New device: id=8, fd=169, path=‘/dev/input/event4’, name=‘USB 2.0 Camera’, classes=0x80000401, configuration=‘’, keyLayout=‘/system/usr/keylayout/Generic.kl’, keyCharacterMap=‘/system/usr/keychars/Generic.kcm’, builtinKeyboard=false, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
I/InputReader( 458): Device added: id=8, name=‘USB 2.0 Camera’, sources=0x00002103
W/ResourceType( 587): No package identifier when getting value for resource number 0x00000000
W/PackageManager( 587): Failure retrieving resources for com.serenegiant.usbcameratest0: Resource ID #0x0
I/ActivityStackSupervisor( 458): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.serenegiant.usbcameratest0/.MainActivity (has extras)} from uid 10032 on display 0
I/System.out( 458): com.serenegiant.usbcameratest0.MainActivityaddAppToken taskId:28
D/PhoneWindow( 458): DecorView - SCREEN_WEITH = 1920 - SCREE_HEIGHT = 1032
I/System.out( 458): action Title!
V/WindowManagerService( 458): Adding window Window{35068297 u0 Starting com.serenegiant.usbcameratest0} at 2 of 7 (after Window{1cdac2c3 u0 com.android.launcher3/com.android.launcher3.Launcher})
D/ViewRootImpl( 458): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=28 ty=3 fl=#1830118 pfl=0x12 fmt=-3 wanim=0x10303e5 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.serenegiant.usbcameratest0token=Token{14b31942 ActivityRecord{2c02338d u0 com.serenegiant.usbcameratest0/.MainActivity t28}}}
I/InputDispatcher( 458): Dropping event because there is no touchable window at (829, 711).
D/ViewRootImpl( 458): 1920<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=28 sim=#20 ty=3 fl=#1830118 pfl=0x12 fmt=-3 wanim=0x10303e5 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.serenegiant.usbcameratest0token=Token{14b31942 ActivityRecord{2c02338d u0 com.serenegiant.usbcameratest0/.MainActivity t28}}}
I/OpenGLRenderer( 458): Initialized EGL, version 1.4
W/gralloc ( 160): Debugmem The fd=36, in vmalloc !!! Ishwc=0
W/gralloc ( 160): Debugmem The fd=69, in vmalloc !!! Ishwc=0
W/gralloc ( 160): Debugmem The fd=76, in vmalloc !!! Ishwc=0
I/System.out( 1363): action Title!
I/InputDispatcher( 458): Dropping event because there is no touchable window at (829, 710).
V/MainActivity( 1363): onStart:
I/InputDispatcher( 458): Dropping event because there is no touchable window at (829, 709).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (830, 709).
V/WindowManagerService( 458): Adding window Window{22cc281c u0 com.serenegiant.usbcameratest0/com.serenegiant.usbcameratest0.MainActivity} at 2 of 8 (before Window{35068297 u0 Starting com.serenegiant.usbcameratest0})
D/ViewRootImpl( 1363): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=28 sim=#100 ty=1 fl=#1810100 wanim=0x10303e5 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.serenegiant.usbcameratest0token=android.os.BinderProxy@3b693253}
D/WindowManagerService( 458): Window{22cc281c u0 com.serenegiant.usbcameratest0/com.serenegiant.usbcameratest0.MainActivity} ==========setInputFocusLw ========== =======
D/ViewRootImpl( 1363): 1920<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=28 sim=#120 ty=1 fl=#1810100 fmt=-3 wanim=0x10303e5 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.serenegiant.usbcameratest0token=android.os.BinderProxy@3b693253}
W/gralloc ( 160): Debugmem The fd=113, in vmalloc !!! Ishwc=0
W/gralloc ( 160): Debugmem The fd=71, in vmalloc !!! Ishwc=0
