MIPI单通道屏调试过程及问题整理
本人小菜,写这些过程及问题主要目的就是想请教大神,其次也是想为和我一样的MIPI调屏新手开辟一条更直观的路。
正好官网有DSI的调试教程,马上搞起!:lol
MIPI屏的基本信息为:分辨率为480x854 单通道2 lane屏本身OK,因为可以用单片机板子点亮OK
MIPI DSI的调试步骤来设置:
1.配置/kernel/arch/arm/configs/firefly-rk3288_defconfig
2./kernel/arch/arm/boot/dts/下新增配置文件
lcd-swi045-mipi.dtsi
部分代码贴上(完整的在附件中)
* arch/arm/boot/dts/lcd-swi045-mipi.dtsi
 * author:
 * create date: 2015-02-04
 * lcd model: SWI4.5''
 * resolution: 480x854
 * mipi channel: single
        /* about mipi */
        disp_mipi_init: mipi_dsi_init{
                    compatible = "rockchip,mipi_dsi_init";
                    rockchip,screen_init    = <1>;
                    rockchip,dsi_lane       = <2>;
                    rockchip,dsi_hs_clk     = <1000>;
                    rockchip,mipi_dsi_num   = <1>;
        disp_mipi_power_ctr: mipi_power_ctr {
                    compatible = "rockchip,mipi_power_ctr";
                    mipi_lcd_rst:mipi_lcd_rst{
                            compatible = "rockchip,lcd_rst";
                            rockchip,gpios = <&gpio0 GPIO_B5 GPIO_ACTIVE_LOW>;
                            rockchip,delay = <100>;
            disp_mipi_init_cmds: screen-on-cmds {
                                        rockchip,cmd_debug = <0>;
                                        compatible = "rockchip,screen-on-cmds";
                                        rockchip,on-cmds1 {
                                                        compatible = "rockchip,on-cmds";
                                                        rockchip,cmd_type = <LPDT>;
                                                        rockchip,dsi_id = <0>;
                                                        rockchip,cmd = <0x00 0x00>;
                                                        rockchip,cmd_delay = <0>;
                                        rockchip,on-cmds2 {
                                                        rockchip,cmd = <0xff 0x80 0x09 0x01>;
                                        rockchip,on-cmds3 {
                                                        rockchip,cmd = <0x00 0x80>;
                                        rockchip,on-cmds4 {
                                                        rockchip,cmd = <0xff 0x80 0x09>;
                                        rockchip,on-cmds5 {
                                   //有100多行Initial code   省略没贴
                        native-mode = <&timing0>;
                        compatible = "rockchip,display-timings";
                        timing0: timing0 {
                screen-type = <SCREEN_MIPI>;
                lvds-format = <LVDS_8BIT_2>;
                out-face    = <OUT_P888>;
                clock-frequency = <30000000>;
                hactive = <800>;
                vactive = <480>;
                hback-porch = <40>;
                hfront-porch = <50>;
                vback-porch = <10>;
                vfront-porch = <4>;
                hsync-len = <8>;
                vsync-len = <7>;
                hsync-active = <0>;
                vsync-active = <0>;
                de-active = <0>;
                pixelclk-active = <0>;
                swap-rb = <0>;
                swap-rg = <0>;
                swap-gb = <0>;
3./kernel/arch/arm/boot/dts/firefly-rk3288.dts下添加DST文件
修改lcd_rst的GPIO配置
4.由于是单通道,/kernel/arch/arm/boot/dts/rk3288.dtsi中配置dsihost0
5.连线()
编译烧录后发现屏无任何反应,应该是初始化都没有成功{:3_47:}
呼唤zhangsb大神,代码上是否哪里存在问题?{:3_59:}
Code.rar (2.59 KB)
cmd的第一个字节DSI数据类型没有写上去,还有没看到背光的配置
总结是个好习惯
背光我暂时没有配置,因为背光我是外供的,所以不会出现无背光的情况。
另外DSI数据类型是什么?我只有LCM的Initial,如何与DSI数据类型对应起来?
zhangsb大神,我有看到Data Type主要分为Generic xx write和DCS xx write。
以0x29和0x39为例,这两种Data Type在是使用的时候有什么区别么?
