请问Firefly官方统一固件Firefly-rk3399_xubuntu1604_201705111112对应的源码在哪里?我需要重编内核,官方wiki上的gitlab源码编出来能进shell(串口)但HDMI没显示。
同求,firefly提供的image烧写后看kernel版本是4.4.52,而从gitlab上拿下来的code是4.4.55了。
我感觉官方的kernel不是从gitlab是编译出来的。
遇到和楼上一样的问题.[3509142.066]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[3509142.066] X Protocol Version 11, Revision 0
[3509142.066] Build Operating System: Linux 4.6.0-1-amd64 x86_64 Debian
[3509142.066] Current Operating System: Linux firefly 4.4.55 #1 SMP Wed Jun 7 15:32:20 CST 2017 aarch64
[3509142.066] Kernel command line: console=ttyFIQ0 root=/dev/mmcblk1p6 rw rootwait mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00008000@0x00006000(resource),0x0000A000@0x0000E000(kernel),0x00002000@0x00018000(backup),-@0x0001A000(boot) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2017-04-25_15:10:21 androidboot.mode=emmc
[3509142.066] Build Date: 23 December 2016 02:17:57AM
[3509142.066] xorg-server 2:1.18.4-1 (http://www.debian.org/support)
[3509142.066] Current version of pixman: 0.33.6
[3509142.067] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[3509142.067] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[3509142.067] (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Feb 11 16:28:08 2016
[3509142.067] (==) Using config directory: “/etc/X11/xorg.conf.d”
[3509142.067] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[3509142.067] (==) No Layout section. Using the first Screen section.
[3509142.067] (==) No screen section available. Using defaults.
[3509142.067] () |–>Screen “Default Screen Section” (0)
[3509142.067] () | |–>Monitor “”
[3509142.067] (==) No device specified for screen “Default Screen Section”.
Using the first device section listed.
[3509142.067] () | |–>Device “Rockchip Graphics”
[3509142.067] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[3509142.067] (==) Automatically adding devices
[3509142.067] (==) Automatically enabling devices
[3509142.067] (==) Automatically adding GPU devices
[3509142.067] (==) Max clients allowed: 256, resource mask: 0x1fffff
[3509142.067] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[3509142.068] Entry deleted from font path.
[3509142.068] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[3509142.068] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[3509142.068] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[3509142.068] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[3509142.068] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[3509142.068] (==) ModulePath set to “/usr/lib/xorg/modules”
[3509142.068] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[3509142.068] (II) Loader magic: 0x55852bdd70
[3509142.068] (II) Module ABI versions:
[3509142.068] X.Org ANSI C Emulation: 0.4
[3509142.068] X.Org Video Driver: 20.0
[3509142.068] X.Org XInput driver : 22.1
[3509142.068] X.Org Server Extension : 9.0
[3509142.073] (++) using VT number 7
[3509142.073] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[3509142.074] (II) no primary bus or device found
[3509142.075] (II) LoadModule: “glx”
[3509142.076] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[3509142.086] (II) Module glx: vendor=“X.Org Foundation”
[3509142.086] compiled for 1.18.4, module version = 1.0.0
[3509142.086] ABI class: X.Org Server Extension, version 9.0
[3509142.086] (==) AIGLX enabled
[3509142.086] (II) LoadModule: “modesetting”
[3509142.087] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[3509142.088] (II) Module modesetting: vendor=“X.Org Foundation”
[3509142.088] compiled for 1.18.4, module version = 1.18.4
[3509142.088] Module class: X.Org Video Driver
[3509142.088] ABI class: X.Org Video Driver, version 20.0
[3509142.089] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[3509142.089] (WW) Falling back to old probe method for modesetting
[3509142.089] (EE) open /dev/dri/card0: No such file or directory
[3509142.090] (EE) No devices detected.
[3509142.090] (EE)
Fatal server error:
[3509142.090] (EE) no screens found(EE)
[3509142.090] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[3509142.090] (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[3509142.091] (EE)
Demsg:[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.4.55 (woody@admin-node) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP Wed Jun 7 15:32:20 CST 2017
[ 0.000000] On node 0 totalpages: 1015296
[ 0.000000] DMA zone: 15864 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 1015296 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7ee8000 s46144 r8192 d31680 u86016
[ 0.000000] pcpu-alloc: s46144 r8192 d31680 u86016 alloc=21*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 999432
[ 0.000000] Kernel command line: console=ttyFIQ0 root=/dev/mmcblk1p6 rw rootwait mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00008000@0x00006000(resource),0x0000A000@0x0000E000(kernel),0x00002000@0x00018000(backup),-@0x0001A000(boot) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2017-04-25_15:10:21
[ 0.000000] software IO TLB [mem 0xef600000-0xf3600000] (64MB) mapped at [ffffffc0ef600000-ffffffc0f35fffff]
[ 0.000000] Memory: 3903476K/4061184K available (11454K kernel code, 1356K rwdata, 4028K rodata, 1152K init, 767K bss, 157708K reserved, 0K cma-reserved)
modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB)
.init : 0xffffff8008fb0000 - 0xffffff80090d0000 ( 1152 KB)
.text : 0xffffff8008080000 - 0xffffff8008bb0000 ( 11456 KB)
.rodata : 0xffffff8008bb0000 - 0xffffff8008fb0000 ( 4096 KB)
.data : 0xffffff80090d0000 - 0xffffff80092232c0 ( 1357 KB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
fixed : 0xffffffbffe7fd000 - 0xffffffbffec00000 ( 4108 KB)
PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB)
memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.000000] ITS: allocated 65536 Devices @ef000000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x00000000ef080000
[ 0.000000] CPU0: using LPI pending table @0x00000000ef090000
[ 0.001191] Console: colour dummy device 80x25
[ 0.001217] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.001231] pid_max: default: 32768 minimum: 301
[ 0.001322] Security Framework initialized
[ 0.001332] Yama: becoming mindful.
[ 0.001416] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.001428] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002251] Initializing cgroup subsys devices
[ 0.002269] Initializing cgroup subsys freezer
[ 0.002298] ftrace: allocating 42952 entries in 168 pages
[ 0.119725] sched-energy: Sched-energy-costs installed from DT
[ 0.119745] CPU0: update cpu_capacity 401
[ 0.119800] ASID allocator initialised with 65536 entries
[ 0.120639] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.121066] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.122202] Detected VIPT I-cache on CPU1
[ 0.122236] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.122272] CPU1: using LPI pending table @0x00000000ef2a0000
[ 0.122318] CPU1: update cpu_capacity 401
[ 0.122322] CPU1: Booted secondary processor [410fd034]
[ 0.122861] Detected VIPT I-cache on CPU2
[ 0.122882] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.122915] CPU2: using LPI pending table @0x00000000ef2d0000
[ 0.122946] CPU2: update cpu_capacity 401
[ 0.122950] CPU2: Booted secondary processor [410fd034]
[ 0.123426] Detected VIPT I-cache on CPU3
[ 0.123447] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.123480] CPU3: using LPI pending table @0x00000000ef300000
[ 0.123509] CPU3: update cpu_capacity 401
[ 0.123512] CPU3: Booted secondary processor [410fd034]
[ 0.124026] Detected PIPT I-cache on CPU4
[ 0.124057] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.124093] CPU4: using LPI pending table @0x00000000ef350000
[ 0.124136] CPU4: update cpu_capacity 1024
[ 0.124140] CPU4: Booted secondary processor [410fd082]
[ 0.124658] Detected PIPT I-cache on CPU5
[ 0.124677] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.124711] CPU5: using LPI pending table @0x00000000ef380000
[ 0.124739] CPU5: update cpu_capacity 1024
[ 0.124742] CPU5: Booted secondary processor [410fd082]
[ 0.124828] Brought up 6 CPUs
[ 0.124909] SMP: Total of 6 processors activated.
