之前買了OV13850攝像頭模組,今日才有空試一試。發現不能動作。按理FIREFLY已調適好了,不用再作任何修改才是。我檢查了一些軟件元件也都存在無誤。是否是硬件問題?以下是一些訊息,煩請官方或能仁之士幫我看看:
root@rk3288:/ # dmesg | grep cam
<4>[ 4.249382] D1:camsys_platform_probe(1061): 1-gpios-cifpower: gpio=236
<4>[ 4.255866] D1:camsys_platform_probe(1064): gpios-cifpower: gpio_request
<4>[ 4.262563] D1:camsys_platform_probe(1066): 1-gpios-cifpower: gpio_request=0
<4>[ 4.269577] D1:camsys_platform_probe(1075): gpios-cifpower: 236 high
<4>[ 4.276025] D1:camsys_mipiphy_probe_cb(163): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
<4>[ 4.287204] D1:camsys_mipiphy_probe_cb(160): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xf19b0000 size: 0x4000)
<4>[ 4.301466] D1:camsys_platform_probe(1208): ff910000.isp memory:
<4>[ 4.307469] D1:camsys_platform_probe(1218): Register memory (phy: 0xff910000 vir: 0xf19e0000 size: 0x10000)
<4>[ 4.317454] D1:camsys_platform_probe(1213): I2c memory (phy: 0x2d9e2000 vir: 0xed9e2000 size: 0x1000)
<4>[ 4.326915] D1:camsys_platform_probe(1233): Probe ff910000.isp device success
<11>[ 10.728031] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_hal.ver
<11>[ 10.736111] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_trace
<11>[ 10.744013] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_camboard.ver
<11>[ 10.752358] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_libisp.ver
<11>[ 10.760476] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_isi.ver
root@rk3288:/ # logcat | grep Camera
I/ActivityManager( 470): Delay finish: com.google.android.apps.plus/.service.CameraMonitor
E/CameraService( 144): no camera found before! check again…
I/CameraService( 144): Loaded “RK29_ICS_CameraHal_Module” camera module
D/CameraHal( 144): createInstance(780): open xml file(/etc/cam_board.xml) success
D/CameraHal( 144):
D/CameraHal( 144):
D/CameraHal( 144):
D/CameraHal( 144): Cam_board.xml Version Check:
D/CameraHal( 144): /etc/cam_board.xml : v0.7.0
D/CameraHal( 144): CameraHal_board_xml_parser: v0.7.0
D/CameraHal( 144):
D/CameraHal( 144):
D/CameraHal( 144): ParserSensorInfo(45): SensorName(OV13850ˬ=���$��2�kr�o��H�������0R’�d=�uu�Y����5oλ��v���k���"4�!��eQ���˷)
D/CameraHal( 144): ParserSensorInfo(47): SensorDevID(CAMSYS_DEVID_SENSOR_1B)
D/CameraHal( 144): ParserSensorInfo(58): SensorDevID(33554432)
D/CameraHal( 144): ParserSensorInfo(60): SensorHostDevID(CAMSYS_DEVID_MARVIN)
D/CameraHal( 144): ParserSensorInfo(75): Sensori2cBusNum(3)
D/CameraHal( 144): ParserSensorInfo(78): SensorI2cAddrByte(2)
D/CameraHal( 144): ParserSensorInfo(81): SensorI2cRate(100000)
D/CameraHal( 144): ParserSensorInfo(84): SensorMclk(24000000)
D/CameraHal( 144): ParserSensorInfo(87): SensorAvdd(NC) min(0) max(0)
D/CameraHal( 144): ParserSensorInfo(92): SensorDovdd(NC) min(18000000) max(18000000)
D/CameraHal( 144): ParserSensorInfo(97): SensorDvdd(NC) min(0) max(0)
D/CameraHal( 144): ParserSensorInfo(102): SensorGpioPwdn(RK30_PIN2_PB6) active(0)
D/CameraHal( 144): ParserSensorInfo(106): SensorGpioRst(RK30_PIN2_PB7) active(0)
D/CameraHal( 144): ParserSensorInfo(110): SensorGpioPwen(RK30_PIN0_PB3) active(1)
D/CameraHal( 144): ParserSensorInfo(114): SensorFacing(front)
D/CameraHal( 144): ParserSensorInfo(123): SensorInterface(MIPI)
D/CameraHal( 144): ParserSensorInfo(136): SensorMirrorFlip(0)
D/CameraHal( 144): ParserSensorInfo(142): SensorOrientation(180)
D/CameraHal( 144): ParserSensorInfo(139): SensorPowerupSequence(1234)
D/CameraHal( 144): ParserSensorInfo(234): SensorFovParemeter fov_h(60.0)(60.000000) fov_v(60.0)(60.000000)
