编译Android固件打包烧写后进不去系统?
依维基教程编译Android 固件
最后打包成统一固件update.img
烧写后进不去系统…
会卡在有Firefly的画面不动
怎办?
DDR Version 1.00 20141007
SRX
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
U-Boot 2014.10-RK3288-02 (Feb 17 2015 - 12:00:55)
CPU: rk3288
CPU's clock information:
    arm pll = 600000000HZ
    periph pll = 300000000HZ
    ddr pll = 200000000HZ
    codec pll = 594000000HZ
Board:	Rockchip platform Board
DRAM:  Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
can't find dts node for ricoh619
pmic:act8846
#Boot ver: 2015-02-17#2.17
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
Hit any key to stop autoboot:  1  0
failed to load fdt from boot!
kernel   @ 0x02000000 (0x005f8ad8)
ramdisk  @ 0x04bf0000 (0x00120f15)
Secure Boot state: 0
bootrk: do_bootm_linux...
   Loading Device Tree to 0480c000, end 04827184 ... OK
Starting kernel ...
<hit enter to activate fiq debugger>
[    0.000000] Booting Linux on physical CPU 0x500
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.0 (luffy@luffy-UbuntuV1204) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Fri Feb 13 18:26:41 CST 2015
[    0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288
[    0.000000] hdmi init vic is -1
[    0.000000] rockchip_ion_reserve
[    0.000000] cma: CMA: reserved 16 MiB at 2e800000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] Boot mode: REBOOT (6) flag: NORMAL (0xc3524200)
[    0.000000] PERCPU: Embedded 9 pages/cpu @c1eb6000 s14016 r8192 d14656 u36864
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 522768
[    0.000000] Kernel command line: console=ttyFIQ0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 board.ap_has_alsa=0 init=/init  mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00020000@0x00414000(radical_update),-@0x00434000(user) storagemedia=emmc loader.timestamp=2015-02-17_12:00:55 hdmi.vic=-1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 2048MB = 2048MB total
[    0.000000] Memory: 2047084k/2047084k available, 50068k reserved, 1318912K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0a76cb8   (10684 kB)
[    0.000000]       .init : 0xc0a77000 - 0xc0cc66c0   (2366 kB)
[    0.000000]       .data : 0xc0cc8000 - 0xc0d64ec8   ( 628 kB)
[    0.000000]        .bss : 0xc0d64ec8 - 0xc0e7ee04   (1128 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] rk_clk_tree_init start! cru base = 0xfed00000
[    0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0
[    0.000000] rkclk_init_clks: cnt_parent = 7
[    0.000000] rkclk_init_clks: cnt_rate = 32
[    0.000000] Architected local timer running at 24.00MHz (phys).
[    0.000000] Switching to timer-based delay loop
[    0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns
[    0.000000] process version: 0
[    0.000000] channel:0, lkg:0
[    0.000000] target-temp:95
[    0.000000] channel:2, lkg:0
[    0.000000] channel:1, lkg:0
[    0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
[    0.522376] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.522427] pid_max: default: 32768 minimum: 301
[    0.522768] Security Framework initialized
[    0.522809] SELinux:  Initializing.
[    0.523040] Mount-cache hash table entries: 512
[    0.525076] Initializing cgroup subsys debug
[    0.525121] Initializing cgroup subsys freezer
[    0.525212] CPU: Testing write buffer coherency: ok
[    0.525982] /cpus/cpu@0 missing clock-frequency property
[    0.526024] /cpus/cpu@1 missing clock-frequency property
[    0.526059] /cpus/cpu@2 missing clock-frequency property
[    0.526091] /cpus/cpu@3 missing clock-frequency property
[    0.526218] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[    0.526331] Setting up static identity map for 0xc078b0a8 - 0xc078b100
[    0.530054] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x14f8 (version 3.0)
[    0.610250] CPU1: Booted secondary processor
[    0.610341] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[    0.629973] CPU2: Booted secondary processor
[    0.630056] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[    0.649765] CPU3: Booted secondary processor
[    0.649847] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[    0.650220] Brought up 4 CPUs
[    0.650319] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.650350] CPU: All CPU(s) started in SVC mode.
[    0.652575] devtmpfs: initialized
[    0.669986] pinctrl core: initialized pinctrl subsystem
[    0.670721] regulator-dummy: no parameters
[    0.672360] NET: Registered protocol family 16
[    0.677493] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.678418] ion_snapshot: 0x2e230000 map to 0xf0107000 and copy to 0xc0e5a454 (version 0.1)
[    0.678912] Registered FIQ tty driver
[    0.682486] console [ttyFIQ0] enabled
[    0.682948] Registered fiq debugger ttyFIQ0
[    0.684703] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[    0.684792] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[    0.684865] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[    0.684937] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[    0.685203] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[    0.685431] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[    0.685656] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[    0.685883] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[    0.686107] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[    0.686338] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[    0.686566] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[    0.686789] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[    0.687031] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[    0.687268] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[    0.687326] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[    0.687378] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[    0.687430] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[    0.689160] rockchip_interrupts_register:bank_num=7
[    0.695769] of_get_gpio_init_config:gpio[0] = 256, value = 0
[    0.695854] of_get_gpio_init_config:gpio[1] = 233, value = 0
[    0.695936] of_get_gpio_init_config:gpio[2] = 136, value = 0
[    0.696111] rockchip_pinctrl_probe:init ok
[    0.716097] rk_iommu ff900800.iep_mmu: (iep) Enter
[    0.716445] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[    0.716501] rk_iommu ff900800.iep_mmu: (iep) Initialized
[    0.717077] rk_iommu ff950800.vip_mmu: (vip) Enter
[    0.717399] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[    0.717453] rk_iommu ff950800.vip_mmu: (vip) Initialized
[    0.717999] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[    0.718323] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[    0.718377] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[    0.718944] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[    0.719268] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[    0.719321] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[    0.719943] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[    0.720328] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[    0.720381] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[    0.720950] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[    0.721273] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[    0.721326] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[    0.721900] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[    0.722280] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[    0.722333] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[    0.728024] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.728082] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.728703] DDR DEBUG: version 1.00 20140603