V/WindowManagerService( 458): Adding window Window{37161fa u0 SurfaceView} at 2 of 9 (before Window{22cc281c u0 com.serenegiant.usbcameratest0/com.serenegiant.usbcameratest0.MainActivity})
V/MainActivity( 1363): surfaceCreated:
V/MainActivity( 1363): surfaceChanged:
I/ActivityManagerService( 458): Displayed com.serenegiant.usbcameratest0/.MainActivity: +385ms
D/ViewRootImpl( 458): onDetachedFromWindow ungister contentObserver
V/MainActivity( 1363): onAttach:
D/ViewRootImpl( 1363): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,64)(wrapxwrap)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#51 ty=2005 fl=#1000098 fmt=-3 wanim=0x1030004 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.serenegiant.usbcameratest0token=null}
D/ViewRootImpl( 1363): 222<<<<<< BACK FROM relayoutWM.LayoutParams{(0,64)(wrapxwrap)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#51 sim=#20 ty=2005 fl=#1000098 fmt=-3 wanim=0x1030004 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.serenegiant.usbcameratest0token=null}
W/gralloc ( 160): Debugmem The fd=72, in vmalloc !!! Ishwc=0
W/gralloc ( 160): Debugmem The fd=84, in vmalloc !!! Ishwc=0
V/WindowManagerService( 458): not Base app: Adding window Window{3de63652 u0 com.serenegiant.usbcameratest0/com.serenegiant.usbcameratest0.MainActivity} at 4 of 10
D/WindowManagerService( 458): Window{3de63652 u0 com.serenegiant.usbcameratest0/com.serenegiant.usbcameratest0.MainActivity} ==========setInputFocusLw ========== =======
D/ViewRootImpl( 1363): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(wrapxwrap)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#ffffffff sim=#120 ty=2 fl=#1860002 fmt=-2 wanim=0x10303e6 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.serenegiant.usbcameratest0token=android.os.BinderProxy@3b693253}
D/ViewRootImpl( 1363): 864<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(wrapxwrap)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#ffffffff sim=#120 ty=2 fl=#1860002 fmt=-2 wanim=0x10303e6 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.serenegiant.usbcameratest0token=android.os.BinderProxy@3b693253}
W/gralloc ( 160): Debugmem The fd=81, in vmalloc !!! Ishwc=0
W/gralloc ( 160): Debugmem The fd=92, in vmalloc !!! Ishwc=0
D/TaskPersister( 458): removeObsoleteFile: deleting file=27_task.xml
D/TaskPersister( 458): removeObsoleteFile: deleting file=27_task_thumbnail.png
V/WindowManagerService( 458): Adding window Window{1a189911 u0 PopupWindow:308c5216} at 5 of 12 (after Window{3de63652 u0 com.serenegiant.usbcameratest0/com.serenegiant.usbcameratest0.MainActivity})
D/WindowManagerService( 458): Window{1a189911 u0 PopupWindow:308c5216} ==========setInputFocusLw ========== =======
D/ViewRootImpl( 1363): onAttachToWindow register content observer attrs=WM.LayoutParams{(28,157)(796x54)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#10000033 sim=#1 ty=1000 fl=#41860200 fmt=-3 wanim=0x10302e1 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.serenegiant.usbcameratest0token=android.view.ViewRootImpl$W@3fc5d797}
D/ViewRootImpl( 1363): 796<<<<<< BACK FROM relayoutWM.LayoutParams{(28,157)(796x54)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#10000033 sim=#11 ty=1000 fl=#41860200 fmt=-3 wanim=0x10302e1 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.serenegiant.usbcameratest0token=android.view.ViewRootImpl$W@3fc5d797}
W/gralloc ( 160): Debugmem The fd=64, in vmalloc !!! Ishwc=0
W/gralloc ( 160): Debugmem The fd=100, in vmalloc !!! Ishwc=0
W/gralloc ( 160): Debugmem The fd=103, in vmalloc !!! Ishwc=0
