双屏显示,副屏显示不正常怎么处理
双屏显示,开机logo,主屏和副屏都显示正常,进入开机动画后,主屏显示正常,副屏有亮屏,但显示不正常。交换主副屏,发现现在跟着副屏走。
现在如图所示:
打印信息如下:
DDR Version 1.00 20160530
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10-gc28aaca-dirty (May 04 2017 - 04:08:32)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 20
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2017-05-04#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x00697490)
ramdisk @ 0x05bf0000 (0x00138ec8)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561b7b0 … OK
[ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (xxl@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #38 SMP PREEMPT Thu May 25 08:30:11 EDT 2017 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288 [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(drm): base(0) size(0) align(0) [ 0.000000] ion heap(cma): base(0) size(28000000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 640 MiB at 58000000 [ 0.000000] ion_reserve: cma reserved base 58000000 size 671088640 [ 0.000000] cma: CMA: reserved 16 MiB at 1f000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1eee000 s13376 r8192 d15296 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264 [ 0.000000] Kernel command line: vmalloc=496M console=ttyFIQ0 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),0x00200000@0x0039C000(userdata),0x00020000@0x0059C000(radical_update),-@0x005BC000(user) storagemedia=emmc loader.timestamp=2017-05-04_04:08:32 [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] allocated 4194304 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 1387700k/1387700k available, 709452k reserved, 917504K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0b878a0 (11775 kB) [ 0.000000] .init : 0xc0b88000 - 0xc0be3440 ( 366 kB) [ 0.000000] .data : 0xc0be4000 - 0xc0d73d40 (1600 kB) [ 0.000000] .bss : 0xc0d73d40 - 0xc0e949bc (1156 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! [ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div [ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0 [ 0.000000] rkclk_init_clks: cnt_parent = 7 [ 0.000000] rkclk_init_clks: cnt_rate = 28 [ 0.000000] rk3288 set GPLL BW 20 for HDMI! [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 3 [ 0.000000] channel:0, lkg:8 [ 0.000000] target-temp:80 [ 0.000000] channel:2, lkg:0 [ 0.000000] channel:0, lkg:8 [ 0.000000] channel:1, lkg:8 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 0.352084] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.352100] pid_max: default: 32768 minimum: 301 [ 0.352212] Security Framework initialized [ 0.352228] SELinux: Initializing. [ 0.352300] Mount-cache hash table entries: 512 [ 0.352942] Initializing cgroup subsys debug [ 0.352957] Initializing cgroup subsys memory [ 0.352983] Initializing cgroup subsys freezer [ 0.353012] CPU: Testing write buffer coherency: ok [ 0.353323] /cpus/cpu@0 missing clock-frequency property [ 0.353336] /cpus/cpu@1 missing clock-frequency property [ 0.353346] /cpus/cpu@2 missing clock-frequency property [ 0.353355] /cpus/cpu@3 missing clock-frequency property [ 0.353402] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500 [ 0.353452] Setting up static identity map for 0xc08592b8 - 0xc0859310 [ 0.356423] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x1709 (version 3.1) [ 0.430247] CPU1: Booted secondary processor [ 0.430280] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501 [ 0.449924] CPU2: Booted secondary processor [ 0.449947] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502 [ 0.469631] CPU3: Booted secondary processor [ 0.469656] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503 [ 0.469757] Brought up 4 CPUs [ 0.469785] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.469794] CPU: All CPU(s) started in SVC mode. [ 0.470525] devtmpfs: initialized [ 0.474829] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0 [ 0.475912] pinctrl core: initialized pinctrl subsystem [ 0.476162] regulator-dummy: no parameters [ 0.500470] NET: Registered protocol family 16 [ 0.502236] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.502560] ion_snapshot: 0x1ea90000 map to 0xe0907000 and copy to 0xc0e6fecc (version 0.1) [ 0.502822] Registered FIQ tty driver [ 0.504107] console [ttyFIQ0] enabled [ 0.504351] Registered fiq debugger ttyFIQ0 [ 0.504926] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff [ 0.504951] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f [ 0.504970] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f [ 0.504990] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b [ 0.505094] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff [ 0.505165] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff [ 0.505229] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff [ 0.505295] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff [ 0.505359] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff [ 0.505424] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff [ 0.505488] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff [ 0.505554] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff [ 0.505628] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff [ 0.505696] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3 [ 0.505712] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f [ 0.505727] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf [ 0.505740] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f [ 0.506353] rockchip_interrupts_register:bank_num=7 [ 0.508264] of_get_gpio_init_config:gpio[0] = 6, value = 0 [ 0.508323] rockchip_pinctrl_probe:init ok [ 0.515042] rk_iommu ff900800.iep_mmu: (iep) Enter [ 0.515131] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.515147] rk_iommu ff900800.iep_mmu: (iep) Initialized [ 0.515322] rk_iommu ff950800.vip_mmu: (vip) Enter [ 0.515394] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.515410] rk_iommu ff950800.vip_mmu: (vip) Initialized [ 0.515569] rk_iommu ff930300.vopb_mmu: (vopb) Enter [ 0.515645] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.515661] rk_iommu ff930300.vopb_mmu: (vopb) Initialized [ 0.515832] rk_iommu ff940300.vopl_mmu: (vopl) Enter [ 0.515905] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.515921] rk_iommu ff940300.vopl_mmu: (vopl) Initialized [ 0.516091] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter [ 0.516169] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.516185] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized [ 0.516354] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter [ 0.516427] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.516443] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized [ 0.516611] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter [ 0.516691] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.516706] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized [ 0.518364] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.518381] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.519008] rk3368_init_rockchip_pmu_ops: could not find pmu dt node [ 0.519036] DDR DEBUG: version 1.00 20150126 [ 0.519066] DDR DEBUG: Channel a: [ 0.519077] DDR DEBUG: DDR3 Device [ 0.519092] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.519104] DDR DEBUG: Channel b: [ 0.519112] DDR DEBUG: DDR3 Device [ 0.519126] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.519137] DDR DEBUG: addr=0xd7d000 [ 0.519148] DDR DEBUG: stride=9, size=256, halfcap=40000000 [ 0.519160] DDR DEBUG: socAddr[0]=0xd7d000, socAddr[1]=0xd7d100 [ 0.519171] DDR DEBUG: chAddr[0]=0xd7d000, chAddr[1]=0xd7d000 [ 0.519185] DDR DEBUG: dtar[0]=0x501af000, dtar[1]=0x501af000 [ 0.519242] DDR DEBUG: init success!!! freq=200MHz [ 0.519252] DDR DEBUG: Channel a: [ 0.519266] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.519282] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.519298] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.519314] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.519328] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.519340] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.519351] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.519360] DDR DEBUG: Channel b: [ 0.519373] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.519388] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.519404] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.519420] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.519434] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.519445] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.519456] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.543875] bio: create slab at 0 [ 0.544410] Rockchip hdmi driver version 2.0 . [ 0.545585] SCSI subsystem initialized [ 0.545746] usbcore: registered new interface driver usbfs [ 0.545793] usbcore: registered new interface driver hub [ 0.545888] usbcore: registered new device driver usb [ 0.548636] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter [ 0.549302] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter [ 0.549757] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter [ 0.550208] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter [ 0.550332] media: Linux media interface: v0.10 [ 0.550377] Linux video capture interface: v2.00 [ 0.550496] pps_core: LinuxPPS API ver. 1 registered [ 0.550509] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.550533] PTP clock support registered [ 0.550589] i2c-core: driver [bq24296] using legacy suspend method [ 0.550601] i2c-core: driver [bq24296] using legacy resume method [ 0.551273] ion_drm_heap_create: 0@0 [ 0.551405] Rockchip ion module is successfully loaded (v1.1) [ 0.551577] Advanced Linux Sound Architecture Driver Initialized. [ 0.551977] Bluetooth: Core ver 2.16 [ 0.552016] NET: Registered protocol family 31 [ 0.552028] Bluetooth: HCI device and connection manager initialized [ 0.552046] Bluetooth: HCI socket layer initialized [ 0.552062] Bluetooth: L2CAP socket layer initialized [ 0.552092] Bluetooth: SCO socket layer initialized [ 0.552346] cfg80211: Calling CRDA to update world regulatory domain [ 0.553429] act8846_i2c_probe,line=881 [ 0.554453] act8846_parse_dt,line=744 [ 0.554872] act8846_i2c_probe: act8846_pmic_hold=1 [ 0.556966] act_dcdc1: 1200 mV [ 0.559945] vccio: 3300 mV [ 0.561827] vdd_logic: 700 <--> 1500 mV at 1125 mV [ 0.564779] act_dcdc4: 2000 mV [ 0.566039] vccio_sd: 1800 <--> 3300 mV at 3300 mV [ 0.568356] act_ldo2: 1000 mV [ 0.570685] act_ldo3: 3300 mV [ 0.573008] act_ldo4: 3300 mV [ 0.575321] act_ldo5: 3300 mV [ 0.577625] act_ldo6: 1000 mV [ 0.579958] vcc_18: 1800 mV [ 0.582270] act_ldo8: 1800 mV [ 0.587113] vdd_arm: 712 <--> 1500 mV at 900 mV [ 0.591817] vdd_gpu: 712 <--> 1500 mV at 900 mV [ 0.592551] rk808_i2c_probe,line=1355 [ 0.593888] The device is not rk808 -11 [ 0.593977] rk808: probe of 0-001b failed with error -11 [ 0.594050] i2c-core: driver [rk816] using legacy suspend method [ 0.594063] i2c-core: driver [rk816] using legacy resume method [ 0.594107] i2c-core: driver [rk818] using legacy suspend method [ 