/*添加完Data Type的代码如下
 * author:
                /* about mipi */
                                        rockchip,dsi_hs_clk                = <940>;
                                        /*mipi_lcd_rst:mipi_lcd_rst{
                                        lcd_en:lcd_en {
                                                   rockchip,power_type = <GPIO>;
                                                   gpios = <&gpio7 GPIO_A3 GPIO_ACTIVE_HIGH>;
                                                   rockchip,delay = <10>;
                                        lcd_cs:lcd_cs {
                                                  gpios = <&gpio7 GPIO_A4 GPIO_ACTIVE_HIGH>;
                                        mipi_lcd_en:mipi_lcd_en {
                                                        compatible = "rockchip,lcd_en";
                                                        rockchip,gpios = <&gpio0 GPIO_C1 GPIO_ACTIVE_HIGH>;
                                        rockchip,on-cmds1 {
                                                        rockchip,cmd = <0x15 0x00 0x00>;
                                        rockchip,on-cmds2 {
                                                        rockchip,cmd = <0x39 0xff 0x80 0x09 0x01>;
                                        rockchip,on-cmds3 {
                                                        rockchip,cmd = <0x15 0x00 0x80>;
                                        rockchip,on-cmds4 {
                                                        rockchip,cmd = <0x39 0xff 0x80 0x09>;
                                        rockchip,on-cmds5 {
                                        rockchip,on-cmds6 {
                                                        rockchip,cmd = <0x39 0xf5 0x01 0x18 0x02 0x18 0x10 0x18 0x02 0x18 0x0e 0x18 0x0f 0x20>;
                                        rockchip,on-cmds7 {
                                                        rockchip,cmd = <0x15 0x00 0x90>;
                                         rockchip,on-cmds8 {
                                                        rockchip,cmd = <0x39 0xf5 0x02 0x18 0x08 0x18 0x06 0x18 0x0d 0x18 0x0b 0x18>;
                                        rockchip,on-cmds9 {
                                                        rockchip,cmd = <0x15 0x00 0xa0>;
                                        rockchip,on-cmds10 {
                                                        rockchip,cmd = <0x39 0xf5 0x10 0x18 0x01 0x18 0x14 0x18 0x14 0x18>; //0xff
                                        rockchip,on-cmds11 {
                                                        rockchip,cmd = <0x15 0x00 0xb0>;
                                        rockchip,on-cmds12 {
                                                        rockchip,cmd = <0x39 0xf5 0x14 0x18 0x12 0x18 0x13 0x18 0x11 0x18 0x13 0x18 0x00 0x00>;
                                        rockchip,on-cmds13 {
                                         rockchip,on-cmds14 {
                                                        rockchip,cmd = <0x39 0xc0 0x00 0x58 0x00 0x14 0x16>;
                                        rockchip,on-cmds15 {
                                                        rockchip,cmd = <0x15 0x00 0x8b>;
                                        rockchip,on-cmds16 {
                                                        rockchip,cmd = <0x15 0xb0 0x40>;
                                        rockchip,on-cmds17 {
                                                        rockchip,cmd = <0x15 0x00 0xc6>;
                                        rockchip,on-cmds18 {
                                                        rockchip,cmd = <0x15 0xb0 0x03>;
                                        rockchip,on-cmds19 {
                                                        rockchip,cmd = <0x15 0x00 0xb4>;
                                        rockchip,on-cmds20 {
                                                        rockchip,cmd = <0x15 0xc0 0x10>;
                                        rockchip,on-cmds21 {
                                                        rockchip,cmd = <0x15 0x00 0x82>;
                                        rockchip,on-cmds22 {
                                                        rockchip,cmd = <0x15 0xc5 0xa3>;
