从gitlab上拿更新的kernel(ffc1a16eb9081347d4c32b9b2332d7d4e5b1fcd5)编译后HDMI显示正常了。赞官方的及时回复。
但是,这个版本的wifi不工作了。。。
下面是bootlog和dmesg log。
但是,这个版本的wifi不工作了。。。
boot log:
DDR Version 1.07 20161103
Channel 0: DDR3, 666MHz
Channel 1: DDR3, 666MHz
256B stride
pmugrf_os_reg[2] = 0x3AA17AA1, stride = 0xD
Boot1: 2016-07-29, version: 1.05
CPUId = 0x0
ChipType = 10 1842
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=29820MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 62439
LoadTrustBL
No find bl30.bin
No find bl32.bin
theLoader 200000 78322
LoaderFlag2: 0x0
WARNING: plat_rockchip_comm_sram_init:code:ff8d9000, 67000, ef0
NOTICE: BL31: v1.2(debug):b995f80
NOTICE: BL31: Built : 16:53:56, Nov 7 2016
INFO: boot cpu mask: 0
INFO: Vesion: 2016.0.01
INFO: plat_rockchip_pmu_init(1211): pd status 3e
INFO: SPSR = 0x3c9
U-Boot 2017.02-RK3399-06-ga7c7ca8 (Apr 25 2017 - 15:10:21)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
aclk_periph_h = 148500000HZ, hclk_periph_h = 74250000HZ, pclk_periph_h = 37125000HZ
aclk_periph_l0 = 99000000HZ, hclk_periph_l0 = 99000000HZ, pclk_periph_l0 = 49500000HZ
hclk_periph_l1 = 99000000HZ, pclk_periph_l1 = 49500000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from resource image.
no key node
pmic:rk808
can’t find dts node for pwm1
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2017-04-25#1.05
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
misc partition not found!
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x011a33c0)
ramdisk @ 0x05bf0000 (0x00000000)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000005600000, end 0000000005613fa3 … OK
Add bank:0000000000200000, 00000000f7e00000
[ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.4.55 (hunter@hunter-K501LX) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #3 SMP Sat Jun 10 11:15:22 CST 2017 [ 0.000000] Boot CPU: AArch64 Processor [410fd034] [ 0.000000] Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7ee8000 s46144 r8192 d31680 u86016 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 999432 [ 0.000000] Kernel command line: console=ttyFIQ0 root=/dev/mmcblk1p6 rw rootwait mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00008000@0x00006000(resource),0x0000A000@0x0000E000(kernel),0x00002000@0x00018000(backup),-@0x0001A000(boot) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2017-04-25_15:10:21 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] software IO TLB [mem 0xef600000-0xf3600000] (64MB) mapped at [ffffffc0ef600000-ffffffc0f35fffff] [ 0.000000] Memory: 3903476K/4061184K available (11454K kernel code, 1356K rwdata, 4032K rodata, 1152K init, 767K bss, 157708K reserved, 0K cma-reserved) [ 0.000000] Virtual kernel memory layout: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB) [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB) [ 0.000000] .init : 0xffffff8008fb0000 - 0xffffff80090d0000 ( 1152 KB) [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008bb0000 ( 11456 KB) [ 0.000000] .rodata : 0xffffff8008bb0000 - 0xffffff8008fb0000 ( 4096 KB) [ 0.000000] .data : 0xffffff80090d0000 - 0xffffff80092233c0 ( 1357 KB) [ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum) [ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual) [ 0.000000] fixed : 0xffffffbffe7fd000 - 0xffffffbffec00000 ( 4108 KB) [ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB) [ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 64. [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6 [ 0.000000] NR_IRQS:64 nr_irqs:64 0 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000 [ 0.000000] ITS: allocated 65536 Devices @ef000000 (psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GIC: using LPI property table @0x00000000ef080000 [ 0.000000] ITS: Allocated 1792 chunks for LPIs [ 0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000 [ 0.000000] CPU0: using LPI pending table @0x00000000ef090000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] } [ 0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] } [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001199] Console: colour dummy device 80x25 [ 0.001226] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000) [ 0.001239] pid_max: default: 32768 minimum: 301 [ 0.001331] Security Framework initialized [ 0.001341] Yama: becoming mindful. [ 0.001426] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.001438] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.002266] Initializing cgroup subsys devices [ 0.002284] Initializing cgroup subsys freezer [ 0.002312] ftrace: allocating 43004 entries in 168 pages [ 0.119854] sched-energy: Sched-energy-costs installed from DT [ 0.119874] CPU0: update cpu_capacity 401 [ 0.119932] ASID allocator initialised with 65536 entries [ 0.120765] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.121187] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.122322] Detected VIPT I-cache on CPU1 [ 0.122357] CPU1: found redistributor 1 region 0:0x00000000fef20000 [ 0.122393] CPU1: using LPI pending table @0x00000000ef2a0000 [ 0.122438] CPU1: update cpu_capacity 401 [ 0.122442] CPU1: Booted secondary processor [410fd034] [ 0.122980] Detected VIPT I-cache on CPU2 [ 0.123001] CPU2: found redistributor 2 region 0:0x00000000fef40000 [ 0.123034] CPU2: using LPI pending table @0x00000000ef2d0000 [ 0.123064] CPU2: update cpu_capacity 401 [ 0.123067] CPU2: Booted secondary processor [410fd034] [ 0.123541] Detected VIPT I-cache on CPU3 [ 0.123562] CPU3: found redistributor 3 region 0:0x00000000fef60000 [ 0.123596] CPU3: using LPI pending table @0x00000000ef300000 [ 0.123624] CPU3: update cpu_capacity 401 [ 0.123628] CPU3: Booted secondary processor [410fd034] [ 0.124141] Detected PIPT I-cache on CPU4 [ 0.124169] CPU4: found redistributor 100 region 0:0x00000000fef80000 [ 0.124204] CPU4: using LPI pending table @0x00000000ef350000 [ 0.124248] CPU4: update cpu_capacity 1024 [ 0.124251] CPU4: Booted secondary processor [410fd082] [ 0.124770] Detected PIPT I-cache on CPU5 [ 0.124789] CPU5: found redistributor 101 region 0:0x00000000fefa0000 [ 0.124822] CPU5: using LPI pending table @0x00000000ef380000 [ 0.124851] CPU5: update cpu_capacity 1024 [ 0.124854] CPU5: Booted secondary processor [410fd082] [ 0.124939] Brought up 6 CPUs [ 0.125022] SMP: Total of 6 processors activated. [ 0.125031] CPU features: detected feature: GIC system register CPU interface [ 0.125043] CPU: All CPU(s) started at EL2 [ 0.125091] alternatives: patching kernel code [ 0.126459] devtmpfs: initialized [ 0.146817] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns [ 0.146848] futex hash table entries: 2048 (order: 5, 131072 bytes) [ 0.147382] pinctrl core: initialized pinctrl subsystem [ 0.148477] NET: Registered protocol family 16 [ 0.152149] cpuidle: using governor ladder [ 0.156172] cpuidle: using governor menu [ 0.156195] Registered FIQ tty driver [ 0.156590] vdso: 2 pages (1 code @ ffffff8008bb6000, 1 data @ ffffff80090d4000) [ 0.156625] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.156821] DMA: preallocated 256 KiB pool for atomic allocations [ 0.247331] console [ttyFIQ0] enabled [ 0.247857] Registered fiq debugger ttyFIQ0 [ 0.270416] ACPI: Interpreter disabled. [ 0.273173] iommu: Adding device ff650000.vpu_service to group 0 [ 0.273783] iommu: Adding device ff660000.rkvdec to group 1 [ 0.274358] iommu: Adding device ff8f0000.vop to group 2 [ 0.274906] iommu: Adding device ff900000.vop to group 3 [ 0.276542] vgaarb: loaded [ 0.277063] SCSI subsystem initialized [ 0.277561] usbcore: registered new interface driver usbfs [ 0.278088] usbcore: registered new interface driver hub [ 0.278637] usbcore: registered new device driver usb [ 0.279175] media: Linux media interface: v0.10 [ 0.279603] Linux video capture interface: v2.00 [ 0.280054] pps_core: LinuxPPS API ver. 1 registered [ 0.280498] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.281309] PTP clock support registered [ 0.282602] Advanced Linux Sound Architecture Driver Initialized. [ 0.283640] Bluetooth: Core ver 2.21 [ 0.283975] NET: Registered protocol family 31 [ 0.284376] Bluetooth: HCI device and connection manager initialized [ 0.284937] Bluetooth: HCI socket layer initialized [ 0.285368] Bluetooth: L2CAP socket layer initialized [ 0.285839] Bluetooth: SCO socket layer initialized [ 0.287064] clocksource: Switched to clocksource arch_sys_counter [ 0.317441] pnp: PnP ACPI: disabled [ 0.325716] thermal thermal_zone1: power_allocator: sustainable_power will be estimated [ 0.326647] NET: Registered protocol family 2 [ 0.327481] TCP established hash table entries: 32768 (order: 6, 262144 bytes) [ 0.328306] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes) [ 0.329437] TCP: Hash tables configured (established 32768 bind 32768) [ 0.330114] UDP hash table entries: 2048 (order: 5, 196608 bytes) [ 0.330772] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes) [ 0.331685] NET: Registered protocol family 1 [ 0.332369] RPC: Registered named UNIX socket transport module. [ 0.332893] RPC: Registered udp transport module. [ 0.333322] RPC: Registered tcp transport module. [ 0.333735] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.334932] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.335754] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.339385] Initialise system trusted keyring [ 0.347100] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.349255] NFS: Registering the id_resolver key type [ 0.349718] Key type id_resolver registered [ 0.350102] Key type id_legacy registered [ 0.350467] Installing knfsd (copyright (C) 1996 [email]okir@monad.swb.de[/email]). [ 0.351695] fuse init (API version 7.23) [ 0.355949] NET: Registered protocol family 38 [ 0.356372] Key type asymmetric registered [ 0.356738] Asymmetric key parser 'x509' registered [ 0.357334] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [ 0.357988] io scheduler noop registered [ 0.358351] io scheduler deadline registered [ 0.358843] io scheduler cfq registered (default) [ 0.360554] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned [ 0.365762] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found [ 0.366371] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found [ 0.366947] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found [ 0.909107] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout! [ 0.909746] rockchip-pcie: probe of f8000000.pcie failed with error -110 [ 0.911012] rk-vcodec ff650000.vpu_service: No core reset resource define [ 0.911661] rk-vcodec ff650000.vpu_service: do not have pd_video [ 0.912211] rk-vcodec ff650000.vpu_service: probe device [ 0.912709] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0ee9a3c10 [ 0.913466] rk-vcodec ff650000.vpu_service: allocator is drm [ 0.914013] rk-vcodec ff650000.vpu_service: checking hw id 0 [ 0.914942] rk-vcodec ff650000.vpu_service: init success [ 0.915794] rk-vcodec ff660000.rkvdec: No core reset resource define [ 0.916466] rk-vcodec ff660000.rkvdec: do not have pd_video [ 0.916965] rk-vcodec ff660000.rkvdec: probe device [ 0.917440] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0ee9a8410 [ 0.918140] rk-vcodec ff660000.rkvdec: allocator is drm [ 0.918648] rk-vcodec ff660000.rkvdec: checking hw id 6876 [ 0.919441] rk-vcodec ff660000.rkvdec: init success [ 0.921250] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.921916] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12 [ 0.924142] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.924807] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 0.926635] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 0.928757] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A [ 0.930150] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A [ 0.931890] [drm:drm_core_init] Initialized drm 1.1.0 20060810 [ 0.935302] usbcore: registered new interface driver udl [ 0.936997] mali ff9a0000.gpu: Failed to get regulator [ 0.937462] mali ff9a0000.gpu: Power control initialization failed [ 0.938334] Unable to detect cache hierarchy from DT for CPU 0 [ 0.947111] brd: module loaded [ 0.952254] loop: module loaded [ 0.953074] zram: Added device: zram0 [ 0.953687] lkdtm: No crash points registered, enable through debugfs [ 0.955021] tun: Universal TUN/TAP device driver, 1.6 [ 0.955480] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 0.957346] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input). [ 0.957966] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28). [ 0.958477] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11). [ 0.959167] rk_gmac-dwmac fe300000.ethernet: clock input from PHY [ 0.959702] rk_gmac-dwmac fe300000.ethernet: init for RGMII [ 0.965270] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 0.965712] Ring mode enabled [ 0.965982] DMA HW capability register supported [ 0.966388] Normal descriptors [ 0.966682] RX Checksum Offload Engine supported (type 2) [ 0.967168] TX Checksum insertion supported [ 0.967542] Wake-Up On Lan supported [ 0.967895] Enable RX Mitigation via HW Watchdog Timer [ 1.030951] libphy: stmmac: probed [ 1.031269] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active [ 1.031834] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01) [ 1.033317] PPP generic driver version 2.4.2 [ 1.033916] usbcore: registered new interface driver rndis_wlan [ 1.034689] dhd_module_init: in [ 1.034699] [ 1.034701] ======================================================= [ 1.034703] ==== Launching Wi-Fi driver! (Powered by Rockchip) ==== [ 1.034704] ======================================================= [ 1.034706] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD) init. [ 1.034710] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ 1.034713] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized [ 1.034715] RTL871X: module init start [ 1.034718] RTL871X: rtl8188eu v4.3.24_16705.20160509 [ 1.034794] usbcore: registered new interface driver rtl8188eu [ 1.034796] RTL871X: module init ret=0 [ 1.034806] Rockchip WiFi SYS interface (V1.00) ... [ 1.034839] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 1.034874] usbcore: registered new interface driver pegasus [ 1.034911] usbcore: registered new interface driver rtl8150 [ 1.034946] usbcore: registered new interface driver r8152 [ 1.034989] usbcore: registered new interface driver asix [ 1.035028] usbcore: registered new interface driver ax88179_178a [ 1.035095] usbcore: registered new interface driver cdc_ether [ 1.035132] usbcore: registered new interface driver dm9601 [ 1.035180] usbcore: registered new interface driver smsc75xx [ 1.035226] usbcore: registered new interface driver smsc95xx [ 1.035265] usbcore: registered new interface driver net1080 [ 1.035300] usbcore: registered new interface driver rndis_host [ 1.035337] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 1.035403] usbcore: registered new interface driver cdc_ncm [ 1.035440] usbcore: registered new interface driver cdc_mbim [ 1.036672] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3 [ 1.040260] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd [ 1.041313] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.041323] ehci-pci: EHCI PCI platform driver [ 1.041372] ehci-platform: EHCI generic platform driver [ 1.043197] ehci-platform fe3c0000.usb: EHCI Host Controller [ 1.043338] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1 [ 1.043430] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000 [ 1.049072] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00 [ 1.049196] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.049202] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.049207] usb usb1: Product: EHCI Host Controller [ 1.049212] usb usb1: Manufacturer: Linux 4.4.55 ehci_hcd [ 1.049216] usb usb1: SerialNumber: fe3c0000.usb [ 1.049628] hub 1-0:1.0: USB hub found [ 1.049652] hub 1-0:1.0: 1 port detected [ 1.050144] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.050157] ohci-pci: OHCI PCI platform driver [ 1.050203] ohci-platform: OHCI generic platform driver [ 1.050689] ohci-platform fe3e0000.usb: Generic Platform OHCI controller [ 1.050830] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2 [ 1.050912] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000 [ 1.059549] ======== bcm_wlan_set_plat_data ======== [ 1.059985] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter [ 1.060481] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: rfkill-wlan driver has not Successful initialized [ 1.061305] host_oob_irq: -1 [ 1.061560] host_oob_irq_flags=0x4 [ 1.061858] dhd_wifi_platform_load: Enter [ 1.062236] Power-up adapter 'DHD generic adapter' [ 1.062689] wifi_platform_set_power = 1 [ 1.063026] ======== PULL WL_REG_ON HIGH! ======== [ 1.063458] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ 1.063871] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized [ 1.105214] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.105813] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.106460] usb usb2: Product: Generic Platform OHCI controller [ 1.106980] usb usb2: Manufacturer: Linux 4.4.55 ohci_hcd [ 1.107463] usb usb2: SerialNumber: fe3e0000.usb [ 1.108298] hub 2-0:1.0: USB hub found [ 1.108652] hub 2-0:1.0: 1 port detected [ 1.109806] usbcore: registered new interface driver cdc_acm [ 1.110319] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.111064] usbcore: registered new interface driver cdc_wdm [ 1.111632] usbcore: registered new interface driver usb-storage [ 1.112243] usbcore: registered new interface driver usbserial [ 1.112780] usbcore: registered new interface driver usbserial_generic [ 1.113385] usbserial: USB Serial support registered for generic [ 1.113943] usbcore: registered new interface driver cp210x [ 1.114462] usbserial: USB Serial support registered for cp210x [ 1.115021] usbcore: registered new interface driver ftdi_sio [ 1.115557] usbserial: USB Serial support registered for FTDI USB Serial Device [ 1.116283] usbcore: registered new interface driver keyspan [ 1.116798] usbserial: USB Serial support registered for Keyspan - (without firmware) [ 1.117511] usbserial: USB Serial support registered for Keyspan 1 port adapter [ 1.118178] usbserial: USB Serial support registered for Keyspan 2 port adapter [ 1.118835] usbserial: USB Serial support registered for Keyspan 4 port adapter [ 1.119519] usbcore: registered new interface driver option [ 1.120026] usbserial: USB Serial support registered for GSM modem (1-port) [ 1.120744] usbcore: registered new interface driver oti6858 [ 1.121270] usbserial: USB Serial support registered for oti6858 [ 1.121826] usbcore: registered new interface driver pl2303 [ 1.122346] usbserial: USB Serial support registered for pl2303 [ 1.122901] usbcore: registered new interface