[    0.728786] DDR DEBUG: Channel a:
[    0.728823] DDR DEBUG: DDR3 Device
[    0.728873] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[    0.728915] DDR DEBUG: Channel b:
[    0.728947] DDR DEBUG: DDR3 Device
[    0.728992] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[    0.729035] DDR DEBUG: addr=0xd6a000
[    0.729074] DDR DEBUG: stride=9, size=256, halfcap=40000000
[    0.729114] DDR DEBUG: socAddr[0]=0xd6a000, socAddr[1]=0xd6a100
[    0.729155] DDR DEBUG: chAddr[0]=0xd6a000, chAddr[1]=0xd6a000
[    0.729201] DDR DEBUG: dtar[0]=0x201ad000, dtar[1]=0x201ad000
[    0.729414] DDR DEBUG: init success!!! freq=200MHz
[    0.729452] DDR DEBUG: Channel a:
[    0.729500] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[    0.729559] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[    0.729618] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[    0.729675] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[    0.729727] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[    0.729770] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[    0.729809] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[    0.729843] DDR DEBUG: Channel b:
[    0.729889] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[    0.729947] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[    0.730004] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[    0.730062] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[    0.730113] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[    0.730155] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[    0.730194] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[    0.805859] bio: create slab <bio-0> at 0
[    0.807789] Enter firefly_noatx8_init
[    0.808251] firefly_noatx8_probe 51
[    0.808992] SCSI subsystem initialized
[    0.809490] usbcore: registered new interface driver usbfs
[    0.809645] usbcore: registered new interface driver hub
[    0.809942] usbcore: registered new device driver usb
[    0.812968] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[    0.817285] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[    0.818868] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[    0.820350] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[    0.821167] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[    0.824029] media: Linux media interface: v0.10
[    0.824173] Linux video capture interface: v2.00
[    0.824330] pps_core: LinuxPPS API ver. 1 registered
[    0.824373] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.824457] PTP clock support registered
[    0.824906] rockchip_temp_probe,line=362
[    0.825698] tsadc ff280000.tsadc: initialized
[    0.826981] rockchip_ion_parse_dt: num_heaps = 1
[    0.827041] 0:  0  3  vmalloc  0x  (null)
[    0.827877] Rockchip ion module is successfully loaded (v1.0)
[    0.828457] Advanced Linux Sound Architecture Driver Initialized.
[    0.829632] Bluetooth: Core ver 2.16
[    0.829799] NET: Registered protocol family 31
[    0.829844] Bluetooth: HCI device and connection manager initialized
[    0.829905] Bluetooth: HCI socket layer initialized
[    0.829957] Bluetooth: L2CAP socket layer initialized
[    0.830052] Bluetooth: SCO socket layer initialized
[    0.830732] cfg80211: Calling CRDA to update world regulatory domain
[    0.833115] act8846_i2c_probe,line=898
[    0.834494] act8846_parse_dt,line=746
[    0.836000] act8846_i2c_probe: act8846_pmic_hold=1
[    0.836071] act8846_i2c_probe: act8846_pmic_sleep=1
[    0.836128] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[    0.836186] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[    0.838659] act_dcdc1: 1200 mV
[    0.842361] vccio: 3300 mV
[    0.844959] vdd_logic: 700 <--> 1500 mV at 1125 mV
[    0.848867] act_dcdc4: 2000 mV
[    0.850684] vccio_sd: 1800 <--> 3300 mV at 3300 mV
[    0.853537] act_ldo2: 1050 mV
[    0.856388] act_ldo3: 1800 mV
[    0.859261] act_ldo4: 3300 mV
[    0.862144] act_ldo5: 3300 mV
[    0.864976] act_ldo6: 1100 mV
[    0.867848] vcc_18: 1800 mV
[    0.870696] act_ldo8: 1850 mV
[    0.877201] vdd_arm: 712 <--> 1500 mV at 1012 mV
[    0.883484] vdd_gpu: 712 <--> 1500 mV at 900 mV
[    0.884472] rk808_i2c_probe,line=1368
[    0.886103] The device is not rk808 -11
[    0.886367] rk808: probe of 0-001b failed with error -11
[    0.890652] Switching to clocksource arch_sys_counter
[    0.911221] usb_battery_charger_detect_synop , battery_charger_detect 1, pass DCD, dcd_state = 1
[    0.957644] rk-fb rockchip-fb: rk fb ion client create success!
[    0.957715] rk-fb rockchip-fb: rockchip framebuffer driver probe
[    0.958803] rk-screen rk_screen.9: rockchip screen probe success
[    0.959574] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[    0.960408] rk32-edp ff970000.edp: screen is not edp!
[    0.960482] rk32-edp: probe of ff970000.edp failed with error -22
[    0.961597] rk3288-lcdc lcdc0: can't find power_ctr node for lcdc0
[    0.962389] graphics fb0: rockchip framebuffer registerd:fb0
[    0.963406] graphics fb1: rockchip framebuffer registerd:fb1
[    0.963948] graphics fb2: rockchip framebuffer registerd:fb2
[    0.964486] graphics fb3: rockchip framebuffer registerd:fb3
[    0.965032] graphics fb4: rockchip framebuffer registerd:fb4
[    0.966718] rk_iommu ff930300.vopb_mmu: (vopb) Enabled
[    0.967143] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[    0.967213] rk3288-lcdc lcdc0: wakeup from standby!
[    1.101637] alloc_buffer:ion_phy_addr=0x10000000
[    1.144973] fb0:phy:10000000>>vir:f0191000>>len:0x1800000
[    1.259052] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[    1.260209] rockchip_set_mux:warning ignore bank num 15
[    1.260640] rockchip_set_mux:warning ignore bank num 15
[    1.261036] rockchip_set_mux:warning ignore bank num 15
[    1.261426] rockchip_set_mux:warning ignore bank num 15
[    1.261814] rockchip_set_mux:warning ignore bank num 15
[    1.262203] rockchip_set_mux:warning ignore bank num 15
[    1.263081] rockchip_set_mux:warning ignore bank num 15
[    1.263566] rockchip_set_mux:warning ignore bank num 15
[    1.264450] rockchip_set_mux:warning ignore bank num 15
[    1.265032] rockchip_set_mux:warning ignore bank num 15
[    1.265846] rockchip_set_mux:warning ignore bank num 15
[    1.266343] rockchip_set_mux:warning ignore bank num 15
[    1.267122] rockchip_set_mux:warning ignore bank num 15
[    1.267632] rockchip_set_mux:warning ignore bank num 15
[    1.271897] NET: Registered protocol family 2
[    1.273388] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    1.273876] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    1.274372] TCP: Hash tables configured (established 8192 bind 8192)
[    1.274524] TCP: reno registered
[    1.274677] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    1.274814] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    1.275470] NET: Registered protocol family 1
[    1.276029] Unpacking initramfs...