                                        rockchip,on-cmds23 {
                                        rockchip,on-cmds24 {
                                                        rockchip,cmd = <0x39 0xc5 0x96 0x38>;
                                        rockchip,on-cmds25 {
                                        rockchip,on-cmds26 {
                                                        rockchip,cmd = <0x39 0xd8 0x9f 0x9f>;
                                        rockchip,on-cmds27 {
                                        rockchip,on-cmds28 {
                                                        rockchip,cmd = <0x15 0xd9 0x82>;
                                        rockchip,on-cmds29 {
                                                        rockchip,cmd = <0x15 0x00 0x81>;
                                        rockchip,on-cmds30 {
                                                        rockchip,cmd = <0x15 0xc1 0x66>;
                                        rockchip,on-cmds31 {
                                        rockchip,on-cmds32 {
                                                        rockchip,cmd = <0x15 0xc1 0xea>;
                                        rockchip,on-cmds33 {
                                                        rockchip,cmd = <0x15 0x00 0xa1>;
                                        rockchip,on-cmds34 {
                                                        rockchip,cmd = <0x15 0xc1 0x08>;
                                        rockchip,on-cmds35 {
                                                        rockchip,cmd = <0x15 0x00 0x89>;
                                        rockchip,on-cmds36 {
                                                        rockchip,cmd = <0x15 0xc4 0x08>;
                                        rockchip,on-cmds37 {
                                                        rockchip,cmd = <0x15 0x00 0xa3>;
                                        rockchip,on-cmds38 {
                                                        rockchip,cmd = <0x15 0xc0 0x00>;
                                        rockchip,on-cmds39 {
                                        rockchip,on-cmds40 {
                                                        rockchip,cmd = <0x15 0xc4 0x30>;
                                        rockchip,on-cmds41 {
                                                        rockchip,cmd = <0x15 0x00 0x8a>;
                                        rockchip,on-cmds42 {
                                                        rockchip,cmd = <0x15 0xc4 0x40>;
                                        rockchip,on-cmds43 {
                                        rockchip,on-cmds44 {
                                                        rockchip,cmd = <0x15 0xc4 0x83>;
                                        rockchip,on-cmds45 {
                                                        rockchip,cmd = <0x15 0x00 0x92>;
                                        rockchip,on-cmds46 {
                                                        rockchip,cmd = <0x39 0xc5 0x01 0x03>;
                                        rockchip,on-cmds47 {
                                                        rockchip,cmd = <0x15 0x00 0xb1>;
                                        rockchip,on-cmds48 {
                                                        rockchip,cmd = <0x39 0xc5 0xa9 0x15 0x00 0x15 0x00>;
                                        rockchip,on-cmds49 {
                                                        rockchip,cmd = <0x15 0x00 0xc0>;
                                        rockchip,on-cmds50 {
                                                        rockchip,cmd = <0x15 0xc5 0x00>;
                                        rockchip,on-cmds51 {
                                        rockchip,on-cmds52 {
                                                        rockchip,cmd = <0x15 0xb3 0x02>;
                                        rockchip,on-cmds53 {
                                        rockchip,on-cmds54 {
                                                        rockchip,cmd = <0x15 0xb3 0x45>;
                                        rockchip,on-cmds55 {
                                                        rockchip,cmd = <0x15 0x00 0x40>;