[ 0.124918] CPU features: detected feature: GIC system register CPU interface
[ 0.124931] CPU: All CPU(s) started at EL2
[ 0.124979] alternatives: patching kernel code
[ 0.126347] devtmpfs: initialized
[ 0.146478] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.146507] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.147031] pinctrl core: initialized pinctrl subsystem
[ 0.147362] regulator-dummy: no parameters
[ 0.148129] NET: Registered protocol family 16
[ 0.152015] cpuidle: using governor ladder
[ 0.156038] cpuidle: using governor menu
[ 0.156060] Registered FIQ tty driver
[ 0.156455] vdso: 2 pages (1 code @ ffffff8008bb6000, 1 data @ ffffff80090d4000)
[ 0.156489] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.156686] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.175087] gpiochip_add: registered GPIOs 0 to 31 on device: gpio0
[ 0.175193] gpiochip_add: registered GPIOs 32 to 63 on device: gpio1
[ 0.175317] gpiochip_add: registered GPIOs 64 to 95 on device: gpio2
[ 0.175416] gpiochip_add: registered GPIOs 96 to 127 on device: gpio3
[ 0.175517] gpiochip_add: registered GPIOs 128 to 159 on device: gpio4
[ 0.247329] console [ttyFIQ0] enabled
[ 0.247855] Registered fiq debugger ttyFIQ0
[ 0.271380] ACPI: Interpreter disabled.
[ 0.272164] of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/vcc3v3-pcie-regulator[0]’ - status (0)
[ 0.272215] vcc3v3_pcie: no parameters
[ 0.272348] reg-fixed-voltage vcc3v3-pcie-regulator: vcc3v3_pcie supplying 0uV
[ 0.272400] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vcc3v3-sys[0]’
[ 0.272417] vcc3v3_sys: 3300 mV
[ 0.272531] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[ 0.272666] of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/vcc5v0-host-regulator[0]’ - status (0)
[ 0.272703] vcc5v0_host: no parameters
[ 0.272830] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[ 0.272879] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vcc5v0-sys[0]’
[ 0.272895] vcc5v0_sys: 5000 mV
[ 0.273006] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
[ 0.273051] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vcc-phy-regulator[0]’
[ 0.273066] vcc_phy: no parameters
[ 0.273177] reg-fixed-voltage vcc-phy-regulator: vcc_phy supplying 0uV
[ 0.273226] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vccadc-ref[0]’
[ 0.273240] vcc1v8_sys: 1800 mV
[ 0.273360] reg-fixed-voltage vccadc-ref: vcc1v8_sys supplying 1800000uV
[ 0.273478] of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/vcc-lcd-regulator[0]’ - status (0)
[ 0.273518] vcc_lcd: no parameters
[ 0.273628] reg-fixed-voltage vcc-lcd-regulator: vcc_lcd supplying 0uV
[ 0.274162] iommu: Adding device ff650000.vpu_service to group 0
[ 0.274764] iommu: Adding device ff660000.rkvdec to group 1
[ 0.275346] iommu: Adding device ff8f0000.vop to group 2
[ 0.275890] iommu: Adding device ff900000.vop to group 3
[ 0.277478] vgaarb: loaded
[ 0.278001] SCSI subsystem initialized
[ 0.278504] usbcore: registered new interface driver usbfs
[ 0.279036] usbcore: registered new interface driver hub
[ 0.279583] usbcore: registered new device driver usb
[ 0.280134] media: Linux media interface: v0.10
[ 0.280559] Linux video capture interface: v2.00
[ 0.281007] pps_core: LinuxPPS API ver. 1 registered
[ 0.281452] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.282264] PTP clock support registered
[ 0.283610] Advanced Linux Sound Architecture Driver Initialized.
[ 0.284723] Bluetooth: Core ver 2.21
[ 0.285062] NET: Registered protocol family 31
[ 0.285463] Bluetooth: HCI device and connection manager initialized
[ 0.286027] Bluetooth: HCI socket layer initialized
[ 0.286459] Bluetooth: L2CAP socket layer initialized
[ 0.286925] Bluetooth: SCO socket layer initialized
[ 0.288196] clocksource: Switched to clocksource arch_sys_counter
[ 0.318171] pnp: PnP ACPI: disabled
[ 0.326328] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.327249] NET: Registered protocol family 2
[ 0.328049] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.328872] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[ 0.330006] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.330694] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.331371] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.332353] NET: Registered protocol family 1
[ 0.333060] RPC: Registered named UNIX socket transport module.
[ 0.333597] RPC: Registered udp transport module.
[ 0.334010] RPC: Registered tcp transport module.
[ 0.334431] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.335013] PCI: CLS 0 bytes, default 64
[ 0.335602] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.336408] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.340156] Initialise system trusted keyring
[ 0.347924] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.350082] NFS: Registering the id_resolver key type
[ 0.350563] Key type id_resolver registered
[ 0.350931] Key type id_legacy registered
[ 0.351307] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.352560] fuse init (API version 7.23)
[ 0.356869] NET: Registered protocol family 38
[ 0.357293] Key type asymmetric registered
[ 0.357658] Asymmetric key parser ‘x509’ registered
[ 0.358252] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.358904] io scheduler noop registered
[ 0.359286] io scheduler deadline registered
[ 0.359779] io scheduler cfq registered (default)
[ 0.361162] phy phy-ff770000.syscon:usb2-phy@e460.0: Looking up phy-supply from device tree
[ 0.361174] phy phy-ff770000.syscon:usb2-phy@e460.0: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e460/otg-port failed
[ 0.361439] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: GPIO lookup for consumer otg-vbus
[ 0.361448] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: using device tree for GPIO lookup
[ 0.361459] of_get_named_gpiod_flags: can’t parse ‘otg-vbus-gpios’ property of node ‘/syscon@ff770000/usb2-phy@e460[0]’
[ 0.361467] of_get_named_gpiod_flags: can’t parse ‘otg-vbus-gpio’ property of node ‘/syscon@ff770000/usb2-phy@e460[0]’
[ 0.361475] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: using lookup tables for GPIO lookup
[ 0.361483] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: lookup for GPIO otg-vbus failed
[ 0.361491] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 0.362307] phy phy-ff770000.syscon:usb2-phy@e460.1: Looking up phy-supply from device tree
[ 0.362381] vcc5v0_host: could not add device link phy-ff770000.syscon:usb2-phy@e460.1 err -2
[ 0.363053] phy phy-ff770000.syscon:phy@f780.2: Looking up phy-supply from device tree
[ 0.363064] phy phy-ff770000.syscon:phy@f780.2: Looking up phy-supply property in node /syscon@ff770000/phy@f780 failed
[ 0.364163] phy phy-ff800000.phy.3: Looking up phy-supply from device tree
[ 0.364174] phy phy-ff800000.phy.3: Looking up phy-supply property in node /phy@ff800000/dp-port failed
[ 0.364296] phy phy-ff800000.phy.4: Looking up phy-supply from device tree
[ 0.364306] phy phy-ff800000.phy.4: Looking up phy-supply property in node /phy@ff800000/usb3-port failed
[ 0.364629] phy phy-phy@e220.5: Looking up phy-supply from device tree
[ 0.364639] phy phy-phy@e220.5: Looking up phy-supply property in node /phy@e220 failed
[ 0.366350] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[ 0.366359] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[ 0.366385] of_get_named_gpiod_flags: parsed ‘ep-gpios’ property of node ‘/pcie@f8000000[0]’ - status (0)
[ 0.366616] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[ 0.366626] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply property in node /pcie@f8000000 failed
[ 0.366640] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.367213] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree
[ 0.367223] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed
[ 0.367234] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.367790] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree
[ 0.367799] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed
[ 0.367808] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.910227] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 0.910867] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 0.912133] rk-vcodec ff650000.vpu_service: No core reset resource define
[ 0.912782] rk-vcodec ff650000.vpu_service: do not have pd_video
[ 0.913333] rk-vcodec ff650000.vpu_service: probe device
[ 0.913831] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0ee9a3c10
[ 0.914585] rk-vcodec ff650000.vpu_service: allocator is drm
[ 0.915133] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 0.916056] rk-vcodec ff650000.vpu_service: init success
[ 0.916892] rk-vcodec ff660000.rkvdec: No core reset resource define
[ 0.917561] rk-vcodec ff660000.rkvdec: do not have pd_video
[ 0.918061] rk-vcodec ff660000.rkvdec: probe device
[ 0.918535] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0ee9a8410
[ 0.919230] rk-vcodec ff660000.rkvdec: allocator is drm
[ 0.919738] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 0.920524] rk-vcodec ff660000.rkvdec: init success
[ 0.922382] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.923048] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.925250] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.925915] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.927108] pwm-regulator vdd-log: GPIO lookup for consumer enable
[ 0.927117] pwm-regulator vdd-log: using device tree for GPIO lookup
[ 0.927126] of_get_named_gpiod_flags: can’t parse ‘enable-gpios’ property of node ‘/vdd-log[0]’
[ 0.927135] of_get_named_gpiod_flags: can’t parse ‘enable-gpio’ property of node ‘/vdd-log[0]’
[ 0.927141] pwm-regulator vdd-log: using lookup tables for GPIO lookup
[ 0.927150] pwm-regulator vdd-log: lookup for GPIO enable failed
[ 0.927176] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.927200] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.927222] vdd_log: 800 ↔ 1400 mV at 1004 mV
[ 0.927370] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.927380] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.927705] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.929745] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 0.931126] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
[ 0.932883] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 0.935822] usbcore: registered new interface driver udl
[ 0.937485] mali ff9a0000.gpu: Looking up mali-supply from device tree
[ 0.937504] mali ff9a0000.gpu: Failed to get regulator
[ 0.937956] mali ff9a0000.gpu: Power control initialization failed
[ 0.938796] Unable to detect cache hierarchy from DT for CPU 0
[ 0.947573] brd: module loaded
[ 0.952831] loop: module loaded
[ 0.953659] zram: Added device: zram0
[ 0.954281] lkdtm: No crash points registered, enable through debugfs
[ 0.955617] tun: Universal TUN/TAP device driver, 1.6
[ 0.956062] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.957827] rk_gmac-dwmac fe300000.ethernet: Looking up phy-supply from device tree
[ 0.957908] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 0.958543] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 0.959041] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 0.959725] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 0.960269] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 0.965827] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.966279] Ring mode enabled
[ 0.966549] DMA HW capability register supported
[ 0.966945] Normal descriptors
[ 0.967246] RX Checksum Offload Engine supported (type 2)
[ 0.967725] TX Checksum insertion supported
[ 0.968099] Wake-Up On Lan supported
[ 0.968458] Enable RX Mitigation via HW Watchdog Timer
[ 0.969014] of_get_named_gpiod_flags: parsed ‘snps,reset-gpio’ property of node ‘/ethernet@fe300000[0]’ - status (0)
[ 1.031150] libphy: stmmac: probed
[ 1.031473] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.032037] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.033513] PPP generic driver version 2.4.2
[ 1.034115] usbcore: registered new interface driver rndis_wlan
[ 1.034961] dhd_module_init: in
[ 1.034969] ======== bcm_wlan_set_plat_data ========
[ 1.034973] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.034977] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: rfkill-wlan driver has not Successful initialized
[ 1.034980] host_oob_irq: -1
[ 1.034982] host_oob_irq_flags=0x4
[ 1.034984] dhd_wifi_platform_load: Enter
[ 1.035047] Power-up adapter ‘DHD generic adapter’
[ 1.035119] wifi_platform_set_power = 1
[ 1.035122] ======== PULL WL_REG_ON HIGH! ========
[ 1.035125] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.035128] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[ 1.040384] =======================================================
[ 1.040931] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 1.041487] =======================================================
[ 1.042034] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD) init.
[ 1.042711] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.043123] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[ 1.043902] RTL871X: module init start
[ 1.044242] RTL871X: rtl8188eu v4.3.24_16705.20160509
[ 1.044760] usbcore: registered new interface driver rtl8188eu
[ 1.045281] RTL871X: module init ret=0
[ 1.045622] Rockchip WiFi SYS interface (V1.00) …
[ 1.046086] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.046776] usbcore: registered new interface driver pegasus
[ 1.047324] usbcore: registered new interface driver rtl8150
[ 1.047856] usbcore: registered new interface driver r8152
[ 1.048389] usbcore: registered new interface driver asix
[ 1.048898] usbcore: registered new interface driver ax88179_178a
[ 1.049476] usbcore: registered new interface driver cdc_ether
[ 1.050024] usbcore: registered new interface driver dm9601
[ 1.050572] usbcore: registered new interface driver smsc75xx
[ 1.051120] usbcore: registered new interface driver smsc95xx
[ 1.051669] usbcore: registered new interface driver net1080
[ 1.052209] usbcore: registered new interface driver rndis_host
[ 1.052767] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.053490] usbcore: registered new interface driver cdc_ncm
[ 1.054020] usbcore: registered new interface driver cdc_mbim
[ 1.055749] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.059678] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.061258] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.061837] ehci-pci: EHCI PCI platform driver
[ 1.062295] ehci-platform: EHCI generic platform driver
[ 1.064555] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.065216] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.065990] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.072218] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.072878] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.073489] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.074122] usb usb1: Product: EHCI Host Controller
[ 1.074561] usb usb1: Manufacturer: Linux 4.4.55 ehci_hcd
[ 1.075035] usb usb1: SerialNumber: fe3c0000.usb
[ 1.075871] hub 1-0:1.0: USB hub found
[ 1.076245] hub 1-0:1.0: 1 port detected
[ 1.077096] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.077667] ohci-pci: OHCI PCI platform driver
[ 1.078106] ohci-platform: OHCI generic platform driver
[ 1.079045] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.079801] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.080586] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.135344] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.135941] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.136586] usb usb2: Product: Generic Platform OHCI controller
[ 1.137105] usb usb2: Manufacturer: Linux 4.4.55 ohci_hcd
[ 1.137587] usb usb2: SerialNumber: fe3e0000.usb
[ 1.138414] hub 2-0:1.0: USB hub found
[ 1.138767] hub 2-0:1.0: 1 port detected
[ 1.139916] usbcore: registered new interface driver cdc_acm
[ 1.140424] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.141164] usbcore: registered new interface driver cdc_wdm
[ 1.141747] usbcore: registered new interface driver usb-storage
[ 1.142361] usbcore: registered new interface driver usbserial