[    1.499870] Freeing initrd memory: 1152K (c4bf0000 - c4d10000)
[    1.501619] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[    1.503037] probe device ff9a0000.vpu_service
[    1.503469] vpu_service: power on
[    1.504621] checking hw id 4831
[    1.505674] vpu_service set to auto frequency mode
[    1.505847] vcodec vpu_service: vcodec ion client create success!
[    1.506973] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled
[    1.507081] rk_iommu ff9a0800.vpu_mmu: (vpu) Disabled
[    1.507134] rk_iommu ff9a0800.vpu_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e27f000
[    1.507181] vpu_service: power off...
[    1.507266] done
[    1.507297] init success
[    1.507460] probe device ff9c0000.hevc_service
[    1.508058] hevc_service: power on
[    1.509176] checking hw id 6867
[    1.510041] vcodec hevc_service: vcodec ion client create success!
[    1.511033] rk_iommu ff9c0440.hevc_mmu: (hevc) Enabled
[    1.511143] rk_iommu ff9c0440.hevc_mmu: (hevc) Disabled
[    1.511195] rk_iommu ff9c0440.hevc_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e27c000
[    1.511242] hevc_service: power off...
[    1.511327] done
[    1.511358] init success
[    1.511727] rknandbase v1.0 2014-03-31
[    1.512359] rknand_probe clk rate = 148500000
[    1.512737] rknand_driver:ret = 0
[    1.513834] audit: initializing netlink socket (disabled)
[    1.513948] type=2000 audit(1.000:1): initialized
[    1.516264] bounce pool size: 64 pages
[    1.531866] fuse init (API version 7.22)
[    1.533115] msgmni has been set to 1456
[    1.539113] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.539174] io scheduler noop registered
[    1.539214] io scheduler deadline registered
[    1.539559] io scheduler cfq registered (default)
[    1.541961] rga ff920000.rga: rga ion client create success!
[    1.542455] rga: Driver loaded succesfully
[    1.543950] IEP Power ON
[    1.544069] iep ion client create success!
[    1.545047] rk_iommu ff900800.iep_mmu: (iep) Enabled
[    1.545140] IEP Power OFF
[    1.545187] rk_iommu ff900800.iep_mmu: (iep) Disabled
[    1.545241] rk_iommu ff900800.iep_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e272000
[    1.545303] IEP Driver loaded succesfully
[    1.545593] Module initialized.
[    1.547983] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[    1.548056] dma-pl330 ffb20000.pdma: 	DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[    1.552491] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[    1.552564] dma-pl330 ff250000.pdma: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    1.553302] pwm-voltage-regulator pwm_regulator.23: unable to request PWM, trying legacy API
[    1.553365] pwm-voltage-regulator pwm_regulator.23: unable to request legacy PWM
[    1.553408] pwm_regulator_probe:error
[    1.553480] platform pwm_regulator.23: Driver pwm-voltage-regulator requests probe deferral
[    1.554560] rk_serial.c v1.8 2014-03-04
[    1.555197] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[    1.555859] serial ff180000.serial: membase 0xf0172000
[    1.565559] loop: module loaded
[    1.567306] SCSI Media Changer driver v0.25
[    1.568302] tun: Universal TUN/TAP device driver, 1.6
[    1.568350] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.570016] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[    1.570075] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
[    1.570123] stmmac_probe_config_dt: clock input or output? (input).
[    1.570168] stmmac_probe_config_dt: TX delay(0x30).
[    1.570209] stmmac_probe_config_dt: RX delay(0x10).
[    1.570332] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[    1.570372] stmmc_pltfr_init:
[    1.570408] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[    1.570483] stmmc_pltfr_init: ERROR: Request gmac phy reset pin failed.
[    1.570522] stmmc_pltfr_init: init for RGMII
[    1.570562] tx delay=0x30
[    1.570562] rx delay=0x10
[    1.571993] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    1.572035]  Normal descriptors
[    1.572066]  Ring mode enabled
[    1.572099]  DMA HW capability register supported
[    1.572137]  RX Checksum Offload Engine supported (type 2)
[    1.572174]  TX Checksum insertion supported
[    1.572207]  Wake-Up On Lan supported
[    1.572324]  Enable RX Mitigation via HW Watchdog Timer
[    1.573596] PPP generic driver version 2.4.2
[    1.574095] PPP BSD Compression module registered
[    1.574142] PPP Deflate Compression module registered
[    1.574204] PPP MPPE Compression module registered
[    1.574246] NET: Registered protocol family 24
[    1.574341] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[    1.574389] CSLIP: code copyright 1989 Regents of the University of California.
[    1.574434] Rockchip WiFi SYS interface (V1.00) ...