0.594119] i2c-core: driver [rk818] using legacy resume method [ 0.595796] Switching to clocksource arch_sys_counter [ 0.619619] rga: Module initialized. [ 0.620342] rga2 ff920000.rga: rga ion client create success! [ 0.620545] rga: Driver loaded succesfully [ 0.620784] rk-fb rockchip-fb: rk fb ion client create success! [ 0.620799] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 0.621062] prmry screen timing parse success [ 0.621126] prmry screen power ctrl parse success [ 0.621195] extend screen timing parse success [ 0.621235] rk-screen rk_screen.9: request lcd_en gpio fail:-16 [ 0.621265] extend screen power ctrl parse success [ 0.621278] rk-screen rk_screen.9: rockchip screen probe success [ 0.621439] Use LVDS as prmry screen [ 0.621525] rk32-lvds rk32-lvds: rk32 lvds driver probe success [ 0.621886] Use EDP as extend screen [ 0.622016] rk32-edp rk32-edp: failed to get reset [ 0.622032] rk32-edp rk32-edp: failed to get reset [ 0.622754] rk32-edp rk32-edp: rk32 edp driver probe success [ 0.622939] rk32-dsi [ 0.623057] dsi->host.irq =51 [ 0.623077] mipi dsi chip is not found, read id:ffffffff, but 3133302a is correct [ 0.623093] rk32-mipi ff960000.mipi: rk mipi_dsi probe fail! [ 0.623108] rk32-mipi ff960000.mipi: rockchip mipi_dsi v1.1 2014-06-17 [ 0.623140] rk32-mipi: probe of ff960000.mipi failed with error -1 [ 0.623875] graphics fb0: rockchip framebuffer registerd:fb0 [ 0.624200] graphics fb1: rockchip framebuffer registerd:fb1 [ 0.624369] graphics fb2: rockchip framebuffer registerd:fb2 [ 0.624541] graphics fb3: rockchip framebuffer registerd:fb3 [ 0.644472] @@@@@@lt8911_probe() [ 0.644525] LT8911 1-0029: edp lt8911 probe ok [ 0.647417] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 0.743947] rk3288-lcdc lcdc0: lcdc0: dclk:72000000>>fps:57 [ 0.743975] rk3288-lcdc lcdc0: wakeup from standby! [ 0.762423] alloc_buffer:ion_phy_addr=0x58000000 [ 0.769228] fb0:phy:58000000>>vir:e0991000>>len:0xd00000 [ 0.769657] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled [ 0.770067] graphics fb4: rockchip framebuffer registerd:fb4 [ 0.770393] graphics fb5: rockchip framebuffer registerd:fb5 [ 0.770566] graphics fb6: rockchip framebuffer registerd:fb6 [ 0.770741] graphics fb7: rockchip framebuffer registerd:fb7 [ 0.790654] Error: Driver 'LT8911' is already registered, aborting... [ 0.889171] rk3288-lcdc lcdc1: lcdc1: dclk:72000000>>fps:57 [ 0.889386] rk32-edp rk32-edp: edp pll locked [ 0.890022] rk32-edp rk32-edp: max link rate:2.70Gps max number of lanes:1 [ 0.893007] rk32-edp rk32-edp: link training success. [ 0.948254] rk3288-lcdc lcdc1: wakeup from standby! [ 0.948270] fb4:phy:58000000>>vir:e0991000>>len:0xd00000 [ 0.948293] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled [ 0.949165] rockchip_set_mux:warning ignore bank num 15 [ 0.949311] rockchip_set_mux:warning ignore bank num 15 [ 0.949431] rockchip_set_mux:warning ignore bank num 15 [ 0.949549] rockchip_set_mux:warning ignore bank num 15 [ 0.949672] rockchip_set_mux:warning ignore bank num 15 [ 0.949789] rockchip_set_mux:warning ignore bank num 15 [ 0.950367] rockchip_set_mux:warning ignore bank num 15 [ 0.950528] rockchip_set_mux:warning ignore bank num 15 [ 0.951100] rockchip_set_mux:warning ignore bank num 15 [ 0.951248] rockchip_set_mux:warning ignore bank num 15 [ 0.951799] rockchip_set_mux:warning ignore bank num 15 [ 0.951946] rockchip_set_mux:warning ignore bank num 15 [ 0.952508] rockchip_set_mux:warning ignore bank num 15 [ 0.952668] rockchip_set_mux:warning ignore bank num 15 [ 0.954132] NET: Registered protocol family 2 [ 0.954830] TCP established hash table entries: 4096 (order: 3, 32768 bytes) [ 0.954914] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 0.954990] TCP: Hash tables configured (established 4096 bind 4096) [ 0.955055] TCP: reno registered [ 0.955072] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.955099] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.955296] NET: Registered protocol family 1 [ 0.956051] Unpacking initramfs... [ 1.023433] Freeing initrd memory: 1248K (c5bf0000 - c5d28000) [ 1.024131] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available [ 1.024694] vcodec_service: probe device ff9a0000.vpu_service [ 1.024898] vcodec_service: No reset resource define [ 1.025099] vcodec_service: ff9a0000.vpu_service: power on [ 1.025197] vcodec_service: probe device ff9a0000.vpu_service [ 1.025214] vcodec_service: checking hw id 4831 [ 1.025661] vcodec_service: ff9a0000.vpu_service: power off... [ 1.025705] vcodec_service: done [ 1.025715] vcodec_service: init success [ 1.025777] vcodec_service: probe device ff9c0000.hevc_service [ 1.026110] vcodec_service: ff9c0000.hevc_service: power on [ 1.026173] vcodec_service: probe device ff9c0000.hevc_service [ 1.026190] vcodec_service: checking hw id 6867 [ 1.026468] vcodec_service: ff9c0000.hevc_service: power off... [ 1.026512] vcodec_service: done [ 1.026522] vcodec_service: init success [ 1.026662] rknandbase v1.0 2014-03-31 [ 1.026798] rknand: probe of ff400000.nandc failed with error -1 [ 1.026917] rknand_driver:ret = 0 [ 1.028149] audit: initializing netlink socket (disabled) [ 1.028197] type=2000 audit(0.670:1): initialized [ 1.029124] bounce pool size: 64 pages [ 1.033667] fuse init (API version 7.22) [ 1.034062] msgmni has been set to 952 [ 1.035980] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 1.036001] io scheduler noop registered [ 1.036013] io scheduler deadline registered [ 1.036105] io scheduler cfq registered (default) [ 1.037901] IEP Driver loaded succesfully [ 1.037997] Module initialized. [ 1.038997] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208 [ 1.039018] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10 [ 1.040427] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208 [ 1.040448] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 1.040731] pwm-voltage-regulator pwm_regulator.24: unable to request PWM, trying legacy API [ 1.040751] pwm-voltage-regulator pwm_regulator.24: unable to request legacy PWM [ 1.040763] pwm_regulator_probe:error [ 1.040787] pwm-voltage-regulator: probe of pwm_regulator.24 failed with error -16 [ 1.040985] rk_serial.c v1.8 2014-03-04 [ 1.041219] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0 [ 1.041396] serial ff180000.serial: membase e16b2000 [ 1.041557] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1 [ 1.041725] serial ff190000.serial: membase e16c4000 [ 1.041877] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3 [ 1.042044] serial ff1b0000.serial: membase e16c6000 [ 1.042194] ff1c0000.serial: ttyS4 at MMIO 0xff1c0000 (irq = 91) is a rk29_serial.4 [ 1.042357] serial ff1c0000.serial: membase e16ce000 [ 1.045118] loop: module loaded [ 1.045503] zram: Created 1 device(s) ... [ 1.045580] i2c-core: driver [mpu6050B1] using legacy suspend method [ 1.045593] i2c-core: driver [mpu6050B1] using legacy resume method [ 1.045610] mpu_init: Probe name mpu6050B1 [ 1.045766] ak8963_mod_init: Probe name ak8963_mod [ 1.046471] SCSI Media Changer driver v0.25 [ 1.046790] tun: Universal TUN/TAP device driver, 1.6 [ 1.046804] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 1.046934] vmac_init. [ 1.047520] stmmac_probe_config_dt: Can not read property: pmu_regulator. [ 1.047537] stmmac_probe_config_dt: clock input/output? (input). [ 1.047551] stmmac_probe_config_dt: TX delay(0x30). [ 1.047563] stmmac_probe_config_dt: RX delay(0x20). [ 1.047618] stmmac_probe_config_dt: is rockchip,rk3288-gmac [ 1.047629] stmmc_pltfr_init: [ 1.047638] stmmc_pltfr_init: ERROR: Get power-gpio failed. [ 1.047695] stmmc_pltfr_init: init for RMII [ 1.048150] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 1.048161] Normal descriptors [ 1.048170] Ring mode enabled [ 1.048180] DMA HW capability register supported [ 1.048192] RX Checksum Offload Engine supported (type 2) [ 1.048202] TX Checksum insertion supported [ 1.048212] Wake-Up On Lan supported [ 1.048252] Enable RX Mitigation via HW Watchdog Timer [ 1.048756] PPP generic driver version 2.4.2 [ 1.048920] PPP BSD Compression module registered [ 1.048934] PPP Deflate Compression module registered [ 1.048956] PPP MPPE Compression module registered [ 1.048970] NET: Registered protocol family 24 [ 1.049006] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 1.049020] CSLIP: code copyright 1989 Regents of the University of California. [ 1.049033] Rockchip WiFi SYS interface (V1.00) ... [ 1.049067] esp_mem_init enter date May 20 2017 00:25:41 [ 1.049079] esp_mem_init VERSION [V2.5] [ 1.049122] esp_mem_init complete [ 1.049210] usbcore: registered new interface driver catc [ 1.049250] usbcore: registered new interface driver kaweth [ 1.049264] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 1.049302] usbcore: registered new interface driver pegasus [ 1.049339] usbcore: registered new interface driver rtl8150 [ 1.049381] usbcore: registered new interface driver r8152 [ 1.049394] hso: drivers/net/usb/hso.c: Option Wireless [ 1.049465] usbcore: registered new interface driver hso [ 1.049508] usbcore: registered new interface driver asix [ 1.049546] usbcore: registered new interface driver ax88179_178a [ 1.049586] usbcore: registered new interface driver cdc_ether [ 1.049623] usbcore: registered new interface driver cdc_eem [ 1.049665] usbcore: registered new interface driver dm9601 [ 1.049703] usbcore: registered new interface driver dm9620 [ 1.049750] usbcore: registered new interface driver smsc75xx [ 1.049796] usbcore: registered new interface driver smsc95xx [ 1.049834] usbcore: registered new interface driver gl620a [ 1.049872] usbcore: registered new interface driver net1080 [ 1.049918] usbcore: registered new interface driver plusb [ 1.049959] usbcore: registered new interface driver rndis_host [ 1.049998] usbcore: registered new interface driver cdc_subset [ 1.050034] usbcore: registered new interface driver zaurus [ 1.050075] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 1.050139] usbcore: registered new interface driver simcom_wwan [ 1.050178] usbcore: registered new interface driver int51x1 [ 1.050217] usbcore: registered new interface driver kalmia [ 1.050263] usbcore: registered new interface driver ipheth [ 1.050308] usbcore: registered new interface driver sierra_net [ 1.050348] usbcore: registered new interface driver cx82310_eth [ 1.050394] usbcore: registered new interface driver cdc_ncm [ 1.050434] usbcore: registered new interface driver qmi_wwan [ 1.050473] usbcore: registered new interface driver cdc_mbim [ 1.050486] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.052957] EHCI: ehci_rk_probe e1700000 e1700010 [ 1.052976] rockchip_ehci_host ff500000.usb: EHCI Host Controller [ 1.053007] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1 [ 1.053339] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000 [ 1.068196] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00 [ 1.068281] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.068298] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.068313] usb usb1: Product: EHCI Host Controller [ 1.068325] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd [ 1.068338] usb usb1: SerialNumber: ff500000.usb [ 1.068782] hub 1-0:1.0: USB hub found [ 1.068809] hub 1-0:1.0: 1 port detected [ 1.068976] EHCI: ehci_rk_probe ok [ 1.069085] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.069301] usbcore: registered new interface driver cdc_acm [ 1.069315] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.069368] usbcore: registered new interface driver usblp [ 1.069411] usbcore: registered new interface driver cdc_wdm [ 1.069475] usbcore: registered new interface driver usb-storage [ 1.069514] usbcore: registered new interface driver ums-alauda [ 1.069552] usbcore: registered new interface driver ums-cypress [ 1.069591] usbcore: registered new interface driver ums-datafab [ 1.069635] usbcore: registered new interface driver ums_eneub6250 [ 1.069685] usbcore: registered new interface driver ums-freecom [ 1.069726] usbcore: registered new interface driver ums-isd200 [ 1.069766] usbcore: registered new interface driver ums-jumpshot [ 1.069804] usbcore: registered new interface driver ums-karma [ 1.069842] usbcore: registered new interface driver ums-onetouch [ 1.069881] usbcore: registered new interface driver ums-sddr09 [ 1.069920] usbcore: registered new interface driver ums-sddr55 [ 1.069982] usbcore: registered new interface driver ums-usbat [ 1.070081] usbcore: registered new interface driver usbserial [ 1.070124] usbcore: registered new interface driver usbserial_generic [ 1.070158] usbserial: USB Serial support registered for generic [ 1.070199] usbcore: registered new interface driver option [ 1.070229] usbserial: USB Serial support registered for GSM modem (1-port) [ 1.070306] usbcore: registered new interface driver trancevibrator [ 1.070319] usb20_otg: version 3.10a 21-DEC-2012 [ 1.070779] e1780040 [ 1.070793] Core Release: 3.10a [ 1.070806] Setting default values for core params [ 1.070950] Using Buffer DMA mode [ 1.070963] Periodic Transfer Interrupt Enhancement - disabled [ 1.070974] Multiprocessor Interrupt Enhancement - disabled [ 1.070987] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 1.070997] ^^^^^^^^^^^^^^^^^Device Mode [ 1.071011] Dedicated Tx FIFOs mode [ 1.071032] pcd_init otg_dev = ddf03cc0 [ 1.071191] usb20_otg ff580000.usb: DWC OTG Controller [ 1.071219] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2 [ 1.071252] usb20_otg ff580000.usb: irq 55, io mem 0x00000000 [ 1.071312] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.071330] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.071344] usb usb2: Product: DWC OTG Controller [ 1.071357] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 1.071370] usb usb2: SerialNumber: ff580000.usb [ 1.071792] hub 2-0:1.0: USB hub found [ 1.071819] hub 2-0:1.0: 1 port detected [ 1.072126] usb20_host: version 3.10a 21-DEC-2012 [ 1.074654] e1800040 [ 1.074668] Core Release: 3.10a [ 1.074679] Setting default values for core params [ 1.074804] Using Buffer DMA mode [ 1.074816] Periodic Transfer Interrupt Enhancement - disabled [ 1.074827] Multiprocessor Interrupt Enhancement - disabled [ 1.074839] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 1.074850] ^^^^^^^^^^^^^^^^^^Host Mode [ 1.074877] usb20_host ff540000.usb: DWC OTG Controller [ 1.074904] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3 [ 1.074934] usb20_host ff540000.usb: irq 57, io mem 0x00000000 [ 1.075025] Init: Power Port (0) [ 1.075083] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.075100] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.075116] usb usb3: Product: DWC OTG Controller [ 1.075129] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 1.075141] usb usb3: SerialNumber: ff540000.usb [ 1.075556] hub 3-0:1.0: USB hub found [ 1.075579] hub 3-0:1.0: 1 port detected [ 1.076300] usbcore: registered new interface driver xpad [ 1.076360] usbcore: registered new interface driver usb_acecad [ 1.076408] usbcore: registered new interface driver aiptek [ 1.076454] usbcore: registered new interface driver gtco [ 1.076501] usbcore: registered new interface driver hanwang [ 1.076548] usbcore: registered new interface driver kbtab [ 1.076605] usbcore: registered new interface driver wacom [ 1.076619] ILITEK line = 3281: Enter [ 1.076741] ILITEK line = 2937: Enter ilitek_i2c_probe +++++++++ client->addr = 0x41++++++ [ 1.076793] ILITEK line = 2639: 2639,ilitek_request_io_port,ilitek_request_io_port gpio_free(i2c.reset_gpio); reset_gpio = 229 i2c.irq_gpio = 230 [ 1.076810] ------------[ cut here ]------------ [ 1.076836] WARNING: at drivers/gpio/gpiolib.c:1519 gpiod_free+0xe0/0xfc() [ 1.076847] Modules linked in: [ 1.076866] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.0 #38 [ 1.076905] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14) [ 1.076931] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68) [ 1.076954] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_null+0x18/0x1c) [ 1.076976] [] (warn_slowpath_null+0x18/0x1c) from [] (gpiod_free+0xe0/0xfc) [ 1.077004] [] (gpiod_free+0xe0/0xfc) from [] (ilitek_request_io_port+0xe4/0x1e8) [ 1.077030] [] (ilitek_request_io_port+0xe4/0x1e8) from [] (ilitek_i2c_probe+0xe4/0x3d4) [ 1.077056] [] (ilitek_i2c_probe+0xe4/0x3d4) from [] (i2c_device_probe+0xa8/0xd4) [ 1.077081] [] (i2c_device_probe+0xa8/0xd4) from [] (really_probe+0xa8/0x20c) [ 1.077102] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48) [ 1.077121] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84) [ 1.077144] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90) [ 1.077164] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c) [ 1.077182] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138) [ 1.077204] [] (driver_register+0x9c/0x138) from [] (i2c_register_driver+0x40/0xac) [ 1.077224] [] (i2c_register_driver+0x40/0xac) from [] (ilitek_init+0x34/0x78) [ 1.077246] [] (ilitek_init+0x34/0x78) from [] (do_one_initcall+0x34/0xc8) [ 1.077272] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0) [ 1.077295] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130) [ 1.077317] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4) [ 1.077342] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c) [ 1.077377] ---[ end trace b1e54f4a0269983a ]--- [ 1.077464] ILITEK line = 2983: ilitek i2c.irq_gpio = 230, i2c.client->irq = 193 [ 1.077479] ILITEK line = 223: Enter 10 ilitek_reset [ 1.166665] dwc_otg_hcd_suspend, usb device mode [ 1.304296] ILITEK line = 350: ilitek_i2c_transfer err [ 1.353942] ILITEK line = 350: ilitek_i2c_transfer err [ 1.412980] ILITEK line = 350: ilitek_i2c_transfer err [ 1.472019] ILITEK line = 350: ilitek_i2c_transfer err [ 1.530660] ILITEK line = 453: ilitek_i2c_write_and_read, i2c write error, ret = -11 [ 1.551281] ILITEK line = 350: ilitek_i2c_transfer err [ 1.610320] ILITEK line = 350: ilitek_i2c_transfer err [ 1.669367] ILITEK line = 350: ilitek_i2c_transfer err [ 1.728402] ILITEK line = 350: ilitek_i2c_transfer err [ 1.786509] ILITEK line = 462: ilitek_i2c_write_and_read, i2c read error, ret = -11 [ 1.786528] ILITEK line = 2444: ilitek_i2c_read_tp_info, MCU KERNEL version:255.255.255.255.255 [ 1.786943] ILITEK line = 350: ilitek_i2c_transfer err [ 1.845940] ILITEK line = 350: ilitek_i2c_transfer err [ 1.904978] ILITEK line = 350: ilitek_i2c_transfer err [ 1.964025] ILITEK line = 350: ilitek_i2c_transfer err [ 2.022664] ILITEK line = 453: ilitek_i2c_write_and_read, i2c write error, ret = -11 [ 2.043145] ILITEK line = 350: ilitek_i2c_transfer err [ 2.102189] ILITEK line = 350: ilitek_i2c_transfer err [ 2.161224] ILITEK line = 350: ilitek_i2c_transfer err [ 2.220270] ILITEK line = 350: ilitek_i2c_transfer err [ 2.278504] ILITEK line = 462: ilitek_i2c_write_and_read, i2c read error, ret = -11 [ 2.278519] ILITEK line = 3035: ilitek read tp info fail free gpio [ 2.278548] ilitek_i2c: probe of 4-0041 failed with error -1 [ 2.278966] sensor_register_slave:mma8452,id=17 [ 2.278982] sensor_register_slave:gs_mc3230,id=23 [ 2.278992] gsensor_init [ 2.279003] sensor_register_slave:mpu6880_acc,id=24 [ 2.279014] sensor_register_slave:mpu6500_acc,id=25 [ 2.279025] sensor_register_slave:cm3217,id=48 [ 2.279037] sensor_register_slave:cm3218,id=49 [ 2.283968] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0 [ 2.284019] i2c /dev entries driver [ 2.284640] IR NEC protocol handler initialized [ 2.284655] IR RC5(x) protocol handler initialized [ 2.284665] IR RC6 protocol handler initialized [ 2.284675] IR JVC protocol handler initialized [ 2.284685] IR Sony protocol handler initialized [ 2.284695] IR RC5 (streamzap) protocol handler initialized [ 2.284705] IR SANYO protocol handler initialized [ 2.284715] IR MCE Keyboard/mouse protocol handler initialized [ 2.284875] usbcore: registered new interface driver uvcvideo [ 2.284887] USB Video Class driver (1.1.1) [ 2.284900] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0 [ 2.285924] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288 [ 2.285924] [ 2.286006] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0) [ 2.286158] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe16d8000 size: 0x4000) [ 2.286806] D1:camsys_platform_probe(1394): ff910000.isp memory: [ 2.286826] D1:camsys_platform_probe(1404): Register memory (phy: 0xff910000 vir: 0xe1740000 size: 0x10000) [ 2.286843] D1:camsys_platform_probe(1399): I2c memory (phy: 0x1defb000 vir: 0xddefb000 size: 0x1000) [ 2.286858] D1:camsys_init_ext_fsh_module(20): init external flash module [ 2.286870] D1:camsys_platform_probe(1419): Probe ff910000.isp device success [ 2.287219] not find test_power_init dev node [ 2.287278] i2c-core: driver [bq27320] using legacy suspend method [ 2.287289] i2c-core: driver [bq27320] using legacy resume method [ 2.287606] rockchip_temp_probe,line=362 [ 2.337557] tsadc ff280000.tsadc: initialized [ 2.337930] device-mapper: uevent: version 1.0.3 [ 2.338197] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email]dm-devel@redhat.com[/email] [ 2.338482] Bluetooth: HCI UART driver ver 2.2 [ 2.338499] Bluetooth: HCI H4 protocol initialized [ 2.338511] Bluetooth: HCILL protocol initialized [ 2.338522] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21 [ 2.338534] rtk_btusb: Register usb char device interface for BT driver [ 2.338717] usbcore: registered new interface driver rtk_btusb [ 2.339350] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller than default(576000), use default, just enable dvfs [ 2.343533] cpufreq version 1.0, suspend freq 1200 MHz [ 2.343731] cpuidle: using governor ladder [ 2.343746] cpuidle: using governor menu [ 2.343784] Synopsys Designware Multimedia Card Interface Driver [ 2.343797] MHSC version = Ver 2.00 2015-06-10 [ 2.344106] dw cru_regsbase addr 0x1d8. [ 2.344119] dw cru_reset_offset val 3. [ 2.344135] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a [ 2.344179] dwmmc_rockchip ff0f0h00.