[ 1.142897] usbcore: registered new interface driver usbserial_generic
[ 1.143501] usbserial: USB Serial support registered for generic
[ 1.144063] usbcore: registered new interface driver cp210x
[ 1.144580] usbserial: USB Serial support registered for cp210x
[ 1.145150] usbcore: registered new interface driver ftdi_sio
[ 1.145683] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.146409] usbcore: registered new interface driver keyspan
[ 1.146924] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 1.147639] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 1.148306] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 1.148962] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 1.149647] usbcore: registered new interface driver option
[ 1.150154] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.150873] usbcore: registered new interface driver oti6858
[ 1.151398] usbserial: USB Serial support registered for oti6858
[ 1.151959] usbcore: registered new interface driver pl2303
[ 1.152478] usbserial: USB Serial support registered for pl2303
[ 1.153036] usbcore: registered new interface driver qcserial
[ 1.153568] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.154233] usbcore: registered new interface driver sierra
[ 1.154740] usbserial: USB Serial support registered for Sierra USB modem
[ 1.156139] usbcore: registered new interface driver iforce
[ 1.156709] usbcore: registered new interface driver xpad
[ 1.157489] usbcore: registered new interface driver usbtouchscreen
[ 1.158366] i2c /dev entries driver
[ 1.159425] fan53555-regulator 0-0040: GPIO lookup for consumer vsel
[ 1.159434] fan53555-regulator 0-0040: using device tree for GPIO lookup
[ 1.159464] of_get_named_gpiod_flags: parsed ‘vsel-gpios’ property of node ‘/i2c@ff3c0000/syr827@40[0]’ - status (0)
[ 1.159841] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.160468] fan53555-regulator 0-0040: Looking up vin-supply from device tree
[ 1.160536] fan53555-reg: supplied by vcc5v0_sys
[ 1.160943] vcc5v0_sys: could not add device link regulator.9 err -2
[ 1.162350] vdd_cpu_b: 712 ↔ 1500 mV at 1000 mV
[ 1.162663] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.162677] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.162828] fan53555-regulator 0-0041: GPIO lookup for consumer vsel
[ 1.162835] fan53555-regulator 0-0041: using device tree for GPIO lookup
[ 1.162844] of_get_named_gpiod_flags: can’t parse ‘vsel-gpios’ property of node ‘/i2c@ff3c0000/syr828@41[0]’
[ 1.162852] of_get_named_gpiod_flags: can’t parse ‘vsel-gpio’ property of node ‘/i2c@ff3c0000/syr828@41[0]’
[ 1.162859] fan53555-regulator 0-0041: using lookup tables for GPIO lookup
[ 1.162867] fan53555-regulator 0-0041: lookup for GPIO vsel failed
[ 1.163199] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.163807] fan53555-regulator 0-0041: Looking up vin-supply from device tree
[ 1.163847] fan53555-reg: supplied by vcc5v0_sys
[ 1.164270] vcc5v0_sys: could not add device link regulator.10 err -2
[ 1.165931] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 1.166232] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.166243] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.166860] rk808 0-001b: Pmic Chip id: 0x0
[ 1.170412] rk808 0-001b: GPIO lookup for consumer dvs
[ 1.170420] rk808 0-001b: using device tree for GPIO lookup
[ 1.170430] of_get_named_gpiod_flags: can’t parse ‘dvs-gpios’ property of node ‘/i2c@ff3c0000/pmic@1b[0]’
[ 1.170438] of_get_named_gpiod_flags: can’t parse ‘dvs-gpio’ property of node ‘/i2c@ff3c0000/pmic@1b[0]’
[ 1.170445] rk808 0-001b: using lookup tables for GPIO lookup
[ 1.170452] rk808 0-001b: lookup for GPIO dvs failed
[ 1.170460] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.171002] rk808 0-001b: GPIO lookup for consumer dvs
[ 1.171009] rk808 0-001b: using device tree for GPIO lookup
[ 1.171017] of_get_named_gpiod_flags: can’t parse ‘dvs-gpios’ property of node ‘/i2c@ff3c0000/pmic@1b[1]’
[ 1.171024] of_get_named_gpiod_flags: can’t parse ‘dvs-gpio’ property of node ‘/i2c@ff3c0000/pmic@1b[1]’
[ 1.171030] rk808 0-001b: using lookup tables for GPIO lookup
[ 1.171037] rk808 0-001b: lookup for GPIO dvs failed
[ 1.171044] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.171629] rk808 0-001b: Looking up vcc1-supply from device tree
[ 1.171677] DCDC_REG1: supplied by vcc3v3_sys
[ 1.172062] vcc3v3_sys: could not add device link regulator.11 err -2
[ 1.172540] vdd_center: 750 ↔ 1350 mV at 900 mV
[ 1.172688] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.172699] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.172743] rk808 0-001b: Looking up vcc2-supply from device tree
[ 1.172779] DCDC_REG2: supplied by vcc3v3_sys
[ 1.173163] vcc3v3_sys: could not add device link regulator.12 err -2
[ 1.173481] vdd_cpu_l: 750 ↔ 1350 mV at 900 mV
[ 1.173611] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.173621] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.173659] rk808 0-001b: Looking up vcc3-supply from device tree
[ 1.173693] DCDC_REG3: supplied by vcc3v3_sys
[ 1.174078] vcc3v3_sys: could not add device link regulator.13 err -2
[ 1.174106] vcc_ddr: at 3300 mV
[ 1.174242] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.174252] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.174293] rk808 0-001b: Looking up vcc4-supply from device tree
[ 1.174327] DCDC_REG4: supplied by vcc3v3_sys
[ 1.174712] vcc3v3_sys: could not add device link regulator.14 err -2
[ 1.174892] vcc_1v8: 1800 mV
[ 1.175018] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.175028] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.175071] rk808 0-001b: Looking up vcc6-supply from device tree
[ 1.175105] LDO_REG1: supplied by vcc3v3_sys
[ 1.175498] vcc3v3_sys: could not add device link regulator.15 err -2
[ 1.176339] vcc1v8_dvp: 1800 mV
[ 1.176471] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.176482] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.176528] rk808 0-001b: Looking up vcc6-supply from device tree
[ 1.176564] LDO_REG2: supplied by vcc3v3_sys
[ 1.176942] vcc3v3_sys: could not add device link regulator.16 err -2
[ 1.177650] vcc3v0_tp: 3000 mV
[ 1.177778] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.177788] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.177838] rk808 0-001b: Looking up vcc7-supply from device tree
[ 1.177873] LDO_REG3: supplied by vcc3v3_sys
[ 1.178265] vcc3v3_sys: could not add device link regulator.17 err -2
[ 1.178961] vcc1v8_pmu: 1800 mV
[ 1.179091] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.179101] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.179149] rk808 0-001b: Looking up vcc9-supply from device tree
[ 1.179198] LDO_REG4: supplied by vcc3v3_sys
[ 1.179577] vcc3v3_sys: could not add device link regulator.18 err -2
[ 1.180277] vcc_sd: 1800 ↔ 3300 mV at 3000 mV
[ 1.180404] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.180414] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.180463] rk808 0-001b: Looking up vcc9-supply from device tree
[ 1.180497] LDO_REG5: supplied by vcc3v3_sys
[ 1.180875] vcc3v3_sys: could not add device link regulator.19 err -2
[ 1.181582] vcca3v0_codec: 3000 mV
[ 1.181712] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.181722] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.181777] rk808 0-001b: Looking up vcc10-supply from device tree
[ 1.181813] LDO_REG6: supplied by vcc3v3_sys
[ 1.182206] vcc3v3_sys: could not add device link regulator.20 err -2
[ 1.182906] vcc_1v5: 1500 mV
[ 1.183033] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.183042] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.183097] rk808 0-001b: Looking up vcc7-supply from device tree
[ 1.183130] LDO_REG7: supplied by vcc3v3_sys
[ 1.183523] vcc3v3_sys: could not add device link regulator.21 err -2
[ 1.184221] vcca1v8_codec: 1800 mV
[ 1.184360] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.184370] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.184425] rk808 0-001b: Looking up vcc11-supply from device tree
[ 1.184459] LDO_REG8: supplied by vcc3v3_sys