W/ViewRootImpl( 1363): Dropping event due to root view being removed: MotionEvent { action=ACTION_HOVER_ENTER, id[0]=0, x[0]=112.58887, y[0]=33.304443, toolType[0]=TOOL_TYPE_MOUSE, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=248390, downTime=248270, deviceId=2, source=0x2002 }
W/ViewRootImpl( 1363): Dropping event due to root view being removed: MotionEvent { action=ACTION_HOVER_MOVE, id[0]=0, x[0]=112.58887, y[0]=33.304443, toolType[0]=TOOL_TYPE_MOUSE, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=248390, downTime=248270, deviceId=2, source=0x2002 }
I/USBMonitor( 1363): name=/dev/bus/usb/003/005,desc=41,busnum=3,devnum=5,rawDesc=[B@cf379a2
I/libusb/core( 1363): [1446core.c:2085:libusb_init2]:libusb v1.0.19.10903
I/libusb/usbfs( 1363): [1446
I/libusb/usbfs( 1363): [1446android_usbfs.c:512:op_init2]:call android_scan_devices
I/EventHub( 458): Removed device: path=/dev/input/event4 name=USB 2.0 Camera id=8 fd=169 classes=0x80000401
W/InputMethodManagerService( 458): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@3d149f6f attribute=null, token = android.os.BinderProxy@24112d8f
I/InputReader( 458): Device removed: id=8, name=‘USB 2.0 Camera’, sources=0x00002103
I/libUVCCamera( 1363): [1452
F/libc ( 1363): Fatal signal 11 (SIGSEGV), code 2, fault addr 0xa08bf000 in tid 1451 (BaseActivity)
I/DEBUG ( 163): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
I/DEBUG ( 163): Build fingerprint: ‘Android/rk3288_box/rk3288_box:5.1.1/LMY49F/shanyu05252132:eng/test-keys’
I/DEBUG ( 163): Revision: ‘0’
I/DEBUG ( 163): ABI: ‘arm’
I/DEBUG ( 163): pid: 1363, tid: 1451, name: BaseActivity >>> com.serenegiant.usbcameratest0 <<<
I/DEBUG ( 163): signal 11 (SIGSEGV), code 2 (SEGV_ACCERR), fault addr 0xa08bf000
I/DEBUG ( 163): r0 a08bf000 r1 9e864c0c r2 000001c8 r3 00000004
I/DEBUG ( 163): r4 b811cd78 r5 00000a0c r6 00000000 r7 00000000
I/DEBUG ( 163): r8 9e864408 r9 b8073f10 sl b80f23c8 fp 0000000f
I/DEBUG ( 163): ip 80000000 sp a0ababd8 lr a1b357a8 pc b6e0c9f0 cpsr 200f0010
I/DEBUG ( 163):
I/DEBUG ( 163): backtrace:
I/DEBUG ( 163): #00 pc 000129f0 /system/lib/libc.so (__memcpy_base+104)
I/DEBUG ( 163): #01 pc 000127a4 /data/app/com.serenegiant.usbcameratest0-1/lib/arm/libuvc.so
I/DEBUG ( 163): #02 pc 0000a138 /data/app/com.serenegiant.usbcameratest0-1/lib/arm/libusb100.so (usbi_handle_transfer_completion+184)
I/DEBUG ( 163): #03 pc 000113bc /data/app/com.serenegiant.usbcameratest0-1/lib/arm/libusb100.so
I/DEBUG ( 163): #04 pc 00009e84 /data/app/com.serenegiant.usbcameratest0-1/lib/arm/libusb100.so
I/DEBUG ( 163): #05 pc 0000a9d4 /data/app/com.serenegiant.usbcameratest0-1/lib/arm/libusb100.so (libusb_handle_events_timeout_completed+292)
I/DEBUG ( 163): #06 pc 0000ab60 /data/app/com.serenegiant.usbcameratest0-1/lib/arm/libusb100.so (libusb_handle_events+48)
I/DEBUG ( 163): #07 pc 000122fc /data/app/com.serenegiant.usbcameratest0-1/lib/arm/libuvc.so (_uvc_handle_events+64)
I/DEBUG ( 163): #08 pc 0001659b /system/lib/libc.so (__pthread_start(void*)+30)
I/DEBUG ( 163): #09 pc 000144c3 /system/lib/libc.so (__start_thread+6)
W/ActivityManagerService( 458): Force finishing activity 1 com.serenegiant.usbcameratest0/.MainActivity
I/DEBUG ( 163):
I/DEBUG ( 163): Tombstone written to: /data/tombstones/tombstone_08
I/BootReceiver( 458): Copying /data/tombstones/tombstone_08 to DropBox (SYSTEM_TOMBSTONE)
W/gralloc ( 160): Debugmem The fd=86, in vmalloc !!! Ishwc=0
E/JavaBinder( 458): !!! FAILED BINDER TRANSACTION !!!