@rs3mm8: $ led to get hpclk_mmc [ 2.344483] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller. [ 2.344656] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0] [ 2.344782] 1358..dw_mci_set_ios: no card. [mmc0] [ 2.357242] 1358..dw_mci_set_ios: no card. [mmc0] [ 2.376959] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0] [ 2.378057] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo [ 2.378076] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized [ 2.378391] dw cru_regsbase addr 0x1d8. [ 2.378404] dw cru_reset_offset val 0. [ 2.378419] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a [ 2.378458] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc [ 2.380430] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller. [ 2.380551] dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc1] [ 2.380971] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found! [ 2.381042] 1358..dw_mci_set_ios: no card. [mmc1] [ 2.396598] 1358..dw_mci_set_ios: no card. [mmc1] [ 2.409065] mmc0: BKOPS_EN bit is not set [ 2.410949] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0] [ 2.413236] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0) [ 2.413261] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0] [ 2.413282] [mmc0] tuning regsbase addr 0x218. [ 2.414222] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-282 (26 len) [ 2.414236] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-282 (26 len) [ 2.414247] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 147 [ 2.414293] mmc0: new HS200 MMC card at address 0001 [ 2.414574] mmcblk0: mmc0:0001 AWPD3R 14.5 GiB [ 2.414871] rkpart: partition size too small (0) [ 2.414891] uboot: 0x000400000 -- 0x000800000 (4 MB) [ 2.414900] misc: 0x000800000 -- 0x000c00000 (4 MB) [ 2.414910] resource: 0x000c00000 -- 0x001c00000 (16 MB) [ 2.414919] kernel: 0x001c00000 -- 0x002c00000 (16 MB) [ 2.414928] boot: 0x002c00000 -- 0x004c00000 (32 MB) [ 2.414937] recovery: 0x004c00000 -- 0x006c00000 (32 MB) [ 2.414945] backup: 0x006c00000 -- 0x00a000000 (52 MB) [ 2.414954] cache: 0x00a000000 -- 0x012000000 (128 MB) [ 2.414962] kpanic: 0x012000000 -- 0x012400000 (4 MB) [ 2.414971] system: 0x012400000 -- 0x072400000 (1536 MB) [ 2.414979] metadata: 0x072400000 -- 0x073400000 (16 MB) [ 2.414988] baseparamer: 0x073400000 -- 0x073800000 (4 MB) [ 2.414997] userdata: 0x073800000 -- 0x0b3800000 (1024 MB) [ 2.415005] radical_update: 0x0b3800000 -- 0x0b7800000 (64 MB) [ 2.415014] user: 0x0b7800000 -- 0x3a3a00000 (11970 MB) [ 2.415043] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15[ 2.416350] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo [ 2.416366] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc1] [ 2.416686] dw cru_regsbase addr 0x1d8. [ 2.416695] dw cru_reset_offset val 1. [ 2.416706] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a [ 2.416741] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc [ 2.416957] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller. [ 2.417088] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2] [ 2.417356] 1358..dw_mci_set_ios: no card. [mmc2] [ 2.435960] 1358..dw_mci_set_ios: no card. [mmc2] [ 2.455640] 1358..dw_mci_set_ios: no card. [mmc2] [ 2.455657] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo [ 2.455670] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized [ 2.455965] hidraw: raw HID events driver (C) Jiri Kosina [ 2.457438] usbcore: registered new interface driver usbhid [ 2.457449] usbhid: USB HID core driver [ 2.457571] ashmem: initialized [ 2.457681] logger: created 256K log 'log_main' [ 2.457785] logger: created 256K log 'log_events' [ 2.457885] logger: created 256K log 'log_radio' [ 2.457979] logger: created 256K log 'log_system' [ 2.459259] input: rk29-keypad as /devices/ff100000.adc/key.32/input/input0 [ 2.460162] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010 [ 2.460178] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22 [ 2.460189] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl [ 2.460201] ES8323 2-0010: Error applying setting, reverse things back [ 2.460654] es8323_i2c_probe:register ISR (irq=196) [ 2.461328] rockchip-spdif ff8b0000.rockchip-spdif: spdif ready. [ 2.461644] es8323_probe [ 2.701618] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63) [ 2.701640] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc1] [ 3.046013] EHCI: rk_ehci_hcd_enable, disable host controller [ 3.046021] dwc_otg_hcd_enable, enable host controller [ 3.149375] Using Buffer DMA mode [ 3.149383] Periodic Transfer Interrupt Enhancement - disabled [ 3.149389] Multiprocessor Interrupt Enhancement - disabled [ 3.149395] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 3.149401] ^^^^^^^^^^^^^^^^^^Host Mode [ 3.193687] Init: Power Port (0) [ 3.193728] ff540000.usb resume, HPRT0:0x21401 [ 3.226643] rockchip-es8323 rockchip-es8323.29: ES8323 HiFi <-> ff890000.rockchip-i2s mapping ok [ 3.229027] rockchip-hdmi-i2s rockchip-hdmi-i2s.27: rk-hdmi-i2s-hifi <-> ff890000.rockchip-i2s mapping ok [ 3.229378] u32 classifier [ 3.229384] Actions configured [ 3.229394] Netfilter messages via NETLINK v0.30. [ 3.229446] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 3.229712] ctnetlink v0.93: registering with nfnetlink. [ 3.229772] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 3.229780] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 3.229973] xt_time: kernel timezone is -0000 [ 3.230133] ip_tables: (C) 2000-2006 Netfilter Core Team [ 3.230241] arp_tables: (C) 2002 David S. Miller [ 3.230273] TCP: cubic registered [ 3.230279] Initializing XFRM netlink socket [ 3.230450] NET: Registered protocol family 10 [ 3.230857] mip6: Mobile IPv6 [ 3.230879] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 3.230987] sit: IPv6 over IPv4 tunneling driver [ 3.231261] NET: Registered protocol family 17 [ 3.231281] NET: Registered protocol family 15 [ 3.231325] Bridge firewalling registered [ 3.231335] Ebtables v2.0 registered [ 3.231482] Bluetooth: RFCOMM TTY layer initialized [ 3.231502] Bluetooth: RFCOMM socket layer initialized [ 3.231510] Bluetooth: RFCOMM ver 1.11 [ 3.231515] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 3.231521] Bluetooth: BNEP filters: protocol multicast [ 3.231529] Bluetooth: BNEP socket layer initialized [ 3.231535] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 3.231544] Bluetooth: HIDP socket layer initialized [ 3.231566] l2tp_core: L2TP core driver, V2.0 [ 3.231578] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 3.231585] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 3.231774] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 3.231783] [WLAN_RFKILL]: can't find rockchip,grf property [ 3.231789] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6212 [ 3.231797] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 3.231805] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control. [ 3.231812] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 3.231832] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0. [ 3.231848] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0. [ 3.231855] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 3.231882] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 3.3V [ 3.231891] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 3.231927] [BT_RFKILL]: Enter rfkill_rk_init [ 3.232038] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147. [ 3.232055] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157. [ 3.232067] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154. [ 3.232079] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159. [ 3.232130] [BT_RFKILL]: Request irq for bt wakeup host [ 3.232225] [BT_RFKILL]: ** disable irq [ 3.232286] [BT_RFKILL]: ap6335 device registered. [ 3.232861] rk3288_init_suspend [ 3.232873] rk3288_suspend_init enter [ 3.233115] rk3288_suspend_init: pm_ctrbits =200007 [ 3.233144] gpio_get_dts_info suspend:4 [ 3.233150] gpio_get_dts_info resume:4 [ 3.233156] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 3.233178] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 3.233299] clks_gating_suspend_init:clkgt info ok [ 3.233385] Registering SWP/SWPB emulation handler [ 3.233689] ddrfreq: verion 1.2 20140526 [ 3.233699] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz [ 3.233706] ddrfreq: auto-freq=0 [ 3.233711] ddrfreq: auto-freq-table[0] 240MHz [ 3.233717] ddrfreq: auto-freq-table[1] 324MHz [ 3.233722] ddrfreq: auto-freq-table[2] 456MHz [ 3.233728] ddrfreq: auto-freq-table[3] 528MHz [ 3.238041] regulator-dummy: disabling [ 3.238110] ======================================================= [ 3.238117] ==== Launching Wi-Fi driver! (Powered by Rockchip) ==== [ 3.238122] ======================================================= [ 3.238127] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init. [ 3.238167] dhd_module_init: in [ 3.238173] ======== bcm_wlan_set_plat_data ======== [ 3.238179] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter [ 3.238196] host_oob_irq: 198 [ 3.238200] host_oob_irq_flags=4 [ 3.238204] dhd_wifi_platform_load: Enter [ 3.238217] Power-up adapter 'DHD generic adapter' [ 3.238221] pcd_pullup, is_on 0 [ 3.238238] wifi_platform_set_power = 1 [ 3.238243] ======== PULL WL_REG_ON HIGH! ======== [ 3.238248] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ 3.238250] file system registered [ 3.238257] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1 [ 3.238263] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled. [ 3.238696] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 3.238704] android_usb gadget: Number of LUNs=2 [ 3.238710] lun0: LUN: removable file: (no medium) [ 3.238716] lun1: LUN: removable file: (no medium) [ 3.238838] android_usb gadget: android_usb ready [ 3.238903] sensor_init: Probe name sensors [ 3.238917] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01 [ 3.239439] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:27:44 UTC (1293884864) [ 3.243722] rockchip_headset_probe() Can not read property headset_gpio [ 3.243734] rockchip_headset: probe of rockchip_headset.31 failed with error -2 [ 3.244133] usbcore: registered new interface driver snd-usb-audio [ 3.244140] ALSA device list: [ 3.244145] #0: RK_ES8323 [ 3.244149] #1: RK-HDMI-I2S [ 3.244378] Freeing unused kernel memory: 364K (c0b88000 - c0be3000) [ 3.331440] Indeed it is in host mode hprt0 = 00021501 [ 3.341235] [WLAN_RFKILL]: wifi turn on power. 