driver qcserial [ 1.123437] usbserial: USB Serial support registered for Qualcomm USB modem [ 1.124095] usbcore: registered new interface driver sierra [ 1.124606] usbserial: USB Serial support registered for Sierra USB modem [ 1.125927] usbcore: registered new interface driver iforce [ 1.126489] usbcore: registered new interface driver xpad [ 1.127245] usbcore: registered new interface driver usbtouchscreen [ 1.128129] i2c /dev entries driver [ 1.129594] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected! [ 1.130288] fan53555-reg: supplied by vcc5v0_sys [ 1.132935] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected! [ 1.133600] fan53555-reg: supplied by vcc5v0_sys [ 1.136599] rk808 0-001b: Pmic Chip id: 0x0 [ 1.140179] rk808-regulator rk808-regulator: there is no dvs0 gpio [ 1.140762] rk808-regulator rk808-regulator: there is no dvs1 gpio [ 1.141398] DCDC_REG1: supplied by vcc3v3_sys [ 1.142494] DCDC_REG2: supplied by vcc3v3_sys [ 1.143408] DCDC_REG3: supplied by vcc3v3_sys [ 1.144030] DCDC_REG4: supplied by vcc3v3_sys [ 1.144825] LDO_REG1: supplied by vcc3v3_sys [ 1.146286] LDO_REG2: supplied by vcc3v3_sys [ 1.147590] LDO_REG3: supplied by vcc3v3_sys [ 1.148894] LDO_REG4: supplied by vcc3v3_sys [ 1.150234] LDO_REG5: supplied by vcc3v3_sys [ 1.151533] LDO_REG6: supplied by vcc3v3_sys [ 1.152830] LDO_REG7: supplied by vcc3v3_sys [ 1.154171] LDO_REG8: supplied by vcc3v3_sys [ 1.155468] SWITCH_REG1: supplied by vcc3v3_sys [ 1.156124] SWITCH_REG2: supplied by vcc3v3_sys [ 1.159920] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0 [ 1.160936] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009568000 [ 1.162203] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff800956a000 [ 1.162928] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c [ 1.163861] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22 [ 1.164451] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl [ 1.165428] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back [ 1.166403] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff800956c000 [ 1.177083] fusb302 4-0022: port 0 probe success [ 1.177513] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff800956e000 [ 1.179213] IR NEC protocol handler initialized [ 1.179616] IR RC5(x/sz) protocol handler initialized [ 1.180077] IR RC6 protocol handler initialized [ 1.180480] IR JVC protocol handler initialized [ 1.180882] IR Sony protocol handler initialized [ 1.181300] IR SANYO protocol handler initialized [ 1.181718] IR Sharp protocol handler initialized [ 1.182148] IR MCE Keyboard/mouse protocol handler initialized [ 1.182664] IR XMP protocol handler initialized [ 1.183147] usbcore: registered new interface driver uvcvideo [ 1.183649] USB Video Class driver (1.1.1) [ 1.185298] rockchip_cpu_avs: cluster0 leakage=20 adjust_volt=0 [ 1.185844] rockchip_cpu_avs: cluster1 leakage=33 adjust_volt=0 [ 1.187680] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647 [ 1.189214] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: [email]dm-devel@redhat.com[/email] [ 1.190107] Bluetooth: Virtual HCI driver ver 1.5 [ 1.190627] Bluetooth: HCI UART driver ver 2.3 [ 1.191020] Bluetooth: HCI UART protocol H4 registered [ 1.191482] Bluetooth: HCI UART protocol LL registered [ 1.191932] Bluetooth: HCI UART protocol ATH3K registered [ 1.192474] usbcore: registered new interface driver bfusb [ 1.193003] usbcore: registered new interface driver btusb [ 1.197920] sdhci: Secure Digital Host Controller Interface driver [ 1.198474] sdhci: Copyright(c) Pierre Ossman [ 1.198859] Synopsys Designware Multimedia Card Interface Driver [ 1.200233] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode. [ 1.200891] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller. [ 1.201503] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a [ 1.202043] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo [ 1.202928] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated. [ 1.203708] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found [ 1.204256] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found [ 1.205582] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode. [ 1.206245] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller. [ 1.206845] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a [ 1.207391] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo [ 1.208257] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated. [ 1.209086] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found [ 1.209868] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done [ 1.210663] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done [ 1.222121] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 1.233337] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized [ 1.234226] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.236520] sdhci-arasan fe330000.sdhci: No vmmc regulator found [ 1.237046] sdhci-arasan fe330000.sdhci: No vqmmc regulator found [ 1.249478] fusb302 4-0022: CC connected in 0 as UFP [ 1.263154] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA [ 1.265080] wifi_platform_bus_enumerate device present 1 [ 1.265552] ======== Card detection to detect SDIO card! ======== [ 1.265688] hidraw: raw HID events driver (C) Jiri Kosina [ 1.266467] usbcore: registered new interface driver usbhid [ 1.266469] usbhid: USB HID core driver [ 1.266729] ashmem: initialized [ 1.267666] sdio: host isn't initialization successfully. [ 1.269540] usbcore: registered new interface driver snd-usb-audio [ 1.285518] u32 classifier [ 1.285772] Netfilter messages via NETLINK v0.30. [ 1.286271] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 1.287126] ctnetlink v0.93: registering with nfnetlink. [ 1.287739] ip_set: protocol 6 [ 1.288017] IPVS: Registered protocols () [ 1.288535] IPVS: Connection hash table configured (size=4096, memory=64Kbytes) [ 1.289269] IPVS: Creating netns size=1592 id=0 [ 1.289694] IPVS: ipvs loaded. [ 1.290270] ip_tables: (C) 2000-2006 Netfilter Core Team [ 1.290841] Initializing XFRM netlink socket [ 1.291839] NET: Registered protocol family 10 [ 1.293318] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 1.295008] sit: IPv6 over IPv4 tunneling driver [ 1.295971] NET: Registered protocol family 17 [ 1.296398] NET: Registered protocol family 15 [ 1.296821] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this. [ 1.297954] Bridge firewalling registered [ 1.298612] Bluetooth: RFCOMM socket layer initialized [ 1.299100] Bluetooth: RFCOMM ver 1.11 [ 1.299443] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 1.299967] Bluetooth: HIDP socket layer initialized [ 1.300782] 8021q: 802.1Q VLAN Support v1.8 [ 1.301186] lib80211: common routines for IEEE802.11 drivers [ 1.301723] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 1.302423] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 1.302893] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354 [ 1.303506] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 1.304137] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 1.304832] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0. [ 1.305628] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 1.306096] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 1.306555] [BT_RFKILL]: Enter rfkill_rk_init [ 1.306962] mmc1: MAN_BKOPS_EN bit is not set [ 1.307701] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83. [ 1.308477] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9. [ 1.309206] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90. [ 1.309916] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4. [ 1.311469] [BT_RFKILL]: Request irq for bt wakeup host [ 1.313066] [BT_RFKILL]: ** disable irq [ 1.313113] [BT_RFKILL]: BT_WAKE_HOST IRQ fired [ 1.313932] [BT_RFKILL]: bt_default device registered. [ 1.314459] Key type dns_resolver registered [ 1.317367] Registered cp15_barrier emulation handler [ 1.318409] Registered setend emulation handler [ 1.320944] Loading compiled-in X.509 certificates [ 1.323041] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned [ 1.324241] mmc1: new HS400 Enhanced strobe MMC card at address 0001 [ 1.325763] mmcblk1: mmc1:0001 BJNB4R 29.1 GiB [ 1.326887] mmcblk1boot0: mmc1:0001 BJNB4R partition 1 4.00 MiB [ 1.327041] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008c31d80) [ 1.327198] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008c31d80) [ 1.327571] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports [ 1.327590] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver [ 1.327642] dwhdmi-rockchip ff940000.hdmi: Detected HDMI controller 0x21:0x1a:0xa0:0xc1 [ 1.329311] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008c2d7e8) [ 1.329689] rockchip-drm display-subsystem: bound fec00000.dp (ops 0xffffff8008c2dff8) [ 1.329740] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2 [ 1.329752] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 1.329755] [drm:drm_vblank_init] No driver support for vblank timestamp query. [ 1.329834] rockchip-drm display-subsystem: failed to parse loader memory [ 1.335965] mmcblk1boot1: mmc1:0001 BJNB4R partition 2 4.00 MiB [ 1.337452] mmcblk1rpmb: mmc1:0001 BJNB4R partition 3 4.00 MiB [ 1.338354] uboot: 0x000400000 -- 0x000800000 (4 MB) [ 1.338829] trust: 0x000800000 -- 0x000c00000 (4 MB) [ 1.339315] resource: 0x000c00000 -- 0x001c00000 (16 