RK3328开发板 Linux启动错误
请问各位大神,谁在用最新的RK3328开发板,论坛里面似乎没有人讨论这个开发板的。
我自己编译的u-boot kernel rootfs 然后烧写到板子中,出现如下错误:
VFS: Cannot open root device “mmcblk2p7” or unknown-block(179,7): error -6
[ 2.601859] Please append a correct “root=” boot option; here are the available partitions:
[ 2.601870] 0100 4096 ram0 (driver?)
[ 2.601882] b300 7634944 mmcblk2 driver: mmcblk
[ 2.601891] b301 4000 mmcblk2p1 5a30833f-8c43-47b1-a41d-84d40883d0c6
[ 2.601898] b302 64 mmcblk2p2 67ad7741-4638-47c6-a488-d396583e582a
[ 2.601906] b303 4096 mmcblk2p3 3adea03d-c612-46ed-cff9-b79439f11561
[ 2.601914] b304 4096 mmcblk2p4 e582484a-9010-404a-899d-47bd16ba3fa8
[ 2.601921] b305 4096 mmcblk2p5 dc11277f-eb7f-42d9-8027-a83b14220e50
[ 2.601928] b306 114688 mmcblk2p6 295a726a-357d-4382-d5a6-e7e871da99e0
[ 2.601938] b360 512 mmcblk2rpmb (driver?)
[ 2.601946] b340 4096 mmcblk2boot1 (driver?)
[ 2.601953] b320 4096 mmcblk2boot0 (driver?)
[ 2.601959] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,7)
[ 2.601966] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 4.4.70 #2
[ 2.601969] Hardware name: Rockchip RK3328 EVB (DT)
请问怎么解决?谁有Linux下的parameter_gpt.txt文件?谢谢啦
我没有,帮顶
发生了kernel panic错误哦,具体的需要你自己检查下了哦,是否有修改的代码中有问题的地方,vfs的启动参数等是否有问题等等。。。
找到篇kernel panic的文章,可以看下哦
http://blog.csdn.net/ylyuanlu/article/details/9115159
还有一篇kernel panic的定位的博客,仅供参考
http://blog.csdn.net/wh8_2011/article/details/52021035
看起来是根文件系统有问题哦.
rootdev指定分区错误?
根文件系统制作有误?
根文件下载错误?