156 [ 3.383311] type=1403 audit(1293884864.640:2): policy loaded auid=4294967295 ses=4294967295 [ 3.403511] init: could not import file 'init.box.samba.rc' from '/init.rk30board.rc' [ 3.405045] init: invalid gid 'trace' [ 3.483907] init: /dev/hw_random not found [ 3.483964] keychord: using input dev rk29-keypad for fevent [ 3.488408] init: /dev/hw_random not found [ 3.489267] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system [ 3.490018] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs: [ 3.492498] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option [ 3.496381] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro [ 3.496457] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0 [ 3.497202] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system [ 3.502032] e2fsck: e2fsck 1.42.9 (28-Dec-2013) [ 3.502069] e2fsck: system: clean, 1865/81600 files, 109156/393216 blocks [ 3.505763] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc [ 3.505820] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0 [ 3.508523] usb 3-1: new high-speed USB device number 2 using usb20_host [ 3.508588] Indeed it is in host mode hprt0 = 00001101 [ 3.512861] EXT4-fs (mmcblk0p8): recovery complete [ 3.513273] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard [ 3.513329] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0 [ 3.513686] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option [ 3.517224] EXT4-fs (mmcblk0p11): recovery complete [ 3.517233] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro [ 3.517276] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0 [ 3.517951] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata [ 3.522087] e2fsck: e2fsck 1.42.9 (28-Dec-2013) [ 3.522115] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks [ 3.525957] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard [ 3.526011] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0 [ 3.526043] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata [ 3.526838] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory [ 3.526869] fsck.f2fs: fsck.f2fs terminated by exit(255) [ 3.527064] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1 [ 3.527344] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option [ 3.547870] wifi_platform_bus_enumerate device present 1 [ 3.547879] ======== Card detection to detect SDIO card! ======== [ 3.547885] mmc2:mmc host rescan start! [ 3.596530] EXT4-fs (mmcblk0p13): recovery complete [ 3.596903] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro [ 3.596977] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0 [ 3.598604] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata [ 3.603332] e2fsck: e2fsck 1.42.9 (28-Dec-2013) [ 3.603363] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 3018/65536 files, 39031/262144 blocks [ 3.607384] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic [ 3.607437] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0 [ 3.607450] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs [ 3.621107] arm_release_ver of this mali_ko is 'r6p0-02rel0', rk_ko_ver is '13', built at '09:15:10', on 'Oct 22 2015'. [ 3.621175] mali ffa30000.gpu: Continuing without Mali clock control [ 3.621208] mali pd enabled [ 3.621215] clk enabled [ 3.621224] MALI_DVFS_STEP = 4, div_dvfs = 10 [ 3.621231] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70 [ 3.621237] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80 [ 3.621243] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90 [ 3.621249] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100 [ 3.621331] turn on mali power [ 3.621339] kbase_platform_rk_init,register_reboot_notifier [ 3.621378] hrtimer: interrupt took 10791 ns [ 3.621458] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1 [ 3.622117] mali ffa30000.gpu: Probed as mali0 [ 3.623099] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ' should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ' [ 3.623687] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ' should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ' [ 3.624260] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ' should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ' [ 3.625150] zram0: detected capacity change from 0 to 533413888 [ 3.671822] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS [ 3.703510] EXT4-fs (mmcblk0p13): Unrecognized mount option "background_gc=on" or missing value [ 3.705555] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101 [ 3.705568] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 3.705575] usb 3-1: Product: USB 2.0 Hub [ 3.705934] hub 3-1:1.0: USB hub found [ 3.705992] hub 3-1:1.0: 4 ports detected [ 3.713632] bat_cap: oldcap path is /sys/devices/ff100000.adc [ 3.713674] bat_cap: oldcap_path no exist [ 3.713817] binder: 148:148 transaction failed 29189, size 0-0 [ 3.714229] init: Warning! Service displayd needs a SELinux domain defined; please fix! [ 3.717462] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}' [ 3.717480] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial' [ 3.717642] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead [ 3.718031] rtk_btusb: btchr_open: BT usb char device is opening [ 3.718040] rtk_btusb: btchr_open: Failed to get hci dev[NULL] [ 3.718053] rtk_btusb: btchr_open: BT usb char device is opening [ 3.718058] rtk_btusb: btchr_open: Failed to get hci dev[NULL] [ 3.718074] rtk_btusb: btchr_open: BT usb char device is opening [ 3.718080] rtk_btusb: btchr_open: Failed to get hci dev[NULL] [ 3.718091] rtk_btusb: btchr_open: BT usb char device is opening [ 3.718097] rtk_btusb: btchr_open: Failed to get hci dev[NULL] [ 3.764358] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2] [ 3.790594] logd.auditd: start [ 3.799118] mmc2: queuing unknown CIS tuple 0x80 (2 bytes) [ 3.800648] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) [ 3.802163] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) [ 3.804990] mmc2: queuing unknown CIS tuple 0x80 (7 bytes) [ 3.808353] mmc2: queuing unknown CIS tuple 0x81 (9 bytes) [ 3.812886] init: cannot find '/system/bin/debuggerd64', disabling 'debuggerd64' [ 3.814244] init: cannot find '/system/bin/install-recovery.sh', disabling 'flash_recovery' [ 3.814629] init: cannot find '/system/bin/bplus_helper', disabling 'bplus_helper' [ 3.814795] init: Warning! Service drmservice needs a SELinux domain defined; please fix! [ 3.814999] init: cannot find '/system/bin/akmd', disabling 'akmd' [ 3.816087] android_usb: already disabled [ 3.823439] ff540000.usb suspend, HPRT0:0x1485 [ 3.826461] read descriptors [ 3.826476] read strings [ 3.826501] pcd_pullup, is_on 1 [ 3.909125] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [ 3.909150] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2] [ 3.909208] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2] [ 3.910444] mmc2: new high speed SDIO card at address 0001 [ 3.926935] bcmsdh_register: register client driver [ 3.927036] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter [ 3.927095] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter [ 3.927102] bus num (host idx)=2, slot num (rca)=1 [ 3.927108] found adapter info 'DHD generic adapter' [ 3.927317] F1 signature read @0x18000000=0x1541a9a6 [ 3.928644] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4 [ 3.929106] DHD: dongle ram size is set to 524288(orig 524288) at 0x0 [ 3.929172] wifi_platform_get_mac_addr [ 3.929178] ======== bcm_wlan_get_mac_address ======== [ 3.929183] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter. [ 3.929191] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00] [ 3.929197] [WLAN_RFKILL]: This mac address is not valid, ignored... [ 3.929205] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=1 [ 3.929237] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt [ 3.929512] wl_create_event_handler(): thread:wl_event_handler:bc started [ 3.929517] tsk Enter, tsk = 0xdd70149c [ 3.929646] dhd_attach(): thread:dhd_watchdog_thread:bd started [ 3.929687] dhd_attach(): thread:dhd_dpc:be started [ 3.929706] dhd_dpc_thread: set dpc_cpucore 0 from config.txt [ 3.929734] dhd_attach(): thread:dhd_rxf:bf started [ 3.929744] dhd_deferred_work_init: work queue initialized [ 3.929859] dhdsdio_probe_init: set use_rxchain 0 from config.txt [ 3.935504] Dongle Host Driver, version 1.201.59.5 (r506368) [ 3.935504] Compiled in drivers/net/wireless/bcmdhd on May 20 2017 at 00:25:54 [ 3.936236] Register interface [wlan0] MAC: cc:b8:a8:25:5b:04 [ 3.936236] [ 3.936250] dhd_prot_ioctl : bus is down. we have nothing to do [ 3.936283] bcmsdh_oob_intr_unregister: Enter [ 3.936289] bcmsdh_oob_intr_unregister: irq is not registered [ 3.936298] dhd_txglom_enable: enable 0 [ 3.936302] dhd_bus_devreset: WLAN OFF DONE [ 3.936334] wifi_platform_set_power = 0 [ 3.936339] ======== PULL WL_REG_ON LOW! ======== [ 3.936345] [WLAN_RFKILL]: rockchip_wifi_power: 0 [ 4.039884] [WLAN_RFKILL]: wifi shut off power. [ 4.039899] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0 [ 4.039905] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled. [ 4.039977] dhd_module_init: Exit err=0 [ 4.698468] healthd: No charger supplies found [ 4.698483] healthd: No battery devices found [ 4.717269] rk3288-lcdc lcdc0: blank mode:0 [ 6.240720] warning: `system_server' uses 32-bit capabilities (legacy support in use) [ 7.510408] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.510432] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.510441] D1:camsys_open(739): camsys_marvin(ddef5110) is opened! [ 7.510537] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 7.510553] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 7.510584] rockchip_gpio_request:GPIO7-13 [ 7.510595] rockchip_gpio_set:GPIO7-13 level = 1 [ 7.510602] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 7.510612] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x5 [ 7.510622] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xb824,result=0xb824 [ 7.510631] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 7.510652] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8825) register success [ 7.515702] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 7.515714] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 7.515822] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 7.515855] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 7.516927] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 7.517989] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.519049] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 7.521094] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.521155] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 7.521165] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.521177] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 7.522268] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 7.522299] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 7.524363] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 7.524378] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 7.524388] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.524396] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.524403] D1:camsys_release(763): camsys_marvin(ddef5110) is closed [ 7.529711] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.529724] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.529733] D1:camsys_open(739): camsys_marvin(ddef5110) is opened! [ 7.529826] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 7.529840] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 7.529878] rockchip_gpio_set:GPIO7-13 level = 1 [ 7.529884] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 7.529895] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x5 [ 7.529904] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xb824,result=0xb824 [ 