W/ActivityManagerService( 458): Exception thrown during pause
W/ActivityManagerService( 458): android.os.TransactionTooLargeException
W/ActivityManagerService( 458): at android.os.BinderProxy.transactNative(Native Method)
W/ActivityManagerService( 458): at android.os.BinderProxy.transact(Binder.java:496)
W/ActivityManagerService( 458): at android.app.ApplicationThreadProxy.schedulePauseActivity(ApplicationThreadNative.java:708)
W/ActivityManagerService( 458): at com.android.server.am.ActivityStack.startPausingLocked(ActivityStack.java:913)
W/ActivityManagerService( 458): at com.android.server.am.ActivityStack.finishActivityLocked(ActivityStack.java:3092)
W/ActivityManagerService( 458): at com.android.server.am.ActivityStack.finishTopRunningActivityLocked(ActivityStack.java:2919)
W/ActivityManagerService( 458): at com.android.server.am.ActivityStackSupervisor.finishTopRunningActivityLocked(ActivityStackSupervisor.java:2567)
W/ActivityManagerService( 458): at com.android.server.am.ActivityManagerService.handleAppCrashLocked(ActivityManagerService.java:11764)
W/ActivityManagerService( 458): at com.android.server.am.ActivityManagerService.makeAppCrashingLocked(ActivityManagerService.java:11661)
W/ActivityManagerService( 458): at com.android.server.am.ActivityManagerService.crashApplication(ActivityManagerService.java:12347)
W/ActivityManagerService( 458): at com.android.server.am.ActivityManagerService.handleApplicationCrashInner(ActivityManagerService.java:11856)
W/ActivityManagerService( 458): at com.android.server.am.NativeCrashListener$NativeCrashReporter.run(NativeCrashListener.java:86)
E/lowmemorykiller( 156): Error writing /proc/1363/oom_score_adj; errno=22
W/InputMethodManagerService( 458): Got RemoteException sending setActive(false) notification to pid 1363 uid 10057
I/WindowState( 458): WIN DEATH: Window{37161fa u0 SurfaceView}
I/WindowState( 458): WIN DEATH: Window{22cc281c u0 com.serenegiant.usbcameratest0/com.serenegiant.usbcameratest0.MainActivity}
I/Zygote ( 171): Process 1363 exited due to signal (11)
I/ActivityManagerService( 458): Process com.serenegiant.usbcameratest0 (pid 1363) has died
I/System.out( 458): com.serenegiant.usbcameratest0.MainActivityaddAppToken taskId:29
V/WindowManagerService( 458): Adding window Window{3cc3e36b u0 Starting com.serenegiant.usbcameratest0} at 2 of 7 (after Window{1cdac2c3 u0 com.android.launcher3/com.android.launcher3.Launcher})
D/ViewRootImpl( 458): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=29 ty=3 fl=#1830118 pfl=0x12 fmt=-3 wanim=0x10303e5 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.serenegiant.usbcameratest0token=Token{16c07d26 ActivityRecord{2dc0e881 u0 com.serenegiant.usbcameratest0/.MainActivity t29}}}
I/art ( 1462): Late-enabling -Xcheck:jni
D/ViewRootImpl( 458): 1920<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=29 sim=#20 ty=3 fl=#1830118 pfl=0x12 fmt=-3 wanim=0x10303e5 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.serenegiant.usbcameratest0token=Token{16c07d26 ActivityRecord{2dc0e881 u0 com.serenegiant.usbcameratest0/.MainActivity t29}}}
I/ActivityManagerService( 458): Start proc 1462:com.serenegiant.usbcameratest0/u0a57 for activity com.serenegiant.usbcameratest0/.MainActivity
D/DisplayManager( 1462): getDisplayInfo: displayId=0, info=DisplayInfo{“Built-in Screen”, uniqueId “local:0”, app 1920 x 1032, real 1920 x 1080, largest app 1920 x 1847, smallest app 1080 x 1007, 120.00001 fps, supportedRefreshRates [120.00001], rotation 0, density 160 (159.89508 x 160.42105) dpi, layerStack 0, appVsyncOff 0, presDeadline 9333333, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/InputDispatcher( 458): Dropping event because there is no touchable window at (852, 687).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (854, 688).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (856, 687).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (859, 684).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (864, 679).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (869, 673).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (873, 668).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (876, 664).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (876, 660).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (875, 657).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (873, 653).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (869, 650).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (865, 647).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (860, 642).