MB) [ 1.339796] kernel: 0x001c00000 -- 0x003000000 (20 MB) [ 1.340282] backup: 0x003000000 -- 0x003400000 (4 MB) [ 1.340754] boot: 0x003400000 -- 0x747800000 (29764 MB) [ 1.341279] mmcblk1: p1 p2 p3 p4 p5 p6 [ 1.351083] usb 1-1: new high-speed USB device number 2 using ehci-platform [ 1.446316] Console: switching to colour frame buffer device 240x67 [ 1.459241] rockchip-drm display-subsystem: fb0: frame buffer device [ 1.466377] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0 [ 1.466957] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201 [ 1.467552] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 1.468182] usb 1-1: Product: USB 2.0 Hub [MTT] [ 1.469061] hub 1-1:1.0: USB hub found [ 1.469598] hub 1-1:1.0: 7 ports detected [ 1.470158] I : [File] : drivers/gpu/arm/midgard_for_linux/backend/gpu/mali_kbase_devfreq.c; [Line] : 271; [Func] : kbase_devfreq_init(); success initing power_model_simple. [ 1.472215] mali ff9a0000.gpu: Probed as mali0 [ 1.475614] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller [ 1.476271] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 3 [ 1.477050] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00030010 [ 1.477843] xhci-hcd xhci-hcd.6.auto: irq 227, io mem 0xfe800000 [ 1.478449] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.479041] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.479681] usb usb3: Product: xHCI Host Controller [ 1.480116] usb usb3: Manufacturer: Linux 4.4.55 xhci-hcd [ 1.480586] usb usb3: SerialNumber: xhci-hcd.6.auto [ 1.481342] hub 3-0:1.0: USB hub found [ 1.481684] hub 3-0:1.0: 1 port detected [ 1.482191] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller [ 1.482756] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 4 [ 1.483460] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 1.484216] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003 [ 1.484807] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.485441] usb usb4: Product: xHCI Host Controller [ 1.485867] usb usb4: Manufacturer: Linux 4.4.55 xhci-hcd [ 1.486345] usb usb4: SerialNumber: xhci-hcd.6.auto [ 1.487075] hub 4-0:1.0: USB hub found [ 1.487416] hub 4-0:1.0: 1 port detected [ 1.488481] xhci-hcd xhci-hcd.6.auto: remove, state 1 [ 1.488932] usb usb4: USB disconnect, device number 1 [ 1.512988] xhci-hcd xhci-hcd.6.auto: Host not halted after 16000 microseconds. [ 1.513625] xhci-hcd xhci-hcd.6.auto: Host controller not halted, aborting reset. [ 1.514300] xhci-hcd xhci-hcd.6.auto: USB bus 4 deregistered [ 1.514893] xhci-hcd xhci-hcd.6.auto: remove, state 1 [ 1.515353] usb usb3: USB disconnect, device number 1 [ 1.516080] xhci-hcd xhci-hcd.6.auto: USB bus 3 deregistered [ 1.519816] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 1.520417] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 3 [ 1.521199] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00030010 [ 1.521979] xhci-hcd xhci-hcd.7.auto: irq 228, io mem 0xfe900000 [ 1.522585] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.523186] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.523814] usb usb3: Product: xHCI Host Controller [ 1.524246] usb usb3: Manufacturer: Linux 4.4.55 xhci-hcd [ 1.524716] usb usb3: SerialNumber: xhci-hcd.7.auto [ 1.525374] hub 3-0:1.0: USB hub found [ 1.525715] hub 3-0:1.0: 1 port detected [ 1.526204] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 1.526754] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 4 [ 1.527454] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 1.528205] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003 [ 1.528796] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.529429] usb usb4: Product: xHCI Host Controller [ 1.529854] usb usb4: Manufacturer: Linux 4.4.55 xhci-hcd [ 1.530328] usb usb4: SerialNumber: xhci-hcd.7.auto [ 1.530968] hub 4-0:1.0: USB hub found [ 1.531314] hub 4-0:1.0: 1 port detected [ 1.533422] ehci-platform fe380000.usb: EHCI Host Controller [ 1.534003] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5 [ 1.534769] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000 [ 1.541067] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00 [ 1.541670] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.542271] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.542899] usb usb5: Product: EHCI Host Controller [ 1.543330] usb usb5: Manufacturer: Linux 4.4.55 ehci_hcd [ 1.543800] usb usb5: SerialNumber: fe380000.usb [ 1.544444] hub 5-0:1.0: USB hub found [ 1.544782] hub 5-0:1.0: 1 port detected [ 1.545501] ohci-platform fe3a0000.usb: Generic Platform OHCI controller [ 1.546188] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6 [ 1.546928] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000 [ 1.602519] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.603161] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.603806] usb usb6: Product: Generic Platform OHCI controller [ 1.604355] usb usb6: Manufacturer: Linux 4.4.55 ohci_hcd [ 1.604837] usb usb6: SerialNumber: fe3a0000.usb [ 1.606448] hub 6-0:1.0: USB hub found [ 1.606843] hub 6-0:1.0: 1 port detected [ 1.609172] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode. [ 1.609864] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller. [ 1.610501] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a [ 1.611047] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo [ 1.611944] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated. [ 1.612794] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found [ 1.613361] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found [ 1.614384] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq [ 1.626416] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 1.638652] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized [ 1.652340] asoc-simple-card rt5640-sound: rt5640-aif1 <-> ff890000.i2s mapping ok [ 1.661409] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card0/input0 [ 1.665629] asoc-simple-card hdmi-codec: i2s-hifi <-> ff8a0000.i2s mapping ok [ 1.670722] rockchip-spdif ff870000.spdif: Missing dma channel for stream: 0 [ 1.671396] rockchip-spdif ff870000.spdif: ASoC: pcm constructor failed: -22 [ 1.672028] asoc-simple-card spdif-sound: ASoC: can't create pcm ff870000.spdif-dit-hifi :-22 [ 1.672811] asoc-simple-card spdif-sound: ASoC: failed to instantiate card -22 [ 1.673862] asoc-simple-card: probe of spdif-sound failed with error -22 [ 1.676102] input: gpio-keys as /devices/platform/gpio-keys/input/input1 [ 1.679318] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 09:18:19 UTC (1358500699) [ 1.688535] mmc2: queuing unknown CIS tuple 0x80 (2 bytes) [ 1.691590] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) [ 1.694552] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) [ 1.698832] mmc2: queuing unknown CIS tuple 0x80 (7 bytes) [ 1.708851] ret 1024 [ 1.710149] ALSA device list: [ 1.710417] #0: rockchip,rt5640-codec [ 1.710755] #1: HDMI-CODEC [ 1.712245] EXT4-fs (mmcblk1p6): couldn't mount as ext3 due to feature incompatibilities [ 1.713881] EXT4-fs (mmcblk1p6): couldn't mount as ext2 due to feature incompatibilities [ 1.750288] usb 1-1.2: new low-speed USB device number 3 using ehci-platform [ 1.787037] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [ 1.828145] usb 3-1: new high-speed USB device number 2 using xhci-hcd [ 1.840687] vendor storage:20160801 ret = 0 [ 1.847194] usb 1-1.2: New USB device found, idVendor=03f0, idProduct=0024 [ 1.847815] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 1.848516] usb 1-1.2: Product: HP Basic USB Keyboard [ 1.848973] usb 1-1.2: Manufacturer: CHICONY [ 1.858685] input: CHICONY HP Basic USB Keyboard as /devices/platform/fe3c0000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:03F0:0024.0001/input/input2 [ 1.912068] hid-generic 0003:03F0:0024.0001: input,hidraw0: USB HID v1.10 Keyboard [CHICONY HP Basic USB Keyboard] on usb-fe3c0000.usb-1.2/input0 [ 1.957786] usb 3-1: New USB device found, idVendor=0b95, idProduct=772b [ 1.958437] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 1.959089] usb 3-1: Product: AX88772B [ 1.959431] usb 3-1: Manufacturer: ASIX Elec. Corp. [ 1.959868] usb 3-1: SerialNumber: 0001E8 [ 1.960316] EXT4-fs (mmcblk1p6): 3 orphan inodes deleted [ 1.960805] EXT4-fs (mmcblk1p6): recovery complete [ 1.965849] EXT4-fs (mmcblk1p6): mounted filesystem with ordered data mode. Opts: (null) [ 1.966674] VFS: Mounted root (ext4 filesystem) on device 179:6. [ 1.967818] devtmpfs: mounted [ 1.969118] Freeing unused kernel memory: 1152K (ffffff8008fb0000 - ffffff80090d0000) [ 1.987283] usb 1-1.4: new low-speed USB device number 4 using ehci-platform [ 2.048733] systemd[1]: System time before build time, advancing clock. [ 2.061791] systemd[1]: Failed to insert module 'autofs4': No such file or directory [ 2.076907] random: systemd: uninitialized urandom read (16 bytes read, 64 bits of entropy available) [ 2.080744] random: systemd: uninitialized urandom read (16 bytes read, 65 bits of entropy available) [ 2.082395] usb 1-1.4: New USB device found, idVendor=03f0, idProduct=1198 [ 2.083017] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.083711] usb 1-1.4: Product: HP USB 1000dpi Laser Mouse [ 2.084229] usb 1-1.4: Manufacturer: HP [ 2.084523] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN) [ 2.086234] systemd[1]: Detected architecture arm64.Welcome to Ubuntu 16.04.2 LTS!