7.529913] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 7.529928] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8858) register success [ 7.534963] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 7.534973] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 7.535079] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 7.535106] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 7.536174] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 7.537230] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.538294] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 7.540339] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.540350] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.540411] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 7.540421] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.540434] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 7.541532] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 7.541560] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 7.543616] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 7.543633] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 7.543644] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.543652] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.543660] D1:camsys_release(763): camsys_marvin(ddef5110) is closed [ 7.548831] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.548845] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.548853] D1:camsys_open(739): camsys_marvin(ddef5110) is opened! [ 7.548949] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 7.548965] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 7.549002] rockchip_gpio_set:GPIO7-13 level = 1 [ 7.549009] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 7.549019] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x5 [ 7.549029] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xb824,result=0xb824 [ 7.549037] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 7.549052] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success [ 7.554090] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 7.554101] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 7.554206] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 7.554234] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 7.555302] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 7.556360] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.557425] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 7.559470] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.559480] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.559541] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 7.559551] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.559564] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 7.560645] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 7.560673] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 7.562732] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 7.562749] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 7.562761] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.562769] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.562797] D1:camsys_release(763): camsys_marvin(ddef5110) is closed [ 7.566556] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.566569] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.566579] D1:camsys_open(739): camsys_marvin(ddef5110) is opened! [ 7.566679] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 7.566694] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 7.566732] rockchip_gpio_set:GPIO7-13 level = 1 [ 7.566738] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 7.566748] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x5 [ 7.566757] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xb824,result=0xb824 [ 7.566766] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 7.566781] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV5648) register success [ 7.571822] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 7.571832] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 7.571937] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 7.571965] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 7.573032] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 7.574095] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.575171] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 7.577222] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.577233] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.577300] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 7.577310] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.577323] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 7.578411] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 7.578441] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 7.580496] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 7.580511] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 7.580521] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.580529] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.580537] D1:camsys_release(763): camsys_marvin(ddef5110) is closed [ 7.584651] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.584664] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.584672] D1:camsys_open(739): camsys_marvin(ddef5110) is opened! [ 7.584768] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 1) for dev_id 0x1000000 success! [ 7.584781] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x1000000 success! [ 7.584790] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit [ 7.584887] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV2659) register success [ 7.589924] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 7.589934] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 7.590039] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 7.590064] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 7.591140] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 7.592203] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.593267] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 0 [ 7.595313] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.595374] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 1 [ 7.595385] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.595397] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 7.596495] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 7.596526] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 7.598586] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success [ 7.598604] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 7.598616] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.598625] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.598633] D1:camsys_release(763): camsys_marvin(ddef5110) is closed [ 7.603706] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.603718] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 7.603727] D1:camsys_open(739): camsys_marvin(ddef5110) is opened! [ 7.603817] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 7.603831] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 7.603841] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default [ 7.603866] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: TC358749XBG) register success [ 7.608905] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 7.608915] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 7.609021] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 7.609048] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on [ 7.610115] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 7.611171] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.612232] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 7.614282] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.614293] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 7.614350] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 7.614360] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 7.614372] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 7.615456] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 7.615480] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 7.617533] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 7.617548] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 7.617559] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.617566] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 7.617574] D1:camsys_release(763): camsys_marvin(ddef5110) is closed [ 8.959892] [otg id chg] last id -1 current id 1 [ 8.959919] PortPower off [ 8.959927] rk_battery_charger_detect_cb , battery_charger_detect 6 [ 9.059352] Using Buffer DMA mode [ 9.059372] Periodic Transfer Interrupt Enhancement - disabled [ 9.059379] Multiprocessor Interrupt Enhancement - disabled [ 9.059386] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 9.059392] ^^^^^^^^^^^^^^^^^Device Mode [ 9.296392] healthd: battery none chg= [ 9.477685] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj: [ 9.477706] lowmemorykiller: oom_adj 0 => oom_score_adj 0 [ 9.477712] lowmemorykiller: oom_adj 1 => oom_score_adj 58 [ 9.477717] lowmemorykiller: oom_adj 2 => oom_score_adj 117 [ 9.477723] lowmemorykiller: oom_adj 3 => oom_score_adj 176 [ 9.477728] lowmemorykiller: oom_adj 9 => oom_score_adj 529 [ 9.477733] lowmemorykiller: oom_adj 15 => oom_score_adj 1000 [ 9.550287] ***************vbus detect***************** [ 9.552476] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 9.729501] Using Buffer DMA mode [ 9.729517] Periodic Transfer Interrupt Enhancement - disabled [ 9.729523] Multiprocessor Interrupt Enhancement - disabled [ 9.729529] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 9.729534] ^^^^^^^^^^^^^^^^^Device Mode [ 9.729573] *******************soft connect!!!