RK3288 纯linux开发启动不了
首先我更新了ubuntu固件 名称为Firefly-RK3288_Ubuntu14.04_201611211031 烧写地址全部都是按照paramter参数来配置的
[img]/计算机/文档(E:)/学习记录[RK3288.gif]
FIRMWARE_VER:4.4.2
MACHINE_MODEL:rk30sdk
MACHINE_ID:007
MANUFACTURER:RK30SDK
MAGIC: 0x5041524B
ATAG: 0x60000800
MACHINE: 3066
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
#KERNEL_IMG: 0x62008000
#FDT_NAME: rk-kernel.dtb
#RECOVER_KEY: 1,1,0,20,0
CMDLINE:console=tty0 console=ttyFIQ0 earlyprintk root=/dev/block/mtd/by-name/linuxroot linuxroot rw rootfstype=ext4 init=/sbin/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00008000@0x00002000(resource),0x00008000@0x0000A000(boot),0x00002000@0x00012000(misc),0x0001a000@0x00014000(backup),-@0x0002e000(linuxroot)
自己编译使用的内核是git clone https://github.com/T-Firefly/firefly-3.14-kernel
./mkbootimg --kernel arch/arm/boot/zImage --ramdisk ../initrd.img --second resource.img -o boot.img
但是烧写boot.img的时候 内核却启动不了
U-Boot 2014.10-RK3288-02 (Nov 13 2015 - 10:22:31)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_MODEL:RK3288!
Unknow param: MACHINE_ID:007!
Unknow param: MANUFACTURER:RK3288!
no adc node
pmic:act8846
Enter power_led_init
#Boot ver: 2015-11-13#2.17
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
failed to load fdt from boot!
kernel @ 0x02000000 (0x0055b6b0)
ramdisk @ 0x04bf0000 (0x002752ca)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 0481a000, end 04826b24 … OK
Uncompressing Linux… done, booting the kernel.
麻烦大家帮忙看看 谢谢了
我在想是不是uboot也需要固件刷新吗 但是固件解包里面没有看到uboot这个文件呀
使用固件的boot.img是可以启动的 启动打印信息如下
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
kernel @ 0x02000000 (0x0066aa90)
ramdisk @ 0x04bf0000 (0x00275b90)
Loading Device Tree to 0480b000, end 04826a08 … OK
[ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (firefly@tchip-server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #164 SMP PREEMPT Mon Nov 21 10:31:03 CST 2016 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288 [ 0.000000] hdmi init vic is -1 [ 0.000000] rockchip_ion_reserve [ 0.000000] cma: CMA: reserved 16 MiB at 2e800000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f96000 s14016 r8192 d14656 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768 [ 0.000000] Kernel command line: console=tty0 console=ttyFIQ0 earlyprintk root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00008000@0x00002000(resource),0x00008000@0x0000A000(boot),0x00002000@0x00012000(misc),0x0001a000@0x00014000(backup),-@0x0002e000(linuxroot) storagemedia=emmc loader.timestamp=2015-11-13_10:22:31 hdmi.vic=-1 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
也没人理我,问题解决了,是parameter的问题,需要使用牛头的这个工具
你好,怎么解决的,我现在也是这个问题,能不能把经验分享出来呢?