[ 1.184836] vcc3v3_sys: could not add device link regulator.22 err -2
[ 1.185532] vcc_3v0: 3000 mV
[ 1.185654] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.185663] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.185717] rk808 0-001b: Looking up vcc8-supply from device tree
[ 1.185750] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.186150] vcc3v3_sys: could not add device link regulator.23 err -2
[ 1.186178] vcc3v3_s3: at 3300 mV
[ 1.186304] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.186313] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.186369] rk808 0-001b: Looking up vcc12-supply from device tree
[ 1.186403] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.186802] vcc3v3_sys: could not add device link regulator.24 err -2
[ 1.186841] vcc3v3_s0: at 3300 mV
[ 1.186946] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.186955] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.190221] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.191237] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009568000
[ 1.192506] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff800956a000
[ 1.193250] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[ 1.194168] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 1.194760] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl
[ 1.195738] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[ 1.196711] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff800956c000
[ 1.198086] fusb302 4-0022: GPIO lookup for consumer int-n
[ 1.198095] fusb302 4-0022: using device tree for GPIO lookup
[ 1.198121] of_get_named_gpiod_flags: parsed ‘int-n-gpios’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’ - status (0)
[ 1.198149] fusb302 4-0022: GPIO lookup for consumer vbus-5v
[ 1.198156] fusb302 4-0022: using device tree for GPIO lookup
[ 1.198177] of_get_named_gpiod_flags: parsed ‘vbus-5v-gpios’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’ - status (0)
[ 1.198217] fusb302 4-0022: GPIO lookup for consumer vbus-other
[ 1.198224] fusb302 4-0022: using device tree for GPIO lookup
[ 1.198232] of_get_named_gpiod_flags: can’t parse ‘vbus-other-gpios’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’
[ 1.198240] of_get_named_gpiod_flags: can’t parse ‘vbus-other-gpio’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’
[ 1.198246] fusb302 4-0022: using lookup tables for GPIO lookup
[ 1.198254] fusb302 4-0022: lookup for GPIO vbus-other failed
[ 1.198262] fusb302 4-0022: GPIO lookup for consumer discharge
[ 1.198269] fusb302 4-0022: using device tree for GPIO lookup
[ 1.198276] of_get_named_gpiod_flags: can’t parse ‘discharge-gpios’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’
[ 1.198283] of_get_named_gpiod_flags: can’t parse ‘discharge-gpio’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’
[ 1.198290] fusb302 4-0022: using lookup tables for GPIO lookup
[ 1.198297] fusb302 4-0022: lookup for GPIO discharge failed
[ 1.207381] fusb302 4-0022: port 0 probe success
[ 1.207807] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff800956e000
[ 1.209429] IR NEC protocol handler initialized
[ 1.209833] IR RC5(x/sz) protocol handler initialized
[ 1.210290] IR RC6 protocol handler initialized
[ 1.210692] IR JVC protocol handler initialized
[ 1.211093] IR Sony protocol handler initialized
[ 1.211511] IR SANYO protocol handler initialized
[ 1.211928] IR Sharp protocol handler initialized
[ 1.212354] IR MCE Keyboard/mouse protocol handler initialized
[ 1.212869] IR XMP protocol handler initialized
[ 1.213352] usbcore: registered new interface driver uvcvideo
[ 1.213854] USB Video Class driver (1.1.1)
[ 1.214658] rockchip-iodomain ff320000.syscon:io-domains: Looking up pmu1830-supply from device tree
[ 1.214818] rockchip-iodomain ff770000.syscon:io-domains: Looking up bt656-supply from device tree
[ 1.214885] rockchip-iodomain ff770000.syscon:io-domains: Looking up audio-supply from device tree
[ 1.214941] rockchip-iodomain ff770000.syscon:io-domains: Looking up sdmmc-supply from device tree
[ 1.214990] rockchip-iodomain ff770000.syscon:io-domains: Looking up gpio1830-supply from device tree
[ 1.215468] rockchip_cpu_avs: cluster0 leakage=14 adjust_volt=0
[ 1.216013] rockchip_cpu_avs: cluster1 leakage=23 adjust_volt=0
[ 1.217852] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.219359] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.220268] Bluetooth: Virtual HCI driver ver 1.5
[ 1.220794] Bluetooth: HCI UART driver ver 2.3
[ 1.221199] Bluetooth: HCI UART protocol H4 registered
[ 1.221650] Bluetooth: HCI UART protocol LL registered
[ 1.222100] Bluetooth: HCI UART protocol ATH3K registered
[ 1.222642] usbcore: registered new interface driver bfusb
[ 1.223176] usbcore: registered new interface driver btusb
[ 1.224018] cpu cpu0: Looking up cpu-supply from device tree
[ 1.224326] cpu cpu0: Looking up cpu-supply from device tree
[ 1.225613] cpu cpu4: Looking up cpu-supply from device tree
[ 1.228064] sdhci: Secure Digital Host Controller Interface driver
[ 1.228619] sdhci: Copyright(c) Pierre Ossman
[ 1.229008] Synopsys Designware Multimedia Card Interface Driver
[ 1.230387] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.231046] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.231658] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.232211] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.233078] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.233798] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
[ 1.233808] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe310000 failed
[ 1.233836] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
[ 1.233845] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe310000 failed
[ 1.233861] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.234410] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.234966] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp
[ 1.234973] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup
[ 1.234982] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@fe310000[0]’
[ 1.234990] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@fe310000[0]’
[ 1.234997] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup
[ 1.235005] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
[ 1.235233] wifi_platform_bus_enumerate device present 1
[ 1.235708] ======== Card detection to detect SDIO card! ========
[ 1.235738] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.235756] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.235766] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.235799] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.235811] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.235816] dwmmc_rockchip fe320000.dwmmc: Looking up vmmc-supply from device tree
[ 1.235822] dwmmc_rockchip fe320000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe320000 failed
[ 1.235838] dwmmc_rockchip fe320000.dwmmc: Looking up vqmmc-supply from device tree
[ 1.235899] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 1.235910] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer cd
[ 1.235913] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[ 1.235919] of_get_named_gpiod_flags: can’t parse ‘cd-gpios’ property of node ‘/dwmmc@fe320000[0]’
[ 1.235924] of_get_named_gpiod_flags: can’t parse ‘cd-gpio’ property of node ‘/dwmmc@fe320000[0]’
[ 1.235928] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[ 1.235932] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO cd failed
[ 1.235937] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer wp
[ 1.235940] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[ 1.235944] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@fe320000[0]’
[ 1.235949] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@fe320000[0]’
[ 1.235952] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[ 1.235956] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO wp failed
[ 1.236096] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.236230] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.241450] sdio: host isn’t initialization successfully.