******************* [ 9.793994] acc_open [ 9.794023] acc_release [ 9.845225] USB RESET [ 9.937280] android_work: sent uevent USB_STATE=CONNECTED [ 9.940760] USB RESET [ 10.068412] android_usb gadget: high-speed config #1: android [ 10.068536] android_work: sent uevent USB_STATE=CONFIGURED [ 10.874984] phy_power_on: enable = 1 [ 10.914390] Read the Ethernet MAC address from IDB:00:00:00:00:00:00 [ 10.914429] eth0: device MAC address 42:d2:fa:67:18:da [ 10.916519] libphy: stmmac: probed [ 10.916531] eth0: PHY ID 001cc816 at 0 IRQ 192 (stmmac-0:00) active [ 10.916539] eth0: PHY ID 001cc816 at 1 IRQ 192 (stmmac-0:01) active [ 11.239328] dwc_otg_hcd_resume, usb device mode [ 11.341373] ff540000.usb resume, HPRT0:0x1485 [ 11.345389] dwc_otg_hcd_suspend, usb device mode [ 11.390547] ff540000.usb suspend, HPRT0:0x1485 [ 11.592537] FAT-fs (mmcblk0p15): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 11.613241] init: no such service 'fuse_internal_sd' [ 12.052285] pm policy 0 -> 1 [ 13.587407] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.587435] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.587446] D1:camsys_open(739): camsys_marvin(ddef5110) is opened! [ 13.594629] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 13.594649] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 13.594689] rockchip_gpio_set:GPIO7-13 level = 1 [ 13.594696] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 13.594708] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x5 [ 13.594719] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xb824,result=0xb824 [ 13.594730] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 13.594754] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8825) register success [ 13.599817] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 13.599830] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 13.599937] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 13.599969] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 13.601037] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 13.602092] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.603151] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 13.605199] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.605263] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 13.605273] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.605285] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 13.606364] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 13.606387] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 13.608433] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 13.608449] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 13.608460] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.608468] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.608476] D1:camsys_release(763): camsys_marvin(ddef5110) is closed [ 13.609232] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.609242] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.609251] D1:camsys_open(739): camsys_marvin(ddef5110) is opened! [ 13.609335] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 13.609350] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 13.609386] rockchip_gpio_set:GPIO7-13 level = 1 [ 13.609392] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 13.609402] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x5 [ 13.609412] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xb824,result=0xb824 [ 13.609421] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 13.609436] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8858) register success [ 13.614472] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 13.614483] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 13.614589] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 13.614614] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 13.615678] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 13.616738] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.617798] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 13.619837] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.619846] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.619902] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 13.619912] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.619925] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 13.621007] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 13.621031] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 13.623079] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 13.623091] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 13.623101] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.623109] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.623116] D1:camsys_release(763): camsys_marvin(ddef5110) is closed [ 13.623699] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.623709] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.623718] D1:camsys_open(739): camsys_marvin(ddef5110) is opened! [ 13.623796] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 13.623810] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 13.623845] rockchip_gpio_set:GPIO7-13 level = 1 [ 13.623852] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 13.623861] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x5 [ 13.623871] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xb824,result=0xb824 [ 13.623879] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 13.623892] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success [ 13.628934] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 13.628944] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 13.629050] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 13.629072] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 13.630135] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 13.631190] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.632249] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 13.634289] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.634298] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.634349] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 13.634359] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.634371] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 13.635446] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 13.635468] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 13.637514] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 13.637526] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 13.637535] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.637543] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.637552] D1:camsys_release(763): camsys_marvin(ddef5110) is closed [ 13.638077] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.638087] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.638095] D1:camsys_open(739): camsys_marvin(ddef5110) is opened! [ 13.638170] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 13.638184] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 13.638214] rockchip_gpio_set:GPIO7-13 level = 1 [ 13.638221] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 13.638229] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x5 [ 13.638239] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xb824,result=0xb824 [ 13.638248] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 13.638260] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV5648) register success [ 13.643303] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 13.643316] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 13.643422] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 13.643449] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 13.644519] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 13.645576] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.646633] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 13.648669] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.648677] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.648733] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 13.648741] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.648751] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 13.649829] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 13.649850] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 13.651893] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 13.651905] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 13.651914] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.651920] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.651926] D1:camsys_release(763): camsys_marvin(ddef5110) is closed [ 13.652450] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.652459] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.652466] D1:camsys_open(739): camsys_marvin(ddef5110) is opened! [ 13.652533] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 1) for dev_id 0x1000000 success! [ 13.652544] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x1000000 success! [ 13.652552] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit [ 13.652639] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV2659) register success [ 13.657662] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 13.657670] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 13.657774] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 13.657794] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 13.658850] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 13.659899] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.660952] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 0 [ 13.662985] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.663026] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 1 [ 13.663034] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.663045] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 13.664113] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 13.664132] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 13.666173] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success [ 13.666184] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 13.666192] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.666198] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.666204] D1:camsys_release(763): camsys_marvin(ddef5110) is closed [ 13.666829] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.666837] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.666844] D1:camsys_open(739): camsys_marvin(ddef5110) is opened! [ 13.666903] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 13.666914] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 13.666921] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default [ 13.666935] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: TC358749XBG) register success [ 13.671964] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 13.671975] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 13.672079] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 13.672102] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on [ 13.673162] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 13.674214] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.675268] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 13.677303] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.677311] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.677362] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 13.677370] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.677380] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 13.678453] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 13.678472] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 13.680515] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 13.680527] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 13.680536] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.680542] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.680548] D1:camsys_release(763): camsys_marvin(ddef5110) is closed [ 13.689738] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.689751] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.689757] D1:camsys_open(739): camsys_marvin(ddef5110) is opened! [ 