D/PhoneWindow( 1462): DecorView - SCREEN_WEITH = 1920 - SCREE_HEIGHT = 1032
I/InputDispatcher( 458): Dropping event because there is no touchable window at (855, 637).
I/System.out( 1462): action Title!
I/InputDispatcher( 458): Dropping event because there is no touchable window at (849, 630).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (840, 623).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (831, 616).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (819, 608).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (806, 600).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (793, 594).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (778, 587).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (763, 580).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (747, 575).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (732, 570).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (717, 565).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (700, 560).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (687, 555).
V/MainActivity( 1462): onStart:
I/InputDispatcher( 458): Dropping event because there is no touchable window at (676, 549).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (665, 543).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (655, 536).
D/OpenGLRenderer( 1462): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
D/Atlas ( 1462): Validating map…
W/Atlas ( 1462): Pointer 0x0, not in getPreloadedDrawables?
I/InputDispatcher( 458): Dropping event because there is no touchable window at (645, 528).
V/WindowManagerService( 458): Adding window Window{2c205c3f u0 com.serenegiant.usbcameratest0/com.serenegiant.usbcameratest0.MainActivity} at 2 of 8 (before Window{3cc3e36b u0 Starting com.serenegiant.usbcameratest0})
I/InputDispatcher( 458): Dropping event because there is no touchable window at (636, 521).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (624, 513).
D/ViewRootImpl( 1462): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=29 sim=#100 ty=1 fl=#1810100 wanim=0x10303e5 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.serenegiant.usbcameratest0token=android.os.BinderProxy@3b7b1b0e}
I/InputDispatcher( 458): Dropping event because there is no touchable window at (612, 507).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (601, 501).
D/WindowManagerService( 458): Window{2c205c3f u0 com.serenegiant.usbcameratest0/com.serenegiant.usbcameratest0.MainActivity} ==========setInputFocusLw ========== =======
I/InputDispatcher( 458): Dropping event because there is no touchable window at (590, 497).
I/InputDispatcher( 458): Dropping event because there is no touchable window at (578, 494).
D/ViewRootImpl( 1462): 1920<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=29 sim=#120 ty=1 fl=#1810100 fmt=-3 wanim=0x10303e5 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.serenegiant.usbcameratest0token=android.os.BinderProxy@3b7b1b0e}
I/mali_so ( 1462): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 780; [Func] : base_context_deal_with_version_affairs_rk_ext;
I/mali_so ( 1462): arm_release_ver of this mali_so is ‘r6p0-02rel0’, rk_so_ver is ‘11@0’, built at ‘16:20:19’ for 3288w, on ‘Aug 1 2016’.
I/mali_so ( 1462): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 807; [Func] : base_context_deal_with_version_affairs_rk_ext;
I/mali_so ( 1462): mali_ver_property has been set to ‘r6p0-02rel0-13-11@0’, to return.