[ 2.089809] systemd[1]: Set hostname to .
[ 2.093904] input: HP HP USB 1000dpi Laser Mouse as /devices/platform/fe3c0000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:03F0:1198.0002/input/input3
[ 2.120349] random: systemd: uninitialized urandom read (16 bytes read, 65 bits of entropy available)
[ 2.128966] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 2.129653] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 2.131423] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 2.132571] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 2.134540] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 2.140234] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 2.144834] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 67 bits of entropy available)
[ 2.146593] hid-generic 0003:03F0:1198.0002: input,hidraw1: USB HID v2.00 Mouse [HP HP USB 1000dpi Laser Mouse] on usb-fe3c0000.usb-1.4/input0
[ 2.153614] hid-generic 0003:03F0:1198.0003: hiddev0,hidraw2: USB HID v2.00 Device [HP HP USB 1000dpi Laser Mouse] on usb-fe3c0000.usb-1.4/input1
[ 2.154264] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 233
[ 2.164048] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.164672] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[ 2.182838] bcmsdh_register: register client driver
[ 2.184004] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.184780] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.185249] bus num (host idx)=2, slot num (rca)=1
[ 2.185679] found adapter info ‘DHD generic adapter’
[ 2.186244] sdioh_attach: set sd_f2_blocksize 128
[ 2.187326] bcmsdh_probe: Host OOB irq is not defined
[ 2.187781] sdioh_probe: bcmsdh_probe failed
[ 2.188737] bcmsdh_sdmmc: probe of mmc2:0001:2 failed with error -12
[ 2.320908] systemd[1]: Reached target Encrypted Volumes.
[ OK ] Reached target Encrypted Volumes.
[ 2.322411] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 2.323425] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 2.324366] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 2.325439] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 2.326494] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 2.330525] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 2.335052] systemd[1]: Reached target Remote File Systems (Pre).
[ OK ] Reached target Remote File Systems (Pre).
[ 2.336225] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 2.337276] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 2.338820] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 2.339678] systemd[1]: Reached target User and Group Name Lookups.
[ OK ] Reached target User and Group Name Lookups.
[ 2.340718] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 2.342118] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 2.343212] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 2.349856] systemd[1]: Starting Load Kernel Modules…
[ 2.351548] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 2.356472] systemd[1]: Starting Set console keymap…
[ 2.362549] systemd[1]: Starting Create Static Device Nodes in /dev…
[ 2.367822] systemd[1]: Starting Journal Service…
[ 2.372048] systemd[1]: Mounting Debug File System…
[ 2.380642] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 2.381786] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 2.387715] systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
[ 2.390022] systemd[1]: Failed to start Load Kernel Modules.
[FAILED] Failed to start Load Kernel Modules.
See ‘systemctl status systemd-modules-load.service’ for details.
[ 2.391665] systemd[1]: systemd-modules-load.service: Unit entered failed state.
[ 2.396803] systemd[1]: systemd-modules-load.service: Failed with result ‘exit-code’.
[ 2.398571] systemd[1]: Started Remount Root and Kernel File Systems.
[ OK ] Started Remount Root and Kernel File Systems.
[ 2.400104] systemd[1]: Mounted Debug File System.
[ OK ] Mounted Debug File System.
[ 2.409619] systemd[1]: Started Create Static Device Nodes in /dev.
[ OK ] Started Create Static Device Nodes in /dev.
[ 2.476873] systemd[1]: Starting udev Kernel Device Manager…
[ 2.479339] systemd[1]: Starting Load/Save Random Seed…
[ 2.483275] systemd[1]: Starting udev Coldplug all Devices…
[ 2.486184] systemd[1]: Mounting FUSE Control File System…
[ 2.489022] systemd[1]: Mounting Configuration File System…
[ 2.492197] systemd[1]: Starting Apply Kernel Variables…
[ 2.495295] systemd[1]: Started Load/Save Random Seed.
[ OK ] Started Load/Save Random Seed.
[ OK ] Mounted Configuration File System.
[ OK ] Mounted FUSE Control File System.
[ OK ] Started Set console keymap.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Journal Service.
[ OK ] Started udev Kernel Device Manager.
Starting Flush Journal to Persistent Storage…
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
Starting LSB: AppArmor initialization…
Starting Set console font and keymap…
Starting Tell Plymouth To Write Out Runtime Data…
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Tell Plymouth To Write Out Runtime Data.
Starting Create Volatile Files and Directories…
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown…
Starting Network Time Synchronization…
[ OK ] Started Network Time Synchronization.
[ OK ] Started LSB: AppArmor initialization.
[ OK ] Started Update UTMP about System Boot/Shutdown.
Starting Raise network interfaces…
[ OK ] Reached target System Time Synchronized.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Paths.
[ OK ] Reached target System Initialization.
Starting Socket activation for snappy daemon.
[ OK ] Started Daily apt activities.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Started Timer to automatically refresh installed snaps.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on Socket activation for snappy daemon.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started Regular background program processing daemon.
Starting Permit User Sessions…
Starting Avahi mDNS/DNS-SD Stack…
Starting Accounts Service…
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
Starting LSB: automatic crash report generation…
[ OK ] Started Run anacron jobs.
[ OK ] Started CUPS Scheduler.
Starting Restore /etc/resolv.conf i…re the ppp link was shut down…
Starting System Logging Service…
[ OK ] Started Make remote CUPS printers available locally.
Starting Login Service…
Starting Network Manager…
Starting Modem Manager…
Starting LSB: Set the CPU Frequency Scaling governor to “ondemand”…
Starting Save/Restore Sound Card State…
[ OK ] Started Snappy daemon.
Starting Auto import assertions from block devices…
[ OK ] Started Set console font and keymap.
[ OK ] Started Permit User Sessions.
[ OK ] Started Restore /etc/resolv.conf if…fore the ppp link was shut down.
[ OK ] Found device /dev/ttyFIQ0.
[ OK ] Started System Logging Service.
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Started Auto import assertions from block devices.
[ OK ] Started Network Manager.
[ OK ] Started Login Service.
[ OK ] Started LSB: Set the CPU Frequency Scaling governor to “ondemand”.
Starting Network Manager Script Dispatcher Service…
Starting Authenticate and Authorize Users to Run Privileged Tasks…
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Reached target Sound Card.
Starting Light Display Manager…
[ OK ] Created slice system-getty.slice.
[ OK ] Started LSB: automatic crash report generation.
[ OK ] Started Network Manager Script Dispatcher Service.
[ OK ] Started Authenticate and Authorize Users to Run Privileged Tasks.
[ OK ] Started Accounts Service.
Starting Load/Save RF Kill Switch Status…
[ OK ] Started Raise network interfaces.
[ OK ] Reached target Network.
[ OK ] Started Unattended Upgrades Shutdown.
Starting /etc/rc.local Compatibility…
[ OK ] Started /etc/rc.local Compatibility.
[ OK ] Started Modem Manager.
[ OK ] Started Light Display Manager.
Starting Hold until boot process finishes up…
[ OK ] Started Hold until boot process finishes up.
Starting Hostname Service…
Starting Set console scheme…
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyFIQ0.
[ OK ] Reached target Login Prompts.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes…
[ OK ] Started Set console scheme.
[ OK ] Started Hostname Service.
[ OK ] Started Update UTMP about System Runlevel Changes.
[ OK ] Started Load/Save RF Kill Switch Status.