[    1.574677] usbcore: registered new interface driver catc
[    1.574809] usbcore: registered new interface driver kaweth
[    1.574854] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    1.574985] usbcore: registered new interface driver pegasus
[    1.575111] usbcore: registered new interface driver rtl8150
[    1.575236] usbcore: registered new interface driver r8152
[    1.575275] hso: drivers/net/usb/hso.c: Option Wireless
[    1.575499] usbcore: registered new interface driver hso
[    1.575650] usbcore: registered new interface driver asix
[    1.575778] usbcore: registered new interface driver ax88179_178a
[    1.575906] usbcore: registered new interface driver cdc_ether
[    1.576033] usbcore: registered new interface driver cdc_eem
[    1.576159] usbcore: registered new interface driver dm9601
[    1.576286] usbcore: registered new interface driver dm9620
[    1.576478] usbcore: registered new interface driver smsc75xx
[    1.576639] usbcore: registered new interface driver smsc95xx
[    1.576780] usbcore: registered new interface driver gl620a
[    1.576908] usbcore: registered new interface driver net1080
[    1.577037] usbcore: registered new interface driver plusb
[    1.577167] usbcore: registered new interface driver rndis_host
[    1.577310] usbcore: registered new interface driver cdc_subset
[    1.577437] usbcore: registered new interface driver zaurus
[    1.577573] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    1.577751] usbcore: registered new interface driver int51x1
[    1.577883] usbcore: registered new interface driver kalmia
[    1.578012] usbcore: registered new interface driver ipheth
[    1.578154] usbcore: registered new interface driver sierra_net
[    1.578299] usbcore: registered new interface driver cx82310_eth
[    1.578460] usbcore: registered new interface driver cdc_ncm
[    1.578592] usbcore: registered new interface driver qmi_wwan
[    1.578724] usbcore: registered new interface driver cdc_mbim
[    1.578766] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.582062] ehci_rk_probe f1a00000 f1a00010
[    1.582123] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller
[    1.582223] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[    1.583294] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[    1.599375] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00
[    1.599610] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.599672] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.599728] usb usb1: Product: Rockchip On-Chip EHCI Host Controller
[    1.599778] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[    1.599825] usb usb1: SerialNumber: ff500000.usb
[    1.601221] hub 1-0:1.0: USB hub found
[    1.601300] hub 1-0:1.0: 1 port detected
[    1.628890] ehci_rk_probe ok
[    1.629351] usbcore: registered new interface driver cdc_acm
[    1.629398] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.629584] usbcore: registered new interface driver usblp
[    1.629740] usbcore: registered new interface driver cdc_wdm
[    1.629944] usbcore: registered new interface driver usb-storage
[    1.630074] usbcore: registered new interface driver ums-alauda
[    1.630202] usbcore: registered new interface driver ums-cypress
[    1.630327] usbcore: registered new interface driver ums-datafab
[    1.630450] usbcore: registered new interface driver ums_eneub6250
[    1.630573] usbcore: registered new interface driver ums-freecom
[    1.630697] usbcore: registered new interface driver ums-isd200
[    1.630820] usbcore: registered new interface driver ums-jumpshot
[    1.630957] usbcore: registered new interface driver ums-karma
[    1.631085] usbcore: registered new interface driver ums-onetouch
[    1.631211] usbcore: registered new interface driver ums-sddr09
[    1.631336] usbcore: registered new interface driver ums-sddr55
[    1.631462] usbcore: registered new interface driver ums-usbat
[    1.631735] usbcore: registered new interface driver usbserial
[    1.631869] usbcore: registered new interface driver usbserial_generic
[    1.631984] usbserial: USB Serial support registered for generic
[    1.632131] usbcore: registered new interface driver option
[    1.632242] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.632481] usbcore: registered new interface driver trancevibrator
[    1.632527] usb20_otg: version 3.10a 21-DEC-2012
[    1.633541] f1a80040
[    1.633589] Core Release: 3.10a
[    1.633627] Setting default values for core params
[    1.634059] Using Buffer DMA mode
[    1.634101] Periodic Transfer Interrupt Enhancement - disabled
[    1.634140] Multiprocessor Interrupt Enhancement - disabled
[    1.634182] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.634219] ^^^^^^^^^^^^^^^^^Device Mode
[    1.634263] Dedicated Tx FIFOs mode
[    1.634321] pcd_init otg_dev = ed96f6c0
[    1.634798] usb20_otg ff580000.usb: DWC OTG Controller
[    1.634892] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[    1.634998] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[    1.635189] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.635247] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.635299] usb usb2: Product: DWC OTG Controller
[    1.635345] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[    1.635392] usb usb2: SerialNumber: ff580000.usb
[    1.636703] hub 2-0:1.0: USB hub found
[    1.636784] hub 2-0:1.0: 1 port detected
[    1.637710] usb20_host: version 3.10a 21-DEC-2012
[    1.641245] f1b00040
[    1.641293] Core Release: 3.10a
[    1.641331] Setting default values for core params
[    1.641732] Using Buffer DMA mode
[    1.641772] Periodic Transfer Interrupt Enhancement - disabled
[    1.641811] Multiprocessor Interrupt Enhancement - disabled
[    1.641852] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.641888] ^^^^^^^^^^^^^^^^^^Host Mode
[    1.641978] usb20_host ff540000.usb: DWC OTG Controller
[    1.642068] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[    1.642185] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[    1.642352] Init: Power Port (0)
[    1.642534] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    1.642594] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.642646] usb usb3: Product: DWC OTG Controller
[    1.642692] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[    1.642738] usb usb3: SerialNumber: ff540000.usb
[    1.644049] hub 3-0:1.0: USB hub found
[    1.644128] hub 3-0:1.0: 1 port detected
[    1.645773] .. rk pwm remotectl v1.0 init
[    1.646021] remotectl probe j=0x0
[    1.646578] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[    1.647157] pwm enable val=0x646205
[    1.647999] usbcore: registered new interface driver xpad
[    1.648162] usbcore: registered new interface driver usb_acecad
[    1.648309] usbcore: registered new interface driver aiptek
[    1.648451] usbcore: registered new interface driver gtco
[    1.648685] usbcore: registered new interface driver hanwang
[    1.648836] usbcore: registered new interface driver kbtab
[    1.649000] usbcore: registered new interface driver wacom
[    1.650109] sensor_register_slave:mma8452,id=17
[    1.650160] sensor_register_slave:cm3217,id=44
[    1.650202] sensor_register_slave:cm3218,id=45
[    1.656741] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[    1.656918] i2c /dev entries driver
[    1.659160] IR NEC protocol handler initialized
[    1.659209] IR RC5(x) protocol handler initialized
[    1.659246] IR RC6 protocol handler initialized
[    1.659281] IR JVC protocol handler initialized
[    1.659316] IR Sony protocol handler initialized
[    1.659351] IR RC5 (streamzap) protocol handler initialized
[    1.659388] IR SANYO protocol handler initialized
[    1.659426] IR MCE Keyboard/mouse protocol handler initialized
[    1.659678] usbcore: registered new interface driver uvcvideo
[    1.659720] USB Video Class driver (1.1.1)
[    1.659765] CamSys driver version: v0.19.0,  CamSys head file version: v0.8.0
[    1.662965] D1:camsys_platform_probe(1061): 1-gpios-cifpower: gpio=236
[    1.663051] D1:camsys_platform_probe(1064): gpios-cifpower: gpio_request
[    1.663115] D1:camsys_platform_probe(1066): 1-gpios-cifpower: gpio_request=0
[    1.663180] D1:camsys_platform_probe(1075): gpios-cifpower: 236 high
[    1.663398] D1:camsys_mipiphy_probe_cb(163): ff910000.isp mipi phy0 probe success(reg_phy: 0x0  reg_vir: 0x0  size: 0x0)
[    1.663865] D1:camsys_mipiphy_probe_cb(160): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000  reg_vir: 0xf19b0000  size: 0x4000)
[    1.665953] D1:camsys_platform_probe(1208): ff910000.isp memory:
[    1.666016] D1:camsys_platform_probe(1218):     Register memory (phy: 0xff910000 vir: 0xf19e0000 size: 0x10000)
[    1.666076] D1:camsys_platform_probe(1213):     I2c memory (phy: 0x2d9df000 vir: 0xed9df000 size: 0x1000)
[    1.666130] D1:camsys_platform_probe(1233): Probe ff910000.isp device success
[    1.669172] device-mapper: uevent: version 1.0.3
[    1.669935] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[    1.670911] Bluetooth: HCI UART driver ver 2.2
[    1.670962] Bluetooth: HCI H4 protocol initialized