[ 1.247370] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.259471] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.260359] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.261462] sdhci-arasan fe330000.sdhci: GPIO lookup for consumer wp
[ 1.261472] sdhci-arasan fe330000.sdhci: using device tree for GPIO lookup
[ 1.261483] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/sdhci@fe330000[0]’
[ 1.261491] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/sdhci@fe330000[0]’
[ 1.261499] sdhci-arasan fe330000.sdhci: using lookup tables for GPIO lookup
[ 1.261507] sdhci-arasan fe330000.sdhci: lookup for GPIO wp failed
[ 1.262606] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply from device tree
[ 1.262617] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply property in node /sdhci@fe330000 failed
[ 1.262645] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply from device tree
[ 1.262655] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe330000 failed
[ 1.262670] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.263207] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.290374] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.292771] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/leds/power[0]’ - status (0)
[ 1.292919] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/leds/user[0]’ - status (0)
[ 1.293092] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.294560] usbcore: registered new interface driver usbhid
[ 1.295050] usbhid: USB HID core driver
[ 1.296845] ashmem: initialized
[ 1.297691] rockchip-saradc ff100000.saradc: Looking up vref-supply from device tree
[ 1.302295] usbcore: registered new interface driver snd-usb-audio
[ 1.303653] of_get_named_gpiod_flags: parsed ‘hp-con-gpio’ property of node ‘/i2c@ff110000/rt5640@1c[0]’ - status (0)
[ 1.303689] of_get_named_gpiod_flags: can’t parse ‘realtek,ldo1-en-gpios’ property of node ‘/i2c@ff110000/rt5640@1c[0]’
[ 1.319803] u32 classifier
[ 1.320056] Netfilter messages via NETLINK v0.30.
[ 1.320563] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.321686] ctnetlink v0.93: registering with nfnetlink.
[ 1.322520] ip_set: protocol 6
[ 1.322818] IPVS: Registered protocols ()
[ 1.323465] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 1.324289] IPVS: Creating netns size=1592 id=0
[ 1.324737] IPVS: ipvs loaded.
[ 1.325597] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.326295] Initializing XFRM netlink socket
[ 1.327889] NET: Registered protocol family 10
[ 1.330644] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.331443] sit: IPv6 over IPv4 tunneling driver
[ 1.332770] NET: Registered protocol family 17
[ 1.333232] NET: Registered protocol family 15
[ 1.333683] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.334852] Bridge firewalling registered
[ 1.335922] mmc1: MAN_BKOPS_EN bit is not set
[ 1.336468] Bluetooth: RFCOMM socket layer initialized
[ 1.336992] Bluetooth: RFCOMM ver 1.11
[ 1.337425] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.337995] Bluetooth: HIDP socket layer initialized
[ 1.339670] 8021q: 802.1Q VLAN Support v1.8
[ 1.340102] lib80211: common routines for IEEE802.11 drivers
[ 1.340633] lib80211_crypt: registered algorithm ‘NULL’
[ 1.340660] lib80211_crypt: registered algorithm ‘WEP’
[ 1.340685] lib80211_crypt: registered algorithm ‘CCMP’
[ 1.340711] lib80211_crypt: registered algorithm ‘TKIP’
[ 1.340731] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.341646] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.345381] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354
[ 1.345990] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.346644] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.347338] of_get_named_gpiod_flags: can’t parse ‘WIFI,poweren_gpio’ property of node ‘/wireless-wlan[0]’
[ 1.347353] of_get_named_gpiod_flags: can’t parse ‘WIFI,reset_gpio’ property of node ‘/wireless-wlan[0]’
[ 1.347409] of_get_named_gpiod_flags: parsed ‘WIFI,host_wake_irq’ property of node ‘/wireless-wlan[0]’ - status (0)
[ 1.347423] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 1.348262] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.348738] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.349325] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.353600] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 1.354726] of_get_named_gpiod_flags: parsed ‘uart_rts_gpios’ property of node ‘/wireless-bluetooth[0]’ - status (0)
[ 1.354742] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 1.355600] of_get_named_gpiod_flags: can’t parse ‘BT,power_gpio’ property of node ‘/wireless-bluetooth[0]’
[ 1.355649] of_get_named_gpiod_flags: parsed ‘BT,reset_gpio’ property of node ‘/wireless-bluetooth[0]’ - status (0)
[ 1.355662] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 1.356429] of_get_named_gpiod_flags: parsed ‘BT,wake_gpio’ property of node ‘/wireless-bluetooth[0]’ - status (0)
[ 1.356441] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 1.357167] of_get_named_gpiod_flags: parsed ‘BT,wake_host_irq’ property of node ‘/wireless-bluetooth[0]’ - status (0)
[ 1.357179] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 1.357950] mmcblk1: mmc1:0001 BJNB4R 29.1 GiB
[ 1.359544] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.359552] mmcblk1boot0: mmc1:0001 BJNB4R partition 1 4.00 MiB
[ 1.360668] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[ 1.360968] mmcblk1boot1: mmc1:0001 BJNB4R partition 2 4.00 MiB
[ 1.361656] [BT_RFKILL]: ** disable irq
[ 1.361740] mmcblk1rpmb: mmc1:0001 BJNB4R partition 3 4.00 MiB
[ 1.362605] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.362734] [BT_RFKILL]: bt_default device registered.
[ 1.362867] Key type dns_resolver registered
[ 1.363993] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 1.364486] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 1.364971] kernel: 0x001c00000 – 0x003000000 (20 MB)
[ 1.365466] backup: 0x003000000 – 0x003400000 (4 MB)
[ 1.365943] boot: 0x003400000 – 0x747800000 (29764 MB)
[ 1.366488] mmcblk1: p1 p2 p3 p4 p5 p6
[ 1.367637] Registered cp15_barrier emulation handler
[ 1.368238] Registered setend emulation handler
[ 1.369888] Loading compiled-in X.509 certificates
[ 1.371181] phy phy-ff770000.syscon:usb2-phy@e450.6: Looking up phy-supply from device tree
[ 1.371224] phy phy-ff770000.syscon:usb2-phy@e450.6: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
[ 1.371614] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: GPIO lookup for consumer otg-vbus
[ 1.371626] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: using device tree for GPIO lookup
[ 1.371639] of_get_named_gpiod_flags: can’t parse ‘otg-vbus-gpios’ property of node ‘/syscon@ff770000/usb2-phy@e450[0]’
[ 1.371651] of_get_named_gpiod_flags: can’t parse ‘otg-vbus-gpio’ property of node ‘/syscon@ff770000/usb2-phy@e450[0]’
[ 1.371661] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: using lookup tables for GPIO lookup
[ 1.371672] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: lookup for GPIO otg-vbus failed
[ 1.371682] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 1.372747] phy phy-ff770000.syscon:usb2-phy@e450.7: Looking up phy-supply from device tree
[ 1.372843] vcc5v0_host: could not add device link phy-ff770000.syscon:usb2-phy@e450.7 err -2
[ 1.373779] phy phy-ff7c0000.phy.8: Looking up phy-supply from device tree
[ 1.373794] phy phy-ff7c0000.phy.8: Looking up phy-supply property in node /phy@ff7c0000/dp-port failed
[ 1.373930] phy phy-ff7c0000.phy.9: Looking up phy-supply from device tree
[ 1.373943] phy phy-ff7c0000.phy.9: Looking up phy-supply property in node /phy@ff7c0000/usb3-port failed
[ 1.374380] mali ff9a0000.gpu: Looking up mali-supply from device tree
[ 1.375796] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 1.377219] I : [File] : drivers/gpu/arm/midgard_for_linux/backend/gpu/mali_kbase_devfreq.c; [Line] : 271; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 1.379220] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 1.379349] mali ff9a0000.gpu: Probed as mali0
[ 1.383272] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 1.384006] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 3
[ 1.384859] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00030010
[ 1.385690] xhci-hcd xhci-hcd.2.auto: irq 227, io mem 0xfe800000
[ 1.386417] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.387016] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.387672] usb usb3: Product: xHCI Host Controller
[ 1.388104] usb usb3: Manufacturer: Linux 4.4.55 xhci-hcd
[ 1.388593] usb usb3: SerialNumber: xhci-hcd.2.auto
[ 1.389649] hub 3-0:1.0: USB hub found
[ 1.390015] hub 3-0:1.0: 1 port detected
[ 1.390765] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 1.391459] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 4
[ 1.392220] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.393048] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.393662] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.394308] usb usb4: Product: xHCI Host Controller
[ 1.394741] usb usb4: Manufacturer: Linux 4.4.55 xhci-hcd
[ 1.395234] usb usb4: SerialNumber: xhci-hcd.2.auto
[ 1.396256] hub 4-0:1.0: USB hub found
[ 1.396625] hub 4-0:1.0: 1 port detected
[ 1.398774] xhci-hcd xhci-hcd.2.auto: remove, state 1
[ 1.399257] usb usb4: USB disconnect, device number 1
[ 1.423675] xhci-hcd xhci-hcd.2.auto: Host not halted after 16000 microseconds.