                                        rockchip,on-cmds56 {
                                        rockchip,on-cmds57 {
                                        rockchip,on-cmds58 {
                                                        rockchip,cmd = <0x39 0xc0 0x00 0x44 0x00 0x00 0x00 0x03>;
                                        rockchip,on-cmds59 {
                                                        rockchip,cmd = <0x15 0x00 0xa6>;
                                        rockchip,on-cmds60 {
                                                        rockchip,cmd = <0x39 0xc1 0x01 0x00 0x00>;
                                        rockchip,on-cmds61 {
                                        rockchip,on-cmds62 {
                                                        rockchip,cmd = <0x39 0xce 0x85 0x03 0x00 0x84 0x03 0x00>;
                                        rockchip,on-cmds63 {
                                        rockchip,on-cmds64 {
                                                        rockchip,cmd = <0x39 0xce 0x33 0x5c 0x00 0x33 0x5d 0x00>;
                                        rockchip,on-cmds65 {
                                        rockchip,on-cmds66 {
                                                        rockchip,cmd = <0x39 0xce 0x38 0x03 0x03 0x56 0x00 0x00 0x00 0x38 0x02 0x03 0x57 0x00 0x00 0x00>;
                                        rockchip,on-cmds67 {
                                        rockchip,on-cmds68 {
                                                        rockchip,cmd = <0x39 0xce 0x38 0x01 0x03 0x58 0x00 0x00 0x00 0x38 0x00 0x03 0x59 0x00 0x00 0x00>;
                                        rockchip,on-cmds69 {
                                        rockchip,on-cmds70 {
                                                        rockchip,cmd = <0x39 0xce 0x30 0x00 0x03 0x5a 0x00 0x00 0x00 0x30 0x01 0x03 0x5b 0x00 0x00 0x00>;
                                        rockchip,on-cmds71 {
                                                        rockchip,cmd = <0x15 0x00 0xd0>;
                                        rockchip,on-cmds72 {
                                                        rockchip,cmd = <0x39 0xce 0x30 0x02 0x03 0x5c 0x00 0x00 0x00 0x30 0x03 0x03 0x5d 0x00 0x00 0x00>;
                                        rockchip,on-cmds73 {
                                                        rockchip,cmd = <0x15 0x00 0xc7>;
                                        rockchip,on-cmds74 {
                                                        rockchip,cmd = <0x15 0xcf 0x00>;
                                        rockchip,on-cmds75 {
                                        rockchip,on-cmds76 {
                                                        rockchip,cmd = <0x39 0xcb 0x00 0x00 0x00 0x00 0x54 0x54 0x54 0x54 0x00 0x54 0x00 0x54 0x00 0x00 0x00>;
                                        rockchip,on-cmds77 {
                                        rockchip,on-cmds78 {
                                                        rockchip,cmd = <0x39 0xcb 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x54 0x54 0x54 0x54 0x00 0x54>;
                                        rockchip,on-cmds79 {
                                                        rockchip,cmd = <0x15 0x00 0xe0>;
                                        rockchip,on-cmds80 {
                                                        rockchip,cmd = <0x39 0xcb 0x00 0x54 0x00 0x00 0x00 0x00 0x00 0x00 0x00>;
                                        rockchip,on-cmds81 {
                                        rockchip,on-cmds82 {
                                                        rockchip,cmd = <0x39 0xcc 0x00 0x00 0x00 0x00 0x0c 0x0a 0x10 0x0e 0x00 0x02>;
                                        rockchip,on-cmds83 {
                                        rockchip,on-cmds84 {
                                                        rockchip,cmd = <0x39 0xcc 0x00 0x06 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0b>;
                                        rockchip,on-cmds85 {
                                        rockchip,on-cmds86 {
                                                        rockchip,cmd = <0x39 0xcc 0x09 0x0f 0x0d 0x00 0x01 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00>;