I/OpenGLRenderer( 1462): Initialized EGL, version 1.4
D/OpenGLRenderer( 1462): Enabling debug mode 0
W/gralloc ( 160): Debugmem The fd=65, in vmalloc !!! Ishwc=0
W/gralloc ( 160): Debugmem The fd=78, in vmalloc !!! Ishwc=0
W/gralloc ( 160): Debugmem The fd=89, in vmalloc !!! Ishwc=0
V/WindowManagerService( 458): Adding window Window{27dd255 u0 SurfaceView} at 2 of 9 (before Window{2c205c3f u0 com.serenegiant.usbcameratest0/com.serenegiant.usbcameratest0.MainActivity})
V/MainActivity( 1462): surfaceCreated:
V/MainActivity( 1462): surfaceChanged:
I/ActivityManagerService( 458): Displayed com.serenegiant.usbcameratest0/.MainActivity: +705ms
V/MainActivity( 1462): onAttach:
D/ViewRootImpl( 1462): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,64)(wrapxwrap)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#51 ty=2005 fl=#1000098 fmt=-3 wanim=0x1030004 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.serenegiant.usbcameratest0token=null}
D/ViewRootImpl( 1462): 222<<<<<< BACK FROM relayoutWM.LayoutParams{(0,64)(wrapxwrap)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#51 sim=#20 ty=2005 fl=#1000098 fmt=-3 wanim=0x1030004 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.serenegiant.usbcameratest0token=null}
V/WindowManagerService( 458): not Base app: Adding window Window{111356c2 u0 com.serenegiant.usbcameratest0/com.serenegiant.usbcameratest0.MainActivity} at 4 of 10
D/WindowManagerService( 458): Window{111356c2 u0 com.serenegiant.usbcameratest0/com.serenegiant.usbcameratest0.MainActivity} ==========setInputFocusLw ========== =======
D/ViewRootImpl( 1462): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(wrapxwrap)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#ffffffff sim=#120 ty=2 fl=#1860002 fmt=-2 wanim=0x10303e6 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.serenegiant.usbcameratest0token=android.os.BinderProxy@3b7b1b0e}
D/ViewRootImpl( 1462): 864<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(wrapxwrap)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#ffffffff sim=#120 ty=2 fl=#1860002 fmt=-2 wanim=0x10303e6 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.serenegiant.usbcameratest0token=android.os.BinderProxy@3b7b1b0e}
W/gralloc ( 160): Debugmem The fd=96, in vmalloc !!! Ishwc=0
D/TaskPersister( 458): removeObsoleteFile: deleting file=28_task.xml
D/TaskPersister( 458): removeObsoleteFile: deleting file=28_task_thumbnail.png
D/PopupWindow( 1462): findDropDownPosition mDrawingLocation(32,112) xoff=-4 yOff=-8 anchroHeight=53
D/PopupWindow( 1462): ----displayFrame=Rect(0, 25 - 1920, 1032)
D/PopupWindow( 1462): root.getWidth=864screenY=563 anchorHeight=53mPopupWidth=796
D/PopupWindow( 1462): final p.x=28 p.y=157
V/WindowManagerService( 458): Adding window Window{35aed32f u0 PopupWindow:14bfd9a0} at 5 of 11 (after Window{111356c2 u0 com.serenegiant.usbcameratest0/com.serenegiant.usbcameratest0.MainActivity})
D/WindowManagerService( 458): Window{35aed32f u0 PopupWindow:14bfd9a0} ==========setInputFocusLw ========== =======
D/ViewRootImpl( 1462): onAttachToWindow register content observer attrs=WM.LayoutParams{(28,157)(796x54)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#10000033 sim=#1 ty=1000 fl=#41860200 fmt=-3 wanim=0x10302e1 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.serenegiant.usbcameratest0token=android.view.ViewRootImpl$W@3bbe9959}
D/ViewRootImpl( 1462): 796<<<<<< BACK FROM relayoutWM.LayoutParams{(28,157)(796x54)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#10000033 sim=#11 ty=1000 fl=#41860200 fmt=-3 wanim=0x10302e1 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.serenegiant.usbcameratest0token=android.view.ViewRootImpl$W@3bbe9959}
D/ViewRootImpl( 1462): onDetachedFromWindow ungister contentObserver
W/gralloc ( 160): Debugmem The fd=40, in vmalloc !!! Ishwc=0
W/gralloc ( 160): Debugmem The fd=102, in vmalloc !!! Ishwc=0
W/InputEventReceiver( 1462): Attempted to finish an input event but the input event receiver has already been disposed.