[ 1.424316] xhci-hcd xhci-hcd.2.auto: Host controller not halted, aborting reset.
[ 1.425001] xhci-hcd xhci-hcd.2.auto: USB bus 4 deregistered
[ 1.425727] xhci-hcd xhci-hcd.2.auto: remove, state 1
[ 1.426182] usb usb3: USB disconnect, device number 1
[ 1.427137] xhci-hcd xhci-hcd.2.auto: USB bus 3 deregistered
[ 1.431684] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[ 1.432446] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 3
[ 1.433272] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00030010
[ 1.434072] xhci-hcd xhci-hcd.3.auto: irq 228, io mem 0xfe900000
[ 1.434751] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.435370] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.436002] usb usb3: Product: xHCI Host Controller
[ 1.436443] usb usb3: Manufacturer: Linux 4.4.55 xhci-hcd
[ 1.436917] usb usb3: SerialNumber: xhci-hcd.3.auto
[ 1.437833] hub 3-0:1.0: USB hub found
[ 1.438198] hub 3-0:1.0: 1 port detected
[ 1.438809] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[ 1.439421] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 4
[ 1.440142] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.440938] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.441542] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.442173] usb usb4: Product: xHCI Host Controller
[ 1.442607] usb usb4: Manufacturer: Linux 4.4.55 xhci-hcd
[ 1.443081] usb usb4: SerialNumber: xhci-hcd.3.auto
[ 1.443959] hub 4-0:1.0: USB hub found
[ 1.444339] hub 4-0:1.0: 1 port detected
[ 1.446982] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.447653] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 1.448452] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 1.488415] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.489395] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.490007] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.490709] usb usb5: Product: EHCI Host Controller
[ 1.491152] usb usb5: Manufacturer: Linux 4.4.55 ehci_hcd
[ 1.491666] usb usb5: SerialNumber: fe380000.usb
[ 1.493540] hub 5-0:1.0: USB hub found
[ 1.493941] hub 5-0:1.0: 1 port detected
[ 1.496284] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.497709] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 1.498791] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 1.498830] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 1.499981] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.500641] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 1.502811] hub 1-1:1.0: USB hub found
[ 1.503975] hub 1-1:1.0: 7 ports detected
[ 1.553913] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.554564] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.555236] usb usb6: Product: Generic Platform OHCI controller
[ 1.555769] usb usb6: Manufacturer: Linux 4.4.55 ohci_hcd
[ 1.556277] usb usb6: SerialNumber: fe3a0000.usb
[ 1.558134] hub 6-0:1.0: USB hub found
[ 1.558585] hub 6-0:1.0: 1 port detected
[ 1.561826] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.562552] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.563171] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.563759] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.564678] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.565430] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
[ 1.565456] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe310000 failed
[ 1.565523] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
[ 1.565547] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe310000 failed
[ 1.565587] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.566140] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.566744] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp
[ 1.566762] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup
[ 1.566786] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@fe310000[0]’
[ 1.566806] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@fe310000[0]’
[ 1.566824] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup
[ 1.566845] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
[ 1.567291] platform sdio-pwrseq: GPIO lookup for consumer reset
[ 1.567311] platform sdio-pwrseq: using device tree for GPIO lookup
[ 1.567371] of_get_named_gpiod_flags: parsed ‘reset-gpios’ property of node ‘/sdio-pwrseq[0]’ - status (0)
[ 1.567431] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 1.579629] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.591712] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 1.593499] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,hp-det-gpio’ property of node ‘/rt5640-sound[0]’
[ 1.593522] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,mic-det-gpio’ property of node ‘/rt5640-sound[0]’
[ 1.607101] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mapping ok
[ 1.617141] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card0/input0
[ 1.620685] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,hp-det-gpio’ property of node ‘/spdif-sound[0]’
[ 1.620712] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,mic-det-gpio’ property of node ‘/spdif-sound[0]’
[ 1.621334] rockchip-spdif ff870000.spdif: Missing dma channel for stream: 0
[ 1.621970] rockchip-spdif ff870000.spdif: ASoC: pcm constructor failed: -22
[ 1.622631] asoc-simple-card spdif-sound: ASoC: can’t create pcm ff870000.spdif-dit-hifi :-22
[ 1.623415] asoc-simple-card spdif-sound: ASoC: failed to instantiate card -22
[ 1.624472] asoc-simple-card: probe of spdif-sound failed with error -22
[ 1.626347] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/gpio-keys/button@0[0]’ - status (0)
[ 1.626437] gpio-5 (GPIO Key Power): gpiod_set_debounce: missing set() or set_debounce() operations
[ 1.626977] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 1.629961] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:02 UTC (1358499002)
[ 1.639526] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.641707] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.643917] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.647398] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.668996] ret 1024
[ 1.670591] ALSA device list:
[ 1.670860] #0: rockchip,rt5640-codec
[ 1.672491] EXT4-fs (mmcblk1p6): couldn’t mount as ext3 due to feature incompatibilities
[ 1.673921] EXT4-fs (mmcblk1p6): couldn’t mount as ext2 due to feature incompatibilities
[ 1.706490] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 1.744764] EXT4-fs (mmcblk1p6): recovery complete
[ 1.745735] EXT4-fs (mmcblk1p6): mounted filesystem with ordered data mode. Opts: (null)
[ 1.746510] VFS: Mounted root (ext4 filesystem) on device 179:6.
[ 1.747535] devtmpfs: mounted
[ 1.748339] Freeing unused kernel memory: 1152K (ffffff8008fb0000 - ffffff80090d0000)
[ 1.813709] systemd[1]: System time before build time, advancing clock.