[    1.671002] Bluetooth: HCILL protocol initialized
[    2.456877] cpufreq version 1.0, suspend freq 1200 MHz
[    2.457463] cpuidle: using governor ladder
[    2.457508] cpuidle: using governor menu
[    2.457649] Synopsys Designware Multimedia Card Interface Driver
[    2.458414] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[    2.459223] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[    2.459732] 3230..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[    2.459787] Line3235..dw_mci_init_slot: The rk_sdmmc Ver 1.12 2014-07-08
[    2.460170] 1357..dw_mci_set_ios:  no card. [mmc0]
[    2.475173] 1357..dw_mci_set_ios:  no card. [mmc0]
[    2.494773] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[    2.494813] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[    2.494838] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[    2.495198] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[    2.495958] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[    2.496152] 3224..dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[    2.496695] 1357..dw_mci_set_ios:  no card. [mmc1]
[    2.514453] 1357..dw_mci_set_ios:  no card. [mmc1]
[    2.528598] mmc0: BKOPS_EN bit is not set
[    2.537317] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[    2.537331] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[    2.537486] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 26000000Hz, actual 25000000HZ div = 2)
[    2.537509] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[    2.537519] rk_sdmmc: ERROR dw_mci_setup_bus: div SHOULD NOT LARGER THAN ONE! [mmc0]
[    2.537529] rk_sdmmc: BOOT dw_mci_setup_bus: workaround div = 1, host->bus_hz = 50000000 [mmc0]
[    2.537575] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[    2.541353] rk_sdmmc: BOOT Bus speed=25000000Hz,Bus width=8bits.[mmc0]
[    2.541401] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[    2.541512] 3230..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[    2.541591] 1357..dw_mci_set_ios:  no card. [mmc2]
[    2.546808] mmc0: new high speed MMC card at address 0001
[    2.547071] mmcblk0: mmc0:0001 abcde 7.25 GiB
[    2.547370] mtd: partition size too small (0)
[    2.547385]      uboot: 0x000400000 -- 0x000800000 (4 MB)
[    2.547395]       misc: 0x000800000 -- 0x000c00000 (4 MB)
[    2.547404]   resource: 0x000c00000 -- 0x001c00000 (16 MB)
[    2.547413]     kernel: 0x001c00000 -- 0x002c00000 (16 MB)
[    2.547422]       boot: 0x002c00000 -- 0x004c00000 (32 MB)
[    2.547431]   recovery: 0x004c00000 -- 0x006c00000 (32 MB)
[    2.547440]     backup: 0x006c00000 -- 0x00a000000 (52 MB)
[    2.547448]      cache: 0x00a000000 -- 0x012000000 (128 MB)
[    2.547457]     kpanic: 0x012000000 -- 0x012400000 (4 MB)
[    2.547465]     system: 0x012400000 -- 0x042400000 (768 MB)
[    2.547474]   metadata: 0x042400000 -- 0x042800000 (4 MB)
[    2.547482]   userdata: 0x042800000 -- 0x082800000 (1024 MB)
[    2.547491] radical_update: 0x082800000 -- 0x086800000 (64 MB)
[    2.547500]       user: 0x086800000 -- 0x1d0400000 (5276 MB)
[    2.547528]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141357..dw_mci_set_ios:  no card. [mmc1]
[    2.553771] 1357..dw_mci_set_ios:  no card. [mmc2]
[    2.573453] 1357..dw_mci_set_ios:  no card. [mmc2]
[    2.573652] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[    2.573665] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[    2.573918] leds-gpio leds.31: pins are not configured from the driver
[    2.574133] hidraw: raw HID events driver (C) Jiri Kosina
[    2.575403] usbcore: registered new interface driver usbhid
[    2.575412] usbhid: USB HID core driver
[    2.575727] ashmem: initialized
[    2.575826] logger: created 256K log 'log_main'
[    2.575939] logger: created 256K log 'log_events'
[    2.576030] logger: created 256K log 'log_radio'
[    2.576123] logger: created 256K log 'log_system'
[    2.577117] input: rk29-keypad as /devices/ff100000.adc/key.34/input/input1
[    2.577696] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ftrace; cannot claim for 2-0010
[    2.577713] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[    2.577725] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[    2.577737] ES8323 2-0010: Error applying setting, reverse things back
[    2.578018] es8323 probe i2c recv ok
[    2.578227] i2c-core: driver [ES8323] using legacy suspend method
[    2.578238] i2c-core: driver [ES8323] using legacy resume method
[    2.578552] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered
[    2.578582] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[    2.578601] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral
[    2.578815] es8323_probe
[    2.578899] es8323_probe:register ISR (irq=194)
[    3.213400] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> NULL --> Left Line Mux
[    3.213415] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> NULL -> Left Line Mux
[    3.213425] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> NULL --> Left Line Mux
[    3.213434] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> NULL -> Left Line Mux
[    3.213444] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> NULL --> Left Line Mux
[    3.213452] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> NULL -> Left Line Mux
[    3.213462] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> NULL --> Right Line Mux
[    3.213470] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> NULL -> Right Line Mux
[    3.213479] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> NULL --> Right Line Mux
[    3.213486] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> NULL -> Right Line Mux
[    3.213495] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> NULL --> Right Line Mux
[    3.213503] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> NULL -> Right Line Mux
[    3.213513] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left PGA Mux
[    3.213520] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left PGA Mux
[    3.213529] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left PGA Mux
[    3.213537] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left PGA Mux
[    3.213546] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> LAMP --> Left PGA Mux
[    3.213553] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> LAMP -> Left PGA Mux
[    3.213562] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right PGA Mux
[    3.213570] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right PGA Mux
[    3.213579] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right PGA Mux
[    3.213586] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right PGA Mux
[    3.213595] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> RAMP --> Right PGA Mux
[    3.213603] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> RAMP -> Right PGA Mux
[    3.213613] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Differential Mux
[    3.213620] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Differential Mux
[    3.213629] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Differential Mux
[    3.213636] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Differential Mux
[    3.213645] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Differential Mux
[    3.213652] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Differential Mux
[    3.213661] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Differential Mux
[    3.213669] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Differential Mux
[    3.213689] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left Line Mux
[    3.213696] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left Line Mux
[    3.213705] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left Line Mux
[    3.213713] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left Line Mux
[    3.213722] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> LAMP --> Left Line Mux
[    3.213729] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> LAMP -> Left Line Mux
[    3.213738] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right Line Mux
[    3.213746] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right Line Mux
[    3.213754] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right Line Mux
[    3.213762] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right Line Mux
[    3.213771] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> RAMP --> Right Line Mux
[    3.213779] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> RAMP -> Right Line Mux
[    3.213911] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[    3.213923] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[    3.213933] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[    3.213943] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[    3.213962] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[    3.216840] Enter::rk29_es8323_init----135
[    3.220150] rockchip-es8323 rockchip-es8323.29:  ES8323 HiFi <-> rockchip-i2s.0 mapping ok
[    3.220663] u32 classifier
[    3.220670]     Actions configured
[    3.220681] Netfilter messages via NETLINK v0.30.