W/ViewRootImpl( 1462): Dropping event due to root view being removed: MotionEvent { action=ACTION_HOVER_ENTER, id[0]=0, x[0]=313.35864, y[0]=34.51544, toolType[0]=TOOL_TYPE_MOUSE, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=257296, downTime=257168, deviceId=2, source=0x2002 }
W/ViewRootImpl( 1462): Dropping event due to root view being removed: MotionEvent { action=ACTION_HOVER_MOVE, id[0]=0, x[0]=314.35864, y[0]=34.51544, toolType[0]=TOOL_TYPE_MOUSE, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=1, eventTime=257312, downTime=257168, deviceId=2, source=0x2002 }
W/InputMethodManagerService( 458): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@2c471f35 attribute=null, token = android.os.BinderProxy@1570e05e
D/UsbDeviceConnectionJNI( 1462): close
I/USBMonitor( 1462): name=/dev/bus/usb/003/005,desc=38,busnum=3,devnum=5,rawDesc=[B@92f292a
V/MainActivity( 1462): onConnect:
W/linker ( 1462): libjpeg-turbo1500.so: unused DT entry: type 0x6ffffffe arg 0x368c
W/linker ( 1462): libjpeg-turbo1500.so: unused DT entry: type 0x6fffffff arg 0x1
W/linker ( 1462): libusb100.so: unused DT entry: type 0x6ffffffe arg 0x2ecc
W/linker ( 1462): libusb100.so: unused DT entry: type 0x6fffffff arg 0x1
W/linker ( 1462): libuvc.so: unused DT entry: type 0x6ffffffe arg 0x3c48
W/linker ( 1462): libuvc.so: unused DT entry: type 0x6fffffff arg 0x1
W/linker ( 1462): libUVCCamera.so: unused DT entry: type 0x6ffffffe arg 0x59b4
W/linker ( 1462): libUVCCamera.so: unused DT entry: type 0x6fffffff arg 0x1
I/libusb/core( 1462): [1480core.c:2085:libusb_init2]:libusb v1.0.19.10903
I/libusb/usbfs( 1462): [1480
I/libusb/usbfs( 1462): [1480android_usbfs.c:512:op_init2]:call android_scan_devices
I/MainActivity( 1462): supportedSize:{“formats”:[{“index”:1,“type”:6,“default”:1,“size”:[“1920x1080”,“1280x720”,“1024x768”,“640x480”,“800x600”,“1280x1024”,“320x240”]},{“index”:2,“type”:4,“default”:1,“size”:[“1920x1080”,“1280x720”,“1024x768”,“640x480”,“800x600”,“1280x1024”,“320x240”]}]}
I/libUVCCamera( 1462): [1503
W/libUVCCamera( 1462): [1504UVCPreview.cpp:119:get_frame]:allocate new frame
W/libUVCCamera( 1462): [1503
W/libUVCCamera( 1462): [1504*UVCPreview.cpp:119:get_frame]:allocate new frame
V/MainActivity( 1462): onDisconnect:
I/EventHub( 458): New device: id=9, fd=201, path=‘/dev/input/event4’, name=‘USB 2.0 Camera’, classes=0x80000401, configuration=‘’, keyLayout=‘/system/usr/keylayout/Generic.kl’, keyCharacterMap=‘/system/usr/keychars/Generic.kcm’, builtinKeyboard=false, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
I/InputReader( 458): Device added: id=9, name=‘USB 2.0 Camera’, sources=0x00002103
W/EventHub …
logcat
换uvc确定是不是camera的问题
KrisFei博主,我使用的aio-rk3288j主板,想用两个ov5640的USB摄像头,按照你博客里面修改,现在系统里面有video0和video1.但是自带相机没切换相机(使用360相机就可以切换)请问有没有办法修改到自带相机可以切换呢?还有一个问题就是我的相机最大拍照像素是20481536,就是不能拍25921944(不是死机要不然就是照片是绿色的)请问有解决方法。辛苦您帮我解答一下。谢谢。
楼主,这个问题有没有解决?我现在和你遇到同样的问题,求指教