D/CameraHal( 144): ParserSensorInfo(237): SensorAWB_Frame_Skip fps(15)
D/CameraHal( 144): ParserSensorInfo(210): SensorPhy: MIPI lane: 2 phyindex: 1 fmt: 0x2b
D/CameraHal( 144): ParserVCMInfo(249): VCMDrvName(BuiltInSensor)
D/CameraHal( 144): ParserVCMInfo(252): VCMName(NC)
D/CameraHal( 144): ParserVCMInfo(255): VCMI2cBusNum(3)
D/CameraHal( 144): ParserVCMInfo(258): VCMI2cAddrByte(0)
D/CameraHal( 144): ParserVCMInfo(261): VCMI2cRate(0)
D/CameraHal( 144): ParserVCMInfo(272): VCMVdd(NC) min(0) max(0)
D/CameraHal( 144): ParserVCMInfo(264): VCMGpioPwdn(NC) active(0)
D/CameraHal( 144): ParserVCMInfo(268): VCMGpioPower(NC) active(0)
D/CameraHal( 144): ParserVCMInfo(288): start current(20) rated current(80) vcm max(100) step mode(13) drv max(100)
D/CameraHal( 144): ParserFlashInfo(302): FlashName(Internal)
D/CameraHal( 144): ParserFlashInfo(305): FlashI2cBusNum(0)
D/CameraHal( 144): ParserFlashInfo(308): FlashI2cAddrByte(0)
D/CameraHal( 144): ParserFlashInfo(311): FlashI2cRate(0)
D/CameraHal( 144): ParserFlashInfo(314): FlashTrigger(NC) active(0)
D/CameraHal( 144): ParserFlashInfo(318): FlashEn(NC) active(0)
D/CameraHal( 144): ParserFlashInfo(325): FlashLuminance(0)
D/CameraHal( 144): ParserFlashInfo(328): FlashColorTemp(0)
D/CameraHal( 144): StartElementHandler(746): HDR(1)!
D/CameraHal( 144): StartElementHandler(750): ZSL(1)!
D/CameraHal( 144): StartElementHandler(754): zoom(1)!
D/CameraHal( 144): StartElementHandler(764): Continue_SnapShot(1)!
D/CameraHal( 144): StartElementHandler(758): PreviewSize(800x600)!
D/CameraHal( 144): ParserDVConfig(595): DV_QCIF(qcif) resolution(176x144) fps(10) support(1)
D/CameraHal( 144): ParserDVConfig(607): DV_QVGA(qvga) resolution(320x240) fps(10) support(1)
D/CameraHal( 144): ParserDVConfig(619): DV_CIF(cif) resolution(352x288) fps(10) support(1)
D/CameraHal( 144): ParserDVConfig(631): DV_VGA(480p) resolution(640x480) fps(10) support(0)
D/CameraHal( 144): ParserDVConfig(643): DV_480P(480p) resolution(720x480) fps(10) support(0)
D/CameraHal( 144): ParserDVConfig(667): DV_720P(720p) resolution(1280x720) fps(10) support(1)
D/CameraHal( 144): ParserDVConfig(679): DV_1080P(1080p) resolution(1920x1080) fps(10) support(1)
D/CameraHal( 144): number of camdevice (1)
D/CameraHal( 144): now DV size(7)
E/CameraHal( 144): camera_get_number_of_cameras(683): board profiles cam num 1
D/CameraHal( 144): read cam name from xml(/data/media_profiles.xml)
D/CameraHal( 144): videoname0=“UVC Camera” index=0 facing=0 →
D/CameraHal( 144):
D/CameraHal( 144): videoname1=“UVC Camera” index=1 facing=0 →
D/CameraHal( 144):
D/CameraHal( 144): find camera count(2) cam1(UVC Camera) cam2(UVC Camera)
E/CameraHal( 144): camera_get_number_of_cameras(690): load sensor name(OV13850ˬ=���$��2�kr�o��H�����/dev/camsys_marvin) connect 0
E/CameraHal( 144): camera_get_number_of_cameras(743): Open /dev/video0 failed! strr: No such file or directory
D/CameraHal( 144): camera_get_number_of_cameras(1111): camera_get_number_of_cameras(1111): Current board have 0 cameras attached.
D/CameraHal( 144): camera_get_number_of_cameras(1114): meida_profiles_xml_control time (45565)us
D/CameraHal( 144):
D/CameraHal( 144):
D/CameraHal( 144):
D/CameraHal( 144):
D/CameraHal( 144):
D/CameraHal( 144): ParserSensorInfo(45): SensorName(OV13850�)
D/CameraHal( 144):
D/CameraHal( 144):
E/CameraHal( 144): camera_get_number_of_cameras(690): load sensor name(OV13850�) connect 0
D/CameraHal( 144): camera_get_number_of_cameras(1114): meida_profiles_xml_control time (42674)us