                                        rockchip,on-cmds87 {
                                        rockchip,on-cmds88 {
                                                        rockchip,cmd = <0x39 0xcc 0x00 0x00 0x00 0x00 0x0d 0x0f 0x09 0x0b 0x00 0x05>;
                                        rockchip,on-cmds89 {
                                        rockchip,on-cmds90 {
                                                        rockchip,cmd = <0x39 0xcc 0x00 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0e>;
                                        rockchip,on-cmds91 {
                                        rockchip,on-cmds92 {
                                                        rockchip,cmd = <0x39 0xcc 0x10 0x0a 0x0c 0x00 0x06 0x00 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00>;
                                        rockchip,on-cmds93 {
                                        rockchip,on-cmds94 {
                                                        rockchip,cmd = <0x39 0xe1 0x01 0x0b 0x11 0x0d 0x06 0x0f 0x0b 0x0a 0x04 0x07 0x0f 0x08 0x0f 0x0f 0x09 0x06>;
                                        rockchip,on-cmds95 {
                                        rockchip,on-cmds96 {
                                                        rockchip,cmd = <0x39 0xe2 0x01 0x0c 0x12 0x0d 0x06 0x0e 0x0b 0x0a 0x03 0x07 0x0e 0x09 0x0f 0x0f 0x09 0x06>;
                                        rockchip,on-cmds97 {
                                        rockchip,on-cmds98 {
                                        rockchip,on-cmds99 {
                                        rockchip,on-cmds100 {
                                        rockchip,on-cmds101 {
                                        rockchip,on-cmds102 {
                                        rockchip,on-cmds103 {
                                        rockchip,on-cmds104 {
                                                        rockchip,cmd = <0x39 0xff 0xff 0xff 0xff>;
                                        rockchip,on-cmds105 {
                                                        rockchip,cmd = <0x15 0x35 0x00>;
                                        rockchip,on-cmds106 {
                                                        rockchip,cmd = <0x15 0x11>;
                                                        rockchip,cmd_delay = <120>;
                                        rockchip,on-cmds107 {
                                                        rockchip,cmd = <0x15 0x29>;
                        timing0: timing0 {
                                hactive = <854>;
                                vactive = <480>;
                                hback-porch = <40>;
                                vback-porch = <10>;
                                vfront-porch = <4>;
                                hsync-len = <8>;
                                vsync-len = <7>;
                                hsync-active = <0>;
                                vsync-active = <0>;
                                de-active = <0>;
                                swap-rb = <0>;
                                swap-rg = <0>;
                                swap-gb = <0>;
以上为dtsi的配置。另外我试着抓出fb0中的图片,发现其分辨率变为480x800。
仔细查找发现原来timing设置中把480x854竖屏写成了横屏{:3_47:}。。。
改完后抓出来的图片分辨率就是480x854了。。。。
发现已经有闪烁的迹象了,但是还是没显示。由于数据线都是用跳线形式,猜想会不会是因为速率太快使信号丢失了?
继续改{:3_46:}
将dsi_hs_clk改为500M
继续编译烧写固件
奇迹出现啦,虽然有问题,但是有画面啦~~~~{:3_59:}
既然屏已经点亮,系统的问题还是另开新帖再问大神吧~~~~~
希望对大家有一些帮助~~~
請教一下,dsi_hs_clk的設定是如何得知的?
系统没有你这个分辨率的资源,得自己修改。systemui里面的
请问你是用的那个源码:是普通版的,还是PAD版的,有用官方提供的更新操作么?
gufengdianxia 发表于 2015-2-16 15:06
仔细查找发现原来timing设置中把480x854竖屏写成了横屏。。。
改完后抓出来的图片分辨率就是4 …
源吗是用的普通还是PAD的。根据这个文档中:http://wiki.t-firefly.com/index.php/Firefly-RK3288/Build_android 中提到的 更新操作:git clone -b firefly/master git://git.us.linux-rockchip.org/rk3288_r-box_android4.4.2_sdk.git你这边有做么?我也在研究这个MIPI接口,可惜一直都没有亮
pad版本的 去年过年时候搞得 目前没更新过
需要如何修改?我是修改了DPI后显示正常
我试出来的 我这屏幕小 速度无所谓
你遇到什么问题了么?什么分辨率的屏
gufengdianxia 发表于 2015-7-13 08:01
你遇到什么问题了么?什么分辨率的屏
请教个问题,屏的驱动代码是放什么位置的?我看了半天没看得屏怎么初始化出来的。。。
这里面只有一些dts的配置吧,初始化休眠之类的都不需要?
请问楼主用pad版本的,添加文件步骤相同,最后没有信号输出是怎么回事啊,好像进入什么睡眠模式,要怎么办?
gufengdianxia你好,
想请问你DPI是在哪修改的?
我现在这边有一块320x480的3.5吋的屏幕, 目前也还没点出画面…