13.689829] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 13.689840] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 13.689873] rockchip_gpio_set:GPIO7-13 level = 1 [ 13.689878] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 13.689887] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x5 [ 13.689896] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xb824,result=0xb824 [ 13.689903] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 13.689922] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8825) register success [ 13.694952] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 13.694960] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 13.695064] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 13.695089] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 13.696146] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 13.697195] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.698246] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 13.700282] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.700327] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 13.700335] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.700345] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 13.701413] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 13.701431] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 13.703472] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 13.703484] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 13.703491] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.703497] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.703504] D1:camsys_release(763): camsys_marvin(ddef5110) is closed [ 13.704061] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.704069] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.704076] D1:camsys_open(739): camsys_marvin(ddef5110) is opened! [ 13.704139] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 13.704150] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 13.704178] rockchip_gpio_set:GPIO7-13 level = 1 [ 13.704184] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 13.704191] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x5 [ 13.704198] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xb824,result=0xb824 [ 13.704205] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 13.704216] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8858) register success [ 13.709237] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 13.709245] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 13.709350] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 13.709367] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 13.710432] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 13.711484] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.712537] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 13.714573] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.714580] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.714623] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 13.714631] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.714641] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 13.715714] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 13.715733] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 13.717774] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 13.717785] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 13.717793] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.717799] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.717805] D1:camsys_release(763): camsys_marvin(ddef5110) is closed [ 13.718284] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.718292] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.718298] D1:camsys_open(739): camsys_marvin(ddef5110) is opened! [ 13.718359] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 13.718371] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 13.718397] rockchip_gpio_set:GPIO7-13 level = 1 [ 13.718402] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 13.718410] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x5 [ 13.718417] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xb824,result=0xb824 [ 13.718424] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 13.718434] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success [ 13.723457] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 13.723464] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 13.723569] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 13.723586] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 13.724641] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 13.725690] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.726742] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 13.728774] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.728781] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.728821] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 13.728829] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.728839] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 13.729903] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 13.729919] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 13.731957] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 13.731967] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 13.731974] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.731980] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.731986] D1:camsys_release(763): camsys_marvin(ddef5110) is closed [ 13.732482] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.732491] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.732498] D1:camsys_open(739): camsys_marvin(ddef5110) is opened! [ 13.732562] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 13.732573] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 13.732601] rockchip_gpio_set:GPIO7-13 level = 1 [ 13.732606] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 13.732615] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x5 [ 13.732622] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0xb824,result=0xb824 [ 13.732629] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 13.732639] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV5648) register success [ 13.737662] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 13.737670] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 13.737774] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 13.737795] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 13.738851] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 13.739901] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.740957] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 13.743003] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.743011] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.743054] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 13.743062] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.743073] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 13.744144] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 13.744162] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 13.746204] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 13.746215] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 13.746223] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.746229] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.746235] D1:camsys_release(763): camsys_marvin(ddef5110) is closed [ 13.746658] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.746666] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.746672] D1:camsys_open(739): camsys_marvin(ddef5110) is opened! [ 13.746735] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 1) for dev_id 0x1000000 success! [ 13.746746] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x1000000 success! [ 13.746753] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit [ 13.746835] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV2659) register success [ 13.751853] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 13.751861] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 13.751965] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 13.751983] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on [ 13.753038] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 13.754087] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.755139] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 0 [ 13.757171] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.757212] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 1 [ 13.757221] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.757231] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 13.758297] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 13.758312] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 13.760350] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success [ 13.760360] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 13.760368] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.760374] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.760380] D1:camsys_release(763): camsys_marvin(ddef5110) is closed [ 13.760975] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.760983] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on [ 13.760989] D1:camsys_open(739): camsys_marvin(ddef5110) is opened! [ 13.761048] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 13.761058] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success! [ 13.761066] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default [ 13.761081] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: TC358749XBG) register success [ 13.766098] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on [ 13.766106] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1 [ 13.766210] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0 [ 13.766227] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on [ 13.767284] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1 [ 13.768345] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.769412] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(79) set 1 [ 13.771453] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.771461] E:camsys_i2c_write(36): Get 3 i2c adapter is failed! [ 13.771512] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(79) set 0 [ 13.771520] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL! [ 13.771530] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0 [ 13.772611] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off [ 13.772636] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off [ 13.774679] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success [ 13.774690] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success! [ 13.774699] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.774705] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off [ 13.774711] D1:camsys_release(763): camsys_marvin(ddef5110) is closed
麻烦各位大神看看,有木有遇到类似问题,怎么解?
补发异常现象图片
ro.htg.force参数
你好,解决了吗
你好,解决了吗, 关注此问题
