按照官方wiki,修改完成,在串口不显示ttyS4
aliases {
serial0 = &uart0;
serial1 = &uart1;
serial2 = &uart2;
serial3 = &uart3;
serial4 = &uart4;
uart4: serial@ff370000 {
compatible = “rockchip,rk3399-uart”, “snps,dw-apb-uart”;
reg = <0x0 0xff370000 0x0 0x100>;
clocks = <&pmucru SCLK_UART4_PMU>, <&pmucru PCLK_UART4_PMU>;
clock-names = “baudclk”, “apb_pclk”;
interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH 0>;
reg-shift = <2>;
reg-io-width = <4>;
pinctrl-names = “default”;
pinctrl-0 = <&uart4_xfer>;
status = “disabled”;
uart4 {
uart4_xfer: uart4-xfer {
rockchip,pins =
<1 7 RK_FUNC_1 &pcfg_pull_up>,
<1 8 RK_FUNC_1 &pcfg_pull_none>;
&uart4 {
current-speed = <9600>;
no-loopback-test;
status = “okay”;
&spidev0 {
就是这个步骤
已解决,在firefly_defconfig 添加
CONFIG_SERIAL_8250=y
# CONFIG_SERIAL_8250_DEPRECATED_OPTIONS is not set
CONFIG_SERIAL_8250_CONSOLE=y
+CONFIG_SERIAL_8250_NR_UARTS=5
+CONFIG_SERIAL_8250_RUNTIME_UARTS=5
# CONFIG_SERIAL_8250_PCI is not set
CONFIG_SERIAL_8250_DW=y
# CONFIG_HW_RANDOM is not set