[    3.220733] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    3.221013] ctnetlink v0.93: registering with nfnetlink.
[    3.221072] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    3.221079] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    3.221297] xt_time: kernel timezone is -0000
[    3.221463] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.221577] arp_tables: (C) 2002 David S. Miller
[    3.221612] TCP: cubic registered
[    3.221618] Initializing XFRM netlink socket
[    3.221802] NET: Registered protocol family 10
[    3.222231] mip6: Mobile IPv6
[    3.222254] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.222355] sit: IPv6 over IPv4 tunneling driver
[    3.222648] NET: Registered protocol family 17
[    3.222669] NET: Registered protocol family 15
[    3.222713] Bridge firewalling registered
[    3.222723] Ebtables v2.0 registered
[    3.222901] Bluetooth: RFCOMM TTY layer initialized
[    3.222925] Bluetooth: RFCOMM socket layer initialized
[    3.222932] Bluetooth: RFCOMM ver 1.11
[    3.222940] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.222946] Bluetooth: BNEP filters: protocol multicast
[    3.222955] Bluetooth: BNEP socket layer initialized
[    3.222962] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.222972] Bluetooth: HIDP socket layer initialized
[    3.222995] l2tp_core: L2TP core driver, V2.0
[    3.223008] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    3.223016] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    3.223210] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    3.223219] wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[    3.223227] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    3.223235] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[    3.223243] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    3.223263] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[    3.223281] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[    3.223289] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    3.223314] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[    3.223354] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    3.223403] [BT_RFKILL]: Enter rfkill_rk_init
[    3.223512] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[    3.223527] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[    3.223540] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[    3.223553] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[    3.223565] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[    3.223612] [BT_RFKILL]: Request irq for bt wakeup host
[    3.223700] [BT_RFKILL]: ** disable irq
[    3.223772] [BT_RFKILL]: ap6335 device registered.
[    3.224424] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess.
[    3.224737] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[    3.224756] rk3288_init_suspend
[    3.224764] rk3288_suspend_init enter
[    3.224880] rk3288_suspend_init: pm_ctrbits =40017
[    3.224911] gpio_get_dts_info suspend:8
[    3.224918] gpio_get_dts_info resume:8
[    3.224923] rockchip,pmic-suspend_gpios:1007c30 1007c40 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[    3.224949] rockchip,pmic-resume_gpios:2007c32 2007c42 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[    3.225070] clks_gating_suspend_init:clkgt info ok
[    3.225157] Registering SWP/SWPB emulation handler
[    3.225455] ddrfreq: verion 1.2 20140526
[    3.225465] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
[    3.225473] ddrfreq: auto-freq=0
[    3.225478] ddrfreq: auto-freq-table[0] 240MHz
[    3.225484] ddrfreq: auto-freq-table[1] 324MHz
[    3.225489] ddrfreq: auto-freq-table[2] 456MHz
[    3.225495] ddrfreq: auto-freq-table[3] 528MHz
[    3.227098] act_ldo3: operation not allowed
[    3.227335] vga_edid_probe: turn on ldo3 done.
[    3.227356] act_ldo4: operation not allowed
[    3.227584] vga_edid_probe: turn on ldo done.
[    3.227613] act_ldo2: operation not allowed
[    3.227841] vga_edid_probe: turn on ldo2 done.
[    3.227860] act_ldo8: operation not allowed
[    3.228086] vga_edid_probe: turn on ldo done.
[    3.253173] vga-ddc: read and parse vga edid success.
[    3.253183] vga-ddc: max mode 1600x900@59[pixclock-97751 KHZ]
[    3.253197] vga-ddc: best mode 1600x900@60[pixclock-9 KHZ]
[    3.253203] vga_edid_probe: success. 8
[    3.253313] firefly_vga_get_enable 180, 0
[    3.253320] firefly_vga_get_status 186
[    3.253332] firefly_vga_set_enable 159 enable:1
[    3.253347] firefly_vga_enable 130 start
[    3.253353] firefly_switch_fb 55
[    3.253360]
[    3.253360] rk_fb_switch_screen lcdc_id 0 type 1 enable 1
[    3.253370] fb0 win id 1 state 1
[    3.253382] regulator-dummy: disabling
[    3.253448] rk3288-lcdc lcdc0: lcdc0: dclk:118800000>>fps:66
[    3.253470] fb1 win id 0 state 0
[    3.253475] fb2 win id 2 state 0
[    3.253480] fb3 win id 3 state 0
[    3.253485] fb4 win id 4 state 0
[    3.253491]
[    3.253491] rk_fb_switch_screen lcdc_id 0 type 1 enable 1 done
[    3.253491]
[    3.253514] VGA ENABLE
[    3.253628] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered
[    3.253651] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[    3.253665] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral
[    3.253741] pcd_pullup, is_on 0
[    3.253775] file system registered
[    3.254286] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    3.254295] android_usb gadget: Number of LUNs=2
[    3.254302]  lun0: LUN: removable file: (no medium)
[    3.254308]  lun1: LUN: removable file: (no medium)
[    3.254420] android_usb gadget: android_usb ready
[    3.254489] sensor_init: Probe name sensors
[    3.254504] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[    3.255026] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:03:19 UTC (1293883399)
[    3.260336] usbcore: registered new interface driver snd-usb-audio
[    3.260359] ALSA device list:
[    3.260365]   #0: RK_ES8323
[    3.261606] Freeing unused kernel memory: 2364K (c0a77000 - c0cc6000)
[    3.261959] rockchip-hdmi-spdif rockchip-hdmi-spdif.27:  rk-hdmi-spdif-hifi <-> rockchip-spdif mapping ok
[    3.266097] SELinux:  Permission attach_queue in class tun_socket not defined in policy.