Ubuntu 16.04.2 LTS firefly ttyFIQ0
firefly login: root (automatic login)
Last login: Fri Jun 9 06:45:34 UTC 2017 on ttyFIQ0
Welcome to Ubuntu 16.04.2 LTS (GNU/Linux 4.4.55 aarch64)
dmesg:
[ 0.000000] On node 0 totalpages: 1015296
[ 0.000000] DMA zone: 15864 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 1015296 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s46144 r8192 d31680 u86016 alloc=21*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.147707] regulator-dummy: no parameters
[ 0.175121] gpiochip_add: registered GPIOs 0 to 31 on device: gpio0
[ 0.175228] gpiochip_add: registered GPIOs 32 to 63 on device: gpio1
[ 0.175335] gpiochip_add: registered GPIOs 64 to 95 on device: gpio2
[ 0.175449] gpiochip_add: registered GPIOs 96 to 127 on device: gpio3
[ 0.175551] gpiochip_add: registered GPIOs 128 to 159 on device: gpio4
[ 0.271182] of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/vcc3v3-pcie-regulator[0]’ - status (0)
[ 0.271232] vcc3v3_pcie: no parameters
[ 0.271381] reg-fixed-voltage vcc3v3-pcie-regulator: vcc3v3_pcie supplying 0uV
[ 0.271435] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vcc3v3-sys[0]’
[ 0.271451] vcc3v3_sys: 3300 mV
[ 0.271565] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[ 0.271699] of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/vcc5v0-host-regulator[0]’ - status (0)
[ 0.271735] vcc5v0_host: no parameters
[ 0.271849] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[ 0.271899] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vcc5v0-sys[0]’
[ 0.271914] vcc5v0_sys: 5000 mV
[ 0.272025] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
[ 0.272072] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vcc-phy-regulator[0]’
[ 0.272090] vcc_phy: no parameters
[ 0.272194] reg-fixed-voltage vcc-phy-regulator: vcc_phy supplying 0uV
[ 0.272247] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vccadc-ref[0]’
[ 0.272276] vcc1v8_sys: 1800 mV
[ 0.272398] reg-fixed-voltage vccadc-ref: vcc1v8_sys supplying 1800000uV
[ 0.272513] of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/vcc-lcd-regulator[0]’ - status (0)
[ 0.272549] vcc_lcd: no parameters
[ 0.272662] reg-fixed-voltage vcc-lcd-regulator: vcc_lcd supplying 0uV
[ 0.280498] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.334358] PCI: CLS 0 bytes, default 64
[ 0.350467] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.356738] Asymmetric key parser ‘x509’ registered
[ 0.360250] phy phy-ff770000.syscon:usb2-phy@e460.0: Looking up phy-supply from device tree
[ 0.360262] phy phy-ff770000.syscon:usb2-phy@e460.0: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e460/otg-port failed
[ 0.360499] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: GPIO lookup for consumer otg-vbus
[ 0.360509] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: using device tree for GPIO lookup
[ 0.360520] of_get_named_gpiod_flags: can’t parse ‘otg-vbus-gpios’ property of node ‘/syscon@ff770000/usb2-phy@e460[0]’
[ 0.360529] of_get_named_gpiod_flags: can’t parse ‘otg-vbus-gpio’ property of node ‘/syscon@ff770000/usb2-phy@e460[0]’
[ 0.360537] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: using lookup tables for GPIO lookup
[ 0.360545] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: lookup for GPIO otg-vbus failed
[ 0.361431] phy phy-ff770000.syscon:usb2-phy@e460.1: Looking up phy-supply from device tree
[ 0.361505] vcc5v0_host: could not add device link phy-ff770000.syscon:usb2-phy@e460.1 err -2
[ 0.362212] phy phy-ff770000.syscon:phy@f780.2: Looking up phy-supply from device tree
[ 0.362223] phy phy-ff770000.syscon:phy@f780.2: Looking up phy-supply property in node /syscon@ff770000/phy@f780 failed
[ 0.363324] phy phy-ff800000.phy.3: Looking up phy-supply from device tree
[ 0.363335] phy phy-ff800000.phy.3: Looking up phy-supply property in node /phy@ff800000/dp-port failed
[ 0.363427] phy phy-ff800000.phy.4: Looking up phy-supply from device tree
[ 0.363437] phy phy-ff800000.phy.4: Looking up phy-supply property in node /phy@ff800000/usb3-port failed
[ 0.363755] phy phy-phy@e220.5: Looking up phy-supply from device tree
[ 0.363765] phy phy-phy@e220.5: Looking up phy-supply property in node /phy@e220 failed
[ 0.365468] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[ 0.365478] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[ 0.365503] of_get_named_gpiod_flags: parsed ‘ep-gpios’ property of node ‘/pcie@f8000000[0]’ - status (0)
[ 0.365738] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[ 0.365749] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply property in node /pcie@f8000000 failed
[ 0.366350] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree
[ 0.366360] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed
[ 0.366928] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree
[ 0.366937] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed
[ 0.926014] pwm-regulator vdd-log: GPIO lookup for consumer enable
[ 0.926022] pwm-regulator vdd-log: using device tree for GPIO lookup
[ 0.926033] of_get_named_gpiod_flags: can’t parse ‘enable-gpios’ property of node ‘/vdd-log[0]’
[ 0.926041] of_get_named_gpiod_flags: can’t parse ‘enable-gpio’ property of node ‘/vdd-log[0]’
[ 0.926048] pwm-regulator vdd-log: using lookup tables for GPIO lookup
[ 0.926069] pwm-regulator vdd-log: lookup for GPIO enable failed
[ 0.926095] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.926104] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.926125] vdd_log: 800 ↔ 1400 mV at 1004 mV
[ 0.926275] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 0.926285] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 0.936976] mali ff9a0000.gpu: Looking up mali-supply from device tree
[ 0.955480] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.957250] rk_gmac-dwmac fe300000.ethernet: Looking up phy-supply from device tree
[ 0.968454] of_get_named_gpiod_flags: parsed ‘snps,reset-gpio’ property of node ‘/ethernet@fe300000[0]’ - status (0)
[ 1.034806] Rockchip WiFi SYS interface (V1.00) …
[ 1.041313] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.050144] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.062236] Power-up adapter ‘DHD generic adapter’
[ 1.129182] fan53555-regulator 0-0040: GPIO lookup for consumer vsel
[ 1.129191] fan53555-regulator 0-0040: using device tree for GPIO lookup
[ 1.129220] of_get_named_gpiod_flags: parsed ‘vsel-gpios’ property of node ‘/i2c@ff3c0000/syr827@40[0]’ - status (0)
[ 1.130224] fan53555-regulator 0-0040: Looking up vin-supply from device tree
[ 1.130696] vcc5v0_sys: could not add device link regulator.9 err -2
[ 1.132089] vdd_cpu_b: 712 ↔ 1500 mV at 1000 mV
[ 1.132392] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.132404] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.132557] fan53555-regulator 0-0041: GPIO lookup for consumer vsel
[ 1.132565] fan53555-regulator 0-0041: using device tree for GPIO lookup
[ 1.132573] of_get_named_gpiod_flags: can’t parse ‘vsel-gpios’ property of node ‘/i2c@ff3c0000/syr828@41[0]’
[ 1.132581] of_get_named_gpiod_flags: can’t parse ‘vsel-gpio’ property of node ‘/i2c@ff3c0000/syr828@41[0]’
[ 1.132588] fan53555-regulator 0-0041: using lookup tables for GPIO lookup
[ 1.132597] fan53555-regulator 0-0041: lookup for GPIO vsel failed
[ 1.133559] fan53555-regulator 0-0041: Looking up vin-supply from device tree
[ 1.134007] vcc5v0_sys: could not add device link regulator.10 err -2
[ 1.135671] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 1.135961] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.135971] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.140129] rk808 0-001b: GPIO lookup for consumer dvs
[ 1.140137] rk808 0-001b: using device tree for GPIO lookup
[ 1.140148] of_get_named_gpiod_flags: can’t parse ‘dvs-gpios’ property of node ‘/i2c@ff3c0000/pmic@1b[0]’
[ 1.140156] of_get_named_gpiod_flags: can’t parse ‘dvs-gpio’ property of node ‘/i2c@ff3c0000/pmic@1b[0]’
[ 1.140163] rk808 0-001b: using lookup tables for GPIO lookup
[ 1.140171] rk808 0-001b: lookup for GPIO dvs failed
[ 1.140720] rk808 0-001b: GPIO lookup for consumer dvs
[ 1.140726] rk808 0-001b: using device tree for GPIO lookup
[ 1.140734] of_get_named_gpiod_flags: can’t parse ‘dvs-gpios’ property of node ‘/i2c@ff3c0000/pmic@1b[1]’
[ 1.140742] of_get_named_gpiod_flags: can’t parse ‘dvs-gpio’ property of node ‘/i2c@ff3c0000/pmic@1b[1]’
[ 1.140748] rk808 0-001b: using lookup tables for GPIO lookup
[ 1.140755] rk808 0-001b: lookup for GPIO dvs failed
[ 1.141345] rk808 0-001b: Looking up vcc1-supply from device tree
[ 1.141784] vcc3v3_sys: could not add device link regulator.11 err -2
[ 1.142256] vdd_center: 750 ↔ 1350 mV at 900 mV
[ 1.142403] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.142415] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.142458] rk808 0-001b: Looking up vcc2-supply from device tree
[ 1.142880] vcc3v3_sys: could not add device link regulator.12 err -2
[ 1.143196] vdd_cpu_l: 750 ↔ 1350 mV at 900 mV