[ 1.826788] systemd[1]: Failed to insert module ‘autofs4’: No such file or directory
[ 1.839064] random: systemd: uninitialized urandom read (16 bytes read, 40 bits of entropy available)
[ 1.842636] random: systemd: uninitialized urandom read (16 bytes read, 40 bits of entropy available)
[ 1.846140] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 1.849473] systemd[1]: Detected architecture arm64.
[ 1.852317] systemd[1]: Set hostname to .
[ 1.896456] vendor storage:20160801 ret = 0
[ 1.902406] random: systemd: uninitialized urandom read (16 bytes read, 47 bits of entropy available)
[ 1.907294] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 47 bits of entropy available)
[ 1.912739] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 47 bits of entropy available)
[ 1.915524] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 47 bits of entropy available)
[ 1.916862] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 47 bits of entropy available)
[ 1.917904] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 47 bits of entropy available)
[ 1.920006] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 48 bits of entropy available)
[ 1.923441] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 48 bits of entropy available)
[ 2.031690] systemd[1]: Created slice System Slice.
[ 2.032743] systemd[1]: Listening on udev Control Socket.
[ 2.033565] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 2.034616] systemd[1]: Listening on Syslog Socket.
[ 2.035555] systemd[1]: Reached target Remote File Systems (Pre).
[ 2.036596] systemd[1]: Reached target User and Group Name Lookups.
[ 2.037748] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.039166] systemd[1]: Created slice User and Session Slice.
[ 2.039974] systemd[1]: Reached target Encrypted Volumes.
[ 2.041020] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.041975] systemd[1]: Listening on udev Kernel Socket.
[ 2.042920] systemd[1]: Reached target Swap.
[ 2.044151] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 2.052787] systemd[1]: Listening on Journal Socket.
[ 2.055172] systemd[1]: Starting Set console keymap…
[ 2.058352] systemd[1]: Starting Create Static Device Nodes in /dev…
[ 2.062129] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 2.064699] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 234
[ 2.068081] systemd[1]: Starting Journal Service…
[ 2.068344] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.068379] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[ 2.072340] systemd[1]: Mounting Debug File System…
[ 2.073176] systemd[1]: Reached target Slices.
[ 2.077600] systemd[1]: Starting Load Kernel Modules…
[ 2.078469] systemd[1]: Reached target Remote File Systems.
[ 2.082735] systemd[1]: Started Remount Root and Kernel File Systems.
[ 2.085353] bcmsdh_register: register client driver
[ 2.085963] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.086598] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.087067] bus num (host idx)=2, slot num (rca)=1
[ 2.087525] found adapter info ‘DHD generic adapter’
[ 2.088081] sdioh_attach: set sd_f2_blocksize 128
[ 2.088827] bcmsdh_probe: Host OOB irq is not defined
[ 2.089298] sdioh_probe: bcmsdh_probe failed
[ 2.089964] bcmsdh_sdmmc: probe of mmc2:0001:2 failed with error -12
[ 2.095905] systemd[1]: Mounted Debug File System.
[ 2.097895] systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
[ 2.099728] systemd[1]: Failed to start Load Kernel Modules.
[ 2.100953] systemd[1]: systemd-modules-load.service: Unit entered failed state.
[ 2.102096] systemd[1]: systemd-modules-load.service: Failed with result ‘exit-code’.
[ 2.103586] systemd[1]: Started Create Static Device Nodes in /dev.
[ 2.160016] systemd[1]: Starting udev Kernel Device Manager…
[ 2.162520] systemd[1]: Starting Apply Kernel Variables…
[ 2.165145] systemd[1]: Mounting Configuration File System…
[ 2.167969] systemd[1]: Mounting FUSE Control File System…
[ 2.179761] systemd[1]: Starting udev Coldplug all Devices…
[ 2.182065] systemd[1]: Starting Load/Save Random Seed…
[ 2.185645] systemd[1]: Mounted Configuration File System.
[ 2.186016] systemd[1]: Mounted FUSE Control File System.
[ 2.187093] systemd[1]: Started Apply Kernel Variables.
[ 2.197174] systemd[1]: Started Load/Save Random Seed.
[ 2.199141] systemd[1]: Started Set console keymap.
[ 2.226103] systemd[1]: Started Journal Service.
[ 2.277571] systemd-journald[196]: Received request to flush runtime journal from PID 1
[ 3.240145] IPVS: Creating netns size=1592 id=1
[ 3.269352] [BT_RFKILL]: ENABLE UART_RTS
[ 3.335445] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 3.335634] eth0: device MAC address 7a:ea:9c:8f:61:cf
[ 3.370229] [BT_RFKILL]: DISABLE UART_RTS
[ 3.370332] [BT_RFKILL]: bt turn on power
[ 3.370998] [BT_RFKILL]: bt shut off power
[ 3.383129] tty_port_close_start: tty->count = 1 port count = 2.
[ 3.479442] cfg80211: World regulatory domain updated:
[ 3.479455] cfg80211: DFS Master region: unset
[ 3.479459] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 3.479468] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 3.479474] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 3.479479] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 3.479485] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 3.479490] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 3.479495] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 3.479500] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 3.479505] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 3.537311] random: nonblocking pool is initialized
[ 4.470303] [BT_RFKILL]: ENABLE UART_RTS
[ 4.571293] [BT_RFKILL]: DISABLE UART_RTS
[ 4.571337] [BT_RFKILL]: bt turn on power
[ 5.630298] ttyS0 - failed to request DMA
[ 14.090587] dhd_wifi_platform_load_sdio: sdio_register_driver timeout or error
[ 14.090847] wifi_platform_set_power = 0
[ 14.090862] ======== PULL WL_REG_ON LOW! ========
[ 14.090877] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 14.090910] [WLAN_RFKILL]: wifi shut off power.
[ 14.090924] wifi_platform_bus_enumerate device present 0
[ 14.090936] ======== Card detection to remove SDIO card! ========
[ 14.090950] mmc2:mmc host rescan start!
[ 14.091021] unregister wifi platform drivers
[ 14.091035] wifi_platform_bus_enumerate device present 0
[ 14.091047] ======== Card detection to remove SDIO card! ========
[ 14.091059] mmc2:mmc host rescan start!
[ 14.091076] dhd_module_init: Failed to load the driver, try cnt 0
[ 14.091140] dhd_module_init: Failed to load driver max retry reached**
[ 14.091153] dhd_module_init: Exit err=-62
[ 16.771325] Bluetooth: hci0 command 0x1003 tx timeout
[ 18.775572] Bluetooth: hci0 command 0x1001 tx timeout
[ 20.779575] Bluetooth: hci0 command 0x1009 tx timeout
[ 26.767441] Bluetooth: hci0 command 0x1003 tx timeout
[ 26.770977] Bluetooth: hci0 hardware error 0x00
[ 28.775478] Bluetooth: hci0 command 0x1003 tx timeout
[ 30.779465] Bluetooth: hci0 command 0x1001 tx timeout
[ 32.783485] Bluetooth: hci0 command 0x1009 tx timeout
[ 49.140553] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 49.178691] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 94.163481] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 94.216060] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
zouxf 发表于 2017-6-9 15:16
内核的源码会持续更新,不可能每更新一次内核源码,就重新发布一版固件的。
HDMI没有显示,
- 提供内核 …
不是每次更新源码就重新发布一版固件。而是每次发布固件的时候同时把对应的内核源码commit版本写出来。这样对于开发者来说有一个确定好用的基础代码。
希望官方考虑。![]()