[    3.266110] SELinux: the above unknown classes and permissions will be denied
[    3.560400] type=1403 audit(1293883399.800:2): policy loaded auid=4294967295 ses=4294967295
[    3.560492] SELinux: Loaded policy from /sepolicy
[    3.561915] type=1404 audit(1293883399.800:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[    3.616465] dwc_otg_hcd_enable, enable host controller
[    3.739469] Using Buffer DMA mode
[    3.739476] Periodic Transfer Interrupt Enhancement - disabled
[    3.739482] Multiprocessor Interrupt Enhancement - disabled
[    3.739488] OTG VER PARAM: 0, OTG VER FLAG: 0
[    3.739494] ^^^^^^^^^^^^^^^^^^Host Mode
[    3.783819] Init: Power Port (0)
[    3.869940] vga-ddc: read and parse vga edid success.
[    3.869953] vga-ddc: max mode 1600x900@59[pixclock-97751 KHZ]
[    3.869970] vga-ddc: best mode 1600x900@60[pixclock-9 KHZ]
[    3.869976] VGA Devie connected 8
[    3.869981] firefly_vga_set_mode 203
[    3.869987] firefly_vga_set_mode 219 1600 900 60 108000000
[    3.869993] firefly_vga_enable 130 start
[    3.869999] firefly_switch_fb 55
[    3.870005]
[    3.870005] rk_fb_switch_screen lcdc_id 0 type 1 enable 1
[    3.870016] fb0 win id 1 state 1
[    3.870102] rk3288-lcdc lcdc0: lcdc0: dclk:118800000>>fps:66
[    3.870125] fb1 win id 0 state 0
[    3.870130] fb2 win id 2 state 0
[    3.870135] fb3 win id 3 state 0
[    3.870140] fb4 win id 4 state 0
[    3.870145]
[    3.870145] rk_fb_switch_screen lcdc_id 0 type 1 enable 1 done
[    3.870145]
[    4.167535] Indeed it is in host mode hprt0 = 00021501
[    4.344651] usb 3-1: new high-speed USB device number 2 using usb20_host
[    4.344738] Indeed it is in host mode hprt0 = 00001101
[    4.431351] init: init.rk30board.bootmode.emmc.rc: 8: invalid command '/devices/ff0f0000.rksdmmc/mmc_host/mmc'
[    4.431369] init: init.rk30board.bootmode.emmc.rc: 9: invalid command '/devices/ff0c0000.rksdmmc/mmc_host/mmc'
[    4.431382] init: init.rk30board.bootmode.emmc.rc: 10: invalid command '/devices/ff580000.usb'
[    4.431392] init: init.rk30board.bootmode.emmc.rc: 11: invalid command '/devices/ff580000.usb'
[    4.431402] init: init.rk30board.bootmode.emmc.rc: 12: invalid command '/devices/ff500000.usb'
[    4.431412] init: init.rk30board.bootmode.emmc.rc: 13: invalid command '/devices/ff500000.usb'
[    4.431421] init: init.rk30board.bootmode.emmc.rc: 14: invalid command '/devices/ff540000.usb'
[    4.431431] init: init.rk30board.bootmode.emmc.rc: 15: invalid command '/devices/ff540000.usb'
[    4.431713] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[    4.482176] init: /dev/hw_random not found
[    4.482234] keychord: using input dev ff680000.pwm for fevent
[    4.482244] keychord: using input dev rk29-keypad for fevent
[    4.487216] fs_mgr: parse_link_device : path = NULL
[    4.487248] fs_mgr: parse_link_device : path = NULL
[    4.487266] fs_mgr: parse_link_device : path = NULL
[    4.487282] fs_mgr: parse_link_device : path = NULL
[    4.487298] fs_mgr: parse_link_device : path = NULL
[    4.487313] fs_mgr: parse_link_device : path = NULL
[    4.487329] fs_mgr: parse_link_device : path = NULL
[    4.487345] fs_mgr: parse_link_device : path = NULL
[    4.487399] fs_mgr: ---------------resize_fs blk_dev /dev/block/platform/ff0f0000.rksdmmc/by-name/system, type ext4fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[    4.488189] resize2fs: resize2fs 1.41.14 (22-Dec-2010)resize2fs: /sbin/resize2fs: Bad magic number in super-block while trying to open /dev/block/platform/ff0f0000.rksdmmc/by-name/systemresize2fs: Couldn't find valid filesystem superblock.resize2fs: resize2fs terminated by exit(1)
[    4.490130] EXT4-fs (mmcblk0p10): VFS: Can't find ext4 filesystem
[    4.490189] fs_mgr: Cannot mount filesystem on /dev/block/platform/ff0f0000.rksdmmc/by-name/system at /system
[    4.490215] init: fs_mgr_mount_all returned an error
[    4.490975] drmboot: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ' should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 '
[    4.494351] init: /dev/hw_random not found
[    4.496546] init: cannot find '/system/vendor/bin/pvrsrvctl', disabling 'pvrsrvctl'
[    4.496567] init: cannot find '/system/bin/servicemanager', disabling 'servicemanager'
[    4.496582] init: cannot find '/system/bin/vold', disabling 'vold'
[    4.496615] init: cannot find '/system/bin/displayd', disabling 'displayd'
[    4.496628] init: cannot find '/system/bin/netd', disabling 'netd'
[    4.496640] init: cannot find '/system/bin/debuggerd', disabling 'debuggerd'
[    4.496654] init: cannot find '/system/bin/rild', disabling 'ril-daemon'
[    4.496667] init: cannot find '/system/bin/rild3', disabling 'ril-daemon3'
[    4.496680] init: cannot find '/system/bin/surfaceflinger', disabling 'surfaceflinger'
[    4.496693] init: cannot find '/system/bin/app_process', disabling 'zygote'
[    4.496716] init: cannot find '/system/bin/drmserver', disabling 'drm'
[    4.496729] init: cannot find '/system/bin/mediaserver', disabling 'media'
[    4.496741] init: cannot find '/system/bin/installd', disabling 'installd'
[    4.496755] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[    4.496769] init: cannot find '/system/bin/keystore', disabling 'keystore'
[    4.496781] init: cannot find '/system/bin/drmservice', disabling 'drmservice'
