RK3288上面点LCD屏,一直缺色无法解决,换了其他屏点现象一样。反复对比信号连接正常而且也没复用,希望版主和知道的大神给个方向!!
是否可以查看一下是指的RGB格式是否对应?
dts中的 这个配置。
out-face =
dts中的 这个配置。
out-face =
这样配置的,缺色很明显,感觉不是8BIT的
timing0: timing0 {
screen-type = <SCREEN_RGB>;
out-face = <OUT_P888>; //在这里配置8bit(P888)和6bit(P666)
color-mode = <COLOR_YCBCR>;
clock-frequency = <51200000>;
hactive = <1024>;
vactive = <600>;
hback-porch = <140>;
hfront-porch = <160>;
vback-porch = <20>;
vfront-porch = <12>;
hsync-len = <20>;
vsync-len = <3>;
hsync-active = <1>;
vsync-active = <1>;
de-active = <0>;
pixelclk-active = <0>;
swap-rb = <0>;
swap-rg = <0>;
swap-gb = <0>;