[ 1.143325] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.143336] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.143374] rk808 0-001b: Looking up vcc3-supply from device tree
[ 1.143793] vcc3v3_sys: could not add device link regulator.13 err -2
[ 1.143824] vcc_ddr: at 3300 mV
[ 1.143943] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.143953] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.143995] rk808 0-001b: Looking up vcc4-supply from device tree
[ 1.144432] vcc3v3_sys: could not add device link regulator.14 err -2
[ 1.144612] vcc_1v8: 1800 mV
[ 1.144736] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.144747] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.144791] rk808 0-001b: Looking up vcc6-supply from device tree
[ 1.145219] vcc3v3_sys: could not add device link regulator.15 err -2
[ 1.146066] vcc1v8_dvp: 1800 mV
[ 1.146198] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.146208] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.146252] rk808 0-001b: Looking up vcc6-supply from device tree
[ 1.146663] vcc3v3_sys: could not add device link regulator.16 err -2
[ 1.147372] vcc3v0_tp: 3000 mV
[ 1.147500] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.147510] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.147556] rk808 0-001b: Looking up vcc7-supply from device tree
[ 1.147968] vcc3v3_sys: could not add device link regulator.17 err -2
[ 1.148671] vcc1v8_pmu: 1800 mV
[ 1.148799] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.148808] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.148860] rk808 0-001b: Looking up vcc9-supply from device tree
[ 1.149287] vcc3v3_sys: could not add device link regulator.18 err -2
[ 1.149984] vcc_sd: 1800 ↔ 3300 mV at 3000 mV
[ 1.150140] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.150150] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.150199] rk808 0-001b: Looking up vcc9-supply from device tree
[ 1.150611] vcc3v3_sys: could not add device link regulator.19 err -2
[ 1.151311] vcca3v0_codec: 3000 mV
[ 1.151438] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.151447] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.151497] rk808 0-001b: Looking up vcc10-supply from device tree
[ 1.151909] vcc3v3_sys: could not add device link regulator.20 err -2
[ 1.152608] vcc_1v5: 1500 mV
[ 1.152735] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.152744] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.152797] rk808 0-001b: Looking up vcc7-supply from device tree
[ 1.153224] vcc3v3_sys: could not add device link regulator.21 err -2
[ 1.153921] vcca1v8_codec: 1800 mV
[ 1.154071] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.154081] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.154136] rk808 0-001b: Looking up vcc11-supply from device tree
[ 1.154548] vcc3v3_sys: could not add device link regulator.22 err -2
[ 1.155245] vcc_3v0: 3000 mV
[ 1.155373] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.155382] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.155435] rk808 0-001b: Looking up vcc8-supply from device tree
[ 1.155868] vcc3v3_sys: could not add device link regulator.23 err -2
[ 1.155899] vcc3v3_s3: at 3300 mV
[ 1.156005] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.156015] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.156089] rk808 0-001b: Looking up vcc12-supply from device tree
[ 1.156524] vcc3v3_sys: could not add device link regulator.24 err -2
[ 1.156562] vcc3v3_s0: at 3300 mV
[ 1.156670] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.156679] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.167768] fusb302 4-0022: GPIO lookup for consumer int-n
[ 1.167777] fusb302 4-0022: using device tree for GPIO lookup
[ 1.167803] of_get_named_gpiod_flags: parsed ‘int-n-gpios’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’ - status (0)
[ 1.167826] fusb302 4-0022: GPIO lookup for consumer vbus-5v
[ 1.167833] fusb302 4-0022: using device tree for GPIO lookup
[ 1.167855] of_get_named_gpiod_flags: parsed ‘vbus-5v-gpios’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’ - status (0)
[ 1.167877] fusb302 4-0022: GPIO lookup for consumer vbus-other
[ 1.167884] fusb302 4-0022: using device tree for GPIO lookup
[ 1.167892] of_get_named_gpiod_flags: can’t parse ‘vbus-other-gpios’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’
[ 1.167900] of_get_named_gpiod_flags: can’t parse ‘vbus-other-gpio’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’
[ 1.167907] fusb302 4-0022: using lookup tables for GPIO lookup
[ 1.167914] fusb302 4-0022: lookup for GPIO vbus-other failed
[ 1.167921] fusb302 4-0022: GPIO lookup for consumer discharge
[ 1.167927] fusb302 4-0022: using device tree for GPIO lookup
[ 1.167935] of_get_named_gpiod_flags: can’t parse ‘discharge-gpios’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’
[ 1.167942] of_get_named_gpiod_flags: can’t parse ‘discharge-gpio’ property of node ‘/i2c@ff3d0000/fusb30x@22[0]’
[ 1.167948] fusb302 4-0022: using lookup tables for GPIO lookup
[ 1.167955] fusb302 4-0022: lookup for GPIO discharge failed
[ 1.184464] rockchip-iodomain ff320000.syscon:io-domains: Looking up pmu1830-supply from device tree
[ 1.184644] rockchip-iodomain ff770000.syscon:io-domains: Looking up bt656-supply from device tree
[ 1.184697] rockchip-iodomain ff770000.syscon:io-domains: Looking up audio-supply from device tree
[ 1.184749] rockchip-iodomain ff770000.syscon:io-domains: Looking up sdmmc-supply from device tree
[ 1.184802] rockchip-iodomain ff770000.syscon:io-domains: Looking up gpio1830-supply from device tree
[ 1.189214] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.193861] cpu cpu0: Looking up cpu-supply from device tree
[ 1.194177] cpu cpu0: Looking up cpu-supply from device tree
[ 1.195444] cpu cpu4: Looking up cpu-supply from device tree
[ 1.202928] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.203645] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
[ 1.203655] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe310000 failed
[ 1.203683] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
[ 1.203692] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe310000 failed
[ 1.204815] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp
[ 1.204821] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup
[ 1.204831] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@fe310000[0]’
[ 1.204839] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@fe310000[0]’
[ 1.204846] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup
[ 1.204854] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
[ 1.208257] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.208966] dwmmc_rockchip fe320000.dwmmc: Looking up vmmc-supply from device tree
[ 1.208975] dwmmc_rockchip fe320000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe320000 failed
[ 1.208995] dwmmc_rockchip fe320000.dwmmc: Looking up vqmmc-supply from device tree
[ 1.209637] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer cd
[ 1.209644] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[ 1.209653] of_get_named_gpiod_flags: can’t parse ‘cd-gpios’ property of node ‘/dwmmc@fe320000[0]’
[ 1.209661] of_get_named_gpiod_flags: can’t parse ‘cd-gpio’ property of node ‘/dwmmc@fe320000[0]’
[ 1.209668] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[ 1.209675] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO cd failed
[ 1.209683] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer wp
[ 1.209689] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[ 1.209697] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@fe320000[0]’
[ 1.209705] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@fe320000[0]’
[ 1.209711] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[ 1.209717] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO wp failed
[ 1.235314] sdhci-arasan fe330000.sdhci: GPIO lookup for consumer wp
[ 1.235324] sdhci-arasan fe330000.sdhci: using device tree for GPIO lookup
[ 1.235335] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/sdhci@fe330000[0]’
[ 1.235343] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/sdhci@fe330000[0]’
[ 1.235351] sdhci-arasan fe330000.sdhci: using lookup tables for GPIO lookup
[ 1.235359] sdhci-arasan fe330000.sdhci: lookup for GPIO wp failed
[ 1.236455] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply from device tree
[ 1.236466] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply property in node /sdhci@fe330000 failed
[ 1.236495] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply from device tree
[ 1.236504] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe330000 failed
[ 1.265392] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/leds/power[0]’ - status (0)
[ 1.265522] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/leds/user[0]’ - status (0)
[ 1.267279] rockchip-saradc ff100000.saradc: Looking up vref-supply from device tree
[ 1.267666] sdio: host isn’t initialization successfully.