[    4.496794] init: cannot find '/system/bin/bmd', disabling 'bmd'
[    4.496817] init: cannot find '/system/bin/bindvbplayservice', disabling 'dvbdataserv'
[    4.496834] init: cannot find '/system/bin/sdcard', disabling 'sdcard'
[    4.496861] init: cannot find '/system/bin/chrome.sh', disabling 'chrome'
[    4.496875] init: cannot find '/system/bin/akmd', disabling 'akmd'
[    4.496897] init: cannot find '/system/bin/bplus_helper', disabling 'bplus_helper'
[    4.497615] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
[    4.497627] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial'
[    4.497728] init: property 'ro.product.manufacturer' doesn't exist while expanding '${ro.product.manufacturer}'
[    4.497738] init: cannot expand '${ro.product.manufacturer}' while writing to '/sys/class/android_usb/android0/iManufacturer'
[    4.497750] init: property 'ro.product.model' doesn't exist while expanding '${ro.product.model}'
[    4.497759] init: cannot expand '${ro.product.model}' while writing to '/sys/class/android_usb/android0/iProduct'
[    4.497770] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead
[    4.497779] init: property 'ro.product.usbfactory' doesn't exist while expanding '$ro.product.usbfactory'
[    4.497789] init: cannot expand '$ro.product.usbfactory' while writing to '/sys/class/android_usb/android0/f_mass_storage/inquiry_string'
[    4.497834] binder: 126:126 transaction failed 29189, size 0-0
[    4.541677] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[    4.541689] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    4.541697] usb 3-1: Product: USB 2.0 Hub [MTT]
[    4.542064] hub 3-1:1.0: USB hub found
[    4.542123] hub 3-1:1.0: 4 ports detected
[    4.640009] init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}'
[    4.640024] init: powerctl: cannot expand '${sys.powerctl}'
[    4.640036] init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}'
[    4.640046] init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes'
[    4.640069] init: cannot find '/system/bin/sh', disabling 'console'
[    4.640146] android_usb: already disabled
[    4.641674] read descriptors
[    4.641687] read strings
[    4.641711] pcd_pullup, is_on 1
[    4.817063] usb 3-1.4: new low-speed USB device number 3 using usb20_host
[    4.922297] usb 3-1.4: New USB device found, idVendor=0d62, idProduct=a100
[    4.922307] usb 3-1.4: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[    4.922315] usb 3-1.4: Product: USB Optical Mouse
[    4.922322] usb 3-1.4: Manufacturer: Darfon
[    4.926720] input: Darfon USB Optical Mouse as /devices/ff540000.usb/usb3/3-1/3-1.4/3-1.4:1.0/input/input2
[    4.926931] hid-generic 0003:0D62:A100.0001: input,hidraw0: USB HID v1.10 Mouse [Darfon USB Optical Mouse] on usb-ff540000.usb-1.4/input0
[    5.481927] binder: 126:126 transaction failed 29189, size 0-0
[    5.486071] iep dpi mode inactivity
[    6.466018] binder: 126:126 transaction failed 29189, size 0-0
[    7.450111] binder: 126:126 transaction failed 29189, size 0-0
[    8.434197] binder: 126:126 transaction failed 29189, size 0-0
[    9.418288] binder: 126:126 transaction failed 29189, size 0-0
[   10.402380] binder: 126:126 transaction failed 29189, size 0-0
[   10.465175] es8323_mic_state_ctrl read:
[   10.465201] mic_state_switch 0
[   10.465209] hp_det = 0,insert hp
[   10.465216] hp mic use intern
[   11.386473] binder: 126:126 transaction failed 29189, size 0-0
[   12.370566] binder: 126:126 transaction failed 29189, size 0-0
[   13.354657] binder: 126:126 transaction failed 29189, size 0-0
[   14.338749] binder: 126:126 transaction failed 29189, size 0-0
[   15.322841] binder: 126:126 transaction failed 29189, size 0-0
[   16.306931] binder: 126:126 transaction failed 29189, size 0-0
[   17.291018] binder: 126:126 transaction failed 29189, size 0-0
[   17.412148] *****************vbus detect*******************
[   17.591385] Using Buffer DMA mode
[   17.591401] Periodic Transfer Interrupt Enhancement - disabled
[   17.591409] Multiprocessor Interrupt Enhancement - disabled
[   17.591417] OTG VER PARAM: 0, OTG VER FLAG: 0
[   17.591425] ^^^^^^^^^^^^^^^^^Device Mode
[   17.591467] *******************soft connect!!!*******************
[   17.705498] USB RESET
[   17.890504] android_work: sent uevent USB_STATE=CONNECTED
[   17.894407] USB RESET
[   18.136265] android_usb gadget: high-speed config #1: android
[   18.136342] android_work: sent uevent USB_STATE=CONFIGURED
[   18.275113] binder: 126:126 transaction failed 29189, size 0-0
[   19.259210] binder: 126:126 transaction failed 29189, size 0-0
[   20.243299] binder: 126:126 transaction failed 29189, size 0-0
[   21.227391] binder: 126:126 transaction failed 29189, size 0-0
[   22.211483] binder: 126:126 transaction failed 29189, size 0-0
[   23.195575] binder: 126:126 transaction failed 29189, size 0-0
[   24.179666] binder: 126:126 transaction failed 29189, size 0-0
[   25.163757] binder: 126:126 transaction failed 29189, size 0-0
[   26.147849] binder: 126:126 transaction failed 29189, size 0-0
[   27.131941] binder: 126:126 transaction failed 29189, size 0-0
[   28.116032] binder: 126:126 transaction failed 29189, size 0-0
[   29.100120] binder: 126:126 transaction failed 29189, size 0-0
固件是在同一个环境下编译的吗?
