目前的问题是我按照下载的这块的资料,将相应的ID号放到了对应的内核程序中,但是输入相应的命令行时没反应,下面是4G模块启动的打印
[ 16.715185] usb 1-1: reset high-speed USB device number 2 using dwc2
[ 17.175155] usb 1-1: USB disconnect, device number 2
[ 17.554994] usb 1-1: new high-speed USB device number 3 using dwc2
[ 17.796061] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[ 17.829624] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 17.863984] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 17.897710] hub 1-1:1.0: USB hub found
[ 17.904940] hub 1-1:1.0: 4 ports detected
[ 18.185047] usb 1-1.3: new high-speed USB device number 4 using dwc2
[ 18.319133] usb 1-1.3: New USB device found, idVendor=05c6, idProduct=9025
[ 18.353269] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 18.387639] usb 1-1.3: Product: Android
[ 18.417905] usb 1-1.3: Manufacturer: Android
[ 18.467943] RK3288
[ 18.473220] option 1-1.3:1.0: GSM modem (1-port) converter detected
[ 18.483118] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB0
[ 18.493956] RK3288
[ 18.499238] option 1-1.3:1.1: GSM modem (1-port) converter detected
[ 18.509156] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB1
[ 18.519291] RK3288
[ 18.524129] option 1-1.3:1.2: GSM modem (1-port) converter detected
[ 18.533658] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB2
[ 18.544085] RK3288
[ 18.548692] option 1-1.3:1.3: GSM modem (1-port) converter detected
[ 18.557756] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB3
[ 18.567830] RK3288
[ 18.572488] option 1-1.3:1.4: GSM modem (1-port) converter detected
[ 18.581751] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB4
[ 18.591554] RK3288
[ 18.596651] option 1-1.3:1.5: GSM modem (1-port) converter detected
[ 18.605812] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB5
[ 18.922808] random: nonblocking pool is initialized
有谁做过这块,在串口如何输入相应的命令行来检测对应的输出,以此来验证该模块是否正常工作。