[ 1.270889] of_get_named_gpiod_flags: parsed ‘hp-con-gpio’ property of node ‘/i2c@ff110000/rt5640@1c[0]’ - status (0)
[ 1.270922] of_get_named_gpiod_flags: can’t parse ‘realtek,ldo1-en-gpios’ property of node ‘/i2c@ff110000/rt5640@1c[0]’
[ 1.301682] lib80211_crypt: registered algorithm ‘NULL’
[ 1.301692] lib80211_crypt: registered algorithm ‘WEP’
[ 1.301701] lib80211_crypt: registered algorithm ‘CCMP’
[ 1.301711] lib80211_crypt: registered algorithm ‘TKIP’
[ 1.304785] of_get_named_gpiod_flags: can’t parse ‘WIFI,poweren_gpio’ property of node ‘/wireless-wlan[0]’
[ 1.304792] of_get_named_gpiod_flags: can’t parse ‘WIFI,reset_gpio’ property of node ‘/wireless-wlan[0]’
[ 1.304826] of_get_named_gpiod_flags: parsed ‘WIFI,host_wake_irq’ property of node ‘/wireless-wlan[0]’ - status (0)
[ 1.307694] of_get_named_gpiod_flags: parsed ‘uart_rts_gpios’ property of node ‘/wireless-bluetooth[0]’ - status (0)
[ 1.308447] of_get_named_gpiod_flags: can’t parse ‘BT,power_gpio’ property of node ‘/wireless-bluetooth[0]’
[ 1.308471] of_get_named_gpiod_flags: parsed ‘BT,reset_gpio’ property of node ‘/wireless-bluetooth[0]’ - status (0)
[ 1.309200] of_get_named_gpiod_flags: parsed ‘BT,wake_gpio’ property of node ‘/wireless-bluetooth[0]’ - status (0)
[ 1.309910] of_get_named_gpiod_flags: parsed ‘BT,wake_host_irq’ property of node ‘/wireless-bluetooth[0]’ - status (0)
[ 1.322385] phy phy-ff770000.syscon:usb2-phy@e450.6: Looking up phy-supply from device tree
[ 1.322395] phy phy-ff770000.syscon:usb2-phy@e450.6: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
[ 1.322998] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: GPIO lookup for consumer otg-vbus
[ 1.323006] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: using device tree for GPIO lookup
[ 1.323014] of_get_named_gpiod_flags: can’t parse ‘otg-vbus-gpios’ property of node ‘/syscon@ff770000/usb2-phy@e450[0]’
[ 1.323021] of_get_named_gpiod_flags: can’t parse ‘otg-vbus-gpio’ property of node ‘/syscon@ff770000/usb2-phy@e450[0]’
[ 1.323027] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: using lookup tables for GPIO lookup
[ 1.323034] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: lookup for GPIO otg-vbus failed
[ 1.325095] phy phy-ff770000.syscon:usb2-phy@e450.7: Looking up phy-supply from device tree
[ 1.325170] vcc5v0_host: could not add device link phy-ff770000.syscon:usb2-phy@e450.7 err -2
[ 1.325760] phy phy-ff7c0000.phy.8: Looking up phy-supply from device tree
[ 1.326190] phy phy-ff7c0000.phy.8: Looking up phy-supply property in node /phy@ff7c0000/dp-port failed
[ 1.326282] phy phy-ff7c0000.phy.9: Looking up phy-supply from device tree
[ 1.326289] phy phy-ff7c0000.phy.9: Looking up phy-supply property in node /phy@ff7c0000/usb3-port failed
[ 1.338354] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.338829] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 1.339315] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 1.339796] kernel: 0x001c00000 – 0x003000000 (20 MB)
[ 1.340282] backup: 0x003000000 – 0x003400000 (4 MB)
[ 1.340754] boot: 0x003400000 – 0x747800000 (29764 MB)
[ 1.464862] mali ff9a0000.gpu: Looking up mali-supply from device tree
[ 1.483460] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.527454] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.611944] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.612677] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
[ 1.612698] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe310000 failed
[ 1.612744] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
[ 1.612762] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe310000 failed
[ 1.613932] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp
[ 1.613945] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup
[ 1.613963] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@fe310000[0]’
[ 1.613980] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@fe310000[0]’
[ 1.613994] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup
[ 1.614009] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
[ 1.614283] platform sdio-pwrseq: GPIO lookup for consumer reset
[ 1.614298] platform sdio-pwrseq: using device tree for GPIO lookup
[ 1.614341] of_get_named_gpiod_flags: parsed ‘reset-gpios’ property of node ‘/sdio-pwrseq[0]’ - status (0)
[ 1.640649] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,hp-det-gpio’ property of node ‘/rt5640-sound[0]’
[ 1.640673] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,mic-det-gpio’ property of node ‘/rt5640-sound[0]’
[ 1.652340] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mapping ok
[ 1.664554] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,hp-det-gpio’ property of node ‘/hdmi-codec[0]’
[ 1.664579] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,mic-det-gpio’ property of node ‘/hdmi-codec[0]’
[ 1.665629] asoc-simple-card hdmi-codec: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 1.670038] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,hp-det-gpio’ property of node ‘/spdif-sound[0]’
[ 1.670125] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,mic-det-gpio’ property of node ‘/spdif-sound[0]’
[ 1.672028] asoc-simple-card spdif-sound: ASoC: can’t create pcm ff870000.spdif-dit-hifi :-22
[ 1.675599] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/gpio-keys/button@0[0]’ - status (0)
[ 1.675677] gpio-5 (GPIO Key Power): gpiod_set_debounce: missing set() or set_debounce() operations
[ 1.712245] EXT4-fs (mmcblk1p6): couldn’t mount as ext3 due to feature incompatibilities
[ 1.713881] EXT4-fs (mmcblk1p6): couldn’t mount as ext2 due to feature incompatibilities
[ 2.061791] systemd[1]: Failed to insert module ‘autofs4’: No such file or directory
[ 2.507326] systemd[1]: Mounted Configuration File System.
[ 2.507776] systemd[1]: Mounted FUSE Control File System.
[ 2.511800] systemd[1]: Started Set console keymap.
[ 2.513710] systemd[1]: Started Apply Kernel Variables.
[ 2.534144] systemd[1]: Started Journal Service.
[ 2.602176] systemd-journald[204]: Received request to flush runtime journal from PID 1
[ 2.773991] asix 3-1:1.0 eth1: register ‘asix’ at usb-xhci-hcd.7.auto-1, ASIX AX88772B USB 2.0 Ethernet, 20:6a:8a:97:45:05
[ 3.282338] random: nonblocking pool is initialized
[ 3.660744] cfg80211: World regulatory domain updated:
[ 3.660768] cfg80211: DFS Master region: unset
[ 3.660773] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 3.660781] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 3.660787] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 3.660792] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 3.660799] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 3.660805] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 3.660811] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 3.660816] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 3.660821] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 3.695163] phy phy-ff770000.syscon:usb2-phy@e450.6: charger = USB_SDP_CHARGER
[ 3.758150] [BT_RFKILL]: ENABLE UART_RTS
[ 3.779477] IPVS: Creating netns size=1592 id=1
[ 3.852752] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 3.852891] eth0: device MAC address 3e:e5:f3:7a:dc:57
[ 3.859075] [BT_RFKILL]: DISABLE UART_RTS
[ 3.859132] [BT_RFKILL]: bt turn on power
[ 3.859378] [BT_RFKILL]: bt shut off power
[ 3.859513] rk_iommu ff903f00.iommu: Unbalanced pm_runtime_enable!
[ 3.862212] tty_port_close_start: tty->count = 1 port count = 2.
[ 4.162303] fusb302 4-0022: PD disabled
[ 4.175868] rockchip-dwc3 usb@fe800000: USB peripheral connected
[ 4.231619] asix 3-1:1.0 enx206a8a974505: renamed from eth1
[ 4.260368] IPv6: ADDRCONF(NETDEV_UP): enx206a8a974505: link is not ready
[ 4.332254] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 5.030871] IPv6: ADDRCONF(NETDEV_UP): enx206a8a974505: link is not ready
[ 5.069122] [BT_RFKILL]: ENABLE UART_RTS
[ 5.170083] [BT_RFKILL]: DISABLE UART_RTS
[ 5.170131] [BT_RFKILL]: bt turn on power
[ 6.240245] ttyS0 - failed to request DMA
[ 7.033303] IPv6: ADDRCONF(NETDEV_CHANGE): enx206a8a974505: link becomes ready
[ 7.038299] asix 3-1:1.0 enx206a8a974505: link up, 100Mbps, full-duplex, lpa 0x41E1
[ 7.872198] IPVS: Creating netns size=1592 id=2
[ 8.333123] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 11.480184] [BT_RFKILL]: ENABLE UART_RTS
[ 11.581215] [BT_RFKILL]: DISABLE UART_RTS
[ 11.581283] [BT_RFKILL]: bt turn on power
[ 14.189232] dhd_wifi_platform_load_sdio: sdio_register_driver timeout or error
[ 14.189393] wifi_platform_set_power = 0
[ 14.189400] ======== PULL WL_REG_ON LOW! ========
[ 14.189407] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 14.189427] [WLAN_RFKILL]: wifi shut off power.
[ 14.189433] wifi_platform_bus_enumerate device present 0
[ 14.189439] ======== Card detection to remove SDIO card! ========
[ 14.189445] mmc2:mmc host rescan start!
[ 14.189491] unregister wifi platform drivers
[ 14.189497] wifi_platform_bus_enumerate device present 0
[ 14.189502] ======== Card detection to remove SDIO card! ========
[ 14.189507] mmc2:mmc host rescan start!
[ 14.189515] dhd_module_init: Failed to load the driver, try cnt 0
[ 14.189541] dhd_module_init: Failed to load driver max retry reached**
[ 14.189546] dhd_module_init: Exit err=-62
[ 16.334375] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 32.335449] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 49.131462] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 49.192664] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 64.336406] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 94.157429] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 94.224482] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 128.337150] cdn-dp fec00000.dp: [drm:cdn_dp_request_firmware] ERROR Timed out trying to load firmware
[ 128.338051] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 129.339457] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 131.340392] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 135.341428] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 139.160262] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 139.207189] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 143.342450] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 159.343423] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 184.148780] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 184.197708] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 191.344434] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 229.180895] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 229.256250] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
试了下,果然好了,赞速度!
commit 6731a7c69a3ff80aaeae879e5892aa5091160b91
btw, 我看log里写了“enable Qualcomm 4G module”,是指sim卡也可以用了吗?
jiangbo 发表于 2017-6-10 20:12
试了下,果然好了,赞速度!
你有没有发现有时系统启动不了的问题?
tim 发表于 2017-6-15 10:58
你有没有发现有时系统启动不了的问题?
没有发现。
请教一下这个是怎么解决的?最近也碰到类似的问题了。rockchip wifi_get oob_irg: rfkill-wlan driver has not successfully initialized
zouxf 发表于 2017-6-10 14:36
已更新,多谢反馈。
为啥这个评论隐藏了
午夏时分 发表于 2023-11-2 13:17
请教一下这个是怎么解决的?最近也碰到类似的问题了。rockchip wifi_get oob_irg: rfkill-wlan driver has …
你好,请问解决了嘛
